Indicates an immediate danger.
Indicates a possibly dangerous situation.
Indicates the possibility of flawed results and damage to the equipment.
The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device mustFor the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
The device is intended exclusively for the welding process specified on the rating plate.
Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose." The manufacturer is not responsible for any damage resulting from improper use.
The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
The manufacture shall also not be liable for faulty or incorrect work results.
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
This may affect a number of device types in terms of:*) both at the interface with the public grid
See technical data
In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
IMPORTANT! Ensure secure grounding of the grid connection!
The fumes produced during welding contain toxic gases and vapors.
Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
Use at-source extraction source and a room extraction system.
If possible, use a welding torch with an integrated extraction device.
Keep your head out of the welding fumes and gases.
Take the following precautionary measures for fumes and harmful gases:Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
Use a welding helmet with air supply if there is insufficient ventilation.
If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
The following components are factors that determine how toxic the welding fumes are:Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
Flying sparks can cause fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
Keep suitable, tested fire extinguishers on hand.
Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
Do not touch voltage-carrying parts inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Before every use, check power connections for secure fit by hand.
In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
Do not wrap cables or leads around your body or parts of the body.
Concerning the electrode (stick electrode, tungsten electrode, welding wire, etc.)The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
Switch off unused devices.
When working at elevated heights, wear a safety harness to prevent falls.
Before working on the device, switch off the device and remove the mains plug.
Secure the device to prevent the mains plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
After opening the device:If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Covers and side panels must only be opened/removed during maintenance and repair work.
During operationThe welding wire protruding from the welding torch poses a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
Do not touch the workpiece during or after welding—risk of burns.
Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Leave the welding torch and other parts with a high operating temperature to cool before working on them.
Special regulations apply in areas at risk of fire or explosion
– follow the appropriate national and international regulations.
Welding machines for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the welding machine may not be located in such areas.
Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
If the device is equipped with a carrier strap or handle, then this is used exclusively for transport by hand. The carrier strap is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
All lifting equipment (straps, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
The test interval and scope must at least comply with the respective valid national standards and guidelines.
There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
Use filters if necessary.
Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
Keep shielding gas cylinders away from welding or other electrical circuits.
Risk of explosion: Never weld on a compressed shielding gas cylinder.
Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
When no welding is taking place, close the valve of the shielding gas cylinder.
Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
Risk of asphyxiation due to uncontrolled shielding gas leak
Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
Do not lift or transport any active devices. Switch off and disconnect devices from the grid before transport or lifting.
Before transporting a welding system (e.g., with a trolley, cooling unit, welding machine, and wirefeeder), completely drain the coolant and dismantle the following components:It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is switched on.
Before switching on the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
Always secure the shielding gas cylinder well and remove before transporting by crane.
Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
Only use appropriate original coolant from the manufacturer.
Do not mix original coolant from the manufacturer with other coolants.
Only connect system components from the manufacturer to the cooling unit circuit.
If there is damage due to use of other system components or other coolants, the manufacturer accepts no liability for this and all warranty claims are forfeited.
Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
When the system is cool, always check the coolant level before starting welding.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating welding systems within the same 12-month interval.
A safety inspection by a certified electrician is recommended:For the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
Packaging materialsDevices with the CE label satisfy the essential requirements of the low-voltage and electromagnetic compatibility directive (e.g., relevant product standards of the EN 60974 series).
Fronius International GmbH declares that the device complies with Directive 2014/53/EU. The full text of the EU Declaration of Conformity is available on the following website: http://www.fronius.com
The TransSteel (TSt) 3000c Pulse power source is a fully digitized, microprocessor-controlled inverter power source.
A modular design and ability to easily extend the system guarantee a high degree of flexibility. The device is designed for the following welding processes:
The device has a "Power limitation" safety feature. This means that the power source can be operated at the power limit without compromising process safety. For details, refer to the "Welding operations" chapter.
The central control and regulation unit of the power sources is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Control algorithms ensure that the desired target state is maintained.
The TransSteel 3000c Pulse is used in trade and industry for manual applications with classical steel and galvanized sheet metal.
The power source is designed for:There are warning notices and safety symbols on the power sources. These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and property damage.
Welding is dangerous. The following basic requirements must be met:
Warning notices are attached to the device for certain device versions.
The arrangement of the symbols may vary.
| ! | Warning! Caution! The symbols represent possible dangers. |
| A | Drive rollers can injure fingers. |
| B | The welding wire and drive parts are under welding voltage during operation. Keep hands and metal objects away! |
| 1. | An electric shock can be fatal. |
| 1.1 | Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves. |
| 1.2 | Use a base that is insulated from the floor and work area to protect against electric shock. |
| 1.3 | Before working on the device, switch off the device and remove the mains plug or disconnect the power supply. |
| 2. | Inhalation of welding fumes can be harmful to health. |
| 2.1 | Keep your face away from any welding fumes. |
| 2.2 | Use forced-air ventilation or local extraction to remove welding fumes. |
| 2.3 | Remove welding fumes with a fan. |
| 3. | Welding sparks can cause an explosion or fire. |
| 3.1 | Keep flammable materials away from the welding process. Do not perform welding near flammable materials. |
| 3.2 | Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher. |
| 3.3 | Do not weld on drums or closed containers. |
| 4. | Arc rays can burn the eyes and injure the skin. |
| 4.1 | Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body. |
| 5. | Before working on the machine or welding: undertake training on the device and read the instructions! |
| 6. | Do not remove or paint over the sticker with the warnings. |
| * | Manufacturer order number of the sticker |
In order to process a wide range of materials effectively, various welding processes, procedures, and welding characteristics are available on the power source.
MIG/MAG standard synergic
MIG/MAG standard synergic welding is a MIG/MAG welding process covering the entire power range of the power source with the following arc types:
Dip transfer arc
Droplet transfer occurs in the lower power range during the short circuit.
Intermediate arc
The droplet increases in size at the end of the wire electrode and is transferred in the mid power range during the short circuit.
Spray arc
A short circuit-free transfer of material in the high power range.
MIG/MAG pulsed synergic
MIG/MAG pulsed synergic welding is a pulsed arc process with a controlled material transfer.
In the base current phase, the energy input is reduced to such an extent that the arc barely burns steadily and the surface of the workpiece is preheated. In the pulsing current phase, an accurately timed current pulse guarantees a precise detachment of the weld material droplet.
This principle guarantees low-spatter welding and precise operation throughout the entire power range.
SynchroPulse is available for the standard synergic and pulsed synergic processes.
The cyclic change of the welding power between two operating points with SynchroPulse achieves a finely rippled weld appearance and a non-continuous heat input.
The power sources can be operated with various system components and options. This makes it possible to optimize procedures and to simplify machine handling and operation, depending on the field of application for the power source.
Read and understand all safety rules and user documentation for this equipment and all system components.
| (1) | MIG/MAG welding torch |
| (2) | Stabilization of the gas cylinder holder |
| (3) | Power source |
| (4) | Cooling unit |
| (5) | Trolley with gas cylinder holder |
| (6) | Grounding and electrode cable |
| (7) | TIG welding torch |
The functions are all arranged in a logical way on the control panel. The individual parameters required for welding can be
Due to the synergic function, all other parameters are also adjusted if a single parameter is changed.
Because of software updates, certain functions may be available for your device but not described in these Operating Instructions or vice versa.
In addition, individual figures may also differ slightly from the operating elements of your device. However, the function of these operating elements is identical.
| No. | Function |
| (1) | "Parameter selection" button (right) a) for selecting the following parameters Arc length correction For correcting the arc length Welding voltage in V *) Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding. Pulse / arc-force dynamic correction For continuously correcting the droplet detachment force in MIG/MAG pulsed synergic welding - ... reduced droplet detachment force 0 ... neutral droplet detachment force + ... increased droplet detachment force For influencing the short-circuiting dynamic at the instant of droplet transfer in MIG/MAG standard synergic welding, MIG/MAG standard manual welding, and manual metal arc welding - ... harder and more stable arc 0 ... neutral arc + ... soft and low-spatter arc b) for changing parameters in the Setup menu |
| (2) | "Parameter selection" button (left) a) for selecting the following parameters Sheet thickness Sheet thickness in mm or in. If the welding current to be selected is not known, it is sufficient to enter the sheet thickness. The required welding current and any other parameters marked with *) will then be adjusted automatically. Welding current *) Welding current in A Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding. Wire speed *) Wire speed in m/min or ipm. b) for changing parameters in the Setup menu |
| (3) | Selection dial (right) For changing the arc length correction, welding voltage, and arc-force dynamic parameters For changing parameters in the Setup menu |
| (4) | Selection dial (left) For changing the sheet thickness, welding current, and wire speed parameters For selecting parameters in the Setup menu |
| (5) | EasyJob save buttons For saving up to 5 operating points |
| (6) | "Process" button **) For selecting the welding process MIG/MAG standard manual welding MIG/MAG standard synergic welding MIG/MAG pulsed synergic welding TIG welding Manual metal arc welding |
| (7) | "Mode" button For selecting the operating mode 2-step mode 4-step mode Special 4-step mode Spot welding/stitch welding |
| (8) | "Shielding gas" button For selecting the shielding gas used. The SP parameter is reserved for additional shielding gases. When the shielding gas is selected, the LED behind the corresponding shielding gas lights up. |
| (9) | "Wire diameter" button For selecting the wire diameter used. The SP parameter is reserved for additional wire diameters. When the wire diameter is selected, the LED behind the corresponding wire diameter lights up. |
| (10) | "Material" button For selecting the filler metal used. The SP parameter is reserved for additional materials. When the material type is selected, the LED behind the corresponding filler metal lights up. |
| (11) | "Wire threading" button Press and hold the button: Gasless wire threading into the torch hosepack While the button is being held, the wire drive operates at feeder inching speed. |
| (12) | Gas-test button For setting the required gas volume on the gas pressure regulator. Tap the button once: shielding gas flows out Tap the button again: shielding gas flow stops If the Gas-test button is not tapped again, the shielding gas flow will stop after 30 s. |
| (13) | SF - spot/stitch/SynchroPulse welding indicator
| (14) | Intermediate arc indicator A spatter-prone "intermediate arc" occurs between the dip transfer arc and the spray arc. The intermediate arc indicator lights up to alert you to this critical area. |
| (15) | HOLD indicator At the end of each welding operation, the actual values for welding current and welding voltage are stored - the "HOLD" indicator lights up. |
| (16) | Pulse indicator Lights up when the MIG/MAG pulsed synergic welding process is selected |
| (17) | Real Energy Input For displaying the energy applied during the welding operation. The Real Energy Input indicator must be activated in level 2 of the Setup menu – EnE parameter. The value continuously rises during welding in line with the permanently increasing energy input. The final value is stored after the end of welding until welding starts again or the power source is switched back on - the HOLD indicator lights up. |
| *) | During the MIG/MAG standard synergic welding process and MIG/MAG pulsed synergic welding process, if one of these parameters is selected, then the synergic function ensures that all other parameters, including the welding voltage parameter, are adjusted automatically. |
| **) | In conjunction with the VRD option, the indicator of the currently selected welding process is also used as status indicator:
Various service parameters can be retrieved by pressing the "Parameter selection" buttons at the same time.
Opening the display
The first parameter "Firmware version" will be displayed, e.g., "1.00 | 4.21"
Selecting parameters
Use the "Mode" and "Process" buttons or the left-hand selection dial to select the required setup parameter
Available parameters
Explanation | |
Example: | Firmware version |
Example: | Welding program configuration |
Example: | Number of the currently selected welding program |
Example: | Indicates the actual arc time since first use |
Example: | Motor current for wire drive in A |
2nd | 2. menu level for service technicians |
A keylock can be selected to prevent the settings from being inadvertently changed on the control panel. As long as the keylock is active:
Activating/deactivating the keylock:
Keylock activated:
The message "CLO | SEd" appears on the displays.
Keylock deactivated:
The message "OP | En" appears on the displays.
The keylock can also be activated and deactivated using the keylock switch option.
| (1) | Welding torch connection For connecting the welding torch |
| (2) | Polarity reverser For selecting the welding potential on the MIG/MAG welding torch |
| (3) | (-) Current socket with bayonet latch Used for
| (4) | (+) Current socket with bayonet latch Used for
| (5) | LocalNet connection Standardized connection for remote control |
| (6) | Power switch For switching the power source on and off |
| (7) | TMC connection (TIG Multi Connector) For connecting the TIG welding torch |
| (8) | MIG/MAG shielding gas connection socket For the shielding gas supply to the welding torch connection (1) |
| (9) | Mains cable with strain relief Not prefitted on all models |
| (10) | EASY DOCUMENTATION label |
| (11) | TIG shielding gas connection socket For the shielding gas supply for the (-) current socket (3) |
| No. | Function |
| (1) | Wirespool holder with brake For holding standard wirespools with a max. diameter of 300 mm (11.81 in.) and a max. weight of 19 kg (41.89 lbs.) |
| (2) | 4-roller drive |
| * | Side panel not shown |
Depending on the welding process, a minimum level of equipment is required to work with the power source.
The following describes the welding processes and the corresponding minimum equipment for welding operations.
Before starting work, switch off all devices and components involved, and disconnect them from the grid.
The power source is only intended for MIG/MAG, MMA and TIG welding. Any other use is deemed to be "not in accordance with the intended purpose." The manufacturer shall not be liable for any damage resulting from such improper use.
Intended use also means:The device can be set up and operated outdoors in accordance with degree of protection IP 23.
Direct moisture (e.g., from rain) must be avoided.
Danger from machines toppling over or falling.
Set up the device securely on an even, solid surface.
Check all screw connections are tightly fastened after installation.
Danger of electrical current due to electrically conductive dust in the device.
Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
The ventilation channel is a very important safety device. When selecting the setup location, ensure that the cooling air can enter or exit unhindered through the vents on the front and back. Any electrically conductive dust (e.g., from grinding work) must not be allowed to be sucked into the device.
The devices are designed for the grid voltage stated on the rating plate. If the mains cable or mains plug has not been attached to your version of the appliance, these must be installed according to national standards. Fuse protection for the grid lead can be found in the technical data.
Danger due inadequately dimensioned electrical installations.
This can lead to serious damage
The grid lead and its fuse protection should be designed to suit the existing power supply.
The technical data on the rating plate should be followed.
The following mains cables are required to operate the power source:
Europe:
Cable cross-section 4G2.5
USA/Canada:
Cable cross-section AWG 12, extra-hard usage
Depending on the version, a strain-relief device corresponding to the cable cross-section is fitted on the power source.
The item numbers of the different cables can be found in the Spare Parts List.
Europe:
USA/Canada:
Danger from work that is not carried out properly.
Serious personal injury and damage to property may result.
The work described below may only be performed by trained specialist personnel.
Follow national standards and guidelines.
Danger from improperly prepared mains cable.
Short circuits and damage to property may result.
Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before commissioning.
The ground conductor should be approx. 10 - 15 mm (0.4 - 0.6 in.) longer than the phase conductors.
A graphic representation of the mains cable connection is provided in the following sections for fitting the strain-relief device. To connect the mains cable, proceed as follows:
IMPORTANT! Tie the phase conductors near the block terminal using cable ties.
The power source is generator-compatible.
The maximum apparent power S1max of the power source must be known in order to select the correct generator output.
The maximum apparent power S1max of the power source is calculated for 3-phase devices as follows:
S1max = I1max x U1 x √3
I1max and U1 according to the device rating plate and technical data
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator can be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the power source!
The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
The mains voltage tolerance is specified in the "Technical data" section.
SGEN = S1max x 1.35
Commissioning is described with reference to a manual, water-cooled MIG/MAG application.
The steps and activities described below include references to various system components, such as
For more detailed information about installing and connecting the system components, please refer to the appropriate Operating Instructions for the system components.
Work performed incorrectly can cause serious injury and damage.
The following activities must only be carried out by trained and qualified personnel.
Please note the information in the "Safety instructions" chapter!
The following diagram shows an overview of how the individual system components are put together.
Danger due to feed roller holders shooting upwards.
This could result in injury.
When unlocking the clamping lever, keep fingers away from the area to the left and right of the clamping lever.
Danger due to open feed rollers.
After inserting/changing the feed rollers, always install the protective cover of the 4-roller drive.
Risk of injury due to springiness of spooled wire electrode.
When inserting the wirespool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Risk of injury from falling wirespool.
Ensure that the wirespool is fitted securely to the wirespool holder.
Danger of injury and property damage if the wirespool topples over because the locking ring has been placed the wrong way around.
Always position the locking ring as shown in the diagram on the left.
When inserting the basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Risk of injury from falling basket-type spool.
Make sure that the basket-type spool with basket-type spool adapter is fitted securely to the wirespool holder.
When working with basket-type spools, only use the basket-type spool adapter supplied with the device.
Danger of injury and property damage if the basket-type spool topples over because the locking ring has been placed the wrong way around.
Danger of injury and damage to property due to falling basket-type spool.
Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
When inserting the wire electrode into the 4-roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Risk of damage to the welding torch from sharp end of wire electrode.
Deburr the end of the wire electrode well before threading in.
Risk of injury from emerging wire electrode.
When pressing the "Wire threading" button or the torch trigger, keep the welding torch away from your face and body, and wear suitable protective goggles.
IMPORTANT! To facilitate exact positioning of the wire electrode, the following procedure is possible when the "Wire threading" button is pressed and held down.
If you release the "Wire threading" button and press it again before one second has elapsed, the sequence starts again from the beginning. This makes it possible to continuously position the wire at a low wire speed of 1 m/min or 39.37 ipm where necessary.
If there is no wire threading button present, the torch trigger can be used in a similar way. Before using the torch trigger for wire threading, proceed as follows:
Danger of injury and damage from electric shock and from the wire electrode emerging from the torch.
When you press the torch trigger:
Keep the welding torch away from your face and body
Wear suitable protective goggles
Do not point the welding torch at people
Make sure that the wire electrode does not touch any conductive or grounded parts (e.g., housing, etc.)
IMPORTANT! If the torch trigger is pressed instead of the "Wire threading" button, the welding wire runs at the feeder creep speed (depending on the welding program) for the first 3 seconds. After these 3 seconds, wirefeeding is briefly interrupted.
The welding system detects that the welding process should not start, but that the wire is to be threaded in. At the same time, the gas solenoid valve closes, and the welding voltage on the wire electrode is switched off.
If the torch trigger is kept pressed, wirefeeding restarts immediately without shielding gas and welding voltage, and the process continues as described above.
Risk of contact pressure being too high.
This can result in severe damage to property and poor weld properties.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
Contact pressure standard values for U-groove rollers:
Steel: 4 - 5
CrNi: 4 - 5
Tubular covered electrodes: 2 - 3
After releasing the wire threading button, the wirespool must stop unreeling.
If it continues unreeling, readjust the brake.
Danger from incorrect installation.
Do not dismantle the brake.
Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
The brake is only available as a complete unit.
The illustration of the brake is for information purposes only.
After switching on the power source for the first time, the date and time must be set. For this purpose, the power source changes to the second level of the service menu; the yEA parameter is selected.
To set the date and time see page (→), step 5
"Power limitation" is a safety function for MIG/MAG welding. This means that the power source can be operated at the power limit whilst maintaining process safety.
Wire speed is a determining parameter for welding power. If it is too high, the arc gets smaller and smaller and may be extinguished. In order to prevent this, the welding power is lowered.
If the "MIG/MAG standard synergic welding" or "MIG/MAG pulsed synergic welding" process is selected, the symbol for the "Wire speed" parameter flashes as soon as the safety function trips. The flashing continues until the next welding start-up, or until the next parameter change.
If the "Wire speed" parameter is selected, for example, the reduced value for wire speed is displayed.
Operating the device incorrectly can cause serious injury and damage to property.
Do not use the functions described here until you have fully read and understood the Operating Instructions.
Do not use the functions described here until you have fully read and understood all of the Operating Instructions of the system components, especially the safety rules.
For details of the meaning, settings, setting range and units of the available welding parameters (e.g., gas pre-flow time), please refer to the "Setup parameters" chapter.
| GPr | Gas pre-flow time |
| I-S | Starting current Can be increased or decreased depending on the application |
| SL | Slope Starting current is continuously lowered as far as the welding current and the welding current as far as the final current |
| I | Welding current phase Even heat input into the parent material whose temperature is raised by the advancing heat |
| I-E | Final current To fill up end-craters |
| GPo | Gas post-flow time |
| SPt | Spot welding time / interval welding time |
| SPb | Interval pause time |
"4-step mode" is suitable for longer weld seams.
"Special 2-step mode" is ideal for welding in higher power ranges. In special 2-step mode, the arc starts at a lower power, which makes it easier to stabilize.
To activate special 2-step mode:
Special 4-step mode allows the starting and final current to be configured in addition to the advantages of 4-step mode.
The "Spot welding" mode is suitable for welded joints on overlapped sheets.
Start by pressing and releasing the torch trigger - GPr gas pre-flow time - welding current phase over the SPt spot welding time duration - GPo gas post-flow time.
If the torch trigger is pressed again before the end of the spot welding time (< SPt), the process is canceled immediately.
The "2-step stitch welding" mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
The "4-step stitch welding" mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
IMPORTANT! Observe the safety rules and operating conditions in the Operating Instructions for the cooling unit.
IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component - such as remote control or wirefeeder - on the control panel of the power source.
The sheet thickness, welding current, wire speed, and welding voltage parameters are directly linked. It is sufficient to change one of the parameters, as the remaining parameters are immediately adjusted accordingly
All welding parameter set values remain stored until the next time they are changed. This applies even if the power source is switched off and on again. To display the actual welding current during welding, select the welding current parameter.
The arc length correction and arc-force dynamic parameters can be used to optimize the welding result.
Arc length correction:
| - | = shorter arc, reduced welding voltage |
| 0 | = neutral arc |
| + | = longer arc, increased welding voltage |
For continuous correction of the droplet detachment force in MIG/MAG pulsed synergic welding
| - | reduced droplet detachment force |
| 0 | neutral droplet detachment force |
| + | increased droplet detachment force |
For influencing the short-circuiting dynamic at the instant of droplet transfer during MIG/MAG standard synergic welding
| - | = hard, stable arc |
| 0 | = neutral arc |
| + | = soft, low-spatter arc |
SynchroPulse is recommended for welded joints with aluminum alloys whose weld seams should have a rippled appearance. This effect is achieved using a welding power that changes between two operating points.
The two operating points result from a positive and negative change in the welding power to a dFd (delta wire feed) value that can be adjusted in the Setup menu (delta wire feed: 0.0 - 3.0 m/min or 0.0 - 118.1 ipm).
Other parameters for SynchroPulse:To enable SynchroPulse, you must change at least the value of the F (Frequency) parameter from OFF to a variable in the range of 0.5 to 5 Hz in the process Setup menu.
SynchroPulse is not supported with standard manual welding selected.
How SynchroPulse works when used in "Special 4-step" mode
I-S = starting-current phase, SL = Slope, I-E = crater-fill phase, v = wire speed
The MIG/MAG standard manual welding process is a MIG/MAG welding process with no synergic function.
Changing one parameter does not result in any automatic adjustments to the other parameters. All of the variable parameters must therefore be adjusted individually, as dictated by the welding process in question.
The following parameters are available for MIG/MAG manual welding:
Wire speed
1 m/min (39.37 ipm.) - maximum wire speed, e.g., 25 m/min (984.25 ipm.)
Welding voltageTransSteel 4000 Pulse: 15.5 - 31.5 V
TransSteel 5000 Pulse: 14.5 - 39 V
Arc-force dynamic:
Welding current
Only the actual value is displayed
In MIG/MAG standard manual welding, special 4-step mode corresponds to conventional 4-step mode.
The welding parameter values are shown in the digital display located above.
To display the actual welding current during welding:
To obtain the best possible welding results, the arc-force dynamic parameter will sometimes need to be adjusted.
The spot welding and stitch welding modes are MIG/MAG welding processes. The spot welding and stitch welding modes are activated on the control panel.
Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
Stitch welding is used for light-gage sheets.
As the wire electrode is not fed continuously, the weld pool can cool down during the intervals. Local overheating leading to the parent material being melted through is largely avoided.
Procedure for establishing a welding spot:
Procedure for stitch welding:
The "Save" buttons allow up to five EasyJob operating points to be saved. Each operating point corresponds to the settings made on the control panel.
EasyJobs can be stored for each welding process.
IMPORTANT! Setup parameters are not saved at this time.
1Press and hold one of the "Save" buttons to save the current settings on the control panel, e.g.
2Release the "Save" button | ||
1To retrieve saved settings, press the corresponding "Save" button briefly, e.g.
1Press and hold the relevant "Save" button to delete the memory content of that "Save" button, e.g.
2Keep the "Save" button held down
3Release the "Save" button | ||
Press one of the "Save" buttons on the control panel to retrieve the saved settings using the Up/Down welding torch.
The "Save" buttons can now be selected using the buttons on the Up/Down welding torch. Vacant "Save" buttons are skipped.
In addition to the "Save" button number lighting up, a number is displayed directly on the Up/Down welding torch:
Display on the Up/Down welding torch | EasyJob operating point on the control panel |
Danger of injury and damage from electric shock.
When the power switch is switched to position - I -, the tungsten electrode of the welding torch is live.
Ensure that the tungsten electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component - such as wirefeeder or remote control - on the control panel of the power source.
When using a welding torch with a torch trigger and TIG Multi Connector plug (with 2-step mode factory setting):
Pulsed welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:Pulsed welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:The power source controls the "Duty cycle dcY" and "Base current I-G" parameters according to the set pulse current (welding current) and pulse frequency.
Adjustable parameters:
| I-S | Starting current |
| I-E | Final current |
| F-P | Pulse frequency (1/F-P = Time between two pulses) |
| I-P | Pulse current (set welding current) |
Fixed parameters:
| tup | UpSlope |
| tdown | DownSlope |
| dcY | Duty cycle |
| I-G | Base current |
For a parameter description see section Parameters for TIG welding from page (→).
When the power switch is switched to position - I -, the rod electrode in the electrode holder is live.
Ensure that the rod electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
To influence the short-circuiting dynamic at the instant of droplet transfer:
| 0 | = neutral arc |
To obtain the best possible welding result, the HotStart function will sometimes need to be adjusted.
AdvantagesThe setting of the available parameters is described in the section "Setup settings", "Setup menu - level 2".
Key
| Hti | Hot-current time, 0 - 2 s, Factory setting 0.5 s |
| HCU | HotStart current, 100 - 200%, Factory setting 150% |
| IH | Main current = set welding current |
Function
During the specified hot-current time (Hti), the welding current is increased to a certain value. This value (HCU) is higher than the selected welding current (IH).
As the arc becomes shorter, the welding voltage may also fall so that the rod electrode is more likely to stick to the workpiece. This may also cause the rod electrode to burn out.
Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. The welding process can be resumed without problems once the rod electrode has been detached from the workpiece.
The anti-stick (Ast) function can be activated and deactivated in the Setup menu for the setup parameters for MMA welding.
If the Easy Documentation option is available on the power source, the most important welding data for each welding operation can be documented and saved as a CSV file on a USB thumb drive.
A Fronius signature is stored with the welding data, which can be used to check and guarantee the authenticity of the data.
Easy Documentation is activated / deactivated by plugging / unplugging the supplied Fronius USB thumb drive with FAT32 formatting into the back of the power source.
IMPORTANT! To document the welding data, the date and time must be set correctly.
The following data are documented:
Device type
File name
Part number
Serial number
Firmware version of power source
Firmware of PC board DOCMAG (Easy Documentation)
Document version
https://www.easydocu.weldcube.com (A PFDF report of selected welding data can be created under this link)
Nr. | Meter |
Date | Date yyyy-mm-dd |
Time | Time hh:mm:ss |
Duration | Duration in [s] |
I | Welding current * in [A] |
U | Welding voltage * in [V] |
vd | Wire speed * in [m/min] |
wfs | Wire speed * in [ipm] |
IP | Power * from current values in [W] |
IE | Energy from instantaneous values in [kJ] |
I-Mot | Motor current * in [A] |
Synid | Characteristic number |
Job | EasyJob number |
Process | Welding process |
Mode | Operating mode |
Status | PASS: regular welding |
Interval | Weld seam number for "Interval" operating mode |
Signature | Signature for each weld seam number |
* | in each case from the main process phase; |
The welding data are documented as average values in the main process phase and for each welding operation.
By scanning this link...
https://easydocu.weldcube.com |
The power source display shows:
Easy Documentation is activated.
doc | on is also displayed when the power source is switched off and on again with the USB thumb drive connected.
Easy Documentation remains activated.
Setting the date and time is carried out in the 2nd level of the service menu.
The first parameter in the service menu is displayed.
Select the "2nd" setup parameter using the left-hand selection dial
The first parameter in the 2nd level of the service menu is displayed.
Select the "yEA" (= year) setup parameter using the left-hand selection dial
To set the date and time:
Setting ranges:
| yEA | Year (20yy; 0 - 99) |
| Mon | Month (mm; 1 -1 12) |
| dAY | Day (dd; 1 - 31) |
| Hou | Hour (hh; 0 - 24) |
| Min | Minute (mm; 0 - 59) |
If the power source is reset to factory settings via setup parameter FAC, the date and time remain stored.
Risk of data loss or data damage due to premature disconnection of the USB thumb drive
Do not disconnect the USB thumb drive until approx. 10 seconds after the end of the last welding operation to ensure correct data transfer.
Easy Documentation is deactivated.
The Setup menu offers easy access to expert knowledge related to the power source, as well as additional functions. The Setup menu makes it possible to easily adjust the parameters for various tasks.
Accessing the Setup menu is described with reference to the MIG/MAG standard synergic welding process.
Access is the same for the other welding processes.
Press the "Process" button to select the "MIG/MAG standard synergic welding" process
The control panel is now located in the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
Adjusting parameters
Select the desired setup parameter using the left-hand selection dial
Change the setup parameter value using the right-hand selection dial
Exiting the Setup menu
The specifications "min." and "max." are used for setting ranges that vary according to the power source, welding program, etc.
| GPr | Gas pre-flow time Unit: s Setting range: 0 - 9.9 Factory setting: 0.1 |
| GPo | Gas post-flow time Unit: s Setting range: 0 - 9.9 Factory setting: 0.5 |
| SL | Slope (for special 2-step mode and special 4-step mode) Unit: s Setting range: 0 - 9.9 Factory setting: 0.1 |
| I-S | Starting current (for special 2-step mode and special 4-step mode) Unit: % (of welding current) Setting range: 0 - 200 Factory setting: 100 |
| I-E | Final current (for special 2-step mode and special 4-step mode) Unit: % (of welding current) Setting range: 0 - 200 Factory setting: 50 |
| t-S | Starting current duration (only for special 2-step mode) Unit: s Setting range: 0.0 - 9.9 Factory setting: 0.0 |
| t-E | Final current duration (only for special 2-step mode) Unit: s Setting range: 0.0 - 9.9 Factory setting: 0.0 |
| Fdi | Feeder inching speed Unit: m/min (ipm) Setting range: 1 - max (39.37 - max) Factory setting: 10 (393.7) |
| bbc | Burnback effect Burnback effect due to wire retraction at the end of welding When the welding current is switched off, the wire electrode is retracted at 7.5 m/min for the duration of the set bbc value. Unit: s Setting range: 0 - 0.2 Factory setting: 0 |
| Ito | Length of wire that is fed before the safety cut-out trips Unit: mm (in.) Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94) Factory setting: OFF NOTE!The Ito function (length of wire fed until safety cut-out trips) is a safety function. At high wire speeds in particular, the length of wire fed until the safety cut-out trips can deviate from the set wire length. |
| SPt | Spot welding time / interval welding time Unit: s Setting range: 0.3 - 5 Factory setting: 1 |
| SPb | Interval pause time Unit: s Setting range: OFF, 0.3 - 10 (in 0.1 s increments) Factory setting: OFF IMPORTANT! SPb = OFF must be set for spot welding! |
| Int | Interval Displayed only if a value has been set for SPb Unit: Setting range: 2T (2-step), 4T (4-step) Factory setting: 2T (2-step) |
| F | Frequency for SynchroPulse Unit: Hz Setting range: OFF, 0.5 - 5 Factory setting: OFF |
| dFd | Delta wire feed Offset welding power for SynchroPulse option Unit: m/min (ipm) Setting range: 0 - 3 (0 - 118.1) Factory setting: 2 (78.7) |
| AL2 | Arc length correction for upper SynchroPulse operating point Unit: % (of welding power) Setting range: 30 - +30 Factory setting: 0 |
| FAC | Reset power source to factory settings Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset IMPORTANT! If the power source is reset, all the personal settings in the Setup menu are lost. Operating points stored using save buttons remain stored when the power source is reset. The functions in the second level of the setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito). |
| 2nd | Second level of the Setup menu (see "Setup Menu 2nd Level") |
| bbc | Burnback effect Burnback effect due to a delayed switch-off of the welding current after the wire electrode has come to a stop. A ball forms on the wire electrode. Unit: s Setting range: AUt, 0 - 0.3 Factory setting: AUt |
| IGC | Ignition current Unit: A Setting range: 100 - 650 Factory setting: 500 |
| SPt | Spot welding time / interval welding time Unit: s Setting range: 0.3 - 5 Factory setting: 0.3 |
| SPb | Interval pause time Unit: s Setting range: OFF, 0.3 - 10 (in 0.1 s increments) Factory setting: OFF |
IMPORTANT! When resetting the power source using the Factory FAC setup parameter, the hot current time (Hti) and HotStart current (HCU) setup parameters are also reset.
| HCU | HotStart current Unit: % Setting range: 100 - 200 Factory setting: 150 |
| Hti | Hot current time Unit: s Setting range: 0 - 2.0 Factory setting: 0.5 |
| ASt | Anti-stick Unit: - Setting range: On, OFF Factory setting: OFF |
| FAC | Reset power source to factory settings Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset. IMPORTANT! If the power source is reset, all the personal settings are lost. Operating points stored using save buttons are not deleted when the power source is reset - they remain stored. The functions in the second level of the setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito). |
| F-P | Pulse frequency Unit: Hertz Setting range: OFF; 1 - 990 (up to 10 Hz: in 0.1 Hz increments) (up to 100 Hz: in 1 Hz increments) (over 100 Hz: in 10 Hz increments) Factory setting: OFF |
| tUP | UpSlope Unit: seconds Setting range: 0.01 - 9.9 Factory setting: 0.5 |
| tdo | DownSlope Unit: seconds Setting range: 0.01 - 9.9 Factory setting: 1 |
| I-S | Starting current Unit: % of main current Setting range: 1 - 200 Factory setting: 35 |
| I-2 | Lowering current Unit: % of main current Setting range: 1 - 100 Factory setting: 50 |
| I-E | Final current Unit: % of main current Setting range: 1 - 100 Factory setting: 30 |
| GPo | Gas post-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 9.9 |
| tAC | Tacking Unit: seconds Setting range: OFF, 0.1 - 9.9 Factory setting: OFF |
| FAC | Reset power source to factory settings Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings When the power source is reset, the majority of the applied settings are deleted. The following values remain:- when "PrG" appears on the digital display, the power source has been reset.
The following restrictions occur in relation to the Setup menu 2nd level:
Setup menu 2nd level cannot be selected:
If level 2 of the Setup menu is selected, the following functions are not available, even in robot mode:
Accessing the 2nd level of the Setup menu:
The control panel is now located in the 2nd level of the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
A parameter is displayed in the first level of the Setup menu.
| SEt | Country-specific setting (Standard/USA) ... Std/US Unit: - Setting range: Std, US (Standard/USA) Factory setting: Standard version: Std (measurements: cm/mm) USA version: US (measures: in.) |
| Syn | Synergic programs/characteristics Standards EN/AWS Unit: - Setting range: EUr/US Factory setting: Standard version: EUr USA version: US |
| C-C | Cooler mode (only when the cooling unit is connected) Unit: - Setting range: AUt, On, OFF Factory setting: AUt AUt: The cooling unit cuts out after a 2-minute welding off-time. IMPORTANT! If the coolant temperature and flow monitoring option has been installed in the cooling unit, the cooling unit cuts out as soon as the return-flow temperature drops below 50 °C, but at the earliest after a 2-minute welding off-time. On: The cooling unit is always switched on. OFF: The cooling unit is always switched off. IMPORTANT! If the FAC welding parameter is used, the C-C parameter is not reset to the factory setting. If the MMA welding process is selected, the cooling unit is always switched off, even if the switch is in the "On" position. |
| C-t | Cooling time (only when the cooling unit is connected) Time from when flow monitoring is triggered until the "no | H2O" service code is output. For example, if there are air bubbles in the cooling system, the cooling unit will not cut out until the end of this preset time. Unit: s Setting range: 5 - 25 Factory setting: 10 IMPORTANT! Every time the power source is switched on, the cooling unit carries out a test run for 180 seconds. |
| r | Welding circuit resistance (in mOhm) See the section "Measuring the welding circuit resistance r" from page (→). |
| L | Welding circuit inductivity (in microhenrys) See the section "Displaying the welding circuit inductivity L" from page (→). |
| EnE | Electrical energy of the arc in relation to the welding speed Unit: kJ Setting range: On/OFF Factory setting: OFF Since the full range of values (1 kJ - 99999 kJ) cannot be displayed on the three-digit display, the following display format has been selected: Value in kJ / indicator on display: 1 to 999 / 1 to 999 1000 to 9999 / 1.00 to 9.99 (without unit digit, e.g., 5270 kJ -> 5.27) 10000 to 99999 / 10.0 to 99.9 (without unit or tens digit, e.g., 23580 kJ -> 23.6) |
| ALC | Correction of the arc length via the welding voltage Only for MIG/MAG synergic welding Setting range: On/OFF Factory setting: OFF The arc length depends on the welding voltage. The welding voltage can be individually adjusted in synergic operation. If the ALC parameter is set to "OFF", individual adjustment of the welding voltage is not possible. The welding voltage adjusts automatically according to the selected welding current or wire speed. When the arc length correction is adjusted, the voltage changes while the welding current and the wire speed remain constant. When adjusting the arc length correction using the selection wheel, the left display is used for the correction value of the arc length. On the right display, the value for the welding voltage changes at the same time. The left display then shows the original value again, e.g., welding current. |
| Ejt | EasyJob Trigger To activate/deactivate switching between EasyJobs using the torch trigger Unit: - Setting range: On/OFF Factory setting: OFF Function with MIG/MAG torch trigger Press torch trigger briefly (< 0.5 s) No welding taking place:
Welding taking place:
Function with MIG/MAG Up/Down key If an EasyJob is selected, the EasyJob is changed, otherwise the welding current is changed. No welding taking place:
| SEt | Country-specific setting (Standard/USA) ... Hour/US Unit: Setting range: Std, US (Standard/USA) Factory setting: Standard version: Std (dimensions: cm / mm) USA version: US (dimensions: in.) |
| r | r (resistance) - welding circuit resistance (in mOhm) See the section "Measuring the welding circuit resistance r" from page (→). |
| L | L (inductivity) - welding circuit inductivity (in microhenrys) See the section "Displaying the welding circuit inductivity L" from page (→). |
| C-C | Cooling unit control (only with TransSteel 3500c MP and if cooling unit is connected) Unit: Setting range: Aut, On, OFF Factory setting: Aut Aut: the cooling unit cuts out after a 2-minute welding off-time. IMPORTANT! If the coolant temperature and flow monitoring options have been installed in the cooling unit, the cooling unit cuts out as soon as the return-flow temperature drops below 50 °C, but at the earliest after a 2-minute welding off-time. On: The cooling unit is always switched on OFF: The cooling unit is always switched off IMPORTANT! If the FAC welding parameter is used, the C-C parameter is not reset to the factory setting. If the MMA welding process is selected, the cooling unit is always switched off, even if the switch is in the "On" position. |
| C-t | Cooling time (only with TransSteel 3500c MP and if cooling unit is connected) Time from when flow monitoring is triggered until the "no | H2O" service code is output. For example, if there are air bubbles in the cooling system, the cooling unit will not cut out until the end of this preset time. Unit: s Setting range: 5 - 25 Factory setting: 10 IMPORTANT!Every time the power source is switched on, the cooling unit carries out a test run for 180 seconds. |
Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The calculated welding circuit resistance is shown on the display.
r = welding circuit resistance in milliohm (mOhm)
If the welding circuit resistance has been measured correctly, the set welding voltage will correspond exactly to the welding voltage at the arc. If you manually measure the voltage on the output jacks of the power source, this voltage will be higher than the welding voltage at the arc - that is, higher by the same amount as the voltage drop of the hosepack.
The welding circuit resistance depends on the hosepack used:Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The welding circuit resistance depends on the hosepack used:Incorrect measurement of the welding circuit resistance can have a negative effect on the welding result.
Ensure that the workpiece has an optimum contact surface in the area of the earthing clamp (clean surface, no rust, etc.).
Ensure that the workpiece has an optimum contact surface for the contact tip (clean surface, no rust, etc.).
The measurement is finished when the welding circuit resistance is shown on the display in mOhm (for example 11.4).
Ensure that the workpiece has an optimum contact surface for the electrode (clean surface, no rust, etc.).
The way that the hosepack is arranged has a very significant effect on the welding circuit inductivity and therefore affects the welding process. It is important to lay the hosepacks correctly in order to obtain the best possible welding result.
The setup parameter "L" is used to display the most recently calculated welding circuit inductivity. The welding circuit inductivity is adjusted when the welding circuit resistance is measured. Detailed information in this regard can be found under the "Welding circuit resistance" chapter.
The most recently calculated welding circuit inductivity L is shown on the right-hand digital display.
L ... Welding circuit inductivity (in microhenrys)
The devices are equipped with an intelligent safety system, which largely negates the need for melting-type fuses. Melting-type fuses therefore no longer need to be replaced. After a possible malfunction has been remedied, the device is ready for use again.
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
If an error message that is not described here appears on the displays, first try to resolve the problem as follows:
If the error occurs again despite several attempts to eliminate it, or if the troubleshooting measures listed here are unsuccessful.
| Cause: | The cooling unit used is not compatible with the power source |
| Remedy: | Connect compatible cooling unit |
| Cause: | The connected wirefeeder is not supported |
| Remedy: | Connect supported wirefeeder |
| Cause: | Different control panels for selecting materials are in the system |
| Remedy: | Connect similar control panels to select materials |
| Cause: | Impermissible change of welding process during welding |
| Remedy: | During welding do not make any impermissible change to the welding process, reset error message by pressing any button |
| Cause: | More than one robot interface is connected |
| Remedy: | Only one robot interface may be connected, check the system configuration |
| Cause: | More than one remote control is connected |
| Remedy: | Only one remote control may be connected, check the system configuration |
| Cause: | The power source control has detected a primary overvoltage |
| Remedy: | Check the grid voltage. If the service code persists, switch off the power source, wait for 10 seconds and then switch the power source on again. If the error still persists, contact the After-Sales Service team |
| Cause: | The earth current watchdog has triggered the safety cut-out of the power source. |
| Remedy: | Switch off the power source Place the power source on an insulating surface Connect the grounding cable to a section of the workpiece that is closer to the arc Wait for 10 seconds and then switch the power source on again If you have tried this several times and the error keeps recurring, contact the After-Sales Service team |
| Cause: | The power source is being used in single-phase mode |
| Remedy: | - |
| Cause: | The power source is being used in three-phase mode |
| Remedy: | - |
| Cause: | Mains undervoltage: the grid voltage has fallen below the tolerance range |
| Remedy: | Check the grid voltage. If the service code persists, contact the After-Sales Service team |
| Cause: | Mains overvoltage: the grid voltage has risen above the tolerance range |
| Cause: | Incorrect wirefeeder connected |
| Remedy: | Connect correct wirefeeder |
| Cause: | Wirefeeder overtemperature |
| Remedy: | Allow wirefeeder to cool down |
| Cause: | Fault in the wirefeed system (overcurrent in wirefeeder drive) |
| Remedy: | Arrange the hosepack in as straight a line as possible; check that there are no kinks or dirt in the inner liner; check the contact pressure on the 4 roller drive |
| Cause: | Wirefeeder motor is sticking or faulty |
| Remedy: | Check the wirefeeder motor or contact the After-Sales Service team |
| Cause: | Overtemperature in the primary circuit of the power source |
| Remedy: | Allow power source to cool down, check air filter and clean if necessary, check that fan is on |
| Cause: | Overtemperature on the booster located in the power source |
| Cause: | Overtemperature in the secondary circuit of the power source |
| Remedy: | Allow power source to cool down, check that fan is on |
| Cause: | Overtemperature in wirefeeder motor |
| Cause: | Overtemperature in welding torch |
| Remedy: | Allow welding torch to cool down |
| Cause: | Overtemperature in cooling unit |
| Remedy: | Allow cooling unit to cool down, check that fan is on |
| Cause: | Overtemperature on the power source transformer |
| Cause: | Overtemperature in the power source |
| Cause: | Undertemperature in the power source primary circuit |
| Remedy: | Place power source in a heated room and allow it to warm up |
| Cause: | Undertemperature on the booster located in the power source |
| Cause: | Undertemperature in the power source secondary circuit |
| Cause: | Undertemperature in the wirefeeder motor |
| Remedy: | Place wirefeeder in a heated room and allow to warm up |
| Cause: | Undertemperature in the welding torch |
| Remedy: | Place welding torch in a heated room and allow to warm up |
| Cause: | Undertemperature in the cooling unit |
| Remedy: | Place cooling unit in a heated room and allow to warm up |
| Cause: | Undertemperature on the power source transformer |
| Cause: | Undertemperature in power source |
| Cause: | Coolant flow rate too low |
| Remedy: | Check coolant flow rate and cooling unit, including cooling circuit (for minimum coolant flow, see "Technical Data" chapter in the Operating Instructions for the device) |
| Cause: | The coolant temperature is too high |
| Remedy: | Allow cooling unit and cooling circuit to cool down, until "hot | H2O" is no longer displayed. Open the cooling unit and clean the cooler, check fan is working properly. |
| Cause: | No preconfigured program has been selected |
| Remedy: | Select a configured program |
| Cause: | "Ignition time-out" function is active; current did not start flowing before the length of wire specified in the Setup menu had been fed. The power source safety cut-out has tripped |
| Remedy: | Shorten the wire stick-out; press the torch trigger again; clean the surface of the workpiece; if necessary, set the "Ito" parameter in the Setup menu |
| Cause: | The selected welding program is invalid |
| Remedy: | Select a valid welding program |
| Cause: | The required wirefeeder is not available for the selected characteristic |
| Remedy: | Connect the correct wirefeeder, check the plug connections for the hosepack |
| Cause: | Measurement of the welding circuit resistance failed |
| Remedy: | Check grounding cable, current cable, or hosepack and replace if necessary, re-measure the welding circuit resistance |
| Cause: | Date and time are not set on the power source |
| Remedy: | To reset the service code, press the arrow key; Set date and time in the 2nd level of the service menu: see page (→) |
| Cause: | The battery of OPT Easy Documentation is low |
| Remedy: | To reset the service code, press the arrow key; Contact service (to change the battery) |
| Cause: | The battery of the OPT Easy Documentation is empty |
| Remedy: | To reset the service code, press the arrow key - the display shows no | dAt; Contact service (to change the battery); After changing the battery, the date and time in the are displayed in the 2nd level of the service menu: see page (→) |
| Cause: | Error writing data; Internal documentation error; Communication error; |
| Remedy: | Turn power source off and on again |
| Cause: | Invalid file system on USB thumb drive; General USB error |
| Remedy: | Unplug the USB thumb drive |
| Cause: | The plugged in USB thumb drive is full |
| Remedy: | Unplug USB thumb drive, plug in new USB thumb drive |
Under normal operating conditions, the welding system requires only a minimum of care and maintenance. However, several points must be observed in order for the welding system to remain operational for years to come.
Air inlet and outlet openings must not be blocked or even partially covered.
Remove the air filter on the rear of the housing from the side and clean it.
Danger of damage to property.
The air filter must only be fitted when dry.
If required, clean air filter using dry compressed air or by washing it.
Danger due to the effect of compressed air.
Do not bring the air nozzle too close to electronic parts.
Danger of electric shock due to grounding cable and device grounding points not being connected properly.
When refitting the side panels, ensure that the grounding cable and device grounding points are properly connected.
Disposal must only be carried out in accordance with the section of the same name in the "Safety rules" chapter.
Average wire electrode consumption at a wire speed of 5 m/min | |||
| 1.0 mm wire electrode diameter | 1.2 mm wire electrode diameter | 1.6 mm wire electrode diameter |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminum wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminum wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
For devices designed for special voltages, the technical data on the rating plate applies.
The following applies for all devices with a permitted grid voltage of up to 460 V: The standard mains plug allows the user to operate with a grid voltage of up to 400 V. For grid voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
The duty cycle (ED) is the period of a ten minute cycle in which the device may be operated at the stated power without overheating.
The ED values cited on the rating plate relate to an ambient temperature of 40 °C.
If the ambient temperature is higher, the ED or power must be lowered accordingly.
Example: Welding with 150 A at 60% ED
To use the device without interruptions:
Mains voltage (U1) | 3 x 380 / 400 V, 3 x 460 V |
Max. effective primary current (I1eff) |
3 x 380/400 V | 14.0 A |
3 x 460 V | 12.0 A |
Max. primary current (I1max) |
3 x 380/400 V | 19.0 A |
3 x 460 V | 16.0 A |
Mains fuse | 35 A slow-blow |
Mains voltage tolerance | -10 / +15% |
Mains frequency | 50/60 Hz |
Cos phi (1) | 0.99 |
Max. permitted grid impedance Zmax on PCC1) | 92.2 mOhm |
Recommended residual-current circuit breaker | Type B |
Welding current range (I2) |
MIG/MAG | 10 - 300 A |
TIG | 10 - 300 A |
MMA | 10 - 300 A |
Welding current at 10 min / 40 °C | 40% / 300 A |
Output voltage range according to standard characteristic (U2) |
MIG/MAG | 14.5 - 29.0 V |
TIG | 10.4 - 22.0 V |
MMA | 20.4 - 32.0 V |
Open circuit voltage | 59 V |
Apparent power at 400 V AC | 11.8 kVA |
Protection class | IP 23 |
Type of cooling | AF |
Insulation class | B |
Overvoltage category | III |
Pollution degree according to IEC60664 | 3 |
EMC emission class | A2) |
Safety symbols | S, CE, CSA |
Dimensions l x w x h | 747 x 300 x 497 mm |
Weight | 36 kg / 79.4 lb. |
Max. shielding gas pressure | 5 bar/72.52 psi |
Coolant | Original Fronius |
Wire speed | 1 - 25 m/min / 40 - 980 ipm |
Wire drive | 4-roller drive |
Wire diameter | 0.8 - 1.6 mm/0.03 - 0.06 in. |
Wirespool diameter | max. 300 mm / max. 11.81 in. |
Wirespool weight | max. 19.0 kg / max. 41.9 lb. |
Max. noise emission (LWA) | 72 dB (A) |
Idle state power consumption at 400 V | 36.5 W |
Power source efficiency at | 90% |
| 1) | Interface to a 230/400-V and 50-Hz public grid |
| 2) | A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
TransSteel 3000 C PULSE FSC/nc | TransSteel 4000 PULSE/nc | TransSteel 5000 PULSE/nc |
A label with the most common welding programs is affixed to the power source:
The welding programs are active if the "SEt" setup parameter is set to "Std" (Standard)
Welding program database: DB 3992
(1) d = 1.2 mm (2) d = 0.9 mm
The welding programs are active if the "SEt" setup parameter is set to "US" (USA).
Welding program database: UID 3992
