If you have any questions about the tests, a team of experts is on hand.
E-Mail: welding.techsupport@fronius.com
The wire buffer test box is used for checking output signals from the wire buffer. The wire buffer’s communication can also be checked with the power source to which it is connected.
(1) | Torch control connecting cable for connecting to a power source or a wire-feed unit |
(2) | Wire buffer connecting cable for connecting to a power source or a wire-feed unit |
(3) | BNC socket for measuring the output signals using a BNC plug |
(4) | Minus potential connection for measuring the output signals using a digital multimeter |
(5) | Plus potential connection for measuring the output signals using a digital multimeter |
(6) | Wire buffer connection for connecting a wire buffer |
(7) | Guntrigger switch for triggering welding start-up using the test box |
Risk of electric shock, if the power source is ON.
During all work: ensure that no welding operation is started,
do not touch the central connection of the power source
„Wire buffer full“ set value: 2.34 - 2.46 volts
„Wire buffer empty“ set value: 0.42 - 0.54 volts
To enable the wire buffer’s output signals to be tested in conjunction with a PullMig CMT hosepack, the wire buffer’s control line must be changed.
IMPORTANT! The wire buffer control line, item no. 43,0004,2803, is not included in the scope of supply of the wire buffer test box.
Symbols used | |
Torch side | |
Feed side |
Symbols used | |
Torch side | |
Feed side |
Only qualified technicians, who have attended the appropriate Fronius training course, are permitted to commission and operate the device.
Danger due to welding processes starting unintentionally.
The following steps should only be carried out when there is no wire being fed in the welding system.
In welding systems that have an external welding start-up facility (robot applications) it is possible to trigger welding start-up using the Guntrigger switch on the wire buffer test box. This enables error messages to be checked easily at the power source’s indicators. To check error messages, proceed as follows:
