The water-cooled plasma robot welding torch is designed for plasma welding and plasma brazing of materials up to a thickness of 1.5 mm (PTW 500), 3 mm (PTW 1500) and 8 mm (PTW 3500).
The welding torches have a Fronius F++ connection as standard. Various adapters are available to enable the torches to be operated with any standard plasma device. Each torch can be equipped with KD Drive, a pushed wire-feed unit or a drag gas nozzle.
The plasma robot welding torch is used in automated applications, e.g.:
IMPORTANT! Insert the tungsten electrode so that the tip protrudes approx. 10 mm out of the torch body. Slightly tighten the torch cap so that the tungsten electrode can still move inside the torch body.
IMPORTANT! Check that the tungsten electrode is adjusted correctly (see „Adjusting the tungsten electrode.
IMPORTANT! Check that the tungsten electrode is adjusted correctly (see „Adjusting the tungsten electrode“)
Water-cooled protective gas nozzles must be connected to the water connections.
Ceramic protective gas nozzles do not need any water cooling. If ceramic protective gas nozzles are being used, the two water connections must be joined together using the water stopper.
Apart from the specified plasma gas flow rate, the position of the tungsten electrode plays a crucial role in determining the loading limits.
By loading limits we mean the maximum possible welding currentThe supplied setting gage makes it easier to position the tungsten electrode.
IMPORTANT! The standard setting for measurement „x“ on the adjusting gauge depends on the diameter of the plasma nozzle. Refer to the following table when adjusting the standard setting for measurement „x“:
∅ Plasma-nozzle | „x“ | Adjusting gauge |
1.0 mm | - | - |
1.5 mm | 1.5 mm | ∅1.5 - 2 mm |
2.0 mm | 2.0 mm | ∅1.5 - 2 mm |
2.5 mm | 2.5 mm | ∅2.5 - 3 mm |
3.0 mm | 2.5 mm | ∅2.5 - 3 mm |
The plasma torch is intended exclusively for plasma welding and plasma brazing. Utilisation for any other purpose, or in any other manner, shall be deemed to be „not in accordance with the intended purpose“.
Utilisation in accordance with the „intended purpose“ also comprises
An incorrectly adjusted tungsten electrode can damage the plasma nozzle during commissioning. Adjust the tungsten electrode according to the plasma nozzle used and the application.
The plasma torch must be cooled constantly during operation.
Igniting the pilot arc without presetting the plasma gas can damage the plasma nozzle, ceramic centring tube and tungsten electrode (all wearing parts).
IMPORTANT! To reduce wear, the pilot arc should burn throughout the operation.
The following loading limits apply to the standard tungsten electrode setting (see also „Adjusting the tungsten electrode“).
IMPORTANT! Do not exceed the upper or lower limits set for plasma gas values and max. welding current during operation.
IMPORTANT! The minimum coolant flow rate is 1 l/min
This table is only valid for the PTW 500 (electrode diameter 1.0 mm; d.c. 60%):
ø Plasma nozzle | Plasma gas flow rate | Max. welding current |
0.6 mm | Min. 0.30 l/min | 15 A |
0.8 mm | Min. 0.30 l/min | 20 A |
1 mm | Min. 0.30 l/min | 28 A |
1.2 mm | Min. 0.30 l/min | 35 A |
1.4 mm | Min. 0.30 l/min | 45 A |
1.6 mm | Min. 0.30 l/min | 50 A |
1.8 mm | Min. 0.30 l/min | 50 A |
This table is only valid for the PTW 1500:
1.5 mm | Min. 0.30 l/min | 60 A |
2.0 mm | Min. 0.35 l/min | 80 A |
2.5 mm | Min. 0.45 l/min | 110 A |
3.0 mm | Min. 0.55 l/min | 130 A |
This table is only valid for the PTW 3500 in conjunction with a FK9000 cooling unit:
2.0 mm | Min. 1.0 l/min | 170 A |
2.5 mm | Min. 1.0 l/min | 190 A |
3.2 mm | Min. 1.0 l/min | 210 A |
3.5 mm | Min. 1.0 l/min | 225 A |
4.0 mm | Min. 1.0 l/min | 250 A |
Table is only valid for the PTW 3500 in conjunction with a CHILLY 15 cooling unit:
2.0 mm | Min. 1.0 l/min | 225 A |
2.5 mm | Min. 1.0 l/min | 250 A |
3.2 mm | Min. 1.0 l/min | 275 A |
3.5 mm | Min. 2.0 l/min | 300 A |
4.0 mm | Min. 2.0 l/min | 350 A |
Minimum plasma gas flow rate:
Amount of gas at which the welding arc still remains stable.
IMPORTANT! Welding using a minimum plasma gas flow places a severe load on the plasma nozzle and should be avoided.
Maximum plasma gas flow rate:
Amount of gas that makes working with the maximum welding current possible, depending on the plasma nozzle
Maximum welding current:
Welding current permitted when using a particular plasma nozzle, standard tungsten electrode setting and minimum or maximum plasma gas flow rate.
IMPORTANT! Use pure argon as plasma gas. The limit values listed above can only be obtained using pure argon.
In the case of a plasma nozzle with a diameter of 2.0 mm and a selected minimum plasma gas flow rate of 0.35 l/min, a maximum welding current of 80 A is permitted for the standard tungsten electrode setting.
Before carrying out any work on the welding torch:
Turn the mains switches of the power source and plasma device to the "0" position
Disconnect the power source and plasma device from the mains
Put up an easy-to-understand warning sign to stop anybody inadvertently switching them back on again
| Cause: | Tungsten electrode missing |
| Remedy: | Insert tungsten electrode |
| Cause: | Plasma nozzle and tungsten electrode too far apart |
| Remedy: | Position tungsten electrode correctly |
| Cause: | Plasma nozzle and tungsten electrode touching or too close (short circuit between plasma nozzle and tungsten electrode) |
| Cause: | Excessive load values |
| Remedy: | Check current and plasma gas flow rate, change plasma nozzle, reduce load |
| Cause: | Insufficient cooling |
| Remedy: | Check the current and plasma gas flow rate, check the cooling circuit, increase the plasma gas flow rate, check for wear on the nozzle connection |
Regular and preventive maintenance of the plasma welding torch are important factors in achieving problem-free operation. The plasma welding torch is subjected to high temperatures. This is why the plasma welding torch needs more frequent maintenance than other components of a welding system.
Deposits inside the plasma torch can cause high frequency arc-overs, thereby damaging the plasma torch
Dismantle the plasma torch and check for deposits/contamination
Packaging materials
| PTW 1500 |
Power range | 0.5 - 50 A |
Maximum value at 60 % d.c. | 50 A |
Maximum value at 100 % d.c. | 35 A |
Pilot arc current | 5 A |
Voltage measurement (V-Peak) | 113 V |
Striking voltage (Up) | 1o kV |
Plasma gas/shielding gas (EN ISO 14175) | Argon |
Hosepack length | 4 m |
Electrode diameter | 1 mm |
Cooling system | *) |
Cooling power ***) | 500 W |
Min. coolant pressure | 3.0 bar |
Max. coolant pressure | 5.5 bar |
Minimum coolant flowrate | 1.0 l/min |
d.c. = duty cycle
*) Liquid cooling
**) Original Fronius coolant
***) Minimum cooling power in accordance with standard IEC 60974-2
The product complies with standard IEC 60974-7
| PTW 1500 |
d.c. = duty cycle
*) Liquid cooling
| PTW 1500 | PTW 3500 |
Power range | 3 - 150 A | 3 - 350 A |
Maximum value at 60 % d.c. | - | - |
Maximum value at 100 % d.c. | 150 A | 350 A |
Pilot arc current | 10 A | 30 A |
Voltage measurement (V-Peak) | 113 V | 113 V |
Striking voltage (Up) | 1o kV | 1o kV |
Plasma gas/shielding gas (EN ISO 14175) | Argon | Argon |
Hosepack length | 4 / 6 / 8 m | 4 / 6 m |
Electrode diameter | 1.6 - 3.2 mm | 4.8 - 6.4 mm |
Cooling system | *) | *) |
Cooling power ***) | 700 / 1000 / 1300 W | 1700 / 1900 W |
Min. coolant pressure | 3.0 bar | 3.0 bar |
Max. coolant pressure | 5.5 bar | 5.5 bar |
Minimum coolant flowrate | 1.0 l/min | 1.0 l/min |
d.c. = duty cycle
*) Liquid cooling
