LogoRobacta Reamer brush head for aluminium applications
  • en
    • Contact
    • Imprint
    • Terms and Conditions
    • Data privacy statement
    • Cookie Policy
    • 023-04062025
    • Safety rules
      • General
      • Proper use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Specific hazards
      • Protecting yourself and others
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Copyright
    • General
      • General
        • General
        • Device concept
        • Application areas
        • Scope of supply
        • Options
        • Warning notices on the cleaning device
      • Transport
        • Transport means
        • Transport notices on the packaging
    • Controls, connections and mechanical components
      • Safety
        • Safety
        • Control elements, connections and mechanical components
      • Harting Han6P connecting plug pin assignment (X1) for robot control
        • General
    • Installation and commissioning
      • Safety
        • Safety
        • Ensuring that the cleaning device is depressurised
      • Before commissioning
        • Operators, maintenance personnel
        • Setup regulations
        • Compressed air supply specifications
        • Measures for the safe operation of the device with untrained personnel
      • Screwing the cleaning device to the underlying surface
        • Screwing the cleaning device and installation stand to the underlying surface
      • Adjusting and fitting the standard brush head
        • General
        • Adjusting the brush head
        • Fitting the brush head
      • Adjusting and fitting the Braze+ brush head
        • General
      • Torch cleaning position
        • Cleaning position of the welding torch - standard brush head
        • Cleaning position of the welding torch - Braze+ brush head
      • Adjusting the position of the cleaning motor (with standard brush head)
      • Adjusting the position of the cleaning motor (with Braze+ brush head)
      • Installation and function of mechanically-controlled wire cutter (option)
        • How the mechanically controlled wire cutter works
        • Maximum wire diameter
        • Installing the mechanically-controlled wire cutter
      • Installation and function of electrically-controlled wire cutter (option)
        • How the electrically-controlled wire cutter works
        • Installing the electrically-controlled wire cutter
      • Installing the compressed air supply
        • Establishing the compressed air supply for the cleaning device, function of the compressed air relief valve
      • Manually checking the cleaning device functions
        • Safety
        • Checking functions manually
      • Starting up the cleaning device
        • Prerequisites for start-up
        • Start-up
      • Cleaning program and signals
        • Safety
        • Cleaning program sequence
        • Signal inputs and outputs
    • Care, maintenance and disposal
      • Safety
        • Safety
        • General
        • Before each start-up
        • Daily
        • Every 6 months
        • As necessary
        • Changing the end brushes (standard brush head only)
        • Changing the round brush
        • Changing the diagonal brushes
        • Disposal
    • Troubleshooting
      • Safety
        • Safety
      • Troubleshooting
        • Errors in program sequence
    • Technical data
      • Technical data
        • Robacta Reamer brush head for aluminium applications
    • Appendix
      • Circuit diagram: Robacta Reamer brush head for aluminium applications
      • Pneumatics diagram of Robacta Reamer brush head for aluminium applications
      • Circuit diagram: Wire cutter
      • Declaration of conformity
    Robacta Reamer brush head for aluminium applications Operating Instructions
    Controls and connections
    Pin assignment (connection for the robot control)
    Cleaning programme sequence
    Spare parts
    Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of automated welding, and
    • read and carefully follow these operating instructions as well as the operating instructions for all system components.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before commissioning the device, rectify any faults that could compromise safety.
    1. Safety rules
    Proper use
    The cleaning device is to be used exclusively for the mechanical cleaning of Fronius robot welding torches in automated operation. Any other or additional use is deemed improper.
    Proper use includes:
    • carefully reading these operating instructions
    • following all the instructions and safety rules in these operating instructions
    • performing all stipulated inspection and maintenance work
    The device is designed for operation in industry and commercial use.
    1. Safety rules
    Ambient temperature range:
    • during operation: 0 °C to + 40 °C (32 °F to 104 °F)
    • during transport and storage: -25 °C to +55 °C (-13 °F to 131 °F)
    Relative humidity:
    • up to 50 % at 40 °C (104 °F)
    • up to 90 % at 20 °C (68 °F)
    Keep ambient air free from dust, acids, corrosive gases and substances, etc.
    Can be used at altitudes of up to 2000 m (6500 ft)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so undertake:
    • to observe the basic instructions regarding safety at work and accident prevention,
    • to read these operating instructions, especially the "Safety rules" section and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Specific hazards
    Stay out of the working area of the robot.
    The device must be incorporated into a higher-level safety system within a secured area.
    If this area has to be accessed when setup and maintenance work is carried out, make sure that
    • the entire system is switched off for the duration of the work in this area
    • and that it is prevented from starting up accidentally, e.g. as the result of a control fault
    If untrained operators have access to the device, its compressed air supply must be disconnected for the duration of work in accordance with "Performance Level d" of the ISO 13849-1 standard.
    In addition to these operating instructions, the safety rules issued by the robot manufacturer must also be observed.
    Keep your body, especially your hands, face, hair, clothing and all tools away from moving parts, such as:
    • rotating brush head
    • lifting device moving up/down
    • wire cutter
    Protect hands, face and eyes against flying parts (shavings, etc.) and compressed air escaping from the cleaning nozzles.
    Covers may only be opened/removed for the duration of any maintenance, installation or repair work.
    During operation
    • Ensure that all covers are closed and fitted properly
    • Keep all covers closed
    1. Safety rules
    When welding, you expose yourself to numerous dangers. In addition to these operating instructions, the safety rules of the manufacturer of the entire welding system must also be observed.
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity,
    • make them aware of all the dangers and health risks (crushing from mechanically-powered parts, injury from brush head, flying shavings and similar matter, escaping compressed air, flying sparks, dazzling by arc, inhaling of harmful welding fumes, noise, possible danger from mains or welding current, etc.),
    • provide suitable protective equipment or
    • erect suitable safety screens/curtains.
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check for possible problems, and check and evaluate neighbouring devices' resistance to interference according to national and international requirements:
    • Safety devices
    • Power, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite correct mains connection, additional measures are necessary (e.g. use a suitable line filter).
    2. Control lines
      • must be kept as short as possible
      • must run close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Shield, if necessary
      • Shield off other nearby devices
      • Shield off entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    A device toppling over could easily kill someone. Place the device horizontally on a level, firm and solid surface and anchor it securely to prevent it toppling over.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    After transporting the device, it must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device if all safety devices are fully functional. If the safety devices are not fully functional, there is a risk of
    • damage to the device and other material assets belonging to the operator,
    • Only use suitable original parting agent from the manufacturer.
    • Observe the information on the parting agent safety data sheet when handling parting agent. The parting agent safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    • Do not mix the manufacturer's parting agent with other parting agents.
    • If damage results from using a different parting agent, the manufacturer accepts no liability. In addition, no warranty claims will be entertained.
    • Used parting agent must be disposed of properly in accordance with the relevant national and international regulations.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device is performed at least once every 12 months.
    A safety inspection should be carried out by a qualified electrician
    • after any changes are made
    • after any additional parts are installed, or after any conversions
    • after repair, care and maintenance has been carried out
    • at least every twelve months.
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on safety inspection and calibration can be obtained from your service centre. They will provide you on request with any documents you may require.
    1. Safety rules
    Disposal
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE label meet the requirements of all valid EU Directives, such as:
    • Directive 2014/30/EU on electromagnetic compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • and others
    The full text of the EU Declaration of Conformity is available at
    Devices bearing the CSA label satisfy the requirements of the relevant standards for Canada and the USA.
    1. Safety rules
    Copyright
    General
    General
    General
    The cleaning device automatically cleans MIG/MAG welding torches, which are used to weld aluminium materials. This device allows you to clean the inside, front and outside of the gas nozzle across a wide range of torch geometries. The result is a significant increase in the service life of wearing parts.
    1. General
    General
    General
    1. General
    2. General
    General
    1. General
    2. General
    Device concept
    A brush head is used to clean the welding torch. The brush head is equipped with different brush types, giving optimal cleaning results. All brushes can be replaced without the need for any tools.
    Welding residues are blown away from the welding torch and brush head by two cleaning nozzles.
    A stable installation stand is available for the cleaning device.
    1. General
    2. General
    Application areas
    The cleaning device is ideal for use in robot and other automated applications.
    The main application areas are:
    • Automobile and component supply industry
    • Equipment construction
    • Chemical plant construction
    • Machine and tracked vehicle manufacturing
    • Construction machinery and special vehicles
    1. General
    2. General
    Scope of supply
    NOTE!
    The brush head is not part of the scope of supply.
    (1)
    Robacta Reamer brush head cleaning device for aluminium applications
    (2)
    Spatter tray retainer
    (3)
    Spatter tray
    (4)
    Tightening key for cleaning motor
    (5)
    Compressed air relief valve
    Not shown:
    (6)
    Harting Han6P connecting plug (X1) without cable
    (7)
    Operating instructions
    (8)
    Fixings for assembling the cleaning device:
    • 4 screws
    • 4 washers
    • 4 lock washers
    • 4 nuts
    1. General
    2. General
    Options
    The following options are available for the cleaning device:
    • Installation stand
    • Wire cutter
    1. General
    2. General
    NOTE!
    The cleaning device is fitted with warning notices and a rating plate.
    The warning notices and rating plate must not be removed or painted over.
    WARNING! Risk of serious injury from:
    • mechanically powered parts
    • compressed air escaping from the cleaning nozzles
    • flying parts (shavings, etc.)
    Keep device free from current and pressure during maintenance and servicing.
    Do not use the functions described here until you have thoroughly read and understood the following documents:
    • these operating instructions
    • all the operating instructions for the system components, especially the safety rules
    For indoor use only
    Wear eye protection
    Warning: Automatic start-up
    1. General
    Transport
    Transport means
    The device is to be transported by the following means:
    • On pallets using a counterbalanced lift truck
    • On pallets using a lift truck
    • Manually
    WARNING!
    Danger from falling devices and objects.
    Secure the device to prevent it from falling over while being transporting on a counterbalanced lift truck or lift truck.
    Avoid sudden changes in direction, braking or acceleration.
    1. General
    2. Transport
    Transport means
    • Manually
    WARNING!
    1. General
    2. Transport
    CAUTION!
    Danger due to improper transport.
    Observe the transport notices on the device packaging.
    Safety
    Safety
    Observe the following safety rules when using all functions described in the "Controls, connections and mechanical components" section.
    WARNING!
    Danger from incorrect operation!
    The functions described must only be used by trained and qualified personnel.
    these Operating Instructions,
    all the Operating Instructions for the system components, especially the safety rules
    1. Controls, connections and mechanical components
    Safety
    Safety
    WARNING!
    2. Safety
    Safety
    WARNING!
    Side view
    Front view
    No. Function
    (1)
    Harting Han6P connection socket (X1)
    for a 24 V DC supply
    CAUTION!
    Risk of damage to Harting Han6P connection (X1) supply due to overcurrent.
    Secure supply against overcurrent with a 500 mA slow-blow fuse.
    (2)
    Compressed air connection
    for a dry compressed air supply at 6 bar (86.99 psi)
    Thread identification compressed air connection: G ¼ ″
    For more details on compressed air conditions, see section Compressed air supply specifications  on page (→)
    (3)
    "Cleaning" screw
    for manually checking the following functions:
    • Cleaning motor ON/OFF
    • Supply of compressed air to the cleaning nozzles (compressed air emerges from cleaning nozzles)
    • Lifting device UP/DOWN
    (4)
    Protective covering
    (5)
    Cleaning nozzles
    for cleaning the brush head and welding torch using compressed air
    (6)
    Compressed air connection for the wire cutter option
    (7)
    Lifting device
    lifts the cleaning motor with the brush head to the cleaning position ready to commence cleaning
    (8)
    Cleaning motor
    drives the brush head
    2. Controls, connections and mechanical components
    Side view
    Front view
    No. Function
    (1)
    CAUTION!
    (2)
    (3)
    "Cleaning" screw
    (4)
    Protective covering
    (5)
    Cleaning nozzles
    (6)
    (7)
    Lifting device
    (8)
    Cleaning motor
    General
    CAUTION!
    Danger from overcurrent.
    Damage to the Harting Han6P connection supply may result.
    Secure the power supply of the cleaning device against overcurrent with a 500 mA slow-blow fuse.
    NOTE!
    To avoid malfunction, keep the cable length between the cleaning device and robot control as short as possible.
    The Harting Han6P connecting plug (X1) for connecting the cleaning device to the robot control is included in the scope of supply. The cable harness must be adapted to the connection technology on the robot control.
    2. Harting Han6P connecting plug pin assignment (X1) for robot control
    General
    CAUTION!
    NOTE!
    Harting Han6P connecting plug pin assignment (X1) - cable-end view
    Input and output signals on the Robacta Reamer Alu brush head:
    1. Start cleaning input signal (cleaning motor ON, lifting device UP, compressed air supply to cleaning nozzles ON)
    2. Not assigned
    3. GND
    4. + 24 V DC
    5. Cleaning motor DOWN output signal
    6. Earthing
    (see circuit diagrams in appendix)
    Safety
    Safety
    Observe the following safety rules for all work described in the "Installation and start-up" section.
    WARNING!
    Incorrect operation or poorly executed work can cause serious injury or damage.
    All activities described in these operating instructions may only be carried out by trained and qualified personnel. All functions described in these operating instructions may only be used by trained and qualified personnel. Do not carry out any of the work or use any of the functions described until you have fully read and understood the following documents:
    WARNING!
    Machines that start up automatically can cause serious injury and damage.
    In addition to these operating instructions, the safety rules issued by the manufacturer of the robot and welding system must also be observed. For your personal safety, ensure that all protective measures have been taken and will remain in place while you are in the working area of the robot.
    WARNING!
    mechanically powered components
    Before performing work on the cleaning device or any connected system components:
    disconnect the customer's compressed air and power supplies from the cleaning device and the connected system components, and ensure that they remain disconnected until work is complete
    ensure that the cleaning device is depressurised - please see the "Ensuring that the cleaning device is depressurised" section below for the relevant instructions
    WARNING!
    Whenever the cleaning device and connected system components are supplied with voltage and/or compressed air, a risk of serious injury exists from:
    rotating brush head
    activated wire cutter
    If work has to be performed on the cleaning device while it is being supplied with voltage and/or compressed air:
    keep your body, especially your hands, face, hair, tools and all clothing away from the brush head, brush head lifting device, wire cutter and cleaning nozzles
    wear ear protection
    wear protective goggles with side protection
    1. Installation and commissioning
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    2. Safety
    Attempt to briefly activate the cleaning device without any compressed air supply to check whether the cleaning device is depressurised. Proceed as follows:
    1Take protective measures:
    • The brush head, brush head lifting device, wire cutter and cleaning nozzles could start up. Therefore keep your body, especially your hands, face and hair, any objects and all clothing away from the parts referred to above
    • wear ear protection
    • wear protective goggles with side protection
    2Ensure that the cleaning device has been disconnected from the compressed air supply
    3Briefly turn the "Cleaning" screw on the cleaning device 90° to the right, then turn it straight back to its original position
    • If the cleaning device does not respond to the turning of the screw, the cleaning device is depressurised
    • If the cleaning device responds to the turning of the screw, the cleaning device is still connected to a compressed air supply. If this is the case, you must disconnect the cleaning device from the compressed air supply and check again that the cleaning device is depressurised before starting work
    WARNING!
    Risk of machines starting automatically.
    The device must only be operated by one person.
    Nobody may be in the working area of the device while it is in operation.
    The device must only be serviced or maintained by one person.
    Nobody else may be within the radius of the device while it is being worked on.
    2. Before commissioning
    WARNING!
    Setup regulations
    The cleaning device is tested to protection class IP 21, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12.5 mm (0.49 in.)
    • No protection against the ingress of water
    The device must not be set up and operated outdoors. The built in electrical parts must be protected from direct wetting.
    WARNING!
    Danger from machines falling or toppling over.
    Always secure the cleaning device to the underlying surface.
    To ensure that the cleaning device functions correctly, the following compressed air supply specifications must be met:
    • Establish compressed air supply using a pressure limiter and compressed air filter
    • Provide compressed air quality conforming to ISO 8573-1:2001, class 7 4 3, instrument air
      • Solid particle concentration £ 10 mg/m3
      • Vapour pressure dew point £ + 3 °C
      • Oil concentration  £ 1 mg/m3
    If untrained operators have access to the device, its compressed air supply must be disconnected for the duration of work in accordance with 'Performance Level d' of the ISO 13849-1 standard.
    To ensure that the compressed air supply is interrupted as required, MS6-SV pressure build-up and pressure relief valves from FESTO are recommended.
    WARNING!
    Always secure the installation stand to the underlying surface.
    The screws for fastening the installation stand are not included in the scope of supply of the installation stand. The installer is responsible for selecting the right type of screws or bolts.
    Always secure the cleaning device to the installation stand.
    1Place the optionally available installation stand on a level, firm and vibration-free surface (foundation)
    • Position the installation stand in such a way that the distance the robot has to travel to the cleaning device on the installation stand is as short as possible
    2Tightly screw the installation stand to the surface (foundation) using the selected mounting materials
    Screw on the cleaning device and the spatter tray retainer using the fixings supplied with the cleaning device.
    Place components on the installation stand and secure
    Attach the spatter tray retainer as shown
    2. Screwing the cleaning device to the underlying surface
    WARNING!
    WARNING!
    If the underlying surface thickness is less than 5 mm (0.197 in.), use the fixings supplied with the cleaning device for fastening.
    If the underlying surface thickness is greater than 5 mm (0.197 in.), do not use the fixings supplied for fastening. In this situation the installer is responsible for selecting the right type of fixing.
    1Place the cleaning device and the spatter tray retainer on a level, firm and vibration-free surface (foundation).
    • Position the cleaning device in such a way that the distance the robot has to travel to the cleaning position is as short as possible.
    Place components on the underlying surface and secure
    General
    NOTE!
    The following information applies to the use of the manufacturer's contact tips, gas nozzles and brush head.
    If other manufacturers' products are used, trouble-free operation of the device cannot be guaranteed. The manufacturer accepts no liability for damage arising from the use of other manufacturers' contact tips, gas nozzles or brush heads.
    The brush head has two different settings (A and B) to modify the distance between the diagonal brushes according to the type of gas nozzle being used.
    NOTE!
    The following list of settings is intended as a guide only.
    Setting A for:
    standard gas nozzles with an outer diameter up to 23 mm (0.91 inch)
    Setting B for:
    standard gas nozzles with an outer diameter from 24 mm (0.95 inch) upwards
    2. Adjusting and fitting the standard brush head
    General
    NOTE!
    NOTE!
    Setting A for:
    Setting B for:
    Adjust the brush head as follows:
    1Remove the protective covering from the cleaning device
    3Fit the protective covering to the cleaning device in its original position
    General
    NOTE!
    2. Adjusting and fitting the Braze+ brush head
    General
    NOTE!
    • End of gas nozzle is approx. 45 mm (1.77 in.) beneath upper edge of cleaning device housing, positioned centrally with respect to the cleaning motor
    2. Torch cleaning position
    • End of gas nozzle is approx. 90 mm (3.54 in.) beneath upper edge of cleaning device housing, positioned centrally with respect to the cleaning motor
    2Ensure that the lifting device (1) is in its lowest position
    3Move the welding torch to the cleaning position
    4Remove the gas nozzle from the torch body
    5
    6Loosen screw (2) on the lifting device (1)
    7Manually push the lifting device (1) into its highest lift position and hold in place
    8Manually push the cleaning motor (3) and brush head (4) into the cleaning position
    • see diagram (5) for welding torch with spatter guard
    • see diagram (6) for welding torch with insulating sleeve
    9Fix the cleaning motor (3) in this position in the lifting device (1) - tighten the screw (2) on the lifting device (1)
    10Fit the gas nozzle to the torch body
    11Press brush head together and pull off bracket
    12Fit the protective covering to the cleaning device in its original position
    2. Adjusting the position of the cleaning motor (with standard brush head)
    5
    4Loosen screw (2) on the lifting device (1)
    5Manually push the lifting device (1) into its highest lift position and hold in place
    6Manually push the cleaning motor (3) and brush head (4) into the cleaning position
    7Fix the cleaning motor (3) in this position in the lifting device (1) - tighten the screw (2) on the lifting device (1)
    8Fit the protective covering to the cleaning device in its original position
    2. Adjusting the position of the cleaning motor (with Braze+ brush head)
    NOTE!
    If you change over to a new welding torch, the mechanically controlled wire cutter must be reset!
    If a torch body pushes the valve lever (1) to the side by more than 15° with the gas nozzle, the wire cutter is activated and the wire electrode is cut.
    NOTE!
    The wire electrode is cut while the torch body is moving.
    2. Installation and function of mechanically-controlled wire cutter (option)
    NOTE!
    NOTE!
    Wire electrodes with a diameter of up to 1.6 mm (0.063 in.) can be cut by the wire cutter.
    NOTE!
    Use the fixings supplied with the wire cutter for the assembly shown.
    NOTE!
    Use a suitable adapter to connect the wire cutter compressed air hose to the cleaning device.
    The electrically-controlled wire cutter opens and closes when there is an active signal from the robot control.
    2. Installation and function of electrically-controlled wire cutter (option)
    NOTE!
    Use the fixings supplied with the wire cutter for the work described below.
    Ensure that the recesses in the spacers face the cleaning device.
    Use supplied adapter to connect the wire cutter compressed air hose to the cleaning device.
    NOTE!
    The wire cutter must be controlled electrically by the robot control.
    Function of the compressed air relief valve
    To establish the compressed air supply:
    1Depressurise the compressed air supply line (1) and ensure that it remains depressurised for the duration of the work on the device
    2Screw the supplied compressed air relief valve tightly to the compressed air connection on the cleaning device
    3Connect the compressed air supply line (1) to the compressed air relief valve
    Function of the compressed air relief valve:
    • Valve open (2): compressed air is being supplied
    • Valve closed (3): compressed air is not being supplied
    2. Installing the compressed air supply
    Safety
    WARNING!
    For the following tasks, the cleaning device must be supplied with compressed air. This results in danger from the rotating cleaning cutter, cleaning motor moving up/down, gas nozzle clamping device moving out/in, flying parts (chips, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Keep your body, especially your hands, face, hair, any objects and all clothing awayfrom the cleaning cutter, cleaning motor, lifting device, gas nozzle clamping device,wire cutter and parting-agent injection nozzle..
    Wear ear protection!
    Wear protective goggles with side protection.
    2. Manually checking the cleaning device functions
    Safety
    WARNING!
    NOTE!
    Functions are deactivated if the slot on the "Cleaning" screw is horizontal.
    The following must be checked when the functions are being performed:
    • function of the cleaning motor (cleaning motor OFF/ON)
    • correct setting of the cleaning motor (lifting device moves UP/DOWN)
      • Standard brush head: for more details, see section Adjusting the position of the cleaning motor (with standard brush head)  from page (→)
      • Braze+ brush head: for more details, see section Adjusting the position of the cleaning motor (with Braze+ brush head)  from page (→)
    • function of the cleaning nozzles (compressed air emerges from cleaning nozzles)
    1Establish the compressed air supply to the welding torch cleaning device
    Deactivating the functions
    The following requirements must be met before the cleaning device is started up:
    • If present, the cleaning device installation stand is screwed to the underlying surface
    • The cleaning device is screwed to the underlying surface
    • Brush head is fitted
    • Position of the cleaning motor has been set
    • Compressed air supply has been established
    • Functions have been checked manually
    • Cleaning device is connected to the robot control
    • All coverings are fitted and all safety devices are intact and in their proper place
    2. Starting up the cleaning device
    Start-up
    The cleaning device starts up when there is an active signal from the robot control.
    Safety
    CAUTION!
    Danger due to improper commissioning.
    Only start automatic mode once the cleaning device has been installed and commissioned properly.
    2. Cleaning program and signals
    Safety
    CAUTION!
    Signal input „start cleaning (cleaning motor ON, lifting device UP, compressed air supply to cleaning nozzles ON)“:
    Signal output „cleaning motor down“:
    Safety
    Safety
    Observe the following safety rules for all work described in the "Care, maintenance and disposal" section.
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    1. Care, maintenance and disposal
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    2. Safety
    General
    The cleaning device generally needs no maintenance. However, to keep the cleaning device in good working condition for years to come, several points on care and maintenance must be observed.
    2. Care, maintenance and disposal
    General
    • Check the cleaning brushes on the brush head and replace worn brushes
    • Empty the cleaning device spatter tray
    • If fitted, empty the wire cutter tray
    • Carry out a general visual inspection of the cleaning device and wire cutter
    Daily
    • Remove any dirt deposits from device
    Every 6 months
    1Open the device and check the pneumatic valves for
    • Leaks
    • The secure seating of all screws
    • The secure seating of all screw joints on the pneumatic valves
    As necessary
    Open the device and
    1Clean inside of device using dry reduced compressed air
    2Lightly oil the lifting device cylinder guides
    3Restore the original condition of the device
    4Fit the protective covering to the cleaning device in its original position
    NOTE!
    In the process described below for changing the round brush, a standard brush head is shown.
    The process is identical for aBraze+ brush head.
    NOTE!
    Before changing the brush, note the setting of the brush head (A or B) and be sure to use this setting during assembly.
    This will ensure that the correct clearance is maintained between the diagonal brushes after the brush has been changed.
    5
    6Fit the protective covering to the cleaning device in its original position
    NOTE!
    In the process described below for changing a diagonal brush, a standard brush head is shown.
    NOTE!
    Before changing the brushes, note the setting of the brush head (A or B) and be sure to use this setting during assembly.
    5Fit the protective covering to the cleaning device in its original position
    Disposal
    Troubleshooting
    Safety
    Safety
    Observe the following safety rules for all work described in the "Troubleshooting" section.
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    1. Troubleshooting
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    1. Troubleshooting
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    rotating brush head
    wear ear protection
    1. Troubleshooting
    2. Safety
    1. Troubleshooting
    Troubleshooting
    1. Troubleshooting
    2. Troubleshooting
    Welding torch is poorly cleaned or damaged
    Cause:Position of the cleaning motor has been set incorrectly
    Remedy:Adjust the position of the cleaning motor
    Cause:Worn cleaning brushes on cleaning head
    Remedy:Replace cleaning brushes on cleaning head
    Lifting device is not moving up or down
    Cause:Compressed air relief valve closed
    Remedy:Open compressed air relief valve
    Cause:No signal from robot
    Remedy:Check connection to robot control
    Cause:Mechanical fault on solenoid valve
    Remedy:Contact After-Sales Service (arrange for solenoid valve to be replaced)
    Cause:Choke valve not adjustable, or faulty
    Remedy:Contact After-Sales Service (arrange for choke valve to be replaced)
    Cause:Faulty sealing in lifting cylinder
    Remedy:Contact After-Sales Service (arrange for lifting cylinder to be replaced)
    Cleaning motor does not work
    Cause:Mechanical fault on cleaning motor
    Remedy:Contact After-Sales Service (arrange for cleaning motor to be replaced)
    Technical data
    Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼ ″
    Max. noise emission (LWA)
    82 dB (A)
    Standard I/O
    Input: + 24 V DC/ max. 100 mA
    Output: + 24 V DC / max. 30 mA
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    Degree of protection
    IP 21
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    Dimensions l x w x h
    165 x 245 x 350 mm
    6.50 x 9.65 x 13.78 in.
    Weight
    (without optional wire cutter)
    10 kg
    22.05 lb.
    1. Technical data
    Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼ ″
    82 dB (A)
    Standard I/O
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    IP 21
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    165 x 245 x 350 mm
    Weight
    10 kg
    22.05 lb.
    1. Technical data
    2. Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼ ″
    82 dB (A)
    Standard I/O
    Cleaning time
    3.0 - 5.0 s
    Total cycle time
    4.0 - 7.5 s
    IP 21
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    165 x 245 x 350 mm
    Weight
    10 kg
    22.05 lb.
    Appendix
    1. Appendix
    1. Appendix
    1. Appendix
    1. Appendix
