Indicates immediate danger.
The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, attention must also be paid to any generally applicable and local regulations regarding accident prevention and environmental protection.
All safety and danger notices on the device:The terminals can reach high temperatures.
Only operate the device when all protection devices are fully functional. If the protection devices are not fully functional, there is a danger of:Any safety devices that are not fully functional must be repaired by an authorised specialist before the device is switched on.
For the location of the safety and danger notices on the device, refer to the section headed "General remarks" in the Operating Instructions for the device.
Any equipment malfunctions which might impair safety must be remedied before the device is turned on.
The servicing information contained in these operating instructions is intended only for the use of qualified service engineers. An electric shock can be fatal. Do not carry out any actions other than those described in the documentation. This also applies to qualified personnel.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Loose connections, scorched, damaged or inadequately dimensioned cables and leads must be immediately repaired by authorised personnel.
Maintenance and repair work must only be carried out by an authorised specialist.
It is impossible to guarantee that bought-in parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements. Use only original spare parts (also applies to standard parts).
Components that are not in perfect condition must be changed immediately.
The text and illustrations are all technically correct at the time of printing. We reserve the right to make changes. The contents of the operating instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the instructions, we will be most grateful for your comments.
The user is responsible for the safekeeping of any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
The Fronius Smart Meter is a bidirectional electricity meter which optimises self-consumption and records the household's load curve. In conjunction with the Fronius inverter, Fronius Datamanager and Fronius data interface, the Fronius Smart Meter provides a clear overview of a user's own power consumption.
The meter measures the power flow to the loads or to the grid and forwards the information via the Modbus RTU/RS485 communication to the Fronius inverter.
Observe and follow safety instructions!
Failure to observe the safety instructions will result in damage to personnel and equipment.
Switch off the power supply before establishing a mains connection.
Observe the safety instructions.
Technical data, markings and safety symbols are located on the Fronius Smart Meter. These must not be removed nor painted over. The notices and symbols warn of incorrect operation that could result in serious injury and damage to property.
Symbols on the rating plate: | |
CE mark | |
Regulatory Compliance Mark (RCM) | |
WEEE mark |
The Fronius Smart Meter can be installed at two possible locations in the system: at the feed-in point and at the consumption point.
Placement at the feed-in point
Fronius Smart Meter located at the feed-in point.
Placement at the consumption point
Fronius Smart Meter located at the consumption load.
The Fronius Smart Meter can be mounted on a 35 mm DIN rail. The housing comprises 4 DUs (division units, max. 72 mm).
The Fronius Smart Meter is a hard-wired device and requires a disconnecting device (circuit breaker, switch or disconnector) and overcurrent protection (automatic circuit breaker).
The Fronius Smart Meter consumes 10 - 30 mA. The nominal capacity of the disconnecting devices and the overcurrent protection is determined by the wire thickness, the mains voltage and the required breaking capacity.
Danger from mains voltage.
Switch off the power supply before connecting the mains voltage inputs to the Fronius Smart Meter.
IMPORTANT!
Do not install more than one cable per screw terminal. If necessary, use terminal blocks. The measuring inputs of the current transformers must be earthed on one side as shown in the circuit diagram.
Connect each voltage cable to the terminal strip as shown in the graphics below.
General
Do not use current transformers with a voltage output.
Current transformers are directional. If they are mounted backwards or with swapped wires, the measured power will be negative.
Primary current
Maximum current per phase. A current transformer with a primary current greater than the maximum expected current per phase should be selected. The closer the expected current is to this value, the more precise the measurement will be.
Secondary current
The current transformer must supply alternating current at a nominal current of 1 or 5 A. The nominal values for the current transformer are listed in the current transformer data sheet.
Power
The Fronius Smart Meter needs 0.3 VA to carry out its measurements. Losses also occur on the outgoing and return leads. The power of the current transformer must be greater than the sum total of the power of the Fronius Smart Meter and the leads. The higher the power, the better.
Line resistances at different cross-sections (copper wires) | ||||||
Secondary current | Cross-section | Line resistances at different lead lengths (outgoing and return lead) | ||||
0.5 m | 1.0 m | 2.5 m | 5 m | 10 m | ||
5 | 1.5 | 0.3 VA | 0.6 VA | 1.5 VA | 2.9 VA | 5.8 VA |
5 | 2.5 | 0.2 VA | 0.4 VA | 0.9 VA | 1.8 VA | 3.6 VA |
5 | 4 | - | - | 0.6 VA | 1.1 VA | 2.2 VA |
Example
The length of the outgoing and return lead (0.5 m each) between the Fronius Smart Meter and the current transformer is a total of 1 m and has a copper cable cross-section of 1.5 mm²; the line resistance is therefore 0.6 VA according to the table above. The self-consumption of the Fronius Smart Meter is 0.3 VA.
Line resistance 0.6 VA + self-consumption 0.3 VA = 0.9 VA
→ A current transformer with a rating of 1 VA, 1.5 VA, 5 VA or higher is suitable here.
Accuracy class
Use Class 1 or better (Class 0.5, 0.2, etc.). Class 1 is equivalent to a deviation of ± 1% of the secondary current at maximum power.
Mounting
Rigid or hinged.
"Rigid" is usually cheaper with better power and accuracy values. Hinged current transformers can be opened for attachment to the conductor. To prevent it being opened inadvertently, a plastic cable tie can be secured to the current transformer. Hinged current transformers can be installed in a system without interrupting the voltage.
Attach the current transformers to the conductor to be measured and connect the current transformer cables to the Fronius Smart Meter. Always switch off the power supply before disconnecting live conductors.
The current transformers are connected to connections 1 and 3; 4 and 6; 7 and 9. If necessary, excessively long cables can be shortened accordingly. Observe the sequence in which the phases are connected. Accurate power measurement is only ensured if the mains voltage phases match the current phases.
Suitable voltage transformers: Only voltage transformers with a voltage range from 210 to 440 V (phase - phase) may be used. The voltage transformers must be connected to terminals 2, 5, 8 and 11 at the point of direct voltage measurement.
Fronius SnapINverter:
Connect the data communication connections of the Fronius Smart Meter to the Fronius system monitoring in the inverter. Several Smart Meters can be installed in the system, see chapter Multi-meter system - Fronius SnapINverter on page (→).
Fronius GEN24 inverter:
Connect the data communication connections of the Fronius Smart Meter to the Modbus interface of the Fronius GEN24 inverter. Several Smart Meters can be installed in the system, see chapter Multi-meter system - Fronius GEN24 inverter on page (→).
More information on successful commissioning.
Note the following information about connecting the data communication cable to the inverter.
Use cables of type CAT5 or higher.
Use a mutual twisted cable pair for data lines that belong together (D+, D- and M1+, M1-).
If the output cables are close to the mains cabling, use wires or cables that are designed for 300 V to 600 V (never less than the operating voltage).
Use double-insulated or sheathed output cables when they are close to bare conductors.
Use shielded twisted pair cables to avoid faults.
The outputs of the Fronius Smart Meter are electrically isolated from hazardous voltages.
Inverter in the system | |
Meter - Fronius Smart Meter | |
Modbus RTU slave | |
Terminating resistor |
Due to interference, it is recommended that terminating resistors are used as illustrated below to ensure proper functioning.
* The terminating resistor on Fronius Smart Meters is installed between 33 and 34. The terminating resistor R 120 Ohm is included with the Fronius Smart Meter.
Only the transformation ratio of the current and voltage transformers must be set. All other parameters have already been set in advance.
Password (0001):
Transformation ratio of the current transformers1) (0001 - 99992)):
Transformation ratio of the voltage transformers1), 3) (001.0 - 500.02)):
Change password and write it down4):
1) IMPORTANT! Changing the transformation ratios will reset the meter data in the Fronius Smart Meter to 0.
2) Transformation ratio in the current transformer x Transformation ratio of the voltage transformers = max. 1,000,000.
3) Changeover only when using voltage transformers (direct voltage measurement Vt = 1).
4) IMPORTANT! The password cannot be reset.
Grid | |
Utility meter | |
Primary meter | |
Secondary meter | |
Producer meter | |
Loads in the system | |
Additional loads in the system | |
Additional producers in the system | |
A maximum of 4 Modbus participants can be connected to the Modbus terminal.
IMPORTANT!
Only one primary meter, one battery and one Ohmpilot can be connected per inverter. Due to the high data transfer of the battery, the battery occupies 2 participants.
Example:
Input | Battery | Fronius | Quantity | Quantity |
Modbus | 1 | 0 | ||
1 | 1 | |||
1 | 2 | |||
1 | 3 |
If several Fronius Smart Meters are installed, a separate address must be set for each one (see Setting the address of the Fronius Smart Meter on page (→)). The primary meter is always assigned address 1. All the other meters are numbered consecutively with the address range from 2 to 14. Different Fronius Smart Meter power categories can be used in combination.
IMPORTANT!
Use max. 3 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to chapter Terminating resistors on page (→).
The inputs M0 and M1 can be selected for this purpose. A maximum of 4 Modbus participants can be connected to the Modbus terminal on inputs M0 and M1.
IMPORTANT!
Example 1:
Modbus 0 | 0 | 4 | ||
0 | 2 | |||
0 | 1 | |||
Modbus 1 | 1 | 3 |
Example 2:
Modbus 0 | 1 | 3 | ||
Modbus 1 | 0 | 4 | ||
0 | 2 | |||
0 | 1 |
IMPORTANT!
Use max. 7 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to chapter Terminating resistors on page (→).
A graphic view of the menu structure can be found in the User Information that is supplied as standard.
Symbol | Name | Event | Function |
Prog | 1 x | Increases the set value | |
Page | 1 x | Moves the cursor | |
Enter | 1 x | Confirms the entry |
Only configure the menu items "Password" and "Address".
The parameter „Node A“ is preset and must not be changed.
Page | 1 x | Continue to the next screen | |
Page | 5 seconds | Reset value / change menu |
The following illustrations are symbolic representations. The values displayed vary for each individual unit.
Display | Description |
Total active energy consumed | |
Total reactive energy | |
Total active energy produced Press arrow key for 5 seconds to reset the value | |
Partial reactive energy Press arrow key for 5 seconds to reset the value | |
Maximum effective power average value Press arrow key for 5 seconds to reset the value | |
Effective power average value | |
Voltage and current menu Press the arrow key and wait 2 seconds until the next display (current phase L1) appears. | |
Current phase L1 | |
Current phase L2 | |
Current phase L3 | |
Chained voltage phase L1-L2 | |
Chained voltage phase L2-L3 | |
Chained voltage phase L1-L3 | |
Effective power | |
Reactive power | |
Apparent power |
IMPORTANT! Settings under the "Meter" menu item are only to be made by trained and qualified personnel!
The service password must be entered in order to access the "Meter" menu item.
Three-phase or single-phase Fronius Smart Meters can be used. In both cases, the selection is made under the "Fronius Smart Meter" item. The Fronius Datamanager automatically identifies the meter type.
A primary meter and several secondary meters can be selected. The primary meter needs to be configured first before a secondary meter can be selected.
Access point:
The Fronius Datamanager start page is displayed.
LAN:
The Fronius Smart Meter is configured as a primary meter.
The "Current general view" menu area displays the power of the PV modules, self-consumption, the energy fed into the grid and the battery charge (if available).
The Fronius Smart Meter is configured as a secondary meter.
IMPORTANT! Settings under the "Device configuration" menu item are only to be made by trained and qualified personnel!
The technician password must be entered in order to access the "Device configuration" menu item.
Three-phase or single-phase Fronius Smart Meters can be used. In both cases, the selection is made under the "Components" menu area. The meter type is determined automatically.
WLAN:
The network wizard and the product setup can be carried out independently of each other. A network connection is required for the Solar.web installation wizard.
Ethernet:
Modbus transmission speed: 9600 baud
Parity bit: None
Software version: Datamanager 3.7.2 / Energypackage 1.3.3
Input | |
Three-phase nominal voltage | 400 - 415 V |
Single-phase nominal voltage | 230 - 240 V |
Voltage transformer ratio (kVT) | 1...1500.0 |
Self-consumption - voltage path (max. voltage) | 4.5 VA (1.85 W) for 440 V |
Nominal frequency | 50 - 60 Hz |
Nominal current, lb | 1 A + 5 A |
Maximum current, Imax | 6 A |
Starting current | 20 mA |
Current transformer ratio (kCT) | 1...9,999 |
Short-time overload (EN/IEC 62053-21, EN/IEC 62053-23) | 20 lmax / 0.5 s |
Self-consumption - current path (max. current) | 0.3 W for phase |
Maximum value kVT x kCT | 5,000,000 (CT/1A) or 1,000,000 (CT/5A) |
Current distortion factor | In acc. with EN/IEC 62053-21 |
Power factor | Active cosφ 0.5 ind to 0.8 cap, |
Energy | |
Max. display | As per table |
Resolution | As per table |
LED indicator | 1 pulse / 0.1 Wh |
Active energy accuracy | Class 1 |
Reactive energy accuracy | Class 2 |
Response time after switch-on | < 5 s |
kCT x kVT | Maximum display |
| Resolution |
1 to 9.9 | 9 9 9 9 9 9 . 9 9 | kWh / kvarh | 10 Wh / varh |
10 to 99.9 | 9 9 9 9 9 9 9 . 9 | kWh / kvarh | 100 Wh / varh |
100 to 999.9 | 9 9 9 9 9 9 9 9 | kWh / kvarh | 1 kWh / varh |
1000 to 9999.9 | 9 9 9 9 9 9 . 9 9 | MWh / kvarh | 10 kWh / varh |
≥ 10000 | 9 9 9 9 9 9 9 . 9 | MWh / kvarh | 100 kWh / varh |
Average power | |
Measured variable | Effective power |
Calculation | Average value over set period of time |
Integration time | 5 / 8 / 10 / 15 / 20 / 30 / 60 minutes |
Operating hours counter | |
Operating hours counter | Hours and minutes |
Resolution | 7-digit (5 hours + 2 minutes) |
Max. display | 99,999 h 59 min |
Counting start | 3-phase effective power |
Programmable values | 0.10 to 50% Pn |
3-phase effective power | In acc. with 400 V 5 A - 3464 W |
Operating hours counter reset | Accessible via keypad or locked |
Output | |
Energy pulse | |
Contact load | 110 V DC/AC - 50 mA |
Assignable energy | Active or reactive energy |
Pulse value | 10 Wh (Varh) - 100 Wh (Varh) - 1 kWh (kVarh) - 10 kWh (kVarh) - 100 kWh (kVarh) - 1000 kWh (kVarh) |
Pulse duration | 50 - 100 - 150 - 200 - 300 - 400 - 500 ms |
RS485 communication | |
Standard | RS485 - 3 conductors |
Transmission | Serial, asynchronous |
Protocol | Modbus RTU |
Addresses | 1 to 255 |
Number of bits | 8 |
Stop bit | 1 |
Parity bit | None - even - odd |
Baud rate | 4800 - 9600 - 19200 bit/s |
Response time | ≤ 200 ms |
Insulation (EN/IEC 62052-11, 62053-21) | |
Installation category | III |
Pollution level | 2 |
Insulation voltage | 300 V phase-neutral |
Impulse withstand voltage | 5 kV 1.2/60 µs |
Test voltage | 2.75 kV r.m.s. 50 Hz / 1 min |
Test voltage | 4 kV r.m.s. 50 Hz / 1 min |
Electromagnetic compatibility | |
Test in acc. with EN/IEC 62052-11 |
Operating conditions | |
Reference temperature | 23 °C (±2 °C) |
Operating range | -5 to 55 °C |
Temperature limit for storage and transport | -25 to 70 °C |
Tropical model |
Max. power loss (for thermal dimensioning of the switch cabinet) | ≤ 2.8 W |
Housing | |
Housing | 4 modules according to DIN 43880 |
Sealable front and terminal cover |
Connection | Screw connection |
Mounting | Can be snapped onto 35 mm DIN rail |
Housing material | Polycarbonate, self-extinguishing |
Degree of protection (EN 60529) | IP54 front, IP20 connections |
Weight | 260 grams |
Screw terminals | |
Measuring input | |
Wire (rigid) | Min. 0.05 mm² / max. 4 mm² |
Wire (flexible) | Min. 0.05 mm² / max. 2.5 mm² |
Recommended torque | 0.5 Nm / max. 0.8 Nm |
Output | |
Parity bit: None
Input | |
Energy | |
| Resolution |
Average power | |
Output | |
Energy pulse | |
Stop bit | 1 |
Tropical model |
Housing | |
Screw terminals | |
Measuring input | |
Output | |
Detailed, country-specific warranty terms are available on the internet:
www.fronius.com/solar/warranty
To obtain the full warranty period for your newly installed Fronius inverter or storage system, please register at: www.solarweb.com.
