LogoOPT/i WF 7 bar gas purging
  • en
    • Contact
    • Imprint
    • Terms and Conditions
    • Data privacy statement
    • 005-18092023
    • General
      • Scope of supply
      • Compressed air supply specifications
      • Installation position
      • Tools required
    • Installing OPT/i WF 7 bar gas purging
      • Safety
      • Preparations
      • And finally...
    Scope of supply
    Spare parts
    General
    Scope of supply
    (1)
    PA 100 mm hose
    (2)
    Hose clamp
    (3)
    Union nut
    (4)
    Hose connection
    (5)
    2-way solenoid valve
    (6)
    Matching disc 13 x 0,3
    (7)
    Nut
    (8)
    Compressed air coupling, part 1
    (9)
    Compressed air coupling, part 2
    (10)
    Elbow connector
    (11)
    Cable harness (not shown)
    (12)
    These installation instructions (not shown)
    Scope of supply
    (1)
    PA 100 mm hose
    (2)
    Hose clamp
    (3)
    Union nut
    (4)
    Hose connection
    (5)
    (6)
    (7)
    Nut
    (8)
    (9)
    (10)
    Elbow connector
    (11)
    (12)
    To ensure that it functions correctly, the following compressed air supply specifications must be met:
    • Constant compressed air supply of at least 5 bar
    • Compressed air is free of oil
    • Compressed air is free of water
    • Compressed air is free of dust – no dirt particles larger than 5 µm
    OPT/i WF 7 bar gas purging can be installed on the following devices
    • all variants of the WF 15i/25i/30i R and R PAP
    • all variants of the SB 500i R and R PAP
    The installation of the OPT/i WF 7 bar gas purging option is illustrated using the WF 30i R robot wirefeeder. Installation on other devices is carried out in the same way.
    Regardless of the type of device (PAP or conventional), an installation on the front or the back is possible.
    Recommendation:
    • PAP: installation on the front (FSC side)
    • Standard: installation on the back
    If OPT/i WF gas nozzle touch sensing is already installed in the device, the OPT/i WF 7 bar gas purging option must be installed on the opposite side from the OPT/i WF gas nozzle touch sensing. The installation must be carried out as described, irrespective of the installation side.
    View of the rear of the device with housing cover removed
    (1)
    Wirefeeder / SplitBox
    (2)
    (3)
    Tools required
    • TX 20 TORX® screwdriver
    • TX 25 TORX® screwdriver
    • 17 mm flat spanner
    • Knife
    • Thread sealant (e.g. Teflon tape, Loctite, etc.)
    Safety
    WARNING!
    WARNING!
    Danger from electric current.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Danger due to hot system components and/or equipment.
    Can result in serious burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.)
    Wear suitable protective equipment (e.g., heat-resistant gloves, safety goggles, etc.) if cooling down is not possible.
    Safety
    WARNING!
    WARNING!
    WARNING!
    Preparations
    1Disconnect all connections on the device from all other system components
    2Place the device on a suitable base
    3Undo four TX 20 screws (1)
    4Open cover (2)
    5Pull the housing cover (3) off the device as shown
    Remove blind plug
    5
    Do not trap the cables!
    6
    7Break off the OPT 4 bushing (1) or remove it using the knife
    8Cut away any protruding flash with the knife
    9
    Connect the cable harness of the OPT/i WF 7 bar gas purging option to the cable harness in the device
    10
    11
    12
    Matching disc has to cover the recess completely
    13
    14Push the hose clamp supplied onto the hose connection
    15Push the compressed air hose onto the hose connection and secure it using the hose clamp
    And finally...
    NOTE!
    When fitting the housing cover, ensure that the cables and hoses are not kinked, trapped, sheared or damaged in any way.
    1Push housing cover (3) as far as it will go onto the device as shown
    2Tighten the four TX 20 screws (1)
    3Close the cover (2)
    4Return the device to its original position
    5Establish connections to other system components
