en
      Operating InstructionsFK 5000, FK 5000 MV
    • Safety rules
      • General
      • Intended use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Mains connection
      • Protecting yourself and others
      • Noise emission values
      • Danger from toxic gases and vapours
      • Danger from flying sparks
      • Risks from mains current and welding current
      • Meandering welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Specific hazards
      • Requirement for the shielding gas
      • Danger from shielding gas cylinders
      • Danger from escaping shielding gas
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
    • General
      • General
        • Device concept
        • Variants
        • Scope of supply
        • Field of application
        • Validity of "General Delivery and Payment Conditions"
        • Service life of the coolant pump
        • Information about the coolant
        • Information on leaks
        • Firmware updates
      • Options
        • General
        • Coolant temperature monitoring and flow monitoring
        • Coolant filter
        • Front coolant connections
        • Duo filter mounting / coolant connections
    • Connections and mechanical components
    • Installation and commissioning
      • Before installation and commissioning
        • Safety
        • Setup regulations
        • Guarantee provisions regarding the coolant pump
        • Intended use
      • Fitting the cooling unit to the trolley
        • General
      • Connecting the cooling unit to the power source
        • Safety
      • Connect the coolant hoses to the cooling unit
        • Safety
        • Connecting interconnecting hosepack coolant hoses to the cooling unit
        • Connecting welding torch coolant hoses to the cooling unit
      • Filling and starting up the cooling unit
        • Filling the cooling unit
        • Commissioning the cooling unit
      • Fitting the coolant filter option
        • Safety
    • Troubleshooting
      • Troubleshooting
        • Safety
        • Troubleshooting
        • Displayed service codes
      • Twisting the coolant pump shaft
        • Safety
    • Care, maintenance and disposal
        • Safety
        • General
        • Symbols for care and maintenance of the cooling unit
        • Maintenance intervals, maintenance work
        • Gas purging the cooler
        • Changing the coolant
        • Disposal
    • Technical data
      • Technical data
        • General
        • FK 5000, FK 5000 MV
    • 037-07092026
    FK 5000, FK 5000 MV
    download
    Troubleshooting
    Maintenance
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statementCookie Policy
    Safety rules
    link_horizontalLink copied
    Warnings are intended to warn people of possible injury and to prevent personal injury and damage to the product. They relate to individual actions performed with and on the product.
    DANGER!
    Indicates an immediately dangerous situation.
    Serious injury or death will result if the hazard is not avoided.
    Action step to escape the situation.
    WARNING!
    Serious injury or death will potentially result if the hazard is not avoided.
    CAUTION!
    Minor or moderate injury may result if the hazard is not avoided.
    NOTE!
    Indicates a situation which may result in damage to property.
    Failure to avoid the situation may result in impaired work results and material damage to the product or other property.
    Action step to avoid the situation.
    Safety instructions are intended to ensure safe use of the product. They are preventive and help to inform users about basic risks when using the product. They do not refer specifically to individual actions performed with and on the product.
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of welding and
    • read and follow these operating instructions carefully.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before switching on the device, rectify any faults that could compromise safety.
    1. Safety rules
    Intended use
    The external high-frequency device is intended exclusively to support the ignition of a TIG arc in combination with Fronius system components.
    The environmental conditions, safety instructions, and regulations of the welding machine shall apply.
    Any other use or use above and beyond this shall be deemed to be not in accordance with the intended use.
    Intended use also means:
    • Reading these operating instructions in their entirety
    • Following all the instructions and safety rules in these operating instructions
    • Observing the welding machine operating instructions
    • Carrying out all the specified inspection and maintenance work
    The device is designed for commercial and industrial use.
    1. Safety rules
    Ambient temperature range:
    • during operation: -10 °C to + 40 °C (14 °F to 104 °F)
    • during transport and storage: -20 °C to +55 °C (-4 °F to 131 °F)
    Relative humidity:
    • up to 50% at 40 °C (104 °F)
    • up to 90% at 20 °C (68 °F)
    The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
    Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so must:
    • observe the basic instructions regarding safety at work and accident prevention; and
    • read these operating instructions (especially the "Safety rules" section) and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Mains connection
    This may affect a number device types in terms of:
    • Connection restrictions
    • Criteria with regard to the maximum permissible mains impedance *)
    • Criteria with regard to the minimum short-circuit power requirement *)
    *) at the interface with the public grid
    see "Technical data"
    In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
    IMPORTANT! Ensure that the mains connection is earthed properly
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks, e.g.
    • flying sparks and hot pieces of metal
    • Arc radiation, which can damage eyes and skin
    • Hazardous electromagnetic fields, which can endanger the lives of those using cardiac pacemakers
    • Risk of electrocution from mains current and welding current
    • Greater noise pollution - the noise level may exceed 85 dB
    • Harmful welding fumes and gases
    Suitable protective clothing must be worn when working with the device. The protective clothing must have the following properties:
    • Flame-resistant
    • Insulating and dry
    • Covers the whole body, is undamaged and in good condition
    • Safety helmet
    • Trousers with no turn-ups
    Protective clothing refers to a variety of different items. Operators should:
    • Protect eyes and face from UV rays, heat and sparks using a protective visor and regulation filter
    • Wear regulation protective goggles with side protection behind the protective visor
    • Wear stout footwear that provides insulation even in wet conditions
    • Protect the hands with suitable gloves (electrically insulated and providing protection against heat)
    • Wear ear protection to reduce the harmful effects of noise and to prevent injury
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers (risk of dazzling by the arc, injury from flying sparks, harmful welding fumes, noise, possible risks from mains current and welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains.
    1. Safety rules
    During no-load operation or the cooling phase after operation, the device generates a maximum sound power level of <80 dB(A) (ref. 1pW) corresponding to the maximum permissible operating point under rated load according to EN 60974-1.
    A workplace-related sound emission value depends on various parameters, such as:
    • the welding or working process (MIG/MAG, TIG, plasma, rod electrode);
    • the selected type of current (AC, DC);
    • the power range;
    • the type of weld metal or workpiece;
    • the resonance characteristics of the workpiece;
    • the workplace environment;
    • and so on.
    A workplace noise level measurement is recommended.
    1. Safety rules
    The fumes produced during welding contain harmful gases and vapours.
    Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
    Keep your face away from welding fumes and gases.
    Fumes and hazardous gases
    • must not be breathed in
    • must be extracted from the working area using appropriate methods.
    Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
    If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
    The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:
    • Metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaners, degreasers, etc.
    • Welding process used
    The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
    Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
    Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    1. Safety rules
    Flying sparks may cause fires or explosions.
    Never weld close to flammable materials.
    Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
    Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
    Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
    Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
    1. Safety rules
    An electric shock is potentially life threatening and can be fatal.
    Do not touch live parts either inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
    Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
    Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Use the handle to ensure the power connections are tight before every use.
    In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
    Do not wrap cables or leads around the body or parts of the body.
    The electrode (rod electrode, tungsten electrode, welding wire, etc.) must
    • never be immersed in liquid for cooling
    • never be touched when the welding system is switched on.
    Double the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
    Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
    Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    If necessary, provide adequate earthing for the workpiece.
    Switch off unused devices.
    Wear a safety harness if working at height.
    Before working on the device, switch it off and pull out the mains plug.
    Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
    After opening the device:
    • Discharge all live components
    • Ensure that all components in the device are de-energised.
    If work on live parts is required, have a second person switch off the main switch at the right moment.
    1. Safety rules
    If the following instructions are ignored, meandering welding currents can develop with the following consequences:
    • Fire hazard
    • Overheating of parts connected to the workpiece
    • Damage to ground conductors
    • Damage to device and other electrical equipment
    Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
    If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
    In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check and evaluate the immunity to interference of nearby devices according to national and international regulations. Examples of equipment that may be susceptible to interference from the device include:
    • Safety devices
    • Network, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite the correct mains connection, additional measures are necessary (e.g. use of a suitable line filter)
    2. Welding power-leads
      • must be kept as short as possible
      • must be laid close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Earthing of the workpiece
      • If necessary, establish an earth connection using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices nearby
      • Shield the entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    Specific hazards
    Keep hands, hair, clothing and tools away from moving parts. For example:
    • Fans
    • Cogs
    • Rollers
    • Shafts
    • Wire spools and welding wires
    Do not reach into the rotating cogs of the wire drive or into rotating drive components.
    Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
    During operation
    • Ensure that all covers are closed and all side panels are fitted properly.
    • Keep all covers and side panels closed.
    The welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
    Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
    Never touch the workpiece during or after welding - risk of burns.
    Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
    Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
    Special provisions apply in areas at risk of fire or explosion
    - observe relevant national and international regulations.
    Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
    Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
    Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
    • Hook chains or ropes onto all suspension points provided on the suitable load-carrying equipment.
    • Chains or ropes must be at the smallest angle possible to the vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
    All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
    The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
    Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
    1. Safety rules
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    1. Safety rules
    Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
    Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
    Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
    Keep the shielding gas cylinders well away from any welding or other electrical circuits.
    Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
    Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
    Turn your face to one side when opening the valve of a shielding gas cylinder.
    Close the shielding gas cylinder valve if no welding is taking place.
    If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
    The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
    1. Safety rules
    Risk of suffocation from the uncontrolled escape of shielding gas
    Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
    • Ensure an adequate supply of fresh air with a ventilation rate of at least 20 m³/hour.
    • Observe safety and maintenance instructions on the shielding gas cylinder or the main gas supply.
    • Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    • Check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before every start-up.
    1. Safety rules
    A device toppling over could easily kill someone. Place the device on a solid, level surface such that it remains stable
    • The maximum permissible tilt angle is 10°.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
    When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
    Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
    After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a danger of:
    • serious or fatal injury to the operator or third parties;
    • damage to the device and other material assets belonging to the operating company; and
    Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
    Only Fronius original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
    Only use suitable original coolant from Fronius.
    Do not mix Fronius original coolant with other coolants.
    Only connect Fronius system components to the cooling circuit.
    Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant can ignite under certain. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
    Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from the service centre or downloaded from the manufacturer's website.
    Check the coolant level before starting to weld while the system is still cool.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
    The manufacturer recommends that the welding machines be calibrated at the same 12-monthly interval.
    A safety inspection should be carried out by a qualified electrician:
    • after any modifications or installation of additional parts;
    • following repair, care and maintenance.
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on the safety inspection and calibration can be obtained from a Fronius branch or Fronius Service Partner.
    1. Safety rules
    Disposal
    According to the relevant EU Directive and national law, the following products must be disposed of separately and recycled:
    • Waste electrical and electronic equipment
    • Used batteries (portable batteries, industrial batteries)
    Used equipment and batteries must be returned to the distributor or an authorised local collection system. Do not dispose of batteries in domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
    Arrange for the safe collection and proper disposal of damaged, leaking or decommissioned batteries by a battery recycling company or the Fronius Service Partner.
    It should also be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances, such as heavy metals or electrolytes, which can contaminate the soil, water and air.
    This ensures environmental protection and the sustainable use of natural resources.
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark meet the requirements of all valid EU directives, such as:
    • Directive 2014/30/EU on Electromagnetic Compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • And so on
    The full text of the EU Declaration of Conformity can be found at
    https://www.fronius.com .
    Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Data security
    • saving and retaining personal settings
    1. Safety rules
    Copyright
    Copyright of this document remains with Fronius International GmbH.
    Text, illustrations and other media correspond to the technical state of the art at the time of publication. Fronius reserves the right to make changes. If you have any suggestions for improvement, or can point out any inconsistencies in this document, we will be most grateful for your comments.
    General
    General
    Device concept
    The cooling unit fits perfectly into the modular product design of the TransSteel power sources.
    The cooling unit and power source together form a unit. As with the standalone power source, the power source/cooling unit combination can be mounted on the trolley.
    1. General
    General
    Device concept
    1. General
    2. General
    Device concept
    1. General
    2. General
    Variants
    Two versions of the cooling unit are available:
    • FK 5000 (basic version)
    • FK 5000 MV (Multivoltage version)
    The FK 5000 MV adapts itself automatically to the mains voltage. The Multivoltage version is available only from the factory.
    1. General
    2. General
    Scope of supply
    The scope of supply comprises:
    • Cooling unit
    • 5 l coolant in a canister
    • Four 5x25mm self-tapping screws
    • Operating instructions
    1. General
    2. General
    The cooling unit can be used for:
    • water-cooled MIG/MAG manual welding torches
    1. General
    2. General
    With regard to cooling units, the "General Delivery and Payment Conditions" according to the price list only apply under the following conditions:
    • Max. 8 hrs/day operation (single shift operation)
    • Only original coolant from the manufacturer is used
    • Regular maintenance and regular change of coolant
    1. General
    2. General
    NOTE!
    If used properly the coolant pump will have a service life of approx. 10,000 operating hours. After the end of its nominal service life, the coolant pump may develop a fault. To avoid a lengthy period of work disruption, the pump should be scheduled for replacement after approx. 10,000 operating hours.
    1. General
    2. General
    CAUTION!
    Danger from using non-permitted coolant.
    This can result in severe damage to property.
    Only use coolant available from the manufacturer. Other coolants are not recommended for electrical conductivity and material compatibility reasons.
    Do not mix different coolants.
    When changing the coolant, make sure all the coolant is replaced.
    When switching from ethanol-based coolant to FCL 10/20 coolant, Change Kit FCL10 must be used and the instructions provided must be followed.
    Operate the CU1200i Pro /MC exclusively with Cooling Liquid FCL10/20.
    1. General
    2. General
    The shaft sealing surfaces inside the coolant pump are lubricated by the coolant, meaning that a certain leakage flow should always be expected. A low leakage flow is permitted.
    The coolant pump requires a certain warm-up time after being started for the first time or upon restarting after a long period of downtime. An increased leakage flow can occur during this warm-up phase. The leakage flow will normally sink back down to a low level after the warm-up phase. If this is not the case then contact After-Sales Service.
    1. General
    2. General
    Firmware updates
    As a result of firmware updates, you may find that your device has certain functions that are not described in these operating instructions, or vice versa. Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    1. General
    2. General
    The cooling unit is fitted with safety symbols and a rating plate. The rating plate and safety symbols must not be removed or painted over. The symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage.
    Welding is dangerous. The following basic requirements must be met to ensure the equipment is used properly:
    • Welders must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved must be kept at a safe distance from the cooling unit and the welding process
    Do not use the functions described here until you have thoroughly read and understood the following documents:
    • this document
    • all documents relating to the system components, especially the safety rules
    Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules.
    1. General
    Options
    General
    The options listed below are available for all cooling unit variants.
    1. General
    2. Options
    General
    1. General
    2. Options
    Coolant temperature monitoring and flow monitoring are parts of an installation set and cannot be ordered separately.
    A temperature sensor monitors the coolant return temperature during welding.
    How it works:
    • If the temperature of the coolant exceeds 70 °C (158 °F):
      • the wire-feed unit/power source outputs the service code "hot l H2O"
      • the temperature sensor interrupts the welding current
      • the cooling unit remains operational
    • The temperature sensor restores the welding current when the coolant temperature falls to 65 °C (149 °F)
    Flow monitoring
    A flow sensor monitors the coolant flow during welding.
    How it works:
    • If the coolant flow drops below 0.7 l/min (0.18 gal./min [US])
      • the wire-feed unit/power source outputs the service code "no l H2O"
      • flow rate monitoring interrupts the welding current
      • the cooling unit is switched off
    1. General
    2. Options
    Coolant filter
    The coolant filter is equipped with a CrNi screen, and its function is to filter dirt particles above 150 micrometers in size from the coolant. This ensures that no coarse dirt particles can pass into the coolant circuit. The coolant filter is fitted to the coolant return connection on the cooling unit.
    1. General
    2. Options
    The front coolant connections allow the cooling unit to be used in conjunction with power sources with an integrated wire drive (compact power sources).
    1. General
    2. Options
    The kit adds two additional coolant connections to the cooling unit. This allows the coolant filter to be mounted on the rear in a protected location and the welding torch to remain connected to the front as usual (compact power sources).
    Front of cooling unit
    Rear of cooling unit
    (1)
    Blanking cover
    • if the front coolant connections option is installed, then this is the coolant flow connection (blue)
    (2)
    Blanking cover
    • if the front coolant connections option is installed, then this is the coolant return connection (red)
    (3)
    Screw cap for coolant container
    (4)
    Operating and maintenance instructions
    (5)
    Coolant viewing window
    (6)
    Power source connecting plug
    (7)
    Rating plate
    (8)
    Coolant return connection (red)
    • if the front coolant connections option is installed, a blanking cover will be present
    (9)
    Coolant flow connection (blue)
    1. Connections and mechanical components
    (1)
    Blanking cover
    (2)
    Blanking cover
    (3)
    (4)
    (5)
    (6)
    (7)
    Rating plate
    (8)
    (9)
    2. Connections and mechanical components
    (1)
    Blanking cover
    (2)
    Blanking cover
    (3)
    (4)
    (5)
    (6)
    (7)
    Rating plate
    (8)
    (9)
    Safety
    WARNING!
    Fully read and understand this document.
    1. Installation and commissioning
    Safety
    WARNING!
    2. Before installation and commissioning
    Safety
    WARNING!
    Setup regulations
    WARNING!
    Danger from machines toppling over or falling.
    Set up the device securely on an even, solid surface.
    Check all screw connections are tightly fastened after installation.
    WARNING!
    Danger from electric current.
    Ensure the cooling unit is properly insulated.
    Always ensure that there is no electrically conductive connection between the base plate of the cooling unit and the surface.
    Before installing the cooling unit, remove all electrically conductive parts between the base plate of the cooling unit and the surface.
    The device is tested to IP 23 protection, meaning:
    • Protection against penetration by solid foreign bodies with diameters greater than 12.5 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° to the vertical
    Cooling air
    The system must be set up in such a way that the cooling air can flow unimpeded through the slots in the side panels. Ensure that there is always an all-round clearance of 0.5 m (1 ft. 7.69 in.) around the device.
    Air inlet openings and air outlet openings
    CAUTION!
    Danger from insufficient cooling air supply.
    Air inlet openings (1) and outlet openings (2) must never be covered, not even partially.
    Dust
    Ensure that any metallic dust, for example from grinding work, is not sucked into the system by the fan.
    Outdoor operation
    The device can be set up and operated outdoors in accordance with degree of protection IP23. Avoid direct wetting (e.g. from rain).
    The cooling unit is delivered empty.
    Use only original Fronius coolant (Cooling Liquid FCL 10/20 or torch coolant) when filling the cooling unit. Other coolants are not recommended for electrical conductivity and material compatibility reasons.
    The coolant pump may only be used with original coolant supplied by the manufacturer. Do not allow the coolant pump to run dry (even for a very short time), as this will destroy the coolant pump. The manufacturer accepts no liability for damage caused in such cases.
    Intended use
    The device is intended solely for use in conjunction with Fronius system components.
    Any use above and beyond this purpose is deemed improper.
    Proper use also includes:
    • Fully reading and understanding these Operating Instructions
    • Following all the instructions and safety rules in these Operating Instructions
    • Performing all stipulated inspection and servicing work
    The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
    General
    The welding system can be fitted to a trolley to make the system (incl. cooling unit) more mobile.
    2. Fitting the cooling unit to the trolley
    General
    *)  TU Car 4 Pro scope of supply
    Safety
    WARNING!
    Before starting the work described below:
    Turn the power source mains switch to the "O" position.
    Disconnect the power source from the mains.
    Ensure that the power source remains disconnected from the mains until all work has been completed.
    After opening the device, use a suitable measuring instrument to check that electrically charged components (e.g. capacitors) have been discharged.
    WARNING!
    Danger from inadequate ground conductor connections.
    The housing screws provide a suitable ground conductor connection for earthing the housing and must NOT be replaced by any other screws that do not provide a reliable ground conductor connection.
    2. Connecting the cooling unit to the power source
    Safety
    WARNING!
    WARNING!
    CAUTION!
    Risk of short circuit from kinked or damaged cables.
    When connecting the power source to the cooling unit, ensure that the cables are not kinked.
    *)  Cooling unit scope of supply
    Safety
    WARNING!
    2. Connect the coolant hoses to the cooling unit
    Safety
    WARNING!
    NOTE!
    Connect the colour-coded coolant hoses to the corresponding coolant flow and return connections on the cooling unit.
    NOTE!
    Connect the coloured coolant hoses to the corresponding coolant flow and return connections on the cooling unit.
    WARNING!
    WARNING!
    Danger from coolant leakage.
    If there is any coolant on the exterior of the cooling unit, remove it immediately.
    Make sure that no coolant gets into the interior of the cooling unit.
    CAUTION!
    If the coolant connections are on the front of the cooling unit, carry out the following steps as shown – but at the front coolant flow connection (blue).
    Push the sealing cone in the coolant flow connection backwards
    Push the locking ring backwards until the sealing cone returns to its original position and release the locking ring again
    5
    2. Filling and starting up the cooling unit
    WARNING!
    WARNING!
    CAUTION!
    5
    NOTE!
    Before starting up the cooling unit, first check that it contains an adequate amount of coolant and that the coolant is clean and uncontaminated.
    NOTE!
    During welding, check at regular intervals that the coolant is flowing properly.
    You should be able to see a steady return flow of coolant into the coolant container.
    The cooling unit is powered from the power source. If the power source mains switch is turned to position "I", the cooling unit will also start to operate.
    Safety
    WARNING!
    WARNING!
    Danger from hot coolant.
    This can result in serious burns or scalding.
    Before carrying out any work, allow the coolant to cool to +25 °C / +77 °F.
    WARNING!
    2. Fitting the coolant filter option
    Safety
    WARNING!
    WARNING!
    WARNING!
    NOTE!
    Make sure that no coolant enters the device.
    If there is any coolant on the exterior of the device, remove it immediately.
    NOTE!
    If the coolant connections are on the front of the cooling unit, fit the coolant filter in the same way.
    Connect the coolant filter to the coolant return connection (red) on the front of the cooling unit.
    Troubleshooting
    Troubleshooting
    Safety
    WARNING!
    WARNING!
    WARNING!
    Danger due to insufficient ground conductor connection.
    The housing screws provide a suitable ground conductor connection for grounding the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    WARNING!
    WARNING!
    1. Troubleshooting
    Troubleshooting
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    1. Troubleshooting
    2. Troubleshooting
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    1. Troubleshooting
    2. Troubleshooting
    Troubleshooting
    Make a note of the serial number and configuration of the device and contact our After-Sales Service team with a detailed description of the error, if
    • errors occur that are not listed below
    • the troubleshooting measures listed are unsuccessful
    Insufficient or no coolant flow
    Cause:Coolant level too low
    Remedy:Top up coolant
    Cause:Constriction or foreign body in cooling circuit
    Remedy:Remove constriction or foreign body
    Cause:Coolant contaminated
    Remedy:Change the coolant
    Cause:Coolant filter (option) misplaced when connecting coolant return
    Remedy:Clean coolant filter/replace filter element
    Cause:Coolant pump sticking
    Remedy:Turn coolant pump shaft (see operating instructions, "Turning coolant pump shaft" section). Contact After-Sales Service if the coolant pump shaft proves impossible to turn
    Cause:Coolant pump defective
    Remedy:Contact After-Sales Service
    Coolant pump does not work after turning the coolant pump shaft
    Cause: Temperature switch on coolant pump has tripped
    Remedy:Wait until the end of the coolant pump's cooling phase (2 - 3 minutes)
    Insufficient cooling power
    Cause:Cooler contaminated
    Remedy:Gas purge cooler with dry compressed air
    Cause:Faulty fan
    High operating noise level
    The welding torch becomes very hot
    Cause:The specification of the cooling unit is inadequate
    Remedy:Observe the duty cycle and loading limits
    Cause:The specification of the welding torch is inadequate
    Cause:Inadequate coolant flow
    Remedy:Check coolant level. Top up with coolant if necessary.
    Check coolant for contamination. Change the coolant if necessary
    Remedy:Coolant pump sticking: Turn coolant pump shaft (see operating instructions, "Turning coolant pump shaft" section). Contact After-Sales Service if the coolant pump shaft proves impossible to turn
    1. Troubleshooting
    2. Troubleshooting
    NOTE!
    Depending on the welding system, the service codes are displayed on the power source or the wire-feed unit.
    hot l H2O
    The optional coolant temperature sensor in the cooling unit has tripped.
    Cause: Coolant temperature too high
    Remedy: Wait until the end of the cooling phase, i.e. until "hot | H2O" is no longer displayed.
    If using a ROB 5000 or field bus coupler for robot control: After completion of troubleshooting and before resuming welding, set the "Source error reset" signal.
    no l H2O
    The optional cooling unit flow sensor has tripped.
    Cause: Coolant flow problem
    1. Troubleshooting
    Safety
    WARNING!
    All the work described below must only be carried out by trained and qualified personnel.
    Fully read and understand all the Operating Instructions for the system components, especially the safety rules.
    WARNING!
    1. Troubleshooting
    2. Twisting the coolant pump shaft
    Safety
    WARNING!
    WARNING!
    1. Troubleshooting
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    Immediately remove any coolant that enters the device or spills onto its exterior during the work described in the following.
    WARNING!
    1. Care, maintenance and disposal
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    2. Care, maintenance and disposal
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    General
    Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the device remains in a usable condition for many years.
    (1)
    Change the coolant
    (2)
    Gas purge the cooler
    (3)
    Clean the coolant return filter on the outside of the unit and the coolant pre-filter inside the unit and replace the filter element if necessary
    (4)
    Only use original coolant from the manufacturer (Cooling Liquid FCL 10/20 oder ethanolbasiertes Kühlmittel)
    (5)
    Read this document
    The relevant maintenance intervals and work are described in detail in the following pages.
    CAUTION!
    Danger due to starting up without coolant.
    Only operate the cooling unit after it has been filled with coolant.
    If water-cooled system components are put into operation without coolant, this usually results in a defect of the system components.
    The manufacturer is not liable for any resulting damage, and all warranty claims are voided
    CAUTION!
    Danger from non-permitted coolant.
    Use only original coolant from the manufacturer (Cooling Liquid FCL 10/20 or ethanol-based coolant) when filling the cooling unit.
    At every start-up
    • Ensure that all hosepacks and welding torches are undamaged
    • Check that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely
    • Check the screw connections between all system components of the welding system for tightness
    • Check all the coolant connections of the welding system for tightness
    • Monitor the coolant return flow in the coolant tank
      • If no coolant is returning to the container, identify and remedy the cause
    Once a week
    • Check coolant level. If the coolant level is below the "min" mark, top up with coolant. Attention when using OPT/CU Torch deflate - see section Maintenance intervals, maintenance work from page (→).
    • Check the purity of the coolant. Change the coolant if necessary
    Every 2 months
    • If present: clean the coolant return filter on the outside of the unit and replace the filter element if necessary
    Every 6 months
    • Gas purge the cooler
    Every 6 months in 3-shift operation with ethanol-based coolant
    • Change the coolant
    Every 12 months in single-shift operation with ethanol-based coolant
    • Change the ethanol-based coolant
    Every 12 months in 3-shift operation with FCL 10/20 coolant
    CU1200i Pro /MC only:
    • clean the coolant pre-filter in the interior of the unit and replace the filter element if necessary
    IMPORTANT! Cleaning the pre-filter and replacing the filter element must be documented by the operator of the device!
    Every 24 months in single-shift operation with FCL 10/20 coolant
    CAUTION!
    Risk from gas purging the cooler.
    This may result in damage to electronic components.
    Always follow the instructions in the "Safety" section at the start of the "Care, maintenance and disposal" chapter.
    Do not bring the air nozzle too close to electronic components.
    For the sake of clarity, the cooling unit is shown in the following figures without the power source. However, the power source can remain on the cooling unit when gas purging the cooler.
    • Remove the device side panels and clean the cooler
    If a large amount of dust has accumulated:
    • remove device side panels and clean inside of device with dry, reduced compressed air.
    To change the coolant:
    CAUTION!
    Risk of injury and material damage from the welding current and accidental ignition of an arc.
    Before starting work:
    disconnect the ground earth connection between the welding system and the workpiece
    remove the wire electrode from the welding torch being used
    depending on the system, remove the wirespool or the basket-type spool from the power source or the wire-feed unit
    NOTE!
    The coolant must not be disposed of in the public sewage system.
    Dispose of coolant in accordance with the applicable local and national regulations.
    NOTE!
    Use only original Fronius coolant when refilling the cooling unit.
    NOTE!
    Seal off the coolant hose as soon as it is pulled out of the coolant pump connection.
    This will ensure that as little coolant as possible enters the device. Immediately remove any coolant that enters the device or spills onto its exterior.
    NOTE!
    If the coolant connections are on the front of the cooling unit, carry out the following steps as shown - but at the front coolant flow connection (blue).
    5
    6
    7
    8
    9
    10Ensure that all hose connections are properly established and are not leaking
    11Ensure that there is no coolant inside the device or on its exterior
    12
    Disposal
    Technical data
    Technical data
    General
    The cooling capacity of a cooling unit depends on
    • Ambient temperature
    • Delivery head
    • Flow rate Q (l/min) - The flow rate Q depends on the length of the interconnecting hosepack and the diameter of the hose.
    1. Technical data
    Technical data
    General
    • Delivery head
    1. Technical data
    2. Technical data
    General
    • Delivery head
    1. Technical data
    2. Technical data
    FK 5000, FK 5000 MV
    FK 5000
    FK 5000 MV
    Mains voltage
    400 V AC
    200-230/400-480 V AC
    Mains voltage tolerance
    -10% / +10%
    -10% / +10%
    Mains frequency
    50 / 60 Hz
    50 / 60 Hz
    Current input
    0.6 / 0.7 A
    0.6 / 1.4 A
    Cooling power at
    Q = 1 l/min + 25 °C (77 °F)
    Q = 1l / min + 40 °C (104 °F)
    Q = max. + 25 °C (77 °F)
    Q = max. + 40 °C (104 °F)
    1000 W
    800 W
    1500 W
    1000 W
    1000 W
    800 W
    1500 W
    1000 W
    Max. delivery head
    35 m
    114 ft. 9.95 in.
    35 m
    114 ft. 9.95 in.
    Max. delivery rate
    3.5 l/min
    0.92 gal./min [US]
    3.5 l/min
    0.92 gal./min [US]
    Max. pump pressure
    4.2 bar
    60.89 psi
    4.2 bar
    60.89 psi
    Pump
    Centrifugal pump
    Centrifugal pump
    Pump service life
    approx. 10,000 hrs
    approx. 10,000 hrs
    Coolant capacity
    6 l
    1.59 gal. [US]
    6 l
    1.59 gal. [US]
    Protection class
    IP 23
    IP 23
    Dimensions l/w/h
    710/300/230 mm
    27.95/11.81/9.06 in.
    710/300/230 mm
    Weight (without coolant)
    13.6 kg
    29.98 Ib.
    16 kg
    35.27 lb.
    Flow monitoring*
    Sensor
    error below 0.7 l/min (0.18 gal./min)
    Sensor
    Coolant temperature monitoring*
    Error above 70 °C (158 °F)
    Mark of conformity
    CE
    CE
    * Optional
