LogoMHP 280i G PM, MHP 320i W PM
  • en
    • Contact
    • Legal Notice
    • General Terms & Conditions
    • Data Privacy Statement
    • Cookie Policy
    • 021-16072024
    • General
      • General
      • Functions of the torch trigger
      • Up/Down-function
      • JobMaster-function
      • Proper use
    • Safety
      • Safety
    • Start-up
      • MTG d, MTW d - Fitting wearing parts to the torch body
      • Note regarding the inner liner with gas-cooled welding torches
      • Checking the clamping nipple
      • Inserting a steel inner liner into the torch body
      • Inserting a plastic inner liner into the torch body
      • Fitting wearing parts inside the hosepack
      • Fitting the inner liner inside the hosepack
      • Attaching the torch body
      • Connecting the welding torch to the wirefeeder
      • Threading the wire electrode
      • Setting the contact pressure
    • Changing the torch neck, rotating the torch neck
      • Changing the torch body
      • Rotating the torch body
    • Care, maintenance and disposal
      • General
      • Maintenance at every start-up
      • Every time the wirespool/basket-type spool is changed
      • Recognising faulty wearing parts
      • Changing the wirefeeding nozzle
      • Changing the infeed nozzle
      • Changing the feed rollers
    • Troubleshooting
      • Troubleshooting
    • Technical data
      • General
      • Gas-cooled welding torch - MHP 280i G PM
      • Water-cooled welding torch - MHP 320i W PM
    • Appendix
      • CircuitDiagram: MHP 280i G PM, MHP 320i W PM
    MHP 280i G PM, MHP 320i W PM Operating Instructions
    Spare Parts
    General
    General
    Welding torches with integrated wire drives are suitable for MIG/MAG manual welding with long hosepacks, particularly when soft filler metals are being used. Two geared precision rollers ensure power is transmitted over a large area. This provides outstanding wirefeed characteristics, even when using very soft aluminium or CuSi wire electrodes and very long hosepacks.
    The welding torches are particularly robust and reliable, with an ergonomic grip, ball joint and perfect weight distribution for fatigue-free working.
    Available as gas-cooled and water-cooled versions and in conjunction with the available Multilock torch necks, the welding torches can be used in an extremely wide range of applications. They are ideal for manual batch and single-piece production as well as for jobs in the workshop.
    1. General
    General
    1. General
    The torch trigger on the welding torch has two switching positions.
    Welding torch functions in switching position 1 (torch trigger half pressed):
    • LED illuminated
    Welding torch functions in switching position 2 (torch trigger fully pressed):
    • LED goes out
    • Welding start-up
    1. General
    Up/Down-function
    The Up/Down torch has the following functions:
    • Changes the welding power in Synergic operation via the Up/Down buttons
    • Error display:
      • all the LEDs light up red if there is a system fault
      • all the LEDs flash red if there is a data communication fault
    • Self-test during the run-up sequence:
      • all LEDs light up briefly one after the other
    1. General
    JobMaster-function
    The JobMaster welding torch has the following functions:
    • The desired welding parameter on the power source can be selected using the arrow buttons
    • The selected welding parameter can be changed using the +/- buttons
    • The display shows the current welding parameter and value
    1. General
    Proper use
    The MIG/MAG manual welding torch is intended solely for MIG/MAG welding in manual applications.
    Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
    Proper use includes:
    • Carefully reading and following all the instructions given in the operating instructions
    • Performing all stipulated inspection and maintenance work.
    Safety
    The welding torch is fitted with safety symbols and a rating plate. The rating plate and safety symbols must not be removed or painted over. The symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage.
    Rating plate with safety symbols
    Warning of moving parts
    • The enclosed "Safety rules" document
    • All the Operating Instructions for the system components, especially the safety rules
    Welding is dangerous. The following basic requirements must be met to ensure the equipment is used properly:
    • Welders must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved must be kept at a safe distance from the welding torch and the welding process
    Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules.
    Keep hands, hair, clothing and tools away from moving parts. For example:
    • Cogs
    • Feed rollers
    • Wirespools and wire electrodes
    Do not reach into the rotating feed rollers of the wire drive or into rotating drive components.
    The cover of the welding torch may only be opened while maintenance or repair work is being carried out.
    During operation
    • Ensure that the cover is closed.
    • Keep the cover closed.
    1. Safety
    • Cogs
    • Feed rollers
    During operation
    1. Safety
    Safety
    WARNING!
    WARNING!
    Danger from electric current.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, lines and hosepacks must be properly connected, undamaged, correctly insulated and adequately dimensioned at all times.
    CAUTION!
    Risk of burns from hot welding torch components and hot coolant.
    This can result in scalding.
    Before commencing any of the work described in this document, allow all welding torch components and the coolant to cool to room temperature (+25°C, +77°F).
    CAUTION!
    Danger from operation of water-cooled welding torches without coolant.
    Never operate a water-cooled welding torch without coolant.
    During welding, ensure that the coolant is circulating correctly – this will be the case if a regular return flow of coolant can be seen in the coolant container of the cooling unit.
    The manufacturer will not be liable for any damages due to non-observance of the above mentioned points, and all claims against the warranty shall be void.
    CAUTION!
    Risk of coolant escaping.
    This can result in injury and damage to property.
    Seal the coolant hoses on water-cooled welding torches with the plastic stoppers fitted to them if the hoses are detached from the cooling unit or other system components.
    CAUTION!
    Risk of injury from moving parts.
    Close the cover over the feed rollers before using the welding torch.
    Start-up
    Screw on and tighten the gas nozzle as far as it will go
    1. Start-up
    1. Start-up
    NOTE!
    If a plastic inner liner is used in the torch body of a gas-cooled welding torch, reduce the power figure shown in the technical data by 30%.
    To operate gas-cooled welding torches at maximum power, use a steel inner liner in the torch body.
    1. Start-up
    Left: brass clamping nipple with seal ring. Right: silver clamping nipple without seal ring.
    * Check the clamping nipple before commissioning and whenever the inner liner is changed. To do so, carry out a visual inspection:
    • Left: brass clamping nipple with seal ring. You cannot see through the seal ring.
    • Right: silver clamping nipple with see-through bushing
    NOTE!
    Incorrect or defective clamping nipple in push applications
    Causes gas loss and poor weld properties
    use brass clamping nipples to minimise gas loss
    check that the seal ring is intact
    NOTE!
    Incorrect clamping nipple in push-pull applications
    Tangled wire and increased abrasion in the inner liner when using a clamping nipple with seal ring
    use silver clamping nipple to facilitate wirefeeding
    1. Start-up
    * Use the cutting pipe of the welding torch
    1. Start-up
    1. Start-up
    5
    6
    7
    8
    9
    10
    Push in infeed nozzle as far as it will go
    1. Start-up
    NOTE!
    Ensure that the hosepack is straight when fitting the inner liner, otherwise the liner might not be inserted correctly.
    Insert inner liner as far as it will go into the infeed nozzle (1)
    5
    6
    Steel inner liner
    Plastic inner liner
    7
    8
    Screw the cap onto the inner liner as far as it will go. The inner liner must be visible through the hole in the cap.
    9
    NOTE!
    Steel inner liners with an outer diameter of less than 1 mm (0.039 in.) cannot be screwed into the welding torch - the specified tightening torque therefore does not apply to these liners.
    All other inner liners must be screwed into the welding torch and tightened to the specified tightening torque.
    10
    1. Start-up
    CAUTION!
    Risk of damage to the welding torch.
    Always tighten the union nut on the torch body as far as it will go.
    NOTE!
    Before fitting a torch body, ensure that the interface between the torch body and the hosepack is clean and undamaged.
    NOTE!
    In the case of water-cooled welding torches, increased resistance may arise when tightening the union nut due to the construction of the welding torch.
    This is normal. Always tighten the union nut on the torch body as far as it will go.
    NOTE!
    The torch body is in the 0° position when the dowel pin (1) on the hosepack engages in the locating hole (2) in the torch body.
    Ensure that the union nut is tightened as far as it will go.
    1. Start-up
    1. Start-up
    Only if the optional coolant connections are fitted in the cooling unit and when using a water-cooled welding torch.
    Always connect the coolant hoses according to their colour coding.
    1. Start-up
    CAUTION!
    Risk of injury and damage from the welding current and accidental ignition of an arc.
    Before starting work, disconnect the ground earth connection between the welding system and the workpiece.
    CAUTION!
    Risk of damage to the welding torch from sharp end of wire electrode.
    Deburr the end of the wire electrode well before threading in.
    CAUTION!
    Risk of injury due to springiness of spooled wire electrode.
    When inserting the wire electrode into the 4-roller drive of the wirefeeder, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Risk of injury and damage from wire electrode emerging.
    While working:
    Hold the welding torch with the end directed away from the face and body
    Wear suitable protective goggles
    Do not point the welding torch at people
    Make sure that the wire electrode does not touch any conductive or earthed parts (e.g. housing)
    NOTE!
    Before feeding in the wire electrode, lay out the hosepack in a straight line as shown below.
    Maximum permitted feeder inching speed = 10 m/s.
    5
    1. Start-up
    Use the values shown on the illustration on the inside of the cover as standard values when setting the contact pressure.
    NOTE!
    The contact pressure is set as follows:
    Turn screw clockwise = reduce the contact pressure,
    maximum load moment = gently as far as stop - turn the screw until the contact pressure indicator is in the 'min' position
    Turn screw anti-clockwise = increase the contact pressure,
    maximum load moment = 0.4 Nm - turn the screw until the contact pressure indicator is in the 'max' position
    CAUTION!
    Risk of burns from hot coolant and hot torch body.
    Before carrying out any work, allow the coolant and torch body to cool to room temperature (+25 °C, +77 °F).
    NOTE!
    Some coolant will always remain in the torch body.
    Only remove the torch body with the gas nozzle pointing downwards.
    NOTE!
    NOTE!
    1. Changing the torch neck, rotating the torch neck
    CAUTION!
    NOTE!
    NOTE!
    NOTE!
    CAUTION!
    * Ensure that the union nut is tightened as far as it will go.
    General
    Regular preventive maintenance of the welding torch is essential if trouble-free operation is to be ensured. The welding torch is subjected to high temperatures and heavy soiling. The welding torch therefore requires more frequent maintenance than other components in the welding system.
    CAUTION!
    Risk of damage from improper handling of the welding torch.
    This can result in severe damage to property.
    Do not strike the welding torch on hard objects.
    Avoid scoring and scratches on the contact tip.
    Do not bend the torch body under any circumstances.
    1. Care, maintenance and disposal
    General
    CAUTION!
    • Check wearing parts
      • replace faulty wearing parts
    • Remove welding spatter from gas nozzle
    Check the gas nozzle, spatter guard and insulation for damage and replace any damaged components.
    • Also at every start-up when using water-cooled welding torches:
      • check all coolant connections for tightness (no leaks)
      • check that the coolant can flow unhindered
    Every time the wirespool/basket-type spool is changed:
    • Clean wirefeeding hose with reduced compressed air
    • Recommended: replace the inner liner. Clean the wearing parts before fitting the new inner liner
    1. Insulating parts
      • Burned-off outside edges, notches
    2. Nozzle fittings
      • Heavily covered in welding spatter
    3. Spatter guard
    4. Contact tips
      • Worn-out (oval) wire entry and wire exit holes
      • Penetration on the tip of the contact tip
    5. Gas nozzles
      • Notches
    1Remove the wire electrode from the hosepack
    5
    6
    7
    8
    9
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    NOTE!
    17
    NOTE!
    Always change feed rollers in pairs.
    Only use feed rollers that match the wire diameter used and the wire alloy.
    An overview of available feed rollers can be found in the Spare Parts Lists.
    NOTE!
    To tighten the new feed rollers, use the screws supplied with the new rollers.
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    Turn the feed roller onto the drive until the splines on the feed roller engage in the grooves on the drive.
    15
    16
    17
    Troubleshooting
    Troubleshooting
    1. Troubleshooting
    Troubleshooting
    No welding current
    Power source mains switch is on, indicators on the power source are lit up, shielding gas available
    Cause:Grounding (earthing) connection is incorrect
    Remedy:Establish a proper grounding (earthing) connection
    Cause:There is a break in the current cable in the welding torch
    Remedy:Replace welding torch
    Nothing happens when the torch trigger is pressed
    Cause:The FSC ('Fronius System Connector' central connector) is not plugged in properly
    Remedy:Push on the FSC as far as it will go
    Cause:Welding torch or welding torch control line is faulty
    Cause:Interconnecting hosepack faulty or not connected properly
    Remedy:Connect interconnecting hosepack properly
    Replace faulty interconnecting hosepack
    Cause:Faulty power source
    Remedy:Contact After-Sales Service
    No shielding gas
    All other functions are OK
    Cause:Gas cylinder is empty
    Remedy:Change the gas cylinder
    Cause:Gas pressure regulator is faulty
    Remedy:Replace gas pressure regulator
    Cause:The gas hose is not connected, or is damaged or kinked
    Remedy:Fit gas hose, lay out straight Replace faulty gas hose
    Cause:Welding torch is faulty
    Cause:Gas solenoid valve is faulty
    Remedy:Contact After-Sales Service (arrange for gas solenoid valve to be replaced)
    Poor weld properties
    Cause:Incorrect welding parameters
    Remedy:Correct settings
    Cause:Poor grounding (earthing) connection
    Remedy:Ensure good contact to workpiece
    Cause:Too little or no shielding gas
    Remedy:Check the pressure regulator, gas hose, gas solenoid valve and welding torch shielding gas connection. On gas-cooled welding torches, inspect the gas seals, use a suitable inner liner
    Cause:Welding torch is leaking
    Cause:Contact tip is too large or worn out
    Remedy:Replace contact tip
    Cause:Wrong wire alloy or wrong wire diameter
    Remedy:Check wirespool/basket-type spool in use
    Remedy:Check weldability of the base material
    Cause:The shielding gas is not suitable for this wire alloy
    Remedy:Use the correct shielding gas
    Cause:Unfavourable welding conditions: shielding gas is contaminated (by moisture, air), inadequate gas shield (weld pool "boiling", draughts), contaminants in the workpiece (rust, paint, grease)
    Remedy:Optimise the welding conditions
    Cause:Shielding gas escaping at clamping nipple
    Remedy:Use the correct clamping nipple
    Cause:Clamping nipple seal ring defective, shielding gas escaping at clamping nipple
    Remedy:Replace clamping nipple to ensure a gas-tight seal
    Cause:Welding spatter in the gas nozzle
    Remedy:Remove welding spatter
    Cause:Turbulence caused by too high a rate of shielding gas flow
    Remedy:Reduce shielding gas flow rate, recommended:
    shielding gas flow rate (l/min) = wire diameter (mm) x 10
    (e.g. 16 l/min for 1.6 mm wire electrode)
    Cause:Distance between the welding torch and the workpiece too great
    Remedy:Reduce the distance between the welding torch and the workpiece (approx. 10 - 15 mm / 0.39 - 0.59 in.)
    Cause:Tilt angle of the welding torch is too great
    Remedy:Reduce the tilt angle of the welding torch
    Cause:Wirefeed components do not match the diameter of the wire electrode/wire electrode material
    Remedy:Use the correct wirefeed components
    Poor wirefeeding
    Cause:Depending on the system, brake force in wirefeeder or power source set too high
    Remedy:Reduce the brake force
    Cause:Hole in the contact tip is displaced
    Remedy:Change the contact tip
    Cause:The inner liner or wire-guide insert is defective
    Remedy:Check the inner liner and wire-guide insert for kinks, dirt, etc.
    Change the defective inner liner or wire-guide insert
    Cause:The feed rollers are not suitable for the wire electrode being used
    Remedy:Use suitable wirefeeder rollers
    Cause:Wirefeeder rollers have the wrong contact pressure
    Remedy:Optimise contact pressure
    Cause:The wirefeeder rollers are soiled or damaged
    Remedy:Clean or replace wirefeeder rollers
    Cause:Inner liner wrongly fitted or kinked
    Remedy:Replace inner liner
    Cause:The inner liner has been cut too short
    Remedy:Replace the inner liner and cut the new inner liner to the correct length
    Cause:Wire electrode worn due to excessive contact pressure on the wirefeeder rollers
    Remedy:Reduce contact pressure on the wirefeeder rollers
    Cause:Wire electrode contains impurities or is corroded
    Remedy:Use high-quality wire electrode with no impurities
    Cause:For steel inner liners: use of uncoated inner liner
    Remedy:Use a coated inner liner
    Cause:Clamping nipple in wire entry and wire exit area deformed (oval, knocked out), shielding gas escaping at clamping nipple
    The gas nozzle becomes very hot
    Cause:No thermal dissipation as the gas nozzle is too loose
    Remedy:Screw on the gas nozzle as far as it will go
    The welding torch becomes very hot
    Cause:Only on Multilock welding torches: torch neck union nut is loose
    Remedy:Tighten the union nut
    Cause:Welding torch operated above the maximum welding current
    Remedy:Reduce welding power or use a more powerful welding torch
    Cause:The specification of the welding torch is inadequate
    Remedy:Observe the duty cycle and loading limits
    Cause:Only on water-cooled systems: Inadequate coolant flow
    Remedy:Check coolant level, coolant flow, coolant contamination, the routing of the hosepack, etc.
    Cause:The tip of the welding torch is too close to the arc
    Remedy:Increase stick-out
    Contact tip has a short service life
    Cause:Incorrect wirefeeder rollers
    Remedy:Use correct wirefeeder rollers
    Cause:Wire electrode contains impurities/is corroded
    Cause:Uncoated wire electrode
    Remedy:Use wire electrode with suitable coating
    Cause:Wrong dimension of contact tip
    Remedy:Use a contact tip of the correct dimension
    Cause:Duty cycle of welding torch has been exceeded
    Remedy:Shorten the duty cycle or use a more powerful welding torch
    Cause:Contact tip has overheated. No thermal dissipation as the contact tip is too loose
    Remedy:Tighten the contact tip
    NOTE!
    When using CrNi, the contact tip may be subject to a higher degree of wear due to the nature of the surface of the CrNi wire electrode.
    Torch trigger malfunction
    Cause:Defective plug connection between welding torch and power source
    Remedy:Establish proper plug connections / have power source or welding torch serviced
    Cause:Build up of dirt between torch trigger and torch trigger housing
    Remedy:Clean away the dirt
    Cause:Control line is faulty
    Weld seam porosity
    Cause:Spatter build-up in the gas nozzle causing inadequate gas shield for weld seam
    Cause:Holes in gas hose or hose is not connected properly
    Remedy:Replace gas hose
    Cause:O-ring on central connector has been cut or is faulty
    Remedy:Replace O-ring
    Cause:Moisture/condensation in the gas line
    Remedy:Dry gas line
    Cause:Gas flow is either too high or too low
    Remedy:Correct gas flow
    Cause:Insufficient gas flow at start or end of welding
    Remedy:Increase gas pre-flow and gas post-flow
    Cause:Rusty or poor quality wire electrode
    Cause:For gas-cooled welding torches: gas is escaping through a non-insulated inner liner
    Remedy:Use only insulated inner liners with gas-cooled welding torches
    Cause:Too much parting agent applied
    Remedy:Remove excess parting agent/apply less parting agent
    Technical data
    General
    Voltage measurement (V-Peak):
    • for manually-operated welding torches: 113 V
    • for mechanically-driven welding torches: 141 V
    Torch trigger technical data:
    • Umax = 5 V
    • Imax = 10 mA
    The torch trigger may only be operated in accordance with the technical data.
    The product conforms to the requirements of IEC 60974-7 / - 10 Class A.
    1. Technical data
    General
    • Umax = 5 V
    • Imax = 10 mA
    1. Technical data
    I (ampere) 10 min/40°C
    M21+C1 (EN ISO 14175)
    40% D.C.* / 280 A
    60% D.C.* / 220 A
    100% D.C.* / 170 A
    0.8-1.6
    0.031-0.063
    5.85 / 7.85 / 9.85
    19 / 26 / 29
    0.55 A RMS
    27 V AC
    1-20 m/min
    0.039-0.0787 ipm
    * D.C. = Duty cycle
    1. Technical data
    100% D.C.* / 320 A
    0.8-1.6
    0.031-0.063
    5.85 / 7.85 / 9.85
    19 / 26 / 29
    700 / 850 / 1000
    0.26
    43.51
    5.5
    77.77
    0.55 A RMS
    27 V AC
    1-20 m/min
    0.039-0.0787 ipm
    D.C. = Duty cycle
    Lowest cooling power as per IEC 60974-2
    Appendix
    1. Appendix
