Only an original wire cutter may be fitted to the mounting set:
44,0450,1447 ... single wire cutter
44,0450,1027 ... twin wire cutter
Fitting a different wire cutter is not permitted.
(1) | Cover |
(2) | Holder |
(3) | 2 hexagon nuts size 10 mm |
(4) | 2 lock washers |
(5) | 2 washers |
(6) | 2 Innensechskant-Schrauben M6 x 16 mm |
(7) | 2 M5 x 10 mm TX25 screws |
(8) | Compressed air connection |
(9) | Union nut |
(10) | T-connection |
(11) | PUR hose 4 x 2 mm, 0.38 m |
(12) | 2 aluminium sleeves D11 x 54 mm |
(13) | 2 Allen screws, M5 x 80 mm |
All the work and functions described in this document may only be carried out by trained and qualified personnel.
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
Danger from electric shock and mechanically powered parts.
Before carrying out any work on the cleaning device or the connected system components:
Disconnect the customer's compressed air and power supplies from the cleaning device and the connected system components.
Ensure that they remain disconnected until all work is complete.
