Indicates immediate danger.
Transport, storage or operation of the device outside the stipulated range will be deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
Ambient air temperature range:The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
Can be used at altitudes up to 2000 m (6561 ft.)
Packaging materialsCopyright of these operating instructions remains with the manufacturer.
All safety and danger notices on the deviceFor the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
Before switching on the device, rectify any faults that could compromise safety.
The device is intended solely for the welding processes specified on the rating plate.
Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
The manufacturer likewise accepts no liability for inadequate or incorrect results.
The device generates a maximum sound power level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation at the maximum permissible operating point under maximum rated load conditions according to EN 60974-1.
It is not possible to provide a workplace-related emission value during welding (or cutting) as this is influenced by both the process and the environment. All manner of different welding parameters come into play, including the welding process (MIG/MAG, TIG welding), the type of power selected (DC or AC), the power range, the type of weld metal, the resonance characteristics of the workpiece, the workplace environment, etc.
The fumes produced during welding contain harmful gases and vapours.
Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
Keep your face away from welding fumes and gases.
Fumes and hazardous gasesEnsure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
Flying sparks may cause fires or explosions.
Never weld close to flammable materials.
Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
An electric shock is potentially life threatening and can be fatal.
Do not touch live parts either inside or outside the device.
Make sure that you and others are protected with an adequately insulated, dry temporary backing or cover for the earth or ground potential. This temporary backing or cover must extend over the entire area between the body and the earth or ground potential.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Loose connections, scorched, damaged or inadequately dimensioned cables and leads must be replaced immediately.
Do not sling cables or leads around the body or parts of the body.
The electrode (rod electrode, tungsten electrode, welding wire, etc.) mustDouble the open circuit voltage of a power source can occur between the welding electrodes of two power sources. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
If necessary, provide an adequate earthing connection for the workpiece.
Switch off unused devices.
The battery can catch fire if overheated. Do not expose the device to heat
(e.g. a permanent heat source or fire)
Do not operate or store the device in a potentially explosive atmosphere.
Special regulations apply in rooms at risk of fire or explosion.
Observe relevant national and international regulations.
To comply with European Directive 2006/66/EC on batteries and accumulators and its implementation in national law, batteries and rechargeable batteries that have reached the end of their life must be collected separately and returned to an approved recycling facility. Be sure to return any device that you no longer require to your distributor, or find out about the approved collection and recycling facilities in your area. Ignoring this European Directive may have potentially adverse effects on the environment and your health!
Devices with mechanically undamaged rechargeable batteries may be returned to the relevant Fronius Service Partner for repair or battery replacement.
As soon as it becomes evident that the rechargeable battery has been mechanically damaged (e.g. electrolyte is escaping), dispose of the device at your nearest recycling centre in accordance with national laws and guidelines.
If anything is unclear or you have any questions about disposal, contact your Fronius Service Partner.
Use only the "ActiveCharger 1000" battery charger to charge the power source. Use of a different charger poses a fire risk.
Only operate the power source using the battery provided. Use of a different battery could result in the risk of injury and/or fire.
If the battery is disconnected, keep it away from metal objects such as paperclips, coins, keys, nails, screws or other small metal objects that could establish a connection between the battery terminals. Short circuiting of the battery poles could result in a burn injury or a fire.
Do not use damaged or modified batteries and power sources. Damaged or modified components and devices may exhibit unpredictable behaviour that could result in an explosion or injury.
Do not expose the power source and the battery to fire or temperatures exceeding 130 °C (266 °F). This could result in an explosion.
Follow the charging instructions contained in these Operating Instructions. Do not charge the battery outside of the permitted temperature range - see sectionEnvironmental conditions on page (→). Improper charging or exposure to unauthorised temperatures could damage the battery and increase the risk of fire.
If the floor is electrically conductive, the device must be set up with sufficient insulating material to insulate it from the floor.
If distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
Use filters if necessary.
Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
Keep the shielding gas cylinders well away from any welding or other electrical circuits.
Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
Turn your face to one side when opening the valve of a shielding gas cylinder.
Close the shielding gas cylinder valve if no welding is taking place.
If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
Risk of suffocation from the uncontrolled escape of shielding gas
Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
After transporting the device, it must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
The manufacturer recommends that the welding system be calibrated during the same 12-month period.
A safety inspection should be carried out by a qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on safety inspection and calibration can be obtained from your service centre. They will provide you with any documents you may require, on request.
Devices with the CE mark satisfy the essential requirements of the low-voltage and electromagnetic compatibility directives (e.g. relevant product standards of the EN 60 974 series).
Fronius International GmbH hereby declares that the device is compliant with Directive 2014/53/EU. The full text on the EU Declaration of Conformity can be found at the following address: http://www.fronius.com
The Operating Instructions must always be kept to hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device:For the location of the safety and danger notices on the device, refer to the section headed "General information" in the Operating Instructions for the device.
Before switching on the device, eliminate any faults that could compromise safety.
Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended purpose. The manufacturer shall not be held liable for any damage arising from such usage.
For exact information on permitted environmental conditions, please refer to the "Technical data" section.
The device is to be used exclusively for its intended purpose. Any use above and beyond this purpose is deemed improper. The manufacturer is not liable for any damage, or unexpected or incorrect results arising out of such misuse.
Proper use also includes:Proper handling of the device is essential for it to function correctly. Never pull on the cable when handling the device.
This may affect a number device types in terms of:*) at the interface with the public grid
see "Technical data"
In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
IMPORTANT! Ensure that the mains connection is earthed properly
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Loose connections, scorched, damaged or inadequately dimensioned cables and leads must be immediately repaired by authorised personnel.
Before leaving the work area, ensure that people or property cannot come to any harm in your absence.
Operate devices with ground conductors only on a grid with a ground conductor and a socket with a ground conductor contact. Operating the device on a grid without a ground conductor or on a socket without a ground conductor contact is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
Only operate the device in accordance with the protection class shown on the rating plate.
Never commission the device if it is damaged.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Safety devices that are not fully functional and components with defects must be repaired by an authorized specialist before the device is turned on.
A freely accessible mains plug is required after installation.
Before each start-up, check the mains plug and mains cable and charging cables and charging terminals for damage.
If dirt accumulates on the device, clean the surface of the device housing with a soft cloth and only with solvent-free cleaning agents.
Maintenance and repair work must only be carried out by authorised personnel. Use only original spare and wearing parts (also applies to standard parts). It is impossible to guarantee that bought-in parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements.
Modifications, installations or conversions are only permitted with the approval of the manufacturer.
The manufacturer recommends that a safety inspection of the device is performed at least once every 12 months.
The safety inspection may only be performed by an appropriately qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on safety inspections can be obtained from your service centre. They will provide you on request with any documents you may require.
Devices with the CE marking satisfy the essential requirements of the applicable guidelines.
Devices displaying the EAC mark of conformity satisfy the requirements of the relevant standards in Russia, Belarus, Kazakhstan, Armenia and Kyrgyzstan.
Minimum AWG size of an extension cable | |||
25 ft (7.6 m) | 50 ft (15.2 m) | 100 ft (30.5 m) | 150 ft (45.6 m) |
AWG 16 | AWG 12 | AWG 10 | AWG 8 |
During welding, an electronic regulator adapts the power source characteristic to suit the welding electrode. The result is a lightweight and compact device with excellent ignition and weld properties.
When cellulose electrodes (CEL) are used, a special operating mode can be selected to ensure perfect welding results.
TIG welding with touchdown ignition greatly extends the range of applications.
The warning notices and safety symbols on the power source must not be removed or painted over. They warn against incorrect operation which can lead to serious injury and damage.
Meaning of safety symbols on the device:
Risk of serious injury and damage due to incorrect operation.
Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules.
Danger due to improper handling of the lithium-ion battery.
This can result in severe injury or damage to property.
Never expose the power source to naked flames. Excessive heat can cause the battery to explode or burst.
Do not open the power source or remove the battery. If the battery becomes damaged due to improper handling, poisonous substances can escape which may be harmful to health.
Do not drop the power source into water. This can cause a short circuit, even if the power source is switched off. This in turn can cause the battery to become hot, ignite or burst.
Do not open the power source.
The power source may only be opened by a Fronius service technician.
If you need a replacement battery, hand the power source over to a Fronius Service Partner.
When storing or transporting the power source, observe the environmental conditions in the Technical data section from page (→) .
Particularly if the power source is stored for long periods of time, observe the following points:The service life of the battery is dependent entirely upon how it is handled.
The way in which the battery is operated and stored and the conditions under which this occurs are therefore extremely important.
The intelligent functions of the power source (see section Battery protection functions from page (→) ) play a significant role in increasing the service life of the battery.
However, the user must observe the following key points in order to guarantee maximum battery life:The power source has a deep discharge protector to warn the user if the state of charge of the battery is too low. If this is the case, the power source switches off.
Function of the deep discharge protector:Danger due to prolonged storage of the battery in a discharged state.
This can damage the battery.
If the deep discharge protector is triggered, charge the power source immediately!
Automatic switch-off avoids unnecessary power consumption, thereby extending the effective period of operation with one battery charge.
If the power source is not operated for a specific length of time, it switches off automatically.
To reactivate the power source, press the On/Off button for at least two seconds.
The factory setting for the automatic switch-off time is 15 minutes (if no welding is performed for 15 minutes, the power source switches off automatically).
This value can be changed in the Setup menu using the tSd parameter.
Temperature monitoring prevents the battery from being charged or discharged if the temperature of the battery is outside the permitted temperature range.
The battery charger has an internal temperature management functionUndertemperature
If the battery falls below the permitted temperature range, neither welding nor charging is possible.
Overtemperature
Charging is only possible again at a battery temperature of less than +45 °C.
Once the battery has been fully charged, the charger turns off automatically and switches to conservation charging mode.
More information on how the battery charger and the individual operating modes work can be found in the charger description on page (→) .
The power source is intended exclusively for MMA welding and TIG welding.
The integrated battery must only be charged with the Fronius ActiveCharger 1000.
Any other use is deemed improper.
The manufacturer is not liable for damage resulting from such use.
Danger from machines toppling over or falling.
Set up the device securely on an even, solid surface.
Check all screw connections are tightly fastened after installation.
Cooling air
The device must be set up in such a way that cooling air can flow freely through the slots in the front and rear panels.
Dust
Ensure that metallic dust is not sucked into the system by the fan, when carrying out grinding for example.
Outdoor operation
The device can be set up and operated outdoors in accordance with IP23 degree of protection. Avoid direct wetting (e.g. from rain).
The device is designed to be connected to the mains using the Fronius ActiveCharger 1000 only (= hybrid mode, see Operating modes on page (→) ).
No warranty claims will be entertained if the device is operated with other chargers.
As a result of software updates, you may find that there are functions available on your device that are not described in these Operating Instructions, or vice versa.
Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
| (1) | (-) current socket with bayonet latch |
| (2) | (+) current socket with bayonet latch |
| (3) | Carrying strap |
| (4) | Cable strap for holding the mains cable and the welding power-leads Do not use to move the device! |
| (5) | Battery charger connection |
| (6) | Air filter |
(1) | Setting value indicator shows which setting value is selected:
(2) | Unit indicator shows the unit of the value that is currently being changed using the adjusting dial (8):
(3) | Battery capacity indicator shows the state of charge of the battery:
(4) | Display |
(5) | Welding process indicator shows which welding process is selected:
(6) | Welding process button |
(7) | On/Off button |
(8) | Adjusting dial |
(9) | TAC indicator |
(10) | Setting value button |
(11) | Status indicators display various operating modes of the power source:
As soon as the power source is switched on, the electrode in the electrode holder is live. Make sure the electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.).
This function is used to set the starting current.
Setting range: 0 - 200%
Operating principle:
At the start of the welding process, the welding current is reduced (SoftStart) or increased (HotStart) for 0.5 seconds, depending on the setting.
The change is shown as a percentage from the set welding current.
The duration of the starting current can be changed in the Setup menu using the Hti parameter, see Parameters for MMA welding on page (→) .
The maximum HotStart current is limited to 180 A.
To obtain optimum welding results, it will sometimes be necessary to adjust the arc-force dynamic.
Setting range: 0 - 100 (corresponds to 0 - 200 A current increase)
At the moment of droplet transfer or in the event of a short circuit, the amperage is briefly increased in order to obtain a stable arc.
If the rod electrode threatens to sink into the weld pool, this measure prevents the weld pool solidifying, as well as preventing a prolonged short-circuit of the arc. This largely prevents the rod electrode from sticking.
The maximum arc-force dynamic current is limited to 180 A.
Do not use pure tungsten electrodes (colour-coded green) if the TIG welding process has been selected.
Danger from falling gas cylinders.
Place gas cylinders on a solid, level surface so that they remain stable. Secure gas cylinders to prevent them from falling over.
Observe the safety rules of the gas cylinder manufacturer.
Risk of injury and damage from electric shock.
As soon as the power source is switched on, the electrode in the welding torch is live. Make sure the electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.).
For more information on activating and setting the TIG Comfort Stop function see Parameters for TIG welding on page (→).
Function and application of TIG Comfort Stop:
| (1) | Gas pre-flow |
| (2) | Gas post-flow |
Downslope:
The downslope time tdown is 0.5 seconds and cannot be adjusted.
Gas post-flow:
The gas post-flow must be carried out manually.
1Turn the adjusting dial to select the required parameter | |
2Press the adjusting dial to display the preset value of the parameter | |
3Turn the adjusting dial to change the value - the new value becomes effective immediately - exception: when restoring the factory settings, press the adjusting dial after changing the value to activate the new value. | |
4Press the adjusting dial to return to the list of parameters |
Starting current duration
0,1 - 1,5 seconds
for the SoftStart / HotStart function
Factory setting: 0.5 seconds
Anti-Stick
On / OFF
When the anti-stick function is active, the arc is extinguished after 1.5 seconds in the event of a short circuit (sticking of the electrode)
Factory setting: ON (activated)
Break voltage (U cut off)
25 - 80 Volts
Used to specify at which arc length the welding process is to be completed.
The welding voltage increases as the length of the arc increases. The arc is extinguished when it reaches the voltage specified here.
Factory setting: 45 volts
Software version
The full version number of the currently installed software is spread across a number of displays and can be retrieved by turning the adjusting dial.
Automatic switch-off (time Shut down)
300 - 900 Seconds / OFF
If the power source is not operated for the specified length of time, it switches off automatically.
Factory setting: 900 seconds
Factory setting (FACtory)
The power source can be reset to its factory settings here.
no / YES / ALL
Resetting of the selected value to its factory setting must be confirmed by pressing the adjusting dial.
Comfort Stop Sensitivity
0.3 - 2.0 V/OFF
For details see section TIG Comfort Stop from page (→).
12 - 35 V
Used to specify at which arc length the welding process is completed. The welding voltage increases as the length of the arc increases. The arc is extinguished when it reaches the voltage specified here.
This parameter is only available when the CSS parameter is set to OFF.
Factory setting: 15 volts
Software version
Automatic shutdown (time Shut down)
300 - 9000 seconds/OFF
no/YES/ALL
VRD is an additional safety device that prevents, as far as possible, output voltages that may pose a danger to persons.
VRD = Voltage Reduction Device.
Within 0.
3 seconds of the end of welding:
VRD is active again
The output voltage is limited to 14 V again
Do not open the power source. The power source may only be opened by a Fronius service engineer.
Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the device remains in a usable condition for many years.
Air inlets and outlets must never be covered, not even partially.
Always dispose of the device separately from the installed battery.
The following section explains how to remove the battery.
All the work and functions described in this document must only be carried out by trained and qualified personnel.
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
Danger from electric current.
Switch off the power source.
Disconnect the power source from the battery charger.
Ensure that the power source remains disconnected from the battery charger until all work has been completed.
The following steps on removing the rechargeable battery pack must only be used when disposing of the device!
If the rechargeable battery pack needs to be repaired or replaced, contact After-Sales Service.
Before removing the rechargeable battery pack, the power source must be disconnected from the battery charger!
Ensure that the power source is completely discharged.
Fire hazard due to short circuit of the battery!
If the battery is short-circuited, sparks may be generated and the battery may catch fire.
After terminating the (-) power cable, insulate it well (e.g. wrap it with insulating tape)!
| Cause: | Device is too hot |
| Remedy: | Check/reduce ambient temperature, allow power source to cool down |
| Cause: | Device temperature too low |
| Remedy: | Check/increase ambient temperature, operate the power source in a warmer environment For more information see the Environmental conditions section on page (→) |
| Cause: | Battery discharged, deep discharge protection has been activated |
| Remedy: | Charge the battery now |
CAUTION!Danger due to prolonged storage of the battery in a discharged state. This can damage the battery. If the deep discharge protector is triggered, charge the power source promptly! | |
When E and a 2 digit error number appear in the display (e.g. E02) and the "Error" indicator lights up, this is an internal power source service code.
Example:
It is also possible that several error numbers are present. These appear when turning the adjusting dial.
Make a note of the error numbers shown in the display, and of the serial number and configuration of the power source, and contact our after-sales service team with a detailed description of the error.
| Cause: | Internal temperature sensor fault on ACCUPLT / ACCUPLT-TIG PC board |
| Remedy: | Contact after-sales service |
| Cause: | Internal supply voltage 15 V outside the valid range |
| Remedy: | Contact After-Sales Service |
| Cause: | Load too high on power source current sockets |
| Remedy: | Use power source correctly (welding) |
| Cause: | No communication with the control panel |
| Cause: | Internal error on ACCUPLT / ACCUPLT-TIG PC board |
| Cause: | Communication error between battery and ACCUPLT / ACCUPLT-TIG PC board |
| Cause: | Wrong firmware (software) has been loaded |
| Cause: | Battery fault |
| Cause: | A voltage of > 113 V DC has been measured on the current sockets |
| Cause: | The battery has entered a state of deep discharge as it has been stored for too long without being charged |
| Remedy: | Charge the battery now If charging is no longer possible, contact After-Sales Service. |
| Cause: | Control panel defective |
| Remedy: | Check/reduce ambient temperature, allow battery to cool down |
| Remedy: | Check/increase ambient temperature, disconnect and reconnect battery charger |
| Cause: | Charging cable defective |
| Remedy: | Renew charging cable |
| Cause: | Welding power-lead connections have been disconnected |
| Remedy: | Establish proper welding power-lead connections |
| Cause: | Poor or no earth |
| Remedy: | Establish a connection to the workpiece |
| Cause: | There is a break in the power cable in the welding torch or electrode holder |
| Remedy: | Replace welding torch or electrode holder |
| Cause: | Duty cycle exceeded - power source overloaded - fan running |
| Remedy: | Keep within duty cycle |
| Cause: | Thermostatic automatic circuit breaker has been tripped |
| Remedy: | Wait until the power source comes back on automatically at the end of the cooling phase |
| Cause: | The fan in the power source is faulty |
| Cause: | Insufficient cooling air intake |
| Remedy: | Ensure adequate air supply |
| Cause: | Air filter is dirty |
| Remedy: | Clean air filter |
| Cause: | Power module error |
| Remedy: | Turn off the power source, then turn it on again. If the error occurs frequently, contact After-Sales Service |
| Cause: | Incorrect welding process selected |
| Remedy: | Select "MMA welding" or "MMA welding with Cel electrode" process |
| Cause: | Starting current too low; electrode sticking during ignition |
| Remedy: | Increase starting current using HotStart function |
| Cause: | Starting current too high; electrode consumed too quickly during ignition or is generating a lot of spatter |
| Remedy: | Reduce starting current using SoftStart function |
| Cause: | Electrode (e.g. grooved electrode) voltage too high |
| Remedy: | If possible, use alternative electrode or a power source with more welding power |
| Cause: | Break voltage (Uco) set too low |
| Remedy: | Increase break voltage (Uco) in Setup menu |
| Cause: | Value of arc-force dynamic parameter (MMA welding) set too low |
| Remedy: | Increase value of arc-force dynamic parameter |
| Cause: | Incorrect electrode polarity |
| Remedy: | Reverse electrode polarity (refer to manufacturer's instructions) |
| Cause: | Poor grounding (earthing) connection |
| Remedy: | Fasten earthing clamps directly to workpiece |
| Cause: | Setup parameters not ideal for selected welding process |
| Remedy: | Select the optimal settings in the Setup menu for the selected welding process |
| Cause: | Incorrect tungsten electrode polarity |
| Remedy: | Connect the TIG welding torch to the (-) current socket |
| Cause: | Incorrect (or no) shielding gas |
| Remedy: | Use inert shielding gas (argon) |
| Cause: | VRD option not present or internal device fault |
Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
If the ambient temperature is higher, either the ED or output must be reduced accordingly.
Example: Welding at 150 A at 60% ED
If the device is to be continuously operated without stopping:
Rated battery voltage | 52.8 V | ||
Charging current | 10 A | ||
Rapid charging current |
| 18 A | |
Battery capacity | 7.5 Ah | ||
Battery type | Li-ion | ||
Standard charging | 50 min. | ||
Rapid charging | 30 min. | ||
Welding time | 2.5 mm2 | Electrode | 14 - 18 pc. |
| 3.25 mm2 | Electrode | 6 - 8 pc. |
Welding current range | Electrode DC | 10 - 140 A | |
| TIG DC | 3 - 150 A |
Welding current in hybrid mode (manual metal arc welding) | |||
| 40 °C (104 °F) | 18% D.C.1) | 140 A |
| 40 °C (104 °F) | 25% D.C.1) | 100 A |
| 40 °C (104 °F) | 100% D.C.1) | 40 A |
Welding current in hybrid mode (TIG welding) | |||
| 40 °C (104 °F) | 25% D.C.1) | 150 A |
40 °C (104 °F) | 50% D.C.1) | 100 A | |
| 40 °C (104 °F) | 100% D.C.1) | 65 A |
Open circuit voltage | 91 V | ||
Reduced open circuit voltage | 14 V | ||
Degree of protection | IP 23 | ||
Type of cooling | AF | ||
Mark of conformity | CE, S | ||
Dimensions l x w x h | 435 x 160 x 310 mm | ||
Weight | 10.9 kg (24.3 lb) | ||
1) D.C. = Duty cycle
A number of safety symbols can be seen on the charger's rating plate. The safety symbols must not be removed or painted over.
Possible sources of ignition, such as fire, sparks and naked flames, must be kept away from the battery.
Ensure an adequate supply of fresh air during charging. Maintain a distance of at least 0.5 m (19.69 in.) between battery and charger during the charging procedure.
An electric shock can be fatal. Do not open the device!
The housing must never be opened by anyone other than a Fronius-trained service engineer. The device must be disconnected from the mains before starting any work with the housing open. A suitable measuring instrument must be used to ensure that electrically charged components (e.g. capacitors) are fully discharged. Ensure that the device remains disconnected from the mains until all work has been completed.
This warning sign is located inside the device. It must NOT be removed or painted over.
The discharge time of the capacitors is approx. one minute.
The charger is designed to charge the power sources listed below. Any use above and beyond this purpose is deemed improper. The manufacturer shall not be liable for any damage resulting from such use. Proper use also includes:
Charging any other devices can cause serious injury or damage, and is therefore prohibited.
The following power sources may be charged:
The charger is intended solely for commercial use.
The rating plate, which is located on the housing, contains information about the permitted mains voltage. The device is designed for this mains voltage only. For details on the required fuse protection for the mains lead, see theTechnical data section on page (→) . If there is no mains cable or mains plug on your version of the appliance, fit one that conforms to national standards.
Danger due to insufficiently dimensioned electrical installations.
This can result in serious damage to property.
The mains lead and its fuse must be dimensioned to suit the local power supply.
Read the technical data on the rating plate.
The charger is completely generator-compatible, provided the maximum apparent power delivered by the generator is at least 2 kVA.
This also applies if the generator in question is an inverter.
The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
Details on the mains voltage tolerance can be found in the Technical data section on page (→) .
Dust
Outdoor operation
The device can be set up and operated outdoors in accordance with IP40 degree of protection. Avoid direct wetting (e.g. from rain).
If the charger is installed in a switch cabinet (or a similar sealed area), then forced-air ventilation must be provided to ensure adequate heat dissipation.
There should be an all-round clearance of 10 cm (3.9 in.) around the charger.
| (1) | Mains cable for connection to the mains |
| (2) | Connection P1 - charging lead socket to plug in the charging cable for connection to the power source |
| (3) | Control panel |
| (1) | CHARGING indicator (green) Charging in progress |
| (2) | QUICK CHARGING indicator (green) Quick charging in progress |
| (3) | COMPLETED indicator (green) Power source fully charged |
| (4) | Error indicator (red) See section Troubleshooting on page (→) |
| (5) | Mains indicator (green) Mains supply voltage available |
| (6) | QUICK CHARGE button Starts and stops quick charging |
The system includes the following features for maximum user-friendliness:
It does not matter in what order the devices are connected to the mains
The power source can even be connected to the charger while it is in use
Charging
Starts automatically when the battery charger is connected to the power source and the mains
Quick charging
Activation:
Deactivation:
Conservation charging
Starts automatically once the battery charger has fully charged the power source
Hybrid mode
= the battery charger is charging the power source while the power source is in operation
Acivation:
Depending on the underlying surface, different wall plugs and screws are needed to fit the wall bracket.
Wall plugs and screws are therefore not included in the scope of supply. The installer is responsible for selecting the correct wall plugs and screws.
Do not open the device.
| Cause: | Mains fault (overvoltage or undervoltage) |
| Remedy: | Check mains supply voltage (see Technical data) |
| Cause: | Charger fault |
| Cause: | Mains fuse underrated/incorrect circuit breaker |
| Remedy: | Fuse mains correctly (see Technical data) |
| Cause: | Mains fuse trips in open circuit |
Mains voltage | ~ 230 V AC, ±15% |
Grid frequency | 50/60 Hz |
Mains current | max. 9.5 A eff. |
Mains fuse protection | max. 16 A |
Efficiency | max. 95 % |
Effective power | max. 1100 W |
Apparent power | max. 2370 VA |
Power input (stand-by) | max. 2.1 W |
Safety class | I (with ground conductor) |
Maximum permitted mains impedance at the interface (PCC) to the public grid | None |
EMC emission class | A |
Mark of conformity | CE |
Output voltage range | 30 - 58 V DC |
Output current | max. 18 A DC |
Output power | max. 1040 W |
Cooling | Convection and fan |
Dimensions L x W x H | 270 x 168 x 100 mm |
Weight (without cable) | Approx. 2 kg |
Protection class | IP43S |
Overvoltage category | II |
EN 62477-1 |
EN 60974-10 | (Class A) |
Mains voltage | ~ 120 V AC, ±15% |
Mains current | max. 15 A eff. |
Mains fuse protection | max. 20 A |
Efficiency | max. 94 % |
Apparent power | max. 1900 VA |
Power input (stand-by) | max. 1.6 W |
Output power | max. 1000 W |
Weight | Approx. 2 kg |
UL 1012 |
C22.2 No.107.1-01 |
FCC CFR 47 Part 15 | (Class A) |
Mains voltage | ~ 100 - 110 V AC, +10% / -15% |
Mains current | max. 15.7 A eff. |
Efficiency | max. 92 % |
Effective power | max. 940 W |
Apparent power | max. 1600 VA |
Output current | max. 15 A DC |
Output power | max. 840 W |
EN 62477-1 |
