Read and understand all safety rules and user documentation for this equipment and all system components.
Danger from electric current due to defective system components and incorrect operation.
All cables, leads, and hosepacks must always be securely connected, undamaged, and correctly insulated.
Only use adequately dimensioned cables, leads, and hosepacks.
Danger from contact with toxic welding fumes.
Serious personal injuries may result.
Always extract welding fumes.
Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ (11.77 cfm) per hour at all times.
In case of doubt, the concentration of noxious substances at the work station should be assessed by a safety engineer.
Danger due to hot system components and/or equipment.
This can result in burns or scalding.
Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
Danger from operation without coolant.
Never commission water-cooled devices without coolant.
During welding, ensure that the coolant is circulating correctly. When using Fronius cooling units, this will be the case if proper return flow of coolant can be seen in the cooling unit’s coolant container.
Risk of coolant escaping.
Personal injury and damage to property may result.
When disconnecting a water-cooled welding torch from the cooling unit or other system components, always seal the coolant hoses using the plastic seal attached to the torch.
The TIG manual welding torch is intended solely for TIG welding and TIG brazing in manual applications.
Any other use is deemed to be "not in accordance with the intended purpose.”
| (1) | Standard interface Pushing the button backward:
Pushing the button forward during welding:
| (2) | Potentiometer interface Pressing the Start button:
Potentiometer:
| (3) | Without torch trigger |
| (4) | Standard interface with torch trigger extension Pushing the button backward:
| (5) | Up-Down interface (not shown) The welding torch is supplied from the factory with an Up/Down interface. For more information, see the following section Functions of the Up/Down torch from page (→). |
Potentiometer:
| (1) | Start button The button initiates the following functions:
| (2) | Up/Down button For changing the welding power |
Push the button forward and hold until intermediate lowering is complete
Risk of damage due to excessive tightening torque on the fixing sleeve (1) or gas lens (2).
Damage to the thread may result.
Only tighten the fixing sleeve (1) or gas lens (2) a little.
| * | Replaceable rubber sealing sleeve only for TTB 220 G/A |
| ** | A gas lens (2) may be used instead of the fixing sleeve (1) depending on the type of welding torch |
Risk of damage due to excessive tightening torque on the torch cap.
Only tighten the torch cap enough so that the tungsten electrode can no longer be moved by hand.
| * | Replaceable rubber sealing sleeve only for TTB 220 G/P |
Risk due to damaged O-ring on the torch body.
A damaged O-ring on the torch body can lead to contamination of the shielding gas, resulting in a defective weld.
Before each start-up, ensure that the O-ring on the torch body is undamaged.
Danger due to incorrectly fitted torch body.
Ensure that the locking device is fully forward after fitting the torch body - only then is the torch body properly fitted and locked.
Risk due to damaged O-ring on the welding torch connection.
A damaged O-ring on the welding torch connection can lead to contamination of the shielding gas, resulting in a defective weld.
Before each start-up, ensure that the O-ring on the welding torch connection is undamaged.
* only with water-cooled welding system
Danger due to incompatible system components.
Only connect torch bodies and hosepacks that are using the same type of cooling.
Only fit gas-cooled torch bodies to gas-cooled hosepacks.
Danger from switched on power source during automatic emptying of the welding torch.
Unintentional arc ignitions can occur.
Follow the instructions for automatic emptying of the welding torch in the cooling unit Operating Instructions, the power source Operating Instructions, and on the power source control panel.
When carrying out the work on the torch body as described below, keep at least 1 m (39.37 in.) away from electrically conductive objects.
Only fit water-cooled torch bodies to water-cooled hosepacks.
In addition to the above list of steps to be carried out at every start-up, for water-cooled welding torches:
Materials should be disposed of according to valid local and national regulations.
| Cause: | Bayonet lock bent |
| Remedy: | Replace bayonet lock |
| Cause: | Incorrect ground connection |
| Remedy: | Establish proper ground connection |
| Cause: | Power cable in welding torch interrupted |
| Remedy: | Replace welding torch |
| Cause: | Tungsten electrode loose |
| Remedy: | Tighten tungsten electrode using torch cap |
| Cause: | Wearing parts loose |
| Remedy: | Tighten wearing parts |
| Cause: | Power plug not plugged in |
| Remedy: | Plug in power plug |
| Cause: | Welding torch or welding torch control line faulty |
| Cause: | Plug connections "torch trigger/control line/power source" faulty |
| Remedy: | Check plug connection / send power source or welding torch to service team |
| Cause: | PCB in welding torch faulty |
| Remedy: | Replace PCB |
| Cause: | Welding torch connection not sealed |
| Remedy: | Replace O-ring on the bayonet lock |
| Cause: | Hosepack is not sealed |
| Remedy: | Replace hosepack |
| Cause: | Shielding gas hose connection to torch body not sealed |
| Remedy: | Adjust and seal hose |
| Cause: | Gas cylinder empty |
| Remedy: | Change gas cylinder |
| Cause: | Gas pressure regulator faulty |
| Remedy: | Replace gas pressure regulator |
| Cause: | Gas hose kinked, damaged, or not attached |
| Remedy: | Attach and straighten gas hose. Replace faulty gas hose |
| Cause: | Welding torch faulty |
| Cause: | Gas solenoid valve faulty |
| Remedy: | Contact service team (have gas solenoid valve replaced) |
| Cause: | Incorrect welding parameters |
| Remedy: | Check settings |
| Remedy: | Check ground connection and terminal for polarity |
| Cause: | Welding torch is inadequately dimensioned |
| Remedy: | Observe duty cycle and load limits |
| Cause: | For water-cooled systems only: Coolant flow too low |
| Remedy: | Check water level, water flow rate, water contamination, etc. Coolant pump blocked: Switch on shaft of coolant pump at the gland using a screwdriver |
| Cause: | For water-cooled systems only: "Cooling unit Ctrl" parameter is set to "OFF". |
| Remedy: | In the Setup menu, set the "Cooling unit Ctrl" parameter to "Aut" or "ON". |
| Cause: | Spattering in the gas nozzle, causing inadequate gas shield for weld seam |
| Remedy: | Remove welding spatter |
| Cause: | Holes in gas hose or imprecise gas hose connection |
| Remedy: | Replace gas hose |
| Cause: | O-ring at central connector is cut or faulty |
| Remedy: | Replace O-ring |
| Cause: | Moisture/condensate in the gas line |
| Remedy: | Dry gas line |
| Cause: | Gas flow too strong or weak |
| Remedy: | Correct gas flow |
| Cause: | Inadequate quantity of gas at the start or end of welding |
| Remedy: | Increase gas pre-flow and gas post-flow |
| Cause: | Too much parting agent applied |
| Remedy: | Remove excess parting agent/apply less parting agent |
| Cause: | Unsuitable tungsten electrode (e.g., WP electrode for DC welding) |
| Remedy: | Use suitable tungsten electrode |
| Remedy: | Screw on wearing parts tightly |
| Cause: | Tungsten electrode not protruding far enough out of the gas nozzle |
| Remedy: | Have tungsten electrode protrude more out of the gas nozzle |
This product meets the requirements set out in standard IEC 60974-7.
The performance data specifications only apply when using standard wearing parts.
When using gas lenses and shorter gas nozzles, the welding current is reduced.
The welding current specifications apply to gas-cooled torch bodies only from a length of 65 mm (2.56 in.).
When using shorter torch bodies, the welding current is reduced by 30%.
When welding at the power limit of the welding torch, use larger tungsten electrodes and gas nozzle opening diameters to increase the service life of the wearing parts.
Take amperage, AC balance, and AC current offset into account as performance-enhancing factors.
| TTB 80 G | TTB 120 G | TTB 160 G / F |
DC welding current at 10 min / 40 °C (104 °F) | 35 % D.C.1) / 80 A | 15 % D.C.1) / 120 A | 35 % D.C.1) / 160 A |
60 % D.C.1) / 60 A | 35 % D.C.1) / 80 A | 60 % D.C.1) / 120 A | |
100 % D.C.1) / 50 A | 60 % D.C.1) / 60 A | 100 % D.C.1) / 90 A | |
AC welding current at 10 min / 40 °C (104 °F) | 35 % D.C.1) / 30 A | 35 % D.C.1) / 40 A | 35 % D.C.1) / 120 A |
| 60 % D.C.1) / 90 A | ||
| 100 % D.C.1) / 70 A | ||
Shielding gas | Argon | Argon | Argon |
Electrode diameter | 1,0 - 3,2 mm | 1,0 - 3,2 mm | 1,0 - 3,2 mm |
Permissible tungsten electrode types | in accordance with standard EN ISO 6848 | ||
| TTB 220 G |
DC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 220 A |
60% D.C.1) / 170 A | |
100% D.C.1) / 130 A | |
AC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 180 A |
60% D.C.1) / 130 A | |
100% D.C.1) / 100 A | |
Shielding gas (Standard EN ISO 14175) | Argon |
Electrode diameter | 1.0 - 4.0 mm |
| TTB 220 A G F | TTB 220 P G F |
DC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 220 A | 30% D.C.1) / 220 A |
60% D.C.1) / 170 A | 60% D.C.1) / 160 A | |
100% D.C.1) / 130 A | 100% D.C.1) / 130 A | |
AC welding current at 10 min / 40 °C (104 °F) | 35% D.C.1) / 180 A | 30% D.C.1) / 170 A |
60% D.C.1) / 120 A | 60% D.C.1) / 120 A | |
100% D.C.1) / 100 A | 100% D.C.1) / 100 A | |
Shielding gas (Standard EN ISO 14175) | Argon | Argon |
Electrode diameter | 1.0 - 4.0 mm | 1.0 - 4.0 mm |
| 1) | D.C. = duty cycle |
| TTB 180 W | TTB 300 W |
DC welding current at 10 min / 40 °C (104 °F) | 60% D.C.1) / 180 A | 60% D.C.1) / 300 A |
100% D.C.1) / 140 A | 100% D.C.1) / 230 A | |
AC welding current at 10 min / 40 °C (104 °F) | 60% D.C.1) / 140 A | 60% D.C.1) / 250 A |
100% D.C.1) / 110 A | 100% D.C.1) / 190 A | |
Electrode diameter | 1.0 - 3.2 mm | 1.0 - 3.2 mm |
Minimum permissible coolant flow Qmin | 1 l/min | 1 l/min |
| THP 120 G SH | THP 180 G SH |
DC welding current | 35% D.C.1) / 120 A | 35% D.C.1) / 180 A |
60% D.C.1) / 100 A | 60% D.C.1) / 130 A | |
100% D.C.1) / 80 A | 100% D.C.1) / 100 A | |
AC welding current | 35% D.C.1) / 90 A | 35% D.C.1) / 120 A |
60% D.C.1) / 70 A | 60% D.C.1) / 90 A | |
100% D.C.1) / 50 A | 100% D.C.1) / 70 A | |
4.0 m / 8.0 m | 4.0 m / 8.0 m | |
Maximum permitted open circuit voltage (U0) | 113 V | 113 V |
Maximum permitted striking voltage (UP) | 10 kV | 10 kV |
Torch trigger Umax | 35 V | 35 V |
Torch trigger Imax | 100 mA | 100 mA |
The THP 150 G SH hosepack is not intended or suitable for arc ignition devices, for example high frequency ignition.
The hosepack is intended for use with TransPocket 150/180 and AccuPocket 150 power sources only.
| THP 150 G SH |
DC welding current | 25% D.C.1) / 150 A |
35% D.C.1) / 120 A | |
60% D.C.1) / 100 A | |
100% D.C.1) / 80 A | |
AC welding current | 25% D.C.1) / 110 A |
35% D.C.1) / 90 A | |
60% D.C.1) / 70 A | |
100% D.C.1) / 50 A | |
4.0 m / 8.0 m | |
Maximum permitted open circuit voltage U0 | 113 V |
Maximum permitted striking voltage UP | Not intended for or suitable for arc ignition devices! |
| THP 300 SH |
DC welding current | 60% D.C.1) / 300 A |
AC welding current | 60% D.C.1) / 250 A |
4.0 m / 8.0 m | |
Lowest cooling capacity as per IEC standard 60974-2, depending on the hosepack length | 650 W / 650 W |
Minimum permissible coolant pressure pmin | 3 bar |
Maximum permissible coolant pressure pmax | 5.5 bar |
Maximum permitted striking voltage UP | 10 kV |
