Indicates immediate danger.
All safety and danger notices on the deviceFor the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
Before switching on the device, rectify any faults that could compromise safety.
The device is intended solely for the welding processes specified on the rating plate.
Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
The manufacturer likewise accepts no liability for inadequate or incorrect results.
Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended purpose. The manufacturer shall not be held liable for any damage arising from such usage.
Ambient temperature range:The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
This may affect a number device types in terms of:*) at the interface with the public grid
see "Technical data"
In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
IMPORTANT! Ensure that the mains connection is earthed properly
The device generates a maximum sound power level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation at the maximum permissible operating point under maximum rated load conditions according to EN 60974-1.
It is not possible to provide a workplace-related emission value during welding (or cutting) as this is influenced by both the process and the environment. All manner of different welding parameters come into play, including the welding process (MIG/MAG, TIG welding), the type of power selected (DC or AC), the power range, the type of weld metal, the resonance characteristics of the workpiece, the workplace environment, etc.
The fumes produced during welding contain harmful gases and vapours.
Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
Keep your face away from welding fumes and gases.
Fumes and hazardous gasesEnsure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
Flying sparks may cause fires or explosions.
Never weld close to flammable materials.
Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
An electric shock is potentially life threatening and can be fatal.
Do not touch live parts either inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Use the handle to ensure the power connections are tight before every use.
In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
Do not wrap cables or leads around the body or parts of the body.
The electrode (rod electrode, tungsten electrode, welding wire, etc.) mustDouble the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer shall not be held liable for any damage arising from such usage.
If necessary, provide adequate earthing for the workpiece.
Switch off unused devices.
Wear a safety harness if working at height.
Before working on the device, switch it off and pull out the mains plug.
Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
After opening the device:If work on live parts is required, have a second person switch off the main switch at the right moment.
Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
Do not reach into the rotating cogs of the wire drive or into rotating drive components.
Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
During operationThe welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
Never touch the workpiece during or after welding - risk of burns.
Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
Special provisions apply in areas at risk of fire or explosion
- observe relevant national and international regulations.
Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
Use filters if necessary.
Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
Keep the shielding gas cylinders well away from any welding or other electrical circuits.
Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
Turn your face to one side when opening the valve of a shielding gas cylinder.
Close the shielding gas cylinder valve if no welding is taking place.
If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
Risk of suffocation from the uncontrolled escape of shielding gas
Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
Before transporting the device, allow coolant to drain completely and detach the following components:After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
Only the manufacturer's original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
Only use suitable original coolant from the manufacturer.
Do not mix the manufacturer's original coolant with other coolants.
Only connect the manufacturer's system components to the cooling circuit.
The manufacturer accepts no liability for damage resulting from use of other system components or a different coolant. In addition, all warranty claims will be forfeited.
Cooling Liquid FCL 10/20 does not ignite. The ethanol-based coolant can ignite under certain conditions. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Check the coolant level before starting to weld, while the system is still cool.
The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
The manufacturer recommends that the welding system be calibrated during the same 12-month period.
A safety inspection should be carried out by a qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on safety inspection and calibration can be obtained from your service centre. They will provide you with any documents you may require, on request.
Packaging materialsDevices with the CE mark satisfy the essential requirements of the low-voltage and electromagnetic compatibility directives (e.g. relevant product standards of the EN 60 974 series).
Fronius International GmbH hereby declares that the device is compliant with Directive 2014/53/EU. The full text on the EU Declaration of Conformity can be found at the following address: http://www.fronius.com
The wirefeeders of the VR 7000 series are designed to be used with wirespools of max. 300 mm (11.81 in.) diameter.
The wirespool holder is located inside the wirefeeder housing. The wirespool is thus protected from soiling.
The standard 4 roller drive has good wire feeding properties. The VR 7000-series wirefeeders are also suitable for use with long hosepacks.
Thanks to their compact overall design, the VR 7000 wirefeeders can be used in a wide variety of different situations.
The VR 7000 wirefeeders can be operated with the following power sources:
The "CMT (Cold Metal Transfer)" welding process is only possible with the VR 7000 CMT in conjunction with an appropriate CMT power source and CMT drive unit.
All variants of the VR 7000 are suitable for all standard shielding gases.
The VR 7000-11 and VR 7000-30 wirefeeders have a water-cooled electric motor with shrunk-on-disc rotor, and may only be operated in conjunction with an appropriate cooling unit.
The wire-feed unit has safety symbols on the rating plate. The safety symbols must not be removed or painted over. The symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage.
Welding is dangerous. The following basic requirements must be met:
The "mode" switch enables the processes and modes to be selected on site; the "gas test" and "wire threading" functions can also be carried out on site.
The "Mode" switch option cannot be used:
if the wirefeeder is fitted with the VR 4000 digital display.
on the VR 7000 CMT.
on the VR 7000 CMT.
The wirefeeder can be fitted with the following control panels as an alternative to the "Standard" control panel:
Please refer to the installation instructions for a detailed description of the optional control panels
IMPORTANT! On the VR 7000 CMT, the optional VR 4000 Ci and VR 4000 control panels are used exclusively to display actual values. Parameters cannot be adjusted via the optional control panels and the RCU 5000i remote control.
Robacta Drive installation kit |
Push-pull unit installation kit |
Digital gas control |
900 A installation kit |
Gas economiser valve installation kit |
Plastic-to-metal adapter installation kit |
Gas test/wire threading installation kit |
Trabant |
Fixable tensioning lever installation kit |
Gas nozzle touch sensor installation kit |
Wire-end connector installation kit |
Wire-end check installation kit |
VR 143-2 intermediate drive adapter installation kit: |
Torch blow-off basic installation kit: |
Torch blow-off High End installation kit: |
VR mount for upright console |
QuickConnect option |
Wirefeeding hose option |
Setting parameters at control panels is only possible in manual welding mode.
In the automated welding mode or in robot welding, the robot control provides the set values for the welding parameters. Specifying command values via control panels is not possible in automated welding mode or in robot welding.
Welding parameters that must be entered on a wire-feed unit control panel cannot be changed on the power source. Welding parameters can only be changed on the wire-feed unit.
(1) | Welding power/wire speed adjuster
(2) | Arc length/arc-force dynamic adjuster
(1) | Welding torch connection |
(2) | Water return connection (red) |
(3) | Water flow connection (blue) |
(4) | Blanking cover |
(5) | Torch control connection |
(6) | LocalNet connection |
(7) | Blanking cover on VR 7000, VR 7000-11, VR 7000-30 |
(8) | Blanking cover on VR 7000, VR 7000-11, VR 7000-30 |
(9) | Blanking cover on VR 7000, VR 7000-11, VR 7000-30 |
(10) | Blanking cover |
(11) | Blanking cover |
(12) | Blanking cover |
(13) | Bushing for compressed air |
(14) | Bushing for interconnecting hosepack |
(15) | Bushing for external wire electrode |
(16) | Wirespool holder with brake |
(17) | 4 roller drive |
(18) | Process selector switch1) IMPORTANT! If the VR 7000 wirefeeder is connected to a TS 4000/5000 power source, MIG/MAG pulse synergic welding is not available. |
(19) | Mode selector switch1) |
(20) | "Gas-test/wire threading" button1) Press the button down: Press the button up: The "Gas-test/wire threading" button (20) can also be installed as a separate option on the VR 7000. |
IMPORTANT! Settings made on the mode selection switch cannot be altered on other controls, e.g.:
(21) | Shielding gas connection for interconnecting hosepack |
(22) | Water flow connection (blue) for interconnecting hosepack |
(23) | Water return connection (red) for interconnecting hosepack |
(24) | LocalNet connection for interconnecting hosepack |
(25) | (+) current socket with bayonet latch for interconnecting hosepack |
(26) | Blanking cover |
(27) | Blanking cover |
(28) | Blanking cover |
(29) | LHSB connection for CMT interconnecting hosepack |
(30) | Blanking cover |
(31) | Blanking cover |
(32) | Socket for swivel pin |
The wire-feed units can be placed on the power source if a swivel pin holder is available, e.g.:
More detailed information on the swivel pin receptors can be found in the "Swivel pin receptors for upright consoles" and "PickUp" operating instructions.
Danger from falling wire-feed unit.
Check that the wirefeeder is securely placed on the swivel pin.
The wirefeeder is connected to the power source using the interconnecting hosepack.
For the "CMT" welding process, a special CMT interconnecting hosepack with additional LHSB cable is required for connecting the VR 7000 CMT to the CMT power source.
Do not carry out the steps described here until you have read and completely understood all the operating instructions.
| * | On the VR 7000 CMT only |
| ** | LHSB cable, on CMT interconnecting hosepack only |
When connecting the interconnecting hosepack, check that
all connections are connected properly
all cables, leads and hosepacks are undamaged and correctly insulated.
| Fronius F++ | Euro connection | for Dinse |
VR 7000 | X | X | X |
VR 7000-11 | X | (X) | - |
VR 7000-30 | X | (X) | - |
VR 7000 CMT | X | - | - |
| (X) | ... up to max 500 A |
When using a welding current over 500 A, only operate wirefeeders VR 7000-11 and VR 7000-30 with Fronius welding torches that are adequately dimensioned for the welding torch F++ connection.
When connecting the welding torch, check that
* The MIG/MAG manual welding torch control plug comes in two versions:
| * | Control plug for wire buffer |
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
IMPORTANT! Only use feed rollers that match the wire electrode.
An overview of the feed rollers available and their possible areas of use can be found in the spare parts lists.
In the USA, all wirefeeders are delivered without feed rollers. After inserting the wirespool, the feed rollers must be inserted into the wirefeeder.
Danger from springiness of spooled wire electrode.
This can result in severe injuries.
When inserting the wirespool/basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Danger from falling wirespool/basket-type spool.
Make sure that the wirespool or basket-type spool with adapter is fitted securely to the wirespool holder.
Danger from the wirespool falling because the locking ring has been placed the wrong way around.
Always position the locking ring as shown in the diagram on the left.
When working with basket-type spools, use only the basket-type spool adapter supplied with the wire-feed unit! USA wire-feed units are supplied without basket-type spool adapters.
Danger from falling basket-type spool.
Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
When inserting the wire electrode into the 4 roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
Danger from sharp end of wire electrode.
This may result in damage to the welding torch.
Deburr the end of the wire electrode well before feeding in.
Danger from wire electrode emerging at speed.
When pressing the wire threading button or the torch trigger, keep the welding torch away from your face and body, and wear suitable protective goggles.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
Contact pressure standard values | Semi-cylindrical rolls | Trapeze | Plastic |
Aluminium | 1.5 | - | 3.5 - 4.5 |
Steel | 3 - 4 | 1.5 | - |
CrNi | 3 - 4 | 1.5 | - |
After releasing the torch trigger the wirespool should stop unreeling.
Adjust brake if necessary.
Danger from falling wirespool.
To ensure that the wirespool is properly in place and that the brake works properly, fit the brake according to the following diagram.
The wirefeeding hose option serves to protect the external wire electrode while it is being conveyed to the 4 roller drive of the wirefeeder.
The wirefeeding hose is available in two versions:
Risk of serious injury and property damage or an inferior weld as a result of earth contact or short-circuit of a non-insulated wire electrode.
In the case of automated applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder (e.g. by using a wirefeeding hose).
An earth contact or short-circuit can be caused by:
Using wirefeeding hoses ensures that the wire electrode remains insulated as it is transported towards the wirefeeder. To prevent chafing, do not route the wirefeeding hoses over sharp edges. Use hose holders or hose protectors as necessary. Coupling pieces and hoods for welding wire drums also ensure safe transport of the wire electrode.
The wire-feed unit is commissioned by pressing the torch trigger (for manual applications) or by means of a welding start-up signal (for automatic applications).
Additional requirement for automated applications in conjunction with external wire electrodes:
Under normal operating conditions, the wire-feed unit requires only a minimum of care and maintenance. However, some important points must be noted to ensure that the welding system remains in a usable condition for many years.
Danger due to the effect of compressed air.
Do not bring the air nozzle too close to electronic components.
Supply voltage | 55 V DC |
Nominal current | 4 A |
Wire speed | 0.5 - 22 m/min |
Degree of protection | IP 23 |
Dimensions l x w x h | 640 x 260 x 430 mm |
Weight | 18 kg |
Types of wirespool | all standardised wirespools |
Maximum permitted wirespool weight | 16 kg |
Wirespool diameter | max. 300 mm |
Wire diameter | 0.8 - 1.6 mm |
Wire drive | 4-roller drive |
Maximum shielding gas pressure | 7 bar |
Coolant | Original Fronius |
Maximum coolant pressure | 6 bar |
LocalNet data rate | 57600 baud |
LHSB connection | - |
Weight | 18 kg |
Wire speed | 0.5 - 11 m/min |
Weight | 19 kg |
Wire diameter | 0.8 - 3.2 mm |
Wire drive | 4 roller drive, |
Wire speed | 0.5 - 30 m/min |
Weight | 19 kg |
Weight | 18 kg |
Wire diameter | 0.8 - 1.2 mm |
LHSB data rate | 10 MBaud |
LHSB connection - interconnecting hosepack | Standard |
LHSB CMT drive unit connection | Standard |
Supply voltage for CMT drive unit | 24 V DC, 100 mA |
Wire buffer connection | Standard |
Supply voltage for wire buffer | 24 V DC, 40 mA |
