TU Car 4 Basic |
| TU Car 4 Standard |
TU Car 4 Basic |
| TU Car 4 Standard |
Danger from welding system topples over.
The welding system plus trolley must not exceed a combined height of 880 mm (34.646 inch).
The trolley must not be used if the combined height is greater than 880 mm (34.646 inch).
The brakes on the swivel casters are designed only to keep the trolley stationary on a level surface.
Danger from falling gas cylinder.
Secure the gas cylinder firmly on the trolley.
Always lash the gas cylinder down with both straps of the gas cylinder holder.
Only use gas cylinders with a maximum capacity of 20 litres.
Observe the safety rules of the gas cylinder manufacturer.
Danger from electric current.
Secure all the devices and components involved to prevent unintentional restarting.
Danger from machines toppling over or falling.
Set up the device securely on an even, solid surface.
Check all screw connections are tightly fastened after installation.
| (1) | TPS/i, TSt |
| (2) | TPS, TT/MW 4000 |
| (3) | iWave 190i, iWave 230i |
| (4) | TT/MW 2500 - 3000 |
Use the screws supplied with the trolley to secure the welding machine to the trolley.
Use the screws supplied with the trolley to secure the bottom system component to the trolley.
Danger from devices being dropped or falling over.
After fitting, ensure that all system components are screwed together tightly.
