LogoRobacta Reamer V, V Easy, V Easy Han6P, V Easy Han6PJ
  • en
    • Contact
    • Imprint
    • Terms and Conditions
    • Data privacy statement
    • Variable "Menu5" ist nicht definiert.
    • 043-28052025
    • Safety rules
      • General
      • Proper use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Specific hazards
      • Protecting yourself and others
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Copyright
    • General
      • General
        • Principle
        • Illustration of the various types
        • Device concept - Robacta Reamer V Easy, Robacta Reamer V
        • Device concept - Robacta Reamer V Easy Han6P J
        • Applications
        • Warning notices on the cleaning device
      • Transport
        • Transport means
        • Transport notices on the packaging
      • Robacta Reamer V Easy scope of supply and options
        • Robacta Reamer V Easy options
      • Robacta Reamer V Easy Han6P J scope of supply, options and required components
        • Robacta Reamer V Easy Han6P J required components
        • Robacta Reamer V Easy Han6P J options
      • Robacta Reamer V scope of supply and options
        • Robacta Reamer V options
    • Controls, connections and mechanical components
      • Safety
        • Safety
      • Robacta Reamer V Easy, Robacta Reamer V Easy Han6P J control elements, connections and mechanical components
      • Robacta Reamer V control elements, connections and mechanical components
      • Standard I/O connecting plug (X1) pin assignment for robot control (Robacta Reamer V)
        • General
        • Robacta Reamer V pin assignment on standard I/O connecting plug (X1)
      • Harting Han6P connecting plug pin assignment (X1) for robot control (Robacta Reamer V Easy, Robacta Reamer V Easy Han6P J)
        • General
    • Installation and commissioning
      • Safety
        • Safety
        • Ensuring that the cleaning device is depressurised
      • Before commissioning
        • Operators, maintenance personnel
        • Setup regulations
        • Compressed air supply specifications
        • Measures for the safe operation of the device with untrained personnel
      • Screwing the Robacta Reamer V Easy, Robacta Reamer V to the underlying surface
        • Screwing the cleaning device and installation stand to the underlying surface
        • Screwing the cleaning device to the underlying surface
      • Screwing the Robacta Reamer V Easy Han6P J to the underlying surface
        • Screwing the adjusted cleaning device and installation stand to the underlying surface
      • Torch cleaning position
        • Welding torch cleaning position
      • Adjust gas nozzle clamping device
        • Adjusting the gas nozzle clamping device
      • Fitting the cleaning cutter
        • General
      • Adjusting the lifting device
      • Installing a mechanically or electrically-controlled wire cutter on the Robacta Reamer V Easy
        • Installing the mechanically controlled wire cutter
        • Installing the electrically-controlled wire cutter
      • Installing the adjusted wire cutter
        • Fitting mounting plates for the wire cutter
      • Wire cutter function
        • Maximum wire diameter
        • How the mechanically controlled wire cutter works
        • How the electrically-controlled wire cutter works
      • Installing the compressed air supply
        • Establishing the compressed air supply for the cleaning device, function of the compressed air relief valve
      • Starting up the parting agent nebuliser
        • Fill parting agent container (1 litre) and connect to the cleaning device
        • Connect the parting agent container (10 litres) to the cleaning device
        • Adjusting the parting agent nebuliser spray amount
      • Using the fill-level control sensor
        • General
        • Controls and indicators on the sensor
        • Installation adapter borehole dimensions
        • Fitting the fill-level control sensor
        • Calibrating the empty state
        • Calibrating the full state
        • Locking/unlocking the fill-level control sensor
        • Electrical connection
      • Separating GND for actuators and sensors (Robacta Reamer V only)
        • General
        • Separating GND for actuators and sensors (Robacta Reamer V)
        • Separating GND for actuators and sensors (electrically controlled wire cutter on the Robacta Reamer V)
      • Checking the Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J functions
        • Safety
        • Manually checking the Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J functions
      • Manually checking Robacta Reamer V functions
        • Safety
      • Starting up the cleaning device
        • Prerequisites for start-up
        • Start-up
      • Cleaning programme
        • Safety
        • Cleaning program on the Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J
      • Cleaning signal waveform on the Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J
        • Signal inputs
        • Signal outputs
      • Robacta Reamer V cleaning signal waveform
        • Signal inputs
        • Signal outputs
        • Signal waveform: optional wire cutter (inputs and outputs)
        • Signals not defined using time
    • Care, maintenance and disposal
        • General
        • Before each start-up
        • Daily
        • Weekly
        • Every 6 months
        • As necessary
        • Disposal
    • Troubleshooting
      • Safety
        • Safety
      • Troubleshooting
        • Errors in program sequence
    • Technical data
      • Technical data
        • Robacta Reamer V
    • Appendix
      • Robacta Reamer V Circuit Diagram
      • Robacta Reamer V Easy, Easy Han6P, Easy Han6P J
      • Robacta Reamer V pneumatic diagram
      • Robacta Reamer V Easy and Easy Han6P J pneumatic diagram
      • Declaration of conformity - Robacta Reamer V
      • Declaration of conformity - Robacta Reamer V Easy
    Robacta Reamer V, V Easy, V Easy Han6P, V Easy Han6PJ Operating Instructions
    Control elements and connections Robacta Reamer V Easy, Robacta Reamer V Easy Han6P J
    Cleaning program on the Robacta Reamer V Easy, Robacta Reamer V Easy Han6P and Robacta Reamer V Easy Han6P J
    Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of automated welding, and
    • read and carefully follow these operating instructions as well as the operating instructions for all system components.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before commissioning the device, rectify any faults that could compromise safety.
    1. Safety rules
    Proper use
    The cleaning device is to be used exclusively for the mechanical cleaning of Fronius robot welding torches in automated operation. Any other or additional use is deemed improper.
    Proper use includes:
    • carefully reading these operating instructions
    • following all the instructions and safety rules in these operating instructions
    • performing all stipulated inspection and maintenance work
    The device is designed for operation in industry and commercial use.
    1. Safety rules
    Ambient temperature range:
    • during operation: 0 °C to + 40 °C (32 °F to 104 °F)
    • during transport and storage: -25 °C to +55 °C (-13 °F to 131 °F)
    Relative humidity:
    • up to 50 % at 40 °C (104 °F)
    • up to 90 % at 20 °C (68 °F)
    Keep ambient air free from dust, acids, corrosive gases and substances, etc.
    Can be used at altitudes of up to 2000 m (6500 ft)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so undertake:
    • to observe the basic instructions regarding safety at work and accident prevention,
    • to read these operating instructions, especially the "Safety rules" section and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Specific hazards
    Stay out of the working area of the robot.
    The device must be incorporated into a higher-level safety system within a secured area.
    If this area has to be accessed when setup and maintenance work is carried out, make sure that
    • the entire system is switched off for the duration of the work in this area
    • and that it is prevented from starting up accidentally, e.g. as the result of a control fault.
    If untrained operators have access to the device, its compressed air supply must be disconnected for the duration of work in accordance with "Performance Level d" of the ISO 13849-1 standard.
    In addition to these Operating Instructions, the safety rules issued by the robot manufacturer must also be observed.
    Keep your body, especially your hands, face, hair, clothing and all tools away from moving parts, such as:
    • rotating cleaning cutter
    • upwards/downwards travelling cleaning motor
    • extending/retracting gas nozzle clamping device
    • wire cutter
    Do not touch cleaning cutters immediately after use - risk of burns. Observe the special safety rules in the Operating Instructions for handling cleaning cutters.
    Protect hands, face and eyes against flying parts (shavings, etc.) and compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Covers may only be opened/removed for the duration of any maintenance, installation or repair work.
    During operation
    • Ensure that all covers are closed and fitted properly
    • Keep all covers closed
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks. In addition to these Operating Instructions, the safety rules of the manufacturer of the entire welding system must also be observed.
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers and health risks (crushing from mechanically-powered parts, injury from cleaning cutter, flying shavings and similar matter, escaping compressed air/parting agent mixture, flying sparks, dazzling by arc, inhaling of harmful welding fumes, noise, possible danger from mains or welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check for possible problems, and check and evaluate neighbouring devices' resistance to interference according to national and international requirements:
    • Safety devices
    • Power, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite correct mains connection, additional measures are necessary (e.g. use a suitable line filter).
    2. Control lines
      • must be kept as short as possible
      • must run close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Shield, if necessary
      • Shield off other nearby devices
      • Shield off entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    A device toppling over could easily kill someone. Place the device horizontally on a level, firm and solid surface and anchor it securely to prevent it toppling over.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    After transporting the device, it must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device if all safety devices are fully functional. If the safety devices are not fully functional, there is a risk of
    • damage to the device and other material assets belonging to the operator,
    • Only use suitable original parting agent from the manufacturer.
    • Observe the information on the parting agent safety data sheet when handling parting agent. The parting agent safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    • Do not mix the manufacturer's parting agent with other parting agents.
    • If damage results from using a different parting agent, the manufacturer accepts no liability. In addition, no warranty claims will be entertained.
    • Used parting agent must be disposed of properly in accordance with the relevant national and international regulations.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device is performed at least once every 12 months.
    A safety inspection should be carried out by a qualified electrician
    • after any changes are made
    • after any additional parts are installed, or after any conversions
    • after repair, care and maintenance has been carried out
    • at least every twelve months.
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on safety inspection and calibration can be obtained from your service centre. They will provide you on request with any documents you may require.
    1. Safety rules
    Disposal
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark satisfy the essential requirements of the applicable directives (e.g. low-voltage and electromagnetic compatibility directives, machinery directive).
    Devices with the CSA test mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Copyright
    General
    General
    Principle
    Cleaning devices from the Robacta Reamer V series are used to automatically clean MIG/MAG welding torches. The Robacta Reamer V series cleaning devices allow you to clean the inside and front of the gas nozzle on a wide range of welding torch shapes. The result is a significant increase in the service life of wearing parts. At the same time, evenly applying parting agent prevents the build-up of dirt.
    1. General
    General
    Principle
    1. General
    2. General
    Principle
    1. General
    2. General
    Robacta Reamer V Easy Han6P J, Robacta Reamer V Easy, Robacta Reamer V
    1. General
    2. General
    The gas nozzle clamping device on the front of the cleaning devices holds the gas nozzle in place during cleaning. A cleaning cutter is used to clean the nozzle. After the cleaning process, a parting agent is applied to the inside and front of the gas nozzle through the parting-agent injection nozzle that is fixed in the middle of the cleaning motor.
    The options available for each cleaning device are shown on the following pages.
    1. General
    2. General
    The gas nozzle clamping device on the front of the Robacta Reamer V Easy Han6P J holds the gas nozzle in place during cleaning. A cleaning cutter is used to clean the nozzle. After the cleaning process, a parting agent is applied to the inside and front of the gas nozzle through the parting-agent injection nozzle that is fixed in the middle of the cleaning motor.
    The Robacta Reamer V Easy Han6P J also has an adjustment that works as follows:
    • The manufacturer always screws all Robacta Reamer V Easy Han6P J to an adjustment plate in the same position
    • The Robacta Reamer V Easy Han6P J is fitted to a mounting plate at the installation location
    • Dowel pins interlock the Robacta Reamer V Easy Han6P J adjustment plate and the mounting plate so that the Robacta Reamer V Easy Han6P J is always firmly fastened to the mounting plate in the same position
    • As a result, when a device is replaced, the robot does not have much setting up to do. Once the device is replaced, only the motor in the lifting device of the new cleaning device has to be adjusted
      NOTE!
      The gas nozzle clamping device is adjusted for gas nozzles with an outer diameter of 25 mm (0.98 inch). If gas nozzles with a different outer diameter are used, the gas nozzle clamping device must be adjusted before using it for the first time and each time a device is replaced, as appropriate to the gas nozzle.
    • The same system in connection with the cleaning device is also available for the wire cutter
    Components required for installing the Robacta Reamer V Easy Han6P J:
    • Mounting plate for the Robacta Reamer V Easy Han6P J
    Components required for installing the Robacta Reamer V Easy Han6P J together with the adjusted wire cutter:
    • Adjusted wire cutter
    • Mounting plates for the wire cutter
    The options available for the cleaning device are shown on the following pages.
    1. General
    2. General
    Applications
    The cleaning devices are exclusively intended for use in robot and other automated applications, and can be used for a wide range of materials.
    The main application areas are:
    • Automobile and component supply industry
    • Equipment construction
    • Chemical plant construction
    • Machine and tracked vehicle manufacturing
    • Construction machinery and special vehicles
    1. General
    2. General
    The cleaning device is fitted with warning notices and a rating plate. The warning notices and rating plate must not be removed or painted over.
    The locations of the warning notices are shown on the Robacta Reamer V as an example. The warning notices are all in the same place on the Robacta Reamer V Easy, Robacta Reamer V Easy Han6P and Robacta Reamer V Easy Han6P J.
    WARNING! Risk of serious injury from:
    • mechanically powered components
    • compressed air/parting agent mixture escaping from the parting-agent injection nozzle
    • flying parts (shavings, etc.)
    Keep the device free from current and pressure during maintenance and servicing.
    Do not use the functions described here until you have thoroughly read and understood the following documents:
    • these operating instructions
    • all the operating instructions for the system components, especially the safety rules
    For indoor use only
    Augenschutz benutzen
    Warnung vor automatischem Anlauf
    1. General
    Transport
    Transport means
    The device is to be transported by the following means:
    • On pallets using a counterbalanced lift truck
    • On pallets using a lift truck
    • Manually
    WARNING!
    Danger from falling devices and objects.
    Secure the device to prevent it from falling over while being transporting on a counterbalanced lift truck or lift truck.
    Avoid sudden changes in direction, braking or acceleration.
    1. General
    2. Transport
    Transport means
    • Manually
    WARNING!
    1. General
    2. Transport
    CAUTION!
    Danger due to improper transport.
    Observe the transport notices on the device packaging.
    1. General
    NOTE!
    The "Robacta Reamer" parting agent (item number 42,0411,8042) and the cleaning cutter are not part of the scope of supply.
    (1)
    Robacta Reamer V Easy cleaning device
    (2)
    Spatter tray retainer
    (3)
    Spatter tray
    (4)
    Tightening key for cleaning motor
    (5)
    Compressed air relief valve
    not shown:
    (6)
    Harting Han6P connecting plug (X1) without cable
    (7)
    Operating instructions
    (8)
    Fixings for assembling the cleaning device:
    • 4 screws
    • 4 washers
    • 4 lock washers
    • 4 nuts
    1. General
    2. Robacta Reamer V Easy scope of supply and options
    NOTE!
    (1)
    (2)
    (3)
    Spatter tray
    (4)
    (5)
    not shown:
    (6)
    (7)
    (8)
    • 4 screws
    • 4 washers
    • 4 lock washers
    • 4 nuts
    1. General
    The following options are available for the cleaning device:
    • Installation stand
    • Wire cutter
    • Suction line for canister (10 litres)
    1. General
    NOTE!
    (1)
    Robacta Reamer V Easy Han6P J cleaning device
    (2)
    (3)
    Spatter tray
    (4)
    (5)
    not shown:
    (6)
    (7)
    (8)
    • 4 screws
    1. General
    2. Robacta Reamer V Easy Han6P J scope of supply, options and required components
    NOTE!
    (1)
    (2)
    (3)
    Spatter tray
    (4)
    (5)
    not shown:
    (6)
    (7)
    (8)
    • 4 screws
    1. General
    NOTE!
    The mounting plate and fixings are not part of the scope of supply for the cleaning device, but are needed to ensure that the cleaning device is adjusted when it is installed.
    1. General
    • Mounting plates for the wire cutter including fixings
    1. General
    NOTE!
    (1)
    Robacta Reamer V cleaning device
    (2)
    (3)
    Spatter tray
    (4)
    (5)
    not shown:
    (6)
    Standard I/O connecting plug (X1) without cable
    (7)
    (8)
    • 4 screws
    • 4 washers
    • 4 lock washers
    • 4 nuts
    1. General
    2. Robacta Reamer V scope of supply and options
    NOTE!
    (1)
    (2)
    (3)
    Spatter tray
    (4)
    (5)
    not shown:
    (6)
    (7)
    (8)
    • 4 screws
    • 4 washers
    • 4 lock washers
    • 4 nuts
    1. General
    • Wire cutter
    Safety
    Safety
    Observe the following safety rules for all work described in the "Control elements, connections and mechanical components" chapter.
    WARNING!
    1. Controls, connections and mechanical components
    Safety
    Safety
    WARNING!
    2. Safety
    Safety
    WARNING!
    NOTE!
    The control elements, connections and mechanical components are shown on the Robacta Reamer V Easy.
    The control elements, connections and mechanical components are the same for the Robacta Reamer V Easy Han6P J.
    Side view
    Front view
    (1)
    Harting Han6P connection socket (X1)
    for a + 24 V DC supply
    CAUTION!
    Danger from overcurrent.
    Damage to the Harting Han6P (X1) connection power supply may result.
    Fuse the power supply of the cleaning device with 500 mA slow-blow fuse against overcurrent.
    (2)
    Compressed air connection
    for a dry compressed air supply at 6 bar (86.99 psi)
    Thread identification compressed air connection: G ¼“
    (3)
    Parting agent container
    (4)
    "Cleaning" screw
    for manually testing all cleaning device functions:
    • Cleaning motor on/off
    • Lifting device up/down
    • Gas nozzle clamping device extending/retracting
    • Compressed air and parting agent supply to parting-agent injection nozzle (compressed air/parting agent mixture is sprayed out of the parting-agent injection nozzle)
    (5)
    Parting agent adjuster
    for adjusting the amount of parting agent sprayed inside the gas nozzle
    (6)
    Lifting device
    lifts the cleaning motor and the cleaning cutter when cleaning the inside of the gas nozzle
    (7)
    Cleaning motor with parting-agent injection nozzle
    drives the cleaning cutter
    (8)
    Compressed air connection for the wire cutter option
    (9)
    Parting-agent injection nozzle
    applies the parting agent to the inside and front of the gas nozzle
    (10)
    Cleaning cutter
    with internal through hole for the parting-agent injection nozzle
    (11)
    "Spray parting agent" button
    for manually testing the spray device - when the button is pressed, only the spray device is activated (compressed air or a mixture of compressed air/parting agent is sprayed from the parting-agent injection nozzle). The other functions of the cleaning device remain inactive.
    (12)
    (13)
    Protective covering
    (14)
    TCP (ToolCenterPoint) with protective covering
    Absolute zero position for setting and checking the position of the welding torch (for cleaning purposes)
    CAUTION!
    Danger from exposed tip of TCP.
    This can result in severe injuries.
    The protective covering may only be removed when setting and checking the position of the welding torch.
    Before and after adjusting or checking, the protective covering must remain on the TCP.
    2. Robacta Reamer V Easy, Robacta Reamer V Easy Han6P J control elements, connections and mechanical components
    NOTE!
    Side view
    Front view
    (1)
    CAUTION!
    (2)
    (3)
    (4)
    "Cleaning" screw
    (5)
    (6)
    Lifting device
    (7)
    (8)
    (9)
    (10)
    Cleaning cutter
    (11)
    (12)
    (13)
    Protective covering
    (14)
    CAUTION!
    Side view
    Front view
    (1)
    Standard I/O connection socket (X1)
    CAUTION!
    Damage to standard I/O connection (X1) supply may result.
    (2)
    (3)
    Fill-level control sensor
    emits a signal once the fill level in the parting agent container falls below a specified level
    (4)
    (5)
    (6)
    Protective covering
    (7)
    Lifting device
    (8)
    (9)
    Compressed air and electrical connections for wire cutter option
    (10)
    Cleaning cutter
    (11)
    (12)
    CAUTION!
    This can result in injuries.
    (13)
    "Lifting device up/down" screw
    for manually checking the lifting device (lifting device moves up/down)
    (14)
    "Spray in parting agent" screw
    for manually checking the spray device (compressed air or compressed air/parting agent mixture is sprayed out of the parting-agent injection nozzle)
    (15)
    "Clamp gas nozzle/Cleaning motor on" screw
    for manually checking the gas nozzle clamping device and the cleaning motor (gas nozzle clamping device extends/retracts, cleaning motor off/on)
    (16)
    2. Robacta Reamer V control elements, connections and mechanical components
    Side view
    Front view
    (1)
    CAUTION!
    (2)
    (3)
    (4)
    (5)
    (6)
    Protective covering
    (7)
    Lifting device
    (8)
    (9)
    (10)
    Cleaning cutter
    (11)
    (12)
    CAUTION!
    (13)
    (14)
    (15)
    (16)
    General
    CAUTION!
    Damage to the standard I/O (X1) connection supply may result.
    Secure the power supply of the cleaning device against overcurrent with a 500 mA slow-blow fuse.
    NOTE!
    To avoid malfunction, keep the cable length between the cleaning device and robot control as short as possible.
    The standard I/O (X1) connecting plug for connecting the cleaning device to the robot control is part of the scope of supply. The cable harness must be adapted to the connection technology on the robot control.
    2. Standard I/O connecting plug (X1) pin assignment for robot control (Robacta Reamer V)
    General
    CAUTION!
    NOTE!
    Robacta Reamer V pin assignment on standard I/O connecting plug (X1) - cable-end view
    Input and output signals on the Robacta Reamer V:
    1. Clamp gas nozzle/Cleaning motor ON (cleaning cutter turning) input signal + 24 V DC
    2. GND general
    3. Cleaning motor UP input signal (cleaning cutter moves to cleaning position) + 24 V DC
    4. Spray parting agent input signal + 24 V DC
    5. + 24 V DC (supply)
    6. Gas nozzle free output signal
    1. Gas nozzle clamped output signal
    2. Cleaning motor turning output signal (impulse signal)
    3. Parting agent level OK output signal
    4. Cleaning motor lowered output signal (cleaning cutter in start position)
    5. Cleaning motor raised output signal (cleaning cutter in cleaning position)
    6. Cut wire electrode input signal + 24 V DC
    7. Wire cutter open output signal
    8. Wire cutter closed output signal
    9. Optional GND for sensors - the procedure for connecting the pin is described in the section "Separating GND for actuators and sensors (Robacta Reamer V only)".
    10. Not assigned
    11. Not assigned
    General
    CAUTION!
    Damage to the Harting Han6P connection supply may result.
    NOTE!
    The Harting Han6P connecting plug (X1) for connecting the cleaning device to the robot control is included in the scope of supply. The cable harness must be adapted to the connection technology on the robot control.
    2. Harting Han6P connecting plug pin assignment (X1) for robot control (Robacta Reamer V Easy, Robacta Reamer V Easy Han6P J)
    General
    CAUTION!
    NOTE!
    Harting Han6P connecting plug pin assignment (X1) - cable-end view
    Input and output signals on the Robacta Reamer V Easy Han6P, Robacta Reamer V Easy Han6P J:
    1. Start cleaning input signal (clamp gas nozzle, cleaning motor on, cleaning motor off, spray parting agent)
    2. Not assigned
    3. GND
    4. + 24 V DC
    5. Gas nozzle free output signal
    6. Earthing
    (see circuit diagrams in appendix)
    Safety
    Safety
    WARNING!
    All the work and functions described in this document must only be carried out by trained and qualified personnel.
    Read and understand this document.
    Read and understand all the Operating Instructions for the system components, especially the safety rules.
    WARNING!
    Risk of machines starting automatically.
    In addition to these Operating Instructions, also observe the safety rules issued by the manufacturer of the robot and welding system. Before entering the robot work area, ensure that all protective measures in the robot work area are in place and remain in place for the duration of the access.
    WARNING!
    Danger from mechanically powered parts, flying parts (shavings, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Before carrying out any work, disconnect the compressed air and power supplies from the cleaning device and the connected system components, and ensure that they remain disconnected until work is complete.
    Before carrying out any work, make sure that the cleaning device is depressurised - for the necessary steps, see the following section Ensuring that the cleaning device is depressurised from page (→).
    WARNING!
    Whenever the cleaning device is supplied with voltage and/or compressed air, a risk of serious injury exists from: rotating cleaning cutter, cleaning motor moving up/down, extending/retracting gas nozzle clamping device, activated wire cutter, flying parts (shavings, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    If work has to be performed on the cleaning device while it is being supplied with voltage and/or compressed air, take the following protective measures:
    Keep your body, especially your hands, face, hair, any objects and all clothing away from the cleaning cutter, cleaning motor, lifting device, gas nozzle clamping device, wire cutter and parting-agent injection nozzle.
    Wear ear protection!
    Wear protective goggles with side protection.
    1. Installation and commissioning
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Safety
    Attempt to briefly activate the cleaning device without any compressed air supply to check whether the cleaning device is depressurised. Proceed as follows:
    1Take protective measures:
    • The cleaning cutter, lifting device, gas nozzle clamping device, wire cutter and parting-agent injection nozzle could start up. Therefore keep your body, especially your hands, face and hair, any objects and all clothing away from the components referred to above
    • Wear ear protection
    • Wear protective goggles with side protection
    2Ensure that the cleaning device has been disconnected from the compressed air supply
    Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J:
    3Briefly turn the "Cleaning" screw on the cleaning device 90° to the right, then turn it straight back to its original position
    • If the cleaning device does not respond to the turning of the screw, the cleaning device is depressurised
    • If the cleaning device responds to the turning of the screw, the cleaning device is still connected to a compressed air supply.
      If this is the case, you must disconnect the cleaning device from the compressed air supply and check again that the cleaning device is depressurised before starting work
    Robacta Reamer V:
    3Briefly turn the "Lifting device up/down" screw on the cleaning device 90° to the right, then turn it straight back to its original position
    WARNING!
    The device must only be operated by one person.
    Nobody may be in the working area of the device while it is in operation.
    The device must only be serviced or maintained by one person.
    Nobody else may be within the radius of the device while it is being worked on.
    2. Before commissioning
    WARNING!
    Setup regulations
    The cleaning device is tested to protection class IP 21, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12.5 mm (0.49 in.)
    • No protection against the ingress of water
    The device must not be set up and operated outdoors. The built in electrical parts must be protected from direct wetting.
    WARNING!
    Danger from machines falling or toppling over.
    Always secure the cleaning device to the underlying surface.
    To ensure that the cleaning device functions correctly, the following compressed air supply specifications must be met:
    • Establish compressed air supply using a pressure limiter and compressed air filter
    • Provide compressed air quality conforming to ISO 8573-1:2001, class 7 4 3, instrument air
      • Solid particle concentration £ 10 mg/m3
      • Vapour pressure dew point £ + 3 °C
      • Oil concentration  £ 1 mg/m3
    If untrained operators have access to the device, its compressed air supply must be disconnected for the duration of work in accordance with 'Performance Level d' of the ISO 13849-1 standard.
    To ensure that the compressed air supply is interrupted as required, MS6-SV pressure build-up and pressure relief valves from FESTO are recommended.
    WARNING!
    Always secure the installation stand to the underlying surface.
    The screws for fastening the installation stand are not included in the scope of supply of the installation stand. The installer is responsible for selecting the right type of screws or bolts.
    Always secure the cleaning device to the installation stand.
    1Place the optionally available installation stand on a level, firm and vibration-free surface (foundation)
    • Position the installation stand in such a way that the distance the robot has to travel to the cleaning device on the installation stand is as short as possible
    2Tightly screw the installation stand to the surface (foundation) using the selected mounting materials
    Screw on the cleaning device and the spatter tray retainer using the fixings supplied with the cleaning device.
    Place components on the installation stand and secure
    Attach the spatter tray retainer as shown
    2. Screwing the Robacta Reamer V Easy, Robacta Reamer V to the underlying surface
    WARNING!
    WARNING!
    If the underlying surface thickness is less than 5 mm (0.197 in.), use the fixings supplied with the cleaning device for fastening.
    If the underlying surface thickness is greater than 5 mm (0.197 in.), do not use the fixings supplied for fastening. In this situation the installer is responsible for selecting the right type of fixing.
    1Place the cleaning device and the spatter tray retainer on a level, firm and vibration-free surface (foundation).
    • Position the cleaning device in such a way that the distance the robot has to travel to the cleaning position is as short as possible.
    Place components on the underlying surface and secure
    WARNING!
    Different fixings may be required to set up the installation stand depending on the type of underlying surface (foundation).
    Fixings are therefore not included in the scope of supply of the installation stand. The installer is responsible for selecting the right type of fixing.
    1Place the optional installation stand on a level, firm and vibration-free surface (foundation)
    2Screw the installation stand to the underlying surface (foundation) using the appropriate fixings
    WARNING!
    Use the fixings supplied with the mounting plate to fasten the mounting plate to the installation stand.
    5
    6
    7
    2. Screwing the Robacta Reamer V Easy Han6P J to the underlying surface
    WARNING!
    WARNING!
    5
    6
    7
    NOTE!
    The welding torch cleaning position is shown on the Robacta Reamer V as an example.
    The welding torch cleaning position is the same for all Robacta Reamer V cleaning devices.
    2. Torch cleaning position
    NOTE!
    CAUTION!
    Robacta Reamer V Easy Han6P J only:
    Risk of damage to the cleaning device and the welding torch if the gas nozzle clamping device is not properly adjusted.
    The gas nozzle clamping device must not be altered when using gas nozzles with an outer diameter of 25 mm (0.98 inch) - the gas nozzle clamping device has already been adjusted for use with gas nozzles with an outer diameter of 25 mm (0.98 inch) at the factory.
    When using gas nozzles with an outer diameter greater/less than 25 mm (0.98 inch), the gas nozzle clamping device must be adjusted before using it for the first time and each time a device is replaced.
    NOTE!
    The gas nozzle clamping device is adjusted in the same way on the Robacta Reamer V Easy and the Robacta Reamer V.
    NOTE!
    Adjust the clamping device in such a way that no reaction forces can be transferred to the robot. The gas nozzle must only be clamped onto the cylindrical surface.
    1Loosen the Allen screws on the guide bolts (1) and (2)
    2Move the welding torch to the cleaning position
    • centrally with respect to the cleaning motor
    3Using the adjusting screw (3), position the clamping device (4) so that the clamping device is on the gas nozzle
    4Tighten the Allen screws on the guide bolts (1) and (2)
    5Move and check the TCP tip
    NOTE!
    Only clamp the gas nozzle centrally above the cleaning motor.
    2. Adjust gas nozzle clamping device
    CAUTION!
    NOTE!
    NOTE!
    NOTE!
    General
    NOTE!
    The cleaning cutter is fitted in the same way for all Robacta Reamer V cleaning devices.
    2. Fitting the cleaning cutter
    General
    NOTE!
    CAUTION!
    Danger due to cleaning cutter that has become very hot through use.
    This can result in severe burns.
    Before handling cleaning cutters, allow cleaning cutter to cool to room temperature (+25 °C, +77 °F).
    CAUTION!
    Danger from incompatible wearing parts.
    This can result in damage to property and malfunctions.
    Only use the device manufacturer's contact tips, gas nozzles and cleaning cutters. No liability is accepted for damage caused by the use of contact tips, gas nozzles or cleaning cutters from third-party manufacturers.
    The cleaning cutter is not part of the scope of suppl.. Consult the manufacturer's spare parts list for the appropriate cleaning cutter: https://spareparts.fronius.com/
    1Remove the protective covering from the cleaning device
    3Fit the protective covering to the cleaning device in its original position
    NOTE!
    The lifting device is adjusted in the same way for all Robacta Reamer V cleaning devices.
    1Remove the protective covering (1)
    2Remove the gas nozzle from the torch neck
    3Loosen the screw (2) on the lifting device
    4Ensure that the lifting device (3) is in its lowest lift position
    5Move the welding torch to the cleaning position (approx. 1 - 2 mm / 0.039 - 0.079 in. above the protective covering, centrally with respect to the cleaning motor)
    6Manually push the lifting device (3) into its highest lift position and hold in place
    7Manually push the cleaning motor (4) and cleaning cutter to the cleaning position
    • see diagram (5) for welding torch and spatter guard
    • see diagram (6) for welding torch and insulating sleeve
    NOTE!
    The cleaning cutter must not touch any welding torch components.
    8Fix the cleaning motor (4) in this position in the lifting device (3) - tighten the screw (2) on the lifting device
    9Complete a function test without the gas nozzle fitted: Move the lifting device manually to the uppermost position
    • The cleaning cutter must close around the contact tip without touching it. If the cleaning cutter touches the welding torch components, readjust the lifting device
    10Fit the gas nozzle to the torch neck
    11Complete a function test with the gas nozzle fitted: Move the lifting device manually to the uppermost position
    • The cleaning cutter must be inserted into the gas nozzle gently, without touching it. If the cleaning cutter touches the welding torch components, readjust the lifting device
    12Fit the protective covering to the cleaning device in its original position
    2. Adjusting the lifting device
    NOTE!
    NOTE!
    NOTE!
    Use the fixings supplied with the wire cutter
    Use screws and washers to fit the wire cutter to the cleaning device
    5
    NOTE!
    Route the compressed air hose for the wire cutter behind the cleaning device
    Use a suitable adapter to connect the wire cutter compressed air hose to the cleaning device.
    2. Installing a mechanically or electrically-controlled wire cutter on the Robacta Reamer V Easy
    NOTE!
    5
    NOTE!
    NOTE!
    Ensure that the recesses in the spacers face the cleaning device.
    NOTE!
    The wire cutter must be controlled electrically by the robot control
    NOTE!
    NOTE!
    NOTE!
    NOTE!
    NOTE!
    NOTE!
    The wire cutter is controlled electrically by the robot control
    NOTE!
    Use the fixings supplied with the mounting plates to fasten the mounting plates.
    2. Installing the adjusted wire cutter
    NOTE!
    NOTE!
    NOTE!
    Wire electrodes with a diameter of up to 1.6 mm (0.063 in.) can be cut with an electrically or mechanically controlled wire cutter.
    2. Wire cutter function
    NOTE!
    If you change over to a new welding torch, the mechanically controlled wire cutter must be reset!
    If a torch body pushes the valve lever (1) to the side by more than 15° with the gas nozzle, the wire cutter is activated and the wire electrode is cut.
    NOTE!
    The wire electrode is cut while the torch body is moving.
    The electrically-controlled wire cutter opens and closes when there is an active signal from the robot control.
    To establish the compressed air supply:
    1Depressurise the compressed air supply line of the cleaning device and ensure that it remains depressurised for the duration of the following work on the device
    2Screw the supplied compressed air relief valve into the compressed air connection on the cleaning device
    3Connect the compressed air supply line to the compressed air relief valve
    The compressed air supply to the cleaning device can be broken and re-established by moving the compressed air relief valve forwards and backwards - see description below.
    The diagram below shows the compressed air relief valve in the closed position = no compressed air supply to the device:
    Compressed air relief valve closed
    The diagram below shows the compressed air relief valve in the open position = compressed air is being supplied to the device:
    Compressed air relief valve open
    2. Installing the compressed air supply
    NOTE!
    Only use "Robacta Reamer" parting agent (item number 42,0411,8042) supplied by the manufacturer.
    The composition of the manufacturer's parting agent is designed specifically for the cleaning device. If other manufacturers' products are used, trouble-free operation cannot be guaranteed.
    2. Starting up the parting agent nebuliser
    NOTE!
    NOTE!
    The composition of this parting agent is designed specifically for the cleaning device. If other manufacturers' products are used, trouble-free operation cannot be guaranteed.
    * Option (long parting agent hose)
    NOTE!
    To ensure that the spray amount is adjusted properly, the welding torch must be in the cleaning position.
    1Establish a compressed air supply to the cleaning device
    2Connect the cleaning device to the robot control
    3Start the spraying process using the robot control and check that sufficient spray is being applied
    4If the spray amount is not sufficient, increase it as required
    • by adjusting the spray time using the robot control - a spray time of ~ 0.7 seconds is recommended (nur Robacta Reamer V only)
    • or by using the parting agent adjuster - see figure below
    Finely adjusting the spray amount on parting agent adjuster
    General
    The fill-level control sensor emits a signal once the fill level in the parting agent container falls below a specified level.
    2. Using the fill-level control sensor
    General
    (1)
    'OUT OFF' button
    for programming the sensor
    (2)
    'OUT ON' button
    (3)
    LED
    indicates the sensor operating status
    • LED on/flashing: sensor is active
    • LED on/not flashing: sensor is not active
    NOTE!
    First press the upper part of the sensor into the installation adapter as shown - the sockets (1) on the installation adapter must fit into the recesses (2) in the sensor.
    When the upper part of the sensor is properly lined up in the installation adapter, press the sensor fully into the installation adapter - the latch (3) on the installation adapter must snap back over the sensor (sensor audibly engages).
    Use the fixings supplied with the sensor.
    Screw the installation adapter and sensor on to the parting agent container housing
    Fixings are not included in the sensor/installation adapter scope of supply. The installer is responsible for selecting the right type of fixing.
    NOTE!
    Ensure the fixings do not damage the parting agent container.
    1Drain the parting agent container until the parting agent level is at least 20 mm (0.787 in.) below the sensor
    2Establish a power supply to the sensor
    3Press the "OUT OFF" button for between 2 and 6 seconds
    • The LED on the sensor flashes slowly
    • After releasing the "OUT OFF" button the LED goes out - the sensor has detected a low fluid level
    1Fill the parting agent container with parting agent
    2Press the "OUT OFF" button for at least 6 seconds
    • The sensor LED flashes slowly at first, then more rapidly after 6 seconds
    • After releasing the "OUT OFF" button the LED goes out - the sensor has detected a high fluid level
    NOTE!
    It is possible to lock the fill-level control sensor to prevent it from being adjusted accidentally.
    Locking the fill-level control sensor:
    1Simultaneously press the "OUT OFF" and "OUT ON" buttons for at least 10 seconds
    • The LED status changes briefly
      • if the LED lights up when locking, it will go out briefly after locking
      • if the LED does not light up when locking, it will come on briefly after locking
    Unlocking the fill-level control sensor:
      • if the LED lights up when unlocking, it will go out briefly after unlocking
      • if the LED does not light up when unlocking, it will come on briefly after unlocking
    Wire colours:
    1.
    brown
    3.
    blue
    4.
    black
    General
    NOTE!
    The separate GND supply for actuators and sensors is only available for devices purchased after 01/01/2017.
    2. Separating GND for actuators and sensors (Robacta Reamer V only)
    General
    NOTE!
    NOTE!
    Once the cable clip has been removed from the terminal strip, pin 15 becomes available on the standard I/O connecting plug (X1) as GND for sensors and pin 2 as GND for actuators.
    For more information on the standard I/O connecting plug, see section "Standard I/O connecting plug (X1) pin assignment for robot control".
    NOTE!
    After reconnecting the cables, the actuators and sensors of the wire cutter are supplied separately with GND.
    Safety
    WARNING!
    For the following tasks, the cleaning device must be supplied with compressed air. This results in danger from the rotating cleaning cutter, cleaning motor moving up/down, gas nozzle clamping device moving out/in, flying parts (chips, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Keep your body, especially your hands, face, hair, any objects and all clothing awayfrom the cleaning cutter, cleaning motor, lifting device, gas nozzle clamping device,wire cutter and parting-agent injection nozzle..
    2. Checking the Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J functions
    Safety
    WARNING!
    NOTE!
    Functions are deactivated if the slot on the "Cleaning" screw is horizontal.
    1Disconnect the cleaning device from the robot control
    2Establish a compressed air supply to the cleaning device
    The following must be checked when the functions are being performed:
    • how far the cleaning cutter is inserted into the gas nozzle
    • function of the gas nozzle clamping device
    • function of the cleaning motor
    • parting agent emerging from the parting-agent injection nozzle
    Lifting device up/down, Clamp gas nozzle/Cleaning motor on, Spray in parting agent
    Deactivating the functions
    If necessary, only activate the spray device:
    5
    Spraying in parting agent
    The following must be checked when the function is being performed:
    Safety
    WARNING!
    2. Manually checking Robacta Reamer V functions
    Safety
    WARNING!
    NOTE!
    When the slot for the "Lifting device up/down", "Spray in parting agent" and "Clamp gas nozzle/Cleaning motor on" screws is positioned horizontally, function is deactivated.
    • operation of the gas nozzle clamping device
    • function of cleaning motor
    Clamp gas nozzle/cleaning motor on
    5
    6
    7
    8
    The following requirements must be met before the cleaning device is started up:
    • If present, the cleaning device installation stand is screwed to the underlying surface
    • The cleaning device is screwed to the underlying surface
    • The gas nozzle clamping device has been adjusted - not on the Robacta Reamer V Easy Han6P J and if a gas nozzle with an outer diameter of 25 mm ( 0,98 inch) is used. For more information, see "Adjusting the gas nozzle clamping device"
    • The cleaning cutter is fitted
    • The lifting device has been adjusted
    • If present, the wire cutter has been installed
    • If present, the parting agent nebuliser is started up
    • If present, the fill-level control sensor is started up
    • The compressed air supply has been established
    • The functions have been checked manually
    • The cleaning device is connected to the robot control
    • All coverings are fitted and all safety devices are intact and in their proper place
    2. Starting up the cleaning device
    Start-up
    The cleaning device starts up when there is an active signal from the robot control.
    Cleaning programme
    Safety
    CAUTION!
    Danger due to improper installation and commissioning.
    The cleaning device's functions must be manually checked before starting automatic operation.
    Do not start in automated mode until the cleaning device has been properly installed and started up.
    NOTE!
    Not coating the interior of the welding torch may result in permanent soiling of the torch when welding begins.
    Always wet the interior of the welding torch with the manufacturer's parting agent before starting automatic operation.
    2. Cleaning programme
    Safety
    CAUTION!
    NOTE!
    Signal inputs
    Start cleaning (clamp gas nozzle, cleaning motor on, cleaning motor off, spray parting agent):
    2. Cleaning signal waveform on the Robacta Reamer V Easy and Robacta Reamer V Easy Han6P J
    Signal inputs
    Signal outputs
    Gas nozzle free:
    Signal inputs
    Clamp gas nozzle/cleaning motor on:
    Cleaning motor up:
    Spray in parting agent:
    2. Robacta Reamer V cleaning signal waveform
    Signal inputs
    Cleaning motor up:
    Signal outputs
    Gas nozzle free:
    Gas nozzle clamped:
    Cleaning motor turning (impulse signal):
    Cleaning motor lowered:
    Cleaning motor raised:
    Cut wire electrode input signal:
    Wire cutter open output signal:
    Wire cutter closed output signal:
    Parting agent level OK:
    General
    The cleaning device generally needs no maintenance. However, to keep the cleaning device in good working condition for years to come, several points on care and maintenance must be observed.
    1. Care, maintenance and disposal
    General
    2. Care, maintenance and disposal
    General
    • Check fill level in parting agent container and top up if necessary
    • Check fill level in parting agent spatter tray and empty if necessary
    • Check cleaning cutter for wear and replace if necessary
    • Empty the cleaning device spatter tray
    • If fitted, empty the wire cutter tray
    • Carry out a general visual inspection of the cleaning device and make sure that any damage is repaired immediately (before start-up)
    Daily
    CAUTION!
    Danger from cleaning agents containing solvents.
    Only use solvent-free cleaning products on the cleaning device.
    1Remove parting agent deposits and dirt from device
    Weekly
    CAUTION!
    Only use solvent-free cleaning products on the parting agent container.
    1Check the parting agent container for soiling and clean if necessary
    2Blow through suction filter in parting agent container using compressed air from the inside outwards through the suction hose (for more detailed information see section Starting up the parting agent nebuliser from page (→))
    Every 6 months
    1Open the device and check the pneumatic valves for
    • Leaks
    • The secure seating of all screws
    • The secure seating of all screw joints on the pneumatic valves
    As necessary
    Open the device and
    1Clean inside of device using dry reduced compressed air
    2Lightly oil the lifting device cylinder guides
    3Restore the original condition of the device
    Disposal
    Troubleshooting
    Safety
    Safety
    Observe the following safety rules for all work described in the "Troubleshooting" section.
    WARNING!
    WARNING!
    In addition to these Operating Instructions, also observe the safety rules issued by the manufacturer of the robot and welding system. For your personal safety, ensure that all protective measures have been taken and will remain in place while you are in the working area of the robot.
    WARNING!
    Before carrying out any work, disconnect the customer's compressed air and power supplies from the cleaning device and the connected system components, and ensure that they remain disconnected until work is complete.
    WARNING!
    CAUTION!
    1. Troubleshooting
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    2. Safety
    Robacta Reamer V:
    1. Troubleshooting
    Troubleshooting
    1. Troubleshooting
    2. Troubleshooting
    The parting agent does not spray
    Parting agent container is full
    Cause:Not enough spray
    Remedy:Adjust spray time
    Cause:Parting agent hose suction filter in the parting agent container is soiled
    Remedy:Clean the suction filter of the parting agent hose with compressed air (for more detailed information, see section Starting up the parting agent nebuliser from page (→))
    Cause:No signal from robot
    Remedy:Check robot program
    Cause:Parting-agent injection nozzle blocked
    Remedy:Clean parting-agent injection nozzle
    Contact After-Sales Service (arrange for parting-agent injection nozzle to be replaced)
    Cause:Vacuum pump faulty
    Remedy:Contact After-Sales Service (arrange for vacuum pump to be replaced)
    Cause:Mechanical fault on solenoid valve
    Remedy:Contact After-Sales Service (arrange for solenoid valve to be replaced)
    Welding torch is poorly cleaned or damaged
    Cause:Position of the cleaning motor has been set incorrectly
    Remedy:Set the position of the cleaning motor correctly - see section Adjusting the lifting device from page (→)
    Cause:Gas nozzle clamped in wrong position
    Remedy:Adjust the gas nozzle clamping device - see section Adjust gas nozzle clamping device from page (→)
    Cause:Cleaning cutter not suited to welding torch shape
    Remedy:Fit the correct cleaning cutter
    Cause:Cleaning cutter is worn
    Remedy:Replace cleaning cutter
    Lifting device is not moving up or down
    Cause:No compressed air supply
    Remedy:Establish a compressed air supply
    Cause:Choke valve not adjustable, or faulty
    Remedy:Contact After-Sales Service (arrange for choke valve to be replaced)
    Cause:Faulty sealing in lifting cylinder
    Remedy:Contact After-Sales Service (arrange for lifting cylinder to be replaced)
    Cleaning motor does not work
    Cause:Mechanical fault on cleaning motor
    Remedy:Contact After-Sales Service (arrange for cleaning motor to be replaced)
    Technical data
    Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼“
    Harting Han6P (X1)
    Input: + 24 V DC/ max. 100 mA
    Output: + 24 V DC / max. 30 mA
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    Parting agent container capacity
    1 l
    0.26 gal. (US)
    Degree of protection
    IP 21
    Marks of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    Max. noise emission (LWA)
    82 dB (A)
    Dimensions l x w x h
    165 x 245 x 350 mm
    6.50 x 9.65 x 13.78 in.
    Weight
    (without parting agent and optional wire cutter)
    10 kg
    22.05 lb.
    1. Technical data
    Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼“
    Harting Han6P (X1)
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    1 l
    0.26 gal. (US)
    IP 21
    Marks of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    82 dB (A)
    165 x 245 x 350 mm
    Weight
    10 kg
    22.05 lb.
    1. Technical data
    2. Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼“
    Harting Han6P (X1)
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    1 l
    0.26 gal. (US)
    IP 21
    Marks of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    82 dB (A)
    165 x 245 x 350 mm
    Weight
    10 kg
    22.05 lb.
    1. Technical data
    2. Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼“
    Harting Han6P (X1)
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    1 l
    0.26 gal. (US)
    IP 21
    Marks of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    82 dB (A)
    185 x 245 x 352 mm
    7.28 x 9.65 x 13.86 in.
    Weight
    (without parting agent, wire cutter and mounting plates for the wire cutter / Robacta Reamer V Easy Han6P J)
    11 kg
    24.25 lb.
    1. Technical data
    2. Technical data
    Robacta Reamer V
    Supply voltage
    + 24 V DC
    Nominal output
    7.2 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    440 l/min
    465 qt./min
    G ¼“
    Standard I/O (X1)
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    1 l
    0.26 gal. (US)
    IP 21
    Marks of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    82 dB (A)
    185 x 250 x 350 mm
    7.28 x 9.84 x 13.78 in.
    Weight
    11.5 kg
    25.35 lb.
    Appendix
    1. Appendix
    1. Appendix
    1. Appendix
    1. Appendix
    1. Appendix
    1. Appendix
