LogoFronius Symo Advanced
  • en
    • Contact
    • Imprint
    • Terms and Conditions
    • Data Privacy Statement
    • Cookie Policy
    • Cookie Policy
    • 030-24032022
    • Safety rules
      • Explanation of safety notices
      • General
      • Environmental conditions
      • Qualified personnel
      • Noise emission values
      • EMC measures
      • Data protection
      • Copyright
    • General
      • Device concept
      • Proper use/intended purpose
    • Data communication and Fronius Solar Net
      • Fronius Solar Net and data interface
      • Data communication area
      • Description of the "Fronius Solar Net" LED
      • Example
      • Explanation of the multifunction current interface
    • Fronius Datamanager 2.0
      • Controls, connections and displays on the Fronius Datamanager 2.0
      • Fronius Datamanager during the night or when the available DC voltage is insufficient
      • Starting for the first time
      • Further information on Fronius Datamanager 2.0
    • Controls and indicators
      • Controls and displays
      • Display
    • Navigation at the menu level
      • Activating display backlighting
      • Automatic deactivation of display backlighting / changing to the "NOW" menu item
      • Opening the menu level
      • Values displayed under the NOW menu item
      • Values displayed under the LOG menu item
    • SETUP menu item
      • Initial setting
      • Software updates
      • Navigating the SETUP menu item
      • Setting menu entries, general
      • Application example: Setting the time
    • Menu items in the Set-up menu
      • Standby
      • DATCOM
      • USB
      • Relay (floating contact switch)
      • Energy Manager
        (under Relay menu item)
      • Time / Date
      • Display settings
      • ENERGY YIELD
      • Fan
    • The INFO menu item
      • Measured values
      • PSS status
      • Grid status
      • Device information
      • Version
    • Switching the key lock on and off
      • General
    • USB Stick as a Data Logger and for Updating Inverter Software
      • USB flash drive as a datalogger
      • Suitable USB flash drives
      • USB flash drive for updating the inverter software
      • Removing the USB flash drive
    • The Basic menu
      • Accessing the Basic menu
      • Menu items in the Basic menu
      • Settings if the "DC SPD" option is installed
    • Switching off current supply and restarting the inverter
      • Switch off power to the inverter
    • Status diagnostics and troubleshooting
      • Status code display
      • Total failure of the display
      • Class 1 status codes
      • Class 3 status codes
      • Status codes – Class 4
      • Status codes – Class 5
      • Class 6 status codes
      • Status codes – Class 7
      • Class 10 - 12 status codes
      • Customer service
      • Operation in dusty environments
    • Technical data
      • Fronius Symo Advanced 10.0-3-M
      • Fronius Symo Advanced 12.5-3-M
      • Fronius Symo Advanced 15.0-3-M
      • Fronius Symo Advanced 17.5-3-M
      • Fronius Symo Advanced 20.0-3-M
      • Explanation of footnotes
      • Integrated DC disconnector Fronius Symo Advanced 10.0-12.5
      • Integrated DC disconnector Fronius Symo Advanced 15.0 - 20.0
      • Applicable standards and guidelines
    • Warranty terms and conditions, and disposal
      • Fronius manufacturer's warranty
      • Disposal
    Setup menu
    Status diagnostics
    Technical data
    Safety rules
    DANGER!
    Indicates immediate danger.
    WARNING!
    CAUTION!
    NOTE!
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    General
    The device has been manufactured in line with the state of the art and according to recognized safety standards. If used incorrectly or misused, however, it can cause:
    • Injury or death to the operator or a third party
    • Damage to the device and other material assets belonging to the operating company.
    All personnel involved in commissioning, maintenance, and servicing of the device must:
    • Be suitably qualified
    • Have knowledge of and experience in dealing with electrical installations and
    • Have fully read and precisely followed these Operating Instructions
    The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, attention must also be paid to any generally applicable and local regulations regarding accident prevention and environmental protection.
    All safety and danger notices on the device:
    • Must be kept in a legible state
    • Must not be damaged
    • Must not be removed
    • Must not be covered, pasted or painted over
    The terminals can reach high temperatures.
    Only operate the device when all protection devices are fully functional. If the protection devices are not fully functional, there is a danger of:
    Any safety devices that are not fully functional must be repaired by an authorised specialist before the device is switched on.
    For the location of the safety and danger notices on the device, refer to the section headed "General remarks" in the Operating Instructions for the device.
    Any equipment malfunctions which might impair safety must be remedied before the device is turned on.
    Qualified personnel
    The servicing information contained in these operating instructions is intended only for the use of qualified service engineers. An electric shock can be fatal. Do not carry out any actions other than those described in the documentation. This also applies to qualified personnel.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Loose connections, scorched, damaged or inadequately dimensioned cables and leads must be immediately repaired by authorised personnel.
    Maintenance and repair work must only be carried out by an authorised specialist.
    It is impossible to guarantee that bought-in parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements. Use only original spare parts (also applies to standard parts).
    Components that are not in perfect condition must be changed immediately.
    The maximum sound power level of the inverter is specified in the Technical Data.
    The device is cooled as quietly as possible with the aid of an electronic temperature control system; this depends on the amount of converted power, the ambient temperature, the level of soiling of the device, etc.
    It is not possible to provide a workplace-related emission value for this device because the actual sound pressure level is heavily influenced by the installation situation, the power quality, the surrounding walls and the properties of the room in general.
    EMC measures
    In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g. when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers). If this is the case, then the operator is obliged to take appropriate action to rectify the situation.
    Data protection
    The user is responsible for the safekeeping of any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
    Copyright
    The text and illustrations are all technically correct at the time of printing. We reserve the right to make changes. The contents of the operating instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the instructions, we will be most grateful for your comments.
    General
    Device concept
    Device design:
    (1)
    Housing cover
    (2)
    Inverter
    (3)
    Wall bracket
    (4)
    Connection area incl. DC main switch
    (5)
    (6)
    Data communication cover
    The inverter transforms the direct current generated by the solar modules into alternating current. This alternating current is fed into the public grid synchronously with the grid voltage.
    The inverter has been developed exclusively for use in grid-connected photovoltaic systems; it is impossible to generate energy independently of the public grid.
    Thanks to its design and the way it works, the inverter is extremely safe both to install and to operate.
    The inverter automatically monitors the public grid. In the event of abnormal grid conditions, the inverter ceases operating immediately and stops feeding power into the grid (e.g. if the grid is switched off, if there is an interruption, etc.).
    The grid is monitored by monitoring the voltage, frequency and islanding conditions.
    The inverter operates fully automatically. As soon after sunrise as there is sufficient energy available from the solar modules, the inverter starts monitoring the grid. When insolation has reached a sufficient level, the inverter starts feeding energy into the grid.
    The inverter operates in such a way that the maximum possible amount of power is obtained from the solar modules.
    As soon as the power available has fallen below the level at which energy can be fed into the grid, the inverter disconnects the power electronics completely from the grid and stops running. It retains all its settings and stored data.
    If the inverter becomes too hot, it automatically reduces the current output power in order to protect itself.
    Reasons for the inverter becoming too hot include the ambient temperature being too high or inadequate heat dissipation (e.g. if it is installed in a switch cabinet without suitable heat dissipation).
    Device concept
    Device design:
    (1)
    Housing cover
    (2)
    Inverter
    (3)
    Wall bracket
    (4)
    (5)
    (6)
    The inverter is intended exclusively to convert direct current from solar modules into alternating current and to feed this into the public grid.
    Utilisation not in accordance with the intended purpose comprises:
    • Any use above and beyond this purpose
    • Making any modifications to the inverter that have not been expressly approved by Fronius
    • the installation of components that are not distributed or expressly approved by Fronius.
    Fronius shall not be liable for any damage resulting from such action.
    No warranty claims will be entertained.
    Proper use also includes:
    • Carefully reading and obeying all the instructions and all the safety and danger notices in the Operating Instructions and Installation Instructions
    • Performing all stipulated maintenance work
    • Installation as specified in the Installation Instructions
    When designing the photovoltaic system, ensure that all components are operated within their permitted operating ranges at all times.
    Observe all the measures recommended by the solar module manufacturer to ensure that the solar module retains its properties in the long term.
    Obey the regulations of the power supply company regarding connection methods and energy fed into the grid.
    There are warning notices and safety symbols on and in the inverter. These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and damage.
    Safety symbols:
    Danger of serious injury and damage due to incorrect operation
    • All the Operating Instructions for the system components of the photovoltaic system, especially the safety rules
    Dangerous electrical voltage
    Wait for the capacitors to discharge.
    To comply with European Directive 2012/19/EU on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must be returned to your distributor or disposed of at an approved collection and recycling facility in your area. Ignoring this European Directive may have potentially adverse effects on the environment and your health!
    Text of the warning notices:
    WARNING!
    An electric shock can be fatal. Before opening the device, it must be disconnected at the input and output. Wait for the capacitors to discharge (5 minutes).
    Symbols on the rating plate:
    CE mark – confirms compliance with applicable EU directives and regulations.
    UKCA mark – confirms compliance with applicable UK directives and regulations.
    WEEE mark – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law.
    RCM mark – tested in accordance with the requirements of Australia and New Zealand.
    ICASA mark – tested in accordance with the requirements of the Independent Communications Authority of South Africa.
    CMIM mark – tested in accordance with IMANOR requirements for import regulations and compliance with Moroccan standards.
    Fronius Solar Net was developed to make system add-ons flexible to use in a variety of different applications. Fronius Solar Net is a data network that enables multiple inverters to be linked up using system add-ons.
    It is a bus system that uses a ring topology. One suitable cable is sufficient for communication between one or several inverters that are connected on the Fronius Solar Net using a system add-on.
    Similarly, every inverter on the Fronius Solar Net must be assigned a unique number.
    Refer to the section entitled "The SETUP menu item" for instructions on how to assign a unique number.
    Fronius Solar Net automatically recognises a wide variety of system add-ons.
    In order to distinguish between several identical system add-ons, each one must be assigned a unique number.
    More detailed information on the individual system add-ons can be found in the relevant operating instructions or on the internet at http://www.fronius.com
    More detailed information on cabling Fronius DATCOM components can be found at:
    → http://www.fronius.com/QR-link/4204101938
    Depending on the model, the inverter may be equipped with the Fronius Datamanager plug-in card (8).
    Item
    Description
    (1)
    Switchable multifunction current interface.
    For more details, refer to the section below entitled "Explanation of the multifunction current interface"
    Use the 2-pin mating connector supplied with the inverter to connect to the multifunction current interface.
    (2)
    (3)
    IN Fronius Solar Net connection / interface protocol IN
    OUT Fronius Solar Net connection / interface protocol
    "Fronius Solar Net" / interface protocol input and output for connecting to other DATCOM components (e.g. inverter, Fronius sensor box, etc.)
    If several DATCOM components are linked together, a terminating plug must be connected to every free IN or OUT connection on a DATCOM component.
    For inverters with a Fronius Datamanager plug-in card, two terminating plugs are supplied with the inverter.
    (4)
    The "Fronius Solar Net" LED
    indicates whether the Fronius Solar Net power supply is available
    (5)
    The "Data transfer" LED
    flashes while the USB flash drive is being accessed. The USB flash drive must not be removed while recording is in progress.
    (6)
    USB A socket
    for connecting a USB flash drive with maximum dimensions of
    65 x 30 mm (2.6 x 2.1 in.)
    The USB flash drive can function as a datalogger for any inverter that it is connected to. The USB flash drive is not included in the scope of supply of the inverter.
    (7)
    Floating switch contact (relay) with mating connector
    Max. 250 V AC / 4 A AC
    Max. 30 V DC / 1 A DC
    Max. 1.5 mm² (AWG 16) cable cross-section
    Pin 1 = NO contact (normally open)
    Pin 2 = C (common)
    Pin 3 = NC contact (normally closed)
    For a more detailed explanation, please see the "Menu items in the Setup menu / Relay" section.
    Use the mating connector supplied with the inverter to connect to the floating switch contact.
    (8)
    Fronius Datamanager with WLAN antenna
    or
    cover for option card compartment
    (9)
    Cover for option card compartment
    The "Fronius Solar Net" LED is on:
    the power supply for data communication within the Fronius Solar Net / interface protocol is OK
    The "Fronius Solar Net" LED flashes briefly every 5 seconds:
    data communication error in the Fronius Solar Net
    • Overcurrent (current flow > 3 A, e.g. resulting from a short circuit in the Fronius Solar Net ring)
    • Undervoltage (not a short circuit, voltage in Fronius Solar Net < 6.5 V, e.g. if there are too many DATCOM components on the Fronius Solar Net and not enough electrical power is available)
      In this case, power for the Fronius DATCOM components must be supplied by connecting an additional power supply (43,0001,1194) to one of the Fronius DATCOM components.
      To detect the presence of an undervoltage, check some of the other Fronius DATCOM components for faults as required.
    After cutting out because of overcurrent or undervoltage, the inverter attempts to restore the power supply in the Fronius Solar Net every 5 seconds while the fault is still present.
    Once the fault is rectified, power to the Fronius Solar Net will be restored within 5 seconds.
    Example
    Recording and archiving data from the inverter and sensor using a Fronius Datamanager and a Fronius Sensor Box:
    Data network with 3 inverters and a Fronius Sensor Box:
    - Inverter 1 with Fronius Datamanager
    - Inverters 2 and 3 without Fronius Datamanager!
    = Terminating plug
    The external communication (Fronius Solar Net) takes place on the inverter via the data communication area. The data communication area contains two RS 422 interfaces as inputs and outputs. RJ45 plug connectors are used to make the connection.
    IMPORTANT! Since the Fronius Datamanager functions as a datalogger, the Fronius Solar Net ring must not include any other datalogger.
    There must only be one Fronius Datamanager in each Fronius Solar Net ring.
    Any other Fronius Datamanagers must be removed and the unoccupied option card slot sealed off by replacing the cover (item number 42,0405,2094); alternatively, use an inverter without Fronius Datamanager (light version).
    Various wiring variants can be connected to the multifunction current interface. However, these cannot be operated simultaneously. For example, if an S0 meter is connected to the multifunction current interface, it is not possible to connect a signal contact for the surge protection device (or vice versa).
    Pin 1 = measurement input: max. 20 mA, 100 Ohm measurement resistor (load impedance)
    Pin 2 = max. short circuit current 15 mA, max. open circuit voltage 16 V DC or GND
    Wiring diagram variant 1: Signal contact for surge protection device
    Depending on the setting in the Basic menu (Signal Input submenu), the DC SPD option (surge protection device) either outputs a warning or an error on the display. Further information on the DC SPD option can be found in the Installation Instructions.
    Wiring diagram variant 2: S0 meter
    A meter for recording the self-consumption of each S0 can be connected directly to the inverter. This S0 meter can be positioned directly at the feed-in point or in the consumption branch. As one of the settings on the Fronius Datamanager website, a dynamic power reduction can be set under the "DNO Editor" menu item (see Fronius Datamanager 2.0 Operating Instructions on our website www.fronius.com)
    IMPORTANT! In order to connect an S0 meter to the inverter, it may be necessary to update the inverter firmware.
    Requirements for the S0 meter:
    • Must comply with the IEC62053-31 Class B standard
    • Max. voltage 15 V DC
    • Max. current when ON 15 mA
    • Min. current when ON 2 mA
    • Max. current when OFF 0.15 mA
    Recommended max. pulse rate of the S0 meter:
    PV output kWp [kW]
    Max. pulse rate per kWp
    30
    1000
    20
    2000
    10
    5000
    ≤ 5.5
    10,000
    No.
    Function
    (1)
    IP switch
    For switching the IP address:
    Switch position A
    Default IP address with opening of the WLAN access point
    Fronius Datamanager 2.0 uses the set IP address 169.254.0.180 to establish a direct connection to a PC via LAN.
    Setting the IP switch to position A also opens an access point to enable a direct WLAN connection to the Fronius Datamanager 2.0.
    Access data for this access point:
    Network name: FRONIUS_240.XXXXXX
    Code: 12345678
    Access to the Fronius Datamanager 2.0 is possible:
    • Using the DNS name "http://datamanager"
    • Using the IP address 169.254.0.180 for the LAN interface
    • Using the IP address 192.168.250.181 for the WLAN access point
    Switch position B
    Assigned IP address
    The Fronius Datamanager 2.0 uses an assigned IP address (factory setting dynamic (DHCP))
    The IP address can be set on the Fronius Datamanager 2.0 website.
    (2)
    WLAN LED
    • Flashing green: Fronius Datamanager 2.0 is in Service mode
      (IP switch on the Fronius Datamanager 2.0 plug-in card is in position A or Service mode has been activated via the inverter display, the WLAN access point is open)
    • Lights up green: WLAN connection established
    • Flashing green/red (alternately): WLAN access point has timed out following activation (1 hour)
    • Lights up red: no WLAN connection
    • Flashing red: faulty WLAN connection
    • Does not light up: Fronius Datamanager 2.0 is in Slave mode
    (3)
    Solar.web connection LED
    • Lights up green: Fronius Solar.web connection established
    • Lights up red: Fronius Solar.web connection is required but has not been established
    • Does not light up: no connection to Fronius Solar.web is required
    (4)
    Supply LED
    • Lights up green: Fronius Solar Net is providing an adequate power supply; Fronius Datamanager 2.0 is ready for use.
    • Does not light up: insufficient or no power supply from Fronius Solar Net - an external power supply is required
      or
      the Fronius Datamanager 2.0 is in Slave mode
    • Flashing red: update in progress
      IMPORTANT! Never interrupt the power supply while an update is in progress.
    • Lights up red: update failed
    (5)
    Connection LED
    • Lights up green: connection established within Fronius Solar Net
    • Lights up red: connection within Fronius Solar Net interrupted
    (6)
    LAN connection
    Ethernet interface, colour-coded blue, for connecting the Ethernet cable
    (7)
    I/Os
    Digital inputs and outputs
    Modbus RTU 2-wire (RS485):
    D-
    Modbus data -
    D+
    Modbus data +
    Int./ext. power supply
    GND
    Uint / Uext
    Internal voltage output 12.8 V
    or
    input for an external supply voltage
    >12.8 - 24 V DC (+ 20%)
    Digital inputs: 0 - 3, 4 - 9
    Voltage level: low = min. 0V - max. 1.8V; high = min. 3V - max. 24V DC (+ 20%)
    Input currents: dependent on input voltage; input resistance = 46 kOhm
    Digital outputs: 0 - 3
    Switching capacity when power is supplied by the Fronius Datamanager 2.0 plug-in card: 3.2 W in total for all 4 digital outputs
    Switching capacity when power is supplied by an external power supply delivering min. 12.8 - max. 24 V DC (+ 20%), connected to Uint / Uext and GND: 1 A, 12.8 - 24 V DC (depending on external power supply) for each digital output
    The connection to the I/Os is established via the mating connector supplied.
    (8)
    Antenna socket
    This is where the WLAN antenna is connected
    (9)
    Modbus termination switch (for Modbus RTU)
    Internal bus terminator with 120 ohm resistor (yes/no)
    Switch in "on" position: 120 ohm terminating resistor active
    Switch in "off" position: no terminating resistor active
    IMPORTANT! On an RS485 bus, the terminating resistor on the first and last device must be active.
    (10)
    Fronius Solar Net Master / Slave switch
    To switch from master to slave mode within a Fronius Solar Net ring
    IMPORTANT! In slave mode, all the LEDs on the Fronius Datamanager 2.0 plug-in card are off.
    No.
    Function
    (1)
    IP switch
    Switch position A
    Code: 12345678
    Switch position B
    Assigned IP address
    (2)
    WLAN LED
    (3)
    (4)
    Supply LED
      or
    (5)
    Connection LED
    (6)
    LAN connection
    (7)
    I/Os
    D-
    Modbus data -
    D+
    Modbus data +
    GND
    Uint / Uext
    or
    (8)
    Antenna socket
    (9)
    (10)
    The Night Mode parameter under "Display Settings" in the Setup menu is preset to OFF in the factory.
    For this reason the Fronius Datamanager cannot be accessed during the night or when the available DC voltage is insufficient.
    To nevertheless activate the Fronius Datamanager, switch the inverter off and on again at the mains and press any function button on the inverter display within 90 seconds.
    See also the chapters on "Menu items in the Setup menu", "Display settings" (Night Mode).
    Setting up the Fronius Datamanager 2.0 for the first time is made considerably easier with the Fronius Solar.web app. The Fronius Solar.web app is available in the respective app stores.
    When starting Fronius Datamanager 2.0 for the first time,
    • the Fronius Datamanager 2.0 plug-in card must be installed in the inverter,
      or
    • there must be a Fronius Datamanager Box 2.0 in the Fronius Solar Net ring.
    IMPORTANT! In order to establish a connection to Fronius Datamanager 2.0, "Obtain IP address automatically (DCHP)" must be activated on the end device in question (e.g. laptop, tablet, etc.).
    NOTE!
    If the photovoltaic system has only one inverter, steps 1 and 2 below can be skipped.
    In this case, starting for the first time will commence with step 3.
    1Connect inverter with Fronius Datamanager 2.0 or Fronius Datamanager Box 2.0 to the Fronius Solar Net
    2When networking several inverters in Fronius SolarNet:Set the Fronius Solar Net master / slave switch on the Fronius Datamanager 2.0 plug-in card correctly
    • One inverter with Fronius Datamanager 2.0 = master
    • All other inverters with Fronius Datamanager 2.0 = slave (the LEDs on the Fronius Datamanager 2.0 plug-in cards are not illuminated)
    3Switch the device to Service mode
    • Activate the WiFi Access Point via the Setup menu on the inverter
    The inverter establishes the WLAN access point. The WLAN access point remains open for 1 hour. The IP switch on the Fronius Datamanager 2.0 can remain in switch position A due to the activation of the WiFi Access Point.
    Installation using the Solar.web app
    Installation using a web browser
    4Download the Fronius Solar.web LIVE or Solar Web Pro app
    5Run the Fronius Solar.web app
    4Connect the end device to the WLAN access pointSSID = FRONIUS_240.xxxxx (5-8 digits)
    • Search for a network with the name "FRONIUS_240.xxxxx"
    • Establish a connection to this network
    • Enter the password 12345678
    (Alternatively, connect the end device and inverter using an Ethernet cable.)
    5Enter the following in the browser:
    http://datamanager
    or
    192.168.250.181 (IP address for WLAN connection)
    or
    169.254.0.180 (IP address for LAN connection)
    The Setup wizard start page is displayed.
    The technician wizard is intended for the installer and contains standard-specific settings. Running the technician wizard is optional.
    If the technician wizard is run, it is vital to note the service password that is issued. This service password is necessary for setting the "DNO Editor" menu item.
    If the technician wizard is not run, no specifications regarding power reduction are set.
    Running the Fronius Solar.web wizards is mandatory.
    6Run the Fronius Solar.web wizards and follow the instructions
    The Fronius Solar.web homepage is displayed,
    or
    the Fronius Datamanager 2.0 web page is displayed.
    7Where necessary, run the technician wizard and follow the instructions
    Further information on the Fronius Datamanager 2.0 and other start-up options can be found at:
    → http://www.fronius.com/QR-link/4204260191DE
    Item
    Description
    (1)
    Display
    For displaying values, settings and menus
    Monitoring and status LEDs
    (2)
    Initialisation LED (red) lights up
    • During the initialisation phase when starting up the inverter
    • If, when starting up the inverter in the initialisation phase, there is a continuous hardware fault
    (3)
    Status LED (orange) lights up
    • If, after the initialisation phase, the inverter is in its automatic startup or self-test phase (as soon as the solar modules are delivering sufficient power after sunrise)
    • If status codes (STATE Codes) are shown on the inverter display
    • If the inverter has been switched to Standby mode in the Setup menu (= feeding energy into the grid switched off manually)
    • If the inverter software is being updated
    (4)
    Operating status LED (green) lights up
    • If the PV system is working correctly after the inverter's automatic startup phase
    • all the time while energy is being fed into the grid
    Function keys - allocated different functions depending on the selection:
    (5)
    "Left/up" key
    For navigating to the left and up
    (6)
    "Down/right" key
    For navigating down and to the right
    (7)
    "Menu/Esc" key
    For switching to the menu level
    For quitting the Setup menu
    (8)
    "Enter" key
    For confirming a selection
    The keys operate capacitively. Exposure to water may impair their function. If necessary, wipe the keys dry with a cloth to ensure optimum functionality.
    Item
    Description
    (1)
    Display
    (2)
    (3)
    (4)
    (5)
    "Left/up" key
    (6)
    "Down/right" key
    (7)
    "Menu/Esc" key
    (8)
    "Enter" key
    Display
    Power for the display comes from the mains voltage. Depending on the setting selected in the Setup menu, the display can be kept on all day.
    IMPORTANT! The display on the inverter is not a calibrated measuring device.
    A slight inaccuracy in comparison with the energy meter used by the energy company is intrinsic to the system. A calibrated meter will be needed to calculate the bills for the power supply company.
    Display areas in Display mode
    Display areas in Setup mode
    Scroll bar
    The Energy Manager symbol
    is displayed when the Energy Manager function is activated
    Inv. no. = Inverter DATCOM number,
    Save symbol - appears briefly while set values are being saved,
    USB connection - appears if a USB stick has been connected
    1Press any key
    The display backlighting is activated.
    There is an option under "Display Settings - Backlighting" in the SETUP menu to set the display backlighting so that it is on all the time or off all the time.
    1Press any key
    If two minutes pass without any button being pressed, the display backlighting switches off automatically and the inverter goes to the "NOW" menu item (assuming the display backlighting is set to AUTO).
    The automatic selection of the "NOW" menu item can happen from any position on the menu level, unless the inverter was manually switched into the "Standby" operating mode.
    After automatically selecting the "NOW" menu item, the current power of feeding in is displayed.
    1Press "ESC"
    The display switches to the menu level.
    2Using the "Left" or "Right" keys   select the desired menu item
    3Press the "Enter" key   to select the desired menu item
    The menu items
    • NOW
      Displays real-time values
    • LOG
      Data recorded today, during the current calendar year and since the inverter was started for the first time
    • GRAPH
      Day characteristic displays a plot showing the output power during the day. The time axis is scaled automatically. Press the "Back" key to close the display
    • SETUP
      Setup menu
    • INFO
      Information about the device and the software
    Output power (W) - depending on the device type (MultiString), when the Enter key is pressed,    the individual output powers for MPP Tracker 1 and MPP Tracker 2 (MPPT1 / MPPT2) are displayed
    AC reactive power (VAr)
    Grid voltage (V)
    Output current (A)
    Grid frequency (Hz)
    Solar voltage (V) - U PV1 from MPP Tracker 1 and U PV2 from MPP Tracker 2 (MPPT1 / MPPT2), if MPP Tracker 2 is activated (see "The Basic menu" - "Menu items in the Basic menu")
    Solar power (A) - I PV1 from MPP Tracker 1 and I PV2 from MPP Tracker 2 (MPPT1 / MPPT2), if MPP Tracker 2 is activated (see "The Basic menu" - "Menu items in the Basic menu")
    Fronius Eco: The total current from both measuring channels is displayed. Both channels are shown separately in SolarWeb.
    Time date - Time and date on the inverter or in the Fronius Solar Net ring
    Energy fed in (kWh / MWh)
    Energy fed into the grid during the period in question.
    When the Enter key is pressed,   the individual output powers for MPP Tracker 1 and MPP Tracker 2 (MPPT1 / MPPT2) are displayed, if MPP Tracker 2 is activated (see "The Basic menu" - "Menu items in the Basic menu")
    There may be discrepancies compared with values displayed on other measuring instruments because of differences in measuring methods. As far as the billing of the energy fed in is concerned, the only binding display values are those produced by the calibrated measuring instrument provided by the utility company.
    Max. output power (W)
    Largest amount of energy fed into the grid during the period in question.
    Yield
    Amount of money earned during the period in question
    Like the "Energy fed in" figure, the yield figure may also exhibit discrepancies compared with other measured values.
    The subitem "Energy yield" in the "Menu items in the Set-up menu" section explains how to select a currency and charge rate.
    The factory setting depends on the respective country setup.
    CO2 savings
    CO2 emissions saved during the period in question
    The subitem "CO2 factor" in the "Menu items in the Set-up menu" section explains how to set the CO2 factor.
    Maximum grid voltage (V) [phase indicator - neutral or phase - phase]
    Highest grid voltage measured during the period in question
    When the Enter key is pressed,   the individual grid voltages are listed
    Maximum solar voltage (V)
    Highest solar module voltage measured during the period in question
    When the Enter key is pressed,    the voltage values for MPP Tracker 1 and MPP Tracker 2 (MPPT1 / MPPT2) are displayed, if MPP Tracker 2 is activated (see "The Basic menu" - "Menu items in the Basic menu")
    Operating hours
    Length of time the inverter has been working (HH:MM).
    IMPORTANT! In order for the day and year values to be displayed correctly, the time must be set accurately.
    SETUP menu item
    Initial setting
    The inverter is pre-configured after commissioning has been completely carried out (e.g. using the Installation Wizard) according to the country setup.
    The SETUP menu item allows the initial settings of the inverter to be changed easily to bring it in line, as closely as possible, with the preferences and requirements of the user.
    Initial setting
    Software updates
    IMPORTANT! As a result of software updates, you may find that your device has certain functions that are not described in these Operating Instructions, or vice versa. Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    Entering the SETUP menu item
    1At the menu level, use the "Left" or "Right" keys    to select the "SETUP" menu item
    2Press the "Enter" key
    The first entry under the SETUP menu item is displayed:
    "Standby"
    Scrolling between the entries
    3Use the "Up" and "Down" keys    to scroll between the available entries
    Exiting an entry
    4To exit a menu entry, press the "Back" key
    The menu level appears
    If no key is pressed for 2 minutes:
    • The inverter switches from wherever it is on the menu level back to the "NOW" display mode (exception: "Standby" Setup menu item).
    • The display backlighting goes out unless it has been set to ON in Display Setting - Backlighting (see Display Setting - Backlighting).
    • The power currently being fed in is displayed or the currently active state code is displayed.
    1Open the desired menu
    2Use the 'Up' or 'Down' keys to select the desired menu item
    3Press "Enter"
    The available settings are displayed:
    The first digit of a value to be set flashes:
    4Use the 'Up' or 'Down' buttons to select the desired setting
    5Press the 'Enter' key to save and apply the setting.
    To discard the setting, press the 'Esc' key.
    4Use the 'Up' or 'Down' keys to select a value for the first digit
    5Press "Enter"
    The second digit of the value flashes.
    6Repeat steps 4 and 5 until ...
    the whole value to be set flashes.
    7Press "Enter"
    8Repeat steps 4 - 6 as required for units or other values that are to be set until the appropriate unit or the value flashes.
    9Press the 'Enter' key to save and apply the changes.
    To discard the changes, press the 'Esc' key.
    The currently selected menu item is displayed.
    1Select "Clock" from the Setup menu    .
    An overview of the values that can be changed is displayed.
    3Use the "Up" and "Down" keys    Select "Set time"
    4Press the "Enter"    key
    The current time appears. (HH:MM:SS, 24-hour clock), the "tens" digit for the hour will flash.
    5Use the "Up" and "Down" keys    to select a value for the first digit of the code
    6Press the "Enter"    key
    The "units" digit for the hour will flash.
    7Repeat steps 5 and 6 to set the "units" digit for the hour, for the minutes and for the seconds until...
    the set time starts flashing.
    8Press the "Enter"    key
    The time is applied and the overview of values that can be changed is displayed.
    4Press the "Esc"    key
    The "Clock" item on the Setup menu appears.
    Standby
    Manual activation / deactivation of Standby mode
    • No energy is fed into the grid.
    • The Startup LED will show steady orange.
    • In the display, STANDBY / ENTER are alternately displayed
    • In Standby mode, no other menu item at menu level can be accessed or adjusted.
    • The automatic switchover into the "NOW" display mode after 2 minutes of keyboard inactivity does not occur.
    • Standby mode can only be terminated manually by pressing the "Enter" key.
    • Pressing "Enter" at any time will cause energy to resume feeding into the grid, as long as there is no error (state code)
    Switching off Standby mode (manually switching off feeding energy into the grid):
    1Select the "Standby" item
    2Press "Enter" function    key
    "STANDBY" and "ENTER" appear alternately on the display.
    Standby mode is now active.
    The Startup LED shows steady orange.
    Resuming feeding energy into the grid:
    In standby mode, the display alternates between 'STANDBY' and 'ENTER'.
    1Press the "Enter" function key to resume feeding energy into the    grid
    The "Standby" menu item is displayed.
    At the same time, the inverter enters the startup phase.
    The operating state LED shows steady green when feeding energy into the grid has been resumed.
    Standby
    DATCOM
    Checking data communications, entering the inverter number, protocol settings
    Setting range
    Status / inverter number / protocol type
    Status
    Indicates data communication is taking place via Fronius Solar Net or that a data communications error has occurred
    Inverter number
    Sets the number (= address) of the inverter in a system with several inverters
    Setting range
    00 - 99 (00 = inverter address 100)
    Factory setting
    01
    IMPORTANT! If a number of inverters are linked together in a data communications system, assign a unique address to each one.
    Protocol type
    Specifies the communications protocol to be used to transfer the data:
    Setting range
    Solar Net / Interface *
    Factory setting
    Fronius Solar Net
    * The protocol type "Interface" only functions when there is no Datamanager card in the inverter. All Fronius Datamanager cards should be removed from the inverter.
    USB
    Running firmware updates or saving detailed information from the inverter to the USB flash drive
    Setting range
    Safely remove hardware / Software update / Logging interval
    To remove a USB flash drive from the USB A socket on the plug-in data communications card without losing any data.
    The USB flash drive can be removed:
    • If the OK message appears
    • when the "Data transfer" LED stops flashing or comes on steady
    Software update
    To update the inverter firmware using a USB flash drive.
    Procedure:
    1Download the relevant firmware update file "froxxxxx.upd"
    (e.g. from http://www.fronius.com; xxxxx stands for the version number)
    NOTE!
    To successfully update the inverter software, the USB flash drive provided for the purpose must not have a hidden partition or any encryption (see chapter "Suitable USB flash drives").
    2Save the firmware update file to the highest data level of the USB flash drive
    3Open the lid of the data communication area on the inverter
    4Plug the USB flash drive containing the firmware update file into the USB socket in the inverter's data communication area
    5Select "USB" from the Setup menu, followed by "Software update"
    7Wait until the version currently installed on the inverter and the new firmware version are displayed for comparison:
    • First Page: Recerbo software (LCD), key controller software (KEY), country setup version (Set)
    • Second Page: Power stage set software (PS1/PS2)
    8Press the "Enter" function button after each page
    The inverter starts copying the data.
    "BOOT" and the progress of storing the individual tests expressed in % are displayed until all the data for all the electronic modules has been copied.
    Once copying is complete, the inverter updates the electronic modules as required in sequence.
    "BOOT", the affected modules and the update progress in % are displayed.
    The final step is for the inverter to update the display.
    The display remains dark for approx. 1 minute while the monitoring and status LEDs flash.
    Once the firmware update is complete, the inverter enters its start-up phase before going on to start feeding energy into the grid. Unplug the USB flash drive using the "Safely remove hardware" function.
    When the inverter firmware is updated, any custom settings that were configured in the Setup menu are retained.
    Logging interval
    Activate / deactivate the USB logging function and specify a logging interval
    Unit
    Minutes
    Setting range
    30 min. / 20 min./ 15 min./ 10 min./ 5 min./ No log
    Factory setting
    30 min.
    30 min.
    The logging interval is 30 minutes; every 30 minutes new logging data will be saved to the USB flash drive.
    20 min.
    15 min.
    10 min.
    5 min.
    The logging interval is 5 minutes; every 5 minutes new logging data will be saved to the USB flash drive.
    No log
    No data is saved
    IMPORTANT! In order for the USB logging function to work correctly the time must be set correctly. Setting the time is discussed in the section "Menu items in the Setup menu" - "Clock".
    Status codes (state codes), the status of the inverter (e.g. feeding energy into the grid) or Energy Manager functions can be displayed using the floating switch contact (relay).
    Setting range
    Relay mode / Relay test / Switch-on point* / Switch-off point*
    * these are only shown if the "E-Manager" function has been activated under "Relay mode".
    Relay mode
    The following functions can be shown using relay mode:
    • Alarm function (Permanent / ALL / GAF)
    • Active output (ON / OFF)
    • Energy Manager (E-Manager)
    Setting range
    ALL / Permanent / GAF / OFF / ON / E-Manager
    Factory setting
    ALL
    Alarm function:
    ALL / Permanent:
    Switching the floating switch contact for permanent and temporary service codes (e.g. brief interruption to energy being fed into the grid, a service code occurs a certain number of times a day - can be adjusted in the "BASIC" menu)
    GAF
    As soon as GAF mode is selected, the relay is switched on. The relay opens as soon as the power stage set registers an error and goes from normally feeding energy into the grid to being in an error state. This means that the relay can be used for fail-safe functions.
    Application example
    It may be necessary to perform phase compensation when using a single-phase inverter at a multiphase site. If an error occurs on one or several inverters and the connection to the grid is broken, the other inverters must also be disconnected to maintain the phase balance. The "GAF" relay function can be used in conjunction with the Datamanager or an external protection device to recognise or signal that an inverter is not feeding in or is disconnected from the grid and to then disconnect the remaining inverters from the grid using a telecontrol command.
    Active output:
    ON:
    The floating NO contact is on all the time the inverter is in operation (as long as the display is not dark or is displaying something).
    OFF:
    The floating NO contact is off.
    Energy Manager:
    E-Manager:
    Further details on the "Energy Manager" function may be found in the "Energy Manager" section.
    Relay test
    Function test to determine whether the floating switch contact switches
    Switch-on point (only if "Energy Manager" function is activated)
    for setting the effective power limit beyond which the floating switch contact is switched on
    Factory setting
    1000 W
    Setting range
    Set switch-off point up to the maximum nominal output of the inverter (W or kW)
    Switch-off point (only if "Energy Manager" function is activated)
    for setting the effective power limit beyond which the floating switch contact is switched off
    Factory setting
    500
    Setting range
    0 to the set switch-on point of the inverter (W or kW)
    Energy Manager
    The "Energy Manager" (E-Manager) function can be used to activate the floating switch contact in such a way that it functions as an actuator.
    Thus, a consumer that is connected to the floating switch contact can be controlled by specifying a switch-on or switch-off point that depends on the feed-in power (effective power).
    The floating switch contact is automatically switched off:
    • If the inverter is not feeding any power into the grid
    • If the inverter is manually switched to Standby mode
    • If the effective power is set to < 10% of the nominal output of the inverter.
    To activate the Energy Manager function, select the "E-Manager" item and press the "Enter" key.
    When the "Energy Manager" function is running, the "Energy Manager" symbol will appear in the top left corner of the display:
       When the floating NO contact is off (open contact)
       When the floating NC contact is on (closed contact)
    To deactivate the Energy Manager function, select a different function (ALL / Permanent / OFF / ON) and press the "Enter" key.
    NOTE!
    Notes on setting up the switch-on and switch-off points
    If the difference between the switch-on and switch-off points is too small, or if there are fluctuations in effective power, the result may be multiple switching cycles.
    To avoid switching on and off frequently, the difference between the switch-on and switch-off points should be at least 100 - 200 W.
    When choosing the switch-off point, the power consumption of the connected consumer should be taken into account.
    When choosing the switch-on point, the weather conditions and anticipated insolation should be taken into account.
    Application example
    Switch-on point = 2000 W, switch-off point = 1800 W
    If the inverter is outputting 2000 W or above, then the floating switch contact on the inverter is switched on.
    If the inverter output falls to below 1800 W, the floating switch contact is switched off.
    This allows useful applications, such as operating a heat pump or an air-conditioning system using as much self-generated power as possible, to be implemented quickly
    Time / Date
    Set the time, date, the display format and automatic changeover between summer and winter time
    Setting range
    Set time / Set date / Time display format / Date display format / Summer/winter time
    Set time
    Set the time (hh:mm:ss or hh:mm am/pm – depending on the setting for the time display format)
    Set date
    Set the date (dd.mm.yyyy or mm/dd/yyyy - depending on the setting for the date display format)
    Time display format
    For specifying the time display format
    Setting range
    12hrs / 24hrs
    Factory setting
    Depends on country setup
    Date display format
    for specifying the date display format
    Setting range
    mm/dd/yyyy or dd.mm.yy
    Factory setting
    Summer/winter time
    Activate/deactivate automatic changeover between summer and winter time
    IMPORTANT! Only use the automatic summer/winter time changeover function if the Fronius Solar Net ring does not include any LAN- or WLAN-compatible system components (e.g. Fronius Datalogger Web, Fronius Datamanager or Fronius Hybridmanager).
    Setting range
    on / off
    Factory setting
    on
    IMPORTANT! The time and date must be set accurately in order for the day and year values and for the day characteristic to be displayed correctly.
    Display settings
    Setting range
    Language / Night mode / Contrast / Illumination
    Language
    Set language for display
    Setting range
    English, German, French, Spanish, Italian, Dutch, Czech, Slovakian, Hungarian, Polish, Turkish, Portuguese, Romanian
    Night mode
    Night mode controls Fronius DATCOM and inverter display operation during the night or when the DC voltage is insufficient
    Setting range
    AUTO / ON / OFF
    Factory setting
    OFF
    AUTO:
    Fronius DATCOM mode is always in effect as long as there is a Fronius Datamanager connected in an active and uninterrupted Fronius Solar Net.
    The inverter display remains dark during the night, but can be activated by pressing any function button.
    ON:
    Fronius DATCOM mode is always in effect. The inverter supplies 12 V of DC voltage continuously to power the Fronius Solar Net. The display is always active.
    IMPORTANT! If Fronius DATCOM night mode is set to ON or AUTO when there are Fronius Solar Net components connected, the inverter's current consumption during the night will increase to around 7 W.
    OFF:
    Fronius DATCOM will not run at night, the inverter therefore does not require any power during the night to supply the Fronius Solar Net with energy.
    The inverter display is switched off during the night and the Fronius Datamanager is not available. To nevertheless activate the Fronius Datamanager, switch the inverter off and on again at the mains and press any function button on the inverter display within 90 seconds.
    Contrast
    Set the contrast on the inverter display
    Setting range
    0 - 10
    Factory setting
    5
    Since the contrast is temperature-dependent, it may be necessary to adjust the setting under the "Contrast" menu item when the environmental conditions change.
    Illumination
    Initial setting for inverter display illumination
    The "Illumination" menu item only relates to the inverter display backlighting.
    Setting range
    AUTO / ON / OFF
    Factory setting
    AUTO
    AUTO:
    The inverter display backlighting is activated by pressing any key. If no key is pressed for 2 minutes, the display backlighting will go off again.
    ON:
    The inverter display backlighting remains permanently on when the inverter is active.
    OFF:
    The inverter display backlighting is permanently switched off.
    ENERGY YIELD
    The following settings can be changed/set here:
    • Counter deviation / Calibration
    • Currency
    • Feed-in tariff
    • CO2 factor
    Setting range
    Currency / Feed-in tariff
    Counter deviation / calibration
    Calibrating the counter
    Currency
    Set the currency
    Setting range
    3 characters, A-Z
    Feed-in tariff
    Set the remuneration rate for energy fed into the grid
    Setting range
    2 digits, 3 decimal places
    Factory setting
    (depends on country setup)
    CO2 factor
    Setting the CO2 factor of the energy fed into the grid
    Fan
    To check that the fan is working correctly
    Setting range
    Test fan #1 / Test fan #2 (depending on the device)
    • Use the "Up" and "Down" keys to select the desired fan
    • Testing of the selected fan is initiated by clicking "Enter".
    • The fan will continue to run until the operator exits the menu by pressing "Esc".
    IMPORTANT! Nothing will show on the inverter display if the fan is working. The only way to check how the fan is working is by listening and feeling.
    The INFO menu item
    Measured values
    PV Ins.
    Insulation resistance of the PV system
    Ext. Lim.
    external Limitation
    U PV 1 / U PV 2* (U PV 2 is not available on the Fronius Symo 15.0-3 208)
    Current DC voltage at the DC input terminals, even if the inverter is feeding no power into the grid whatsoever (from the 1st or 2nd MPP Tracker)
    * MPP Tracker 2 must be switched to ON via the Basic menu
    GVDPR
    Grid voltage-dependent power reduction
    Fan #1
    Percentage of target output for fan
    Measured values
    PV Ins.
    Ext. Lim.
    external Limitation
    GVDPR
    Fan #1
    PSS status
    The status of the most recent inverter fault can be displayed.
    IMPORTANT! Due to the low level of insolation early in the morning and in the evening, the status codes STATE 306 (Power low) and STATE 307 (DC low) are displayed routinely at these times of day. These status codes do not indicate any kind of fault at this point in time.
    • Press the "Enter" key to see the status of the power stage set and the most recent fault
    • Use the "Up" and "Down" keys to scroll through the list
    • Press the "Back" key to close the status and fault list
    Grid status
    The five most recent grid faults can be displayed:
    • Press the 'Enter' key to see the five most recent grid faults
    • Use the 'Up' and 'Down' keys to scroll through the list
    • Press the 'Back' key to close the grid fault display
    Device information
    For displaying the settings that will be of relevance to a power supply company. The values shown will depend on the country setup or the device-specific settings of the inverter.
    Display area
    General / Country-specific setting / MPP tracker / Grid monitoring / Grid voltage limits / Grid frequency limits / Q-mode / AC power limit / AC voltage derating / Fault Ride Through
    General:
    Device type - the exact name of the inverter
    fam. - inverter family of the inverter
    serial number - serial number of the inverter
    Country-specific setting:
    Setup - specified country setup
    Version - version of country setup
    Origin activated - indicates that the normal country-specific setup is activated.
    Alternat. activated - indicates that the alternative country-specific setup is activated (for Fronius Symo Hybrid only)
    Group - group for updating the inverter software
    MPP Tracker:
    Tracker 1 - indicates the set tracking behaviour (MPP AUTO / MPP USER / FIX)
    Tracker 2 - indicates the set tracking behaviour (MPP AUTO / MPP USER / FIX)
    Grid monitoring:
    GMTi - Grid Monitoring Time - start-up time of the inverter in sec (seconds)
    GMTr - Grid Monitoring Time reconnect - reconnection time in sec (seconds) after a grid fault
    ULL - U (voltage) Longtime Limit - voltage limit value in V (volts) for the 10-minute average voltage value
    LLTrip - Longtime Limit Trip - trip time for ULL monitoring, how fast the inverter should switch off
    Grid voltage limits inner limit value:
    UImax - upper inner grid voltage in V (volts)
    TTMax - Trip Time Max - trip time for exceeding the upper inner grid voltage limit value in cyl*
    UMin - lower inner grid voltage in V (volts)
    TTMin - Trip Time Min - trip time for falling below the lower inner grid voltage limit value in cyl*
    *cyl = grid periods (cycles); 1 cyl corresponds to 20 ms at 50 Hz or 16.66 ms at 60 Hz
    Grid voltage limits outer limit value
    UMax - upper outer grid voltage in V (volts)
    TTMax - Trip Time Max - trip time for exceeding the upper outer grid voltage limit value in cyl*
    UMin - lower outer grid voltage in V (volts)
    TTMin - Trip Time Min - trip time for falling below the lower outer grid voltage limit value in cyl*
    Grid frequency limits:
    FILmax - upper inner grid frequency in Hz (Hertz)
    FILmin - lower inner grid frequency in Hz (Hertz)
    FOLmax - upper outer grid frequency in Hz (Hertz)
    FOLmin - lower outer grid frequency in Hz (Hertz)
    Q-mode:
    Indicates which reactive power setting is currently active on the inverter (e.g. OFF, Q / P, etc.)
    AC power limit including SoftStart indicator and/or AC grid frequency derating:
    Max P AC - maximum output power, which can be changed using the "Manual Power Reduction" function
    GPIS - Gradual Power Incrementation at Startup - indicates (%/sec) whether the SoftStart function is active on the inverter
    GFDPRe - Grid Frequency Dependent Power Reduction enable limit - indicates the set grid frequency in Hz (Hertz) from when power derating takes place
    GFDPRv - Grid Frequency Dependent Power Reduction derating gradient - indicates the set grid frequency in %/Hz, how strong power derating is
    AC voltage derating:
    GVDPRe - Grid Voltage Depending Power Reduction enable limit - threshold value in V from which voltage-dependent power derating starts
    GVDPRv - Grid Voltage Depending Power Reduction derating gradient - derating gradient %/V with which the power is reduced
    Message - indicates whether the dispatch of an info message via Fronius Solar Net is active
    Version
    Displays the version and serial numbers of the PC boards in the inverter (e.g. for service purposes)
    Display area
    Display / Display Software / Integrity Checksum / Memory Card / Memory Card #1 / Power Stage / Power Stage Software / EMI Filter / Power Stage #3 / Power Stage #4
    General
    The inverter has a key lock function.
    When the key lock is active, the Setup menu is not accessible, i.e. the setup data cannot be changed accidentally (or maliciously).
    The code 12321 has to be entered in order to activate / deactivate the key lock.
    General
    1Press the "Menu" key
    The menu level appears.
    2Press the unassigned "Menu / Esc" key
    5 times
    "Access Code" is displayed in the "CODE" menu; the first digit starts flashing.
    3Enter the code 12321: Use the "Plus" and "Minus" keys    to select a value for the first digit of the code
    The second digit flashes.
    5Repeat steps 3 and 4 for the second, third, fourth and fifth digits of the access code until...
    the selected code starts flashing.
    "Setup Menu Lock" is displayed in the "LOCK" menu.
    7Use the "Plus" and "Minus" keys    to turn the key lock on or off:
    ON = key lock is on (the Setup menu is not accessible)
    OFF = key lock is off (the Setup menu is accessible)
    If a USB flash drive is connected to the USB A socket it can function as a datalogger for an inverter.
    At any time, the logging data stored on the USB flash drive can be
    • imported into the Fronius Solar.access software using the FLD file that was logged at the same time,
    • viewed directly in third-party programs (e.g. Microsoft® Excel) using the CSV file logged at the same time.
    Older versions (before Excel 2007) are limited to a maximum of 65,536 rows.
    Further information on "Data on a USB flash drive", "Data volume and storage capacity" as well as "Buffer memory" can be found at:
    ® https://manuals.fronius.com/html/4204260426
    Due to the variety of USB flash drives available on the market, it cannot be guaranteed that every USB flash drive will be detected by the inverter.
    Fronius recommends that only certified, industry-grade USB flash drives are used (look out for the USB-IF logo).
    The inverter supports USB flash drives with the following file systems:
    • FAT12
    • FAT16
    • FAT32
    Fronius recommends that the USB flash drive employed should only be used for recording logging data or updating the inverter software. The USB flash drives should not contain any other data.
    USB symbol on the inverter display, e.g. in display mode 'NOW':
    If the inverter detects a USB flash drive, the USB symbol will appear in the top right corner of the display.
    When inserting a USB flash drive, check whether the USB symbol is displayed (it may also flash).
    Note! Please note for outdoor applications that conventional USB flash drives are often only guaranteed to work within a restricted temperature range.
    For outdoor applications ensure that the USB flash drive also functions, for example, at low temperatures.
    With the help of the USB flash drive, end customers can also update the inverter software via the SETUP menu: the update file is first saved to the USB flash drive, from where it is then transferred to the inverter.
    Safety instruction concerning the removal of a USB flash drive:
    IMPORTANT! To avoid any loss of data, a USB flash drive may only be removed if the following conditions are met:
    • Only remove a USB flash drive via the 'Safely remove USB / HW' item on the SETUP menu
    • The 'Data transmission' LED has stopped flashing or comes on steady.
    The Basic menu
    5 times
    3Enter the code 22742: Use the "Plus" and "Minus" keys    to select a value for the first digit of the code
    The Basic menu appears.
    7Use the "Plus" and "Minus" keys    to select the desired entry
    8Press the "Enter" key to open the desired menu item
    9Press the "Esc" key to exit the Basic menu
    5 times
    The Basic menu is used to set the following parameters, which are important for installing and operating the inverter:
    MPP Tracker 1 / MPP Tracker 2
    • MPP Tracker 2: ON / OFF (MultiMPP Tracker devices only, excluding Fronius Symo 15.0-3 208)
    • DC operating mode: MPP AUTO / FIX / MPP USER
      • MPP AUTO: normal operating status; the inverter automatically searches for the ideal operating point
      • FIX: for entering a fixed DC voltage at which the inverter will operate
      • MPP USER: for entering a lower MP voltage above which the inverter will search for its ideal operating point
    • Dynamic Peak Manager: ON / OFF
    • Fixed voltage: for entering the fixed voltage
    • MPPT start voltage: for entering the start voltage
    USB log book
    Activates or deactivates the function for saving all error messages to a USB flash drive
    AUTO / OFF / ON
    Input signal
    • Function: Ext Sig. / S0-Meter / OFF
      Only with the Ext Sig. function selected:
      • Triggering method: Warning (warning shown on display) / Ext. Stop (inverter switches off)
      • Connection type: N/C (normally closed contact) / N/O (normally open contact)
    SMS / relay
    • Event delay:
      for entering the time delay after which an SMS is sent or the relay is to switch
      900 - 86,400 seconds
    • Event counter:
      for entering the number of events that lead to signalling:
      10 - 255
    Insulation setting
    • Insulation warning: ON / OFF
    • Threshold warning: for entering a threshold that leads to a warning
    • Threshold fault: for entering a threshold that leads to a fault (not available in all countries)
    TOTAL Reset
    Under the LOG menu item, this setting resets the max. and min. voltage values and the max. power of feeding in to zero.
    Once the values have been reset, this action cannot be undone.
    To reset the values to zero, press the "Enter" key.
    "CONFIRM" is displayed.
    Press "Enter" again.
    The values are reset and the menu is displayed
    If the option: DC SPD (surge protection) has been fitted in the inverter, the following menu items will be set by default:
    Signal input: Ext Sig.
    1. Turn off the automatic circuit breaker.
    2. Turn the DC disconnector to the "Off" switch position.
    To start up the inverter again, follow the steps listed above in reverse order.
    Status code display
    The inverter performs a system self-diagnosis that automatically detects many faults that may occur and shows them on the display. This means you are promptly made aware of malfunctions in the inverter or the photovoltaic system, or of any installation or operating faults.
    If the system self-diagnosis has detected a specific fault, the associated status code will be shown on the display.
    IMPORTANT! Status codes may sometimes appear briefly as a result of the inverter's control response. If the inverter then continues working with no sign of any problem, this means that there was no fault.
    Status code display
    Total failure of the display
    If the display fails to come on some time after sunrise:
    • Check the AC voltage on the inverter connection sockets:
      the AC voltage must be 220/230 V (+ 10 % / - 5 %) or 380/400 V (+ 10 % / - 5 %).
    Class 1 status codes
    Class 1 status codes generally only arise momentarily and are caused by the public grid.
    Example: The grid frequency is too high and the inverter may not feed any energy into the grid owing to a standard. There is nothing wrong with the device.
    The initial response of the inverter is to disconnect itself from the grid. The grid is subsequently checked during the stipulated monitoring period. If no further problem has been detected by the end of this period, then the inverter will resume feeding energy into the grid.
    The GPIS SoftStart function is activated according to the country setup:
    After cutting out due to an AC error, the output power of the inverter is continuously increased in line with the national guidelines.
    Code
    Description
    Behaviour
    Remedy
    102
    AC voltage too high
    Following careful testing and when the grid conditions are within the permissible range again, the inverter will resume feeding energy into the grid.
    Check grid connections;
    if this status code keeps recurring, contact your system fitter
    103
    AC voltage too low
    105
    AC frequency too high
    106
    AC frequency too low
    107
    No AC grid
    108
    Stand-alone operation detected
    112
    RCMU error
    Class 3 status codes
    Class 3 includes status codes that may occur while feeding energy into the grid, but generally do not cause the process to be interrupted for any length of time.
    The inverter disconnects automatically from the grid, the grid is then monitored as specified and the inverter attempts to resume feeding energy into the grid.
    Code
    Description
    Behaviour
    Remedy
    301
    Overcurrent (AC)
    Short-term interruption while feeding energy into the grid.
    The inverter resumes its start-up routine.
    302
    Overcurrent (DC)
    303
    DC module overtemperature
    The inverter resumes with its startup routine.
    Purge cooling air openings and heat sink; **)
    304
    AC module overtemperature
    305
    No power being fed in, despite closed relay
    306
    PV output too low for feeding energy into the grid
    The inverter resumes its startup routine.
    wait for sufficient level of insolation;
    307
    DC low
    DC input voltage too low for feeding energy into the grid
    IMPORTANT! Due to the low level of insolation early in the morning and in the evening, the status codes 306 (Power low) and 307 (DC low) are displayed routinely at these times of day. These status codes do not indicate any kind of fault.
    308
    Intermediate circuit voltage too high
    309
    DC input voltage MPPT 1 too high
    311
    Polarity of DC strings reversed
    313
    DC input voltage MPPT2 too high
    314
    Current sensor calibration timeout
    315
    AC current sensor error
    316
    InterruptCheck fail
    325
    Overtemperature in the connection area
    326
    Fan 1 error
    327
    Fan 2 error
    *) If the status code is displayed all the time: notify a Fronius-trained service engineer
    **) Fault is rectified automatically. If this status code keeps recurring, contact your system engineer
    Status codes – Class 4
    Some of the class 4 status codes necessitate intervention by a Fronius-trained service technician.
    Code
    Description
    Behaviour
    Remedy
    401
    Unable to communicate with the power stage set
    The inverter will automatically attempt to connect again and, if possible, will resume feeding energy into the grid
    406
    AC module temperature sensor faulty (L1)
    407
    AC module temperature sensor faulty (L2)
    408
    DC component measured in the grid too high
    412
    Fixed voltage mode has been selected instead of MPP voltage mode, and the fixed voltage has been set to too low or too high a value.
    415
    Safety cut-out via option card or RECERBO has triggered
    The inverter is not feeding any energy into the grid.
    416
    No communication possible between power stage set and control system.
    417
    Hardware ID problem
    Update inverter firmware; *)
    419
    Unique ID conflict
    420
    No communication possible with the Fronius Datamanager
    421
    HID range error
    425
    426 - 428
    Possible hardware fault
    431
    Software problem
    Perform AC reset (switch automatic circuit breaker off and on again); update inverter firmware; *)
    436
    Functional incompatibility (one or more PC boards in the inverter are not compatible with each other, e.g. after a PC board has been replaced)
    437
    Power stage set problem
    438
    443
    Intermediate circuit voltage too low or asymmetric
    445
    • Compatibility error (e.g. due to replacement of a PC board)
    • Invalid power stage set configuration
    447
    Insulation fault
    448
    Neutral conductor not connected
    450
    Guard cannot be found
    451
    Memory error detected
    452
    Communication error between the processors
    453
    Grid voltage and power stage set are incompatible
    454
    Grid frequency and power stage set are incompatible
    456
    Anti-islanding function is no longer being implemented correctly
    457
    Grid voltage relay fault
    Check AC cable *)
    458
    Error when recording measuring signal
    459
    Error when recording the measuring signal for the insulation test
    460
    Reference voltage source for the digital signal processor (DSP) is working out of tolerance
    461
    DSP data memory error
    462
    Error during DC feed monitoring routine
    463
    Reversed AC polarity, AC connector inserted incorrectly
    474
    RCMU sensor faulty
    475
    Insulation fault (connection between solar module and ground)
    476
    Driver supply voltage too low
    479
    Intermediate circuit voltage relay is switched off
    480,
    481
    482
    Setup interrupted after initial start-up
    Restart Setup after an AC reset (switch automatic circuit breaker off and on again)
    483
    Voltage UDC fixed on MPP2 string out of limits
    Check MPP settings; *)
    485
    CAN transmit buffer is full
    Perform AC reset (switch automatic circuit breaker off and on again; *)
    489
    Permanent overvoltage on intermediate circuit capacitor (five 479 status codes in a row)
    *) If the status code is displayed all the time: notify a Fronius-trained service technician
    **) If this status code keeps recurring, contact your system engineer
    Status codes – Class 5
    Class 5 status codes do not generally interfere with feeding energy into the grid, but can cause restrictions. These status codes are displayed until they are acknowledged by pressing a key (however, the inverter continues to operate normally in the background).
    Code
    Description
    Behaviour
    Remedy
    502
    Insulation error on the solar modules
    Warning message is shown on the display
    509
    No energy fed into the grid in the past 24 hours
    Acknowledge status code;
    check whether all the conditions for the problem-free feeding of energy into the grid have been met (e.g. are the solar modules covered with snow?); **)
    515
    Unable to communicate with filter
    Warning message on the display
    516
    No communication possible with the storage unit
    Storage unit warning message
    517
    Power derating caused by too high a temperature
    When power derating occurs, a warning message is shown on the display.
    If necessary, purge cooling air openings and heat sink;
    fault is rectified automatically; **)
    518
    Internal DSP malfunction
    519
    520
    No energy fed into the grid by MPPT1 in the past 24 hours
    check whether all the conditions for the problem-free feeding of energy into the grid have been met (e.g. are the solar modules covered with snow?); *)
    522
    DC low String 1
    523
    DC low String 2
    558,
    559
    560
    Power derating caused by overfrequency
    Displayed when grid frequency becomes excessively high. The power is reduced.
    As soon as the grid frequency is back within the permissible range and the inverter has returned to normal operation, the fault is rectified automatically; **)
    564
    566
    Arc detector switched off
    (e.g. during external arc monitoring)
    The status code is displayed every day until the arc detector is reactivated.
    No error
    Confirm status code by pressing 'Enter'
    568
    Incorrect input signal on the multifunction current interface
    The status code is displayed in the case of an incorrect input signal on the multifunction current interface and with the following setting:
    Basic menu / Input signal / Mode of operation = Ext. Signal, triggering method = Warning
    check the devices connected to the multifunction current interface; **)
    572
    Power limited by the power stage set
    Power is being limited by the power stage set
    573
    Undertemperature warning
    581
    "Special Purpose Utility-Interactive" (SPUI) setup activated
    The inverter is no longer compliant with the IEEE1547 and IEEE1574.1 standards because the standalone function has been deactivated, a frequency-dependent power reduction has been activated and the frequency and voltage limits are being changed
    No error
    *) If the status code is displayed all the time: Notify a Fronius-trained service technician.
    **) If this status code keeps recurring, contact your system engineer.
    Class 6 status codes
    Some of the class 6 status codes necessitate intervention by a Fronius-trained service engineer.
    Code
    Description
    Behaviour
    Remedy
    601
    CAN bus is full
    603
    AC module temperature sensor faulty (L3)
    604
    DC module temperature sensor faulty
    607
    RCMU error
    Reset status code by pressing 'Enter'. The inverter resumes the feeding of energy into the grid; if the status code keeps appearing, check the complete photovoltaic system for damage; **)
    608
    Status codes – Class 7
    Class 7 status codes relate to the control system, the configuration and inverter data recording, and may directly or indirectly affect the process of feeding energy into the grid.
    Code
    Description
    Behaviour
    Remedy
    701 - 704
    Provides information about the internal processor status
    705
    Conflict when setting the inverter number (e.g. number already assigned)
    Correct inverter number in Setup menu
    706 - 716
    721
    EEPROM has been re-initialised
    Acknowledge status code; *)
    722 - 730
    731
    Initialisation error - USB flash drive is not supported
    Check or replace USB flash drive
    Check file system on USB flash drive; *)
    732
    Initialisation error - Overcurrent on USB flash drive
    733
    No USB flash drive connected
    Connect or check USB flash drive; *)
    734
    Update file not recognised or not present
    Check update file (e.g. for correct file name)
    735
    Update file does not match the device, update file too old
    Warning message on the display, update process is interrupted
    Check update file
    and if necessary download an update file to match the device (e.g. at
    http://www.fronius.com); *)
    736
    Write or read error occurred
    Check USB flash drive and the data contained on it or replace USB flash drive
    Never unplug a USB flash drive if the 'data transfer' LED is still flashing or lit; *)
    737
    File could not be opened
    Remove and then reinsert USB flash drive; check or replace USB flash drive
    738
    Log file cannot be saved (e.g. USB flash drive is write-protected or full)
    Create some storage space, remove write protection, if necessary check or replace USB flash drive; *)
    740
    Initialisation error - error in file system on USB flash drive
    Check USB flash drive; reformat on PC for FAT12, FAT16 or FAT32
    741
    Error during recording of logging data
    743
    Error occurred during update process
    Repeat update process, check USB flash drive; *)
    745
    Update file corrupt
    Download update file again; check or replace USB flash drive; *)
    746
    Wait for two minutes, then start the update again; *)
    751
    Time lost
    Reset time and date on the inverter; *)
    752
    Real Time Clock module communication error
    753
    Internal error: Real Time Clock module is in emergency mode
    Time may be inaccurate or lost (feeding energy into the grid normal)
    754 - 755
    757
    Hardware error in the Real Time Clock module
    Error message on the display; the inverter is not feeding any energy into the grid
    758
    760
    Internal hardware error
    761 - 765
    766
    Emergency power limitation has been activated (max. 750 W)
    767
    768
    Different power limitation in the hardware modules
    772
    Storage unit not available
    773
    Software update group 0 (invalid country setup)
    775
    PMC power stage set not available
    Press 'Enter' key to acknowledge error; *)
    776
    Invalid device type
    781 - 794
    Class 10 - 12 status codes
    1000 - 1299- Provide information on the status of the internal processor program
    Description
    Is of no concern when the inverter is working properly and only appears in the "Status PS" setup parameter. In the event of an actual error, this status code assists Fronius Technical Support during the error analysis.
    Customer service
    IMPORTANT! Contact your Fronius dealer or a Fronius-trained service technician if
    • an error appears frequently or all the time
    • an error appears that is not listed in the tables
    Operation in dusty environments
    When operating the inverter in extremely dusty environments:
    when necessary, clean the cooling elements and fan on the back of the inverter as well as the air intakes at the mounting bracket using clean compressed air.
    Technical data
    Fronius Symo Advanced 10.0-3-M
    10.0-3-M
    Input data
    MPP voltage range
    270 - 800 V DC
    Max. input voltage
    (at 1000 W/m²/ -10 °C in an open circuit)
    1000 V DC
    Min. input voltage
    200 V DC
    Max. input current (MPP1 / MPP2)
    (MPP1 + MPP2)
    27.0 / 16.5 A (14 A for voltages < 420 V)
    43.5 A
    Max. short circuit current of the solar modules (ISC PV) (MPP1 / MPP2)
    40.5 / 24.8 A
    Max. inverter backfeed current to the array 3)
    40.5 / 24.8 A (RMS)4)
    Output data
    Nominal output power (Pnom)
    10,000 W
    Max. output power
    10,000 W
    Rated apparent power
    10,000 VA
    Nominal grid voltage
    3~ NPE 400 / 230 V or 3~ NPE 380 / 220
    Min. grid voltage
    150 V / 260 V
    Max. grid voltage
    280 V / 485 V
    Nominal output current at 220 / 230 V
    15.2 / 14.4 A
    Max. output current
    20 A
    Nominal frequency
    50 / 60 Hz 1)
    Total harmonic distortion
    < 1.75%
    Power factor (cos phi)
    0 - 1 ind./cap.2)
    Max. output fault current per period
    64 A / 2.34 ms
    General data
    Maximum efficiency
    97.8%
    European efficiency UDCmin / UDCnom / UDCmax
    95.4 / 97.3 / 96.6%
    Self-consumption at night
    0.7 W & 117 VA
    Cooling
    Controlled forced-air ventilation
    Protection class
    IP 66
    Dimensions h x w x d
    725 x 510 x 225 mm
    Weight
    34.8 kg
    Permitted ambient temperature
    -25 °C - +60 °C
    Permissible humidity
    0 - 100%
    EMC emission class
    B
    DC / AC overvoltage category
    2/3
    Pollution degree
    Noise emission
    65 dB(A) (ref. 1pW)
    Inverter topology
    Non-insulated transformerless
    Protection devices
    DC isolation measurement
    Integrated
    DC overload performance
    Operating point shift, power limiter
    DC disconnector
    Integrated
    RCMU
    Integrated
    Active anti-islanding method
    Frequency conversion method
    10.0-3-M
    Input data
    MPP voltage range
    270 - 800 V DC
    Max. input voltage
    1000 V DC
    Min. input voltage
    200 V DC
    (MPP1 + MPP2)
    43.5 A
    40.5 / 24.8 A
    Output data
    10,000 W
    Max. output power
    10,000 W
    10,000 VA
    Min. grid voltage
    150 V / 260 V
    Max. grid voltage
    280 V / 485 V
    15.2 / 14.4 A
    Max. output current
    20 A
    Nominal frequency
    50 / 60 Hz 1)
    < 1.75%
    0 - 1 ind./cap.2)
    64 A / 2.34 ms
    General data
    Maximum efficiency
    97.8%
    95.4 / 97.3 / 96.6%
    0.7 W & 117 VA
    Cooling
    Protection class
    IP 66
    725 x 510 x 225 mm
    Weight
    34.8 kg
    -25 °C - +60 °C
    0 - 100%
    EMC emission class
    B
    2/3
    Pollution degree
    Noise emission
    65 dB(A) (ref. 1pW)
    Inverter topology
    Protection devices
    Integrated
    DC disconnector
    Integrated
    RCMU
    Integrated
    Fronius Symo Advanced 12.5-3-M
    12.5-3-M
    Input data
    MPP voltage range
    320 - 800 V DC
    Max. input voltage
    1000 V DC
    Min. input voltage
    200 V DC
    (MPP1 + MPP2)
    43.5 A
    40.5 / 24.8 A
    Output data
    12,500 W
    Max. output power
    12,500 W
    12,500 VA
    Min. grid voltage
    150 V / 260 V
    Max. grid voltage
    280 V / 485 V
    18.9 / 18.1 A
    Max. output current
    20 A
    Nominal frequency
    50 / 60 Hz 1)
    < 2%
    0 - 1 ind./cap.2)
    64 A / 2.34 ms
    General data
    Maximum efficiency
    97.8%
    95.7 / 97.5 / 96.9%
    0.7 W & 117 VA
    Cooling
    Protection class
    IP 66
    725 x 510 x 225 mm
    Weight
    34.8 kg
    -25 °C - +60 °C
    0 - 100%
    EMC emission class
    B
    2/3
    Pollution degree
    Noise emission
    65 dB(A) (ref. 1pW)
    Inverter topology
    Protection devices
    Integrated
    DC disconnector
    Integrated
    RCMU
    Integrated
    Fronius Symo Advanced 15.0-3-M
    15.0-3-M
    Input data
    MPP voltage range
    320 - 800 V DC
    Max. input voltage
    1000 V DC
    Min. input voltage
    200 V DC
    (MPP1 + MPP2)
    33.0 / 27.0 A
    51.0 A
    49.5 / 40.5 A
    49.5 / 40.5 A
    Output data
    15,000 W
    Max. output power
    15,000 W
    Rated apparent power / SRATED
    15,000 VA
    Min. grid voltage
    150 V / 260 V
    Max. grid voltage
    280 V / 485 V
    22.7 / 21.7 A
    Max. output current
    32 A
    Nominal frequency
    50 / 60 Hz 1)
    < 1.5%
    0 - 1 ind./cap.2)
    64 A / 2.34 ms
    General data
    Maximum efficiency
    98%
    UDCmax
    96.2 / 97.6 / 97.1%
    0.7 W & 117 VA
    Cooling
    Protection class
    IP 66
    725 x 510 x 225 mm
    Weight
    43.4 kg / 43.2 kg
    -25 °C - +60 °C
    0 - 100%
    EMC emission class
    B
    2/3
    Pollution degree
    Noise emission
    65 dB(A) (ref. 1pW)
    Inverter topology
    Protection devices
    Integrated
    DC disconnector
    Integrated
    RCMU
    Integrated
    Fronius Symo Advanced 17.5-3-M
    17.5-3-M
    Input data
    MPP voltage range
    370 - 800 V DC
    Max. input voltage
    1000 V DC
    Min. input voltage
    200 V DC
    (MPP1 + MPP2)
    33.0 / 27.0 A
    51.0 A
    49.5 / 40.5 A
    49.5 / 40.5 A
    Output data
    17,500 W
    Max. output power
    17,500 W
    17,500 VA
    Min. grid voltage
    150 V / 260 V
    Max. grid voltage
    280 V / 485 V
    26.5 / 25.4 A
    Max. output current
    32 A
    Nominal frequency
    50 / 60 Hz 1)
    < 1.5%
    0 - 1 ind./cap.2)
    64 A / 2.34 ms
    General data
    Maximum efficiency
    98%
    UDCmax
    96.4 / 97.7 / 97.2%
    0.7 W & 117 VA
    Cooling
    Protection class
    IP 66
    725 x 510 x 225 mm
    Weight
    43.4 kg / 43.2 kg
    -25 °C - +60 °C
    0 - 100%
    EMC emission class
    B
    2/3
    Pollution degree
    Noise emission
    65 dB(A) (ref. 1pW)
    Inverter topology
    Protection devices
    Integrated
    DC disconnector
    Integrated
    RCMU
    Integrated
    Fronius Symo Advanced 20.0-3-M
    20.0-3-M
    Input data
    MPP voltage range
    420 - 800 V DC
    Max. input voltage
    1000 V DC
    Min. input voltage
    200 V DC
    (MPP1 + MPP2)
    33.0 / 27.0 A
    51.0 A
    49.5 / 40.5 A
    49.5 / 40.5 A
    Output data
    20,000 W
    Max. output power
    20,000 W
    20,000 VA
    Min. grid voltage
    150 V / 260 V
    Max. grid voltage
    280 V / 485 V
    30.3 / 29 A
    Max. output current
    32 A
    Nominal frequency
    50 / 60 Hz 1)
    < 1.25%
    0 - 1 ind./cap.2)
    64 A / 2.34 ms
    General data
    Maximum efficiency
    98%
    UDCmax
    96.5 / 97.8 / 97.3%
    0.7 W & 117 VA
    Cooling
    Protection class
    IP 66
    725 x 510 x 225 mm
    Weight
    43.4 kg / 43.2 kg
    -25 °C - +60 °C
    0 - 100%
    EMC emission class
    B
    2/3
    Pollution degree
    Noise emission
    65 dB(A) (ref. 1pW)
    Inverter topology
    Protection devices
    Integrated
    DC disconnector
    Integrated
    RCMU
    Integrated
    Explanation of footnotes
    1)
    The values quoted are default values; the inverter is configured specifically to meet the needs of the country in question.
    2)
    Depending on the country setup or device-specific settings
    (ind. = inductive; cap. = capacitive)
    3)
    Maximum current from a defective PV module to all other PV modules. From the inverter itself to the PV side of the inverter, it is 0 A.
    4)
    Guaranteed by the electrical configuration of the inverter
    5)
    Current peak when switching on the inverter
    Integrated DC disconnector Fronius Symo Advanced 10.0-12.5
    Settings
    Product name
    Benedict LS32 E 7857
    Rated insulation voltage
    1000 VDC
    Rated impulse withstand voltage
    8 kV
    Suitability for insulation
    Yes, DC only
    Utilisation category and / or PV utilisation category
    As per IEC/EN 60947-3 utilisation category DC-PV2
    Rated short-time withstand current (Icw)
    Rated short-time withstand current (Icw): 1000 A for 2 poles; 1700 A for 2+2 poles
    Rated short-circuit making capacity (Icm)
    Rated short-time withstand current (Icm): 1000 A for 2 poles; 1700 A for 2+2 poles
    Rated breaking capacity
    Rated operating voltage (Ue)
    [V d.c.]
    Rated operating current (Ie)
    [A]
    2P
    I(make) / I(break)
    [A]
    2P
    [A]
    2 + 2P
    I(make) / I(break)
    [A]
    2 + 2P
    ≤ 500
    32
    128
    50
    200
    600
    27
    108
    35
    140
    700
    22
    88
    22
    88
    800
    17
    68
    17
    68
    900
    12
    48
    12
    48
    1000
    6
    24
    6
    24
    Integrated DC disconnector Fronius Symo Advanced 15.0 - 20.0
    Settings
    Product name
    Benedict LS32 E 7858
    1000 VDC
    8 kV
    Yes, DC only
    Rated short-time withstand current (Icw): 1400 A for 2 poles; 2400 A for 2+2 poles
    Rated short-time withstand current (Icm): 1400 A for 2 poles; 2400 A for 2+2 poles
    [V d.c.]
    [A]
    2P
    I(make) / I(break)
    [A]
    2P
    [A]
    2 + 2P
    I(make) / I(break)
    [A]
    2 + 2P
    ≤ 500
    55
    220
    85
    340
    600
    55
    220
    75
    300
    700
    55
    220
    60
    240
    800
    49
    196
    49
    196
    900
    35
    140
    35
    140
    1000
    20
    80
    25
    100
    Applicable standards and guidelines
    CE mark
    The devices comply with all the requisite and relevant standards and guidelines that form part of the relevant EU Directive, and are therefore permitted to display the CE mark.
    Circuit to prevent stand alone operation
    The inverter has an approved circuit to prevent stand alone operation.
    Grid failure
    The standard measurement and safety procedures integrated into the inverter ensure that in the event of a grid failure, the feed-in of energy is immediately interrupted (e.g. switch-off by the energy supplier or damage to lines).
    Warranty terms and conditions, and disposal
    Fronius manufacturer's warranty
    Detailed, country-specific warranty terms are available on the internet:
    www.fronius.com/solar/warranty
    To obtain the full warranty period for your newly installed Fronius inverter or storage system, please register at: www.solarweb.com.
    Disposal
    Waste electrical and electronic equipment must be collected separately and recycled in an environmentally responsible manner in accordance with the European Directive and national law. Used equipment must be returned to the distributor or through a local, authorised collection and disposal system. Proper disposal of the old device promotes sustainable recycling of material resources. Ignoring this may lead to potential health/environmental impacts.
