en
      Operating InstructionsTransSteel 3500 / 5000 Syn
    • Safety rules
      • General
      • Proper use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Mains connection
      • Protecting yourself and others
      • Danger from toxic gases and vapours
      • Danger from flying sparks
      • Risks from mains current and welding current
      • Meandering welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Specific hazards
      • Requirement for the shielding gas
      • Danger from shielding gas cylinders
      • Danger from escaping shielding gas
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
    • General information
      • General
        • Device concept
        • Functional principle
        • Application areas
      • Welding processes, procedures and welding characteristics for MIG/MAG welding
        • General
        • Welding characteristics
        • Summary of MIG/MAG standard synergic welding
        • Gouging (arc air gouging)
      • System components
        • General
        • Danger from incorrect operation
        • Overview
      • Options
        • General
        • Machine interface
        • Gas preheater CO2 connection
        • Keylock switch
        • VRD: safety function
        • VRD: safety principle
    • Control elements and connections
      • Synergic control panel
        • General
        • Safety
        • Service parameters
        • Keylock
      • Connections, switches and mechanical components
        • TSt 3500/5000 Syn power source
    • Installation and commissioning
      • Minimum equipment needed for welding task
        • General
        • Gas-cooled MIG/MAG welding
        • MIG/MAG welding, water-cooled
        • MMA welding
      • Before installation and commissioning
        • Safety
        • Utilisation for intended purpose only
        • Setup regulations
        • Mains connection
      • Connecting the mains cable
        • Mains cable connection safety
        • General
        • Stipulated mains cables and strain-relief devices
        • Fitting the Europe strain-relief device
        • Fitting the Canada/US strain-relief device
      • Generator-powered operation
      • Start-up
        • General
        • Information on system components
        • Assembling the system components (overview)
        • Placing the wirefeeder on the power source
        • Fitting the interconnecting hosepack strain-relief device
        • Connecting the interconnecting hosepack
        • Connecting the gas cylinder
        • Establishing a ground earth connection
        • Connecting MIG/MAG welding torches
        • Inserting/replacing feed rollers
        • Inserting the wirespool
        • Inserting the basket-type spool
        • Feeding in the wire electrode
        • Setting the contact pressure
        • Adjusting the brake
        • Design of the brake
    • Welding
      • Power limitation
        • Safety function
      • MIG/MAG modes
        • General
        • Symbols and their explanations
        • 2-step mode
        • 4-step mode
        • Special 4-step mode
        • Spot welding
        • 2-step stitch welding
        • 4-step stitch welding
      • MIG/MAG welding
        • Safety
        • Preparatory work
        • Overview
      • MIG/MAG standard synergic welding
        • Corrections during welding
      • MIG/MAG standard manual welding
        • General
        • Available parameters
      • Spot and stitch welding
        • General
        • Spot welding
        • Stitch welding
      • EasyJob mode
        • General
        • Storing EasyJob operating points
        • Retrieving EasyJob operating points
        • Deleting EasyJob operating points
        • Retrieving EasyJob operating points on the Up/Down welding torch
      • MMA welding
        • Safety
        • Preparation
        • MMA welding
        • HotStart function
        • Anti-stick function
      • Arc Air Gauging (TSt 5000 Syn)
        • Safety
        • Preparation
        • Arc air gouging
    • Easy Documentation
      • General
        • General
        • Documented welding data
        • New CSV file
        • PDF report / Fronius signature
      • Activating / deactivating Easy Documentation
        • Setting the date and time
        • Deactivating Easy Documentation
    • Setup settings
      • Setup menu
        • General remarks
        • Operation
        • Setup parameters for MIG/MAG standard manual welding
        • Setup parameters for MIG/MAG standard synergic welding
        • Setup parameters for MMA welding
      • Setup menu - Level 2
        • Operation (level 2 Setup menu)
        • Parameters for MIG/MAG welding in the Setup menu level 2
        • Parameters for manual metal arc (MMA) welding in the Setup menu level 2
      • Measuring welding circuit resistance r
        • General
        • Measuring welding circuit resistance (MIG/MAG welding)
      • Retrieving the welding circuit inductivity L
        • General
        • Displaying welding circuit inductivity
        • Laying the hosepacks correctly
    • Troubleshooting and maintenance
      • Troubleshooting
        • General
        • Safety
        • Fault diagnosis
        • Displayed service codes
        • Displayed service codes in connection with OPT Easy Documentation
      • Care, maintenance and disposal
        • General
        • Safety
        • At every start-up
        • Every 2 months
        • Every 6 months
        • Disposal
    • Appendix
      • Average consumption values during welding
        • Average wire electrode consumption during MIG/MAG welding
        • Average shielding gas consumption during MIG/MAG welding
        • Average shielding gas consumption during TIG welding
      • Technical data
        • Special voltages
        • Explanation of the term "duty cycle"
        • TSt 3500 Syn
        • TSt 3500 MV Syn
        • TSt 5000 Syn
        • TSt 5000 MV Syn
        • Overview with critical raw materials, year of production of the device
      • Welding program tables
        • TransSteel 3500 Syn - Euro welding program tables
        • TransSteel 5000 Syn - Euro welding program tables
        • TransSteel 3500 Syn - US welding program tables
        • TransSteel 5000 Syn - US welding program tables
        • TransSteel 3500 Yard welding program tables
        • TransSteel 5000 Yard welding program tables
      • Standard value tables for MIG/MAG standard manual welding
        • Settings tables
    • 018-09122025
    download
    Controls
    Commissioning
    MIG/MAG welding
    Setup settings
    Troubleshooting
    Maintenance
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statement
    Safety rules
    link_horizontalLink copied
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of welding and
    • read and follow these operating instructions carefully.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before switching on the device, rectify any faults that could compromise safety.
    1. Safety rules
    Proper use
    The device is intended solely for the welding processes specified on the rating plate.
    Any use above and beyond this purpose is deemed improper.
    Proper use includes:
    • carefully reading and following all the instructions given in the operating instructions
    • studying and obeying all safety and danger notices carefully
    • performing all stipulated inspection and maintenance work.
    Never use the device for the following purposes:
    • Thawing out pipes
    • Charging batteries
    • Starting engines
    The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
    The manufacturer likewise accepts no liability for inadequate or incorrect results.
    1. Safety rules
    Ambient temperature range:
    • during operation: -10 °C to + 40 °C (14 °F to 104 °F)
    • during transport and storage: -20 °C to +55 °C (-4 °F to 131 °F)
    Relative humidity:
    • up to 50% at 40 °C (104 °F)
    • up to 90% at 20 °C (68 °F)
    The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
    Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so undertake:
    • to observe the basic instructions regarding safety at work and accident prevention,
    • to read these operating instructions, especially the "Safety rules" section and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Mains connection
    This may affect a number device types in terms of:
    • Connection restrictions
    • Criteria with regard to the maximum permissible mains impedance *)
    • Criteria with regard to the minimum short-circuit power requirement *)
    *) at the interface with the public grid
    see "Technical data"
    In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
    IMPORTANT! Ensure that the mains connection is earthed properly
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks, e.g.
    • flying sparks and hot pieces of metal
    • Arc radiation, which can damage eyes and skin
    • Hazardous electromagnetic fields, which can endanger the lives of those using cardiac pacemakers
    • Risk of electrocution from mains current and welding current
    • Greater noise pollution
    • Harmful welding fumes and gases
    Suitable protective clothing must be worn when working with the device. The protective clothing must have the following properties:
    • Flame-resistant
    • Insulating and dry
    • Covers the whole body, is undamaged and in good condition
    • Safety helmet
    • Trousers with no turn-ups
    Protective clothing refers to a variety of different items. Operators should:
    • Protect eyes and face from UV rays, heat and sparks using a protective visor and regulation filter
    • Wear regulation protective goggles with side protection behind the protective visor
    • Wear stout footwear that provides insulation even in wet conditions
    • Protect the hands with suitable gloves (electrically insulated and providing protection against heat)
    • Wear ear protection to reduce the harmful effects of noise and to prevent injury
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers (risk of dazzling by the arc, injury from flying sparks, harmful welding fumes, noise, possible risks from mains current and welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains.
    1. Safety rules
    The fumes produced during welding contain harmful gases and vapours.
    Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
    Keep your face away from welding fumes and gases.
    Fumes and hazardous gases
    • must not be breathed in
    • must be extracted from the working area using appropriate methods.
    Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
    If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
    The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:
    • Metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaners, degreasers, etc.
    • Welding process used
    The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
    Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
    Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    1. Safety rules
    Flying sparks may cause fires or explosions.
    Never weld close to flammable materials.
    Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
    Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
    Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
    Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
    1. Safety rules
    An electric shock is potentially life threatening and can be fatal.
    Do not touch live parts either inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
    Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
    Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Use the handle to ensure the power connections are tight before every use.
    In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
    Do not wrap cables or leads around the body or parts of the body.
    The electrode (rod electrode, tungsten electrode, welding wire, etc.) must
    • never be immersed in liquid for cooling
    • never be touched when the welding system is switched on.
    Double the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
    Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
    Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    If necessary, provide adequate earthing for the workpiece.
    Switch off unused devices.
    Wear a safety harness if working at height.
    Before working on the device, switch it off and pull out the mains plug.
    Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
    After opening the device:
    • Discharge all live components
    • Ensure that all components in the device are de-energised.
    If work on live parts is required, have a second person switch off the main switch at the right moment.
    1. Safety rules
    If the following instructions are ignored, meandering welding currents can develop with the following consequences:
    • Fire hazard
    • Overheating of parts connected to the workpiece
    • Damage to ground conductors
    • Damage to device and other electrical equipment
    Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
    If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
    In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check and evaluate the immunity to interference of nearby devices according to national and international regulations. Examples of equipment that may be susceptible to interference from the device include:
    • Safety devices
    • Network, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite the correct mains connection, additional measures are necessary (e.g. use of a suitable line filter)
    2. Welding power-leads
      • must be kept as short as possible
      • must be laid close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Earthing of the workpiece
      • If necessary, establish an earth connection using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices nearby
      • Shield the entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    Specific hazards
    Keep hands, hair, clothing and tools away from moving parts. For example:
    • Fans
    • Cogs
    • Rollers
    • Shafts
    • Wire spools and welding wires
    Do not reach into the rotating cogs of the wire drive or into rotating drive components.
    Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
    During operation
    • Ensure that all covers are closed and all side panels are fitted properly.
    • Keep all covers and side panels closed.
    The welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
    Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
    Never touch the workpiece during or after welding - risk of burns.
    Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
    Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
    Special provisions apply in areas at risk of fire or explosion
    - observe relevant national and international regulations.
    Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
    Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
    Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
    • Hook chains or ropes onto all suspension points provided on the suitable load-carrying equipment.
    • Chains or ropes must be at the smallest angle possible to the vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
    All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
    The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
    Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
    1. Safety rules
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    1. Safety rules
    Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
    Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
    Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
    Keep the shielding gas cylinders well away from any welding or other electrical circuits.
    Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
    Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
    Turn your face to one side when opening the valve of a shielding gas cylinder.
    Close the shielding gas cylinder valve if no welding is taking place.
    If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
    The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
    1. Safety rules
    Risk of suffocation from the uncontrolled escape of shielding gas
    Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
    • Ensure an adequate supply of fresh air with a ventilation rate of at least 20 m³/hour.
    • Observe safety and maintenance instructions on the shielding gas cylinder or the main gas supply.
    • Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    • Check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before every start-up.
    1. Safety rules
    A device toppling over could easily kill someone. Place the device on a solid, level surface such that it remains stable
    • The maximum permissible tilt angle is 10°.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
    When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
    Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
    Before transporting the device, allow coolant to drain completely and detach the following components:
    • Wirefeeder
    • Wirespool
    • Shielding gas cylinder
    After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a risk of
    • damage to the device and other material assets belonging to the operator
    Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
    Only the manufacturer's original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
    Only use suitable original coolant from the manufacturer.
    Do not mix the manufacturer's original coolant with other coolants.
    Only connect the manufacturer's system components to the cooling circuit.
    Cooling Liquid FCL 10/20 does not ignite. The ethanol-based coolant can ignite under certain conditions. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
    Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Check the coolant level before starting to weld, while the system is still cool.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
    The manufacturer recommends that the welding machines be calibrated at the same 12-monthly interval.
    A safety inspection should be carried out by a qualified electrician
    • after any additional parts are installed, or after any conversions
    • after repair, care and maintenance are carried out
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on the safety inspection and calibration can be obtained from your Fronius branch or your Fronius partner. They will provide you with any documents you may require, on request.
    1. Safety rules
    Disposal
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark meet the requirements of all valid EU directives, such as:
    • Directive 2014/30/EU on Electromagnetic Compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • And so on
    The full text of the EU Declaration of Conformity can be found at
    https://www.fronius.com .
    Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Data security
    • saving and retaining personal settings
    1. Safety rules
    Copyright
    General information
    General
    Device concept
    The TransSteel (TSt) 3500 Syn and TSt 5000 Syn power sources are fully digitised, microprocessor-controlled inverter power sources.
    The modular design and potential for system add-ons ensure a high degree of flexibility.
    The devices are designed for the welding of steel and the following welding processes:
    • MAG welding
    • MMA welding
    The device has a "Power limitation" safety feature. This means that the power source can be operated at the power limit without compromising process safety. For more information, see the "Welding mode" section.
    1. General information
    General
    Device concept
    • MAG welding
    • MMA welding
    2. General
    Device concept
    • MAG welding
    • MMA welding
    2. General
    The central control and regulation unit of the power source is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
    During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Control algorithms ensure that the desired command values are kept.
    This results in:
    • a precise welding process,
    • a high degree of reproducibility of all results,
    • excellent weld properties.
    2. General
    Application areas
    The devices are used in the commercial sector for manual and automated applications with classical steel and galvanised sheets:
    • Machine and equipment construction
    • Steelwork
    • Plant and container construction
    • Shipyards and the offshore industry
    • Metal and gantry construction
    • Rail vehicle construction
    • Metalworking trades
    2. General
    Warning notices and safety symbols are affixed to the power source. These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and damage.
    Warning notices affixed to the power source
    Welding is dangerous. The following basic requirements must be met:
    • Welders must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved in the welding process must be kept at a safe distance
    • All the Operating Instructions for the system components, especially the safety rules
    General
    Power sources offer a selection of welding processes, procedures and welding characteristics that enable a wide range of materials to be processed in the most effective way.
    2. Welding processes, procedures and welding characteristics for MIG/MAG welding
    General
    When selecting the filler metal, various process-optimised welding characteristics are available depending on the welding process and shielding gas combination.
    The supplementary label for the welding process provides information about certain properties and the use of the welding characteristic:
    Special welding characteristic properties:
    Steel
    Characteristics for conventional welding tasks
    Steel root
    Characteristics for root passes with powerful arc
    Steel dynamic
    Characteristics for high welding speeds with concentrated arc
    The MIG/MAG standard synergic welding process is a MIG/MAG welding process across the entire power range of the power source with the following arc types:
    Dip transfer arc
    Droplet transfer takes place during a short circuit in the lower power range.
    Intermediate arc
    The droplet increases in size on the end of the wire electrode and is transferred in the mid-power range during the short circuit.
    Spray arc
    A short circuit-free transfer of material in the high power range.
    During arc air gouging, an arc is ignited between a carbon electrode and the workpiece, and the base material is melted and cleaned with compressed air.
    The operating parameters for arc air gouging are defined in a special characteristic.
    Applications:
    • Removing shrink holes, pores or slag inclusions from workpieces
    • Detaching sprue or finishing entire workpiece surfaces in casting operations
    • Edge preparation for heavy plates
    • Preparation and repair of welds
    • Working out root passes or defects
    • Production of air gaps
    IMPORTANT! Arc air gouging is only possible on steel materials!
    System components
    General
    The power sources can be operated with various system components and options. This makes it possible to optimise procedures and to simplify machine handling and operation, as necessitated by the particular field of application in which the power source is to be used.
    2. System components
    General
    WARNING!
    Fully read and understand this document.
    Overview
    (1)
    Welding torch
    (2)
    Wirefeeder
    (3)
    Wirefeeder holder
    (4)
    Interconnecting hosepacks
    (5)
    Power source
    (6)
    Cooling unit
    (7)
    Trolley and gas cylinder holders
    (8)
    Grounding cable and electrode cable
    Options
    General
    The options listed below are available with all power source variants.
    2. Options
    General
    2. Options
    Machine interface
    The machine interface connects the power source to the machine control. The following signals can be transmitted across the machine interface:
    Signal input: Start of welding / end of welding
    • Signal input for a floating contact (sensor, relay, etc.) between pin X1:1 and pin X1:2
    • The machine control signal input is processed by the power source in the same way as a welding torch signal input. Ensure that the correct mode is set (2-step or 4-step)
    • Use gold-plated contacts for optimum signal transmission
    Signal output: Current flow signal
    • Floating contact between pin X1:3 and pin X1:4
    NOTE!
    The machine interface isolates the welding circuit up to a maximum of 500 V DC.
    To ensure reliable isolation from the welding circuit, use a relay with an insulation voltage greater than 1500 V DC.
    Technical data - start/end of welding signal input
    UmaxAC
    5 V
    Imax
    4 mA
    Technical data - current flow signal output
    Umax
    24 V
    Imax
    20 mA
    2. Options
    External gas preheaters for gas pressure regulators can be connected to the gas preheater CO2 connection. Gas preheaters have a 36 V supply.
    NOTE!
    Voltage is only supplied to gas preheaters during welding operations.
    The power of the gas preheaters must not exceed 150 W.
    The gas preheater supply is protected against overloads and short-circuits.
    Technical data
    UA
    36 VAC
    PA, max
    150 W
    2. Options
    Keylock switch
    An optional keylock switch is available for the power source to prevent the settings from being inadvertently changed on the control panel. If the keylock switch is in the horizontal position,
    • no settings can be set on the control panel,
    • only parameter settings can be retrieved,
    • any assigned "Save" button can be retrieved provided that an assigned "Save" button was selected when the keylock was enabled.
    Keylock activated:
    "CLO | SEd" appears on the display
    Keylock deactivated:
    "OP | En" appears on the display
    2. Options
    A Voltage Reduction Device (VRD) is an optional safety device for reducing the voltage. It is recommended for environments in which the risk of an electric shock or electrical accident is increased considerably during arc welding:
    • Due to a low human body resistance of the welder
    • If the welder is exposed to a clear risk of touching the workpiece or other parts of the welding circuit
    A low human body resistance is possible when there is:
    • water in the area
    • humidity
    • heat, particularly ambient temperatures in excess of 32°C (89.6°F)
    In wet, damp or hot locations, humidity or sweat can significantly reduce the skin resistance and the insulation resistance of protective equipment and clothing.
    Such environments can include:
    • Temporary dams for draining certain areas of a site during construction work (cofferdams)
    • Trenches
    • Mines
    • Rain
    • Areas partly submerged by water
    • Spraywater areas
    The VRD option reduces the voltage between the electrode and the workpiece. In safe conditions, the indicator for the currently selected welding process is permanently lit. A safe condition is defined as follows:
    • The output voltage in an open circuit is limited to 35 V.
    For as long as the welding operation is active (welding circuit resistance < 200 Ohm), the indicator of the currently selected welding process flashes and the output voltage may exceed 35 V.
    2. Options
    The welding circuit resistance is greater than the minimum human body resistance (greater than or equal to 200 Ohm):
    • VRD is active
    • Open circuit voltage is limited to 35 V
    • Unintentional contact with the output voltage does not put the welder at risk
    The welding circuit resistance is less than the minimum human body resistance (less than 200 Ohm):
    • VRD is inactive
    • Output voltage not restricted in order to ensure sufficient welding power
    • Example: Welding starts
    In MMA welding mode:
    Within 0.3 seconds of end of welding:
    • VRD is active again
    • The output voltage is limited to 35 V once more
    General
    The functions on the control panel are all arranged in a logical way. The various welding parameters can easily be selected using buttons and can just as easily be
    • altered using buttons or the adjusting dial
    • displayed on the digital display during welding
    The synergic function ensures that all other welding parameters are adjusted whenever an individual parameter is changed.
    NOTE!
    Due to software updates, you may find that your device has certain functions that are not described in these operating instructions or vice versa.
    Individual illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    The power source uses the Synergic control panel and certain general items of data such as sheet thickness, filler metal, wire diameter and shielding gas to calculate the best welding parameters. As a result, stored knowledge is available at all times. All the parameters can be adjusted manually. The Synergic control panel also allows parameters to be set manually.
    1. Control elements and connections
    General
    NOTE!
    2. Synergic control panel
    General
    NOTE!
    Safety
    WARNING!
    (1)
    "Parameter selection" button (right)
    a) for selecting the following welding parameters
    Arc length correction
    for correcting the arc length
    Welding voltage in V *)
    Before the start of welding, the device automatically displays a standard value based on the programmed parameters. During welding, the actual value is displayed.
    Arc-force dynamic
    for influencing the short-circuiting dynamic at the moment of droplet transfer
    - ... harder, more stable arc
    0 ... neutral arc
    + ... soft, low-spatter arc
    b) for changing parameters in the Setup menu
    (2)
    "Parameter selection" button (left)
    Sheet thickness
    Sheet thickness in mm or in.
    If the welding current to be selected is not known, it is sufficient to enter the sheet thickness. The required welding current and any other parameters marked with *) will then be adjusted automatically.
    Welding current *)
    Welding current in A
    Wire speed *)
    Wire speed in m/min or ipm.
    (3)
    Adjusting dial (right)
    for changing the arc length correction, welding voltage and arc-force dynamic parameters
    for changing welding parameters in the Setup menu
    (4)
    Adjusting dial (left)
    for changing the sheet thickness, welding current and wire speed parameters
    for selecting welding parameters in the Setup menu
    (5)
    "Save" buttons (Easy Job)
    zum Speichern von bis zu 5 Arbeitspunkten
    (6)
    "Process" button **)
    for saving up to 5 operating points
     MANUAL - MIG/MAG standard manual welding
     SYNERGIC - MIG/MAG standard synergic welding
     STICK - Manual metal arc (MMA) welding
    (7)
    "Mode" button
    for selecting the operating mode
     2 T - 2-step mode
     4 T - 2-step mode
    S 4 T - Special 4-step mode
    (8)
    "Shielding gas" button
    for selecting the shielding gas to be used. The SP parameter is reserved for additional shielding gases.
    When a shielding gas is selected, the LED behind the relevant shielding gas lights up.
    (9)
    "Wire diameter" button
    for selecting the wire diameter to be used. The SP parameter is reserved for additional wire diameters.
    When a wire diameter is selected, the LED behind the relevant wire diameter lights up.
    (10)
    "Material" button
    for selecting the filler metal to be used. The SP parameter is reserved for additional filler metals
    When a material is selected, the LED behind the relevant filler metal lights up.
    (11)
    "Wire threading" button
    Press and hold the button:
    gasless wire threading into the torch hosepack
    While the button is being held, the wire drive operates at feeder inching speed.
    (12)
    "Gas-test" button
    For setting the necessary gas flow rate on the pressure regulator.
    Press the button once: shielding gas flows out
    Press the button again: shielding gas flow stops
    If the "Gas-test" button is not tapped again, the shielding gas flow will stop after 30 s.
    (13)
    SF - spot / stitch welding indicator
    lights up if a value has been entered for the spot / stitch welding time Setup parameter (SPt) (spot or stitch welding operating mode is enabled)
    (14)
    Intermediate arc indicator
    A spatter-prone "intermediate arc" occurs between the dip transfer arc and the spray arc. The intermediate arc indicator lights up to alert you to this critical range.
    (15)
    HOLD indicator
    At the end of each welding operation, the actual values for welding current and welding voltage are stored - the "HOLD" indicator lights up.
    (16)
    Real Energy Input
    for displaying the energy applied during the welding operation.
    The Real Energy Input display must be activated in level 2 of the Setup menu - EnE parameter. The value continuously rises during welding in line with the permanently increasing energy yield. The final value at the end of welding remains stored until welding starts again or the power source is switched back on - the HOLD indicator lights up.
    If one of these parameters is selected in the MIG/MAG standard synergic welding process, then the synergic function ensures that all other parameters, including the welding voltage parameter, are adjusted automatically.
    In conjunction with the VRD option, the currently selected welding process indicator is simultaneously an additional indicator:
    • The indicator is permanently lit: The Voltage Reduction Device (VRD) is active and is limiting the output voltage to less than 35 V.
    • The indicator starts to flash as soon as a welding action starts in which the output voltage can exceed 35 V.
    Service parameters
    Various service parameters can be retrieved by pressing the "Parameter selection" buttons at the same time.
    Opening the display
    The first parameter ("Firmware version") is displayed, e.g. "1.00 | 4.21"
    Selecting parameters
    Use the "Mode" and "Process" buttons or the left-hand adjusting dial to select the required Setup parameter
    Explanation
    Example:
    1.00 | 4.21
    Firmware version
    Example:
    2 | 491
    Welding program configuration
    Example:
    r 2 | 290
    Number of the currently selected welding program
    654 | 32.1
    = 65,432.1 hours
    = 65,432 hours 6 mins
    Indicates the actual arc time since using for the first time
    Note: The arc time indicator is not suitable as a basis for calculating hiring fees, warranty services, etc.
    Example:
    iFd | 0.0
    Motor current for wire drive in A
    The value changes as soon as the motor is running.
    2nd
    Second menu level for service technicians
    Keylock
    A keylock can be selected to prevent the settings from being inadvertently changed on the control panel. As long as the keylock is active
    • No settings can be made on the control panel
    • Only parameter settings can be retrieved
    • Any assigned "Save" button can be retrieved provided that an assigned "Save" button was selected when the keylock was enabled
    To activate/deactivate the keylock:
    Keylock activated:
    The message "CLO | SEd" appears on the displays.
    The message "OP | En" appears on the displays.
    The keylock can be activated and deactivated using the keylock switch option.
    (1)
    (-) - current socket with bayonet latch
    Used for
    • Connecting the grounding cable during MIG/MAG welding
    • Connecting the electrode cable or grounding cable during manual metal arc welding (depending on the type of electrode used)
    (2)
    Mains switch
    For switching the power source on and off
    (3)
    (+) - current socket with bayonet latch
    Used for
    • Connecting the current cable from the interconnecting hosepack during MIG/MAG welding
    (4)
    Gas preheater socket (option)
    (5)
    Machine interface (optional)
    (6)
    EASY DOCUMENTATION sticker
    (7)
    Mains cable with strain relief device
    (8)
    LocalNet port
    Standardised connection socket for the wirefeeder (interconnecting hosepack)
    (9)
    Air filter
    Remove from the side for cleaning
    2. Connections, switches and mechanical components
    (1)
    Used for
    (2)
    Mains switch
    (3)
    Used for
    (4)
    (5)
    (6)
    (7)
    (8)
    LocalNet port
    (9)
    Air filter
    General
    Depending on the welding process, a certain minimum equipment level is required in order to work with the welding machine.
    The welding processes and the corresponding minimum equipment for the welding operation are described in the following.
    1. Installation and commissioning
    General
    2. Minimum equipment needed for welding task
    General
    • Power source
    • Grounding cable
    • MIG/MAG welding torch, gas-cooled
    • Gas connection (shielding gas supply)
    • Wirefeeder (VR 5000 Remote)
    • Interconnecting hosepack, gas-cooled
    • Wire electrode
    • Power source
    • Cooling unit
    • Grounding cable
    • MIG/MAG welding torch, water-cooled
    • Water-cooling option (for VR 5000 Remote)
    • Interconnecting hosepack, water-cooled
    • Wire electrode
    MMA welding
    • Power source
    • Grounding cable
    • Electrode holder
    • Rod electrodes
    Safety
    WARNING!
    WARNING!
    2. Before installation and commissioning
    Safety
    WARNING!
    WARNING!
    The power source may only be used for MIG/MAG and MMA welding.
    Any other form of usage is deemed "not in accordance with the intended purpose".
    The manufacturer shall not be held liable for any damages arising from such usage.
    Utilisation in accordance with the "intended purpose" also comprises
    • following all the information in the operating instructions
    • carrying out all the specified inspection and servicing work
    Setup regulations
    The device is tested to IP 23 protection, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° to the vertical
    The device can be set up and operated outdoors in accordance with degree of protection IP 23.
    Avoid direct wetting (e.g. from rain).
    WARNING!
    Danger from machines toppling over or falling.
    Set up the device securely on an even, solid surface.
    Check all screw connections are tightly fastened after installation.
    WARNING!
    Danger from electrical current due to electrically conductive dust in the device.
    Only operate the device with an air filter fitted. The air filter is a very important safety device for achieving IP 23 protection.
    The venting duct is a very important safety device. When choosing the installation location, ensure that the cooling air can enter and exit unhindered through the air ducts on the front and back of the device. Electroconductive metallic dust (e.g. from grinding work) must not be allowed to get sucked into the device.
    Mains connection
    • The devices are designed for the mains voltage specified on the rating plate.
    • If your version of the appliance does not come with mains cables and plugs ready-fitted, these must be fitted in accordance with national regulations and standards.
    • For details of fuse protection of the mains lead, please see the technical data.
    CAUTION!
    Danger due to insufficiently dimensioned electrical installations.
    Dimension the mains lead and its fuse to suit the local power supply.
    The technical data shown on the rating plate applies.
    WARNING!
    The work described below must only be carried out by trained and qualified personnel.
    Observe national standards and directives.
    CAUTION!
    Danger due to improperly prepared mains cable.
    This can result in short circuits and damage to property.
    Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
    2. Connecting the mains cable
    WARNING!
    CAUTION!
    General
    If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before commissioning.
    A strain-relief device for the following cable cross-sections is fitted to the power source:
    Power source
    Cable cross-section
    fitted strain-relief device for
    Canada / US
    Europe
    TSt 3500 Syn
    AWG 12 *)
    4G2.5
    TSt 5000 Syn
    AWG 10 *)
    4G4
    TSt 3500 MV Syn
    AWG 10 *)
    4G4
    TSt 5000 MV Syn
    AWG 6 *)
    4G10
    Canada / US cable type: Extra-hard usage
    Strain-relief devices for other cable cross-sections must be designed accordingly.
    Power source
    Mains voltage
    Cable cross-section
    Canada / US
    Europe
    TSt 3500 Syn
    3 x 380 / 400 V
    AWG 12 *)
    4G2.5
    3 x 460 V
    AWG 12 *)
    4G2.5
    TSt 5000 Syn
    3 x 380 / 400 V
    AWG 8 *)
    4G4
    3 x 460 V
    AWG 10 *)
    4G4
    TSt 3500 MV Syn
    3 x 208 / 230 / 400 / 460 V
    AWG 10 *)
    4G4
    TSt 5000 MV Syn
    AWG 6 *)
    4G10
    The item numbers of the different cables can be found in the Spare Parts List of the device.
    AWG ... American Wire Gauge
    The ground conductor should be approx. 10 - 15 mm (0.4 - 0.6 in.) longer than the phase conductors.
    An illustration of the mains cable connection can be found in the following sections: "Fitting the strain-relief device" or "Fitting the strain-relief device for Canada / US". To connect the mains cable, proceed as follows:
    1Remove the side panel from the device
    2Push the mains cable in far enough to make it possible to connect the ground conductor and the phase conductors to the block terminal properly.
    3Fit ferrules to the ground conductor and phase conductors
    4Connect the ground conductor and phase conductors to the block terminal
    5Use the strain-relief device to secure the mains cable
    6Fit the side panel of the device
    5
    IMPORTANT! Tie the phase conductors near the block terminals using cable ties.
    5
    The welding machine is generator-compatible.
    The maximum apparent power S1max of the welding machine must be known in order to select the correct generator output.
    The maximum apparent power S1max of the welding machine is calculated as follows:
    3-phase devices: S1max = I1max x U1 x √3
    Single-phase devices: S1max = I1max x U1
    See device rating plate or technical data for I1max and U1 values
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator may be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the welding machine.
    When using single-phase devices with a 3-phase generator, note that the specified generator apparent power is often only available as a whole across all three phases of the generator. If necessary, obtain further information on the single-phase power of the generator from the generator manufacturer.
    NOTE!
    The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
    Details of the mains voltage tolerance can be found in the "Technical data" section.
    2. Generator-powered operation
    SGEN = S1max x 1.35
    NOTE!
    Start-up
    General
    Commissioning a power source is described by reference to a manual water-cooled MIG/MAG application.
    2. Start-up
    General
    2. Start-up
    The steps and activities described below include references to various system components, including:
    • trolley
    • upright console
    • cooling units
    • wire-feed units
    • interconnecting hosepacks
    • welding torches, etc.
    For more detailed information about installing and connecting the system components, please refer to the appropriate operating instructions.
    2. Start-up
    WARNING!
    Work that is carried out incorrectly can cause serious injury and damage.
    The following activities must only be carried out by trained and qualified personnel.
    All instructions in the section headed "Safety rules" must be observed.
    The diagram below is intended to show you how to fit the individual system components.
    2. Start-up
    CAUTION!
    Risk of injury and material damage from falling wirefeeder.
    Make sure that the wirefeeeder is located securely on the swivel pin and that the devices, upright consoles and trolleys are stable.
    2. Start-up
    Fitting the strain-relief device to the trolley
    Fitting the strain-relief device to the wirefeeder
    IMPORTANT! To prevent wear and tear, leave some slack when connecting the cables. A strain-relief device is not provided for 1.2 m (3 ft 11.24 in.) interconnecting hosepacks.
    2. Start-up
    WARNING!
    Fitting the equipment incorrectly can cause serious injury and damage.
    Do not carry out the steps described here until you have read and completely understood all the Operating Instructions.
    NOTE!
    When connecting the interconnecting hosepack, check that
    all connections are connected properly
    all cables, leads and hosepacks are undamaged and correctly insulated
    IMPORTANT! There is no cooling unit present in the case of gas-cooled systems. There is no need to attach the water connections in the case of gas-cooled systems.
    2. Start-up
    WARNING!
    There is a high risk of very serious injury and damage if a gas cylinder falls over.
    When using gas cylinders:
    Place them on a solid, level surface in such a way that they remain stable
    Secure the gas cylinders to prevent them from falling over
    Fit the VR holder option
    Observe the safety rules of the gas cylinder manufacturer
    1Place the gas cylinder on the base of the trolley
    2Secure the gas cylinder by fixing the cylinder strap around the upper part of the cylinder (but not around the neck) to prevent it from toppling over
    3Take the protective cap off the gas cylinder
    4Briefly open the gas cylinder valve to remove any dust or dirt
    5Inspect the seal on the gas pressure regulator
    6Screw the pressure regulator onto the gas cylinder and tighten it
    7Connect the shielding gas hose of the interconnecting hosepack to the pressure regulator using the gas hose
    NOTE!
    US devices are supplied with an adapter for the gas hose:
    Seal male thread spacers on the gas solenoid valve using suitable means before screwing on the adapter.
    Test the adapter to ensure that it is gas-tight.
    2. Start-up
    NOTE!
    When establishing a ground earth connection, observe the following points:
    Use a separate grounding cable for each power source
    Keep the plus cable and grounding cable together as long and as close as possible
    Physically separate the welding circuits of individual power sources
    Do not route several grounding cables in parallel;
    if parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
    Keep the grounding cable as short as possible, provide a large cable cross-section
    Do not cross grounding cables
    Avoid ferromagnetic materials between the grounding cable and the interconnecting hosepack
    Do not wind up long grounding cables - coil effect!
    Lay long grounding cables in loops
    Do not route grounding cables in iron pipes, metal cable conduits or on steel rails, avoid cable ducts;
    (routing of plus cables and grounding cables together in an iron pipe does not cause any problems)
    If there are several grounding cables, separating the grounding points on the component so that they are as far away from one another as possible is recommended, as well as preventing crossed current paths from occurring underneath the individual arcs.
    Use compensated interconnecting hosepacks (interconnecting hosepacks with integrated grounding cable)
    2. Start-up
    * when the optional water connection and the water-cooled welding torch are fitted
    2. Start-up
    CAUTION!
    Danger from feed roller holders flying upwards.
    This can result in injuries.
    When unlocking the clamping lever, keep fingers away from the area to the left and right of the lever.
    CAUTION!
    Danger from exposed feed rollers.
    Always fit the protective cover of the 4-roller drive after inserting or replacing a feed roller.
    2. Start-up
    CAUTION!
    Risk of injury due to springiness of spooled wire electrode.
    While inserting the wirespool, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Risk of injury from falling wirespool.
    Make sure the wirespool sits securely on the wirespool holder.
    CAUTION!
    Risk of injury and material damage if the wirespool topples over because the locking ring has been placed the wrong way around.
    Always position the locking ring as shown in the diagram on the left.
    2. Start-up
    CAUTION!
    When inserting the basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Risk of injury from falling basket-type spool.
    Make sure that the basket-type spool and basket-type spool adapter are fitted securely to the wirespool holder.
    NOTE!
    When working with basket-type spools, only use the basket-type spool adapter included in the scope of supply.
    CAUTION!
    Risk of injury and material damage if the basket-type spool topples over because the locking ring has been placed the wrong way round.
    CAUTION!
    Risk of injury and material damage from falling basket-type spool.
    Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
    2. Start-up
    Feeding in the wire electrode
    CAUTION!
    When inserting the wire electrode into the 4-roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Risk of damage to the welding torch from sharp end of wire electrode.
    Deburr the end of the wire electrode well before threading in.
    CAUTION!
    Risk of injury from emerging wire electrode.
    When pressing the wire threading button or the torch trigger, keep the welding torch away from your face and body, and wear suitable protective goggles.
    IMPORTANT! To facilitate the exact positioning of the wire electrode, the following sequences are possible when the wire threading button is pressed and held down.
    • Hold the button for up to one second ... the wire speed stays at 1 m/min or 39.37 ipm for the first second.
    • Hold the button for up to 2.5 seconds ... after one second has elapsed, the wire speed increases at a uniform rate over the next 1.5 seconds.
    • Hold the button for more than 2.5 seconds ... after 2.5 seconds, the wire is fed at a constant rate equal to the wire speed set for the Fdi welding parameter.
    If the "Wire threading" button is released and pressed again before one second has elapsed, the sequence starts again from the beginning. This makes it possible to continuously position the wire at a low wire speed of 1 m/min or 39.37 ipm where necessary.
    If there is no "Wire threading" button, the torch trigger can be used in the same way. Before using the torch trigger for wire threading, proceed as follows:
    1Press the "Mode" button to select 2-step mode
    2Set the "Ito" parameter to "Off" in the Setup menu
    CAUTION!
    Risk of injury and damage from electric shock and from the wire electrode emerging from the torch.
    When pressing the torch trigger:
    Keep the welding torch away from your face and body
    Wear suitable protective goggles
    Do not point the welding torch at people
    Make sure that the wire electrode does not touch any conductive or earthed parts (e.g. housing)
    IMPORTANT! If the torch trigger is pressed instead of the "Wire threading" button, the welding wire runs at the feeder creep speed (depending on the welding program) for the first 3 seconds. After these 3 seconds, wirefeeding is briefly interrupted.
    The welding system detects that the welding process should not start, but that the wire is to be fed in. At the same time, the gas solenoid valve closes, and the welding voltage on the wire electrode is switched off.
    If the torch trigger is held down, wirefeeding restarts immediately without shielding gas and welding voltage, and the process continues as described above.
    2. Start-up
    Setting the contact pressure
    CAUTION!
    Risk from excessive contact pressure.
    This can result in severe damage to property and poor weld properties.
    Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
    Contact pressure preferred values for U-groove rollers:
    Steel: 4 - 5
    CrNi: 4 - 5
    Tubular cored electrodes: 2 - 3
    2. Start-up
    Adjusting the brake
    NOTE!
    After releasing the "Wire threading" button, the wirespool should stop unreeling.
    If it continues unreeling, readjust the brake.
    2. Start-up
    Design of the brake
    link_horizontalLink copied
    CAUTION!
    Danger from incorrect installation.
    This can result in injury and damage to property.
    Do not dismantle the brake.
    Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
    The brake is only available as a complete unit.
    The illustration of the brake is for information purposes only.
    Welding
    Power limitation
    Safety function
    "Power limitation" is a safety function for MIG/MAG welding. This means that the power source can be operated at the power limit whilst maintaining process safety.
    Wire speed is a determining parameter for welding power. If it is too high, the arc gets smaller and smaller and may be extinguished. In order to prevent this, the welding power is lowered.
    For the selected "MIG/MAG standard synergic welding" process, the symbol for the "Wire speed" parameter flashes as soon as the safety function trips. The flashing continues until the next welding start-up, or until the next parameter change.
    For example, if the "Wire speed" parameter is selected, the reduced value for wire speed is displayed.
    1. Welding
    Power limitation
    Safety function
    1. Welding
    2. Power limitation
    Safety function
    1. Welding
    MIG/MAG modes
    General
    WARNING!
    Operating the equipment incorrectly can cause serious injury and damage.
    Do not use the functions described here until you have read and completely understood these Operating Instructions.
    Do not use the functions described here until you have fully read and understood all of the Operating Instructions for the system components, in particular the safety rules.
    For details of the meaning, settings, setting range and units of the available welding parameters (e.g. gas pre-flow time), please refer to the "Setup parameters" chapter.
    1. Welding
    2. MIG/MAG modes
    General
    WARNING!
    1. Welding
    2. MIG/MAG modes
    Symbols and their explanations
    Press the torch trigger | Hold the torch trigger | Release the torch trigger
    GPr
    Gas pre-flow time
    I-S
    Starting current
    Can be increased or decreased depending on the application
    SL
    Slope
    The starting current is continuously lowered as far as the welding current and the welding current as far as the final current
    I
    Welding current phase
    Uniform thermal input into the base material, whose temperature is raised by the advancing heat
    I-E
    Final current
    To fill the end-crater
    GPo
    Gas post-flow time
    SPt
    Spot welding time / interval welding time
    SPb
    Interval pause time
    1. Welding
    2. MIG/MAG modes
    2-step mode
    "2-step mode" is suitable for
    • Tacking work
    • Short weld seams
    • Automated and robot welding
    1. Welding
    2. MIG/MAG modes
    4-step mode
    "4-step mode" is suitable for longer weld seams.
    1. Welding
    2. MIG/MAG modes
    Special 4-step mode
    Special 4-step mode allows the starting and final current to be configured in addition to the advantages of 4-step mode.
    1. Welding
    2. MIG/MAG modes
    Spot welding
    The "Spot welding" mode is suitable for welded joints on overlapped sheets.
    Start by pressing and releasing the torch trigger - GPr gas pre-flow time - Welding current phase for the duration of the SPt spot welding time - GPo gas post-flow.
    If the torch trigger is pressed again before the end of the spot welding time (< SPt), the process is cancelled immediately.
    1. Welding
    2. MIG/MAG modes
    2-step stitch welding
    The "2-step stitch welding" mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the base material.
    1. Welding
    2. MIG/MAG modes
    4-step stitch welding
    The "4-step stitch welding" mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the base material.
    1. Welding
    MIG/MAG welding
    Safety
    WARNING!
    WARNING!
    1. Welding
    2. MIG/MAG welding
    Safety
    WARNING!
    WARNING!
    1. Welding
    2. MIG/MAG welding
    Preparatory work
    1Connect welding torch water hoses to the correct connections on the wirefeeder
    (when using a cooling unit and water-cooled welding torch)
    2Plug in the mains plug
    3Move the mains switch to the "I" position:
    • all the indicators on the control panel light up briefly
    • where applicable, the cooling unit starts to run
    IMPORTANT! Follow the safety rules and note operating conditions in the cooling unit Operating Instructions.
    1. Welding
    2. MIG/MAG welding
    Overview
    MIG/MAG welding is composed of the following sections:
    • MIG/MAG standard synergic welding
    • MIG/MAG standard manual welding
    • Spot and stitch welding
    1. Welding
    1Press the "Material" button to select the filler metal to be used.
    2Press the "Wire diameter" button to select the diameter of the wire electrode used.
    3Press the "Shielding gas" button to select the shielding gas to be used.
    The assignment of the SP position is in the welding program tables in the appendix.
    4Press the "Process" button to select the desired welding process:
    5Press the "Mode" button to select the desired MIG/MAG mode:
    • 2-step mode
    • 4-step mode
    • Special 4-step mode
    IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component (TR 2000 or TR 3000 remote control) on the control panel of the power source.
    6Use the "Parameter selection" buttons to select the welding parameters to be used to specify the welding power:
    • Sheet thickness
    • Welding current
    • Wire speed
    • Welding voltage
    7Use the appropriate adjusting dial to set the relevant welding parameters.
    The welding parameter values are shown in the digital display located above them.
    All welding parameter set values remain stored until the next time they are changed. This applies even if the power source is switched off and on again. To display the actual welding current during welding, select the welding current parameter.
    8Open the gas cylinder valve
    9Setting the shielding gas flow rate:
    • Tap the "Gas-test" button
    • Turn the adjusting screw on the underside of the pressure regulator until the pressure gauge shows the required gas flow rate
    • Tap the "Gas-test" button again
    CAUTION!
    do not point the welding torch at people
    make sure that the wire electrode does not touch any conductive or earthed parts (e.g. housing)
    10Press the torch trigger and start welding
    1. Welding
    2. MIG/MAG standard synergic welding
    • 2-step mode
    • 4-step mode
    • Sheet thickness
    • Welding current
    • Wire speed
    • Welding voltage
    CAUTION!
    1. Welding
    Corrections during welding
    The arc length correction and arc-force dynamic parameters can be used to optimise the welding result.
     Arc length correction:
    = shorter arc, reduced welding voltage
    0
    = neutral arc
    = longer arc, increased welding voltage
    Arc-force dynamic:
    To influence the short-circuiting dynamic at the instant of droplet transfer
    = hard, stable arc
    0
    = neutral arc
    = soft, low-spatter arc
    1. Welding
    General
    The MIG/MAG standard manual welding process is a MIG/MAG welding process with no synergic function.
    Changing one parameter does not result in any automatic adjustments to the other parameters. All of the variable parameters must therefore be adjusted individually, as dictated by the welding process in question.
    1. Welding
    2. MIG/MAG standard manual welding
    General
    1. Welding
    Available parameters
    The following parameters are available in MIG/MAG manual welding:
    Wire feed speed
    1 m/min (39.37 ipm) - maximum wire feed speed, e.g. 25 m/min (984.25 ipm)
    Welding voltage
     TSt 3500: 15.5 - 31.5 V
    TSt 5000: 14.5 - 39 V
    Dynamic
     for influencing the short-circuiting dynamic at the moment of particle transfer
    Welding current
    only for displaying the actual value
    1. Welding
    1Press the "Process" button to select the desired welding process:
    2Press the "Mode" button to select the desired MIG/MAG mode:
    • 2-step mode
    • 4-step mode
    • In MIG/MAG standard manual welding, special 4-step mode corresponds to conventional 4-step mode.
    IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component (TR 2000 or TR 3000 remote control) on the control panel of the wirefeeder.
    3Press the "Parameter selection" button to select the wire speed parameter
    4Use the adjusting dial to set the desired value for the wire speed
    5Press the "Parameter selection" button to select the welding voltage parameter
    6Use the adjusting dial to set the desired value for the welding voltage
    To display the actual welding current during welding:
    • Press the "Parameter selection" button to select the welding current parameter
    • The actual welding current is shown on the digital display during welding.
    7Open the gas cylinder valve
    8Setting the shielding gas flow rate:
    CAUTION!
    9Press the torch trigger and start welding
    1. Welding
    To obtain the best possible welding results, the arc-force dynamic parameter will sometimes need to be adjusted.
    1Press the "Parameter selection" button to select the arc-force dynamic parameter
    2Use the adjusting dial to set the desired arc-force dynamic valueThe welding parameter value is shown in the digital display located above it.
    1. Welding
    General
    The spot and stitch welding modes are MIG/MAG welding processes. The spot and stitch welding modes can be activated on the power source control panel.
    Spot welding is used on welded joints on overlapped sheets that are only accessible on one side.
    Stitch welding is used for light-gauge sheets.
    As the wire electrode is not fed continuously, the weld pool can cool down during the intervals. Local overheating leading to the base material being melted through is largely avoided.
    1. Welding
    2. Spot and stitch welding
    General
    1. Welding
    Spot welding
    Activating spot welding mode:
    • For the SPt Setup parameter (spot / stitch welding time), enter a value > OFF
    As soon as a value is entered for the SPt Setup parameter, spot welding mode is activated. The spot / stitch welding indicator (SF) lights up on the control panel.
    Preparations:
    1Set the spot / stitch welding time (SPt) in the Setup menu
    2Select the filler metal, wire diameter and shielding gas being used with the relevant buttons
    3Select the desired welding process:   MIG/MAG standard manual welding   MIG/MAG standard synergic welding
    4Select the desired MIG/MAG mode:   2-step mode
    (For spot welding mode, only 2-step mode is available)
    5Depending on the selected welding process, select the desired welding parameters using the relevant adjusting dial
    6Open the gas cylinder valve
    7Set the shielding gas flow rate
    WARNING!
    Danger due to emerging wire electrode.
    This can result in serious personal injuries.
    Hold the welding torch so that the tip of the welding torch points away from the face and body.
    Wear suitable protective goggles.
    Do not point the welding torch at people.
    Ensure that the wire electrode does not touch any electrically conductive objects.
    12Spot welding
    Procedure for producing a welding spot:
    1Hold the welding torch vertical
    2Press and release the torch trigger
    3Keep the welding torch in the same position
    4Wait for the gas post-flow time
    5Raise the welding torch
    1. Welding
    Stitch welding
    Activating stitch welding mode:
    • For the SPt Setup parameter (spot pause time), enter a value > OFF
    As soon as a value is entered for the SPt Setup parameter, the spot / stitch welding indicator (SF) lights up.
    Preparations:
    2Set the spot pause time (SPb) in the Setup menu
    3Select the filler metal, wire diameter and shielding gas being used with the relevant buttons
    4Select the desired welding process:   MIG/MAG standard manual welding   MIG/MAG standard synergic welding
    5Select the desired MIG/MAG mode for stitch welding mode:   2-step mode   4-step mode
    6Depending on the selected welding process, select the desired welding parameters using the relevant adjusting dial
    8Set the shielding gas flow rate
    CAUTION!
    10Stitch welding
    Procedure for stitch welding:
    2Depending on the selected mode:
    press and hold the torch trigger (2-step mode)
    press and release the torch trigger (4-step mode)
    3Keep the torch in the same position
    4Wait for the welding interval
    5Position the welding torch at the next point
    6To end stitch welding, depending on the selected mode:
    release the torch trigger (2-step mode)
    7Wait for the gas post-flow time
    8Lift the torch off the workpiece
    1. Welding
    EasyJob mode
    General
    The "Save" buttons allow up to 5 EasyJob operating points to be saved. Every operating point matches the settings on the control panel.
    EasyJobs can be stored for each welding process.
    IMPORTANT! Setup parameters are not saved at this time.
    1. Welding
    2. EasyJob mode
    General
    1. Welding
    2. EasyJob mode
    Storing EasyJob operating points
    1Press and hold one of the "Save" buttons to save the current settings on the control panel, e.g.:
    • The left indicator displays "Pro"
    • After a short time, the left indicator switches to the original value
    2Release the "Save" button
    1. Welding
    2. EasyJob mode
    Retrieving EasyJob operating points
    1To retrieve saved settings, press the corresponding "Save" button briefly, e.g.:
    • The control panel will show the saved settings
    1. Welding
    2. EasyJob mode
    Deleting EasyJob operating points
    1Press and hold the relevant "Save" button to delete the memory content of that "Save" button, e.g.:
    • The left indicator displays "Pro".
    2Keep the "Save" button held down
    • The left display shows "CLr".
    • After a while, both displays show "---"
    3Release the "Save" button
    1. Welding
    2. EasyJob mode
    Retrieving EasyJob operating points on the Up/Down welding torch
    One of the "Save" buttons on the control panel must be pressed in order to retrieve the saved settings using the Up/Down welding torch.
    1Press one of the "Save" buttons on the control panel, e.g.:
    The control panel will show the saved settings.
    The "Save" buttons can now be selected using the buttons on the Up/Down welding torch. Vacant "Save" buttons are skipped.
    In addition to the "Save" button number lighting up, a number is displayed directly on the Up/Down welding torch:
    Indicator on the Up/Down welding torch
    EasyJob operating point on the control panel
    1. Welding
    MMA welding
    Safety
    WARNING!
    WARNING!
    1. Welding
    2. MMA welding
    Safety
    WARNING!
    WARNING!
    1. Welding
    2. MMA welding
    Preparation
    1Move the mains switch to the "O" position
    2Disconnect the mains plug
    3Detach all cables to the wirefeeder at the power source IMPORTANT! Check the rod electrode packaging to determine whether the rod electrodes are for (+) or (-) welding.
    4Plug the grounding cable into either the (-) or the (+) current socket, depending on the type of electrode, and lock in place
    5Use the other end of the grounding cable to establish a connection to the workpiece
    6Plug the bayonet current plug of the electrode holder cable into the free current socket with the opposite polarity, according to the type of electrode, and twist it clockwise to latch it in place
    7Plug in the mains plug
    1. Welding
    2. MMA welding
    MMA welding
    CAUTION!
    Risk of injury and damage from electric shock.
    As soon as the mains switch is in the "I" position, the rod electrode in the electrode holder is live.
    Make sure that the rod electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.)
    1Move the mains switch to the "I" position: all the indicators on the control panel will briefly light up
    2Press the "Process" button to select the MMA welding process:
    The welding voltage is applied to the welding socket with a three second time lag.If the MMA welding process is selected, any cooling unit present is automatically deactivated. It is not possible to switch it on.
    NOTE!
    Under certain circumstances, it may not be possible to change welding parameters that have been set on a system component (such as remote control or wirefeeder) from the control panel of the power source.
    3Press the "Parameter selection" button to select the amperage parameter.
    4Use the adjusting dial to set the desired amperage.The amperage value is displayed in the left-hand digital display.
    All welding parameter set values that have been set using the adjusting dial remain stored until the next time they are changed. This applies even if the power source was switched off and on again in the interim.
    5Start welding
    1. Welding
    2. MMA welding
    Influence of the short-circuiting dynamic at the instant of droplet transfer:
    = hard, stable arc
    0
    = neutral arc
    1. Welding
    2. MMA welding
    HotStart function
    To obtain optimum welding results, it will sometimes be necessary to adjust the HotStart function.
    Advantages
    • Improved ignition properties, even when using electrodes with poor ignition properties
    • Better fusion of the base material during the start-up phase, meaning fewer cold-shut defects
    • Largely prevents slag inclusions
    For details on setting the available welding parameters, please refer to "Setup parameters", "Setup menu - level 2".
    Legend
    Hti
    Hot-current time,
    0 - 2 s,
    factory setting: 0.5 s
    HCU
    HotStart current,
    100 - 200 %,
    factory setting 150 %
    IH
    Main current = set welding current
    Function
    During the specified hot-current time (Hti), the welding current is increased to a certain value. This value (HCU) is higher than the selected welding current (IH).
    1. Welding
    2. MMA welding
    Anti-stick function
    As the arc becomes shorter, the welding voltage may drop so far that the rod electrode will tend to stick. This may also cause the rod electrode to burn out.
    Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. After the rod electrode has been detached from the workpiece, the welding process can be continued without any problems.
    The anti-stick function (Ast) can be activated and deactivated in the Setup menu with the Setup parameters for manual metal arc welding.
    1. Welding
    Arc Air Gauging (TSt 5000 Syn)
    Safety
    WARNING!
    WARNING!
    1. Welding
    2. Arc Air Gauging (TSt 5000 Syn)
    Safety
    WARNING!
    WARNING!
    1. Welding
    Preparation
    IMPORTANT! A grounding cable with a cable cross-section of 120 mm² is required for arc air gouging.
    3Remove the MIG/MAG welding torch
    4Plug the grounding cable into the (-) current socket and twist to fasten it
    6Plug the bayonet current plug of the arc air gouging torch into the (+) current socket and twist it clockwise to fasten it
    7Connect the compressed air connection of the arc air gouging torch to the compressed air supply
    Working pressure: 5 - 7 bar (constant)
    8Clamp the carbon electrode so that the electrode tip protrudes approximately 100 mm out of the arc air gouging torch;
    the air outlet openings of the arc air gouging torch must be located at the bottom
    9Plug in the mains plug
    1. Welding
    Arc air gouging
    CAUTION!
    As soon as the mains switch is in the "I" position, the electrode in the arc air gouging torch is live.
    Make sure the electrode does not touch any persons or electrically conducting or earthed parts (e.g. the housing, etc.).
    CAUTION!
    Risk of personal injury due to loud operating noise.
    Use suitable ear protection during arc air gouging!
    IMPORTANT! Under certain circumstances, it may not be possible to change welding parameters that have been set on a control panel of a system component (such as remote control or wirefeeder) from the control panel of the power source.
    3In the setup menu for MMA welding, set the AAG parameter to "on";
    To enter the setup menu, see page (→).
    NOTE!
    Settings for the break voltage and the starting current time are ignored.
    4Exit the setup menu for MMA welding
    5Press the "Parameter selection" button to select the amperage parameter.
    6Using the adjusting dial, adjust the main current according to the electrode diameter as indicated on the electrode packagingThe amperage value is displayed in the left-hand digital display.
    NOTE!
    At higher amperages, guide the arc air gouging torch with both hands!
    Use a suitable welding helmet.
    7Open the compressed air valve on the handle of the arc air gouging torch
    8Initiate processing
    The tilt angle of the carbon electrode and the gouging speed determine the depth of an air gap.
    The arc air gouging parameters are the same as the welding parameters for MMA welding, see page (→).
    Easy Documentation
    General
    General
    If the Easy Documentation option is available on the power source, the most important welding data for each weld can be documented and saved as a CSV file on a USB flash drive.
    A Fronius signature is stored with the welding data which can be used to check and guarantee the authenticity of the data.
    Easy Documentation is activated / deactivated by plugging / unplugging the supplied Fronius USB flash drive with FAT32 formatting into the back of the power source.
    IMPORTANT! To document the welding data, the date and time must be set correctly.
    1. Easy Documentation
    General
    General
    2. General
    General
    2. General
    Documented welding data
    The following data is also documented:
    Device type
    File name
    Item number
    Serial number
    Firmware version of power source
    Firmware of PC board DOCMAG (Easy Documentation)
    Docu version
    https://www.easydocu.weldcube.com (a PFDF report of selected welding data can be created under this link)
    Nr.
    Counter
    Start by plugging in the USB flash drive;
    When switching the power source off and on, the counter continues at the last weld seam number.
    A new CSV file is created after 1000 welds.
    Date
    Date yyyy-mm-dd
    Time
    Time hh:mm:ss
    at start of current flow
    Duration
    Duration in [s]
    from start of current flow to end of current (current flow signal)
    I
    Welding current * in [A]
    U
    Welding voltage * in [V]
    vd
    Wire speed * in [m/min]
    wfs
    Wire speed * in [ipm]
    IP
    Power * from instantaneous values in [W]
    IE
    Energy from instantaneous values in [kJ]
    across the entire weld
    I-Mot
    Motor current * in [A]
    Synid
    Characteristic number
    per weld
    Job
    EasyJob number
    per weld seam
    Process
    Welding process
    Mode
    Operating mode
    Status
    PASS: regular welding
    IGN: Welding interrupted during the ignition phase
    Err | xxx: Welding interrupted due to a fault; the corresponding service code is documented
    Interval
    Weld seam number for "Interval" operating mode
    Signature
    Signature per weld seam number
    In each case from the main process phase;
    In the event of termination in the ignition phase, the average value in the ignition phase is stored and a identifier is output to indicate that the main process phase has been reached
    The welding data is documented as average values in the main process phase and per weld.
    2. General
    New CSV file
    A new CSV file is generated:
    • if the USB flash drive is disconnected and reconnected while the power source is on
    • If the date and time are changed
    • From 1000 welds
    • During a firmware update
    • if the USB flash drive is disconnected and reconnected to another power source
      (= change of serial number).
    2. General
    PDF report / Fronius signature
    By scanning the link on the left
    • A PDF report of the selected welding data can be created
    • The authenticity of the data can be checked and guaranteed via the Fronius signature read out with the welding data.
    https://easydocu.weldcube.com
    Activating / deactivating Easy Documentation
    Setting the date and time
    The date and time are set in the 2nd level of the service menu.
    The first parameter in the service menu is displayed.
    Select the "2nd" setup parameter using the left-hand adjusting dial
    The first parameter in the 2nd level of the service menu is displayed.
    Select the "yEA" (= year) setup parameter using the left-hand adjusting dial
    5
    To set the date and time:
    • Left-hand adjusting dial:
      Select parameter
    • Right-hand adjusting dial:
      Change values
    Setting ranges:
    yEA
    Year (20yy; 0 - 99)
    Mon
    Month (mm; 1 -1 12)
    dAY
    Day (dd; 1 - 31)
    Hou
    Hour (hh; 0 - 24)
    Min
    Minute (mm; 0 - 59)
    NOTE!
    If the power source is reset to factory settings via setup parameter FAC, the date and time remain stored.
    2. Activating / deactivating Easy Documentation
    5
      Select parameter
      Change values
    Setting ranges:
    yEA
    Year (20yy; 0 - 99)
    Mon
    Month (mm; 1 -1 12)
    dAY
    Day (dd; 1 - 31)
    Hou
    Hour (hh; 0 - 24)
    Min
    Minute (mm; 0 - 59)
    NOTE!
    Deactivating Easy Documentation
    CAUTION!
    Risk of data loss or data damage due to premature disconnection of the USB flash drive
    Do not disconnect the USB flash drive until approx. 10 seconds after the end of the last weld to ensure correct data transfer.
    1Unplug the USB flash drive from the power source
    The following appears on the power source display:
    Easy Documentation is deactivated.
    2Confirm the display by pressing the arrow key
    Setup settings
    Setup menu
    General remarks
    The Setup menu provides simple access to expert knowledge in the power source and to additional functions. The Setup menu can be used to make simple adjustments of the parameters to suit the various job settings.
    1. Setup settings
    Setup menu
    General remarks
    1. Setup settings
    2. Setup menu
    General remarks
    1. Setup settings
    2. Setup menu
    Operation
    Access to the setup menu is described based on the MIG/MAG standard synergic welding process.
    Access is the same for the other welding processes.
    Accessing the Setup menu
    Use the "Process" button to select the "MIG/MAG standard synergic welding" process
    The control panel is now in the Setup menu for the "MIG/MAG standard synergic welding" process - the last setup parameter that was selected is displayed.
    Changing welding parameters
    Select the desired setup parameter using the left-hand adjusting dial
    Alter the setup parameter value using the right-hand adjusting dial
    Exiting the Setup menu
    1. Setup settings
    2. Setup menu
    Setup parameters for MIG/MAG standard manual welding
    "Min." and "max." are used for setting ranges that differ according to power source, welding program, etc.
    GPr
    Gas pre-flow time
    Unit: s
    Setting range: 0 - 9.9
    Factory setting: 0.1
    GPo
    Gas post-flow time
    Unit: s
    Factory setting: 0.5
    Fdi
    Feeder inching speed
    Unit: m/min (ipm)
    Setting range: 1 - max. (39.37 - max.)
    Factory setting: 10 (393.7)
    bbc
    Burn-back time correction
    Burn-back time effect due to a delayed switch-off of the welding current after the wire electrode stops being fed forward. A ball forms on the wire electrode.
    Unit: s
    Setting range: AUt, 0 - 0.3
    Factory setting: AUt
    IGC
    Ignition current
    Unit: A
    Setting range: 100 - 650
    Factory setting: 500
    Ito
    Length of wire that is fed before the safety cut-out trips
    Unit: mm (in.)
    Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94)
    Factory setting: OFF
    NOTE!
    The Ito function (wire length up to safety cut-out) is a safety function.
    The length of wire that is fed before the safety cut-out trips may differ from the pre-set wire length, particularly when the wire is being fed at fast wire speeds.
    SPt
    Unit: s
    Setting range: 0.3 - 5
    Factory setting: 0.3
    SPb
    Interval pause time
    Unit: s
    Setting range: OFF, 0.3 - 10 (in 0.1 s increments)
    Int
    Interval
    Displayed only if a value has been set for SPb
    Unit: -
    Setting range: 2T (2-step), 4T (4-step)
    Factory setting: 2T (2-step)
    FAC
    Reset power source to factory settings
    Press and hold down one of the "Parameter selection" buttons for 2 s to restore the factory settings
    - when "PrG" appears on the digital display, the power source has been reset
    IMPORTANT! When the power source is reset, all personal settings in the Setup menu are lost.
    Operating points that were saved using the "Save" buttons are retained when the power source is reset. The functions in the second level of the Setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito).
    2nd
    Second level of the Setup menu (see "Setup menu - level 2")
    1. Setup settings
    2. Setup menu
    Setup parameters for MIG/MAG standard synergic welding
    GPr
    Gas pre-flow time
    Unit: s
    GPo
    Gas post-flow time
    Unit: s
    SL
    Slope (special 4-step mode only)
    Unit: s
    I-S
    I (current) - Starting - Starting current (special 4-step mode only)
    Unit: % (of welding current)
    Setting range: 0 - 200
    Factory setting: 100
    I-E
    I (current) - End: Final current (special 4-step mode only)
    Factory setting: 50
    t-S
    t (time) - Starting - Starting current duration (special 4-step mode only)
    Unit: s
    Setting range: OFF, 0.1 - 9.9
    t-E
    t (time) - End: Final current duration (special 4-step mode only)
    Unit: s
    Fdi
    Feeder inching - feeder inching speed
    Unit: m/min (ipm)
    bbc
    Burn-back time correction - burn-back effect
    Wire burn-back effect through wire withdrawal at end of welding, regardless of the selected characteristic
    Unit: s
    Setting range: Aut, 0 - 0.3
    Factory setting: Aut
    Ito
    Ignition time-out function - length of wire that is fed before the safety cut-out trips
    Unit: mm (in.)
    NOTE!
    The "Ignition time-out" function (ito) is a safety function.
    SPt
    Spot time - spot / stitch welding time
    Unit: s
    Setting range: OFF, 0.1 - 5
    SPb
    Spot break - stitch pause time
    Unit: s
    Setting range: OFF, 0.1 - 10 (in 0.1 s increments)
    FAC
    - when "PrG" appears on the digital display, the power source has been reset.
    When the power source is reset, operating points that were saved using the "Save" buttons are not deleted, but are retained in the memory. The functions in the second level of the Setup menu (2nd) are also not deleted. Exception: Ignition time-out function parameter (ito).
    2nd
    Second level of the set-up menu (see "Set-up menu - Level 2")
    1. Setup settings
    2. Setup menu
    Setup parameters for MMA welding
    IMPORTANT! If you reset the power source using the FAC factory setup parameter, the hot-current time (Hti) and HotStart current (HCU) setup parameters are also reset.
    HCU
    HotStart current
    Unit: %
    Setting range: 100 - 200
    Factory setting: 150
    Hti
    Hot current time
    Unit: s
    Setting range: 0 - 2.0
    ASt
    Anti-stick
    Unit: -
    Setting range: On, OFF
    AAG
    Gouging (Arc Air Gauging)
    Arc air gouging with a carbon electrode, e.g., for joint preparation
    Unit: -
    Setting range: on / oFF
    Factory setting: oFF
    FAC
    Press and hold down one of the "Parameter selection" buttons for 2 s to restore the factory settings - when "PrG" appears on the digital display, the power source has been reset.
    IMPORTANT! When the power source is reset, all personal settings are lost.
    2nd
    1. Setup settings
    Setup menu - Level 2
    Operation (level 2 Setup menu)
    To access the Level 2 Setup menu:
    The control panel is now in the second level of the setup menu for the "MIG/MAG standard synergic welding" process - the last setup parameter that was selected is displayed.
    A parameter is displayed in the first level of the Setup menu.
    1. Setup settings
    2. Setup menu - Level 2
    1. Setup settings
    Parameters for MIG/MAG welding in the Setup menu level 2
    C-C
    Cooling unit Control
    (only with connected cooling unit)
    Unit: -
    Setting range: Aut, On, OFF
    Aut: The cooling unit cuts out after a 2-minute welding off-time.
    IMPORTANT! If the coolant temperature and flow monitoring options have been installed in the cooling unit, the cooling unit cuts out as soon as the return-flow temperature drops below 50 °C, but at the earliest after a 2-minute welding off-time.
    On: The cooling unit is always ON
    OFF: The cooling unit is always OFF
    IMPORTANT! If the FAC welding parameter is used, the C-C parameter is not reset to the factory setting. If the MMA welding process is selected, the cooling unit is always switched off, even if the switch is in the "On" position.
    C-t
    Cooling Time
    Time from when flow monitoring is triggered until the "no | H2O" service code is output. For example, if there are air bubbles in the cooling system, the cooling unit will not cut out until the end of this preset time.
    Unit: s
    Setting range: 5 - 25
    Factory setting: 10
    IMPORTANT! Every time the power source is switched on, the cooling unit carries out a test run for 180 seconds.
    SEt
    Setting - country-specific setting (Standard/USA), etc. Std/US
    Unit: -
    Setting range: Std, US (Standard/USA)
    Factory setting:
    Standard version: Std (measurements: cm/mm)
    USA version: US (measurements: inches)
    r
    r (resistance) - welding circuit resistance (in mOhm)
    see "Measuring welding circuit resistance r"
    L
    L (inductivity) - welding circuit inductivity (in microhenry)
    see "Displaying welding circuit inductivity L"
    EnE
    Real Energy Input – electrical energy of the arc relative to the welding speed
    Unit: kJ
    Setting range: ON / OFF
    Since the full range of values (1 kJ - 99999 kJ) cannot be displayed on the three-digit display, the following display format has been selected:
    Value in kJ / indicator on display:
    1 to 999 / 1 to 999
    1000 to 9999 / 1.00 to 9.99 (without "ones" digit, e.g. 5270 kJ -> 5.27)
    10000 to 99999 / 10.0 to 99.9
    (without "ones" and "tens" digits, e.g. 23580 kJ -> 23.6)
    ALC
    Arc Length Correction - correction of the arc length via the welding voltage
    The arc length depends on the welding voltage. The welding voltage can be adjusted to suit individual needs in Synergic operation.
    If the ALC parameter is set to "OFF", the welding voltage cannot be adjusted. The welding voltage is automatically determined by the selected welding current or wire speed. If the arc length correction is adjusted, the voltage changes, but the welding current and wire speed remain the same. When setting the arc length correction using the adjusting dial, the left display is used for the correction value of the arc length. The welding voltage value on the right display changes simultaneously. Afterwards the left display shows the original value, e.g. welding current.
    Ejt
    EasyJob Trigger - for activating / deactivating the switching of EasyJobs by means of the torch trigger
    Unit: -
    Function with MIG/MAG torch trigger
    Press torch trigger briefly (< 0.5 s)
    No welding operation:
    • All MIG/MAG EasyJobs are switched through in succession.
    • If no EasyJob is selected, the torch trigger functions normally.
    • If no MIG/MAG EasyJob is selected, no change is made.
    During welding:
    • Switching through MIG/MAG EasyJobs with the same operating mode (4-step, special 4-step mode, 4-step stitch welding) and with the same welding process.
    • Switching is not possible during spot welding.
    Function with MIG/MAG Up/Down button
    • If EasyJob is selected, the EasyJob is changed; otherwise the welding current is changed.
    During welding:
    • Switching through MIG/MAG EasyJobs with the same operating mode (2-step, 4-step, special 4-step mode, 4-step stitch welding) and with the same welding process.
    • Switching back is possible.
    1. Setup settings
    Parameters for manual metal arc (MMA) welding in the Setup menu level 2
    r
    See "Measuring welding circuit resistance r" from page (→).
    L
    see "Displaying welding circuit inductivity L" from page (→).
    1. Setup settings
    General
    Measuring the welding circuit resistance makes it possible to have a consistent welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
    The calculated welding circuit resistance is shown on the display.
    r = welding circuit resistance in milliohm (mOhm)
    If the welding circuit resistance has been measured correctly, the set welding voltage will correspond exactly to the welding voltage at the arc. If you manually measure the voltage on the output jacks of the power source, this voltage will be higher than the welding voltage at the arc - that is, higher by the same amount as the voltage drop of the hosepack.
    The welding circuit resistance depends on the hosepack used:
    • If the length or cross-sectional area of the hosepack has changed, measure the welding circuit resistance again
    • Measure the welding circuit resistance for every welding process separately with the appropriate welding power-leads
    1. Setup settings
    2. Measuring welding circuit resistance r
    General
    1. Setup settings
    Measuring welding circuit resistance (MIG/MAG welding)
    NOTE!
    Risk of incorrect measurement of the welding circuit resistance.
    This may negatively affect the welding result.
    Ensure that the workpiece in the area of the earthing clamp provides an optimal contact surface (cleaned surface, free from rust, etc.).
    1Ensure that the MANUAL or SYNERGIC process has been selected
    2Establish a grounding (earthing) connection to the workpiece
    3Access the Level 2 (2nd) Setup menu
    4Select parameter "r"
    5Remove the gas nozzle from the welding torch
    6Screw on the contact tip
    7Make sure the wire electrode does not protrude from the contact tip
    NOTE!
    Ensure that the workpiece provides an optimal contact surface for the contact tip (cleaned surface, free from rust, etc.).
    8Place the contact tip flush against the workpiece surface
    9Press the torch trigger briefly
    • The welding circuit resistance is calculated. "run" is shown on the display during the measurement
    The measurement is finished when the welding circuit resistance is shown on the display in mOhm ( for example, 11.4).
    10Fit the gas nozzle back onto the welding torch
    1. Setup settings
    Retrieving the welding circuit inductivity L
    General
    Laying of the hosepacks has a significant effect on welding circuit inductivity and therefore affects the welding process. It is important to lay the hosepacks correctly in order to obtain the best possible welding result.
    1. Setup settings
    2. Retrieving the welding circuit inductivity L
    General
    1. Setup settings
    The setup parameter "L" is used to display the most recently calculated welding circuit inductivity. The welding circuit inductivity is calibrated at the same time as the welding circuit resistance is measured. Detailed information can be found in the "Measuring welding circuit resistance" section.
    1Access the Level 2 (2nd) Setup menu
    2Select parameter "L"
    The most recently calculated welding circuit inductivity L is shown on the right-hand digital display.
    L ... Welding circuit inductivity (in microhenry)
    1. Setup settings
    Laying the hosepacks correctly
    Troubleshooting and maintenance
    Troubleshooting
    General
    The devices are equipped with an intelligent safety system. This means that to a large extent it has been possible to dispense with melting-type fuses. Melting-type fuses therefore no longer need to be replaced. After a possible malfunction has been remedied, the device is ready for use again.
    1. Troubleshooting and maintenance
    Troubleshooting
    General
    2. Troubleshooting
    General
    2. Troubleshooting
    Safety
    WARNING!
    WARNING!
    WARNING!
    Danger due to insufficient ground conductor connection.
    The housing screws provide a suitable ground conductor connection for grounding the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    2. Troubleshooting
    Fault diagnosis
    Make a note of the serial number and configuration of the device and contact our After-Sales Service team with a detailed description of the error, if
    • errors occur that are not listed below
    • the troubleshooting measures listed are unsuccessful
    Welding machine does not function
    Mains switch is on, but indicators are not lit up
    Cause:There is a break in the mains lead; the mains plug is not plugged in
    Remedy:Check the mains lead, ensure that the mains plug is plugged in
    Cause:Mains socket or mains plug faulty
    Remedy:Replace faulty parts
    Cause:Mains fuse protection
    Remedy:Change the mains fuse protection
    Cause:Short circuit on the 24 V supply of SpeedNet connection socket or external sensor
    Remedy:Unplug connected components
    Nothing happens when the torch trigger is pressed
    Welding machine mains switch is ON and indicators are lit up
    Cause:Only for welding torches with an external control plug: The control plug is not plugged in
    Remedy:Plug in the control plug
    Cause:Welding torch or welding torch control line is faulty
    Remedy:Replace welding torch
    Power source mains switch is on, power source ON indication is lit up on the power source, indications on wire-feed unit are not lit up
    Cause:The interconnecting hosepack is faulty or not connected properly
    Remedy:Check interconnecting hosepack
    No welding current
    Mains switch is on, one of the overtemperature service codes "to" is displayed. Detailed information on the service codes "to0" to "to6" can be found in the section "Displayed service codes".
    Cause:Overload
    Remedy:Take the duty cycle into account
    Cause:Thermostatic safety cut-out has tripped
    Remedy:Wait until the power source automatically comes back on after the end of the cooling phase
    Cause:Limited supply of cooling air
    Remedy:Remove air filter on the rear of the housing from the side and clean. Ensure that the cooling air ducts are accessible.
    Cause:The fan in the power source is faulty
    Remedy:Contact After-Sales Service
    No welding current
    Welding machine mains switch is on and indicators are lit
    Cause:Grounding (earthing) connection is incorrect
    Remedy:Check the grounding (earthing) connection for correct polarity
    Cause:There is a break in the power cable in the welding torch
    No protective gas shield
    All other functions are OK
    Cause:Gas cylinder is empty
    Remedy:Change the gas cylinder
    Cause:The gas pressure regulator is faulty
    Remedy:Replace the gas pressure regulator
    Cause:Gas hose is not fitted or is damaged
    Remedy:Fit or change the gas hose
    Cause:Welding torch is faulty
    Remedy:Change the welding torch
    Cause:Gas solenoid valve is faulty
    Irregular wire feed speed
    Cause:Braking force has been set too high
    Remedy:Loosen the brake
    Cause:Hole in the contact tip is too narrow
    Remedy:Use a suitable contact tip
    Cause:Faulty inner liner in welding torch
    Remedy:Check the inner liner for kinks, dirt, etc. and replace if necessary
    Cause:The feed rollers are not suitable for the wire electrode being used
    Remedy:Use suitable feed rollers
    Cause:Feed rollers have the wrong contact pressure
    Remedy:Optimise the contact pressure
    Wirefeed problems
    when using applications with long welding torch hosepacks
    Cause:Incorrect arrangement of welding torch hosepack
    Remedy:Arrange the welding torch hosepack in as straight a line as possible, avoiding bends
    Welding torch becomes very hot
    Cause:Welding torch is inadequately dimensioned
    Remedy:Observe the duty cycle and loading limits
    Cause:Only on water-cooled systems: inadequate coolant flow
    Remedy:Check coolant level, coolant flow, for coolant contamination, etc. For further information refer to the cooling unit operating instructions
    Cause:The distance from the workpiece is too small
    Remedy:Increase stickout
    Poor weld properties
    Cause:Incorrect welding parameters
    Remedy:Check the settings
    Cause:Poor ground earth connection
    Remedy:Ensure good contact to workpiece
    Cause:Inadequate or no shielding gas
    Remedy:Check the pressure regulator, gas hose, gas solenoid valve, torch gas connection, etc.
    Cause:Welding torch is leaking
    Remedy:Change welding torch
    Cause:Wrong contact tip, or contact tip is worn out
    Remedy:Replace contact tip
    Cause:Wrong wire alloy or wrong wire diameter
    Remedy:Check the wire electrode that has been inserted
    Remedy:Check weldability of the base material
    Cause:The shielding gas is not suitable for this wire alloy
    Remedy:Use the correct shielding gas
    Cause:Contaminated gas nozzle
    Remedy:Clean the gas nozzle, remove any welding spatter
    2. Troubleshooting
    If an error message that is not described here appears on the displays, proceed as follows to resolve the problem:
    1Turn the power source mains switch to the "O" position
    2Wait 10 seconds
    3Move the mains switch to the I position
    If the error occurs again despite several attempts to eliminate it, or if the troubleshooting measures listed here are unsuccessful.
    1Make a note of the error message displayed
    2Note down the configuration of the power source
    3Contact our After-Sales Service team with a detailed description of the error
    ESr | 20
    Cause:The selected cooling unit is not compatible with the power source
    Remedy:Connect compatible cooling unit
    Cause:An invalid welding process was called up on the robot interface (no. 37) or an empty flag was selected (no. 32)
    Remedy:Call up a valid welding process or select assigned "Save" button
    ELn | 8
    Cause:The connected wire-feed unit is not supported
    Remedy:Connect supported wire-feed unit
    ELn | 12
    Cause:Different control panels for selecting materials are in the system
    Remedy:Connect similar control panels to select materials
    ELn | 13
    Cause:Invalid change of welding process during welding
    Remedy:During welding do not carry out any illegal change of the welding process, reset error message by pressing any button
    ELn | 14
    Cause:More than only one robot interface is connected
    Remedy:Only one robot interface may be connected, check the system configuration
    ELn | 15
    Cause:More than only one remote control unit is connected
    Remedy:Only one remote control unit may be connected, check the system configuration
    Err | IP
    Cause:The power source control has detected a primary overvoltage
    Remedy:Check the mains voltage.
    If the service code is still present, turn off the power source, wait 10 seconds, and then turn on the power source.
    If the fault persists, contact After-Sales Service
    Err | PE
    Cause:The earth current watchdog has triggered the safety cut-out of the power source.
    Remedy:Switch off the power source
    Place the power source on an insulating surface
    Connect the grounding (earthing) cable to a section of the workpiece that is closer to the arc
    Wait for 10 seconds and then switch the power source on again
    If you have tried this several times and the error keeps recurring, contact After-Sales Service
    Err | Ur
    Cause:If the VRD option is available, the open circuit voltage limit of 35 V has been exceeded.
    Remedy:Switch off power source
    no | UrL
    Cause:The VRD option has tripped too early.
    Remedy:Check whether all welding power-leads and control lines are connected.
    Wait 10 seconds and switch the power source back on again
    If the error occurs again - contact After Sales Service.
    E-Stop
    Cause:"External stop" has tripped
    Remedy:Remedy the event that triggered the external stop
    -St | oP-
    Cause:At the robot interface the flag was not deleted by the robot
    Remedy:Delete the signal robot ready at the robot interface
    PHA | SE1
    Cause:The power source is operated in single-phase mode.
    Remedy:-
    PHA | SE3
    Cause:The power source is operated in 3-phase mode
    Remedy:-
    Err | 51
    Cause:Mains undervoltage: The mains voltage has fallen below the tolerance range
    Remedy:Check the mains voltage, if the error keeps recurring, contact the After-Sales Service
    Err | 52
    Cause:Mains overvoltage: The mains voltage has risen above the tolerance range
    EFd 5
    Cause: Incorrect wire-feed unit connected
    Remedy:Connect correct wire-feed unit
    EFd 8
    Cause: Overtemperature on the wire-feed unit
    Remedy:Allow wire-feed unit to cool down
    EFd | 81, EFd | 83
    Cause:Fault in the wire feed system (overcurrent in wire-feed unit drive)
    Remedy:Arrange the hosepack in as straight a line as possible; check that there are no kinks or dirt in the inner liner; check the contact pressure on the 4 roller drive
    Cause:Wire-feed unit motor is sticking or defective
    Remedy:Check the wire-feed unit motor or contact After-Sales Service
    to0 | xxx
    Note: xxx stands for a temperature value
    Cause:Overtemperature in the primary circuit of the power source
    Remedy:Allow power source to cool down, check air filter and clean if necessary, check that fan is on
    to1 | xxx
    Cause:Overtemperature on the booster located in the power source
    to2 | xxx
    Cause:Overtemperature in the secondary circuit of the power source
    Remedy:Allow power source to cool down, check that fan is on
    to3 | xxx
    Remark: xxx stands for a temperature value
    Cause:Overtemperature in the wire-feed unit motor
    to4 | xxx
    Cause:Overtemperature in welding torch
    Remedy:Allow welding torch to cool down
    to5 | xxx
    Cause:Overtemperature in cooling unit
    Remedy:Allow cooling unit to cool down, check that fan is on
    to6 | xxx
    Cause:Overtemperature at the transformer of the power source
    to7 | xxx
    Cause:Overtemperature in the power source
    Remedy:Allow power source to cool down, check air filter and clean if necessary, check whether the fan is running
    tu0 | xxx
    Cause:Undertemperature in the power source primary circuit
    Remedy:Place power source in a heated room and allow to warm up
    tu1 | xxx
    Cause:Undertemperature on the booster located in the power source
    Remedy:Place power source in a heated room and allow it to warm up
    tu2 | xxx
    Cause:Undertemperature in the power source secondary circuit
    tu3 | xxx
    Cause:Undertemperature in the wire-feed unit motor
    Remedy:Place wire-feed unit in a heated room and allow to warm up
    tu4 | xxx
    Cause:Undertemperature in the welding torch
    Remedy:Place welding torch in a heated room and allow to warm up
    tu5 | xxx
    Cause:Undertemperature in the cooling unit
    Remedy:Place cooling unit in a heated room and allow to warm up
    tu6 | xxx
    Cause:Undertemperature on the transformer of the power source
    tu7 | xxx
    no | H2O
    Cause: Coolant flow rate too low
    Remedy:Check coolant flow rate and cooling unit, including cooling circuit (for minimum coolant flow, see "Technical Data" section in the device operating instructions)
    hot | H2O
    Cause: The coolant temperature is too high
    Remedy:Allow cooling unit and cooling circuit to cool down, until "hot | H2O" is no longer displayed. Open the cooling unit and clean the cooler, check fan is working properly. Robot interface or field bus coupler: before resuming welding, set the "Source error reset" signal.
    no | Prg
    Cause:No preconfigured program has been selected
    Remedy:Select a configured program
    no | IGn
    Cause: "Ignition time-out" function is active; current did not start flowing before the length of wire specified in the set-up menu had been fed. The power source safety cut-out has tripped
    Remedy:Shorten the free wire end, press the torch trigger again; clean the workpiece surface; if necessary, set the "Ito" parameter in the Setup menu
    EPG | 17
    Cause: The welding program selected is invalid
    Remedy:Select valid welding program
    EPG | 29
    Cause: The required wire-feed unit is not available for the selected characteristic
    Remedy:Connect correct wire-feed unit, check plug connections for the hosepack
    EPG | 35
    Cause: Measurement of the welding circuit resistance failed
    Remedy:Check grounding cable, current cable or hosepack and replace if necessary; remeasure welding circuit resistance
    no | GAS
    Cause: The Gas watchdog option has detected that there is no gas pressure
    Remedy:Connect a new gas cylinder or open the gas cylinder valve/pressure regulator, restart "Gas watchdog" option, reset "no | GAS" error message by pressing any button.
    2. Troubleshooting
    Displayed service codes in connection with OPT Easy Documentation
    no | dAt
    Welding is not possible.
    Cause:Date and time are not set on the power source
    Remedy:To reset the service code, press the arrow key;
    Set the date and time in the 2nd level of the service menu;
    see page (→)
    bAt | Lo
    Welding is possible
    Cause:The battery of OPT Easy Documentation is low
    Contact service (to change the battery)
    bAt | oFF
    Cause:The battery of the OPT Easy Documentation is empty
    Remedy:To reset the service code, press the arrow key - the display shows no | dAt;
    Contact service (to change the battery);
    After changing the battery, set the date and time in the 2nd level of the service menu;
    see page (→)
    Err | doc
    Cause:Error writing data;
    Internal documentation error;
    Communication error;
    Remedy:Switch the power source off and back on
    Err | USb
    Cause:Invalid file system on USB flash drive;
    General USB error
    Remedy:Unplug USB flash drive
    USB | full
    Cause:The plugged in USB flash drive is full
    Remedy:Unplug USB flash drive, plug in new USB flash drive
    Care, maintenance and disposal
    General
    Under normal operating conditions, the welding system requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the welding system remains in a usable condition for many years.
    2. Care, maintenance and disposal
    General
    Safety
    WARNING!
    Danger from electric current.
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Fully read and understand this document.
    At every start-up
    • Check mains plug, mains cable, welding torch, interconnecting hosepack and ground earth connection for damage
    • Check that the device has an all-round clearance of 0.5 m (1 ft. 8 in.) to ensure that cooling air can flow in and out freely
    NOTE!
    The air inlets and outlets must never be covered, not even partially.
    Every 2 months
    CAUTION!
    Risk of damage.
    The air filter must only be fitted when dry.
    If required, clean air filter using dry compressed air or by washing it.
    Every 6 months
    CAUTION!
    Danger due to the effect of compressed air.
    Do not bring the air nozzle too close to electronic components.
    1Dismantle device side panels and clean inside of device with dry, reduced compressed air
    2If a lot of dust has accumulated, clean the cooling air ducts
    WARNING!
    An electric shock can be fatal!
    Risk of electric shock from improperly connected ground cables and equipment grounds.
    When reassembling the side panels, make sure that grounding cables and equipment grounds are properly connected.
    Disposal
    Appendix
    Average consumption values during welding
    Average wire electrode consumption during MIG/MAG welding
    Average wire electrode consumption at a wire speed of 5 m/min
    1.0 mm wire electrode diameter
    1.2 mm wire electrode diameter
    1.6 mm wire electrode diameter
    Steel wire electrode
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    Aluminium wire electrode
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    Average wire electrode consumption at a wire speed of 10 m/min
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    2. Average consumption values during welding
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Appendix
    Average shielding gas consumption during MIG/MAG welding
    Wire electrode diameter
    1.0 mm
    1.2 mm
    1.6 mm
    2.0 mm
    2 x 1.2 mm (TWIN)
    Average consumption
    10 l/min
    12 l/min
    16 l/min
    20 l/min
    24 l/min
    1. Appendix
    Average shielding gas consumption during TIG welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    Technical data
    Special voltages
    For devices designed for special voltages, the technical data on the rating plate applies.
    For all machines with a permitted mains voltage of up to 460 V: The standard mains plug allows the user to operate with a mains voltage of up to 400 V. For mains voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
    1. Appendix
    2. Technical data
    Special voltages
    1. Appendix
    2. Technical data
    Explanation of the term "duty cycle"
    Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
    NOTE!
    The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
    If the ambient temperature is higher, either the ED or output must be reduced accordingly.
    Example: Welding at 150 A at 60% ED
    • Welding phase = 60% of 10 minutes = 6 minutes
    • Cooling phase = remaining time = 4 minutes
    • After the cooling phase, the cycle begins again.
    If the device is to be continuously operated without stopping:
    1Look in the technical data for a ED value of 100% for the current ambient temperature.
    2Reduce the output or amperage in line with this value so that the device can remain in use without observing a cooling phase.
    1. Appendix
    2. Technical data
    TSt 3500 Syn
    Mains voltage (U1)
    3 x
    380 V
    400 V
    460 V
    Max. effective primary current (I1eff)
    15.0 A
    14.4 A
    12.6 A
    Max. primary current (I1max)
    23.6 A
    22.7 A
    19.8 A
    35 A slow-blow
    Mains voltage tolerance
    -10 / +15%
    Grid frequency
    50 / 60 Hz
    Cos phi (1)
    0.99
    Max. permissible mains impedance Zmax on PCC1)
    77 mOhm
    Recommended earth-leakage circuit breaker
    Type B
    Welding current range (I2)
    MIG / MAG
    10 - 350 A
    Rod electrode
    10 - 350 A
    Welding current at
    10 min / 40 °C (104 °F)
    40%
    60%
    100%
    350 A
    300 A
    250 A
    Output voltage range according to standard characteristic (U2)
    MIG / MAG
    14.5 - 31.5 V
    Rod electrode
    20.4 - 35.0 V
    Open circuit voltage (U0 peak / U0 r.m.s)
    60 V
    Apparent power
    at 400 V AC / 350 A / 40 % ED2)
    15,67 kVA
    Degree of protection
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    Overvoltage category
    III
    Pollution level according to IEC60664
    Safety symbols
    S, CE, CSA
    Dimensions l x w x h
    747 x 300 x 497 mm
    29.4 x 11.8 x 19.6 in.
    Weight
    29 kg
    63.5 lb.
    Max. noise emission (LWA)
    72 dB (A)
    Idle state power consumption at 400 V
    35,7 W
    Power source efficiency at 350 A / 34 V
    91 %
    1)
    Interface to a 230/400 V, 50 Hz public grid
    2)
    ED = duty cycle
    1. Appendix
    2. Technical data
    TSt 3500 MV Syn
    Mains voltage (U1)
    3 x
    200 V
    230 V
    24.1 A
    20.8 A
    38.1 A
    32.9 A
    35 A slow-blow
    Mains voltage (U1)
    3 x
    400 V
    460 V
    11.9 A
    10.6 A
    18.7 A
    16.7 A
    35 A slow-blow
    -10 / +15%
    Grid frequency
    50 / 60 Hz
    Cos phi (1)
    0.99
    122 mOhm
    Type B
    MIG / MAG
    10 - 350 A
    Rod electrode
    10 - 350 A
    Welding current at
    40%
    60%
    100%
    U1: 200 - 460 V
    350 A
    300 A
    250 A
    MIG / MAG
    14.5 - 31.5 V
    Rod electrode
    20.4 - 35 V
    50 V
    Apparent power
    at 200 V AC / 350 A / 40 % ED2)
    13,18 kVA
    12,96 kVA
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    III
    Safety symbols
    S, CE, CSA
    747 x 300 x 497 mm
    Weight
    37.3 kg
    82 lb.
    74 dB (A)
    35,7 W
    91 %
    1)
    2)
    ED = duty cycle
    1. Appendix
    2. Technical data
    TSt 5000 Syn
    Mains voltage (U1)
    3 x
    380 V
    400 V
    460 V
    27 A
    25.9 A
    23.2 A
    42.7 A
    41.0 A
    36.7 A
    35 A slow-blow
    -10 / +15%
    Grid frequency
    50 / 60 Hz
    Cos phi (1)
    0.99
    11 mOhm
    Type B
    MIG / MAG
    10 - 500 A
    Rod electrode
    10 - 500 A
    Welding current at
    40%
    60%
    100%
    500 A
    420 A
    360 A
    MIG / MAG
    14.3 - 39 V
    Rod electrode
    20.2 - 40 V
    65 V
    Apparent power
    at 400 V AC / 500 A / 40 % ED2)
    28,36 kVA
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    III
    Safety symbols
    S, CE, CSA
    747 x 300 x 497 mm
    Weight
    32.3 kg
    71.2 lb.
    74 dB (A)
    31,2 W
    Power source efficiency at 500 A / 40 V
    91 %
    1)
    2)
    ED = duty cycle
    1. Appendix
    2. Technical data
    TSt 5000 MV Syn
    Mains voltage (U1)
    3 x
    200 V
    230 V
    39.5 A
    36.3 A
    66.7 A
    57.4 A
    63 A slow-blow
    Mains voltage (U1)
    3 x
    400 V
    460 V
    20.6 A
    18.1 A
    32.5 A
    28.6 A
    35 A slow-blow
    -10 / +15%
    Grid frequency
    50 / 60 Hz
    Cos phi (1)
    0.99
    63 mOhm
    Type B
    MIG / MAG
    10 - 500 A
    Rod electrode
    10 - 500 A
    Welding current at
    35%
    60%
    100%
    U1: 200 V
    500 A
    420 A
    360 A
    Welding current at
    40%
    60%
    100%
    U1: 208 - 460 V
    500 A
    420 A
    360 A
    MIG / MAG
    14.3 - 39 V
    Rod electrode
    20.2 - 40 V
    57 V
    Apparent power
    at 200 V AC / 500 A / 40 % ED2)
    23,08 kVA
    22,49 kVA
    IP 23
    Type of cooling
    AF
    Insulation class
    B
    III
    Safety symbols
    S, CE, CSA
    747 x 300 x 497 mm
    Weight
    43.6 kg / 96.1 lb.
    75 dB (A)
    82,7 W
    90 %
    1)
    2)
    ED = duty cycle
    1. Appendix
    2. Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address.
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    1. Appendix
    Welding program tables
    link_horizontalLink copied
    TransSteel 3500 Syn - Euro welding program tables
    Welding programs are active if
    • the Setup parameter "SEt" is set to "Std" (Standard),
      or
    • the VR 5000 Remote wirefeeder is fitted with the Synergic Steel control panel option.
    Welding program database: UID 3431
    Welding program table on the power source control panel
    Welding program table on the Synergic Steel (VR 5000 Remote) control panel
    * Diameter = 1,2 mm (0.45 in.)
    1. Appendix
    2. Welding program tables
      or
    1. Appendix
    TransSteel 5000 Syn - Euro welding program tables
      or
    Welding program database: UID 3430
    1. Appendix
    TransSteel 3500 Syn - US welding program tables
    • the Setup parameter "SEt" is set to "US" (USA),
      or
    • the VR 5000 Remote wirefeeder is fitted with the Synergic US control panel option.
    Welding program table on the Synergic US (VR 5000 Remote) control panel
    1. Appendix
    TransSteel 5000 Syn - US welding program tables
      or
    1. Appendix
    TransSteel 3500 Yard welding program tables
    Welding programs are active if a VR 5000 Remote wirefeeder with the Synergic YARD control panel option is in the system.
    In this case, the welding program display on the power source is deactivated.
    The welding program is only shown on the VR 5000 Remote.
    Welding program table on the Synergic YARD (VR 5000 Remote) control panel
    * Diameter = 1.2 mm (0.45 in.)
    1. Appendix
    TransSteel 5000 Yard welding program tables
    In this case, the welding program indication on the power source is deactivated.
    1. Appendix
    Standard value tables for MIG/MAG standard manual welding
    Settings tables
    • Shielding gas: Argon + CO2 *
    • Material: G3 Si 1
    • Wire diameter: 0.8 mm (.03 in.)
    • Ignition current: 400 A
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    2.1 m/min (82.68 ipm)
    13.7 V
    1 mm (.04 in.)
    2.8 m/min (110.24 ipm)
    15.8 V
    1.5 mm (.06 in.)
    5.9 m/min (232.28 ipm)
    17 V /
    2 mm (.08 in.)
    6.5 m/min (255.91 ipm)
    18 V
    3 mm (.12 in.)
    10.8 m/min (425.20 ipm)
    20 V
    4 mm (.16 in.)
    14 m/min (551.18 ipm)
    23.4 V
    5 mm (.2 in.)
    16.7 m/min (657.48 ipm)
    27 V
    0
    6 mm (.24 in.)
    19 m/min (748.03 ipm)
    27.8 V
    0
    8 mm (.31 in.)
    21 m/min (826.77 ipm)
    30.4 V
    0
    10 mm (.39 in.)
    23 m/min (905.51 ipm)
    32.6 V
    0
    12 mm (.47 in.)
    34 V
    0
    • Material: G3 Si 1
    • Wire diameter: 0.9 mm (.035 in.)
    • Ignition current: 450 A
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    1.6 m/min (62.99 ipm)
    13.3 V
    1 mm (.04 in.)
    1.9 m/min (74.8 ipm)
    14 V
    1.5 mm (.06 in.)
    2.5 m/min (98.43 ipm)
    15 V
    2 mm (.08 in.)
    4.5 m/min (177.17 ipm)
    16.5 V
    3 mm (.12 in.)
    6.2 m/min (244.09 ipm)
    17 V
    4 mm (.16 in.)
    7.5 m/min (295.28 ipm)
    19.5 V
    5 mm (.2 in.)
    11 m/min (433.07 ipm)
    24 V
    6 mm (.24 in.)
    12.4 m/min (488.19 ipm)
    25.5 V
    0
    8 mm (.31 in.)
    13 m/min (511.81 ipm)
    26 V
    0
    10 mm (.39 in.)
    16 m/min (629.92 ipm)
    28 V
    0
    12 mm (.47 in.)
    19.1 m/min (751.97 ipm)
    30 V
    0
    15 mm (.59 in.)
    22 m/min (866.14 ipm)
    32 V
    0
    20 mm (.79 in.)
    34 V
    0
    • Material: G3 Si 1
    • Wire diameter: 1.0 mm (.04 in.)
    • Ignition current: 500 A
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    14.3 V
    2.5
    1 mm (.04 in.)
    2 m/min (78.74 ipm)
    14.5 V
    2.5
    1.3 mm (.05 in.)
    14.6 V
    1.5 mm (.06 in.)
    3.1 m/min (122.05 ipm)
    15.9 V
    2 mm (.08 in.)
    16.4 V
    3 mm (.12 in.)
    17.5 V
    4 mm (.16 in.)
    18.1 V
    5 mm (.2 in.)
    26.6 V
    6 mm (.24 in.)
    27.3 V
    0
    8 mm (.31 in.)
    29.5 V
    0
    10 mm (.39 in.)
    32.5 V
    0
    12 mm (.47 in.)
    34 V
    0
    15 mm (.59 in.)
    35 V
    0
    20 mm (.79 in.)
    36.9 V
    0
    • Material: G3 Si 1
    • Wire diameter: 1.2 mm (.045 in.)
    • Ignition current: 580 A
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1 mm (.04 in.)
    15.5 V
    1.5 mm (.06 in.)
    2.4 m/min (94.49 ipm)
    16 V
    2 mm (.08 in.)
    3.5 m/min (137.8 ipm)
    17.4 V
    3 mm (.12 in.)
    4.7 m/min (185.04 ipm)
    18.5 V
    4 mm (.16 in.)
    5.6 m/min (220.47 ipm)
    19.8 V
    2.5
    5 mm (.2 in.)
    7.2 m/min (283.46 ipm)
    20.5 V
    6 mm (.24 in.)
    8.1 m/min (318.9 ipm)
    24.3 V
    8 mm (.31 in.)
    8.8 m/min (346.46 ipm)
    28 V
    0
    10 mm (.39 in.)
    9.3 m/min (366.14 ipm)
    29 V
    0
    12 mm (.47 in.)
    10.8 m/min (425.2 ipm)
    32 V
    0
    15 mm (.59 in.)
    11.5 m/min (452.76 ipm)
    33 V
    0
    20 mm (.79 in.)
    18 m/min (708.66 ipm)
    34 V
    0
    25 mm (.98 in.)
    36 V
    0
    30 mm (1.18 in.)
    37.5 V
    0
    • Material: G3 Si 1
    • Wire diameter: 1.4 mm (.06 in.)
    • Ignition current: 650 A
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1 mm (.04 in.)
    1.2 m/min (47.24 ipm)
    13.7 V
    1.5 mm (.06 in.)
    1.7 m/min (66.93 ipm)
    15 V
    2 mm (.08 in.)
    2.2 m/min (86.61 ipm)
    16 V
    3 mm (.12 in.)
    3.2 m/min (125.98 ipm)
    17 V
    4 mm (.16 in.)
    3.8 m/min (149.61 ipm)
    17.8 V
    5 mm (.2 in.)
    4.3 m/min (169.29 ipm)
    18.6 V
    6 mm (.24 in.)
    4.8 m/min (188.98 ipm)
    21.5 V
    8 mm (.31 in.)
    5.5 m/min (216.54 ipm)
    26 V
    0
    10 mm (.39 in.)
    7 m/min (275.59 ipm)
    27.5 V
    0
    12 mm (.47 in.)
    9 m/min (354.33 ipm)
    30 V
    0
    15 mm (.59 in.)
    10.3 m/min (405.51 ipm)
    31.8 V
    0
    20 mm (.79 in.)
    12.5 m/min (492.13 ipm)
    33 V
    0
    25 mm (.98 in.)
    15 m/min (590.55 ipm)
    36.8 V
    0
    30 mm (1.18 in.)
    40 V
    0
    • Material: G3 Si 1
    • Wire diameter: 1.6 mm (1/16 in.)
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1.5 mm (.06 in.)
    16 V
    2 mm (.08 in.)
    1.4 m/min (55.12 ipm)
    16.4 V
    3 mm (.12 in.)
    16.9 V
    4 mm (.16 in.)
    17.9 V
    5 mm (.2 in.)
    5.3 m/min (208.66 ipm)
    18.7 V
    6 mm (.24 in.)
    4 m/min (157.48 ipm)
    20.7 V
    8 mm (.31 in.)
    24 V
    10 mm (.39 in.)
    26.9 V
    0
    12 mm (.47 in.)
    27.2 V
    0
    15 mm (.59 in.)
    6.7 m/min (263.78 ipm)
    29.1 V
    0
    20 mm (.79 in.)
    8.5 m/min (334.65 ipm)
    31 V
    0
    25 mm (.98 in.)
    12 m/min (472.44 ipm)
    36.5 V
    0
    30 mm (1.18 in.)
    40 V
    0
    * Argon + 18 % CO2 (M21)
    • Shielding gas: CO2
    • Material: G3 Si 1
    • Wire diameter: 0.8 mm (.3 in.)
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    1.5 m/min (59.06 ipm)
    16 V
    1 mm (.04 in.)
    3 m/min (118.11 ipm)
    16.8 V
    1.5 mm (.06 in.)
    5 m/min (196.85 ipm)
    18.6 V
    2 mm (.08 in.)
    6.4 m/min (251.97 ipm)
    19.5 V
    3 mm (.12 in.)
    9.5 m/min (374.02 ipm)
    22.3 V
    4 mm (.16 in.)
    11.1 m/min (437.01 ipm)
    23.1 V
    5 mm (.2 in.)
    15.2 m/min (598.43 ipm)
    25.8 V
    6 mm (.24 in.)
    17.5 m/min (688.98 ipm)
    26.1 V
    8 mm (.31 in.)
    20 m/min (787.40 ipm)
    27 V
    0
    10 mm (.39 in.)
    28.5 V
    0
    12 mm (.47 in.)
    31.5 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    17.1 V
    1 mm (.04 in.)
    17.4 V
    1.5 mm (.06 in.)
    2.7 m/min (106.3 ipm)
    18.6 V
    2 mm (.08 in.)
    19.2 V
    3 mm (.12 in.)
    6 m/min (236.22 ipm)
    20.5 V
    4 mm (.16 in.)
    21.5 V
    5 mm (.2 in.)
    10 m/min (393.7 ipm)
    24 V
    6 mm (.24 in.)
    24.9 V
    8 mm (.31 in.)
    25.5 V
    12 mm (.47 in.)
    29.5 V
    15 mm (.59 in.)
    17 m/min (669.29 ipm)
    32 V
    0
    20 mm (.79 in.)
    34 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    16.7 V
    1 mm (.04 in.)
    2 m/min (78.74 ipm)
    17.6 V
    1.3 mm (.05 in.)
    2.6 m/min (102.36 ipm)
    18.9 V
    1.5 mm (.06 in.)
    20.4 V
    2.5
    2 mm (.08 in.)
    20.8 V
    2.5
    3 mm (.12 in.)
    21.4 V
    2.5
    4 mm (.16 in.)
    8 m/min (314.96 ipm)
    22.5 V
    2.5
    5 mm (.2 in.)
    24.8 V
    2.5
    6 mm (.24 in.)
    27.1 V
    2.5
    8 mm (.31 in.)
    28.8 V
    1.5
    10 mm (.39 in.)
    30.9 V
    0
    12 mm (.47 in.)
    20 m/min (787.4 ipm)
    33.3 V
    0
    15 mm (.59 in.)
    25 m/min (984.25 ipm)
    38.2 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    1 m/min (39.37 ipm)
    17.5 V
    1.5
    1 mm (.04 in.)
    18.0 V
    2 mm (.08 in.)
    2 m/min (78.74 ipm)
    18.8 V
    2.5
    3 mm (.12 in.)
    19.3 V
    4 mm (.16 in.)
    20.5 V
    5 mm (.2 in.)
    22.5 V
    6 mm (.24 in.)
    23 V
    8 mm (.31 in.)
    25.9 V
    12 mm (.47 in.)
    10 m/min (393.70 ipm)
    29.7 V
    15 mm (.59 in.)
    36 V
    20 mm (.79 in.)
    41 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1 mm (.04 in.)
    18.2 V
    1.5 mm (.06 in.)
    19.1 V
    2 mm (.08 in.)
    20 V
    3 mm (.12 in.)
    22.6 V
    4 mm (.16 in.)
    4.2 m/min (165.35 ipm)
    23.9 V
    5 mm (.2 in.)
    5.1 m/min (200.79 ipm)
    25.1 V
    6 mm (.24 in.)
    26.2 V
    8 mm (.31 in.)
    29.9 V
    0
    12 mm (.47 in.)
    33.9 V
    0
    15 mm (.59 in.)
    36.2 V
    0
    20 mm (.79 in.)
    38 V
    0
    25 mm (.98 in.)
    40 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1.5 mm (.06 in.)
    19.8 V
    2 mm (.08 in.)
    20.5 V
    3 mm (.12 in.)
    21.3 V
    4 mm (.16 in.)
    2.3 m/min (90.55 ipm)
    21.8 V
    5 mm (.2 in.)
    23 V
    6 mm ( .24 in.)
    23.9 V
    8 mm (.31 in.)
    3.6 m/min (141.73 ipm)
    24.9 V
    12 mm (.47 in.)
    26.5 V
    15 mm (.59 in.)
    30 V
    20 mm (.79 in.)
    7.1 m/min (279.53 ipm)
    33 V
    25 mm (.98 in.)
    40 V
    1. Appendix
    2. Standard value tables for MIG/MAG standard manual welding
    Settings tables
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    13.7 V
    1 mm (.04 in.)
    15.8 V
    1.5 mm (.06 in.)
    17 V /
    2 mm (.08 in.)
    18 V
    3 mm (.12 in.)
    20 V
    4 mm (.16 in.)
    23.4 V
    5 mm (.2 in.)
    27 V
    0
    6 mm (.24 in.)
    27.8 V
    0
    8 mm (.31 in.)
    30.4 V
    0
    10 mm (.39 in.)
    32.6 V
    0
    12 mm (.47 in.)
    34 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    13.3 V
    1 mm (.04 in.)
    14 V
    1.5 mm (.06 in.)
    15 V
    2 mm (.08 in.)
    16.5 V
    3 mm (.12 in.)
    17 V
    4 mm (.16 in.)
    19.5 V
    5 mm (.2 in.)
    24 V
    6 mm (.24 in.)
    25.5 V
    0
    8 mm (.31 in.)
    26 V
    0
    10 mm (.39 in.)
    28 V
    0
    12 mm (.47 in.)
    30 V
    0
    15 mm (.59 in.)
    32 V
    0
    20 mm (.79 in.)
    34 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    14.3 V
    2.5
    1 mm (.04 in.)
    2 m/min (78.74 ipm)
    14.5 V
    2.5
    1.3 mm (.05 in.)
    14.6 V
    1.5 mm (.06 in.)
    15.9 V
    2 mm (.08 in.)
    16.4 V
    3 mm (.12 in.)
    17.5 V
    4 mm (.16 in.)
    18.1 V
    5 mm (.2 in.)
    26.6 V
    6 mm (.24 in.)
    27.3 V
    0
    8 mm (.31 in.)
    29.5 V
    0
    10 mm (.39 in.)
    32.5 V
    0
    12 mm (.47 in.)
    34 V
    0
    15 mm (.59 in.)
    35 V
    0
    20 mm (.79 in.)
    36.9 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1 mm (.04 in.)
    15.5 V
    1.5 mm (.06 in.)
    16 V
    2 mm (.08 in.)
    17.4 V
    3 mm (.12 in.)
    18.5 V
    4 mm (.16 in.)
    19.8 V
    2.5
    5 mm (.2 in.)
    20.5 V
    6 mm (.24 in.)
    24.3 V
    8 mm (.31 in.)
    28 V
    0
    10 mm (.39 in.)
    29 V
    0
    12 mm (.47 in.)
    32 V
    0
    15 mm (.59 in.)
    33 V
    0
    20 mm (.79 in.)
    34 V
    0
    25 mm (.98 in.)
    36 V
    0
    30 mm (1.18 in.)
    37.5 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1 mm (.04 in.)
    13.7 V
    1.5 mm (.06 in.)
    15 V
    2 mm (.08 in.)
    16 V
    3 mm (.12 in.)
    17 V
    4 mm (.16 in.)
    17.8 V
    5 mm (.2 in.)
    18.6 V
    6 mm (.24 in.)
    21.5 V
    8 mm (.31 in.)
    26 V
    0
    10 mm (.39 in.)
    27.5 V
    0
    12 mm (.47 in.)
    30 V
    0
    15 mm (.59 in.)
    31.8 V
    0
    20 mm (.79 in.)
    33 V
    0
    25 mm (.98 in.)
    36.8 V
    0
    30 mm (1.18 in.)
    40 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1.5 mm (.06 in.)
    16 V
    2 mm (.08 in.)
    16.4 V
    3 mm (.12 in.)
    16.9 V
    4 mm (.16 in.)
    17.9 V
    5 mm (.2 in.)
    18.7 V
    6 mm (.24 in.)
    20.7 V
    8 mm (.31 in.)
    24 V
    10 mm (.39 in.)
    26.9 V
    0
    12 mm (.47 in.)
    27.2 V
    0
    15 mm (.59 in.)
    29.1 V
    0
    20 mm (.79 in.)
    31 V
    0
    25 mm (.98 in.)
    36.5 V
    0
    30 mm (1.18 in.)
    40 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    16 V
    1 mm (.04 in.)
    16.8 V
    1.5 mm (.06 in.)
    18.6 V
    2 mm (.08 in.)
    19.5 V
    3 mm (.12 in.)
    22.3 V
    4 mm (.16 in.)
    23.1 V
    5 mm (.2 in.)
    25.8 V
    6 mm (.24 in.)
    26.1 V
    8 mm (.31 in.)
    27 V
    0
    10 mm (.39 in.)
    28.5 V
    0
    12 mm (.47 in.)
    31.5 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    17.1 V
    1 mm (.04 in.)
    17.4 V
    1.5 mm (.06 in.)
    18.6 V
    2 mm (.08 in.)
    19.2 V
    3 mm (.12 in.)
    20.5 V
    4 mm (.16 in.)
    21.5 V
    5 mm (.2 in.)
    24 V
    6 mm (.24 in.)
    24.9 V
    8 mm (.31 in.)
    25.5 V
    12 mm (.47 in.)
    29.5 V
    15 mm (.59 in.)
    32 V
    0
    20 mm (.79 in.)
    34 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    16.7 V
    1 mm (.04 in.)
    2 m/min (78.74 ipm)
    17.6 V
    1.3 mm (.05 in.)
    18.9 V
    1.5 mm (.06 in.)
    20.4 V
    2.5
    2 mm (.08 in.)
    20.8 V
    2.5
    3 mm (.12 in.)
    21.4 V
    2.5
    4 mm (.16 in.)
    22.5 V
    2.5
    5 mm (.2 in.)
    24.8 V
    2.5
    6 mm (.24 in.)
    27.1 V
    2.5
    8 mm (.31 in.)
    28.8 V
    1.5
    10 mm (.39 in.)
    30.9 V
    0
    12 mm (.47 in.)
    33.3 V
    0
    15 mm (.59 in.)
    38.2 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    0.8 mm (.03 in.)
    1 m/min (39.37 ipm)
    17.5 V
    1.5
    1 mm (.04 in.)
    18.0 V
    2 mm (.08 in.)
    2 m/min (78.74 ipm)
    18.8 V
    2.5
    3 mm (.12 in.)
    19.3 V
    4 mm (.16 in.)
    20.5 V
    5 mm (.2 in.)
    22.5 V
    6 mm (.24 in.)
    23 V
    8 mm (.31 in.)
    25.9 V
    12 mm (.47 in.)
    29.7 V
    15 mm (.59 in.)
    36 V
    20 mm (.79 in.)
    41 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1 mm (.04 in.)
    18.2 V
    1.5 mm (.06 in.)
    19.1 V
    2 mm (.08 in.)
    20 V
    3 mm (.12 in.)
    22.6 V
    4 mm (.16 in.)
    23.9 V
    5 mm (.2 in.)
    25.1 V
    6 mm (.24 in.)
    26.2 V
    8 mm (.31 in.)
    29.9 V
    0
    12 mm (.47 in.)
    33.9 V
    0
    15 mm (.59 in.)
    36.2 V
    0
    20 mm (.79 in.)
    38 V
    0
    25 mm (.98 in.)
    40 V
    0
    • Material: G3 Si 1
    Sheet thickness
    Wire feed speed
    Welding voltage
    Dynamic
    1.5 mm (.06 in.)
    19.8 V
    2 mm (.08 in.)
    20.5 V
    3 mm (.12 in.)
    21.3 V
    4 mm (.16 in.)
    21.8 V
    5 mm (.2 in.)
    23 V
    6 mm ( .24 in.)
    23.9 V
    8 mm (.31 in.)
    24.9 V
    12 mm (.47 in.)
    26.5 V
    15 mm (.59 in.)
    30 V
    20 mm (.79 in.)
    33 V
    25 mm (.98 in.)
    40 V
