Warnings are intended to warn people of possible injury and to prevent personal injury and damage to the product. They relate to individual actions performed with and on the product.
Indicates an immediately dangerous situation.
Serious injury or death will result if the hazard is not avoided.
Action step to escape the situation.
Serious injury or death will potentially result if the hazard is not avoided.
Minor or moderate injury may result if the hazard is not avoided.
Indicates a situation which may result in damage to property.
Failure to avoid the situation may result in impaired work results and material damage to the product or other property.
Action step to avoid the situation.
Safety instructions are intended to ensure safe use of the product. They are preventive and help to inform users about basic risks when using the product. They do not refer specifically to individual actions performed with and on the product.
The full text of the EU Declaration of Conformity can be found at
https://www.fronius.com .
Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
Copyright of this document remains with Fronius International GmbH.
Text, illustrations and other media correspond to the technical state of the art at the time of publication. Fronius reserves the right to make changes. If you have any suggestions for improvement, or can point out any inconsistencies in this document, we will be most grateful for your comments.
The device has been manufactured in line with the state of the art and according to recognised safety standards.
The welding machine may only be used for MIG/MAG, MMA and TIG welding in combination with Fronius components.
Any use above and beyond this purpose shall be deemed to be not in accordance with the intended use.
Intended use also includes:The device has been manufactured in line with the state of the art and according to recognised safety standards.
Intended use also includes:IMPORTANT! Utilisation for any other purpose, or in any other manner, shall be deemed to be improper use.
Prohibited improper use includes:The TPS 320i C MIG/MAG welding machine is a completely digitised, microprocessor-controlled inverter welding machine with integrated 4-roller wire drive.
A modular design and potential for system add-ons ensure a high degree of flexibility.
There is no longer an interconnecting hosepack between the welding machine and the wirefeeder. Its compact design makes the TPS 320i C particularly suitable for mobile applications.
The welding machine can be adapted to any specific situation.
Depending on the device firmware, in some cases "power source" may still be shown on the display.
Power source = welding machine
The central control and regulation unit of the welding machines is coupled with a digital signal processor. The central control and regulation unit and the signal processor control the entire welding process.
During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Rule algorithms ensure that the desired target state is maintained.
The devices are used in workshops and industry for manual and automated applications with classical steel, galvanised sheets, chrome/nickel and aluminium.
The integral 4-roller wire drive, high performance and light weight of the TPS 320i C welding machine makes it the ideal choice for portable applications on building sites or in repair workshops.
FCC
This equipment complies with the limit values for a digital device of EMC emission class A pursuant to Part 15 of the FCC Rules. These limit values are intended to provide an adequate level of protection against harmful emissions when the device is being used in an industrial environment. This device generates and uses high-frequency energy and can cause interference to radio communications if it is not installed and used according to the Operating Instructions.
The use of this device in residential areas will probably cause harmful interference, in which case the user will be obliged to correct the interference at their own expense.
FCC ID: QKWMCU3
Industry Canada RSS
This device complies with the Industry Canada licence-exempt RSS standards. Its use is subject to the following conditions:
| (1) | The device must not cause any harmful interference. |
| (2) | The device must be able to cope with any interference, including that which could adversely affect its operation. |
IC: 12270A-MCU3
EU
Conformity with Directive 2014/53 / EU – Radio Equipment Directive (RED)
When installing the antennae to be used for this transmitter, it is essential to maintain a minimum distance of 20 cm from all people. They must not be set up or operated together with another antenna or another transmitter. To comply with exposure to radio frequency guidelines, the operating conditions of the transmitter must be available to OEM integrators and end users.
ANATEL / Brazil
This device is operated on a secondary basis. It has no protection against harmful interference, even from devices of the same type.
This device cannot cause interference in systems operated on a primary basis.
This device complies with ANATEL's specific absorption rate limit values in relation to exposure to high-frequency electric, magnetic and electromagnetic fields.
IFETEL / Mexico
Operation of this device is subject to the following two conditions:
| (2) | This device must accept any interference received, including interference that may cause undesired operation. |
IFETEL: FRFR4326-001338
NCC / Taiwan
In accordance with NCC regulations for low-power radio frequency devices:
Article 12
A certified low-power radio frequency device must not change the frequency, increase the power or alter the characteristics and functions of the original structure without approval.
Article 14
The use of low-power radio frequency devices must not adversely affect flight safety and communications.
A detected malfunction must be deactivated and corrected immediately until no malfunction is present.
The notice in the preceding paragraph refers to radio communications operated in accordance with the provisions of the Telecommunications Act. Low-power radio frequency devices must withstand interference from legitimate communications or radiological, electrical radio frequency devices for industrial, scientific and medical applications.
Thailand
The Bluetooth® word mark and logos are registered trademarks owned by Bluetooth SIG, Inc. and any use of such marks by Fronius International GmbH is under license. Other trademarks and trade names are those of their respective owners.
Warning notices and safety symbols are affixed to welding machines with the CSA test mark for use in North America (USA and Canada). These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and damage.
| *) | on the inside of the device |
Safety symbols on the rating plate:
Welding is dangerous. The following basic requirements must be met:
For certain device versions, warning notices are affixed to the device.
The arrangement of the symbols may vary.
| ! | Warning! Attention! The symbols represent possible dangers. |
| A | Feed rollers can injure fingers. |
| B | The welding wire and drive parts are live during operation. Keep hands and metal objects away! |
| 1. | An electric shock can be fatal. |
| 1.1 | Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves. |
| 1.2 | Use a base that is insulated from the floor and work area to protect against electric shock. |
| 1.3 | Before working on the device, switch off the device and pull out the mains plug or disconnect it from the power supply. |
| 2. | Inhalation of welding fumes can be harmful to health. |
| 2.1 | Keep your face away from any welding fumes. |
| 2.2 | Use forced-air ventilation or a local extraction system to remove welding fumes. |
| 2.3 | Remove welding fumes with a fan. |
| 3 | Welding sparks can cause an explosion or fire. |
| 3.1 | Keep flammable materials away from the welding process. Never weld close to flammable materials. |
| 3.2 | Welding sparks can cause a fire. Have fire extinguishers to hand. If necessary, have a supervisor ready who can operate the fire extinguisher. |
| 3.3 | Do not weld on drums or closed containers. |
| 4. | Arc rays can burn the eyes and injure the skin. |
| 4.1 | Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body. |
| 5. | Before working on the system or welding: undertake training on the device and read the instructions! |
| 6. | Do not remove or paint over the warning sticker. |
| * | Manufacturer order number of the sticker |
The welding machines can be operated with various system components and options. This makes it possible to optimise procedures and to simplify machine handling and operation, depending on the field of application for the welding machine.
| (1) | Cooling units |
| (2) | Welding machines |
| (3) | Trolleys and gas cylinder holders |
Also:
OPT/i gas flow rate sensor
OPT/i gas pressure sensor
OPT/i TPS 320i C CMT
OPT/i TPS 320i C TIG TMC
OPT/i TPS 320i C wire end
OPT/i TPS 320i C PushPull
OPT/i TPS C wire feed
OPT/i TPS C polarity reverser
OPT/i TPS C QC DFS AD10
OPT/i TPS C QC DFS Powerliner
OPT/i TPS VRD
OPT/i Ext. sensor connector
OPT/i TPS 320i C viewing window
OPT/i TPS C Ext.Welding Release
Option for external welding release
OPT/i TPS C Ethernet
OPT/i TPS C SpeedNet Connector
Optional second SpeedNet connection socket
Factory-fitted on the rear of the welding machine.
OPT/i TPS dust filter
IMPORTANT! Use of the OPT/i TPS dust filter option reduces the duty cycle.
OPT/i TPS C 2. plus socket
Optional second (+) current socket on the rear of the welding machine
OPT/i TPS C 2. ground socket
Optional second (-) current socket on the rear of the welding machine
OPT/i ground socket PC front
Optional (-) current socket (Power Connector) on the front of the welding machine - is fitted instead of the standard current socket with bayonet latch.
OPT/i Synergic Lines
Option for enabling all special characteristics available on TPSi welding machines;
this also automatically enables special characteristics created in future.
OPT/i GUN Trigger
Option for special functions in conjunction with the torch trigger
OPT/i Jobs
Option to view, create, edit, delete, export and import jobs in SmartManager
For details, see from page (→).
OPT/i Documentation
Option for the documentation function
OPT/i WebJobEdit
Option for editing jobs via the SmartManager of the welding machine
OPT/i Limit Monitoring
Option for specifying the limit values for the welding current, welding voltage and wire speed
OPT/i Custom NFC - ISO 14443A
Option to use a customer-specific frequency band for key cards
OPT/i CMT Cycle Step
Option for an adjustable, cyclical CMT welding process
OPT/i OPC-UA
Standardised data interface protocol
OPT/i MQTT
OPT/i SynchroPulse 10 Hz
To increase the SynchroPulse frequency from 3 Hz to 10 Hz
OPT/i WeldCube Navigator
Software for creating digital instructions for manual welding processes to be followed by welders.
The welder is guided through the welding instructions by WeldCube Navigator.
Various Welding Packages, welding characteristics and welding processes are available with welding machines that enable a wide range of materials to be effectively welded.
The following welding packages are available for TPSi welding machine:
Standard Welding Package
4,066,012
(enables MIG/MAG standard synergic welding)
Pulse Welding Package
4,066,013
(enables MIG/MAG pulse synergic welding)
LSC Welding Package *
4,066,014
(enables the LSC process)
PMC Welding Package **
4,066,015
(enables the PMC process)
CMT Welding Package ***
4,066,016
(enables the CMT process)
ConstantWire Welding Package
4,066,019
(enables constant current or constant voltage operation during brazing)
| * | Only in conjunction with the Standard Welding Package |
| ** | Only in conjunction with the Pulse Welding Package |
| *** | Only in conjunction with the Standard Welding Package and the Pulse Welding Package |
IMPORTANT! A TPSi welding machine without welding packages only offers the following welding processes:
Depending on the welding process and shielding gas mix, various process-optimised welding characteristics are available when selecting the filler metal.
Examples of welding characteristics:
The additional designation (*) next to the welding process provides information about the special properties and use of the welding characteristic.
The description of the characteristics is set out as follows:
Designation
Process
Properties
additive
CMT
Characteristics with reduced heat input and greater stability at a higher deposition rate for welding bead onto bead in adaptive structures
arc blow
PMC
Characteristic to avoid arc breaks due to arc blow.
arcing
Standard
Characteristics for a special type of hardfacing on a wet or dry surface
(e.g. grinding rollers in the sugar and ethanol industries)
base
Standard
braze
CMT, LSC, PMC
Characteristic for brazing processes (reliable wetting and good flow of braze material)
braze+
CMT
Characteristic for brazing processes with the special Braze+ gas nozzle and high brazing speed (gas nozzle with narrow opening and high flow rate)
CC/CV
CC/CV
Characteristic with constant current or constant voltage curve for operating the welding machine with a power supply unit. A wirefeeder is not required.
cladding
CMT, LSC, PMC
Characteristics for overlay welding with low penetration, low dilution and wide weld seam flow for improved wetting
constant current
PMC
Constant current characteristic
For applications where no arc length control is required (stickout changes are not compensated)
CW additive
PMC, ConstantWire
Characteristic with constant wire speed progression for the additive production process
With this characteristic, no arc is ignited, the welding wire is only fed as filler metal.
dynamic
CMT, PMC, Puls, Standard
Characteristic for deep penetration and reliable root fusion at high welding speeds
dynamic +
PMC
Characteristic with short arc length for high welding speeds with arc length control independent of the material surface.
edge
CMT
Characteristic for welding corner seams with targeted energy input and high welding speed
flanged edge
CMT
Characteristic for welding flange welds with targeted energy input and high welding speed
galvanized
CMT, LSC, PMC, Puls, Standard
Characteristics for galvanised sheet surfaces (low risk of zinc pores and reduced penetration)
galvannealed
PMC
Characteristics for iron-zinc-coated material surfaces
gap bridging
CMT, PMC
Characteristic for the best gap-bridging ability due to very low heat input
hotspot
CMT
Characteristic with hot start sequence, specially for plug welds and MIG/MAG spot weld joints
mix 2) / 3)
PMC
Also required:
Pulse and PMC welding packages
Characteristic for generating a rippled weld.
The heat input into the component is specifically controlled by the cyclical process change between pulsed and dip transfer arc.
marking
Characteristics for marking conductive surfaces
Characteristic for marking electrically conductive surfaces.
Marking is performed by low power spark erosion and a reversing wire movement.
mix 2) / 3)
CMT
Also required:
CMT drive unit WF 60i Robacta Drive CMT
Pulse, Standard and CMT welding packages
Characteristic for producing a rippled weld.
The heat input into the component is specifically controlled by the cyclical process change between pulsed arc or CMT.
mix drive 2)
PMC
Also required:
PushPull drive unit WF 25i Robacta Drive or WF 60i Robacta Drive CMT
Characteristic for producing a rippled weld by means of a cyclical process interruption of the pulsed arc and an additional wire movement
multi arc
PMC
Characteristic for components being welded by several arcs each influencing the other Ideal for increased welding circuit inductance or mutual welding circuit coupling.
open root
LSC, CMT
Characteristic with powerful arc, especially suitable for root passes with air gap
PCS 3)
PMC
The characteristic changes directly from a pulsed arc to a concentrated spray arc above a certain power. The advantages of pulsed and spray arcs combined in a single characteristic.
PCS mix
PMC
The characteristic changes cyclically between a pulsed or spray arc to a dip transfer arc, depending on the power range. It is especially suitable for vertical-up welds due to the alternating hot and then cold, supporting process phase.
pin
CMT
Characteristic for welding brads to an electrically conductive surface
The retraction movement of the wire electrode and the set current curve progression define the appearance of the pin.
pin picture
CMT
Characteristic for welding brads with a spherical end onto an electrically conductive surface, especially for creating pin pictures.
pin print
CMT
Characteristic for writing texts, patterns or markings on electrically conductive component surfaces
Writing takes place by positioning individual dots the size of a welding droplet.
pin spike
CMT
Characteristic for welding brads with pointed ends onto an electrically conductive surface.
pipe
PMC, Pulse, Standard
Characteristics for pipe applications and positional welding on narrow gap applications
pipe cladding
PMC, CMT
Characteristics for overlay welding of outer pipe claddings with little penetration, low dilution and wide weld seam flow
retro
CMT, Puls, PMC, Standard
The characteristic has the same weld properties as the predecessor TransPuls Synergic (TPS) series.
ripple drive 2)
PMC
Also required:
Characteristic for producing a rippled weld by means of a cyclical process interruption of the pulsed arc and an additional wire movement.
The weld rippling characteristics are similar to that of TIG welds.
root
CMT, LSC, Standard
Characteristics for root passes with powerful arc
seam track
PMC, Pulse
Characteristic with amplified current control, especially suitable for the use of a seam tracking system with external current measurement.
TIME
PMC
Characteristic for welding with very long stickout and TIME shielding gases to increase the deposition rate.
(TIME = Transferred Ionized Molten Energy)
universal
The characteristic is ideal for all standard welding tasks.
weld+
CMT
Characteristics for welding with short stickout and Braze+ gas nozzle (gas nozzle with small opening and high flow velocity)
| 1) | Can only be used with iWave AC/DC multiprocess welding machines |
| 2) | Welding characteristics with special properties provided by additional hardware |
| 3) | Mixed process characteristics |
Designation
Process
Properties
additive
CMT
arc blow
PMC
arcing
Standard
base
Standard
braze
CMT, LSC, PMC
braze+
CMT
CC/CV
CC/CV
cladding
CMT, LSC, PMC
constant current
PMC
CW additive
PMC, ConstantWire
dynamic
dynamic +
PMC
edge
CMT
flanged edge
CMT
galvanized
galvannealed
PMC
gap bridging
CMT, PMC
hotspot
CMT
mix 2) / 3)
PMC
Also required:
marking
mix 2) / 3)
CMT
Also required:
mix drive 2)
PMC
Also required:
multi arc
PMC
open root
LSC, CMT
PCS 3)
PMC
PCS mix
PMC
pin
CMT
pin picture
CMT
pin print
CMT
pin spike
CMT
pipe
pipe cladding
PMC, CMT
retro
ripple drive 2)
PMC
Also required:
root
CMT, LSC, Standard
seam track
PMC, Pulse
TIME
PMC
universal
weld+
CMT
MIG/MAG pulse synergic welding is a pulsed-arc process with controlled material transfer.
In the base current phase, the energy supply is reduced to such an extent that the arc is only just stable and the surface of the workpiece is preheated. In the pulsing current phase, a precisely dosed current pulse ensures the targeted detachment of a droplet of welding material.
This principle guarantees low-spatter welding and precise work over the entire power range.
The MIG/MAG standard synergic welding process is a MIG/MAG welding process across the entire power range of the welding machine with the following arc types:
Dip transfer arc
Droplet transfer takes place during a short circuit in the lower power range.
Intermediate arc
The intermediate arc alternates irregularly between short circuits and spray transitions. This results in increased spatter. It is not possible to use this arc effectively, so it is better to avoid it.
Spray arc
A short circuit-free transfer of material takes place in the high power range.
PMC = Pulse Multi Control
PMC is a pulsed arc welding process with high-speed data processing, precise recording of the process status and improved droplet detachment. Faster welding possible with a stable arc and even penetration.
LSC = Low Spatter Control
LSC is a low-spatter dip transfer arc process. Before the short circuit bridge is broken, the current is lowered and re-ignition takes place at significantly lower welding current values.
SynchroPulse is available for all processes (standard/pulsed/LSC/PMC).
Due to the cyclical change of welding power between two operating points, SynchroPulse achieves a flaking seam appearance and non-continuous heat input.
CMT = Cold Metal Transfer
A special CMT drive unit is required for the CMT process.
The reversing wire movement in the CMT process results in a droplet detachment with improved dip transfer arc properties.
The advantages of the CMT process are as follows
The CMT process is suitable for:
A CMT reference book is available complete with typical applications;
see ISBN 978-3-8111-6879-4.
CMT Cycle Step is a further development of the CMT welding process. A special CMT drive unit is also required for this process.
CMT Cycle Step is the welding process with the lowest heat input.
The CMT Cycle Step welding process switches cyclically between CMT welding and pauses of an adjustable duration.
These pauses in the welding process lower the heat input; the continuity of the weld seam is maintained.
Individual CMT cycles are also possible. The size of the CMT spot welds is determined by the number of CMT cycles.
The SlagHammer function is implemented in all steel characteristics.
In conjunction with a CMT drive unit WF 60i CMT, slag is knocked off the weld seam and wire electrode end by a reversing wire movement without arc before welding.
Knocking off the slag ensures reliable and precise ignition of the arc.
A wire buffer is not required for the SlagHammer function.
The SlagHammer function is automatically executed if a CMT drive unit is present in the welding system.
An active SlagHammer function is displayed in the status bar below the SFI symbol. |
With stitch welding, all welding processes can be cyclically interrupted. This facilitates targeted control of the heat input.
Welding time, pause time and the number of interval cycles can be set individually (e.g. for producing a rippled weld seam, for tacking light-gauge sheets or for longer pause times for simple, automatic spot welding mode).
Stitch welding is possible with any operating mode.
In special 2-step mode and special 4-step mode, no interval cycles are performed during the start and end phases. The interval cycles are only executed in the main process phase.
ConstantWire is used in laser brazing and other laser welding applications.
The welding wire is fed to the solder or weld pool, and the ignition of an arc is prevented by controlling the wire speed.
Constant current (CC) and constant voltage (CV) applications are possible.
The welding wire can be fed either under current for hot wire applications or currentless for cold wire applications.
Welding parameters can be easily changed and selected using the adjusting dial.
The parameters are shown on the display while welding is in progress.
The synergic function ensures that other welding parameters are also adjusted whenever an individual parameter is changed.
As a result of firmware updates, you may find that your device has certain functions that are not described in these operating instructions, or vice versa.
Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
Fully read and understand this document.
| No. | Function |
| (1) | USB port for servicing purposes For connecting TPS/i Licence Key, TPS/i Demonstrator Dongle und TPS/i Service Dongle For details on the function of the USB port, see page (→). IMPORTANT! The USB port is not electrically isolated from the welding circuit. Devices that establish an electrical connection with another device must therefore not be connected to the USB port. |
| (2) | Adjusting dial with turn/press function To select elements, set values and scroll through lists |
| (3) | Display (touchscreen)
| (4) | Key card reader for NFC keys
NFC key = NFC card or NFC key ring |
| (5) | Wire threading button To thread the wire electrode into the torch hosepack with no accompanying flow of gas or current |
| (6) | Gas-test button For setting the required gas flow rate on the gas pressure regulator. After pressing this button, gas flows for 30 seconds. Press the button again to stop the gas flow prematurely. |
Touch the display
Pressing on (and therefore selecting) an element on the display highlights this element. |
Turn the adjusting dial
For certain parameters, a value changed by turning the adjusting dial is applied automatically without having to press the adjusting dial. |
Press the adjusting dial
Press the button
Press the wire threading button to thread the wire electrode into the welding torch hosepack without an accompanying flow of gas or current. | |
When the gas-test button is pressed, gas will flow out for 30 seconds. Press again to end the process prematurely. |
| No. | Function |
| (1) | Status bar The status bar provides information on:
For details, see from page (→) |
| (2) | Left-hand menu bar The left-hand menu bar contains the menus:
The buttons in the left-hand menu bar are actuated by touching the display. |
| (3) | Main area The welding parameters, graphics, lists or navigation elements are shown in the main area. The structure of the main area and the elements shown in it vary according to the application. (3a) Available welding parameters The main area is operated via the adjusting dial or by touching the display. |
| (4) | Right-hand menu bar Depending on the menu selected in the left-hand menu bar, the right-hand menu bar may be used as follows:
The buttons in the right-hand menu bar are actuated by touching the display. |
| (5) | Welding data display Welding current, welding voltage, wire speed, welding power (in kW) Different values are displayed here depending on the situation:
| No. | Function |
The status bar is divided into segments and contains the following information:
| (1) | Current welding process |
| (2) | Current operating mode |
| (3) | Current welding program (material, shielding gas, characteristic and wire diameter) |
| (4) | Process functions display |
| Arc length stabilizer | |
| Penetration stabilizer | |
| SynchroPulse | |
| Spatter Free Ignition, SlagHammer, SFI HotStart | |
| CMT Cycle Step (only in combination with the CMT welding process) | |
| Interval | |
| Symbol lights up green: | |
| Symbol is grey: | |
| (5) | Bluetooth/WiFi status indicator (certified devices only)
or Intermediate arc indicator |
| (6) | During operation with a Velo system: The Velo status Symbol lights up green: Velo function is active Symbol is grey: Velo function is deactivated Symbol is grey and struck through: The Velo function is not supported by the set filler metal or characteristic. |
| (7) | Currently logged-on user (with active user management) or the key symbol when the welding machine is locked (e.g. when the profile/role "locked" is active) |
| (8) | Time and date |
The following functions can be selected and set directly in the status bar:
(1) Welding process
(2) Operating mode
(3) Characteristic (e.g. dynamic, root, universal, etc.)
(4) SynchroPulse, Spatter Free Ignition, Interval, CMT Cycle Step, Penetration stabilizer, Arc length stabilizer
Touch the desired function in the status bar and set it in the window that opens.
Additional information on the characteristic (3) and for SynchroPulse, SFI, etc. (4) can be called up using the respective buttons.
If the characteristic-dependent current limit is reached while MIG/MAG welding, a corresponding message appears in the status bar.
The information appears.
Further information on the current limit can be found in the Troubleshooting section on page (→)
The display is shown in full screen mode:
Hiding the EasyJobs produces the optimal full-screen display:
Defaults / View / EasyJobs / EasyJobs Off
With a few default settings and the setting options via the status bar, the welding machine can be fully operated in full-screen mode for manual applications.
The number and sequence of the displayed parameters may vary depending on the device type, equipment and available Welding Packages.
If there are more than six parameters in a menu, the parameters are divided into several pages.
Navigate between several pages using the "Next page" and "Previous page" buttons:
Animated graphics are shown on the display for certain parameters.
These animated graphics change when the value of the parameter is changed.
In the menus, certain parameters are greyed out because they have no function with the currently selected settings.
Greyed-out parameters can be selected and changed, but have no influence on the current welding process or the welding result.
| (a) | Greyed out parameter (e.g. penetration stabilizer) |
| (b) | Greyed out parameter selected |
| (c) | Value of the greyed out parameter is changed |
| (d) | Greyed out parameter with changed value - no effect with current settings |
| No. | Function |
| (1) | Welding torch connection For connecting the welding torch |
| (2) | (-) current socket with bayonet latch Used to connect the return lead cable during MIG/MAG welding |
| (3) | Control panel cover For protecting the control panel |
| (4) | Control panel with display For operating the welding machine |
| (5) | (+) current socket with bayonet latch |
| (6) | Blanking cover Reserved for the TMC connection socket of the TIG option |
| (7) | Mains cable with strain relief |
| (8) | Mains switch For switching the welding machine on and off |
| (9) | Blanking cover Reserved for TIG shielding gas connection option |
| (10) | Blanking cover Reserved for optional 2nd (-) current socket or 2nd (+) current socket |
| (11) | Blanking cover Reserved for external sensor option |
| (12) | MIG/MAG shielding gas connection socket |
| (13) | Blanking cover Reserved for Ethernet option |
| (14) | Blanking cover Reserved for optional 2nd SpeedNet connection socket |
| (15) | Wirespool holder with brake For holding standard wire spools weighing up to 16 kg (35.27 lbs) and with a max. diameter of 300 mm (11.81 in) |
| (16) | 4-roller drive |
| No. | Function |
Depending on the welding process, a certain minimum equipment level is required in order to work with the welding machine.
The welding processes and the corresponding minimum equipment for the welding operation are described in the following.
The welding machine is generator-compatible.
The maximum apparent power S1max of the welding machine must be known in order to select the correct generator output.
The maximum apparent power S1max of the welding machine is calculated for 3-phase devices as follows:
S1max = I1max x U1 x √3
See device rating plate or technical data for I1max and U1 values
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator may be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the welding machine.
The voltage delivered by the generator must never violate the upper or lower limits of the mains voltage tolerance range.
Details of the mains voltage tolerance can be found in the "Technical data" section.
For more detailed information about installing and connecting the system components, please refer to the appropriate operating instructions.
If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before commissioning.
A universal strain-relief device for cable diameters from 12-30 mm (0.47-1.18 in.) is fitted to the welding machine.
Strain-relief devices for other cable cross-sections must be designed accordingly.
Welding machine
mains voltage: USA & Canada * | Europe
TPS 320i C /nc
3 x 380 V, 3 x 400 V, 3 x 460 V: AWG 14 | 4G 2.5 mm²
TPS 320i C /MV/nc
3 x 200 V, 3 x 230 V: AWG 10 | 4G 4.0 mm²
TPS 320i C /S/nc **
3 x 460 V, 3 x 575 V: AWG 14 | -
| * | Cable type for USA / Canada: Extra-hard usage |
| ** | Welding machine without CE mark; not available in Europe |
AWG = American wire gauge
The work described below must only be carried out by trained and qualified personnel.
Observe national standards and directives.
Danger due to improperly prepared mains cable.
This can result in short circuits and damage to property.
Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
IMPORTANT! The ground conductor should be approx. 20 - 25 mm (0.8 - 1 in.) longer than the phase conductors.
Tightening torque = 1.2 Nm
(TPS 320i C /nc, TPS 320i C /S/nc)
Tightening torque = 3.5 Nm
(TPS 320i C /MV/nc)
Phase conductor:
Tightening torque = 1.5 Nm, TX 15
Tightening torque = 1.5 Nm, TX 25
(TPS 320i C /MV/nc)
Ground conductor:
5 x TX25
Tightening torque = 3 Nm
Danger from electric current.
This can result in serious personal injury.
Do not lift or transport operational devices.
Switch off devices before transport or lifting and disconnect from the mains.
Disconnect ground earth connections before transport.
Danger due to device toppling over.
Use only transport equipment supplied by the manufacturer when transporting devices by crane.
Hook chains or ropes onto the suspension points provided on the transport equipment.
Chains or ropes must be at the smallest angle possible to the vertical.
Observe and comply with applicable national and regional guidelines for the prevention of accidents and risks during transport.
Danger due to damaged devices.
This can result in personal injury and damage to property.
After transport and before commissioning, visually inspect the device for damage.
Any damage must be repaired by trained service technicians before commissioning the device.
The carrying handle on the device is only to be used for transport by hand.
The carrying handle is not suitable for transporting with a crane, counterbalanced lift truck or other mechanical hoist.
Example of a welding system with the following components: | |
Danger due to falling devices or components.
Before transporting the welding system, detach the wirefeeder and the shielding gas cylinder and allow coolant to drain completely.
Ensure that the remaining system components are securely seated on the trolley.
Use only transport equipment supplied by the manufacturer when transporting welding systems by crane.
Danger from machines and components falling as a result of damaged lifting tackle.
Regularly check all lifting tackle used for crane transport, such as straps, buckles, chains, etc., for mechanical damage, corrosion and changes caused by other environmental factors.
The inspection interval and scope of the inspection must comply with the relevant valid national standards and guidelines.
Danger due to devices or welding systems toppling over.
Set up the device securely on an even, solid surface.
The maximum permissible tilt angle is 10°.
Check all screw connections are tightly fastened after installation.
Danger from areas at risk of fire and explosion as well as from areas with increased electrical risk.
Observe national and international regulations for areas at risk of fire and explosion.
Observe national and international regulations for areas with increased electrical risk.
Danger due to inappropriate selection of the installation location.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
The ambient air must be free from dust, acids, corrosive gases or substances and similar.
Do not install and operate the device over 2000 m (6561 ft. 8.16 in.) above sea level.
The device can be set up and operated outdoors in accordance with IP23. Avoid direct wetting (e.g. from rain).
Risk of electric shock due to inadequate mains connection.
This can result in serious injury and death.
Only connect the device to a mains supply with a ground conductor.
Only connect the device to the mains via a connector system with a ground conductor contact.
If operating the device on a mains supply without ground conductor and on a socket without ground conductor contact, observe all national regulations for protective separation.
An inadequately dimensioned electrical installation can cause serious damage to property.
The mains lead and its fuse protection must be dimensioned to suit the local power supply.
The technical data shown on the rating plate applies.
Before connecting the device to the mains, check with the grid operator whether the device may be connected.
The maximum permissible mains impedance that is decisive for a mains connection is stated in the technical data.
IMPORTANT! Ensure that the mains connection is earthed properly!
Due to local regulations and national guidelines, a residual current circuit breaker may be required when connecting a device to the public grid. The type of residual current circuit breaker recommended for the device is specified in the technical data.
Danger from incorrect operation or misuse.
This can result in serious personal injuries – including to third parties, damage to property and impaired welding results.
All persons involved in commissioning, operating, maintaining and servicing the device must be appropriately qualified and have knowledge of welding.
Read and follow these operating instructions carefully.
The operating instructions must always be at hand wherever the device is being used.
Observe generally applicable and regional rules on accident prevention and environmental protection.
Danger from electric shocks.
These can result in serious injury and death.
Do not touch live parts inside or outside the device.
During MIG/MAG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder mount.
Use an adequately insulated, dry base or cover for the earth or ground potential.
This base or cover must extend over the entire area between the body and the earth or ground potential.
Only use undamaged, insulated and adequately dimensioned cables and leads.
Do not wrap cables or leads around the body or parts of the body.
Never touch the welding wire, tungsten electrode or rod electrode when the welding machine is switched on.
Earth the workpiece.
Switch off unused devices.
Before working on the device, switch off the device, pull out the mains plug and attach a clearly legible and easy-to-understand warning sign to prevent anyone from plugging the mains plug back in and switching it on again.
After opening the device, ensure that all components in the device are de-energised – especially components that store electrical charges.
Danger from electromagnetic fields.
Damage to health and effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids, may result.
Maintain as large a distance as possible between the welding power-leads and the head/torso of the welder.
Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body.
Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress.
Danger from stray welding currents.
This can result in overheating of components, fire, destruction of ground conductors and damage to the device and other electrical equipment.
Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
If power distribution boards, twin-head mounts, etc. are being used, ensure that the unused welding torch/electrode holder is adequately insulated.
In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wire spool to the wirefeeder.
Electromagnetic compatibility (EMC) describes the unwanted reciprocal influence of electrical/electronic devices.
The EMC device classification is stated on the rating plate of the device or in the technical data.
Despite compliance with the standardised emission limit values, electrical devices can influence each other in special cases in the intended area of application.
Equipment that may be susceptible to interference from the device includes:Danger from electromagnetic emissions.
These can result in operating faults and malfunctions as well as resulting damage.
Use suitable line filters.
Keep welding power-leads as short as possible, allow the power-leads to run close together and lay the power-leads far away from other cables.
Carry out equipotential bonding.
Earth the workpiece, e.g. using suitable capacitors.
Shield the entire welding system.
Shield other devices nearby.
Danger from flying sparks.
These can result in fires and explosions.
Keep flammable materials at least 11 metres (36 ft. 1.07 in.) away from the arc, or cover with an approved cover.
Take appropriate measures to ensure that sparks and hot metal parts do not pass through small cracks and openings into surrounding areas.
Only weld in areas with a fire or explosion risk or on sealed tanks, vessels or pipes if these have been prepared in accordance with the relevant national and international standards.
Do not weld on containers in which gases, fuels, mineral oils and the like are or were stored.
Flammable vapours should be kept away from the arc's radiation area (e.g. solvent vapours).
Danger due to flying sparks and hot pieces of metal.
This can result in injuries.
Suitable protective clothing must be worn when working with the device.
The protective clothing must be flame-retardant, insulating and dry, cover the whole body and be undamaged. Trousers must not have turn-ups.
Wear stout footwear that provides insulation even in wet conditions.
Wear suitable, electrically insulated and heat protective gloves.
Wear a safety helmet.
Danger from arc radiation, UV rays, heat and flying sparks, which can damage the eyes and skin
Use a protective visor with a regulation filter element.
Wear regulation protective goggles with side protection behind the protective visor.
Danger due to increased noise exposure.
This can result in hearing damage.
Use ear protection during welding.
The device generates a maximum sound power level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation at the maximum permissible operating point under rated load conditions according to EN 60974-1.
It is not possible to provide a workplace-related emission value during welding (or cutting) as this is influenced by both the process and the environment. All manner of different welding parameters come into play, including the welding process (MIG/MAG, TIG welding), the type of power selected (DC or AC), the power range, the type of weld metal, the resonance characteristics of the workpiece, the workplace environment, etc.
A workplace noise level measurement is recommended.
Danger from welding operation (dazzling, flying sparks, harmful welding fume, noise, etc.)
This can result in personal injury.
Keep all persons not involved out of the working area while any devices are in operation or welding is in progress.
Inform people in the vicinity about all hazards of welding operation.
Provide suitable protective equipment.
Erect suitable safety screens/curtains.
Danger from gases and vapours that are harmful to health.
Fume produced during welding contains substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
Keep your face away from welding fume and gases.
Do not breathe in fume or harmful gases.
Ensure an adequate supply of fresh air.
Ensure that there is a ventilation rate of at least 20 m³/h (11.77 cfm) at all times.
Danger due to missing, defective or circumvented safety devices.
Only operate the device when all safety devices are fully functional.
Any safety devices that are not fully functional must be repaired by a qualified specialist before the device is switched on.
Danger from rotating parts such as fans, gears, rollers, shafts or wire spools.
Keep hands, hair, clothing and tools away from moving parts.
Do not reach into the rotating cogs of the wire drive or into rotating drive components.
Danger due to missing or opened covers.
Ensure that all covers and side panels are in place and fitted properly before operation.
During operation ensure all covers and side panels are closed.
Open covers and side panels only while carrying out assembly and maintenance activities.
Danger due to pressurised shielding gas cylinders.
This can result in serious personal injury and damage to property as a result of explosions.
Protect pressurised shielding gas cylinders from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
Do not weld on pressurised shielding gas cylinders.
Keep the shielding gas cylinders well away from any welding or other circuits.
Do not hang the welding torch on a shielding gas cylinder.
If the shielding gas cylinder is not connected, leave the protective cap in place on the valve on the cylinder.
Mount shielding gas cylinders vertically and secure them to prevent them from falling over according to the instructions.
The manufacturer's instructions must be observed and followed as well as national and international regulations for shielding gas cylinders and accessories.
Before transporting a welding system with a trolley by crane, remove the shielding gas cylinder.
Observe safety and maintenance instructions on the shielding gas cylinder or a central gas supply.
Danger from shielding gas escaping unnoticed.
Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
This can result in serious injury and death from suffocating.
There must be a ventilation rate of at least 20 m³ / hour at all times.
Close the valve of the shielding gas cylinder or a central gas supply if no welding is taking place.
Turn your face away from the outlet when opening a valve of a shielding gas cylinder.
Check the shielding gas cylinder or the central gas supply for uncontrolled gas leakage before every start-up.
When using an adapter, prior to assembly seal the device-side thread of the shielding gas connection using suitable Teflon tape.
Danger from contaminated shielding gas.
This can result in damage to property and flawed welding results.
The quality of the shielding gas must meet the following requirements:
Solid particle size < 40 μm
Pressure dew point < -20 °C
Max. oil content < 25 mg/m³
Danger from hot components, parts and liquids.
These can result in burns and injuries.
Never touch the workpiece during or after welding.
Allow hot components, hot parts and hot liquids to cool before touching (e.g. welding torch).
Switch off an existing cooling unit before disconnecting coolant hoses.
Danger from slag jumping off cooling workpieces.
This can result in burns and injuries.
The protective equipment must also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
Before starting work, switch off all the devices and components involved and disconnect them from the mains.
Secure all the devices and components involved to prevent unintentional restarting.
Danger from electrical current due to electrically conductive dust in the device.
Only operate the device with an air filter fitted. The air filter is a very important safety device for achieving IP 23 protection.
The commissioning process for the TPS 320i C welding machine is described using a manual gas-cooled MIG/MAG application as an example.
Danger from falling gas cylinders.
Place gas cylinders on a solid, level surface so that they remain stable. Secure gas cylinders to prevent them from falling over.
Observe the safety rules of the gas cylinder manufacturer.
When establishing a ground earth connection, observe the following points:
Use a separate return lead cable for each welding machine
Keep the plus cable and return lead cable together as long and as close as possible
Physically separate the welding circuits of individual welding machines
Do not route several return lead cables in parallel;
if parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
Keep the return lead cable as short as possible, provide a large cable cross-section
Do not cross return lead cables
Avoid ferromagnetic materials between the return lead cable and the interconnecting hosepack
Do not wind up long return lead cables - coil effect!
Lay long return lead cables in loops
Do not route return lead cables in iron pipes, metal cable conduits or on steel beams, avoid cable ducts;
(routing of plus cables and return lead cables together in an iron pipe does not cause any problems)
If there are several return lead cables, keep the grounding points on the component as far away from one another as possible and prevent crossed current paths from occurring underneath the individual arcs
Use compensated interconnecting hosepacks (interconnecting hosepacks with integrated return lead cable)
A shared ground earth connection for multiple welding machines will have an adverse effect on welding results!
If multiple welding machines are being used to weld a component, a shared ground earth connection can have a massive impact on the welding results.
Separate the welding circuits!
Provide a different ground earth connection for each welding circuit!
Do not use a single, shared return (ground) lead!
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
Only use feed rollers that match the wire electrode.
An overview of the feed rollers available and their potential application areas can be found in the Spare Parts Lists.
Danger from feed roller holders flying upwards.
When unlocking the lever, keep fingers away from the area to the left and right of the lever.
Danger from springiness of spooled wire electrode.
While inserting the wirespool, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
Danger of injury and damage from falling wirespool.
Make sure that the wirespool is fitted securely to the wirespool holder.
Danger from the wirespool falling because the locking ring has been placed the wrong way around.
This can result in personal injury and function impairment.
Always position the locking ring as shown in the diagram on the left.
While inserting the basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
Danger from falling basket-type spool.
Make sure that the basket-type spool and basket-type spool adapter are fitted securely to the wirespool holder.
When working with basket-type spools, only use the basket-type spool adapter included in the scope of supply.
Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
Danger from the basket-type spool falling because the locking ring has been placed the wrong way around.
Danger from elasticity of the spooled wire electrode.
Wear safety goggles.
When inserting the wire spool/basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Danger from sharp end of wire electrode.
This can damage the welding torch.
Properly deburr the end of the wire electrode before threading in.
Lay the torch hosepack as straight as possible.
Danger due to emerging wire electrode.
Hold the welding torch with the end directed away from the face and body.
Wear suitable protective goggles.
Do not point the welding torch at people.
Ensure that the wire electrode can only intentionally make contact with electrically conductive objects.
The wire electrode can be threaded by pressing a wire threading button present in the welding system or by pressing the torch trigger.
The "Wire threading" dialogue window is shown on the display.
Notes on wire threading
If contact is made with the earth during wire threading, the wire electrode is automatically stopped.
When the torch trigger is pressed once, the wire electrode moves forwards 1 mm.
With a push wire feeding system:
If contact is made with the workpiece during threading, the wire play in the inner liner is measured. If the measurement is successful, a wire play value is entered in the event logbook, which is used to control the system.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
Contact pressure standard values for U-groove rollers
Steel:
4 - 5
CrNi
4 - 5
Tubular cored electrodes
2 - 3
After releasing the torch trigger the wirespool should stop unreeling.
Adjust brake if necessary.
Danger from incorrect installation.
This can result in injury and damage to property.
Do not dismantle the brake.
Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
The brake is only available as a complete unit.
The illustration of the brake is for information purposes only.
IMPORTANT! For optimum welding results, the manufacturer recommends performing an R/L alignment when starting the device for the first time and when any changes are made to the welding system.
More information about the R/L alignment can be found under "R/L alignment" in the "Process parameters" section of the "Welding mode" chapter (page (→)).
The welding machine can be locked using an NFC key, e.g. to prevent unauthorised access or welding parameters being changed without permission.
A contactless system on the control panel allows the welding machine to be locked and unlocked.
The welding machine must be switched on before it can be locked or unlocked.
Locking the welding machine
The key symbol appears on the display.
The key symbol is then displayed in the status bar.
The welding machine is now locked.
Only the welding parameters can be viewed and adjusted using the adjusting dial.
Any attempt to access a locked function will result in a notification being displayed.
Unlocking the welding machine
The crossed-out key symbol appears on the display.
The key symbol no longer appears in the status bar.
All welding machine functions are fully available again.
More information about locking and unlocking the welding machine can be found in the "Defaults - Management / Administration" chapter from page (→).
Danger from incorrect operation.
Possible serious injury and damage to property.
Do not use the functions described here until you have read and completely understood these operating instructions.
Do not use the functions described here until you have fully read and understood all of the operating instructions for the system components, in particular the safety rules!
See the Setup menu for information on settings, setting range and units of measurement for the available parameters.
GPr
Gas pre-flow
I-S
Starting-current phase: the base material is heated up rapidly, despite the high thermal dissipation that occurs at the start of welding
t-S
Starting current time
Start arc length correction
SL1
Slope 1: the starting current is steadily lowered until it reaches the welding current
I
Welding-current phase: uniform thermal input into the base material, whose temperature is raised by the advancing heat
I-E
Final current phase: to prevent any local overheating of the base material due to heat build-up towards the end of welding. This eliminates any risk of weld seam drop-through.
t-E
Final current time
End arc length correction
SL2
Slope 2: the welding current is steadily lowered until it reaches the final current
GPo
Gas post-flow
SPt
Spot welding time
A detailed explanation of the parameters can be found in the section headed "Process parameters".
"4-step mode" is suitable for longer welds.
"Special 4-step mode" is particularly suitable for welding aluminium materials. The special slope of the welding current curve takes account of the high thermal conductivity of aluminium.
"Special 2-step mode" is ideal for welding in the higher power range. In special 2-step mode, the arc starts at a lower power, which makes it easier to stabilise.
The "Spot welding" mode is suitable for welded joints on overlapped sheets.
Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
The "MIG/MAG and CMT welding" section comprises the following steps:
If using a cooling unit, follow the safety rules and note the operating conditions in the cooling unit operating instructions.
A cooling unit connected to the welding system will begin to operate.
More information on R/L alignment can be found under "R/L alignment" in the MIG/MAG process parameters chapter (page (→)).
An overview of the welding processes is displayed.
The number and sequence of the displayed welding processes may vary depending on the device type, equipment and available Welding Packages.
An overview of the operating modes is displayed.
The number and sequence of the displayed operating modes may vary depending on the device type, equipment and available Welding Packages.
Welding process and operating mode can alternatively be set via the menu bar.
The number and sequence of the displayed welding processes may vary depending on the device type, equipment and available welding packages.
Different welding processes are available depending on the model of welding machine or function packages installed.
An overview of the operating modes is displayed:
The available characteristics per welding process are not displayed if only one characteristic is available for the selected filler metal.
In this case, the confirmation step of the filler metal wizard follows immediately; steps 10 - 14 do not apply.
The confirmation step of the filler metal wizard is displayed:
The selected filler metal and associated characteristics per welding process will be saved.
The value of the parameter is displayed as a horizontal scale, the parameter is illustrated by means of an animated graphic:
The value of the selected parameter can now be changed.
The adjusted value of the welding parameter is applied immediately.
If one of the "Wire speed", "Material thickness", "Current" or "Voltage" parameters is changed during synergic welding, the other welding parameters are immediately adjusted accordingly.
Each time at the end of welding, the welding data is saved depending on the setting; Hold or Mean is shown on the display (see also page (→)).
Under certain circumstances, it may not be possible to change welding parameters that have been set on a system component (such as wirefeeder or remote control) from the control panel of the welding machine.
Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
4-step mode is assigned as standard for spot welding.
Press the torch trigger - Spot welding process runs until the end of the spot welding time - Press again to stop the spot welding time prematurely
The spot welding parameter can be changed to 2-step under Defaults / System / Mode Setup
(more information on 2-step and 4-step mode in spot welding starts on page (→))
Procedure for producing a welding spot:
Pre-set start of welding and end of welding parameters are also active for spot welding.
Start of welding / end of welding treatment for spot welding can be assigned under Process parameters / General MIG/MAG / Weld-Start/Weld-End.
If the final current time is active, the end of welding is not after the pre-set spot welding time, but only once the pre-set slope and final current times have ended.
Procedure for stitch welding:
Notes on stitch welding
With PMC characteristics, the setting of the SFI parameter influences the re-ignition behaviour in interval operation:
SFI = on
Re-ignition takes place with SFI.
SFI = off
Re-ignition takes place by means of touchdown ignition.
For aluminium alloys, SFI is always used for pulse and PMC ignition. SFI ignition cannot be deactivated.
If the SlagHammer function is stored on the selected characteristic, faster and more stable SFI ignition takes place in conjunction with a CMT drive unit and a wire buffer.
The following welding parameters for MIG/MAG pulse synergic welding and PMC welding can be set and displayed by selecting "Welding":
Wire speed 1)
0.5 - max. 2) 3) m/min / 19.69 - max 2) 3) ipm.
Material thickness 1)
0.1 - 30.0 mm 2) / 0.004 - 1.18 2) in.
Current 1) [A]
Setting range: depends on the welding process and welding program selected
Before the start of welding, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding.
Arc length correction
for correcting the arc length;
-10 - +10
Factory setting: 0
- ... shorter arc length
0 ... neutral arc length
+ ... longer arc length
If the arc length correction is adjusted, the welding voltage changes, but the welding current and wire speed remain the same.
On the display, the voltage value with unchanged arc length correction (1), the voltage value corresponding to the currently set arc length correction (2) and the symbol of an active arc length correction (3) are displayed.
For certain PMC characteristics, the arc length correction cannot be adjusted when the arc length stabilizer is active.
The arc length correction is then not displayed in the welding parameters.
Pulse correction
For correcting the pulsing energy of a pulsed arc
-10 - +10
Factory setting: 0
- ... lower droplet detachment force
0 ... neutral droplet detachment force
+ ... increased droplet detachment force
SynchroPulse can be activated via the status bar.
(See page (→))
If SynchroPulse is activated, the SynchroPulse parameters are also displayed with the welding parameters.
Wire speed 1)
Current 1) [A]
-10 - +10
Factory setting: 0
Pulse correction
-10 - +10
Factory setting: 0
(See page (→))
The following welding parameters for MIG/MAG standard synergic welding, LSC welding and CMT welding can be set and displayed by selecting the "Welding" menu button:
Wire speed 1)
Current 1) [A]
-10 - +10
Factory setting: 0
Dynamic correction
for setting the short circuit current and the current to short-circuit break-up
-10 - +10
Factory setting: 0
-10
harder arc (higher current in case of short-circuit break-up, increased welding spatter)
+10
softer arc (lower current in case of short-circuit break-up, less welding spatter forms)
(See page (→))
The following welding parameters for MIG/MAG standard manual welding can be set and displayed by selecting the "Welding" menu button:
Voltage 1) [V]
Wire speed 1)
for setting a harder, more stable arc
0.5 - max. 2) m/min / 19.69 - max 2) ipm.
Arc-force dynamic
to influence the short-circuiting dynamic at the instant of droplet transfer
0 - 10
Factory setting: 1.5
0 ... harder and more stable arc
10 ... soft and low-spatter arc
| 1) | Synergic parameter When a synergic parameter is changed, the synergic function automatically changes all other synergic parameters to match. The actual setting range depends on the welding machine and wirefeeder used and on the welding program selected. |
| 2) | The actual setting range depends on the welding program selected. |
| 3) | The maximum value depends on the wirefeeder used. |
If EasyJob mode has been activated, 5 additional buttons appear on the display. These enable up to 5 operating points to be saved at the touch of a button.
The current welding settings are saved.
If there is a robot interface in the welding system, the EasyJob buttons are not displayed, the EasyJob mode is greyed out and cannot be activated.
The overview to activate/deactivate EasyJob mode is displayed.
EasyJob mode is activated and the default settings are displayed.
Five EasyJob buttons are displayed for the welding parameters.
The EasyJobs are stored under job numbers 1 - 5 and can also be retrieved using "Job mode".
Storing an EasyJob overwrites any other job saved under the same number!
The size and colour of the button changes. After about three seconds, the button is displayed green with a frame.
The settings have now been stored. The most recently stored settings will be active. An active EasyJob is shown with a tick on the EasyJob button.
Unoccupied EasyJob buttons are shown in dark grey.
For occupied EasyJobs, the button number is shown in white.
The size and colour of the button changes briefly; it is then displayed with a tick.
If a tick is not displayed after touching an EasyJob button, this means that there is no operating point saved under this button.
The button
The EasyJob operating point has been deleted.
* ... highlighted in red
With this function, any stored job can be loaded as an EasyJob in the welding menu without switching to Job Mode.
In the welding parameters, the "Load Job" button is also displayed in the right-hand menu bar.
The list of stored jobs is displayed.
The job is loaded in the welding menu, the welding machine is not in Job Mode.
Up to 1000 jobs can be stored and reproduced on the welding machine.
This eliminates the need to manually document the welding parameters.
Job Mode thereby increases the quality of automated and manual applications.
Jobs can only be stored when in welding mode. When storing jobs, the process parameters and certain machine defaults are taken into account in addition to the present welding settings.
The job list is displayed.
To overwrite an existing job, select it by turning and pressing the adjusting dial (or selecting "Next").
The selected job can be overwritten after acknowledging the confirmation prompt.
Select "Create a new Job" to create a new job
The next free job number is displayed.
The keyboard is displayed.
The name is saved and a confirmation that the job has been stored is displayed.
Before retrieving a job, make sure that the welding system has been installed and set up for the job.
Job mode is activated.
"Job welding" and the data from the most recently retrieved job are displayed.
IMPORTANT! "Job" is the only parameter that can be altered in Job Mode; all the other welding parameters are read-only.
The job name is changed and the job list is displayed.
As an alternative to the procedure described above, the job can also be renamed in the process parameters:
Process parameters / Job / Optimize job / Rename job
A confirmation prompt asking whether you really want to delete the job is displayed.
The job is deleted, the job list is displayed.
As an alternative to the procedure described above, the job can also be deleted in the process parameters:
Process parameters / Job / Optimize job / Delete job
The load job function can be used to load the data for a saved job or an EasyJob to the welding screen. The relevant data from the job is displayed in the welding parameters and can be changed, saved as a new job or EasyJob, or used to start welding.
The load job information is shown.
The data for the selected job is loaded onto the welding screen.
The data for the loaded job can now be used for welding (no job mode), changed, or be saved as a new job or an EasyJob.
An overview of the job functions is displayed.
The overview of the most recently optimised job is displayed.
Individual correction limits for welding power and arc length can be defined for each job.
If correction limits are defined for a job, the welding power and arc length for the job in question can be corrected within the defined limits while welding.
A list of the job correction limits for the last job opened is displayed.
Pre-settings for "Save as Job" are used to set the default values that are assumed for every newly created job.
The default settings for saving new jobs are displayed.
Risk of injury and damage from electric shock.
As soon as the mains switch is in the "I" position, the tungsten electrode of the welding torch is live.
Ensure that the tungsten electrode does not touch any persons or electrically conductive or earthed parts (e.g. housing, etc.).
Alternatively, the welding process can also be selected via the status bar (compare with the selection described from page (→)).
The welding voltage is applied to the welding socket with a three second time lag.
Under certain circumstances, it may not be possible to change welding parameters that have been set on a control panel of a system component (such as remote control or wirefeeder) from the control panel of the welding machine.
The TIG welding parameters are displayed.
The value of the welding parameter is displayed as a horizontal scale:
The welding arc is ignited by touching the workpiece with the tungsten electrode.
Check the rod electrode packaging or labelling to determine whether the rod electrodes are for positive pole or negative pole welding.
As soon as the mains switch is in the "I" position, the rod electrode in the electrode holder is live.
Make sure that the rod electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.)
If the MMA/SMAW welding process is selected, any cooling unit present is automatically deactivated. It is not possible to switch it on.
The MMA welding parameters are displayed.
The following welding parameters for MMA welding can be set and displayed under "Welding":
Arc-force dynamic
0-100
Factory setting: 20
100 ... harder and more stable arc
Main current [A]
Setting range: depends on the welding machine being used
Starting current
for setting a starting current value in the range 0-200% of the set welding current in order to avoid slag inclusions or incomplete fusion.
The starting current depends on the electrode type.
0-200%
Factory setting: 150%
The starting current is active for the starting current time set under the process parameters.
Process parameters / Common ... see page (→)
Process parameters / Components & Monitoring ... see page (→)
Process parameters / JOB ... see page (→)
Depending on the device type, equipment or Welding Packages available, the display and sequence of process parameters may vary.
The following process parameters can be set and displayed for the start and end of welding:
Special 2/4 step parameters
Starting current
for setting the starting current for MIG/MAG welding (e.g. aluminium welding start-up)
0 - 400% (of welding current)
Factory setting: 135%
for correcting the arc length at the start of welding
-10 - -0.1 / auto / 0.0 - 10.0
Factory setting: auto
auto:
the value set in the welding parameters is taken over
for setting the length of time the starting current is to be active
off / 0.1 - 10.0 s
Factory setting: off
Slope 1
for setting the time during which the starting current is decreased or increased to the welding current
0.0 - 9.9 s
Factory setting: 1.0 s
Slope 2
for setting the time during which the welding current is decreased or increased to the final current.
0.0 - 9.9 s
Final current
for setting the final current so that
Factory setting: 50%
for correcting the arc length at the end of welding
auto:
Final current time
for setting the length of time for which the final current is to be active
off / 0.1 - 10.0 s
SFI parameters
SFI
to activate / deactivate the function SFI (Spatter Free Ignition - spatter-free ignition of the arc)
SFI causes an almost spatter-free ignition of the arc due to a controlled starting current curve with synchronised wire retraction movement.
off / on
SFI is permanently integrated in certain welding processes and cannot be deactivated.
If SH is displayed in the status line for SFI, the SlagHammer function is active in addition to SFI.
SFI and SH cannot be deactivated.
SFI HotStart
for setting a HotStart time in conjunction with SFI ignition
During SFI ignition, a spray arc phase occurs within the set HotStart time. This increases the heat input irrespective of the mode, thus ensuring deeper penetration right from the very start of welding.
off / 0.01 - 2.00 s
Manual parameters
Ignition current (manual)
for setting the ignition current for MIG/MAG standard manual welding
100 - 550 A (TPS 320i, TPS 320i C)
100 - 600 A (TPS 400i)
100 - 650 A (TPS 500i, TPS 600i)
Factory setting: 500 A
Wire withdrawal (manual)
for setting the wire withdrawal value (= composite value based on backward movement of wire and a time) for MIG/MAG standard manual welding.
The wire withdrawal depends on the features of the welding torch.
0.0 - 10.0
Factory setting: 0.0
Wire withdrawal
Wire withdrawal
For setting the wire withdrawal value (= composite value based on backward movement of wire and a time).
0.0 - 10.0
The following process parameters can be set and displayed for Gas-Setup:
Gas pre flow
for setting the gas flow time before the arc is ignited
0-9.9 s
Factory setting: 0.1 s
Gas postflow
for setting the gas flow time after the arc has gone out
0-9.9 s
Factory setting: 0.5 s
Command value gas
Shielding gas flow rate
(only in conjunction with the OPT/i gas flow rate sensor option)
off / 0.5-30.0 l/min
Factory setting: 15.0 l/min
For the gas flow sensor to function correctly, the supply pressure at the welding machine must be at least 4.5 bar / 65 psi when the target flow rate is maintained.
Uninstall existing flow controllers if necessary to achieve the minimum supply pressure of 4.5 bar / 65 psi.
Gas factor
dependent on the shielding gas used
auto / 0.90-20.00
(the correction factor is automatically set for standard gases from the Fronius welding database)
In Job Mode, the set values of the parameters listed above can be stored individually for each job.
The following process parameters can be set and displayed for the process control:
The penetration stabilizer is used to set the max. permitted change in the wire speed to ensure that the welding current and hence the penetration are kept stable or constant with variable stickout.
The penetration stabilizer parameter is only available when the WP PMC (Welding Process Pulse Multi Control) or WP LSC (Welding Process Low Spatter Control) option has been enabled on the welding machine.
0.0-10.0 m/min (ipm)
Factory setting: 0 m/min
auto
A value of 10 m/min is stored for all characteristics, the penetration stabilizer is activated.
0
The penetration stabilizer is not activated.
The wire speed remains constant.
0.1-10.0
The penetration stabilizer is activated.
The welding current remains constant.
Application examples
Penetration stabilizer = 0 m/min (not activated)
Changing the contact tube distance (h) alters the resistance in the welding circuit due to the longer stickout (s2).
The constant voltage control for constant arc length causes a reduction in the mean current value and hence a smaller penetration (x2).
Penetration stabilizer = n m/min (activated)
Specifying a value for the penetration stabilizer ensures a constant arc length without large current variations if the stickout is changed (s1 ==> s2).
The penetration (x1, x2) remains virtually unchanged and stable.
Penetration stabilizer = 0.5 m/min (activated)
To minimise the change in welding current if the stickout is changed (s1 ==> s3), the wire speed is increased or reduced by 0.5 m/min.
In the example shown, the stabilising effect is obtained without a change in current up to the set value of 0.5 m/min (Position 2).
I ... Welding current vD ... Wire speed
The arc length stabilizer forces short arcs, advantageous for welding, via a short-circuit current control and keeps them stable even with a variable stickout or external interference.
The arc length stabilizer welding parameter is only available if the WP PMC (Welding Process Pulse Multi Control) option has been enabled on the welding machine.
0.0 / auto / 0.1-5.0 (effect of stabilizer)
0.0
The arc length stabilizer is deactivated.
auto
0.1-5.0
The arc length stabilizer is activated.
The arc length is decreased until short circuits start to occur.
If the arc length stabilizer is activated, the normal arc length correction is only effective at the start of welding.
The arc length correction is then no longer displayed in the welding parameters.
Arc length stabilizer = 0 / 0.5 / 2.0
Arc length stabilizer = 0.5
Arc length stabilizer = 2
Activating the arc length stabilizer reduces the arc length until short circuits start to occur. The advantages of a short, stable and controlled arc can be used more effectively as a result.
Increasing the arc length stabilizer causes a further shortening of the arc length (L1 ==> L2 ==> L3). The advantages of a short, stable and controlled arc can be used more effectively.
Arc length stabilizer with change of weld seam profile and position
Arc length stabilizer not activated
A change of weld seam profile or welding position can negatively affect the welding result
Arc length stabilizer activated
Since the number and duration of the short circuits is controlled, the properties of the arc stay the same if the weld seam profile or welding position is changed.
I ... Welding current vD ... Wire speed U ... Welding voltage
* ... Number of short circuitsExample: Stick out change
Arc length stabilizer without penetration stabilizer
The advantages of a short arc are maintained even if the stick out is changed, since the short-circuit properties stay the same.
Arc length stabiliser with penetration stabilizer
If the stick out is changed with the penetration stabilizer activated, the penetration also stays the same.
The short circuit behaviour is controlled by the arc length stabilizer.
* ... Number of short circuits Δs ... Stick out changeThe following process parameters can be set for welding in conjunction with a Velo system:
Velo
To activate/deactivate the Velo system
off / on
Welding speed "Velo"
For setting the welding speed for the Velo system
10–300 cm/min
Factory setting: 35 cm/min
Wire retract "Velo"
For setting how far the Velo welding wire is retracted from the weld after the end of welding
off / auto / 0.0–25.0 mm
The following process parameters can be set for SynchroPulse welding:
(1) SynchroPulse
to activate/deactivate SynchroPulse
off / on
Factory setting: on
(2) Wire speed
for setting the average wire speed and therefore the welding power for SynchroPulse
e.g. 2–25 m/min (ipm)
(depending on wire speed and welding characteristic)
Factory setting: 5.0 m/min
(3) Delta wire feed
for setting the Delta wire feed:
with SynchroPulse, the set wire speed is alternately increased/decreased by the Delta wire feed. The parameters concerned adapt themselves to this wire speed acceleration/delay accordingly.
0.1–6.0 m/min / 5–235 ipm
Factory setting: 2.0 m/min
The maximum adjustable Delta wire feed of 6 m/min (235 ipm) is only possible up to a frequency of approx. 3 Hz.
In the frequency range of 3–10 Hz, the adjustable Delta wire feed decreases.
(4) Frequency
for setting the frequency for SynchroPulse
0.5–10.0 Hz
Factory setting: 3.0 Hz
In TWIN mode, the setting of the frequency on the lead welding machine also affects the trail welding machine.
The setting of the frequency on the trail welding machine has no effect.
(5) Duty Cycle (high)
for weighting the duration of the higher operating point in a SynchroPulse period
10–90%
Factory setting: 50 Hz
In TWIN mode, the setting of the duty cycle (high) on the lead welding machine also affects the trail welding machine.
The setting of the duty cycle (high) on the trail welding machine has no effect.
(6) Arc correction high
for correcting the arc length for SynchroPulse in the upper operating point (= average wire speed plus Delta wire feed)
-10.0-+10.0
- .... short arc
0 ... uncorrected arc length
+ ... longer arc
If SynchroPulse is activated, the normal arc length correction has no effect on the welding process.
(7) Arc correction low
for correcting the arc length for SynchroPulse in the lower operating point (= average wire speed less Delta wire speed)
-10.0-+10.0
- ... short arc
+ ... longer arc
The following process parameters for mixed processes can be set under "Process mix":
Wire speed vD *
Wire speed
1.0–25.0 m/min / 40–985 ipm
The wire speed value is applied or can be specified and changed in the Process mix parameters.
-10.0-+10.0
The arc length correction value is applied or can be specified and changed in the process mix parameters.
Pulse correction
for changing the pulse energy in the pulsed arc process phase
-10.0-+10.0
The pulse correction value is applied or can be specified and changed in the process mix parameters.
Upper power time correction (3) *
to set the duration of the hot process phase in a mixed process
-10.0-+10.0
Factory setting: 0
Upper and lower power time correction is used to define the relationship between hot and cold process phases.
If the upper power time correction is increased, the process frequency reduces and the PMC process phase becomes longer.
If the upper power time correction is reduced, the process frequency increases and the PMC process phase becomes shorter.
Lower power time correction (2) *
to set the duration of the cold process phase in a mixed process
-10.0-+10.0 / 1-100 CMT cycles (for CMT mix characteristics)
Factory setting: 0
If the lower power time correction is increased, the process frequency reduces and there is a longer LSC process phase or a longer CMT process phase for CMT mix.
If the lower power time correction is reduced, the process frequency increases and there is a shorter LSC process phase or a shorter CMT process phase for CMT mix.
Lower power correction (1) *
to set the energy input in the cold process phase in a mixed process
-10.0-+10.0
Factory setting: 0
If the lower power correction is increased, this results in a higher wire speed and therefore higher energy input in the cold LSC process phase or in the cold CMT process phase.
* Representation of the parameters in the following graphics
| (1) | Lower power correction |
| (2) | Low power time corr. |
| (3) | High power time corr. |
| vD | Wire speed |
Wire speed
Wire speed
1.0–30.0 m/min / 40–1181 ipm
The wire speed value is applied or can be specified and changed in the parameters for additive welding.
-10.0-+10.0
Power correction
for setting the welding power at a constant wire speed to ensure a consistent seam structure
-10.0-+10.0
Factory setting: 0
Deposition rate stabilizer
on / 0.1–10.0 m/min / off
Factory setting: on
Deposition rate stabilizer dynamic
auto / 10.0–0.0
CMT Cycle Step
for activating/deactivating the CMT Cycle Step function
On / Off
Wire speed
Wire speed, determines the deposition rate during the welding process phase and therefore the size of the welding spot;
Setting range: in m/min (ipm), dependent on the welding characteristic
The wire speed value is applied or can also be specified or changed in the CMT Cycle Step parameters.
Cycles (welding spot size)
for setting the number of CMT cycles (weld droplets) for a welding spot;
the number of CMT cycles and the set wire speed determine the size of the welding spot.
1–2000
Pause time interval
for setting the time between each welding spot
0.01–2.00 s
The higher the value for the pause time interval, the cooler the welding process is (heavier flaking).
Cycles interval
for setting the number of repeated CMT cycles including pauses until the end of welding
constant / 1–2000
constant
The repetitions are carried out continuously;
end of welding, for example using "Arc Off"
Spot welding time
0.1 - 10.0 s
Interval
to activate / deactivate stitch welding
off / on
Wire speed
0.0 - max. m/min (depending on the wirefeeder used)
Stitch welding time
0.01 - 9.9 s
Factory setting: 0.3 s
Interval break time
off / 0.01 - 9.9 s
Interval cycles
constant / 1 - 99
Factory setting: constant
Ignition current
Wire withdrawal
0.0 - 10.0
Characteristic slope
auto / U constant / 1000 - 8 A/V
Align the welding circuit resistance (R) and welding circuit inductivity (L) if one of the following components of the welding system is changed:
Prerequisites for R/L alignment:
The welding system must be complete: closed welding circuit with welding torch and torch hosepack, wirefeeders, grounding cable, interconnecting hosepacks.
Performing R/L alignment:
The current welding circuit inductivity and welding circuit resistance values are displayed.
The second step of the R/L alignment wizard appears.
The third step of the R/L alignment wizard appears.
The fourth step of the R/L alignment wizard appears.
After a successful measurement, the current values are displayed.
Alternatively, R/L alignment can also be carried out via a Jobmaster welding torch.
The following process parameters can be set and displayed for the TIG and MMA welding processes:
Process parameters for MMA welding:
0.0-2.0 s
Characteristic
for selecting the electrode characteristic
I-constant / 0.1-20.0 A/V / P-constant / Arc air gouging
Factory setting: I-constant
| (1) | Load line for rod electrode |
| (2) | Load line for rod electrode where arc length is increased |
| (3) | Load line for rod electrode where arc length is reduced |
| (4) | Characteristic where "I-constant" parameter is selected (constant welding current) |
| (5) | Characteristic where "0.1-20" parameter is selected (drooping characteristic with adjustable slope) |
| (6) | Characteristic where "P-constant" parameter is selected (constant welding power) |
| (7) | Example of pre-set arc-force dynamic where characteristic (4) is selected |
| (8) | Example of pre-set arc-force dynamic where characteristic (5) or (6) is selected |
I-constant (constant welding current)
0.1-20.0 A/V (drooping characteristic with adjustable slope)
P-constant (constant welding power)
Arc air gouging
| (7) | Example of pre-set arc-force dynamic where characteristic (5) or (6) is selected |
| (8) | Possible change in the current where characteristic (5) or (6) is selected, as a function of the welding voltage (arc length) |
| (a) | Operating point where arc length is long |
| (b) | Operating point where welding current IH is set |
| (c) | Operating point where arc length is short |
The characteristics (4), (5) and (6) shown here apply when using a rod electrode whose characteristic corresponds - at a given arc length - to the load line (1).
Depending on what welding current (I) has been set, the point of intersection (operating point) of characteristics (4), (5) and (6) will be displaced along the load line (1). The operating point provides information on the actual welding voltage and the actual welding current.
Where the welding current (IH) is permanently set, the operating point may migrate along the characteristics (4), (5) and (6) according to the welding voltage at a given moment. The welding voltage U is dependent upon the arc length.
If the arc length changes (e.g. in accordance with the load line (2)) the resulting operating point will be the point where the corresponding characteristic (4), (5) or (6) intersects with the load line (2).
Applies to characteristics (5) and (6): Depending upon the welding voltage (arc length), the welding current (I) will also become either smaller or larger, even though the value set for IH remains the same.
Anti-stick
to activate/deactivate the anti-stick function
off / on
Factory setting: on
As the arc becomes shorter, the welding voltage may drop so far that the rod electrode will tend to stick. This may also cause the rod electrode to burn out.
The anti-stick function prevents the electrode from burning out. If the rod electrode begins to stick, the welding machine switches the welding current off after 1.5 seconds. After the rod electrode has been lifted off the workpiece, the welding process can be continued without any problems.
Break voltage
for setting a voltage, at which the welding process can be ended by slightly lifting the rod electrode.
20-90 V
Factory setting: 90 V
The arc length depends on the welding voltage. To end the welding process, it is usually necessary to significantly lift the rod electrode away from the workpiece. With the break voltage parameter, the welding voltage can be limited to a value that makes it possible to end the welding process simply by lifting the rod electrode slightly.
IMPORTANT! If, during welding, you often find that the welding process is ended unintentionally, increase the value of the break voltage.
Process parameters for TIG welding:
Break voltage
for setting a voltage, at which the welding process can be ended by slightly lifting the TIG welding torch.
10.0-30.0 V
Factory setting: 14 V
Comfort Stop Sensitivity
to activate/deactivate the TIG Comfort Stop function
off / 0.1 - 1.0 V
Factory setting: 0.8 V
At the end of the welding process, the welding current is switched off automatically if the arc length increases by more than a defined amount. This prevents the arc being unnecessarily elongated when the TIG gas-valve torch is lifted off the workpiece.
Sequence:
Depending on the device type, equipment or WeldingPackages available, the display and sequence of process parameters may vary.
The following process parameters can be set and displayed for the system components of a welding system:
Cooling unit
Cooling unit mode
to determine whether a cooling unit is to be switched on or off, or operated automatically
eco / auto / on / off (depending on the cooling unit)
Delay time flow sensor
for setting the time from when the flow sensor responds until a warning message is output
5 - 25 s
Factory setting: 5 s
Coolant flow warning level
(only if the flow temperature sensor option is present on the cooling unit)
If the parameter is activated, a warning is generated if the value entered is not reached.
off / 0.75 - 0.95 l/min
Wirefeeder
Inching value
for setting the wire speed at which the wire electrode is threaded into the torch hosepack
e.g. 2 - 25 m/min / 20 - 3935 ipm
(depending on the wire speed)
Factory setting: 10 m/min
The feeder inching speed can also be set in the window that opens when the wire threading button is pressed:
Press feeder inching button
Press and turn the adjusting dial to change the value of the feeder inching speed
Select "Close" or press the adjusting dial to accept the value
Power source
Ignition timeout
Length of wire that is fed before the safety cut-out trips
off / 5 - 100 mm (0.2 - 3.94 in.)
The ignition time-out process parameter is a safety function.
The length of wire that is fed before the safety cut-out trips may differ from the pre-set wire length, particularly when the wire is being fed at fast wire speeds.
How it works:
Once the torch trigger is pressed, gas pre-flow begins immediately. Wirefeeding then begins, followed by ignition. If no current starts flowing before the specified length of wire has been fed, the power source cuts out automatically.
To try again, press the torch trigger again.
Sense lead
to enable/disable the sense lead function
off / on
Factory setting: on
The sense lead is additional hardware for direct voltage measurement on the workpiece. The function is used to determine the correct actual value when several welding processes are welding on one component at the same time and there is a risk of coupled interference voltages due to unfavourable hosepack routing or common earth leads.
If two motors are used in a welding system, they need to be calibrated to maintain process stability.
System calibration must be carried out on welding systems with PushPull units or unreeling wirefeeders following successful installation or replacement of a wirefeeder.
A notification will be displayed.
The system calibration wizard starts.
System calibration can also be started manually here.
Perform system calibration:
If system calibration is required, the system calibration wizard starts. The first step in the system calibration wizard is displayed:
When system calibration has been completed successfully, a confirmation to this effect is displayed.
The "Arc break watchdog settings" overview is displayed.
The overview "Wire stick contact tip - setup menu" is displayed.
The overview "Wire stick work piece - setup menu" is displayed.
This function can be used to measure the inductances present in the welding circuit.
Inductances can lead to welding problems, for example when several systems weld on one component.
With the help of inductance measurement and appropriate cable management, welding problems can be prevented early on during the commissioning of a welding system.
Selecting the "Welding circuit coupling" button starts a corresponding wizard.
Measuring results:
Result | Rcoupling | Kcoupling |
Very good | 0 mOhm | 0% |
Good | 1 - 2.5 mOhm | 2 - 15% |
Average | 3 - 15 mOhm | 16 - 30% |
Poor | 16 - 100 mOhm | 31 - 100% |
The measurement results are stored in the logbook.
Details on the welding circuit coupling are described in the operating instructions "Cable Management Guide" - 42,0426,0420,xx.
The operating instructions are available as HTML under the following link:
https://manuals.fronius.com/html/4204260420 |
The overview "Wire end monitoring setup menu" is displayed.
| (1) | Wire end reaction for OPT/i WF R WE ring sensor 4,100,878,CK |
| (2) | Wire end reaction for OPT/i WF R WE drum 4,100,879,CK |
| (3) | Wire end reaction for OPT/i WF R WE wire end 4,100,869,CK |
The gas monitoring parameters are only available when the optional OPT/i gas flow rate sensor is present.
A lower limit for the gas flow rate can be set using gas monitoring. If the gas flow rate drops below this limit for a defined period of time, an error message is immediately issued and the welding operation is halted.
The "Gas monitoring" overview is displayed.
If the wrong gas factor is set, this can have a massive impact on the gas flow rate and therefore the welding result.
All the standard gases from the Fronius welding database are considered under the "auto" setting.
Setting the gas factor manually is only advisable for special gases, and only after consultation.
The "Motor force monitoring" overview is displayed.
The parameters for wire buffer monitoring are available if there is a wire buffer in the welding system.
The following process parameters can be set for job optimisation:
Job parameter
Wire speed
for adjusting the wire speed
e.g. 2 - 25 m/min (ipm)
Arclength correction
-10.0 - +10.0
- .... short arc
+ ... longer arc
Pulse correction
for MIG/MAG pulse synergic welding, PMC welding for correction of the pulse energy
-10.0 - +10.0
Or
Dynamic correction
for MIG/MAG standard synergic welding, LSC welding and CMT welding to adjust the short circuit current and the current to short-circuit break-up
-10.0 - +10.0
-10
+10
Welding process parameters
Change characteristic - current ID: xxxx
The ID no. of the currently stored characteristic is displayed.
After pressing the dial, the method and property of the characteristic can be changed.
Process
The process assigned to the characteristic is displayed.
Property
The property assigned to the characteristic is displayed.
Trigger mode
for setting the operating mode
2-step / 4-step / S2-step / S4-step / spot welding
The other adjustable process parameters correspond to the process parameters already described:
Weld-Start/ Weld-End ... see page (→)
Spot welding ... see page (→)
Process control ... see page (→)
SynchroPulse ... see page (→)
Process mix settings ... see page (→)
CMT Cycle Step ... see page (→)
Only if the OPT/i CMT Cycle Step option is present on the power source.
Gas-Setup ... see page (→)
Power
Arc length correction ... see page (→)
Job slope ... see page (→)
Documentation ... see page (→)
Limit monitoring ... see page (→)
(only in conjunction with the OPT/i Limit Monitoring option)
Components ... see page (→)
In addition to setting the parameters, jobs can also be renamed, copied and deleted under "Optimize job" with the help of the corresponding buttons.
Further information on optimising jobs can be found in the "Welding mode" section, under "Job Mode" on page (→).
The following process parameters can be set for the job correction limits:
Power
Upper power limit
For setting the upper power limit for a job
0 - 20%
Factory setting: 0%
Lower power limit
For setting the lower power limit for a job
-20 - 0%
Factory setting: 0%
Upper arc length correction Limit
for setting the upper arc length correction limit for a job
0.0 - 10.0
Factory setting: 0
Lower arc length correction Limit
for setting the lower arc length correction limit for a job
-10.0 - 0.0
Factory setting: 0
Further information on optimising jobs can be found in the Job correction limits section, under Job Mode on page (→).
After confirming the displayed information, the following process parameters can be set for the "Save as Job" pre-settings:
Job slope
Job slope
defines the time between the job that is currently selected and the next job
0.0 - 10.0 s
Factory setting: 0 s
MIG/MAG job correction limit
Upper power correction limit
0 - 20%
Factory setting: 0%
Lower power correction limit
0 - -20%
Factory setting: 0%
Upper arc length correction limit
0.0 - 10.0
Lower arc length correction limit
0.0 - -10.0
Limit Monitoring
Lower voltage limit
for setting the lower voltage limit as a function of the set value
-10.0 - 0.0 V
Factory setting: 0 V
Upper voltage limit
for setting the upper voltage limit as a function of the set value
0.0 - 10.0 V
Maximum duration of voltage deviation
for setting the maximum duration of a voltage deviation
off / 0.1 - 10.0 s
Lower current limit
for setting the lower current limit as a function of the set value
-100.0 - 0.0 A
Factory setting: 0
Upper current limit
for setting the upper current limit as a function of the set value
0.0 - 100.0 A
Factory setting: 0
Maximum duration of current deviation
for setting the maximum duration of a current deviation
off / 0.1 - 10.0 s
Lower wire speed limit
for setting the lower wire speed limit
-10.0 - 0.0 m/min (ipm)
Upper wire speed limit
for setting the upper wire speed limit
0.0 - 10.0 m/min (ipm)
Maximum duration of wire speed deviation
for setting the maximum duration of a wire speed deviation
off / 0.1 - 10.0 s
Lower welding duration limit
for setting the lower welding duration limit
0.0 ... -50.0 s
Upper welding duration limit
for setting the upper welding duration limit
0.0 - 50.0 s
Welding duration monitoring
to enable/disable welding duration monitoring
on / off
Factory setting: on
Lower energy limit
for setting the lower energy limit
0.0 ... -max
Factory setting: -1.0
Upper energy limit
for setting the upper energy limit
0.0 - max
Energy monitoring
to enable/disable energy monitoring
on / off
Factory setting: on
Limit reaction
for setting the reaction if the limit values are exceeded or undercut
Ignore / Warning / Error
Factory setting: Ignore
Ignore
Limit values will not be monitored or logged in the logbook
Warning
If the limit values are exceeded or undercut, a warning will show on the display and the welding process will not be interrupted.
Error
If the limit values are exceeded or undercut, the welding process will stop immediately and an error message will show on the display.
As a result of firmware updates, you may find that there are functions available on your device that are not described in these operating instructions or vice versa.
Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
Fully read and understand this document.
"Defaults" contains the following options:
An overview of units and standards is displayed.
The time and date can either be set using the NTP (Network Time Protocol) or manually.
Setting the time and date using the NTP
A DNS server must be available, or the network parameters must be configured correctly if setting the time and date manually (see "Setting network parameters manually", page (→)).
The welding machine is synchronised with the time on the NTP server. If the NTP has been set up, the time will be synchronised each time the welding machine is started, as long as a connection to the time server can be established.
Setting the time and date manually
In order to be able to set the time and date manually, "Automatic Time & Date" must not be selected.
The default view settings are displayed.
The current system data is displayed.
Arc power from real-time values in kW If the welding speed is known, the electrical energy per unit length can be calculated: E = IP / vs
Arc energy in kJ E = IE / L
The arc energy is preferably used during manual welding to calculate the energy per unit length. | |||||||
Current welding speed in cm/min | |||||||
Job currently set | |||||||
Current weld seam | |||||||
Duration of the current weld seam in s | |||||||
Current motor current in A, wirefeeder 1 | |||||||
Current motor current in A, wirefeeder 2 | |||||||
Current motor current in A, wirefeeder 3 | |||||||
Current motor force in N, wirefeeder motor 1 | |||||||
Current motor force in N, wirefeeder motor 2 | |||||||
Current motor force in N, wirefeeder motor 3 | |||||||
Current flow rate in l/min on the cooling unit Error output if flow rate < 0.7 l/min | |||||||
Current shielding gas flow rate | |||||||
Total shielding gas consumption | |||||||
Current coolant temperature in °C on the cooling unit Error output if coolant temperature > 70 °C | |||||||
Arc time in h | |||||||
Total welding machine operating hours in h |
The options for displaying the characteristics are displayed.
In the case of the MIG/MAG welding parameters, this function enables additional parameters or settings to be displayed.
Job parameters
Current, voltage, material thickness, power, arc length correction, pulse correction or dynamic correction
VELO
Velo, Welding speed "Velo", Wire retract "Velo"
SFI parameters
SFI, SFI HotStart
Process control
Penetration stabilizer, arc length stabilizer
SynchroPulse settings
SynchroPulse, Delta wire speed, frequency, duty cycle (high), arc correction high, arc correction low
Interval settings
Interval, interval cycles, interval pause time, stitch welding time
Process mix
Upper power duration correction, lower power duration correction, lower power correction
Cycle Step
CMT Cycle Step, cycles (welding spot size), interval pause time, interval cycles
AC settings
AC power balance, AC cycles negative, AC cycles positive
Start/end of welding settings
Starting current, starting arc length correction, starting current time, slope 1, slope 2, final current, end arc length correction, end current time
Spot welding settings
Spot welding time
Gas defaults
Command value gas, gas pre-flow, gas post-flow
TWIN process control
Pulse synchronisation ratio, lead/trail phase shift, trail ignition delay
Additive process control
Power correction, deposition rate stabilizer, deposition rate stabilizer arc-force dynamic
Display additional parameters:
The parameter is displayed in the welding parameters, where it can now also be modified.
This function is used to set the functions and parameters available on a JobMaster welding torch.
Job parameters
Job number, EasyJobs, current, wire speed, voltage, material thickness, power, arc length correction, pulse correction or dynamic correction
Process, characteristic property, trigger mode
VELO
Velo, welding speed "Velo", wire retract "Velo"
SFI parameters
SFI, SFI HotStart
Process control
Interval settings
Process mix
Cycle Step
AC settings
Spot welding time
Gas defaults
General settings
R/L alignment, wire forwards/backwards, gas test
Setting parameters for the JobMaster welding torch:
The parameter is displayed on the JobMaster welding torch, where it can now also be modified.
Depending on the device type, equipment or WeldingPackages available, the display and sequence of system defaults may vary.
The device information is displayed.
A confirmation prompt for the factory settings is displayed.
The process parameters and machine preset values are reset to the factory settings, an overview of the machine presets is displayed.
A confirmation prompt asking whether you really want to reset the website password is displayed.
The website password is reset to the factory setting.
The system overview of the default settings is displayed.
Factory settings
In the default settings, the following special functions can be set under "Mode Setup":
| * | Only if the OPT/i GUN Trigger option is available on the welding machine. |
Special 4-step = Guntrigger
With a JobMaster welding torch and with special 4-step mode selected, this function allows you to change jobs via the torch trigger during welding. Job changing takes place within defined job groups.
A job group is defined by the next non-programmed job.
Example:
Job group 1: Job no. 3 / 4 / 5
Job no. 6 is not assigned ==> End of job group 1
Job group 2: Job no. 7 / 8 / 9
Special JobMaster display = on
The following can now be set and carried out on the JobMaster welding torch:
The parameter "Special JobMaster display" is no longer available as of firmware version 4.0.0.
The corresponding settings can be implemented as follows:
Defaults / Display / JobMaster MIG/MAG display
(see page (→))
Spot welding
2-step = spot welding in 2-step mode:
The spot welding process runs for as long as the torch trigger is kept pressed and ends no later than at the expiry of the spot welding time.
Releasing the torch trigger stops the spot welding process before the spot welding time expires.
4-step = spot welding in 4-step mode:
The spot welding process starts once the torch trigger is pressed and ends no later than at the expiry of the spot welding time.
Press the torch trigger again to stop the spot welding process before the spot welding time expires.
More information on spot welding:
Torch trigger job selection = on
This function allows the user to change to the next job using the torch trigger. Job changing takes place within defined job groups.
Example:
You can switch jobs when the device is in standby or during welding.
Service Connect is a remote maintenance tool for fault diagnosis and troubleshooting, data analysis and process optimisation on the welding machine.
After accepting the terms of use directly on the control panel of the welding machine, a Fronius technician can access the welding machine remotely.
Procedure when a problem arises on the welding machine for which remote diagnostics are requested from Fronius:
End remote operation:
The network settings contain the following entries:
If DHCP is enabled, the IP address, Network mask, Standard gateway, DNS Server 1 and DNS Server 2 network parameters are greyed out and cannot be adjusted.
DHCP is disabled, the network parameters can now be set.
The numerical pad for the selected parameter is displayed.
The value for the network parameter is applied, the network settings are displayed.
The WLAN setup overview is displayed.
Setup country code
Activating WLAN
Adding a network
The available WLAN networks are displayed.
Deleting a network
General
Each Bluetooth device has its own MAC address. This MAC address can be used to assign the devices to specific welding machines, preventing mix-ups.
The welding machine is able to communicate with the following Bluetooth devices:
An active Bluetooth connection is indicated in the status bar on the display when the Bluetooth symbol lights up blue.
For safety reasons, when using Bluetooth devices of the same type, only one device can be actively connected to the welding machine.
It is possible to establish multiple active Bluetooth connections when using Bluetooth devices of different types.
An existing, active Bluetooth connection cannot be interrupted or influenced by another Bluetooth device.
If the connection between a wired or Bluetooth remote control and the welding machine is interrupted during the welding process, the welding process is ended.
Running Bluetooth setup
The overview of the Bluetooth devices is displayed.
Activating or deactivating the welding machine Bluetooth function
Adding a Bluetooth device
Symbols displayed under Info:
Active Bluetooth connection | |
Paired | |
Inactive |
Deleting the Bluetooth device
WeldCube Air is a cloud-based centralised collection of welding data, process metrics and other functionalities.
WeldCube Air is available as an online service.
Knowledge of network technology is required to set up WeldCube Air. Contact your IT department.
Before connecting to WeldCube Air:
Unlock the following ports and domains
https://dps.prod.air.az.weldcube.com/ Port 443 (HTTPS)
https://stpwwcpcprod001.blob.core.windows.net/ Port 443 (HTTPS)
https://stpwwcashared.blob.core.windows.net/ Port 443 (HTTPS)
Port 8883 (MQTT)
Activate the time server
Select Defaults / Display / Date & Time / Automatic Time & Date
With manual time setting, the time deviation must not exceed 2 minutes.
Disable WeldCube Air | |
Unpair device |
Further information on WeldCube Air is available at:
https://www.weldcube.com
Increased connection security
To increase the connection security between WeldCube Premium and the welding system, an existing connection to WeldCube Premium can be confirmed under Client authorization.
Confirm connection:
| Status of the extended connection unknown Extended connection pending Extended connection permitted |
The setting is applied.
Power source = welding machine
The welding machine configuration is displayed.
The text is applied and the welding machine configuration is displayed.
Use "Wire feeder setup" to activate or deactivate potentiometers on a wirefeeder.
Not relevant for TPS 320i C.
The logbook is displayed.
Welding operations, events, errors, warnings or notifications can be displayed using the respective buttons.
The following data is also logged:
| (1) | Welding operation number |
| (2) | Date (ddmmyy) |
| (3) | Time (hhmmss) |
| (4) | Welding duration in s |
| (5) | Welding current in A (average value) |
| (6) | Welding voltage in V (average value) |
| (7) | Wire speed in m/min |
| (8) | Arc energy in kJ (for details see page (→)) |
| (9) | Job no. |
Turn the adjusting dial to scroll through the list.
Pressing the adjusting dial displays details of a logbook entry.
Details for welds:
| (10) | Welding section number |
| (11) | Duration of the welding section in s |
| (12) | Welding current in A (average value) |
| (13) | Welding voltage in V (average value) |
| (14) | Wire speed in m/min |
| (15) | Welding speed (cm/min) |
| (16) | Arc power from real-time values in W (for details see page (→)) |
| (17) | Arc energy in kJ (for details see page (→)) |
| (18) | Job no. |
| (19) | Process |
The settings for limit value monitoring are displayed.
The documentation overview is displayed.
User management is advisable if several users work with the same welding machine.
User management works with different roles and the help of NFC keys.
Users are assigned different roles depending on their level of training or qualifications.
User management
User management encompasses all users registered on the welding machine. Users are assigned different roles depending on their level of training or qualifications.
NFC card
An NFC card or an NFC key ring is assigned to a certain user who is registered on the welding machine.
NFC cards and NFC key rings will both be referred to under the general term NFC key for the purpose of these Operating Instructions.
IMPORTANT! Each user should be assigned their own NFC key.
Roles
Roles are used for managing registered users (= user management). Users' access rights and permitted activities are defined by their roles.
Under Defaults / Administration / User management, 2 roles are predefined as factory settings:
Administrator
with full rights and options
The "Administrator" role cannot be deleted, renamed or edited.
The "Administrator" role is assigned the pre-defined "Admin" user, which cannot be deleted. The "Admin" user can assign names, languages, units, web passwords and NFC keys.
As soon as "Admin" assigns an NFC key, user management is activated.
Locked
Factory-set with access to welding processes, but not to process parameters and defaults
The "Locked" role
The "Locked" role cannot have any NFC keys assigned to it.
If no NFC key is assigned to the pre-defined user "Admin", every NFC key will work to lock and unlock the welding machine (no user management, see "Locking and unlocking the welding machine using the NFC key", page (→)).
User management consists of the following sections:
Please proceed systematically when creating roles and NFC keys.
Fronius recommends creating one or two administrator keys. In the worst case, a welding machine can no longer be operated without administrator rights.
Procedure
Losing an NFC administrator key can lead to the welding machine becoming unusable, depending on the settings. Keep one of the two NFC administrator keys in a safe place.
Procedure
Once an NFC key is assigned to the pre-defined "Admin" user under Defaults / Administration / User management / Administrator, user management becomes active.
User management is displayed, "Administrator" is selected.
The information to be transferred to the NFC card is displayed.
A note concerning the activated user management is displayed.
Under Admin / NFC card, the number of the assigned NFC key is displayed.
To create a second administrator key:
User management appears.
The functions that can be executed within a role are displayed.
Symbols:
... hidden | |
... read only | |
... read and write |
For privacy reasons, only person identity numbers and not full names should be entered when creating users.
The role will open, the functions can be adjusted:
If no user is assigned to a role, then the it is possible to start editing the role by pressing the adjusting dial.
The role and all assigned users will be deleted.
The users assigned to the role are displayed.
The user is deleted.
A confirmation prompt asking whether you want to delete or replace the NFC card is displayed.
If the NFC card is deleted by the predefined "Admin" user, user management is deactivated.
User management is deactivated, the welding machine is locked.
The welding machine can be locked and unlocked again with any NFC key (see page (→)).
Procedure when
CENTRUM is a piece of software for the central management of users. Detailed information is available in the CENTRUM Operating Instructions (42,0426,0338,xx).
The CENTRUM server can also be activated directly on the welding machine, as follows:
The Central User Management Server is displayed.
The welding machines have their own website: SmartManager.
As soon as the welding machine is connected to a computer using a network cable, or is on a network, the welding machine's SmartManager can be retrieved using the welding machine's IP address.
At least IE 10 or a similar modern browser is required to access SmartManager.
The entries displayed on SmartManager may vary depending on system configuration, software upgrades and available options.
Examples of entries displayed:
| * | Power source = welding machine |
| ** | Depending on the available robot interface, the name of the interface will be displayed as an entry on the website. |
Factory settings for user name and password
The SmartManager of the welding machine is displayed.
There are two auxiliary functions when logging on to SmartManager:
Start unlocking function?
An unintentionally locked welding machine can be unlocked with this function and all its functions made available.
A TXT file with the following name will be saved to the computer's "Downloads" folder:
unlock_SN[serial number]_YYYY_MM_DD_hhmmss.txt
Fronius will respond to each e-mail with a one-time unlocking file named as follows:
response_SN[serial number]_YYYY_MM_DD_hhmmss.txt
This will work just once to unlock the welding machine.
Forgotten password?
After clicking "Forgotten password?" a notice will be displayed explaining that the password can be reset on the welding machine (see also "Resetting the website password", page (→)).
By clicking this symbol
Changing the password for the SmartManager:
| * | A password must meet the following criteria:
Clicking on this symbol expands the display of characteristics, material specifications and certain welding parameters for the welding machine's SmartManager.
The settings depend on which user is currently logged on.
The languages available for SmartManager can be displayed by clicking on the language abbreviation.
To change the language, click on the one you would like.
The current status of the welding machine is shown between the Fronius logo and displayed welding machine.
Attention / Warning |
Fault on welding machine * |
Welding machine is welding |
The welding machine is ready (online) |
The welding machine is not ready (offline) |
| * | In the event of an error, a red error line complete with error number will be displayed above the line with the Fronius logo. Clicking on the error line will reveal a description of the error. |
A click on the Fronius logo opens the homepage of Fronius: www.fronius.com.
The welding system's current data is displayed.
The system data displayed will vary depending on the welding process, equipment and existing WeldingPackages.
e.g. system data for MIG/MAG:
The last 100 entries in the logbook are shown in the Documentation entry. These logbook entries can be welding operations, errors, warnings, notifications and events.
Press the "Time filter" button to restrict the data to a specific period of time. To do so, the date (yyyy mm dd) and time (hh mm) are entered in the format from – to in each case.
A blank filter loads the latest welding operations again.
The option to show welding operations, errors, warnings, notifications and events can be deactivated.
The following data is displayed:
| (2) | Start time (date and time) |
| (3) | Welding duration in s |
| (4) | Welding current in A (average value) |
| (5) | Welding voltage in V (average value) |
| (6) | Wire speed in m/min |
| (7) | IP - arc power in W (from real-time values in accordance with ISO/TR 18491) |
| (8) | IE - arc energy in kJ (in total across the entire weld in accordance with ISO/TR 18491) |
Robot speed and jobs are also displayed if present in the system.
Clicking on a logbook entry will display details.
Details for welds:
Section no.
| (9) | Duration of the welding section in s |
| (10) | Welding current in A (average value) |
| (11) | Welding voltage in V (average value) |
| (12) | Wire speed in m/min |
| (13) | Welding speed (cm/min) |
| (14) | Arc power from real-time values in W (for details see page (→)) |
| (15) | Arc energy in kJ (for details see page (→)) |
| (16) | Job no. |
| (17) | Process |
Further values can be displayed by clicking on the "Insert column" button:
If the OPT/i documentation option is available on the welding machine, individual welding sections can also be displayed.
This documentation can be exported in the desired format using the "PDF" and "CSV" buttons.
In order to create CSV exports, the OPT/i documentation option must be available on the welding machine.
Details for welds:
Section no.
| (16) | Job no. |
| (17) | Process |
In the basic settings, the sampling rate for documentation can be activated and set.
In addition, motor force M1 - M3, gas flow actual value and welding speed can be activated for documentation.
If the OPT/i Jobs option is available on the welding machine, the following is possible in the Job data entry:
| * | Viewing and exporting as PDF also works when the OPT/i Jobs option is not available on the welding machine. |
The job overview lists all jobs stored in the welding system.
Clicking on a job displays the data and parameters stored for this job.
Job data and parameters can only be viewed in the job overview. The column width for parameters and values can be easily dragged and adjusted with the mouse pointer.
Other jobs can easily be added to the list with the data listed by clicking on the "Add column" button.
All added jobs are compared to the job that is currently selected.
Existing welding system jobs can be optimised, provided the OPT/i Jobs option is present on the welding machine.
As an aid when editing a job, other jobs can be added with ease to the list with the data displayed by clicking on "Add job".
Creating a new job
This function allows jobs stored externally to be transferred to the welding system, provided the OPT/i Jobs option is available on the welding machine.
This function allows jobs from the welding machine to be stored externally, provided the OPT/i Jobs option is available on the welding machine.
The jobs are exported as an XML file into the computer's Download folder.
Under "Job overview" and "Edit job", existing jobs in the welding system can be exported as PDF or CSV files.
For CSV exports, the OPT/i Jobs option must be available on the welding machine.
The PDF or CSV settings are displayed.
A PDF or CSV file containing the selected jobs is created and saved according to the settings of the browser in question.
General process parameters and process parameters for welding machine components and monitoring can be viewed and changed under Process parameters.
Changing process parameters
The welding machine configuration can be viewed and changed under name & location.
Welding parameters and special functions for the welding machine and JobMaster welding torch can be set under Parameter display.
The selected parameters / functions are:
The date & time can be set automatically or manually.
The following parameters can be set under Network settings:
Management
WLAN
WeldCube Air
Connect the welding machine to WeldCubeAir
(alternatively, click on the cloud icons in the upper right corner)
Only displayed if the OPT/i MQTT option is installed on the welding machine.
MQTT - Message Queuing Telemetry Transport
(standardised data interface protocol)
Supported functions:
Defining MQTT settings
Only displayed if the OPT/i OPC UA option is installed on the welding machine.
OPC-UA - Open Platform Communications - Unified Architecture
Defining OPC UA settings
In the backup & restore entry
Starting backup
Searching for a restore file
If you have any questions about the configuration, contact your network administrator.
In the user management entry
User management is created on a welding machine and can then be saved with the export/import function and transferred to another welding machine.
Existing users can be viewed, changed and deleted; new users can be created.
Viewing/changing a user:
Deleting a user:
Creating a user:
Existing user roles can be viewed, changed and deleted, new user roles can be created
Viewing/changing a user role:
The "Administrator" role cannot be changed.
Deleting a user role:
The "Administrator" and "Locked" roles cannot be deleted.
Creating a user role:
Exporting users and user roles from a welding machine
The user management data from the welding machine will be saved to the "Downloads" folder on the computer.
File format: userbackup_SNxxxxxxxx_YYYY_MM_DD_hhmmss.user
SN = Serial number, YYYY = Year, MM = Month, DD = Day
hh = hour, mm = minute, ss = second
Importing users and user roles to a welding machine
The user management data will be saved to the welding machine.
For activating a CENTRUM server
(CENTRUM = Central User Management)
In the overview entry, welding system components and options are displayed with all available information, e.g. firmware version, item number, serial number, production date, etc.
Clicking on the button "Expand all groups" displays further details for the individual system components.
Welding machine example:
Clicking on the button "Reduce all groups" hides the details for the system components.
Click the "Export component overview as ..." button to create an XML file of the system component details. This XML file can either be opened or saved.
The welding machine firmware can be updated in the "Update" entry.
The current version of the firmware on the welding machine is displayed.
Update welding machine firmware:
Firmware link: |
Once the update has been successfully completed, the welding machine may need to be restarted.
When an update has been completed successfully, a confirmation to this effect is displayed.
Firmware link: |
SmartManager is not available during the restart.
After the restart, SmartManager may not be available any more.
If you select "No", the new software functions are activated when you next switch the device on/off.
Clicking on the link displays information on open source licensing.
The mobile application Fronius WeldConnect can also be called up in the "Update" entry. |
The following functions can be performed with WeldConnect:
Fronius WeldConnect is available in the following forms:
Further information on Fronius WeldConnect is available at:
The following data can be displayed under Function Packages:
In the Characteristics overview entry:
You can search for, sort and filter the displayed characteristics at any time.
The following information is displayed for the characteristics:
To sort the characteristics in ascending or descending order, click on the arrow next to the respective information.
The column widths can be easily dragged and adjusted with the cursor.
Clicking on the "Show filter" symbol displays the possible filter criteria. With the exception of "ID" and "Replaced by", the characteristics can be filtered by all information.
First selection box = select all
To hide the filter criteria, click on the "Hide filter" symbol.
In the Screenshot entry, a digital image of the welding machine display can be created at any time, irrespective of the navigation or set values.
Different functions are available for saving the screenshot depending on the browser used; the display may vary.
The welding machines are equipped with an intelligent safety system, meaning it has been possible to dispense with nearly all fuses. After a possible malfunction has been remedied, the welding machine can be used again as normal.
Possible malfunctions, warning notices or status codes are shown on the display as plain text dialogues.
Danger from electric current.
Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
Secure all the devices and components involved to prevent unintentional restarting.
Danger from inadequate ground conductor connections.
This can result in injury and damage to property.
The housing screws provide a suitable ground conductor connection for earthing the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
"Current limit" is a safety function for MIG/MAG welding, whereby
If the welding power is too high, the arc gets smaller and smaller and may be extinguished. To stop the arc from being extinguished, the welding machine reduces the wire speed and therefore the welding power.
A corresponding message appears in the status bar on the display.
Corrective measures
| Cause: | There is a break in the mains lead; the mains plug is not plugged in |
| Remedy: | Check the mains lead, ensure that the mains plug is plugged in |
| Cause: | Mains socket or mains plug faulty |
| Remedy: | Replace faulty parts |
| Cause: | Mains fuse protection |
| Remedy: | Change the mains fuse protection |
| Cause: | Short circuit on the 24 V supply of SpeedNet connection socket or external sensor |
| Remedy: | Unplug connected components |
| Cause: | Overload; the duty cycle has been exceeded |
| Remedy: | Check duty cycle |
| Cause: | Thermostatic automatic circuit breaker has tripped |
| Remedy: | Wait until the welding machine automatically comes back on after the end of the cooling phase |
| Cause: | Limited supply of cooling air |
| Remedy: | Ensure accessibility to cooling air ducts |
| Cause: | Faulty fan in welding system |
| Remedy: | Contact After-Sales Service |
| Cause: | Grounding (earthing) connection is incorrect |
| Remedy: | Check the grounding (earthing) connection for correct polarity |
| Cause: | There is a break in the power cable in the welding torch |
| Remedy: | Replace welding torch |
| Cause: | The control plug is not plugged in |
| Remedy: | Plug in the control plug |
| Cause: | Welding torch or welding torch control line is faulty |
| Cause: | The interconnecting hosepack is defective or not connected properly (not for welding machines with integrated wire drive) |
| Remedy: | Check the interconnecting hosepack |
| Cause: | Gas cylinder is empty |
| Remedy: | Change the gas cylinder |
| Cause: | The gas pressure regulator is faulty |
| Remedy: | Replace the gas pressure regulator |
| Cause: | Gas hose is not fitted or is damaged |
| Remedy: | Fit or change the gas hose |
| Cause: | Welding torch is faulty |
| Remedy: | Change the welding torch |
| Cause: | Gas solenoid valve is faulty |
| Cause: | Incorrect welding and/or correction parameters |
| Remedy: | Check the settings |
| Cause: | Poor grounding (earthing) connection |
| Remedy: | Ensure good contact to workpiece |
| Cause: | Multiple welding machines are welding one component |
| Remedy: | Increase the distance between the hosepacks and the return lead cables; Do not use a common earth. |
| Cause: | Inadequate or no shielding gas |
| Remedy: | Check the pressure regulator, gas hose, gas solenoid valve, torch gas connection, etc. |
| Cause: | Welding torch is leaking |
| Remedy: | Change welding torch |
| Cause: | Wrong contact tip, or contact tip is worn out |
| Remedy: | Replace contact tip |
| Cause: | Wrong wire alloy or wrong wire diameter |
| Remedy: | Check the wire electrode that has been inserted |
| Remedy: | Check weldability of the base material |
| Cause: | The shielding gas is not suitable for this wire alloy |
| Remedy: | Use the correct shielding gas |
| Cause: | Shielding gas, wirefeeder, welding torch or workpiece is contaminated or magnetically charged |
| Remedy: | Perform R/L alignment; adjust arc length; check whether shielding gas, wirefeed, welding torch position or workpiece is contaminated or magnetically charged |
| Cause: | Braking force has been set too high |
| Remedy: | Loosen the brake |
| Cause: | Hole in the contact tip is too narrow |
| Remedy: | Use a suitable contact tip |
| Cause: | Faulty inner liner in welding torch |
| Remedy: | Check the inner liner for kinks, dirt, etc. and replace if necessary |
| Cause: | The wirefeeder rollers are not suitable for the wire electrode being used |
| Remedy: | Use suitable feed rollers |
| Cause: | Feed rollers have the wrong contact pressure |
| Remedy: | Optimise the contact pressure |
| Cause: | Incorrect arrangement of welding torch hosepack |
| Remedy: | Arrange the welding torch hosepack in as straight a line as possible, avoiding bends |
| Cause: | Welding torch is inadequately dimensioned |
| Remedy: | Observe the duty cycle and loading limits |
| Cause: | Only on water-cooled systems: inadequate coolant flow |
| Remedy: | Check coolant level, coolant flow, for coolant contamination, etc. For further information refer to the cooling unit operating instructions |
| Cause: | The distance from the workpiece is too small |
| Remedy: | Increase stickout |
Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the device remains in a usable condition for many years.
Danger from hot components and parts.
This can cause burns.
Allow hot components and parts such as welding torches to cool down before working on them.
It is impossible to guarantee that non-Fronius parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements.
Air inlets and outlets must never be covered, not even partially.
Danger due to the effect of compressed air.
Do not clean electronic components with compressed air at close distance.
The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
The manufacturer recommends that the welding machines be calibrated at the same 12-monthly interval.
A safety inspection should be carried out by a qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on the safety inspection and calibration can be obtained from your Fronius branch or your Fronius partner. They will provide you with any documents you may require, on request.
IMPORTANT! To update the firmware, you need a PC or laptop that is connected to the welding machine via an Ethernet network.
Used equipment and batteries must be returned to the distributor or an authorised local collection system. Do not dispose of batteries in domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
Arrange for the safe collection and proper disposal of damaged, leaking or decommissioned batteries by a battery recycling company or the Fronius Service Partner.
It should also be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances, such as heavy metals or electrolytes, which can contaminate the soil, water and air.
This ensures environmental protection and the sustainable use of natural resources.Packaging materialsAverage wire electrode consumption at a wire speed of 5 m/min | |||
| Wire electrode diameter | ||
| 1.0 mm | 1.2 mm | 1.6 mm |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminium wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminium wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
If the ambient temperature is higher, either the ED or output must be reduced accordingly.
Example: Welding at 150 A at 60% ED
If the device is to be continuously operated without stopping:
For devices designed for special voltages, the technical data on the rating plate applies.
For all machines with a permitted mains voltage of up to 460 V: The standard mains plug allows the user to operate with a mains voltage of up to 400 V. For mains voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
Ambient air temperature range: | |
during operation | + -10 °C to + 40 °C |
During transport and storage: | -20 °C to +55 °C |
Relative humidity of the ambient air: | |
at 40 °C / 104 °F | max. 50% |
at 20 °C / 68 °F | max. 90% |
Netzspannung (U1) | 3 x 400 V |
Max. Effektiv-Primärstrom (I1eff) | 12,5 A |
Max. Primärstrom (I1max) | 19,7 A |
Netzabsicherung | 35 A träge |
Netzspannungs-Toleranz | -15 / +15 % |
Netzfrequenz | 50 / 60 Hz |
Cos Phi (1) | 0,99 |
Max. zulässige Netzimpedanz Zmax am PCC1) | 96 mOhm |
Empfohlener Fehlerstrom-Schutzschalter | Type B |
Schweißstrom-Bereich (I2) |
MIG / MAG | 3 - 320 A |
WIG | 3 - 320 A |
Stabelektrode | 10 - 320 A |
Schweißstrom bei | 40 % / 320 A |
Ausgangsspannungs-Bereich laut Norm-Kennlinie (U2) | |
MIG / MAG | 14,2 - 30,0 V |
WIG | 10,1 - 22,8 V |
Stabelektrode | 20,4 - 32,8 V |
Leerlauf-Spannung | 71 V |
Schutzart | IP 23 |
Kühlart | AF |
Überspannungs-Kategorie | III |
Verschmutzungsgrad nach Norm IEC60664 | 3 |
EMV Emissionsklasse | A 2) |
Sicherheitskennzeichnung | S, CE |
Abmessungen l x b x h | 706 x 300 x 510 mm |
Gewicht | 35,8 kg / 78,9 lb. |
Max. Geräusch-Emission (LWA) | 69 dB (A) |
Max. Schutzgas-Druck | 7 bar / 101 psi |
Kühlmittel | Original Fronius |
Drahtgeschwindigkeit | 1 - 25 m/min / 40 - 980 ipm |
Drahtantrieb | 4-Rollen Antrieb |
Drahtdurchmesser | 0,8 - 1,6 mm / 0,03 - 0,06 in. |
Drahtspulen-Durchmesser | max. 300 mm / max. 11,8 in. |
Drahtspulen-Gewicht | max. 19,0 kg / max. 41,9 lb. |
Leistungsaufnahme im Leerlaufzustand bei 400 V | 34,7 W |
Energieeffizienz des Schweißgeräts | 89 % |
Die Drahtvorschub-Einheit der TPS 320i C ist im Schweißgerät integriert.
| 1) | Schnittstelle zum öffentlichen Stromnetz mit 230 / 400 V und 50 Hz |
| 2) | Ein Gerät der Emissionsklasse A ist nicht für die Verwendung in Wohngebieten vorgesehen, in denen die elektrische Versorgung über ein öffentliches Niederspannungsnetz erfolgt. Die elektromagnetische Verträglichkeit kann durch leitungsgeführte oder abgestrahlte Funkfrequenzen beeinflusst werden. |
Mains voltage (U1) | 3 x 380 / 400 / 460 V |
Max. effective primary current (I1eff) |
Max. primary current (I1max) |
Mains fuse protection | 35 A slow-blow |
Mains voltage tolerance | -10 / +15% |
Grid frequency | 50/60 Hz |
Cos phi (1) | 0.99 |
Max. permitted mains impedance Zmax at PCC1) | 96 mOhm |
Recommended residual current circuit breaker | Type B |
Welding current range (I2) |
Welding current at | 40% / 320 A |
Output voltage range according to standard characteristic (U2) |
Open circuit voltage | 82 V |
Protection class | IP 23 |
Type of cooling | AF |
Overvoltage category | III |
Pollution degree according to IEC60664 | 3 |
EMC emission class | A 2) |
Safety symbols | S, CE, CSA |
Dimensions L x W x H | 706 x 300 x 510 mm |
Weight | 34.7 kg / 78.9 lb. |
Max. noise emission (LWA) | 69 dB (A) |
Max. shielding gas pressure | 7 bar / 101 psi |
Coolant | Original Fronius |
Wire speed | 1-25 m/min / 40-980 ipm |
Wire drive | 4-roller drive |
Wire diameter | 0.8-1.6 mm / 0.03-0.06 in. |
Wirespool diameter | max. 300 mm / max. 11.8 in. |
Wirespool weight | max. 19.0 kg / max. 41.9 lb. |
Idle state power consumption at 400 V | 34.7 W |
Welding machine efficiency | 89% |
The wirefeeder for the TPS 320i C /nc is integrated in the welding machine.
| 1) | Interface to a 230/400 V and 50 Hz public grid |
| 2) | An emission class A device is not designed for use in residential areas supplied with power from a public low-voltage grid. The electromagnetic compatibility can be influenced by conducted or radiated radio frequencies. |
Mains voltage (U1) | 3 x 460 / 575 V |
Mains fuse protection | 20 A slow-blow |
Mains voltage tolerance | -10 / +10% |
Open circuit voltage | 85 V |
Safety symbols | S, CSA |
Weight | 33.11 kg / 73.0 lb. |
The wirefeeder for the TPS 320i C is integrated in the welding machine.
Mains voltage (U1) | 3 x 200 / 230 / 380 / 400 / 460 V |
Mains voltage tolerance | -10 / +15 % |
Welding current at
U1 = 380–460 V |
40% / 320 A |
Wire speed | 1–25 m/min / 40–980 ipm |
Wire diameter | 0.8–1.6 mm / 0.03–0.06 in. |
Wire spool diameter | max. 300 mm / max. 11.8 in. |
Wire spool weight | max. 19.0 kg / max. 41.9 lb. |
The wirefeeder for the TPS 320i C /nc MV is integrated in the welding machine.
Conformity with Directive 2014/53 / EU - Radio Equipment Directive (RED)
The following table contains the frequency ranges and maximum HF transmission power used by Fronius wireless products sold in the EU in accordance with Article 10.8 (a) and 10.8 (b) of the RED.
WiFi 2.4 GHz |
Frequency range | 2412–2462 MHz |
Channels used | Channel: 1–11 b, g, n20, ax 20 |
Output | <20 dBm |
Modulation | 802.11b: DSSS 802.11g: OFDM 802.11n: OFDM 802.11ax: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM (up to 143.4 Mbit/s for 1 spatial stream and up to 286.8 Mbit/s for 2 spatial streams) |
Bluetooth 5.2LE 2.4 GHz |
Frequency range | 2402–2482 MHz |
Channels used | 0–39 |
Output | <7 dBm |
Modulation | GFSK |
Data rates | 125 kbps, 500 kbps, 1 Mbps, 2 Mbps |
RFID |
Frequency range | 13.56 MHz |
Channels used | |
Field strength of the transmitter at 10 m distance | -8.8 dBµA/m |
Modulation | Reader/Writer, Card Emulation, Peer to Peer Modes |
Protocol standards: | ISO 14443A/B, ISO15693, ISO18092, |
Data rate: | 848 kbps |
