Indicates immediate danger.
Only qualified personnel are authorised to commission your inverter and only within the scope of the respective technical regulations.
Read the Installation and Operating Instructions before installing and commissioning the equipment.
This may result in serious injury and damage to property.
Surge protective devices must only ever be installed and connected by a qualified electrical installation engineer!
Follow the safety rules.
Ensure that both the AC side and the DC side of the inverter are de-energised before carrying out any installation and connection work.
Fire prevention
Danger due to poor or unprofessional installation.
This may result in damage to inverters and other live photovoltaic system components.
Poor or unprofessional installation can cause overheating of cables and terminal connections and result in arcs. These can cause heat damage, which in turn may lead to fires.
Observe the following when connecting AC and DC cables:
Tighten all terminals to the torque specified in the operating instructions
Tighten all grounding terminals (PE / GND), including free ones, to the torque specified in the operating instructions
Do not overload cables
Check cables for damage and verify that they are laid correctly
Take note of the safety instructions, Operating Instructions and any local connection regulations
Using fastening screws, always screw the inverter firmly to the mounting bracket to the torque specified in the Operating Instructions.
Ensure that the fastening screws are tight before starting the inverter!
Note! Fronius will not accept any costs associated with production downtimes, installer costs, etc., that may arise as the result of a detected arc and its consequences. Fronius accepts no liability for fires that can occur despite the presence of the integrated arc detection/extinguishing system (e.g. fires caused by a parallel arc).
Note! After an arc has been detected, the entire photovoltaic system must be checked for possible damage before resetting the inverter.
Observe the manufacturer's connection, installation and operating instructions at all times. To reduce the hazard potential to a minimum, perform all installation and connection work carefully according to the instructions and regulations.
Refer to the device Installation Instructions for the tightening torques to be used at the relevant terminal connections.
Fronius shall not be liable for any damage resulting from such action.
No warranty claims will be entertained.
When designing the photovoltaic system, ensure that all components are operated within their permitted operating ranges at all times.
Observe all the measures recommended by the solar module manufacturer to ensure that the solar module retains its properties in the long term.
Obey the regulations of the power supply company regarding connection methods and energy fed into the grid.
| The inverter is suitable for indoor installation. | |
| The inverter is suitable for outdoor installation. Because of its IP 65 protection class, the inverter is resistant to water jets from any direction and can also be used in damp environments. | |
| In order to minimise the heating up of the inverter, do not expose it to direct insolation. Install the inverter in a protected location, e.g. in the vicinity of the solar modules or beneath the eaves. | |
| Can be used at altitudes of up to 2000 m IMPORTANT! The inverter must not be installed or used at altitudes above 2000 m. | |
| Do not install the inverter in:
| During certain operating phases the inverter may produce a slight noise. For this reason it should not be installed close to living areas. | |
| All inverters are designed to be dust-tight. However, in areas with a heavy build-up of dust, the thermal efficiency may still be impaired by dust forming on the cooling surfaces. Regular cleaning is necessary in such situations. We therefore recommend not installing the inverter in areas and environments with high dust accumulation. | |
The inverter is suitable for vertical installation on a vertical wall or column. | |
The inverter is suitable for a horizontal installation position. | |
The inverter is suitable for installation on a sloping surface. | |
Do not install the inverter on a sloping surface with its connection sockets at the top. | |
Do not install the inverter at an angle on a vertical wall or column. | |
Do not install the inverter horizontally on a vertical wall or pillar. | |
Do not install the inverter on a vertical wall or pillar with its connection sockets facing upwards. | |
Do not install the inverter overhanging with the connection sockets at the top. | |
Do not install the inverter overhanging with the connection sockets at the bottom. | |
Do not install the inverter on the ceiling. |
Please note the following criteria when choosing a location for the inverter:
Only install on a solid, non-flammable surface | ||
Max. ambient temperatures: | ||
Relative humidity: | ||
The airflow within the inverter is from the left to the top (cold air taken in from the left, hot air dissipated out of the top). | ||
The environmental conditions of the inverter must be maintained at the installation location. | ||
If the inverter is to be installed on the outer wall of a cattle shed, maintain a minimum all-round clearance of 2 m between the inverter and all ventilation and other openings in the building. | ||
Danger due to residual voltage in capacitors.
This may result in an electric shock.
Wait for the capacitors to discharge. The discharge time is five minutes.
Danger due to dirt or water on the terminals and contacts of the inverter's connection area.
This may result in damage to the inverter.
When drilling, ensure that terminals and contacts in the connection area do not become dirty or wet.
The mounting bracket without a power stage set does not conform to the protection class of the inverter as a whole, and therefore must not be installed without a power stage set.
The mounting bracket should be protected from dirt and moisture during installation.
Degree of protection IP 20 applies to the mounting bracket with no inverter and the venting duct.
Important! Different fixings may be required to fit the mounting bracket depending on the type of underlying surface. Fixings are therefore not included in the scope of supply of the inverter. The installer is responsible for selecting the right type of fixing.
To install the inverter, the manufacturer recommends the use of steel or aluminium screws with a diameter of 6 - 8 mm.
Danger from inadequate ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing and must NOT be replaced by any other screws that do not provide a reliable ground conductor connection.
Note! When fitting the mounting bracket to the wall, ensure that the mounting bracket does not become warped or deformed.
Note! When mounting the mounting bracket on the wall, ensure that the mounting bracket does not become warped or deformed.
When mounting the inverter on a mast or a vertical carrier, Fronius recommends the use of a standard mast fixing kit.
This kit enables the inverter to be mounted on round or rectangular masts with various cross-sections.
The mounting bracket must be affixed at a minimum of four points.
Incorrect operation or poorly executed work can cause serious injury or damage.
Only qualified staff are authorised to commission your inverter and only within the scope of the respective technical regulations. Read the Installation and Operating Instructions before installing and commissioning the equipment.
Danger due to grid voltage and DC voltage from solar modules that are exposed to light.
Ensure that both the AC side and the DC side of the inverter are de-energised before carrying out any connection work.
Only an authorised electrical engineer is permitted to connect this equipment to the public grid.
Danger due to grid voltage and DC voltage from solar modules.
The DC main switch is only to be used to de-energise the power stage set. The connection area is still live when the DC main switch is switched off.
Ensure that the power stage set and connection area are disconnected from one another before carrying out any maintenance or service tasks.
The power stage set is only to be disconnected from the mounting bracket once it is de-energised.
Maintenance and servicing in the power stage set of the inverter must only be carried out by Fronius-trained service technicians.
Risk of damage to the inverter as the result of incorrectly tightened terminals.
Incorrectly tightened terminals can cause heat damage to the inverter that may result in a fire. When connecting AC and DC cables, ensure that all the terminals are tightened to the specified torque.
IMPORTANT! To ensure a proper ground connection, all three PE grounding terminals must be tightened to the specified torque when the inverter is installed.
To provide the best possible grid monitoring, the resistance in the leads to the AC-side terminals should be as low as possible.
| PE | Ground conductor / earthing |
| L1 | Phase conductor |
| N | Neutral conductor |
Max. cross-section of each conductor cable:
16 mm²
Min. cross-section of each conductor cable:
in accordance with the fuse rating on the AC side, but at least 2.5 mm²
The AC cables can be connected to the AC terminals without ferrules.
IMPORTANT! When using ferrules for AC cables with a cross-section of 16 mm², the ferrules must be crimped with a right-angled cross-section.
The use of ferrules with insulating collars is only permitted up to a max. cable cross-section of 10 mm².
The following types of AC cable can be connected to the AC terminals of the inverter:
The AC-side terminals are suitable for connecting single-wire, round aluminium cables. Because of the formation of a non-conductive oxide layer due to the reaction of aluminium with air, the following points must be considered when connecting aluminium cables:
Always follow the cable manufacturer instructions when using aluminium cables.
When designing cable cross-sections, take local regulations into account.
Connection conditions:
IMPORTANT! Do not use brushes, files or emery paper, as the aluminium particles get trapped and can be transferred to other conductors.
IMPORTANT!Repeat the procedure if the cable has been disconnected and is to be re-connected.
IMPORTANT! The PE ground conductor of the AC cable must be laid in such a way that it is the last to be disconnected in the event that the strain-relief device should fail.
This can be ensured, for example, by making it somewhat longer and by laying it in a loop.
If AC cables are laid over the shaft of the DC main switch or across the connection block of the DC main switch, they may be damaged when the inverter is swung in, or they may even prevent the inverter from being swung in.
IMPORTANT! Do not lay AC cables over the shaft of the DC main switch or across the connection block of the DC main switch.
If overlength AC or DC cables are to be laid in loops in the connection area, attach the cables with cable ties to the eyelets provided on the top and bottom of the connection block.
Inverter | Phases | Max. output | Max. output overcurrent protection |
Fronius Galvo 1.5 | 1 | 1500 W | 1 x C 25 A |
Fronius Galvo 2.0 | 1 | 2000 W | 1 x C 25 A |
Fronius Galvo 2.5 | 1 | 2500 W | 1 x C 25 A |
Fronius Galvo 3.0 | 1 | 3000 W | 1 x C 25 A |
Fronius Galvo 3.1 | 1 | 3100 W | 1 x C 25 A |
Local regulations, the energy company or other factors may require a residual current protective device (RCD) in the AC connection lead.
For this situation, a type A residual current protective device is generally adequate. In particular cases, and depending on local factors, however, the type A residual current protective device may trip at the wrong time.
For this reason, Fronius recommends that an RCD suitable for frequency converters be used.
Risk of electric shock if the solar module ground is not grounded or is not grounded properly.
To comply with IEC 62109-2:2011, any grounding required by the manufacturer of the solar module ground within the inverter must only be carried out via the specified fuse.
Danger from DC voltage in solar modules.
An electric shock can be fatal. The inverter's insulation monitoring is deactivated when the solar modules are grounded.
Ensure that grounded solar modules are assembled so that they are insulated according to Protection Class II
Place the relevant safety sticker in a clearly visible place on the photovoltaic system
Configure the inverter so that an error message is displayed if the fuse trips.
The power stage set, which is enclosed in a separate housing, must only be disconnected from the connection area when in a de-energized state.
Danger due to dirt or water on the terminals and contacts of the connection area.
The mounting bracket without a power stage set does not conform to the protection class of the inverter as a whole, and therefore must not be installed without a power stage set. The mounting bracket should be protected from dirt and moisture during installation.
Danger due to incorrectly tightened terminals.
This may result in heat damage to the inverter, which may lead to fire.
Danger due to overloading.
The maximum amperage when connecting to a single DC terminal is 36 A.
Connect the DC+ and DC- cables to the DC+ and DC- terminals on the inverter, taking care to ensure that the polarity is correct.
NOTE! If solar modules are grounded by a built-in grounding protection device in the inverter, they will not be grounded if the DC main switch is in the OFF position.
NOTE! When connecting aluminium cables:NOTE! The solar modules connected to the inverter must comply with the IEC 61730 Class A standard.
NOTE! When photovoltaic modules are exposed to light, they supply current to the inverter.
NOTE! Ensure the polarity is correct when connecting the DC cables.
NOTE! For grounding solar module frames or racks, the relevant specifications from the solar module manufacturer must be taken into account along with national guidelines.
NOTE! If the inverter is installed in Australia or New Zealand (required standard: AS4777.2:2020), the following applies:
In order to select suitable solar modules and get the most efficient use out of the inverter, please note the following points:
Before connecting solar modules, make sure that the voltage specified by the manufacturer corresponds to the actual measured voltage.
Note the safety instructions and specifications of the solar module manufacturer regarding solar module grounding.
Cable cross section per DC cable:
minimum 2.5 mm² - maximum 16 mm²
The DC cables can be connected to the DC terminals without ferrules.
Note! To ensure effective strain relief of the solar module strings, only use cables with identical cross-sections.
IMPORTANT! When using ferrules for DC cables with a cross-section of 16 mm², the ferrules must be crimped with a right-angled cross-section.
The DC-side terminals are suitable for connecting single-wire, round aluminium cables. Because of the formation of a non-conductive oxide layer due to the reaction of aluminium with air, the following points must be considered when connecting aluminium cables:
Note! Always follow the cable manufacturer instructions when using aluminium cables.
Note! When designing cable cross-sections, take local regulations into account.
IMPORTANT! Repeat the procedure if the cable has been disconnected and is to be re-connected.
Danger due to incorrect polarity and voltage.
Check the polarity and voltage of the solar module strings before making the connection. The voltage must not exceed the following values:
Fronius Galvo 1.5-1: 420 V
Fronius Galvo 2.0-1: 420 V
Fronius Galvo 2.5-1: 550 V
Fronius Galvo 3.0-1: 550 V
Fronius Galvo 3.1-1: 550 V
A dummy device is not suitable for connecting operationally to a photovoltaic system, and must only ever be used for demonstration purposes. Dummy devices are indicated as such on their rating plate.
IMPORTANT! Never connect DC cables to the DC connection sockets on a dummy device.
The connection of de-energised cables or sections of cable for demonstration purposes is permissible.
Only break out as many target break points as the number of cables that are provided (e.g. if there are 2 DC cables, then break out 2 recesses).
If DC cables are laid over the shaft of the DC main switch or across the connection block of the DC main switch, they may be damaged when the inverter is swung in or they may even prevent the inverter from being swung in.
IMPORTANT! Do not lay DC cables over the shaft of the DC main switch or across the connection block of the DC main switch.
Some manufacturers of solar modules stipulate that the modules must be grounded.
Inside the inverter is a means for grounding solar modules on the negative pole via a fuse.
The fuse holder for grounding the solar modules is located on the rear of the inverter.
The inverter can also be operated with solar modules that need to be grounded on the positive pole.
IMPORTANT! The fuse in the inverter is not used for grounding the solar modules on the positive pole; this has to take place outside the inverter.
Solar module ground on the negative pole via a fuse
| (1) | Solar module |
| (2) | Inverter |
| (3) | Fuse |
Fronius recommends the following fuse for the solar module ground on the negative pole:
nominal current rating 1 A / 600 V, fuse dimensions 10 x 38 mm
IMPORTANT! Fuses for grounding the solar module are not part of the scope of supply of the inverter. If the manufacturer of the solar module stipulates that earthing is required, an appropriate fuse must be ordered separately.
The inverter's insulation monitoring must be deactivated when the solar modules are grounded. In the Basic menu, the inverter must therefore be configured so that when the grounding fuse trips, an error message is displayed or the inverter is switched off (according to the country setup).
The access code 22742 must be entered to access the Basic menu.
IMPORTANT! Operating the inverter with one option card and two broken-out option card slots is not permitted.
To cater for this eventuality, a suitable blanking cover (42,0405,2020) is available from Fronius as an option.
IMPORTANT! If data communication cables are wired into the inverter, observe the following points:
Danger of residual voltage from capacitors.
The housing screws provide a suitable ground conductor connection for earthing the housing and must NOT be replaced by any other screws that do not provide a reliable ground conductor connection.
IMPORTANT! Observe the ESD guidelines when handling option cards.
IMPORTANT! Only one Fronius Datamanager in master mode is permitted per Fronius Solar Net ring. Switch any other Fronius Datamanagers to slave mode or remove them.
Seal off the unoccupied option card slot by replacing the cover (item number 42,0405,2094); alternatively, use an inverter without a Fronius Datamanager (light version).
IMPORTANT! Only break out one opening for the PC board when installing a Datamanager in the inverter.
Ensure that the conduits are tightly sealed.
Condensation within the conduits can damage the inverter or components of the photovoltaic systems.
To avoid undesirable air circulation and condensation in the conduits:
Seal all conduits being used with a permanently elastic sealant
Seal every incoming and outgoing conduit
Seal both conduit ends.
The side sections of the housing lid are designed to function as holding and carrying handles.
Note! For safety reasons, the inverter is fitted with a latch that prevents the inverter from being swung into the mounting bracket unless the DC main switch is switched off.The fastening screws in the data communication area of the inverter are used for securing the inverter to the mounting bracket. Correctly tightened fastening screws are a prerequisite if proper contact is to be established between the inverter and mounting bracket.
Danger due to incorrectly tightened fastening screws.
This may result in arcs occurring when the inverter is in operation, which may lead to fire.
Always use the specified torque when tightening the fastening screws.
When starting the inverter for the first time, it is necessary to select various setup settings.
If setup is interrupted before it is complete, it can be restarted by means of an AC reset. An AC reset can be carried out by switching the automatic circuit breaker off and on again.
The country setup can only be set when using the inverter for the first time. If the country setup needs to be changed at a later date, please contact your Technical Support team.
* Country setup examples | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
If the inverter is supplied with a USB flash drive, the inverter software must be updated as soon as the inverter has been commissioned:
If a USB flash drive is connected to the USB A socket it can function as a datalogger for an inverter.
The logging data stored on the USB flash drive can be viewed at any time in third-party programmes (e.g Microsoft® Excel) using the CSV file logged at the same time.
Older versions of Excel (before Excel 2007) are limited to a maximum of 65,536 rows.
If the USB flash drive is being used as a data logger, three files will be created automatically:
| (1) | USB root directory |
| (2) | Fronius inverters (Fronius Galvo, Fronius Symo, Fronius Primo or Fronius Eco) |
| (3) | Inverter number - can be set in the Setup menu under DATCOM |
If there are several inverters with the same inverter number, the three files will be saved in the same folder. A digit is added to the file name as a suffix (e.g.: DALO_02.fld)
Structure of the CSV file:
| (1) | ID |
| (2) | Inverter no. |
| (3) | Inverter type (DATCOM code) |
| (4) | Logging interval in seconds |
| (5) | Energy in watts per second, relative to the logging interval |
| (6) | Inductive reactive power |
| (7) | Capacitive reactive power |
| (8) | Average values during the logging interval (AC voltage, AC current, DC voltage, DC current) |
| (9) | Additional information |
A USB flash drive with a storage capacity of 1 GB can record logging data for roughly seven years at a logging interval of five minutes.
CSV file
CSV files can only store 65,535 lines (data records) (up to Microsoft® Excel 2007; there is no restriction from this version onwards).
At a five-minute logging interval, the 65,535 lines will be written within approximately seven months (CSV data size of approx. 8 MB).
In order to avoid data loss, the CSV file should be backed up to a PC and deleted from the USB flash drive within this seven-month period. If the logging interval is set to a longer period, this time frame will be increased accordingly.
FLD file
The FLD file should not be larger than 16 MB. This will provide enough storage capacity for approximately six years at a logging interval of five minutes.
If the file exceeds the 16 MB limit, it should be backed up to a PC and all of the data on the USB flash drive should be deleted.
After backing up and removing the data, the USB flash drive can be reconnected immediately to resume recording the logging data without any further steps being required.
Note! Using a full USB flash drive can lead to data loss or data being overwritten. When using USB flash drives, always ensure that there is sufficient storage capacity on the flash drive.
Risk of USB flash drive becoming full.
This may result in data being lost or overwritten.
If the USB stick is unplugged (e.g. for data backup purposes), the logging data is written to a buffer memory in the inverter.
As soon as the USB stick is plugged in again, the data is copied automatically from the buffer memory to the stick.
The buffer memory can store a maximum of six logging points. Data is only logged while the inverter is running (output greater than 0 W). The logging interval is permanently set at 30 minutes. Data can be recorded on the buffer memory for a three-hour time period as a result.
When the buffer memory is full, the oldest data in the memory will be overwritten by the next batch of data.
IMPORTANT! The buffer memory requires a permanent power supply.
If there is a power failure while the inverter is in operation, all the data in the buffer memory will be lost. To avoid losing data during the night, the automatic night switch-off facility must be deactivated (switch the "Night Mode" setup parameter to ON - see the Datamanager 2.0 Operating Instructions, section "Setting and displaying the menu items", "Viewing and adjusting parameters in the DATCOM menu item").
On the Fronius Eco or Fronius Symo 15.0-3 208, the buffer memory also functions with just a DC supply.
Due to the variety of USB flash drives available on the market, it cannot be guaranteed that every USB flash drive will be detected by the inverter.
Fronius recommends that only certified, industry-grade USB flash drives are used (look out for the USB-IF logo).
The inverter supports USB flash drives with the following file systems:
Fronius recommends that the USB flash drive employed should only be used for recording logging data or updating the inverter software. The USB flash drives should not contain any other data.
USB symbol on the inverter display, e.g. in display mode 'NOW':
If the inverter detects a USB flash drive, the USB symbol will appear in the top right corner of the display.
When inserting a USB flash drive, check whether the USB symbol is displayed (it may also flash).
Note! Please note for outdoor applications that conventional USB flash drives are often only guaranteed to work within a restricted temperature range.
For outdoor applications ensure that the USB flash drive also functions, for example, at low temperatures.
With the help of the USB stick, end customers can also update the inverter software via the USB item on the SETUP menu: the update file is first saved to the USB stick, from where it is then transferred to the inverter. The update file must be saved in the root directory on the USB stick.
Safety instruction concerning the removal of a USB flash drive: | ||
| IMPORTANT! To avoid any loss of data, a USB flash drive may only be removed if the following conditions are met:
Note! When installed outdoors in a horizontal position: once a year, check that all screw joints are tight!
Maintenance and servicing may only be carried out by Fronius-trained service technicians.
Clean the inverter as required with a damp cloth.
Do not use cleaning agents, abrasives solvents or similar to clean the inverter.
The serial number of the inverter is located on the rating plate on the bottom of the inverter.
Depending on the installation position of the inverter, the serial number can be difficult to access or read, e.g. if the inverter has been installed in a dark or shaded area.
Two serial number stickers are enclosed with the inverter's installation instructions:
| * | 57 x 20 mm |
| ** | 67 x 20 mm |
These can be affixed by the customer in a visible location of his choosing, e.g. on the front of the inverter or on the Operating Instructions.
Application example:
Serial number sticker on the Operating Instructions or on the front of the inverter
For Australia only:
Affix the DRM Australia sticker in the Datamanager area.
| * | 57 x 20 mm |
| ** | 67 x 20 mm |
For Australia only:
