en
      Operating InstructionsTPS 270i C
    • Safety rules
      • Explanation of safety instructions
      • General
      • Intended use
      • Environmental conditions
      • Obligations of the operator
      • Obligations of personnel
      • Mains connection
      • Residual current protective device
      • Protecting yourself and others
      • Data on noise emission values
      • Danger from toxic gases and vapours
      • Danger from flying sparks
      • Risks from mains current and welding current
      • Meandering welding currents
      • EMC Device Classifications
      • EMC measures
      • EMF measures
      • Specific hazards
      • Requirement for the shielding gas
      • Danger from shielding gas cylinders
      • Danger from escaping shielding gas
      • Safety measures at the installation location and during transport
      • Safety measures in normal operation
      • Commissioning, maintenance and repair
      • Safety inspection
      • Disposal
      • Safety symbols
      • Data security
      • Copyright
    • General information
      • General
        • Device concept
        • How it works
        • Application areas
        • Description of the warning notices on the device
        • Power source = welding machine
      • System components
        • General
        • Overview
        • Options
    • Welding packages, welding characteristics and welding processes
      • Welding packages
        • General
        • Welding packages
      • Welding characteristics
      • Welding methods and processes
        • MIG/MAG pulse synergic welding
        • MIG/MAG standard synergic welding
        • PMC process
        • LSC process
        • SynchroPulse welding
        • CMT process
        • CMT Cycle Step welding process
        • SlagHammer
        • Stitch welding
    • Controls, connections and mechanical components
      • Control panel
        • General
        • Danger from incorrect operation
        • Control panel
        • Displaying plain text for parameters
      • F1/F2 special function parameters, Favourites button
        • F1 and F2 special function parameters
        • The Favourites button
      • Connections, switches and mechanical components
    • Installation and commissioning
      • Minimum equipment needed for welding task
        • General
        • MIG/MAG gas-cooled welding
        • MIG/MAG water-cooled welding
        • Manual CMT welding
        • TIG DC welding
        • Manual metal arc welding
      • Before installation and commissioning
        • Intended use
        • Setup regulations
        • Mains connection
        • Generator-powered operation
        • Information on system components
      • Connecting the mains cable
        • Mains cable connection safety
        • General
        • Stipulated mains cables
        • Connecting the mains cable - general
      • Start-up
        • Danger from electric current
        • General
        • Connecting the gas cylinder
        • Establishing a ground earth connection
        • Connecting the welding torch
        • Inserting/replacing feed rollers
        • Inserting the wirespool
        • Inserting the basket-type spool
        • Feeding in the wire electrode
        • Setting the contact pressure
        • Adjusting the brake
        • Design of the brake
        • Performing R/L alignment
    • Welding
      • MIG/MAG modes
        • General
        • Symbols and their explanations
        • 2-step mode
        • 4-step mode
        • Special 4-step mode
        • Special 2-step mode
        • Spot welding
      • MIG/MAG and CMT welding
        • Danger from incorrect operation and electric current
        • MIG/MAG and CMT welding – overview
        • Switching on the welding machine
        • Setting the welding process and operating mode
        • Retrieving the currently set filler metal
        • Selecting the filler metal
        • Setting the welding parameters
        • Set the shielding gas flow rate
        • MIG/MAG or CMT welding
      • Spot and stitch welding
        • Spot welding
        • Stitch welding
      • MIG/MAG and CMT welding parameters
        • Welding parameters for MIG/MAG pulse synergic welding and PMC welding
        • Welding parameters for MIG/MAG standard synergic welding, LSC welding and CMT welding
        • Welding parameters for MIG/MAG standard manual welding
        • Explanation of footnotes
      • EasyJob mode
        • General
        • EasyJob mode
      • TIG welding
        • Preparations
        • TIG welding
        • Igniting the arc
        • Finishing welding
      • MMA welding
        • Preparations
        • Manual metal arc (MMA) welding
        • Welding parameters for manual metal arc welding
    • Setup settings
      • Setup menu - overview
        • Entering/exiting the Setup menu
      • Process parameters
        • Process parameters for start of welding/end of welding
        • Process parameters for Gas-Setup
        • Process parameters for process control
        • Penetration stabilizer
        • Arc length stabilizer
        • Combination of penetration stabilizer and arc length stabilizer
        • Process parameters for spot welding
        • Process parameters for stitch welding
        • Process parameters for monitoring and components
        • Process parameters for electrode setup
        • Process parameters for TIG setup
        • Process parameters for SynchroPulse
        • Process parameters for Process Mix
        • R/L alignment
      • Settings
        • General
        • Overview
        • View - Setting the units
        • View - Setting the standards
        • View - Setting hold mode
        • View - Setting the display brightness
        • View - Display replaced characteristics
        • View - Setting F1 and F2 special function parameters via the Setup menu
        • View - Setting the Favourites button via the Setup menu
        • View - Retrieving system data
        • System - Setting the interior lighting
        • System - Restoring factory settings
        • System - Resetting the password for the welding machine website
        • System - USB port settings
        • System - Retrieving device information
        • System - Setting the special display for JobMaster
        • System - Setting the mode for spot welding
      • Setting the language
      • Keylock
        • Keylock
    • SmartManager - the welding machine website
        • General
        • Opening the welding machine SmartManager
        • Changing password / logging off
        • Settings
        • Language selection
        • Fronius
      • Current system data
      • Job-Data
        • Job data
      • Backup & Restore
        • General remarks
        • Backup & Restore
        • Automatic backup
      • Overview
        • Overview
        • Expanding / reducing all groups
        • Export component overview as ...
      • Update
        • Update
        • Searching for an update file (performing the update)
        • Fronius WeldConnect
      • Function Packages
        • Function packages
        • Installing a function package
      • Synergic lines overview
        • Characteristics overview
        • Show filter
      • Screenshot
        • Screenshot
    • Troubleshooting and maintenance
      • The Error menu
        • The Error menu
      • Care, maintenance and disposal
        • General
        • Safety
        • At every start-up
        • If necessary
        • Every 2 months
        • Every 6 months
        • Updating firmware
        • Disposal
        • Troubleshooting
          • General
          • Danger from electrical current and inadequate ground conductor connection
          • Troubleshooting the welding machine
    • Technical data
      • Average consumption values
        • Average wire electrode consumption during MIG/MAG welding
        • Average shielding gas consumption during MIG/MAG welding
        • Average shielding gas consumption during TIG welding
      • Technical data
        • Explanation of the term "duty cycle"
        • Special voltages
        • TPS 270i C
        • TPS 270i C /nc
        • TPS 270i C /MV/nc
        • TPS 270i C /S/nc
        • Overview with critical raw materials, year of production of the device
        • China Energy Label
    • 023-23092026
    TPS 270i C
    download
    Controls
    Commissioning
    MIG/MAG welding
    Setup settings
    SmartManager
    Troubleshooting
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statementCookie Policy
    Safety rules
    link_horizontalLink copied
    DANGER!
    Indicates immediate danger.
    This can result in death or serious injuries.
    Avoid the described danger.
    WARNING!
    Indicates a dangerous situation.
    This can result in serious injuries and death.
    Avoid the dangerous situation.
    CAUTION!
    Indicates a damaging situation.
    This can result in injuries and damage to property.
    Avoid the damaging situation.
    NOTE!
    Indicates the possibility of damage to property and flawed results as well as necessary additional information, tips & tricks, recommendations, etc.
    1. Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    1. Safety rules
    General
    The device is manufactured using state-of-the-art technology and according to recognised safety standards. If used incorrectly or misused, however, it can cause:
    • injury or death to the operator or a third party,
    • damage to the device and other material assets belonging to the operating company,
    • inefficient operation of the device.
    All persons involved in commissioning, operating, maintaining and servicing the device must:
    • be suitably qualified,
    • have sufficient knowledge of welding and
    • read and follow these operating instructions carefully.
    All safety and danger notices on the device
    • must be in a legible state,
    • must not be damaged,
    • must not be removed,
    • must not be covered, pasted or painted over.
    For the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
    Before switching on the device, rectify any faults that could compromise safety.
    1. Safety rules
    Intended use
    The external high-frequency device is intended exclusively to support the ignition of a TIG arc in combination with Fronius system components.
    The environmental conditions, safety instructions, and regulations of the welding machine shall apply.
    Any other use or use above and beyond this shall be deemed to be not in accordance with the intended use.
    Intended use also means:
    • Reading these operating instructions in their entirety
    • Following all the instructions and safety rules in these operating instructions
    • Observing the welding machine operating instructions
    • Carrying out all the specified inspection and maintenance work
    The device is designed for commercial and industrial use.
    1. Safety rules
    Ambient temperature range:
    • during operation: -10 °C to + 40 °C (14 °F to 104 °F)
    • during transport and storage: -20 °C to +55 °C (-4 °F to 131 °F)
    Relative humidity:
    • up to 50% at 40 °C (104 °F)
    • up to 90% at 20 °C (68 °F)
    The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
    Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
    1. Safety rules
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    1. Safety rules
    Before using the device, all persons instructed to do so must:
    • observe the basic instructions regarding safety at work and accident prevention; and
    • read these operating instructions (especially the "Safety rules" section) and sign to confirm that they have understood them and will follow them.
    1. Safety rules
    Mains connection
    This may affect a number device types in terms of:
    • Connection restrictions
    • Criteria with regard to the maximum permissible mains impedance *)
    • Criteria with regard to the minimum short-circuit power requirement *)
    *) at the interface with the public grid
    see "Technical data"
    In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
    IMPORTANT! Ensure that the mains connection is earthed properly
    1. Safety rules
    Local regulations and national guidelines may require a residual current protective device when connecting equipment to the public grid.
    The type of residual current protective device recommended by the manufacturer for the equipment is indicated in the technical data.
    1. Safety rules
    Anyone working with the device exposes themselves to numerous risks, e.g.
    • flying sparks and hot pieces of metal
    • Arc radiation, which can damage eyes and skin
    • Hazardous electromagnetic fields, which can endanger the lives of those using cardiac pacemakers
    • Risk of electrocution from mains current and welding current
    • Greater noise pollution - the noise level may exceed 85 dB
    • Harmful welding fumes and gases
    Suitable protective clothing must be worn when working with the device. The protective clothing must have the following properties:
    • Flame-resistant
    • Insulating and dry
    • Covers the whole body, is undamaged and in good condition
    • Safety helmet
    • Trousers with no turn-ups
    Protective clothing refers to a variety of different items. Operators should:
    • Protect eyes and face from UV rays, heat and sparks using a protective visor and regulation filter
    • Wear regulation protective goggles with side protection behind the protective visor
    • Wear stout footwear that provides insulation even in wet conditions
    • Protect the hands with suitable gloves (electrically insulated and providing protection against heat)
    • Wear ear protection to reduce the harmful effects of noise and to prevent injury
    Keep all persons, especially children, out of the working area while any devices are in operation or welding is in progress. If, however, there are people in the vicinity:
    • Make them aware of all the dangers (risk of dazzling by the arc, injury from flying sparks, harmful welding fumes, noise, possible risks from mains current and welding current, etc.)
    • Provide suitable protective equipment
    • Alternatively, erect suitable safety screens/curtains.
    1. Safety rules
    When idling and in the cooling phase following operation, the machine produces a maximum sound power level of <80 dB(A) (ref. 1 pW) corresponding to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
    A workplace-related sound emission value depends on various parameters, such as:
    • The welding or work process (MIG/MAG, TIG, plasma, HAP),
    • The selected current type (AC, DC),
    • The power range,
    • The type of weld metal or workpiece,
    • The resonance properties of the workpiece,
    • The workplace environment.
    • and others.
    A workplace-related sound level measurement is recommended.
    1. Safety rules
    The fumes produced during welding contain harmful gases and vapours.
    Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
    Keep your face away from welding fumes and gases.
    Fumes and hazardous gases
    • must not be breathed in
    • must be extracted from the working area using appropriate methods.
    Ensure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
    If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
    The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:
    • Metals used for the workpiece
    • Electrodes
    • Coatings
    • Cleaners, degreasers, etc.
    • Welding process used
    The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
    Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
    Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
    Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    1. Safety rules
    Flying sparks may cause fires or explosions.
    Never weld close to flammable materials.
    Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
    Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
    Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
    Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
    1. Safety rules
    An electric shock is potentially life threatening and can be fatal.
    Do not touch live parts either inside or outside the device.
    During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
    Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
    Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
    Use the handle to ensure the power connections are tight before every use.
    In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
    Do not wrap cables or leads around the body or parts of the body.
    The electrode (rod electrode, tungsten electrode, welding wire, etc.) must
    • never be immersed in liquid for cooling
    • never be touched when the welding system is switched on.
    Double the open circuit voltage of a welding system can occur between the welding electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
    Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
    Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
    Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
    Otherwise, this is considered gross negligence.
    If necessary, provide adequate earthing for the workpiece.
    Switch off unused devices.
    Wear a safety harness if working at height.
    Before working on the device, switch it off and pull out the mains plug.
    Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
    After opening the device:
    • Discharge all live components
    • Ensure that all components in the device are de-energised.
    If work on live parts is required, have a second person switch off the main switch at the right moment.
    1. Safety rules
    If the following instructions are ignored, meandering welding currents can develop with the following consequences:
    • Fire hazard
    • Overheating of parts connected to the workpiece
    • Damage to ground conductors
    • Damage to device and other electrical equipment
    Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
    If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
    In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
    1. Safety rules
    Devices in emission class A:
    • Are only designed for use in industrial settings
    • Can cause line-bound and radiated interference in other areas
    Devices in emission class B:
    • Satisfy the emissions criteria for residential and industrial areas. This is also true for residential areas in which the energy is supplied from the public low-voltage mains.
    1. Safety rules
    EMC measures
    Check and evaluate the immunity to interference of nearby devices according to national and international regulations. Examples of equipment that may be susceptible to interference from the device include:
    • Safety devices
    • Network, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    Supporting measures for avoidance of EMC problems:
    1. Mains supply
      • If electromagnetic interference arises despite the correct mains connection, additional measures are necessary (e.g. use of a suitable line filter)
    2. Welding power-leads
      • must be kept as short as possible
      • must be laid close together (to avoid EMF problems)
      • must be kept well apart from other leads
    3. Equipotential bonding
    4. Earthing of the workpiece
      • If necessary, establish an earth connection using suitable capacitors.
    5. Shield, if necessary
      • Shield other devices nearby
      • Shield the entire welding installation
    1. Safety rules
    EMF measures
    Electromagnetic fields may pose as yet unknown risks to health:
    • Effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids
    • Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress
    • For safety reasons, maintain as large a distance as possible between the welding power-leads and the head/torso of the welder
    • Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body
    1. Safety rules
    Specific hazards
    Keep hands, hair, clothing and tools away from moving parts. For example:
    • Fans
    • Cogs
    • Rollers
    • Shafts
    • Wire spools and welding wires
    Do not reach into the rotating cogs of the wire drive or into rotating drive components.
    Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
    During operation
    • Ensure that all covers are closed and all side panels are fitted properly.
    • Keep all covers and side panels closed.
    The welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
    Therefore, always keep the welding torch facing away from the body (devices with wirefeeder) and wear suitable protective goggles.
    Never touch the workpiece during or after welding - risk of burns.
    Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
    Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
    Special provisions apply in areas at risk of fire or explosion
    - observe relevant national and international regulations.
    Welding machines for work in areas with increased electrical risk (e.g. near boilers) must carry the 'Safety' sign. However, the welding machine must not be located in such areas.
    Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
    Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
    Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
    • Hook chains or ropes onto all suspension points provided on the suitable load-carrying equipment.
    • Chains or ropes must be at the smallest angle possible to the vertical.
    • Remove gas cylinder and wirefeeder (MIG/MAG and TIG devices).
    If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
    Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
    If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
    All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
    The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
    Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
    1. Safety rules
    Especially with ring lines, contaminated shielding gas can cause damage to equipment and reduce welding quality.
    Meet the following requirements regarding shielding gas quality:
    • Solid particle size < 40 µm
    • Pressure condensation point < -20 °C
    • Max. oil content < 25 mg/m³
    Use filters if necessary.
    1. Safety rules
    Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
    Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
    Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
    Keep the shielding gas cylinders well away from any welding or other electrical circuits.
    Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
    Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
    Turn your face to one side when opening the valve of a shielding gas cylinder.
    Close the shielding gas cylinder valve if no welding is taking place.
    If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
    The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
    1. Safety rules
    Risk of suffocation from the uncontrolled escape of shielding gas
    Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
    • Ensure an adequate supply of fresh air with a ventilation rate of at least 20 m³/hour.
    • Observe safety and maintenance instructions on the shielding gas cylinder or the main gas supply.
    • Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
    • Check the shielding gas cylinder or main gas supply for uncontrolled gas leakage before every start-up.
    1. Safety rules
    A device toppling over could easily kill someone. Place the device on a solid, level surface such that it remains stable
    • The maximum permissible tilt angle is 10°.
    Special regulations apply in rooms at risk of fire or explosion
    • Observe relevant national and international regulations.
    Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
    When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
    Do not lift or transport operational devices. Switch off and disconnect devices from the grid before transport or lifting.
    After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
    1. Safety rules
    Only operate the device when all safety devices are fully functional. If the safety devices are not fully functional, there is a danger of:
    • serious or fatal injury to the operator or third parties;
    • damage to the device and other material assets belonging to the operating company; and
    Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
    Only Fronius original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
    Only use suitable original coolant from Fronius.
    Do not mix Fronius original coolant with other coolants.
    Only connect Fronius system components to the cooling circuit.
    Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant can ignite under certain. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
    Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from the service centre or downloaded from the manufacturer's website.
    Check the coolant level before starting to weld while the system is still cool.
    1. Safety rules
    • Use only original spare and wearing parts (also applies to standard parts).
    • Do not carry out any modifications, alterations, etc. to the device without the manufacturer's consent.
    • Components that are not in perfect condition must be replaced immediately.
    • When ordering, please give the exact designation and part number as shown in the spare parts list, as well as the serial number of your device.
    1. Safety rules
    Safety inspection
    The manufacturer recommends that a safety inspection of the device be performed at least once every 12 months.
    The manufacturer recommends that the welding machines be calibrated at the same 12-monthly interval.
    A safety inspection should be carried out by a qualified electrician:
    • after any modifications or installation of additional parts;
    • following repair, care and maintenance.
    For safety inspections, follow the appropriate national and international standards and directives.
    Further details on the safety inspection and calibration can be obtained from a Fronius branch or Fronius Service Partner.
    1. Safety rules
    Disposal
    According to the relevant EU Directive and national law, the following products must be disposed of separately and recycled:
    • Waste electrical and electronic equipment
    • Used batteries (portable batteries, industrial batteries)
    Used equipment and batteries must be returned to the distributor or an authorised local collection system. Do not dispose of batteries in domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
    Arrange for the safe collection and proper disposal of damaged, leaking or decommissioned batteries by a battery recycling company or the Fronius Service Partner.
    It should also be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances, such as heavy metals or electrolytes, which can contaminate the soil, water and air.
    This ensures environmental protection and the sustainable use of natural resources.
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    1. Safety rules
    Safety symbols
    Devices with the CE mark meet the requirements of all valid EU directives, such as:
    • Directive 2014/30/EU on Electromagnetic Compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • And so on
    The full text of the EU Declaration of Conformity can be found at
    https://www.fronius.com .
    Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
    1. Safety rules
    Data security
    • saving and retaining personal settings
    1. Safety rules
    Copyright
    Copyright of this document remains with Fronius International GmbH.
    Text, illustrations and other media correspond to the technical state of the art at the time of publication. Fronius reserves the right to make changes. If you have any suggestions for improvement, or can point out any inconsistencies in this document, we will be most grateful for your comments.
    General information
    General
    Device concept
    The TPS 270i C MIG/MAG welding machine is a completely digitised, microprocessor-controlled inverter welding machine with integrated 4-roller wire drive.
    The modular design and potential for system add-ons ensure a high degree of flexibility.
    Its compact design makes the TPS 270i C particularly suitable for mobile applications.
    The welding machine can be adapted to any specific situation.
    1. General information
    General
    Device concept
    2. General
    Device concept
    2. General
    How it works
    The central control and regulation unit of the welding machines is coupled with a digital signal processor. The central control and regulation unit and the signal processor control the entire welding process.
    During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Rule algorithms ensure that the desired target state is maintained.
    This results in:
    • A precise welding process
    • Exact reproducibility of all results
    • Excellent weld properties
    2. General
    Application areas
    The devices are used in trade and industry for manual applications with classical steel, galvanised sheets, chrome/nickel and aluminium.
    The integrated 4-roller wire drive, high performance and low weight of the welding machine makes it the ideal choice for portable applications on building sites or in repair workshops.
    2. General
    Warning notices and safety symbols are affixed to welding machines with the CSA test mark for use in North America (USA and Canada). These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and damage.
    on the inside of the device
    Welding is dangerous. The following basic requirements must be met to ensure the equipment is used properly:
    • Anyone performing automated welding must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved must be kept at a safe distance from the wirefeeder and the welding process
    • These operating instructions
    • All the operating instructions for the system components, especially the safety rules
    Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules.
    • Cogs
    • Feed rollers
    2. General
    For certain device versions, warning notices are affixed to the device.
    The arrangement of the symbols may vary.
    Warning! Attention!
    The symbols represent possible dangers.
    A
    Feed rollers can injure fingers.
    B
    The welding wire and drive parts are live during operation.
    Keep hands and metal objects away!
    1.
    1.1
    Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves.
    1.2
    Use a base that is insulated from the floor and work area to protect against electric shock.
    1.3
    Before working on the device, switch off the device and pull out the mains plug or disconnect it from the power supply.
    2.
    Inhalation of welding fumes can be harmful to health.
    2.1
    Keep your face away from any welding fumes.
    2.2
    Use forced-air ventilation or a local extraction system to remove welding fumes.
    2.3
    Remove welding fumes with a fan.
    Welding sparks can cause an explosion or fire.
    3.1
    Keep flammable materials away from the welding process. Never weld close to flammable materials.
    3.2
    Welding sparks can cause a fire. Have fire extinguishers to hand. If necessary, have a supervisor ready who can operate the fire extinguisher.
    3.3
    Do not weld on drums or closed containers.
    4.
    Arc rays can burn the eyes and injure the skin.
    4.1
    Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body.
    5.
    Before working on the system or welding:
    undertake training on the device and read the instructions!
    6.
    Do not remove or paint over the warning sticker.
    Manufacturer order number of the sticker
    2. General
    Depending on the device firmware, in some cases "power source" may still be shown on the display.
    System components
    General
    The welding machines can be operated with various system components and options. This makes it possible to optimise procedures and to simplify machine handling and operation, depending on the field of application for the welding machine.
    2. System components
    General
    Overview
    (1)
    Welding machine
    (2)
    Cooling unit
    (3)
    Gas cylinder holder
    (4)
    Trolley
    Also:
    • Welding torch
    • Grounding cable and electrode cable
    • Dust filter
    • Additional current sockets
    Options
    OPT/i TPS C polarity reverser
    OPT/i TPS C SpeedNet Connector
    Optional second SpeedNet connection socket
    Installed on the rear of the welding machine.
    OPT/i external sensor connector
    OPT/i TPS 270i C PushPull
    OPT/i TPS C TIG TMC
    OPT/i TPS 270i C Ethernet
    OPT/i Synergic Lines
    Option for enabling all special characteristics available on TPSi welding machines.
    Any special characteristics created in the future will also be automatically enabled.
    OPT/i GUN Trigger
    Option for special functions in conjunction with the torch trigger
    OPT/i OPC-UA
    Standardised data interface protocol
    OPT/i MQTT
    Welding packages
    General
    Various Welding Packages, welding characteristics and welding processes are available with welding machines that enable a wide range of materials to be effectively welded.
    1. Welding packages, welding characteristics and welding processes
    Welding packages
    General
    2. Welding packages
    General
    2. Welding packages
    Welding packages
    The following welding packages are available for TPSi welding machine:
    Standard Welding Package
    4,066,012
    (enables MIG/MAG standard synergic welding)
    Pulse Welding Package
    4,066,013
    (enables MIG/MAG pulse synergic welding)
    LSC Welding Package *
    4,066,014
    (enables the LSC process)
    PMC Welding Package **
    4,066,015
    (enables the PMC process)
    CMT Welding Package ***
    4,066,016
    (enables the CMT process)
    ConstantWire Welding Package
    4,066,019
    (enables constant current or constant voltage operation during brazing)
    Only in conjunction with the Standard Welding Package
    Only in conjunction with the Pulse Welding Package
    Only in conjunction with the Standard Welding Package and the Pulse Welding Package
    IMPORTANT! A TPSi welding machine without welding packages only offers the following welding processes:
    • MIG/MAG standard manual welding
    • TIG welding
    Depending on the welding process and shielding gas mix, various process-optimised welding characteristics are available when selecting the filler metal.
    Examples of welding characteristics:
    • MIG/MAG 3700 PMC Steel 1,0mm M21 - arc blow *
    • MIG/MAG 3450 PMC Steel 1,0mm M21 - dynamic *
    • MIG/MAG 3044 Pulse AlMg5 1.2 mm I1 - universal *
    • MIG/MAG 2684 Standard Steel 0.9 mm M22 - root *
    The additional designation (*) next to the welding process provides information about the special properties and use of the welding characteristic.
    The description of the characteristics is set out as follows:
    Designation
    Process
    Properties
    additive
    CMT
    Characteristics with reduced heat input and greater stability at a higher deposition rate for welding bead onto bead in adaptive structures
    arc blow
    PMC
    Characteristic to avoid arc breaks due to arc blow.
    arcing
    Standard
    Characteristics for a special type of hardfacing on a wet or dry surface
    (e.g. grinding rollers in the sugar and ethanol industries)
    base
    Standard
    braze
    CMT, LSC, PMC
    Characteristic for brazing processes (reliable wetting and good flow of braze material)
    braze+
    CMT
    Characteristic for brazing processes with the special Braze+ gas nozzle and high brazing speed (gas nozzle with narrow opening and high flow rate)
    CC/CV
    CC/CV
    Characteristic with constant current or constant voltage curve for operating the welding machine with a power supply unit. A wirefeeder is not required.
    cladding
    CMT, LSC, PMC
    Characteristics for overlay welding with low penetration, low dilution and wide weld seam flow for improved wetting
    constant current
    PMC
    Constant current characteristic
    For applications where no arc length control is required (stickout changes are not compensated)
    CW additive
    PMC, ConstantWire
    Characteristic with constant wire speed progression for the additive production process
    With this characteristic, no arc is ignited, the welding wire is only fed as filler metal.
    dynamic
    CMT, PMC, Puls, Standard
    Characteristic for deep penetration and reliable root fusion at high welding speeds
    dynamic +
    PMC
    Characteristic with short arc length for high welding speeds with arc length control independent of the material surface.
    edge
    CMT
    Characteristic for welding corner seams with targeted energy input and high welding speed
    flanged edge
    CMT
    Characteristic for welding flange welds with targeted energy input and high welding speed
    galvanized
    CMT, LSC, PMC, Puls, Standard
    Characteristics for galvanised sheet surfaces (low risk of zinc pores and reduced penetration)
    galvannealed
    PMC
    Characteristics for iron-zinc-coated material surfaces
    gap bridging
    CMT, PMC
    Characteristic for the best gap-bridging ability due to very low heat input
    hotspot
    CMT
    Characteristic with hot start sequence, specially for plug welds and MIG/MAG spot weld joints
    mix 2) / 3)
    PMC
    Also required:
    Pulse and PMC welding packages
    Characteristic for generating a rippled weld.
    The heat input into the component is specifically controlled by the cyclical process change between pulsed and dip transfer arc.
    marking
    Characteristics for marking conductive surfaces
    Characteristic for marking electrically conductive surfaces.
    Marking is performed by low power spark erosion and a reversing wire movement.
    mix 2) / 3)
    CMT
    Also required:
    CMT drive unit WF 60i Robacta Drive CMT
    Pulse, Standard and CMT welding packages
    Characteristic for producing a rippled weld.
    The heat input into the component is specifically controlled by the cyclical process change between pulsed arc or CMT.
    mix drive 2)
    PMC
    Also required:
    PushPull drive unit WF 25i Robacta Drive or WF 60i Robacta Drive CMT
    Characteristic for producing a rippled weld by means of a cyclical process interruption of the pulsed arc and an additional wire movement
    multi arc
    PMC
    Characteristic for components being welded by several arcs each influencing the other Ideal for increased welding circuit inductance or mutual welding circuit coupling.
    open root
    LSC, CMT
    Characteristic with powerful arc, especially suitable for root passes with air gap
    PCS 3)
    PMC
    The characteristic changes directly from a pulsed arc to a concentrated spray arc above a certain power. The advantages of pulsed and spray arcs combined in a single characteristic.
    PCS mix
    PMC
    The characteristic changes cyclically between a pulsed or spray arc to a dip transfer arc, depending on the power range. It is especially suitable for vertical-up welds due to the alternating hot and then cold, supporting process phase.
    pin
    CMT
    Characteristic for welding brads to an electrically conductive surface
    The retraction movement of the wire electrode and the set current curve progression define the appearance of the pin.
    pin picture
    CMT
    Characteristic for welding brads with a spherical end onto an electrically conductive surface, especially for creating pin pictures.
    pin print
    CMT
    Characteristic for writing texts, patterns or markings on electrically conductive component surfaces
    Writing takes place by positioning individual dots the size of a welding droplet.
    pin spike
    CMT
    Characteristic for welding brads with pointed ends onto an electrically conductive surface.
    pipe
    PMC, Pulse, Standard
    Characteristics for pipe applications and positional welding on narrow gap applications
    pipe cladding
    PMC, CMT
    Characteristics for overlay welding of outer pipe claddings with little penetration, low dilution and wide weld seam flow
    retro
    CMT, Puls, PMC, Standard
    The characteristic has the same weld properties as the predecessor TransPuls Synergic (TPS) series.
    ripple drive 2)
    PMC
    Also required:
    Characteristic for producing a rippled weld by means of a cyclical process interruption of the pulsed arc and an additional wire movement.
    The weld rippling characteristics are similar to that of TIG welds.
    root
    CMT, LSC, Standard
    Characteristics for root passes with powerful arc
    seam track
    PMC, Pulse
    Characteristic with amplified current control, especially suitable for the use of a seam tracking system with external current measurement.
    TIME
    PMC
    Characteristic for welding with very long stickout and TIME shielding gases to increase the deposition rate.
    (TIME = Transferred Ionized Molten Energy)
    universal
    The characteristic is ideal for all standard welding tasks.
    weld+
    CMT
    Characteristics for welding with short stickout and Braze+ gas nozzle (gas nozzle with small opening and high flow velocity)
    1)
    Can only be used with iWave AC/DC multiprocess welding machines
    2)
    Welding characteristics with special properties provided by additional hardware
    3)
    Mixed process characteristics
    2. Welding characteristics
    Designation
    Process
    Properties
    additive
    CMT
    arc blow
    PMC
    arcing
    Standard
    base
    Standard
    braze
    CMT, LSC, PMC
    braze+
    CMT
    CC/CV
    CC/CV
    cladding
    CMT, LSC, PMC
    constant current
    PMC
    CW additive
    PMC, ConstantWire
    dynamic
    dynamic +
    PMC
    edge
    CMT
    flanged edge
    CMT
    galvanized
    galvannealed
    PMC
    gap bridging
    CMT, PMC
    hotspot
    CMT
    mix 2) / 3)
    PMC
    Also required:
    marking
    mix 2) / 3)
    CMT
    Also required:
    mix drive 2)
    PMC
    Also required:
    multi arc
    PMC
    open root
    LSC, CMT
    PCS 3)
    PMC
    PCS mix
    PMC
    pin
    CMT
    pin picture
    CMT
    pin print
    CMT
    pin spike
    CMT
    pipe
    pipe cladding
    PMC, CMT
    retro
    ripple drive 2)
    PMC
    Also required:
    root
    CMT, LSC, Standard
    seam track
    PMC, Pulse
    TIME
    PMC
    universal
    weld+
    CMT
    1)
    2)
    3)
    MIG/MAG pulse synergic welding is a pulsed-arc process with controlled material transfer.
    In the base current phase, the energy supply is reduced to such an extent that the arc is only just stable and the surface of the workpiece is preheated. In the pulsing current phase, a precisely dosed current pulse ensures the targeted detachment of a droplet of welding material.
    This principle guarantees low-spatter welding and precise work over the entire power range.
    2. Welding methods and processes
    The MIG/MAG standard synergic welding process is a MIG/MAG welding process across the entire power range of the welding machine with the following arc types:
    Dip transfer arc
    Droplet transfer takes place during a short circuit in the lower power range.
    Intermediate arc
    The intermediate arc alternates irregularly between short circuits and spray transitions. This results in increased spatter. It is not possible to use this arc effectively, so it is better to avoid it.
    Spray arc
    A short circuit-free transfer of material takes place in the high power range.
    PMC process
    PMC = Pulse Multi Control
    PMC is a pulsed arc welding process with high-speed data processing, precise recording of the process status and improved droplet detachment. Faster welding possible with a stable arc and even penetration.
    LSC process
    LSC = Low Spatter Control
    LSC is a low-spatter dip transfer arc process. Before the short circuit bridge is broken, the current is lowered and re-ignition takes place at significantly lower welding current values.
    SynchroPulse is available for all processes (standard/pulsed/LSC/PMC).
    Due to the cyclical change of welding power between two operating points, SynchroPulse achieves a flaking seam appearance and non-continuous heat input.
    CMT process
    CMT = Cold Metal Transfer
    A special CMT drive unit is required for the CMT process.
    The reversing wire movement in the CMT process results in a droplet detachment with improved dip transfer arc properties.
    The advantages of the CMT process are as follows
    • Low heat input
    • Less spattering
    • Reduced emissions
    • High process stability
    The CMT process is suitable for:
    • Joint welding, cladding and brazing – particularly in the case of high requirements in terms of heat input and process stability
    • Light-gauge sheet welding with minimal distortion
    • Special connections, such as copper, zinc, and steel/aluminium
    NOTE!
    A CMT reference book is available complete with typical applications;
    see ISBN 978-3-8111-6879-4.
    CMT Cycle Step is a further development of the CMT welding process. A special CMT drive unit is also required for this process.
    CMT Cycle Step is the welding process with the lowest heat input.
    The CMT Cycle Step welding process switches cyclically between CMT welding and pauses of an adjustable duration.
    These pauses in the welding process lower the heat input; the continuity of the weld seam is maintained.
    Individual CMT cycles are also possible. The size of the CMT spot welds is determined by the number of CMT cycles.
    SlagHammer
    The SlagHammer function is implemented in all steel characteristics.
    In conjunction with a CMT drive unit WF 60i CMT, slag is knocked off the weld seam and wire electrode end by a reversing wire movement without arc before welding.
    Knocking off the slag ensures reliable and precise ignition of the arc.
    A wire buffer is not required for the SlagHammer function.
    The SlagHammer function is automatically executed if a CMT drive unit is present in the welding system.
    Stitch welding
    With stitch welding, all welding processes can be cyclically interrupted. This facilitates targeted control of the heat input.
    Welding time, pause time and the number of interval cycles can be set individually (e.g. for producing a rippled weld seam, for tacking light-gauge sheets or for longer pause times for simple, automatic spot welding mode).
    Stitch welding is possible with any operating mode.
    In special 2-step mode and special 4-step mode, no interval cycles are performed during the start and end phases. The interval cycles are only executed in the main process phase.
    Control panel
    General
    Welding parameters can be easily changed and selected using the adjusting dial.
    The parameters are shown on the display while welding is in progress.
    The synergic function ensures that other welding parameters are also adjusted whenever an individual parameter is changed.
    NOTE!
    As a result of firmware updates, you may find that your device has certain functions that are not described in these operating instructions, or vice versa.
    Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    1. Controls, connections and mechanical components
    Control panel
    General
    NOTE!
    2. Control panel
    General
    NOTE!
    2. Control panel
    WARNING!
    Fully read and understand this document.
    2. Control panel
    Control panel
    No.Function
    (1)
    Process control parameter indicator
    For the LSC and PMC welding processes
    Penetration stabilizer indicator
    Lights up if the penetration stabilizer is active
    Arc length stabilizer indicator
    Lights up when the arc length stabilizer is active
    (2)
    Left parameter selection
    The corresponding indicator lights up when a parameter is selected.
    The following parameters can be selected by pressing the button:
    Material thickness *
    In mm or inches
    Welding current *
    In A
    Before the start of welding, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding.
    Wire speed *
    In m/min or ipm
    Special function
    Any parameter can be assigned to this
    The function can be selected if a parameter has been saved.
    The "Penetration stabilizer" and "Arc length stabilizer" process control parameters can only be selected when the LSC/PMC welding process is used.
    The currently adjustable parameter is marked with an arrow.
    * Synergic parameter When a synergic parameter is changed, the synergic function automatically changes all other synergic parameters to match.
    (3)
    Display
    For displaying values
    (4)
    Hold/Intermediate arc indicator
    Hold indicator
    The indicator lights up at the end of each welding operation and the actual values for the welding current, welding voltage and wire speed, etc. are automatically shown on the display.
    The indicator lights up when a spatter-prone intermediate arc occurs between the dip transfer arc and the spray arc.
    (5)
    Right parameter selection
    Arc length correction
    For correcting the arc length
    Welding voltage *
    In V
    Pulse/dynamic correction
    The function varies according to the welding process being used. A description of the various functions can be found in the Welding chapter under the corresponding welding process.
    Special function
    (6)
    Indicators
    SFI indicator
    Lights up when SFI (Spatter Free Ignition) is active
    SynchroPulse indicator
    Lights up when SynchroPulse is active
    VRD indicator
    Lights up when the voltage reduction device (VRD) is active
    (7)
    EasyJob buttons
    For saving, retrieving and deleting EasyJobs
    The LED on the corresponding button lights up when an EasyJob is selected.
    (8)
    Right adjusting dial with turn/press function
    For setting the arc length correction, welding voltage, pulse/dynamic correction and F2 parameters
    Turn the adjusting dial:
    change values, select parameters (in the Setup menu and when selecting the filler metal)
    Press the adjusting dial:
    confirm a menu selection, apply values
    (9)
    Welding process selection
    The corresponding LED lights up when a welding process is selected.
    The following welding processes can be selected by pressing the button:
    • PULS SYNERGIC (MIG/MAG pulse synergic welding)
    • SYNERGIC (MIG/MAG standard synergic welding)
    •   MANUAL (MIG/MAG standard manual welding)
    • LSC/PMC (LSC = Low Spatter Control, PMC = Pulse Multi Control)
      Depending on which function package is enabled
    • STICK/TIG (MMA welding/TIG welding)
    • CMT / SP (CMT welding / special programs)
    (10)
    USB port
    To perform the software update using a USB Ethernet adapter.
    For details on the function of the USB port, see page (→).
    (11)
    Mode selection
    The corresponding LED lights up when a mode is selected.
    The following modes can be selected by pressing the button:
    •   2T (2-step mode)
    •   4T (4-step mode)
    •   S4T (Special 4-step mode)
    • S2T    (Special 2-step mode)
    • MODE (Special modes depending on the function package)
    (12)
    Gas-test button
    For setting the required gas flow rate on the gas pressure regulator.
    After pressing this button, gas flows for 30 seconds. Press the button again to stop the gas flow prematurely.
    (13)
    Wire threading button
    To thread the wire electrode into the torch hosepack with no accompanying flow of gas or current
    (14)
    Left adjusting dial with turn/press function
    • For setting the sheet thickness, welding current, wire speed, F1, penetration stabilizer and arc length stabilizer parameters
    • For displaying help texts
    Select parameters, change values, display long help texts
    To confirm a menu selection, apply values, call up help texts for parameters
    (15)
    Favourites button
    Individual parameters or parent folders can be assigned to it
    (16)
    Filler metal info button
    For showing the currently set filler metal
    (17)
    Filler metal selection button
    For selecting the filler metal
    2. Control panel
    The left adjusting dial can be used to display the corresponding plain text for each parameter abbreviation shown on the display.
    Example:
    Parameter or entry from the Setup menu has been selected using the right
    adjusting dial; the LED on the right adjusting dial lights up.
    1Press the left adjusting dial
    The plain text for the parameter is displayed; the LED on the left adjusting dial lights up.
    2To display extended plain texts, turn the left adjusting dial
    The plain text is moved across the display.
    3To make another selection, turn the right adjusting dial
    Example: the selected parameter I-S is assigned to F1
    1Select the desired parameter in the Setup menu
    Further information on the Setup menu can be found from page (→)
    2To assign the selected parameter to F1 or F2, press the parameter selection button for approx. 3 seconds:
    F1 ... left parameter selection
    F2 ... right parameter selection
    F1/F2 flashes while the parameter selection button is pressed.
    As soon as the parameter is saved, the indicator for the corresponding special function parameter lights up.
    F1 (for example) and a tick is shown next to the parameter:
    The selected parameter is now stored under F1.
    If a parameter cannot be assigned to the F1 or F2 special function parameters, after approx. 5 seconds F1 (for example) and X is displayed:
    This deletes an existing stored parameter.
    Retrieving F1 and F2 special function parameters
    1Press the parameter selection button until F1 or F2 lights up:
    The stored parameter is shown first, then the currently set value of the parameter.
    2Change the value of the parameter by turning the adjusting dial:
    F1 ... left adjusting dial
    F2 ... right adjusting dial
    Deleting F1 and F2 special function parameters
    1Press the parameter selection button for at least 5 seconds:
    The stored parameter is deleted, F1 (for example) and X is shown on the display:
    The F1 and F2 special function parameters can also be set in the Setup menu (page (→)).
    2. F1/F2 special function parameters, Favourites button
    Assigning the Favourites button
    Individual parameters or parent folders from the Setup menu can be assigned to the Favourites button. These parameters or parent folders can then be called up directly using the control panel.
    Example: The selected SynchroPulse folder is assigned to the Favourites button
    1Select the desired parameter or the desired parent folder in the Setup menu
    2To assign the selected parameter or folder to the Favourites button, press the Favourites button for approx. 3 seconds
    Next to the parameter or folder    and a tick are shown:
    The selected parameter or folder is now assigned to the Favourites button.
    Retrieving favourites
    Parameters or folders stored under the Favourites button can be retrieved in any setting, except for when the Setup menu is active.
    Ongoing selection processes or called up jobs are cancelled when favourites are retrieved.
    1Briefly press the "Favourites" button (< 3 seconds)
    The LED on the Favourites button lights up and the stored parameter or folder is shown on the display.
    2To end retrieval of the favourite, briefly press the Favourites button again (< 3 seconds)
    The LED on the Favourites button goes out and the display switches to the welding parameters.
    Deleting favourites
    1Press the Favourites button for at least 5 seconds:
    The stored parameter or folder is deleted and    and X are shown on the display:
    The Favourites button can also be assigned in the Setup menu (page (→)).
    Front
    No.Function
    (1)
    Control panel with display
    For operating the welding machine
    (2)
    (+) current socket with bayonet latch
    (3)
    Blanking cover
    Reserved for the TMC connection socket of the TIG option
    (4)
    Welding torch connection
    For connecting the welding torch
    (5)
    (-) current socket with bayonet latch
    Used to connect the return lead cable during MIG/MAG welding
    Rear
    No.Function
    (6)
    MIG/MAG shielding gas connection socket
    (7)
    Blanking cover/TIG shielding gas connection socket (option)
    (8)
    Blanking cover/Ethernet connection socket (option)
    (9)
    Blanking cover/SpeedNet Connector connection socket (option)/external sensor (option)
    (10)
    Mains cable with strain relief
    (11)
    Mains switch
    For switching the welding machine on and off
    Side view
    No.Function
    (12)
    Wire spool holder with brake
    For holding standard wire spools weighing up to 19 kg (41.89 lbs) and with a max. diameter of 300 mm (11.81 in)
    (13)
    4-roller drive
    2. Connections, switches and mechanical components
    Front
    No.Function
    (1)
    (2)
    (3)
    Blanking cover
    (4)
    (5)
    Rear
    No.Function
    (6)
    (7)
    (8)
    (9)
    (10)
    (11)
    Mains switch
    Side view
    No.Function
    (12)
    (13)
    4-roller drive
    Installation and commissioning
    Minimum equipment needed for welding task
    General
    Depending on the welding process, a certain minimum equipment level is required in order to work with the welding machine.
    The welding processes and the corresponding minimum equipment for the welding operation are described in the following.
    1. Installation and commissioning
    General
    2. Minimum equipment needed for welding task
    General
    MIG/MAG gas-cooled welding
    • Welding machine
    • Return lead cable
    • MIG/MAG welding torch, gas-cooled
    • Shielding gas supply
    • Wire electrode
    MIG/MAG water-cooled welding
    • Welding machine
    • Cooling unit
    • Return lead cable
    • MIG/MAG welding torch, water-cooled
    • Wire electrode
    Manual CMT welding
    • Welding machine
    • Standard, Pulse and CMT welding packages enabled on the welding machine
    • Return lead cable
    • PullMig CMT welding torch incl. CMT drive unit and CMT wire buffer
      IMPORTANT! For water-cooled CMT applications, a cooling unit is also required!
    • OPT/i PushPull
    • CMT interconnecting hosepack
    • Wire electrode
    • Shielding gas connection (shielding gas supply)
    TIG DC welding
    • Welding machine
    • Return lead cable
    • TIG gas-valve torch
    • Filler metal (depending on the application)
    Manual metal arc welding
    • Welding machine
    • Return lead cable
    • Electrode holder with welding power-lead
    • Rod electrodes
    Before installation and commissioning
    Danger from incorrect operation
    WARNING!
    2. Before installation and commissioning
    WARNING!
    Intended use
    The welding machine may only be used for MIG/MAG, MMA and TIG welding. Utilisation for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended use.
    Intended use also includes:
    • Following all the instructions contained in the operating instructions
    • Performing all stipulated inspection and maintenance work
    Setup regulations
    The device has been tested according to degree of protection IP23. This means:
    • Protection against solid foreign bodies larger than Ø 12.5 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° from the vertical
    The device can be set up and operated outdoors in accordance with protection class IP23. Direct moisture (e.g., from rain) must be avoided.
    WARNING!
    Danger from falling or falling devices.
    Serious personal injury and property damage can be the result.
    Place the device securely on a flat, solid surface.
    After installation, check all screw connections for tightness.
    The ventilation channel is a very important safety device. When selecting the setup location, ensure that the cooling air can enter or exit unhindered through the vents on the front and back. Any electrically conductive dust (e.g., from grinding work) must not be allowed to be sucked directly into the system.
    Mains connection
    WARNING!
    Risk of electric shock due to inadequate mains connection.
    This can result in serious injury and death.
    Only connect the device to a mains supply with a ground conductor.
    Only connect the device to the mains via a connector system with a ground conductor contact.
    If operating the device on a mains supply without ground conductor and on a socket without ground conductor contact, observe all national regulations for protective separation.
    CAUTION!
    An inadequately dimensioned electrical installation can cause serious damage to property.
    The mains lead and its fuse protection must be dimensioned to suit the local power supply.
    The technical data shown on the rating plate applies.
    NOTE!
    Before connecting the device to the mains, check with the grid operator whether the device may be connected.
    The maximum permissible mains impedance that is decisive for a mains connection is stated in the technical data.
    • The devices are designed for the mains voltage specified on the rating plate.
    • Devices with a rated welding voltage of 3 x 575 V must be operated on three-phase systems with earth neutral.
    • If your version of the appliance does not come with mains cables and mains plugs ready-fitted, these must be fitted by a qualified person in accordance with national standards.
    • The fuse protection for the mains lead is indicated in the technical data.
    IMPORTANT! Ensure that the mains connection is earthed properly!
    Due to local regulations and national guidelines, a residual current circuit breaker may be required when connecting a device to the public grid. The type of residual current circuit breaker recommended for the device is specified in the technical data.
    Generator-powered operation
    link_horizontalLink copied
    The welding machine is generator-compatible.
    The maximum apparent power S1max of the welding machine must be known in order to select the correct generator output.
    The maximum apparent power S1max of the welding machine is calculated as follows:
    3-phase devices: S1max = I1max x U1 x √3
    Single-phase devices: S1max = I1max x U1
    See device rating plate or technical data for I1max and U1 values
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator may be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the welding machine.
    When using single-phase devices with a 3-phase generator, note that the specified generator apparent power is often only available as a whole across all three phases of the generator. If necessary, obtain further information on the single-phase power of the generator from the generator manufacturer.
    NOTE!
    The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
    Details of the mains voltage tolerance can be found in the "Technical data" section.
    Information on system components
    The steps and activities described below include references to various system components, including:
    • Trolley
    • Welding torch
    • etc.
    For more detailed information about installing and connecting the system components, please refer to the appropriate operating instructions.
    Connecting the mains cable
    Mains cable connection safety
    WARNING!
    The work described below must only be carried out by trained and qualified personnel.
    Observe national standards and directives.
    CAUTION!
    Danger due to improperly prepared mains cable.
    This can result in short circuits and damage to property.
    Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
    2. Connecting the mains cable
    WARNING!
    CAUTION!
    General
    If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before commissioning.
    Strain-relief devices for the following cable cross-sections are fitted to TPS 270i C welding machines:
    Welding machine
    Outer diameter of cable
    TPS 270i C /nc
    14 - 16 mm
    TPS 270 i C / S/nc
    14 - 16 mm
    TPS 270i C /MV/nc
    14 - 18.5 mm
    Strain-relief devices for other cable cross-sections must be designed accordingly.
    Stipulated mains cables
    Welding machine
    Mains voltage
    Cable cross-section
    USA / Canada *
    Europe
    TPS 270i C /nc
    3 x 380 V
    3 x 400 V
    3 x 460 V
    AWG 14
    4G 2.5 mm²
    TPS 270i C /MV/nc
    3 x 200 V
    3 x 230 V
    AWG 12
    4G 2.5 mm²
    3 x 380 V
    3 x 400 V
    3 x 460 V
    AWG 14
    4G 2.5 mm²
    TPS 270i C /S/nc **
    3 x 460 V
    3 x 575 V
    AWG 14
    Cable type for USA / Canada: Extra-hard usage
    Welding machine without CE mark; not available in Europe
    AWG = American wire gauge
    Connecting the mains cable - general
    CAUTION!
    Risk of injury and damage from short circuits.
    Short circuits can occur between the phase conductors or between the phase conductors and the ground conductor unless ferrules are used.
    Strip the insulation of the mains cable and fit ferrules to all phase conductors, as well as the ground conductor.
    NOTE!
    Mains cables must be connected to devices in compliance with national standards and guidelines and the work must be carried out by suitably qualified personnel!
    IMPORTANT! The ground conductor should be approx. 20 - 25 mm (0.8 - 1 in.) longer than the phase conductors.
    6 x TX25
    5 x TX25
    Tightening torque = 1.2 Nm
    IMPORTANT! When connecting the cable to the switch, ensure:
    • To route the conductors near to the switch
    • Not to make the conductors unnecessarily long
    • To fit the protective hose supplied over the cable and insert the covered cable into the strain-relief device if cable diameters are small
    5
    6
    7
    5 x TX25, tightening torque = 3 Nm
    8
    6 x TX25, tightening torque = 3 Nm
    Start-up
    Danger from electric current
    WARNING!
    Danger from electric current.
    Before starting work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Danger from electrical current due to electrically conductive dust in the device.
    Only operate the device with an air filter fitted. The air filter is a very important safety device for achieving IP 23 protection.
    2. Start-up
    WARNING!
    WARNING!
    2. Start-up
    General
    Commissioning the welding machine is described with reference to a manual gas-cooled MIG/MAG application.
    2. Start-up
    Connecting the gas cylinder
    WARNING!
    Danger from falling gas cylinders.
    Place gas cylinders on a solid, level surface so that they remain stable.
    Secure gas cylinders to prevent them from falling over.
    Observe the safety rules of the gas cylinder manufacturer.
    Connecting the gas hose
    1Place the gas cylinder on a solid, level surface in such a way that it remains stable
    2Secure the gas cylinder to prevent it from toppling over (but not around the neck of the cylinder)
    3Take the protective cap off the gas cylinder
    4Briefly open the gas cylinder valve to remove any dust or dirt
    5Inspect the seal on the gas pressure regulator
    6Screw the pressure regulator onto the gas cylinder and tighten it
    7Connect the pressure regulator to the shielding gas connection on the welding machine using the gas hose
    2. Start-up
    Establishing a ground earth connection
    NOTE!
    When establishing a ground earth connection, observe the following points:
    Use a separate return lead cable for each welding machine
    Keep the plus cable and return lead cable together as long and as close as possible
    Physically separate the welding circuits of individual welding machines
    Do not route several return lead cables in parallel;
    if parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
    Keep the return lead cable as short as possible, provide a large cable cross-section
    Do not cross return lead cables
    Avoid ferromagnetic materials between the return lead cable and the interconnecting hosepack
    Do not wind up return lead cables - coil effect!
    Lay long return lead cables in loops
    Do not route return lead cables in iron pipes, metal cable conduits or on steel beams, avoid cable ducts;
    (routing of plus cables and return lead cables together in an iron pipe does not cause any problems)
    If there are several return lead cables, keep the grounding points on the component as far away from one another as possible and prevent crossed current paths from occurring underneath the individual arcs
    Use compensated interconnecting hosepacks (interconnecting hosepacks with integrated return lead cable)
    Connecting the return lead cable
    1Plug the return lead cable into the (-) current socket
    2Twist the return lead cable to fasten it
    3Use the other end of the return lead cable to establish a connection to the workpiece
    2. Start-up
    Connecting the welding torch
    1Before connecting the welding torch, check that all cables, lines and hosepacks are undamaged and properly insulated.
    2Open the wire-feed unit cover
    2. Start-up
    Inserting/replacing feed rollers
    In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
    NOTE!
    Only use feed rollers that match the wire electrode.
    An overview of the feed rollers available and their potential application areas can be found in the Spare Parts Lists.
    CAUTION!
    Danger from feed roller holders flying upwards.
    This can result in injuries.
    When unlocking the lever, keep fingers away from the area to the left and right of the lever.
    2. Start-up
    Inserting the wirespool
    CAUTION!
    Danger from springiness of spooled wire electrode.
    While inserting the wirespool, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Danger of injury and damage from falling wirespool.
    Make sure that the wirespool is fitted securely to the wirespool holder.
    CAUTION!
    Danger from the wirespool falling because the locking ring has been placed the wrong way around.
    This can result in personal injury and function impairment.
    Always position the locking ring as shown in the diagram on the left.
    2. Start-up
    Inserting the basket-type spool
    CAUTION!
    While inserting the basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire springing back.
    CAUTION!
    Danger from falling basket-type spool.
    Make sure that the basket-type spool and basket-type spool adapter are fitted securely to the wirespool holder.
    NOTE!
    When working with basket-type spools, only use the basket-type spool adapter included in the scope of supply.
    CAUTION!
    Place the basket-type spool on the adapter provided in such a way that the bars on the spool are inside the adapter guideways.
    CAUTION!
    Danger from the basket-type spool falling because the locking ring has been placed the wrong way around.
    2. Start-up
    Feeding in the wire electrode
    WARNING!
    This can result in serious personal injuries.
    Wear safety goggles.
    When inserting the wirespool/basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
    CAUTION!
    Danger from sharp end of wire electrode.
    This can damage the welding torch.
    Deburr the end of the wire electrode well before threading in.
    Lay the welding torch hosepack as straight as possible.
    WARNING!
    Danger due to emerging wire electrode.
    Hold the welding torch so that the tip of the welding torch points away from the face and body.
    Wear suitable protective goggles.
    Do not point the welding torch at people.
    Ensure that the wire electrode can only intentionally make contact with electrically conductive objects.
    NOTE!
    The wire electrode can be threaded by pressing a wire threading button present in the welding system or by pressing the torch trigger.
    Notes on wire threading
    If contact is made with the earth during wire threading, the wire electrode is automatically stopped.
    When the torch trigger is pressed once, the wire electrode moves forwards 1 mm.
    With a push wire feeding system:
    If contact is made with the workpiece during threading, the wire play in the inner liner is measured. If the measurement is successful, a wire play value is entered in the event logbook, which is used to control the system.
    2. Start-up
    Setting the contact pressure
    NOTE!
    Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
    Contact pressure standard values for U-groove rollers
    Steel:
    4 - 5
    CrNi
    4 - 5
    Tubular cored electrodes
    2 - 3
    2. Start-up
    Adjusting the brake
    NOTE!
    After releasing the torch trigger the wirespool should stop unreeling.
    Adjust brake if necessary.
    2. Start-up
    Design of the brake
    CAUTION!
    Danger from incorrect installation.
    This can result in injury and damage to property.
    Do not dismantle the brake.
    Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
    The brake is only available as a complete unit.
    The illustration of the brake is for information purposes only.
    2. Start-up
    Performing R/L alignment
    IMPORTANT! For optimum welding results, the manufacturer recommends performing an R/L alignment when starting the device for the first time and when any changes are made to the welding system.
    Welding
    MIG/MAG modes
    General
    WARNING!
    Danger from incorrect operation.
    Possible serious injury and damage to property.
    Do not use the functions described here until you have read and completely understood these operating instructions.
    Do not use the functions described here until you have fully read and understood all of the operating instructions for the system components, in particular the safety rules!
    See the Setup menu for information on settings, setting range and units of measurement for the available parameters.
    1. Welding
    MIG/MAG modes
    General
    WARNING!
    1. Welding
    2. MIG/MAG modes
    General
    WARNING!
    1. Welding
    2. MIG/MAG modes
    Symbols and their explanations
    Press the torch trigger | Hold the torch trigger | Release the torch trigger
    GPr
    Gas pre-flow
    I-S
    Starting-current phase: the base material is heated up rapidly, despite the high thermal dissipation that occurs at the start of welding
    t-S
    Starting current time
    Start arc length correction
    SL1
    Slope 1: the starting current is steadily lowered until it reaches the welding current
    I
    Welding-current phase: uniform thermal input into the base material, whose temperature is raised by the advancing heat
    I-E
    Final current phase: to prevent any local overheating of the base material due to heat build-up towards the end of welding. This eliminates any risk of weld seam drop-through.
    t-E
    Final current time
    End arc length correction
    SL2
    Slope 2: the welding current is steadily lowered until it reaches the final current
    GPo
    Gas post-flow
    SPt
    Spot welding time
    A detailed explanation of the parameters can be found in the section headed "Process parameters".
    1. Welding
    2. MIG/MAG modes
    2-step mode
    "2-step mode" is suitable for
    • Tacking work
    • Short welds
    • Automated and robot welding
    1. Welding
    2. MIG/MAG modes
    4-step mode
    "4-step mode" is suitable for longer welds.
    1. Welding
    2. MIG/MAG modes
    Special 4-step mode
    "Special 4-step mode" is particularly suitable for welding aluminium materials. The special slope of the welding current curve takes account of the high thermal conductivity of aluminium.
    1. Welding
    2. MIG/MAG modes
    Special 2-step mode
    "Special 2-step mode" is ideal for welding in the higher power range. In special 2-step mode, the arc starts at a lower power, which makes it easier to stabilise.
    1. Welding
    2. MIG/MAG modes
    Spot welding
    The "Spot welding" mode is suitable for welded joints on overlapped sheets.
    1. Welding
    MIG/MAG and CMT welding
    Danger from incorrect operation and electric current
    WARNING!
    WARNING!
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    1. Welding
    2. MIG/MAG and CMT welding
    WARNING!
    WARNING!
    1. Welding
    MIG/MAG and CMT welding – overview
    The "MIG/MAG and CMT welding" section comprises the following steps:
    • Switching on the welding machine
    • Selecting the welding process and operating mode
    • Retrieving the currently set filler metal
    • Selecting the filler metal
    • Setting the welding and process parameters
    • Setting the shielding gas flow rate
    • MIG/MAG or CMT welding
    1. Welding
    1Connect the mains cable
    2Move the mains switch to the "I" position
    1. Welding
    Setting the welding process and operating mode
    1Press the "Welding process" button until the LED for the desired welding process lights up
    2Press the "Mode" button until the LED for the desired operating mode lights up
    1. Welding
    1Press the "Filler metal info" button
    The LED on the button lights up and the currently set filler metal is shown on the display:
    2Turn the right adjusting dial
    The currently set wire diameter is shown on the display:
    3Turn the right adjusting dial
    The currently set shielding gas is shown on the display:
    4Turn the right adjusting dial
    The currently set characteristic is shown on the display:
    5Press the "Filler metal info" button
    The currently set welding parameter values are shown on the display.
    1. Welding
    1Press the "Filler metal selection" button
    The LED on the button lights up and "filler metal?" is shown on the display:
    2Press the right adjusting dial
    The first available filler metal is displayed:
    3Select the desired filler metal by turning the right adjusting dial
    4Press the right adjusting dial
    "diameter?" is shown on the display: *
    5Press the right adjusting dial
    The first available wire diameter is displayed:
    6Select the desired wire diameter by turning the right adjusting dial
    7Press the right adjusting dial
    "gas?" is shown on the display: *
    8Press the right adjusting dial
    The first available shielding gas is displayed:
    9Select the desired shielding gas by turning the right adjusting dial
    10Press the right adjusting dial
    If available, the first available characteristic is displayed: *
    11Select the desired characteristic by turning the right adjusting dial
    12Press the right adjusting dial
    A prompt to apply the new filler metal is displayed: *
    13Press the right adjusting dial
    The set filler metal is saved.
    The previous item can be called up by turning the right adjusting wheel and selecting "back".
    1. Welding
    Setting the welding parameters
    1Press the button until the desired welding parameter lights up
    Material thickness
    Welding current
    Wire speed
    Special function
    2Turn the left adjusting dial to change the value of the welding parameter
    3If necessary:
    Welding voltage
    Special function
    4Turn the right adjusting dial to change the value of the welding parameter
    The amended parameter values are applied immediately.
    If one of the wire speed, material thickness, welding current or welding voltage parameters are changed during synergic welding, the remaining welding parameters are immediately altered accordingly.
    1. Welding
    Set the shielding gas flow rate
    1Open the gas cylinder valve
    2Press the gas-test button
    Gas flows out.
    The "Gas purging" dialogue window appears on the display, indicating the remaining gas purging time. If there is a gas regulator or gas sensor in the welding system, the actual gas value is also displayed.
    3Turn the adjusting screw on the underside of the pressure regulator until the pressure gauge shows the required shielding gas flow rate
    4Press the gas-test button
    The flow of gas stops.
    1. Welding
    CAUTION!
    Risk of injury and damage from electric shock and from the wire electrode emerging from the torch.
    When pressing the torch trigger:
    keep the torch away from your face and body
    do not point the welding torch at people
    make sure that the wire electrode does not touch any electrically conducting or earthed (grounded) parts, such as the housing, etc.
    1Press the torch trigger and start welding
    Whenever welding ends, the actual values for the welding current, welding voltage and wire speed are stored, and HOLD appears on the display.
    NOTE!
    It is not always possible to change parameters that have been set on a system component control panel (e.g. remote control) on the welding machine control panel.
    1. Welding
    Spot and stitch welding
    Spot welding
    Spot welding is used on welded joints on overlapped sheets that are only accessible on one side.
    Spot welding can be carried out in the following welding processes:
    PULSE SYNERGIC | SYNERGIC | MANUAL | LSC/PMC | SP (CMT)
    1Select the desired welding process by pressing the "Welding process" button
    2Select the MODE by pressing the "Mode" button
    "Spot" appears briefly on the display.
    3Setup menu / Process parameters / Spot welding
    The SPt (spot welding time) parameter is shown.
    5Enter the desired value for the spot welding time: press and turn the right adjusting dial
    Setting range: 0.1 - 10.0 s
    Factory setting: 1.0 s
    6Confirm the value by pressing the right adjusting dial
    NOTE!
    4-step mode is assigned as standard for spot welding.
    Press the torch trigger - Spot welding process runs until the end of the spot welding time - Press again to stop the spot welding time prematurely
    The spot welding setting can be changed to 2-step in the Setup menu under Settings / System / SPm
    (more information on 2-step and 4-step mode for spot welding starts on page (→))
    7Select the filler metal, wire diameter and shielding gas
    8Open the gas cylinder valve
    9Set the shielding gas flow rate
    WARNING!
    10Spot welding
    Procedure for producing a welding spot:
    1Hold the welding torch vertical
    2Press and release the torch trigger
    3Keep the welding torch in the same position
    4Wait for the gas post-flow time
    5Raise the welding torch
    NOTE!
    Pre-set start of welding and end of welding parameters are also active for spot welding.
    A start of welding / end of welding action for spot welding can be stored in the Setup menu under Process parameters / Start/End.
    If the final current time is active, the end of welding is not after the pre-set spot welding time, but only once the pre-set slope and final current times have ended.
    1. Welding
    2. Spot and stitch welding
    Spot welding
    NOTE!
    WARNING!
    10Spot welding
    NOTE!
    1. Welding
    Stitch welding
    2Select the operating mode for stitch welding
    3Select the filler metal, wire diameter and shielding gas
    4Set the desired welding parameters depending on the selected welding process
    5Activate stitch welding:
    Setup menu / Process parameters / Interval / set Int. parameter to "on"
    6Set the other parameters for stitch welding:
    Stitch welding time Int-t, interval break time Int-b, interval cycles Int-C,
    7Open the gas cylinder valve
    8Set the shielding gas flow rate
    WARNING!
    9Stitch welding
    Procedure for stitch welding:
    2Depending on the selected mode:
    press and hold the torch trigger (2-step mode)
    press and release the torch trigger (4-step mode)
    4Wait for the welding interval
    5Position the welding torch at the next point
    6To end stitch welding, depending on the selected mode:
    release the torch trigger (2-step mode)
    7Wait for the gas post-flow time
    8Raise the welding torch
    Notes on stitch welding
    With PMC characteristics, the setting of the SFI parameter influences the re-ignition behaviour in interval operation:
    SFI = on
    Re-ignition takes place with SFI.
    SFI = off
    Re-ignition takes place by means of touchdown ignition.
    For aluminium alloys, SFI is always used for pulse and PMC ignition. SFI ignition cannot be deactivated.
    If the SlagHammer function is stored on the selected characteristic, faster and more stable SFI ignition takes place in conjunction with a CMT drive unit and a wire buffer.
    1. Welding
    MIG/MAG and CMT welding parameters
    Welding parameters for MIG/MAG pulse synergic welding and PMC welding
    The following welding parameters can be set and displayed for MIG/MAG pulse synergic welding and PMC welding:
    using the left adjusting dial:
    Material thickness 1)
    Setting range: 0.1 - 30.0 mm 2) / 0.004 - 1.18 in. 2)
    Welding current 1)
    in A
    Setting range: depends on the welding process and welding program selected
    Wire speed 1)
    Setting range: 0.5 - 25 m/min 2) / 20 - 980 ipm. 2)
    Special function
    any parameter can be assigned to this (see page (→))
    Penetration stabilizer 4) (see page (→))
    Setting range: 0 - 10 m/min / 0 - 393.7 ipm
    Factory setting: 0
    Arc length stabilizer 4) (see page (→))
    Setting range: 0 - 5
    Factory setting: 0
    using the right adjusting dial:
    for correcting the arc length;
    Setting range: -10 - +10
    Factory setting: 0
    - .... shorter arc length
    0 ... neutral arc length
    + ... longer arc length
    Welding voltage 1)
    in V
    for correcting the pulsing energy of a pulsed arc
    Factory setting: 0
    - ... lower droplet detachment force
    0 ... neutral droplet detachment force
    + ... increased droplet detachment force
    Special function
    1. Welding
    2. MIG/MAG and CMT welding parameters
    Welding current 1)
    in A
    Wire speed 1)
    Special function
    Factory setting: 0
    Factory setting: 0
    Factory setting: 0
    Welding voltage 1)
    in V
    Factory setting: 0
    Special function
    1. Welding
    Welding parameters for MIG/MAG standard synergic welding, LSC welding and CMT welding
    The following welding parameters for MIG/MAG standard synergic welding, LSC welding and CMT welding can be set and displayed:
    Welding current 1)
    in A
    Wire speed 1)
    for setting a harder, more stable arc
    Special function
    Factory setting: 0
    Setting range. 0 - 2
    Factory setting: 0
    for correcting the arc length, which is pre-set by the characteristic or the synergic program
    Factory setting: 0
    Welding voltage 1)
    in V
    for influencing the short-circuiting dynamic at the instant of droplet transfer
    Factory setting: 0
    - ... harder and more stable arc
    0 ... neutral arc
    + ... soft and low-spatter arc
    Special function
    1. Welding
    Welding parameters for MIG/MAG standard manual welding
    The following welding parameters can be set and displayed for MIG/MAG standard manual welding:
    Wire speed 1)
    Special function
    Welding voltage 1)
    in V
    Factory setting: 0
    0 ... harder and more stable arc
    10 ... soft and low-spatter arc
    Special function
    1. Welding
    Explanation of footnotes
    1)
    Synergic parameter
    The actual setting range depends on the welding machine and wirefeeder used and on the welding program selected.
    2)
    The actual setting range depends on the welding program selected.
    3)
    The maximum value depends on the wirefeeder used.
    4)
    Only in the LSC and PMC welding processes
    1. Welding
    EasyJob mode
    General
    The 5 EasyJob buttons enable up to 5 operating points to be saved quickly.
    The current welding settings are saved.
    1. Welding
    2. EasyJob mode
    General
    1. Welding
    2. EasyJob mode
    EasyJob mode
    Storing EasyJob operating points
    1To store the current welding settings, press one of the EasyJob buttons for approx. 3 seconds.
    "Job", the button number and a tick are shown on the display and the EasyJob button LED lights up, e.g.:
    The settings have now been stored.
    IMPORTANT! If an operating point has already been saved under an EasyJob button it will be overwritten without any prior warning.
    Retrieving EasyJob operating points
    2To retrieve a saved EasyJob operating point, press the corresponding EasyJob button briefly (< 3 seconds).
    The EasyJob button LED lights up and the saved values are shown on the display.
    If no values are displayed after pressing an EasyJob button, an operating point is not stored under this EasyJob button.
    Deleting EasyJob operating points
    3To delete an EasyJob operating point, press the relevant EasyJob button for approx. 5 seconds.
    After approx. 3 seconds the saved operating point will be overwritten with the current settings and "Job", the button number and a tick are shown on the display.
    After a total of approx. 5 seconds the EasyJob button LED goes out and "Job", the button number and an X are shown on the display, e.g.:
    The EasyJob operating point has been deleted.
    1. Welding
    TIG welding
    WARNING!
    WARNING!
    1. Welding
    2. TIG welding
    WARNING!
    WARNING!
    1. Welding
    2. TIG welding
    Preparations
    1Move the mains switch to the "O" position
    2Disconnect the mains plug
    3Remove the MIG/MAG welding torch
    4Disconnect the grounding (earthing) cable from the (-) current socket
    5Plug the grounding (earthing) cable into the 2nd (+) current socket and twist to fasten it
    6Use the other end of the grounding (earthing) cable to establish a connection to the workpiece
    7Plug the bayonet current plug on the TIG gas-valve torch into the (-) current socket and twist it clockwise to fasten it
    8Screw the pressure regulator onto the (argon) gas cylinder and tighten it
    9Connect the gas hose of the TIG gas-valve torch to the pressure regulator
    10Plug in the mains plug
    1. Welding
    2. TIG welding
    TIG welding
    CAUTION!
    Risk of injury and damage from electric shock.
    As soon as the mains switch is in the "I" position, the tungsten electrode of the welding torch is live.
    Ensure that the tungsten electrode does not touch any persons or electrically conductive or earthed parts (e.g. housing, etc.).
    1Move the mains switch to the "I" position
    2Press the "Welding process" button until the LED for the STICK/TIG welding process lights up and "TIG" is shown on the display.
    After a short time, the currently set welding current is shown on the display. The welding current indicator lights up.
    The welding voltage is applied to the welding socket with a three second time lag.
    NOTE!
    Under certain circumstances, it may not be possible to change welding parameters that have been set on a control panel of a system component (such as remote control or wirefeeder) from the control panel of the welding machine.
    3To change the welding current, turn the left adjusting dial
    The altered welding current is applied immediately.
    4Adjust the process parameters accordingly to make user or application-specific settings on the welding system
    5Open the gas cut-off valve on the TIG gas-valve torch
    6Set the desired shielding gas flow rate on the pressure regulator
    7Start welding (ignite the arc)
    1. Welding
    2. TIG welding
    Igniting the arc
    The welding arc is ignited by touching the workpiece with the tungsten electrode.
    1Place the gas nozzle on the ignition location so that there is 2-3 mm (0.08 - 0.12 in.) between the tip of the tungsten electrode and the workpiece. Keep a distance
    2Gradually tilt the welding torch up until the tungsten electrode touches the workpiece
    3Raise the welding torch and tilt it into the normal position - the arc now ignites
    4Carry out welding
    1. Welding
    2. TIG welding
    Finishing welding
    1Lift the TIG gas-valve torch away from the workpiece until the arc goes out.
    IMPORTANT! To protect the tungsten electrode, ensure that the shielding gas at the end of welding flows for long enough to allow the tungsten electrode to cool sufficiently.
    2Close the gas stop valve on the TIG gas-valve torch
    1. Welding
    MMA welding
    WARNING!
    WARNING!
    1. Welding
    2. MMA welding
    WARNING!
    WARNING!
    1. Welding
    2. MMA welding
    Preparations
    NOTE!
    Check the rod electrode packaging or labelling to determine whether the rod electrodes are for positive pole or negative pole welding.
    4Plug the grounding (earthing) cable into either the (-) or the (+) current socket depending on the type of electrode, and twist to fasten it
    5Use the other end of the grounding (earthing) cable to establish a connection to the workpiece
    6Plug the bayonet current plug of the electrode holder cable into the free current socket with the opposite polarity, according to the type of electrode, and twist it clockwise to latch it in place
    7Plug in the mains plug
    1. Welding
    2. MMA welding
    Manual metal arc (MMA) welding
    CAUTION!
    As soon as the mains switch is in the "I" position, the rod electrode in the electrode holder is live.
    Make sure that the rod electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.)
    2Press the "Welding process" button until the LED for the STICK/TIG welding process lights up and "STICK" is shown on the display.
    After a short time, the currently set welding current and the currently set dynamic are shown on the display. The welding current and dynamic indicators light up.
    NOTE!
    4If required, turn the right adjusting dial to change the dynamic
    The amended values are applied immediately.
    5Adjust the process parameters accordingly to make user or application-specific settings on the welding system
    6Start welding
    1. Welding
    2. MMA welding
    Welding parameters for manual metal arc welding
    The following welding parameters can be set and displayed for manual metal arc welding:
    Main current 1)
    in A
    Setting range: depends on the welding machine being used
    Arc-force dynamic
    to influence the short-circuiting dynamic at the instant of droplet transfer
    Setting range: 0 - 100
    Factory setting: 20
    100 ... harder and more stable arc
    Setup settings
    Setup menu - overview
    Entering/exiting the Setup menu
    1To enter the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    "Process parameters" is shown on the display.
    2To exit the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    1. Setup settings
    1. Setup settings
    2. Setup menu - overview
    1. Setup settings
    Process param. (1)
    Settings
    Language xx 2)
    Start/End (3)
    View
    System
    back
    Gas-setup
    Process c. (4)
    Spot welding
    Interval
    Unit (9) xx (10)
    CLS [s] (16)
    Components (5)
    Standard (11) xx (12)
    FAC (17)
    STICK (6)
    UIBS (13)
    Web-PWreset(18)
    TIG (7)
    DRSL. (14)
    USB
    SynchroPulse
    F1/F2 Param (15)
    Information
    Process Mix (8)
    Favourite
    iJob xx (19)
    R/L-check/alignment
    System data
    SPm (20)
    < back
    < back
    < back
    Press the left adjusting dial:
    The parameter is shown in plain text
    Turn the left adjusting dial:
    To read long plain texts for parameters; the plain text for the parameter is moved to the left on the display
    (1)
    Process parameters
    (2)
    Language abbreviation
    (3)
    Start/end of welding
    (4)
    Process control
    (5)
    Component monitoring
    (6)
    Electrode setup
    (7)
    TIG setup
    (8)
    Process mix
    (9)
    Units
    (10)
    metric/imperial
    (11)
    Standards
    (12)
    CEN/AWS
    (13)
    Display brightness
    (14)
    Display replaced characteristics
    (15)
    Activate F1/F2 parameter
    (16)
    Duration of interior lighting
    (17)
    Restore factory settings
    (18)
    Reset password for the website
    (19)
    Mode Setup – Special display for JobMaster
    (20)
    2-step/4-step spot welding
    1. Setup settings
    Process parameters
    Process parameters for start of welding/end of welding
    The following process parameters can be set and displayed for the start and end of welding:
    I-S
    Starting current
    For setting the starting current for MIG/MAG welding (e.g. aluminium welding start-up)
    Setting range: 0 - 200 % (of welding current)
    Factory setting: 135%
    AlS
    For correcting the arc length at the start of welding
    Setting range: -10 - -0.1 / auto / 0.0 - 10.0
    Factory setting: 0
    auto:
    the value set in the welding parameters is taken over
    t-S
    For setting the length of time the starting current is to be active 
    Setting range: off / 0.1 - 10.0 s
    Factory setting: off
    SL1
    Slope 1
    For setting the time during which the starting current is decreased or increased to the welding current
    Setting range: 0 - 9.9 s
    Factory setting: 1 s
    SL2
    Slope 2
    For setting the time during which the welding current is decreased or increased to the final current.
    I-E
    Final current
    For setting the final current so that
    1. heat build-up towards the end of welding is prevented and
    2. the end-crater can be filled when welding aluminium
    Setting range: 0 - 200% (of welding current)
    Factory setting: 50
    AlE
    For correcting the arc length at the end of welding
    Setting range: -10 - -0.1 / auto / 0.0 - 10.0 (of welding voltage)
    Factory setting: 0
    auto:
    t-E
    Final current time
    For setting the length of time for which the final current is to be active
    SFI
    to activate/deactivate the SFI function (Spatter-Free Ignition of the arc)
    Setting range: off / on
    SFI-HS
    SFI HotStart
    For setting a HotStart time in conjunction with SFI ignition
    During SFI ignition, a spray arc phase occurs within the set HotStart time. This increases the heat input irrespective of the mode, thus ensuring deeper penetration right from the very start of welding.
    Setting range: off / 0.01 - 2.00 s
    W-r
    Wire retract
    For setting the wire withdrawal value (= composite value based on backward movement of wire and a time).
    The wire withdrawal depends on the features of the welding torch.
    Setting range: 0.0 - 10.0
    Factory setting: 0.0
    IgC
    Ignition current (manual mode)
    For setting the ignition current for MIG/MAG standard manual welding
    Setting range: 100 - 450 A
    Factory setting: 450
    W-r (man.)
    Wire retract (manual mode)
    For setting the wire withdrawal value (= composite value based on backward movement of wire and a time) for MIG/MAG standard manual welding.
    CHS
    Characteristic slope
    (with MIG/MAG standard manual welding)
    auto / U constant / 1000 - 8 A/V
    Factory setting: auto
    1. Setup settings
    2. Process parameters
    I-S
    Starting current
    AlS
    Factory setting: 0
    auto:
    t-S
    SL1
    Slope 1
    SL2
    Slope 2
    I-E
    Final current
    Factory setting: 50
    AlE
    Factory setting: 0
    auto:
    t-E
    Final current time
    SFI
    SFI-HS
    SFI HotStart
    W-r
    Wire retract
    IgC
    W-r (man.)
    CHS
    1. Setup settings
    Process parameters for Gas-Setup
    The following process parameters can be set and displayed for Gas-Setup:
    GPr
    Gas pre-flow
    For setting the gas flow time before the arc is ignited
    Factory setting: 0.1 s
    GPo
    Gas post-flow
    For setting the gas flow time after the arc has gone out
    Factory setting: 0.5 s
    GCF
    Gas factor
    For setting the gas correction factor
    Setting range: auto / 0.90 - 20.0
    (the correction factor is automatically set for standard gases from the Fronius welding database)
    1. Setup settings
    Process parameters for process control
    The following process parameters can be set and displayed for the process control:
    • PSt - penetration stabilizer
    • AlSt - arc length stabilizer
    Penetration stabilizer and arc length stabilizer can also be set in combination with one another.
    1. Setup settings
    The penetration stabilizer is used to set the max. permitted change in the wire speed to ensure that the welding current and hence the penetration are kept stable or constant with variable stickout.
    The penetration stabilizer parameter is only available when the WP PMC (Welding Process Pulse Multi Control) or WP LSC (Welding Process Low Spatter Control) option has been enabled on the welding machine.
    0.0-10.0 m/min (ipm)
    Factory setting: 0 m/min
    auto
    A value of 10 m/min is stored for all characteristics, the penetration stabilizer is activated.
    0
    The penetration stabilizer is not activated.
    The wire speed remains constant.
    0.1-10.0
    The penetration stabilizer is activated.
    The welding current remains constant.
    Application examples
    Penetration stabilizer = 0 m/min (not activated)
    Changing the contact tube distance (h) alters the resistance in the welding circuit due to the longer stickout (s2).
    The constant voltage control for constant arc length causes a reduction in the mean current value and hence a smaller penetration (x2).
    Penetration stabilizer = n m/min (activated)
    Specifying a value for the penetration stabilizer ensures a constant arc length without large current variations if the stickout is changed (s1 ==> s2).
    The penetration (x1, x2) remains virtually unchanged and stable.
    Penetration stabilizer = 0.5 m/min (activated)
    To minimise the change in welding current if the stickout is changed (s1 ==> s3), the wire speed is increased or reduced by 0.5 m/min.
    In the example shown, the stabilising effect is obtained without a change in current up to the set value of 0.5 m/min (Position 2).
    I ... Welding current vD  ... Wire speed
    1. Setup settings
    The arc length stabilizer forces short arcs, advantageous for welding, via a short-circuit current control and keeps them stable even with a variable stickout or external interference.
    The arc length stabilizer welding parameter is only available if the WP PMC (Welding Process Pulse Multi Control) option has been enabled on the welding machine.
    0.0 / auto / 0.1-5.0 (effect of stabilizer)
    0.0
    The arc length stabilizer is deactivated.
    auto
    • For inert gases (100% Ar, He, etc.) a value = 0 is stored.
    • For the remaining materials / gas combinations, a characteristic-dependent value between 0.2-0.5 is stored.
    • From a wire speed of 16 m/min a value = 0 is stored
    0.1-5.0
    The arc length stabilizer is activated.
    The arc length is decreased until short circuits start to occur.
    NOTE!
    If the arc length stabilizer is activated, the normal arc length correction is only effective at the start of welding.
    The arc length correction is then no longer displayed in the welding parameters.
    Arc length stabilizer = 0 / 0.5 / 2.0
      Arc length stabilizer = 0.5
      Arc length stabilizer = 2
    Activating the arc length stabilizer reduces the arc length until short circuits start to occur. The advantages of a short, stable and controlled arc can be used more effectively as a result.
    Increasing the arc length stabilizer causes a further shortening of the arc length (L1 ==> L2 ==> L3). The advantages of a short, stable and controlled arc can be used more effectively.
    Arc length stabilizer with change of weld seam profile and position
    Arc length stabilizer not activated
    A change of weld seam profile or welding position can negatively affect the welding result
    Arc length stabilizer activated
    Since the number and duration of the short circuits is controlled, the properties of the arc stay the same if the weld seam profile or welding position is changed.
    I ... Welding current vD ... Wire speed U ... Welding voltage
    * ... Number of short circuits
    1. Setup settings
    Combination of penetration stabilizer and arc length stabilizer
    Example: Stick out change
    Arc length stabilizer without penetration stabilizer
    The advantages of a short arc are maintained even if the stick out is changed, since the short-circuit properties stay the same.
    Arc length stabiliser with penetration stabilizer
    If the stick out is changed with the penetration stabilizer activated, the penetration also stays the same.
    The short circuit behaviour is controlled by the arc length stabilizer.
    * ... Number of short circuits Δs ... Stick out change
    1. Setup settings
    Process parameters for spot welding
    SPt
    Spot welding time
    0.1 - 10.0  s
    1. Setup settings
    Process parameters for stitch welding
    Int
    Interval
    off / on
    Int-t
    Stitch welding time
    0.1 - 10.0  s
    Int-b
    Interval break time
    off / 0.1 - 10 s
    Int-C
    Interval cycles
    constant / ...
    Factory setting: constant
    1. Setup settings
    Process parameters for monitoring and components
    The following process parameters can be set and displayed for the system components of a welding system:
    C-C
    Cooling unit mode
    To determine whether a cooling unit is to be switched on or off, or operated automatically
    Setting range: eco / auto / on / off (depending on the cooling unit)
    C-t
    Delay time flow sensor
    For setting the time from when the flow sensor responds until a warning message is output
    Setting range: 5 - 25 s
    Factory setting: 10 s
    CFU
    Cooler flow warning limit
    Setting range: off / 0.75 - 0.95 l/min
    Fdi
    Feeder inching speed
    in m/min (ipm)
    For setting the wire speed at which the wire electrode is threaded into the torch hosepack
    Setting range:
    min. - max. (depending on the wire speed)
    Factory setting: 10.0 m/min
    ito
    Ignition time-out
    Length of wire that is fed before the safety cut-out trips
    Setting range: off / 5 - 100 mm (0.2 - 3.94 in.)
    The ignition time-out process parameter is a safety function. The length of wire that is fed before the safety cut-out trips may differ from the pre-set wire length, particularly when the wire is being fed at fast wire speeds.
    How it works:
    Once the torch trigger is pressed, gas pre-flow begins immediately. Wirefeeding then begins, followed by ignition. If no current starts flowing before the specified length of wire has been fed, the power source cuts out automatically.
    To try again, press the torch trigger again.
    GSL
    Lower gas flow rate limit
    Setting range: 0.5 - 30.0 l/min
    Factory setting: 7.0 l/min
    GSt
    Maximum duration of gas flow deviation
    Setting range: off; 0.1 - 10.0 s
    Factory setting: 2.0 s
    GSF
    Gas factor sensor
    Dependent on the shielding gas used
    (only in conjunction with the OPT/i gas controller option)
    Setting range: auto, 0.90 - 20.0
    FFR
    Reaction in case of deviation of the wire speed force
    Setting range: Ignore / Warning / Error
    Factory setting: Ignore
    FFu
    Upper wire feed speed force
    Setting range: 0 - 999 N
    Factory setting: 0 N
    FFt
    Max. duration of wire speed deviation
    Factory setting: 3.0 s
    1. Setup settings
    Process parameters for electrode setup
    The following process parameters can be set and displayed for manual metal arc welding (STICK):
    I-S
    Starting current
    Factory setting: 150%
    Hti
    For setting the length of time for which the starting current is to be active
    Setting range: 0.0 - 2.0 s
    Eln
    Characteristic
    For selecting the electrode characteristic
    Setting range: I-constant / 0.1 - 20.0 A/V / P-constant
    Factory setting: I-constant
    (1)
    Load line for rod electrode
    (2)
    Load line for rod electrode where arc length is increased
    (3)
    Load line for rod electrode where arc length is reduced
    (4)
    Characteristic where "I-constant" parameter is selected (constant welding current)
    (5)
    Characteristic where "0.1-20" parameter is selected (drooping characteristic with adjustable slope)
    (6)
    Characteristic where "P-constant" parameter is selected (constant welding power)
    (7)
    Example of pre-set arc-force dynamic where characteristic (4) is selected
    (8)
    Example of pre-set arc-force dynamic where characteristic (5) or (6) is selected
    I-constant (constant welding current)
    • If the "I-constant" parameter is set, the welding current will be kept constant, irrespective of the welding voltage. This results in a vertical characteristic (4).
    • The "I-constant" parameter is particularly suitable for rutile electrodes and basic electrodes.
    0.1-20.0 A/V (drooping characteristic with adjustable slope)
    • Parameter "0.1-20" is used to set a drooping characteristic (5). The setting range extends from 0.1 A / V (very steep) to 20 A / V (very flat).
    • Setting a flat characteristic (5) is only advisable for cellulose electrodes.
    P-constant (constant welding power)
    • If the "P-constant" parameter is set, the welding power is kept constant, irrespective of the welding voltage and welding current. This results in a hyperbolic characteristic (6).
    • The "P-constant" parameter is particularly suitable for cellulose electrodes, as well as for arc air gouging.
    • For arc air gouging, set the arc-force dynamic to "100".
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (8)
    (9)
    Possible change in the current where characteristic (5) or (6) is selected, as a function of the welding voltage (arc length)
    (a)
    Operating point where arc length is long
    (b)
    Operating point where welding current IH is set
    (c)
    Operating point where arc length is short
    The characteristics (4), (5) and (6) shown here apply when using a rod electrode whose characteristic corresponds, at a given arc length, to the load line (1).
    Depending on what welding current (I) has been set, the point of intersection (operating point) of characteristics (4), (5) and (6) will be displaced along the load line (1). The operating point provides information on the actual welding voltage and the actual welding current.
    Where the welding current (IH) is permanently set, the operating point may migrate along the characteristics (4), (5) and (6) according to the welding voltage at a given moment. The welding voltage U is dependent upon the arc length.
    If the arc length changes (e.g. in accordance with the load line (2)) the resulting operating point will be the point where the corresponding characteristic (4), (5) or (6) intersects with the load line (2).
    Applies to characteristics (5) and (6): Depending upon the welding voltage (arc length), the welding current (I) will also become either smaller or larger, even though the value set for IH remains the same.
    Ast
    Anti-stick
    To activate/deactivate the anti-stick function
    Factory setting: on
    As the arc becomes shorter, the welding voltage may drop so far that the rod electrode will tend to stick. This may also cause the rod electrode to burn out.
    The anti-stick function prevents the electrode from burning out. If the rod electrode begins to stick, the welding machine switches the welding current off after 1.5 seconds. After the rod electrode has been lifted off the workpiece, the welding process can be continued without any problems.
    Uco
    Break voltage
    For setting a voltage, at which the welding process can be ended by slightly lifting the rod electrode.
    Setting range: 20.0 - 90.0 V
    Factory setting: 90.0 V
    The arc length depends on the welding voltage. To end the welding process, it is usually necessary to significantly lift the rod electrode away from the workpiece. With the break voltage parameter, the welding voltage can be limited to a value that makes it possible to end the welding process simply by lifting the rod electrode slightly.
    IMPORTANT! If, during welding, you often find that the welding process is ended unintentionally, increase the value of the break voltage.
    1. Setup settings
    Process parameters for TIG setup
    The following process parameters can be set and displayed for TIG welding:
    Uco
    Break voltage
    For setting a voltage, at which the welding process can be ended by slightly lifting the TIG welding torch.
    Setting range: 10.0 - 30.0 V
    Factory setting: 14.0 V
    CSS
    Comfort Stop Sensitivity
    To activate/deactivate the TIG Comfort Stop function
    Setting range: off / 0.1 - 2.0 V
    Factory setting: 0.8 V
    At the end of the welding operation, the welding current is switched off automatically if the arc length increases by more than a defined amount. This prevents the arc being unnecessarily elongated when the TIG gas-valve torch is lifted off the workpiece.
    Sequence:
    1Welding
    2At the end of the welding action, briefly raise the welding torch
    The arc length is increased significantly.
    3Lower the welding torch
    • The arc length is reduced significantly
    • The TIG Comfort Stop function is triggered
    4Keep the welding torch at the same height
    • The welding current is continuously decreased (downslope).
    • The arc goes out.
    IMPORTANT! The downslope is pre-set and cannot be adjusted.
    5 Raise the welding torch from the workpiece
    1. Setup settings
    Process parameters for SynchroPulse
    The following process parameters can be set for SynchroPulse welding:
    Syn-Puls
    SynchroPulse
    To activate/deactivate SynchroPulse
    vd (1)
    Wire speed
    For setting the average wire speed and therefore the welding power for SynchroPulse
    Setting range: 1.0 - 25.0 m/min (40 - 985 ipm)
    Factory setting: 5 m/min
    dFd (2)
    Delta wire feed
    For setting the Delta wire feed:
    with SynchroPulse, the set wire speed is alternately increased/decreased by the Delta wire feed. The parameters concerned adapt themselves to this wire speed acceleration/delay accordingly.
    Setting range: 0.1 - 6.0 m/min (5 - 235 ipm)
    Factory setting: 2.0 m/min
    F (3)
    Frequency
    For setting the frequency for SynchroPulse
    Setting range: 0.5 - 3.0 Hz
    Factory setting: 3.0 Hz
    DC (4)
    Duty Cycle (high)
    For weighting the duration of the higher operating point in a SynchroPulse period
    Setting range: 10 - 90%
    Factory setting: 50%
    Al-h (5)
    Arc length correction high
    For correcting the arc length for SynchroPulse in the upper operating point (= average wire speed plus Delta wire feed)
    Setting range: -10.0 - +10.0
    Factory setting: 0
    - .... short arc
    0 ... uncorrected arc length
    + ... longer arc
    Al-l (6)
    Arc correction low
    For correcting the arc length for SynchroPulse in the lower operating point (= average wire speed less Delta wire feed)
    Factory setting: 0
    - .... short arc
    + ... longer arc
    1. Setup settings
    Process parameters for Process Mix
    The following process parameters for mixed processes can be set under "Process mix":
    Mixed process between PMC and LSC welding process. A cold LSC process phase follows a hot PMC process phase as part of a cycle.
    Mixed process between PMC and wire movement reversal using a PushPull drive unit. A cold low power phase with calibration movement follows a hot PMC process phase.
    Mixed process between CMT and PMC welding process. Cold CMT process phases follow hot PMC process phases.
    (1)
    Lpc - Lower power correction
    (2)
    Lptc - Lower power time correction
    (3)
    Hptc - Upper power time correction
    vd
    Wire speed
    Is taken from the welding parameters
    The wire speed value can also be specified or changed in the Process mix parameters.
    Alc
    The arc length correction value can also be specified or changed in the Process mix parameters.
    For CMT mix:
    Positive correction:
    increase in the pulsed voltage for the PMC phase
    longer reverse movement in the CMT phase (increases arc length)
    Negative correction:
    reduction in the pulsed voltage for the PMC phase
    shorter reverse movement in the CMT phase (reduces arc length)
    PDc
    Pulse/dynamic correction
    The pulse/dynamic correction value can also be specified or changed in the Process mix parameters.
    For CMT mix:
    increase in the pulse energy (pulse current height, pulse current width)
    Reduction in the pulse frequency in the PMC phase
    reduction in the pulse energy (pulse current height, pulse current width)
    Increase in the pulse frequency in the PMC phase
    Hptc (3)
    To set the duration of the hot process phase in a mixed process
    Factory setting: 0
    Lptc (2)
    To set the duration of the cold process phase in a mixed process
    Upper and lower power time correction is used to define the relationship between hot and cold process phases.
    If the lower power time correction is increased, the process frequency reduces and the LSC process phase becomes longer.
    If the lower power time correction is reduced, the process frequency increases and the LSC process phase becomes shorter.
    Lpc (1)
    To set the energy input in the cold process phase in a mixed process
    Factory setting: 0
    If the lower power correction is increased, this results in a higher wire speed and therefore higher energy yield in the cold LSC process phase.
    1. Setup settings
    R/L alignment
    Align the welding circuit resistance (R) and welding circuit inductivity (L) if one of the following components of the welding system is changed:
    • Torch hosepacks
    • Return lead cables, welding power-leads
    • Welding torches, electrode holders
    • Push-pull units
    Prerequisites for R/L alignment:
    The welding system must be complete: closed welding loop with torch and torch hosepack, wirefeeders, return lead cable, interconnecting hosepacks.
    Performing R/L alignment:
    1Select Setup menu / Process param. / R/L-check / alignment
    The current welding circuit inductivity values in µH and welding circuit resistance values in mOhm are displayed.
    3Press the right adjusting dial (or press the torch trigger)
    "Connect earth" is shown on the display.
    4Establish a safe ground earth connection
    IMPORTANT! Contact between the earthing clamp and workpiece must be established on a cleaned area of the workpiece.
    5Press the right adjusting dial (or press the torch trigger)
    "Remove nozzle" is shown on the display.
    6Remove the gas nozzle from the welding torch
    7Press the right adjusting dial (or press the torch trigger)
    "Contact workp." is shown on the display.
    8Place the contact tip of the welding torch flush against the workpiece surface
    9Press the torch trigger
    (or press the right adjusting dial)
    After a successful measurement, the current values are displayed.
    10Select "Finish" by turning the right adjusting dial
    11Press the right adjusting dial
    12To exit the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    1. Setup settings
    Settings
    General
    NOTE!
    As a result of firmware updates, you may find that there are functions available on your device that are not described in these operating instructions or vice versa.
    Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    WARNING!
    Fully read and understand this document.
    1. Setup settings
    2. Settings
    General
    NOTE!
    WARNING!
    1. Setup settings
    2. Settings
    Overview
    The settings contain the following options:
    Under "View"
    • Unit
    • Standard
    • Hold mode
    • UIBS - display brightness
    • DRSL - display replaced characteristics
    • F1/F2 - setting F1 and F2 special function parameters
    • Set the parameters for the Favourites button
    • System data
    Under "System"
    • CLS - Interior lighting setup
    • FAC - Restore factory settings
    • Web-PW reset - Reset the password for the welding machine website
    • USB - Settings for the USB port
    • Information
    • iJob - Jobmaster special display
    • Spm - Spot welding operating mode
    1. Setup settings
    2. Settings
    View - Setting the units
    1Select Setup menu / Settings / View / Unit
    The first of the available units is displayed.
    3Select the desired unit by turning the right adjusting dial:
    • metric (mm, kg, etc.)
    • imperial (in., lbs., etc.)
    4Press the right adjusting dial to apply the units
    5To exit the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    1. Setup settings
    2. Settings
    View - Setting the standards
    1Select Setup menu / Settings / View / Standard
    The first of the available standards is displayed.
    3Select the desired standard by turning the right adjusting dial:
    • CEN
      Name of filler metal according to European standards
      (e.g. AlMg 5, CuSi3, Steel, etc.)
    • AWS
      Name of filler metal according to the American Welding Society Standard
      (e.g. ER 5356, ER CuSi-A, ER 70 S-6, etc.)
    4Press the right adjusting dial to set the standard
    1. Setup settings
    2. Settings
    View - Setting hold mode
    1Select Setup menu / Settings / View / Hold-M.
    The first of the available hold modes is displayed.
    3Turn the right-hand dial to select the desired display of the welding data at the end of welding:
    • Hold
      The current actual values at the end of welding are displayed.
    • Mean
      The mean values over the entire main current phase are displayed.
    4Press the right adjusting dial to set the hold mode
    1. Setup settings
    2. Settings
    View - Setting the display brightness
    1Select Setup menu / Settings / View / UIBS
    UIBS = User interface brightness settings
    The value for the display brightness is shown.
    3Select the desired display brightness by turning the right adjusting dial (1 - 4)
    4Press the right adjusting dial to apply the value
    1. Setup settings
    2. Settings
    View - Display replaced characteristics
    1Select setup menu / Settings / View / DRSL
    DRSL = Display replaced synergic lines
    3Select "on" by turning the right adjusting dial
    4Press the right adjusting dial to activate the function
    1. Setup settings
    2. Settings
    View - Setting F1 and F2 special function parameters via the Setup menu
    1Select Setup menu / Settings / View / F1/F2 Param.
    The parameters currently stored under F1 and F2 are displayed.
    If no parameters are stored, the first possible parameter is displayed.
    3Select the desired parameter by turning the right adjusting dial
    5Turn the right adjusting dial to determine under which special function the parameter should be stored:
    - ... the parameter is not assigned to a special function/a stored parameter is deleted
    F1 ... parameter is stored under special function F1
    F2 ... parameter is stored under special function F2
    6Press the right adjusting dial to confirm the selection
    7To exit the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    1. Setup settings
    2. Settings
    View - Setting the Favourites button via the Setup menu
    1Select Setup menu / Settings / View / Favourite
    The list of parent folders and parameters is displayed.
    If a parameter or a folder is currently stored under the Favourites button, this is indicated with    at the end of the display.
    3Select the desired parameter or folder by turning the right adjusting dial
    5Turn the right adjusting dial to determine whether the parameter or folder should be stored under the Favourites button:
    - ... parameter or folder is not stored
       ... parameter or folder is stored
    The stored parameter or folder is indicated with    at the end of the display.
    1. Setup settings
    2. Settings
    View - Retrieving system data
    1Select Setup menu / Settings / View / System data
    The first available system data value is displayed.
    3Select the desired system data value by turning the right adjusting dial
    4To exit the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    The following system data can be displayed:
    IP
    Current arc power in kW
    The arc power is the product of welding current and welding voltage and is used to calculate the electrical energy per unit length:
    E = IP / vs
    E
    Electrical energy per unit length in kJ/cm
    IP
    Arc power in kW
    vs
    Welding speed in cm/s
    IE
    Current arc energy in kJ
    The arc energy is the sum total of the arc power and calculates the heat input of the weld seam most recently produced.
    If the weld seam length is known the electrical energy per unit length can be calculated:
    E = IE / L
    E
    IE
    Arc energy in kJ
    L
    Length of the weld in cm
    The arc energy is preferably used during manual welding.
    I-M1
    Current motor current in A, wirefeeder 1
    (wirefeeder next to the arc)
    I-M2
    Current motor current in A, wirefeeder 2
    (e.g. the rear wirefeeder in a push-pull system)
    I-M3
    Current motor current in A, wirefeeder 3
    (e.g. an unreeling wirefeeder in a push-pull system with unreeling wirefeeder)
    CFI
    Current flow rate in l/min on the cooling unit
    (with built-in OPT/i CU flow temperature sensor option)
    Error output if flow rate < 0.7 l/min
    CU-t
    Current coolant temperature in °C on the cooling unit
    Error output if coolant temperature > 70 °C
    (measured during coolant return)
    I-t
    Arc time in h
    DC-t
    Total welding machine operating hours in h
    Gcon
    Total gas consumption in l
    1. Setup settings
    2. Settings
    System - Setting the interior lighting
    link_horizontalLink copied
    1Select Setup menu / Settings / System / CLS
    3Select the desired duration by turning the right adjusting dial:
    off ... interior lighting switched off
    1 - 60 ... interior lighting is switched on for the duration entered
    on ... interior lighting is switched on permanently
    1. Setup settings
    2. Settings
    System - Restoring factory settings
    1Select Setup menu / Settings / System / FAC
    3Turn the right adjusting dial to select "Yes", thereby restoring the welding machine to the factory settings
    The process parameters and machine default values are immediately reset to the factory settings without any further warning.
    1. Setup settings
    2. Settings
    System - Resetting the password for the welding machine website
    1Select Setup menu / Settings / System / Web-PW reset
    3Turn the right adjusting dial to select "Yes", thereby resetting the password for the welding machine website to the factory settings
    Factory settings
    1. For devices supplied with firmware version ≥ 4.3.15:User name = admin
      Password = 20-digit number on the welding machine rating plate (unique password)
    2. For devices supplied with an earlier version:
      User name = admin
      Password = admin
      In the case of devices supplied with earlier versions, the factory setting is always admin / admin regardless of any firmware updates.
    The password is immediately reset to the factory settings without any further warning.
    1. Setup settings
    2. Settings
    System - USB port settings
    1Select Setup menu / Settings / System / USB
    3Select the desired setting for the USB port on the control panel by turning the right adjusting dial:
    off:
    No data exchange possible on the USB port.
    restricted:
    Licence-Key and Service-Dongle possible
    on:
    No restriction on the USB port
    The setting is applied.
    1. Setup settings
    2. Settings
    System - Retrieving device information
    1Select Setup menu / Settings / System / Information
    The first item of available information is displayed.
    3Select the desired information by turning the right adjusting dial
    Serial number
    Image version
    IP address
    MAC address
    4Press the right adjusting dial to display the information
    1. Setup settings
    2. Settings
    System - Setting the special display for JobMaster
    1Select Setup menu / Settings / System / iJob
    3Activate or deactivate the function by turning the right adjusting dial:
    off ... the special display for JobMaster is deactivated
    on ... the special display for JobMaster is activated
    The following can now be set and carried out on the JobMaster welding torch:
    • Operating mode
    • SynchroPulse
    • Gas test
    1. Setup settings
    2. Settings
    System - Setting the mode for spot welding
    1Select Setup menu / Settings / System / SPm
    2Press the adjusting dial
    3Turn the adjusting dial and select the desired mode for spot welding
    2-step = spot welding in 2-step mode:
    The spot welding process runs for as long as the torch trigger is kept pressed and ends no later than at the expiry of the spot welding time.
    Releasing the torch trigger stops the spot welding process before the spot welding time expires
    4-step = spot welding in 4-step mode:
    The spot welding process starts once the torch trigger is pressed and ends no later than at the expiry of the spot welding time.
    Press the torch trigger again to stop the spot welding process before the spot welding time expires.
    More information on spot welding:
    • Page (→) (spot welding in general)
    • Page (→) (spot welding time)
    1. Setup settings
    Setting the language
    1Access the Setup menu
    2Select the language
    The language abbreviation of the currently set language is highlighted on the display.
    4Select the desired language by turning the right adjusting dial
    The following languages can be selected:
    cs
    Czech
    da
    Danish
    de
    German
    en
    English
    es
    Spanish
    et
    Estonian
    fr
    French
    hr
    Croatian
    hu
    Hungarian
    it
    Italian
    lt
    Lithuanian
    lv
    Latvian
    nl
    Dutch
    no
    Norwegian
    pl
    Polish
    pt
    Portuguese (Brazil)
    ro
    Romanian
    ru
    Russian
    sk
    Slovak
    sl
    Slovenian
    sr
    Serbian
    sv
    Swedish
    tr
    Turkish
    uk
    Ukrainian
    5Press the right adjusting dial to apply the language
    6To exit the Setup menu, press the "Welding process" and "Mode" buttons at the same time
    1. Setup settings
    2. Setting the language
    cs
    Czech
    da
    Danish
    de
    German
    en
    English
    es
    Spanish
    et
    Estonian
    fr
    French
    hr
    Croatian
    hu
    Hungarian
    it
    Italian
    lt
    Lithuanian
    lv
    Latvian
    nl
    Dutch
    no
    Norwegian
    pl
    Polish
    pt
    Portuguese (Brazil)
    ro
    Romanian
    ru
    Russian
    sk
    Slovak
    sl
    Slovenian
    sr
    Serbian
    sv
    Swedish
    tr
    Turkish
    uk
    Ukrainian
    1. Setup settings
    Keylock
    Keylock
    To activate the keylock
    1Press the "Welding process" and left parameter selection buttons at the same time
    Alternatively, the "Mode" and right parameter selection buttons can be pressed.
    The key symbol and a tick are shown on the display:
    The following functions are disabled:
    • the adjusting dial functions
    • selection of the filler metal
    • saving and deleting EasyJobs
    • the "Mode" button
    • the "Welding process" button
    • the Setup menu
    The following functions are available:
    • the "Filler metal info" button
    • retrieving EasyJobs
    • the "Wire threading" button
    • the "Gas-test" button
    • the parameter selection buttons
    To unlock keys again
    The key symbol and a X are shown on the display:
    1. Setup settings
    2. Keylock
    Keylock
    • the "Mode" button
    • the Setup menu
    SmartManager - the welding machine website
    General
    The welding machines have their own website: SmartManager.
    As soon as the welding machine is connected to a computer using a network cable, or is on a network, the welding machine's SmartManager can be retrieved using the welding machine's IP address.
    At least IE 10 or a similar modern browser is required to access SmartManager.
    The entries displayed on SmartManager may vary depending on system configuration, software upgrades and available options.
    Examples of entries displayed:
    • Current system data
    • Documentation, logbook
    • Job data
    • Power source* settings
    • Backup & restore
    • User management
    • Signal visualisation
    • Overview
    • Update
    • Function packages
    • Characteristics overview
    • Screenshot
    • Robot interface **
    Power source = welding machine
    Depending on the available robot interface, the name of the interface will be displayed as an entry on the website.
    1. SmartManager - the welding machine website
    General
    • Job data
    • Backup & restore
    • User management
    • Overview
    • Update
    • Function packages
    • Screenshot
    2. SmartManager - the welding machine website
    General
    • Job data
    • Backup & restore
    • User management
    • Overview
    • Update
    • Function packages
    • Screenshot
    Opening the welding machine SmartManager
    1Setup menu / Settings / System / Information ==> note the IP address of the welding machine (IP)
    2Enter the IP address in the browser search field
    3Enter the user name and password
    Factory settings for user name and password
      User name = admin
      Password = admin
    4Confirm the displayed notice.
    The unique password does not have to be changed when logging in to the SmartManager for the first time.
    The SmartManager of the welding machine is displayed.
    Changing password / logging off
    By clicking this symbol
    • the user password can be changed
    • you can log out of SmartManager
    Changing the password for the SmartManager:
    1Enter the old password
    2Enter the new password*
    3Repeat the new password
    4Click on "Save"
    A password must meet the following criteria:
    • The password must be at least 10 and at most 16 characters long.
    • Three of the following four criteria must be met:
      Uppercase letters A - Z
      Lowercase letters a - z
      Digits 0 - 9
      Special characters , . @ = + - * / ~ " ° _ # ( ) ! ? & % : ;
    Settings
    Clicking on this symbol expands the display of characteristics, material specifications and certain welding parameters for the welding machine's SmartManager.
    The settings depend on which user is currently logged on.
    Language selection
    The languages available for SmartManager can be displayed by clicking on the language abbreviation.
    To change the language, click on the one you would like.
    Fronius
    A click on the Fronius logo opens the homepage of Fronius: www.fronius.com.
    Current system data
    Current system data
    The welding system's current data is displayed.
    NOTE!
    The system data displayed will vary depending on the welding process, equipment and Welding Packages.
    E.g. system data for MIG/MAG:
    (1)
    Device type
    (2)
    Device name
    (3)
    Plant
    (4)
    Production building (hall)
    (5)
    Cell
    (6)
    Filler (addition)
    (7)
    Welding process
    (8)
    Actual values / HOLD or average values (depending on setting)
    (9)
    Welding current
    (10)
    Welding voltage
    (11)
    Wire speed
    (12)
    Arc time
    (13)
    Arc energy
    (14)
    Arc power
    (15)
    Welding current set value
    (16)
    Welding voltage set value
    (17)
    Wire speed set value
    (18)
    (19)
    (20)
    Arc power
    (21)
    (22)
    (23)
    Total shielding gas consumption
    (24)
    Total arc time
    (25)
    Total operating hours of the welding machine
    (26)
    Operating mode
    (27)
    Filler metal, shielding gas, characteristic, diameter, ID
    (28)
    Process functions
    (29)
    Full-screen mode
    2. Current system data
    Current system data
    NOTE!
    (1)
    Device type
    (2)
    Device name
    (3)
    Plant
    (4)
    (5)
    Cell
    (6)
    Filler (addition)
    (7)
    Welding process
    (8)
    (9)
    Welding current
    (10)
    Welding voltage
    (11)
    Wire speed
    (12)
    Arc time
    (13)
    Arc energy
    (14)
    Arc power
    (15)
    (16)
    (17)
    (18)
    (19)
    (20)
    Arc power
    (21)
    (22)
    (23)
    (24)
    Total arc time
    (25)
    (26)
    Operating mode
    (27)
    (28)
    Process functions
    (29)
    Full-screen mode
    Job-Data
    Job data
    The EasyJobs stored on the welding machine can be viewed in the Job Data entry under Job Overview and exported as a PDF file.
    2. Job-Data
    Job data
    Backup & Restore
    General remarks
    In the backup & restore entry
    • all welding system data can be saved as a backup (e.g. current parameter settings, jobs, user characteristics, defaults, etc.),
    • any backups will be restored to the welding system
    • You can select which data you would like to be backed up automatically.
    2. Backup & Restore
    General remarks
    2. Backup & Restore
    Backup & Restore
    Starting backup
    1Click on "Start backup" to save a backup of the welding system data
    The data is saved in a selected location in the default format MCU1-YYYYMMDDHHmm.fbc.
    YYYY = Year
    MM = Month
    DD = Day
    HH = Hour
    mm = Minute
    The date and time correspond to the welding machine settings.
    Searching for a restore file
    1Click on "Search restore file" to transfer an existing backup to the welding machine
    2Select the file and click on "Open"
    The selected backup file is displayed on the welding machine's SmartManager under "Restore".
    3Click on "Start recovery"
    Once the data has been successfully restored, a confirmation to this effect is displayed.
    2. Backup & Restore
    Automatic backup
    1Enable interval settings
    2Enter the intervals at which the automatic backup should take place:
    • Interval:
      daily / weekly / monthly
    • At:
      time (hh:mm)
    3Enter the data for the backup destination:
    • Protocol:
      SFTP (Secure File Transfer Protocol) / SMB (Server Message Block)
    • Server:
      Enter IP address of the destination server
    • Port:
      Enter port number; if no port number is entered, the default port 22 is automatically used.
      If SMB is set under Protocol, leave the Port field blank.
    • Storage location:
      This configures the subfolder where the backup will be stored.
      If no storage location is entered, the backup is stored in the root directory of the server.
      IMPORTANT! For SMB and SFTB, always enter the storage location with a slash "/".
    • Domain/user, password:
      User name and password - as configured on the server;
      When entering a domain, first enter the domain, then backslash "\" and then the user name (DOMAIN\USER)
    4If a connection via proxy server is required, activate and enter the proxy settings:
    • Server
    • Port
    • Users
    • Password
    5Save changes
    6Trigger automatic backup
    If you have any questions about the configuration, contact your network administrator.
    Overview
    Overview
    In the overview entry, welding system components and options are displayed with all available information, e.g. firmware version, item number, serial number, production date, etc.
    2. Overview
    Overview
    2. Overview
    Expanding / reducing all groups
    Clicking on the button "Expand all groups" displays further details for the individual system components.
    Welding machine example:
    • TPSi: Item number
      RD-LCU1: Item number, version, serial number, production date
      Bootloader: Version
      Image: Version
      Licences: WP Standard, WP Pulse, WP LSC, WP PMC, etc.
    • SC2: Item number
      Firmware: Version
    Clicking on the button "Reduce all groups" hides the details for the system components.
    2. Overview
    Export component overview as ...
    Click the "Export component overview as ..." button to create an XML file of the system component details. This XML file can either be opened or saved.
    Update
    Update
    The welding machine firmware can be updated in the "Update" entry.
    The current version of the firmware on the welding machine is displayed.
    Update welding machine firmware:
    Firmware link:
    The update file can be downloaded via the link provided:
    Firmware TPS/i_iWAVE
    1Organise and save the update file
    2Click on "Search update file" to start the update process
    3Select update fileClick on "Update"
    Once the update has been successfully completed, the welding machine may need to be restarted.
    When an update has been completed successfully, a confirmation to this effect is displayed.
    2. Update
    Update
    Firmware link:
    2. Update
    Searching for an update file (performing the update)
    1After clicking on "Search update file", select the desired firmware (*.ffw)
    2Click on "Open"
    The selected update file is displayed on the welding machine's SmartManager under "Update".
    3Click on "Update"
    A progress bar is displayed above the update process.
    When this reaches 100%, you will be prompted to restart the welding machine.
    SmartManager is not available during the restart.
    After the restart, SmartManager may not be available any more.
    If you select "No", the new software functions are activated when you next switch the device on/off.
    4To restart the welding machine, click on "Yes"
    The welding machine restarts; the display goes black for a short time.
    The Fronius logo is shown on the welding machine display during the restart.
    Once the update has been completed successfully, confirmation and the current firmware version are displayed.
    Finally, log back on to SmartManager.
    2. Update
    Fronius WeldConnect
    The mobile application Fronius WeldConnect can also be called up in the "Update" entry.
    WeldConnect is an app for wireless interaction with the welding system.
    The following functions can be performed with WeldConnect:
    • Current unit configuration at a glance
    • Mobile access to the welding machine's SmartManager
    • Automatic determination of the output parameters for MIG/MAG and TIG
    • Cloud storage and wireless transmission to the welding machine
    • Part identification
    • Logging in and out of the welding machine without an NFC card
    • Saving and sharing parameters and jobs
    • Data transfer from one welding machine to another via backup, restore
    • Firmware update
    Fronius WeldConnect is available in the following forms:
    • As an Android app
    • As an Apple/iOS app
    Further information on Fronius WeldConnect is available at:
    https://www.fronius.com/en/welding-technology/innovative-solutions/weldconnect
    Function Packages
    Function packages
    The following data can be displayed under Function Packages:
    • Welding Packages available on the welding machine
      (e.g. WP STANDARD, WP PULSE, WP LSC, etc.)
    • Options available on the welding machine (OPT/i, etc.)
    2. Function Packages
    Function packages
    Installing a function package
    1Organise and save a function package
    2Click on "Search function package file"
    3Select the desired function package file (*.xml)
    4Click on "Open"
    The selected function package file is displayed on the welding machine's SmartManager under "Install function package".
    5Click on "Install function package"
    Once the function package has been successfully installed, a confirmation to this effect is displayed.
    Synergic lines overview
    In the Characteristics overview entry:
    • Available characteristics in the welding system can be displayed:
      Available characteristics button
    • Possible characteristics in the welding system can be displayed:
      Possible characteristics button
    • Characteristics for the welding system can be preselected:
      Characteristic preselection button
    • Saved characteristic preselections can be exported and imported:
      Export & import button
    You can search for, sort and filter the displayed characteristics at any time.
    The following information is displayed for the characteristics:
    • Status
    • Materials
    • Diameter
    • Gas
    • Property
    • Process
    • ID
    • Replaced by
    • SFI
    • SFI HotStart
    • Penetration stabilizer
    • Arc length stabilizer
    • CMT Cycle Step
    • Special
    • Requirements
    To sort the characteristics in ascending or descending order, click on the arrow next to the respective information.
    The column widths can be easily dragged and adjusted with the cursor.
    2. Synergic lines overview
    • Status
    • Materials
    • Diameter
    • Gas
    • Property
    • Process
    • ID
    • Replaced by
    • SFI
    • SFI HotStart
    • CMT Cycle Step
    • Special
    • Requirements
    Show filter
    Clicking on the "Show filter" symbol displays the possible filter criteria. With the exception of "ID" and "Replaced by", the characteristics can be filtered by all information.
    First selection box = select all
    To hide the filter criteria, click on the "Hide filter" symbol.
    Screenshot
    Screenshot
    In the Screenshot entry, a digital image of the welding machine display can be created at any time, irrespective of the navigation or set values.
    1Click on "Create screenshot" to capture a screenshot of the display
    A screenshot of the currently displayed settings is created.
    Different functions are available for saving the screenshot depending on the browser used; the display may vary.
    2. Screenshot
    Screenshot
    Troubleshooting and maintenance
    The Error menu
    The Error menu
    Notifications, warnings and errors are shown on the display with the corresponding number.
    If an error occurs, the Error menu is always in the foreground.
    Pressing the right adjusting dial opens the Error menu on "confirm".
    Pressing the right adjusting dial a second time confirms the error; the Error menu closes.
    By turning the right adjusting dial you can navigate between "Cause", "Solution" and "Hide".
    If you select "Cause" or "Solution", the corresponding description is displayed when the right adjusting dial is pressed.
    Turn the left or right adjusting dial to scroll through the displayed text.
    Pressing the right adjusting dial takes you back to the Error menu.
    If you select "Hide", the Error menu closes, however, the error will not be reset. The top right LED flashes on the display to show that there is a hidden, not reset error. The error can now be called up as the first entry in the Setup menu.
    To enter the Setup menu, press the "Welding process" and "Mode" buttons at the same time.
    1. Troubleshooting and maintenance
    The Error menu
    The Error menu
    2. The Error menu
    The Error menu
    Care, maintenance and disposal
    General
    Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the device remains in a usable condition for many years.
    2. Care, maintenance and disposal
    General
    Safety
    WARNING!
    Danger from electric current.
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    At every start-up
    • Check mains plug, mains cable, welding torch, interconnecting hosepack and grounding (earthing) connection for damage
    • Check whether the all-round clearance of 0.5 m (1 ft. 8 in.) is kept to ensure that the cooling air can easily flow and escape.
    NOTE!
    Air inlets and outlets must never be covered, not even partially.
    If necessary
    If a lot of dust has accumulated:
    • Remove the fin element on the rear of the housing
    • Detach the air filter located behind and clean
    Every 2 months
    • If present: clean air filter
    Every 6 months
    NOTE!
    Danger due to the effect of compressed air.
    Do not clean electronic components with compressed air at close distance.
    • Open the device
    • Clean out the device interior using dry compressed air at reduced pressure
    • If a lot of dust has accumulated, clean the cooling air ducts
    Updating firmware
    IMPORTANT! To update the firmware, you need a PC or laptop that is connected to the welding machine via an Ethernet network.
    1Get latest firmware (e.g. from the Fronius DownloadCenter)
    File format: official_tpsi_x.x.x-xxxx.ffw
    2Establish Ethernet connection between PC/laptop and welding machine
    3Open the welding machine's SmartManager (see page (→))
    4Transfer the firmware to the welding machine (see page (→))
    Disposal
    Troubleshooting
    General
    The welding machines are equipped with an intelligent safety system, meaning it has been possible to dispense with nearly all fuses. After a possible malfunction has been remedied, the welding machine can be used again as normal.
    Possible malfunctions, warning notices or status codes are shown on the display as plain text dialogues.
    3. Troubleshooting
    General
    3. Troubleshooting
    Danger from electrical current and inadequate ground conductor connection
    WARNING!
    CAUTION!
    Danger from inadequate ground conductor connections.
    This can result in injury and damage to property.
    The housing screws provide a suitable ground conductor connection for earthing the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    3. Troubleshooting
    Troubleshooting the welding machine
    Welding machine does not function
    Mains switch is on, but indicators are not lit up
    Cause:There is a break in the mains lead; the mains plug is not plugged in
    Remedy:Check the mains lead, ensure that the mains plug is plugged in
    Cause:Mains socket or mains plug faulty
    Remedy:Replace faulty parts
    Cause:Mains fuse
    Remedy:Change the mains fuse protection
    Cause:Short circuit on the 24 V supply of SpeedNet connection socket or external sensor
    Remedy:Unplug connected components
    No welding current
    Mains switch is on, overtemperature is displayed
    Cause:Overload; the duty cycle has been exceeded
    Remedy:Check duty cycle
    Cause:Thermostatic automatic circuit breaker has tripped
    Remedy:Wait until the welding machine automatically comes back on after the end of the cooling phase
    Cause:Limited supply of cooling air
    Remedy:Ensure accessibility to cooling air ducts
    Cause:Faulty fan in welding system
    Remedy:Contact After-Sales Service
    No welding current
    Welding machine mains switch is on and indicators are lit
    Cause:Grounding (earthing) connection is incorrect
    Remedy:Check the grounding (earthing) connection for correct polarity
    Cause:There is a break in the power cable in the welding torch
    Remedy:Replace welding torch
    Nothing happens when the torch trigger is pressed
    Welding machine mains switch is on and indicators are lit up
    Cause:Only for welding torches with an external control plug: The control plug is not plugged in
    Remedy:Plug in the control plug
    Cause:Welding torch or welding torch control line is faulty
    No protective gas shield
    All other functions are OK
    Cause:Gas cylinder is empty
    Remedy:Change the gas cylinder
    Cause:The gas pressure regulator is faulty
    Remedy:Replace the gas pressure regulator
    Cause:Gas hose is not fitted or is damaged
    Remedy:Fit or change the gas hose
    Cause:Welding torch is faulty
    Remedy:Change the welding torch
    Cause:Gas solenoid valve is faulty
    Poor weld properties
    Cause:Incorrect welding parameters
    Remedy:Check the settings
    Cause:Poor ground earth connection
    Remedy:Ensure good contact to workpiece
    Cause:Inadequate or no shielding gas
    Remedy:Check the pressure regulator, gas hose, gas solenoid valve, torch gas connection, etc.
    Cause:Welding torch is leaking
    Remedy:Change welding torch
    Cause:Wrong contact tip, or contact tip is worn out
    Remedy:Replace contact tip
    Cause:Wrong wire alloy or wrong wire diameter
    Remedy:Check the wire electrode that has been inserted
    Remedy:Check weldability of the base material
    Cause:The shielding gas is not suitable for this wire alloy
    Remedy:Use the correct shielding gas
    Cause:Contaminated gas nozzle
    Remedy:Clean the gas nozzle, remove any welding spatter
    Irregular wire feed speed
    Cause:Braking force has been set too high
    Remedy:Loosen the brake
    Cause:Hole in the contact tip is too narrow
    Remedy:Use a suitable contact tip
    Cause:Faulty inner liner in welding torch
    Remedy:Check the inner liner for kinks, dirt, etc. and replace if necessary
    Cause:The feed rollers are not suitable for the wire electrode being used
    Remedy:Use suitable feed rollers
    Cause:Feed rollers have the wrong contact pressure
    Remedy:Optimise the contact pressure
    Wirefeed problems
    when using long hosepacks
    Cause:Incorrect arrangement of hosepack
    Remedy:Arrange the hosepack in as straight a line as possible, avoid tight bends
    Welding torch becomes very hot
    Cause:Welding torch is inadequately dimensioned
    Remedy:Observe the duty cycle and loading limits
    Cause:Only on water-cooled systems: inadequate coolant flow
    Remedy:Check coolant level, coolant flow, for coolant contamination, etc. For further information refer to the cooling unit operating instructions
    Cause:The distance from the workpiece is too small
    Remedy:Increase stickout
    Technical data
    Average consumption values
    Average wire electrode consumption during MIG/MAG welding
    Average wire electrode consumption at a wire speed of 5 m/min
    Wire electrode diameter
    1.0 mm
    1.2 mm
    1.6 mm
    Steel wire electrode
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    Aluminium wire electrode
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    Average wire electrode consumption at a wire speed of 10 m/min
    1.0 mm
    1.2 mm
    1.6 mm
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Technical data
    1.0 mm
    1.2 mm
    1.6 mm
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    1.0 mm
    1.2 mm
    1.6 mm
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Technical data
    2. Average consumption values
    1.0 mm
    1.2 mm
    1.6 mm
    1.8 kg/h
    2.7 kg/h
    4.7 kg/h
    0.6 kg/h
    0.9 kg/h
    1.6 kg/h
    CrNi wire electrode
    1.9 kg/h
    2.8 kg/h
    4.8 kg/h
    1.0 mm
    1.2 mm
    1.6 mm
    3.7 kg/h
    5.3 kg/h
    9.5 kg/h
    1.3 kg/h
    1.8 kg/h
    3.2 kg/h
    CrNi wire electrode
    3.8 kg/h
    5.4 kg/h
    9.6 kg/h
    1. Technical data
    Average shielding gas consumption during MIG/MAG welding
    1.0 mm
    1.2 mm
    1.6 mm
    2.0 mm
    Average consumption
    10 l/min
    12 l/min
    16 l/min
    20 l/min
    1. Technical data
    Average shielding gas consumption during TIG welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Technical data
    Technical data
    Explanation of the term "duty cycle"
    Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
    The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
    If the ambient temperature is higher, either the ED or output must be reduced accordingly.
    Example: Welding at 150 A at 60% ED
    • Welding phase = 60% of 10 minutes = 6 minutes
    • Cooling phase = remaining time = 4 minutes
    • After the cooling phase, the cycle begins again.
    If the device is to be continuously operated without stopping:
    1Look in the technical data for a ED value of 100% for the current ambient temperature.
    2Reduce the output or amperage in line with this value so that the device can remain in use without observing a cooling phase.
    1. Technical data
    2. Technical data
    1. Technical data
    2. Technical data
    Special voltages
    For devices designed for special voltages, the technical data on the rating plate applies.
    For all machines with a permitted mains voltage of up to 460 V: The standard mains plug allows the user to operate with a mains voltage of up to 400 V. For mains voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
    1. Technical data
    2. Technical data
    TPS 270i C
    Mains voltage (U1)
    3 x 400 V
    Max. effective primary current (I1eff)
    9.7 A
    Max. primary current (I1max)
    15.3 A
    Mains fuse
    16 A slow-blow
    Mains voltage tolerance
    -15 / +15%
    Grid frequency
    50/60 Hz
    Cos phi (1)
    0.99
    Max. permitted mains impedance Zmax at PCC1)
    117 mOhm
    Recommended residual current circuit breaker
    Type B
    Welding current range (I2)
    MIG / MAG
    TIG
    Rod electrode
    3 - 270 A
    3 - 270 A
    10 - 270 A
    Welding current
    at 10 min / 40 °C (104 °F)
    40% / 270 A
    60% / 220 A
    100% / 190 A
    Output voltage range according to standard characteristic (U2)
    MIG / MAG
    TIG
    Rod electrode
    14.2 - 27.5 V
    14.1 - 20.8 V
    20.4 - 30.8 V
    Open circuit voltage (U0 peak/U0 r.m.s)
    57 V
    Protection class
    IP 23
    EMC emission class
    A
    Dimensions L x W x H
    687 x 276 x 445 mm
    27.0 x 10.9 x 17.5 in.
    Weight
    33.1 kg
    73.0 lb
    Max. noise emission (LWA)
    69 dB (A)
    Max. shielding gas pressure
    7 bar
    101.5 psi
    Wire speed
    1 - 25 m/min
    40 - 980 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8-1.6 mm
    0.03-0.06 in.
    Wirespool diameter
    max. 300 mm
    max. 11.8 in.
    Wirespool weight
    max. 19.0 kg
    max. 41.9 lb.
    Idle state power consumption at 400 V
    31 W
    Welding machine efficiency
    at 270 A / 30.8 V
    90%
    The wirefeeder for the TPS 270i C is integrated in the welding machine.
    1)
    Interface to a 230/400 V and 50 Hz public grid
    1. Technical data
    2. Technical data
    TPS 270i C /nc
    Mains voltage (U1)
    3 x 380 / 400 / 460 V
    3 x 380 V
    3 x 400 V
    3 x 460 V
    9.5 A
    9.7 A
    8.5 A
    3 x 380 V
    3 x 400 V
    3 x 460 V
    16.0 A
    15.3 A
    13.4 A
    Mains fuse
    16 A slow-blow
    -10 / +15%
    Grid frequency
    50/60 Hz
    Cos phi (1)
    0.99
    117 mOhm
    Type B
    MIG / MAG
    TIG
    Rod electrode
    3 - 270 A
    3 - 270 A
    10 - 270 A
    Welding current
    40% / 270 A
    60% / 220 A
    100% / 190 A
    MIG / MAG
    TIG
    Rod electrode
    14.2 - 27.5 V
    14.1 - 20.8 V
    20.4 - 30.8 V
    66 V
    Protection class
    IP 23
    EMC emission class
    A
    687 x 276 x 445 mm
    Weight
    32.5 kg
    71.7 lb.
    69 dB (A)
    7 bar
    101.5 psi
    Wire speed
    1 - 25 m/min
    40 - 980 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8-1.6 mm
    0.03-0.06 in.
    Wirespool diameter
    max. 300 mm
    max. 11.8 in.
    Wirespool weight
    max. 19.0 kg
    max. 41.9 lb.
    31 W
    at 270 A / 30.8 V
    90%
    1)
    1. Technical data
    2. Technical data
    TPS 270i C /MV/nc
    Mains voltage (U1)
    3 x 200 / 230 / 380 / 400 / 460 V
    3 x 200 V
    3 x 230 V
    3 x 380 V
    3 x 400 V
    3 x 460 V
    16.9 A
    15.1 A
    9.5 A
    9.7 A
    8.5 A
    3 x 200 V
    3 x 230 V
    3 x 380 V
    3 x 400 V
    3 x 460 V
    26.5 A
    23.7 A
    16.0 A
    15.3 A
    13.4 A
    Mains fuse protection
    3 x 200 / 230 V
    35 A slow-blow
    16 A slow-blow
    -10 / +15%
    Grid frequency
    50/60 Hz
    Cos phi (1)
    0.99
    117 mOhm
    Type B
    MIG / MAG
    TIG
    Rod electrode
    3 - 270 A
    3 - 270 A
    10 - 270 A
    Welding current
    40% / 270 A
    60% / 220 A
    100% / 190 A
    MIG / MAG
    TIG
    Rod electrode
    14.2 - 27.5 V
    14.1 - 20.8 V
    20.4 - 30.8 V
    66 V
    Protection class
    IP 23
    EMC emission class
    A
    687 x 276 x 445 mm
    Weight
    33.2 kg
    73.1 lb.
    69 dB (A)
    7 bar
    101.5 psi
    Wire speed
    1 - 25 m/min
    40 - 980 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8-1.6 mm
    0.03-0.06 in.
    Wirespool diameter
    max. 300 mm
    max. 11.8 in.
    Wirespool weight
    max. 19.0 kg
    max. 41.9 lb.
    35.9 W
    at 270 A / 30.8 V
    90%
    1)
    1. Technical data
    2. Technical data
    TPS 270i C /S/nc
    Mains voltage (U1)
    3 x 460 / 575 V
    Max. effective primary current(I1eff)
    3 x 460 V
    3 x 575 V
    9.1 A
    7.2 A
    3 x 460 V
    3 x 575 V
    14.3 A
    11.4 A
    Mains fuse
    20 A slow-blow
    -10 / +10%
    Grid frequency
    50/60 Hz
    Cos phi (1)
    0.99
    Type B
    MIG / MAG
    TIG
    Rod electrode
    3 - 270 A
    3 - 270 A
    10 - 270 A
    Welding current
    40% / 270 A
    60% / 220 A
    100% / 190 A
    MIG / MAG
    TIG
    Rod electrode
    14.2 - 27.5 V
    14.1 - 20.8 V
    20.4 - 30.8 V
    68 V
    Protection class
    IP 23
    687 x 276 x 445 mm
    Weight
    30.4 kg
    67.0 lb.
    69 dB (A)
    7 bar
    101.5 psi
    Wire speed
    1 - 25 m/min
    40 - 980 ipm
    Wire drive
    4-roller drive
    Wire diameter
    0.8-1.6 mm
    0.03-0.06 in.
    Wirespool diameter
    max. 300 mm
    max. 11.8 in.
    Wirespool weight
    max. 19.0 kg / max. 41.9 lb.
    1. Technical data
    2. Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address.
    Find downloads: critical
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    1. Technical data
    2. Technical data
    China Energy Label
    Part Name
    Hazardous Substances
    Lead
    (Pb)
    Mercury
    (Hg)
    Cadmium
    (Cd)
    hexavalent
    chromium
    (Cr (VI))
    polybrominated
    biphenyls
    (PBB)
    polybrominated
    diphenyl ethers
    (PBDE)
    diethylhexyl phthalate
    (DEHP)
    benzyl butyl phthalate
    (BBP)
    dibutyl phthalate
    (DBP)
    di-isobutyl phthalate
    (DOBP)
    Packaging
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Housing
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Metal Parts
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    PCB
    X
    O
    O
    O
    O
    O
    O
    O
    O
    O
    Cables and Cable Assemblies
    O
    O
    O
    O
    O
    O
    O
    O
    O
    O
    This table is prepared in accordance with the provisions of SJ/T 11364.
    O
    Indicates that the hazardous substance contained in all of the homogeneous materials for this part is below the limit requirement of GB/T 26572.
    X
    Indicates that the hazardous substance contained in at least one of the homogeneous materials used for this part is above the limit requirement of GB/T 26572.
    All parts in this table marked with an "X" comply with the European Union's RoHS legislation.
