All the work and functions described in this document must only be carried out by trained and qualified personnel.
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
The robot interfaces ROB 4000/5000 and ROB 5000 OC, hereafter referred to as robot interfaces, are designed for automatic welders and have analog and digital inputs and outputs. The robot interfaces are to be installed in an automatic welder and robot control cubicle (can also be surface-mounted).
Advantages
The robot interface is connected using a 10-pin cable (43,0004,0459 / 0460 / 0509: 10-pin remote control cable 5/10/20 m) to a 10-pin LocalNet interface on the digital power source. If no LocalNet interface ports are available, the LocalNet passive distributor (4,100,261) can be used (e.g. between the power source and interconnecting hosepack).
The LocalNet passive distributor cannot be used with a JobMaster TIG welding torch.
A 1 m long LocalNet cable harness, including a 10-pin socket, is supplied with the robot interface. The 10-pin socket is used as a bushing through the side of the control cubicle. The „ROB 5000 LocalNet installation set“ option (4,100,270: 10-pin connection socket with cable harness for the robot interface) is available if an additional LocalNet node (e.g. remote control) needs to be connected to the robot control.
A made-up, 1.5m long cable harness is available for connecting the robot control to the robot interface (4,100,260: cable harness ROB 5000; 4,100,274: cable harness ROB 4000).
The cable harness on the interface side is terminated with Molex plugs and is already made-up. The cable harness on the control side can be modified to match the termination system used on the robot control. The comprehensive labelling of the cable harness, with each identifier printed at several locations along the cable, simplifies the connection procedure.
To prevent faults, the length of the cable between the robot interface and the control must not exceed 1.5 m.
ROB 4000 (4,100,239)
Additional functions ROB 5000 (4,100,255), ROB 5000 OC (4,100,474)
| (1) | Power source |
| (2) | Cooling unit |
| (3) | Robot interface |
| (4) | Robot control |
| (5) | Robot control cubicle |
| (6) | Robot |
| (7) | Motor |
| (8) | Welding torch |
| (9) | Interconnecting hosepack |
| (10) | LocalNet cable |
| (11) | LocalNet cable |
| (12) | Wirespool |
While the robot interface is connected to the LocalNet, “2-step mode” remains selected
More information about operating modes can be found in the power source operating instructions.
On the OPEN COLLECTOR ROB 5000 OC robot interface, all digital input signals are inverted (inverse logic).
Wiring of the digital input signals:
Signal level:
Ground: GND = X7/2 or X12/2
| ROB 4000/5000 | ROB 5000 OC |
Signal X2:4 | HIGH | LOW |
The “Welding start” signal starts the welding process. The welding process continues until “Welding start” is reset.
Exception:
Signal X2:5 | HIGH | LOW |
„Robot ready“ is
„Quick stop“ is
The “Quick stop” signal stops the welding process immediately
The “Quick stop” signal is intended to be used solely as a way of protecting the machine by shutting it down immediately. If additional personal protection is required, a suitable Emergency Stop button should be provided.
„Quick stop“ ends the welding process without burn-back.
“Quick stop” is active as soon as the power source is switched on
Prepare the power source for welding:
Commands and command values are not accepted when “Quick stop” is active.
TIG mode is permanently selected on the ROB 4000 robot interface.
| ROB 4000/5000 |
| ROB 5000 OC | ||||
| MODE |
| MODE | ||||
| „0“ | „1“ | „2“ |
| „0“ | „1“ | „2“ |
Job mode | 0 | 1 | 0 |
| 1 | 0 | 1 |
Parameter selection internal | 1 | 1 | 0 |
| 0 | 0 | 1 |
CC / CV | 1 | 0 | 1 |
| 0 | 1 | 0 |
TIG | 0 | 1 | 1 |
| 1 | 0 | 0 |
Signal level when BIT 0 - BIT 2 are set
| ROB 4000/5000 |
| ROB 5000 OC | ||||
Signal X2:6 (BIT 0) | HIGH |
| LOW | |||
| ROB 5000 |
| ROB 5000 OC | ||||
Signal X8:1 (BIT 1) | HIGH |
| LOW | |||
Signal X8:2 (BIT 2) | HIGH |
| LOW | |||
The following operating modes are supported:
Job mode (ROB 5000/ROB 5000 OC)
Call up saved welding parameters using the corresponding job number.
Internal parameter selection (ROB 5000/ROB 5000 OC)
Selecting welding parameters via the robot control programming interface is timeconsuming, especially when programming a job. The “Internal parameter selection” mode enables the required welding parameters to be selected from the power source control panel or via a remote control unit.
Internal parameter selection can also take place while welding is in progress. The signals required for the current welding operation continue to be sent from the robot control.
CC/CV (constant current/constant voltage; ROB 5000/ROB 5000 OC
„CC/CV“ (constant current/constant voltage) mode is available as an option for the ROB 5000/ROB 5000 OC robot interface or the robot control field bus coupler.
The power source can be operated with either a constant welding current or a constant welding voltage.
Restrictions compared to other operating modes:
The following parameters can be selected for the left-hand display using the “Parameter selection” key:
Available input signals:
The input signals listed below will be present when “CC/CV” mode is selected. These input signals assume different functions in this mode compared with other modes.
The input signals and their functions:
The “Welding start” input signal only starts the welding current; the wirefeed is not started.
Signal level for analog input signals:
Even if CC/CV mode is selected, the signal level for the analog input signals is 0 to 10 V.
0 V ....... e.g. minimum welding current
10 V ......e.g. maximum welding current
Specifying a command value for the welding current:
Specifying a command value for the welding voltage:
TIG
TIG welding is selected. The required welding current is obtained from the analog „Welding current“ input signal.
Signal X2:7 | HIGH | LOW |
The “Gas test” signal starts the “Gas test” function (as does the “Gas test” key). The required gas flow can be set on the pressure regulator on the gas cylinder.
The gas test can be used to create an additional gas pre-flow during positioning.
IMPORTANT! If welding is in progress, the gas pre-flow and post-flow times are controlled by the power source. It is therefore not necessary to set the “Gas test” signal when welding!
Risk of injury from filler wire emerging.
keep welding torch away from face and body
The „Wire inching“ signal enables the filler wire to be fed into the hosepack without the use of current or gas (as does the „Feeder inching“ key).
The feeder inching speed is determined by the corresponding setting in the power source setup menu.
The „wire feed“ input signal has priority over the „wire retract“ signal. If both signals are present at the same time, the wire feed continues.
IMPORTANT! To facilitate the exact positioning of the filler wire, the following procedure is executed when the „wire inching“ signal is set:
| (1) | Wire inching signal |
IMPORTANT! If the digital input signal „Cold wire disable“ is also set, then the analog output signal „wire speed“ applies, rather than „Fdi“. The digital input signal „wire inching“ starts immediately with the analog command value for the wire speed. In this case, the figure does not apply.
Signal X14:6 | HIGH | LOW |
The “Wire retract” signal causes the wire to be retracted. The wire speed is determined by the corresponding setting in the power source setup menu.
Do not allow long lengths of wire to be retracted, as the wire is not wound onto the wirespool.
IMPORTANT! To facilitate the exact positioning of the filler wire, the following procedure is executed when the „wire retract“ signal is set
| (1) | Wire retract signal |
IMPORTANT! If the digital input signal „Cold wire disable“ is also set, then the analog output signal „wire speed“ applies to the retract speed, rather than „Fdi“. The digital input signal „wire retract“ starts retracting the wire immediately with the analog command value for the wire speed. In this case, Fig. 3 does not apply.
Signal X8:5 | HIGH | LOW |
To reset an error, the “Source error reset” signal must be on for at least 10 ms.
Any error messages (“Source error”) that appear on the power source are reset using the “Source error reset” signal. However, the cause of the error must first be eliminated.
If the robot control has no digital signal for resetting, always set the “Source error reset“ signal to
The error is then reset immediately after the cause has been rectified.
Any Service Codes that are output will not be displayed while the “Source error reset” signal is set.
Example: if there is not enough coolant, the “No | H2O” Service code will not be displayed if the signal is set. This can result in damage to the water-cooled welding torch.
Remedies: Only use the “Source error reset” signal as a short pulse to reset the error.
Danger from surprisingly starting welding process.
If the “Source error reset” signal is still
24 V ROB 4000/5000 (High)
GND ROB 5000 OC (Low),
the „Welding start“ signal must not be set while the error is being rectified, otherwise welding will start as soon as the error is fixed.
Signal X8:6 | HIGH | LOW |
The „Job/program select“ signal allows the „Program number“ signals to be used in different ways (Job/program bit 0 -7, see next page)
In job mode, if „Job/Program Select“ is
the required job is digitally selected by means of „Job/Program bit 0 - 7“. Select Job mode using mode bit 0-2.
IMPORTANT! In job mode (mode bit 0-2), if „Job/Program Select“ is
there is also the analog job selection option. Refer to the paragraphs on „Analog job selection“ for more information.
In the case of internal parameter selection or TIG, „Job/program bit 0 -7“ is used to select the process (see the following section „Program number“). Select internal parameter selection or TIG with mode bit 0-2.
The allocations are identical to those in the “Job number” function (see next section). The choice between the „program number“ and „job number“ functions is made using mode bits 0 -2.
Pin X11/1 | Job / program bit 0 | Process | |
ROB 5000 | ROB 5000 OC |
| 0 V | 24 V | DC |
| 24 V | 0 V | AC |
Pin X11/2 | Job / program bit 1 | Process | |
| 0 V | 24 V | DC - |
| 24 V | 0 V | AC + |
Pin X11/3 | Job / program bit 2 | Process | |
| 0 V | 24 V | No cap-shaping |
| 24 V | 0 V | Cap-shaping activated |
Pin X11/4 | Job / program bit 3 | Process | |
| 0 V | 24 V | Pulse ON |
| 24 V | 0 V | Pulse OFF |
000 | Set pulse range on power source |
001 | Setting of pulse range deactivated |
010 | 0.2 - 2 Hz |
011 | 2 - 20 Hz |
100 | 20 - 200 Hz |
101 | 200 - 2000 Hz |
X11/5 | Pulse range, first digit |
X11/6 | Pulse range, second digit |
X11/7 | Pulse range, third digit |
Example ROB 5000:
Example ROB 5000 OC:
Pin | Signal ROB 5000 | Signal ROB 5000 OC | Program bit |
X11/1 | 24 V | 0 V | 0 |
X11/2 | 24 V | 0 V | 1 |
X11/3 | 24 V | 0 V | 2 |
X11/4 | 24 V | 0 V | 3 |
X11/5 | 24 V | 0 V | 4 |
X11/6 | 24 V | 0 V | 5 |
X11/7 | 24 V | 0 V | 6 |
X11/8 | 24 V | 0 V | 7 |
The allocations are identical to those in the „Program number“ function. The choice between the „job number“ and „program number“ functions is made using mode bits 0 -2.
The “Job number” function is available if “Job mode” was selected using mode bits 0 -2.
When the “Job number” function is used, saved welding parameters are called up using the number of the corresponding job.
System requirements for analog job selection are as follows:
Activate analog job selection as follows:
Analog job selection enables job numbers to be selected using the following analog input signals:
In job mode, the usual functions that these two input signals perform are absent. The two signals have therefore been given this additional analog job selection function.
IMPORTANT! More information about these two input signals can be found in the “Analog input signals” chapter.
Both analog input signals
A: Part value 1 for “Base current” input signal:
1. Step = Voltage (V)/0.625 V
2. Part value 1 = Step * 16
Example
1. Step = 6.25 V/0.625 V = 10
2. Part value 1 = 10 * 16 = 160
B: Part value 2 for “Duty cycle” input signal:
3. Step = Voltage (V)/0.625 V
4. Part value 2 = Step
Example
3. Step = 6.25 V/0.625 V = 10
4. Part value 2 = 10
C: Selected job:
5. Job = Part value 1 (A) + Part value 2 (B)
Example
5. 160 (A) + 10 (B) = 170
IMPORTANT! Both analog input signals
The highest selectable job is thus:
A: 9.375 V / 0.625 V = 15, 15 * 16 = 240
B: 9.375 V / 0.625 V = 15
C: 240 + 15 = 255
Signal X14:2 | HIGH | LOW |
The “Welding simulation” signal allows a programmed welding path to be simulated; an arc, wire feed and shielding gas are not required. The digital output signals „Arc stable“, „Main current signal“ and „Process active“ are set just as if welding was actually being performed.
Signal X8:7 | HIGH | LOW |
The “Touch sensing” signal can be used to indicate that the tungsten electrode has made contact with the workpiece (short-circuit between workpiece and electrode).
If the “Touch sensing” signal is set, the control panel on the power source shows “touch”. There will be a voltage of 30 V on the tungsten electrode (current limited to 3 A).
The fact that a short-circuit has occurred is transmitted to the robot control via the „Arc stable“ signal (see the „Digital output signals“ chapter).
Output of the „arc stable“ signal takes about 0.2 s longer than the duration of the short-circuit current.
No welding can take place while the “Touch sensing” signal is set. If the robot control sets the „Touch sensing“ signal during a welding operation, welding is stopped at the end of the burn-back time (which can be specified in the power source setup menu). Position detection can be carried out.
Signal X14:5 | HIGH | LOW |
The “KD disable” signal facilitates the changeover from internal to external control of the cold-wire feeder:
External or internal control of the cold-wire feeder affects the following functions:
The analog differential amplifier inputs on the robot interface ensure the robot interface and the analog outputs on the robot control are electrically isolated. Each input on the robot interface has its own negative potential.
If the robot control uses a common GND for its analog output signals, the negative potentials, i.e. the inputs on the robot interface, must be linked together.
The analog inputs described below are active at voltages from 0-10 V. If individual analog inputs are not allocated, the values set at the power source will be used.
Pin X2/1....... Analog in + 0 to + 10 V
Pin X2/8....... Analog in - (minus)
A voltage of 0 - 10 V is specified for the “Welding current command value”.
0 V ........ Minimum welding current
10 V ...... Maximum welding current
The command value for “Welding current” cannot be entered while in Job mode.
Pin X2/2....... Analog in + 0 to + 10 V
Pin X2/9....... Analog in - (minus)
A voltage of 0 - 10 V is specified for external parameter 1.
0 V ........ External parameter 1 - minimum value
10 V ...... External parameter 1 - maximum value
IMPORTANT! The power source operating instructions contain a much more detailed description of the external parameter, as well as the functions it can perform.
Pin X14/3....... Analog in + 0 to + 10 V
Pin X14/11......Analog in - (minus)
A voltage of 0 - 10 V is specified for the “Base current command value”.
0 V ........ Minimum base current
10 V ...... Maximum base current
Pin X5/1....... Analog in + 0 to + 10 V
Pin X5/8....... Analog in - (minus)
A voltage of 0 - 10 V is specified for the “Duty cycle command value”.
0 V ........ Minimum duty cycle
10 V ...... Maximum duty cycle
Pin X5/2....... Analog in + 0 to + 10 V
Pint X5/9....... Analog in - (minus)
If a cold-wire feeder is being used: the “External parameter 2” analog input is currently only used to specify a value for the wirefeed speed.
A voltage of 0 - 10 V is specified for the wirefeed speed command value.
The following applies in each instance:
0 V ........ Minimum wirefeed speed
10 V ...... Maximum wirefeed speed
If the connection between the power source and the robot interface goes down, all digital and analog output signals on the robot interface will be set to “0”.
The power source supply voltage (24 V SECONDARY) is available in the robot interface.
24 V SECONDARY is electrically isolated from the LocalNet. A suppressor circuit limits excess voltages to 100 V.
Use pin X14/1 to select which voltage is to be connected to the digital outputs of the robot interface.
Pin X2/12............ ....... 24 V signal
Pin X7/2 or X12/2....... GND
The „Arc stable“ signal is set as soon as a stable arc is present.
Pin X8/10.................... 24 V signal
When the robot control sets the “Welding start” digital input signal, the welding process begins with the gas pre-flow, followed by the actual welding operation and the gas postflow.
The power source sets the “Process active” signal from the start of the gas pre-flow to the end of the gas post-flow.
The “Process active” signal ensures optimum gas shielding
Pin X8/9....................... 24 V signal
Pint X7/2 or X12/2....... GND
While the robot interface is connected to the LocalNet, “2-step mode” remains selected (display: 2-step mode).
The following are defined in the power source setup menu:
The main current signal is set between the starting current and final current phases.
IMPORTANT! More information can be found in the power source operating instructions
Pin X14/10...................24 V signal
Pin X2/13.................... 24 V signal
The robot welding torch will normally have a cut-off switch. In the event of a collision, the contact in the cut-off switch opens and triggers the LOW active “Collision protection” signal.
The robot control must shut down the robot immediately and stop the welding process using the “Quick stop” input signal
Pin X2/14.................... 24 V signal
The “Power source ready” signal remains on as long as the power source is ready to weld.
The “Power source ready” signal is reset whenever an error occurs in the power source or the robot control sets the “Quick stop” signal.
The “Power source ready” signal can therefore be used to detect internal errors and errors in the robot.
Pin X5/15.................... 24 V signal
The „High frequency active“ signal remains present as long as the high frequency is active.
Pin X5/16.................... 24 V signal
In pulse mode (fPuls < 5 Hz) the „PULSE HIGH“ signal is active with every HIGH pulse.
The analog outputs on the robot interface are used for setting up the robot and for displaying and documenting process parameters.
Pin X5/4......... Analog out + 0 to + 10 V
Pin X5/11....... Analog out - (minus)
The actual “welding voltage” value is indicated by a voltage of 0 - 10 V on the analog output
When the power source is idle the „HOLD“ value becomes the “Welding voltage command value” as soon as the welding operation is complete.
Pin X2/3......... Analog out + 0 to + 10 V
Pin X2/10....... Analog out - (minus)
The actual “Welding current” value is indicated by a voltage of 0 - 10 V on the analog output
When the power source is idle the „HOLD“ value becomes the “Welding current command value” as soon as the welding operation is complete.
Pin X5/7......... Analog out + 0 to + 10 V
Pin X5/14....... Analog out - (minus)
The actual “motor current” value is indicated by a voltage of 0 - 10 V on the analog output
IMPORTANT! The actual “Motor current” value provides information about the status of the wirefeed system.
Pin X5/6......... Analog out + 0 to + 10 V
Pin X5/13....... Analog out - (minus)
The wirefeed speed is indicated by a voltage of 0 - 10 V on the analog output
When the power source is idle the „HOLD“ value becomes the wirefeed speed as soon as the welding operation is complete.
IMPORTANT! The wirefeed speed is calculated from the speed of the motor (rpm).
The wirefeed speed passed to the control may differ from the real speed
Pin X5/5......... Analog out + 0 to + 10 V
Pin X5/12....... Analog out - (minus)
The Arc length analog output (AVC) is used for interfacing to an AVC device (automatic voltage control).
Depending on the requirements of the robot application, not all the input and output signals (commands) available on the robot interface need be used. The various command subsets of the robot interfaces are illustrated in the following examples, which demonstrate how to connect the robot interface to the robot control. The I/O signals shown in bold represent the minimum command subset required in each instance.
Example of the most important analog and digital commands for controlling the power source using analog command values
Reset error messages - ROB 4000:
In contrast to the ROB 5000/ROB 5000 OC, the ROB 4000 robot interface does not allow errors to be reset using the „Source error reset“ signal. Error messages on the power source are reset automatically as soon as the error is rectified.
The “Welding start” signal must not be set while the error is being rectified, otherwise welding will start as soon as the error is fixed.
Example of the use of the ROB 5000 command set for controlling the power source using analog command values
Job selection via the robot:
| ROB 5000 |
| ROB 5000 OC | ||||
| MODE |
| MODE | ||||
| „0“ | „1“ | „2“ |
| „0“ | „1“ | „2“ |
| 1 | 0 | 1 |
| 0 | 0 | 1 |
| 0 | 1 | 0 |
TIG | 0 | 1 | 1 |
| 1 | 0 | 0 |
The ROB 5000/ROB 5000 OC has the following additional digital functions
Reset error messages - ROB 5000 / ROB 5000 OC:
Error messages on the power source are reset using the “Source error reset” signal. However, the cause of the error must first be eliminated.
If the „Source error reset“ signal is still
All digital inputs on the ROB 5000 OC (Open Collector) robot interface are inverted.
Application example MODE 2 and QUICK STOP on ROB 5000 OC
Example of the most important analog and digital commands:
| ROB 5000 |
| ROB 5000 OC | ||||
| MODE |
| MODE | ||||
| „0“ | „1“ | „2“ |
| „0“ | „1“ | „2“ |
| 1 | 0 | 1 |
| 0 | 0 | 1 |
| 0 | 1 | 0 |
TIG | 0 | 1 | 1 |
| 1 | 0 | 0 |
Error messages on the power source are reset using the “Source error reset” signal (not illustrated on this page). However, the cause of the error must first be eliminated.
A detailed description of the Service Codes that can be displayed can be found in the “Troubleshooting” chapter of your power source operating instructions.
