en
      Operating instructionsTTB 80 - 300, THP 120 - 300 SH
    • Safety
      • Safety
      • Intended use
    • Welding torch variants
      • Available welding torch variants
    • Functions of the Up/Down torch
      • Operating elements of the Up/Down-torch
      • Functional description of the Up/Down-torch
    • Mounting the Wearing Parts
      • Fitting an A-type wearing part with gas nozzle (push-on type)
      • Fitting a P-type wearing part with gas nozzle (screw type)
    • Fitting the torch body and connecting the welding torch
      • Connecting the welding torch
      • Rotating the torch body
    • Changing the torch body of a gas-cooled welding torch
    • Changing the torch body of a water-cooled welding torch
      • Automatic emptying of the welding torch and changing the torch body
      • Manually emptying the welding torch and changing the torch body
    • Service, maintenance and disposal
      • Prohibited
      • Maintenance at every start-up
      • Disposal
    • Troubleshooting
      • Troubleshooting
    • Technical data
      • General
      • Gas-cooled torch body –
        TTB 80,TTB 120, TTB 160, TTB 220
      • Water-cooled torch body -
        TTB 180, TTB 300
      • Gas-cooled hosepack -
        THP 120 G SH,
        THP 180 G SH
        THP 150 G SH
      • Water-cooled hosepack - THP 300 SH
    • 005-21042026
    download
    Fitting wearing parts, A-type
    Fitting wearing parts, P-type
    Maintenance
    Troubleshooting
    Technical data
    Spare parts
    ContactLegal NoticeGeneral Terms & ConditionsData Privacy StatementCookie Policy
    Safety
    link_horizontalLink copied
    Safety
    WARNING!
    Read and understand all safety rules and user documentation for this equipment and all system components.
    WARNING!
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, leads, and hosepacks must always be securely connected, undamaged, and correctly insulated.
    Only use adequately dimensioned cables, leads, and hosepacks.
    WARNING!
    Danger from contact with toxic welding fumes.
    Serious personal injuries may result.
    Always extract welding fumes.
    Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ (11.77 cfm) per hour at all times.
    In case of doubt, the concentration of noxious substances at the work station should be assessed by a safety engineer.
    CAUTION!
    Danger due to hot system components and/or equipment.
    This can result in burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
    Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
    CAUTION!
    Danger from operation without coolant.
    Never commission water-cooled devices without coolant.
    During welding, ensure that the coolant is circulating correctly. When using Fronius cooling units, this will be the case if proper return flow of coolant can be seen in the cooling unit’s coolant container.
    CAUTION!
    Risk of coolant escaping.
    Personal injury and damage to property may result.
    When disconnecting a water-cooled welding torch from the cooling unit or other system components, always seal the coolant hoses using the plastic seal attached to the torch.
    1. Safety
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    CAUTION!
    1. Safety
    Intended use
    The TIG manual welding torch is intended solely for TIG welding and TIG brazing in manual applications.
    Any other use is deemed to be "not in accordance with the intended purpose.”
    Intended use also means:
    • Following all the instructions in the Operating Instructions
    • Carrying out all the specified inspection and maintenance work.
    (1)
    Standard interface
    Pushing the button backward:
    1. If high frequency ignition (HF ignition) is activated at the power source, the ignition process is activated
    2. When contact ignition is activated on the power source, the welding voltage is applied to the tungsten electrode. The welding process starts when the torch contacts the workpiece
    Pushing the button forward during welding:
    1. When welding in 4-step mode, intermediate lowering is activated by pushing the button forward and holding it in place. This function is only available if the lowering current I2 has been set on the power source
    (2)
    Potentiometer interface
    Pressing the Start button:
    Potentiometer:
    1. For adjusting the welding current
    (3)
    Without torch trigger
    (4)
    Standard interface with torch trigger extension
    (5)
    Up-Down interface (not shown)
    The welding torch is supplied from the factory with an Up/Down interface. For more information, see the following section Functions of the Up/Down torch from page (→).
    1. Welding torch variants
    (1)
    Standard interface
    (2)
    Potentiometer:
    (3)
    (4)
    (5)
    (1)
    Start button
    The button initiates the following functions:
    1. If high frequency ignition (HF ignition) is activated on the power source, the ignition process is activated by pushing the button backward
    2. If touch ignition is activated on the power source, the welding voltage is applied to the tungsten electrode by pushing the button backward. The welding process starts when the torch contacts the workpiece
    3. When welding in 4-step mode, intermediate lowering is activated by pushing the button forward and holding it in place. This function is only available if the lowering current I2 has been set on the power source
    (2)
    Up/Down button
    For changing the welding power
    1. Functions of the Up/Down torch
    (1)
    Start button
    (2)
    Up/Down button
    Changing the welding power:
    Intermediate lowering:
    Push the button forward and hold until intermediate lowering is complete
    CAUTION!
    Risk of damage due to excessive tightening torque on the fixing sleeve (1) or gas lens (2).
    Damage to the thread may result.
    Only tighten the fixing sleeve (1) or gas lens (2) a little.
    Replaceable rubber sealing sleeve only for TTB 220 G/A
    A gas lens (2) may be used instead of the fixing sleeve (1) depending on the type of welding torch
    CAUTION!
    Risk of damage due to excessive tightening torque on the torch cap.
    Only tighten the torch cap enough so that the tungsten electrode can no longer be moved by hand.
    Screw down the torch cap
    1. Mounting the Wearing Parts
    CAUTION!
    CAUTION!
    CAUTION!
    Replaceable rubber sealing sleeve only for TTB 220 G/P
    CAUTION!
    NOTE!
    Risk due to damaged O-ring on the torch body.
    A damaged O-ring on the torch body can lead to contamination of the shielding gas, resulting in a defective weld.
    Before each start-up, ensure that the O-ring on the torch body is undamaged.
    1* Grease the O-ring on the torch body
    Push the torch body locking device fully back and at the same time turn the torch body 180°
    CAUTION!
    Danger due to incorrectly fitted torch body.
    Ensure that the locking device is fully forward after fitting the torch body - only then is the torch body properly fitted and locked.
    1. Fitting the torch body and connecting the welding torch
    NOTE!
    CAUTION!
    NOTE!
    Risk due to damaged O-ring on the welding torch connection.
    A damaged O-ring on the welding torch connection can lead to contamination of the shielding gas, resulting in a defective weld.
    Before each start-up, ensure that the O-ring on the welding torch connection is undamaged.
    * only with water-cooled welding system
    Removing the torch body:
    4Remove contamination from the hosepack interface
    5Remove contamination from the torch body interface
    6Fit the protective cap to the torch body interface
    Fitting the torch body:
    CAUTION!
    Danger due to incompatible system components.
    Only connect torch bodies and hosepacks that are using the same type of cooling.
    Only fit gas-cooled torch bodies to gas-cooled hosepacks.
    NOTE!
    CAUTION!
    5Perform a test weld and check the quality of the weld
    1. Changing the torch body of a gas-cooled welding torch
    CAUTION!
    NOTE!
    CAUTION!
    CAUTION!
    Danger from switched on power source during automatic emptying of the welding torch.
    Unintentional arc ignitions can occur.
    Follow the instructions for automatic emptying of the welding torch in the cooling unit Operating Instructions, the power source Operating Instructions, and on the power source control panel.
    When carrying out the work on the torch body as described below, keep at least 1 m (39.37 in.) away from electrically conductive objects.
    Automatic emptying of the welding torch (e.g., with CU 600t /MC) and removing the torch body:
    1Empty the torch hosepack using the corresponding cooling unit function
    5Remove contamination and coolant residues from the hosepack interface
    6Remove contamination and coolant residues from the torch body interface
    7Fit the protective cap to the torch body interface
    CAUTION!
    Only fit water-cooled torch bodies to water-cooled hosepacks.
    NOTE!
    CAUTION!
    5Press the gas-test button on the power source
    Shielding gas flows out for 30 s.
    6Check the coolant flow:
    You must be able to see a strong return flow into the cooling unit coolant container.
    7Perform a test weld and check the quality of the weld
    1. Changing the torch body of a water-cooled welding torch
    CAUTION!
    CAUTION!
    NOTE!
    CAUTION!
    Manually emptying the welding torch and removing the torch body:
    1Switch off the power source and disconnect from the grid
    2Wait for the cooling unit to run down
    3Shut off the coolant supply hose from the cooling unit
    4Purge the coolant supply hose with compressed air at maximum 4 bar (58.02 psi)
    • This will cause a large part of the coolant to flow back into the coolant container
    5
    6
    7
    8Remove contamination and coolant residues from the hosepack interface
    9Remove contamination and coolant residues from the torch body interface
    10Fit the protective cap to the torch body interface
    CAUTION!
    NOTE!
    CAUTION!
    5Connect the power source to the grid and switch on
    6Press the gas-test button on the power source
    7Check the coolant flow:
    8Perform a test weld and check the quality of the weld
    Prohibited
    1. Service, maintenance and disposal
    Prohibited
    • Check wearing parts, replace faulty wearing parts
    • Purge the gas nozzle of welding spatter
    In addition to the above list of steps to be carried out at every start-up, for water-cooled welding torches:
    • Ensure that all coolant connections are leak-tight
    • Ensure that there is a proper coolant return flow
    Disposal
    Materials should be disposed of according to valid local and national regulations.
    Troubleshooting
    Troubleshooting
    1. Troubleshooting
    Troubleshooting
    Welding torch cannot be connected
    Cause:Bayonet lock bent
    Remedy:Replace bayonet lock
    No welding current
    Power source switched on, power source indication illuminates, shielding gas present
    Cause:Incorrect ground connection
    Remedy:Establish proper ground connection
    Cause:Power cable in welding torch interrupted
    Remedy:Replace welding torch
    Cause:Tungsten electrode loose
    Remedy:Tighten tungsten electrode using torch cap
    Cause:Wearing parts loose
    Remedy:Tighten wearing parts
    No function after pressing torch trigger
    Cause:Power plug not plugged in
    Remedy:Plug in power plug
    Cause:Welding torch or welding torch control line faulty
    Cause:Plug connections "torch trigger/control line/power source" faulty
    Remedy:Check plug connection / send power source or welding torch to service team
    Cause:PCB in welding torch faulty
    Remedy:Replace PCB
    HF flashover at welding torch connection
    Cause:Welding torch connection not sealed
    Remedy:Replace O-ring on the bayonet lock
    HF flashover at the shell-type handle
    Cause:Hosepack is not sealed
    Remedy:Replace hosepack
    Cause:Shielding gas hose connection to torch body not sealed
    Remedy:Adjust and seal hose
    No shielding gas
    All other functions present
    Cause:Gas cylinder empty
    Remedy:Change gas cylinder
    Cause:Gas pressure regulator faulty
    Remedy:Replace gas pressure regulator
    Cause:Gas hose kinked, damaged, or not attached
    Remedy:Attach and straighten gas hose. Replace faulty gas hose
    Cause:Welding torch faulty
    Cause:Gas solenoid valve faulty
    Remedy:Contact service team (have gas solenoid valve replaced)
    Poor-quality weld properties
    Cause:Incorrect welding parameters
    Remedy:Check settings
    Remedy:Check ground connection and terminal for polarity
    Welding torch gets very hot
    Cause:Welding torch is inadequately dimensioned
    Remedy:Observe duty cycle and load limits
    Cause:For water-cooled systems only: Coolant flow too low
    Remedy:Check water level, water flow rate, water contamination, etc. Coolant pump blocked: Switch on shaft of coolant pump at the gland using a screwdriver
    Cause:For water-cooled systems only: "Cooling unit Ctrl" parameter is set to "OFF".
    Remedy:In the Setup menu, set the "Cooling unit Ctrl" parameter to "Aut" or "ON".
    Porosity of weld seam
    Cause:Spattering in the gas nozzle, causing inadequate gas shield for weld seam
    Remedy:Remove welding spatter
    Cause:Holes in gas hose or imprecise gas hose connection
    Remedy:Replace gas hose
    Cause:O-ring at central connector is cut or faulty
    Cause:Moisture/condensate in the gas line
    Remedy:Dry gas line
    Cause:Gas flow too strong or weak
    Remedy:Correct gas flow
    Cause:Inadequate quantity of gas at the start or end of welding
    Remedy:Increase gas pre-flow and gas post-flow
    Cause:Too much parting agent applied
    Remedy:Remove excess parting agent/apply less parting agent
    Poor ignition properties
    Cause:Unsuitable tungsten electrode (e.g., WP electrode for DC welding)
    Remedy:Use suitable tungsten electrode
    Remedy:Screw on wearing parts tightly
    Gas nozzle is cracked
    Cause:Tungsten electrode not protruding far enough out of the gas nozzle
    Remedy:Have tungsten electrode protrude more out of the gas nozzle
    Technical data
    General
    This product meets the requirements set out in standard IEC 60974-7.
    NOTE!
    The performance data specifications only apply when using standard wearing parts.
    When using gas lenses and shorter gas nozzles, the welding current is reduced.
    NOTE!
    The welding current specifications apply to gas-cooled torch bodies only from a length of 65 mm (2.56 in.).
    When using shorter torch bodies, the welding current is reduced by 30%.
    NOTE!
    When welding at the power limit of the welding torch, use larger tungsten electrodes and gas nozzle opening diameters to increase the service life of the wearing parts.
    Take amperage, AC balance, and AC current offset into account as performance-enhancing factors.
    1. Technical data
    General
    NOTE!
    NOTE!
    NOTE!
    1. Technical data
    TTB 80 G
    TTB 120 G
    TTB 160 G / F
    DC welding current at 10 min / 40 °C (104 °F)
    35 % D.C.1) / 80 A
    15 % D.C.1) / 120 A
    35 % D.C.1) / 160 A
    60 % D.C.1) / 60 A
    35 % D.C.1) / 80 A
    60 % D.C.1) / 120 A
    100 % D.C.1) / 50 A
    60 % D.C.1) / 60 A
    100 % D.C.1) / 90 A
    100 % D.C.1) / 50 A
    AC welding current at 10 min / 40 °C (104 °F)
    35 % D.C.1) / 30 A
    35 % D.C.1) / 40 A
    35 % D.C.1) / 120 A
    60 % D.C.1) / 90 A
    100 % D.C.1) / 70 A
    Shielding gas
    (Standard EN ISO 14175)
    Argon
    Argon
    Argon
    Electrode diameter
    1,0 - 3,2 mm
    (0.039 - 0.126 in.)
    1,0 - 3,2 mm
    (0.039 - 0.126 in.)
    1,0 - 3,2 mm
    (0.039 - 0.126 in.)
    Permissible tungsten electrode types
    in accordance with standard EN ISO 6848
    TTB 220 G
    35% D.C.1) / 220 A
    60% D.C.1) / 170 A
    100% D.C.1) / 130 A
    35% D.C.1) / 180 A
    60% D.C.1) / 130 A
    100% D.C.1) / 100 A
    Shielding gas (Standard EN ISO 14175)
    Argon
    Electrode diameter
    1.0 - 4.0 mm
    0.039 - 0.158 in.
    TTB 220 A G F
    TTB 220 P G F
    35% D.C.1) / 220 A
    30% D.C.1) / 220 A
    60% D.C.1) / 170 A
    60% D.C.1) / 160 A
    100% D.C.1) / 130 A
    100% D.C.1) / 130 A
    35% D.C.1) / 180 A
    30% D.C.1) / 170 A
    60% D.C.1) / 120 A
    60% D.C.1) / 120 A
    100% D.C.1) / 100 A
    100% D.C.1) / 100 A
    Argon
    Argon
    Electrode diameter
    1.0 - 4.0 mm
    0.039 - 0.158 in.
    1.0 - 4.0 mm
    0.039 - 0.158 in.
    1)
    D.C. = duty cycle
    1. Technical data
    TTB 180, TTB 300
    TTB 180 W
    TTB 300 W
    60% D.C.1) / 180 A
    60% D.C.1) / 300 A
    100% D.C.1) / 140 A
    100% D.C.1) / 230 A
    60% D.C.1) / 140 A
    60% D.C.1) / 250 A
    100% D.C.1) / 110 A
    100% D.C.1) / 190 A
    Argon
    Argon
    Electrode diameter
    1.0 - 3.2 mm
    (0.039 - 0.126 in.)
    1.0 - 3.2 mm
    (0.039 - 0.126 in.)
    Minimum permissible coolant flow Qmin
    1 l/min
    (0.26 gal/min)
    1 l/min
    (0.26 gal/min)
    1)
    D.C. = duty cycle
    1. Technical data
    THP 120 G SH,
    THP 180 G SH
    THP 120 G SH
    THP 180 G SH
    DC welding current
    35% D.C.1) / 120 A
    35% D.C.1) / 180 A
    60% D.C.1) / 100 A
    60% D.C.1) / 130 A
    100% D.C.1) / 80 A
    100% D.C.1) / 100 A
    AC welding current
    35% D.C.1) / 90 A
    35% D.C.1) / 120 A
    60% D.C.1) / 70 A
    60% D.C.1) / 90 A
    100% D.C.1) / 50 A
    100% D.C.1) / 70 A
    Argon
    Argon
    4.0 m / 8.0 m
    (13 ft. + 1.48 in. / 26 ft. + 2.96 in.)
    4.0 m / 8.0 m
    Maximum permitted open circuit voltage (U0)
    113 V
    113 V
    Maximum permitted striking voltage (UP)
    10 kV
    10 kV
    Torch trigger Umax
    35 V
    35 V
    Torch trigger Imax
    100 mA
    100 mA
    1)
    D.C. = duty cycle
    1. Technical data
    THP 150 G SH
    NOTE!
    The THP 150 G SH hosepack is not intended or suitable for arc ignition devices, for example high frequency ignition.
    The hosepack is intended for use with TransPocket 150/180 and AccuPocket 150 power sources only.
    THP 150 G SH
    DC welding current
    25% D.C.1) / 150 A
    35% D.C.1) / 120 A
    60% D.C.1) / 100 A
    100% D.C.1) / 80 A
    AC welding current
    25% D.C.1) / 110 A
    35% D.C.1) / 90 A
    60% D.C.1) / 70 A
    100% D.C.1) / 50 A
    Argon
    4.0 m / 8.0 m
    Maximum permitted open circuit voltage U0
    113 V
    Maximum permitted striking voltage UP
    Not intended for or suitable for arc ignition devices!
    1)
    D.C. = duty cycle
    1. Technical data
    THP 300 SH
    DC welding current
    60% D.C.1) / 300 A
    100% D.C.1) / 230 A
    AC welding current
    60% D.C.1) / 250 A
    100% D.C.1) / 190 A
    Argon
    4.0 m / 8.0 m
    (13 ft. + 1.48 in. / 26 ft + 2.96 in.)
    Lowest cooling capacity as per IEC standard 60974-2, depending on the hosepack length
    650 W / 650 W
    1 l/min
    (0.26 gal./min [US])
    Minimum permissible coolant pressure pmin
    3 bar
    (43 psi)
    Maximum permissible coolant pressure pmax
    5.5 bar
    (79 psi)
    113 V
    10 kV
    1)
    D.C. = duty cycle
