Indicates immediate danger.
All safety and danger notices on the deviceFor the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
Before switching on the device, rectify any faults that could compromise safety.
The device is intended solely for the welding processes specified on the rating plate.
Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
The manufacturer likewise accepts no liability for inadequate or incorrect results.
Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended purpose. The manufacturer shall not be held liable for any damage arising from such usage.
Ambient temperature range:The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
This may affect a number device types in terms of:*) at the interface with the public grid
see "Technical data"
In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
IMPORTANT! Ensure that the mains connection is earthed properly
The fumes produced during welding contain harmful gases and vapours.
Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
Keep your face away from welding fumes and gases.
Fumes and hazardous gasesEnsure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
Flying sparks may cause fires or explosions.
Never weld close to flammable materials.
Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
An electric shock is potentially life threatening and can be fatal.
Do not touch live parts either inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Use the handle to ensure the power connections are tight before every use.
In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
Do not wrap cables or leads around the body or parts of the body.
The electrode (rod electrode, tungsten electrode, welding wire, etc.) mustDouble the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer shall not be held liable for any damage arising from such usage.
If necessary, provide adequate earthing for the workpiece.
Switch off unused devices.
Wear a safety harness if working at height.
Before working on the device, switch it off and pull out the mains plug.
Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
After opening the device:If work on live parts is required, have a second person switch off the main switch at the right moment.
Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
Do not reach into the rotating cogs of the wire drive or into rotating drive components.
Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
During operationThe welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
Never touch the workpiece during or after welding - risk of burns.
Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
Special provisions apply in areas at risk of fire or explosion
- observe relevant national and international regulations.
Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
Use filters if necessary.
Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
Keep the shielding gas cylinders well away from any welding or other electrical circuits.
Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
Turn your face to one side when opening the valve of a shielding gas cylinder.
Close the shielding gas cylinder valve if no welding is taking place.
If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
Risk of suffocation from the uncontrolled escape of shielding gas
Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
Before transporting the device, allow coolant to drain completely and detach the following components:After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
Only the manufacturer's original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
Only use suitable original coolant from the manufacturer.
Do not mix the manufacturer's original coolant with other coolants.
Only connect the manufacturer's system components to the cooling circuit.
The manufacturer accepts no liability for damage resulting from use of other system components or a different coolant. In addition, all warranty claims will be forfeited.
Cooling Liquid FCL 10/20 does not ignite. The ethanol-based coolant can ignite under certain conditions. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Check the coolant level before starting to weld, while the system is still cool.
The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
The manufacturer recommends that the welding system be calibrated during the same 12-month period.
A safety inspection should be carried out by a qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on safety inspection and calibration can be obtained from your service centre. They will provide you with any documents you may require, on request.
Packaging materialsDevices with the CE mark satisfy the essential requirements of the low-voltage and electromagnetic compatibility directives (e.g. relevant product standards of the EN 60 974 series).
Fronius International GmbH hereby declares that the device is compliant with Directive 2014/53/EU. The full text on the EU Declaration of Conformity can be found at the following address: http://www.fronius.com
Observe the safety rules in the power source operating instructions at all times.
Owing to its modular design, the robot wirefeeder can be extended as needed (e.g. Robacta Drive, gas purging, torch support etc.)
The VR 1500 is available with different wire speeds:
The VR 1550 is available with a wire feed speed of 22 m/min.
The motor plate and control unit can be installed and operated independently of each other. The control unit, however, must be earthed/grounded separately.
The robot wirefeeder is specially designed for fitting to the robot arm and can be used in conjunction with the TS 4000 / 5000, TPS 3200 / 4000 / 5000 power sources. The robot wirefeeder is suitable for all standard shielding gases.
The VR 1500 - 11 and VR 1500 - 12 are also used for flux core wire applications.
The VR 1500 - 12 is primarily used for complex wirefeeding applications requiring a high degree of torque:
The VR 1500 - 30 is also used for flat wire applications.
In particular, the VR 1500 - 11, VR 1500 - 12 and VR 1500 - 30 are also used in conjunction with the high performance TS / TPS 7200 and TPS 9000 power sources.
The wire-feed unit has safety symbols on the rating plate. The safety symbols must not be removed or painted over. The symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage.
Welding is dangerous. The following basic requirements must be met:
VR 1500 cover |
Risk of injury from rotating cogs on the wire drive.
If you use the wirefeeder without the "VR 1500 cover", you must take other suitable safety precautions.
VR 1500 adapter plate |
Danger from electric current.
If you do not use the optional VR 1500 adapter plate, the wirefeeder must be mounted in such a way that it is insulated from earth.
VR 1500 torch support |
Wirefeeding hose |
VR 1500 cover |
Wirefeeding hose |
Unreeling wirefeeders are mainly used for large spools and welding wire drums, which are located outside the welding system. The welding wire is transported to the wirefeeder by means of the unreeling wirefeeder. A push-bull calibration is required between the wirefeeder and unreeling wirefeeder.
The unreeling wirefeeders are available in the following versions:
VR 1530 - 11 | wire speed max. 11 m/min, water-cooled electric motor with shrunk-on-disc rotor |
VR 1530 - 12 | wire speed max. 12 m/min, high torque, water-cooled electric motor with shrunk-on-disc rotor |
VR 1530 - 22 | wire speed max. 22 m/min, standard motor |
VR 1530 - 30 | wire speed max. 30 m/min, water-cooled electric motor with shrunk-on-disc rotor |
VR 1530 - PD | unreeling wirefeeder with planetary drive |
900 A VR 1500 installation kit (VR 1500 - 11, VR 1500 - 12 and VR 1500 - 30 only, each with Fronius central connector F++) |
VR 1500 basic torch blow out installation kit (max. 7 bar) |
High end torch blow out installation kit (15 bar) |
PMR 4000 PullMig, PM 43 installation kit |
Gas nozzle touch sensor installation kit |
VR 1500 gas pressure sensor installation kit |
Digital gas control |
Gas economiser valve installation kit |
Fixable tensioning lever installation kit for plastic motor plate |
Wire-end connector installation kit |
Unreeling wirefeeder installation kit, 17-pin amphenol plug |
Increased motor supply installation kit for VR 1500 - 12 (2 x 8 A) control unit |
CMT VR 1550 installation kit |
VR 1500 MO/K holder |
Robot wirespool holder |
Cover for robot wirespool holder |
VR 1500 - 22, VR 1500 - 11, VR 1500 - 12 and VR 1500 - 30 control unit |
Please note the following if the control unit and motor plate are used separately: The control unit must be earthed
The motor plate must be insulated
3-roller wire straightening section |
Tuchel plug |
VR 1500 wire end sensor (incl. spool cover) |
VR 1500 wire end sensor (for welding wire drum without control cable) |
The positions of the following controls, connections and mechanical components are customer-specific and may vary.
| (1) | Blanking cover / gas pressure sensor adjusting button (optional) |
| (2) | Water return connection (red) |
| (3) | Gas test button for setting the required gas flow rate on the pressure regulator. If you press and hold this button, gas will flow. |
| (4) | Wire threading button for threading the wire electrode into the torch hosepack with no flow of gas or current. |
| (5) | Additional fan |
| (6) | Robacta robot welding torch connection on VR 1500 (see circuit diagram X10 for pin assignment) or Wire buffer connection on VR 1550 (CMT-WS) and VR 1550 CMT installation kit (optional) |
| (7) | Robacta robot welding torch connection on VR 1550 (CMT-WS) (see circuit diagram X10 for pin assignment) |
| (8) | Blanking cover/AIR IN "torch blow out" connection (high end option, max. 15 bar) or LHSB connection on VR 1550 (CMT-WS) and VR 1550 CMT installation kit (optional) |
| (9) | Water flow connection (black or blue) |
| (10) | AIR OUT "torch blow out" connection (optional) |
| (11) | Tuchel plug (optional) |
| (12) | Welding torch connection for connecting the welding torch |
| (13) | VR 1500 cover (optional) |
| (1) | LocalNet connection - interconnecting hosepack |
| (2) | LocalNet connection standardised connection socket for system extensions (e.g. remote control, etc.) If the optional unreeling wirefeeder installation kit has been fitted to the wirefeeder, the 17-pin amphenol plug of the unreeling wirefeeder installation kit is plugged into (2) and the LocalNet connection is plugged into (14). If the optional VR 1550 CMT installation kit has been fitted to the VR 1550, the LHSB connection of the VR 1550 CMT installation kit is plugged into (2) and the LocalNet connection is plugged into (14). |
| (3) | (+) current connection with bayonet latch - interconnecting hosepack |
| (4) | 2nd (+) socket with bayonet latch (optional 900 A installation kit) |
| (5) | Blanking cover / wire-end connector (optional) |
| (6) | Blanking cover |
| (7) | Wire infeed tube |
| (8) | VR 1500 cover (optional) |
| (9) | Shielding gas connection |
| (10) | Water return connection (red) - interconnecting hosepack |
| (11) | Water flow connection (blue) - interconnecting hosepack |
| (12) | Blanking cover/AIR IN "torch blow out" connection (high end option, max. 7 bar) |
| (13) | Blanking cover |
| (14) | Blanking cover/LocalNet connection (if the optional unreeling wirefeeder installation kit is fitted to the wirefeeder or if the optional VR 1550 CMT installation kit is fitted to the wirefeeder) |
| (15) | Blanking cover/AIR IN "torch blow out" connection (high end option, max. 15 bar) |
| (16) | Additional filter |
The VR 1500 - 11, VR 1500 - 12 and VR 1500 - 30 wirefeeders are equipped with a water-cooled electric motor with shrunk-on-disc rotor and may only be operated in conjunction with an FK 4000 R, FK 4000 R US or FK 9000 R cooling unit.
For the protection of the motor we recommend that you install the optional flow watchdog for the cooling unit (fitted as standard on the FK 4000 R US).
When using a welding current over 500 A, only operate the VR 1500 - 11, VR 1500 - 12 and VR 1500 - 30 wirefeeders with adequately dimensioned Fronius welding torches that have an F++ connection.
If the PMR 4000 push-pull option is installed on the VR 1500 - 11 and VR 1500 - 30 wirefeeders, the power source must be equipped with an increased power supply (55 V DC, 8 A).
If unreeling wirefeeders are used, the power source must be equipped with an increased power supply (55 V DC, 8 A).
If the TPS 7200 / 9000 is used with VR 1500 - 12 and unreeling wirefeeders, both the 1st and second power source must be equipped with an increased power supply (55 V DC, 8 A).
To operate the VR 1500 - 12, the power source must be equipped with an increased power supply (55 V DC, 8 A).
To operate the VR 1500 - 12 with an unreeling wirefeeder, the VR 1500 - 12 must be equipped with an increased motor supply installation kit.
The wirefeeder is connected to the power source using the interconnecting hosepack.
Risk of damage to the wirefeeding hose if it is attached to the hosepack.
Do not attach the wirefeeding hose to the hosepack under any circumstances.
Do not carry out the steps described here until you have read and completely understood all the operating instructions.
A | Interconnecting hosepack; wirefeeder end |
R | red |
B | blue |
C | 2nd power cable (optional) |
R | red |
B | blue |
| Fronius F++ | Euro | for Dinse | for Tweco |
VR 1500 | X | X | X | X |
VR 1500 - 11 | X | (X) | - | - |
VR 1500 - 12 | X | (X) | - | - |
VR 1500 - 30 | X | (X) | - | - |
VR 1550 | X | X | - | - |
VR 1550 (CMT-WS) | X | - | - | - |
(X) ... up to a max. of 500 A
When using a welding current over 500 A, only operate the VR 1500 - 11, VR 1500 - 12 and VR 1500 - 30 wirefeeders with adequately dimensioned Fronius welding torches that have F++ connections.
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
IMPORTANT! Only use feed rollers that match the wire electrode.
An overview of the feed rollers available and their possible areas of use can be found in the spare parts lists.
In the USA, all wirefeeders are delivered without feed rollers. After inserting the wirespool, the feed rollers must be inserted into the wirefeeder.
Risk of serious injury and property damage or an inferior weld as a result of earth contact or short-circuit of a non-insulated wire electrode.
In the case of automated applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder (e.g. by using a wirefeeding hose).
An earth contact or short-circuit can be caused by:
Using wirefeeding hoses ensures that the wire electrode remains insulated as it is transported towards the wirefeeder. To prevent chafing, do not route the wirefeeding hoses over sharp edges. Use hose holders or hose protectors as necessary. Coupling pieces and hoods for welding wire drums also ensure safe transport of the wire electrode.
Risk of injury from springiness of spooled wire electrode.
When inserting the wire electrode into the 4 roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
Risk of damage to the welding torch from sharp end of wire electrode.
This can result in serious damage to property.
Deburr the end of the wire electrode well before feeding in.
Risk of injury from wire electrode emerging at speed.
When pressing the wire threading button or the torch trigger, keep the welding torch away from your face and body, and wear suitable protective goggles.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
Contact pressure standard values
| Feed rollers | ||
Semi-cylindrical | Trapeze | Plastic | |
Aluminium | 1.5 | - | 3.5 - 4.5 |
Steel | 3 - 4 | 1.5 | - |
CrNi | 3 - 4 | 1.5 | - |
The "wire end" error message is used for the following errors on VR 1500 series systems:
Two options can be preset on the power source for the "wire end" error message:
| (1) | complete welding ... e.g. for short weld seams |
| (2) | stop welding immediately ... e.g. for long weld seams, flux core wire applications, high-performance welding (risk of motor power module overload if these welding processes are not stopped) |
| Cause: | The wire end check option has detected the end of the welding wire. |
| Remedy: | Insert new wirespool and thread in the welding wire, acknowledge the error on the power source |
| Cause: | Additional fan filter is contaminated - air supply for the additional fan is no longer sufficient to cool the power electronics - the power electronics temperature switch has tripped |
| Remedy: | Clean filter or replace, acknowledge the error on the power source |
| Cause: | Ambient temperature too high |
| Remedy: | Reduce ambient temperature, if necessary position and operate the welding system at a cooler location; acknowledge the error on the power source |
| Cause: | Motor current too high e.g. due to wire threading problems or an inadequately dimensioned wirefeeder |
| Remedy: | Check wire threading conditions, rectify faults, acknowledge error on the power source |
Press the "Setup/Store" button on the power source to acknowledge an error message. Setup/Store button on the power source Setup/Store button on the power source |
Under normal operating conditions, the wire-feed unit requires only a minimum of care and maintenance. However, some important points must be noted to ensure that the welding system remains in a usable condition for many years.
Danger due to the effect of compressed air.
Do not bring the air nozzle too close to electronic components.
The specified degree of protection is only guaranteed if the VR 1500 "cover" installation kit is installed.
Supply voltage | 55 V DC |
Nominal current | 4 A |
Wire diameter | 0.8 - 1.6 mm |
Wire feed speed | 0.5 - 22 m/min |
Torque | 4 Nm |
Degree of protection | IP 21 |
Dimensions l x w x h | 405 x 208 x 205 mm |
Weight | 7 kg |
Drive | 4-roller drive |
Maximum shielding gas pressure | 7 bar |
Coolant | Original Fronius coolant |
Maximum coolant pressure | 6 bar |
Wire diameter | 0.8 - 3.2 mm |
Wire feed speed | 0.5 - 11 m/min |
Torque | 11 Nm |
Dimensions l x w x h | 400 x 300 x 205 mm |
Weight | 8 kg |
Drive | 4-roller drive, water-cooled electric motor with shrunk-on-disc rotor |
Special accessories | Additional fan for the power electronics |
Nominal current | 6 A |
Wire feed speed | 0.5 - 12 m/min |
Torque | 21.6 Nm |
Weight | 10 kg |
Wire feed speed | 0.5 - 30 m/min |
Torque | 3.7 Nm |
Weight | 8 kg |
Torque | 4 Nm |
Weight | 7 kg |
