Danger from incorrect connection to the power source.
This can result in damage to the PC.
Connect the power source to the PC using the LocalNet RS 232 interface and the cables provided only.
The LocalNet RS 232 interface can only be used in conjunction with LocalNet application software and system components (power source, wire-feed unit, etc.) with LocalNet connection sockets. To ensure correct operation, the LocalNet application software must already be running on the computer.
| (1) | LocalNet RS 232 interface |
| (2) | LocalNet interface cable |
| (3) | RS 232 interface cable |
| (4) | Software tools CD |
Each display represents a transmit line (TxD) and a receive line (RxD). A flashing display indicates that data is being transferred along the respective lines.
x ... Display flashes
RS 232 | LocalNet | Status | ||
TxD | RxD | TxD | RxD |
x | x | x | x | Communication is ok |
x | - | x | x | PC does not respond; start the LocalNet application software on the PC |
- | - | - | x | Interface error; connect to PC and check system components. Replace interface if necessary. |
- | x | x | - | PC is sending data - system component does not respond; system component possibly faulty |
- | - | - | - | No display flashing; check connection to PC and system component. Replace interface if necessary |
| (1) | Connect the RS 232 interface cable and LocalNet interface cable to the LocalNet RS 232 interface according to the labelling. |
| (2) | Connect the RS 232 interface cable to the free interface (e.g. COM1) that has already been defined on the PC |
| (3) | Connect the LocalNet interface cable to the LocalNet connection socket on the system component (e.g. power source) |
A software update for the following Fronius system components can be performed using the LocalNet RS 232 interface:
The following requirements must be satisfied in order to perform software updates using the LocalNet RS 232 interface:
IMPORTANT! If software with a compatible version number has already been installed, then only the configurations need to to checked.
After switching on the system components, ensure that the relevant system component is not activated.
IMPORTANT! The latest firmware is available from the DownloadCenter (https://www.fronius.com/de/schweisstechnik/downloads)
| Cause: | An old version of „BasicLoad“ is installed on the PC |
| Remedy: | Install a newer version of „BasicLoad“ on the PC, repeat the update |
| Cause: | The components are not connected correctly |
| Remedy: | Ensure that all components are properly connected to each other |
| Cause: | BasicLoad settings are not set to LocalNet |
| Remedy: | Set the BasicLoad settings to LocalNet |
