Indicates immediate danger.
The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, attention must also be paid to any generally applicable and local regulations regarding accident prevention and environmental protection.
All safety and danger notices on the device:The terminals can reach high temperatures.
Only operate the device if all of its protection devices are fully functional. If the protection devices are not fully functional, there is a risk ofAny safety devices that are not functioning properly must be repaired by a suitably qualified technician before the device is switched on.
For the location of the safety and danger notices on the device, refer to the "General" section in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended purpose. The manufacturer shall not be held liable for any damage arising from such usage.
The servicing information contained in these Operating Instructions is intended only for the use of qualified service engineers. An electric shock can be fatal. Do not perform any actions other than those described in the documentation. This applies even if you are qualified to do so.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Loose connections, scorched, damaged or inadequately dimensioned cables and leads must be immediately repaired by authorised personnel.
Maintenance and repair work must only be carried out by authorised personnel.
It is impossible to guarantee that bought-in parts are designed and manufactured to meet the demands made of them, or that they satisfy safety requirements. Use only original spare parts (also applies to standard parts).
Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
Components that are not in perfect condition must be replaced immediately.
The maximum sound power level of the inverter is specified in the Technical Data.
The device is cooled as quietly as possible with the aid of an electronic temperature control system; this depends on the amount of converted power, the ambient temperature, the level of soiling of the device, etc.
It is not possible to provide a workplace-related emission value for this device because the actual sound pressure level is heavily influenced by the installation situation, the power quality, the surrounding walls and the properties of the room in general.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g. when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers). If this is the case, then the operator is obliged to take appropriate action to rectify the situation.
To comply with the European Directive 2012/19/EU on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must be returned to your distributor, or you must locate the approved collection and recycling facilities in your area. Ignoring this European Directive may have potentially adverse effects on the environment and your health!
The user is responsible for the safekeeping of any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
The text and illustrations are all technically correct at the time of printing. We reserve the right to make changes. The contents of the operating instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the instructions, we will be most grateful for your comments.
Device design:
| (1) | Housing lid |
| (2) | Inverters |
| (3) | Mounting bracket |
| (4) | Connection area incl. DC main switch |
| (5) | Data communication area |
| (6) | Data communication cover |
The inverter converts the direct current created in the solar modules into alternating current. This alternating current is fed into the public grid synchronously with the grid voltage.
The inverter has been developed exclusively for use in grid-connected photovoltaic systems; it is impossible to generate energy independently of the public grid.
The inverter automatically monitors the public grid. In the event of abnormal grid conditions, the inverter ceases operating immediately and stops feeding power into the grid (e.g. if the grid is switched off, if there is an interruption, etc.).
The grid is monitored by monitoring the voltage, monitoring the frequency and monitoring islanding conditions.
The inverter operates fully automatically. As soon after sunrise as there is sufficient energy available from the solar modules, the inverter starts monitoring the grid. When insolation has reached a sufficient level, the inverter starts feeding energy into the grid.
The inverter operates in such a way that the maximum possible amount of power is obtained from the solar modules.
As soon as the power available has fallen below the level at which energy can be fed into the grid, the inverter disconnects the power electronics completely from the grid and stops running. It retains all its settings and stored data.
If the inverter becomes too hot, it automatically reduces the current output power in order to protect itself.
Reasons for the inverter becoming too hot include the ambient temperature being too high or inadequate heat dissipation (e.g. if it is installed in a switch cabinet without suitable heat dissipation).
Device design:
| (1) | Housing lid |
| (2) | Inverters |
Fronius shall not be liable for any damage resulting from such action.
No warranty claims will be entertained.
When designing the photovoltaic system, ensure that all components are operated within their permitted operating ranges at all times.
Observe all the measures recommended by the solar module manufacturer to ensure that the solar module retains its properties in the long term.
Obey the regulations of the power supply company regarding connection methods and energy fed into the grid.
There are warning notices and safety symbols on and in the inverter. These warning notices and safety symbols must not be removed or painted over. They warn against operating the device incorrectly, as this may result in serious injury and damage.
Safety symbols: | |
![]() | Risk of serious injury and damage due to incorrect operation |
![]() | Do not use the functions described here until you have fully read and understood the following documents:
![]() | Dangerous electrical voltage |
![]() | Wait for the capacitors to discharge. |
Text of the warning notices:
WARNING!
An electric shock can be fatal. Make sure that both the input side and output side of the device are de-energised before opening the device. Wait for the capacitors to discharge (3 minutes).
A dummy device is not suitable for the operative connection to a photovoltaic system and may only be taken into operation for demonstration purposes.
IMPORTANT! With a dummy device never connect live DC cables to the DC terminals.
Attaching not-energized cables or cable pieces for demonstration purposes is permitted.
A dummy device can be identified by the device rating plate:
Fronius Solar Net was developed to make system add-ons flexible to use in a variety of different applications. Fronius Solar Net is a data network that enables multiple inverters to be linked up using system add-ons. | |
It is a bus system that uses a ring topology. One suitable cable is sufficient for communication between one or several inverters that are connected on the Fronius Solar Net using a system add-on. | |
Similarly, every inverter on the Fronius Solar Net must be assigned a unique number. | |
Fronius Solar Net automatically recognises a wide variety of system add-ons. | |
In order to distinguish between several identical system add-ons, each one must be assigned a unique number. | |
More detailed information on the individual system add-ons can be found in the relevant operating instructions or on the internet at http://www.fronius.com | |
More detailed information on cabling Fronius DATCOM components can be found at: | |
![]() | → http://www.fronius.com/QR-link/4204101938 |
Depending on the model, the inverter may be equipped with the Fronius Datamanager plug-in card (8).
Item | Description |
(1) | Switchable multifunction current interface. Use the 2-pin mating connector supplied with the inverter to connect to the multifunction current interface. |
(2) | IN Fronius Solar Net connection / interface protocol IN If several DATCOM components are linked together, a terminating plug must be connected to every free IN or OUT connection on a DATCOM component. |
(4) | The "Fronius Solar Net" LED |
(5) | The "Data transfer" LED |
(6) | USB A socket The USB flash drive can function as a datalogger for any inverter that it is connected to. The USB flash drive is not included in the scope of supply of the inverter. |
(7) | Floating switch contact (relay) with mating connector Max. 250 V AC / 4 A AC Pin 1 = NO contact (normally open) For a more detailed explanation, please see the "Menu items in the Setup menu / Relay" section. |
(8) | Fronius Datamanager with WLAN antenna |
(9) | Cover for option card compartment |
Various wiring variants can be connected to the multifunction current interface. However, these cannot be operated simultaneously. For example, if an S0 meter is connected to the multifunction current interface, it is not possible to connect a signal contact for the surge protection device (or vice versa).
Pin 1 = measurement input: max. 20 mA, 100 Ohm measurement resistor (load impedance)
Pin 2 = max. short circuit current 15 mA, max. open circuit voltage 16 V DC or GND
Wiring diagram variant 1: Signal contact for surge protection device
Depending on the setting in the Basic menu (Signal Input submenu), the DC SPD option (surge protection device) either outputs a warning or an error on the display. Further information on the DC SPD option can be found in the Installation Instructions.
Wiring diagram variant 2: S0 meter
A meter for recording the self-consumption of each S0 can be connected directly to the inverter. This S0 meter can be positioned directly at the feed-in point or in the consumption branch. As one of the settings on the Fronius Datamanager website, a dynamic power reduction can be set under the "EVU Editor" menu item (see Fronius Datamanager 2.0 Operating Instructions on our website www.fronius.com)
IMPORTANT! In order to connect an S0 meter to the inverter, it may be necessary to update the inverter firmware.
Requirements for the S0 meter:
Recommended max. pulse rate of the S0 meter:
PV output kWp [kW] | Max. pulse rate per kWp |
30 | 1000 |
20 | 2000 |
10 | 5000 |
≤ 5.5 | 10,000 |
The "Fronius Solar Net" LED is on:
the power supply for data communication within the Fronius Solar Net / interface protocol is OK
The "Fronius Solar Net" LED flashes briefly every 5 seconds:
data communication error in the Fronius Solar Net
After cutting out because of overcurrent or undervoltage, the inverter attempts to restore the power supply in the Fronius Solar Net every 5 seconds while the fault is still present.
Once the fault is rectified, power to the Fronius Solar Net will be restored within 5 seconds.
Recording and archiving data from the inverter and sensor using a Fronius Datamanager and a Fronius Sensor Box:
![]() | = Terminating plug |
The external communication (Fronius Solar Net) takes place on the inverter via the data communication area. The data communication area contains two RS 422 interfaces as inputs and outputs. RJ45 plug connectors are used to make the connection.
IMPORTANT! Since the Fronius Datamanager functions as a data logger, the Fronius Solar Net ring must not include any other data logger.
Only one Fronius Datamanager per Fronius Solar Net ring!
Any other Fronius Datamanagers must be removed and the unoccupied option card compartment sealed off using the blanking cover (42,0405,2020 - available from Fronius as an optional extra); alternatively, use an inverter without Fronius Datamanager (light version).
Information on installing option cards (e.g.: Datamanager) in the inverter and connecting the data communication cable can be found in the Installation Instructions.
The inverter is fitted with the WLAN-enabled system monitoring Fronius Datamanager 2.0 as standard.
The following functions are included with the system monitoring:
Further information on Fronius Datamanager 2.0 can be found online in the Fronius Datamanager 2.0 Operating Instructions.
The Night Mode parameter under "Display Settings" in the Setup menu is preset to OFF in the factory.
For this reason the Fronius Datamanager cannot be accessed during the night or when the available DC voltage is insufficient.
To nevertheless activate the Fronius Datamanager, switch the inverter off and on again at the mains and press any function button on the inverter display within 90 seconds.
See also the chapters on "Menu items in the Setup menu", "Display settings" (Night Mode).
Setting up the Fronius Datamanager 2.0 for the first time is made considerably easier with the Fronius Solar.web app. The Fronius Solar.web app is available in the respective app stores.
When starting Fronius Datamanager 2.0 for the first time,
IMPORTANT! In order to establish a connection to Fronius Datamanager 2.0, "Obtain IP address automatically (DCHP)" must be activated on the end device in question (e.g. laptop, tablet, etc.).
If the photovoltaic system has only one inverter, steps 1 and 2 below can be skipped.
In this case, starting for the first time will commence with step 3.
The inverter establishes the WiFi access point. The WiFi access point remains open for 1 hour. The IP switch on the Fronius Datamanager 2.0 can remain in switch position A due to the activation of the WiFi Access Point.
Installation using the Solar.web App |
| Installation using a web browser |
4.Download the Fronius Solar.web LIVE or Solar Web Pro app ![]() 5.Run the Fronius Solar.web app |
| 1.Connect the end device to the WiFi access point SSID = FRONIUS_240.xxxxx (5-8 digits)
2.Enter the following in the browser: http://datamanager or 192.168.250.181 (IP address for WLAN connection) or 169.254.0.180 (IP address for LAN connection) |
The Setup wizard start page is displayed.
The technician wizard is intended for the installer and contains standard-specific settings. Running the technician wizard is optional.
If the technician wizard is run, it is vital to note the service password that is issued. This service password is necessary for setting the EVU Editor menu item.
If the technician wizard is not run, no specifications regarding power reduction are set.
Running the Fronius Solar.web wizards is mandatory.
The Fronius Solar.web homepage is displayed,
or
the Fronius Datamanager 2.0 web page is displayed.
Further information on the Fronius Datamanager 2.0 and other start-up options can be found at: | |
![]() | → http://www.fronius.com/QR-link/4204260191DE |
(1) | Display |
(2) | General status LED (red)
(3) | Startup LED (orange)
(4) | Operating status LED (green)
(5) | 'Left/up' key |
(6) | 'Down/right' key |
(7) | 'Menu/Esc' key |
(8) | 'Enter' key |
The keys are capacitive, and any exposure to water can impair their function. Wipe the keys dry with a cloth if necessary to ensure optimum functionality.
(1) | Display |
(8) | 'Enter' key |
Power for the display comes from the mains voltage. Depending on the setting selected in the Setup menu, the display can be kept on all day.
The display on the inverter is not a calibrated measuring device.
A slight inaccuracy in comparison with the energy meter used by the power supply company is intrinsic to the system. A calibrated meter will be needed to calculate the bills for the power supply company.
| (*) | Scroll bar |
| (**) | The Energy Manager symbol is displayed when the Energy Manager function is activated |
| (***) | Inv. no. = Inverter DATCOM number, Save symbol - appears briefly while set values are being saved, USB connection - appears if a USB flash drive has been connected |
If two minutes pass without any button being pressed, the display backlighting switches off automatically and the inverter goes to the "NOW" menu item (assuming the display backlighting is set to AUTO).
The automatic selection of the "NOW" menu item can happen from any position on the menu level, unless the inverter was manually switched into the "Standby" operating mode.
After automatically selecting the "NOW" menu item, the current power of feeding in is displayed.
![]() | ![]() | 1.Press the 'Menu' key |
![]() | The display switches to the menu level | |
![]() | 1.Use the 'Left' or 'Right' keys to select the desired menu item | |
![]() | 1.Press the 'Enter' key to select the desired menu item |
| NOW |
| LOG |
| GRAPH Press the 'Back' key to remove the display |
| NOW |
| LOG |
| Values displayed in the NOW menu item: |
AC Output power (W) | |
AC Reactive power (V Ar) | |
AC Voltage (V) | |
AC Output current (A) | |
AC Frequency (Hz) | |
PV Array Voltage (V) | |
PV Array Current (A) | |
Time / date |
| Values displayed in the LOG menu item: |
AC Energy Yield (kWh / MWh) There may be discrepancies with values displayed on other measuring instruments because of differences in measuring methods. As far as the billing of the energy fed in is concerned, the only binding display values are those produced by the calibrated measuring device provided by the electricity supply company. | |
AC Max. Output Power (W) | |
Earnings Like the energy supplied figure, the yield figure may also exhibit discrepancies with other measured values. The 'Setup Menu' section explains how to select a currency and charge rate. | |
CO2 savings (g / kg) The value for CO2 savings depends on the power station facilities and corresponds to the CO2 emissions that would be released when generating the same amount of energy. The factory setting is 0.53 kg / kWh (source: DGS – Deutsche Gesellschaft für Sonnenenergie e.V. (German Society for Solar Energy). | |
AC Max. Voltage L-N (V) | |
PV Array Max. Voltage (V) | |
Operating Hours IMPORTANT! A prerequisite for the correct display of day and year values is that the time is set correctly. |
The inverter is pre-configured after commissioning has been completely carried out (e.g. using the Installation Wizard) according to the country setup.
The SETUP menu item allows the initial settings of the inverter to be changed easily to bring it in line, as closely as possible, with the preferences and requirements of the user.
| SETUP |
As a result of software updates, you may find that your device has certain functions that are not described in these Operating Instructions, or vice versa.
Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
Entering the SETUP menu item
![]() | ![]() | 1.At the menu level, use the "Left" or "Right" keys to select the "SETUP" menu item |
![]() | 1.Press the "Enter" key | |
![]() | The first entry under the SETUP menu item is displayed: | |
Scrolling between the entries
![]() | ![]() | 1.Use the "Up" and "Down" keys to move between the available entries |
Exiting an entry
![]() | ![]() | 1.To exit a menu entry, press the "Back" key The menu level appears |
If no key is pressed for 2 minutes:
The available settings are displayed: |
| The first digit of a value to be set flashes: |
1.Use the 'Up' or 'Down' buttons to select the desired setting 2.Press the 'Enter' key to save and apply the setting. To discard the setting, press the 'Esc' key. | 1.Use the 'Up' or 'Down' keys to select a value for the first digit 2.Press "Enter" The second digit of the value flashes. 1.Repeat steps 4 and 5 until ... the whole value to be set flashes. | |
| 1.Press "Enter" 2.Repeat steps 4 - 6 as required for units or other values that are to be set until the appropriate unit or the value flashes. 3.Press the 'Enter' key to save and apply the changes. To discard the changes, press the 'Esc' key. | |
The currently selected menu item is displayed. |
![]() | ![]() | 1.Select 'Time / Date' from the Setup menu |
![]() | 1.Press the 'Enter' key | |
![]() | An overview of the values that can be changed is displayed. | |
![]() | 1.Use the 'Up' or 'Down' keys to select 'Set time' | |
![]() | The current time appears. | |
![]() | 1.Use the 'Up' and 'Down' keys to select a value for the 'tens' digit for the hour | |
![]() | The 'units' digit for the hour will flash. | |
1.Repeat steps 5 and 6 for the 'units' digit for the hour, for the minutes and seconds until... | ||
![]() | the set time starts flashing. | |
![]() | The time is applied and the overview of values that can be changed is displayed. | |
![]() | 1.Press the 'Esc' key |
![]() | The 'Time / Date' item on the Setup menu appears. | |
Manual activation / deactivation of Standby mode
Switching off Standby mode (manually switching off feeding energy into the grid):
"STANDBY" and "ENTER" appear alternately on the display.
Standby mode is now active.
The Startup LED shows steady orange.
Resuming feeding energy into the grid:
"STANDBY" and "ENTER" appear alternately on the display when in Standby mode.
The "Standby" menu item is displayed.
At the same time, the inverter enters the startup phase.
The operating state LED shows steady green when feeding energy into the grid has been resumed.
Activating / deactivating the WiFi Access Point. This is necessary for setting up or adjusting system monitoring using the Datamanager web interface, for example. If no Datamanager is detected by the inverter, [not available] is displayed
Setting range | WiFi Access Point |
| Activate WiFi AP? To activate the WiFi Access Point |
| WiFi Access Point The SS-ID (SS) and password (PW) are displayed. |
| Deactivate WiFi AP? To deactivate the WiFi Access Point |
| WiFi Access Point Displayed if there is no system monitoring present on the inverter. |
Checking data communications, entering the inverter number, protocol settings
Setting range | Status / inverter number / protocol type |
Status | |
Inverter number | |
Setting range | 00 - 99 (00 = inverter address 100) |
Factory setting | 01 |
IMPORTANT! If a number of inverters are linked together in a data communications system, assign a unique address to each one. | |
Protocol type | |
Setting range | Solar Net / Interface * |
Factory setting | Fronius Solar Net |
* The protocol type "Interface" only functions when there is no Datamanager card in the inverter. All Fronius Datamanager cards should be removed from the inverter. | |
Running firmware updates or saving detailed information from the inverter to the USB flash drive
Setting range | Safely remove hardware / Software update / Logging interval |
To remove a USB flash drive from the USB A socket on the plug-in data communications card without losing any data.
Software update
To update the inverter firmware using a USB flash drive.
To successfully update the inverter software, the USB flash drive provided for the purpose must not have a hidden partition or any encryption (see chapter "Suitable USB flash drives").
The inverter starts copying the data.
"BOOT" and the progress of storing the individual tests expressed in % are displayed until all the data for all the electronic modules has been copied.
Once copying is complete, the inverter updates the electronic modules as required in sequence.
"BOOT", the affected modules and the update progress in % are displayed.
The final step is for the inverter to update the display.
The display remains dark for approx. 1 minute while the monitoring and status LEDs flash.
Once the firmware update is complete, the inverter enters its start-up phase before going on to start feeding energy into the grid. Unplug the USB flash drive using the "Safely remove hardware" function.
When the inverter firmware is updated, any custom settings that were configured in the Setup menu are retained.
| Logging interval | |
Unit | Minutes | |
Setting range | 30 min. / 20 min./ 15 min./ 10 min./ 5 min./ No log | |
Factory setting | 30 min. | |
30 min. | The logging interval is 30 minutes; every 30 minutes new logging data will be saved to the USB flash drive. | |
20 min. | ![]() | |
15 min. | ||
10 min. | ||
5 min. | The logging interval is 5 minutes; every 5 minutes new logging data will be saved to the USB flash drive. | |
No log | No data is saved | |
IMPORTANT! In order for the USB logging function to work correctly the time must be set correctly. Setting the time is discussed in the section "Menu items in the Setup menu" - "Time / Date".
Status codes (state codes), the status of the inverter (e.g. feeding energy into the grid) or Energy Manager functions can be displayed using the floating switch contact (relay).
Setting range | Relay mode / Relay test / Switch-on point* / Switch-off point* |
* these are only shown if the "E-Manager" function has been activated under "Relay mode".
Relay mode
Setting range | ALL / Permanent / GAF / OFF / ON / E-Manager |
Factory setting | ALL |
Alarm function: | ||
ALL / Permanent: | Switching the floating switch contact for permanent and temporary service codes (e.g. brief interruption to energy being fed into the grid, a service code occurs a certain number of times a day - can be adjusted in the "BASIC" menu) | |
GAF | As soon as GAF mode is selected, the relay is switched on. The relay opens as soon as the power stage set registers an error and goes from normally feeding energy into the grid to being in an error state. This means that the relay can be used for fail-safe functions. Application example | |
Active output: | ||
ON: | The floating NO contact is on all the time the inverter is in operation (as long as the display is not dark or is displaying something). | |
OFF: | The floating NO contact is off. | |
Energy Manager: | ||
E-Manager: | Further details on the "Energy Manager" function may be found in the "Energy Manager" section. | |
Relay test | ||
Switch-on point (only if "Energy Manager" function is activated) | ||
Factory setting | 1000 W |
Setting range | Set switch-off point up to the maximum nominal output of the inverter (W or kW) |
Switch-off point (only if "Energy Manager" function is activated) | |
Factory setting | 500 |
Setting range | 0 to the set switch-on point of the inverter (W or kW) |
The "Energy Manager" (E-Manager) function can be used to activate the floating switch contact in such a way that it functions as an actuator.
Thus, a consumer that is connected to the floating switch contact can be controlled by specifying a switch-on or switch-off point that depends on the feed-in power (effective power).
The floating switch contact is automatically switched off:
To activate the Energy Manager function, select the "E-Manager" item and press the "Enter" key. | |
![]() | When the floating NO contact is off (open contact) |
![]() | When the floating NO contact is on (closed contact) |
To deactivate the Energy Manager function, select a different function (ALL / Permanent / OFF / ON) and press the "Enter" key.
Notes on setting up the switch-on and switch-off points
If the difference between the switch-on and switch-off points is too small, or if there are fluctuations in effective power, the result may be multiple switching cycles.
To avoid switching on and off frequently, the difference between the switch-on and switch-off points should be at least 100 - 200 W.
When choosing the switch-off point, the power consumption of the connected consumer should be taken into account.
When choosing the switch-on point, the weather conditions and anticipated insolation should be taken into account.
Application example
Switch-on point = 2000 W, switch-off point = 1800 W
If the inverter is outputting 2000 W or above, then the floating switch contact on the inverter is switched on.
If the inverter output falls to below 1800 W, the floating switch contact is switched off.
This allows useful applications, such as operating a heat pump or an air-conditioning system using as much self-generated power as possible, to be implemented quickly
Set the time, date, the display format and automatic changeover between summer and winter time
Setting range | Set time / Set date / Time display format / Date display format / Summer/winter time |
Set time | |
Set date | |
Time display format | |
Setting range | 12hrs / 24hrs |
Factory setting | Depends on country setup |
Date display format | |
Setting range | mm/dd/yyyy or dd.mm.yy |
Summer/winter time | |
IMPORTANT! Only use the automatic summer/winter time changeover function if the Fronius Solar Net ring does not include any LAN- or WLAN-compatible system components (e.g. Fronius Datalogger Web, Fronius Datamanager or Fronius Hybridmanager). | |
Setting range | on / off |
Factory setting | on |
IMPORTANT! The time and date must be set accurately in order for the day and year values and for the day characteristic to be displayed correctly. | |
Setting range | Language / Night mode / Contrast / Illumination |
Language | |
Setting range | English, German, French, Spanish, Italian, Dutch, Czech, Slovakian, Hungarian, Polish, Turkish, Portuguese, Romanian |
Night mode | |
Setting range | AUTO / ON / OFF |
Factory setting | OFF |
AUTO: | Fronius DATCOM mode is always in effect as long as there is a Fronius Datamanager connected in an active and uninterrupted Fronius Solar Net. | |
ON: | Fronius DATCOM mode is always in effect. The inverter supplies 12 V of DC voltage continuously to power the Fronius Solar Net. The display is always active. IMPORTANT! If Fronius DATCOM night mode is set to ON or AUTO when there are Fronius Solar Net components connected, the inverter's current consumption during the night will increase to around 7 W. | |
OFF: | Fronius DATCOM will not run at night, the inverter therefore does not require any power during the night to supply the Fronius Solar Net with energy. | |
Contrast | ||
Setting range | 0 - 10 |
Factory setting | 5 |
Since the contrast is temperature-dependent, it may be necessary to adjust the setting under the "Contrast" menu item when the environmental conditions change. | |
Illumination | |
The "Illumination" menu item only relates to the inverter display backlighting. | |
Factory setting | AUTO |
AUTO: | The inverter display backlighting is activated by pressing any key. If no key is pressed for 2 minutes, the display backlighting will go off again. | |
ON: | The inverter display backlighting remains permanently on when the inverter is active. | |
OFF: | The inverter display backlighting is permanently switched off. |
The following settings can be changed/set here:
Setting range | Currency / Feed-in tariff |
Counter deviation / calibration | |
Currency | |
Setting range | 3 characters, A-Z |
Feed-in tariff | |
Setting range | 2 digits, 3 decimal places |
Factory setting | (depends on country setup) |
CO2 factor | |
To check that the fan is working correctly
Setting range | Test fan #1 / Test fan #2 (depending on the device) |
IMPORTANT! Nothing will show on the inverter display if the fan is working. The only way to check how the fan is working is by listening and feeling.
| INFO |
| INFO |
Measured values | Display range: | PV ins. / Ext. lim. / U PV1 / GVDPR / Fan #1 |
| PV Iso. Ext. lim. U PV1 GVDPR Fan #1 | |
PSS status | The status of the most recent inverter fault can be displayed. IMPORTANT! Due to the low level of insolation early in the morning and in the evening, the status codes 306 (Power low) and 307 (DC low) are displayed routinely at these times of day. These status codes do not indicate any kind of fault.
Grid status | The five most recent grid faults can be displayed:
For displaying the settings that will be of relevance to an energy supply company. The values shown will depend on the country setup or the device-specific settings of the inverter.
Display range | General / Country-specific setting / MPP tracker / Grid monitoring / Grid voltage limits / Grid frequency limits / Q-mode / AC power limit / AC voltage derating / Fault Ride Through |
General: | Device type |
Country-specific setting: | Setup Version Group |
MPP Tracker: | Tracker 1 |
Monitoring the grid: | GMTi GMTr ULL LLTrip |
Grid voltage limits: | UILmax UILmin |
Grid frequency limits: | FILmax FILmin |
Q-mode: | current power factor setting cos phi |
AC power limit: | Max. P AC |
AC voltage derating: | Status GVDPRe GVDPRv Message |
Fault Ride Through: | Status - default setting: OFF DB min - default setting: 90% DB max - default setting: 120% k-Fac. - default setting: 0 |
Displays the version and serial numbers of the PC boards in the inverter (e.g. for service purposes)
Display area | Display / Display Software / Integrity Checksum / Memory Card / Memory Card #1 / Power Stage / Power Stage Software / EMI Filter / Power Stage #3 / Power Stage #4 |
The inverter has a key lock function.
When the key lock is active, the Setup menu is not accessible, i.e. the setup data cannot be changed accidentally (or maliciously).
The code 12321 has to be entered in order to activate / deactivate the key lock.
1.Press the "Menu" key | |
![]() | The menu level appears. 1.Press the unassigned "Menu / Esc" key 5 times |
![]() | "Access Code" is displayed in the "CODE" menu; the first digit starts flashing. |
1.Enter the code 12321: Use the "Plus" and "Minus" keys to select a value for the first digit of the code | |
![]() | The second digit flashes. |
1.Repeat steps 3 and 4 for the second, third, fourth and fifth digits of the access code until... the selected code starts flashing. 1.Press the "Enter" key |
![]() | "Setup Menu Lock" is displayed in the "LOCK" menu. |
1.Use the "Plus" and "Minus" keys to turn the key lock on or off:ON = key lock is on (the Setup menu is not accessible) OFF = key lock is off (the Setup menu is accessible) | |
If a USB stick is connected to the USB A socket it can function as a datalogger for an inverter.
At any time, the logging data stored on the USB stick can beOlder versions (before Excel 2007) are limited to a maximum of 65,536 rows.
Further information on "Data on a USB stick", "Data volume and storage capacity" as well as "Buffer memory" can be found at: | |
![]() | ® http://www.fronius.com/QR-link/4204260171EN |
Due to the variety of USB flash drives available on the market, it cannot be guaranteed that every USB flash drive will be detected by the inverter.
Fronius recommends that only certified, industry-grade USB flash drives are used (look out for the USB-IF logo).
The inverter supports USB flash drives with the following file systems:
Fronius recommends that the USB flash drives employed should only be used for recording logging data or updating the inverter software. The USB flash drives should not contain any other data.
USB symbol on the inverter display, e.g. in display mode 'NOW': | ||
| If the inverter detects a USB flash drive, the USB symbol will appear in the top right corner of the display. When inserting a USB flash drive, check whether the USB symbol is displayed (it may also flash). |
Note! Please note for outdoor applications that conventional USB flash drives are often only guaranteed to work within a restricted temperature range.
For outdoor applications ensure that the USB flash drive also functions, for example, at low temperatures.
With the help of the USB stick, end customers can also update the inverter software via the USB item on the SETUP menu: the update file is first saved to the USB stick, from where it is then transferred to the inverter. The update file must be saved in the root directory on the USB stick.
Security note concerning the removal of a USB stick: | ||
| IMPORTANT! To avoid any loss of data, a USB stick may only be removed if the following conditions are met:
The Basic menu is used to set the following parameters, which are important for installing and operating the inverter:
![]() | 1.Press the 'Menu' key | |
| The menu level appears. 1.Press the unassigned 'Menu / Esc' key 5 times |
![]() | "Access Code" is displayed in the "CODE" menu; the first digit starts flashing. | |
![]() | 1.Enter the code 22742: Use the 'Up' and 'Down' keys to select a value for the first digit of the code | |
![]() | The second digit starts flashing. | |
![]() | 1.Repeat steps 3 and 4 for the second, third, fourth and fifth digit of the access code until ... the selected code starts flashing. 1.Press the 'Enter' key |
| The Basic menu appears. | |
![]() | 1.Use the 'Up' or 'Down' keys to select the desired menu item | |
![]() | 1.Press the 'Enter' key to open the desired menu item | |
![]() | 1.Press the 'Esc' key to exit the Basic menu |
The Basic menu contains the following items:
MPP Tracker 1
USB log book |
Input signal
SMS / relay
Grounding setting
Insulation mode
Temperature warning |
TOTAL Reset To reset the values to zero, press the 'Enter' key. |
The inverter performs a system self-diagnosis that automatically detects many faults that may occur and shows them on the display. This means you are promptly made aware of malfunctions in the inverter or the photovoltaic system, or of any installation or operating faults.
If the system self-diagnosis has detected a specific fault, the associated status code will be shown on the display.
IMPORTANT! Status codes may sometimes appear briefly as a result of the inverter's control response. If the inverter then continues working with no sign of any problem, this means that there was no fault.
| * | The mains voltage tolerance depends on the country setup |
Class 1 status codes generally only arise momentarily and are caused by the public grid.
The initial response of the inverter in this case is to disconnect itself from the grid. The grid is subsequently checked for the stipulated monitoring period. If no further problem has been detected by the end of this period, then the inverter will resume feeding energy into the grid.
The GPIS SoftStart function is activated according to the country setup:
after cutting out due to an AC error, the output power of the inverter is continuously increased by 10% every minute in line with the VDE-AR-N 4105 guideline.
Code |
| Description |
| Behaviour |
| Remedy |
102 |
| AC voltage too high |
| Following careful testing and when the grid conditions are within the permissible range again, the inverter will resume feeding energy into the grid. |
| Check grid connections: |
103 |
| AC voltage too low |
105 |
| AC frequency too high |
106 |
| AC frequency too low |
107 |
| AC grid outside the permissible limits |
108 |
| Stand alone operation detected |
Class 3 includes status codes that may occur while feeding energy into the grid, but generally do not cause the process to be interrupted for any length of time.
The inverter disconnects automatically from the grid, the grid is then monitored as specified and the inverter attempts to resume feeding energy into the grid.
Code |
| Description |
| Behaviour |
| Remedy |
301 |
| Short-term interruption while feeding energy into the grid due to overcurrent in the inverter |
| Fault is rectified automatically; |
302 |
| Overcurrent (DC) |
303 |
| Power stage set overtemperature |
| Short-term interruption while feeding energy into the grid due to overtemperature |
| Purge openings for cooling air and heat sink if necessary; |
304 |
| Internal temperature too high |
306 |
| LOW PV OUTPUT |
| Short-term interruption while feeding energy into the grid |
307 |
| LOW PV VOLTAGE |
IMPORTANT! Due to the low level of insolation early in the morning and in the evening, the status codes 306 (LOW PV OUTPUT) and 307 (LOW PV VOLTAGE) are displayed routinely at these times of day. These status codes do not indicate any kind of fault. | ||||||
308 |
| Intermediate circuit overvoltage |
309 |
| DC input voltage too high |
Some of the class 4 status codes necessitate intervention by a Fronius-trained service engineer.
Code |
| Description |
| Behaviour |
| Remedy |
401 |
| No communication with power stage set possible |
| The inverter will automatically attempt to connect again and, if possible, will resume feeding energy into the grid |
| If the status code is displayed all the time: notify a Fronius-trained service engineer |
406 |
| Power stage set temperature sensor faulty |
407 |
| Internal temperature sensor faulty |
408 |
| DC feeding into the grid detected |
412 |
| Fixed voltage mode has been selected instead of MPP voltage mode and the fixed voltage has been set to too low or too high a value. |
| If this status code keeps recurring, contact your system engineer |
415 |
| Safety cut-out via option card or RECERBO has triggered |
| The inverter is not feeding any energy into the grid. |
416 |
| No communication possible between power stage set and control system. |
425 |
| No communication possible with the power stage set |
445 |
| Invalid limit value settings |
| The inverter is not feeding any energy into the grid for safety reasons. |
| Update the inverter firmware; |
452 |
| Communication error between the processors |
453 |
| Short-term grid voltage error |
454 |
| Short-term grid frequency error |
457 | Grid relay sticking | The inverter is not feeding any energy into the grid. | notify a Fronius-trained service engineer | |||
459 |
| Error when recording the measuring signal for the insulation test |
460 |
| Reference voltage source for the digital signal processor (DSP) is working out of tolerance |
472 |
| Fuse for solar module ground is faulty |
| Replace fuse for solar module ground; |
475 | Solar module ground, insulation fault (connection between solar module and ground) | The inverter is not feeding any energy into the grid. | If this status code keeps recurring, contact your system engineer | |||
482 |
| Start-up incomplete |
| Perform AC reset (turn automatic circuit breaker off and on), complete start-up |
Class 5 status codes do not generally prevent the feeding of energy into the grid, but can restrict it. These status code are displayed until they are acknowledged by pressing a key (the inverter, however, continues to operate normally in the background).
Code |
| Description |
| Behaviour |
| Remedy |
502 |
| Insulation error on the solar modules |
| Warning message is shown on the display |
509 |
| No energy fed into the grid in the past 24 hours |
| Acknowledge status code; |
517 |
| Derating caused by too high a temperature |
| When power derating occurs, a warning message is shown on the display |
| Purge cooling air openings and heat sink if necessary; |
551 |
| Warning is shown on the display |
558 |
| Functional incompatibility (one or more PC boards in the inverter are not compatible with each other, e.g. after a PC board has been replaced) |
| Possible error displays or malfunctions on the inverter |
560 |
| Derating caused by overfrequency |
| This status code is displayed when the grid frequency becomes excessively high. |
| As soon as the grid frequency is back within the permissible range and the inverter has returned to normal operation, the fault is rectified automatically. |
568 |
| Incorrect input signal on the multifunction current interface |
| The status code is displayed in the case of an incorrect input signal on the multifunction current interface and with the following setting: |
Some of the class 6 status codes necessitate intervention by a Fronius-trained service engineer.
Code |
| Description |
| Behaviour |
| Remedy |
668 |
| Check the devices connected to the multifunction current interface; |
Class 7 status codes relate to the control system, the configuration and inverter data recording, and may directly or indirectly affect the process of feeding energy into the grid.
Code |
| Description |
| Behaviour |
| Remedy |
705 |
| Conflict when setting the inverter number (e.g. number already assigned) |
| Correct the inverter number via the Setup menu |
721 |
| EEPROM has been reinitialised or EEPROM is faulty |
731 |
| Initialisation error - USB stick is not supported |
| Check or replace USB stick |
732 |
| Overcurrent on USB stick |
733 |
| No USB stick connected |
| Warning message is shown on the display. |
| Connect or check USB stick |
734 |
| Update file not recognised or not present |
| Check update file (e.g. for correct file name) |
735 |
| Update file does not match the device, update file too old |
| Warning message appears on the display, update process is interrupted |
| Check update file |
736 |
| Write or read error occurred |
| Check USB stick and the data contained on it or replace USB stick |
738 |
| Log file cannot be saved (e.g. USB stick is write-protected or full) |
| Create storage space, remove write protection, check or replace USB stick if necessary |
743 |
| Error occurred during update process |
| Repeat the update process, check USB stick |
745 |
| Update file corrupt |
| Re-download update file |
751 |
| Time lost |
| Reset the time and date on the inverter |
752 |
| Real Time Clock module communication error |
757 |
| Hardware error in the Real Time Clock module |
| Error message is shown on the display; the inverter is not feeding any energy into the grid |
758 |
| Internal error: Real Time Clock module is in emergency mode |
| Time may be inaccurate or lost (feeding energy into the grid normal) |
766 |
| Emergency power derating has been activated (max. 750 W) |
| Error message is shown on the display |
When operating the inverter in extremely dusty environments:
when necessary, clean the cooling elements and fan on the back of the inverter as well as the air intakes at the mounting bracket using clean compressed air.
Input data
MPP voltage range | 120 - 335 V DC |
Max. input voltage | 420 V DC |
Max. input current | 13.3 A |
Max. short circuit current of the solar modules | 20.0 A |
Max. feedback current4) | 8.9 A |
Output data
Nominal output power (Pnom) | 1500 W |
Max. output power | 1500 W |
Nominal grid voltage | 1 ~ NPE 230 V |
Min. grid voltage | 180 V 1) |
Max. grid voltage | 270 V 1) |
Max. output current | 7.2 A |
Nominal frequency | 50 - 60 Hz 1) |
Total harmonic distortion | < 4 % |
Power factor cos phi | 1 |
Max. permitted grid impedance Zmax at PCC3) | none |
Power-up current pulse6) and duration | 36.0 A / 9.4 ms |
Max. output fault current per period | 43.0 A / 1.24 ms |
General data
Maximum efficiency | 95.9 % |
Europ. efficiency | 94.5 % |
Overnight self-consumption | 0.47 W |
Cooling | Controlled forced-air ventilation |
Degree of protection | IP 65 |
Dimensions h x w x d | 645 x 431 x 204 mm |
Weight | 16.35 kg |
Permissible ambient temperature | - 25 °C - +50 °C |
Permitted humidity | 0 - 100 % |
EMC emission class | B |
Overvoltage category DC / AC | 2 / 3 |
Protection devices
DC insulation measurement | Warning/shutdown 7) at RISO < 600 kOhm |
Response to DC overload | Operating point shift, power limitation |
DC disconnector | Integrated |
Input data
Output data
General data
Weight | 16.35 kg |
Protection devices
Input data
Max. input current | 17.8 A |
Max. short circuit current of the solar modules | 26.8 A |
Max. feedback current4) | 11.9 A |
Output data
Nominal output power (Pnom) | 2000 W |
Max. output power | 2000 W |
Max. output current | 9.7 A |
General data
Maximum efficiency | 96.0 % |
Europ. efficiency | 94.9 % |
Weight | 16.35 kg |
Protection devices
Response to DC overload | Operating point shift |
Input data
MPP voltage range | 165 - 440 V DC |
Max. input voltage | 550 V DC |
Max. input current | 16.6 A |
Max. short circuit current of the solar modules | 24.8 A |
Max. feedback current4) | 11 A |
Output data
Nominal output power (Pnom) | 2500 W |
Max. output power | 2500 W |
Max. output current | 12.1 A |
General data
Maximum efficiency | 96.1 % |
Europ. efficiency | 95.2 % |
Weight | 16.75 kg |
Protection devices
Input data
Max. input current | 19.8 A |
Max. short circuit current of the solar modules | 29.6 A |
Max. feedback current4) | 13.2 A |
Output data
Nominal output power (Pnom) | 3000 W |
Max. output power | 3000 W |
Max. output current | 14.5 A |
General data
Europ. efficiency | 95.4 % |
Weight | 16.75 kg |
Protection devices
Input data
Max. input current | 20.7 A |
Max. short circuit current of the solar modules | 31.0 A |
Max. feedback current4) | 13.8 A |
Output data
Nominal output power (Pnom) | 3100 W |
Max. output power | 3100 W |
Max. output current | 15.0 A |
General data
Weight | 16.75 kg |
Protection devices
Grid voltage tolerance | +10 / -5 % 1) |
Weight | 16.75 kg |
| 1) | The values quoted are default values; the inverter is configured specifically to meet the needs of the country in question. |
| 2) | Depending on the country setup or device-specific settings (ind. = inductive; cap. = capacitive) |
| 3) | PCC = interface to the public grid |
| 4) | Maximum current from the inverter to the solar module when an error occurs in the inverter or when the insulation between the AC and DC side is defective |
| 5) | Guaranteed by the electrical configuration of the inverter |
| 6) | Current peak when switching on the inverter |
| 7) | Depending on the country setup |
CE mark
The devices comply with all the requisite and relevant standards and guidelines that form part of the relevant EU Directive, and are therefore permitted to display the CE mark.
Circuit to prevent stand-alone operation
The inverter has an approved circuit to prevent stand-alone operation.
Grid failure
The standard measurement and safety procedures integrated into the inverter ensure that in the event of a grid failure, the feed-in of energy is immediately interrupted (e.g. switch-off by the energy supplier or damage to lines).
Detailed, country-specific warranty terms are available on the internet:
www.fronius.com/solar/warranty
To obtain the full warranty period for your newly installed Fronius inverter or storage system, please register at: www.solarweb.com.
If your inverter is to be replaced, Fronius will take back the old device and arrange for it to be recycled in an appropriate manner.
