en
      Operating InstructionsTPS/i Robotics Push welding system
    • Safety rules
      • General
      • Intended use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Mains connection
      • Protecting yourself and others
      • Danger from toxic gases and vapours
      • Danger from flying sparks
      • Risks from mains current and welding current
      • Meandering welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Specific hazards
      • Requirement for the shielding gas
      • Danger from shielding gas cylinders
      • Danger from escaping shielding gas
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
      • Description of the warning notices on the device
    • System configurations
      • System configurations - conventional robot
        • Push with wire drum
        • Push with wirespool
        • Push with 4-roller unreeling wirefeeder and wire drum
        • Power sharing with cooling unit CU1400i PRO MC
        • Power sharing with cooling unit CU2000i PRO MC
      • System configurations - PAP
    • System components
      • WF wire-feed unit
        • Device concept
        • Proper use
        • Safety
      • WF 25i REEL R /4R, WF 30i REEL R /2R
        • Safety
        • Device concept
        • Application area
        • Proper use
      • Interconnecting hosepack
        • General
      • Torch hosepack
        • General remarks
        • Scope of supply
        • Buttons on the Robacta MHP hosepack
      • CrashBox /i
        • General
        • Note on the correct operation of CrashBoxes
        • Also required for installation
        • Device concept
        • Application areas
        • Information on repairing CrashBoxes
        • Scope of supply
        • Clamp system scope of supply and options
      • Robot welding torch
        • Safety
        • General
      • OPT/i camera mount
        • General
        • Drilling template
    • Controls, connections and mechanical components
      • WFi R control elements and mechanical components
        • Safety
      • WF 15i / 25i / 30i R
        • WF 15i R, WF 30i R connections
        • WF 30i R / L connections
        • WF 25i R connections
        • WF 25i R / L connections
      • WF 15i / 25i / 30i R PAP
        • WF 15i R PAP, WF 30i R PAP connections
        • WF 25i R PAP connections
        • WF 25i R / L PAP connections
      • WF 30i R HD/4R/W/FSC
        • WF 30i R HD connections
        • Safety
        • Control elements, connections and mechanical components
      • Function of the gas-test, wire retract and wire threading buttons
    • Installation - conventional robot
      • Fitting the welding system to a conventional robot
        • Safety
        • Fitting the TPS/i welding system to a conventional robot
      • Fitting the wire-feed unit
        • Fitting the wirefeeder holder
      • Fitting the CrashBox /i to the robot
        • Installing the CrashBox/i Dummy on the robot
      • Fitting the clamp system
        • Special tilt angle for the welding torch
        • Fitting the clamp system with extension
      • Fitting the MHP G / W hosepack
        • Fitting the MHP G / W conventional hosepack - Standard
        • Optimum hosepack arrangement
      • Fitting the TPS/i torch neck
        • Safety
        • Fitting the TPS/i torch body - Standard
        • “OPT / i MHP WireBrake” option
        • Fitting the inner liner inside the torch hosepack
      • Fitting the interconnecting hosepack
        • Fitting the Standard interconnecting hosepack to the robot
        • Connecting the extension hosepack
      • Connecting the MHP W hosepack
      • Connecting wire-feed unit to system components
        • Safety
        • General
        • Connecting the wirefeeder to the system components
      • Fitting the OPT / i MHP WireBrake and torch body
        • Safety
        • Prerequisites for operation
        • Compressed air supply specifications
        • Remedying the clamping marks on the wire electrode
        • Technical data
        • Fitting the OPT/i MHP WireBrake
      • Removing the OPT / i MHP WireBrake and torch body
        • Safety
      • Fitting the unreeling wirefeeder
      • Fitting the OPT/i camera mount
        • Load-bearing capacity of the OPT/i camera mount
        • Safety
    • Installation - PAP
      • Axis rotation and service life of the torch hosepack
        • General
        • Recommended axis rotation
        • Maximum axis rotation
        • Hosepack service life depending on the axis rotation in the fifth and sixth robot axis
      • Fitting the welding system to a PAP robot
        • Safety
        • Fitting the TPS/i welding system to a PAP robot
        • Fitting the WF 15i/25i/30i R PAP
      • Installing the CrashBox /i PAP on the robot
      • Fitting the MHPi/MHP S G/W PAP hosepack
        • Fitting the Robacta MHP G/W PAP hosepack
      • Fitting the MHPi/MHP S G/W PAP SM hosepack
        • Fitting the Robacta MHP G/W PAP SM hosepack
        • Fitting the PAP interconnecting hosepack to the robot
        • Connecting the interconnecting hosepack
        • Safety
        • General
        • Connecting the WF 15i/25i/30i R PAP to the system components
    • Start-up
      • Inserting/replacing feed rollers
        • General
        • WF 25i Reel 4R: inserting/replacing feed rollers for the 4-roller drive
        • WF 30i Reel 2R: Inserting/replacing feed rollers for the 2-roller drive
      • Feeding in the wire electrode
        • Insulated routing of wire electrode to wirefeeder
        • Setting the contact pressure
      • Start-up
        • Requirements
        • General
    • Troubleshooting, maintenance and disposal
      • Troubleshooting
        • Safety
        • Fault diagnosis
      • Care, maintenance and disposal
        • General
        • Safety
        • Every start-up
        • Special care of O-rings
        • Whenever the welding torch or torch hosepack is changed
        • Every 6 months
        • "Stop" coolant pump service position - Working mode 17
        • Preparing the WF 15i/25i/30i R PAP for replacement of the welding torch inner liner
        • Recognising faulty wearing parts
        • MTG d, MTW d - Fitting wearing parts to the torch body
        • MTG d, MTW d, MTB - Fitting wearing parts to the torch body
        • Fitting wearing parts to the torch body - MTW 700 i
        • Removing the CrashBox PAP from the robot (without mounting key)
        • Removing the CrashBox PAP from the robot (with mounting key)
        • Changing the torch hosepack, changing the interconnecting hosepack
        • Cleaning the welding torch
        • Disposal
    • Technical data
      • WF wire-feed unit
        • WF 15i R,
          WF 15i R
        • WF 15i R,
          WF 15i R PAP
        • WF 25i R,
          WF 25i R,
          WF 25i R / L
        • WF 25i R,
          WF 25i R PAP,
          WF 25i R / L
        • WF 30i R,
          WF 30i R,
          WF 30i R / L
        • WF 30i R,
          WF 30i R PAP,
          WF 30i R / L
        • WF 30i R HD
      • Unreeling wirefeeder WF REEL
        • WF 25i REEL R /4R/G/W
        • WF 30i REEL R /2R/G/W
      • CrashBox /i
        • Technical data, triggering torques and weight/distance diagram
      • Torch hosepack
        • MHP 400i G / R
        • MHP 400i G / R / PAP
        • MHP 500 S R / G / PAP
        • MHP 700i W / R (0.95 - 2.25 m / 3.12 - 7.38 ft.)
        • MHP 700i W / R (3.25 - 4.25 m / 10.66 - 13.12 ft.)
        • MHP 700i W / R / PAP
        • Gas-cooled robot welding torches
        • MTB 500S G R, MTB 500S G R TD
        • Water-cooled robot welding torches
        • MTB 350i W R
      • Interconnecting hosepacks
        • HP 70i
        • HP 95i
        • HP 120i
        • HP 70i, HP PC Cable HD 70
    • 030-15122025
    download
    Overview of the TPS/i Standard
    Overview of the TPS/i PAP
    Fitting to conventional robots
    Fitting to PAP robots
    Commissioning
    Troubleshooting
    Maintenance
    Changing the hosepack
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statementCookie Policy
    Safety rules
    link_horizontalLink copied
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of automated welding, and
    • read and carefully follow these operating instructions as well as the operating instructions for all system components.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before commissioning the device, rectify any faults that could compromise safety.
    1. Safety rules
    Intended use
    The devices and components described in these operating instructions are intended exclusively for automated MIG/MAG applications in conjunction with Fronius components.
    Any use above and beyond this purpose is deemed improper.
    Intended use also includes:
    • Carefully reading and following all the instructions given in the operating instructions
    • Studying and obeying all safety instructions and danger notices carefully
    • Performing all stipulated inspection and servicing work
    The manufacturer likewise accepts no liability for inadequate or incorrect results.
    1. Safety rules
    Ambient temperature range:
    • during operation: -10 °C to + 40 °C (14 °F to 104 °F)
    • during transport and storage: -20 °C to +55 °C (-4 °F to 131 °F)
    Relative humidity:
    • up to 50% at 40 °C (104 °F)
    • up to 90% at 20 °C (68 °F)
    The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
    Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so undertake:
    • to observe the basic instructions regarding safety at work and accident prevention,
    • to read these operating instructions, especially the "Safety rules" section and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Mains connection
    This may affect a number device types in terms of:
    • Connection restrictions
    • Criteria with regard to the maximum permissible mains impedance *)
    • Criteria with regard to the minimum short-circuit power requirement *)
    *) at the interface with the public grid
    see "Technical data"
    In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
    IMPORTANT! Ensure that the mains connection is earthed properly
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks, e.g.
    • flying sparks and hot pieces of metal
    • Arc radiation, which can damage eyes and skin
    • Hazardous electromagnetic fields, which can endanger the lives of those using cardiac pacemakers
    • Risk of electrocution from mains current and welding current
    • Greater noise pollution
    • Harmful welding fumes and gases
    Suitable protective clothing must be worn when working with the device. The protective clothing must have the following properties:
    • Flame-resistant
    • Insulating and dry
    • Covers the whole body, is undamaged and in good condition
    • Safety helmet
    • Trousers with no turn-ups
    Protective clothing refers to a variety of different items. Operators should:
    • Protect eyes and face from UV rays, heat and sparks using a protective visor and regulation filter
    • Wear regulation protective goggles with side protection behind the protective visor
    • Wear stout footwear that provides insulation even in wet conditions
    • Protect the hands with suitable gloves (electrically insulated and providing protection against heat)
    • Wear ear protection to reduce the harmful effects of noise and to prevent injury
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers (risk of dazzling by the arc, injury from flying sparks, harmful welding fumes, noise, possible risks from mains current and welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains.
    1. Safety rules
    The fumes produced during welding contain harmful gases and vapours.
    Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
    Keep your face away from welding fumes and gases.
    Fumes and hazardous gases
    • must not be breathed in
    • must be extracted from the working area using appropriate methods.
    Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
    If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
    The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:
    • Metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaners, degreasers, etc.
    • Welding process used
    The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
    Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
    Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    1. Safety rules
    Flying sparks may cause fires or explosions.
    Never weld close to flammable materials.
    Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
    Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
    Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
    Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
    1. Safety rules
    An electric shock is potentially life threatening and can be fatal.
    Do not touch live parts either inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
    Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
    Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Use the handle to ensure the power connections are tight before every use.
    In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
    Do not wrap cables or leads around the body or parts of the body.
    The electrode (rod electrode, tungsten electrode, welding wire, etc.) must
    • never be immersed in liquid for cooling
    • never be touched when the welding system is switched on.
    Double the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
    Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
    Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    If necessary, provide adequate earthing for the workpiece.
    Switch off unused devices.
    Wear a safety harness if working at height.
    Before working on the device, switch it off and pull out the mains plug.
    Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
    After opening the device:
    • Discharge all live components
    • Ensure that all components in the device are de-energised.
    If work on live parts is required, have a second person switch off the main switch at the right moment.
    1. Safety rules
    If the following instructions are ignored, meandering welding currents can develop with the following consequences:
    • Fire hazard
    • Overheating of parts connected to the workpiece
    • Damage to ground conductors
    • Damage to device and other electrical equipment
    Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
    If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
    In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check and evaluate the immunity to interference of nearby devices according to national and international regulations. Examples of equipment that may be susceptible to interference from the device include:
    • Safety devices
    • Network, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite the correct mains connection, additional measures are necessary (e.g. use of a suitable line filter)
    2. Welding power-leads
      • must be kept as short as possible
      • must be laid close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Earthing of the workpiece
      • If necessary, establish an earth connection using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices nearby
      • Shield the entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    Specific hazards
    Keep hands, hair, clothing and tools away from moving parts. For example:
    • Fans
    • Cogs
    • Rollers
    • Shafts
    • Wire spools and welding wires
    Do not reach into the rotating cogs of the wire drive or into rotating drive components.
    Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
    During operation
    • Ensure that all covers are closed and all side panels are fitted properly.
    • Keep all covers and side panels closed.
    The welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
    Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
    Never touch the workpiece during or after welding - risk of burns.
    Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
    Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
    Special provisions apply in areas at risk of fire or explosion
    - observe relevant national and international regulations.
    Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
    Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
    Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
    • Hook chains or ropes onto all suspension points provided on the suitable load-carrying equipment.
    • Chains or ropes must be at the smallest angle possible to the vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
    All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
    The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
    Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
    1. Safety rules
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    1. Safety rules
    Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
    Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
    Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
    Keep the shielding gas cylinders well away from any welding or other electrical circuits.
    Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
    Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
    Turn your face to one side when opening the valve of a shielding gas cylinder.
    Close the shielding gas cylinder valve if no welding is taking place.
    If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
    The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
    1. Safety rules
    Risk of suffocation from the uncontrolled escape of shielding gas
    Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
    • Ensure an adequate supply of fresh air with a ventilation rate of at least 20 m³/hour.
    • Observe safety and maintenance instructions on the shielding gas cylinder or the main gas supply.
    • Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    • Check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before every start-up.
    1. Safety rules
    A device toppling over could easily kill someone. Place the device on a solid, level surface such that it remains stable
    • The maximum permissible tilt angle is 10°.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
    When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
    Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
    Before transporting the device, allow coolant to drain completely and detach the following components:
    • Wirefeeder
    • Wirespool
    • Shielding gas cylinder
    After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a risk of
    • damage to the device and other material assets belonging to the operator
    Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
    Only the manufacturer's original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
    Only use suitable original coolant from the manufacturer.
    Do not mix the manufacturer's original coolant with other coolants.
    Only connect the manufacturer's system components to the cooling circuit.
    Cooling Liquid FCL 10/20 does not ignite. The ethanol-based coolant can ignite under certain conditions. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
    Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Check the coolant level before starting to weld, while the system is still cool.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
    The manufacturer recommends that the welding machines be calibrated at the same 12-monthly interval.
    A safety inspection should be carried out by a qualified electrician
    • after any additional parts are installed, or after any conversions
    • after repair, care and maintenance are carried out
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on the safety inspection and calibration can be obtained from your Fronius branch or your Fronius partner. They will provide you with any documents you may require, on request.
    1. Safety rules
    Disposal
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark meet the requirements of all valid EU directives, such as:
    • Directive 2014/30/EU on Electromagnetic Compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • And so on
    The full text of the EU Declaration of Conformity can be found at
    https://www.fronius.com .
    Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Data security
    • saving and retaining personal settings
    1. Safety rules
    Copyright
    1. Safety rules
    For certain device versions, warning notices are affixed to the device.
    The arrangement of the symbols may vary.
    Warning! Attention!
    The symbols represent possible dangers.
    A
    Feed rollers can injure fingers.
    B
    The welding wire and drive parts are live during operation.
    Keep hands and metal objects away!
    1.
    1.1
    Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves.
    1.2
    Use a base that is insulated from the floor and work area to protect against electric shock.
    1.3
    Before working on the device, switch off the device and pull out the mains plug or disconnect it from the power supply.
    2.
    Inhalation of welding fumes can be harmful to health.
    2.1
    Keep your face away from any welding fumes.
    2.2
    Use forced-air ventilation or a local extraction system to remove welding fumes.
    2.3
    Remove welding fumes with a fan.
    Welding sparks can cause an explosion or fire.
    3.1
    Keep flammable materials away from the welding process. Never weld close to flammable materials.
    3.2
    Welding sparks can cause a fire. Have fire extinguishers to hand. If necessary, have a supervisor ready who can operate the fire extinguisher.
    3.3
    Do not weld on drums or closed containers.
    4.
    Arc rays can burn the eyes and injure the skin.
    4.1
    Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body.
    5.
    Before working on the system or welding:
    undertake training on the device and read the instructions!
    6.
    Do not remove or paint over the warning sticker.
    Manufacturer order number of the sticker
    Push with wire drum
    (1)
    Wirefeeding hose with inner liner
    (2)
    TPSi welding machine
    (3)
    CU cooling unit
    (4)
    Upright console
    (5)
    HP interconnecting hosepack
    (6)
    Wirefeeder WF 15i R / WF 25i R / WF 30i R
    (7)
    MHP /i R torch hosepack
    (8)
    MTB /i R robot welding torch
    Maximum wirefeed length:
    max. 8 m between wire drum and wirefeeder
    (max. 10 m with PowerLiner)
    Possible wire diameters:
    0.8 - 2.0 mm
    Welding process:
    Standard, Puls, LSC, PMC
    Use the largest inner liner (incl. basic kit)
    Use the inner liner corresponding to the wire diameter (incl. basic kit)
    1. System configurations
    Push with wire drum
    (1)
    (2)
    (3)
    CU cooling unit
    (4)
    Upright console
    (5)
    (6)
    (7)
    (8)
    0.8 - 2.0 mm
    Welding process:
    2. System configurations - conventional robot
    Push with wire drum
    (1)
    (2)
    (3)
    CU cooling unit
    (4)
    Upright console
    (5)
    (6)
    (7)
    (8)
    0.8 - 2.0 mm
    Welding process:
    Push with wirespool
    (1)
    (2)
    CU cooling unit
    (3)
    Upright console
    (4)
    (5)
    (6)
    (7)
    (8)
    max. 2 m between wirefeeder and wirespool
    0.8 - 2.0 mm
    Welding process:
    (1)
    (2)
    SpeedNet cable COM
    (3)
    Unreeling wirefeeder WV 25i Reel 4R
    (4)
    (5)
    CU cooling unit
    (6)
    Upright console
    (7)
    (8)
    (9)
    (10)
    • max. 20 m between wirefeeder and unreeling wirefeeder
      (max. 30 m with PowerLiner)
    • max. 8 m between wire drum and unreeling wirefeeder
    0.8 - 2.0 mm
    Welding process:
    (1)
    Unreeling wirefeeder WF 25i REEL R /4R/G/W
    (2)
    Main welding machine
    (3)
    CU cooling unit CU1400i PRO MC
    (4)
    Upright console
    (5)
    Power sharing cable
    (6)
    (7)
    (8)
    2nd welding machine
    (9)
    Upright console
    (10)
    OPT/i HP 95i EXT
    connecting power cable
    (11)
    Wirefeeder WF 30i R HD/4R/W/FSC
    (12)
    MHP 700i R/W/FSC torch hosepack
    (13)
    MTB 700/i W robot welding torch
    max. 8 m between wire barrel and wirefeeder
    0.8-2.0 mm
    Welding process:
    Standard, Pulse, LSC, PMC
    (1)
    (2)
    (3)
    CU cooling unit CU2000i PRO MC
    part 1
    (4)
    Upright console
    (5)
    Power sharing cable
    (6)
    (7)
    (8)
    2nd welding machine
    (9)
    part 2
    (10)
    Upright console
    (11)
    OPT/i HP 95i EXT
    (12)
    (13)
    (14)
    0.8-2.0 mm
    Welding process:
    Push with wire drum
    (1)
    (2)
    (3)
    CU cooling unit
    (4)
    Upright console
    (5)
    (6)
    (7)
    (8)
    0.8 - 2.0 mm
    Welding process:
    2. System configurations - PAP
    Push with wire drum
    (1)
    (2)
    (3)
    CU cooling unit
    (4)
    Upright console
    (5)
    (6)
    (7)
    (8)
    0.8 - 2.0 mm
    Welding process:
    Push with wirespool
    (1)
    (2)
    CU cooling unit
    (3)
    Upright console
    (4)
    (5)
    (6)
    (7)
    (8)
    0.8 - 2.0 mm
    Welding process:
    (1)
    (2)
    SpeedNet cable COM
    (3)
    (4)
    (5)
    CU cooling unit
    (6)
    Upright console
    (7)
    (8)
    (9)
    (10)
    0.8 - 2.0 mm
    Welding process:
    System components
    WF wire-feed unit
    Device concept
    The robot wirefeeders of the WF 15i/25i/30i R and R PAP series have been specifically designed for robot mounting.
    The wirefeeders are available in several different versions:
    WF 15i/25i/30i R:
    For applications in which the hosepack is externally mounted on the robot.
    WF 15i/25i/30i R PAP:
    For applications in which the hosepack is mounted in the robot arm.
    WF 25i R / L and 30i R / L:
    For applications in which the torch hosepack is connected to the wirefeeder from the left.
    For high-performance applications with high welding currents up to 1,000 A
    (power sharing mode)
    1. System components
    WF wire-feed unit
    Device concept
    WF 15i/25i/30i R:
    2. WF wire-feed unit
    Device concept
    WF 15i/25i/30i R:
    Proper use
    The device is designed exclusively for wirefeeding in automated MIG/MAG welding applications in conjunction with Fronius system components. Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
    Utilisation in accordance with the intended purpose also comprises:
    • carefully reading these operating instructions
    • following all the instructions and safety rules in these operating instructions
    • performing all stipulated inspection and maintenance work
    Safety
    WARNING!
    The device is fitted with safety symbols and a rating plate. The safety symbols and rating plate must not be removed or painted over. The safety symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage.
    • All the Operating Instructions for the system components, especially the safety rules
    Welding is dangerous. The following basic requirements must be met to ensure the equipment is used properly:
    • Anyone performing automated welding must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved must be kept at a safe distance from the wirefeeder and the welding process
    Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules.
    • Cogs
    • Feed rollers
    • Wirespools and wire electrodes
    During operation
    • Cogs
    • Feed rollers
    During operation
    Safety
    WARNING!
    Fully read and understand these operating instructions before commissioning the unreeling wirefeeder.
    Fully read and understand the operating instructions of the welding machine being used.
    Fully read and understand the operating instructions for all other system components.
    Read and adhere to all safety rules and safety instructions in the above-mentioned documents.
    CAUTION!
    Danger from rotating drive parts if covers are open.
    This can result in injuries.
    When performing maintenance or set-up work, make sure that the drive components of the unreeling wirefeeder cannot be started by the welding machine, by a wirefeeder or by any other system extensions.
    2. WF 25i REEL R /4R, WF 30i REEL R /2R
    Safety
    WARNING!
    CAUTION!
    Device concept
    The unreeling wirefeeder is an extra drive unit for ensuring constant and precision wirefeeding over large wirefeeding distances between the welding wire drum and the robot wirefeeder.
    While in operation, the unreeling wirefeeder is synchronised with the welding machine.
    It is supplied with power and controlled by the welding machine in the welding system.
    The unreeling wirefeeder is available in two versions:
    • WF 25i REEL R /4R
      Integrated version with 4-roller drive
    • WF 30i REEL R /2R
      Integrated version with 2-roller drive - not permitted in conjunction with a basket-type spool
    Application area
    All indoor and automated MIG/MAG applications.
    Proper use
    Example: WF 30i REEL R /2R/G/W
    • Cogs
    • Feed rollers
    • Wirespools and welding wires
    Covers and side panels may only be opened / removed while maintenance or repair work is being carried out.
    Wear eye protection
    General
    The interconnecting hosepack connects the welding machine to the wirefeeder. With the TPS/i welding system the interconnecting hosepack is available in two versions - one split and one standard variant.
    • 3 / 5 / 10 / 15 m (extension - split variant)
    • CON hosepacks 4 / 5.5 / 8 / 10 / 15 / 16 m (continuous variant)
    2. Interconnecting hosepack
    General
    Torch hosepack
    General remarks
    The Robacta MHP hosepack is designed for gas-cooled and water-cooled robot applications. It connects the TPS/i robot wirefeeders to the Robacta MTB robot welding torches.
    2. Torch hosepack
    General remarks
    2. Torch hosepack
    Scope of supply
    Robacta MHP PAP hosepack
    Robacta MHP conventional hosepack
    (1)
    Not supplied:
    • Inner liners
    • Inlet nozzles
    2. Torch hosepack
    "Wire threading" and "wire retract" buttons are located on the Robacta MHP hosepack
    CrashBox /i
    General
    CrashBox /i PAP fitted to robot arm
    CrashBox /i fitted to robot arm with clamp system
    The CrashBox /i is a protection device for the torch body, the drive unit, the wire brake and the torch body coupling. In the event of a collision, the CrashBox sends a signal to the robot control, which stops the robot immediately. The torch holder on the CrashBox protects the welding torch and the system components fitted from damage should a collision occur.
    The clamp system is used for holding gas-cooled and water-cooled robot welding torches. With torch body curvatures of 22°, 36° and 45°, the clamp system positions the welding torch in such a way that the TCP is in the 6th axis or at a 45° angle to the 6th axis, depending on the index disc.
    NOTE!
    Always adjust the holding force of the CrashBox to the system weight.
    Select the CrashBox size according to the following criteria:
    L:
    for push systems with a torch body length of up to 249 mm.
    XL:
    for push systems with a torch body length of up to 249 mm and with extension;
    for push systems with a torch body length of 250-391 mm;
    for push/pull systems with a torch body length of up to 249 mm.
    XXL:
    for push/pull systems with a torch body length of 250-391 mm;
    for push/pull systems with a torch body length of up to 249 mm and with extension.
    If there is a TX/i torch body change system or WireBrake in the welding system, select the next larger CrashBox.
    When cleaning the welding torch with the TC 2000, also select the next larger CrashBox.
    A robot-specific, isolated robot flange is required for fitting the CrashBox /i.
    2. CrashBox /i
    General
    NOTE!
    L:
    XL:
    XXL:
    2. CrashBox /i
    NOTE!
    To avoid damage to the welding torch or the torch hosepack, or to prevent false triggering of the CrashBox, consider the following points:
    Avoid strong accelerations and maximum speeds during robot movements.
    Ensure the free movement of the torch hosepack during all robot movements;
    The torch hosepack must not tighten in any position and thus exert a strain on the CrashBox.
    The torch hosepack must not whip around or get stuck when moving.
    If possible, clarify all movement situations with Fronius system components in a simulation as early as the concept phase.
    2. CrashBox /i
    Depending on the particular robot:
    • 1 x robot flange with screws
    Robot flange as per price list
    2. CrashBox /i
    Device concept
    The CrashBox /i is designed specifically for fitting to the robot arm and for holding gas-cooled and water-cooled robot hosepacks and robot drive units. For PAP systems, the torch hosepack runs through the CrashBox and then through the robot arm. In conventional robot systems the torch hosepack runs along the robot arm and is attached to the clamp. In the event of a crash, the magnetic coupling smoothly deflects the forces along a large deflection path.
    2. CrashBox /i
    Application areas
    The clamp system can be used for the following push robot hosepacks:
    • MHP i G / MHP i W TPS /i hosepacks
    • MTG/MTW TransSteel hosepacks
    2. CrashBox /i
    NOTE!
    Only send complete CrashBoxes for repair!
    Incomplete CrashBoxes (e.g. without a magnetic ring) cannot be checked in the course of a repair.
    2. CrashBox /i
    Scope of supply
    CrashBox /i PAP scope of supply
    CrashBox /i Standard scope of supply
    (1)
    CrashBox /i holder
    (4)
    Bellows
    (2)
    1-ear clamp *
    (5)
    Cheese-head screws, M4 x 16 mm
    (3)
    Locking ring, 2-part *
    (6)
    Magnetic ring
    * Delivered fitted to bellows (4)
    Do not fit the CrashBox /i holder (1) and magnetic ring (4) together before fitting to the robot. The components become even more difficult to release due to the strong magnetism.
    2. CrashBox /i
    (1)
    M8 hexagon nut
    (2)
    M8 washer
    (3)
    Clamp
    (4)
    Index disc
    (5)
    Allen screw, M8 x 40 mm
    Optional (material for extension):
    (6)
    M8 x 40 mm screw
    (7)
    M8 washer
    (8)
    Extension
    (9)
    Index disc
    (10)
    M8 hexagon nut
    Robot welding torch
    Safety
    CAUTION!
    Risk of burns from hot torch body, hot torch body coupling and other hot welding torch components.
    Before starting work on the torch body, the torch body coupling and all other welding torch components:
    Allow the torch body, torch body coupling and all other welding torch components to cool down to room temperature (+25 °C, +77 °F)
    Wear electrically insulated and heat protective gloves
    Use a suitable tool
    2. Robot welding torch
    Safety
    CAUTION!
    Use a suitable tool
    General
    * Optional (no torch body)
    The robot welding torch transmits the arc power to the workpiece. The gas-cooled or water-cooled TPS /i welding torch is designed for use with the CrashBox /i.
    The torch body has an integrated lead for gas nozzle touch sensing.
    Standard:
    With wearing parts, without contact tip
    OVT:
    Without wearing parts
    TXi:
    Automatic torch body changeover
    TXM:
    Manual torch body changeover
    OPT CAM:
    Prepared for the camera mount option
    OPT/i camera mount
    General
    Application example of a mounted OPT/i camera mount (44,0350,0080)
    The OPT/i camera mount can be used to mount seam tracking systems, cameras or similar on the robot welding torch.
    The camera mount is fitted instead of the torch body union nut; the TCP remains the same.
    The seam tracking system or camera is protected by the CrashBox.
    The position of the mounted seam tracking system or camera is reproducible, as it is positioned with a dowel pin.
    Seam tracking system or camera can be mounted in six different places.
    The scope of supply of the OPT/i camera mount includes a mounting key (size 60 mm).
    2. OPT/i camera mount
    General
    Drilling template
    The following holes are provided as standard on the six surfaces of the OPT/i camera mount:
    • 4 M4 threaded holes with a depth of 9 mm
    • 2 holes Ø 4 mm G7, depth = 6 mm
    Safety
    WARNING!
    Fully read and understand this document.
    1. Controls, connections and mechanical components
    Safety
    WARNING!
    2. WFi R control elements and mechanical components
    Safety
    WARNING!
    No.Function
    (1)
    Cover
    (2)
    Clamping lever
    for setting the contact pressure of the feed rollers
    (3)
    4-roller drive
    (4)
    Protective cover for the 4-roller drive
    (5)
    Operating status LED +
    Gas-test / wire threading / wire retract buttons
    (option)
    The function of the wire retract, wire threading and gas-test buttons is described from page (→) onwards.
    No.Function
    (1)
    Welding torch connection
    (2)
    Coolant connection
    For connecting the coolant connection socket from the interconnecting hosepack
    (3)
    Coolant connection socket
    For connecting to the torch hosepack
    (4)
    SpeedNet connection
    For connecting the SpeedNet cable from the interconnecting hosepack
    (5)
    Shielding gas connection
    (6)
    (+) current socket
    For connecting the power cable from the interconnecting hosepack
    (7)
    Wire infeed
    2. WF 15i / 25i / 30i R
    No.Function
    (1)
    (2)
    Coolant connection
    (3)
    (4)
    SpeedNet connection
    (5)
    (6)
    (+) current socket
    (7)
    Wire infeed
    No.Function
    (1)
    Wire infeed
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    (6)
    Coolant connection
    (7)
    No.Function
    (1)
    (2)
    SpeedNet connection
    (3)
    (4)
    (+) current socket
    (5)
    Wire infeed
    No.Function
    (1)
    Wire infeed
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    No.Function
    (1)
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    Coolant connection
    (6)
    (7)
    Wire infeed
    2. WF 15i / 25i / 30i R PAP
    No.Function
    (1)
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    Coolant connection
    (6)
    (7)
    Wire infeed
    No.Function
    (1)
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    Wire infeed
    No.Function
    (1)
    SpeedNet connection
    (2)
    (3)
    (+) current socket
    (4)
    (5)
    Wire infeed
    No.Function
    (1)
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    Coolant connection
    (6)
    (7)
    (+) current socket
    (8)
    Wire infeed
    2. WF 30i R HD/4R/W/FSC
    No.Function
    (1)
    (2)
    (+) current socket
    (3)
    (4)
    SpeedNet connection
    (5)
    Coolant connection
    (6)
    (7)
    (+) current socket
    (8)
    Wire infeed
    Safety
    WARNING!
    Safety
    WARNING!
    Front of WF 25i REEL R /4R/G/W
    Front of WF 30i REEL R /2R/G/W
    Left side
    Rear
    Top/underside
    No.Function
    (1)
    Cover
    (2)
    (3)
    4-roller drive
    (4)
    Protective cover for the 2-roller drive
    (5)
    2-roller drive
    (6)
    Opening for optional sash lock
    (7)
    Operating status LED + Gas-test / wire threading / wire retract buttons
    (8)
    SpeedNet connection
    (9)
    Blanking cover for optional component
    (10)
    (11)
    (12)
    M20 thread
    for connecting QuickConnect option
    (13)
    Wire infeed/outfeed tube
    Wire infeed (underside)
    Wire outfeed (upper side)
    Shows steady green when the device is ready for use
    Gas-test button
    After pressing the gas-test button, gas flows out for 30 seconds. Press the button again to stop the gas flow prematurely.
    Wire retract button
    The wire electrode can be retracted using one of two methods:
    Method 1
    Retracting the wire electrode at the preset wire retract speed:
    • Press and hold the wire retract button
    • The wire electrode will be retracted 1 mm (0.039 in.) after the wire retract button is pressed
    • After a short pause, the wirefeeder continues to retract the wire electrode. If the wire retract button remains pressed, the speed will increase every second at a rate of 10 m/min (393.70 ipm) until the preset wire retract speed is reached
    Method 2
    Retracting the wire electrode in 1 mm increments (0.039 in. increments)
    • Do not hold the wire retract button for more than 1 second (tap it)
    NOTE!
    Do not allow long lengths of wire electrode to be retracted, as the wire electrode is not wound onto the wirespool when retracted.
    NOTE!
    If there was a ground earth connection with the contact tip before the wire retract button was pressed, the wire electrode will be retracted when the button is pressed until it is short-circuit-free - it retracts by no more 10 mm (0.39 in.) with each press of the button.
    If the wire electrode still needs to be retracted, press the wire retract button again.
    Wire threading button
    Wire threading can be performed using one of two methods:
    Method 1
    Threading the wire electrode using the preset feeder inching speed:
    • Press and hold the wire threading button
    • The wire electrode will be threaded 1 mm (0.039 in.) after the wire threading button is pressed
    • After a short pause, the wirefeeder continues to thread the wire electrode. If the wire threading button remains pressed, the speed will increase every second at a rate of 10 m/min (393.70 ipm) until the preset feeder inching speed is reached
    • If the wire electrode comes into contact with a ground earth connection, the wirefeeding will be stopped and the wire electrode will be retracted again by 1 mm (0.039 in.)
    Method 2
    Threading the wire electrode in 1 mm increments (0.039 in. increments)
    • Do not press the wire threading button for more than 1 second (tap it)
    NOTE!
    If there is a ground earth connection with the contact tip before the wire threading button is pressed, the wire electrode will be retracted when the button is pressed until it is short-circuit-free – it retracts by no more than 10 mm (0.39 in.) with each press of the button.
    If there is still a ground earth connection with the contact tip after 10 mm (0.39 in.) of wire retraction, pressing the wire threading button again will cause the wire electrode to be retracted again by a maximum of 10 mm (0.39 in.). The process will be repeated until there is no longer a ground earth connection with the contact tip.
    2. Function of the gas-test, wire retract and wire threading buttons
    Gas-test button
    Wire retract button
    Method 1
    Method 2
    NOTE!
    NOTE!
    Method 1
    Method 2
    NOTE!
    Safety
    WARNING!
    The activities described below may only be carried out by trained and qualified personnel.
    The operating instructions for system components, particularly the chapter entitled "Safety rules", must be observed.
    WARNING!
    Danger from electric shocks.
    These can result in serious injury and death.
    Before starting the work described below, turn the mains switch on the welding machine to the "O" position.
    Disconnect the welding machine from the grid.
    Ensure that the welding machine remains disconnected from the grid until all work has been completed.
    WARNING!
    Danger from falling objects.
    Check all the screw connections described below after fitting to ensure they are tight.
    Check after abnormal operating situations (e.g. after a crash) to ensure screw connections are tight.
    Check screw connections regularly to ensure they are tight.
    WARNING!
    Danger from electric current due to defective system components and incorrect operation.
    All cables, leads and hosepacks must always be securely connected, undamaged and correctly insulated.
    Only use adequately dimensioned cables, leads and hosepacks.
    CAUTION!
    Danger from escaping coolant.
    Switch off the cooling unit during maintenance activities or when replacing components and wear parts.
    The cooling system must be depressurised while the maintenance work is being carried out.
    NOTE!
    Performing maintenance on the active robot welding system is only permitted in Working mode 17 .
    Move the robot to a suitable position to allow water-cooled components and wear parts to be changed.
    1. Installation - conventional robot
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    NOTE!
    2. Fitting the welding system to a conventional robot
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    NOTE!
    Individual components must be fitted to the robot in the following order:
    1. Wire-feed unit - the wirefeeder holder and the side arm holder must be fitted first
    2. CrashBox /i
    3. Clamp system
    4. Torch hosepack
    5. Robot welding torch
    6. Interconnecting hosepack
    NOTE!
    Depending on the robot, please also note the instructions and information on installing the wirefeeder in the User Information.
    2. Fitting the wire-feed unit
    NOTE!
    Example: WF 25i R
    NOTE!
    The coolant line must be routed under the wirefeeder.
    To do so, the wirefeeder must be removed from the holder and re-fitted after the line has been routed.
    Observe the torques when fitting the robot flange:
    Tightening torque for screws of strength class 8.8
    M4
    2,3 - 3,3 Nm
    1,70 - 2,43 lb·ft
    M5
    4,4 - 6,5 Nm
    3,25 - 4,79 lb·ft
    M6
    7,70 - 11,3 Nm
    5,68 - 8,33 lb·ft
    M8
    18,5 - 27,3 Nm
    13,65 - 20,14 lb·ft
    M10
    36,0 - 54,0 Nm
    26,55 - 39,83 lb·ft
    M12
    63,0 - 93,0 Nm
    46,47 - 68,60 lb·ft
    5
    6
    7
    8
    2. Fitting the CrashBox /i to the robot
    M4
    2,3 - 3,3 Nm
    1,70 - 2,43 lb·ft
    M5
    4,4 - 6,5 Nm
    3,25 - 4,79 lb·ft
    M6
    7,70 - 11,3 Nm
    5,68 - 8,33 lb·ft
    M8
    18,5 - 27,3 Nm
    13,65 - 20,14 lb·ft
    M10
    36,0 - 54,0 Nm
    26,55 - 39,83 lb·ft
    M12
    63,0 - 93,0 Nm
    46,47 - 68,60 lb·ft
    5
    6
    7
    8
    M4
    2,3 - 3,3 Nm
    1,70 - 2,43 lb·ft
    M5
    4,4 - 6,5 Nm
    3,25 - 4,79 lb·ft
    M6
    7,70 - 11,3 Nm
    5,68 - 8,33 lb·ft
    M8
    18,5 - 27,3 Nm
    13,65 - 20,14 lb·ft
    M10
    36,0 - 54,0 Nm
    26,55 - 39,83 lb·ft
    M12
    63,0 - 93,0 Nm
    46,47 - 68,60 lb·ft
    The positioning of the welding torch in relation to the workpiece is divided into fixed angles by the index disc. Special angles are available on request.
    2. Fitting the clamp system
    Mount the index disc 45° from the scope of supply of the clamp extension
    NOTE!
    CB (for CrashBox) is stamped on one side of the clamp extension.
    This side must be fitted to the index disc that has already been fitted.
    Fit the clamp extension to the index disc that has already been fitted in such a way that the stamped 'CB' on the clamp extension faces the index disc!
    2. Fitting the MHP G / W hosepack
    Safety
    CAUTION!
    Use a suitable tool
    2. Fitting the TPS/i torch neck
    Safety
    CAUTION!
    Use a suitable tool
    Special tool required
    NOTE!
    Performing maintenance on the active robot welding system is only permitted in the "Stop" coolant pump service position - Working mode 17.
    IMPORTANT! Whenever the welding torch is fitted or removed, ensure that the coupling point is clean and dry. Remove any coolant that has escaped from the coupling point.
    If you would like to fit the “OPT / i MHP WireBrake” option, read the “Fitting the OPT / i MHP WireBrake and torch body” chapter.
    NOTE!
    Ensure that the hosepack is straight when fitting the inner liner, otherwise the liner might not be inserted correctly.
    5
    2. Fitting the interconnecting hosepack
    WARNING!
    Check that they are tight at least every three months.
    Only on water-cooled hosepack
    CON
    = Interconnecting hosepack
    EXT
    = Extension hosepack
    Connect all connections so they are hand-tight.
    Check for tightness.
    Tightening the power connection hand-tight corresponds to 7-8 Nm.
    If the components are not bundled in the protective bag, all interfaces must be fixed so they are immovable.
    NOTE!
    Reduced service life at a bending radius of r < 200 mm.
    Note the bending radius.
    Do not use a bending radius smaller than r = 200 mm.
    NOTE!
    Note the current load.
    Dimensioning of the correct hosepack according to the following table:
    Welding current
    40% d.c. / 40 °C
    Cross-section up to 10 m
    Cross-section up to 50 m
    150 A
    16 mm²
    25 mm²
    200 A
    25 mm²
    35 mm²
    250 A
    35 mm²
    50 mm²
    300 A
    50 mm²
    70 mm²
    400 A
    70 mm²
    95 mm²
    500 A
    95 mm²
    120 mm²
    600 A
    120 mm²
    120 mm²
    IMPORTANT! Whenever the torch hosepack is fitted or removed, ensure that the coupling point is clean and dry. Remove any coolant that has escaped from the coupling point.
    * Push in hosepack as far as it will go
    5
    6
    IMPORTANT! Always route coolant hoses below the hosepack and then guide them to the connection socket:
    WFi R / SB 500i
    SB 60i
    7
    (1)
    Coolant return (red)
    (2)
    Coolant flow (blue)
    IMPORTANT! Connect the coolant hoses to the cooling unit correctly!
    Disconnecting the coolant hoses
    2. Connecting the MHP W hosepack
    5
    6
    WFi R / SB 500i
    SB 60i
    7
    (1)
    (2)
    Coolant flow (blue)
    Safety
    WARNING!
    Danger from electric current.
    CAUTION!
    Risk of injury and damage from loose connections.
    All cables, leads and hosepacks must be properly connected, undamaged, correctly insulated and adequately dimensioned.
    2. Connecting wire-feed unit to system components
    Safety
    WARNING!
    CAUTION!
    General
    NOTE!
    Also follow the instructions and information in the documents 42,0410,1946 and 42,0410,2010 when connecting the wirefeeder to the system components.
    IMPORTANT! The coolant line must be routed under the wirefeeder.
    WF 15i / 25i / 30i R:
    WF 15i / 30i R
    WF 25i R
    WF 25i / 30i R/L:
    WF 30i R / L
    WF 25i R / L
    IMPORTANT! After disconnecting the coolant connection from the hosepack, close the coolant connections on the hosepack using the hosepack's seal cap.
    Safety
    CAUTION!
    Use a suitable tool
    2. Fitting the OPT / i MHP WireBrake and torch body
    Safety
    CAUTION!
    Use a suitable tool
    NOTE!
    OPT/i MHP WireBrake only secures a wire electrode if a torch body is correctly fitted to the OPT/i MHP WireBrake.
    System requirements:
    The wirefeeder of the WF 15i / 25i / 30i R (PAP) series
    OPT/i WF 16 bar gas purging option (4,100,867,CK).
    The OPT/i MHP WireBrake option operates at 6 or 16 bar.
    NOTE!
    To ensure that the WireBrake option functions correctly, wait for 4 seconds after deactivating the "WireBrake on" signal before activating another signal.
    The compressed air supply of the OPT/i MHP WireBrake is provided through the hosepack.
    Observe the following specifications:
    • Compressed air supply of at least 5 bar (72 psi)
    • Compressed air supply for aluminium max. 7 bar (102 psi), for all other materials max. 16 bar (232 psi)
    • Compressed air is free of oil
    • Compressed air is free of dust – no dirt particles larger than 5 mm
    • Compressed air is free of water
    Recommendation: use a filter unit with a pressure regulator.
    NOTE!
    When securing the wire electrode in the OPT/i MHP WireBrake, small clamping marks can occur on the wire electrode.
    To remedy the clamping marks, cut off the wire electrode after securing.
    Calculation of the cut-off point = torch body length + 50 mm (1.97 in.)
    Technical data
    TCP offset
    47 mm
    1.85 in.
    Wire diameter
    0.8 - 1.6 mm
    0.03 - 0.06 in.
    Weight
    450 g
    0.99 Ib.
    NOTE!
    The front O-ring must only be removed at a system pressure of > 5.5 bar / 79.74 psi (step 3).
    At a system pressure of < 5.5 bar / 79.74 psi, the second O-ring remains on the WireBrake option.
    For steel inner liners:
    5
    6
    For plastic inner liners:
    5
    6
    Safety
    CAUTION!
    Use a suitable tool
    2. Removing the OPT / i MHP WireBrake and torch body
    Safety
    CAUTION!
    Use a suitable tool
    WARNING!
    Ensure that the unreeling wirefeeder is fitted in the correct direction. The threading direction of the wire electrode is marked with an arrow.
    The unreeling wirefeeder is designed exclusively for vertical installation on the following mounts:
    • WF Mounting WALL 4,100,846
    • WF Mounting Drum 4,100,845
    Operating a 2-roller WF30i REEL R /2R unreeling wirefeeder with a basket-type spool is not permitted.
    1In accordance with the installation instructions, mount the unreeling wirefeeder onto the wall bracket or the wire drum mount
    2Use the QuickConnect option to connect the wirefeeding hose to the unreeling wirefeeder
    3Use Fronius SpeedNet to connect the unreeling wirefeeder to the welding machine in the welding system
    2. Fitting the unreeling wirefeeder
    WARNING!
    Fitting the OPT/i camera mount
    Load-bearing capacity of the OPT/i camera mount
    CAUTION!
    Danger due to mechanical overload of the system components
    This can result in injury and damage to property.
    Load the OPT/i camera mount with a maximum of 1.5 kg.
    Always observe the relationship between weight and mounting distance shown below.
    2. Fitting the OPT/i camera mount
    CAUTION!
    Safety
    CAUTION!
    Use a suitable tool
    Installation - PAP
    Axis rotation and service life of the torch hosepack
    General
    In addition to environmental and operating conditions, the service life of the PAP welding torch hosepack is heavily influenced by the axis rotation in the fifth and sixth robot axis.
    For details, see the following sections:
    • Recommended axis rotation
    • Maximum axis rotation
    • Hosepack service life depending on the axis rotation in the fifth and sixth robot axis
    1. Installation - PAP
    General
    2. Axis rotation and service life of the torch hosepack
    General
    NOTE!
    The PAP welding torch hosepack reaches its optimal service life when operated within the recommended axis rotations.
    Any axis rotation beyond these limits accelerates wear and thus reduces the service life of the PAP torch hosepack.
    The expected hosepack service life is shown in the diagram "Hosepack service life depending on the axis rotation in the fifth and sixth robot axis" starting on page (→).
    (4)
    Fourth robot axis: +/- 175°
    (5)
    Fifth robot axis: +/- 90°
    (6)
    Sixth robot axis: +/- 200°
    (4)+(6)
    Fourth + sixth robot axis: +/- 360° in total.
    NOTE!
    Operating at the maximum values of the axis rotations reduces the service life of the PAP welding torch hosepack.
    Operating outside the limits invalidates any warranty claim.
       Maximum axis rotations reduce the hosepack service life.
    (4)
    (5)
    Fifth robot axis: +/- 120°
    (6)
    Sixth robot axis: +/- 360°
    (4)+(6)
    Fourth + sixth robot axis: max. +/- 535° in total.
    RLT = relative service life [%], ± AR6 = axis rotation in the sixth robot axis [°]
       = recommended axis rotation in the sixth robot axis
    Example:
    With an axis rotation in the sixth robot axis of 280° and at a tilt angle of 90° in the fifth robot axis, the relative service life of the hosepack is 76-77%.
    IMPORTANT! The values specified in the diagram are standard values that may vary depending on the environmental and operating conditions.
    The values were determined at an axis rotation of 0° in the fourth robot axis.
    Fitting the welding system to a PAP robot
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    NOTE!
    2. Fitting the welding system to a PAP robot
    Safety
    WARNING!
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    NOTE!
    Fitting the TPS/i welding system to a PAP robot
    2. CrashBox /i
    3. Torch hosepack
    4. Robot welding torch
    5. Interconnecting hosepack
    Fitting the WF 15i/25i/30i R PAP
    Installing the CrashBox /i PAP on the robot
    Max. tightening torque for screws of strength class 8.8
    M4
    3.3 Nm / 2.43 lb-ft
    M5
    5.0 Nm / 3.69 lb-ft
    M6
    6.0 Nm / 4.43 lb-ft
    M8
    27.3 Nm / 20.14 lb-ft
    M10
    54 Nm / 39.83 lb-ft
    M12
    93 Nm / 68.60 lb-ft
    5
    6
    7
    8
    2. Installing the CrashBox /i PAP on the robot
    link_horizontalLink copied
    M4
    3.3 Nm / 2.43 lb-ft
    M5
    5.0 Nm / 3.69 lb-ft
    M6
    6.0 Nm / 4.43 lb-ft
    M8
    M10
    54 Nm / 39.83 lb-ft
    M12
    93 Nm / 68.60 lb-ft
    5
    6
    7
    8
    Installing the CrashBox/i Dummy on the robot
    M4
    3.3 Nm / 2.43 lb-ft
    M5
    5.0 Nm / 3.69 lb-ft
    M6
    6.0 Nm / 4.43 lb-ft
    M8
    M10
    54 Nm / 39.83 lb-ft
    M12
    93 Nm / 68.60 lb-ft
    Fitting the MHPi/MHP S G/W PAP hosepack
    Fitting the Robacta MHP G/W PAP hosepack
    5
    6
    7
    8
    9
    10
    2. Fitting the MHPi/MHP S G/W PAP hosepack
    5
    6
    7
    8
    9
    10
    Fitting the inner liner inside the torch hosepack
    NOTE!
    5
    Fitting the MHPi/MHP S G/W PAP SM hosepack
    Fitting the Robacta MHP G/W PAP SM hosepack
    5
    6
    7
    8
    9
    2. Fitting the MHPi/MHP S G/W PAP SM hosepack
    5
    6
    7
    8
    9
    NOTE!
    5
    Fitting the PAP interconnecting hosepack to the robot
    NOTE!
    The mounting of the holder for the interconnecting hosepack depends on the robot manufacturer and robot type.
    Mount the holder for the interconnecting hosepack according to the Installation Instructions for the respective robot.
    3Lay the interconnecting hosepack in the clamps
    4Close the clamps
    NOTE!
    4Close the clamps
    Connecting the extension hosepack
    WARNING!
    CON
    EXT
    NOTE!
    NOTE!
    Welding current
    40% d.c. / 40 °C
    150 A
    16 mm²
    25 mm²
    200 A
    25 mm²
    35 mm²
    250 A
    35 mm²
    50 mm²
    300 A
    50 mm²
    70 mm²
    400 A
    70 mm²
    95 mm²
    500 A
    95 mm²
    120 mm²
    600 A
    120 mm²
    120 mm²
    Connecting the interconnecting hosepack
    Safety
    WARNING!
    CAUTION!
    Safety
    WARNING!
    CAUTION!
    General
    NOTE!
    Connecting the WF 15i/25i/30i R PAP to the system components
    Start-up
    Inserting/replacing feed rollers
    General
    The feed rollers are not installed in the device when it is first delivered.
    In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
    NOTE!
    Risk from inadequate feed rollers.
    This can result in poor weld properties.
    Only use feed rollers that match the wire electrode.
    An overview of the feed rollers available and their possible areas of use can be found in the Spare Parts Lists.
    1. Start-up
    General
    NOTE!
    1. Start-up
    2. Inserting/replacing feed rollers
    General
    NOTE!
    1. Start-up
    WF 25i Reel 4R: inserting/replacing feed rollers for the 4-roller drive
    CAUTION!
    Risk of injury if the feed roller holders fly upwards.
    When unlocking the clamping lever, keep fingers away from the area to the left and right of the lever.
    CAUTION!
    Risk of crushing due to exposed feed rollers.
    Always fit the protective cover of the 4-roller drive after changing feed rollers.
    1. Start-up
    WF 30i Reel 2R: Inserting/replacing feed rollers for the 2-roller drive
    5
    6
    7
    CAUTION!
    Danger from exposed feed rollers.
    Risk of crushing.
    Always fit the protective cover of the 2-roller drive after changing feed rollers.
    1. Start-up
    CAUTION!
    Danger from feed roller holders flying upwards.
    CAUTION!
    Always fit the protective cover of the 4-roller drive after inserting or replacing a feed roller.
    1. Start-up
    Feeding in the wire electrode
    Insulated routing of wire electrode to wirefeeder
    CAUTION!
    Danger due to uninsulated wire electrode.
    This can result in personal injury, damage to property and impaired welding results.
    In the case of automated applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wire spool to the wirefeeder (e.g. by using a wirefeeding hose).
    An earth contact or short-circuit can be caused by:
    • a non-insulated, exposed length of wire electrode coming into contact with a conductive object during the welding process
    • missing insulation between the wire electrode and the earthed enclosure of a robot cell
    • chafed wirefeeding hoses, exposing the wire electrode
    To avoid earth contact or short-circuit:
    • Use wirefeeding hoses for insulated routing of wire electrode to the wirefeeder
    • To prevent chafing, do not route the wirefeeding hoses over sharp edges
    • Use hose holders or hose protectors where necessary
    • Coupling pieces and hoods for welding wire drums are recommended to ensure safe transport of the wire electrode
    1. Start-up
    2. Feeding in the wire electrode
    CAUTION!
    1. Start-up
    CAUTION!
    Risk of injury and damage from the welding current and accidental ignition of an arc.
    Before starting work, disconnect the ground earth connection between the welding system and the workpiece.
    CAUTION!
    Risk of injury and damage from wire electrode emerging.
    While working:
    Hold the welding torch with the end directed away from the face and body
    Wear suitable protective goggles
    Do not point the welding torch at people
    Make sure that the wire electrode does not touch any conductive or earthed parts (e.g. housing)
    Ensure that all covers are closed, all side panels are in place and that all safety devices are intact and in their proper place (e.g. protection devices).
    CAUTION!
    Risk of damage to the welding torch from sharp end of wire electrode.
    Deburr the end of the wire electrode well before threading in.
    CAUTION!
    Risk of injury due to springiness of spooled wire electrode.
    When inserting the wire electrode into the 4-roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Risk of injury from moving or rotating parts in the welding system.
    Ensure that all covers are closed and that all parts are fitted properly and remain in place during operation.
    1. Start-up
    Setting the contact pressure
    NOTE!
    Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
    The standard contact pressure values can be found on the sticker on the 4-roller drive
    1. Start-up
    Start-up
    Requirements
    When commissioning the welding system, the following requirements must be met:
    • All components are installed and connected as described in the "Installation" chapter
    • All appropriate welding media is connected
    • Feed rollers are inserted in wirefeeders or drive unit
    • Wire electrode is threaded in
    • Feed roller contact pressure is set
    • Motor adjustment completed
    • All covers closed, all side panels in place, all safety devices intact and in their proper place (e.g. protective covers)
    1. Start-up
    2. Start-up
    Requirements
    1. Start-up
    2. Start-up
    General
    WARNING!
    Risk of machines starting automatically.
    In addition to this document, observe all user documentation of the robot manufacturer.
    Ensure that all protective measures have been taken and will remain in place in the working area of the robot.
    The device is commissioned by means of an active welding start signal.
    Troubleshooting, maintenance and disposal
    Troubleshooting
    Safety
    WARNING!
    WARNING!
    Secure all the devices and components involved to prevent unintentional restarting.
    CAUTION!
    Danger due to hot system components and/or equipment.
    This can result in burns or scalding.
    Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
    Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
    CAUTION!
    1. Troubleshooting, maintenance and disposal
    Troubleshooting
    Safety
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    2. Troubleshooting
    Safety
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    2. Troubleshooting
    Fault diagnosis
    Make a note of the serial number and configuration of the device and contact our After-Sales Service team with a detailed description of the error, if
    • errors occur that are not listed below
    • the troubleshooting measures listed are unsuccessful
    Welding machine does not function
    Mains switch is on, but indicators are not lit up
    Cause:There is a break in the mains lead; the mains plug is not plugged in
    Remedy:Check the mains lead, ensure that the mains plug is plugged in
    Cause:Mains socket or mains plug faulty
    Remedy:Replace faulty parts
    Cause:Mains fuse protection
    Remedy:Change the mains fuse protection
    Cause:Short circuit on the 24 V supply of SpeedNet connection socket or external sensor
    Remedy:Unplug connected components
    No response after setting a welding start signal
    Welding machine mains switch is on and indicators are lit
    Cause:Welding torch or welding torch control line is faulty
    Remedy:Replace welding torch
    Cause:Interconnecting hosepack is faulty or not connected properly
    Remedy:Check the interconnecting hosepack
    No welding current
    Cause:Grounding (earthing) connection is incorrect
    Remedy:Check the grounding (earthing) connection for correct polarity
    Cause:There is a break in the power cable in the welding torch
    No protective gas shield
    All other functions are OK
    Cause:Gas cylinder is empty
    Remedy:Change the gas cylinder
    Cause:The gas pressure regulator is faulty
    Remedy:Replace the gas pressure regulator
    Cause:Gas hose is not fitted or is damaged
    Remedy:Fit or change the gas hose
    Cause:Welding torch is faulty
    Remedy:Change the welding torch
    Cause:Gas solenoid valve is faulty
    Remedy:Contact After-Sales Service
    Irregular wire feed speed
    Cause:Hole in the contact tip is too narrow
    Remedy:Use a suitable contact tip
    Cause:Faulty inner liner in welding torch
    Remedy:Check the inner liner for kinks, dirt, etc.
    Cause:The feed rollers are not suitable for the wire electrode being used
    Remedy:Use suitable feed rollers
    Cause:Feed rollers have the wrong contact pressure
    Remedy:Optimise the contact pressure
    Wirefeed problems
    when using long hosepacks
    Cause:Incorrect arrangement of hosepack
    Remedy:Arrange the hosepack in as straight a line as possible, avoid tight bends
    Welding torch becomes very hot
    Cause:Welding torch is inadequately dimensioned
    Remedy:Observe the duty cycle and loading limits
    Cause:Only on water-cooled systems: inadequate coolant flow
    Remedy:Check coolant level, coolant flow, for coolant contamination, etc. For further information refer to the cooling unit operating instructions
    Cause:The distance from the workpiece is too small
    Remedy:Increase stickout
    Poor weld properties
    Cause:Incorrect welding parameters
    Remedy:Check the settings
    Cause:Poor ground earth connection
    Remedy:Ensure good contact to workpiece
    Cause:Inadequate or no shielding gas
    Remedy:Check the pressure regulator, gas hose, gas solenoid valve, torch gas connection, etc.
    Cause:Welding torch is leaking
    Remedy:Change welding torch
    Cause:Wrong contact tip, or contact tip is worn out
    Remedy:Replace contact tip
    Cause:Wrong wire alloy or wrong wire diameter
    Remedy:Check the wire electrode that has been inserted
    Remedy:Check weldability of the base material
    Cause:The shielding gas is not suitable for this wire alloy
    Remedy:Use the correct shielding gas
    Cause:Contaminated gas nozzle
    Remedy:Clean the gas nozzle, remove any welding spatter
    Care, maintenance and disposal
    General
    Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the welding system remains in a usable condition for many years.
    2. Care, maintenance and disposal
    General
    Safety
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    Every start-up
    • Check all hosepacks and the ground earth connection for damage. Replace any damaged components.
    • Check feed rollers and inner liners for signs of damage. Replace any damaged components.
    • Check the wirefeeding hoses for damage. Replace any damaged components.
    • Check contact pressure of feed rollers and adjust if necessary.
    • Check that all screw connections between the robot, wirefeeder holder and wire-feed unit are secure.
    Special care of O-rings
    IMPORTANT! When replacing O-rings, grease the new O-ring before fitting it.
    When repeatedly connecting and disconnecting the coolant hoses on the torch hosepack, grease the O-rings regularly.
    Unless a special grease is specified for the O-rings, use the O-ring grease from Fronius with item number 40,0009,0044.
    Whenever the welding torch or torch hosepack is changed
    Whenever the welding torch or torch hosepack is changed, ensure that the coupling point is clean and dry. Remove any coolant that has escaped from the coupling point.
    Ensure that the cooling unit is switched off.
    Every 6 months
    CAUTION!
    Danger from compressed air at close range.
    Electronic components may be damaged.
    Do not bring the air nozzle too close to electronic components.
    • Open covers, remove device side panels and clean inside of device with dry reduced compressed air. After cleaning, restore device to its original state.
    Prerequisites:
    • Min. welding machine firmware V3.2.30
    • Min. firmware RI FB PRO/I interface RI FB PRO/I 1.9.0
    Description:
    In Working mode 17, switch the coolant pump to "stop". The cooling circuit is interrupted, while all other functions of the welding machine remain active. The "Cooling circuit mode" process parameter on the welding machine does not need to be changed.
    Once Working mode 17 has ended, the robot controller continues from the last active program step
    Working mode 17 only works in automatic mode via the robot controller.
    NOTE!
    NOTE!
    Detailed information can be found in the operating instructions 42,0426,0227 ... Description of TPS/i interface signals
    Preparing the WF 15i/25i/30i R PAP for replacement of the welding torch inner liner
    WARNING!
    Toppling or falling devices can cause life-threatening injuries.
    Robot movements may not take place until:
    The wirefeeder has been retracted and locked
    All cables, leads and hosepacks are securely connected to the wirefeeder
    After replacing the inner liner:
    5
    6
    CAUTION!
    Recognising faulty wearing parts
    1. Insulating parts
      • Burned-off outside edges, notches
    2. Nozzle fittings
      • Heavily covered in welding spatter
    3. Spatter guard
    4. Contact tips
      • Worn-out (oval) wire entry and wire exit holes
      • Penetration on the tip of the contact tip
    5. Gas nozzles
      • Notches
    MTG d, MTW d - Fitting wearing parts to the torch body
    Screw on and tighten the gas nozzle as far as it will go
    MTG d, MTW d, MTB - Fitting wearing parts to the torch body
    Tightening torques:
    • Contact tube M5 3 Nm / 2.21 ft lb
    • Nozzle holder M5
    • Clamping nut M12 8 Nm / 5.9 ft lb
    Fitting wearing parts to the torch body - MTW 700 i
    Removing the CrashBox PAP from the robot (without mounting key)
    5
    6
    7
    8
    9
    10
    11
    Removing the CrashBox PAP from the robot (with mounting key)
    5
    6
    7
    8
    9
    10
    11
    Changing the torch hosepack, changing the interconnecting hosepack
    If a robot wirefeeder or a media splitter is mounted in the third robot axis, take the following into account when changing the torch hosepack or interconnecting hosepack:
    CAUTION!
    Risk of damage to the robot wirefeeder or media splitter from escaping coolant.
    After disconnecting the coolant hoses on the torch hosepack, immediately seal off the coolant connections with the covers provided.
    Position the robot in such a way that escaping coolant cannot flow back into the robot wirefeeder or the media splitter.
    NOTE!
    Performing maintenance on the active robot welding system is only permitted in the"Stop" coolant pump service position - Working mode 17.
    Cleaning the welding torch
    Disposal
    Technical data
    WF wire-feed unit
    WF 15i R,
    WF 15i R
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1 A
    Welding current at 10 min/40 °C (104 °F)
    40 % ED* 650 A
    60 % ED* 600 A
    100 % ED* 500 A
    Maximum shielding gas pressure
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    Maximum coolant pressure
    5 bar / 72.53 psi
    Wire speed
    0.5 - 15 m/min / 19.68 - 590.55 ipm
    Wire drive
    4-roller drive
    Recommended wire diameter
    0.8 - 2.4 mm / 0.03 - 0.09 in.
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    Dimensions l x w x h
    274 x 276 x 229 mm
    10.79 x 10.87 x 9.02 in.
    Weight
    5.8 kg / 12.79 Ib.
    * ED = Duty cycle
    1. Technical data
    WF wire-feed unit
    WF 15i R,
    WF 15i R
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1 A
    40 % ED* 650 A
    60 % ED* 600 A
    100 % ED* 500 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    Wire drive
    4-roller drive
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 276 x 229 mm
    Weight
    5.8 kg / 12.79 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 15i R,
    WF 15i R
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1 A
    40 % ED* 650 A
    60 % ED* 600 A
    100 % ED* 500 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    Wire drive
    4-roller drive
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 276 x 229 mm
    Weight
    5.8 kg / 12.79 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 15i R,
    WF 15i R PAP
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1 A
    40 % ED* 650 A
    60 % ED* 600 A
    100 % ED* 500 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    Wire drive
    4-roller drive
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 252 x 229 mm
    10.79 x 9.92 x 9.02 in.
    Weight
    5.8 kg / 12.79 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 25i R,
    WF 25i R,
    WF 25i R / L
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.2 A
    40 % ED* 500 A
    60 % ED* 450 A
    100 % ED* 360 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    1 - 25 m/min / 39.37 - 984.25 ipm
    Wire drive
    4-roller drive
    0.8 - 1.6 mm / 0.03 - 0.06 in.
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 276 x 229 mm
    Weight
    4.8 kg / 10.58 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 25i R,
    WF 25i R PAP,
    WF 25i R / L
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.2 A
    40 % ED* 500 A
    60 % ED* 450 A
    100 % ED* 360 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    Wire drive
    4-roller drive
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 252 x 229 mm
    Weight
    4.8 kg / 10.58 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 30i R,
    WF 30i R,
    WF 30i R / L
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.4 A
    40 % ED* 650 A
    60 % ED* 600 A
    100 % ED* 500 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    1 - 30 m/min / 39.37 - 1181.10 ipm
    Wire drive
    4-roller drive
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 276 x 229 mm
    Weight
    5.4 kg / 11.9 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 30i R,
    WF 30i R PAP,
    WF 30i R / L
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.4 A
    40 % ED* 650 A
    60 % ED* 600 A
    100 % ED* 500 A
    7 bar / 101.53 psi
    Coolant
    Original Fronius
    5 bar / 72.53 psi
    Wire speed
    Wire drive
    4-roller drive
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    274 x 252 x 229 mm
    Weight
    5.4 kg / 11.9 Ib.
    * ED = Duty cycle
    1. Technical data
    WF 30i R HD
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.4 A
    Welding current
    at 10 min / 40 °C (104 °F)
    40% ED* 1,000 A
    60% ED* 900 A
    100% ED* 720 A
    7 bar
    101.53 psi
    Coolant
    Original Fronius
    5 bar
    72.53 psi
    Wire speed
    1-30 m/min
    39.37-1,181.10 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8-1.6 mm
    0.03-0.06 in.
    Protection class
    IP 43
    Mark of conformity
    CE, CSA
    290 x 280 x 235 mm
    11.42 x 11.03 x 9.25 in.
    Weight
    6.3 kg
    13.9 Ib.
    * ED = Duty cycle
    1. Technical data
    Unreeling wirefeeder WF REEL
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.2 A
    Wire speed
    1 - 25 m/min
    39.37 - 984.25 ipm.
    Wire drive
    4-roller drive
    Wire diameter
    0.8 - 2.4 mm
    0.03 - 0.09 in.
    Degree of protection
    IP 21
    Mark of conformity
    CE, CSA
    250 x 210 x 190 mm
    9.8 x 8.3 x 7.5 in.
    Weight
    4.8 kg
    10.58 Ib.
    1. Technical data
    2. Unreeling wirefeeder WF REEL
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 1.2 A
    Wire speed
    1 - 25 m/min
    39.37 - 984.25 ipm.
    Wire drive
    4-roller drive
    Wire diameter
    0.8 - 2.4 mm
    0.03 - 0.09 in.
    IP 21
    Mark of conformity
    CE, CSA
    250 x 210 x 190 mm
    9.8 x 8.3 x 7.5 in.
    Weight
    4.8 kg
    10.58 Ib.
    1. Technical data
    Supply voltage
    24 V DC / 60 V DC
    Nominal current
    0.5 A / 0.9 A
    Wire speed
    1 - 30 m/min
    39.37 - 1181.10 ipm.
    Wire drive
    2-roller drive
    Wire diameter
    0.8 - 1.6 mm
    0.03 - 0.06 in.
    IP 21
    Mark of conformity
    CE, CSA
    250 x 210 x 190 mm
    9.8 x 8.3 x 7.5 in.
    Weight
    4.6 kg
    10.14 Ib.
    1. Technical data
    CrashBox /i
    Technical data, triggering torques and weight/distance diagram
    Item numbers
    CrashBox /i
    44,0350,3589
    CrashBox /i XL
    44,0350,3760
    CrashBox /i XXL
    44,0350,3380
    CrashBox /i PAP
    44,0350,3663
    CrashBox /i PAP XL
    44,0350,3759
    CrashBox /i PAP XXL
    44,0350,0202
    Reset accuracy (1)
    ± 0.05 mm a)
    Maximum deflection in x/y direction
    CrashBox /i
    ~ 45°
    CrashBox /i XL
    ~ 45°
    CrashBox /i XXL
    ~ 45°
    CrashBox /i PAP
    ~ 30°
    CrashBox /i PAP XL
    ~ 30°
    CrashBox /i PAP XXL
    ~ 30°
    Triggering torques in x/y direction
    (+/- 10%)
    CrashBox /i
    21 Nm / 15.49 lb-ft
    CrashBox /i XL
    42 Nm / 30.98 lb-ft
    CrashBox /i XXL
    63.1 Nm / 46.54 lb-ft
    CrashBox /i PAP
    21 Nm / 15.49 lb-ft
    CrashBox /i PAP XL
    31.5 Nm / 23.23 lb-ft
    CrashBox /i PAP XXL
    41 Nm / 30.24 lb-ft
    Weight
    CrashBox /i
    1200 g
    CrashBox /i XL
    1200 g
    CrashBox /i XXL
    1250 g
    CrashBox /i PAP
    700 g
    CrashBox /i PAP XL
    700 g
    CrashBox /i PAP XXL
    750 g
    Dimensions
    CrashBox /i
    Ø90 mm x 60 mm b)
    CrashBox /i XL
    Ø90 mm x 60 mm b)
    CrashBox /i XXL
    Ø90 mm x 60 mm
    CrashBox /i PAP
    Ø90 mm x 40 mm b)
    CrashBox /i PAP XL
    Ø90 mm x 40 mm b)
    CrashBox /i PAP XXL
    Ø90 mm x 40 mm
    a) At a distance of 300 mm from the robot flange
    b) With bellows: Ø110 mm
    Triggering torques and weight/distance diagram
    Max. possible deflection
    z direction [mm]
    ~ 30
    ~ 30
    ~ 30
    ~ 30
    ~ 30
    The specified values only apply in a static state!
    x/y - direction [°]
    ~ 45
    ~ 45
    ~ 45
    ~ 30
    ~ 30
    ~ 30
    Deflection at a distance of 300 mm
    max [°]
    1.5275
    1.5275
    1.5275
    1.5275
    1.5275
    max [mm]
    8
    8
    8
    8
    8
    min [°]
    0.684
    0.684
    0.664
    0.6302
    0.6302
    min [mm]
    3.5
    3.5
    3.5
    3.3
    3.3
    Weight (distance [mm]) [kg]
    400
    5.25
    10.5
    15.78
    5.25
    7.88
    300
    7.00
    14.0
    21.03
    7.00
    10.5
    200
    10.5
    21.0
    31.55
    10.5
    15.75
    100
    21.0
    42.0
    63.1
    21.0
    31.5
    50
    42.0
    84.0
    126.2
    42.0
    63.0
    Triggering
    torque
    (+/- 10%)
    21 Nm
    42 Nm
    63.1 Nm
    21 Nm
    31.5 Nm
    41.0 Nm
    CrashBox /i
    CrashBox /i XL
    CrashBox /i XXL
    CrashBox /i PAP
    CrashBox /i PAP XL
    CrashBox /i PAP XXL
    1. Technical data
    2. CrashBox /i
    Item numbers
    CrashBox /i
    44,0350,3589
    CrashBox /i XL
    44,0350,3760
    CrashBox /i XXL
    44,0350,3380
    CrashBox /i PAP
    44,0350,3663
    CrashBox /i PAP XL
    44,0350,3759
    CrashBox /i PAP XXL
    44,0350,0202
    Reset accuracy (1)
    ± 0.05 mm a)
    CrashBox /i
    ~ 45°
    CrashBox /i XL
    ~ 45°
    CrashBox /i XXL
    ~ 45°
    CrashBox /i PAP
    ~ 30°
    CrashBox /i PAP XL
    ~ 30°
    CrashBox /i PAP XXL
    ~ 30°
    (+/- 10%)
    CrashBox /i
    21 Nm / 15.49 lb-ft
    CrashBox /i XL
    42 Nm / 30.98 lb-ft
    CrashBox /i XXL
    CrashBox /i PAP
    21 Nm / 15.49 lb-ft
    CrashBox /i PAP XL
    CrashBox /i PAP XXL
    41 Nm / 30.24 lb-ft
    Weight
    CrashBox /i
    1200 g
    CrashBox /i XL
    1200 g
    CrashBox /i XXL
    1250 g
    CrashBox /i PAP
    700 g
    CrashBox /i PAP XL
    700 g
    CrashBox /i PAP XXL
    750 g
    Dimensions
    CrashBox /i
    Ø90 mm x 60 mm b)
    CrashBox /i XL
    Ø90 mm x 60 mm b)
    CrashBox /i XXL
    Ø90 mm x 60 mm
    CrashBox /i PAP
    Ø90 mm x 40 mm b)
    CrashBox /i PAP XL
    Ø90 mm x 40 mm b)
    CrashBox /i PAP XXL
    Ø90 mm x 40 mm
    z direction [mm]
    ~ 30
    ~ 30
    ~ 30
    ~ 30
    ~ 30
    x/y - direction [°]
    ~ 45
    ~ 45
    ~ 45
    ~ 30
    ~ 30
    ~ 30
    max [°]
    1.5275
    1.5275
    1.5275
    1.5275
    1.5275
    max [mm]
    8
    8
    8
    8
    8
    min [°]
    0.684
    0.684
    0.664
    0.6302
    0.6302
    min [mm]
    3.5
    3.5
    3.5
    3.3
    3.3
    400
    5.25
    10.5
    15.78
    5.25
    7.88
    300
    7.00
    14.0
    21.03
    7.00
    10.5
    200
    10.5
    21.0
    31.55
    10.5
    15.75
    100
    21.0
    42.0
    63.1
    21.0
    31.5
    50
    42.0
    84.0
    126.2
    42.0
    63.0
    Triggering
    torque
    (+/- 10%)
    21 Nm
    42 Nm
    63.1 Nm
    21 Nm
    31.5 Nm
    41.0 Nm
    CrashBox /i
    CrashBox /i XL
    CrashBox /i XXL
    CrashBox /i PAP
    CrashBox /i PAP XL
    CrashBox /i PAP XXL
    1. Technical data
    Torch hosepack
    MHP 400i G / R
    Welding current at 10 min/40°C
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 400 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    60 % ED* / 400 A
    100 % ED* / 320 A
    Wire diameter
    0.8 - 1.6 mm
    0.031 - 0.063 inch
    Length
    0,95 / 1,10 / 1,25 / 1,45 / 1,75 /
    1,95 / 2,25 / 3,25 / 4,25 m
    3.12 / 3.6 / 4.1 / 4.76 / 5.74 /
    6.4 / 7.38 / 10.66 / 13.94 ft.
    ED = Duty cycle
    1. Technical data
    2. Torch hosepack
    MHP 400i G / R
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 400 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    60 % ED* / 400 A
    100 % ED* / 320 A
    Wire diameter
    0.8 - 1.6 mm
    0.031 - 0.063 inch
    Length
    ED = Duty cycle
    1. Technical data
    2. Torch hosepack
    MHP 400i G / R / PAP
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 400 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    60 % ED* / 400 A
    100 % ED* / 320 A
    Wire diameter
    0.8 - 1.6 mm
    0.031 - 0.063 inch
    Length
    0,93 / 0,94 / 0,96 / 1,0 / 1,04 / 1,06 / 1,09 / 1,12 / 1,13 / 1,15 / 1,18 / 1,19 / 1,2 / 1,22 / 1,25 / 1,31 / 1,35 / 1,37 / 1,4 / 1,43 / 1,45 / 1,51 / 1,59 / 2,13 / 2,28 m
    3.05 / 3.08 / 3.15 / 3.28 / 3.4 / 3.48 / 3.58 / 3.67 / 3.71 / 3.77 / 3.87 / 3.9 / 3.94 / 4.0 / 4.10 / 4.3 / 4.43 / 4.5 / 4.59 / 4.69 / 4.76 / 4.95 / 5.22 / 6.99 / 7.48 ft.
    ED = Duty cycle
    1. Technical data
    2. Torch hosepack
    MHP 500 S R / G / PAP
    Welding current at 10 min/40° C
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    40 % ED* / 500 A
    60 % ED* / 450 A
    100 % ED* / 360 A
    Wire diameter
    0.8 - 1.6 mm
    0.032 - 0.063 in.
    Length
    0.94 / 0.96 / 1.04 / 1.06 / 1.075 /
    1.12 / 1.13 / 1.15 / 1.18 / 1.19 / 1.2 /
    1.22 / 1.31 / 1.35 / 1.37 / 1.4 / 1.43 /
    1.51 / 1.59 / 2.13 m
    3.08 / 3.15 / 3.4 / 3.48 / 3.53 / 3.67 /
    4.3 / 4.43 / 4.5 / 4.59 / 4.69 / 4.95 /
    5.22 / 6.99 ft.
    * ED = Duty cycle
    1. Technical data
    2. Torch hosepack
    MHP 700i W / R (0.95 - 2.25 m / 3.12 - 7.38 ft.)
    M21(EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 700 A
    100 % ED* / 700 A
    Wire diameter
    0.8 - 1.6 mm
    0.031 - 0.063 inch
    Length
    0.95 / 1.10 / 1.25 / 1.45 / 1.75 / 1.95 / 2.25 m
    3.12 / 3.61 / 4.1 / 4.76 / 5.74 / 6.4 / 7.38 ft.
    Lowest cooling capacity Pmin in accordance with standard IEC 60974-2, depending on the length of the hosepack
    0,95 m / 3.12 ft
    1,10 m / 3.61 ft
    1,25 m / 4.1 ft
    1,45 m / 4.76 ft
    1,55 m / 5.08 ft
    1,65 m / 5.41 ft
    1,75 m / 5.74 ft
    1,95 m / 6.4 ft
    2,25 m / 7.38 ft
    1200 W
    1300 W
    1300 W
    1400 W
    1450 W
    1550 W
    1600 W
    1800 W
    2000 W
    Minimum coolant flow Qmin
    1 l/min
    0.26 gal (US) / min
    Minimum coolant pressure pmin
    3 bar
    43.5 psi
    Maximum coolant pressure pmax
    5 bar
    72.5 psi
    ED = Duty cycle
    1. Technical data
    2. Torch hosepack
    MHP 700i W / R (3.25 - 4.25 m / 10.66 - 13.12 ft.)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    60 % ED* / 700 A
    100 % ED* / 580 A
    60 % ED* / 700 A
    100 % ED* / 580 A
    Wire diameter
    0.8 - 1.6 mm
    0.031 - 0.063 inch
    Length
    3.25 / 4.25 m
    10.66 / 13.12 ft.
    Lowest cooling capacity in accordance with standard IEC 60974-2, depending on the length of the hosepack
    3.25 m / 10.66 ft
    4.25 m / 13.12 ft
    1400 W
    1600 W
    1 l/min
    0.26 gal (US) / min
    3 bar
    43.5 psi
    5 bar
    72.5 psi
    ED = Duty cycle
    1. Technical data
    2. Torch hosepack
    MHP 700i W / R / PAP
    M21(EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 700 A
    100 % ED* / 700 A
    Wire diameter
    0.8 - 1.6 mm
    0.031 - 0.063 inch
    Length
    0.93 / 0.96 / 1.04 / 1.06 / 1.09 / 1.12 / 1.13 / 1.15 / 1.18 / 1.19 / 1.2 / 1.22 / 1.31 / 1.35 / 1.37 / 1.4 / 1.43 / 1.51 / 2.28 m
    3.05 / 3.15 / 3.41 / 3.48 / 3.58 / 3.67 / 3.71 / 3.77 / 3.87 / 3.9 / 3.94 / 4 / 4.3 / 4.43 / 4.5 / 4.59 / 4.69 / 4.95 / 7.48 ft.
    0.93 / 0.94 / 0.96 m
    3.05 / 3.08 / 3.15 ft
    1.04 / 1.06 / 1.09 m
    3.41 / 3.48 / 3.58 ft
    1.12 / 1.13 / 1.15 / 1.18 / 1.19 / 1.2 / 1.22 m
    3.67 / 3.71 / 3.77 / 3.87 / 3.9 / 3.94 / 4 ft
    1.31 m
    4.3 ft
    1.35 / 1.37 / 1.4 / 1.43 / 1.45 / 1.51 / 1.59 m
    4.43 / 4.5 / 4.59 / 4.69 / 4.76 / 4.95 / 5.22 ft
    2013 / 2.28 m
    6.99 / 7.48 ft
    1200 W
    1250 W
    1300 W
    1350 W
    1400 W
    2000 W
    1 l/min
    0.26 gal (US) / min
    3 bar
    43.5 psi
    5 bar
    72.5 psi
    ED = Duty cycle
    1. Technical data
    Robot welding torch
    Gas-cooled robot welding torches
    MTB 250i G/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 250 A
    60 % ED* / 200 A
    100 % ED* / 170 A
    60 % ED* / 250 A
    100 % ED* / 200 A
    Wire diameter
    0.8 - 1.2 mm
    0.030 - 0.045 inch
    MTB 320i G/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 320 A
    60 % ED* / 260 A
    100 % ED* / 210 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    MTB 330i G/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 330 A
    60 % ED* / 270 A
    100 % ED* / 220 A
    60 % ED* / 330 A
    100 % ED* / 270 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    MTB 350i G/R (TX, TXM)
    Welding current at 10 min/40° C)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 350 A
    60 % ED* / 300 A
    100 % ED* / 250 A
    60 % ED* / 350 A
    100 % ED* / 300 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    MTB 400i G/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 400 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    60 % ED* / 400 A
    100 % ED* / 320 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    ED = Duty cycle
    1. Technical data
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 250 A
    60 % ED* / 200 A
    100 % ED* / 170 A
    60 % ED* / 250 A
    100 % ED* / 200 A
    Wire diameter
    0.8 - 1.2 mm
    0.030 - 0.045 inch
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 320 A
    60 % ED* / 260 A
    100 % ED* / 210 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 330 A
    60 % ED* / 270 A
    100 % ED* / 220 A
    60 % ED* / 330 A
    100 % ED* / 270 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 350 A
    60 % ED* / 300 A
    100 % ED* / 250 A
    60 % ED* / 350 A
    100 % ED* / 300 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40 % ED* / 400 A
    60 % ED* / 320 A
    100 % ED* / 260 A
    60 % ED* / 400 A
    100 % ED* / 320 A
    Wire diameter
    0.8 - 1.6 mm
    0.030 - 0.062 inch
    ED = Duty cycle
    1. Technical data
    MTB 500S G R, MTB 500S G R TD
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    40% ED* / 500 A
    60% ED* / 450 A
    100% ED* / 360 A
    40% ED* / 500 A
    60% ED* / 450 A
    100% ED* / 360 A
    Wire diameter
    0.8 - 1.6 mm
    0.032 - 0.063 in.
    * ED = Duty cycle
    1. Technical data
    Water-cooled robot welding torches
    MTB 250i W/R
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 250 A
    100 % ED* / 250 A
    Wire diameter
    0.8 - 1.2 mm / 0.032 - 0.047 inch
    MTB 330i W/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 330 A
    100 % ED* / 330 A
    Wire diameter
    0.8 - 1.6 mm / 0.032 - 0.063 inch
    MTB 400i W/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 400 A
    100 % ED* / 400 A
    Wire diameter
    MTB 500i W/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 500 A
    100 % ED* / 500 A
    Wire diameter
    1.0 - 1.6 mm / 0.039 - 0.063 inch
    MTB 700i W/R (TX, TXM)
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 700 A
    100 % ED* / 700 A
    Wire diameter
    ED = Duty cycle
    1. Technical data
    MTB 350i W R
    M21 (EN ISO 14175)
    C1 (EN ISO 14175)
    100 % ED* / 350 A
    100 % ED* / 350 A
    Wire diameter
    ED = Duty cycle
    1. Technical data
    Interconnecting hosepacks
    HP 70i
    Welding current at 10 min / 40 °C
    (104 °F)
    40% ED* / 400 A
    60% ED* / 365 A
    100% ED* / 320 A
    ED = Duty cycle
    1. Technical data
    2. Interconnecting hosepacks
    HP 70i
    (104 °F)
    40% ED* / 400 A
    60% ED* / 365 A
    100% ED* / 320 A
    ED = Duty cycle
    1. Technical data
    HP 95i
    (104 °F)
    40% ED* / 500 A
    60% ED* / 450 A
    100% ED* / 360 A
    ED = Duty cycle
    1. Technical data
    HP 120i
    (104 °F)
    40% ED* / 600 A
    60% ED* / 530 A
    100% ED* / 430 A
    ED = Duty cycle
    1. Technical data
    HP 70i, HP PC Cable HD 70
    (104 °F)
    60% ED* / 600 A
    100% ED* / 500 A
    ED = Duty cycle
