en
      Operating InstructionsMTG/MTW/MTB/MHP 250i-700i ML /G/W
    • General
      • Safety
      • General
      • Intended use
    • Options
      • Pistol grip
      • Heat shield
      • Potentiometer
      • Additional torch trigger on the top
      • Extraction Exento
      • Torch trigger extension
    • Description of available functions
      • Up/Down-function
      • JobMaster-function
      • Functions of the two-stage torch trigger
      • Special functions
    • Variants
      • TT-SH torch trigger, top - straight torch handle
    • Installation and commissioning
      • MTG d, MTW d - Fitting wearing parts to the torch body
      • Variant MTB 200i G / MTB 220i W
      • Assembling Multilock welding torches
      • Note regarding the inner liner with gas-cooled welding torches
      • Checking the clamping nipple
      • Fitting the inner liner inside the torch hosepack
      • Connecting the welding torch to the wirefeeder
      • Twisting the Multilock welding torch body
      • Changing the torch body on a Multilock welding torch
    • Care and maintenance
      • General
      • Recognising faulty wearing parts
      • Maintenance at every start-up
      • Maintenance every time the wirespool/basket-type spool is changed
    • Troubleshooting
      • Troubleshooting
    • Technical data
      • General
      • Gas-cooled welding torch - MTG 250i, 320i, 400i, 550i
      • Gas-cooled hosepack - MHP 250i, 400i, 550i G ML
      • Gas-cooled torch body - MTB 200i, 250i, 320i, 330i, 400i, 550i G ML
      • Water-cooled welding torch - MTW 250i, 400i, 500i, 700i
      • Water-cooled hosepack - MHP 400i, 500i, 700i W ML
      • Water-cooled torch body - MTB 220i, 250i, 330i, 400i, 500i, 700i W ML
    • 025-24022026
    download
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statementCookie Policy
    General
    link_horizontalLink copied
    Safety
    WARNING!
    WARNING!
    Danger from electric current.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, leads and hosepacks must always be securely connected, undamaged and correctly insulated.
    Only use adequately dimensioned cables, leads and hosepacks.
    WARNING!
    Danger due to contact with toxic welding fume.
    This can result in serious personal injury.
    Always extract welding fume.
    Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³/h (11.77 cfm) at all times.
    If in doubt, a safety engineer should be commissioned to check the pollution level in the workplace.
    CAUTION!
    Danger due to hot system components and/or equipment.
    This can result in burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
    Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
    CAUTION!
    Danger due to operation without coolant.
    Never operate water-cooled devices without coolant.
    During welding, ensure that there is a proper coolant flow. When using Fronius cooling units, this is the case if a proper coolant return flow can be seen in the coolant container of the cooling unit.
    CAUTION!
    Risk of coolant escaping.
    This can result in injury and damage to property.
    Seal the coolant hoses on water-cooled welding torches with the plastic stoppers fitted to them if the hoses are detached from the cooling unit or other system components.
    1. General
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    CAUTION!
    1. General
    General
    These MIG/MAG welding torches are exceptionally robust and reliable. The ergonomic grip, ball joint and optimal weight distribution combine to enable fatigue-free working. The welding torches are available as gas-cooled and water-cooled versions in different power categories and sizes, so no weld seam is out of reach. The welding torches can be adapted to deal with a huge variety of different tasks, and are ideal for use in manual series and one-off fabrication, as well as in the workshop sector.
    1. General
    Intended use
    The MIG/MAG manual welding torch is intended exclusively for MIG/MAG welding in manual applications.
    Utilisation for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended use.
    Intended use also includes:
    • Following all the instructions contained in the operating instructions
    • Performing all stipulated inspection and maintenance work
    Options
    Pistol grip
    OPT/i T-Handle SET for W6
    44,0350,5298
    1. Options
    Pistol grip
    44,0350,5298
    1. Options
    Heat shield
    Heat shield
    42,0405,0753
    1. Options
    Potentiometer
    OPT/i Userinterface Poti W6
    4,001,796
    1. Options
    42,0405,0671
    4,070,958,Z
    43,0004,4062
    1. Options
    Extraction Exento
    OPT/i Exento Small /5m
    44,0350,4078
    OPT/i Exento Medium /5m
    44,0350,4077
    OPT/i Exento MTG400i TD/45°
    44,0350,1536
    1. Options
    44,0350,5229
    Up/Down-function
    The Up/Down torch has the following functions:
    • Changes the welding power in Synergic operation via the Up/Down buttons
    • Error display:
      • all the LEDs light up red if there is a system fault
      • all the LEDs flash red if there is a data communication fault
    • Self-test during the run-up sequence:
      • all LEDs light up briefly one after the other
    1. Description of available functions
    Up/Down-function
    • Error display:
    JobMaster-function
    The JobMaster welding torch has the following functions:
    • The desired welding parameter on the power source can be selected using the arrow buttons
    • The selected welding parameter can be changed using the +/- buttons
    • The display shows the current welding parameter and value
    Function of the torch trigger in switching position 1 (torch trigger half pressed):
    • LED lights up.
    Function of the torch trigger in switching position 2 (torch trigger fully pressed):
    • LED goes out
    • Welding starts.
    NOTE!
    An LED on welding torches with an optional torch trigger on the top will not work.
    Special functions
    Various special functions can be stored for the torch trigger and for function keys.
    For details on the special functions, please refer to the operating instructions for the welding machine.
    Variants
    TT-SH with straight torch handle and torch trigger at top
    1. Variants
    Screw on and tighten the gas nozzle as far as it will go
    1. Installation and commissioning
    Variant MTB 200i G / MTB 220i W:
    44,0350,4527
    NOTE!
    Risk from incorrect assembly of the welding torch.
    This can result in damage to the welding torch.
    Before fitting a torch body, ensure that the interface between the torch body and the hosepack is clean and undamaged.
    In the case of water-cooled welding torches, increased resistance may arise when tightening the union nut due to the construction of the welding torch.
    Always tighten the union nut on the torch body as far as it will go.
    The torch body is in the 0° position when the dowel pin (1) on the hosepack engages in the locating hole (2) in the torch body.
    Ensure that the union nut is tightened as far as it will go.
    NOTE!
    Risk due to incorrect inner liner insert.
    This can result in poor weld properties.
    If a gas-cooled welding torch is used with a plastic inner liner and bronze inner liner insert instead of a steel inner liner, the performance data of the welding torch specified in the technical data is reduced by 30%.
    To operate gas-cooled welding torches at maximum power, replace the 40 mm (1.575 in.) inner liner insert with the 320 mm (12,598 in.) inner liner insert.
    Left: Brass clamping nipple with sealing disc. Right: Silver clamping nipple without sealing disc.
    IMPORTANT! Check the clamping nipple before commissioning and every time the inner liner is changed.
    * Carry out a visual inspection for this purpose:
    • Left: Brass clamping nipple with sealing disc. You cannot see through the sealing disc.
    • Right: Silver clamping nipple with visible hole.
    NOTE!
    Incorrect or defective clamping nipple for push applications
    Gas loss and poor weld properties will result.
    Use brass clamping nipples to minimise gas loss.
    Check that the sealing disc is intact.
    NOTE!
    Incorrect clamping nipple for push-pull applications
    Wire winder and increased abrasion in the inner liner when using a clamping nipple with sealing disc.
    Use the silver clamping nipple to facilitate wire feeding.
    Lay the welding torch out straight
    Lay the inner liner out straight
    Push the inner liner into the welding torch until it protrudes from the front of the welding torch
    Mark the end of the torch connector on the inner liner
    5
    Cut off the inner liner at the marking and deburr; left inner liner made of steel, right inner liner made of plastic
    6
    Screw the clamping nipple onto the inner liner as far as it will go. The inner liner must be visible through the hole in the cap
    7
    Fit the extraction nozzle
    Push the extraction nozzle on as far as it will go.
    Only if the optional coolant connections are fitted in the cooling unit and when using a water-cooled welding torch.
    Always connect the coolant hoses according to their colour coding.
    CAUTION!
    Risk of burns from hot coolant and hot torch body.
    This can result in severe scalds.
    Before carrying out any work, allow the coolant and torch body to cool to room temperature (+25 °C, +77 °F).
    CAUTION!
    Some coolant will always remain in the torch body. Only remove the torch body with the gas nozzle pointing downwards
    CAUTION!
    This can result in serious damage to property.
    General
    Regular preventive maintenance of the welding torch is essential if trouble-free operation is to be ensured. The welding torch is subjected to high temperatures and heavy soiling. The welding torch therefore requires more frequent maintenance than other components in the welding system.
    CAUTION!
    Risk of damage from improper handling of the welding torch.
    This can result in severe damage to property.
    Do not strike the welding torch on hard objects.
    Avoid scoring and scratches on the contact tip.
    Do not bend the torch body under any circumstances.
    1. Care and maintenance
    General
    CAUTION!
    1. Insulating parts
      • Burned-off outside edges, notches
    2. Nozzle fittings
      • Heavily covered in welding spatter
    3. Spatter guard
    4. Contact tips
      • Worn-out (oval) wire entry and wire exit holes
      • Penetration on the tip of the contact tip
    5. Gas nozzles
      • Notches
    • Check wearing parts
      • replace faulty wearing parts
    • Remove welding spatter from gas nozzle
    Check the gas nozzle, spatter guard and insulation for damage and replace any damaged components.
    • Also at every start-up when using water-cooled welding torches:
      • check all coolant connections for tightness (no leaks)
      • check that the coolant can flow unhindered
    • Clean wirefeeding hose with reduced compressed air
    • Recommended: replace the inner liner. Clean the wearing parts before fitting the new inner liner
    3Fitting wearing parts
    • For details on fitting the wearing parts, refer to the section MTG d, MTW d - Fitting wearing parts to the torch body from page (→).
    Troubleshooting
    Troubleshooting
    1. Troubleshooting
    Troubleshooting
    No welding current
    Power source mains switch is on, indicators on the power source are lit up, shielding gas available
    Cause:Grounding (earthing) connection is incorrect
    Remedy:Establish a proper grounding (earthing) connection
    Cause:There is a break in the current cable in the welding torch
    Remedy:Replace welding torch
    Nothing happens when the torch trigger is pressed
    Cause:The FSC ('Fronius System Connector' central connector) is not plugged in properly
    Remedy:Push on the FSC as far as it will go
    Cause:Welding torch or welding torch control line is faulty
    Cause:Interconnecting hosepack faulty or not connected properly
    Remedy:Connect interconnecting hosepack properly
    Replace faulty interconnecting hosepack
    Cause:Faulty power source
    Remedy:Contact After-Sales Service
    No shielding gas
    All other functions are OK
    Cause:Gas cylinder is empty
    Remedy:Change the gas cylinder
    Cause:Gas pressure regulator is faulty
    Remedy:Replace gas pressure regulator
    Cause:The gas hose is not connected, or is damaged or kinked
    Remedy:Fit gas hose, lay out straight Replace faulty gas hose
    Cause:Welding torch is faulty
    Cause:Gas solenoid valve is faulty
    Remedy:Contact After-Sales Service (arrange for gas solenoid valve to be replaced)
    Poor weld properties
    Cause:Incorrect welding parameters
    Remedy:Correct settings
    Cause:Poor ground earth connection
    Remedy:Ensure good contact to workpiece
    Cause:Inadequate or no shielding gas
    Remedy:Check the pressure regulator, gas hose, gas solenoid valve and welding torch shielding gas connection. On gas-cooled welding torches, inspect the gas seals, use a suitable inner liner
    Cause:Welding torch is leaking
    Cause:Contact tip is too large or worn out
    Remedy:Replace contact tip
    Cause:Wrong wire alloy or wrong wire diameter
    Remedy:Check wirespool/basket-type spool in use
    Remedy:Check weldability of the base material
    Cause:The shielding gas is not suitable for this wire alloy
    Remedy:Use the correct shielding gas
    Cause:- Contaminated shielding gas (e.g. due to moisture or air)
    - Inadequate gas shield (e.g. due to draughts)
    - Unsteady, oxidising weld pool
    - Contamination in the workpiece (e.g. rust, paint, grease, coatings)
    - Arc length too short
    - Irregularities in the wire feeding (e.g. due to clogged inner liner)
    Remedy:Optimise the welding conditions
    Cause:Shielding gas loss at the clamping nipple
    Remedy:Use the correct clamping nipple
    Cause:Clamping nipple sealing disc defective, shielding gas loss at the clamping nipple
    Remedy:Replace clamping nipple to ensure gas tightness
    Cause:Welding spatter in the gas nozzle
    Remedy:Remove welding spatter
    Cause:Turbulence caused by too high a rate of shielding gas flow
    Remedy:Reduce shielding gas flow rate, recommended:
    Shielding gas flow rate (l/min) = wire diameter (mm) x 10
    (e.g. 16 l/min for 1.6 mm wire electrode)
    Cause:Too large a distance between the welding torch and the workpiece
    Remedy:Reduce the distance between the welding torch and the workpiece (approx. 10 - 15 mm / 0.39 - 0.59 in.)
    Cause:Tilt angle of the welding torch is too great
    Remedy:Reduce the tilt angle of the welding torch
    Cause:Wirefeed components do not match the diameter of the wire electrode / the wire electrode material
    Remedy:Use the correct wirefeed components
    Poor wirefeeding
    Cause:Depending on the system, brake force in wirefeeder or power source set too high
    Remedy:Reduce the brake force
    Cause:Hole in the contact tip is displaced
    Remedy:Change the contact tip
    Cause:The inner liner or wire-guide insert is defective
    Remedy:Check the inner liner and wire-guide insert for kinks, dirt, etc.
    Change the defective inner liner or wire-guide insert
    Cause:The feed rollers are not suitable for the wire electrode being used
    Remedy:Use suitable wirefeeder rollers
    Cause:Wirefeeder rollers have the wrong contact pressure
    Remedy:Optimise contact pressure
    Cause:The wirefeeder rollers are soiled or damaged
    Remedy:Clean or replace wirefeeder rollers
    Cause:Inner liner wrongly fitted or kinked
    Remedy:Replace inner liner
    Cause:The inner liner has been cut too short
    Remedy:Replace the inner liner and cut the new inner liner to the correct length
    Cause:Wire electrode worn due to excessive contact pressure on the wirefeeder rollers
    Remedy:Reduce contact pressure on the wirefeeder rollers
    Cause:Wire electrode contains impurities or is corroded
    Remedy:Use high-quality wire electrode with no impurities
    Cause:For steel inner liners: use of uncoated inner liner
    Remedy:Use a coated inner liner
    Cause:Clamping nipple in wire entry and wire exit area deformed (oval, knocked out), shielding gas escaping at clamping nipple
    Remedy:Replace clamping nipple to ensure a gas-tight seal
    The gas nozzle becomes very hot
    Cause:No thermal dissipation as the gas nozzle is too loose
    Remedy:Screw on the gas nozzle as far as it will go
    The welding torch becomes very hot
    Cause:Only on Multilock welding torches: torch neck union nut is loose
    Remedy:Tighten the union nut
    Cause:Welding torch operated above the maximum welding current
    Remedy:Reduce welding power or use a more powerful welding torch
    Cause:The specification of the welding torch is inadequate
    Remedy:Observe the duty cycle and loading limits
    Cause:Only on water-cooled systems: Inadequate coolant flow
    Remedy:Check coolant level, coolant flow, coolant contamination, the routing of the hosepack, etc.
    Cause:The tip of the welding torch is too close to the arc
    Remedy:Increase stick-out
    Contact tip has a short service life
    Cause:Incorrect wirefeeder rollers
    Remedy:Use correct wirefeeder rollers
    Cause:Wire electrode contains impurities/is corroded
    Cause:Uncoated wire electrode
    Remedy:Use wire electrode with suitable coating
    Cause:Wrong dimension of contact tip
    Remedy:Use a contact tip of the correct dimension
    Cause:Duty cycle of welding torch has been exceeded
    Remedy:Shorten the duty cycle or use a more powerful welding torch
    Cause:Contact tip has overheated. No thermal dissipation as the contact tip is too loose
    Remedy:Tighten the contact tip
    NOTE!
    When using CrNi, the contact tip may be subject to a higher degree of wear due to the nature of the surface of the CrNi wire electrode.
    Torch trigger malfunction
    Cause:Defective plug connection between welding torch and power source
    Remedy:Establish proper plug connections / have power source or welding torch serviced
    Cause:Build up of dirt between torch trigger and torch trigger housing
    Remedy:Clean away the dirt
    Cause:Control line is faulty
    Weld seam porosity
    Cause:Spatter build-up in the gas nozzle causing inadequate gas shield for weld seam
    Cause:Holes in gas hose or hose is not connected properly
    Remedy:Replace gas hose
    Cause:O-ring on central connector has been cut or is faulty
    Remedy:Replace O-ring
    Cause:Moisture/condensation in the gas line
    Remedy:Dry gas line
    Cause:Gas flow is either too high or too low
    Remedy:Correct gas flow
    Cause:Insufficient gas flow at start or end of welding
    Remedy:Increase gas pre-flow and gas post-flow
    Cause:Rusty or poor quality wire electrode
    Cause:For gas-cooled welding torches: gas is escaping through a non-insulated inner liner
    Remedy:Use only insulated inner liners with gas-cooled welding torches
    Cause:Too much parting agent applied
    Remedy:Remove excess parting agent/apply less parting agent
    Technical data
    General
    Voltage measurement (V-Peak):
    • for manually-operated welding torches: 113 V
    • for mechanically-driven welding torches: 141 V
    Torch trigger technical data:
    • Umax = 5 V
    • Imax = 10 mA
    The torch trigger may only be operated in accordance with the technical data.
    The product conforms to the requirements of IEC 60974-7 / - 10 Class A.
    1. Technical data
    General
    • Umax = 5 V
    • Imax = 10 mA
    1. Technical data
    MTG 250i
    MTG 320i
    I (ampere) 10 min/40°C
    M21+C1 (EN ISO 14175)
    40% ED* 250
    60% ED* 200
    100% ED* 170
    40% ED* 320
    60% ED* 260
    100% ED* 210
    [mm]
    [in.]
    0.8-1.2
    0.032-0.047
    0.8-1.6
    0.032-0.063
    [m]
    [ft.]
    3.5/4.5
    12/15
    3.5/4.5
    12/15
    *ED = Duty cycle
    MTG 250i TT-SH
    Torch body position FRONT
    40% ED* 250
    60% ED* 200
    100% ED* 170
    [mm]
    [in.]
    0.8-1.2
    0.032-0.047
    [m]
    [ft.]
    3.5/4.5
    12/15
    *ED = Duty cycle
    When the torch body is in the REAR position, the duty cycle values are reduced by up to 20%.
    MTG 400i
    MTG 550i
    C1 (EN ISO 14175)
    30% ED* 550
    M21 (EN ISO 14175)
    30% ED* 520
    40% ED* 400
    60% ED* 320
    100% ED* 260
    60% ED* 420
    100% ED* 360
    [mm]
    [in.]
    0.8-1.6
    0.032-0.063
    1.2-1.6
    0.047-0.063
    [m]
    [ft.]
    3.5/4.5
    12/15
    3.5/4.5
    12/15
    *ED = Duty cycle
    1. Technical data
    MHP 250i G ML
    MHP 400i G ML
    40% ED* 250
    60% ED* 200
    100% ED* 170
    40% ED* 400
    60% ED* 300
    100% ED* 260
    [mm]
    [in.]
    0.8-1.2
    0.032-0.047
    0.8-1.6
    0.032-0.063
    [m]
    [ft.]
    3.35/4.35
    11/14
    3.35/4.35
    11/14
    *ED = Duty cycle
    MHP 550i G ML
    C1 (EN ISO 14175)
    30% ED* 550
    M21 (EN ISO 14175)
    30% ED* 520
    60% ED* 420
    100% ED* 360
    [mm]
    [in.]
    1.2-1.6
    0.047-0.063
    [m]
    [ft.]
    3.35/4.35
    11/14
    *ED = Duty cycle
    1. Technical data
    MTB 200i G ML
    MTB 250i G ML
    40% ED* 200
    60% ED* 180
    100% ED* 160
    40% ED* 250
    60% ED* 200
    100% ED* 170
    [mm]
    [in.]
    1.0-1.2
    0.039-0.047
    0.8-1.2
    0.032-0.047
    *ED = Duty cycle
    MTB 320i G ML
    MTB 330i G ML
    40% ED* 320
    60% ED* 260
    100% ED* 210
    40% ED* 330
    60% ED* 270
    100% ED* 220
    [mm]
    [in.]
    0.8-1.6
    0.032-0.063
    0.8-1.6
    0.032-0.063
    *ED = Duty cycle
    MTB 400i G ML
    MTB 550i G ML
    C1 (EN ISO 14175)
    30% ED* 550
    M21 (EN ISO 14175)
    30% ED* 520
    40% ED* 400
    60% ED* 320
    100% ED* 260
    60% ED* 420
    100% ED* 360
    [mm]
    [in.]
    0.8-1.6
    0.032-0.063
    0.8-1.6
    0.032-0.063
    *ED = Duty cycle
    1. Technical data
    MTW 250i / TT-SH
    MTW 400i / TT-SH
    100% ED* 250
    100% ED* 400
    [mm]
    [in.]
    0.8-1.2
    0.032-0.047
    0.8-1.6
    0.032-0.063
    [m]
    [ft.]
    3.5/4.5
    12/15
    3.5/4.5/6
    12/15/20
    550/600 W
    1200/1500/1300 W
    0.26
    0.26
    3 bar
    43 psi.
    3 bar
    43 psi.
    5 bar
    72 psi.
    5 bar
    72 psi.
    *ED = Duty cycle
    **Lowest cooling capacity according to IEC 60974-2
    MTW 500i
    MTW 700i
    100% ED* 500
    100% ED* 700
    [mm]
    [in.]
    1.0-1.6
    0.039-0.063
    1.0-1.6
    0.039-0.063
    [m]
    [ft.]
    3.5/4.5/6
    12/15/20
    3.5/4.5
    12/15
    1400/1700/2000 W
    1800/2200 W
    0.26
    0.26
    3 bar
    43 psi.
    3 bar
    43 psi.
    5 bar
    72 psi.
    5 bar
    72 psi.
     *ED = Duty cycle
    1. Technical data
    MHP 400i W ML TT-SH
    100% ED* 400
    [mm]
    [in.]
    0.8-1.6
    0.032-0.063
    [m]
    [ft.]
    3.35/4.35/5.85
    11/14/19
    1200/1500/1300 W
    0.26
    3 bar
    43 psi.
    5 bar
    72 psi.
    *ED = Duty cycle
    MHP 500i W ML
    MHP 700i W ML
    100% ED* 500
    100% ED* 700
    [mm]
    [in.]
    0.8-1.6
    0.032-0.063
    1.0-1.6
    0.039-0.063
    [m]
    [ft.]
    3.35/4.35/5.85
    11/14/19
    3.35/4.35
    11/14
    1400/1700/2000 W
    1800/2200 W
    0.26
    0.26
    3 bar
    43 psi.
    3 bar
    43 psi.
    5 bar
    72 psi.
    5 bar
    72 psi.
    *ED = Duty cycle
    1. Technical data
    MTB 220i W ML
    MTB 250i W ML
    100% ED* 220
    100% ED* 250
    [mm]
    [in.]
    1.0-1.2
    0.039-0.047
    0.8-1.2
    0.032-0.047
    0.26
    0.26
    *ED = Duty cycle
    MTB 330i W ML
    MTB 400i W ML
    100% ED* 330
    100% ED* 400
    [mm]
    [in.]
    0.8-1.6
    0.032-0.063
    0.8-1.6
    0.032-0.063
    0.26
    0.26
    *ED = Duty cycle
    MTB 500i W ML
    MTB 700i W ML
    100% ED* 500
    100% ED* 700
    [mm]
    [in.]
    1.0-1.6
    0.039-0.063
    1.0-1.6
    0.039-0.063
    0.26
    0.26
    *ED = Duty cycle
