Danger from electric current.
Secure all the devices and components involved to prevent unintentional restarting.
After repairs and installations or conversions, a safety inspection must be performed in accordance with the Service Instructions of the device.
Observe national standards and directives.
Only carry out the safety inspection when the device is fully assembled.
Correct any defects found and repeat the safety inspection!
Safety inspection according to Service Instructions 42,0426,0174.
(1) | 1x wire buffer cable harness |
(2) | 2x Taptite screws M5x10 mm |
(3) | 2x Taptite screws 4x8 mm |
(4) | 2x screws T20 4x8 mm |
(5) | 10x cable ties |
(6) | 1x LHSB connecting lead 0.75 m |
(7) | 1x M12 adapter plate |
(8) | 1x LHSB IN cable |
Installation kit PM43 must be already installed in the VR 1550 in order to add the CMT VR 1550 installation kit.
IMPORTANT! The PM 43 installation kit is required in order to use the CMT VR 1550 installation kit.
Only if installation kit PM43 has not yet been fitted to the VR 1550:
While fitting the side panel to the control unit, ensure that cables are not trapped or damaged in any way.
