Danger from crushing due to the incorrect handling of attachments and connection parts.
Injuries to limbs may result.
Use the integrated grips when lifting up, putting down, and attaching the inverter.
When fitting attachments, ensure that no limbs are located between the attachment and the inverter.
Do not hold on to the individual poles on the terminals when locking and unlocking.
Warnings are intended to warn people of possible injuries and to avoid personal injury and damage to the product. They relate to individual actions with and on the product.
Indicates an immediately dangerous situation.
Serious injury or death will result if the danger is not avoided.
Action step to escape the situation.
Serious injury or death may result if the danger is not avoided.
Minor or moderate injury may result if the danger is not avoided.
Indicates a situation that may result in property damage.
If the situation is not avoided, impaired work results, material damage to the product or other property are the possible consequences.
Action step to avoid the situation.
Safety instructions are designed to ensure safe product use. They are preventive and help to inform users about the fundamental risks involved when dealing with the product. They do not refer specifically to individual actions with and on the product.
Incorrect operation or misuse
IMPORTANT!
Tampered-with and non-functioning protection devices
The device may be damaged
Operation or storage of the machine outside the stipulated area will be deemed as not in accordance with the intended purpose.
For exact information on permitted environmental conditions, please refer to the technical data.
During operation, due to the high electrical voltages and currents, local electromagnetic fields (EMF) are generated. These occur in the immediate vicinity of the inverter and the Fronius system components. Electromagnetic fields are also present in the area of the PV modules and their supply lines.
As long as the intended use and a minimum distance of 20 cm are observed, all limit values for human exposure are observed.
If the limit values are complied with, according to current scientific knowledge, no negative health effects from EMF exposure are to be expected. For persons with prostheses1) or active physical aids2), there is a possible health risk in the vicinity of photovoltaic system components. To avoid possible health risks, consult with the responsible doctor.
1) e.g., implants or metal parts
2) e.g., pacemaker, insulin pump, hearing aid, etc.
This system has backup power functions. A backup power supply can be established in the event of a failure in the public grid.
If an automatic backup power supply is installed, attach the backup power supply warning notice (https://www.fronius.com/en/solar-energy/installers-partners/downloads?searchword=42,0409,0275) to the electrical distributor.
Danger due to electrical voltage on live parts of the PV system
Depending on the irradiance conditions and the battery state of charge, the backup power supply is automatically deactivated and activated. This can cause the backup power supply to unexpectedly return from standby mode. This can result in serious personal injury and damage to property.
Disconnect the inverter on the network side before performing maintenance and installation work in the home network.
Set the integrated DC disconnector on the inverter to the "Off" switch position to end the backup power supply.
Test the function of the residual current devices for the backup power supply at least every 6 months.
A description of how to run the test mode can be found in the backup power checklist (https://www.fronius.com/en/solar-energy/installers-partners/downloads?searchword=42,0426,0365).
Influencing factors on the total output in backup power mode:
Reactive power
Electrical loads with a power factor not equal to 1 require active power as well as reactive power. The reactive power places a further load on the inverter. Use the current resulting from the active and reactive power for the correct calculation of the total power. The rated power of the loads is not relevant.
Devices with a high reactive power are mainly electric motors, such as:
High starting/start-up current
Electrical loads that need to accelerate a large mass generally require a high starting/start-up current. This can be up to ten times the nominal current. The maximum current of the inverter is available for the starting/start-up current. Loads with too high a starting/start-up current cannot, therefore, be started/operated, even though the nominal power of the inverter suggests otherwise. Therefore, consider the connected load power and the starting/start-up current when sizing the backup power circuit.
Devices with a high starting/start-up current include:
IMPORTANT!
Very high start-up currents can temporarily distort or interrupt the output voltage. Avoid simultaneous operation of electronic devices in the same backup power circuit.
Unbalanced load
When dimensioning three-phase backup power circuits, consider the total output power and the powers per phase of the inverter.
IMPORTANT!
Only operate the inverter within the limits of its technical capabilities. Operation outside of its technical capabilities can cause the inverter to shut down.
Connection of a point in the device, system, or installation to ground to protect against electric shock in the event of a fault. When installing an inverter from safety class 1 (see Technical data), a ground conductor connection is required.
When connecting the ground conductor, ensure that it is secured to prevent unintentional disconnection. All of the points listed in the chapter headed Connecting the inverter to the public grid (AC side) on page (→) must be observed. When using cable glands, ensure that the ground conductor is last to be subjected to a load in the event of a failure of the cable gland. The respective national standards and regulations and requirements for minimum cross-section must be observed when connecting the ground conductor.
The inverter offers the option to use the integrated AC relays as section switches in conjunction with a central grid and system protection unit (in accordance with VDE-AR-N 4105:2018:11 §6.4.1). For this purpose, the central trigger device (switch) must be integrated into the WSD chain as described in chapter WSD (wired shutdown) on page (→).
The wired shutdown (WSD) interrupts the inverter's grid power feed if the trigger device (switch, e.g., Emergency Stop or fire alarm contact) has been activated.
If an inverter (slave) fails, it is bypassed and the other inverters continue operating. If a second inverter (slave) or the inverter (master) fails, the operation of the entire WSD chain is interrupted.
For installation, see Installing the WSD (wired shutdown) on page (→).
The inverter is equipped with an RCMU (RCMU = residual current monitoring unit) according to IEC 62109-2 and IEC63112.
It monitors residual currents from the PV module up to the AC output and disconnects the inverter from the grid when an improper residual current is detected.
In the case of photovoltaic systems with ungrounded PV modules, the inverter checks the resistance between the positive or negative pole of the photovoltaic system and the ground potential before starting grid power feed operation. In the event of a short circuit between the DC+ or DC- cable and ground (e.g., due to inadequately insulated DC cables or defective PV modules), feeding into the public grid is prevented.
An AFCI (Arc Fault Circuit Interrupter) protects against arc faults and is a protective device in the event of contact errors. The Arc Fault Circuit Interrupter monitors faults that occur in the current and voltage flow on the DC side and shuts down the circuit with an electronic circuit if a contact error is detected. The function prevents overheating at poor contact points and, ideally, possible fires. In the Technical data chapter, check whether the Arc Fault Circuit Interrupter is available for the device in question.
Faulty or incorrect DC installation
Arcs lead to prohibited thermal loads on the DC installation. There is a risk of fire. This may result in injury and damage to the inverter and the components of the photovoltaic system.
Check the plug connections to ensure that they are correct.
Repair faulty insulation correctly.
Perform connection work in line with the instructions.
IMPORTANT!
Fronius will not bear any costs that may arise due to a detected electric arc and its consequences. Fronius accepts no liability for damage which may occur despite the integrated Arc Fault Circuit Interrupter/interruption (e.g., due to a parallel arc).
IMPORTANT!
Active PV module electronics (e.g., power optimizers) can impair the function of the Arc Fault Circuit Interrupter. Fronius cannot guarantee the correct function of the Arc Fault Circuit Interrupter in combination with active PV module electronics.
Reconnection behavior
Grid power feed operation is interrupted for at least 5 minutes after an arc has been detected. Depending on the configuration, grid power feed operation is then automatically resumed. If several arcs occur within a period of 24 hours, grid power feed operation will remain interrupted until a manual reconnection is performed.
In the safe state, the inverter infeed is deactivated and is disconnected from the grid by the AC relay opening. The inverter switches to the safe state when the following events occur:
Technical data, warning notices, labels, and safety symbols are located on the inverter. This information must be kept in a legible condition and must not be removed, covered, pasted over, or painted over. The notices and safety symbols warn against incorrect operation, which may result in serious injury and property damage.
Symbols on the rating plate: | |
CE label – confirms compliance with applicable EU directives and regulations. | |
UKCA marking – confirms compliance with applicable UK directives and regulations. | |
WEEE marking – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law. | |
RCM marking – tested according to the requirements of Australia and New Zealand. | |
ICASA marking – tested according to the requirements of the Independent Communications Authority of South Africa. | |
CMIM marking – tested according to IMANOR requirements for import regulations and compliance with Moroccan standards. | |
Safety symbols: | |
Integrated switch disconnector on the input side of the inverter with switch-on, switch-off, and isolating function according to IEC 60947-3 and AS 60947.3. The values required by the applicable standard for Ithe solar +60°C are given. | |
Risk of serious injury and property damage due to incorrect operation. | |
Dangerous electrical voltage. | |
Allow the capacitors of the inverter to discharge (2 minutes). | |
Warning notice text:
WARNING!
An electric shock can be fatal. Before opening the device, ensure that the input and output sides are de-energized and disconnected.
Safety symbols: | |
WARNING!
Application notes
Software
Example: Click Save.
Instructions for action
This document provides detailed information and instructions to ensure that people can use the machine safely and efficiently.
The information is intended for the following groups of people:Regardless of any qualifications, only perform the activities listed in this document.
The definition of professional qualifications and their applicability are subject to national law.
When you connect your device (and any associated devices) to the internet, the following device and operating data (device ID/identifier, device IP address, device time, configuration settings, hardware and software information, device status log files, serial number) is sent automatically to
Fronius International GmbH, Froniusstraße 1, 4643 Pettenbach, Austria, telephone +43(0) 7242241-0, email: contact@fronius.com (controller)
and stored.
The processing of this device and operating data is carried out for the purpose of ensuring the operational safety of the device (time synchronization, provision of updates). This processing is therefore necessary for the functionality of the device and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
If you do not wish to have such data processed, you must manually disable the device's internet connection.
In addition, the device and operating data is also processed for the purpose of providing services as part of a supplementary digital service for your device (such as solar.web or similar) as soon as you have registered your device with such a digital service (identification). This data is processed to provide the requested digital services and is therefore necessary for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
Furthermore, this data processing is also carried out for maintenance and support purposes and for handling customer concerns as well as in warranty and guarantee cases (only in individual cases and given connection between device and internet). In this context, the device and operating data may also be passed on to our cooperation partners (third-party providers and suppliers). The processing of this data is necessary for maintenance and support purposes or for processing warranty and guarantee cases and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
Device and operating data are also processed for analysis and diagnostic purposes in order to gain insights into the functionality of the devices and improve them accordingly. This data processing is based on our legitimate interest (Art. 6 (1) (f) GDPR).
We store this data for as long as it is necessary to fulfill the existing contract with you. Any storage beyond this is carried out for legal reasons or if we have a legitimate interest in doing so. For more information on data processing for the solar.web-digital service, as well as our general privacy policy and your rights as a data subject, please visit https://www.fronius.com.
The inverter transforms the direct current generated by the PV modules into alternating current. This alternating current is fed into the public grid and synchronized with the mains voltage in use. Moreover, the solar energy can also be stored in a connected battery for later use.
The inverter is intended for use in grid-connected photovoltaic systems. The inverter has backup power functions and switches to backup power mode if it has been wired accordingly*.
The inverter automatically monitors the public grid. Whenever conditions in the electric grid are inconsistent with standard conditions (e.g., grid switch-off, interruption), the inverter will immediately stop producing power and interrupt the supply of power into the grid.
The grid is monitored by monitoring the voltage, frequency, and islanding conditions.
After installation and commissioning, the inverter's operation is fully automatic; the inverter draws the maximum possible power from the solar modules.
Depending on the operating point, this power is used in the home, stored in a battery*, or fed into the grid.
As soon as the energy provided by the solar modules is no longer sufficient, the power from the battery is fed into the home network. Depending on the setting, power may also be obtained from the public grid in order to charge the battery*.
When its temperature gets too high, the inverter automatically reduces the output or charging power, or switches off completely, in order to protect itself.
Reasons for the temperature being too high include a high ambient temperature or insufficient heat dissipation (for example, inadequate heat dissipation when installed in switch cabinets).
| * | Depending on the device variant, suitable battery, corresponding cabling, settings, and local standards and regulations. |
Function | Symo GEN24/Symo GEN24 SC | Symo GEN24 Plus/Symo GEN24 Plus SC |
Backup power variant - PV Point (OP) | ||
Battery connection* | optionally available** | |
Backup power variant - Full Backup | optionally available** |
| * | For suitable batteries, see chapter Suitable batteries. |
| ** | The functions are optionally available via Fronius UP (see chapter Fronius UP). |
With Fronius UP*, optionally available functions can be added to the inverter by the authorized specialist company (see chapter Function overview).
| * | The availability of Fronius UP is country-specific. Click here for further information on availability. |
| (1) | Housing cover |
| (2) | Inverter |
| (3) | Mounting bracket (illustration) |
| (4) | Quick Start Guide |
| (5) | 2 ferrite rings with holder |
The inverter is designed to convert direct current from PV modules into alternating current and feed this power into the public grid. A backup power mode* is possible if the wiring is set up accordingly.
Intended use also means:Follow all grid operator regulations regarding energy fed into the grid and connection methods.
The inverter is a grid-connected inverter with backup power function and is not a stand-alone inverter. The following restrictions in backup power mode must therefore be observed:| * | Depending on the device variant, suitable battery, corresponding cabling, settings, and local standards and regulations. |
Ambient air is drawn in at the front of the device by the fan and blown out at the sides. The even heat dissipation allows several inverters to be installed next to each another.
Risk due to insufficient cooling of the inverter.
This may result in a loss of power in the inverter.
Do not block the fan (e.g., with objects that protrude through the touch guard).
Do not cover the ventilation slots, even partially.
Make sure that the ambient air can always flow through the inverter's ventilation slots unimpeded.
System owners and installers can easily monitor and analyze the PV system using Fronius Solar.web or Fronius Solar.web Premium. With the appropriate configuration, the inverter transmits data such as power, yield, load, and energy balance to Fronius Solar.web. More detailed information can be found at Solar.web - Monitoring & analysis.
Configuration is carried out via the Setup wizard, see chapter Installation with the app or Installation with the browser.
Requirements for configuration:| * | These specifications do not provide an absolute guarantee of flawless operation. High error rates in the transmission, fluctuating receptions or misfires can have an adverse effect on data transfer. Fronius recommends on-site testing to ensure that the connections meet the minimum requirements. |
The inverter can be found via the Multicast DNS (mDNS) protocol. We recommend searching for the inverter using the assigned host name.
The following data can be called up via mDNS:PV module | ||
Fronius GEN24 inverter | ||
Additional inverter in the system | ||
Battery | ||
Fronius Ohmpilot | ||
Primary meter | ||
Secondary meter | ||
Loads in the system | ||
Additional loads and producers in the system | ||
PV Point | ||
Full Backup | ||
Grid | ||
PV module | ||
Battery | ||
Primary meter | ||
PV Point | ||
Full Backup | ||
Grid | ||
In order to be able to obtain the highest rate of self-consumption with your photovoltaic system, a battery can be used to store excess energy. The battery is coupled to the inverter on the direct current side. Multiple current conversion is therefore not required, and the efficiency is increased.
IMPORTANT!
In backup power mode, an increased nominal frequency is used in order to prevent undesired parallel operation with other power generators.
IMPORTANT!
In the fully equipped hybrid PV system with a Fronius Ohmpilot, the Ohmpilot cannot be operated in the event of a power failure for regulatory reasons. It is therefore sensible to install the Ohmpilot outside of the backup power branch.
In the hybrid PV system, batteries may only be connected to an inverter with battery support. Batteries cannot be split between multiple inverters with battery support. Depending on the battery manufacturer, however, several batteries can be combined on one inverter.
| (1) | PV module – inverter – load/grid/battery |
| (2) | Battery – inverter – load/grid* |
| (3) | Grid – inverter – load/battery* |
* Charging the battery from the public grid depends on the settings and local standards and regulations.
Battery systems distinguish between different operating states. In each case, the relevant current operating state is displayed on the user interface of the inverter or in Fronius Solar.web.
Operating state | Description |
Normal operation | The energy is stored or drawn, as required. |
Min. state of charge (SoC) reached | The battery has reached the minimum SoC specified by the manufacturer or the set minimum SoC. The battery cannot be discharged further. |
Energy saving mode (standby) | The system has been put into energy-saving mode. Energy saving mode is automatically ended as soon as sufficient surplus power is available again. |
Start | The battery system starts from energy-saving mode (standby). |
Forced re-charging | The inverter recharges the battery, in order to maintain the SoC specified by the manufacturer or the set minimum SoC (protection against deep discharge). |
Calibration charging | The battery system is charged to the SoC of 100% and then discharged to the SoC of 0%. After 1 hour of waiting time at SoC 0%, the calibration charge is stopped and the battery switches to normal operation. |
Service mode | The battery system is charged or discharged to the SoC of 30% and the SoC of 30% is maintained until the end of the service mode. |
Deactivated | The battery is not active. It has either been deactivated, switched off, or the communication between the battery and the inverter has been interrupted. |
Energy saving mode (standby mode) is used to reduce the self-consumption of the system. Both the inverter and the battery automatically switch to energy saving mode under certain conditions.
The inverter switches to energy saving mode if the battery is flat and no PV power is available. Only the inverter's communication with the Fronius Smart Meter and Fronius Solar.web is maintained.
If all the switch-off conditions are met, the battery switches into energy saving mode within ten minutes. This time delay ensures that the inverter can at least be restarted.
| The battery state of charge is less than or equal to the input minimum state of charge. | |
| The current charging or discharging power of the battery is less than 100 W. | |
| Less than 50 W is available for charging the battery. The power of feeding into the public grid is at least 50 W less than the power currently required in the home network. |
The inverter automatically switches into energy saving mode, following the battery.
If the inverter does not operate for 12 minutes (e.g., fault), or there is an interruption in the electrical connection between the inverter and the battery and there is no backup power mode, the battery switches to energy-saving mode in any case. This reduces self discharge of the battery.
| Energy saving mode is shown on the user interface of the inverter and in Solar.web by an "i" beside the battery symbol in the system overview. |
Fronius explicitly points out that the third-party batteries are not Fronius products. Fronius is not the manufacturer, distributor, or retailer of these batteries. Fronius accepts no liability and offers no service or guarantees for these batteries.
Read this document and the Installation Instructions before installing and commissioning the external battery. The documentation is either enclosed with the external battery or can be obtained from the battery manufacturer or their service partners
All documents associated with the inverter can be found at the following address:
Fronius Reserva | |
Capacity [kWh] | 6.3 - 15.8 |
Number of modules | 2 - 5 |
Fronius Symo GEN24/Symo GEN24 SC1) | |
Fronius Symo GEN24 Plus/Symo GEN24 Plus SC | |
Battery parallel operation2) | |
Fronius Reserva Pro | |
Capacity [kWh] | 12.0 - 32.0 |
Number of modules | 3 - 8 |
| 1) | Battery support optionally available. |
| 2) | Max. 4 batteries with the same capacity can be combined. |
BYD Battery-Box Premium HVS BYD Battery-Box HVS+ | |
Capacity [kWh]1) | 5.1 - 12.8 |
Fronius Symo GEN24/Symo GEN24 SC2) | |
Battery parallel operation3) | |
BYD Battery-Box Premium HVM BYD Battery-Box HVM+ | ||
Capacity [kWh] | 8.3 | 11.0 - 22.1 |
Number of modules | 3 | 4 - 8 |
Fronius Symo GEN24/Symo GEN24 SC2) | ||
Fronius Symo GEN24 Plus/Symo GEN24 Plus SC | ||
Battery parallel operation3) | ||
| 1) | The capacity of 12.8 kWh is not approved and certified for Italy. |
| 2) | Battery support optionally available. |
| 3) | Max. 3 batteries with the same capacity can be combined. With BYD Battery-Box Premium HVM 22.1 max. 2 batteries can be combined. |
IMPORTANT!
See the battery manufacturer's documentation for the maximum DC cable length.
Switch on the battery.
Turn on the automatic circuit breaker. Set the DC disconnector to the "on" switch position.
LG FLEX | 8.6 | 12.9 | 17.2 |
Number of battery modules | 2 | 3 | 4 |
Fronius Symo GEN24/Symo GEN24 SC* | |||
| * | Battery support is optionally available. |
To assemble the battery, perform the steps listed above in reverse order.
There is no energy available from the PV modules or from the public grid. If backup power operation or battery operation are not possible (e.g., deep discharge protection of the battery), the inverter and battery switch off.
Status codes about the inactive state of the battery are displayed on the user interface of the inverter. A notification via e-mail can be activated in Fronius Solar.web.
As soon as energy is available again, the inverter starts operation automatically; however, the battery must be started manually. The switch-on sequence must be observed for this, see chapter Suitable batteries on page (→).
The inverter requires energy from the battery to start backup power operation. This is done manually on the battery; further information on the power supply for restarting the inverter via the battery can be found in the battery manufacturer's Operating Instructions.
| (1) | 2 x 4-pin DC push-in terminal |
| (2) | Push-in WSD (wired shutdown) terminal |
| (3) | Push-in terminals in the data communication area (Modbus, digital inputs and outputs) |
| (4) | 3-pin push-in terminal for PV Point (OP) |
| (5) | 5-pin AC push-in terminal |
| (6) | Cable gland/cable connection AC |
| (7) | 6-pin ground electrode terminal |
| (8) | Data communication area cable gland/cable connection |
| (9) | Connection area divider |
| (10) | 10 x DC glands |
| (11) | Optional cable gland (M16) |
| (12) | Optional cable gland (M16 - M20) |
| (13) | Optional cable gland (M16 - M32) |
| (14) | Optional cable gland (M16 - M25) |
The connection area divider separates the high-voltage conductors (DC and AC) from the signal lines. To make it easier to reach the connection area, the divider can be removed for the connection work, and must be re-inserted.
| (1) | Integrated cable duct |
| (2) | Recesses for removing the connection area divider |
| (3) | Snap tabs for locking/unlocking |
| (4) | Defined breaking point for the DatCom connection |
The integrated cable duct (1) allows for the lines to be laid from one area of the inverter to the other. As a result, multiple inverters can be easily installed next to each other.
The ground electrode terminal provides the option of grounding additional components, such as:
The DC disconnector has 3 switch settings:
| (1) | Locked/off (turned to the left) |
| (2) | Off |
| (3) | On |
IMPORTANT!
In switch settings (1) and (3), the inverter can be secured to prevent it from being switched on/off using a standard padlock. The national guidelines must be complied with in this respect.
| Indicates the inverter operating status. |
BAT switch | Position 1: Setting for connecting compatible batteries (factory setting) |
WSD (wired shutdown) switch | Defines the inverter as the WSD master or WSD secondary device. |
Modbus 0 (MB0) switch | Switches the terminating resistor for Modbus 0 (MB0) on/off. |
Modbus 1 (MB1) switch | Switches the terminating resistor for Modbus 1 (MB1) on/off. |
| For operating the inverter. See Button functions and LED status indicator. |
| Indicates the inverter connection status. |
Battery Connection (Modbus RJ45) | Modbus connection for connecting a compatible battery. IMPORTANT!
LAN 1 | Ethernet connection for data communication (e.g., WiFi router, home network) or, for commissioning with a laptop, see Installation with the browser. |
LAN 2 | Reserved for future functions. |
I/O terminal | Push-in terminal for digital inputs/outputs. See Permitted cables for the data communication connection. |
WSD terminal | Push-in terminal for the WSD installation. See WSD (wired shutdown). |
Modbus terminal | Push-in terminal for the installation of Modbus 0, Modbus 1, 12 V, and GND (ground). |
The operating LED indicates the inverter status. In case of faults, follow the individual steps in the Fronius Solar.start app. | |
Actuate the optical sensor by touching it with a finger. | |
The communication LED indicates the status of the connection. To establish a connection, follow the individual steps in the Fronius Solar.start app. |
Sensor functions | ||
1x | ||
2x | ||
3 seconds | ||
LED status indicator | ||
The inverter is operating correctly. | ||
The inverter is performing the grid checks required by the applicable standards for grid power feed operation. | ||
The inverter is on standby, is not operating (e.g., no energy fed into the grid at night), or is not configured. | ||
The inverter displays an error. The inverter is operating correctly. | ||
The inverter displays a critical status and no energy is fed into the grid. | ||
The inverter displays a backup power overload. | ||
The network connection is being established via WPS. | ||
The network connection is being established via WiFi AP. | ||
The network connection is not configured. | ||
There is a network error, the inverter is operating correctly. | ||
The network connection is active. | ||
The inverter is performing an update. | ||
There is a service message. | ||
The V+/ GND pin provides the possibility of feeding in a voltage in the range of 12.5 to 24 V (+ max. 20%) using an external power supply unit. Outputs IO 0 - 5 can then be operated using the external voltage that has been fed in. A maximum of 1 A may be drawn per output, whereby a total of max. 3 A is permitted. The fuse protection must take place externally.
Danger from polarity reversal at the terminals due to improper connection of external power supply units.
This may result in severe damage to the inverter.
Check the polarity of the external power supply unit with a suitable measuring device before connecting it.
Connect the cables to the V+/GND outputs while ensuring the correct polarity.
IMPORTANT!
If the total output (6 W) is exceeded, the inverter switches off the entire external power supply.
| (1) | Current limitation |
IMPORTANT!
If several backup power variants are available, please note that only one backup power variant may be installed and configured.
The inverter can provide 220‑240 V at the PV Point/PV Point Comfort. A corresponding configuration must be set up during commissioning.
At 220‑240 V output voltage, max. 13 A AC continuous current is available.
Example:
220 V *13 A = 2,860 W
230 V *13 A = max. 3 kW
In backup power mode, some electrical appliances cannot function properly as starting currents are too high (for example, fridges and freezers). It is recommended to switch off non-essential loads during backup power mode. Overload capacity of 35% is possible for a duration of 5 seconds, depending on the capacity of the PV modules and/or the battery at that moment in time.
There is a brief interruption when switching from grid-connected mode to backup power mode. For this reason, the backup power function cannot be used as an uninterruptible power supply, for example for computers.
If no energy from the battery or the PV modules is available in backup power mode, backup power mode ends automatically. If sufficient energy becomes available from the PV modules once again, backup power mode starts again automatically.
In the event of excessive consumption, backup power mode is stopped and the "backup power overload" status code is displayed on the inverter's LED status indicator (see Button functions and LED status indicator on page (→)). The maximum power in backup power mode according to the technical data must be observed.
IMPORTANT!
Example:
IMPORTANT!
Example:
With the PV Point, in the event of a failure of the public grid, 1‑phase electrical devices can be connected to the Opportunity Power (OP) terminal and supplied with a maximum power of 3 kW, if enough power is available in the solar modules or an optional battery. In grid connected operation, the OP terminal is not supplied with voltage, therefore the connected loads will not be permanently supplied with power.
IMPORTANT!
A grid switchover with relay is not possible.
For the installation instructions, see chapter Connecting backup power - PV Point (OP) on page (→).
With the PV Point Comfort, 1-phase electrical devices are permanently supplied with a maximum power of 3 kW.
Switching between grid connected and backup power mode takes place automatically. In the event of a failure of the public grid or the inverter, the PV Point Comfort permanently supplies connected loads. When the grid becomes available again and stability is ensured, the PV Point Comfort automatically switches to grid connected mode and backup power mode is terminated.
IMPORTANT!
Backup power mode requires sufficient power from the PV modules or a battery. The PV Point Comfort is not available in Australia and New Zealand.
For further information and the installation instructions, see chapter PV Point Comfort on page (→).
IMPORTANT!
If several backup power variants are available, it is important to note that only one backup power variant may be installed and configured.
IMPORTANT!
IMPORTANT!
IMPORTANT!
Depending on the installation, the entire house or only selected circuits are supplied with backup power if the public grid fails. The total load of the backup power circuits must not exceed the rated power of the inverter. Note the capacity of the connected battery.
IMPORTANT!
Parallel Backup enables synchronized backup power mode for several inverters. An inverter with connected battery operates as a primary inverter (parallel backup coordinator). The primary inverter controls a maximum of four secondary inverters in the system (parallel backup supporters). After release by the parallel backup coordinator, the parallel backup supporters feed additional available PV power into the backup power circuit. In the event of backup power, this helps to cover the power demand and charge the battery on the primary inverter.
For the configuration of Parallel Backup on the primary inverter or on the secondary inverters and for the I/O cable extension when using Parallel Backup, see Functions and I/Os.
The primary inverter:IMPORTANT!
Depending on the installation, the entire house or only selected circuits are supplied with backup power if the public grid fails. The total load of the backup power circuits must not exceed the rated power of the inverter. Note the capacity of the connected battery. When using the Fronius Backup Controller 3PN-35A, the data communication area may be loaded with additional loads up to max. 3 W.
IMPORTANT!
Danger when using a drill driver.
This may result in the destruction of the quick-fastener system due to overtorque.
Use a screwdriver (TX20).
Do not turn the screws more than 180°.
A quick-fastener system (3) is used to mount the connection area cover and front cover. The system is opened and closed with a half-rotation (180°) of the captive screw (1) into the quick-fastener spring (2).
The system is independent of torque.
All installed components in the PV system must be compatible with each other and have the necessary configuration options. The installed components must not restrict or negatively affect the functioning of the PV system.
Risk due to components in the PV system that are not and/or only partially compatible.
Incompatible components can restrict and/or negatively affect the operation and/or functioning of the PV system.
Only install components recommended by the manufacturer in the PV system.
Before installation, check the compatibility of components that have not been expressly recommended with the manufacturer.
Please observe the following criteria when choosing a location for the inverter:
| Only install on a solid, non-flammable surface. | |
| Max. ambient temperatures: | |
| Relative humidity: | |
| When installing the inverter in a switch cabinet or similar closed environment, it is necessary to make sure that the hot air that develops will be dissipated by forced-air ventilation. | |
When installing the inverter on the outer walls of cattle sheds, it is important to maintain a minimum clearance of 2 m between all sides of the inverter and the ventilation and building openings. | ||
The following substrates are permissible for installation:
The inverter is suitable for indoor installation. | ||
The inverter is suitable for outdoor installation. | ||
In order to keep inverter heating as low as possible, do not expose the inverter to direct sunlight. | ||
The inverter should be installed in a protected location, e.g., near the PV modules or under an overhanging roof. | ||
The inverter must not be installed or operated at more than 4,000 m above sea level. | ||
Do not install the inverter:
During certain operating phases the inverter may produce a slight noise. For this reason it should not be installed in an occupied living area. | ||
Do not install the inverter in:
The inverter is designed to be dust-proof (IP 66). In areas of high dust accumulation, dust deposits may collect on the cooling surfaces, and thus impair the thermal performance. Regular cleaning is required in this case, see chapter Operation in dusty environments on page (→). We therefore recommend not installing the inverter in areas and environments with high dust accumulation. | ||
IMPORTANT!
Refer to the manufacturer's documents for specifications regarding the suitable location of third-party batteries.
The inverter is suitable for vertical installation on a vertical wall or column. | ||
The inverter is suitable for a horizontal installation position. | ||
The inverter is suitable for installation on a sloping surface. | ||
Do not install the inverter on a sloping surface with the connections upwards. | ||
Do not install the inverter in a sloping position on a vertical wall or column. | ||
Do not install the inverter in a horizontal position on a vertical wall or column. | ||
Do not install the inverter with the connections upwards on a vertical wall or column. | ||
Do not install the inverter overhanging with the connections upwards. | ||
Do not install the inverter overhanging with the connections downwards. | ||
Do not install the inverter on the ceiling. | ||
Use the corresponding fixing materials depending on the subsurface and observe the screw dimension recommendations for the mounting bracket.
The installer is responsible for selecting the right type of fixing.
The mounting bracket (illustration) can also be used as a gauge.
The pre-drilled holes on the mounting bracket are intended for screws with a thread diameter of 6 - 8 mm (0.24 - 0.32 inches).
Unevenness on the mounting surface (such as coarse-textured plaster) is largely compensated by the mounting bracket.
When attaching the mounting bracket to the wall or to a column, make sure that the mounting bracket is not deformed.
A deformed mounting bracket may make it difficult to clip/swivel the inverter into position.
IMPORTANT!
Fit the mounting bracket with the arrow pointing upwards.
Align the mounting bracket and mark the drill holes.
Drill the drill holes.
Insert dowels and fasten the mounting bracket to the wall with 4 screws.
When installing the inverter on a mast or beam, Fronius recommends using the "Pole clamp" (order no. SZ 2584.000) mounting kit from Rittal GmbH.
The "Pole clamp" kit covers the following dimensions:
IMPORTANT!
The mounting bracket must be affixed at a minimum of four points.
Lift the inverter by the integrated side handles.
Clip the inverter into the mounting bracket from above. The connections must point downwards.
Press the lower area of the inverter into the snap-in tabs on the mounting bracket until the inverter engages on both sides with an audible click.
Single-core | Multi-stranded | Fine-stranded | Fine-stranded with ferrule and collar | Fine-stranded with ferrule without collar |
Connect round copper conductors to the terminals of the inverter as described below. Select a sufficiently large cable cross-section based on the actual device output.
Grid connections | |||||
Number of pins | |||||
5 | 2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 6 mm2 | 2.5 - 6 mm2 |
Backup power grid connections | |||||
3 | 1.5 - 10 mm2 | 1.5 - 10 mm2 | 1.5 - 10 mm2 | 1.5 - 6 mm2 | 1.5 - 6 mm2 |
PV/BAT connections* | |||||
2 x 4 | 4 - 10 mm2 | 4 - 10 mm2 | 4 - 10 mm2 | 4 - 6 mm2 | 4 - 6 mm2 |
Ground electrode terminal** | |||||
2 | 2.5 - 16 mm2 | 2.5 - 16 mm2 | 2.5 - 16 mm2 | 2.5 - 16 mm2 | 2.5 - 16 mm2 |
4 | 2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 10 mm2 | 2.5 - 10 mm2 |
| * | Dimension the cable cross-section according to the specifications of the battery manufacturer and depending on the installation situation. |
| ** | According to product standard IEC 62109, the ground conductor must correspond to the phase cross-section with phase cross-sections of ≤16 mm² and at least 16 mm² with phase cross-sections of >16 mm². With a conductor cross-section of 1.5 mm2, the maximum permitted line length is 100 m. |
IMPORTANT!
If several single conductors are connected to an input of the terminal, connect the single conductors with a corresponding ferrule.
WSD connections | ||||||
Distance | Stripping length | Cable recommendation | ||||
100 m 109 yd | 10 mm | 0.14 - 1.5 mm2 | 0.14 - 1.5 mm2 | 0.14 - 1 mm2 | 0.14 - 1.5 mm2 | Min. CAT 5 UTP (unshielded twisted pair) |
Modbus connections | ||||||
300 m 328 yd | 10 mm | 0.14 - 1.5 mm2 | 0.14 - 1.5 mm2 | 0.14 - 1 mm2 | 0.14 - 1.5 mm2 | Min. CAT 5 STP (shielded twisted pair) |
IO connections | ||||||
30 m | 10 mm | 0.14 - 1.5 mm2 | 0.14 - 1.5 mm2 | 0.14 - 1 mm2 | 0.14 - 1.5 mm2 | Single conductors possible |
LAN connections |
Fronius recommends using at least CAT 5 STP (shielded twisted pair) cables and a maximum distance of 100 m (109 yd). |
For a standard M32 cable gland with a reducer:
7-15 mm
For a standard M32 cable gland without a reducer:
11-21 mmWith cable diameters greater than 21 mm, the M32 cable gland must be replaced by an M32 cable gland with a larger clamping area—item number: 42,0407,0780—strain-relief device M32 x 1.5 KB 18-25.
Cable diameter for the strain-relief device: max. 9 mm.
.Cable diameter for the connection to the push-in terminal: max. 6 mm
IMPORTANT!
For double-insulated cables with a cable diameter over 6 mm, the external insulation layer must be removed to connect to the push-in terminal.
A residual current circuit breaker for the AC connecting cable may be required depending on national regulations, the grid operator, and other conditions.
A type A residual current circuit breaker is generally sufficient in this case. Nevertheless, false alarms can be triggered for the type A residual current circuit breaker in individual cases and depending on local conditions. For this reason, Fronius recommends using a residual current circuit breaker suitable for frequency inverters with a tripping current of at least 100 mA (national provisions must be taken into account).
IMPORTANT!
Use the inverter with a 32 A automatic circuit breaker as a maximum.
Inverter | Phases | AC power | Maximum fuse protection | Recommended fuse protection |
Fronius Symo GEN24 6.0/Symo GEN24 6.0 SC | 3 | 6000 W | 32 A | 16 A |
Fronius Symo GEN24 8.0/Symo GEN24 8.0 SC | 3 | 8000 W | 32 A | 25 A |
Fronius Symo GEN24 10.0/Symo GEN24 10.0 SC | 3 | 10,000 W | 32 A | 32 A |
Fronius Symo GEN24 12.0 SC | 3 | 12,000 W | 32 A | 32 A |
Read the Installation Instructions and Operating Instructions before installing and commissioning the equipment.
Only qualified personnel are authorized to commission the inverter and only within the scope of the respective technical regulations.
Danger from grid voltage and DC voltage from PV modules that are exposed to light.
Prior to any connection work, ensure that the inverter is de-energized on the AC side and the DC side.
Only an authorized electrical engineer is permitted to connect this equipment to the public grid.
Danger from damaged and/or contaminated terminals.
Prior to connection work, check the terminals for damage and contamination.
Remove any contamination while the equipment is de-energized.
Have defective terminals replaced by an authorized specialist.
Danger due to incorrect connection of the inverter.
It is not possible to operate the inverter in ungrounded networks, e.g., IT networks (isolated networks without ground conductor).
The neutral conductor must be connected in order to operate the inverter.
Make sure that the grid's neutral conductor is grounded.
Turn off the automatic circuit breaker. Set the DC disconnector to the "off" switch position.
Loosen the 5 screws on the connection area cover by rotating them 180° to the left using a screwdriver (TX20).
Remove the connection area cover from the device.
Press the latch on the back of the terminal and remove the AC terminal.
Insert the ferrite rings supplied into the holder.
Guide the mains cable from below through the cable gland on the right side and the ferrite core.
IMPORTANT!
The ground conductor must not be fed through the ferrite core. Dimension the ground conductor longer and lay it with a movement loop so that it will be the last conductor subjected to mechanical stress in the event of a cable gland failure.
For more information about the cable gland, see chapter Cable diameter of the AC cable on page (→).
Select the cable cross-section in accordance with chapter Permitted cables for the electrical connection on page (→).
Strip 12 mm of insulation from the single conductors.
Lift the operating lever of the terminal to open. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then close the operating lever until it engages.
IMPORTANT!
Only one conductor may be connected to each pin. The AC cables can be connected to the AC terminal without ferrules.
| L1 | Phase conductor |
| L2 | Phase conductor |
| L3 | Phase conductor |
| N | Neutral conductor |
| PE | Ground conductor |
Insert the AC terminal into the AC slot until it engages. Fasten the union nut of the cable gland with a torque of 6 ‑ 7 Nm.
To enable suitable PV modules to be chosen and to use the inverter as efficiently as possible, it is important to bear the following points in mind:
IMPORTANT!
Before connecting up the PV modules, check that the voltage for the PV modules specified by the manufacturer corresponds to the actual measured voltage.
IMPORTANT!
The PV modules connected to the inverter must comply with the IEC 61730 Class A standard.
IMPORTANT!
Solar module strings must not be grounded.
IMPORTANT!
IMPORTANT!
IMPORTANT!
The commissioning, maintenance, and service work in the inverter's power stage set may only be carried out by Fronius-trained service personnel in accordance with the technical specifications.
Read the installation instructions and operating instructions before installing and commissioning the equipment.
Danger from mains voltage and DC voltage from PV modules that are exposed to light.
All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and are de-energized.
Danger of an electric shock due to improperly connected terminals/PV plug connectors.
When connecting, ensure that each pole of a string is routed via the same PV input, e.g.:
+ pole string 1 to the input PV 1.1+ and - pole string 1 to the input PV 1.1-
Have defective terminals replaced by an authorized specialist company.
Two independent PV inputs (PV 1 and PV 2) are available. These inputs can be connected to a different number of modules.
When starting for the first time, set up the PV Generator in accordance with the respective configuration (can also be carried out at a later date in the Device Configuration > Components menu area).
IMPORTANT!
Carry out the installation in accordance with the nationally applicable standards and guidelines.
Module array settings:
PV 1: ON
PV 2: OFF
PV 1: ON
PV 2: OFF
PV 1: ON
PV 2: OFF
PV 1 + PV 2 (connected in parallel): ON
IMPORTANT!
The maximum current load of a single terminal is 25 A. PV‑connection strings with a total current of more than 25 A must be split between both PV inputs upstream of the terminals (ISC max ≤ 60 A). The plug connection for splitting the total current must be sufficiently dimensioned, suitable, and installed by a professional. It is not permitted to split the current by bridging from PV 1 to PV 2 at the terminal.
PV 1: ON
PV 2: ON
IMPORTANT!
Carry out the installation in accordance with the nationally applicable standards and guidelines. If the Arc Fault Circuit Interrupter integrated in the inverter is being used for arc detection according to IEC 63027, the solar module strings must not be combined upstream of the inverter.
PV 1: ON
PV 2: OFF
PV 1: ON
PV 2: OFF
PV 1: ON
PV 2: OFF
IMPORTANT!
The maximum current load of a single terminal is 28 A. PV‑connection strings with a total current of more than 28 A must be split between both PV inputs upstream of the terminals (ISC max ≤ 60 A). The plug connection for splitting the total current must be sufficiently dimensioned, suitable, and installed by a professional. It is not permitted to split the current by bridging from PV 1 to PV 2 at the terminal.
PV 1: ON
PV 2: ON
Disconnect connections from the solar module strings (+/-).
Push the DC cables through the DC bushings by hand.
IMPORTANT!
Push the cables through the DC bushings before stripping them. This avoids twisting/bending single wires.
Remove the DC push-in terminals from the slots.
For measurements on the DC cables, use the Fronius Inspection Kit (44,0240,0004) or an adapter cable with a suitable DC plug (e.g., MC4). Connect the adapter cable to the DC push-in terminals and place the DC plug outside the inverter.
Danger from loose and/or incorrectly clamped single conductors in the terminal.
Only connect one single conductor in the slot provided for each terminal.
Check that the single conductors are secure in the terminal.
Make sure that the single conductor has been fully inserted into the terminal and that no single wires are protruding out of the terminal.
Select the cable cross-section in accordance with the instructions in Permitted cables for the electrical connection from page (→).
Strip the insulation of the single conductors by 12 mm.
Connect the solar module strings (+/-).
Danger due to polarity reversal at the terminals.
Use a suitable measuring instrument to check the polarity of the DC cabling.
Use a suitable measuring instrument to check the voltage (max. 1000 VDC)
Use a suitable measuring instrument to check the voltage and polarity of the DC cabling. Remove both DC terminals from the slots.
Risk due to overtorque at the strain-relief device.
Damage to the strain-relief device may result.
Do not use a drill driver.
Insert the DC terminals into the respective slot until they engage. Fasten the screws of the strain-relief device to the housing using a screwdriver (TX20) and a torque of 1.3 - 1.5 Nm.
Only a technical specialist is permitted to perform commissioning, maintenance, and service activities for inverters and batteries, and only within the scope of the technical regulations.
Read the installation instructions and operating instructions from the respective manufacturer before installing and commissioning the equipment.
Danger from mains voltage and DC voltage from the PV module that are exposed to light, as well as batteries.
All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and battery, and are de-energized.
Only a technical specialist is permitted to connect this equipment to the public grid.
Have defective terminals repaired by a technical specialist.
Danger due to operation of the battery above the permissible altitude specified by the manufacturer.
Operating the battery above the permissible altitude can result in restricted operation, loss of operation, and unsafe states of the battery.
Adhere to the manufacturer's instructions regarding the permissible altitude.
Operate the battery only at the altitude specified by the manufacturer.
IMPORTANT!
Prior to installing a battery, ensure that the battery is switched off. Observe the max. DC cable length for the installation of third-party batteries according to the specifications of the manufacturer, see chapter Suitable batteries on page (→).
IMPORTANT!
Push the cables through the DC bushings by hand before stripping the insulation. This avoids twisting/bending single wires.
* The battery ground conductor must be connected externally (e.g., switch cabinet). When connecting an LG FLEX battery, the battery ground conductor can be connected in the inverter see chapter Connecting the LG FLEX ground conductor on page (→). Observe the minimum cross-section of the battery ground conductor.
Make sure that the single conductor has been fully inserted into the terminal and that no single strands are protruding out of the terminal.
Danger due to overvoltage when using other slots on the terminal.
This may result in damage to the battery and/or the PV modules due to discharge.
Only use the slots labeled "BAT" for connecting the battery.
Strip the insulation of the single conductors by 12 mm. Lift the operating lever of the terminal to open. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then close the operating lever until it engages.
Serious damage to the PV system may result.
Use a suitable measuring instrument to check the polarity of the DC cabling when the battery is switched on.
The maximum voltage for the battery input must not be exceeded (see Technical data on page (→)).
Insert the DC terminals into the respective slot until they engage. Fasten the screws of the cable guide to the housing using a screwdriver (TX20) and a torque of 1.3-1.5 Nm.
IMPORTANT!
Information for connection to the battery's DC connections can be found in the installation instructions from the relevant manufacturer.
Push the ground conductor through the DC bushing by hand before stripping the insulation.
Place the battery ground conductor in the integrated cable duct of the connection area divider in the AC connection area. Fasten the battery ground conductor to the ground electrode terminal at the second input from above using a screwdriver (TX20) and a torque of 1.8-2 Nm.
IMPORTANT!
Installing and connecting an option must only be carried out by service personnel trained by Fronius and only within the scope of the respective technical regulations.
Follow the safety rules.
Danger due to damaged and/or contaminated terminals.
Before making any connections, check the terminals for damage and contamination.
Remove contamination in the de-energized state.
Have defective terminals repaired by an authorized specialist.
During the switch from grid-connected operation to backup power mode, momentary interruptions will occur. The PV Point output requires PV power from the solar modules or a battery to power the connected loads.
Connected loads will not be supplied with power during the switchover.
Do not connect any loads that require an uninterruptible supply ( e.g., IT networks, life-sustaining medical devices).
IMPORTANT!
The valid national laws, standards, and provisions, as well as the specifications of the relevant grid operator are to be taken into account and applied.
It is highly recommended that the specific installation be agreed with the grid operator and explicitly approved by this operator. This obligation applies to system constructors in particular (e.g., installers).
IMPORTANT!
All loads that have to be supplied via the OP terminal must be protected by means of a residual current circuit breaker.
In order to ensure the residual current circuit breaker operates properly, a connection must be established between the neutral conductor N´ (OP) and ground.
For the circuit diagram recommended by Fronius, see Circuit diagrams—PV Point on page (→).
Switch off the automatic circuit breaker and DC disconnector. Turn the DC disconnector to the "off" switch setting.
Danger from faulty or incorrect bores.
This may lead to injuries to the eyes and hands as a result of flying debris and sharp edges, as well as damage to the inverter.
When drilling, wear suitable protective goggles.
Only use a step drill when drilling.
Ensure that nothing on the inside of the device is damaged (e.g., the connection block).
Adapt the diameter of the bore to match the corresponding connection.
Deburr the bores using a suitable tool.
Remove the drilling residues from the inverter.
Drill out the optional cable guide with a step drill.
Insert the cable gland into the bore and fasten it using the torque specified by the manufacturer.
Guide the mains cable through the cable gland from below.
Remove the OP terminal.
Strip 12 mm of insulation from the single conductors. The cable cross-section must be between 1.5 mm2 and 10 mm 2.
Lift to open the terminal's operating lever and insert the stripped single conductor into the slot provided, all the way up to the stop. Then close the operating lever until it engages.
| L1´ | Phase conductor |
| N´ | Neutral conductor |
| N´ | PEN conductor |
IMPORTANT!
The PEN conductor must be produced with ends that are permanently marked blue, according to the national provisions, and have a cross-section of 10 mm².
Fasten the ground conductor and PEN conductor to the ground electrode terminal using a screwdriver (TX20) and a torque of 2 Nm.
Insert the OP terminal into the OP slot until it engages. Tighten the union nut of the cable gland.
A battery charge of min. 30% is recommended for test mode.
A description of how to run the test mode can be found in the checklist – Backup power (https://www.fronius.com/de/download-center?searchword=42,0426,0365).
Danger from incorrect installation, commissioning, operation, or incorrect use.
This can result in severe personal injury/damage to property.
Only trained and qualified personnel are authorized to install and commission the system, and only within the scope of the technical regulations.
The Installation and Operating Instructions must be read carefully prior to use.
If anything is unclear, contact your vendor immediately.
IMPORTANT!
It is highly recommended to coordinate the concrete examples implemented and in particular the specific installation with the grid operator to obtain their explicit approval. This obligation applies to system constructors in particular (e.g., installers).
The examples suggested here show a backup power supply with or without an external protection relay (external grid and system protection unit). The respective grid operator decides whether an external protection relay must be used or not.
IMPORTANT!
An uninterruptible power supply (UPS) may only be used to supply individual loads (e.g., computers). Feeding into the power supply of the house network is not permitted. The Installation and Operating Instructions must be read carefully prior to use. If anything is unclear, contact your vendor immediately.
The examples given in this document (in particular cabling variants and circuit diagrams) are suggestions only. These examples have been carefully developed and tested. They can therefore be used as a basis for real-life installation. Anyone following or using these examples does so at their own risk.
IMPORTANT!
IMPORTANT!
IMPORTANT!
The cabling variant required by the utility must be clarified with the utility.
Cabling of the backup power circuits and non-backup power circuits:
If not all the loads in the home need to be supplied in a backup power situation, the circuits need to be divided into backup power circuits and non-backup power circuits. The total load of the backup power circuits must not exceed the rated power of the inverter.
Cabling with third-party components
The backup power circuits and non-backup power circuits must be fused separately according to the required safety measures (e.g., residual current circuit breaker, automatic circuit breaker).
In backup power mode, only the backup power circuits are disconnected from the grid at 3 pins by contactor K1. In this case the rest of the home network is not supplied.
In backup power mode, only the backup power circuits are disconnected from the grid at all pins by contactor K1, and a ground connection is established for them. In this case the rest of the home network is not supplied.
IMPORTANT!
For this circuit variant, the Fronius Smart Meter WR must be used.
In backup power mode, only the backup power circuits are disconnected from the grid by contactors K1 and K2, and a ground connection is established for them. In this case the rest of the home network is not supplied.
IMPORTANT!
The circuit diagrams to be used must be applied in line with the country standard and the implementing regulations of the utility.
In backup power mode, only the backup power circuits and the inverter are disconnected from the grid by changeover switch Q1. In the case of all-pole disconnection, a ground connection is also established. In this case, the loads in the non-backup power circuits are not supplied by the inverter.
The inputs M0 and M1 can be freely selected. A maximum of four Modbus participants can be connected to the Modbus terminal at inputs M0 and M1.
IMPORTANT!
Only one primary meter, one battery, and one Ohmpilot can be connected per inverter. Due to the high data transfer of the battery, the battery occupies two subscribers. If the Inverter Control via Modbus function is activated in the Communication > Modbus menu area, no Modbus participants are possible. It is not possible to send and receive data at the same time.
Example 1:
Input | Battery | Fronius | Number of primary meters | Number of secondary meters |
Modbus 0 | 0 | 4 | ||
0 | 2 | |||
0 | 1 | |||
Modbus 1 | 1 | 3 |
Example 2:
Modbus 0 | 1 | 3 | ||
Modbus 1 | 0 | 4 | ||
0 | 2 | |||
0 | 1 |
IMPORTANT!
Example 1:
0 | 2 | |||
0 | 1 | |||
Modbus 1 | 1 | 3 |
Example 2:
0 | 2 | |||
0 | 1 |
IMPORTANT!
Ingress protection rating IP 66 cannot be ensured if blanking plugs are missing or incorrectly inserted.
Remove the union nut on the cable gland and press the sealing ring with the blanking plugs out from the inside of the device.
Open up the sealing ring at the location where the blanking plugs are to be removed.
* Remove the blanking plugs with a sideways motion.
First, guide the data cables through the union nut of the cable gland and then through the housing opening.
Insert the sealing ring between the union nut and the housing opening. Press the data cables into the seal's cable guide. Then press in the seal until it reaches the underside of the cable gland.
Modbus RJ45
IMPORTANT!
For this connection version, the BAT switch on the data communication area must be in position 1.
Power supply
Voltage is present at the connection. If network devices (e.g., WiFi routers) are connected, the device may be damaged.
Only connect batteries to the battery connection
Modbus terminal
Strip 10 mm of insulation from the single conductors and fit the ferrules if necessary.
IMPORTANT!
If several single conductors are connected to an input of the push-in terminals, connect the single conductors with a corresponding ferrule.
Insert the cables into the respective slot and check the cables are securely retained.
IMPORTANT!
Use a twisted cable pair for data cables that belong together.
Twist the cable shield and insert into the "SHIELD" slot.
IMPORTANT!
Improperly fitted shielding can cause data communication problems.
Fasten the union nut of the cable gland with a torque of min. 2.5 - max. 4 Nm.
For the circuit diagram recommended by Fronius, see System circuit diagrams on page (→).
It may be possible for the system to function without terminating resistors. However, owing to interference, the use of terminating resistors according to the following overview is recommended for trouble-free operation.
For permissible cables and max. distances for the data communication area, refer to the chapter headed Permitted cables for the data communication connection on page (→).
IMPORTANT!
Terminating resistors that are not positioned as illustrated can result in interference in the data communication.
IMPORTANT!
The push-in WSD terminal in the inverter's connection area is delivered with a bypass ex works as standard. The bypass must be removed when installing a trigger device or a WSD chain.
The WSD switch of the first inverter with connected trigger device in the WSD chain must be in position 1 (master). The WSD switch of all other inverters should be in position 0 (secondary device).
Max. distance between 2 devices: 100 m
Max. Number of devices: 28
* Floating contact of the trigger device (e.g., central grid and system protection). If several floating contacts are used in a WSD chain, these must be connected in series.
The housing cover is fitted with a lock for safety reasons, which allows the housing cover on the inverter to be pivoted only when the DC disconnector is off.
Only clip and pivot the housing cover into the inverter when the DC disconnector is switched off.
Do not use excessive force to clip in and pivot the housing cover.
Place the cover on the connection area. Tighten the 5 screws by rotating them 180° to the right in the indicated order using a screwdriver (TX20).
Clip the housing cover into the inverter from above.
Press on the lower part of the housing cover and tighten the 2 screws by rotating them 180° to the right using a screwdriver (TX20).
Turn the DC disconnector to the "on" switch setting. Turn on the automatic circuit breaker. For systems with a battery, observe the switch-on sequence according to the chapter Button functions and LED status indicator on page (→).
IMPORTANT! Open the WiFi access point with the optical sensor, see chapter Suitable batteries on page (→)
When starting the inverter for the first time, various setup settings must be configured.
If the setup is canceled before completion, the input data is not saved and the start screen with the installation wizard is shown once again. The data is saved in the event of an interruption, e.g., a power failure. Commissioning is continued at the point at which the interruption occurred after the power supply is restored. If the setup was interrupted, the inverter feeds energy into the grid at maximum 500 W and the operating status LED flashes yellow.
The country setup can only be set when starting the inverter for the first time. If the country setup needs to be changed at a later date, contact your installer/technical support.
The Fronius Solar.start app is required for installation. Depending on the mobile device used to perform the installation, the app is available on the relevant platform.
WiFi:
Ethernet:
IMPORTANT!
Wait for the capacitors of the inverter to discharge!
IMPORTANT!
IMPORTANT!
Depending on the authorization of the user, settings can be made in the individual menu areas.
IMPORTANT!
IMPORTANT!
All available components of the system can be added via Add component+.
PV Generator
Activate the MPP tracker and enter the connected PV output in the relevant field. In the case of combined solar module strings, PV 1 + PV 2 connected in parallel must be activated.
Meter
Primary meter
IMPORTANT!
For problem-free operation with further energy generators and in Full Backup power mode, it is important to install and configure a Fronius Smart Meter as the primary meter at the feed-in point. The inverter and further generators must be connected to the public grid via the Fronius Smart Meter. Only one primary meter can be configured in the system.
This setting has an effect on the behavior of the inverter during the night. If the primary meter has been configured, the inverter remains permanently connected to the grid in order to enable it to draw energy from other generators at any time.
If the primary meter has not been configured, the inverter switches to standby mode as soon as there is no more PV power available. No energy management specification is sent to the battery (e.g., minimum state of charge reached). The message "Power low" is displayed. The inverter starts again as soon as an energy management specification is sent or sufficient PV power is available.
Secondary meter
In addition to the primary meter, further secondary meters can be added to the system to record the load curves of individual loads and generators (e.g., heat pump, wind power plant, etc.) and provide the measured data for energy profiling in Fronius Solar.web.
For communication via MQTT and Modbus TCP, install the inverter and Smart Meter in the same sub-network.
The Watt value for the production meter is the sum of all production meters. The Watt value for the secondary meter is the sum of all secondary meters.
Battery
If the SoC Limit Mode is set to Auto, the values SoC Minimum and SoC Maximum are preset according to the technical specifications of the battery manufacturer.
If the SoC Limit Mode is set to Manual, the values SoC Minimum and SoC Maximum can be changed after consultation with the battery manufacturer within the framework of their technical specifications. In a backup power situation, the set values are not taken into account.
The setting Allow battery charging from other generators in the home network activates/deactivates charging of the battery from other generators.
The power consumption of the Fronius inverter can be restricted by specifying a value in the Max. Charging Power from AC field. As a maximum, a power consumption equal to the AC rated power of the Fronius inverter is possible.
The setting Allow battery charging from public grid + Allow battery charging from other generators in the home network activates/deactivates the charging of the battery from the public grid and, if present, from other generators in the home network.
The normative or compensatory specifications must be taken into account for this setting. Irrespective of this setting, necessary service-related charging from the public grid is performed (e.g., forced re-charging to protect against deep discharge).
IMPORTANT!
Fronius accepts no liability for damage to third-party batteries.
Ohmpilot
All the Ohmpilots available in the system are displayed. Select the desired Ohmpilot and add to the system via Add.
PV Generator
Meter
Primary meter
IMPORTANT!
Secondary meter
Battery
IMPORTANT!
Ohmpilot
IMPORTANT! For configuration of the PV Point backup power mode, observe the instructions in chapter Safety.
For configuration of the Full Backup backup power mode, observe the instructions in chapter Safety.
Parallel Backup
Parallel Backup enables the additional use of PV power in backup power mode, which secondary inverters make available in the system.Backup Nominal Voltage
Select the voltage for backup power mode.
SoC warning level
In backup power mode, a warning is emitted when this residual battery capacity is reached.
Reserve Capacity
The set value results in a residual capacity (depending on the battery capacity) that is reserved for backup power situations. The battery does not discharge below the reserve capacity in grid connected mode. In backup power mode, the manually set value of SoC Minimum is not taken into account. The battery discharges up to the automatically preset, minimum state of charge. This value is specified by the battery manufacturer.
System preservation during night
To ensure continuous backup power operation even during the night, the inverter calculates a residual capacity for system preservation depending on the battery capacity. When the calculated limit value is reached, the inverter and the battery switch to standby mode. This is maintained for a period of 16 hours. Connected loads are no longer supplied. The battery discharges up to the preset minimum state of charge.
Rapid switch mode
Disconnection from the grid and synchronized reconnection each take place within 20 ms.Material damage due to misconfiguration
This can result in damage to system components.
Only activate the Rapid switch mode function on the primary inverter in conjunction with a Fronius Backup Controller 63A.
Only activate the Rapid switch mode function for secondary inverters if the function is also activated for the primary inverter.
Load Management
Select up to four pins for the load management. Further settings for the load management are available in the Load Management menu item.
Default: Pin 1
Australia - Demand Response Modes (DRM)
Activate the slider if DRM is required. Configure the pins for control via DRM as follows:
Mode | Description | Information | DRM Pin | I/O pin |
DRM0 | Inverter disconnects from the grid | DRM0 occurs in the event of an interruption or short circuit on the REF GEN or COM LOAD lines, or in the event of invalid combinations of DRM1 - DRM8. | REF GEN | IO4 |
DRM1 | Import Pnom ≤ 0% without disconnection from grid | currently not supported | DRM 1/5 | IN6 |
DRM2 | Import Pnom ≤ 50% | currently not supported | DRM 2/6 | IN7 |
DRM3 | Import Pnom ≤ 75% & | currently not supported | DRM 3/7 | IN8 |
DRM4 | Import Pnom ≤ 100% | currently not supported | DRM 4/8 | IN9 |
DRM5 | Export Pnom ≤ 0% without disconnection from grid | currently not supported | DRM 1/5 | IN6 |
DRM6 | Export Pnom ≤ 50% | currently not supported | DRM 2/6 | IN7 |
DRM7 | Export Pnom ≤ 75% & -Qrel* ≥ 0% | currently not supported | DRM 3/7 | IN8 |
DRM8 | Export Pnom ≤ 100% | currently not supported | DRM 4/8 | IN9 |
The percentage specifications always relate to the rated device power. | ||||
IMPORTANT! If the Australia - Demand Response Modes (DRM) function is activated and no DRM control is connected, the inverter switches to standby mode.
Battery Grid Import Limit (§ 14a EnWG)
Define a pin for the implementation of the regulatory requirement per § 14a EnWG.
Enforce Standby
When this function is activated, grid power feed operation of the inverter is interrupted. This makes it possible to shut down the inverter without power and protect its components. The standby function is automatically deactivated when the inverter is restarted.
Fan test
IMPORTANT!
For settings in this menu item, select the Technician user, enter the password for the Technician user, and confirm. Settings may only be made by trained and qualified personnel.
Use this function to check whether the fans of the inverter are working correctly based on acoustics, for example after replacing a fan.
The test takes around 30 seconds per fan. The inverter then switches back to normal operation. Use the Stop fan test function to stop the test manually.
PV 1 and PV 2
Parameter | Value range | Description |
Mode | Off | The MPP tracker is deactivated. |
Auto | The inverter uses the voltage at which the maximum possible output of the MPP tracker is possible. | |
Fixed | The MPP tracker uses the voltage defined in UDC fixed. | |
UDC fixed | 80 ‑ 530 V | The inverter uses the fixed voltage that is used on the MPP tracker. |
Dynamic Peak Manager | Off | Function is deactivated. |
On | The entire solar module string is checked for optimization potential and the best possible voltage for grid power feed operation is determined. | |
On (MLSD) | The function is optimized for systems with Module Level Shutdown devices (MLSD) and is not suitable for PV optimizers. | |
Rated power | 0-2,000,000 | Rated output of PV input |
Ripple Control
Ripple control signals are signals that are sent by an energy company in order to switch controllable loads on and off. The inverter damps or amplifies the ripple control signals, depending on the installation situation. This can be counteracted if necessary by applying the following settings.
Reduction of influence | Off | Function is deactivated. |
On | Function is activated. | |
Frequency of the ripple control signal | 100 ‑ 3000 Hz | The frequency specified by the energy company must be entered here. |
Grid inductance | 0.00001 ‑ 0.005 H | The value measured at the feed-in point must be entered here. |
Measures to prevent FI/RCMU false alarms
(when using a 30 mA residual current circuit breaker)
A type A residual current circuit breaker is generally sufficient in this case. Nevertheless, false alarms can be triggered for the type A residual current circuit breaker in individual cases and depending on local conditions. For this reason, Fronius recommends using a residual current circuit breaker suitable for frequency inverters with a release current of least 100 mA, taking into account national provisions.
Leakage current factor to reduce RCMU/FI false tripping | 0 ‑ 0.25 | By reducing the setting value, the leakage current is reduced and the intermediate circuit voltage is increased, which slightly lowers the efficiency.
Shutdown before 30 mA RCD triggers | Off | The function for reducing false tripping of the residual current circuit breaker is deactivated. |
On | The function for reducing false tripping of the residual current circuit breaker is activated. | |
Rated non-tripping fault current limit value | 0.015 ‑ 0.3 | Value of the non-tripping residual current specified by the manufacturer for the residual current circuit breaker at which the residual current circuit breaker does not switch off under specified conditions. |
Insulation warning
Insulation warning | Off | The insulation warning is deactivated. |
On | The insulation warning is activated. | |
Insulation measurement mode
| Exact | Insulation monitoring takes place with the highest degree of accuracy. The measured insulation resistance is displayed on the user interface of the inverter. |
Fast | Insulation monitoring takes place with a lesser degree of accuracy. The duration of the insulation measurement is shortened. The insulation resistance value is not displayed on the user interface of the inverter. | |
Threshold for the insulation warning | 100,000 ‑ | If the value drops below the threshold, status code 1083 is displayed on the user interface of the inverter. |
Continuous residual current monitoring
Limit value | 0.03-0.3A | Defines the limit value for shutdown in the event of residual current. |
Backup power
Backup power nominal voltage | 220 ‑ 240 V | The nominal phase voltage that the inverter outputs in backup power mode. |
Backup power frequency offset | -5 to +5 Hz | The setting value can be used to reduce or increase the backup power frequency (see Technical data) by the offset value. The default value is +3 Hz. Connected loads (e.g., Fronius Ohmpilot) detect active backup power mode based on the change in frequency and react accordingly (e.g., activation of energy-saving mode).
Backup power undervoltage protection limit value U< [pu] | 0 ‑ 2 %V | This setting value represents the limit value for shutting down backup power mode |
Backup power undervoltage protection time U< | 0.04 ‑ 20 s | Trip time for falling below the backup power undervoltage protection limit value. |
Backup power surge protection limit value U> [pu] | 0 ‑ 2 %V | This setting value represents the limit value for shutting down backup power mode |
Backup power surge protection time U> | 0.04 ‑ 20 s | Trip time for exceeding the backup power surge protection limit value. |
Fast undervoltage protection / ground fault protection limit value U<< [pu] | 0-100%V | Defines the voltage limit value below which rapid undervoltage protection or protection against ground faults is triggered. Typically, a value such as 0.3 pu (30% of the nominal voltage) is set here. |
Fast undervoltage protection / ground fault protection time U<< | 0 ‑ 10 s | Defines the maximum time (in seconds) for which the voltage may be below the set limit value, after which the inverter switches off. This value must be ≤ 0.4 s in accordance with ÖVE E 8101. |
Backup power restart delay | 0 ‑ 600 s | Waiting time for restarting backup power mode following a shutdown. |
Backup power restart attempts | 1 ‑ 10 | The maximum number of automated restart attempts. Once the maximum number of automated restart attempts has been reached, service message 1177 must be manually acknowledged. |
External frequency monitoring in backup power mode
| Off | Function is deactivated |
On | For Full Backup power mode in Italy, activate external frequency monitoring. The inverter checks the mains frequency before ending backup power mode. If the mains frequency is within the permitted limits, the loads are connected to the public grid. | |
Backup power short circuit switch-off time | 0.001 ‑ 60 s | If a short circuit occurs during backup power mode, backup power mode is interrupted within the set time. |
In Germany, new rules for charging batteries came into force on January 1, 2024. When applying §14a EnWG, the charging current must be reduced to a maximum of 4.2 kW by the grid operator for dimming controllable load equipment in accordance with §14a EnWG.
In order to document implementation of the control command, the inverter can be connected to Fronius Solar.web and ensure a permanent Internet connection. In addition, in the menu item Device configuration > Functions & I/Os, activate the Battery Grid Import Limit (§ 14a EnWG).
State of charge settings
If the SoC Limit Mode is set to Manual, the values SoC Minimum and SoC Maximum can be changed. Change the values SoC Minimum and SoC Maximum only after consultation with the battery manufacturer within the framework of their technical specifications. In a backup power situation, the set values are not taken into account.
If Battery charging from other sources is activated, the following options are available: SoC warning level
Reserve Capacity
IMPORTANT! Fronius accepts no liability for damage to third-party batteries.
Time-dependent battery control
Using the Time-dependent battery control, it is possible to specify, restrict, or prevent the charging or discharging of the battery at/to a defined power.
IMPORTANT! The defined rules for battery control have the second lowest priority after Self-Consumption Optimization. Depending on the configuration, the rules may not be fulfilled due to other settings.
The following values can be selected for the Time-dependent battery control rules:The timing of when the rule applies is set in the Time input fields and by selecting the days of the week.
It is not possible to define a time window beyond midnight (00:00).
Example: Two entries are needed to set a rule of 22:00 to 06:00: "22:00 - 23:59" and "00:00 - 06:00"
Service Mode
If Service Mode is activated, the battery system is charged or discharged to the state of charge of 30%. The state of charge of 30% is maintained until the end of service mode.
IMPORTANT! Service Mode is only available for Fronius battery systems.
The following examples serve to explain the energy flows. Efficiency levels are not taken into account.
Battery system
PV system to inverter | 1000 W |
Power into the battery | 500 W |
Power output (AC) of the inverter | 500 W |
Set target value at feed-in point | 0 W |
Infeed into the public grid | 0 W |
Consumption in home | 500 W |
Battery system without photovoltaics, including second generator in the house
Power into the battery | 1500 W |
Power consumption (AC) of the inverter | 1500 W |
Second generator in home network | 2000 W |
Battery system including second generator in the house
Power into the battery | 2500 W |
A regulation always consists of a restriction or specification, and the time and days of the week when the regulation is active. The time of regulations with the same restriction (e.g., max. charging power) must not overlap.
Max. charging and discharging limits
One max. charging and one max. discharging power can be configured at the same time.
Specify charging range
It is possible to define a charging range using a min. and max. charging limit. In this case, it is not possible to discharge the battery.
Specify discharging range
It is possible to define a discharging range using a min. and max. discharging limit. In this case, it is not possible to charge the battery.
Specify a defined charge
It is possible to specify a defined charging power by setting the min. and max. charging power to the same value.
Specify a defined discharge
It is possible to specify a defined discharging power by setting the min. and max. discharging power to the same value.
Possible applications
The regulations in the Battery Management menu area enable optimal use of the energy generated. In some situations, the PV power cannot be used in full due to the time-dependent battery control.
Example | |
Fronius inverter (max. output power) | 6000 W |
Defined discharge of the battery | 6000 W |
PV power | 1000 W |
In this case, the inverter reduces the PV power to 0 W, since the output power of the inverter is max. 6000 W. The inverter is already being fully utilized through discharging the battery.
Priorities
If additional components (e.g., battery, Fronius Ohmpilot) are present in the system, the priorities can be set here. Devices having higher priority are actuated first, and subsequently, if there is still excess energy available, the other devices.
IMPORTANT!
If there is a Fronius Wattpilot in the photovoltaic system, it is considered to be a load. The priority for the load management of the Fronius Wattpilot must be configured in the Fronius Solar.wattpilot app.
Rules
It is possible for up to four different load management rules to be defined. At the same threshold values, the rules are activated in succession. For deactivation, this is done in reverse; the I/O last switched on is the first to be switched off. In the case of different thresholds, the I/O with the lowest threshold is switched on first, followed by the second lowest, and so on.
I/Os controlled by the produced power are always prioritized over a battery and Fronius Ohmpilot. That is to say that an I/O can switch on and result in the battery no longer being charged or the Fronius Ohmpilot no longer being activated.
IMPORTANT!
An I/O is activated/deactivated after 60 seconds.
Set the operating mode to Manual or Automatic. The inverter always adjusts to the set Target value at feed-in point. In Automatic operating mode (factory setting), an adjustment is made to 0 W at the feed-in point (max. self-consumption).
If Manual has been selected under Self-Consumption Optimization, the Operation Mode (Consumption/Feed-in) and the Target value at feed-in point can be set.
IMPORTANT!
Self-Consumption Optimization has lower priority than Battery Management.
All available updates for inverters and other Fronius devices are provided on the product pages and in the "Fronius Download Search" area at www.fronius.com .
The guided setup wizard can be accessed here.
All settings
Resets all configuration data, apart from the country setup. Changes to the country setup may only be made by authorized personnel.
All settings without network
Resets all configuration data, apart from the country setup and the network settings. Changes to the country setup may only be made by authorized personnel.
Current messagesAll current events of the linked system components are displayed here.
IMPORTANT!
Depending on the type of event, this must be confirmed via the "tick" button so that it can be further processed.
History
All events of the linked system components that are no longer present are displayed here.
All the information regarding the system and the current settings is displayed and provided for download in this menu area.
The power data and functional scope of the inverter are stored in the license file.
If the inverter, power stage set PC board, or data communication area is replaced, the license file must also be replaced.
IMPORTANT!
The support user exclusively enables Fronius Technical Support to configure settings on the inverter via a secure connection. Access is deactivated by clicking the Terminate Support User Session button.
IMPORTANT!
The remote access exclusively enables Fronius Technical Support to access the inverter via a secure connection. In this case, diagnostics data are transmitted, which are used for troubleshooting. The remote access can be activated only upon request by Fronius Support.
Server addresses for data transfer
If a firewall is used for outgoing connections, allow the below protocols, server addresses, and ports for successful data transfer, see:
When using FRITZ!Box products, configure Internet access without any restrictions or limitations. Do not set the DHCP Lease Time (validity) to 0 (=infinite).
LAN:
After establishing the connection, check the connection status.
WiFi:
Activate the access point of the inverter. This is opened by touching the sensor > Communications LED flashes blue
After connecting, the status of the connection should be checked.
Access point:
The inverter serves as the access point. A PC or mobile device connects directly to the inverter. Connecting to the Internet is not possible. Assign a Network Name (SSID) and Network Key (PSK) to establish a connection. Assign a Network Key (PSK) with at least 20 characters, consisting of upper and lower case letters, special characters, and numbers, to protect the device from unauthorized access.
It is possible to operate a connection via WiFi and via the access point at the same time.
LAN:
WiFi:
Access point:
The inverter communicates with system components (e.g., Fronius Smart Meter) and other inverters via Modbus. The primary device (Modbus Client) sends control commands to the secondary device (Modbus Server). The control commands are executed by the secondary device.
RTU Server
The following input fields and functions are available for communication via Modbus RTU:
| Meter address offset |
| Inverter address |
| SunSpec Model Type |
| Interface |
| Baud Rate |
| Parity |
| Allow Control If this option is activated, the inverter is controlled via Modbus. Inverter control includes the following functions:
TCP Server
The following input fields and functions are available for communication via Modbus TCP:
| Modbus port |
| Meter Address |
| Restrict Control |
The utility/energy supplier can influence the output power of the inverter with Cloud control. This requires the inverter to have an active Internet connection.
Parameter | Display | Description |
Cloud control | Off | Cloud control of the inverter is deactivated. |
On | Cloud control of the inverter is activated. |
Profile | Value range | Description |
Allow cloud control for regulatory purposes (Technician) | Deactivated/Activated | The function may be mandatory for proper operation of the system.* |
Allow cloud control for Virtual Power Plants (Customer) | Deactivated/Activated | If the Allow remote control for regulatory purposes (technician) function is activated (technician access required), the Allow remote control for virtual power plants function is automatically activated and cannot be deactivated.* |
* Cloud control
A virtual power plant is an interconnection of multiple generators. This virtual power plant can be controlled by means of the cloud control via the Internet. An active inverter Internet connection is a prerequisite for this. System data are transferred.
The Solar API is an IP-based, open JSON interface. If enabled, IOT devices in the local network may access inverter information without authentication. For security reasons, the interface is disabled in the factory. Activate the interface manually if it is required for a third-party application (e.g., EV charger, smart home solutions, etc.). If there is a Fronius Wattpilot in the network, the inverter automatically activates the Solar API.
Fronius recommends using Fronius Solar.web for monitoring and analyzing the inverter and connected system components.
In the event of a firmware update to version 1.14.x, the Solar API setting is applied. In systems with a version below 1.14.x, the Solar API is activated; with higher versions, it is deactivated but can be switched on and off via the menu.
Manually activating the Fronius Solar API
On the user interface of the inverter in the Communication > Solar API menu area, activate the function Activate communication via Solar API.
In this menu, you can agree to the technically necessary data processing or reject it.
In addition, the transfer of analysis data and remote configuration via Fronius Solar.web can be enabled or disabled.
Danger from unauthorized fault analyses and repair work.
Fault analyses and repair work on the PV system may only be carried out by installers/service technicians from authorized specialist companies in accordance with national standards and regulations.
Risk due to unauthorized access.
Incorrectly set parameters can have a negative effect on the public grid and/or the grid power feed operation of the inverter and result in the loss of standard conformity.
Parameters may only be adjusted by installers/service technicians from authorized specialist companies.
Do not give the access code to third parties and/or unauthorized persons.
Risk due to incorrectly set parameters.
Incorrectly set parameters can have a negative effect on the public grid and/or cause inverter malfunctions and failures and result in the loss of standard conformity.
Parameters may only be adjusted if this has been approved or requested by the utility.
Any parameter adjustments must be made in compliance with nationally applicable standards and/or directives as well as the specifications of the utility.
The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. To apply for the access code required for this menu area, see chapter Requesting inverter codes in Solar.SOS.
The selected country setup for the country in question contains preset parameters in accordance with nationally applicable standards and requirements. Changes may need to be made to the selected country setup depending on local grid conditions and the specifications of the utility.
The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. The inverter access code required for this menu area can be requested in the Fronius Solar.SOS portal.
Activating this function limits the output power of the inverter to the specified value in watts.
Energy companies or grid operators can prescribe feed-in limits for inverters (e.g., max. 70% of the kWp or max. 5 kW). The inverter limits the effective power at the grid connection point (installation location of the Fronius Smart Meter or primary meter) to the set value.
The inverter takes account of self-consumption in the household before the power is reduced. An individual limit can be set.
In order to minimize the yield losses due to the power of feeding in limitation, the power available from the module array can be:
If these possibilities have been exhausted, the power drawn from the module array is reduced to such an extent that the feed-in limit is not exceeded.
Installation variants with an inverter, Fronius Smart Meter, and system components are listed under Different operating modes.
Total DC power of the system
The input field for the total DC power of the entire system in Wp. Always enter this value if the Maximum grid feed-in power is specified in %.
Power Control deactivated
The inverter converts all available PV energy.
Power Control activated
Feeding in limited with the following selection options:
IMPORTANT! Implement the settings for Limit per phase if national standards and regulations require a limitation of the single-phase power. Set the value for the permissible power of feeding in for each phase.
IMPORTANT! Power Control settings are automatically applied for the dynamic feed-in limit of I/O power management. Total Power Limit is the default configuration.
Dynamic feed-in limit (Soft Limit)
If this value is exceeded, the inverter readjusts down to the set value.
Export Limit Protection (PAV,E protection)
This function monitors compliance with the feed-in limit. If Dynamic feed-in limit (Soft Limit) is activated, the inverter controls the power of feeding in in such a way that this function is usually not activated. If the specified limit values and the switch-off times are exceeded, this protection function disconnects the inverter from the grid.
The Maximum grid feed-in power (PAV,E) in the case of an asymmetric feed-in (Limit per phase – asymmetric generation or Limit per phase – weakest phase) can be combined with the export limit protection (PAV,E protection) function. The Maximum grid feed-in power is calculated as follows: Maximum grid feed-in power per phase (PAV,E) x 3.
The export limit protection (PAV,E protection) function is only possible if a Smart Meter IP configured with MQTT is installed at the feed-in point.
Export Limit Protection (Hard Limit Trip)
IMPORTANT! This function is only available if Dynamic feed-in limit (Soft Limit) is activated.
Input field for the Maximum grid feed-in power in W or % (setting range: ‑10 % to 100 %).
If there is no meter in the system or if the primary meter has failed, the inverter limits its output power to the set value.
If this value is exceeded, the inverter switches off within max. 5 s. This value must be higher than the value set for Export Limit Control (Soft Limit).
If required, enable the fail-safe function Reduce inverter power to 0% if meter connection has been lost. When this function is enabled, the inverter activates standby mode. No feed-in takes place.
The use of WiFi for communication between the Fronius Smart Meter and the inverter is not recommended with the fail-safe function activated at the same time. Even short-term disconnections can cause the inverter to shut down. This problem arises with weak WiFi signal strengths, a slow or overloaded WiFi connection, and automatic channel selection of the router.
Energy companies or grid operators can prescribe import limitations for inverters. The amperage is limited to the set value.
Total Power Limit
(feed-in limit 0 kW with battery)
Explanation
No power (0 kW) may be fed into the public grid at the grid feed-in point. The load requirement in the home network (6 kW) is supplied by the power generated by the inverter. Surplus production (4 kW) is stored in the battery.
(feed-in limit 0 kW per phase) – asymmetric
Explanation
The load requirement in the home network per phase is determined and supplied.
(feed-in limit 0 kW per phase with battery) – asymmetric
Explanation
The load requirement in the home network per phase is determined and supplied. Additional power required (2 kW) is provided by the battery.
(feed-in limit 0 kW per phase with battery) – symmetrical
Explanation
The weakest phase in the load requirement in the home network is determined (phase 1 = 1 kW). The result of the weakest phase (1 kW) is applied to all phases. Phase 1 (1 kW) can be supplied. Phase 2 (2 kW) and phase 3 (3 kW) cannot be supplied, power from the public grid is required (phase 2 = 1 kW, phase 3 = 2 kW). Surplus production (7 kW) is stored in the battery.
IMPORTANT! To view and change settings in this menu item, select the Technician user. Enter and confirm the password for the Technician user. Settings in this menu area may only be made by trained and qualified personnel.
The inverter can be used as a primary device to control dynamic feed-in limits for additional Fronius inverters (secondary devices) so that feed-in limits prescribed by energy companies or utilities can be centrally managed. This control refers to the Soft Limit feed-in limit see Feed-in limit. To do so, the following requirements must be met:
IMPORTANT! Only one primary meter is required for the primary device.
IMPORTANT! If an inverter with a battery is connected, use this inverter as the primary device for Multiple Inverter Control.
Multiple Inverter Control is available for the following device combinations:
Primary devices | Secondary devices |
GEN24, Verto, Tauro |
Primary meter
One Fronius Smart Meter acts as the only primary meter and is connected directly to the primary device. This Smart Meter measures the total output power of all inverters into the grid and passes this information to the primary device.
Primary device
Configure the feed-in limit on the user interface of the inverter:
To perform the search again, press the Refresh button .
If Use Modbus TCP is activated, it is also possible to select Fronius SnapINverters with Datamanager 2.0 and Fronius Argeno with Use Inverter.
For more information on configuring the Fronius Argeno or Fronius Datamanager 2.0 as a secondary device, refer to the respective operating instructions.
Secondary device
Each secondary device takes over the settings for the feed-in limit from the primary device. A secondary device does not transmit any data for the feed-in limit to the primary device. To do so, the following requirements must be met:
Set the following configurations for the feed-in limit on the secondary device:
Only carry out work steps 2 and 3 if Use Modbus TCP is activated on the primary device.
General
Settings relevant to the grid operator are defined as rules under this menu item. This relates to an effective power limit in % or watts and/or a power factor specification. To view and change settings, select the Technician user, and enter and confirm the password. Only technical specialists may make settings in this menu area.
Under Rules, expand a menu area (e.g., Rule 1). Configure the following settings:
Limitation
IMPORTANT!
A dynamic feed-in limit for several inverters can be configured under Feed-in limit. I/O power management rules are transferred from the inverter (primary device) to connected inverters in the system (secondary devices).
Select the following rules for power management:
IMPORTANT!
The rules for shutdown apply to this device and cannot be applied to other inverters in the system.
Input pattern (assignment of individual I/Os)
1 click = white, contact open
2 clicks = blue, contact closed
3 clicks = gray, not used
Power Factor (cos φ) (define value)
Impedance response
DNO Feedback
If the rule is activated, always configure the DNO Feedback output, e.g., for operating a signal device.
The Import and Export of defined rules can be carried out in the data format *.fpc. The rules and pin assignments in the following connection examples are not the only possible configurations. For pin assignment, take into account the available connections at the Data communication area and settings of the device configuration.
If there is an active rule for the control of the inverter, the device indicates this in the overview of the user interface under Device State.
Controlling Priorities
Used to set controlling priorities for I/O Power Management (DRM or ripple control receiver), the feed-in limit, and control via Modbus.
1 = highest priority, 3 = lowest priority
Local priorities of the I/O power management, the feed-in limit, and the Modbus interface are deactivated by cloud control commands (regulatory purposes and virtual power plants) – see Cloud control – and by backup power.
In terms of controlling priorities, the device differentiates between power control and inverter shutdown. Inverter shutdown always takes precedence over power control. An inverter shutdown command is always executed and does not need to be prioritized.
Power controlConnect the ripple control signal receiver and the I/O terminals of the inverter to one another as shown in the connection diagram.
For distances greater than 10 m between the inverter and the ripple control signal receiver, use a shielded data communication cable (CAT 5 or higher) with twisted cable pairs. Connect the shielding on one side to the terminal of the data communication area (SHIELD).
| (1) | Ripple control signal receiver with 4 relays for effective power limitation. |
| (2) | I/O connection terminals of the data communication area. |
| (1) | Ripple control signal receiver with 3 relays for effective power limitation. |
| (1) | Ripple control signal receiver with 2 relays for effective power limitation. |
| (1) | Ripple control signal receiver with 1 relay for effective power limitation. |
The grid operator may request the connection of one or more inverters to a ripple control receiver in order to limit the active power and/or the power factor of the photovoltaic system.
On the user interface of each inverter connected to the ripple control receiver, set the same parameters for I/O power management.
Description
The Autotest makes it possible to check the Italian protection function, required by the applicable standard for monitoring the voltage and frequency limit values of the inverter during commissioning. In normal operation, the inverter constantly checks the real-time actual value of the voltage and frequency of the grid.
Once the Autotest has started, different individual tests are carried out automatically, in succession. Depending on the grid conditions, the duration of the test is approximately 15 minutes.
IMPORTANT!
In Italy, the inverter may only be commissioned following a successfully completed Autotest (CEI 0-21). If an Autotest is not passed, grid power feed operation may not take place. Once the Autotest is started, it must be completed successfully. The Autotest cannot be started during backup power mode.
Umax | Test for checking the maximum voltage in the phase conductors |
Umin | Test for checking the minimum voltage in the phase conductors |
fmax | Test for checking the maximum mains frequency |
fmin | Test for checking the minimum mains frequency |
fmax alt | Test for checking an alternative maximum mains frequency |
fmin alt | Test for checking an alternative minimum mains frequency |
U outer min | Test for checking the minimum outer voltages |
U longT. | Test for checking the 10 min. voltage average |
Note on the Autotest
The limit values are set in the Safety and Grid Regulations > Country Setup> Grid Support Functions menu area.
The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. The inverter access code required for this menu area can be requested in the Fronius Solar.SOS portal (see chapter Requesting inverter codes in Solar.SOS on page (→)).
A surge protection device (SPD) protects against temporary overvoltages and diverts surge currents (e.g., lightning strike). Based on an overall lightning protection concept, the SPD contributes to the protection of the photovoltaic system components.
For detailed information on the wiring diagram of the surge protection device, see chapter Surge protection device (SPD) on page (→).
If the surge protection device is triggered, the color of the indicator changes from green to red (mechanical display) and the operating status LED of the inverter lights up red (see chapter Button functions and LED status indicator on page (→)). The error code 1030 WSD Open is displayed on the user interface of the inverter in the System > Event Log menu area or in the user menu under Notifications and in Fronius Solar.web. In this case, the inverter must be repaired by an authorized specialist company.
IMPORTANT!
The inverter also switches off if the 2-pin signal cable of the surge protection device is interrupted or damaged.
External surge protection device
To receive a notification when external surge protection devices are triggered, it is recommended to connect the feedback contacts connected in series to the WSD input.
IMPORTANT!
IMPORTANT!
Danger due to electrical voltage on live parts of the photovoltaic system.
Disconnect live parts of the photovoltaic system on all pins and on all sides.
Secure against re-activation in accordance with national regulations.
Allow the capacitors of the inverter to discharge (2 minutes).
Check that the inverter is de-energized with a suitable measuring device.
The surge protection device (SPD) is available as an option and can be retrofitted to the inverter.
For technical data, see chapter Technical data on page (→).
IMPORTANT!
A larger ground conductor cross-section may be required depending on national standards and regulations.
Fit a ring cable lug (internal diameter: 4 mm, outer diameter: max. 10 mm) as well as a corresponding ferrule. Fasten the ground conductor to the PC board with a torque of 1.5 Nm.
Turn off the automatic circuit breaker. Set the DC disconnector to the "off" switch position.
Switch off the battery connected to the inverter.
Wait for the capacitors of the inverter to discharge (2 minutes).
Switch on the battery connected to the inverter.
Set the DC disconnector to the "on" switch position. Turn on the automatic circuit breaker.
The DC Connector Kit GEN24 (item number: 4,240,046) enables PV-connection strings with the following total currents to be connected:
IMPORTANT!
Do not use the DC Connector Kit GEN24 if the device has an integrated Arc Fault Circuit Interrupter (AFCI), which is used for the arc detection requirement according to IEC 63027. Carry out installation in accordance with the nationally applicable standards and guidelines.
IMPORTANT!
To enable suitable PV modules to be chosen and to use the inverter as efficiently as possible, it is important to bear the following points in mind:
IMPORTANT!
Before connecting up the PV modules, check that the voltage for the PV modules specified by the manufacturer corresponds to the actual measured voltage.
IMPORTANT!
The PV modules connected to the inverter must comply with the IEC 61730 Class A standard.
IMPORTANT!
Solar module strings must not be grounded.
The commissioning, maintenance, and service work in the inverter's power stage set may only be carried out by Fronius-trained service personnel in accordance with the technical specifications.
Read the installation instructions and operating instructions before installing and commissioning the equipment.
Danger from mains voltage and DC voltage from PV modules that are exposed to light.
All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and are de-energized.
Only an authorized electrical engineer is permitted to connect this equipment to the public grid.
Danger of an electric shock due to improperly connected terminals/PV plug connectors.
When connecting, ensure that each pole of a string is routed via the same PV input, e.g.:
+ pole string 1 to the input PV 1.1+ and - pole string 1 to the input PV 1.1-
Danger from damaged and/or contaminated terminals.
Prior to connection work, check the terminals for damage and contamination.
Remove any contamination while the equipment is de-energized.
Have defective terminals replaced by an authorized specialist company.
The DC Connector Kit GEN24 is available as an option and can be retrofitted to the inverter.
Risk due to insufficiently dimensioned DC cables.
This may result in damage to the inverter due to thermal overload.
For dimensioning the DC cables, observe the information according to chapter Permitted cables for the electrical connection on page (→).
Loosen the 2 screws on the underside of the housing cover by rotating them 180° to the left using a screwdriver (TX20). Then lift the housing cover away from the inverter at the bottom and detach from above.
Loosen the 5 screws on the connection area cover by rotating them 180° to the left using a screwdriver (TX20).
Remove the connection area cover from the device.
Insert the DC Connector GEN24 into the inverter and fasten it using the 2 screws supplied (TX20) and a torque of 1.2 Nm.
Push the DC cables through the DC bushings by hand.
Press the latch on the back of the terminal and remove the DC terminals.
Strip the insulation of the single conductors by 18 - 20 mm.
Select the cable cross-section in accordance with the instructions in Permitted cables for the electrical connection from page (→).
Press the latch on the terminal with a slotted screwdriver. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then remove the slotted screwdriver from the latch.
Connect the solar module strings (+/-).
Danger due to polarity reversal at the terminals.
This may result in severe damage to the inverter.
Use a suitable measuring instrument to check the voltage (max. 1000 VDC) and the polarity of the DC cabling.
Use a suitable measuring instrument to check the voltage and polarity of the DC cabling.
Risk due to overtorque at the strain-relief device.
Damage to the strain-relief device may result.
Do not use a drill driver.
Insert the DC terminals into the respective slot until they engage. Fasten the screws of the strain-relief device to the housing using a screwdriver (TX20) and a torque of 1.4 Nm.
Danger due to electrostatic discharge (ESD).
This may result in damage to electronic components.
Pay attention to the ESD marking on the product and/or on the packaging.
Take ESD protection measures (grounding, neutralizing, and shielding).
The continuous supply via the PV Point depends on the available PV power.
If the solar modules are not supplying enough power, interruptions may occur.
Do not connect any loads that require an uninterruptible supply.
IMPORTANT!
IMPORTANT!
The PV Point Comfort is available as an option and can be retrofitted to the inverter.
Danger due to insufficiently dimensioned ground conductors.
Observe the national standards and regulations for dimensioning of the ground conductor.
Press the latch on the back of the terminal and remove the AC terminals. Loosen the cable gland.
Disconnect the single conductors from the AC terminal (only necessary for an existing installation).
Remove the ferrite core and the mains cable from the inverter.
Drill out the optional cable gland with a step drill.
Insert the cable gland into the hole and fasten with a torque of 6 Nm.
Insert the insulating film on the right side of the ground electrode terminal.
Insert the PC board into the inverter.
Fasten the PC board using the 4 screws supplied (TX20) and a torque of 1.2 Nm.
Fasten the supplied phase and neutral conductors to the terminal using a slotted screwdriver.
Strip 12 mm of insulation from the single conductors. Lift the operating lever of the AC terminal to open. Insert the stripped single conductor into the slot provided in the AC terminal as far as it will go. Then close the operating lever until it engages.
IMPORTANT!
Establish the PEN connection in accordance with national regulations. If necessary, replace the supplied PEN connection.
Fasten the PEN connection to the ground electrode terminal at the second input from above using a screwdriver (TX20) and a torque of 1.8 - 2 Nm.
Strip 12 mm of the insulation from the single conductors.
Select the cable cross-section according to the specifications for the respective power category of the inverter (see chapter Permitted cables for the electrical connection on page (→)).
Execute the residual current circuit breaker and automatic circuit breaker in accordance with national regulations.
IMPORTANT!
If necessary, use an automatic circuit breaker with a maximum 16 A for fuse protection. A max of 13 A can be supplied in backup power mode. If the inverter is protected with an automatic circuit breaker with a maximum 16 A, it is possible to dispense with an additional automatic circuit breaker.
Pass the phase/neutral conductors through the ferrite core. Fasten the ground conductor to the ground electrode terminal at the third input from above using a screwdriver (TX20) and a torque of 1.8 - 2 Nm.
IMPORTANT!
The ground conductors must not be passed through the ferrite core and must be connected using a movement loop so that the ground conductors are disconnected last if the cable glands fail.
Connect the stripped phase/neutral conductors to the terminals provided.
Insert the terminals into the respective slot until they engage. Fasten the union nuts of the cable glands with a torque of 4 Nm.
Firmware version 1.25.2 or higher is required to commission the PV Point Comfort. Outdated firmware versions could lead to incompatibilities between the inverter and PV Point Comfort. In this case, the inverter firmware should be updated in accordance with the chapter headed Update on page (→).
The inverter is designed so that it does not require additional maintenance work. Nevertheless, a few points must be considered during operation to ensure that the inverter works perfectly.
Maintenance and service work may only be carried out by a technical specialist.
Wipe the inverter, if necessary, with a damp cloth.
Do not use cleaning agents, scouring agents, solvents, or similar products to clean the inverter.
The DC disconnector is used only to switch off power to the power stage set. When the DC disconnector is turned off, the connection area is still energized.
Danger from mains voltage and DC voltage from PV modules.
The connection area must only be opened by an authorized electrician.
The separate power stage set area must only be opened by Fronius-trained service technicians.
Prior to any connection work, ensure that the inverter is de-energized on the AC side and the DC side.
Danger of residual voltage from capacitors.
If the inverter is operated in dusty environments, dirt may build up on the heat sink and fan.
This may result in a loss of power due to insufficient cooling of the inverter.
Make sure that the ambient air can always flow through the inverter's ventilation slots unimpeded.
Remove any build-ups of dirt from the heat sink and the fan.
Switch off power to the inverter and wait for the capacitors to discharge (2 minutes) and the fan to shut down.
Turn the DC disconnector to the "off" switch setting.
Loosen the screws on the underside of the housing cover by rotating them 180° to the left using a screwdriver (TX20). Then lift the housing cover away from the inverter at the bottom and detach from above.
Risk due to damage to the fan bearing in the event of incorrect cleaning.
Excessive speeds and the application of pressure to the fan bearing can cause damage.
Block the fan and clean with compressed air.
When using a cloth or brush, clean the fan without applying any pressure.
Remove any build-up of dirt on the heat sink and fan using compressed air, a cloth, or a brush.
To start up the inverter again, follow the steps listed above in reverse order.
Used equipment and batteries must be returned to the distributor or an authorized local collection system. Do not dispose of batteries with domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
Arrange for the safe collection and proper disposal of damaged, leaking or used batteries by a battery recycling company or the Fronius Service Partner.
In addition, it should be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances such as heavy metals or electrolytes, which can contaminate soil, water and air.
This ensures environmental protection and the sustainable use of natural resources.Packaging materialsDetailed warranty conditions specific to your country can be found at https://www.fronius.com/en/download-center?searchword=Warranty+conditions .
If there is a warranty for the relevant product, register the product at https://warranty.fronius.com/ and activate or extend the warranty.
Fronius components
With the Fronius components, no additional components are required for the automatic changeover to backup power. If components are not available depending on national availability, automatic changeover to backup power can be implemented with the following third-party components.
Product | Item number |
Fronius Backup Controller 3P-35A | 4,240,047,CK |
Fronius Backup Controller 3PN-35A | 4,240,048,CK |
Fronius Smart Meter IP 5kA-3 | 42,0411,0347 |
Fronius Smart Meter 63A-3 | 43,0001,1473 |
Fronius Smart Meter 50kA-3 | 43,0001,1478 |
Fronius Smart Meter TS 65A-3 | 43,0001,0044 |
Fronius Smart Meter TS 5kA-3 | 43,0001,0046 |
Fronius Smart Meter WR | 43,0001,3591 |
Third-party components
Manufacturers/types other than the product examples listed are permissible, provided that they meet the same technical and functional requirements.
Grid and system protection | |
Manufacturer/type | Bender GmbH & Co. KG VMD460-NA-D-2 |
K1 and K2 - AC installation contactor with auxiliary contact | |||
Number of pins | 3-pin or 4-pin | ||
Rated current | depending on the house connection | ||
Coil voltage | 230 VAC | ||
Rated frequency | 50/60 Hz | ||
Coil fuse | 6 A | ||
Minimum short circuit current | 3 kA (contacts) | ||
Test standard | IEC 60947-4-1 | ||
Auxiliary contact | |||
Number of NC contacts | 1 | ||
Switching voltage | 12 - 230 V @ 50 / 60 Hz | ||
Minimum nominal current | 1 A | ||
Minimum short circuit current | 1 kA | ||
Manufacturer/type | ISKRA IK63-40 / Schrack BZ326461 | ||
Buffer power supply - Fault Ride Through cabling variant | |
Manufacturer/type | BKE JS-20-240/DIN_BUF |
K1 and K2 - DC installation contactor with auxiliary contact (Fault Ride Through) | |||
Coil voltage | 24 VDC | ||
Switching voltage | 24 VDC | ||
Manufacturer/type | Finder 22.64.0.024.4710 | ||
K3 - Modular relay | |||
Number of changeover contacts | 2 | ||
Coil voltage | 12 VDC | ||
Manufacturer/type | Finder 22.23.9.012.4000 / Schrack relay RT424012 (bracket RT17017, relay base RT78725) | ||
K4 and K5 - Installation contactor | |||
Number of NC contacts | 2 (25 A) | ||
Coil voltage | 230 V AC (2P) | ||
Manufacturer/type | ISKRA IKA225-02 | ||
Fronius components
Fronius Backup Switch 1P/3P-63A | 4,050,221 |
Fronius Backup Switch 1PN/3PN-63A | 4,050,220 |
Status codes are displayed on the user interface of the inverter in the System > Event Log menu area or in the user menu under Notifications and in Fronius Solar.web*.
| * | If configured accordingly, see chapter Fronius Solar.web on page (→). |
| Cause: | A device that is connected in the WSD chain has interrupted the signal line (e.g., surge protection device) or the bypass installed ex works as standard has been removed and no trigger device has been installed. |
| Remedy: | If the SPD surge protection device has tripped, the inverter must be repaired by an authorized specialist. |
| OR: | Install the bypass installed ex works as standard or a trigger device. |
| OR: | Turn the WSD (wired shutdown) switch to position 1 (WSD primary device). |
WARNINGDanger from work that is not carried out properly. This can result in serious injury and damage to property. The installation and connection of an SPD surge protection device may only be carried out by Fronius-trained service personnel in accordance with the technical specifications. Observe safety rules. | |
DC input data | |
MPP voltage range | 174 - 800 V |
Maximum connected load (PPV max) |
Maximum processable PV power |
Maximum input voltage | 1000 V |
Feed-in start voltage in grid operation 5) | 80 V |
Maximum input current |
Maximum short circuit current for module array (ISC PV) |
Maximum total short circuit current for module array |
Max. inverter backfeed current to the array 3) |
Number of inputs—PV 1 | 2 |
Number of inputs—PV 2 | 1 |
Maximum capacity of the PV generator against ground | 1200 nF |
Limit value of the insulation resistance test between module array and ground (on delivery) 10) | 100 kΩ |
Adjustable range of insulation resistance test between module array and ground 9) | 10-10,000 kΩ |
Limit value and trip time of sudden residual fault current monitoring (on delivery) | 30/300 mA/ms |
Limit value and trip time of continuous residual fault current monitoring (on delivery) | 300/300 mA/ms |
Adjustable range of continuous residual current monitoring 9) | 30-300 mA |
Cyclic repetition of the insulation resistance test (on delivery) | 24 h |
Adjustable range for cyclic repetition of the insulation resistance test | - |
DC input data battery 8) | |
Maximum voltage | 700 V |
Minimum voltage | 160 V |
Maximum current | 22 A |
Maximum output | 6000 W |
DC inputs | 1 |
AC input/output data | |
Rated power (Pnom) | 6000 W |
Maximum output power | 6000 W |
Rated apparent power | 6000 VA |
Nominal mains voltage | 3 ~ NPE 220 V/380 V |
Grounding systems | TN-S (allowed) |
Minimum mains voltage | 154 V 1) |
Maximum mains voltage | 280 V 1) |
Maximum output current | 16.4 A |
Rated output current | 8.7 A |
Current (inrush) 6) | 9.9 A/4 ms |
Nominal frequency | 50/60 Hz 1) |
Initial symmetrical short-circuit current/phase IK" | 16.4 A |
Nominal frequency for Full Backup | 53/63 Hz 1) |
Total harmonic distortion | < 3.5% |
Power factor cos phi 2) | 0-1 (adjustable) |
Maximum permitted grid impedance Zmax on PCC 4) | None |
Maximum output fault current / duration | 80.7 A/10 ms |
AC output data PV Point/PV Point Comfort | |
Maximum output power | 4133 W (for 5 s) |
Nominal output power | 3000 W |
Rated output current | 13 A |
Nominal mains voltage | 1 ~ NPE 220 V/230 V/240 V |
Nominal frequency | 53/63 Hz 1) |
Switching time | ~ 15 s |
Power factor cos phi 2) | 0 - 1 |
AC output data Full Backup 8) | |
Maximum output power | 12,400 W (for 5 s) |
Maximum output power (per phase) | 4133 W (for 5 s) |
Nominal output power | 6000 W |
Nominal output power (per phase) 7) | 3680 W |
Rated output current | 16 A |
Switching time | ~ 10 s |
Switching time with Rapid switch mode | < 20 ms |
General data | |
Maximum efficiency | 98.2% |
Europ. efficiency (Umpp nom) | 97.7% |
Europ. efficiency (Umpp max) | 97.3% |
Europ. efficiency (Umpp min) | 96.5% |
Self-consumption at night | ≤ 10 W |
Cooling | Controlled forced-air ventilation |
Ingress protection rating | IP 66 |
Dimensions H × W × D | 595 × 529 × 180 mm |
Weight | 23.4 kg |
Inverter topology | Non-insulated, no transformer |
Permitted ambient temperature | -25 °C - +60 °C |
Permissible humidity | 0-100% (incl. condensation) |
EMC emission class | B |
DC/AC overvoltage category | 2/3 |
Pollution degree | 2 |
Sound pressure level | 47 dB(A) (ref. 20µPA) |
Protective class | 1 |
Protective devices | |
DC isolation measurement | Warning/shutdown at RISO < 100 kOhm |
Overload performance | Operating point shift, power limit |
DC disconnector | Integrated |
RCMU | Integrated |
RCMU classification | The software class of the safety platform(s) is defined as a class B control function (single-channel with periodic self-test) in accordance with IEC 60730 Annex H. |
Active anti-islanding method | Frequency point shift method |
Data communication | |
WiFi SMA-RP connection | 802.11b/g/n (WPA, WPA2) |
Ethernet (LAN) | RJ 45, 10/100 Mbit |
Wired shutdown (WSD) | Max. 28 devices/WSD chain |
Modbus RTU SunSpec (2x) | RS485 2-wire |
Battery connection | Modbus O/RJ 45/12 V power supply |
Voltage level of digital inputs | Low: min. 0 V-max. 1.8 V |
Input currents of digital inputs | depending on the input voltage; |
Total power for digital output (with internal supply) | 6 W at 12 V |
Power per digital output | 1 A at >12.5 V-24 V |
Datalogger/web server | Integrated |
DC input data | |
DC inputs | 1 |
General data | |
Weight | 23.4 kg |
RCMU | Integrated |
DC input data | |
MPP voltage range | 148 - 800 V |
Minimum input voltage | 80 V |
DC inputs | 1 |
Maximum output current | 18.5 A |
Rated output current (at 230 V) | 8.7 A |
Initial symmetrical short-circuit current/phase IK" | 18.5 A |
Maximum output power | 4255 W (for 5 s) |
Maximum output power | 12,765 W (for 5 s) |
Maximum output power (per phase) | 4255 W (for 5 s) |
Nominal output power (per phase) 7) | 4133 W |
Rated output current (per phase) | 16 A |
General data | |
Maximum efficiency | 98.3% |
Europ. efficiency (Umpp nom) | 97.9% |
Europ. efficiency (Umpp max) | 97.6% |
Europ. efficiency (Umpp min) | 96.3% |
Weight | 22.8 kg |
Sound pressure level | 47 dB(A) (ref. 20 µPA) |
DC isolation measurement 11) | Warning/shutdown at RISO < 100 kOhm |
RCMU 11) | Integrated |
AFCI | Integrated |
AFPE (AFCI) classification (according to IEC 63027) 11) | = F-I-AFPE-1-3-1 |
DC input data | |
MPP voltage range | 224 - 800 V |
Maximum capacity of the PV generator against ground | 1600 nF |
Maximum output | 8000 W |
DC inputs | 1 |
Rated power (Pnom) | 8000 W |
Maximum output power | 8000 W |
Rated apparent power | 8000 VA |
Rated output current | 11.6 A |
Nominal output power | 8000 W |
General data | |
Europ. efficiency (Umpp nom) | 97.8% |
Europ. efficiency (Umpp max) | 97.5% |
Europ. efficiency (Umpp min) | 96.9% |
Weight | 23.4 kg |
RCMU | Integrated |
DC input data | |
MPP voltage range | 197 - 800 V |
DC inputs | 1 |
Rated output current (at 230 V) | 11.6 A |
General data | |
Europ. efficiency (Umpp nom) | 98.0% |
Europ. efficiency (Umpp max) | 97.8% |
Europ. efficiency (Umpp min) | 96.7% |
Weight | 22.8 kg |
RCMU | Integrated |
AFCI | Integrated |
DC input data | |
MPP voltage range | 278 - 800 V |
Maximum capacity of the PV generator against ground | 2000 nF |
Maximum output | 10,000 W |
DC inputs | 1 |
Rated power (Pnom) | 10,000 W |
Maximum output power | 10,000 W |
Rated apparent power | 10,000 VA |
Rated output current | 14.5 A |
Nominal output power | 10,000 W |
Nominal output power | 3680 W |
General data | |
Europ. efficiency (Umpp max) | 97.7% |
Europ. efficiency (Umpp min) | 97.1% |
Weight | 23.4 kg |
RCMU | Integrated |
DC input data | |
MPP voltage range | 246 - 800 V |
DC inputs | 1 |
Rated output current (at 230 V) | 14.5 A |
General data | |
Europ. efficiency (Umpp nom) | 98.1% |
Europ. efficiency (Umpp max) | 97.9% |
Europ. efficiency (Umpp min) | 97.0% |
Weight | 22.8 kg |
RCMU | Integrated |
AFCI | Integrated |
DC input data | |
DC inputs | 1 |
Rated power (Pnom) | 9999 W |
Maximum output power | 9999 W |
Rated apparent power | 9999 VA |
Nominal output power | 9999 W |
General data | |
Weight | 22.8 kg |
RCMU | Integrated |
AFCI | Integrated |
DC input data | |
MPP voltage range | 295 - 800 V |
Maximum output | 12,000 W |
DC inputs | 1 |
Rated power (Pnom) | 12,000 W |
Maximum output power | 12,000 W |
Rated apparent power | 12,000 VA |
Rated output current (at 230 V) | 17.4 A |
Nominal output power | 12,000 W |
Rated output current (per phase) | 17.4 A |
General data | |
Weight | 22.8 kg |
RCMU | Integrated |
AFCI | Integrated |
Frequency range | 2412 - 2462 MHz |
Channels / power used | Channel: 1-11 b,g,n HT20 |
Modulation | 802.11b: DSSS (1Mbps DBPSK, 2Mbps DQPSK, 5.5/11Mbps CCK) |
General data | |
Continuous operating current (Icpv) | < 0.1 mA |
Rated discharge current (In) | 20 kA |
Lightning surge current (limp) | 6.25 kA |
Protection level (Up) | 4 kV |
Short circuit strength PV (Iscpv) | 15 kA |
Disconnector | |
Thermal disconnector | Integrated |
External fuse | None |
Mechanical properties | |
Disconnection indicator | Mechanical indicator (red) |
Remote communication of the connection interruption | Output on the changeover contact |
Housing material | Thermoplastic UL-94-V0 |
Test standards | IEC 61643-31 / DIN EN 50539-11 |
| 1) | The values provided are standard values. If required, the inverter is customized for a specific country. |
| 2) | Depending on the country setup or device-specific settings (ind. = inductive; cap. = capacitive). |
| 3) | Maximum current from a defective PV module to all other PV modules. From the inverter itself to the PV side of the inverter, this is 0 A. |
| 4) | Assured by the electrical design of the inverter. |
| 5) | For backup power mode (PV Point) without a battery, a min. voltage of 150 V is required. |
| 6) | Peak current when turning on the inverter. |
| 7) | The total nominal output power per phase must not exceed the nominal output power of the inverter. |
| 8) | Valid for Fronius inverter with battery support. |
| 9) | The values provided are standard values. These values must be adjusted according to requirements and PV output. |
| 10) | The value provided is a max. value. If this value is exceeded, this may impair the function. |
Symo GEN24 3-10 kW Plus
General data | |
Product name | Benedict LS32 E 7905 |
Rated insulation voltage | 1000 VDC |
Rated impulse withstand voltage | 8 kV |
Suitability for insulation | Yes, DC only |
Utilization category and/or PV utilization category | according to IEC/EN 60947-3 utilization category DC-PV2 |
Rated short-time withstand current (Icw) | Rated short-time withstand current (Icw): 1000 A |
Rated short-circuit capacity (Icm) | Rated short-circuit capacity (Icm): 1000 A |
Rated operating current and rated breaking capacity | ||||
Rated operating voltage (Ue) | Rated operating current (Ie) | I(make) / I(break) | Rated operating current (Ie) | I(make) / I(break) |
≤ 500 VDC | 14 A | 56 A | 36 A | 144 A |
600 VDC | 8 A | 32 A | 30 A | 120 A |
700 VDC | 3 A | 12 A | 26 A | 88 A |
800 VDC | 3 A | 12 A | 17 A | 68 A |
900 VDC | 2 A | 8 A | 12 A | 48 A |
1000 VDC | 2 A | 8 A | 6 A | 24 A |
Number of pins | 1 | 1 | 2 | 2 |
Symo GEN24 3-12 kW Plus SC
General data | |
Product name | Benedict LSA32 E 8229 |
Rated impulse withstand voltage | 6 kV |
300 VDC | 27 A | 108 A | 47 A | 188 A |
400 VDC | 20 A | 80 A | 45 A | 180 A |
500 VDC | 14 A | 56 A | 38 A | 152 A |
600 VDC | 11.5 A | 46 A | 33 A | 132 A |
700 VDC | 7.5 A | 30 A | 28 A | 112 A |
800 VDC | 5.75 A | 23 A | 23 A | 92 A |
900 VDC | 4.75 A | 19 A | 20 A | 80 A |
1000 VDC | 4 A | 16 A | 13 A | 52 A |
