In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All labels on the deviceFor the location of the safety and danger notices on the device, refer to the section headed "General information" in the Operating Instructions for the device.
Before switching on the device, eliminate any faults that could compromise safety.
For exact information on permitted environmental conditions, please refer to the "Technical data" chapter.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Loose connections, scorched, damaged, or under-dimensioned cables and leads must be repaired immediately by an authorized specialist.
Batteries contain acids which pose a risk to the eyes and skin. Furthermore, charging batteries produces gases and vapors that may be hazardous to your health and are highly explosive under certain circumstances.
Never breathe in the gases and vapors produced by the battery – ensure there is a sufficient supply of fresh air. Keep potential sources of ignition such as fire and open flames away from the battery.
Do not place any tools or electrically conductive metals on the battery, in order to prevent short circuits.
Never allow battery acid to come into contact with your eyes, skin, or clothing. Wear eye protection and appropriate protective clothing. Rinse away any splashed acid immediately and thoroughly with clean water, and consult a physician if necessary.
Before leaving the working area, ensure that no personal injury or property damage can occur in your absence.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Before each start-up, check the charging cable, sensor cables, and charging plug for damage.
If dirt accumulates on the device, clean the surface of the device housing with a soft cloth and only with solvent-free cleaning agents.
Repair work must only be carried out by authorized personnel. Use only original spare and wearing parts (also applies to standard parts). It is impossible to guarantee that third-party parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements.
Do not carry out any alterations, installations, or modifications to the device without first obtaining the manufacturer’s permission.
The safety-conscious work of the personnel must be checked regularly.
Packaging materialsCopyright of these Operating Instructions remains with the manufacturer.
Text and illustrations were accurate at the time of printing. Fronius reserves the right to make changes. The contents of the Operating Instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the Operating Instructions, we will be most grateful for your comments.
Indicates an immediate danger.
Indicates a possibly dangerous situation.
Indicates the possibility of flawed results and damage to the equipment.
The TagID is an electronic product that is mounted on lead-based traction batteries. The TagID enables digital identification, parameterization, and monitoring of the battery used in Fronius battery chargers.
The Fronius battery charger, which connects to the TagID, uses the parameters and measured values to adjust the charge of the battery charger.
The TagID is designed for traction batteries and has a temperature sensor.
In addition to the temperature sensor, the TagID+ is equipped with a level sensor to detect and indicate a low electrolyte level.
TagID version:
| (1) | TagID incl. temperature sensor |
| (2) | Pre-assembled auxiliary contacts on CAN cable - Open end - REMA DIN - REMA MRC - Schaltbau DIN |
| (3) | Connection plate |
| (4) | 4x M4x20 TX20 |
| (5) | 12x acid-resistant cable ties |
| (6) | 1.5 m acid-resistant spiral hose |
| (7) | Quick Start Guide |
Additional accessories for TagID+ version:
| (8) | Level sensor |
| (9) | Level sensor dummy |
A number of safety symbols can be seen on the TagID's rating plate. The safety symbols must not be removed or painted over.
CE mark – confirms compliance with applicable EU directives and regulations. | |
Dispose of old devices in accordance with safety rules and not in normal domestic waste. | |
Safety class II equipment has reinforced or double insulation to match the rated insulation voltage between active and accessible parts. |
ANATEL-mark / Brazil - This device is operated on a secondary basis. It does not claim to offer protection against harmful interference, even from devices of the same type. | |||||
| IFETEL-mark / Mexico - Operation of this device is subject to the following two conditions:
| No. | Function |
| (1) | Connection / function Displays the connection status of the TagID. |
| (2) | Error Reports an error where intervention is required. |
| (3) | Battery warning Reports a battery warning where a check is required. |
| (4) | Refill indicator Indicates that a refill is required for the battery. |
| (5) | Access via NFC Using NFC, the serial number of the respective TagID is detected and used for authentication in the portal. The data stored in the cloud can be read out on the TagID using the TagID Config App. |
| (6) | Access via QR code The QR code refers to the corresponding product page of the TagID. |
| No. | Function |
The LED status indicator on the TagID shows whether the system is switched on and the system status of the TagID.
It is possible that several LEDs can light up at the same time (e.g., Connected + Refill indicator, etc.).
| Factory settings
Remedy:
| Not Connected
| Connected
| Refill indicator
Remedy:
IMPORTANT! The blue LED does not go out immediately after refilling, but only when water has been refilled and an initial discharge of the battery has been detected. | |
| Battery warning TagID reports a battery warning during operation.
Remedy:
| Error
Remedy:
| System error
Remedy:
| No contact / defect
Remedy:
Read, understand, and follow all safety rules and user documentation for this device and the battery.
Disconnect the battery from the charger before starting work.
Danger due to static charge of the TagID.
Oxyhydrogen ignition can cause serious personal injury and damage to property.
Do not carry out installation during or immediately after charging.
Mount TagID in well-ventilated rooms.
Wear suitable protective equipment (for example, ESD protective clothing, protective gloves, safety goggles, etc.).
Danger from battery acid.
When fitting the level sensor, look out for any battery acid that may have leaked out.
Wear suitable protective equipment (for example, acid-resistant protective clothing, protective gloves, safety goggles, etc.).
Danger of damage to electrical components from electrical discharge. Suitable measures should be taken to protect against ESD when replacing and installing components.
Wear appropriate protective equipment and use insulated tools when replacing and installing components.
| (1) | TORX® screwdriver TX 20 |
| (2) | Drill driver with depth stop |
| (3) | Drill, 8 mm |
| (4) | Soldering equipment |
| (5) | Slotted screwdriver, 3 mm |
| (6) | Diagonal cutting pliers |
| (7) | Torque screwdriver with 1 - 30 Nm bit insert |
| (8) | Flat wrench size 16, 17, 19, 22 |
Battery and charging plug are used as an example and are taken as reference.
Carry out work such as making the solder contacts outside the hazardous area (charging area).
Disconnect the negative pole from the battery and make sure that it does not make contact with ground.
Loosen the strain-relief device, insert the auxiliary contacts according to the illustration, and use the shorting bar with the pilot contacts. Then reattach the strain-relief device.
Position the CAN cable as shown and fix it on the connector side with a cable tie. Form a loop on the device side and fit a spiral hose.
Remove the transport protection of the pins before assembly. Subsequently, there is a risk of stabbing on the pins.
Place the TagID on the charging cable, keeping the loop for strain relief, and tighten diagonally with 4x TX20 screws (1 Nm).
Tightening torque = 2 Nm
When repairing or removing the TagID, make sure that the insulation of the charging cable is intact.
If necessary, re-insulate any holes that have formed.
Attach the negative pole to the battery according to the manufacturer's instructions.
Make a loop for strain relief with the sensor cable and attach the spiral hose as shown.
Neatly route and bundle the sensor cable with the remaining cable ties.
Insert temperature sensor in the center of the battery.
Danger of short circuit if a depth stop is not used during drilling.
Keep the hole to 10 - 15 mm by fitting a depth stop.
Drill the hole at cell 7 using a depth stop and 8 mm drill bit.
Place the level sensor dummy in the drilled hole and take measurements.
Transfer dimension from level sensor dummy to level sensor.
Subtract 8 mm from the dimension and cut off with diagonal cutting pliers.
Insert the level sensor and ensure that it is flush with the cell.
Download and install the TagID Config App.
Activate the NFC function on the smartphone.
To read a TagID, press "Scan" and place your smartphone on the NFC icon of the TagID to establish a connection.
The internal positioning of the NFC chip is different for every smartphone and must therefore be localized via movement.
For a TagID that has not yet been configured, configuration is started with the first of 8 steps after scanning.
You will be guided through the individual steps in the app.
Taking a photo of the battery and the battery's nameplate links it to the TagID in the system.
In "Notes", you can add free text, e.g., add the charging station assignment.
Once configuration is complete, the data are displayed once again in a summarized form.
The NFC transfer is started with the "Transfer to TagID now" button – it is necessary to place the smartphone on the NFC icon of the TagID again.
Transfer can take up to 5 seconds.
Only after confirmation of success are the data transferred to the TagID.
If the transfer was successful and no TagID status messages were detected, the TagID Config App home screen opens again.
If a pending status message is indicated on the TagID by means of the yellow or red LED, this can be read out at any time using the TagID Config App.
Activation of TagID mode using the wizard when starting for the first time:
Select the type of battery and enable "Power Charge".
Set the charging time when "Power Charge OFF" is selected.
Manual activation of TagID mode:
Activate TagID under the menu item "additional functions".
When TagID mode is deactivated, the preset charging settings are used again.
Make sure that the values set on the charger are compatible with those of the battery to be charged.
The TagID offers the following setting options:
Under "Charging settings", a list with selection options appears which are explained in more detail below:
"Temperature-controlled charging":
"Opportunity charge":
"Power Charge":
"Digital coding pin":
Multivoltage
Multicapacity
"Battery technology group":
Once set, the battery charger can only support the selected technology.
"Calendar":
Power Charge
Charging time
Charge start configuration
"Fallback":
Only possible for Pb-Wet and with multivoltage deactivated. Fallback mode not available for 96V/120V devices.
If a TagID is not recognized, a default characteristic is used.
"Config check":
Checks whether the communicated and measured values at the TagID match. In addition, the compatibility between the battery charger and battery is checked.
Under "Advanced settings", a list with selection options appears which are explained in more detail below:
"RI efficiency mode"
"Intelligent equalization charge"
„Battery WarmUp mode“
"Automatic battery care"
Automatic desulfation
Automatic ionic circulation
Initial charge
If one of these charges is interrupted early, it will be initialized again during the next charge until the respective charge has been completed successfully.
If a fault occurs during operation, a status message is displayed on the TagID (see LED status indicator) and in the TagID Config App.
| Battery warning tab (warning LED): | |
| Cause: |
| Remedy:
| Cause: |
| Remedy:
| Cause: |
| Remedy:
| Device error tab (error LED): | |
| Cause: | |
| Remedy:
| Cause: | |
| Remedy:
| Cause: | |
| Remedy:
| Cause: | |
| Remedy:
| Cause: | |
| Remedy:
In the event of incorrect configuration of the battery master data in the TagID, the following status messages may be displayed on the basis of the Config check in the TagID Config App. Device status tab: | ||
| Cause: | |
| Remedy:
| Cause: |
| Remedy:
| Cause: |
| Remedy:
| Cause: |
| Remedy:
Operating voltage | 20 to 200 V (DC) |
Fuse | 250 mA |
Safety class | II |
Average consumption | < 0.5 W |
Overvoltage category | II |
Pollution degree | 3 |
Terminal connector compatibility | 16 - 120 mm2 (0.63 - 4.72 in.2) |
Protection class | IP 65 |
Dimensions (width x height x depth) | 105 x 33.25 - 41.70 x 121.5 mm |
Weight | 350 g (0.77 lb.) |
Use | Indoors and outdoors |
Operating temperature | -25 to +80 °C |
Storage temperature | -40 to +80 °C |
Maximum operating altitude above sea level | 3000 m (9842.52 ft) |
Fuse | 250 mA |
Safety class | II |
