en
      Operating InstructionsPullMig
    • General
      • Device concept
      • Intended use
      • Safety
      • System requirements
    • Installation and commissioning
      • Mounting the torch neck
      • Assemble wire guidance insert
      • Assemble Inner Liner (Fronius connection without wire-guidance nozzle
      • Assemble Inner Liner (Fronius connection with wire-guidance nozzle)
      • Assemble Inner Liner (Euro connection without wire-guidance nozzle)
      • Connecting up the welding torch
      • Replace Feed Rolls
      • Set Electrode Pressure
      • Replace Wire Inlet Nozzle
      • Up/Down
      • JobMaster
    • Troubleshooting
      • Troubleshooting
    • Technical data
      • PullMig hosepack gas-cooled
      • PullMig hosepack water-cooled
      • PullMig torch neck gas-cooled
      • PullMig torch neck water-cooled
      • PullMig - hosepack / torch neck
      • PushPull Equalisation
    • 005-15042026
    PullMig
    download
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statement
    General
    link_horizontalLink copied
    Device concept
    PullMig is a wire feed unit for manual welding using soft welding wires and with long hose packs. Two toothed precision rolls ensure large-surface power transmission. This leads to outstanding wire feed even with very soft aluminium and CuSi wires and very long hose packs. The many different versions of PullMig available are one of its distinguishing features.
    Thus there are several variations of torch connections available with both external and internal coolant connections. A variety of pipe bend designs ensures excellent weld accessibility.
    1. General
    Device concept
    1. General
    Intended use
    The MIG/MAG manual welding torch is intended exclusively for MIG/MAG welding in manual applications. Utilisation for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended use.
    Intended use also includes:
    • Following all the instructions contained in the operating instructions
    • Performing all stipulated inspection and maintenance work
    1. General
    Safety
    WARNING!
    Fully read and understand this document.
    WARNING!
    Danger from electric current.
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, leads and hosepacks must always be securely connected, undamaged and correctly insulated.
    Only use adequately dimensioned cables, leads and hosepacks.
    CAUTION!
    Danger due to emerging wire electrode.
    This can result in personal injury.
    Hold the welding torch with the end directed away from the face and body.
    Wear suitable protective goggles.
    Do not point the welding torch at people.
    Ensure that the wire electrode can only intentionally make contact with electrically conductive objects.
    CAUTION!
    Danger due to hot system components and/or equipment.
    This can result in burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
    Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
    CAUTION!
    Danger due to operation without coolant.
    Never operate water-cooled devices without coolant.
    During welding, ensure that there is a proper coolant flow. When using Fronius cooling units, this is the case if a proper coolant return flow can be seen in the coolant container of the cooling unit.
    CAUTION!
    Danger due to exposed mechanically moving parts.
    This can result in personal injury and damage to property.
    Only operate the device when all covers are closed and/or completely mounted.
    1. General
    System requirements
    Power source
    • TS 4000 / 5000
    • TPS 2700 / 4000 / 5000
    Software
    • Power source: Software version 3.10.22 or higher
    • Wire feed: Software version 1.70.16 or higher
    Options
    • Installation set „PMR4000 PullMig TS/TPS 2700-5000 (4,100,217)“
    • Software „FS Drive (4,061,113)“
    IMPORTANT! Risk of coolant leakage (on water-cooled welding torches) or damage from overheating (on gas-cooled welding torches). When mounting the torch neck, make sure that the swivel nut is fixed firmly.
    1. Installation and commissioning
    When cutting the inner liner to length, make sure that
    • no burr (sharp edges) protrudes into the inner liner at the cut location.
    • Hold the side-cutting pliers at a slight angle (the burr is then pulled towards the outside).
    • Grind off the burr
    * Contact tube with centering bore
    ** Contact tube without centering bore
    Ø 4 mm (.16 in.): 40,0002,0014; 40,0002,0015
    Ø 4,7 mm (.19 in.): 40,0002,0004; 40,0002,0017
    5
    IMPOTRTANT! Bring the inner liner as close as possible to the wirefeed rollers, but without touching them.
    Before threading in the welding wire, round off the ends of the wire.
    Only use wire guidance nozzles corresponding to diameter of wire. The following wire guidance nozzles are available:
    • 0,8 mm (.030 in.)
    • 1,0 mm (.040 in.)
    • 1,2 mm (.045 in.)
    • 1,6 mm (1/16 in.)
    5
    6
    * Optional infeed nozzle (42,0001,5421)
    IMPORTANT! Bring the inner liner / the infeed nozzle as close as possible to the wirefeed rollers, but without touching them. Before threading in the welding wire, round off the ends of the wire.
    * Standard plug (Standard or Up/Down torches)
    ** JobMaster plug (JobMaster welding torches)
    Replace Feed Rolls
    1Unscrew pressure lever (1)
    2Unscrew axle (2) using slotted screwdriver
    3Remove complete unit (3)
    4Fix drive roll (4) using driving gear key (5) provided
    5Unscrew hexagon nut (6) using open-ended spanner - spanner size 10 mm (.394 in.)
    6Remove drive roll (4)
    1hard (e.g. CrNi)
    2medium (e.g. AlMg / CuSi)
    3soft (e.g. AlSi)
    1Unscrew hexagon nut using open-ended spanner (1)
    2Unscrew and remove wire inlet nozzle using Allen key (2)
    -  key width 2.5 mm (.099 in.)
    Up/Down
    • Set welding output using Up/Down function
    JobMaster
    • Select and set desired parameter using JobMaster function
    IMPORTANT! Refer to MIG/MAG Torch Operating Instructions, chapter headed „JobMaster“ for more detailed information on the JobMaster function.
    Troubleshooting
    Troubleshooting
    1. Troubleshooting
    Troubleshooting
    No number („PPU“) selectable for PullMig (PushPull Unit)
    Cause:„PMR4000 PullMig“ installation set is not installed
    Remedy:Install installation set
    Number for PullMig (e.g. „PPU | 5“), for PushPull equalisation is not selectable
    Cause:Power source does not have „FS Drive“ software
    Remedy:Provide power source with „FS Drive“ software
    PullMig feed rolls are not turning
    Cause:PullMig control plug is not plugged in
    Remedy:Connect PullMig control plug at torch control connection
    Cause:PullMig connection cable damaged
    Remedy:Check cable and replace if necessary
    Irregular wire speed
    Wire electrode forms a loop between feed rolls and wire inlet nozzle
    Cause:Feed rolls not suitable for wire electrode being used
    Remedy:Use appropriate feed rolls
    Cause:Wrong electrode pressure of PullMig or 4-roll drive
    Remedy:Optimise electrode pressure
    Welding wire is deformed or breaks off
    Cause:Electrode pressure of PullMig or 4-roll drive set too high
    Remedy:Set electrode pressure of PullMig or 4-roll drive correctly
    Cause:PullMig turns too fast or too slow
    Remedy:Select right number (e.g. „PPU | 5“) for PullMig during PushPull equalisation
    PullMig becomes too hot
    Cause:Inadequate cooling; water circulation too low or non-existent in cooling unit
    Remedy:Check whether PullMig is properly connected; check cooling unit and bleed if necessary; check coolant throughflow for PullMig
    EFd | xx.x, EFd | 8.1
    Cause:Wire drive blocked/faulty
    Remedy:Inspect/replace motor for wire drive
    EFd | 8.2
    Cause:Fault in wire feed system (overcurrent in PullMig drive)
    Remedy:Lay hose pack out in as straight a line as possible; check liner for kink or dirt; check contact pressure of PullMig feed rolls
    EFd | 9.1
    Cause:External supply voltage: supply voltage has dropped below tolerance range
    Remedy:Check external supply voltage
    EFd | 9.2
    Cause:External supply voltage: supply voltage has exceeded tolerance range
    Technical data
    I (Amp.) 10 min/40° C
    M21 (EN ISO 14175)
    40 % d.c.* 280
    60 % d.c.* 220
    100 % d.c.* 170
    C1 (EN ISO 14175)
    40 % d.c.* 330
    60 % d.c.* 270
    100 % d.c.* 210
    [m]
    (ft.)
    6 / 8 / 10
    (19,6/26,2/32,8)
    [V] DC
    42
    [A]
    0,8
    [m/min] (ipm)
    0,5 - 18
    (19,69 - 787,40)
    [mm]
    (in.)
    0,8 - 1,6
    (.032 - .047)
    * d.c. = duty cycle
    1. Technical data
    M21 (EN ISO 14175)
    40 % d.c.* 280
    60 % d.c.* 220
    100 % d.c.* 170
    C1 (EN ISO 14175)
    40 % d.c.* 330
    60 % d.c.* 270
    100 % d.c.* 210
    [m]
    (ft.)
    6 / 8 / 10
    (19,6/26,2/32,8)
    [V] DC
    42
    [A]
    0,8
    [m/min] (ipm)
    0,5 - 18
    (19,69 - 787,40)
    [mm]
    (in.)
    0,8 - 1,6
    (.032 - .047)
    * d.c. = duty cycle
    1. Technical data
    M21 (EN ISO 14175)
    100 % d.c.* 400
    C1 (ENISO 14175)
    100 % d.c.* 500
    [m]
    (ft.)
    6 / 8 / 10
    (19,6/26,2/32,8)
    Pmin
    [W]**
    1450 / 1800 / 2000 W
    Qmin
    [l/min]
    (gal./min)
    (.26)
    pmin
    [bar]
    (psi.)
    (43.5)
    pmin
    [bar]
    (psi.)
    5,5
    (79.7)
    [V] DC
    42
    [A]
    0,8
    [m/min] (ipm)
    0,5 - 18
    (19,69 - 787,40)
    [mm]
    (in.)
    0,8 - 1,6
    (.032 - .047)
    * d.c. = duty cycle
    ** Minimum cooling power in accordance with standard IEC 60974-2
    1. Technical data
     AL216
     AL236
     AL306
     AL406
    M21 (EN ISO 14175) - d.c.*
    35 % 180
    60 % 140
    100 % 100
    40 % 200
    60 % 160
    100 % 120
    40 % 260
    60 % 210
    100 % 160
    40 % 350
    60 % 280
    100 % 220
    C1 (EN ISO 14175) - d.c.*
    35 % 210
    60 % 160
    100 % 120
    40 % 230
    60 % 190
    100 % 150
    40 % 300
    60 % 240
    100 % 190
    40 % 400
    60 % 320
    100 % 250
    [mm]
    (in.)
    0,6-1,0
    (.024-.039)
    0,6-1,0
    (.024-.039)
    0,8-1,2
    (.032-.047)
    1,0-1,6
    (.039-.063)
     AL2300
     AL2400
     AL3000
     AL4000
    M21(EN 439) - d.c.*
    40 % 200
    60 % 160
    100 % 120
    40 % 200
    60 % 160
    100 % 120
    40 % 250
    60 % 200
    100 % 150
    40 % 350
    60 % 280
    100 % 220
    40 % 230
    60 % 190
    100 % 150
    40 % 240
    60 % 200
    100 % 160
    40 % 400
    60 % 320
    100 % 250
    40 % 400
    60 % 320
    100 % 250
    [mm]
    (in.)
    0,6-1,0
    (.024-.039)
    0,6-1,0
    (.024-.039)
    0,8-1,2
    (.032-.047)
    1,0-1,6
    (.039-.063)
    *d.c. = duty cycle
    1. Technical data
     AW252
     AW332
     AW335
     AW352
    100 % 220
    60 % 200
    100 % 150
    60 % 200
    100 % 150
    100 % 300
    100 % 250
    60 % 250
    100 % 190
    60 % 250
    100 % 190
    100 % 350
    [mm]
    (in.)
    0,6-1,2
    (.024-.047)
    0,8-1,2
    (.032-.047)
    0,8-1,2
    (.032-.047)
    1,0-1,6
    (.039-.063)
     AW502
     AW652
    M21(EN ISO 14175) - d.c.*
    100 % 400
    100 % 500
    100 % 500
    100 % 600
    [mm]
    (in.)
    1,0-1,6
    (.039-.063)
    1,0-2,4
    (.039-.94)
     AW2500
     AW4000
     AW5000
     AW7000
    100 % 220
    100 % 350
    100 % 400
    100 % 550
    100 % 250
    100 % 400
    100 % 500
    100 % 700
    [mm]
    (in.)
    0,6-1,2
    (.024-.047)
    0,8-1,2
    (.032-.047)
    1,0-1,6
    (.039-.063)
    1,0-1,6
    (.039-.063)
    * d.c. = duty cycle
    1. Technical data
    Voltage rating (V-Peak):
    • for manually guided torches: 113 V
    • for mechanically guided torches: 141 V
    The product complies with standard IEC 60974-7.
    1. Technical data
    PushPull equalisation is adjusted in accordance with the Power Source Operating Instructions, chapter headed „PushPull Unit“
