The „Welding start“ signal starts the welding process. The welding process continues until „Welding start“ is reset. Exceptions:
If the Robot interface has been plugged in, the power source will automatically be in 2-step mode.
Robot sets signal once it is ready to start welding. If the robot resets the signal during welding, the power source ends the welding process. The robot control outputs error number 38. "-St oP-" appears on the power source display.
The "Robot ready" signal is reset once the power source is switched on.
If the "Robot ready" signal is not set, the commands or set values listed do not function.
Standard program |
Pulsed arc program |
Job Mode |
Internal parameter selection |
Manual In all other modes, the values for parameters "Wire speed" and "Welding voltage" are calculated using the input signal for the "Welding power" set value. In "Manual" mode, the parameters "Wire speed" and "Welding voltage" are adjusted as follows:
In "Manual" mode, the "Arc length correction (set value)" input signal (0 - 10 V) can take one of the following welding voltage values:
TPS 4000 / 5000... 0 - 10 V corresponds to a welding voltage of 10 - 40 V
TPS 2700... 0- 10 V corresponds to a welding voltage of 10 - 34 V
Control the "Arc-force dynamic" parameter using the input signal "Pulse/dynamic correction"
CC / CV System requirements:
Option for operating the power source with either constant welding voltage or constant welding current. With the "CC / CV" option, there is a limited selection with the "parameter selection" key on the left-hand display (as follows):
Limited selection on the right-hand display with the "parameter selection" key (as follows):
Moreover, the following parameters are no longer available with the "CC/CV" option:
Available input signals: |
The input signals listed below will be available when "CC/CV" mode is selected.
These input signals assume different functions in this mode compared with other modes.
"Welding power set value" input signal |
"Arc length correction" input signal |
"Puls correction" input signal |
"Welding start" input signal |
The input signal "Welding start" only starts the welding current, not the wirefeed or the gas solenoid valve.
"Wire feed" input signal |
"Wire retract" input signal |
Input signal "Robot ready" |
Input signal "Gas test" |
Specifying a set value for the welding current:
If no maximum welding voltage is required, use the "Pulse/dynamic correction" input signal to specify the highest possible welding voltage.
If the welding voltage rises above that specified, maintaining the selected welding current will not be possible.
Specifying a set value for the welding voltage:
If no maximum welding current is required, use the "Welding power (set value)" input signal to specify the highest possible welding current.
If the welding current rises above that specified, maintaining the selected welding voltage will not be possible.
Specifying a set value for the wire speed:
Specifying set values can only be done with the robot, as "Internal parameter selection" is a separate mode.
TIG |
HAP (Hot Active Plasma) |
CMT/Special process |
Neither the welding process nor the currently selected characteristic can be changed during CMT Advanced welding.
To change the welding process or characteristic:
The Master selection twin signal determines which power source will act as master and which as slave.
The "Gas test" signal operates the gas solenoid valve. It corresponds to the gas test button on the power source or wirefeeder control panel. It sets the required gas-flow rate on the pressure regulator.
During welding, controls the power source gas pre- and post-flow.
This command therefore does not need to be carried out on the robot control.
Risk of injury from emerging welding wire!
Keep the welding torch away from your face and body.
The "Wire feed" signal starts the wirefeed and corresponds to the "Feeder inching" button on the power source control panel or wirefeeder. The wire is fed into the hosepack without any accompanying current or gas.
The feeder inching speed is determined by the corresponding setting in the power source setup menu.
The "Wire feed" input signal has priority over the "Wire retract" signal.
If both signals are present at the same time, the wire feed continues.
To facilitate the exact positioning of the wire electrode, the following procedure is executed when the "wire inching" signal is set:
| (1) | Wire inching signal |
If the input signal "Cold wire disable" is also set, then the output signal "Wire speed" applies, rather than "Fdi".
The input signal "Wire inching" starts immediately with the set value for the wire speed. In this case, the figure does not apply.
The "Wire retract" signal causes the wire to be retracted. The wire speed is determined by the corresponding setting in the power source setup menu.
Do not allow long lengths of wire to be retracted, as the wire is not wound onto the wirespool.
To facilitate the exact positioning of the wire electrode, the following procedure is executed when the "Wire retract" signal is set:
If the input signal "Cold wire disable" is also set, then the output signal "Wire speed" applies to the retract speed, rather than "Fdi".
The digital input signal "Wire retract" starts retracting the wire immediately with the analogue set value for the wire speed. In this case, the figure does not apply.
The “Touch sensing“ function is only supported by power sources with serial numbers 2.65.001 and above.
The “Touch sensing“ signal can be used to indicate that the welding wire/gas nozzle has made contact with the workpiece (short-circuit between workpiece and welding wire/gas nozzle).
If the “Touch sensing“ signal is set, the control panel on the power source shows “touch“. There will be a voltage of 30 V on the filler wire/gas nozzle (current limited to 3 A).
The fact that a short-circuit has occurred is transmitted to the robot control via the “arc stable“ signal (see “Output signals“).
Output of the “arc stable“ signal takes about 0.5 s longer than the duration of the short-circuit current.
No welding can take place while the “Touch sensing“ signal is set. To interrupt the welding process for position detection:
If the position is to be detected when the workpiece touches the gas nozzle (instead of the filler wire), connect the gas nozzle to the welding current lead using an RC element (see Fig. „Wire inching“).
The use of an RC element is mandatory so that if the gas nozzle touches the workpiece during welding,
If the gas nozzle makes contact, the short-circuit current flows for approx. 4ms until the RC element capacitors are charged. To ensure contact by the robot control is always detected, the current flow signal lasts 0.5 s longer than the short-circuit current..
| (1) | Welding current lead |
| (2) | Gas nozzle |
If an additional solenoid valve for compressed air is installed in the robot feeder, it can be controlled by the “Torch blow out“ command. The “Torch blow out“ signal is used to clear the gas nozzle of dirt after cleaning the torch.
When a fault occurs, this remains until the robot control sends the "Source error reset" signal to the power source. The reason for the fault must first however be rectified. As the signal level is controlled, it does not react to a rising edge. If the source error reset signal is always HIGH, any error that occurs is reset immediately after it has been rectified.
The "Welding start" signal must not be on the robot, since the power source would start welding again as soon as the fault is rectified.
If a non-programmed characteristic is selected, "no | PrG" appears on the displays. The robot control turns off the "power source ready" signal. To reset, select an occupied program location.
Using this 8-bit signal, the welding operation is carried out with the welding parameters saved under the selected job number. By selecting job number 0, the job can be selected on the control panel.
iWelding does not take place in job mode. If power, arc length correction, pulse correction and burn-back are all specified, the filler metal, gas and wire diameter used are specified via this program number.
To select the program on the power source control panel, select program number 0 on the robot control.
The power source simulates a „real“ welding process using the „Welding simulation“ command. A welding path programmed in the robot control can therefore be simulated without actually welding. All signals are set, just like the real thing (arc stable, process active, main current signal)..However, the following do not occur:
The “SynchroPuls disable“ signal deactivates the SynchroPuls function in the power source if required. The signal can be set before or during welding.
The “SFI disable“ signal deactivates the SFI function in the power source if required. The signal can only be set before welding begins.
In synergic mode, the power, arc length correction, arc-force dynamic/pulse correction and burn-back (command values) must be specified from the robot. If the „Pulse/dynamic correction disable“ signal is set, the internal command value in the power source is used, rather than that in the interface..
If the “Full power range“ signal is set, the welding power is not specified in the same way as in synergic mode, i.e. from vDmin - vDmax (0 - 100%) of the selected characteristic, but uses an absolute value between 0 - 30 m/min (0 - 100%). The maximum wirefeed speed of the connected wirefeeder is not taken into account.
In synergic mode, the robot must specify the command values for power, arc length correction, arc-force dynamic/pulse correction and burn-back. If the “Burn-back disable“ signal is set, the internal power source (not interface) command value is used.
By specifying a value between 0 - 65535 (0-100 %), the welding power is set to the selected characteristic. This setting is only active in program standard and program pulsed-arc modes.
The arc length is corrected by specifying a value between 0 - 65535 (-30 % to +30 %). The arc voltage is then changed, but not the wire speed.
0 | Arc voltage | -30 % | (shorter arc) |
32767 | Arc voltage | 0 % | (shorter arc) |
65535 | Arc voltage | +30 % | (shorter arc) |
This setting is only active when program standard and program pulsed-arc modes are used.
By specifying a value between 0 - 255 (-5 % to +5 %), the arc-force dynamic (standard) or droplet detachment force (pulse) is corrected.
0 | Pulse voltage correction | -5 % |
127 | Pulse voltage correction | 0 % |
255 | Pulse voltage correction | +5 % |
By specifying a value between 0 - 255 (-200 ms to +200 ms), the length of wire left free after welding is corrected. The shorter the burn-off time, the longer the free wire length.
0 | programmed value | -200 ms |
127 | saved value | 0 ms |
255 | programmed value | +200 ms |
This setting is only active when program standard and program pulsed-arc modes are used..
When the signal is set, the power source independently calculates the wire feed speed (power).
The calculation is based on the following values:
The set value of the a-dimension (0-20) is determined from the power signal. If the calculated power is outside of the characteristic range, the “Power out of range“ signal is output.
The “KD disable” signal facilitates the changeover from internal to external control of the cold-wire feed unit:
External or internal control of the cold-wire feed unit affects the following functions:
If option 4,101,039 “I-set TIG interference suppression external box“ is installed on the interface (external box), a cold-wire feeder must not be connected to the LocalNet sockets of the interface.
Instead, a cold-wire feeder must be connected directly to the TIG power source via a passive distributor, to ensure trouble-free operation.
The “AC/DC“ signal is for selecting the corresponding operating mode.
| AC | ...HIGH |
| DC | ...LOW |
The “DC- / DC+“ signal is for selecting the corresponding operating mode.
| DC+ | ...HIGH |
| DC- | ...LOW |
The cap-shaping signal enables automatic cap-shaping when the AC welding process is selected. For optimum results, this function takes account of the pre-set electrode diameter. The automatic cap-shaping function ensures that the optimum cap is formed during welding start-up.
No further cap-shaping is needed at the next welding start-up.
After the cap-shaping function has been performed once, it is deactivated for every subsequent welding start-up.
The “Pulse disable“ signal deactivates the pulse function in the power source if required.
The “Pulse range selection bit 0, bit 1, bit 2“ signal is for setting the pulse frequency range.
By specifying a value between 0 - 65535 (0-100 %), the main current is set to the selected characteristic.
The “External parameter (set value)“ signal allows a freely definable parameter to be activated.
The power source operating instructions contain a much more detailed description of the external parameter, as well as the functions it can perform.
By specifying a value between 0 - 255 (0 % to 100 %), the welding current is reduced to the base current in TIG pulse mode.
0 |
| 0 % |
127 |
| 50 % |
255 |
| 100 % |
Alters the ratio of pulse duration to base current duration when the pulse frequency has been selected. Value range 0 - 255 (10 % to 100 %).
0 |
| 0 % |
127 |
| 40 % |
255 |
| 100 % |
The “Duty cycle disable“ signal deactivates the “Duty cycle (set value)“ function in the power source if required.
The “Base current disable“ signal deactivates the “Base current (set value)“ function in the power source if required.
The signal is for controlling the wirefeed speed when using a cold-wire feed unit.
This signal activates the high frequency ignition. The HF pulses depend on the value set in the power source. (Setting range: 0.01 s - 0.4 s).
If there are problems with sensitive equipment in the immediate vicinity, increase the HFt parameter to a maximum of 0.
4 s. Further details on setting the HFt parameter can be found in the power source operating instructions.
By specifying a value between 0 - 255 (0% to 100%), the process current is reduced to the base current in HAP pulse mode.
0 |
| 0% |
127 |
| 50% |
255 |
| 100% |
0 |
| 0 % |
127 |
| 40 % |
255 |
| 100 % |
This signal is set if the arc is stable after welding has started. The signal informs the robot control that ignition was successful and the arc is present.
This signal is only available when connected to the RCU5000i remote control unit. The signal is set if there is a limit exceed of actual wirefeed speed value, motor current, welding current and welding voltage.
Robot sets the “Welding start“ signal:
Informs the robot that welding is still in progress. So, for example, to ensure optimum gas shielding, the length of time the robot remains in position can be synchronised at the end of the weld seam.
This signal shows the main current phase.
For the most part, the robot torch is fitted with a collision cut-off box attached to the front of the holder on the robot arm. As soon as the robot arm meets a solid obstacle (component, clamping device, etc.), contact with the collision cut-off box is interrupted and signalled to the system. The control must stop the robot immediately.
If the power source is ready to weld, this output is switched to HIGH. The signal goes out and error number 38 is output if:
The exact cause of the error is transmitted to the field bus by means of an error number.
As a rule, the field bus node is supplied externally, e.g. via the robot control. The “Communication ready“ signal informs the robot control that the power source is ready for data communication.
When an error occurs (“power source ready“ signal not illuminated), the error number can help to isolate the cause of the error.
If welding is not finished properly, the wire can be welded to the workpiece. The power source detects the stuck wire and extinguishes the “Robot ready“ signal. Welding continues once the welded wire is released.
The “Robot access“ signal shows whether internal or external parameter setting is selected.
“Robot access“ is only available when connected to the RCU5000i remote control unit.
If no welding wire is detected by the wire-end sensor, the “wire available“ signal is shown as low.
“Welding wire available“ has no significance unless connected to a wire-end sensor.
If no wire-end sensor is installed, the “welding wire available“ signal is shown as high.
This signal shows that the short circuit time has been exceeded (greater than 78 ms).
This signal shows that data documentation is operational via RCU receiver.
The “Pulse high“ signal is for pulse synchronisation (robot)
During welding, transmits the welding voltage measured (between 0 - 100 V). The value on the field bus is between 0 - 65535. In idle, the HOLD value becomes the welding voltage command value immediately after welding.
During welding, transmits the welding current measured (between 0 - 1000 A). The value on the field bus is between 0 - 65535. In idle, the HOLD value becomes the welding current command value immediately after welding.
During welding, transmits the motor current measured (between 0-5 A). The value on the field bus is between 0 - 255.
This specially filtered welding voltage signal is the real value for AVC control (0 - 50 V).
During the welding process, the actual wirefeed speed value measured (0 - vDmax) is transmitted. The value on the field bus is between 0 - 255. In idle the wire command value is transmitted.
The “Power outside range“ signal is set if the “Full power range“ signal is set and the wirefeed speed command value on the selected characteristic lies above or below the possible wirefeed speed.
| (1) | Power out of range |
| (2) | Synergic mode 0 - 100 % |
| (3) | Full power range 0 - 100 % |
* vDmin and vDmax depend on which wirefeeder is connected
After an error has occurred („power source ready“ signal goes out), the error number (A09 - A16) helps isolate the cause of the error. The following errors may be transmitted:
Error no. | Front display | Error description |
0 |
| No error – power source ready |
1 | no | Prg | No pre-programmed program has been selected |
2 | ts1 | xxx | Over-temperature in secondary circuit of the machine |
3 | ts2 | xxx | Over-temperature in secondary circuit of the machine |
4 | ts3 | xxx | Over-temperature in secondary circuit of the machine |
5 | tp1 | xxx | Over-temperature in primary circuit of the machine |
6 | tp2 | xxx | Over-temperature in primary circuit of the machine |
7 | tp3 | xxx | Over-temperature in primary circuit of the machine |
8 | tp4 | xxx | Over-temperature in primary circuit of the machine |
9 | tp5 | xxx | Over-temperature in primary circuit of the machine |
10 | tp6 | xxx | Over-temperature in primary circuit of the machine |
11 | Err | tf1 | Temperature sensor fault (short circuit or open circuit) |
12 | Err | tf2 | Temperature sensor fault (short circuit or open circuit) |
13 | Err | tf3 | Temperature sensor fault (short circuit or open circuit) |
14 | Err | tf4 | Temperature sensor fault (short circuit or open circuit) |
15 | Err | tf5 | Temperature sensor fault (short circuit or open circuit) |
16 | Err | tf6 | Temperature sensor fault (short circuit or open circuit) |
17 | DSP | E05 | DSP error - Contact After-Sales Service. |
18 | Err | bPS | DSP error - Contact After-Sales Service. |
19 | Err | IP | DSP error - Contact After-Sales Service. |
20 | Err | AXX | DSP error - Contact After-Sales Service. |
21 | Err | EXX | DSP error - Contact After-Sales Service. |
22 | Err | EPF | HOST error - Contact After-Sales Service. |
23 | Err | 23.X | HOST error - Contact After-Sales Service. |
24 | Err | 24.X | HOST error - Contact After-Sales Service. |
25 | Err | 25.X | HOST error - Contact After-Sales Service. |
26 | Err | 26.X | HOST error - Contact After-Sales Service. |
27 | Err | 027 | HOST error - Contact After-Sales Service. |
29 | DSP | CXX | DSP error - Contact After-Sales Service. |
30 | Efd | XX.Y | Fault in wirefeeding system (XX and Y -> error list SR40) |
31 | Err | 31.X | HOST error - Contact After-Sales Service. |
32 | Ecf | XXX | HOST error - Contact After-Sales Service. |
33 | tst | XXX | Over-temperature in the control circuit |
34 | Err| tt7 | Temperature sensor fault (short circuit or open circuit) |
35 | DSP | Sy | DSP error - Contact After-Sales Service. |
36 | DSP | nSy | DSP error - Contact After-Sales Service. |
37 | US | POL | HOST error - Contact After-Sales Service. |
38 | -St | op- | Robot not ready |
39 | No | H20 | Flow watchdog - Check cooling unit |
40 | Err | Lic | The licence key is faulty |
49 | Err | 049 | Intermediate circuit-balance error |
50 | Err | 050 | Phase failure |
51 | Err | 051 | Mains undervoltage: mains voltage has fallen below lower limit of tolerance range (+/- 15 %) |
52 | Err | 052 | Mains overvoltage: mains voltage has exceeded upper limit of tolerance range (+/- 10 %) |
53 | Err | PE | Ground (earth) fault |
54 | Err | 054 | Wire stick control |
55 | No | IGn | “Ignition time-out” fault: no ignition occurred within set wire length |
56 | Err | 056 | “Wire end” fault: no more wire available (only if wire sensor available) |
57 | No | GAS | “Gas flow” fault: no gas flowed out within one second after gas pre-flow time began |
58 | No | Arc | “Arc-break monitor” fault: After the arc breaks, no new arc appears within the timespan set for the “Arc” parameter (Set- up menu 2nd) |
59 | Err | 059 | Secondary overvoltage: safety cut-out has tripped |
60 | Err | 060 | DPS500 only: SITRE1A has activated the safety cut-out Close the plasma reactor door (closes external contact). |
61 | Err | Arc | DPS500 only: Digital signal processor (DSP) detected several unwanted arcs in quick succession |
62 | Err | 062 | TP08 overtemperature |
63 | EIF | xxx | Interface fault |
64 | Err | tf8 | Faulty cooling unit temperature sensor - Contact After-Sales Service |
65 | hot | H2O | Overtemperature in cooling system - Wait until the end of the cooling phase |
66 | tJo | XXX | JobMaster overtemperature (xxx stands for the temperature indicator) |
67 | Err | tJo | Jobmaster temperature sensor faulty - Contact After-Sales Service |
68 | Err | 068 | Secondary safety cut-out - Contact After-Sales Service |
69 | Err | 069 | Illegal mode change during welding |
70 | Err | 70.x | Gas error - x stands for |
71 | Err | 71.X | Limit error, X stands for: |
72 | Err | Cfg | Configuration change (total current or Twin) |
73 | noH |ost | Host computer not found |
74 | Touch | Internal dummy for the Touchsensing display on the RCU I5000 |
75 | Err | 75.x | MMArc error (BIAS200 only), X stands for: |
77 | Err | 77.x | Motor overcurrent, X stands for: |
78 | E-Stop | Emergency stop - Contact After-Sales Service |
79 | Err | U0.x | VRD error Limitation of open-circuit voltage |
80 | Err | 080 | Wirefeeder error. Device has become unplugged during welding |
81 | tP7 | hot | Overtemperature in the transformer |
82 | Err | EHF | Overtemperature in external HF |
83 | PHA | SE | The number of phases has changed |
84 | No | Gas | Problem with gas supply |
86 | Err | db | No CMTL licence |
100 | Und | Opc | HOST error - Contact After-Sales Service |
101 | Prt | FIt | HOST error - Contact After-Sales Service |
102 | III | Opa | HOST error - Contact After-Sales Service |
103 | III | Ina | HOST error - Contact After-Sales Service |
104 | III | Bus | HOST error - Contact After-Sales Service |
105 | Err | 105 | HOST error - Contact After-Sales Service |
106 | STK | OVL | HOST error - Contact After-Sales Service |
107 | STK | UVL | HOST error - Contact After-Sales Service |
108 | Err | Dog | HOST error - Contact After-Sales Service |
109 | ASS | Ert | HOST error - Contact After-Sales Service |
110 | Edg | 1 | HOST error - Contact After-Sales Service |
150 | Nothing | Power source switched off or no mains voltage |
63 | EIF | 1.1 | No software configuration - Contact After-Sales Service |
63 | EIF | 1.2 | Wrong bus module - Contact After-Sales Service |
63 | EIF | 1.3 | Bus module not initialised - Contact After-Sales Service |
63 | EIF | 2.1 | Installation set ROB I/O not connected - Contact After-Sales Service |
63 | EIF | 3.1 | Invalid interbus cycles occurred |
63 | EIF | 4.x | Error in CFM, x stands for |
63 | EIF | 5.x | Error in EEprom 2464, x stands for |
63 | EIF | 6.x | Error in Anybus-S module x stands for |
63 | EIF | 7.x | Ethernet communication error, x stands for |
63 | EIF | 8.x | CFM error, x stands for |
63 | EIF | 9.1 | Phase error (only in conjunction with the software configuration group interface), check the phases |
63 | EIF | 10.1 | ProfiNet connection is interrupted (only in conjunction with Daimler Integra software configuration) |
63 | EIF | 11.1 | Double selection process, (only in conjunction with the software configuration group interface) |
Code | Filler metal | WireDiameter | Gas |
1 | G3Si1 | 0,8 | C1 100 % CO2 |
2 | G3Si1 | 1 | C1 100 % CO2 |
3 | G3Si1 | 1,2 | C1 100 % CO2 |
4 | G3Si1 | 1,6 | C1 100 % CO2 |
5 | G3Si1 | SP | M21 Ar+18%CO2 |
6 | G3Si1 | 0,8 | M21 Ar+18%CO2 |
7 | G3Si1 | 1 | M21 Ar+18%CO2 |
8 | G3Si1 | 1,2 | M21 Ar+18%CO2 |
9 | G3Si1 | 1,6 | M21 Ar+18%CO2 |
10 | G3Si1 | SP | M21 Ar+18%CO2 |
11 | Hardfacing | 0,8 | M21 Ar+18%CO2 |
12 | Hardfacing | 1 | M21 Ar+18%CO2 |
13 | Hardfacing | 1,2 | M21 Ar+18%CO2 |
14 | Hardfacing | 1,6 | M21 Ar+18%CO2 |
15 | Hardfacing | SP | M21 Ar+18%CO2 |
16 | AlSi5 | 0,8 | I1 100% Ar |
17 | AlSi5 | 1 | I1 100% Ar |
18 | AlSi5 | 1,2 | I1 100% Ar |
19 | AlSi5 | 1,6 | I1 100% Ar |
20 | AlSi5 |
| I1 100% Ar |
21 | AlMg5 | 0,8 | I1 100% Ar |
22 | AlMg5 | 1 | I1 100% Ar |
23 | AlMg5 | 1,2 | I1 100% Ar |
24 | AlMg5 | 1,6 | I1 100% Ar |
25 | AlMg5 | SP | I1 100% Ar |
26 | Al99.5 | 0,8 | I1 100% Ar |
27 | Al99.5 | 1 | I1 100% Ar |
28 | Al99.5 | 1,2 | I1 100% Ar |
29 | Al99.5 | 1,6 | I1 100% Ar |
30 | Al99.5 | SP | I1 100% Ar |
31 | CuAl8 | 0,8 | I1 100% Ar |
32 | CuAl8 | 1 | I1 100% Ar |
33 | CuAl8 | 1,2 | I1 100% Ar |
34 | CuAl8 | 1,6 | I1 100% Ar |
35 | CuSi3 | SP | I1 100% Ar |
36 | CuSi3 | 0,8 | I1 100% Ar |
37 | CuSi3 | 1 | I1 100% Ar |
38 | CuSi3 | 1,2 | I1 100% Ar |
39 | CuSi3 | 1,6 | I1 100% Ar |
40 | CuSi3 | SP | I1 100% Ar |
41 | CrNi 19 9 | 0,8 | M12 Ar+2.5%CO |
42 | CrNi 19 9 | 1 | M12 Ar+2.5%CO |
43 | CrNi 19 9 | 1,2 | M12 Ar+2.5%CO |
44 | CrNi 19 9 | 1,6 | M12 Ar+2.5%CO |
45 | CrNi 19 9 | SP | M12 Ar+2.5%CO |
46 | CrNi 18 8 6 | 0,8 | M12 Ar+2.5%CO |
47 | CrNi 18 8 6 | 1 | M12 Ar+2.5%CO |
48 | CrNi 18 8 6 | 1,2 | M12 Ar+2.5%CO |
49 | CrNi 18 8 6 | 1,6 | M12 Ar+2.5%CO |
50 | CrNi 18 8 6 | SP | M12 Ar+2.5%CO |
51 | FCW rutile | 0,8 | M12 Ar+18%CO |
52 | FCW rutile | 1 | M12 Ar+18%CO |
53 | FCW rutile | 1,2 | M12 Ar+18%CO |
54 | FCW rutile | 1,6 | M12 Ar+18%CO |
55 | FCW rutile | SP | M12 Ar+18%CO |
56 | FCW basic | 0,8 | M12 Ar+2.5%CO |
57 | FCW basic | 1 | M12 Ar+18%CO |
58 | FCW basic | 1,2 | M12 Ar+18%CO |
59 | FCW basic | 1,6 | M12 Ar+18%CO |
60 | FCW basic | SP | M12 Ar+18%CO |
61 | FCW metall | 0,8 | M12 Ar+2.5%CO |
62 | FCW metall | 1 | M12 Ar+18%CO |
63 | FCW metall | 1,2 | M12 Ar+18%CO |
64 | FCW metall | 1,6 | M12 Ar+18%CO |
65 | FCW metall | SP | M12 Ar+18%CO |
66 | FCW-CrNi | 0,8 | M12 Ar+2.5%CO |
67 | FCW-CrNi | 1 | M12 Ar+18%CO |
68 | FCW-CrNi | 1,2 | M12 Ar+18%CO |
69 | FCW-CrNi | 1,6 | M12 Ar+18%CO |
70 | FCW-CrNi | SP | M12 Ar+18%CO |
71 | SP1 | 0,8 |
72 | SP1 | 1 |
73 | SP1 | 1,2 |
74 | SP1 | 1,6 |
75 | SP1 | SP |
76 | SP2 | 0,8 |
77 | SP2 | 1 |
78 | SP2 | 1,2 |
79 | SP2 | 1,6 |
80 | SP2 | SP |
20 | AlSi5 |
| I1 100% Ar |
71 | SP1 | 0,8 |
72 | SP1 | 1 |
73 | SP1 | 1,2 |
74 | SP1 | 1,6 |
75 | SP1 | SP |
76 | SP2 | 0,8 |
77 | SP2 | 1 |
78 | SP2 | 1,2 |
79 | SP2 | 1,6 |
80 | SP2 | SP |
| Mode bit 0-2 |
| Program standard / |
| pulsed-arc |
| Welding power (command value) |
| (Welding power) |
| Arc length correction (command value) |
| (Arc length correction) |
| Pulse correction (command value) |
| (Pulse correction) |
| Burn back time |
| (Burn back time) |
| Robot ready |
| (Robot ready) |
| Source error reset |
| (Source error reset) |
| Program number |
| (Program bit 0-6) |
| NOTE! Further information is available in the „Fronius-recommended procedures“ sub-section | |||||||
Welding start |
(Welding start) |
Process active signal |
(Process active signal) |
Arc stable |
(Arc stable) |
Main current signal |
(Main current signal) |
Power source ready |
(Power source ready) |
| Error number |
(Error number) |
| (1) | (2) | (3) | (4) | (5) |
| (1) | Gas pre-flow time |
| (2) | Starting currrent |
| (3) | Welding current |
| (4) | End current |
| (5) | Gas post-flow time |
| Mode bit 0-2 |
| pulsed-arc |
| (Welding power) |
| Burn back time |
| (Burn back time) |
| Robot ready |
| (Robot ready) |
| Program number |
| (Program bit 0-6) |
Welding start |
(Welding start) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 0-2 |
| (Job mode) |
| Job number |
| (Job / Program bit 0-7) |
Welding start |
(Welding start) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| (2) | Starting current |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 0-2 |
| (Job mode) |
| Job number |
Welding start |
(Welding start) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| (4) | End current |
| Mode bit 0-2 |
| pulsed-arc |
| (Welding power) |
| Arc length correction |
| Burn back time |
| (Burn back time) |
| Robot ready |
| (Robot ready) |
| Program number |
| (Program bit 0-6) |
| NOTE! Further information is available in the „Fronius-recommended procedures“ sub-section | ||||||||||||
Welding start |
(Welding start) |
Error (e.g. „no arc“) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 5 |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Mode bit 0-2 |
| pulsed-arc |
| (Welding power) |
| Burn back time |
| (Burn back time) |
| Robot ready |
| (Robot ready) |
| Program number |
| (Program bit 0-6) |
Welding start |
(Welding start) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 5 |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 0-2 |
| (Job mode) |
| Job number |
Welding start |
(Welding start) |
(Process active) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 5 |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 0-2 |
| (Job mode) |
| Job number |
Welding start |
(Welding start) |
(Process active) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 5 |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 1 |
| Job number |
| (Job mode) |
| NOTE! Further information is available in the „Fronius-recommended procedures“ sub-section | |||||||||||||
Welding start |
(Welding start) |
Error Limit, Warning |
(Warning) |
(Process active) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 1 |
| Job number |
| (Job mode) |
Welding start |
(Welding start) |
(Warning) |
(Process active) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 1 |
| (Job mode) |
| Job number |
Welding start |
(Welding start) |
Process active |
(Process active) |
Error Limit, Switch-off |
(Stop) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 5 |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
| Robot ready |
| (Robot ready) |
| Mode bit 1 |
| (Job mode) |
| Job number |
Welding start |
(Welding start) |
Process active |
(Process active) |
(Stop) |
Arc stable |
(Arc stable) |
| Error number |
(Error number) |
| 1 | 2 | 3 | 5 |
| 1 | 2 | 3 | 4 | 5 |
| (4) | End current |
Simultaneously selecting the “Job number“ signal or “Program number“ signal and the “Welding start“ signal can affect the ignition and the welding data documentation.
To select a job or program without changing the characteristics, Fronius recommends a time gap of at least 0.1 s between the “Job number“ or “Program number“ signal (1) and the “Welding start“ signal (2).
To select a job or program with a change to the characteristics or operating mode as well, Fronius recommends a time gap of at least 0.3 - 0.8 s between the „Job number“ or „Program number“ signal (1) and the „Welding start“ signal (2).
The time gap between the “Job number“ or “Program number“ signal and the “Welding start“ signal can be set using the gas pre-flow time:
Do not use the “Gas purge_time“ parameter to set the time gap.
