LogoBusmodule RI MOD/i CC Ethernet/IP-2P TWIN
  • en-US
    • Contact
    • Legal Notice
    • T&Cs
    • Data Protection
    • 012-03022023
    • General
      • Safety
      • Connections and Displays
      • Data Transfer Properties
      • Configuration Parameters
    • Setting the Bus Module IP Address
    • Input and output signals
      • Data types
      • Availability of input signals
      • Input signals (from robot to power source)
      • Value Range for Working Mode
      • Value range Process line selection
      • Value range for Operating mode TWIN System
      • Value range for Documentation mode
      • Value range for Process controlled correction
      • Availability of the output signals
      • Output signals (from power source to robot)
      • Assignment of Sensor Statuses 1–4
    Input Signals
    Output Signals
    Spare parts
    General
    Safety
    WARNING!
    Read and understand all safety rules and user documentation for this equipment and all system components.
    WARNING!
    WARNING!
    Danger from unplanned signal transmission.
    Do not transfer safety signals via the interface.
    Safety
    WARNING!
    WARNING!
    WARNING!
    RJ45 connection
    TX+
    TX-
    RX+
    6
    RX-
    4,5,7,8
    Not normally used; to ensure signal completeness, these pins must be interconnected and, after passing through a filter circuit, must terminate at the ground conductor (PE).
    (1) LED MS - Module status
    Off:
    No supply voltage
    Lights up green:
    Controlled by a master
    Flashes green (once):
    Master not configured or master idle
    Lights up red:
    Major error (exception state, serious fault, ...)
    Flashes red:
    Correctable error
    (2) LED NS - Network status
    Off:
    No supply voltage or no IP address
    Lights up green:
    Online, one or more connections established (CIP category 1 or 3)
    Flashes green:
    Online, no connection established
    Lights up red:
    Double IP address, serious error
    Flashes red:
    Overrun of time for one or more connections (CIP category 1 or 3)
    Transfer technology
    Ethernet
    Medium
    When selecting the cables and plugs, the ODVA recommendation for the planning and installation of EtherNet/IP systems must be observed.
    The EMC tests were carried out by the manufacturer with the cable IE-C5ES8VG0030M40M40-F.
    Transmission speed
    10 Mbit/s or 100 Mbit/s
    Bus connection
    RJ-45 Ethernet / M12
    In some robot control systems, it may be necessary to state the configuration parameters described here so that the bus module can communicate with the robot.
    Parameter
    Value
    Description
    Vendor ID
    0534hex (1332dec)
    Fronius International GmbH
    Device Type
    000Chex (12dec)
    Communication adapter
    Product Code
    0380hex (896dec)
    Fronius FB Pro TwinEthernet/IP-2-Port
    Product Name
    Fronius-FB-Pro-Twin-EtherNetIP(TM)
    Image Type
    Instance
    Type
    Instance
    Name
    Instance
    Description
    Instance
    Number
    Size
    [Byte]
    Standard Image
    Producing Instance
    Input Data Standard
    Data from power source to robot
    104
    60
    Consuming
    Instance
    Output Data Standard
    Data from robot to power source
    154
    60
    You can set the bus module IP address as follows:
    1. Using the DIP switch in the interface within the range defined by 192.168.0.xx
      (xx = DIP switch setting = 1 to 63)
      • All positions are set to the OFF position at the factory. In this case, the IP address must be set on the website of the power source
    2. On the website of the power source (if all positions of the DIP switch are set to the OFF position)
    The IP address is set using DIP switch positions 1 to 6. The setting is in binary format. This results in a configuration range of 1 to 63 in decimal format.
    Example for setting the IP address of the bus module using the DIP switch in the interface:
    DIP-Switch
    8
    7
    6
    5
    IP Adress
    OFF
    OFF
    OFF
    OFF
    OFF
    ON
    OFF
    OFF
    OFF
    OFF
    ON
    OFF
    OFF
    OFF
    OFF
    OFF
    ON
    ON
    ON
    ON
    ON
    ON
    ON
    OFF
    62
    ON
    ON
    ON
    ON
    ON
    ON
    63
    Instructions for setting the IP address on the website of the power source (SmartManager):
    Note down the IP address of the power source used:
    1On the power source control panel, select "Defaults"
    2On the power source control panel, select "System"
    3On the power source control panel, select "Information"
    4Note down the displayed IP address (example: 10.5.72.13)
    Access the website of the power source in the internet browser:
    5Connect the computer to the network of the power source
    6Enter the IP address of the power source in the search bar of the Internet browser and confirm
    7Enter the standard user name (admin) and password (admin)
    • The website of the power source is displayed
    Set the bus module IP address:
    8On the power source website, select the "RI FB PRO/i TWIN" tab
    9Enter the desired IP address for the interface under "Module configuration".
    For example: 192.168.0.12
    10Select "Set configuration"
    11Select "Restart module"
    • The set IP address is applied
    DIP-Switch
    8
    7
    6
    5
    IP Adress
    OFF
    OFF
    OFF
    OFF
    OFF
    ON
    OFF
    OFF
    OFF
    OFF
    ON
    OFF
    OFF
    OFF
    OFF
    OFF
    ON
    ON
    ON
    ON
    ON
    ON
    ON
    OFF
    62
    ON
    ON
    ON
    ON
    ON
    ON
    63
    Data types
    The following data types are used:
    • UINT16 (Unsigned Integer)
      Whole number in the range from 0 to 65535
    • SINT16 (Signed Integer)
      Whole number in the range from -32768 to 32767
    Conversion examples:
    • for a positive value (SINT16)
      e.g. desired wire speed x factor
      12.3 m/min x 100 = 1230dec = 04CEhex
    • for a negative value (SINT16)
      e.g. arc correction x factor
      -6.4 x 10 = -64dec = FFC0hex
    Data types
    The input signals listed below are available as of firmware V1.8.0 of the RI FB PRO/i TWIN.
    Address
    Relative
    Absolute
    WORD
    BYTE
    BIT
    BIT
    Signal
    Activity/
    data type
    Range
    Factor
    0
    0
    0
    0
    Welding Start
    Increasing
    Robot ready
    High
    Working mode Bit 0
    High
    See following table Value Range for Working Mode on page (→)
    Working mode Bit 1
    High
    Working mode Bit 2
    High
    5
    5
    Working mode Bit 3
    High
    6
    6
    Working mode Bit 4
    High
    7
    7
    0
    8
    Gas on
    Increasing
    9
    Wire forward
    Increasing
    10
    Wire backward
    Increasing
    11
    Error quit
    Increasing
    12
    Touch sensing
    High
    5
    13
    Torch blow out
    Increasing
    6
    14
    Processline selection Bit 0 (only available for single-wire applications)
    High
    See following table Value range Process line selection on page (→)
    7
    15
    Processline selection Bit 1 (only available for single-wire applications)
    High
    0
    16
    Welding Simulation
    High
    17
    18
    19
    20
    5
    21
    6
    22
    Wire brake on
    High
    7
    23
    Torchbody Xchange
    High
    0
    24
    25
    Teach mode
    High
    26
    27
    28
    5
    29
    Wire sense start
    Increasing
    6
    30
    Wire sense break
    Increasing
    7
    31
    0
    32
    Bit 0
    High
    See following table Value range for Operating mode TWIN System on page (→)
    33
    Bit 1
    High
    34
    35
    36
    5
    37
    Documentation mode
    High
    See following table Value range for Documentation mode on page (→)
    6
    38
    7
    39
    5
    0
    40
    41
    42
    43
    44
    5
    45
    6
    46
    7
    47
    Disable process controlled correction, Power source 1
    High
    6
    0
    48
    49
    50
    51
    52
    5
    53
    6
    54
    7
    55
    7
    0
    56
    ExtInput1 => OPT_Output 1
    High
    57
    ExtInput2 => OPT_Output 2
    High
    58
    ExtInput3 => OPT_Output 3
    High
    59
    ExtInput4 => OPT_Output 4
    High
    60
    ExtInput5 => OPT_Output 5
    High
    5
    61
    ExtInput6 => OPT_Output 6
    High
    6
    62
    ExtInput7 => OPT_Output 7
    High
    7
    63
    ExtInput8 => OPT_Output 8
    High
    8
    0
    64
    65
    66
    67
    68
    5
    69
    6
    70
    7
    71
    Disable Process controlled correction, Power source 2
    High
    9
    0
    72
    Contact tip short circuit detection on
    High
    73
    74
    75
    76
    5
    77
    6
    78
    7
    79
    5
    10
    0–7
    80–87
    11
    0–7
    88–95
    6
    12
    0–7
    96–103
    Welding characteristic- / Job number, Power source 1
    UINT16
    0 to 1000
    13
    0–7
    104–111
    7
    14
    0–7
    112–119
    Welding characteristic- / Job number, Power source 2
    UINT16
    0 to 1000
    15
    0–7
    120–127
    8
    16, 17
    0–7
    128–143
    For the welding processes
    MIG/MAG pulse synergic,
    MIG/MAG standard synergic,
    MIG/MAG standard manual,
    MIG/MAG PMC,
    MIG/MAG LSC,
    CMT, ConstantWire:
    Wire feed speed command value, Power source 1
    SINT16
    -327.68 to 327.67
    [m/min]
    100
    For job mode:
    Power correction, Power source 1
    SINT16
    -20.00 to 20.00
    100
    9
    18, 19
    0–7
    144–159
    MIG/MAG PMC,
    MIG/MAG LSC,
    CMT, ConstantWire:
    Wire feed speed command value, Power source 2
    SINT16
    -327.68 to 327.67
    [m/min]
    100
    For job mode:
    Power correction, Power source 2
    SINT16
    -20.00 to 20.00
    100
    10
    20, 21
    0–7
    160–175
    MIG/MAG PMC,
    MIG/MAG LSC,
    CMT:
    Arclength correction, Power source 1
    SINT16
    -10.0 to 10.0
    [steps]
    10
    MIG/MAG standard manual:
    Welding voltage, Power source 1
    UINT16
    0.0 to 6553.5
    [V]
    10
    For job mode:
    SINT16
    -10.0 to 10.0
    [steps]
    10
    For the welding process ConstantWire:
    Hotwire current, Power source 1
    UINT16
    0.0 to 6553.5
    [A]
    10
    11
    22, 23
    0–7
    176–191
    MIG/MAG PMC,
    MIG/MAG LSC,
    CMT:
    Arclength correction, Power source 2
    SINT16
    -10.0 to 10.0
    [steps]
    10
    Welding voltage, Power source 2
    UINT16
    0.0 to 6553.5
    [V]
    10
    For job mode:
    SINT16
    -10.0 to 10.0
    [steps]
    10
    Hotwire current, Power source 2
    UINT16
    0.0 to 6553.5
    [A]
    10
    12
    24, 25
    0–7
    192–207
    MIG/MAG PMC,
    MIG/MAG LSC,
    CMT:
    Pulse-/dynamic correction, Power source 1
    SINT16
    -10.0 to 10.0
    [steps]
    10
    Dynamic, Power source 1
    UINT16
    0.0 to 10.0
    [steps]
    10
    13
    26, 27
    0–7
    208–223
    MIG/MAG PMC,
    MIG/MAG LSC,
    CMT:
    Pulse-/dynamic correction, Power source 2
    SINT16
    -10.0 to 10.0
    [steps]
    10
    Dynamic, Power source 2
    UINT16
    0.0 to 10.0
    [steps]
    10
    14
    28
    0–7
    224–231
    Wire retract correction, Power source 1
    UINT16
    0.0 to 10.0
    10
    29
    0–7
    232–239
    15
    30
    0–7
    240–247
    Wire retract correction, Power source 2
    UINT16
    0.0 to 10.0
    10
    31
    0–7
    248–255
    16
    32
    0–7
    256–263
    Welding speed
    UINT16
    0.0 to 1000
    [m/min]
    10
    33
    0–7
    264–271
    17
    34
    0–7
    272–279
    Process controlled correction, Power source 1
    SINT16
    See table Value range for Process controlled correction on page (→)
    35
    0–7
    280–287
    18
    36
    0–7
    288–295
    SINT16
    37
    0–7
    296–303
    19
    38
    0–7
    304–311
    Wire forward / backward length
    UINT16
    OFF / 1 to 65535
    [mm]
    39
    0–7
    312–319
    20
    40
    0–7
    320–327
    Wire sense edge detection
    UINT16
    OFF / 0.5 to 20.0
    [mm]
    10
    41
    0–7
    328–335
    21
    42
    0–7
    336–343
    43
    0–7
    344–351
    22
    44
    0–7
    352–359
    45
    0–7
    360–367
    23
    46
    0–7
    368–375
    47
    0–7
    376–383
    24
    48
    0–7
    384–391
    49
    0–7
    392–399
    25
    50
    0–7
    400–407
    51
    0–7
    408–415
    26
    52
    0–7
    416–423
    53
    0–7
    424–431
    27
    54
    0–7
    432–439
    55
    0–7
    440–447
    28
    56
    0–7
    448–455
    57
    0–7
    456–463
    29
    58
    0–7
    464–471
    Seam number
    UINT16
    0 to 65535
    59
    0–7
    472–479
    Bit 4
    Bit 3
    Bit 2
    Bit 1
    Bit 0
    Description
    0
    0
    0
    0
    0
    Internal parameter selection
    0
    0
    0
    0
    Special 2-step mode characteristics
    0
    0
    0
    0
    Job mode
    0
    0
    0
    0
    0
    0
    0
    2-step MIG/MAG standard manual
    0
    0
    0
    Stop coolant pump
    Value range for operating mode
    Bit 1
    Bit 0
    Description
    0
    0
    Process line 1 (default)
    0
    Process line 2
    0
    Process line 3
    Reserved
    Value range for process line selection
    Bit 1
    Bit 0
    Function power source 1
    Function power source 2
    0
    0
    Single mode
    OFF
    0
    TWIN Lead
    TWIN Trail
    0
    TWIN Trail
    TWIN Lead
    OFF
    Single mode
    Value range for TWIN System Mode
    Bit 0
    Description
    0
    Seam number of power source (internal)
    Seam number of robot (Word 29)
    Value range for documentation mode
    Process
    Signal
    Activity /
    data type
    Value range
    configuration range
    Unit
    Factor
    PMC
    Arc length stabilizer
    SINT16
    -327.8 to +327.7
    0.0 to +5.0
    Volts
    10
    Value range for process-dependent correction
    The output signals listed below are available as of firmware V1.8.0 of the RI FB PRO/i TWIN.
    Address
    Relative
    Absolute
    WORD
    BYTE
    BIT
    BIT
    Signal
    Activity/
    data type
    Range
    Factor
    0
    0
    0
    0
    Heartbeat Powersource
    High/low
    1 Hz
    Power source ready
    High
    Warning
    High
    Process active
    High
    Current flow
    High
    5
    5
    Arc stable- / touch signal
    High
    6
    6
    Main current signal
    High
    7
    7
    Touch signal
    High
    0
    8
    Collisionbox active
    Low
    0 = collision or cable break
    9
    Robot Motion Release, Power source 1
    High
    10
    Wire stick workpiece
    High
    11
    12
    Short circuit contact tip
    High
    5
    13
    Parameter selection internally
    High
    6
    14
    7
    15
    Torch body gripped
    High
    0
    16
    Command value out of range
    High
    17
    Correction out of range
    High
    18
    19
    Limitsignal, Power Source 1
    High
    20
    5
    21
    6
    22
    Main supply status
    Low
    7
    23
    0
    24
    Sensor status 1, Power Source 1
    High
    See table Assignment of Sensor Statuses 1–4 on page (→)
    25
    Sensor status 2, Power Source 1
    High
    26
    Sensor status 3, Power Source 1
    High
    27
    Sensor status 4, Power Source 1
    High
    28
    5
    29
    6
    30
    7
    31
    0
    32
    33
    34
    35
    Safety status Bit 0, Power Source 1
    High
    36
    Safety status Bit 1, Power Source 1
    High
    5
    37
    6
    38
    Notification
    High
    7
    39
    System not ready
    High
    5
    0
    40
    41
    42
    43
    44
    5
    45
    6
    46
    7
    47
    6
    0
    48
    49
    50
    51
    52
    5
    53
    6
    54
    Gas nozzle touched
    High
    7
    55
    7
    0
    56
    ExtOutput1 <= OPT_Input1
    High
    57
    ExtOutput2 <= OPT_Input2
    High
    58
    ExtOutput3 <= OPT_Input3
    High
    59
    ExtOutput4 <= OPT_Input4
    High
    60
    ExtOutput5 <= OPT_Input5
    High
    5
    61
    ExtOutput6 <= OPT_Input6
    High
    6
    62
    ExtOutput7 <= OPT_Input7
    High
    7
    63
    ExtOutput8 <= OPT_Input8
    High
    8
    0
    64
    65
    Robot Motion Release, Power source 2
    High
    66
    Limitsignal, Power source 2
    High
    67
    68
    5
    69
    6
    70
    7
    71
    9
    0
    72
    73
    74
    75
    76
    5
    77
    6
    78
    7
    79
    5
    10
    0
    80
    Sensor status 1, Power Source 2
    High
    81
    Sensor status 2, Power Source 2
    High
    82
    Sensor status 3, Power Source 2
    High
    83
    Sensor status 4, Power Source 2
    High
    84
    5
    85
    6
    86
    7
    87
    11
    0
    88
    89
    90
    91
    Safety status Bit 0, Power Source 2
    High
    92
    Safety status Bit 1, Power Source 2
    High
    5
    93
    6
    94
    7
    95
    6
    12
    0–7
    96–103
    UINT16
    0.0 to 655.35 [V]
    100
    13
    0–7
    104–111
    7
    14
    0–7
    112–119
    UINT16
    0.0 to 655.35 [V]
    100
    15
    0–7
    120–127
    8
    16
    0–7
    128–135
    Welding current, Power source 1
    UINT16
    0.0 to 6553.5 [A]
    10
    17
    0–7
    136–143
    9
    18
    0–7
    144–151
    Welding current, Power source 2
    UINT16
    0.0 to 6553.5 [A]
    10
    19
    0–7
    152–159
    10
    20
    0–7
    160–167
    Wire feed speed, Power source 1
    SINT16
    -327.68 to 327.67
    [m/min]
    100
    21
    0–7
    168–175
    11
    22
    0–7
    176–183
    Wire feed speed, Power source 2
    SINT16
    -327.68 to 327.67
    [m/min]
    100
    23
    0–7
    184–191
    12
    24
    0–7
    192–199
    Actual real value for seam tracking
    UINT16
    0 to 6.5535
    10000
    25
    0–7
    200–207
    13
    26
    0–7
    208–215
    Error number, Power source 1
    UINT16
    0 to 65535
    27
    0–7
    216–223
    14
    28
    0–7
    224–231
    Error number, Power source 2
    UINT16
    0 to 65535
    29
    0–7
    232–239
    15
    30
    0–7
    240–247
    Motor current M1, Power source 1
    UINT16
    -327.68 to 327.67 [A]
    100
    31
    0–7
    248–255
    16
    32
    0–7
    256–263
    Motor current M1, Power source 2
    UINT16
    100
    33
    0–7
    264–271
    17
    34
    0–7
    272–279
    Motor current M2, Power source 1
    UINT16
    100
    35
    0–7
    280–287
    18
    36
    0–7
    288–295
    Motor current M2, Power source 2
    UINT16
    100
    37
    0–7
    296–303
    19
    38
    0–7
    304–311
    Motor current M3, Power source 1
    UINT16
    100
    39
    0–7
    312–319
    20
    40
    0–7
    320–327
    Motor current M3, Power source 2
    UINT16
    100
    41
    0–7
    328–335
    21
    42
    0–7
    336–343
    Warning,, Power Source 1
    UINT16
    0 to 65535
    43
    0–7
    344–351
    22
    44
    0–7
    352–359
    Warning,, Power source 2
    UINT16
    0 to 65535
    45
    0–7
    360–367
    23
    46
    0–7
    368–375
    Wire position, Power source 1
    UINT16
    -327.68 to 327.67 [mm]
    100
    47
    0–7
    376–383
    24
    48
    0–7
    284–291
    Wire position, Power source 2
    UINT16
    100
    49
    0–7
    292–399
    25
    50
    0–7
    400–407
    51
    0–7
    408–415
    26
    52
    0–7
    416–423
    53
    0–7
    424–431
    27
    54
    0–7
    432–439
    55
    0–7
    440–447
    28
    56
    0–7
    448–455
    57
    0–7
    456–463
    29
    58
    0–7
    464–471
    59
    0–7
    472–479
    Signal
    Description
    Sensor status 1
    OPT/i WF R wire end (4,100,869)
    Sensor status 2
    OPT/i WF R wire drum (4,100,879)
    Sensor status 3
    OPT/i WF R ring sensor (4,100,878)
    Sensor status 4
    Wire buffer set CMT TPS/i (4,001,763)
