Indicates immediate danger.
All safety and danger notices on the deviceFor the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
Before switching on the device, rectify any faults that could compromise safety.
The device is intended solely for the welding processes specified on the rating plate.
Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
The manufacturer likewise accepts no liability for inadequate or incorrect results.
Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended purpose. The manufacturer shall not be held liable for any damage arising from such usage.
Ambient temperature range:The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
This may affect a number device types in terms of:*) at the interface with the public grid
see "Technical data"
In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
IMPORTANT! Ensure that the mains connection is earthed properly
The fumes produced during welding contain harmful gases and vapours.
Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
Keep your face away from welding fumes and gases.
Fumes and hazardous gasesEnsure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
Flying sparks may cause fires or explosions.
Never weld close to flammable materials.
Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
An electric shock is potentially life threatening and can be fatal.
Do not touch live parts either inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wirespool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Use the handle to ensure the power connections are tight before every use.
In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
Do not wrap cables or leads around the body or parts of the body.
The electrode (rod electrode, tungsten electrode, welding wire, etc.) mustDouble the open circuit voltage of a power source can occur between the welding electrodes of two power sources. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer shall not be held liable for any damage arising from such usage.
If necessary, provide adequate earthing for the workpiece.
Switch off unused devices.
Wear a safety harness if working at height.
Before working on the device, switch it off and pull out the mains plug.
Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
After opening the device:If work on live parts is required, appoint a second person to switch off the main switch at the right moment.
Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
Do not reach into the rotating cogs of the wire drive or into rotating drive components.
Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
During operationThe welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
Therefore, always keep the welding torch away from the body (devices with wirefeeder) and wear suitable protective goggles.
Never touch the workpiece during or after welding - risk of burns.
Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
Special provisions apply in areas at risk of fire or explosion
- observe relevant national and international regulations.
Power sources for work in areas with increased electric risk (e.g. near boilers) must carry the "Safety" sign. However, the power source must not be located in such areas.
Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
Use filters if necessary.
Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
Keep the shielding gas cylinders well away from any welding or other electrical circuits.
Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
Turn your face to one side when opening the valve of a shielding gas cylinder.
Close the shielding gas cylinder valve if no welding is taking place.
If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
Risk of suffocation from the uncontrolled escape of shielding gas
Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
Only the manufacturer's original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
Only use suitable original coolant from the manufacturer.
Do not mix the manufacturer's original coolant with other coolants.
Only connect the manufacturer's system components to the cooling circuit.
The manufacturer accepts no liability for damage resulting from use of other system components or a different coolant. In addition, all warranty claims will be forfeited.
Cooling Liquid FCL 10/20 does not ignite. The ethanol-based coolant can ignite under certain conditions. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Check the coolant level before starting to weld, while the system is still cool.
The manufacturer recommends that a safety inspection of the device is performed at least once every 12 months.
The manufacturer recommends that the power source be calibrated during the same 12-month period.
A safety inspection should be carried out by a qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on safety inspection and calibration can be obtained from your service centre. They will provide you on request with any documents you may require.
Waste electrical and electronic equipment must be collected separately and recycled in an environmentally-friendly way, in accordance with the European Directive and national legislation. Used equipment must be returned to the distributor or disposed of via an approved local collection and disposal facility. Correct disposal of used equipment promotes the sustainable recycling of material resources. Failing to dispose of used equipment correctly can lead to adverse health and/or environmental impacts.
Packaging materials
Separate collection according to material. Check your local authority regulations. Crush containers to reduce size.
Devices with the CE mark satisfy the essential requirements of the low-voltage and electromagnetic compatibility directives (e.g. relevant product standards of the EN 60 974 series).
Fronius International GmbH hereby declares that the device is compliant with Directive 2014/53/EU. The full text on the EU Declaration of Conformity can be found at the following address: http://www.fronius.com
The user is responsible for the safekeeping of any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
The text and illustrations are all technically correct at the time of printing. We reserve the right to make changes. The contents of the operating instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the instructions, we will be most grateful for your comments.
The TransSteel (TSt) 2700c and 3500c power sources are completely digitised, microprocessor-controlled inverter power sources.
The modular design and potential for system add-ons ensure a high degree of flexibility. The devices are designed for the welding of steel.
All devices are suitable for:The TransSteel (TSt) 2700c and 3500c power sources are completely digitised, microprocessor-controlled inverter power sources.
All devices are suitable for:The central control and regulation unit of the power sources is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Control algorithms ensure that the desired target state is maintained.
The device has a "Power limitation" safety feature. This means that the power source can be operated at the power limit without compromising process safety.
This results in:The devices are used in workshops and industry for manual applications with classical steel and galvanised sheets.
The TSt 2700c power sources are primarily used in light-gauge steel sheet (light steelwork) applications. Repair, maintenance, and assembly work in shipyards, automotive suppliers, workshops or the furniture construction industry are among the typical application areas. The TSt 2700c power sources thus position themselves in their power category between the trade/workshop sector and the industry sector.
The TSt 3500c power sources are designed for:Warning notices and safety symbols are affixed to the power sources. These warning notices and safety symbols must not be removed or painted over. They warn against operating the device incorrectly, as this may result in serious injury and damage.
Welding is dangerous. The following basic requirements must be met:
Do not use the functions described here until you have thoroughly read and understood the following documents:
The power sources can be operated with various system components and options. This makes it possible to optimise procedures and to simplify machine handling and operation, as necessitated by the particular field of application in which the power source is to be used.
| (1) | Welding torch |
| (2) | Gas cylinder holder stabiliser |
| (3) | Power source |
| (4) | Trolley and gas cylinder holder |
| (5) | Grounding (earthing) cable and electrode cable |
| (4) | Cooling unit TSt 3500c only |
| (5) | Trolley and gas cylinder holder |
| (6) | Grounding (earthing) cable and electrode cable |
A Voltage Reduction Device (VRD) is an optional safety device for reducing the voltage. It is recommended for environments in which the risk of an electric shock or electrical accident is increased considerably during arc welding:
A low human body resistance is possible when there is:
In wet, damp or hot locations, humidity or sweat can significantly reduce the skin resistance and the insulation resistance of protective equipment and clothing.
Such environments can include:
The VRD option reduces the voltage between the electrode and the workpiece. In safe conditions, the indicator for the currently selected welding process is permanently lit. A safe condition is defined as follows:
For as long as the welding operation is active (welding circuit resistance < 200 Ohm), the indicator of the currently selected welding process flashes and the output voltage may exceed 35 V.
The welding circuit resistance is greater than the minimum human body resistance (greater than or equal to 200 Ohm):
The welding circuit resistance is less than the minimum human body resistance (less than 200 Ohm):
In MMA welding mode:
Within 0.3 seconds of end of welding:
The functions on the control panel are all arranged in a logical way. The individual parameters required for welding can be
The power source uses the Synergic control panel and certain general items of data such as sheet thickness, filler metal, wire diameter and shielding gas to calculate the best welding parameters. As a result, stored knowledge is available at all times. All the parameters can be adjusted manually. The Synergic control panel also allows parameters to be set manually.
Due to software updates, you may find that your device has certain functions that are not described in these operating instructions or vice versa.
Individual illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
(1) | "Parameter selection" button (right) | |
(2) | "Parameter selection" button (left) | |
(3) | Adjusting dial (right) | |
(4) | Adjusting dial (left) | |
(5) | "Save" buttons (Easy Job) | |
(6) | "Process" button ***) | |
(7) | "Mode" button | |
(8) | "Shielding gas" button | |
(9) | "Wire diameter" button | |
(10) | "Material" button | |
(11) | "Gas-test" button
(12) | "Wire threading" button | |
(13) | Intermediate arc indicator | |
(14) | HOLD indicator | |
(15) | SF - spot / stitch welding indicator | |
*) | If one of these parameters is selected in the MIG/MAG standard synergic welding process, then the synergic function ensures that all other parameters, including the welding voltage parameter, are adjusted automatically. |
**) | The Real Energy Input display must be activated in level 2 of the Setup menu – EnE parameter. The value continuously rises during welding in line with the permanently increasing energy yield. The final value at the end of welding remains stored until welding starts again or the power source is switched back on - the HOLD indicator lights up. |
***) | In conjunction with the VRD option, the currently selected welding process indicator is simultaneously an additional indicator:
Various service parameters can be retrieved by pressing the "Parameter selection" buttons at the same time.
Opening the display
1Press and hold the "Parameter selection" button (left) | ||
2Press the "Parameter selection" button (right) | ||
3Release the "Parameter selection" buttons |
The first parameter ("Firmware version") is displayed, e.g. "1.00 | 4.21"
Selecting parameters
1Select the required setup parameter using the "Mode" and "Process" buttons or the left-hand adjusting dial | ||
Available parameters
Example: 1.00 | 4.21
Firmware version
Example: 2 | 491
Welding program configuration
Example: r 2 | 290
Number of the currently selected welding program
Example: iFd | 0.0
Motor current for wire drive in A
The value changes as soon as the motor is running.
Example: 654 | 32.1 = 65,432.1 hours = 65,432 hours 6 mins
Indicates the actual arc time since using for the first time
Note: The arc time indicator is not suitable as a basis for calculating hiring fees, for warranty purposes, etc.
2nd
2nd menu level for service engineers
A keylock can be selected to prevent the settings from being inadvertently changed on the control panel. As long as the keylock is active
Activate/deactivate the keylock as follows:
1Press and hold the "Mode" button | ||
3Release the "Mode" and "Parameter Selection" buttons |
Keylock activated:
The message "CLO | SEd" appears on the displays.
Keylock deactivated:
The message "OP | En" appears on the displays.
| (1) | Welding torch connection for connecting the welding torch |
| (2) | (-) - Current socket with bayonet latch used for
| (3) | LocalNet connection Standardised connection for remote control |
| (4) | (+) - Current socket with bayonet latch used for
| (5) | Shielding gas connection |
| (6) | Mains switch for switching the power source on and off |
| (7) | Mains cable with strain relief device |
| (8) | Air filter |
| (8) | Air filter |
| (3) | (+) - Current socket with bayonet latch used for
| (4) | LocalNet connection Standardised connection for remote control |
| (5) | Mains switch for switching the power source on and off |
| (6) | Mains cable with strain relief device |
| (7) | Air filter |
| (8) | Shielding gas connection |
| (1) | Wirespool holder with brake for holding standard wirespools with a max. diameter of 300 mm (11.81 in.) and a max. weight of up to 19 kg (41.89 lbs.) |
| (2) | 4-roller drive |
| (3) | LED wirespool interior lighting (TSt 2700c only) with the setup parameter LED the turn-off time is adjustable |
Depending on which welding process you intend to use, a certain minimum equipment level will be needed in order to work with the power source.
The welding processes and the minimum equipment levels required for the welding task are then described.
The power source may only be used for MIG/MAG and MMA welding.
Any other form of usage is deemed "not in accordance with the intended purpose".
The manufacturer shall not be held liable for any damages arising from such usage.
The device can be set up and operated outdoors in accordance with degree of protection IP 23.
Avoid direct wetting (e.g. from rain).
Danger from machines toppling over or falling.
Set up the device securely on an even, solid surface.
Check all screw connections are tightly fastened after installation.
Danger from electrical current due to electrically conductive dust in the device.
Only operate the device with an air filter fitted. The air filter is a very important safety device for achieving IP 23 protection.
The venting duct is a very important safety device. When choosing the installation location, ensure that the cooling air can enter and exit unhindered through the air ducts on the front and back of the device. Electroconductive metallic dust (e.g. from grinding work) must not be allowed to get sucked into the device.
The devices are designed for the mains voltage specified on the rating plate. If your version of the appliance does not come with mains cables and plugs ready-fitted, these must be fitted in accordance with national regulations and standards. For details of fuse protection of the mains lead, please see the technical data.
Danger due to insufficiently dimensioned electrical installations.
Dimension the mains lead and its fuse to suit the local power supply.
The technical data shown on the rating plate applies.
A strain-relief device for the following cable cross-sections is fitted to the power source:
Power source | Cable cross-section |
TSt 2700c | AWG 14 to AWG 6 *) | 4G2.5 |
TSt 3500c | AWG 12 *) | 4G2.5 |
| *) | Canada / US cable type: Extra-hard usage |
Strain-relief devices for other cable cross-sections must be designed accordingly.
Power source | Mains voltage | Cable cross-section |
TSt 2700c | 1 x 230 / 240 V | AWG 14 (15 A) *) | 3G2.5 (16 A) |
TSt 2700c | 1 x 240 V | AWG 12 (20 A) *) | - |
TSt 2700c | 1 x 240 V | AWG 12 (30 A) *) | - |
TSt 2700c | 3 x 200 V | AWG 12 | 4G2.5 |
TSt 2700c | 3 x 230 / 240 V | AWG 14 | 4G2.5 |
TSt 2700c | 3 x 380 / 400 V | AWG 14 *) | 4G2.5 |
| 3 x 460 V | AWG 14 *) | 4G2.5 |
TSt 3500c | 3 x 380 / 400 V | AWG 12 *) | 4G2.5 |
| 3 x 460 V | AWG 12 *) | 4G2.5 |
The item numbers of the different cables can be found in the spare parts list.
American Wire Gauge
The work described below must only be carried out by trained and qualified personnel.
Observe national standards and directives.
Danger due to improperly prepared mains cable.
This can cause short circuits and damage.
Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before commissioning.
The ground conductor should be approx. 10 - 15 mm (0.4 - 0.6 in.) longer than the phase conductors.
An illustration of the mains cable connection can be found in the following sections for fitting the strain-relief device. To connect the mains cable, proceed as follows:
IMPORTANT!
Tie the phase conductors near the strain-relief device using cable ties.
IMPORTANT!
IMPORTANT!
IMPORTANT!
Tie the phase conductors near the luster terminal using cable ties.
IMPORTANT!
The power source is generator-compatible.
The maximum apparent power S1max of the power source must be known in order to select the correct generator output.
The maximum apparent power S1max of the power source is calculated as follows:
3-phase devices: S1max = I1max x U1 x √3
Single-phase devices: S1max = I1max x U1
See device rating plate or technical data for I1max and U1 values
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator may be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the power source.
When using single-phase devices with a 3-phase generator, note that the specified generator apparent power is often only available as a whole across all three phases of the generator. If necessary, obtain further information on the single-phase power of the generator from the generator manufacturer.
The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
Details of the mains voltage tolerance can be found in the "Technical data" section.
SGEN = S1max x 1.35
As an alternative to three-phase operation, the multivoltage variant (MV) of the power source enables a welding operation with limited power or duration from just a single-phase supply. The maximum possible welding power is limited due to the dimensioning of the mains fuse protection, upon which the safety cut-out of the power source is dependant.
If the mains cable has a 20 A or 30 A fuse, the FUS parameter may be changed to 20 A or 30 A. Welding with a higher maximum power or for longer periods is therefore possible. The FUS parameter is in the level 2 Setup menu and can be set for a single-phase supply as well as to a US setting (SEt parameter to US).
In order to use the power source in single-phase operation, the following prerequisites must be fulfilled:
The following table shows which mains voltages and fuse values limit the welding current in single-phase operation:
Mains voltage | Fuse value | Welding current limitation |
230 V
| 10 A
| MIG/MAG welding: |
230 V
| 13 A
| MIG/MAG welding: |
230 V
| 16 A
| MIG/MAG welding: |
240 V | 15 A | MIG/MAG welding: |
240 V | 20 A | MIG/MAG welding: |
240 V | 30 A | MIG/MAG welding: |
* | The 100% values relate to welding with no time limits and without cooling breaks |
The welding current data applies at an ambient temperature of 40°C (104°F).
At a mains voltage of 240 V and a fuse value of 30 A the maximum value of 220 A for the MIG/MAG welding for instance is possible at a duty cycle of 40 %.
In single-phase operation a safety cut-out function prevents a triggering of the fuse at higher welding power values. The safety cut-out function is active at fuse values of 15 A, 16 A and 20 A and determines the possible welding time, without triggering of the fuse. If a cut-out of the welding current results due to exceeding the pre-calculated welding time, the service code „toF“ is displayed. In addition to the readout „toF“ from now on a countdown runs for displaying the remaining waiting time, until the welding readiness is restored. Then the message disappears an the power source is operational again.
At a fuse value of 30 A the temperature monitoring of the power source ensures the timely shutdown of the welding current, yet before the fuse triggers. This results in the display of the service codes „to1“ to „to7“. Detailed information concerning the servicecodes „to1“ to „to7“ is located in chapter „Troubleshooting and maintenance, section „Displayed service codes“. If there is no defect or soiling of the cooling components, here the power source is also ready for welding again after an adequate welding break.
230 V
| 10 A
| MIG/MAG welding: |
230 V
| 13 A
| MIG/MAG welding: |
230 V
| 16 A
| MIG/MAG welding: |
For single-phase operation duty cycle values are given in the chapter „Technical data“, depending on the existing fuse value and the welding current. The percentage rates of this duty cycle values indeed relate as well to the 10-minute cycle, as explained in chapter „Technical data“ for the general duty cycle, however the cooling phase of the fuse is rated at only approximately 60 s. Thereafter, the power source is already operational again.
For reasons of technical standards the duty cycle in single-phase operation is only given for the time until the cut-out within the first welding cycle takes place. If the reference to the 10 minute cycle would also persist with regard to the cooling phase, which is usually valid for specifying the duty cycle, in practice longer welding phases than specified would be possible. You see that the specification relates to cooling phases of only approximately 60 s, after which the power source is already operational again.
The example given in the following shows the standard compliant welding and break cycles, at a welding current of 180 A and a duty cycle of 15 %.
The following diagram shows the welding time, which is possible according to the technical standards, depending on the given fuse value and the welding current.
(1) Mains fuse protection 10 A (2) Mains fuse protection 13 A
(3) Mains fuse protection 15 A (4) Mains fuse protection 16 A
(5) Mains fuse protection 20 A
The steps and activities described below include references to various system components, such as
For more detailed information about installing and connecting the system components, please refer to the appropriate operating instructions.
The following diagram shows an overview of how the individual system components are put together.
For detailed information about the individual steps, please refer to the corresponding operating instructions for the system components.
If gas cylinders topple over, there is a risk of very serious injury and damage.
When using gas cylinders
place them on a solid, level surface in such a way that they remain stable
secure the gas cylinders to prevent them from falling over
fit the optional wirefeeder holder
follow the gas cylinder manufacturer's safety rules.
US devices (TSt 3500c only) are supplied with an adapter for the gas hose:
Seal male thread spacers on the gas solenoid valve using suitable means before screwing on the adapter.
Test the adapter to ensure that it is gas-tight.
Danger from electric current due to defective system components and incorrect operation.
All cables, leads and hosepacks must always be securely connected, undamaged and correctly insulated.
Only use adequately dimensioned cables, leads and hosepacks.
Risk of injury if the feed roller holders fly upwards.
When unlocking the lever, keep fingers away from the area to the left and right of the lever.
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
An overview of the available feed rollers can be found in the spare parts lists.
Risk of injury from springiness of spooled wire electrode.
When inserting the wirespool / basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Risk of injury from falling wirespool/basket-type spool.
Make sure that the wirespool or basket-type spool with basket-type spool adapter is fitted securely to the wirespool holder.
Risk of injury and material damage if the wirespool/basket-type spool topples over because the locking ring has been placed the wrong way round.
Always place the locking ring as shown in the diagram on the left.
When working with basket-type spools, only use the basket-type spool adapter included in the scope of supply.
When inserting the wire electrode into the 4-roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
Risk of damage to the welding torch from sharp end of wire electrode.
Deburr the end of the wire electrode well before feeding in.
Risk of injury from wire electrode emerging at speed.
When pressing the "Wire threading" button or the torch trigger, keep the welding torch away from your face and body, and wear suitable protective goggles.
IMPORTANT! To facilitate wire threading, the following sequences are possible when the "Wire threading" button is pressed and held down.
If you release the "Wire threading" button and press it again before one second has elapsed, the sequence starts again from the beginning. This makes it possible to continuously position the wire at a low wire feed speed of 1 m/min or 39.37 ipm where necessary.
If there is no "Wire threading" / "Gas-test" button, the torch trigger can be used in the usual way. Before using the torch trigger for wire threading, proceed as follows:
Risk of injury and damage from electric shock and from the wire electrode emerging from the torch..
When pressing the torch trigger
do not point the welding torch at people
make sure that the wire electrode does not touch any conductive or earthed parts (e.g. Housing etc.)
IMPORTANT! If the torch trigger is pressed instead of the "Wire threading"/"Gas-test" button, the welding wire runs at the feeder creep speed (depending on the welding program) for the first 3 seconds. After these 3 seconds, wirefeeding is briefly interrupted.
The welding system detects that the welding process should not start, but that the wire is to be fed in. At the same time, the gas solenoid valve closes, and the welding voltage on the wire electrode is switched off.
If the torch trigger is kept pressed, wire feeding restarts immediately without shielding gas and welding voltage, and the process continues as described above.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeed.
Standard values for the U-groove rollers:
Steel: 4 - 5
CrNi: 4 - 5
Tubular cored electrodes: 2 - 3
After releasing the torch trigger the wirespool must stop unreeling.
If it continues unreeling, readjust the brake.
Danger from incorrect installation.
Do not dismantle the brake.
Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
The brake is only available as a complete unit.
This illustration of the brake is for information purposes only.
Operating the equipment incorrectly can cause serious injury and damage.
Do not use the functions described here until you have read and completely understood these Operating Instructions.
Do not use the functions described here until you have fully read and understood all of the Operating Instructions for the system components, in particular the safety rules.
The device is started up by pressing the torch trigger (for manual applications).
Before proceeding further as described in the "Welding mode" section, the following activities are required for the "MIG/MAG standard synergic welding" and "MIG/MAG standard manual welding" processes:
"Power limitation" is a safety function for MIG/MAG welding. This means that the power source can be operated at the power limit whilst maintaining process safety.
Wire speed is a determining parameter for welding power. If it is too high, the arc gets smaller and smaller and may be extinguished. In order to prevent this, the welding power is lowered.
For the selected "MIG/MAG standard synergic welding" process, the symbol for the "Wire speed" parameter flashes as soon as the safety function trips. The flashing continues until the next welding start-up, or until the next parameter change.
For example, if the "Wire speed" parameter is selected, the reduced value for wire speed is displayed.
For details of the meaning, settings, setting range and units of the available welding parameters (e.g. gas pre-flow time), please refer to the "Setup parameters" chapter.
"4-step mode" is suitable for longer weld seams.
Special 4-step mode allows the starting and final current to be configured in addition to the advantages of 4-step mode.
The "Spot welding" mode is suitable for welded joints on overlapped sheets.
Start by pressing and releasing the torch trigger - GPr gas pre-flow time - Welding current phase for the duration of the SPt spot welding time - GPo gas post-flow.
If the torch trigger is pressed again before the end of the spot welding time (< SPt), the process is cancelled immediately.
The "2-step stitch welding" mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the base material.
The "4-step stitch welding" mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the base material.
1Press the "Material" button to select the filler metal to be used. | ||
2Press the "Wire diameter" button to select the diameter of the wire electrode used. | ||
3Press the "Shielding gas" button to select the shielding gas to be used. The assignment of the SP position is in the welding program tables in the appendix. | ||
4Press the "Process" button to select the desired welding process: | ||
5Press the "Mode" button to select the desired MIG/MAG mode: | ||
| IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component (TR 2000 or TR 3000 remote control) on the control panel of the power source. | |
6Use the "Parameter selection" buttons to select the welding parameters to be used to specify the welding power: | ||
7Use the appropriate adjusting dial to set the relevant welding parameters. | ||
| The welding parameter values are shown in the digital display located above them. | |
8Open the gas cylinder valve | ||
9Setting the shielding gas flow rate: | ||
make sure that the wire electrode does not touch any conductive or earthed parts (e.g. housing)
10Press the torch trigger and start welding |
To obtain the best possible welding results, the arc length correction and dynamic welding parameters will sometimes need to be corrected.
The MIG/MAG standard manual welding process is a MIG/MAG welding process with no synergic function.
Changing one parameter does not result in any automatic adjustments to the other parameters. All of the variable parameters must therefore be adjusted individually, as dictated by the welding process in question.
The following parameters are available in MIG/MAG manual welding:
Wire feed speed | |
Welding voltage | |
Dynamic | |
Welding current |
1Press the "Process" button to select the desired welding process: | ||
2Press the "Mode" button to select the desired MIG/MAG mode: | ||
| IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component (TR 2000 or TR 3000 remote control) on the control panel of the wirefeeder. | |
3Press the "Parameter selection" button to select the wire speed parameter | ||
4Use the adjusting dial to set the desired value for the wire speed | ||
5Press the "Parameter selection" button to select the welding voltage parameter | ||
6Use the adjusting dial to set the desired value for the welding voltage | ||
| All welding parameter set values remain stored until the next time they are changed. This applies even if the power source is switched off and on again. To display the actual welding current during welding, select the welding current parameter. | |
| To display the actual welding current during welding: | |
7Open the gas cylinder valve | ||
8Setting the shielding gas flow rate: | ||
9Press the torch trigger and start welding |
To obtain the best possible welding results, the arc-force dynamic parameter will sometimes need to be adjusted.
1Press the "Process" button to select the MMA welding process: | ||
| The welding voltage is connected to the welding socket with a 3-second time lag. | |
| NOTE! Under certain circumstances, welding parameters that have been set on a system component control panel (TR 2000 and TR 3000) may not be changed on the control panel of the power source. | |
2Press the "Parameter selection" button to select the amperage parameter. | ||
3Use the adjusting dial to set the desired amperage. | ||
| The amperage value is displayed in the left-hand digital display. | |
| All welding parameter set values remain stored until the next time they are changed. This applies even if the power source is switched off and on again in the meantime. | |
4Start welding | ||
To obtain optimum welding results, it will sometimes be necessary to adjust the HotStart function.
AdvantagesFor details on setting the available welding parameters, please refer to "Setup parameters", "Setup menu - level 2".
Legend
| Hti | Hot-current time, 0 - 2 s, factory setting: 0.5 s |
| HCU | HotStart current, 100 - 200 %, factory setting 150 % |
| IH | Main current = set welding current |
Function
During the specified hot-current time (Hti), the welding current is increased to a certain value. This value (HCU) is higher than the selected welding current (IH).
As the arc becomes shorter, the welding voltage may drop so far that the rod electrode will tend to "stick". This may also cause "burn-out" of the rod electrode.
Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. After the rod electrode has been detached from the workpiece, the welding operation can be continued without difficulty.
The anti-stick (Ast) function can be activated and deactivated in the Setup parameters in "Setup menu: level 2".
The "Save" buttons allow up to 5 EasyJob operating points to be saved. Every operating point matches the settings on the control panel.
EasyJobs can be stored for each welding process.
IMPORTANT! Setup parameters are not saved at this time.
1Press and hold one of the "Save" buttons to save the current settings on the control panel, e.g.:
2Release the "Save" button | ||
1To retrieve saved settings, press the corresponding "Save" button briefly, e.g.:
1Press and hold the relevant "Save" button to delete the memory content of that "Save" button, e.g.:
2Keep the "Save" button held down
3Release the "Save" button | ||
One of the "Save" buttons on the control panel must be pressed to retrieve the saved settings using the Up/Down welding torch.
1Press one of the "Save" buttons on the control panel, e.g.:
The "Save" buttons can now be selected using the buttons on the Up/Down welding torch. Vacant "Save" buttons are skipped.
In addition to the "Save" button number lighting up, a number is displayed directly on the Up/Down welding torch:
Number 1 |
Number 2 |
Number 3 |
Number 4 |
Number 5 |
The Setup menu provides simple access to expert knowledge in the power source and to additional functions. The Setup menu can be used to make simple adjustments of the parameters to suit the various job settings.
Configuring the setup parameters is described here with reference to the "MIG/MAG standard synergic welding" process. The procedure for changing other setup parameters is identical.
Accessing the Setup menu
1Use the "Process" button to select the "MIG/MAG standard synergic welding" process | ||
2Press and hold the "Mode" button |
3Press the "Process" button |
4Release the "Mode" and "Process" buttons |
The control panel is now in the Setup menu for the "MIG/MAG standard synergic welding" process - the last setup parameter that was selected is displayed.
Changing welding parameters
2Change the value of the setup parameter using the "Parameter selection" buttons or the right-hand adjusting dial | ||
Exiting the Setup menu
2Press the "Process" button |
3Release the "Mode" and "Process" buttons |
"Min." and "max." are used for setting ranges that differ according to power source, welding program, etc.
| GPr | Gas pre-flow time Unit: s Setting range: 0 - 9.9 Factory setting: 0.1 |
| GPo | Gas post-flow time Unit: s Setting range: 0 - 9.9 Factory setting: 0.5 |
| Fdi | Feeder inching speed Unit: m/min (ipm) Setting range: 1 - max. (39.37 - max.) Factory setting: 10 (393.7) |
| bbc | Burn-back time correction Burn-back time effect due to a delayed switch-off of the welding current after the wire electrode stops being fed forward. A ball forms on the wire electrode. Unit: s Setting range: AUt, 0 - 0.3 Factory setting: AUt |
| IGC | Ignition current Unit: A Setting range: 100 - 650 Factory setting: 500 |
| Ito | Length of wire that is fed before the safety cut-out trips Unit: mm (in.) Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94) Factory setting: OFF NOTE!The Ito function (wire length up to safety cut-out) is a safety function. The length of wire that is fed before the safety cut-out trips may differ from the pre-set wire length, particularly when the wire is being fed at fast wire speeds. |
| SPt | Spot welding time / interval welding time Unit: s Setting range: 0.3 - 5 Factory setting: 0.3 |
| SPb | Interval pause time Unit: s Setting range: OFF, 0.3 - 10 (in 0.1 s increments) Factory setting: OFF |
| Int | Interval Displayed only if a value has been set for SPb Unit: - Setting range: 2T (2-step), 4T (4-step) Factory setting: 2T (2-step) |
| FAC | Reset power source to factory settings Press and hold down one of the "Parameter selection" buttons for 2 s to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset IMPORTANT! When the power source is reset, all personal settings in the Setup menu are lost. Operating points that were saved using the "Save" buttons are retained when the power source is reset. The functions in the second level of the Setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito). |
| 2nd | Second level of the Setup menu (see "Setup menu - level 2") |
| GPo | Gas post-flow time Unit: s Setting range: 0 - 9.9 Factory setting: 0.1 |
| SL | Slope Unit: s Setting range: 0 - 9.9 Factory setting: 0.1 |
| I-S | I (current) - Starting current Unit: % (of welding current) Setting range: 0 - 200 Factory setting: 100 |
| I-E | I (current) - End: Final current Unit: % (of welding current) Setting range: 0 - 200 Factory setting: 50 |
| t-S | t (time) - Starting - Starting current duration Unit: s Setting range: OFF, 0.1 - 9.9 Factory setting: OFF |
| t-E | t (time) - End: Final current time Unit: s Setting range: OFF, 0.1 - 9.9 Factory setting: OFF |
| Fdi | Feeder inching - feeder inching speed Unit: m/min (ipm.) Setting range: 1 - max. (39.37 - max.) Factory setting: 10 (393.7) |
| bbc | burn-back time correction - Burn back effect due to wire withdrawal at end of welding Unit: s Setting range: Aut, 0 - 0.3 Factory setting: Aut |
| Ito | Ignition time-out function - Length of wire that is fed before the safety cut-out is triggered Unit: mm (in.) Setting range: Off, 5 - 100 (Off, 0.2 - 3.94) Factory setting: OFF NOTE!The "Ignition time-out" function (ito) is a safety function. The length of wire that is fed before the safety cut-out trips may differ from the preset wire length, particularly when the wire is being fed at fast wire feed speeds.
| SPt | Spot time - spot / stitch welding time Unit: s Setting range: OFF, 0.1 - 5 Factory setting: OFF |
| SPb | Spot break - stitch pause time Unit: s Setting range: OFF, 0.1 - 10 (in 0.1 s increments) Factory setting: OFF |
| FAC | Factory - reset power source to factory settings Press and hold down one of the "Parameter selection" buttons for 2 s to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset. IMPORTANT! When the power source is reset, all personal settings in the Setup menu are lost. When the power source is reset, operating points that were saved using the "Save" buttons are not deleted, but are retained in the memory. The functions in the second level of the Setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito). |
IMPORTANT! If you reset the power source using the FAC factory setup parameter, the hot-current time (Hti) and HotStart current (HCU) setup parameters are also reset.
| HCU | HotStart current Unit: % Setting range: 100 - 200 Factory setting: 150 |
| Hti | Hot-current time Unit: s Setting range: 0 - 2.0 Factory setting: 0.5 |
| Ast | Anti-Stick Unit: - Setting range: On, OFF Factory setting: OFF |
| FAC | Factory - Reset power source to factory setting Press and hold down one of the "Parameter selection" buttons for 2 s to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset. IMPORTANT! When the power source is reset, all personal settings are lost. When the power source is reset, operating points that were saved using the "Save" buttons are not deleted, but are retained in the memory. The functions in the second level of the Setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito). |
In conjunction with the level 2 of the Setup menu, the following restrictions occur:
Level 2 of the Setup menu cannot be selected:
If level 2 of the Setup menu is selected, the following functions are not available, even in robot mode:
The control panel is now in the Setup menu - the last setup parameter that was selected is displayed.
Selecting the "2nd" parameter
1Use the "Mode" and "Process" buttons or the left-hand adjusting dial to select the "2nd" setup parameter | ||
Accessing the Level 2 Setup menu
1Use the "Mode" and "Process" buttons or the left-hand adjusting dial to select the required setup parameter | ||
Exiting the Level 2 Setup menu
C-C | Cooling unit Control Unit: - Aut: The cooling unit cuts out after a 2-minute welding off-time. IMPORTANT! If the coolant temperature and flow monitoring options have been installed in the cooling unit, the cooling unit cuts out as soon as the return-flow temperature drops below 50 °C, but at the earliest after a 2-minute welding off-time. On: The cooling unit is always ON IMPORTANT! If the FAC welding parameter is used, the C-C parameter is not reset to the factory setting. If the MMA welding process is selected, the cooling unit is always switched off, even if the switch is in the "On" position. |
C-t | Cooling Time Unit: s IMPORTANT! Every time the power source is switched on, the cooling unit carries out a test run for 180 seconds. |
SEt | Setting - country-specific setting (Standard/USA), etc. Std/US Unit: - |
r | r (resistance) - welding circuit resistance (in mOhm) |
L | L (inductivity) - welding circuit inductivity (in microhenry) |
EnE | Real Energy Input – electrical energy of the arc relative to the welding speed Unit: kJ Since the full range of values (1 kJ - 99999 kJ) cannot be displayed on the three-digit display, the following display format has been selected: Value in kJ / indicator on display: |
ALC | Arc Length Correction - correction of the arc length via the welding voltage Setting range: ON / OFF The arc length depends on the welding voltage. The welding voltage can be adjusted to suit individual needs in Synergic operation. If the ALC parameter is set to "OFF", the welding voltage cannot be adjusted. The welding voltage is automatically determined by the selected welding current or wire speed. If the arc length correction is adjusted, the voltage changes, but the welding current and wire speed remain the same. When setting the arc length correction using the adjusting dial, the left display is used for the correction value of the arc length. The welding voltage value on the right display changes simultaneously. Afterwards the left display shows the original value, e.g. welding current. |
Ejt | EasyJob Trigger - for activating / deactivating the switching of EasyJobs by means of the torch trigger Unit: - Function with MIG/MAG torch trigger No welding operation:
During welding:
Function with MIG/MAG Up/Down button
During welding:
Measuring the welding circuit resistance makes it possible to have a consistent welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The calculated welding circuit resistance is shown on the display.
r = welding circuit resistance in milliohm (mOhm)
If the welding circuit resistance has been measured correctly, the set welding voltage will correspond exactly to the welding voltage at the arc. If you manually measure the voltage on the output jacks of the power source, this voltage will be higher than the welding voltage at the arc - that is, higher by the same amount as the voltage drop of the hosepack.
The welding circuit resistance depends on the hosepack used:Measuring the welding circuit resistance makes it possible to have a consistent welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The welding circuit resistance depends on the hosepack used:Risk of incorrect measurement of the welding circuit resistance.
This may negatively affect the welding result.
Ensure that the workpiece in the area of the earthing clamp provides an optimal contact surface (cleaned surface, free from rust, etc.).
Ensure that the workpiece provides an optimal contact surface for the contact tip (cleaned surface, free from rust, etc.).
The measurement is finished when the welding circuit resistance is shown on the display in mOhm ( for example, 11.4).
Laying of the hosepacks has a significant effect on welding circuit inductivity and therefore affects the welding process. It is important to lay the hosepacks correctly in order to obtain the best possible welding result.
The setup parameter "L" is used to display the most recently calculated welding circuit inductivity. The welding circuit inductivity is calibrated at the same time as the welding circuit resistance is measured. Detailed information can be found in the "Measuring welding circuit resistance" section.
The most recently calculated welding circuit inductivity L is shown on the right-hand digital display.
L ... Welding circuit inductivity (in microhenry)
The devices are equipped with an intelligent safety system. This means that to a large extent it has been possible to dispense with melting-type fuses. Melting-type fuses therefore no longer need to be replaced. After a possible malfunction has been remedied, the device is ready for use again.
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
Make a note of the serial number and configuration of the device and contact our After-Sales Service team with a detailed description of the error, if
| Cause: | There is a break in the mains lead; the mains plug is not plugged in |
| Remedy: | Check the mains lead, ensure that the mains plug is plugged in |
| Cause: | Mains socket or mains plug faulty |
| Remedy: | Replace faulty parts |
| Cause: | Mains fuse protection |
| Remedy: | Change the mains fuse protection |
| Cause: | Short circuit on the 24 V supply of SpeedNet connection socket or external sensor |
| Remedy: | Unplug connected components |
| Cause: | Only for welding torches with an external control plug: The control plug is not plugged in |
| Remedy: | Plug in the control plug |
| Cause: | Welding torch or welding torch control line is faulty |
| Remedy: | Replace welding torch |
| Cause: | The interconnecting hosepack is faulty or not connected properly |
| Remedy: | Check interconnecting hosepack |
| Cause: | Overload |
| Remedy: | Take the duty cycle into account |
| Cause: | Thermostatic safety cut-out has tripped |
| Remedy: | Wait until the power source automatically comes back on after the end of the cooling phase |
| Cause: | Limited supply of cooling air |
| Remedy: | Remove air filter on the rear of the housing from the side and clean. Ensure that the cooling air ducts are accessible. |
| Cause: | The fan in the power source is faulty |
| Remedy: | Contact After-Sales Service |
| Cause: | Grounding (earthing) connection is incorrect |
| Remedy: | Check the grounding (earthing) connection for correct polarity |
| Cause: | There is a break in the power cable in the welding torch |
| Remedy: | Replace the welding torch |
| Cause: | Gas cylinder is empty |
| Remedy: | Change the gas cylinder |
| Cause: | The gas pressure regulator is faulty |
| Remedy: | Replace the gas pressure regulator |
| Cause: | Gas hose is not fitted or is damaged |
| Remedy: | Fit or change the gas hose |
| Cause: | Welding torch is faulty |
| Remedy: | Change the welding torch |
| Cause: | Gas solenoid valve is faulty |
| Cause: | Braking force has been set too high |
| Remedy: | Loosen the brake |
| Cause: | Hole in the contact tip is too narrow |
| Remedy: | Use a suitable contact tip |
| Cause: | Faulty inner liner in welding torch |
| Remedy: | Check the inner liner for kinks, dirt, etc. and replace if necessary |
| Cause: | The feed rollers are not suitable for the wire electrode being used |
| Remedy: | Use suitable feed rollers |
| Cause: | Feed rollers have the wrong contact pressure |
| Remedy: | Optimise the contact pressure |
| Cause: | Incorrect arrangement of welding torch hosepack |
| Remedy: | Arrange the welding torch hosepack in as straight a line as possible, avoiding bends |
| Cause: | Welding torch is inadequately dimensioned |
| Remedy: | Observe the duty cycle and loading limits |
| Cause: | Only on water-cooled systems: inadequate coolant flow |
| Remedy: | Check coolant level, coolant flow, for coolant contamination, etc. For further information refer to the cooling unit Operating Instructions |
| Cause: | Incorrect welding parameters |
| Remedy: | Check the settings |
| Cause: | Poor ground earth connection |
| Remedy: | Ensure good contact to workpiece |
| Cause: | Inadequate or no protective gas shield |
| Remedy: | Check the pressure regulator, gas hose, gas solenoid valve, torch gas connection, etc. |
| Cause: | Welding torch is leaking |
| Cause: | Wrong contact tip, or contact tip is worn out |
| Remedy: | Replace the contact tip |
| Cause: | Wrong wire alloy or wrong wire diameter |
| Remedy: | Check the wire electrode that has been inserted |
| Remedy: | Check weldability of the base material |
| Cause: | The shielding gas is not suitable for this wire alloy |
| Remedy: | Use the correct shielding gas |
If an error message that is not described here appears on the displays, proceed as follows to resolve the problem:
If the error occurs again despite several attempts to eliminate it, or if the troubleshooting measures listed here are unsuccessful.
| Cause: | The selected cooling unit is not compatible with the power source |
| Remedy: | Connect compatible cooling unit |
| Cause: | An invalid welding process was called up on the robot interface (no. 37) or an empty flag was selected (no. 32) |
| Remedy: | Call up a valid welding process or select assigned "Save" button |
| Cause: | The connected wire-feed unit is not supported |
| Remedy: | Connect supported wire-feed unit |
| Cause: | Different control panels for selecting materials are in the system |
| Remedy: | Connect similar control panels to select materials |
| Cause: | Invalid change of welding process during welding |
| Remedy: | During welding do not carry out any illegal change of the welding process, reset error message by pressing any button |
| Cause: | More than only one robot interface is connected |
| Remedy: | Only one robot interface may be connected, check the system configuration |
| Cause: | More than only one remote control unit is connected |
| Remedy: | Only one remote control unit may be connected, check the system configuration |
| Cause: | The power source control has detected a primary overvoltage |
| Remedy: | Check the mains voltage. If the service code is still present, turn off the power source, wait 10 seconds, and then turn on the power source. If the fault persists, contact After-Sales Service |
| Cause: | The earth current watchdog has triggered the safety cut-out of the power source. |
| Remedy: | Switch off the power source Place the power source on an insulating surface Connect the grounding (earthing) cable to a section of the workpiece that is closer to the arc Wait for 10 seconds and then switch the power source on again If you have tried this several times and the error keeps recurring, contact After-Sales Service |
| Cause: | If the VRD option is available, the open circuit voltage limit of 35 V has been exceeded. |
| Remedy: | Switch off power source Wait for 10 seconds and then switch the power source on again |
| Cause: | The VRD option has tripped too early. |
| Remedy: | Check whether all welding power-leads and control lines are connected. Switch off the power source Wait 10 seconds and switch the power source back on again If the error occurs again - contact After Sales Service. |
| Cause: | "External stop" has tripped |
| Remedy: | Remedy the event that triggered the external stop |
| Cause: | At the robot interface the flag was not deleted by the robot |
| Remedy: | Delete the signal robot ready at the robot interface |
| Cause: | Phase failure with TSt 2700c in particular: If the failure occurs during welding, the welding operation stops. with TSt 2700c MV in particular: A single-phase operation with limited power is possible: When switching on the power source, "PHA | SE1" is displayed in order to show that a power reduction will be in effect. If a change in supply from three-phase to single-phase occurs during welding (display: "PHA | SE1") or from single-phase to three-phase (display: "PH | ASE 3"), the welding operation stops. |
| Remedy: | Check the mains fuse, mains cable and mains plug. Switch off the power source, wait 10 seconds and switch the power source back on again. |
| Cause: | The power source is operated in single-phase mode. |
| Remedy: | - |
| Cause: | The power source is operated in 3-phase mode |
| Remedy: | - |
| Cause: | Mains undervoltage: The mains voltage has fallen below the tolerance range |
| Remedy: | Check the mains voltage, if the error keeps recurring, contact the After-Sales Service |
| Cause: | Mains overvoltage: The mains voltage has risen above the tolerance range |
| Cause: | Incorrect wire-feed unit connected |
| Remedy: | Connect correct wire-feed unit |
| Cause: | Overtemperature on the wire-feed unit |
| Remedy: | Allow wire-feed unit to cool down |
| Cause: | Fault in the wire feed system (overcurrent in wire-feed unit drive) |
| Remedy: | Arrange the hosepack in as straight a line as possible; check that there are no kinks or dirt in the inner liner; check the contact pressure on the 4 roller drive |
| Cause: | Wire-feed unit motor is sticking or defective |
| Remedy: | Check the wire-feed unit motor or contact After-Sales Service |
| Cause: | Overtemperature in the primary circuit of the power source |
| Remedy: | Allow power source to cool down, check air filter and clean if necessary, check that fan is on |
| Cause: | Overtemperature on the booster located in the power source |
| Cause: | Overtemperature in the secondary circuit of the power source |
| Remedy: | Allow power source to cool down, check that fan is on |
| Cause: | Overtemperature in the wire-feed unit motor |
| Cause: | Overtemperature in welding torch |
| Remedy: | Allow welding torch to cool down |
| Cause: | Overtemperature in cooling unit |
| Remedy: | Allow cooling unit to cool down, check that fan is on |
| Cause: | Overtemperature at the transformer of the power source |
| Cause: | Overtemperature in the power source |
| Remedy: | Allow power source to cool down, check air filter and clean if necessary, check whether the fan is running |
| Cause: | With the TSt 2700c MV power source operating in single-phase mode, the power source safety cut-out has tripped in order to prevent the mains fuse from tripping. |
| Remedy: | After a pause in welding of around 60 s, the message disappears and the power source is operational again. |
| Cause: | Undertemperature in the power source primary circuit |
| Remedy: | Place power source in a heated room and allow to warm up |
| Cause: | Undertemperature on the booster located in the power source |
| Remedy: | Place power source in a heated room and allow it to warm up |
| Cause: | Undertemperature in the power source secondary circuit |
| Cause: | Undertemperature in the wire-feed unit motor |
| Remedy: | Place wire-feed unit in a heated room and allow to warm up |
| Cause: | Undertemperature in the welding torch |
| Remedy: | Place welding torch in a heated room and allow to warm up |
| Cause: | Undertemperature in the cooling unit |
| Remedy: | Place cooling unit in a heated room and allow to warm up |
| Cause: | Undertemperature on the transformer of the power source |
| Cause: | Undertemperature in the power source |
| Cause: | Coolant flow rate too low |
| Remedy: | Check coolant flow rate and cooling unit, including cooling circuit (for minimum coolant flow, see "Technical Data" section in the device operating instructions) |
| Cause: | The coolant temperature is too high |
| Remedy: | Allow cooling unit and cooling circuit to cool down, until "hot | H2O" is no longer displayed. Open the cooling unit and clean the cooler, check fan is working properly. Robot interface or field bus coupler: before resuming welding, set the "Source error reset" signal. |
| Cause: | No preconfigured program has been selected |
| Remedy: | Select a configured program |
| Cause: | "Ignition time-out" function is active; current did not start flowing before the length of wire specified in the set-up menu had been fed. The power source safety cut-out has tripped |
| Remedy: | Shorten the free wire end, press the torch trigger again; clean the workpiece surface; if necessary, set the "Ito" parameter in the Setup menu |
| Cause: | The welding program selected is invalid |
| Remedy: | Select valid welding program |
| Cause: | The required wire-feed unit is not available for the selected characteristic |
| Remedy: | Connect correct wire-feed unit, check plug connections for the hosepack |
| Cause: | Measurement of the welding circuit resistance failed |
| Remedy: | Check grounding cable, current cable or hosepack and replace if necessary; remeasure welding circuit resistance |
| Cause: | The Gas watchdog option has detected that there is no gas pressure |
| Remedy: | Connect a new gas cylinder or open the gas cylinder valve/pressure regulator, restart "Gas watchdog" option, reset "no | GAS" error message by pressing any button. |
Under normal operating conditions, the welding system requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the welding system remains in a usable condition for many years.
The air inlets and outlets must never be covered, not even partially.
If a lot of dust has accumulated:
TSt 2700cRisk of damage.
The air filter must only be fitted when dry.
If required, clean air filter using dry compressed air or by washing it.
Danger due to the effect of compressed air.
Do not bring the air nozzle too close to electronic components.
An electric shock can be fatal!
Risk of electric shock from improperly connected ground cables and equipment grounds.
When reassembling the side panels, make sure that grounding cables and equipment grounds are properly connected.
Average wire electrode consumption at a wire speed of 5 m/min | |||
| 1.0 mm wire electrode diameter | 1.2 mm wire electrode diameter | 1.6 mm wire electrode diameter |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminium wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminium wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
For devices designed for special voltages, the technical data on the rating plate applies.
For all machines with a permitted mains voltage of up to 460 V: The standard mains plug allows the user to operate with a mains voltage of up to 400 V. For mains voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
If the ambient temperature is higher, either the ED or output must be reduced accordingly.
Example: Welding at 150 A at 60% ED
If the device is to be continuously operated without stopping:
Mains voltage (U1) | 3 x 380 V | ||
Max. effective primary current (I1eff) | 7 A | ||
Max. primary current (I1max) | 13.1 A | ||
Mains fuse | 16 A slow-blow | ||
Mains voltage (U1) | 3 x 400 V | ||
Max. effective primary current (I1eff) | 6.6 A | ||
Max. primary current (I1max) | 12.5 A | ||
Mains voltage (U1) | 3 x 460 V | ||
Max. effective primary current (I1eff) | 5.8 A | ||
Max. primary current (I1max) | 10.8 A | ||
Mains voltage tolerance | -15 % /+ 15 % | ||
Mains frequency | 50 / 60 Hz | ||
Max. permitted mains impedance Zmax on PCC1) | 136 mOhm | ||
Welding current range (I2) MIG/MAG | 10 - 270 A | ||
Welding current range (I2) Rod electrode | 10 - 270 A | ||
Welding current at | 30 % | 60 % | 100 % |
Output voltage range according to standard characteristic (U2) MIG/MAG |
Output voltage range according to standard characteristic (U2) Stabelektrode |
Open circuit voltage (U0 peak / U0 r.m.s) | 41 V | ||
Apparent power at 400 V AC | 8.66 kVA | ||
Protection class | IP 23 | ||
Insulation class | B | ||
Overvoltage category | III | ||
Pollution level according to IEC60664 | 3 | ||
EMC device class | A2) | ||
Safety symbols | S, CE | ||
Dimensions l x w x h | 687 x 276 x 445 mm | ||
Weight | 30 kg | ||
Max. shielding gas pressure | 7 bar | ||
Wire feed speed | 1 - 25 m/min | ||
Wire drive | 4-roller drive | ||
Wire diameter | 0.8 - 1.6 mm | ||
Wirespool diameter | max. 300 mm | ||
Wirespool weight | max. 19.0 kg | ||
Idle state power consumption at 400 V | 38.3 W | ||
Power source efficiency at 270 A / 30.8 V | 89 % | ||
| 1) | Interface to a 230 / 400 V, 50 Hz public grid |
| 2) | A device in emissions class A is not intended for use in residential areas in which the electrical power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Mains voltage (U1) | 3 x 200 V | ||
Max. effective primary current (I1eff) | 13.3 A | ||
Max. primary current (I1max) | 25.7 A | ||
Mains fuse protection | 25 A slow-blow | ||
Mains voltage (U1) | 3 x 230 V | ||
Max. effective primary current (I1eff) | 11.6 A | ||
Max. primary current (I1max) | 22.1 A | ||
Mains fuse protection | 15 A slow-blow | ||
Mains voltage (U1) | 1 x 230 V | ||
Max. effective primary current (I1eff) | 16.0 A | ||
Max. primary current (I1max) | 22.3 A | ||
Mains fuse protection | 16 A slow-blow | ||
Apparent power | 5.13 kVA | ||
Mains voltage (U1) | 1 x 240 V | ||
Max. effective primary current (I1eff) | 15.0 A | ||
Max. primary current (I1max) | 23.9 A | ||
Apparent power | 5.74 kVA | ||
Max. effective primary current (I1eff) | 18.1 A | ||
Max. primary current (I1max) | 24.9 A | ||
Mains fuse protection | 20 A slow-blow | ||
Apparent power | 5,98 kVA | ||
Max. primary current (I1max) | 28.1 A | ||
Mains fuse protection | 30 A slow-blow | ||
Apparent power | 6.74 kVA | ||
Mains voltage tolerance | -10 % /+ 15 % | ||
Max. permitted mains impedance Zmax on PCC1) | 142 mOhm | ||
Welding current range (I2) |
Welding current range (I2) in single-phase operation |
Welding current at 10 min / 40 °C (104 °F) | 30 % | 60 % | 100 % |
Welding current in single-phase operation at | 15 % 2) |
| 100 % |
Welding current in single-phase operation at | 8 % 2) |
| 100 % |
Welding current in single-phase operation at | 11 % 2) |
| 100 % |
Welding current in single-phase operation at | 40 % 2) |
| 100 % |
Output voltage range according to standard characteristic (U2) |
Output voltage range according to standard characteristic (U2) in single-phase operation |
Open circuit voltage (U0 peak / U0 r.m.s) | 42 V | ||
EMC device class | A3) | ||
Safety symbols | S, CE, CSA | ||
Weight | 30 kg | ||
Wirespool weight | max. 20.0 kg | ||
Idle state power consumption at 400 V | 38.5 W | ||
| 2) | Detailed information concerning the duty cycle in single-phase operation is located in chapter „Installation and commissioning“, section „single-phase operation“ |
| 3) | A device in emissions class A is not intended for use in residential areas in which the electrical power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Max. effective primary current (I1eff) | 15.2 A | ||
Mains fuse | 35 A slow-blow | ||
Max. effective primary current (I1eff) | 14.5 A | ||
Max. primary current (I1max) | 23 A | ||
Max. effective primary current (I1eff) | 12.7 A | ||
Max. primary current (I1max) | 20.1 A | ||
Cos phi (1) | 0.99 | ||
Max. permitted mains impedance Zmax at PCC1) | 77 mOhm | ||
Recommended earth-leakage circuit breaker | Type B | ||
Welding current at 10 min / 40 °C (104 °F) | 40 % | 60 % | 100 % |
Open circuit voltage (U0 peak / U0 r.m.s) | 60 V | ||
Apparent power at 400 V AC | 15.87 kVA | ||
Degree of protection | IP 23 | ||
Type of cooling | AF | ||
Dimensions l x w x h | 747 x 300 x 497 mm | ||
Weight | 36 kg | ||
Max. shielding gas pressure | 5 bar | ||
Coolant | Original Fronius | ||
Max. noise emission (LWA) | 72 dB (A) | ||
Idle state power consumption at 400 V | 36.5 W | ||
Power source efficiency at 350 A / 34 V | 90 % | ||
| 1) | Interface to a 230/400 V, 50 Hz public grid |
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
Welding program database:
TSt 2700c
VAT ID 3474
* Diameter = 1,2 mm (0.45 in.)
TSt 2700c USA
VAT ID 3475
TransSteel 3500 Euro
VAT ID 3431
TransSteel 3500 US
VAT ID 3431
