LogoTransSteel 4000 Pulse, TransSteel 5000 Pulse
  • en-US
    • Contact
    • Imprint
    • T&Cs
    • Data protection
    • 008-12122024
    • Safety Instructions
      • Explanation of Safety Instructions
      • General
      • Intended Use
      • Environmental Conditions
      • Obligations of the Operating Company
      • Obligations of Personnel
      • Grid Connection
      • Personal Protection and Protection of Others
      • Danger from toxic gases and vapors
      • Danger from Flying Sparks
      • Risks from mains current and welding current
      • Stray welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Particular hazard areas
      • Requirement for the shielding gas
      • Danger from Shielding Gas Cylinders
      • Danger Posed by Shielding Gas Leak
      • Safety Measures at the Setup Location and during Transport
      • Safety Measures in Normal Operation
      • Maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data backup
      • Copyright
    • General information
      • General
        • Device concept
        • Operating principle
        • Application areas
      • Welding processes, procedures, and welding characteristics for MIG/MAG welding
        • General
        • Brief description of MIG/MAG standard synergic welding
        • Brief description of MIG/MAG pulsed synergic welding
        • Brief description of SynchroPulse welding
        • Brief description of the gouging (Arc Air Gouging)
      • System components
        • General
        • Safety
        • Overview
      • VRD: Safety function
        • VRD: Safety principle
    • Operating controls and connections
      • Control Panel
        • General
        • Safety
        • Control panel
        • Service parameters
        • Keylock
      • Connections, Switches, and Mechanical Components
        • TransSteel 4000/5000 Pulse connections
    • Installation and Startup
      • Minimum equipment for welding operations
        • General
        • Gas-cooled MIG/MAG welding
        • Water-cooled MIG/MAG welding
        • Manual metal arc welding
        • Minimum equipment for arc air gouging
      • Before installation and initial operation
        • Safety
        • Intended use
        • Setup regulations
        • Grid Connection
      • Connecting the Mains Cable
        • General
        • Stipulated mains cables and strain-relief devices
        • Safety
        • Connecting the mains cable
        • Fitting the strain-relief device for Europe
        • Fitting the strain-relief device for Canada / US
      • Generator-Powered Operation
        • Generator-powered operation
      • Commissioning
        • Safety
        • General
        • Information on system components
        • Assembling system components (overview)
        • Place the wirefeeder on the power source
        • Fit the strain-relief device of the interconnecting hosepack
        • Connecting the interconnecting hosepack
        • Correct routing of the interconnecting hosepack
        • Connecting the gas cylinder
        • Establishing a ground earth connection
        • Connecting a MIG/MAG welding torch
        • Other activities
        • Setting the date and time when starting for the first time
    • MIG/MAG welding
      • Power Limitation
        • Safety function
      • MIG/MAG Operating Modes
        • General
        • Symbols and explanations
        • 2-step mode
        • 4-step mode
        • Special 2-step mode
        • Special 4-step mode
        • Spot welding
        • 2-step stitch welding
        • 4-step stitch welding
      • MIG/MAG welding
        • Safety
        • Preparation
        • Overview
      • MIG/MAG synergic welding
        • Corrections during welding
        • SynchroPulse welding
      • MIG/MAG Standard Manual Welding
        • General
        • Available parameters
        • MIG/MAG standard manual welding
      • Spot welding and stitch welding
        • General
        • Spot welding
        • Stitch welding
      • EasyJob mode
        • General
        • Saving EasyJob operating points
        • Retrieving EasyJob operating points
        • Deleting EasyJob operating points
        • Retrieving EasyJob operating points on the Up/Down welding torch
    • MMA welding, arc air gouging
      • Manual Metal Arc Welding
        • Safety
        • Preparation
        • HotStart function
        • Anti-Stick function
      • Arc Air Gauging
        • Safety
        • Preparation
        • Arc air gouging
    • Easy Documentation
      • General
        • General
        • Documented welding data
        • New CSV file
        • PDF report / Fronius signature
      • Activating / deactivating Easy Documentation
        • Activating Easy Documentation
        • Set the date and time
        • Deactivating Easy Documentation
    • Setup Settings
      • Setup Menu
        • General
        • Operation
        • Setup parameters for MIG/MAG synergic welding
        • Setup parameters for MIG/MAG standard manual welding
        • Setup parameters for MMA welding
      • Setup Menu 2nd Level
        • Limitations
        • Operation (Setup Menu 2nd Level)
        • Parameters for MIG/MAG synergic welding in Setup menu 2nd level
        • Parameters for MIG/MAG standard manual welding in Setup menu 2nd level
        • Parameters for manual metal arc welding in Setup menu 2nd level
      • Measuring the Welding Circuit Resistance r
        • General
        • Measuring the welding circuit resistance (MIG/MAG welding)
        • Measuring the welding circuit resistance (MMA welding)
      • Displaying the welding circuit Inductivity L
        • General
        • Displaying the welding circuit inductivity
        • Laying the hosepacks correctly
    • Troubleshooting and Maintenance
      • Troubleshooting
        • General
        • Safety
        • Displayed Service Codes
        • Displayed service codes in connection with OPT Easy Documentation
      • Service, maintenance and disposal
        • General
        • Safety
        • At every start-up
        • Every 2 Months
        • Every 6 Months
        • Disposal
    • Appendix
      • Average consumption values during welding
        • Average wire electrode consumption during MIG/MAG welding
        • Average shielding gas consumption during MIG/MAG welding
        • Average shielding gas consumption during TIG welding
      • Technical data
        • Overview with critical raw materials, year of production of the device
        • Special Voltage
        • Explanation of the term duty cycle
        • TransSteel 4000 Pulse TransSteel 4000 Pulse nc
        • TransSteel 4000 Pulse MV nc
        • TransSteel 5000 Pulse TransSteel 5000 Pulse nc
        • TransSteel 5000 Pulse MV nc
        • China Energy Label
      • Welding program tables
        • Welding program label on the device
        • Welding program tables for TransSteel 4000 Pulse, TransSteel 5000 Pulse
        • Welding program tables for TransSteel 4000 Pulse, TransSteel 5000 Pulse US
    TransSteel 4000 Pulse, TransSteel 5000 Pulse Operating instructions
    Controls
    Start-up
    MIG/MAG welding
    Setup menu
    Fault rectification
    Maintenance
    Technical data
    Spare parts
    Safety Instructions
    DANGER!
    Indicates an immediate danger.
    WARNING!
    Indicates a possibly dangerous situation.
    CAUTION!
    NOTE!
    Indicates the possibility of flawed results and damage to the equipment.
    1. Safety Instructions
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    General
    The device has been manufactured using state-of-the-art technology and according to recognized safety standards. If used incorrectly or misused, however, it can cause
    • Injury or death to the operator or a third party
    • Damage to the device and other material assets belonging to the operating company
    • Inefficient operation of the equipment
    All persons involved in the commissioning, operation, maintenance, and servicing of the device must
    • Be suitably qualified
    • Have knowledge of welding
    • Have completely read and followed these Operating Instructions
    The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
    All safety and danger notices on the device must
    • Be kept in a legible state
    • Not be damaged/marked
    • Not be removed
    • Not be covered, pasted, or painted over
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
    Before switching on the device, remove any faults that could compromise safety.
    Intended Use
    The device is intended exclusively for the welding process specified on the rating plate.
    Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose." The manufacturer is not responsible for any damage resulting from improper use.
    Proper use also means
    • Completely reading and obeying all instructions in the Operating Instructions
    • Completely reading and obeying all safety instructions and danger notices
    • Carrying out all the specified inspection and servicing work
    Never use the device for the following applications:
    • Thawing pipes
    • Charging batteries
    • Starting motors
    The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
    The manufacture shall also not be liable for faulty or incorrect work results.
    Temperature range of the ambient air:
    • During operation: -10°C to +40°C (14°F to 104°F)
    • During transport and storage: -20°C to +55°C (-4°F to 131°F)
    Relative humidity:
    • Up to 50% at 40°C (104°F)
    • Up to 90% at 20°C (68°F)
    Ambient air: free of dust, acids, corrosive gases or substances, etc.
    Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
    The operating company must only allow persons to work with the device if they
    • Are familiar with the basic occupational safety and accident prevention regulations and are trained in handling the device
    • Have read and understood these Operating Instructions, especially the section "Safety Rules," and have confirmed this with their signature
    • Are trained according to the requirements for the work results
    The safety-conscious work of the personnel must be checked regularly.
    All persons who are assigned to work with the device must do the following before beginning the work:
    • Follow the basic regulations for occupational safety and accident prevention
    • Read these Operating Instructions, especially the section "Safety Rules," and confirm that they have understood and will follow them by signing
    Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
    Grid Connection
    Devices with a high output can influence the energy quality of the grid due to their current consumption.
    This may affect a number of device types in terms of:
    • connection restrictions
    • criteria regarding maximum permissible grid impedance *)
    • criteria regarding the minimum required short-circuit power *)
    *) both at the interface with the public grid
    See technical data
    In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
    IMPORTANT! Ensure secure grounding of the grid connection!
    You are exposed to numerous hazards while handling the device, for example:
    • Flying sparks and pieces of hot metal
    • Arc radiation that poses a risk of injury to the eyes and skin
    • Hazardous electromagnetic fields that pose a risk of death for individuals with pacemakers
    • Electrical risks from grid current and welding current
    • Increased noise exposure
    • Harmful welding fumes and gases
    Wear suitable protective clothing when dealing with the device. The protective clothing must have the following properties:
    • Flame resistant
    • Insulating and dry
    • Covering the entire body and in good condition with no damage
    • Safety helmet
    • Cuffless pants
    Protective clothing involves the following:
    • Protecting the face and eyes from UV radiation, heat and flying sparks with a face guard featuring a regulation-compliant filter
    • Wearing regulation-compliant protective goggles with side protection behind the face guard
    • Wearing rigid, wet-insulating footwear
    • Protecting hands with appropriate gloves (featuring electrical insulation and thermal protection)
    • Wearing ear protection to reduce noise exposure and protect against injury
    Keep persons, especially children, away during the operation of the devices and during the welding process. If persons are in the vicinity, however:
    • Instruct them about all hazards (blinding hazard due to arcs, risk of injury from flying sparks, welding fumes hazardous to health, noise exposure, possible hazard due to grid current or welding current, etc.)
    • Provide suitable protective equipment or
    • Construct suitable protective walls and curtains.
    The fumes produced during welding contain toxic gases and vapors.
    Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
    Use at-source extraction source and a room extraction system.
    If possible, use a welding torch with an integrated extraction device.
    Keep your head out of the welding fumes and gases.
    Take the following precautionary measures for fumes and harmful gases:
    • Do not breathe them in.
    • Extract them from the work area using appropriate equipment.
    Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
    Use a welding helmet with air supply if there is insufficient ventilation.
    If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
    The following components are factors that determine how toxic the welding fumes are:
    • The metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaning agents, degreasers, and the like
    • The welding process used
    Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
    Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
    When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
    Flying sparks can cause fires and explosions.
    Never undertake welding near flammable materials.
    Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
    Keep suitable, tested fire extinguishers on hand.
    Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
    Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
    Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
    Do not touch voltage-carrying parts inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
    Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
    Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
    All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Before every use, check power connections for secure fit by hand.
    In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
    Do not wrap cables or leads around your body or parts of the body.
    Concerning the electrode (stick electrode, tungsten electrode, welding wire, etc.)
    • Never immerse it in liquids to cool it
    • Never touch it when the welding system is switched on
    The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
    Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
    Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
    Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
    Switch off unused devices.
    When working at elevated heights, wear a safety harness to prevent falls.
    Before working on the device, switch off the device and remove the mains plug.
    Secure the device to prevent the mains plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
    After opening the device:
    • Discharge all electrically charged components
    • Ensure that all components are disconnected from the power supply
    If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
    If the following instructions are not observed, stray welding currents may occur, which pose a risk of the following:
    • Fire
    • Overheating of parts connected to the workpiece
    • Irreparable damage to ground conductors
    • Damage to the device and other electrical equipment
    Ensure that the workpiece clamp is securely connected to the workpiece.
    Secure the workpiece clamp as close to the spot to be welded as possible.
    Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
    Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
    In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage grid.
    EMC measures
    In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
    Test and assess the immunity of equipment in the vicinity of the device in accordance with national and international provisions. Examples of interference-prone equipment that could be affected by the device:
    • Safety devices
    • Grid power lines, signal lines, and data transfer lines
    • IT and telecommunications equipment
    • Devices for measuring and calibrating
    Supporting measures to avoid EMC problems:
    1. Grid power supply
      • If electromagnetic interference occurs despite a grid connection that complies with regulations, take additional measures (e.g., use a suitable grid filter).
    2. Welding power-leads
      • Keep them as short as possible
      • Route them close together (also to avoid EMF problems)
      • Route them far from other lines
    3. Equipotential bonding
    4. Workpiece grounding
      • If necessary, establish grounding using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices in the vicinity
      • Shield the entire welding installation
    EMF measures
    Electromagnetic fields may cause health problems that are not yet known:
    • Effects on the health of persons close by, e.g., those with pacemakers and hearing aids
    • Persons with pacemakers must seek advice from their doctor before staying in the immediate vicinity of the device and the welding process
    • Keep distances between welding power-leads and the head/torso of the welder as great as possible for safety reasons
    • Do not carry welding power-leads and hosepacks over your shoulder or wrap them around your body or body parts
    Keep hands, hair, loose clothing, and tools away from moving parts, such as:
    • Fans
    • Gears
    • Rollers
    • Shafts
    • Wirespools and welding wires
    Do not reach into rotating gears of the wire drive or into rotating drive parts.
    Covers and side panels must only be opened/removed during maintenance and repair work.
    During operation
    • Ensure that all covers are closed, and all side parts have been mounted properly.
    • Keep all covers and side parts closed.
    The welding wire protruding from the welding torch poses a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
    Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
    Do not touch the workpiece during or after welding—risk of burns.
    Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
    Leave the welding torch and other parts with a high operating temperature to cool before working on them.
    Special regulations apply in areas at risk of fire or explosion
    – follow the appropriate national and international regulations.
    Welding machines for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the welding machine may not be located in such areas.
    Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
    When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
    Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
    • Attach chains or ropes to all designated attachments of the suitable load-carrying equipment.
    • Chains or ropes must be the smallest angle possible from vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device is equipped with a carrier strap or handle, then this is used exclusively for transport by hand. The carrier strap is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
    All lifting equipment (straps, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
    The test interval and scope must at least comply with the respective valid national standards and guidelines.
    There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
    Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
    Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
    Keep shielding gas cylinders away from welding or other electrical circuits.
    Risk of explosion: Never weld on a compressed shielding gas cylinder.
    Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
    If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
    When no welding is taking place, close the valve of the shielding gas cylinder.
    Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
    Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
    Risk of asphyxiation due to uncontrolled shielding gas leak
    Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
    • Ensure there is a sufficient supply of fresh air with a ventilation flow rate of at least 20 m³ per hour.
    • Please observe the safety and maintenance information for the shielding gas cylinder or the main gas supply.
    • When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
    • Always check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before each start-up.
    A toppling device can be deadly! Set up the device securely on an even, solid surface
    • The maximum permitted tilt angle is 10°.
    • Follow the appropriate national and international regulations.
    Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
    Only set up and operate the device in accordance with the protection class shown on the rating plate.
    When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
    Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
    Do not lift or transport any active devices. Switch off and disconnect devices from the grid before transport or lifting.
    Before transporting a welding system (e.g., with a trolley, cooling unit, welding machine, and wirefeeder), completely drain the coolant and dismantle the following components:
    • Wirefeeder
    • Wire spool
    • shielding gas cylinder
    It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a danger of:
    • Inefficient operation of the device
    Safety devices that are not fully functional must be repaired before the device is switched on.
    Before switching on the device, ensure that no one can be put in danger.
    The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
    Always secure the shielding gas cylinder well and remove before transporting by crane.
    Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
    Only use appropriate original coolant from the manufacturer.
    Do not mix original coolant from the manufacturer with other coolants.
    Only connect system components from the manufacturer to the cooling unit circuit.
    If there is damage due to use of other system components or other coolants, the manufacturer accepts no liability for this and all warranty claims are forfeited.
    Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
    Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
    When the system is cool, always check the coolant level before starting welding.
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
    The manufacturer recommends calibrating welding systems within the same 12-month interval.
    A safety inspection by a certified electrician is recommended:
    • After changes
    • After alterations
    • After repair, service, and maintenance
    • At least every twelve months
    For the safety inspection, follow the appropriate national and international standards and guidelines.
    You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
    Disposal
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Crush cardboard boxes
    Safety symbols
    Devices with the CE label satisfy the essential requirements of the low-voltage and electromagnetic compatibility directive (e.g., relevant product standards of the EN 60974 series).
    Fronius International GmbH declares that the device complies with Directive 2014/53/EU. The full text of the EU Declaration of Conformity is available on the following website: http://www.fronius.com
    Data backup
    • saving and storing personal settings
    Copyright
    General information
    General
    Device concept
    TransSteel 4000 / 5000 Pulse
    The TransSteel (TSt) 4000 Pulse and TransSteel 5000 Pulse power sources are fully digitized, microprocessor-controlled inverter power sources.
    A modular design and ability to easily extend the system ensure high flexibility.
    The devices are designed for the following welding processes:
    • MIG/MAG pulse welding
    • MIG/MAG standard synergic welding
    The devices have a "Power limitation" safety feature. This means that the power sources can be operated at the power limit without compromising process safety. For details, refer to the "Welding operations" chapter.
    1. General information
    General
    Device concept
    2. General
    Device concept
    2. General
    Operating principle
    The central control and regulation unit of the power sources is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
    During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Control algorithms ensure that the desired target state is maintained.
    This results in:
    • A precise welding process
    • A high degree of reproducibility on all results
    • Excellent weld properties.
    2. General
    Application areas
    The devices are used in trade and industry for manual and automated applications with classical steel and galvanized sheet metal:
    • Mechanical and equipment engineering
    • Steel construction
    • Plant and container construction
    • Shipyards and the offshore sector
    • Metal and portal construction
    • Rail vehicle construction
    • Metalworking trades
    2. General
    Warning notices and safety symbols are affixed to the power source. These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and property damage.
    Warning notices on the power source
    Welding is dangerous. The following basic requirements must be met:
    • Adequate welding qualifications
    • Appropriate protective equipment
    • Exclusion of unauthorized persons
    • All system component Operating Instructions, especially the safety rules
    General
    In order to process a wide range of materials effectively, various welding processes, procedures, and welding characteristics are available on the power source.
    2. Welding processes, procedures, and welding characteristics for MIG/MAG welding
    General
    MIG/MAG standard synergic welding is a MIG/MAG welding process covering the entire power range of the power source with the following arc types:
    Dip transfer arc
    Droplet transfer occurs in the lower power range during the short circuit.
    Intermediate arc
    The droplet increases in size at the end of the wire electrode and is transferred in the mid power range during the short circuit.
    Spray arc
    A short circuit-free transfer of material in the high power range.
    MIG/MAG pulsed synergic welding is a pulsed arc process with a controlled material transfer.
    In the base current phase, the energy input is reduced to such an extent that the arc barely burns steadily and the surface of the workpiece is preheated. In the pulsing current phase, an accurately timed current pulse guarantees a precise detachment of the weld material droplet.
    This principle guarantees low-spatter welding and precise operation throughout the entire power range.
    SynchroPulse is available for the standard synergic and pulsed synergic processes.
    The cyclic change of the welding power between two operating points with SynchroPulse achieves a finely rippled weld appearance and a non-continuous heat input.
    In arc air gouging, an arc is ignited between a carbon electrode and the workpiece; the parent material is melted and blown out with compressed air.
    The operating parameters for arc air gouging are defined in a special characteristic.
    Applications:
    • Removal of shrink holes, pores, or slag inclusions from workpieces
    • Detaching sprues or the processing of entire workpiece surfaces in foundries
    • Edge preparation for heavy plates
    • Preparation and repair of weld seams
    • Finishing of roots or defects
    • Production of air gaps
    System components
    General
    The power sources can be operated with various system components and options. This makes it possible to optimize procedures and to simplify machine handling and operation, depending on the field of application for the power source.
    2. System components
    General
    Safety
    WARNING!
    Read and understand all safety rules and user documentation for this equipment and all system components.
    Overview
    (1)
    Welding torch
    (2)
    Wirefeeder
    (3)
    Wirefeeder holder
    (4)
    Interconnecting hosepacks
    (5)
    Power source
    (6)
    Cooling unit
    (7)
    Trolley and gas cylinder holders
    (8)
    Grounding and electrode cable
    The Voltage Reduction Device (VRD) is an optional safety device for voltage reduction. It is recommended for environments where arc welding significantly increases the risk of electric shock or electrical accident:
    • Due to low body resistance of the welder
    • If the welder is exposed to a significant risk of touching the workpiece or other parts of the welding circuit
    A low body resistance is likely in the event of:
    • Water in the environment
    • Humidity
    • Heat, especially at ambient temperatures above 32 °C (89.6 °F)
    In wet, damp, or hot places, moisture or sweat can significantly reduce skin resistance, as well as the insulation resistance of protective equipment and clothing.
    Such environments may include:
    • Temporary dam structures for draining certain areas of a construction site during the construction period (cofferdams)
    • Ditches
    • Mines
    • Rain
    • Areas partially covered by water
    • Spray water zones
    The VRD option reduces the voltage between the electrode and the workpiece. In the safe state, the indicator for the currently selected welding process lights up continuously. The safe state is defined as follows:
    • In an open circuit, the output voltage is limited to a maximum of 35 V.
    As long as the welding operation is active (welding circuit resistance < 200 ohms), the indicator of the currently selected welding process flashes and the output voltage can exceed 35 V.
    2. VRD: Safety function
    • Humidity
    • Ditches
    • Mines
    • Rain
    • Spray water zones
    The welding circuit resistance is greater than the minimum body resistance (greater than or equal to 200 ohms):
    • VRD is active
    • Open circuit voltage is limited to 35 V
    • Unintentional contact with the output voltage does not pose any danger
    The welding circuit resistance is less than the minimum body resistance (less than 200 ohms):
    • VRD is inactive
    • No limitation of the output voltage to ensure adequate welding power
    • Example: welding start
    Applies to MMA welding mode:
    Within 0.3 seconds of the end of welding:
    • VRD is active again
    • Restriction of the output voltage to 35 V is ensured again
    Control Panel
    General
    The functions are all arranged in a logical way on the control panel. The individual parameters required for welding can be
    • Selected by means of buttons
    • Changed using buttons or the selection dial
    • Shown on the digital display during welding.
    Due to the synergic function, all other parameters are also adjusted if a single parameter is changed.
    NOTE!
    Because of software updates, certain functions may be available for your device but not described in these Operating Instructions or vice versa.
    In addition, individual figures may also differ slightly from the operating elements of your device. However, the function of these operating elements is identical.
    1. Operating controls and connections
    Control Panel
    General
    NOTE!
    2. Control Panel
    General
    NOTE!
    2. Control Panel
    Safety
    WARNING!
    2. Control Panel
    Control panel
    No.Function
    (1)
    "Parameter selection" button (right)
    a) for selecting the following parameters
    Arc length correction
    For correcting the arc length
    Welding voltage in V *)
    Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding.
    Pulse / arc-force dynamic correction
    For continuously correcting the droplet detachment force in MIG/MAG pulsed synergic welding
    - ... reduced droplet detachment force
    0 ... neutral droplet detachment force
    + ... increased droplet detachment force
    For influencing the short-circuiting dynamic at the instant of droplet transfer in MIG/MAG standard synergic welding, MIG/MAG standard manual welding, and manual metal arc welding
    - ... harder and more stable arc
    0 ... neutral arc
    + ... soft and low-spatter arc
    b) for changing parameters in the Setup menu
    (2)
    "Parameter selection" button (left)
    Sheet thickness
    Sheet thickness in mm or in.
    If the welding current to be selected is not known, it is sufficient to enter the sheet thickness. The required welding current and any other parameters marked with *) will then be adjusted automatically.
    Welding current *)
    Welding current in A
    Wire speed *)
    Wire speed in m/min or ipm.
    (3)
    Selection dial (right)
    For changing the arc length correction, welding voltage, and arc-force dynamic parameters
    For changing parameters in the Setup menu
    (4)
    Selection dial (left)
    For changing the sheet thickness, welding current, and wire speed parameters
    For selecting parameters in the Setup menu
    (5)
    EasyJob save buttons
    For saving up to 5 operating points
    (6)
    "Process" button **)
    For selecting the welding process
    (7)
    "Mode" button
    For selecting the operating mode
    2-step mode
    4-step mode
    Special 4-step mode
    Spot welding/stitch welding
    (8)
    "Shielding gas" button
    For selecting the shielding gas used. The SP parameter is reserved for additional shielding gases.
    When the shielding gas is selected, the LED behind the corresponding shielding gas lights up.
    (9)
    "Wire diameter" button
    For selecting the wire diameter used. The SP parameter is reserved for additional wire diameters.
    When the wire diameter is selected, the LED behind the corresponding wire diameter lights up.
    (10)
    "Material" button
    For selecting the filler metal used. The SP parameter is reserved for additional materials.
    When the material type is selected, the LED behind the corresponding filler metal lights up.
    (11)
    "Wire threading" button
    Press and hold the button:
    Gasless wire threading into the torch hosepack
    While the button is being held, the wire drive operates at feeder inching speed.
    (12)
    Gas-test button
    For setting the required gas volume on the gas pressure regulator.
    Tap the button once: shielding gas flows out
    Tap the button again: shielding gas flow stops
    If the Gas-test button is not tapped again, the shielding gas flow will stop after 30 s.
    (13)
    SF - spot/stitch/SynchroPulse welding indicator
    • Lights up if a value is set for the spot welding/stitch welding time (SPt) setup parameter when spot welding or stitch welding mode is activated
    • Lights up if a value is set for the Frequency (F) setup parameter when the MIG/MAG synergic welding process is activated.
    (14)
    Intermediate arc indicator
    A spatter-prone "intermediate arc" occurs between the dip transfer arc and the spray arc. The intermediate arc indicator lights up to alert you to this critical area.
    (15)
    HOLD indicator
    At the end of each welding operation, the actual values for welding current and welding voltage are stored - the "HOLD" indicator lights up.
    (16)
    Pulse indicator
    Lights up when the MIG/MAG pulsed synergic welding process is selected
    (17)
    Real Energy Input
    For displaying the energy applied during the welding operation.
    The Real Energy Input indicator must be activated in level 2 of the Setup menu – EnE parameter. The value continuously rises during welding in line with the permanently increasing energy input. The final value is stored after the end of welding until welding starts again or the power source is switched back on - the HOLD indicator lights up.
    During the MIG/MAG standard synergic welding process and MIG/MAG pulsed synergic welding process, if one of these parameters is selected, then the synergic function ensures that all other parameters, including the welding voltage parameter, are adjusted automatically.
    In conjunction with the VRD option, the indicator of the currently selected welding process is also used as status indicator:
    • The indicator lights up continuously: the voltage reduction (VRD) is active and limits the output voltage to less than 35 V.
    • The indicator flashes as soon as a welding operation occurs, which can cause the output voltage to be greater than 35 V.
    2. Control Panel
    Service parameters
    Various service parameters can be retrieved by pressing the "Parameter selection" buttons at the same time.
    Opening the display
    The first parameter "Firmware version" will be displayed, e.g., "1.00 | 4.21"
    Selecting parameters
    Use the "Mode" and "Process" buttons or the left-hand selection dial to select the required setup parameter
    Explanation
    Example:
    1.00 | 4.21
    Firmware version
    Example:
    2 | 491
    Welding program configuration
    Example:
    r 2 | 290
    Number of the currently selected welding program
    Example:
    654 | 32.1
    = 65,432.1 hours
    = 65,432 hours 6 mins
    Indicates the actual arc time since first use
    Note: The arc time indicator is not suitable as a basis for calculating hiring fees or for warranty purposes, etc.
    Example:
    iFd | 0.0
    Motor current for wire drive in A
    The value changes as soon as the motor is running.
    2nd
    2nd menu level for service technicians
    2. Control Panel
    Keylock
    A keylock can be selected to prevent the settings from being inadvertently changed on the control panel. As long as the keylock is active:
    • Settings cannot be adjusted on the control panel
    • Only parameter settings can be retrieved
    • Any assigned "Save" button can be retrieved provided that an assigned "Save" button was selected when the keylock was enabled
    Activating/deactivating the keylock:
    Keylock activated:
    The message "CLO | SEd" appears on the displays.
    Keylock deactivated:
    The message "OP | En" appears on the displays.
    The keylock can also be activated and deactivated using the keylock switch option.
    No.Function
    (1)
    (-) Current socket with bayonet latch
    Used for
    • Connecting the grounding cable for MIG/MAG welding
    • Connecting the electrode cable or grounding cable for manual metal arc welding (depending on the type of electrode used)
    (2)
    Power switch
    For switching the power source on and off
    (3)
    (+) Current socket with bayonet latch
    Used for
    • Connecting the mains cable from the interconnecting hosepack for MIG/MAG welding
    (4)
    Gas pre-heater socket (option)
    (5)
    Automatic Interface (option)
    (6)
    EASY DOCUMENTATION label
    (7)
    Mains cable with strain relief
    (8)
    LocalNet connection
    Standardized connection for wirefeeder (interconnecting hosepack)
    (9)
    Air filter
    Pull out from the side for cleaning
    2. Connections, Switches, and Mechanical Components
    No.Function
    (1)
    Used for
    (2)
    Power switch
    (3)
    Used for
    (4)
    (5)
    (6)
    (7)
    (8)
    LocalNet connection
    (9)
    Air filter
    General
    Depending on the welding process, a minimum level of equipment is required to work with the power source.
    The following describes the welding processes and the corresponding minimum equipment for welding operations.
    1. Installation and Startup
    General
    2. Minimum equipment for welding operations
    General
    • Power source
    • Grounding cable
    • Gas-cooled MIG/MAG welding torch
    • Gas connection (shielding gas supply)
    • Wirefeeder (VR 5000 Remote)
    • Gas-cooled interconnecting hosepack
    • Wire electrode
    • Power source
    • Cooling unit
    • Grounding cable
    • Water-cooled MIG/MAG welding torch
    • Water cooling option (for VR 5000 Remote)
    • Water-cooled interconnecting hosepack
    • Wire electrode
    • Power source
    • Grounding cable
    • Electrode holder
    • Rod electrodes
    • TransSteel 4000 / 5000 Pulse, TransSteel 5000 Syn power source
    • Grounding cable 120 mm²
    • KRIS 13 arc air gouging torch
    • Compressed air supply
    Safety
    WARNING!
    WARNING!
    Before starting work, switch off all devices and components involved, and disconnect them from the grid.
    2. Before installation and initial operation
    Safety
    WARNING!
    WARNING!
    Intended use
    The power source is intended exclusively for MIG/MAG, MMA, and TIG welding.
    Utilization for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended purpose.
    The manufacturer shall not be held liable for any damages arising from such use.
    Intended use also means
    • Following all the instructions in these Operating Instructions
    • Carrying out all the specified inspection and maintenance work
    Setup regulations
    The device has been tested according to degree of protection IP 23. This means:
    • Protection against penetration by solid foreign bodies with diameters > 12 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° from the vertical
    The device can be set up and operated outdoors in accordance with degree of protection IP 23.
    Direct moisture (e.g., from rain) must be avoided.
    WARNING!
    Danger from machines toppling over or falling.
    Set up the device securely on an even, solid surface.
    Check all screw connections are tightly fastened after installation.
    WARNING!
    Danger of electrical current due to electrically conductive dust in the device.
    Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
    The ventilation channel is a very important safety device. When selecting the setup location, ensure that the cooling air can enter or exit unhindered through the vents on the front and back. Any electrically conductive dust (e.g., from grinding work) must not be allowed to be sucked into the device.
    Grid Connection
    The devices are designed for the grid voltage stated on the rating plate. If the mains cable or mains plug has not been attached to your version of the appliance, these must be installed according to national standards. Fuse protection for the grid lead can be found in the technical data.
    CAUTION!
    Danger due inadequately dimensioned electrical installations.
    This can lead to serious damage
    The grid lead and its fuse protection should be designed to suit the existing power supply.
    The technical data on the rating plate should be followed.
    General
    If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before commissioning.
    A strain-relief device for the following cable cross-sections is fitted to the power source:
    Power source
    Cable cross-section
    Fitted strain-relief device for
    Canada/US
    Europe
    AWG 12 *)
    4G2.5
    AWG 10 *)
    4G4
    TransSteel 4000 MV Pulse
    AWG 10 *)
    4G4
    TransSteel 5000 MV Pulse
    AWG 6 *)
    4G10
    Canada / US cable type: Extra-hard usage
    Strain-relief devices for other cable cross-sections must be designed accordingly.
    2. Connecting the Mains Cable
    General
    Power source
    Cable cross-section
    Canada/US
    Europe
    AWG 12 *)
    4G2.5
    AWG 10 *)
    4G4
    AWG 10 *)
    4G4
    AWG 6 *)
    4G10
    Power source
    Grid voltage
    Cable cross-section
    Canada / US
    Europe
    3 x 380 / 400 V
    AWG 12 *)
    4G2.5
    3 x 460 V
    AWG 12 *)
    4G2.5
    3 x 380 / 400 V
    AWG 8 *)
    4G4
    3 x 460 V
    AWG 10 *)
    4G4
    3 x 208 / 230 / 400 /460 V
    AWG 10 *)
    4G4
    3 x 208 / 230 / 400 / 460 V
    AWG 6 *)
    4G10
    The item numbers of the different cables can be found in the Spare Parts List for the devices.
    AWG ... American Wire Gauge
    Safety
    WARNING!
    Danger from work that is not carried out properly.
    Serious personal injury and damage to property may result.
    The work described below may only be performed by trained specialist personnel.
    Follow national standards and guidelines.
    CAUTION!
    Danger from improperly prepared mains cable.
    Short circuits and damage to property may result.
    Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
    The ground conductor should be approx. 10 - 15 mm (0.4 - 0.6 in.) longer than the phase conductors.
    A graphic representation of the mains cable connection is provided in the sections "Fitting the strain-relief device" or "Fitting the strain-relief device for Canada / US." To connect the mains cable, proceed as follows:
    1Remove the side panel of the device
    2Push in the mains cable so that the ground conductor and phase conductor can be properly connected to the block terminal.
    3Fit a ferrule to the ground conductor and phase conductor
    4Connect the ground conductor and phase conductor to the block terminal
    5Secure the mains cable with a strain-relief device
    6Fit the side panel of the device
    5
    IMPORTANT! Tie the phase conductors near the block terminal using cable ties.
    5
    The power source is generator-compatible.
    The maximum apparent power S1max of the power source must be known in order to select the correct generator output.
    The maximum apparent power S1max of the power source is calculated for 3-phase devices as follows:
    S1max = I1max x U1 x √3
    I1max and U1 according to the device rating plate and technical data
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator can be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the power source!
    NOTE!
    The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
    The mains voltage tolerance is specified in the "Technical data" section.
    2. Generator-Powered Operation
    SGEN = S1max x 1.35
    NOTE!
    Commissioning
    Safety
    WARNING!
    WARNING!
    2. Commissioning
    Safety
    WARNING!
    WARNING!
    2. Commissioning
    General
    Commissioning is described with reference to a manual, water-cooled MIG/MAG application.
    2. Commissioning
    The steps and activities described below include references to various system components, such as
    • Trolley
    • Upright bracket
    • Cooling units
    • Wirefeeders
    • Interconnecting hosepacks
    • Welding torches, etc.
    For more detailed information about installing and connecting the system components, please refer to the appropriate Operating Instructions for the system components.
    2. Commissioning
    WARNING!
    Work performed incorrectly can cause serious injury and damage.
    The following activities must only be carried out by trained and qualified personnel.
    Please note the information in the "Safety instructions" chapter!
    The following diagram is intended to provide you with an overview of how the individual system components are put together.
    2. Commissioning
    CAUTION!
    Danger of personal injury and damage to equipment due to falling wirefeeder.
    Ensure that the wirefeeder is firmly seated on the pivot pin and that the devices, upright brackets, and trolley are positioned securely.
    2. Commissioning
    Fit the strain-relief device on the trolley
    Fit the strain-relief device on the wirefeeder
    IMPORTANT! In order to prevent wear, the cables should form a "loop inwards" when fitted. For interconnecting hosepacks with a length of 1.2 m (3 ft. 11.24 in.), no strain-relief device is provided.
    2. Commissioning
    WARNING!
    Fitting the device incorrectly can cause serious injury and damage to property.
    Do not perform the steps described here until you have fully read and understood the Operating Instructions.
    NOTE!
    When connecting the interconnecting hosepack, check that
    All connections are connected properly
    All cables, leads, and hosepacks are undamaged and correctly insulated
    IMPORTANT! Gas-cooled systems are not fitted with a cooling unit. The water connections therefore do not need to be connected for gas-cooled systems.
    2. Commissioning
    IMPORTANT! The duty cycle values (D.C.) of the interconnecting hosepack can only be achieved if it is correctly routed.
    2. Commissioning
    WARNING!
    Danger of severe injury and damage to property if gas cylinders fall over.
    When using gas cylinders:
    Place them on a solid, level surface in such a way that they remain stable
    Secure the gas cylinders to prevent them from falling over
    Install the VR holder option
    Observe the safety rules of the gas cylinder manufacturer
    1Place the gas cylinder on the base of the trolley
    2Secure the gas cylinder against falling using the cylinder strap in the upper area of the gas cylinder (but not on the neck of the cylinder)
    3Remove the protective cap of the gas cylinder
    4Briefly open the gas cylinder valve to remove any dirt
    5Inspect the seal on the gas pressure regulator
    6Screw the pressure regulator onto the gas cylinder and tighten it
    7Connect the protective gas shield hose of the interconnecting hosepack to the pressure regulator using a gas hose
    NOTE!
    US devices are supplied with an adapter for the gas hose:
    Seal the outside thread on the gas solenoid valve using suitable means before screwing on the adapter.
    Test the adapter to ensure that it is gas-tight.
    2. Commissioning
    NOTE!
    When establishing a ground earth connection, observe the following points:
    Use a separate grounding cable for each power source
    Keep positive cables and grounding cables together as long and as close as possible
    Physically separate the welding circuits of individual power sources
    Do not route several grounding cables in parallel;
    if parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
    Keep the grounding cables as short as possible, provide a large cable cross-section
    Do not cross over grounding cables
    Avoid ferromagnetic materials between the grounding cables and the interconnecting hosepack
    Do not wind long grounding cables - coil effect!
    Route long grounding cables in loops
    Do not route grounding cables in iron pipes, metal cable trays, or on steel beams, avoid cable ducts;
    (routing positive cables and grounding cables together in an iron pipe does not cause any problems)
    If several grounding cables are used, separate the part's ground points as far as possible and do not allow crossed current paths under the individual arcs.
    Use compensated interconnecting hosepacks (interconnecting hosepacks with integrated grounding cable)
    2. Commissioning
    * with integrated water connection option and water-cooled welding torch
    2. Commissioning
    Other activities
    Carry out the following steps according to the Operating Instructions for the wirefeeder:
    1Insert feed rollers into the wirefeeder
    2Insert wirespool or basket-type spool with basket-type spool adapter into the wirefeeder
    3Feed in the wire electrode
    4Set the contact pressure
    5Adjust the brake
    2. Commissioning
    After switching on the power source for the first time, the date and time must be set. For this purpose, the power source changes to the second level of the service menu; the yEA parameter is selected.
    To set the date and time see page (→), step 5
    MIG/MAG welding
    Power Limitation
    Safety function
    "Power limitation" is a safety function for MIG/MAG welding. This means that the power source can be operated at the power limit whilst maintaining process safety.
    Wire speed is a determining parameter for welding power. If it is too high, the arc gets smaller and smaller and may be extinguished. In order to prevent this, the welding power is lowered.
    If the "MIG/MAG standard synergic welding" or "MIG/MAG pulsed synergic welding" process is selected, the symbol for the "Wire speed" parameter flashes as soon as the safety function trips. The flashing continues until the next welding start-up, or until the next parameter change.
    If the "Wire speed" parameter is selected, for example, the reduced value for wire speed is displayed.
    1. MIG/MAG welding
    Power Limitation
    Safety function
    1. MIG/MAG welding
    2. Power Limitation
    Safety function
    1. MIG/MAG welding
    General
    WARNING!
    Operating the device incorrectly can cause serious injury and damage to property.
    Do not use the functions described here until you have fully read and understood the Operating Instructions.
    Do not use the functions described here until you have fully read and understood all of the Operating Instructions of the system components, especially the safety rules.
    For details of the meaning, settings, setting range and units of the available welding parameters (e.g., gas pre-flow time), please refer to the "Setup parameters" chapter.
    1. MIG/MAG welding
    2. MIG/MAG Operating Modes
    General
    WARNING!
    1. MIG/MAG welding
    Press the torch trigger | Hold the torch trigger | Release the torch trigger
    GPr
    Gas pre-flow time
    I-S
    Starting current
    Can be increased or decreased depending on the application
    SL
    Slope
    Starting current is continuously lowered as far as the welding current and the welding current as far as the final current
    I
    Welding current phase
    Even heat input into the parent material whose temperature is raised by the advancing heat
    I-E
    Final current
    To fill up end-craters
    GPo
    Gas post-flow time
    SPt
    Spot welding time / interval welding time
    SPb
    Interval pause time
    1. MIG/MAG welding
    2-step mode
    "2-step mode" is suitable for
    • Tacking work
    • Short weld seams
    • Automatic and robot operation
    1. MIG/MAG welding
    4-step mode
    "4-step mode" is suitable for longer weld seams.
    1. MIG/MAG welding
    Special 2-step mode
    "Special 2-step mode" is ideal for welding in higher power ranges. In special 2-step mode, the arc starts at a lower power, which makes it easier to stabilize.
    To activate special 2-step mode:
    1Select 2-step mode
    2In the Setup menu, set the t-S (starting current duration) and t-E (final current duration) parameters to a value > 0
    Special 2-step mode is activated.
    3In the Setup menu, set the SL (Slope), I-S (starting current), and I-E (final current) parameters
    1. MIG/MAG welding
    Special 4-step mode
    Special 4-step mode allows the starting and final current to be configured in addition to the advantages of 4-step mode.
    1. MIG/MAG welding
    Spot welding
    The "Spot welding" mode is suitable for welded joints on overlapped sheets.
    Start by pressing and releasing the torch trigger - GPr gas pre-flow time - welding current phase over the SPt spot welding time duration - GPo gas post-flow time.
    If the torch trigger is pressed again before the end of the spot welding time (< SPt), the process is canceled immediately.
    1. MIG/MAG welding
    The "2-step stitch welding" mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
    1. MIG/MAG welding
    4-step stitch welding
    The "4-step stitch welding" mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
    1. MIG/MAG welding
    MIG/MAG welding
    Safety
    WARNING!
    WARNING!
    1. MIG/MAG welding
    2. MIG/MAG welding
    Safety
    WARNING!
    WARNING!
    1. MIG/MAG welding
    2. MIG/MAG welding
    Preparation
    1Connect the water hoses of the welding torch to the corresponding connection sockets on the wirefeeder
    (when using the cooling unit and water-cooled welding torch)
    2Insert mains plug
    3Set the power switch to - I -:
    • All displays on the control panel briefly illuminate
    • If present: The cooling unit starts to work
    IMPORTANT! Observe the safety rules and operating conditions in the Operating Instructions for the cooling unit.
    1. MIG/MAG welding
    2. MIG/MAG welding
    Overview
    MIG/MAG welding is composed of the following sections:
    • MIG/MAG synergic welding
    • MIG/MAG standard manual welding
    • Spot welding and stitch welding
    1. MIG/MAG welding
    1Press the "Material" button to select the filler metal to be used.
    2Press the "Wire diameter" button to select the diameter of the wire electrode used.
    3Press the "Shielding gas" button to select the shielding gas to be used.
    The assignment of the SP position is in the welding program tables in the appendix.
    4Press the "Process" button to select the desired welding process:
    5Press the "Mode" button to select the desired MIG/MAG mode:
    2-step mode
    4-step mode
    Special 4-step mode
    IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component - such as remote control or wirefeeder - on the control panel of the power source.
    6Use the "Parameter selection" buttons to select the welding parameters to be used to specify the welding power:
    Sheet thickness
    Welding current
    Wire speed
    Welding voltage
    7Use the appropriate selection dial to set the welding parameter.
    The value of the parameter is displayed on the digital display located above.
    The sheet thickness, welding current, wire speed, and welding voltage parameters are directly linked. It is sufficient to change one of the parameters, as the remaining parameters are immediately adjusted accordingly
    All welding parameter set values remain stored until the next time they are changed. This applies even if the power source is switched off and on again. To display the actual welding current during welding, select the welding current parameter.
    8Open the gas cylinder valve
    9Adjust quantity of shielding gas:
    • Tap the Gas-test button
    • Turn the adjusting screw on the bottom of the gas pressure regulator until the manometer displays the desired quantity of gas
    • Tap the Gas-test button again
    CAUTION!
    Danger of injury and damage from electric shock and from the wire electrode emerging from the torch.
    When you press the torch trigger:
    Keep the welding torch away from your face and body
    Wear suitable protective goggles
    Do not point the welding torch at people
    Make sure that the wire electrode does not touch any conductive or grounded parts (e.g., housing, etc.)
    10Press the torch trigger and start welding
    1. MIG/MAG welding
    2. MIG/MAG synergic welding
    2-step mode
    4-step mode
    Special 4-step mode
    Sheet thickness
    Welding current
    Wire speed
    Welding voltage
    CAUTION!
    1. MIG/MAG welding
    Corrections during welding
    The arc length correction and arc-force dynamic parameters can be used to optimize the welding result.
     Arc length correction:
    = shorter arc, reduced welding voltage
    0
    = neutral arc
    = longer arc, increased welding voltage
    For continuous correction of the droplet detachment force in MIG/MAG pulsed synergic welding
    0
    For influencing the short-circuiting dynamic at the instant of droplet transfer during MIG/MAG standard synergic welding
    = hard, stable arc
    0
    = neutral arc
    = soft, low-spatter arc
    1. MIG/MAG welding
    SynchroPulse is recommended for welded joints with aluminum alloys whose weld seams should have a rippled appearance. This effect is achieved using a welding power that changes between two operating points.
    The two operating points result from a positive and negative change in the welding power to a dFd (delta wire feed) value that can be adjusted in the Setup menu (delta wire feed: 0.0 - 3.0 m/min or 0.0 - 118.1 ipm).
    Other parameters for SynchroPulse:
    • Frequency F of the operating point change (set in the Setup menu)
    • Arc length correction for the lower operating point (set via the arc length correction parameter on the control panel)
    • Arc length correction for the higher operating point (set in the Setup menu, parameter Al.2)
    To enable SynchroPulse, you must change at least the value of the F (Frequency) parameter from OFF to a variable in the range of 0.5 to 5 Hz in the process Setup menu.
    NOTE!
    SynchroPulse is not supported with standard manual welding selected.
    How SynchroPulse works when used in "Special 4-step" mode
    I-S = starting-current phase, SL = Slope, I-E = crater-fill phase, v = wire speed
    SynchroPulse mode of operation
    1. MIG/MAG welding
    MIG/MAG Standard Manual Welding
    General
    The MIG/MAG standard manual welding process is a MIG/MAG welding process with no synergic function.
    Changing one parameter does not result in any automatic adjustments to the other parameters. All of the variable parameters must therefore be adjusted individually, as dictated by the welding process in question.
    1. MIG/MAG welding
    2. MIG/MAG Standard Manual Welding
    General
    1. MIG/MAG welding
    Available parameters
    The following parameters are available for MIG/MAG manual welding:
    Wire speed
    1 m/min (39.37 ipm.) - maximum wire speed, e.g., 25 m/min (984.25 ipm.)
    Welding voltageTransSteel 4000 Pulse: 15.5 - 31.5 V
    TransSteel 5000 Pulse: 14.5 - 39 V
    Arc-force dynamic:
    Welding current
    Only the actual value is displayed
    1. MIG/MAG welding
    1Press the "Process" button to select the desired welding process:
    2Press the "Mode" button to select the desired MIG/MAG mode:
    2-step mode
    4-step mode
    In MIG/MAG standard manual welding, special 4-step mode corresponds to conventional 4-step mode.
    3Press the "Parameter selection" button to select the wire speed parameter
    4Use the selection dial to set the desired wire speed value
    5Press the "Parameter selection" button to select the welding voltage parameter
    6Use the selection dial to set the desired welding voltage value
    The welding parameter values are shown in the digital display located above.
    To display the actual welding current during welding:
    • Press the "Parameter selection" button to select the welding current parameter
    • The actual welding current is shown on the digital display during welding.
    7Open the gas cylinder valve
    8Adjust quantity of shielding gas:
    CAUTION!
    9Press the torch trigger and start welding
    1. MIG/MAG welding
    To obtain the best possible welding results, the arc-force dynamic parameter will sometimes need to be adjusted.
    1Press the "Parameter selection" button to select the arc-force dynamic parameter
    2Use the selection dial to set the desired arc-force dynamic valueThe welding parameter value is shown in the digital display located above it.
    1. MIG/MAG welding
    General
    The spot welding and stitch welding modes are MIG/MAG welding processes. The spot welding and stitch welding modes are activated on the control panel.
    Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
    Stitch welding is used for light-gage sheets.
    As the wire electrode is not fed continuously, the weld pool can cool down during the intervals. Local overheating leading to the parent material being melted through is largely avoided.
    1. MIG/MAG welding
    2. Spot welding and stitch welding
    General
    1. MIG/MAG welding
    Spot welding
    1In the Setup menu, set the spot welding time / stitch welding time SPt
    IMPORTANT! Stitch pause time SPb = OFF must be set for spot welding!
    2Only for synergic welding:
    Use the corresponding buttons to select the filler metal used, the wire diameter, and the shielding gas
    3Select the desired welding process:
    4Select spot welding/stitch welding mode:
    The spot/stitch/SynchroPulse (SF) indicator lights up on the control panel.
    5Depending on the welding process selected, select the desired welding parameters and adjust them using the appropriate selection dial
    6Open the gas cylinder valve
    7Adjust quantity of shielding gas
    CAUTION!
    8Spot welding
    Procedure for establishing a welding spot:
    1Keep the welding torch vertical
    2Press and release the torch trigger
    3Maintain the position of the welding torch
    4Wait for the gas post-flow time
    5Raise the welding torch
    1. MIG/MAG welding
    Stitch welding
    1In the Setup menu, set the stitch pause time SPb
    Stitch welding is enabled.
    The Int (Interval) parameter is displayed in the Setup menu.
    2In the Setup menu for the Int parameter, set the operating mode for stitch welding (2T / 4T)
    3In the Setup menu, set the spot welding/stitch welding time SPt
    4Only for synergic welding:
    5Select the desired welding process:
    6Select spot welding/stitch welding mode:
    7Depending on the welding process selected, select the desired welding parameters and adjust them using the appropriate selection dial
    CAUTION!
    10Stitch welding
    Procedure for stitch welding:
    2Depending on the stitch mode set under the Int parameter:
    Press and hold the torch trigger (2-step mode)
    Press and release the torch trigger (4-step mode)
    4Wait for the welding interval
    5Position the welding torch at the next point
    6To stop stitch welding, depending on the stitch mode set under the Int parameter:
    Release the torch trigger (2-step mode)
    7Wait for the gas post-flow time
    8Raise the welding torch
    1. MIG/MAG welding
    EasyJob mode
    General
    The "Save" buttons allow up to five EasyJob operating points to be saved. Each operating point corresponds to the settings made on the control panel.
    EasyJobs can be stored for each welding process.
    IMPORTANT! Setup parameters are not saved at this time.
    1. MIG/MAG welding
    2. EasyJob mode
    General
    1. MIG/MAG welding
    2. EasyJob mode
    Saving EasyJob operating points
    1Press and hold one of the "Save" buttons to save the current settings on the control panel, e.g.
    • The left display reads "Pro"
    • After a short time, the left display switches to the original value
    2Release the "Save" button
    1. MIG/MAG welding
    2. EasyJob mode
    Retrieving EasyJob operating points
    1To retrieve saved settings, press the corresponding "Save" button briefly, e.g.
    • The control panel will show the saved settings
    1. MIG/MAG welding
    2. EasyJob mode
    Deleting EasyJob operating points
    1Press and hold the relevant "Save" button to delete the memory content of that "Save" button, e.g.
    • The left display reads "Pro".
    2Keep the "Save" button held down
    • The left display reads "CLr".
    • After a while, both displays show "---"
    3Release the "Save" button
    1. MIG/MAG welding
    2. EasyJob mode
    Retrieving EasyJob operating points on the Up/Down welding torch
    Press one of the "Save" buttons on the control panel to retrieve the saved settings using the Up/Down welding torch.
    1Press one of the "Save" buttons on the control panel, e.g.:
    The control panel will show the saved settings.
    The "Save" buttons can now be selected using the buttons on the Up/Down welding torch. Vacant "Save" buttons are skipped.
    In addition to the "Save" button number lighting up, a number is displayed directly on the Up/Down welding torch:
    Display on the Up/Down welding torch
    EasyJob operating point on the control panel
    MMA welding, arc air gouging
    Manual Metal Arc Welding
    Safety
    WARNING!
    WARNING!
    1. MMA welding, arc air gouging
    Safety
    WARNING!
    WARNING!
    2. Manual Metal Arc Welding
    Safety
    WARNING!
    WARNING!
    Preparation
    1Set the power switch to - O -
    2Unplug mains plug
    3On the power source, disconnect all leads to the wirefeeder IMPORTANT! Check the rod electrode packaging to determine whether the rod electrodes are for (+) or (-) welding.
    4Depending on the type of electrode, insert the grounding cable into the (-) current socket or into the (+) current socket and lock
    5Connect the other end of the grounding cable to the workpiece
    6Depending on the type of electrode, insert the bayonet connector of the electrode holder cable into the free current socket with opposite polarity and twist it clockwise to lock
    7Insert mains plug
    Manual metal arc welding
    CAUTION!
    Danger of injury and damage from electric shock.
    When the power switch is switched to position - I -, the rod electrode in the electrode holder is live.
    Ensure that the rod electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
    1Set the power switch to position - I -: all indicators on the control panel briefly illuminate
    2Press the "Process" button to select the MMA welding process:
    The welding voltage is applied to the welding socket with a three second time lag.If the MMA welding process is selected, a cooling unit, if present, is automatically deactivated. It is not possible to turn it on.
    3Press the "Parameter selection" button to select the amperage parameter.
    4Use the selection dial to set the desired amperage.The amperage value is displayed on the left-hand digital display.
    All parameter set values that are set using the selection dial are saved until their next alteration. This applies even if the power source is switched off and on again.
    5Initiate welding process
    To influence the short-circuiting dynamic at the instant of droplet transfer:
    = hard, stable arc
    0
    = neutral arc
    HotStart function
    To obtain the best possible welding result, the HotStart function will sometimes need to be adjusted.
    Advantages
    • Improved ignition properties, even when using electrodes with poor ignition properties
    • Better fusion of the parent material during the start-up phase, meaning fewer cold-shut defects
    • Slag inclusions largely avoided
    The setting of the available parameters is described in the section "Setup settings", "Setup menu - level 2".
    Key
    Hti
    Hot-current time,
    0 - 2 s,
    Factory setting 0.5 s
    HCU
    HotStart current,
    100 - 200%,
    Factory setting 150%
    IH
    Main current = set welding current
    Function
    During the specified hot-current time (Hti), the welding current is increased to a certain value. This value (HCU) is higher than the selected welding current (IH).
    Anti-Stick function
    As the arc becomes shorter, the welding voltage may also fall so that the rod electrode is more likely to stick to the workpiece. This may also cause the rod electrode to burn out.
    Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. The welding process can be resumed without problems once the rod electrode has been detached from the workpiece.
    The anti-stick (Ast) function can be activated and deactivated in the Setup menu for the setup parameters for MMA welding.
    Arc Air Gauging
    Safety
    WARNING!
    WARNING!
    2. Arc Air Gauging
    Safety
    WARNING!
    WARNING!
    2. Arc Air Gauging
    Preparation
    IMPORTANT! A grounding cable with a cable cross-section of 120 mm² is required for arc air gouging.
    2Unplug the mains plug
    3Remove the MIG/MAG welding torch
    4Insert the grounding cable into the (-) current socket and lock
    6Insert the bayonet connector of the arc air gouging torch into the (+) current socket and twist it clockwise to lock
    7Connect the compressed air connection of the arc air gouging torch to the compressed air supply
    Working pressure: 5 - 7 bar (constant)
    8Clamp the carbon electrode so that the electrode tip protrudes approx. 100 mm from the arc air gouging torch;
    the air outlet openings of the arc air gouging torch must be at the bottom
    9Insert the mains plug
    2. Arc Air Gauging
    Arc air gouging
    CAUTION!
    When the power switch is switched to position - I -, the electrode in the arc air gouging torch is live.
    Ensure that the electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
    CAUTION!
    Risk of personal injury due to loud operating noise.
    Use suitable hearing protection during arc air gouging!
    3In the setup menu for MMA welding, set the AAG parameter to "on";
    to enter the setup menu, see page (→).
    NOTE!
    Settings of the break voltage and the starting current time are ignored.
    4Exit the setup menu for MMA welding
    5Press the "Parameter selection" button to select the amperage parameter.
    6Use the selection dial to set the main current depending on the electrode diameter and in accordance with the specifications on the electrode packagingThe amperage value is displayed on the left-hand digital display.
    NOTE!
    At higher amperages, use both hands to guide the arc air gouging torch!
    Use a suitable welding helmet.
    7Open the compressed air valve on the arc air gouging torch handle
    8Initiate machining operation
    The angle of contact of the carbon electrode and gouging speed determine the depth of an air gap.
    The parameters for arc air gouging correspond to the welding parameters for MMA welding, see page (→).
    Easy Documentation
    General
    General
    If the Easy Documentation option is available on the power source, the most important welding data for each welding operation can be documented and saved as a CSV file on a USB thumb drive.
    A Fronius signature is stored with the welding data, which can be used to check and guarantee the authenticity of the data.
    Easy Documentation is activated / deactivated by plugging / unplugging the supplied Fronius USB thumb drive with FAT32 formatting into the back of the power source.
    IMPORTANT! To document the welding data, the date and time must be set correctly.
    1. Easy Documentation
    General
    General
    2. General
    General
    2. General
    Documented welding data
    The following data are documented:
    Device type
    File name
    Part number
    Serial number
    Firmware version of power source
    Firmware of PC board DOCMAG (Easy Documentation)
    Document version
    https://www.easydocu.weldcube.com (A PFDF report of selected welding data can be created under this link)
    Nr.
    Meter
    Start by plugging in the USB thumb drive;
    when switching the power source off and on, the meter continues at the last weld seam number.
    A new CSV file is created after 1000 welding operations.
    Date
    Date yyyy-mm-dd
    Time
    Time hh:mm:ss
    at the start of current flow
    Duration
    Duration in [s]
    from start of current flow to end of current (current flow signal)
    I
    Welding current * in [A]
    U
    Welding voltage * in [V]
    vd
    Wire speed * in [m/min]
    wfs
    Wire speed * in [ipm]
    IP
    Power * from current values in [W]
    IE
    Energy from instantaneous values in [kJ]
    over the entire welding operation
    I-Mot
    Motor current * in [A]
    Synid
    Characteristic number
    Job
    EasyJob number
    per weld seam
    Process
    Welding process
    Mode
    Operating mode
    Status
    PASS: regular welding
    IGN: Welding canceled during the ignition phase
    Err | xxx: Welding canceled due to an error; the corresponding service code is documented
    Interval
    Weld seam number for "Interval" operating mode
    Signature
    Signature for each weld seam number
    in each case from the main process phase;
    in the event of termination in the ignition phase, the average value in the ignition phase is stored and an identifier is output to indicate that the main process phase has been reached
    The welding data are documented as average values in the main process phase and for each welding operation.
    2. General
    New CSV file
    A new CSV file is generated
    • When the USB thumb drive is disconnected and reconnected with the power source switched on
    • When the date and time are changed
    • From 1000 welding operations
    • During a firmware update
    • When the USB thumb drive is disconnected and reconnected to another power source
      (= change of serial number).
    2. General
    PDF report / Fronius signature
    By scanning this link...
    • A PDF report of the selected welding data can be created
    • The authenticity of the welding data can be checked and guaranteed via the Fronius signature read out with the welding data.
    https://easydocu.weldcube.com
    Activating / deactivating Easy Documentation
    Activating Easy Documentation
    Plug in the USB thumb drive
    The power source display shows:
    Easy Documentation is activated.
    doc | on is also displayed when the power source is switched off and on again with the USB thumb drive connected.
    Easy Documentation remains activated.
    2Acknowledge the display by pressing the arrow key
    3Set the date and time
    2. Activating / deactivating Easy Documentation
    Setting the date and time is carried out in the 2nd level of the service menu.
    The first parameter in the service menu is displayed.
    Select the "2nd" setup parameter using the left-hand selection dial
    The first parameter in the 2nd level of the service menu is displayed.
    Select the "yEA" (= year) setup parameter using the left-hand selection dial
    5
    To set the date and time:
    • Left-hand selection dial:
      select parameter
    • Right-hand selection dial:
      change values
    Setting ranges:
    yEA
    Year (20yy; 0 - 99)
    Mon
    Month (mm; 1 -1 12)
    dAY
    Day (dd; 1 - 31)
    Hou
    Hour (hh; 0 - 24)
    Min
    Minute (mm; 0 - 59)
    NOTE!
    If the power source is reset to factory settings via setup parameter FAC, the date and time remain stored.
    Deactivating Easy Documentation
    CAUTION!
    Risk of data loss or data damage due to premature disconnection of the USB thumb drive
    Do not disconnect the USB thumb drive until approx. 10 seconds after the end of the last welding operation to ensure correct data transfer.
    1Unplug the USB thumb drive from the power source
    Easy Documentation is deactivated.
    Setup Settings
    Setup Menu
    General
    The Setup menu offers easy access to expert knowledge related to the power source, as well as additional functions. The Setup menu makes it possible to easily adjust the parameters for various tasks.
    1. Setup Settings
    Setup Menu
    General
    1. Setup Settings
    2. Setup Menu
    General
    1. Setup Settings
    2. Setup Menu
    Operation
    Accessing the Setup menu is described with reference to the MIG/MAG standard synergic welding process.
    Access is the same for the other welding processes.
    Press the "Process" button to select the "MIG/MAG standard synergic welding" process
    The control panel is now located in the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
    Adjusting parameters
    Select the desired setup parameter using the left-hand selection dial
    Change the setup parameter value using the right-hand selection dial
    Exiting the Setup menu
    1. Setup Settings
    2. Setup Menu
    Setup parameters for MIG/MAG synergic welding
    The specifications "min." and "max." are used for setting ranges that vary according to the power source, welding program, etc.
    GPr
    Gas pre-flow time
    Unit: s
    Setting range: 0 - 9.9
    Factory setting: 0.1
    GPo
    Gas post-flow time
    Unit: s
    Factory setting: 0.5
    SL
    Slope (for special 2-step mode and special 4-step mode)
    Unit: s
    I-S
    Starting current (for special 2-step mode and special 4-step mode)
    Unit: % (of welding current)
    Setting range: 0 - 200
    Factory setting: 100
    I-E
    Final current (for special 2-step mode and special 4-step mode)
    Factory setting: 50
    t-S
    Starting current duration (only for special 2-step mode)
    Unit: s
    Setting range: 0.0 - 9.9
    Factory setting: 0.0
    t-E
    Final current duration (only for special 2-step mode)
    Unit: s
    Fdi
    Feeder inching speed
    Unit: m/min (ipm)
    Setting range: 1 - max (39.37 - max)
    Factory setting: 10 (393.7)
    bbc
    Burnback effect
    Burnback effect due to wire retraction at the end of welding
    When the welding current is switched off, the wire electrode is retracted at 7.5 m/min for the duration of the set bbc value.
    Unit: s
    Setting range: 0 - 0.2
    Factory setting: 0
    Ito
    Length of wire that is fed before the safety cut-out trips
    Unit: mm (in.)
    Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94)
    Factory setting: OFF
    NOTE!
    The Ito function (length of wire fed until safety cut-out trips) is a safety function.
    At high wire speeds in particular, the length of wire fed until the safety cut-out trips can deviate from the set wire length.
    SPt
    Unit: s
    Setting range: 0.3 - 5
    Factory setting: 1
    SPb
    Interval pause time
    Unit: s
    Setting range: OFF, 0.3 - 10 (in 0.1 s increments)
    IMPORTANT! SPb = OFF must be set for spot welding!
    Int
    Interval
    Displayed only if a value has been set for SPb
    Unit:
    Setting range: 2T (2-step), 4T (4-step)
    Factory setting: 2T (2-step)
    F
    Frequency for SynchroPulse
    Unit: Hz
    Setting range: OFF, 0.5 - 5
    dFd
    Delta wire feed
    Offset welding power for SynchroPulse option
    Unit: m/min (ipm)
    Setting range: 0 - 3 (0 - 118.1)
    Factory setting: 2 (78.7)
    AL2
    Arc length correction for upper SynchroPulse operating point
    Unit: % (of welding power)
    Setting range: 30 - +30
    Factory setting: 0
    FAC
    Reset power source to factory settings
    Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings
    - when "PrG" appears on the digital display, the power source has been reset
    IMPORTANT! If the power source is reset, all the personal settings in the Setup menu are lost.
    Operating points stored using save buttons remain stored when the power source is reset. The functions in the second level of the setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito).
    2nd
    Second level of the Setup menu (see "Setup Menu 2nd Level")
    1. Setup Settings
    2. Setup Menu
    Setup parameters for MIG/MAG standard manual welding
    GPr
    Gas pre-flow time
    Unit: s
    GPo
    Gas post-flow time
    Unit: s
    Fdi
    Unit: m/min (ipm)
    bbc
    Burnback effect
    Burnback effect due to a delayed switch-off of the welding current after the wire electrode has come to a stop. A ball forms on the wire electrode.
    Unit: s
    Setting range: AUt, 0 - 0.3
    Factory setting: AUt
    IGC
    Ignition current
    Unit: A
    Setting range: 100 - 650
    Factory setting: 500
    Ito
    Unit: mm (in.)
    NOTE!
    SPt
    Unit: s
    Factory setting: 0.3
    SPb
    Interval pause time
    Unit: s
    Int
    Interval
    Unit:
    FAC
    2nd
    1. Setup Settings
    2. Setup Menu
    Setup parameters for MMA welding
    IMPORTANT! When resetting the power source using the Factory FAC setup parameter, the hot current time (Hti) and HotStart current (HCU) setup parameters are also reset.
    HCU
    HotStart current
    Unit: %
    Setting range: 100 - 200
    Factory setting: 150
    Hti
    Hot current time
    Unit: s
    Setting range: 0 - 2.0
    ASt
    Anti-stick
    Unit: -
    Setting range: On, OFF
    AAG
    Gouging (Arc Air Gauging)
    Arc air gouging with a carbon electrode, e.g., for joint preparation
    Unit: -
    Setting range: on / OFF
    Factory setting: oFF
    FAC
    Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset.
    IMPORTANT! If the power source is reset, all the personal settings are lost.
    Operating points stored using save buttons are not deleted when the power source is reset - they remain stored. The functions in the second level of the setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito).
    2nd
    1. Setup Settings
    Limitations
    The following restrictions occur in relation to the Setup menu 2nd level:
    Setup menu 2nd level cannot be selected:
    • during welding
    • if the "Gas test" function is active
    • if the "Wire threading" function is active
    • if the "Wire withdrawal" function is active
    • if the "Gas purging" function is active
    If level 2 of the Setup menu is selected, the following functions are not available, even in robot mode:
    • Welding start-up - the "Power source ready" signal will not be emitted for robot mode
    • Gas test
    • Wire inching
    • Wire withdrawal
    • Gas purging
    1. Setup Settings
    2. Setup Menu 2nd Level
    Limitations
    • during welding
    • Gas test
    • Wire inching
    • Wire withdrawal
    • Gas purging
    1. Setup Settings
    Operation (Setup Menu 2nd Level)
    Accessing the 2nd level of the Setup menu:
    The control panel is now located in the 2nd level of the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
    A parameter is displayed in the first level of the Setup menu.
    1. Setup Settings
    Parameters for MIG/MAG synergic welding in Setup menu 2nd level
    SEt
    Country-specific setting (Standard/USA) ... Std/US
    Unit: -
    Setting range: Std, US (Standard/USA)
    Factory setting:
    Standard version: Std (measurements: cm/mm)
    USA version: US (measures: in.)
    Syn
    Synergic programs/characteristics
    Standards EN/AWS
    Unit: -
    Setting range: EUr/US
    Factory setting:
    Standard version: EUr
    USA version: US
    C-C
    Cooler mode
    (only when the cooling unit is connected)
    Unit: -
    Setting range: AUt, On, OFF
    AUt:
    The cooling unit cuts out after a 2-minute welding off-time.
    IMPORTANT! If the coolant temperature and flow monitoring option has been installed in the cooling unit, the cooling unit cuts out as soon as the return-flow temperature drops below 50 °C, but at the earliest after a 2-minute welding off-time.
    On:
    The cooling unit is always switched on.
    OFF:
    The cooling unit is always switched off.
    IMPORTANT! If the FAC welding parameter is used, the C-C parameter is not reset to the factory setting. If the MMA welding process is selected, the cooling unit is always switched off, even if the switch is in the "On" position.
    C-t
    Cooling time
    Time from when flow monitoring is triggered until the "no | H2O" service code is output. For example, if there are air bubbles in the cooling system, the cooling unit will not cut out until the end of this preset time.
    Unit: s
    Setting range: 5 - 25
    Factory setting: 10
    IMPORTANT! Every time the power source is switched on, the cooling unit carries out a test run for 180 seconds.
    r
    Welding circuit resistance (in mOhm)
    See the section "Measuring the welding circuit resistance r" from page (→).
    L
    Welding circuit inductivity (in microhenrys)
    See the section "Displaying the welding circuit inductivity L" from page (→).
    EnE
    Electrical energy of the arc in relation to the welding speed
    Unit: kJ
    Setting range: On/OFF
    Since the full range of values (1 kJ - 99999 kJ) cannot be displayed on the three-digit display, the following display format has been selected:
    Value in kJ / indicator on display:
    1 to 999 / 1 to 999
    1000 to 9999 / 1.00 to 9.99 (without unit digit, e.g., 5270 kJ -> 5.27)
    10000 to 99999 / 10.0 to 99.9
    (without unit or tens digit, e.g., 23580 kJ -> 23.6)
    ALC
    Correction of the arc length via the welding voltage
    Only for MIG/MAG synergic welding
    The arc length depends on the welding voltage. The welding voltage can be individually adjusted in synergic operation.
    If the ALC parameter is set to "OFF", individual adjustment of the welding voltage is not possible. The welding voltage adjusts automatically according to the selected welding current or wire speed. When the arc length correction is adjusted, the voltage changes while the welding current and the wire speed remain constant. When adjusting the arc length correction using the selection wheel, the left display is used for the correction value of the arc length. On the right display, the value for the welding voltage changes at the same time. The left display then shows the original value again, e.g., welding current.
    Ejt
    EasyJob Trigger
    To activate/deactivate switching between EasyJobs using the torch trigger
    Unit: -
    Function with MIG/MAG torch trigger
    Press torch trigger briefly (< 0.5 s)
    No welding taking place:
    • Toggles through all MIG/MAG EasyJobs in sequence.
    • If an EasyJob is not selected, the torch trigger functions normally.
    • If a MIG/MAG EasyJob is not selected, no change is made.
    Welding taking place:
    • Toggles through MIG/MAG EasyJobs with the same operating mode (4-step, special 4-step, 4-step stitch welding) and with the same welding process.
    • It is not possible to switch during spot welding.
    Function with MIG/MAG Up/Down key
    If an EasyJob is selected, the EasyJob is changed, otherwise the welding current is changed.
    • Toggles through MIG/MAG EasyJobs with the same operating mode (2-step, 4-step, special 4-step, 4-step stitch welding) and with the same welding process.
      Switching back is possible.
    1. Setup Settings
    Parameters for MIG/MAG standard manual welding in Setup menu 2nd level
    SEt
    Unit: -
    Factory setting:
    C-C
    Cooler mode
    Unit: -
    AUt:
    On:
    OFF:
    C-t
    Cooling time
    Unit: s
    Factory setting: 10
    r
    L
    EnE
    Unit: kJ
    1 to 999 / 1 to 999
    Ejt
    EasyJob Trigger
    Unit: -
    1. Setup Settings
    Parameters for manual metal arc welding in Setup menu 2nd level
    SEt
    Country-specific setting (Standard/USA) ... Hour/US
    Unit:
    Factory setting:
    Standard version: Std (dimensions: cm / mm)
    USA version: US (dimensions: in.)
    r
    r (resistance) - welding circuit resistance (in mOhm)
    L
    L (inductivity) - welding circuit inductivity (in microhenrys)
    1. Setup Settings
    Measuring the Welding Circuit Resistance r
    General
    Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
    The calculated welding circuit resistance is shown on the display.
    r = welding circuit resistance in milliohm (mOhm)
    If the welding circuit resistance has been measured correctly, the set welding voltage will correspond exactly to the welding voltage at the arc. If you manually measure the voltage on the output jacks of the power source, this voltage will be higher than the welding voltage at the arc - that is, higher by the same amount as the voltage drop of the hosepack.
    The welding circuit resistance depends on the hosepack used:
    • If the length or cross-sectional area of the hosepack has changed, measure the welding circuit resistance again
    • Measure the welding circuit resistance for every welding process separately with the appropriate welding power-leads
    1. Setup Settings
    2. Measuring the Welding Circuit Resistance r
    General
    1. Setup Settings
    Measuring the welding circuit resistance (MIG/MAG welding)
    NOTE!
    Incorrect measurement of the welding circuit resistance can have a negative effect on the welding result.
    Ensure that the workpiece has an optimum contact surface in the area of the earthing clamp (clean surface, no rust, etc.).
    1Make sure that one of the MANUAL / STD SYNERGIC / pulsed synergic welding processes is selected
    2Establish a ground earth connection to the workpiece
    3Access the Setup menu 2nd level (2nd)
    4Select parameter "r"
    5Remove the gas nozzle from the welding torch
    6Screw on the contact tip
    7Ensure that the wire electrode does not protrude from the contact tip
    NOTE!
    Ensure that the workpiece has an optimum contact surface for the contact tip (clean surface, no rust, etc.).
    8Place the contact tip flush against the workpiece surface
    9Press the torch trigger briefly
    • The welding circuit resistance is calculated. "run" is shown on the display during the measurement
    The measurement is finished when the welding circuit resistance is shown on the display in mOhm (for example 11.4).
    10Fit the gas nozzle back onto the welding torch
    1. Setup Settings
    Measuring the welding circuit resistance (MMA welding)
    NOTE!
    1Ensure that the Stabelektroden-Schweißen welding process is selected
    NOTE!
    Ensure that the workpiece has an optimum contact surface for the electrode (clean surface, no rust, etc.).
    5Place the electrode flush against the workpiece surface
    6Press the "Parameter selection" button (right)
    The welding circuit resistance is calculated. During the measurement the display shows "run".
    1. Setup Settings
    Displaying the welding circuit Inductivity L
    General
    The way that the hosepack is arranged has a very significant effect on the welding circuit inductivity and therefore affects the welding process. It is important to lay the hosepacks correctly in order to obtain the best possible welding result.
    1. Setup Settings
    2. Displaying the welding circuit Inductivity L
    General
    1. Setup Settings
    The setup parameter "L" is used to display the most recently calculated welding circuit inductivity. The welding circuit inductivity is adjusted when the welding circuit resistance is measured. Detailed information in this regard can be found under the "Welding circuit resistance" chapter.
    1Access the Setup menu 2nd level (2nd)
    2Select parameter "L"
    The most recently calculated welding circuit inductivity L is shown on the right-hand digital display.
    L ... Welding circuit inductivity (in microhenrys)
    1. Setup Settings
    Laying the hosepacks correctly
    Troubleshooting and Maintenance
    Troubleshooting
    General
    The devices are equipped with an intelligent safety system, which largely negates the need for melting-type fuses. Melting-type fuses therefore no longer need to be replaced. After a possible malfunction has been remedied, the device is ready for use again.
    1. Troubleshooting and Maintenance
    Troubleshooting
    General
    2. Troubleshooting
    General
    2. Troubleshooting
    Safety
    WARNING!
    Read and understand all safety rules and user documentation for this equipment and all system components.
    WARNING!
    WARNING!
    Danger due to insufficient ground conductor connection.
    The housing screws provide a suitable ground conductor connection for grounding the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    2. Troubleshooting
    Displayed Service Codes
    If an error message that is not described here appears on the displays, first try to resolve the problem as follows:
    1Switch the power source power switch to the -O- position
    2Wait 10 seconds
    3Switch the power switch to the -I- position
    If the error occurs again despite several attempts to eliminate it, or if the troubleshooting measures listed here are unsuccessful.
    1Make a note of the error message displayed
    2Note down the configuration of the power source
    3Contact our After-Sales Service team with a detailed description of the error
    ESr | 20
    Cause:The cooling unit used is not compatible with the power source
    Remedy:Connect compatible cooling unit
    Cause:An invalid welding process was called up on the robot interface (no. 37) or an empty flag was selected (no. 32)
    Remedy:Call up a valid welding process or select assigned "Save" button
    ELn | 8
    Cause:The connected wirefeeder is not supported
    Remedy:Connect supported wirefeeder
    ELn | 12
    Cause:Different control panels for selecting materials are in the system
    Remedy:Connect similar control panels to select materials
    ELn | 13
    Cause:Impermissible change of welding process during welding
    Remedy:During welding do not make any impermissible change to the welding process, reset error message by pressing any button
    ELn | 14
    Cause:More than one robot interface is connected
    Remedy:Only one robot interface may be connected, check the system configuration
    ELn | 15
    Cause:More than one remote control is connected
    Remedy:Only one remote control may be connected, check the system configuration
    ELn | 16
    Wirefeeder program selector not compatible
    Cause:A wirefeeder with standard program selector is connected to the pulse power source
    Remedy:Connect wirefeeder with pulse program selector
    Err | IP
    Cause:The power source control has detected a primary overvoltage
    Remedy:Check the grid voltage.
    If the service code persists, switch off the power source, wait for 10 seconds and then switch the power source on again.
    If the error still persists, contact the After-Sales Service team
    Err | PE
    Cause:The earth current watchdog has triggered the safety cut-out of the power source.
    Remedy:Switch off the power source
    Place the power source on an insulating surface
    Connect the grounding cable to a section of the workpiece that is closer to the arc
    Wait for 10 seconds and then switch the power source on again
    If you have tried this several times and the error keeps recurring, contact the After-Sales Service team
    Err | Ur
    Cause:If the VRD option is available, the open circuit voltage limit of 35 V has been exceeded.
    no | UrL
    Cause:The VRD option has tripped too early.
    Remedy:Check whether all welding power-leads and control lines are connected.
    Wait 10 seconds and switch the power source back on again
    If the error occurs again - contact the After-Sales Service team.
    PHA | SE1
    Cause:The power source is being used in single-phase mode
    Remedy:-
    PHA | SE3
    Cause:The power source is being used in three-phase mode
    Remedy:-
    Err | 51
    Cause:Mains undervoltage: the grid voltage has fallen below the tolerance range
    Remedy:Check the grid voltage. If the service code persists, contact the After-Sales Service team
    Err | 52
    Cause:Mains overvoltage: the grid voltage has risen above the tolerance range
    EFd 5
    Cause: Incorrect wirefeeder connected
    Remedy:Connect correct wirefeeder
    EFd 8
    Cause: Wirefeeder overtemperature
    Remedy:Allow wirefeeder to cool down
    EFd | 81, EFd | 83
    Cause:Fault in the wirefeed system (overcurrent in wirefeeder drive)
    Remedy:Arrange the hosepack in as straight a line as possible; check that there are no kinks or dirt in the inner liner; check the contact pressure on the 4 roller drive
    Cause:Wirefeeder motor is sticking or faulty
    Remedy:Check the wirefeeder motor or contact the After-Sales Service team
    to0 | xxx
    Note: xxx stands for a temperature value
    Cause:Overtemperature in the primary circuit of the power source
    Remedy:Allow power source to cool down, check air filter and clean if necessary, check that fan is on
    to1 | xxx
    Cause:Overtemperature on the booster located in the power source
    to2 | xxx
    Cause:Overtemperature in the secondary circuit of the power source
    Remedy:Allow power source to cool down, check that fan is on
    to3 | xxx
    Cause:Overtemperature in wirefeeder motor
    to4 | xxx
    Cause:Overtemperature in welding torch
    Remedy:Allow welding torch to cool down
    to5 | xxx
    Cause:Overtemperature in cooling unit
    Remedy:Allow cooling unit to cool down, check that fan is on
    to6 | xxx
    Cause:Overtemperature on the power source transformer
    to7 | xxx
    Cause:Overtemperature in the power source
    tu0 | xxx
    Cause:Undertemperature in the power source primary circuit
    Remedy:Place power source in a heated room and allow it to warm up
    tu1 | xxx
    Cause:Undertemperature on the booster located in the power source
    tu2 | xxx
    Cause:Undertemperature in the power source secondary circuit
    tu3 | xxx
    Cause:Undertemperature in the wirefeeder motor
    Remedy:Place wirefeeder in a heated room and allow to warm up
    tu4 | xxx
    Cause:Undertemperature in the welding torch
    Remedy:Place welding torch in a heated room and allow to warm up
    tu5 | xxx
    Cause:Undertemperature in the cooling unit
    Remedy:Place cooling unit in a heated room and allow to warm up
    tu6 | xxx
    Cause:Undertemperature on the power source transformer
    tu7 | xxx
    Cause:Undertemperature in power source
    no | H2O
    Cause: Coolant flow rate too low
    Remedy:Check coolant flow rate and cooling unit, including cooling circuit (for minimum coolant flow, see "Technical Data" chapter in the Operating Instructions for the device)
    hot | H2O
    Cause: The coolant temperature is too high
    Remedy:Allow cooling unit and cooling circuit to cool down, until "hot | H2O" is no longer displayed. Open the cooling unit and clean the cooler, check fan is working properly.
    no | Prg
    Cause:No preconfigured program has been selected
    Remedy:Select a configured program
    no | IGn
    Cause: "Ignition time-out" function is active; current did not start flowing before the length of wire specified in the Setup menu had been fed. The power source safety cut-out has tripped
    Remedy:Shorten the wire stick-out; press the torch trigger again; clean the surface of the workpiece; if necessary, set the "Ito" parameter in the Setup menu
    EPG | 17
    Cause: The selected welding program is invalid
    Remedy:Select a valid welding program
    EPG | 29
    Cause: The required wirefeeder is not available for the selected characteristic
    Remedy:Connect the correct wirefeeder, check the plug connections for the hosepack
    EPG | 35
    Cause: Measurement of the welding circuit resistance failed
    Remedy:Check grounding cable, current cable, or hosepack and replace if necessary, re-measure the welding circuit resistance
    2. Troubleshooting
    Displayed service codes in connection with OPT Easy Documentation
    no | dAt
    Welding is not possible
    Cause:Date and time are not set on the power source
    Remedy:To reset the service code, press the arrow key;
    Set date and time in the 2nd level of the service menu:
    see page (→)
    bAt | Lo
    Welding is possible
    Cause:The battery of OPT Easy Documentation is low
    Contact service (to change the battery)
    bAt | oFF
    Cause:The battery of the OPT Easy Documentation is empty
    Remedy:To reset the service code, press the arrow key - the display shows no | dAt;
    Contact service (to change the battery);
    After changing the battery, the date and time in the are displayed in the 2nd level of the service menu:
    see page (→)
    Err | doc
    Cause:Error writing data;
    Internal documentation error;
    Communication error;
    Remedy:Turn power source off and on again
    Err | USb
    Cause:Invalid file system on USB thumb drive;
    General USB error
    Remedy:Unplug the USB thumb drive
    USB | full
    Cause:The plugged in USB thumb drive is full
    Remedy:Unplug USB thumb drive, plug in new USB thumb drive
    Service, maintenance and disposal
    General
    Under normal operating conditions, the welding system requires only a minimum of care and maintenance. However, several points must be observed in order for the welding system to remain operational for years to come.
    2. Service, maintenance and disposal
    General
    Safety
    WARNING!
    WARNING!
    At every start-up
    • Check mains plug and mains cable, as well as the welding torch, interconnecting hosepack, and ground earth connection for damage
    • Check if the all-round clearance of the device is 0.5 m (1 ft. 8 in.) so that cooling air can circulate unimpeded
    NOTE!
    Air inlet and outlet openings must not be blocked or even partially covered.
    Every 2 Months
    CAUTION!
    Danger of damage to property.
    The air filter must only be fitted when dry.
    If required, clean air filter using dry compressed air or by washing it.
    Every 6 Months
    CAUTION!
    Danger due to the effect of compressed air.
    Do not bring the air nozzle too close to electronic parts.
    1Dismantle device side panels and blow the inside of the device clean with dry, reduced compressed air
    2Also clean the cooling air ducts if there is a large accumulation of dust
    WARNING!
    Danger of electric shock due to grounding cable and device grounding points not being connected properly.
    When refitting the side panels, ensure that the grounding cable and device grounding points are properly connected.
    Disposal
    Disposal must only be carried out in accordance with the section of the same name in the "Safety rules" chapter.
    Appendix
    Average consumption values during welding
    Average wire electrode consumption during MIG/MAG welding
    Average wire electrode consumption at a wire speed of 5 m/min
    1.0 mm wire electrode diameter
    1.2 mm wire electrode diameter
    1.6 mm wire electrode diameter
    Steel wire electrode
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    Aluminum wire electrode
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    Average wire electrode consumption at a wire speed of 10 m/min
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    2. Average consumption values during welding
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    Average shielding gas consumption during MIG/MAG welding
    Wire electrode diameter
    1.0 mm
    1.2 mm
    1.6 mm
    2.0 mm
    2 x 1.2 mm (TWIN)
    Average consumption
    10 l/min
    12 l/min
    16 l/min
    20 l/min
    24 l/min
    1. Appendix
    Average shielding gas consumption during TIG welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address.
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    1. Appendix
    2. Technical data
    1. Appendix
    2. Technical data
    Special Voltage
    For devices designed for special voltages, the technical data on the rating plate applies.
    The following applies for all devices with a permitted grid voltage of up to 460 V: The standard mains plug allows the user to operate with a grid voltage of up to 400 V. For grid voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
    1. Appendix
    2. Technical data
    Explanation of the term duty cycle
    The duty cycle (ED) is the period of a ten minute cycle in which the device may be operated at the stated power without overheating.
    NOTE!
    The ED values cited on the rating plate relate to an ambient temperature of 40 °C.
    If the ambient temperature is higher, the ED or power must be lowered accordingly.
    Example: Welding with 150 A at 60% ED
    • Welding phase = 60% of 10 mins = 6 mins
    • Cool-down phase = rest time = 4 mins
    • Following the cool-down phase, the cycle begins again.
    To use the device without interruptions:
    1Search for a 100% ED value in the technical data, which corresponds to the existing ambient temperature.
    2Reduce the power or amperage value correspondingly so that the device can operate without a cool-down phase.
    1. Appendix
    2. Technical data
    TransSteel 4000 Pulse TransSteel 4000 Pulse nc
    Mains voltage (U1)
    3 x 380 V/400 V/460 V
    Max. effective primary current (I1eff)
    3 x 380/400 V
    25.0 A
    3 x 460 V
    27.0 A
    Max. primary current (I1max)
    3 x 380/400 V
    32.0 A
    3 x 460 V
    22.0 A
    Mains fuse
    35 A slow-blow
    Mains voltage tolerance
    -10 / +15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    Max. permitted grid impedance Zmax on PCC1)
    11.9 mOhm
    Recommended residual-current circuit breaker
    Type B
    Welding current range (I2)
    MIG/MAG
    10 - 400 A
    MMA
    10 - 400 A
    Welding current at 10 min / 40 °C
    (104 °F)
    40% / 400 A
    60% / 370 A
    100% / 340 A
    Output voltage range according to standard characteristic (U2)
    MIG/MAG
    14.5 - 34.0 V
    MMA
    20.4 - 36.0 V
    Open circuit voltage
    (U0 peak / U0 r.m.s)
    65 V
    Apparent power at 400 V AC / 400 A / 40% ED2)
    20.42 kVA
    Protection class
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    Overvoltage category
    III
    Pollution degree according to IEC60664
    EMC emission class
    A3)
    Safety symbols
    S, CE
    Dimensions l x w x h
    747 x 300 x 497 mm
    29.4 x 11.8 x 19.6 in.
    Weight
    32.5 kg / 71.65 lb.
    Max. noise emission (LWA)
    72 dB (A)
    Idle state power consumption at 400 V
    31.2 W
    Power source efficiency at
    400 A / 36 V
    91%
    1)
    Interface to a 230/400-V and 50-Hz public grid
    2)
    ED = Duty cycle
    3)
    A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid.
    The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies.
    1. Appendix
    2. Technical data
    TransSteel 4000 Pulse MV nc
    Mains voltage (U1)
    3 x 200 V / 230 V / 400 V / 460 V
    3 x 230 V
    33.0 A
    3 x 400 V
    19.0 A
    3 x 460 V
    16.0 A
    3 x 230 V
    42.0 A
    3 x 400 V
    23.0 A
    3 x 460 V
    21.0 A
    Mains fuse
    35 A slow-blow
    -10 / +15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    71.2 mOhm
    Type B
    MIG/MAG
    10 - 400 A
    MMA
    10 - 400 A
    (104 °F)
    U1: 200 - 460 V
    40% / 400 A
    60% / 370 A
    100% / 340 A
    MIG/MAG
    14.5 - 34.0 V
    MMA
    20.4 - 36.0 V
    57 V
    Apparent power
    at 230 V AC / 350 A / 40% ED2)
    16.22 kVA
    at 400 V AC / 350 A / 40% ED2)
    15.96 kVA
    Protection class
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    III
    EMC emission class
    A3)
    Safety symbols
    S, CE, CSA
    747 x 300 x 497 mm
    Weight
    37.3 kg / 82 lb.
    74 dB (A)
    82.7 W
    400 A / 36 V
    90%
    1)
    2)
    ED = Duty cycle
    3)
    1. Appendix
    2. Technical data
    TransSteel 5000 Pulse TransSteel 5000 Pulse nc
    Mains voltage (U1)
    3 x 380 V / 400 V / 460 V
    3 x 380/400 V
    28 A
    3 x 460 V
    24.0 A
    3 x 380/400 V
    44.0 A
    3 x 460 V
    38.0 A
    Mains fuse
    35 A slow-blow
    -10 / +15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    10.7 mOhm
    Type B
    MIG/MAG
    10 - 500 A
    MMA
    10 - 500 A
    (104 °F)
    40% / 500 A
    60% / 420 A
    100% / 360 A
    MIG/MAG
    14.3 - 39 V
    MMA
    20.2 - 40 V
    65 V
    Apparent power at 400 V AC / 500 A / 40% ED2)
    28.36 kVA
    Protection class
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    III
    EMC emission class
    A3)
    Safety symbols
    S, CE
    747 x 300 x 497 mm
    Weight
    32.5 kg / 71.65 lb.
    74 dB (A)
    31.2 W
    500 A / 40 V
    91%
    1)
    2)
    ED = Duty cycle
    3)
    1. Appendix
    2. Technical data
    TransSteel 5000 Pulse MV nc
    Mains voltage (U1)
    3 x 200 V
    39.5 A
    3 x 230 V
    36.3 A
    3 x 400 V
    20.6 A
    3 x 460 V
    18.1 A
    3 x 200 V
    66.7 A
    3 x 230 V
    57.4 A
    3 x 400 V
    32.5 A
    3 x 460 V
    28.6 A
    Mains fuse
    3 x 200 V / 230 V
    63 A slow-blow
    3 x 400 V / 460 V
    35 A slow-blow
    -10 / +15%
    Mains frequency
    50/60 Hz
    Cos phi (1)
    0.99
    52.2 mOhm
    Type B
    MIG/MAG
    10 - 500 A
    MMA
    10 - 500 A
    (104 °F)
    U1: 200 V
    35% / 500 A
    60% / 420 A
    100% / 360 A
    U1: 208 - 460 V
    40% / 500 A
    60% / 420 A
    100% / 360 A
    MIG/MAG
    14.3 - 39 V
    MMA
    20.2 - 40 V
    57 V
    Apparent power
    at 200 V AC / 500 A / 40% ED2)
    23.08 kVA
    22.49 kVA
    Protection class
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    III
    EMC emission class
    A3)
    Safety symbols
    S, CE, CSA
    747 x 300 x 497 mm
    Weight
    43.6 kg / 96.1 lb.
    75 dB (A)
    82.7 W
    500 A / 40 V
    90%
    1)
    2)
    ED = Duty cycle
    3)
    1. Appendix
    2. Technical data
    China Energy Label
    TransSteel 3000 C PULSE FSC/nc
    TransSteel 4000 PULSE/nc
    TransSteel 5000 PULSE/nc
    1. Appendix
    Welding program tables
    Welding program label on the device
    A label with the most common welding programs is affixed to the power source:
    Welding program label on the power source
    1. Appendix
    2. Welding program tables
    1. Appendix
    Welding program tables for TransSteel 4000 Pulse, TransSteel 5000 Pulse
    The welding programs are active if
    • The "SEt" setup parameter is set to "Std" (Standard)
      or
    • The VR 5000 Remote wirefeeder is equipped with the VR Pulse control panel option.
    Welding program database: DB 3994
    (1) d = 1.2 mm (2) d = 0.9 mm (3) d = 1.4 mm
    1. Appendix
    Welding program tables for TransSteel 4000 Pulse, TransSteel 5000 Pulse US
    • The "Set" setup parameter is set to "US" (USA)
      or
