The MIG/MAG manual welding torch is intended exclusively for MIG/MAG welding in manual applications. Utilisation for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended use.
Intended use also includes:The device has been manufactured in line with the state of the art and according to recognized safety standards.
Intended use also includes:Danger from incorrect operation and work that is not carried out properly.
Danger from electric current.
Secure all the devices and components involved to prevent unintentional restarting.
Danger from electric current due to defective system components and incorrect operation.
All cables, leads and hosepacks must always be securely connected, undamaged and correctly insulated.
Only use adequately dimensioned cables, leads and hosepacks.
Danger due to contact with toxic welding fume.
This can result in serious personal injury.
Always extract welding fume.
Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³/h (11.77 cfm) at all times.
If in doubt, a safety engineer should be commissioned to check the pollution level in the workplace.
Danger due to hot system components and/or equipment.
This can result in burns or scalding.
Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
Danger due to operation without coolant.
Never operate water-cooled devices without coolant.
During welding, ensure that there is a proper coolant flow. When using Fronius cooling units, this is the case if a proper coolant return flow can be seen in the coolant container of the cooling unit.
Risk of coolant escaping.
This can result in injury and damage to property.
Seal the coolant hoses on water-cooled welding torches with the plastic stoppers fitted to them if the hoses are detached from the cooling unit or other system components.
Danger from the fumes produced during welding, which contain harmful gases and vapours.
These can cause severe damage to health.
A welding operation is not permitted without an extraction unit that is switched on.
Under certain circumstances, the sole use of a fume extraction torch is not sufficient.
In this case, install an additional extractor to reduce the pollution level in the workplace.
IMPORTANT! In the "MIG/MAG Standard Synergic and Pulse Synergic Welding" operating modes, extra parameters can be set.
IMPORTANT! Coded messages can appear on the JobMaster.
These correspond to the service code displayed on the control panel at the same time (see the "Troubleshooting" section of the welding machine operating instructions).
SynchroPulse (option) - no symbol lights up on the JobMaster (see the "MIG/MAG welding" section of the welding machine operating instructions).
TT-SH with straight torch handle and torch trigger at top
| ** | Screw on and tighten the gas nozzle as far as it will go |
Tightening torques:
Risk of damage to the welding torch. Always tighten the union nut on the torch body as far as it will go.
In the case of water-cooled welding torches, increased resistance may arise when tightening the union nut due to the construction of the welding torch. This is normal. Always tighten the union nut on the torch body as far as it will go.
Before fitting a torch body, ensure that the interface between the torch body and the hosepack is clean and undamaged.
The torch body is in the 0° position when the dowel pin (A) on the hosepack engages in the locating hole (B) in the torch body.
| * | Ensure that the union nut is tightened as far as it will go. |
| * | IMPORTANT! Check the clamping nipple before commissioning and every time the inner liner is changed. |
* Carry out a visual inspection for this purpose:
Incorrect or defective clamping nipple for push applications
Gas loss and poor weld properties will result.
Use brass clamping nipples to minimise gas loss.
Check that the sealing disc is intact.
Incorrect clamping nipple for push-pull applications
Wire winder and increased abrasion in the inner liner when using a clamping nipple with sealing disc.
Use the silver clamping nipple to facilitate wire feeding.
Round off the end of the wire electrode before feeding it in.
| * | LocalNet plug (Standard or Up/Down welding torches) |
| ** | JobMaster plug (JobMaster welding torches) |
Risk of burns from hot coolant and hot torch body.
Before carrying out any work, allow the coolant and torch body to cool to room temperature (+25°C, +77°F).
This can result in severe scalds.
Some coolant will always remain in the torch body.
Only remove the torch body with the gas nozzle pointing downwards.
Ensure that the machine welding torch to be worked on is only ever clamped in a suitable Prisma holder.
Regular preventive maintenance of the welding torch is essential if trouble-free operation is to be ensured. The welding torch is subjected to high temperatures and heavy soiling. The welding torch therefore requires more frequent maintenance than other components in the welding system.
Risk of damage from improper handling of the welding torch.
This can result in severe damage to property.
Do not strike the welding torch on hard objects.
Avoid scoring and scratches on the contact tip.
Do not bend the torch body under any circumstances.
| * | Check the gas nozzle, spatter guard and insulation for damage and replace any damaged components. |
| Cause: | Grounding (earthing) connection is incorrect |
| Remedy: | Establish a proper grounding (earthing) connection |
| Cause: | There is a break in the current cable in the welding torch |
| Remedy: | Replace welding torch |
| Cause: | The FSC ('Fronius System Connector' central connector) is not plugged in properly |
| Remedy: | Push on the FSC as far as it will go |
| Cause: | Welding torch or welding torch control line is faulty |
| Cause: | Interconnecting hosepack faulty or not connected properly |
| Remedy: | Connect interconnecting hosepack properly Replace faulty interconnecting hosepack |
| Cause: | Faulty power source |
| Remedy: | Contact After-Sales Service |
| Cause: | Gas cylinder is empty |
| Remedy: | Change the gas cylinder |
| Cause: | Gas pressure regulator is faulty |
| Remedy: | Replace gas pressure regulator |
| Cause: | The gas hose is not connected, or is damaged or kinked |
| Remedy: | Fit gas hose, lay out straight Replace faulty gas hose |
| Cause: | Welding torch is faulty |
| Cause: | Gas solenoid valve is faulty |
| Remedy: | Contact After-Sales Service (arrange for gas solenoid valve to be replaced) |
| Cause: | Incorrect welding parameters |
| Remedy: | Correct settings |
| Cause: | Poor ground earth connection |
| Remedy: | Ensure good contact to workpiece |
| Cause: | Inadequate or no shielding gas |
| Remedy: | Check the pressure regulator, gas hose, gas solenoid valve and welding torch shielding gas connection. On gas-cooled welding torches, inspect the gas seals, use a suitable inner liner |
| Cause: | Welding torch is leaking |
| Cause: | Contact tip is too large or worn out |
| Remedy: | Replace contact tip |
| Cause: | Wrong wire alloy or wrong wire diameter |
| Remedy: | Check wirespool/basket-type spool in use |
| Remedy: | Check weldability of the base material |
| Cause: | The shielding gas is not suitable for this wire alloy |
| Remedy: | Use the correct shielding gas |
| Cause: | - Contaminated shielding gas (e.g. due to moisture or air) - Inadequate gas shield (e.g. due to draughts) - Unsteady, oxidising weld pool - Contamination in the workpiece (e.g. rust, paint, grease, coatings) - Arc length too short - Irregularities in the wire feeding (e.g. due to clogged inner liner) |
| Remedy: | Optimise the welding conditions |
| Cause: | Shielding gas loss at the clamping nipple |
| Remedy: | Use the correct clamping nipple |
| Cause: | Clamping nipple sealing disc defective, shielding gas loss at the clamping nipple |
| Remedy: | Replace clamping nipple to ensure gas tightness |
| Cause: | Welding spatter in the gas nozzle |
| Remedy: | Remove welding spatter |
| Cause: | Turbulence caused by too high a rate of shielding gas flow |
| Remedy: | Reduce shielding gas flow rate, recommended: Shielding gas flow rate (l/min) = wire diameter (mm) x 10 (e.g. 16 l/min for 1.6 mm wire electrode) |
| Cause: | Too large a distance between the welding torch and the workpiece |
| Remedy: | Reduce the distance between the welding torch and the workpiece (approx. 10 - 15 mm / 0.39 - 0.59 in.) |
| Cause: | Tilt angle of the welding torch is too great |
| Remedy: | Reduce the tilt angle of the welding torch |
| Cause: | Wirefeed components do not match the diameter of the wire electrode / the wire electrode material |
| Remedy: | Use the correct wirefeed components |
| Cause: | Depending on the system, brake force in wirefeeder or power source set too high |
| Remedy: | Reduce the brake force |
| Cause: | Hole in the contact tip is displaced |
| Remedy: | Change the contact tip |
| Cause: | The inner liner or wire-guide insert is defective |
| Remedy: | Check the inner liner and wire-guide insert for kinks, dirt, etc. Change the defective inner liner or wire-guide insert |
| Cause: | The feed rollers are not suitable for the wire electrode being used |
| Remedy: | Use suitable wirefeeder rollers |
| Cause: | Wirefeeder rollers have the wrong contact pressure |
| Remedy: | Optimise contact pressure |
| Cause: | The wirefeeder rollers are soiled or damaged |
| Remedy: | Clean or replace wirefeeder rollers |
| Cause: | Inner liner wrongly fitted or kinked |
| Remedy: | Replace inner liner |
| Cause: | The inner liner has been cut too short |
| Remedy: | Replace the inner liner and cut the new inner liner to the correct length |
| Cause: | Wire electrode worn due to excessive contact pressure on the wirefeeder rollers |
| Remedy: | Reduce contact pressure on the wirefeeder rollers |
| Cause: | Wire electrode contains impurities or is corroded |
| Remedy: | Use high-quality wire electrode with no impurities |
| Cause: | For steel inner liners: use of uncoated inner liner |
| Remedy: | Use a coated inner liner |
| Cause: | Clamping nipple in wire entry and wire exit area deformed (oval, knocked out), shielding gas escaping at clamping nipple |
| Remedy: | Replace clamping nipple to ensure a gas-tight seal |
| Cause: | No thermal dissipation as the gas nozzle is too loose |
| Remedy: | Screw on the gas nozzle as far as it will go |
| Cause: | Only on Multilock welding torches: torch neck union nut is loose |
| Remedy: | Tighten the union nut |
| Cause: | Welding torch operated above the maximum welding current |
| Remedy: | Reduce welding power or use a more powerful welding torch |
| Cause: | The specification of the welding torch is inadequate |
| Remedy: | Observe the duty cycle and loading limits |
| Cause: | Only on water-cooled systems: Inadequate coolant flow |
| Remedy: | Check coolant level, coolant flow, coolant contamination, the routing of the hosepack, etc. |
| Cause: | The tip of the welding torch is too close to the arc |
| Remedy: | Increase stick-out |
| Cause: | Incorrect wirefeeder rollers |
| Remedy: | Use correct wirefeeder rollers |
| Cause: | Wire electrode contains impurities/is corroded |
| Cause: | Uncoated wire electrode |
| Remedy: | Use wire electrode with suitable coating |
| Cause: | Wrong dimension of contact tip |
| Remedy: | Use a contact tip of the correct dimension |
| Cause: | Duty cycle of welding torch has been exceeded |
| Remedy: | Shorten the duty cycle or use a more powerful welding torch |
| Cause: | Contact tip has overheated. No thermal dissipation as the contact tip is too loose |
| Remedy: | Tighten the contact tip |
NOTE!When using CrNi, the contact tip may be subject to a higher degree of wear due to the nature of the surface of the CrNi wire electrode. | |
| Cause: | Defective plug connection between welding torch and power source |
| Remedy: | Establish proper plug connections / have power source or welding torch serviced |
| Cause: | Build up of dirt between torch trigger and torch trigger housing |
| Remedy: | Clean away the dirt |
| Cause: | Control line is faulty |
| Cause: | Spattering in the gas nozzle causing inadequate gas shield for weld |
| Cause: | Holes in gas hose or hose is not connected properly |
| Remedy: | Replace gas hose |
| Cause: | O-ring on central connector has been cut or is faulty |
| Remedy: | Replace O-ring |
| Cause: | Moisture/condensation in the gas line |
| Remedy: | Dry gas line |
| Cause: | Gas flow is either too high or too low |
| Remedy: | Correct gas flow |
| Cause: | Insufficient gas flow at start or end of welding |
| Remedy: | Increase gas pre-flow and gas post-flow |
| Cause: | Rusty or poor quality wire electrode |
| Cause: | Applies to gas-cooled welding torches: gas is escaping through non-insulated inner liners |
| Remedy: | Use only insulated inner liners with gas-cooled welding torches |
| Cause: | Too much parting agent applied |
| Remedy: | Remove excess parting agent/apply less parting agent |
The torch trigger may only be operated in accordance with the technical data.
The product conforms to the requirements of IEC 60974-7 / - 10 Class A.
MTG 250d | MTG 250d TT-SH | |||
I (ampere) 10 min/40°C | 40% ED* 250 | 40% ED* 250 | ||
I (ampere) 10 min/40°C | 40% ED* 200 | 40% ED* 250 | ||
[mm (in.)] | 0.8-1.2 | 0.8-1.2 | ||
[m (ft.)] | 3.5 / 4.5 | 3.5 / 4.5 | ||
*ED = Duty cycle | ||||
MTG 320d | MTG 400d | MTG 500d | |||
I (ampere) 10 min/40°C | 40% ED* 320 | 40% ED* 400 | 40% ED* 500 | ||
I (ampere) 10 min/40°C | 40% ED* 260 | 40% ED* 320 | 40% ED* 400 | ||
| [mm (in.)] | 0.8-1.6 | 1.0-1.6 | 1.0-1.6 | |
[m (ft.)] | 3.5 / 4.5 | 3.5 / 4.5 | 3.5 / 4.5 | ||
*ED = Duty cycle | |||||
| MTB 200i G ML | MTB 250i G ML | |
[mm] | 1.0-1.2 | 0.8-1.2 | |
| MTB 320i G ML | MTB 330i G ML | |
I (ampere) 10 min/40°C | 40% ED* 320 | 40% ED* 330 | |
[mm] | 0.8-1.6 | 0.8-1.6 | |
| MTB 400i G ML | MTB 550i G ML | |
I (ampere) 10 min/40°C | - | 30% ED* 550 | |
I (ampere) 10 min/40°C | - | 30% ED* 520 | |
I (ampere) 10 min/40°C | 40% ED* 400 | - | |
| MHP 400d G ML | |
I (ampere) 10 min/40°C | 40% ED* 400 | |
I (ampere) 10 min/40°C | 40% ED* 320 | |
[mm (in.)] | 0.8-1.6 (0.032-0.063) | |
[m (ft.)] | 3.35 / 4.35 (11 / 14) | |
| MHP 500d G ML M | |
I (ampere) 10 min/40°C | 40% ED* 500 | |
[m (ft.)] | 1.35 / 2.35 / 3.35 (4.4 / 7.7 / 14) | |
MTW 250d | MTW 400d | MTW 500d | MTW 700d | |||
I (ampere) 10 min/40°C | 100% ED* 250 | 100% ED* 400 | 100% ED* 500 | 100% ED* 700 | ||
I (ampere) 10 min/40°C | 100% ED* 200 | 100% ED* 320 | 100% ED* 400 | 100% ED* 560 | ||
[mm (in.)] | 0.8-1.2 (0.032- | 0.8-1.6 (0.032- | 0.8-1.6 (0.032- | 0.8-1.6 (0.032- | ||
[m (ft.)] | 3.5 / 4.5 | 3.5 / 4.5 / 6 | 3.5 / 4.5 | 3.5 / 4.5 | ||
Pmin | [W]** | 550 / 600 | 1200 / 1500 / | 1400 / | 1800 / 2200 | |
Qmin | [l/min (gal./min)] | 1 (0.26) | 1 (0.26) | 1 (0.26) | 1 (0.26) | |
pmin | [bar (psi.)] | 3 (43) | 3 (43) | 3 (43) | 3 (43) | |
pmax | [bar (psi.)] | 5 (72) | 5 (72) | 5 (72) | 5 (72) | |
*ED = Duty cycle | ||||||
**Lowest cooling capacity according to IEC 60974-2 | ||||||
MTW 250d TT-SH | MTW 400d TT-SH | |||
I (ampere) 10 min/40°C | 100% ED* 250 | 100% ED* 400 | ||
[mm (in.)] | 0.8-1.2 (0.032-0.047) | 0.8-1.6 (0.032-0.063) | ||
[m (ft.)] | 3.5 / 4.5 | 3.5 / 4.5 / 6 | ||
Pmin | [W]** | 550 / 600 | 1200 / 1500 / 1300 | |
Qmin | [l/min (gal./min)] | 1 (0.26) | 1 (0.26) | |
pmin | [bar (psi.)] | 3 (43) | 3 (43) | |
pmax | [bar (psi.)] | 5 (72) | 5 (72) | |
MTB 220i W ML | MTB 250i W ML | ||
I (ampere) 10 min/40°C | 100% ED* 220 | 100% ED* 250 | |
1 | 1 | ||
MTB 330i W ML | MTB 400i W ML | ||
I (ampere) 10 min/40°C | 100% ED* 330 | 100% ED* 400 | |
1 | 1 | ||
MTB 500i W ML | MTB 700i W ML | ||
I (ampere) 10 min/40°C | 100% ED* 500 | 100% ED* 700 | |
[mm] | 1.0-1.6 | 1.0-1.6 | |
1 | 1 | ||
| MHP 400d W ML TT-SH | |
I (ampere) 10 min/40°C | 100% ED* 400 | ||
[mm (in.)] | 0.8-1.6 (0.032-0.063) | ||
[m (ft.)] | 3.35 / 4.35 / 5.85 | ||
Pmin | [W]** | 1200 / 1500 / 1300 | |
Qmin | [l/min (gal./min.)] | 1 (0.26) | |
pmin | [bar (psi.)] | 3 (43) | |
pmax | [bar (psi.)] | 5 (72) | |
| MHP 500d W ML | MHP 700d W ML | |
I (ampere) 10 min/40°C | 100% ED* 500 | 100% ED* 700 | ||
I (ampere) 10 min/40°C | 100% ED* 400 | 100% ED* 560 | ||
[mm (in.)] | 0.8-1.6 (0.032-0.063) | 0.8-1.6 (0.032-0.063) | ||
[m (ft.)] | 3.35 / 4.35 (11 / 14) | 3.35 / 4.35 (11 / 14) | ||
Pmin | [W]** | 1400 / 1700 | 1800 / 2200 | |
Qmin | [l/min (gal./min.)] | 1 (0.26) | 1 (0.26) | |
| MHP 700d W ML M | ||
I (ampere) 10 min/40°C | 100% ED* 700 | |||
I (ampere) 10 min/40°C | 100% ED* 560 | |||
[mm (in.)] | 0.8-1.6 (0.032-0.063) | |||
[m (ft.)] | 1.35 / 2.35 / 3.35 (4.4 / 7.7 / 14) | |||
Pmin | [W]** | 1000 / 1400 / 1800 | ||
Qmin | [l/min | 1 (0.26) | ||
pmin | [bar (psi.)] | 3 (43) | ||
pmax | [bar (psi.)] | 5 (72) | ||
* ED = Duty cycle | ||||
** Lowest cooling capacity according to IEC 60974-2 | ||||
