LogoRobacta Reamer V 70 Han12P
  • en
    • Kontakt
    • Impressum
    • AGB
    • Datenschutz
    • Cookie Policy
    • 013-28052025
    • Safety rules
      • General
      • Proper use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Specific hazards
      • Protecting yourself and others
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Copyright
    • General
      • General
        • Principle
        • Functionality of the cleaning device
        • Application areas
        • Warning notices on the cleaning device
      • Transport
        • Transport means
        • Transport notices on the packaging
      • Scope of supply and options
        • Scope of supply
        • Available options
    • Controls, connections and mechanical components
      • Safety
        • Safety
        • Control elements, connections and mechanical components
      • Harting Han12P connecting plug (X1) pin assignment for robot control
        • General
    • Installation and commissioning
      • Safety
        • Safety
        • Ensuring that the cleaning device is depressurised
      • Before commissioning
        • Operators, maintenance personnel
        • Setup regulations
        • Compressed air supply specifications
        • Measures for the safe operation of the device with untrained personnel
      • Screwing the cleaning device to the underlying surface
        • Screwing the cleaning device and installation stand to the underlying surface
      • Torch cleaning position
        • Welding torch cleaning position
      • Adjust gas nozzle clamping device
        • Adjusting the gas nozzle clamping device
      • Fitting the cleaning cutter
      • Adjusting the position of the cleaning motor
      • Configuring the spray device
      • Installing the electrically controlled wire cutter (optional)
        • How the electrically-controlled wire cutter works
        • Maximum wire diameter
      • To establish the compressed air supply:
        • Establishing the compressed air supply for the cleaning device, function of the compressed air relief valve
      • Starting up the parting agent nebuliser
        • Filling the parting agent container (1 litre) and connecting it to the cleaning device
        • Connecting the parting agent container (10 litres) to the cleaning device
        • Adjusting the parting agent nebuliser spray amount
      • Manually checking the cleaning device functions
        • Safety
      • Starting up the cleaning device
        • Prerequisites for start-up
        • Start-up
      • Cleaning programme
        • Safety
        • Cleaning program sequence
      • Signal waveform for cleaning
        • Signal inputs
        • Signal outputs
        • Signal waveform optional wire cutter (input)
    • Care, maintenance and disposal
      • Safety
        • Safety
        • General
        • Before each start-up
        • Daily
        • Weekly
        • Every 6 months
        • As necessary
        • Disposal
    • Troubleshooting
      • Safety
        • Safety
      • Troubleshooting
        • Errors in program sequence
    • Technical data
      • Technical data
        • Robacta Reamer V 70 Han12P
    • Appendix
      • Robacta Reamer V 70 Han12P Circuit Diagram
      • Robacta Reamer V 70 Han12P pneumatic diagram
      • Declaration of conformity
    Robacta Reamer V 70 Han12P Operating Instructions
    Bedienelemente und Anschlüsse
    Steckerbelegung (Anschluss für die Roboter-Steuerung)
    Reinigungsposition des Schweißbrenners
    Spannvorrichtung Gasdüse einstellen
    Reinigungsfräser montieren
    Position des Reinigungsmotors einstellen
    Programmablauf der Reinigung
    Ersatzteile
    Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of automated welding, and
    • read and carefully follow these operating instructions as well as the operating instructions for all system components.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before commissioning the device, rectify any faults that could compromise safety.
    1. Safety rules
    Proper use
    The cleaning device is to be used exclusively for the mechanical cleaning of Fronius robot welding torches in automated operation. Any other or additional use is deemed improper.
    Proper use includes:
    • carefully reading these operating instructions
    • following all the instructions and safety rules in these operating instructions
    • performing all stipulated inspection and maintenance work
    The device is designed for operation in industry and commercial use.
    1. Safety rules
    Ambient temperature range:
    • during operation: 0 °C to + 40 °C (32 °F to 104 °F)
    • during transport and storage: -25 °C to +55 °C (-13 °F to 131 °F)
    Relative humidity:
    • up to 50 % at 40 °C (104 °F)
    • up to 90 % at 20 °C (68 °F)
    Keep ambient air free from dust, acids, corrosive gases and substances, etc.
    Can be used at altitudes of up to 2000 m (6500 ft)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so undertake:
    • to observe the basic instructions regarding safety at work and accident prevention,
    • to read these operating instructions, especially the "Safety rules" section and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Specific hazards
    Stay out of the working area of the robot.
    The device must be incorporated into a higher-level safety system within a secured area.
    If this area has to be accessed when setup and maintenance work is carried out, make sure that
    • the entire system is switched off for the duration of the work in this area
    • and that it is prevented from starting up accidentally, e.g. as the result of a control fault.
    If untrained operators have access to the device, its compressed air supply must be disconnected for the duration of work in accordance with "Performance Level d" of the ISO 13849-1 standard.
    In addition to these Operating Instructions, the safety rules issued by the robot manufacturer must also be observed.
    Keep your body, especially your hands, face, hair, clothing and all tools away from moving parts, such as:
    • rotating cleaning cutter
    • upwards/downwards travelling cleaning motor
    • extending/retracting gas nozzle clamping device
    • wire cutter
    Do not touch cleaning cutters immediately after use - risk of burns. Observe the special safety rules in the Operating Instructions for handling cleaning cutters.
    Protect hands, face and eyes against flying parts (shavings, etc.) and compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Covers may only be opened/removed for the duration of any maintenance, installation or repair work.
    During operation
    • Ensure that all covers are closed and fitted properly
    • Keep all covers closed
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks. In addition to these Operating Instructions, the safety rules of the manufacturer of the entire welding system must also be observed.
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers and health risks (crushing from mechanically-powered parts, injury from cleaning cutter, flying shavings and similar matter, escaping compressed air/parting agent mixture, flying sparks, dazzling by arc, inhaling of harmful welding fumes, noise, possible danger from mains or welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check for possible problems, and check and evaluate neighbouring devices' resistance to interference according to national and international requirements:
    • Safety devices
    • Power, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite correct mains connection, additional measures are necessary (e.g. use a suitable line filter).
    2. Control lines
      • must be kept as short as possible
      • must run close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Shield, if necessary
      • Shield off other nearby devices
      • Shield off entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    A device toppling over could easily kill someone. Place the device horizontally on a level, firm and solid surface and anchor it securely to prevent it toppling over.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    After transporting the device, it must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device if all safety devices are fully functional. If the safety devices are not fully functional, there is a risk of
    • damage to the device and other material assets belonging to the operator,
    • Only use suitable original parting agent from the manufacturer.
    • Observe the information on the parting agent safety data sheet when handling parting agent. The parting agent safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    • Do not mix the manufacturer's parting agent with other parting agents.
    • If damage results from using a different parting agent, the manufacturer accepts no liability. In addition, no warranty claims will be entertained.
    • Used parting agent must be disposed of properly in accordance with the relevant national and international regulations.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device is performed at least once every 12 months.
    A safety inspection should be carried out by a qualified electrician
    • after any changes are made
    • after any additional parts are installed, or after any conversions
    • after repair, care and maintenance has been carried out
    • at least every twelve months.
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on safety inspection and calibration can be obtained from your service centre. They will provide you on request with any documents you may require.
    1. Safety rules
    Disposal
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark satisfy the essential requirements of the applicable directives (e.g. low-voltage and electromagnetic compatibility directives, machinery directive).
    Devices with the CSA test mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Copyright
    General
    General
    Principle
    The cleaning device is used to automatically clean MIG/MAG welding torches. This cleaning device allows you to thoroughly clean the inside and front of the gas nozzle on a wide range of welding torch shapes. The result is a significant increase in the service life of wearing parts. At the same time, evenly applying parting agent prevents the build-up of dirt.
    1. General
    General
    Principle
    1. General
    2. General
    Principle
    1. General
    2. General
    • The gas nozzle clamping device on the front of the cleaning device holds the gas nozzle in place during cleaning.
    • A cleaning cutter is used to clean the nozzle.
    • After the cleaning process, a parting agent is applied to the inside and front of the gas nozzle through the parting-agent injection nozzle.
    1. General
    2. General
    Application areas
    The cleaning device is exclusively intended for use in robot and other automated applications, and can be used for a wide range of materials.
    The main application areas are:
    • Automotive and component supply industry
    • Equipment construction
    • Chemical plant construction
    • Machine and tracked vehicle manufacturing
    • Construction machinery and special vehicles
    1. General
    2. General
    The cleaning device is fitted with warning notices and a rating plate. The warning notices and rating plate must not be removed or painted over.
    WARNING! Risk of serious injury from:
    • Mechanically powered components
    • Compressed air/parting agent mixture escaping from the parting-agent injection nozzle
    • Flying parts (shavings, etc.)
    Keep the device free from current and pressure during maintenance and servicing.
    • All the Operating Instructions for the system components, especially the safety rules
    For indoor use only
    Wear eye protection
    Warning of automatic start-up of the device
    1. General
    Transport
    Transport means
    The device is to be transported by the following means:
    • On pallets using a counterbalanced lift truck
    • On pallets using a lift truck
    • Manually
    WARNING!
    Danger from falling devices and objects.
    Secure the device to prevent it from falling over while being transporting on a counterbalanced lift truck or lift truck.
    Avoid sudden changes in direction, braking or acceleration.
    1. General
    2. Transport
    Transport means
    • Manually
    WARNING!
    1. General
    2. Transport
    CAUTION!
    Danger due to improper transport.
    Observe the transport notices on the device packaging.
    1. General
    Scope of supply
    (1)
    Robacta Reamer V 70 Han12P cleaning device
    (2)
    Leather seal for the parting agent spray device
    (3)
    Spatter tray retainer
    (4)
    Spatter tray
    (5)
    Tightening key for cleaning motor
    (6)
    Compressed air relief valve
    Included in scope of supply, but not shown:
    • Harting Han12P connecting plug (X1) without cable
    • Operating instructions
    • Fixings for assembling the cleaning device:
      • 4 screws
      • 4 washers
      • 4 lock washers
      • 4 nuts
    The "Robacta Reamer" parting agent (item number 42,0411,8042) and the cleaning cutter are not included in the scope of supply.
    1. General
    2. Scope of supply and options
    Scope of supply
    (1)
    (2)
    (3)
    (4)
    Spatter tray
    (5)
    (6)
      • 4 screws
      • 4 washers
      • 4 lock washers
      • 4 nuts
    1. General
    Available options
    The following options are available for the cleaning device:
    • Installation stand
    • Wire cutter
    • Fill-level control sensor
    Safety
    Safety
    Observe the following safety rules for all work described in the "Control elements, connections and mechanical components" chapter.
    WARNING!
    1. Controls, connections and mechanical components
    Safety
    Safety
    WARNING!
    2. Safety
    Safety
    WARNING!
    Side view
    Front view
    No.Function
    (1)
    Parting agent adjuster
    For adjusting the amount of parting agent sprayed inside the gas nozzle
    (2)
    Compressed air connection
    For a dry compressed air supply at 6 bar (86.99 psi)
    Thread identification compressed air connection: G ¼ ″
    (3)
    Harting Han12P connection socket (X1)
    For a + 24 V DC supply
    CAUTION!
    Danger from overcurrent.
    Damage to the Harting Han12P (X1) connection supply may result.
    Secure supply against overcurrent with a 500 mA slow-blow fuse.
    (4)
    Parting agent spatter tray
    (5)
    Parting agent container
    (6)
    Gas nozzle clamping device
    (7)
    Parting agent spray device
    Includes the parting-agent injection nozzle
    Ensures that the parting agent is only applied to the inside and front of the gas nozzle
    (8)
    Parting-agent injection nozzle
    Applies the parting agent to the inside and front of the gas nozzle
    (9)
    Cleaning cutter
    (10)
    Protective covering
    (11)
    "Start cleaning" screw
    Manually checks the following:
    • Function of the gas nozzle clamping device (clamping device piston extends)
    • The insertion depth of the cleaning cutter in the gas nozzle (lifting device moves the cleaning motor upwards)
    • Function of the cleaning motor (cleaning motor starts)
    (12)
    "Spray in parting agent" screw
    For manually checking the spray device (compressed air or compressed air/parting agent mixture is sprayed out of the parting-agent injection nozzle)
    (13)
    Compressed air connection for the wire cutter option
    (14)
    Electrical connection for the wire cutter option
    (15)
    Cleaning motor
    Drives the cleaning cutter
    (16)
    Lifting device
    Lifts the cleaning motor and the cleaning cutter when cleaning the inside of the gas nozzle
    2. Controls, connections and mechanical components
    Side view
    Front view
    No.Function
    (1)
    (2)
    (3)
    CAUTION!
    (4)
    (5)
    (6)
    (7)
    (8)
    (9)
    Cleaning cutter
    (10)
    Protective covering
    (11)
    (12)
    (13)
    (14)
    (15)
    Cleaning motor
    (16)
    Lifting device
    General
    CAUTION!
    CAUTION!
    Danger due to long control line.
    Interference in signal transmission may result.
    Keep the control line between the robot control and the cleaning device as short as possible.
    The Harting Han12P connecting plug (X1) for connecting the cleaning device to the robot control is included in the scope of supply. The cable harness must be adapted to the connection technology on the robot control.
    2. Harting Han12P connecting plug (X1) pin assignment for robot control
    General
    CAUTION!
    CAUTION!
    Harting Han12P connecting plug (X1) pin assignment - cable-end view
    Input and output signals:
    1. Start cleaning input signal (clamp gas nozzle, cleaning motor on, cleaning motor off)
    2. Spray in parting agent input signal
    3. GND
    4. + 24 V DC
    5. Gas nozzle free output signal
    6. Cleaning motor UP output signal
    7. Not assigned
    8. Not assigned
    9. Not assigned
    10. Not assigned
    11. Not assigned
    12. Cut wire electrode input signal
    (see Circuit Diagrams in appendix)
    Safety
    Safety
    WARNING!
    All the work and functions described in this document must only be carried out by trained and qualified personnel.
    Read and understand this document.
    Read and understand all the Operating Instructions for the system components, especially the safety rules.
    WARNING!
    Risk of machines starting automatically.
    In addition to these Operating Instructions, also observe the safety rules issued by the manufacturer of the robot and welding system. Before entering the robot work area, ensure that all protective measures in the robot work area are in place and remain in place for the duration of the access.
    WARNING!
    Danger from mechanically powered parts, flying parts (shavings, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Before carrying out any work, disconnect the compressed air and power supplies from the cleaning device and the connected system components, and ensure that they remain disconnected until work is complete.
    Before carrying out any work, make sure that the cleaning device is depressurised - for the necessary steps, see the following section Ensuring that the cleaning device is depressurised from page (→).
    WARNING!
    Whenever the cleaning device is supplied with voltage and/or compressed air, a risk of serious injury exists from: rotating cleaning cutter, cleaning motor moving up/down, extending/retracting gas nozzle clamping device, activated wire cutter, flying parts (shavings, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    If work has to be performed on the cleaning device while it is being supplied with voltage and/or compressed air, take the following protective measures:
    Keep your body, especially your hands, face, hair, any objects and all clothing away from the cleaning cutter, cleaning motor, lifting device, gas nozzle clamping device, wire cutter and parting-agent injection nozzle.
    Wear ear protection!
    Wear protective goggles with side protection.
    1. Installation and commissioning
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Safety
    Attempt to briefly activate the cleaning device without any compressed air supply to check whether the cleaning device is depressurised. To do this, proceed as follows:
    1Take protective measures:
    • The cleaning cutter, lifting device, gas nozzle clamping device, wire cutter and parting-agent injection nozzle could start up. It is important to keep your body, especially your hands, face and hair, any objects and all clothing away from the components referred to above.
    • Wear ear protection.
    • Wear protective goggles with side protection.
    2Ensure that the cleaning device has been disconnected from the compressed air supply .
    3Turn the "Start cleaning" screw on the cleaning device to position “1” (activated) for max. 2 seconds and then return to the starting position “0” (deactivated).
    • If the cleaning device does not respond to the turning of the screw, the cleaning device is depressurised.
    • If the cleaning device responds to the turning of the activation of the “Start cleaning” function, the cleaning device is still connected to a compressed air supply.
      If this is the case, you must disconnect the cleaning device from the compressed air supply and check again that the cleaning device is depressurised before starting work
    WARNING!
    The device must only be operated by one person.
    Nobody may be in the working area of the device while it is in operation.
    The device must only be serviced or maintained by one person.
    Nobody else may be within the radius of the device while it is being worked on.
    2. Before commissioning
    WARNING!
    Setup regulations
    The cleaning device is tested to protection class IP 21, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12.5 mm (0.49 in.)
    • No protection against the ingress of water
    The device must not be set up and operated outdoors. The built in electrical parts must be protected from direct wetting.
    WARNING!
    Danger from machines falling or toppling over.
    Always secure the cleaning device to the underlying surface.
    To ensure that the cleaning device functions correctly, the following compressed air supply specifications must be met:
    • Establish compressed air supply using a pressure limiter and compressed air filter
    • Provide compressed air quality conforming to ISO 8573-1:2001, class 7 4 3, instrument air
      • Solid particle concentration £ 10 mg/m3
      • Vapour pressure dew point £ + 3 °C
      • Oil concentration  £ 1 mg/m3
    If untrained operators have access to the device, its compressed air supply must be disconnected for the duration of work in accordance with 'Performance Level d' of the ISO 13849-1 standard.
    To ensure that the compressed air supply is interrupted as required, MS6-SV pressure build-up and pressure relief valves from FESTO are recommended.
    WARNING!
    Always secure the installation stand to the underlying surface.
    The screws for fastening the installation stand are not included in the scope of supply of the installation stand. The installer is responsible for selecting the right type of screws or bolts.
    Always secure the cleaning device to the installation stand.
    1Place the optionally available installation stand on a level, firm and vibration-free surface (foundation)
    • Position the installation stand in such a way that the distance the robot has to travel to the cleaning device on the installation stand is as short as possible
    2Tightly screw the installation stand to the surface (foundation) using the selected mounting materials
    Screw on the cleaning device and the spatter tray retainer using the fixings supplied with the cleaning device.
    Place components on the installation stand and secure
    Attach the spatter tray retainer as shown
    2. Screwing the cleaning device to the underlying surface
    WARNING!
    WARNING!
    If the underlying surface thickness is less than 5 mm (0.197 in.), use the fixings supplied with the cleaning device for fastening.
    If the underlying surface thickness is greater than 5 mm (0.197 in.), do not use the fixings supplied for fastening. In this situation the installer is responsible for selecting the right type of fixing.
    1Place the cleaning device and the spatter tray retainer on a level, firm and vibration-free surface (foundation).
    • Position the cleaning device in such a way that the distance the robot has to travel to the cleaning position is as short as possible.
    Place components on the underlying surface and secure
    The welding torch (gas nozzle) must be located centrally above the cleaning motor / cleaning cutter, at a distance of 1-2 mm (0.039 - 0.079 inch) to the protective cover
    2. Torch cleaning position
    CAUTION!
    Danger due to incorrectly adjusted gas nozzle clamping device.
    This may result in damage to the welding torch.
    Adjust the gas nozzle clamping device in such a way that no reaction forces can be transferred to the robot.
    The gas nozzle must only be clamped onto the cylindrical surface.
    Only clamp the gas nozzle centrally above the cleaning motor.
    1Loosen the Allen screws on the guide bolts (1) and (2)
    2Move the welding torch to the cleaning position
    • centrally with respect to the cleaning motor
    3Using the adjusting screw (3), position the clamping device (4) so that the clamping device is touching the gas nozzle
    4Tighten the Allen screws on the guide bolts (1) and (2)
    2. Adjust gas nozzle clamping device
    CAUTION!
    CAUTION!
    Danger due to cleaning cutter that has become very hot through use.
    This can result in severe burns.
    Before handling cleaning cutters, allow cleaning cutter to cool to room temperature (+25 °C, +77 °F).
    CAUTION!
    Danger from incompatible wearing parts.
    This can result in damage to property and malfunctions.
    Only use the device manufacturer's contact tips, gas nozzles and cleaning cutters. No liability is accepted for damage caused by the use of contact tips, gas nozzles or cleaning cutters from third-party manufacturers.
    The cleaning cutter is not part of the scope of suppl.. Consult the manufacturer's spare parts list for the appropriate cleaning cutter: https://spareparts.fronius.com/
    1Remove the protective covering from the cleaning device
    3Fit the protective covering to the cleaning device in its original position
    2. Fitting the cleaning cutter
    CAUTION!
    CAUTION!
    1Remove the protective covering (1)
    2Remove the gas nozzle from the torch body
    3Loosen the screw (2) on the lifting device
    4Ensure that the lifting device (3) is in its lowest lift position
    5Move the welding torch to the cleaning position (approx. 1 - 2 mm / 0.039 - 0.079 in. above the protective covering, centrally with respect to the cleaning motor)
    6Manually push the lifting device (3) into its highest lift position and hold in place
    7Manually push cleaning motor (4) and cleaning cutter to the cleaning position
    • Ensure that the cleaning cutter does not touch any welding torch components
    • See diagram (5) for welding torch with insulating sleeve
    • See diagram (6) for welding torch with spatter guard
    8Fix the cleaning motor (4) in this position in the lifting device (3) - tighten the screw (2) on the lifting device
    9Complete a function test without the gas nozzle fitted: move the cleaning motor manually to the uppermost position
    • The cleaning cutter must close around the contact tip without touching it. If the cleaning cutter touches the welding torch components, readjust the position of the cleaning motor
    10Fit the gas nozzle to the torch body
    11Complete a function test with the gas nozzle fitted: move the cleaning motor manually to the uppermost position
    • The cleaning cutter must be inserted into the gas nozzle gently, without touching it. If the cleaning cutter touches the welding torch components, readjust the position of the cleaning motor
    12Fit the protective covering to the cleaning device in its original position
    2. Adjusting the position of the cleaning motor
    If the opening on the standard leather seal is too large for the gas nozzle used, fit the second leather seal included in the scope of supply as shown below.
    The available leather seals can be found in the Spare Parts List: https://spareparts.fronius.com/
    Replace leather seal:
    Remove existing leather seal
    Fit leather seal with smaller diameter
    2. Configuring the spray device
    The electrically-controlled wire cutter opens and closes when there is an active signal from the robot control.
    2. Installing the electrically controlled wire cutter (optional)
    Wire electrodes with a diameter of up to 1.6 mm (0.063 in.) can be cut by the wire cutter.
    Use the adapter previously removed from the wire cutter.
    Use the fixings supplied with the wire cutter.
    Ensure that the recesses in the spacers face the cleaning device.
    5
    The wire cutter is controlled electrically by the robot control.
    1Depressurise the compressed air supply line of the cleaning device and ensure that it remains depressurised for the duration of the following work on the device
    2Screw the supplied compressed air relief valve into the compressed air connection on the cleaning device
    3Connect the compressed air supply line to the compressed air relief valve
    The compressed air supply to the cleaning device can be broken and re-established by moving the compressed air relief valve forwards and backwards - see description below.
    The diagram below shows the compressed air relief valve in the closed position = no compressed air supply to the device:
    Compressed air relief valve closed
    The diagram below shows the compressed air relief valve in the open position = compressed air is being supplied to the device:
    Compressed air relief valve open
    2. To establish the compressed air supply:
    Only use "Robacta Reamer" parting agent (item number 42,0411,8042) supplied by the manufacturer. The composition of this parting agent is designed specifically for the cleaning device. If other manufacturers' products are used, trouble-free operation cannot be guaranteed.
    5
    2. Starting up the parting agent nebuliser
    5
    * Option (long parting agent hose)
    1Move the welding torch to the cleaning position
    2Establish a compressed air supply to the cleaning device
    3Connect the cleaning device to the robot control
    4Start the spraying process using the robot control and check that sufficient spray is being applied
    5If the spray amount is not sufficient, increase it as required
    • by adjusting the spray time using the robot control - a spray time of ~ 0.7 seconds is recommended
    • or by using the parting agent adjuster - see figure below
    6
    Finely adjusting the spray amount on parting agent adjuster
    Safety
    WARNING!
    For the following tasks, the cleaning device must be supplied with compressed air. This results in danger from the rotating cleaning cutter, cleaning motor moving up/down, gas nozzle clamping device moving out/in, flying parts (chips, etc.), compressed air/parting agent mixture escaping from the parting-agent injection nozzle.
    Keep your body, especially your hands, face, hair, any objects and all clothing awayfrom the cleaning cutter, cleaning motor, lifting device, gas nozzle clamping device,wire cutter and parting-agent injection nozzle..
    2. Manually checking the cleaning device functions
    Safety
    WARNING!
    NOTE!
    When the slot for the "Start cleaning" and "Spray in parting agent" screws is positioned horizontally, the respective function is deactivated.
    2Disconnect the cleaning device from the robot control
    3Establish a compressed air supply to the cleaning device
    Start cleaning function
    The following must be checked when the function is being performed:
    Start cleaning
    5
    Deactivating the function
    Spray in parting agent function
    The following must be checked once the function has been performed:
    • whether the gas nozzle is coated with a sufficient layer of parting agent
    6
    Spraying in parting agent
    7
    The following requirements must be met before starting up the cleaning device:
    • If present, the cleaning device installation stand is screwed to the underlying surface
    • The cleaning device is screwed to the underlying surface
    • Gas nozzle clamping device is adjusted
    • Cleaning cutter is fitted
    • Position of the cleaning motor has been set
    • If present, the wire cutter has been installed
    • Parting agent nebuliser has been started up
    • Compressed air supply has been established
    • Functions have been checked manually
    • Cleaning device is connected to the robot control
    • All coverings are fitted and all safety devices are intact and in their proper place
    2. Starting up the cleaning device
    Start-up
    The cleaning device starts up when there is an active signal from the robot control.
    Cleaning programme
    Safety
    CAUTION!
    Danger due to improper installation and commissioning.
    The cleaning device's functions must be manually checked before starting automatic operation.
    Do not start in automated mode until the cleaning device has been properly installed and started up.
    NOTE!
    Not coating the interior of the welding torch may result in permanent soiling of the torch when welding begins.
    Always wet the interior of the welding torch with the manufacturer's parting agent before starting automatic operation.
    2. Cleaning programme
    Safety
    CAUTION!
    NOTE!
    Signal inputs
    Start cleaning signal:
    Spray in parting agent signal:
    2. Signal waveform for cleaning
    Signal inputs
    Signal outputs
    Gas nozzle free signal:
    Cleaning motor up signal:
    Cut wire electrode input signal:
    Safety
    Safety
    Observe the following safety rules for all work described in the "Care, maintenance and disposal" section.
    WARNING!
    WARNING!
    In addition to these Operating Instructions, also observe the safety rules issued by the manufacturer of the robot and welding system. For your personal safety, ensure that all protective measures have been taken and will remain in place while you are in the working area of the robot.
    WARNING!
    Before carrying out any work, disconnect the customer's compressed air and power supplies from the cleaning device and the connected system components, and ensure that they remain disconnected until work is complete.
    WARNING!
    CAUTION!
    1. Care, maintenance and disposal
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    2. Safety
    General
    The cleaning device generally needs no maintenance. However, to keep the cleaning device in good working condition for years to come, several points on care and maintenance must be observed.
    2. Care, maintenance and disposal
    General
    • Check fill level in parting agent container and top up if necessary
    • Check fill level in parting agent spatter tray and empty if necessary
    • Check cleaning cutter for wear and replace if necessary
    • Empty the cleaning device spatter tray
    • If fitted, empty the wire cutter tray
    • Carry out a general visual inspection of the cleaning device and make sure that any damage is repaired immediately (before start-up)
    Daily
    CAUTION!
    Danger from cleaning agents containing solvents.
    Only use solvent-free cleaning products on the cleaning device.
    1Remove parting agent deposits and dirt from device
    Weekly
    CAUTION!
    Only use solvent-free cleaning products on the parting agent container.
    1Check the parting agent container for soiling and clean if necessary
    2Blow through suction filter in parting agent container using compressed air from the inside outwards through the suction hose (for more detailed information see section Starting up the parting agent nebuliser from page (→))
    Every 6 months
    1Open the device and check the pneumatic valves for
    • Leaks
    • The secure seating of all screws
    • The secure seating of all screw joints on the pneumatic valves
    As necessary
    Open the device and
    1Clean inside of device using dry reduced compressed air
    2Lightly oil the lifting device cylinder guides
    3Restore the original condition of the device
    Disposal
    Troubleshooting
    Safety
    Safety
    Observe the following safety rules for all work described in the "Troubleshooting" section.
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    2. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    1. Troubleshooting
    2. Safety
    1. Troubleshooting
    Troubleshooting
    1. Troubleshooting
    2. Troubleshooting
    The parting agent does not spray
    Parting agent container is full
    Cause:Not enough spray
    Remedy:Adjust spray time
    Cause:Parting agent hose suction filter in the parting agent container is soiled
    Remedy:Clean the suction filter of the parting agent hose with compressed air (for more detailed information, see section Starting up the parting agent nebuliser from page (→))
    Cause:No signal from robot
    Remedy:Check robot program
    Cause:Parting-agent injection nozzle blocked
    Remedy:Clean parting-agent injection nozzle
    Contact After-Sales Service (arrange for parting-agent injection nozzle to be replaced)
    Cause:Vacuum pump faulty
    Remedy:Contact After-Sales Service (arrange for vacuum pump to be replaced)
    Cause:Mechanical fault on solenoid valve
    Remedy:Contact After-Sales Service (arrange for solenoid valve to be replaced)
    Welding torch is poorly cleaned or damaged
    Cause:Position of the cleaning motor has been set incorrectly
    Remedy:Set the position of the cleaning motor correctly - see section Adjusting the position of the cleaning motor from page (→)
    Cause:Gas nozzle clamped in wrong position
    Remedy:Adjust the gas nozzle clamping device - see section Adjusting the gas nozzle clamping device from page (→)
    Cause:Cleaning cutter not suited to welding torch shape
    Remedy:Fit the correct cleaning cutter
    Cause:Cleaning cutter is worn
    Remedy:Replace cleaning cutter
    Lifting device is not moving up or down
    Cause:No compressed air supply
    Remedy:Establish a compressed air supply
    Cause:Choke valve not adjustable, or faulty
    Remedy:Contact After-Sales Service (arrange for choke valve to be replaced)
    Cause:Faulty sealing in lifting cylinder
    Remedy:Contact After-Sales Service (arrange for lifting cylinder to be replaced)
    Cleaning motor does not work
    Cause:Mechanical fault on cleaning motor
    Remedy:Contact After-Sales Service (arrange for cleaning motor to be replaced)
    Technical data
    Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼″
    Standard I/O (X1)
    Input: + 24 V DC/ max. 100 mA
    Output: + 24 V DC / max. 30 mA
    Cleaning time
    4.5 - 6.5 s
    Total cycle time
    5.0 - 9.0 s
    Parting agent container capacity
    1 l
    0.26 gal. (US)
    Degree of protection
    IP 21
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    Max. noise emission (LWA)
    82 dB (A)
    Dimensions l x w x h
    255 x 245 x 390 mm
    10.04 x 9.84 x 15.35 in.
    Weight
    (without parting agent and optional wire cutter)
    10.5 kg
    23.15 lb.
    1. Technical data
    Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼″
    Standard I/O (X1)
    Cleaning time
    4.5 - 6.5 s
    Total cycle time
    5.0 - 9.0 s
    1 l
    0.26 gal. (US)
    IP 21
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    82 dB (A)
    255 x 245 x 390 mm
    Weight
    10.5 kg
    23.15 lb.
    1. Technical data
    2. Technical data
    Supply voltage
    + 24 V DC
    Nominal output
    2.4 W
    Nominal pressure
    6 bar
    86.99 psi
    Air consumption
    420 l/min
    443.81 qt./min
    G ¼″
    Standard I/O (X1)
    Cleaning time
    4.5 - 6.5 s
    Total cycle time
    5.0 - 9.0 s
    1 l
    0.26 gal. (US)
    IP 21
    Mark of conformity
    CE, CSA
    Safety symbols
    S
    'Performance Level'
    c
    82 dB (A)
    255 x 245 x 390 mm
    Weight
    10.5 kg
    23.15 lb.
    Appendix
    1. Appendix
    1. Appendix
    1. Appendix
