Read and understand all safety rules and user documentation for this equipment and all system components.
Danger from electric current due to defective system components and incorrect operation.
All cables, leads, and hosepacks must always be securely connected, undamaged, and correctly insulated.
Only use adequately dimensioned cables, leads, and hosepacks.
Danger from contact with toxic welding fumes.
Serious personal injuries may result.
Always extract welding fumes.
Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ (11.77 cfm) per hour at all times.
In case of doubt, the concentration of noxious substances at the work station should be assessed by a safety engineer.
Danger due to hot system components and/or equipment.
This can result in burns or scalding.
Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
Danger from operation without coolant.
Never commission water-cooled devices without coolant.
During welding, ensure that the coolant is circulating correctly. When using Fronius cooling units, this will be the case if proper return flow of coolant can be seen in the cooling unit’s coolant container.
Risk of coolant escaping.
Personal injury and damage to property may result.
When disconnecting a water-cooled welding torch from the cooling unit or other system components, always seal the coolant hoses using the plastic seal attached to the torch.
The TIG manual welding torch is intended solely for TIG welding and TIG brazing in manual applications.
Any other use is deemed to be "not in accordance with the intended purpose.”
| (1) | Start key The key initiates the following functions:
| (2) | Up/Down key To change the welding power |
| (3) | LED button To illuminate the welding area:
Push the button forwards and hold until intermediate lowering is complete
| (2) | Display For ergonomic reading of essential welding parameters on the welding torch itself |
| (3) | Up/Down key To change welding parameters |
| (4) | Arrow keys To select welding parameters |
| (5) | LED button To illuminate the welding area:
Risk of damage due to excessive tightening torque on the fixing sleeve (1) or gas lens (2).
Damage to the thread may result.
Only tighten the fixing sleeve (1) or gas lens (2) a little.
| * | Replaceable rubber sealing sleeve only for TTB 220 G/A |
| ** | A gas lens (2) may be used instead of the fixing sleeve (1) depending on the type of welding torch |
Risk of damage due to excessive tightening torque on the torch cap.
Only tighten the torch cap enough so that the tungsten electrode can no longer be moved by hand.
| * | Replaceable rubber sealing sleeve only for TTB 220 G/P |
Definition of terms: TFC = Tungsten Fast Clamp
Danger from tungsten electrode when dismantling clamping unit and collet.
The torch body may be damaged.
Always remove the tungsten electrode before dismantling the clamping unit and collet.
Danger from tungsten electrode when fitting clamping unit and collet.
Fit the clamping unit and collet and only then fit the tungsten electrode.
Risk due to damaged O-ring on the torch body.
A damaged O-ring on the torch body can lead to contamination of the shielding gas, resulting in a defective weld.
Before each start-up, ensure that the O-ring on the torch body is undamaged.
Danger due to incorrectly fitted torch body.
Ensure that the locking device is fully forward after fitting the torch body - only then is the torch body properly fitted and locked.
Risk due to damaged O-ring on the welding torch connection.
A damaged O-ring on the welding torch connection can lead to contamination of the shielding gas, resulting in a defective weld.
Before each start-up, ensure that the O-ring on the welding torch connection is undamaged.
* only with water-cooled welding system
The extension hosepack comes with a protective bag in which the interface connecting the extension hosepack to the torch hosepack is placed.
When carrying out the work described below, ensure that the cables and hoses are not kinked, pinched, abraded or otherwise damaged.
Danger of slipping due to overflowing coolant container. If using a MultiControl cooling unit, be aware that an overfilled coolant container can overflow when emptying hosepacks longer than 4 m (13 ft. 1.48 in.).
Follow the instructions for filling the torch hosepack in the cooling unit operating instructions.
Risk of damage from operation without sufficient coolant.
As soon as a good return flow is visible in the coolant container of the cooling unit after starting up the power source, ensure that there is sufficient coolant in the cooling unit.
Danger due to incompatible system components.
Only connect torch bodies and hosepacks that are using the same type of cooling.
Only fit gas-cooled torch bodies to gas-cooled hosepacks.
Danger from switched on power source during automatic emptying of the welding torch.
Unintentional arc ignitions can occur.
Follow the instructions for automatic emptying of the welding torch in the cooling unit Operating Instructions, the power source Operating Instructions, and on the power source control panel.
When carrying out the work on the torch body as described below, keep at least 1 m (39.37 in.) away from electrically conductive objects.
Only fit water-cooled torch bodies to water-cooled hosepacks.
The flexible TIG torch bodies can be bent in all directions and thus individually adapted to a wide variety of situations and applications.
Flexible torch bodies are used, for example, in cases of limited part accessibility or difficult welding positions.
However, the material of a flexible torch body is weakened with every change in shape, so the number of times it can be bent is also limited.
Bending and number of bends are explained in the following sections.
A bend is a one-time change in shape that deviates from the original shape by at least 20°.
A smallest possible bending radius has been defined so that the bending action does not occur at a few certain points but as uniformly as possible over a long length.
The bending radius must not be less than this.
The smallest possible bending radius is 25 mm (1 in.).
A bend must not exceed the maximum bending angle.
The maximum bending angle is 45°.
Bending back to the original shape is considered a bend in its own right.
Example: 45° bends
| (1) | Initial situation: 0° |
| (2) | Movement from 0° to 45° upwards = First bend |
| (3) | Movement from 45° back to 0° = Second bend |
| (4) | Movement from 0° to 45° downwards = Third bend |
| (5) | Movement from 45° back to 0° = Fourth bend |
With a bending radius of more than 25 mm (1 in.) and a maximum bending angle = 45°, the following can be achieved
The articulated torch bodies can be individually adapted to a wide variety of situations and applications, for example in the case of restricted part accessibility or difficult welding positions.
Due to the articulated joint, the welder's hand is closer to the torch handle and thus to the torch triggers.
With articulated welding torches, no material weakening occurs during setup.
The articulated torch body is assembled in the same way as a conventional torch body - see Fitting the torch body on page (→).
Danger if the articulated torch body is screwed out too far.
Unscrew the front part of the articulated torch body by no more than 1 turn.
In addition to the above list of steps to be carried out at every start-up, for water-cooled welding torches:
Disposal must only be carried out in accordance with the section of the same name in the "Safety rules" chapter.
| Cause: | Bayonet lock bent |
| Remedy: | Replace bayonet lock |
| Cause: | Incorrect ground connection |
| Remedy: | Establish proper ground connection |
| Cause: | Power cable in welding torch interrupted |
| Remedy: | Replace welding torch |
| Cause: | Tungsten electrode loose |
| Remedy: | Tighten tungsten electrode using torch cap |
| Cause: | Wearing parts loose |
| Remedy: | Tighten wearing parts |
| Cause: | Power plug not plugged in |
| Remedy: | Plug in power plug |
| Cause: | Welding torch or welding torch control line faulty |
| Cause: | Plug connections "torch trigger/control line/power source" faulty |
| Remedy: | Check plug connection / send power source or welding torch to service team |
| Cause: | PCB in welding torch faulty |
| Remedy: | Replace PCB |
| Cause: | Welding torch connection not sealed |
| Remedy: | Replace O-ring on the bayonet lock |
| Cause: | Hosepack is not sealed |
| Remedy: | Replace hosepack |
| Cause: | Shielding gas hose connection to torch body not sealed |
| Remedy: | Adjust and seal hose |
| Cause: | Gas cylinder empty |
| Remedy: | Change gas cylinder |
| Cause: | Gas pressure regulator faulty |
| Remedy: | Replace gas pressure regulator |
| Cause: | Gas hose kinked, damaged, or not attached |
| Remedy: | Attach and straighten gas hose. Replace faulty gas hose |
| Cause: | Welding torch faulty |
| Cause: | Gas solenoid valve faulty |
| Remedy: | Contact service team (have gas solenoid valve replaced) |
| Cause: | Incorrect welding parameters |
| Remedy: | Check settings |
| Remedy: | Check ground connection and terminal for polarity |
| Cause: | Welding torch is inadequately dimensioned |
| Remedy: | Observe duty cycle and load limits |
| Cause: | For water-cooled systems only: Coolant flow too low |
| Remedy: | Check water level, water flow rate, water contamination, etc. Coolant pump blocked: Switch on shaft of coolant pump at the gland using a screwdriver |
| Cause: | For water-cooled systems only: "Cooling unit Ctrl" parameter is set to "OFF". |
| Remedy: | In the Setup menu, set the "Cooling unit Ctrl" parameter to "Aut" or "ON". |
| Cause: | Spattering in the gas nozzle, causing inadequate gas shield for weld seam |
| Remedy: | Remove welding spatter |
| Cause: | Holes in gas hose or imprecise gas hose connection |
| Remedy: | Replace gas hose |
| Cause: | O-ring at central connector is cut or faulty |
| Remedy: | Replace O-ring |
| Cause: | Moisture/condensate in the gas line |
| Remedy: | Dry gas line |
| Cause: | Gas flow too strong or weak |
| Remedy: | Correct gas flow |
| Cause: | Inadequate quantity of gas at the start or end of welding |
| Remedy: | Increase gas pre-flow and gas post-flow |
| Cause: | Too much parting agent applied |
| Remedy: | Remove excess parting agent/apply less parting agent |
| Cause: | Unsuitable tungsten electrode (e.g., WP electrode for DC welding) |
| Remedy: | Use suitable tungsten electrode |
| Remedy: | Screw on wearing parts tightly |
| Cause: | Tungsten electrode not protruding far enough out of the gas nozzle |
| Remedy: | Have tungsten electrode protrude more out of the gas nozzle |
This product meets the requirements set out in standard IEC 60974-7.
The performance data specifications only apply when using standard wearing parts.
When using gas lenses and shorter gas nozzles, the welding current is reduced.
The welding current specifications apply to gas-cooled torch bodies only from a length of 65 mm (2.56 in.).
When using shorter torch bodies, the welding current is reduced by 30%.
When welding at the power limit of the welding torch, use larger tungsten electrodes and gas nozzle opening diameters to increase the service life of the wearing parts.
Take amperage, AC balance, and AC current offset into account as performance-enhancing factors.
| TTB 80 G | TTB 120 G | TTB 160 G / F |
DC welding current at 10 min / 40 °C (104 °F) | 35 % D.C.1) / 80 A | 15 % D.C.1) / 120 A | 35 % D.C.1) / 160 A |
60 % D.C.1) / 60 A | 35 % D.C.1) / 80 A | 60 % D.C.1) / 120 A | |
100 % D.C.1) / 50 A | 60 % D.C.1) / 60 A | 100 % D.C.1) / 90 A | |
AC welding current at 10 min / 40 °C (104 °F) | 35 % D.C.1) / 30 A | 35 % D.C.1) / 40 A | 35 % D.C.1) / 120 A |
| 60 % D.C.1) / 90 A | ||
| 100 % D.C.1) / 70 A | ||
Shielding gas | Argon | Argon | Argon |
Electrode diameter | 1,0 - 3,2 mm | 1,0 - 3,2 mm | 1,0 - 3,2 mm |
Permissible tungsten electrode types | in accordance with standard EN ISO 6848 | ||
| TTB 160 G / F | TTB 160 P S G1) |
DC welding current | 35% D.C.1) / 160 A | 35% D.C.1) / 160 A |
60% D.C.1) / 120 A | 60% D.C.1) / 120 A | |
100% D.C.1) / 90 A | 100% D.C.1) / 90 A | |
AC welding current | 35% D.C.1) / 120 A | 35% D.C.1) / 120 A |
60% D.C.1) / 90 A | 60% D.C.1) / 90 A | |
100% D.C.1) / 70 A | 100% D.C.1) / 70 A | |
Electrode diameter | 1.0 - 2.4 mm | 1.0 - 3.2 mm |
| TTB 220 G | TTB 220 A G F | TTB 220 P G F |
DC welding current | 35% D.C.1) / 220 A | 35% D.C.1) / 220 A | 35% D.C.1) / 220 A |
60% D.C.1) / 170 A | 60% D.C.1) / 170 A | 60% D.C.1) / 160 A | |
100% D.C.1) / 130 A | 100% D.C.1) / 130 A | 100% D.C.1) / 130 A | |
AC welding current | 35% D.C.1) / 180 A | 35% D.C.1) / 180 A | 35% D.C.1) / 170 A |
60% D.C.1) / 130 A | 60% D.C.1) / 120 A | 60% D.C.1) / 120 A | |
100% D.C.1) / 100 A | 100% D.C.1) / 100 A | 100% D.C.1) / 100 A | |
Electrode diameter | 1.0 - 4.0 mm | 1.0 - 4.0 mm | 1.0 - 4.0 mm |
| TTB 220 P S G2) | TTB 220 P G TFC3) | TTB 260 G |
DC welding current | 35% D.C.1) / 220 A | 35% D.C.1) / 220 A | 35% D.C.1) / 260 A |
60% D.C.1) / 170 A | 60% D.C.1) / 170 A | 60% D.C.1) / 200 A | |
100% D.C.1) / 130 A | 100% D.C.1) / 130 A | 100% D.C.1) / 150 A | |
AC welding current | 35% D.C.1) / 180 A | 35% D.C.1) / 180 A | 35% D.C.1) / 200 A |
60% D.C.1) / 130 A | 60% D.C.1) / 130 A | 60% D.C.1) / 160 A | |
100% D.C.1) / 100 A | 100% D.C.1) / 100 A | 100% D.C.1) / 120 A | |
Electrode diameter | 1.0 - 4.0 mm | 1.0 - 3.2 mm | 1.0 - 4.0 mm |
| 1) | D.C. = Duty cycle |
| 2) | Articulated torch body |
| 3) | TFC clamping system |
| TTB 180 W | TTB 300 W |
DC welding current | 60% D.C.1) / 180 A | 60% D.C.1) / 300 A |
100% D.C.1) / 140 A | 100% D.C.1) / 230 A | |
AC welding current | 60% D.C.1) / 140 A | 60% D.C.1) / 250 A |
100% D.C.1) / 110 A | 100% D.C.1) / 190 A | |
Electrode diameter | 1.0 - 3.2 mm | 1.0 - 3.2 mm |
Minimum coolant flow Qmin | 1 l/min | 1 l/min |
| TTB 400 W F | TTB 500 W |
DC welding current | 60% D.C.1) / 400 A | 60% D.C.1) / 500 A |
100% D.C.1) / 300 A | 100% D.C.1) / 400 A | |
AC welding current | 60% D.C.1) / 320 A | 60% D.C.1) / 400 A |
100% D.C.1) / 250 A | 100% D.C.1) / 300 A | |
Electrode diameter | 1.0 - 4.0 mm | 1.0 - 6.4 mm |
| THP 160i | THP 220i |
DC welding current | 35% D.C.1) / 160 A | 35% D.C.1) / 220 A |
60% D.C.1) / 120 A | 60% D.C.1) / 170 A | |
100% D.C.1) / 90 A | 100% D.C.1) / 130 A | |
AC welding current | 35% D.C.1) / 120 A | 35% D.C.1) / 180 A |
60% D.C.1) / 90 A | 60% D.C.1) / 130 A | |
100% D.C.1) / 70 A | 100% D.C.1) / 100 A | |
Length | 4.0 / 8.0 m | 4.0 / 8.0 m |
Maximum permitted open circuit voltage (U0) | 113 V | 113 V |
Maximum permitted striking voltage (UP) | 10 kV | 10 kV |
| THP 260i |
DC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 260 A |
AC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 200 A |
| THP 300i | THP 400i |
DC welding current | 60% D.C.1) / 300 A | 60% D.C.1) / 400 A |
100% D.C.1) / 230 A | 100% D.C.1) / 300 A | |
AC welding current | 60% D.C.1) / 250 A | 60% D.C.1) / 350 A |
100% D.C.1) / 190 A | 100% D.C.1) / 270 A | |
Lowest cooling capacity as per IEC standard 60974-2 as function of hosepack length | 650 / 650 W | 950 / 950 W |
Minimum coolant pressure pmin | 3 bar | 3 bar |
Maximum coolant pressure pmax | 5.5 bar | 5.5 bar |
| THP 500i |
DC welding current at 10 min / 40 °C (104 °F) | 60% D.C.1) / 500 A |
AC welding current at 10 min / 40 °C (104 °F) | 60% D.C.1) / 400 A |
Lowest cooling capacity as per IEC standard 60974-2 as function of hosepack length | 1200 / 1750 W |
| HPT 220i EXT G |
DC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 220 A |
AC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 180 A |
Length | 10.0 m |
| HPT 400i EXT W |
DC welding current at 10 min / 40 °C (104 °F) | 60% D.C.1) / 400 A |
AC welding current at 10 min / 40 °C (104 °F) | 60% D.C.1) / 350 A |
Length | 10.0 m |
Lowest cooling capacity as per IEC standard 60974-2 as function of hosepack length | 750 / 750 W |
