Serious injury and damage to property may result.
All the work and functions described in this document must only be carried out by trained and qualified personnel.
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
Testing system /i
The testing system /i is used to check MTB R robot welding torches for dimensional deviations.
The testing system /i is available in the following configurations:
Testing/straightening system |
Testing system /i G/W system |
Testing system /i G/W V |
Straightening system /i
44,0350,5241
With the straightening system /i dimensional deviations can be corrected on the MTB R robot welding torches.
IMPORTANT! For dimensional deviations > 5 mm, you should no longer set up the torch body on your own. Send torch body to Fronius for repair.
IMPORTANT! In order to achieve optimal test results with the testing system /i, it is recommended that the system be calibrated by Fronius on a yearly basis.
If possible, use two different base plates for checking and setting up the torch bodies, for example:
Checking with testing system /i
Set up on steel “professional” base plate
| (1) | Clamping bush |
| (2) | 2 shoulder bolts 6h8 M5 x 20 mm |
| (3) | Clamp |
| * | Torch body |
| ** | Torch body holder (included in the scope of delivery of the testing system) |
| (1) | Straightening lever |
| (2) | Torque wrench |
| (3) | Union nut |
| (4) | Torch wrench |
| (5) | Straightening cup ø 16 mm Straightening cup ø 18 mm |
The base plate of the testing system /i contains various positions for mounting the testing unit.
The testing unit is pre-mounted on the 0° mounting position when delivered.
For every other torch body curvature, the testing unit must be mounted on the base plate according to the torch body curvature of the welding torch that is to be tested:
Name | Length (mm) | Length (inch) | Height (mm) | Height (inch) | Angle |
A 0° | 250 | 9.842 | 0 | 0 | 0° |
A 22° | 241 | 9.488 | 50 | 1.969 | 22° |
A 36° | 224 | 8.819 | 86 | 3.386 | 36° |
A 45° | 209 | 8.228 | 107 | 4.213 | 45° |
A1 0° | 187.5 | 7.382 | 0 | 0 | 0° |
A2 22° | 246 | 9.685 | 27 | 1.063 | 22° |
A2 45° | 228.5 | 8.996 | 56.5 | 2.224 | 45° |
A2 60° | 212 | 8.346 | 71 | 2.795 | 60° |
A3 36° | 236 | 9.291 | 44.5 | 1.752 | 36° |
B 0° | 335 | 13.189 | 0 | 0 | 0° |
B 22° | 331 | 13.032 | 27 | 1.063 | 22° |
B 45° | 313.5 | 12.342 | 56.5 | 2.224 | 45° |
B 60° | 297 | 11.692 | 71 | 2.795 | 60° |
B1 22° | 291 | 11.457 | 50 | 1.969 | 22° |
B2 22° | 325 | 12.795 | 50 | 1.969 | 22° |
B3 36° | 338 | 13.307 | 0 | 0 | 36° |
B4 36° | 321 | 12.638 | 44.5 | 1.752 | 36° |
C 22° | 383 | 15.079 | 50 | 1.969 | 22° |
C 36° | 366 | 14.409 | 86 | 3.386 | 36° |
C 45° | 351 | 13.819 | 107 | 4.134 | 45° |
The torch body is okay if
The dowel pin glides fully into the centering sleeve with ease
The dowel pin glides out of the centering sleeve with ease after the spring is released due to the spring force
If the dowel pin cannot easily be moved into or out of the centering sleeve, set up the torch body according to the chapter "Set up MTB R robot welding torch" (from page (→)).
With the testing system /i G/W System you can check complete robot welding torch systems from torch body to CrashBox for dimensional deviations.
The user is responsible for the setup and initial adjustment.
There are various possibilities available for testing, e.g.:
The base plate of the testing system /i G/W contains a wide range of positions for mounting the testing unit.
For every other torch neck curvature, the testing unit must be mounted on the base plate according to the torch neck curvature of the welding torch that is to be tested:
To distinguish between centering sleeve (2) and adjusting sleeve (1), the adjusting sleeves are equipped with two additional cross grooves.
The mounting block is designed for mounting various robot shutoff boxes.
The dowel pin must fully glide into the adjusting sleeve with ease.
The dowel pin must glide out of the adjusting sleeve with ease after the spring is released due to the spring force.
If the dowel pin doesn’t glide into the adjusting sleeve or only does so with difficulty, the complete system with mounting block must be readjusted.
The hosepack must be released during checking.
If the hosepack is not released the robot shut off box may be misaligned.
The complete system is okay if
the dowel pin glides fully into the centering sleeve with ease, and
the dowel pin glides out of the centering sleeve with ease after the spring is released due to the spring force.
If the dowel pin does not easily glide into or out of the centering sleeve, the complete system must be adjusted (e.g. at the clamp).
With the testing system /i G/W V, you can check customer-specific robot welding torch systems and special models for dimensional deviations.
The base plate of the testing system /i G/W V contains various positions for mounting the testing unit.
If the dowel pin doesn’t glide into the adjusting sleeve or only does so with difficulty, the torch body holder with torch body must be readjusted.
The fixing set /i G/W TX is an add-on for checking TX robot welding torches and is used in conjunction with the following testing systems:
Testing units are assembled as described.
Afterwards, the fixing set /i G/W TX and the TX robot welding torch are mounted on the torch body holder.
The testing process is then carried out according to the respective testing system.
If the dowel pin does not easily glide into or out of the centering sleeve, the torch body must be readjusted.
If the torch body is okay:
The testing system /i G/W V is also designed to set up customer-specific welding torches.
For the setup of the welding torch
the torch body holder must be mounted with four screws at the adjustment / centering sleeves on the testing system /i G/W V,
the welding torch must be mounted on the torch body holder.
