en
      Operating InstructionsMHP 500/700 S, MTB 500 S
    • General information
      • Torch hosepack
        • General
        • Scope of supply
      • CrashBox /i
        • General
        • Also required for installation
        • Device concept
        • Application areas
        • Scope of supply
        • Clamp system scope of supply and options
      • Robot welding torch
        • Safety
        • General
    • Installation and commissioning
      • Fitting the welding system to a conventional robot
        • Safety
        • Fitting the TransSteel welding system to a conventional robot
      • Fitting the CrashBox /i to the robot
      • Fitting the clamp system
        • Special tilt angle for the welding torch
        • Fitting the clamp system with extension
      • Fitting the MHP G / W hosepack
        • Fitting the MHP G / W conventional hosepack - standard
      • Fitting the TransSteel torch body
        • Safety
        • Fitting the TransSteel torch body - Standard
        • Fitting the inner liner inside the torch hosepack
      • Fitting the welding system to a PAP robot
        • Safety
        • Fitting the TransSteel welding system to a PAP robot
      • Installing the CrashBox /i PAP on the robot
      • Fitting the MHPi/MHP S G/W PAP hosepack
        • Fitting the Robacta MHP G/W PAP hosepack
    • Appendix
      • Care, maintenance and disposal
        • General
        • Safety
        • Every start-up
        • Every 6 months
        • Recognising faulty wearing parts
        • MTG d, MTW d - Fitting wearing parts to the torch body
        • Fitting wearing parts to the torch body - MTW 700 i
        • Cleaning the welding torch
        • Disposal
      • Torch hosepack
        • MHP 500 S R / G / PAP
        • MHP 700 S R / W / PAP
        • MTB 500S G R, MTB 500S G R US
    • 010-10042026
    download
    ContactImprintTerms and ConditionsData privacy statement
    General information
    link_horizontalLink copied
    Torch hosepack
    General
    The MHP 500 S R/G, MHP 700 S R/W hosepack has been designed for gas-cooled/water-cooled robot applications. It connects the TransSteel Robotics wirefeeders to the robot welding torches of the TransSteel series.
    1. General information
    Torch hosepack
    General
    2. Torch hosepack
    General
    2. Torch hosepack
    Scope of supply
    MHP PAP hosepack
    MHP conventional hosepack
    (1)
    Not supplied:
    • Inner liners
    • Inlet nozzles
    CrashBox /i
    General
    CrashBox /i PAP fitted to robot arm
    CrashBox /i fitted to robot arm with clamp system
    The CrashBox /i is a protection device for the torch body, the drive unit, the wire brake and the torch body coupling. In the event of a collision, the CrashBox sends a signal to the robot control, which stops the robot immediately. The torch holder on the CrashBox protects the welding torch and the system components fitted from damage should a collision occur.
    The clamp system is used for holding gas-cooled and water-cooled robot welding torches. With torch body curvatures of 22°, 36° and 45°, the clamp system positions the welding torch in such a way that the TCP is in the 6th axis or at a 45° angle to the 6th axis, depending on the torque angle gauge.
    A robot-specific, isolated robot flange is required for fitting the CrashBox /i.
    2. CrashBox /i
    General
    2. CrashBox /i
    Depending on the particular robot:
    • 1 x robot flange with screws
    Robot flange as per price list
    2. CrashBox /i
    Device concept
    The CrashBox /i is designed specifically for fitting to the robot arm and for holding gas-cooled and water-cooled robot hosepacks and robot drive units. For PAP systems, the torch hosepack runs through the CrashBox and then through the robot arm. In conventional robot systems the torch hosepack runs along the robot arm and is attached to the clamp. In the event of a crash, the magnetic coupling smoothly deflects the forces along a large deflection path.
    2. CrashBox /i
    Application areas
    The clamp system can be used for the following push robot hosepacks:
    • MHP i G / MHP i W TPS /i hosepacks
    • MTG/MTW TransSteel hosepacks
    2. CrashBox /i
    Scope of supply
    CrashBox /i PAP scope of supply
    CrashBox /i Standard scope of supply
    (1)
    CrashBox /i holder
    (4)
    Bellows
    (2)
    1-ear clamp *
    (5)
    Cheese-head screws, M4 x 16 mm
    (3)
    Locking ring, 2-part *
    (6)
    Magnetic ring
    * Delivered fitted to bellows (4)
    Do not fit the CrashBox /i holder (1) and magnetic ring (4) together before fitting to the robot. The components become even more difficult to release due to the strong magnetism.
    2. CrashBox /i
    (1)
    M8 hexagon nut
    (2)
    M8 washer
    (3)
    Clamp
    (4)
    Index disc
    (5)
    Allen screw, M8 x 40 mm
    Optional (material for extension):
    (6)
    M8 x 40 mm screw
    (7)
    M8 washer
    (8)
    Extension
    (9)
    Index disc
    (10)
    M8 hexagon nut
    Robot welding torch
    Safety
    CAUTION!
    Risk of burns from hot torch body, hot torch body coupling and other hot welding torch components.
    Before starting work on the torch body, the torch body coupling and all other welding torch components:
    Allow the torch body, torch body coupling and all other welding torch components to cool down to room temperature (+25 °C, +77 °F)
    Wear electrically insulated and heat protective gloves
    Use a suitable tool
    2. Robot welding torch
    Safety
    CAUTION!
    Use a suitable tool
    General
    The robot welding torch transmits the arc power to the workpiece. The gas-cooled or water-cooled TransSteel welding torch is designed for use with the CrashBox /i.
    The torch body has an integrated lead for gas nozzle touch sensing.
    Standard: with wearing parts, without contact tip
    OVT: without wearing parts
    Safety
    WARNING!
    Danger from work that is not carried out properly.
    Only trained and qualified personnel may carry out the activities described in the following.
    Observe the operating instructions of the system components, in particular the chapter "Safety rules".
    WARNING!
    Danger of electric shock.
    Could result in serious injury or death.
    Before starting the work described below, switch the power switch on the welding machine to the position - O -.
    Disconnect the welding machine from the grid.
    Ensure that the welding machine remains disconnected from the grid until all work is complete.
    WARNING!
    Danger from falling objects.
    Check that all screw connections described below are tightly fastened after assembly
    Check that screw connections are tightly fastened after abnormal operating situations (e.g., after a crash).
    Check that screw connections are tightly fastened at regular intervals
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, leads, and hosepacks must always be securely connected, undamaged, and correctly insulated.
    Only use adequately dimensioned cables, leads, and hosepacks.
    1. Installation and commissioning
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Fitting the welding system to a conventional robot
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    Individual components must be fitted to the robot in the following order:
    1. Wirefeeder - the wirefeeder holder and the side arm holder must be fitted first
    2. CrashBox /i
    3. Clamp system
    4. Torch hosepack
    5. Robot welding torch
    6. Interconnecting hosepack
    Observe the torques when fitting the robot flange:
    Tightening torque for screws of strength class 8.8
    M4
    2,3 - 3,3 Nm
    1,70 - 2,43 lb·ft
    M5
    4,4 - 6,5 Nm
    3,25 - 4,79 lb·ft
    M6
    7,70 - 11,3 Nm
    5,68 - 8,33 lb·ft
    M8
    18,5 - 27,3 Nm
    13,65 - 20,14 lb·ft
    M10
    36,0 - 54,0 Nm
    26,55 - 39,83 lb·ft
    M12
    63,0 - 93,0 Nm
    46,47 - 68,60 lb·ft
    5
    6
    7
    8
    2. Fitting the CrashBox /i to the robot
    M4
    2,3 - 3,3 Nm
    1,70 - 2,43 lb·ft
    M5
    4,4 - 6,5 Nm
    3,25 - 4,79 lb·ft
    M6
    7,70 - 11,3 Nm
    5,68 - 8,33 lb·ft
    M8
    18,5 - 27,3 Nm
    13,65 - 20,14 lb·ft
    M10
    36,0 - 54,0 Nm
    26,55 - 39,83 lb·ft
    M12
    63,0 - 93,0 Nm
    46,47 - 68,60 lb·ft
    5
    6
    7
    8
    The positioning of the welding torch in relation to the workpiece is divided into fixed angles by the index disc. Special angles are available on request.
    2. Fitting the clamp system
    Mount the index disc 45° from the scope of supply of the clamp extension
    NOTE!
    CB (for CrashBox) is stamped on one side of the clamp extension.
    This side must be fitted to the index disc that has already been fitted.
    Fit the clamp extension to the index disc that has already been fitted in such a way that the stamped 'CB' on the clamp extension faces the index disc!
    2. Fitting the MHP G / W hosepack
    Safety
    CAUTION!
    Use a suitable tool
    2. Fitting the TransSteel torch body
    Safety
    CAUTION!
    Use a suitable tool
    Special tool required
    Lay the welding torch out straight
    Lay the inner liner out straight
    Push the inner liner into the welding torch until it protrudes from the front of the welding torch
    Mark the end of the torch connector on the inner liner
    5
    Cut off the inner liner at the marking and deburr; left inner liner made of steel, right inner liner made of plastic
    6
    Screw the clamping nipple onto the inner liner as far as it will go. The inner liner must be visible through the hole in the cap
    7
    Fit the extraction nozzle
    Push the extraction nozzle on as far as it will go.
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Fitting the welding system to a PAP robot
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. CrashBox /i
    3. Torch hosepack
    4. Robot welding torch
    5. Interconnecting hosepack
    Max. tightening torque for screws of strength class 8.8
    M4
    3.3 Nm / 2.43 lb-ft
    M5
    5.0 Nm / 3.69 lb-ft
    M6
    6.0 Nm / 4.43 lb-ft
    M8
    27.3 Nm / 20.14 lb-ft
    M10
    54 Nm / 39.83 lb-ft
    M12
    93 Nm / 68.60 lb-ft
    5
    6
    7
    8
    2. Installing the CrashBox /i PAP on the robot
    M4
    3.3 Nm / 2.43 lb-ft
    M5
    5.0 Nm / 3.69 lb-ft
    M6
    6.0 Nm / 4.43 lb-ft
    M8
    M10
    54 Nm / 39.83 lb-ft
    M12
    93 Nm / 68.60 lb-ft
    5
    6
    7
    8
    5
    6
    7
    8
    9
    10
    2. Fitting the MHPi/MHP S G/W PAP hosepack
    5
    6
    7
    8
    9
    10
    5
    6
    7
    Appendix
    General
    Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the welding system remains in a usable condition for many years.
    1. Appendix
    General
    1. Appendix
    2. Care, maintenance and disposal
    General
    1. Appendix
    Safety
    WARNING!
    Fully read and understand this document.
    WARNING!
    Danger from electric current.
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    CAUTION!
    Danger due to hot system components and/or equipment.
    This can result in burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
    Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
    1. Appendix
    Every start-up
    • Check all hosepacks and the ground earth connection for damage. Replace any damaged components.
    • Check feed rollers and inner liners for signs of damage. Replace any damaged components.
    • Check the wirefeeding hoses for damage. Replace any damaged components.
    • Check contact pressure of feed rollers and adjust if necessary.
    • Check that all screw connections between the robot, wirefeeder holder and wire-feed unit are secure.
    1. Appendix
    Every 6 months
    CAUTION!
    Danger from compressed air at close range.
    Electronic components may be damaged.
    Do not bring the air nozzle too close to electronic components.
    • Open covers, remove device side panels and clean inside of device with dry reduced compressed air. After cleaning, restore device to its original state.
    1. Appendix
    1. Insulating parts
      • Burned-off outside edges, notches
    2. Nozzle fittings
      • Heavily covered in welding spatter
    3. Spatter guard
    4. Contact tips
      • Worn-out (oval) wire entry and wire exit holes
      • Penetration on the tip of the contact tip
    5. Gas nozzles
      • Notches
    1. Appendix
    Screw on and tighten the gas nozzle as far as it will go
    1. Appendix
    1. Appendix
    1. Appendix
    Disposal
    Waste electrical and electronic equipment must be collected separately and recycled in an environmentally responsible manner in accordance with the EU Directive and national law. Used equipment must be returned to the distributor or through a local, authorised collection and disposal system. Proper disposal of the old device promotes sustainable recycling of material resources. Ignoring this may lead to potential health/environmental impacts.
    Packaging materials
    Collected separately. Check your municipality’s regulations. Reduce the volume of the box.
    1. Appendix
    Torch hosepack
    Welding current at 10 min/40° C
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    Wire diameter
    0.8 - 1.6 mm
    0.032 - 0.063 in.
    Length
    0.94 / 0.96 / 1.04 / 1.06 / 1.075 /
    1.12 / 1.13 / 1.15 / 1.18 / 1.19 / 1.2 /
    1.22 / 1.31 / 1.35 / 1.37 / 1.4 / 1.43 /
    1.51 / 1.59 / 2.13 m
    3.08 / 3.15 / 3.4 / 3.48 / 3.53 / 3.67 /
    3.71 / 3.77 / 3.87 / 3.9 / 3.94 / 4.0 /
    4.3 / 4.43 / 4.5 / 4.59 / 4.69 / 4.95 /
    5.22 / 6.99 ft.
    * ED = Duty cycle
    1. Appendix
    2. Torch hosepack
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    Wire diameter
    0.8 - 1.6 mm
    0.032 - 0.063 in.
    Length
    5.22 / 6.99 ft.
    * ED = Duty cycle
    1. Appendix
    2. Torch hosepack
    X / Imax (10 min/40 °C)
    M21 (EN ISO 14175)
    100% D.C.* 700
    C1 (EN ISO 14175)
    100% D.C.* 700
    [mm (in.)]
    0.8-1.6 (0.032-0.063)
    Pmax
    [m] ([W])
    [ft.] ([W])
    0.96 (1200) / 1.04 (1250) / 1.06 (1250) / 1.075 (1250) / 1.12 (1300) / 1.13 (1300) / 1.15 (1300) / 1.18 (1300) / 1.19 (1300) / 1.2 (1300) / 1.22 (1300) / 1.31 (1350) / 1.35 (1400) / 1.37 (1400) / 1.4 (1400) / 1.43 (1400) / 1.51 (1400)
    3.15 (1200) / 3.41 (1250) / 3.48 (1250) / 3.53 (1250) / 3.67 (1300) / 3.71 (1300) / 3.77 (1300) / 3.87 (1300) / 3.9 (1300) / 3.94 (1300) / 4 (1300) / 4.3 (1350) / 4.43 (1400) / 4.5 (1400) / 4.59 (1400) / 4.69 (1400) / 4.95 (1400)
    Qmin
    [L/min]
    [gal./min]
    0.26
    pmin
    [bar]
    [psi]
    43
    pmax
    [bar]
    [psi]
    5
    72
    * D.C. = Duty cycle
    1. Appendix
    Robot welding torch
    Gas-cooled robot welding torches
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    Wire diameter
    0.8 - 1.6 mm
    0.032 - 0.063 in.
    * ED = Duty cycle
    1. Appendix
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    Wire diameter
    0.8 - 1.6 mm
    0.032 - 0.063 in.
    * ED = Duty cycle
