Indicates immediate danger.
All safety and danger notices on the deviceFor the location of the safety and danger notices on the device, refer to the section headed "General" in the operating instructions for the device.
Before switching on the device, rectify any faults that could compromise safety.
The device is intended solely for the welding processes specified on the rating plate.
Any use above and beyond this purpose is deemed improper. The manufacturer shall not be held liable for any damage arising from such usage.
The device is designed for use in industry and the workshop. The manufacturer accepts no responsibility for any damage caused through use in a domestic setting.
The manufacturer likewise accepts no liability for inadequate or incorrect results.
Operation or storage of the device outside the stipulated area will be deemed as not in accordance with the intended purpose. The manufacturer shall not be held liable for any damage arising from such usage.
Ambient temperature range:The surrounding air must be free from dust, acids, corrosive gases or substances, etc.
Can be used at altitudes of up to 2000 m (6561 ft. 8.16 in.)
This may affect a number device types in terms of:*) at the interface with the public grid
see "Technical data"
In this case, the plant operator or the person using the device should check whether the device may be connected, where appropriate by discussing the matter with the power supply company.
IMPORTANT! Ensure that the mains connection is earthed properly
Local regulations and national guidelines may require a residual current protective device when connecting equipment to the public grid.
The type of residual current protective device recommended by the manufacturer for the equipment is indicated in the technical data.
The device generates a maximum sound power level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation at the maximum permissible operating point under maximum rated load conditions according to EN 60974-1.
It is not possible to provide a workplace-related emission value during welding (or cutting) as this is influenced by both the process and the environment. All manner of different welding parameters come into play, including the welding process (MIG/MAG, TIG welding), the type of power selected (DC or AC), the power range, the type of weld metal, the resonance characteristics of the workpiece, the workplace environment, etc.
The fumes produced during welding contain harmful gases and vapours.
Welding fumes contain substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
Keep your face away from welding fumes and gases.
Fumes and hazardous gasesEnsure an adequate supply of fresh air. Ensure that there is a ventilation rate of at least 20 m³ per hour at all times.
If there is any doubt about whether the extraction capacity is sufficient, the measured toxic emission values should be compared with the permissible limit values.
The following components are responsible, amongst other things, for the degree of toxicity of welding fumes:The relevant material safety data sheets and manufacturer's specifications for the listed components should therefore be studied carefully.
Recommendations for trade fair scenarios, risk management measures and for identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Flammable vapours (e.g. solvent fumes) should be kept away from the arc's radiation area.
Close the shielding gas cylinder valve or main gas supply if no welding is taking place.
Flying sparks may cause fires or explosions.
Never weld close to flammable materials.
Flammable materials must be at least 11 metres (36 ft. 1.07 in.) away from the arc, or alternatively covered with an approved cover.
Sparks and pieces of hot metal may also get into adjacent areas through small gaps or openings. Take appropriate precautions to prevent any danger of injury or fire.
Welding must not be performed in areas that are subject to fire or explosion or near sealed tanks, vessels or pipes unless these have been prepared in accordance with the relevant national and international standards.
Do not carry out welding on containers that are being or have been used to store gases, propellants, mineral oils or similar products. Residues pose an explosive hazard.
An electric shock is potentially life threatening and can be fatal.
Do not touch live parts either inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wirespool, the feed rollers and all pieces of metal that are in contact with the welding wire are live.
Always set the wirefeeder up on a sufficiently insulated surface or use a suitable, insulated wirefeeder holder.
Make sure that you and others are protected with an adequately insulated, dry base or cover for the earth or ground potential. This base or cover must extend over the entire area between the body and the earth or ground potential.
All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Use the handle to ensure the power connections are tight before every use.
In the case of power cables with a bayonet connector, rotate the power cable around the longitudinal axis by at least 180° and pretension.
Do not wrap cables or leads around the body or parts of the body.
The electrode (rod electrode, tungsten electrode, welding wire, etc.) mustDouble the open circuit voltage of a power source can occur between the welding electrodes of two power sources. Touching the potentials of both electrodes at the same time may be fatal under certain circumstances.
Arrange for the mains cable to be checked regularly by a qualified electrician to ensure the ground conductor is functioning properly.
Protection class I devices require a mains supply with ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a mains supply without ground conductor and on a socket without ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer shall not be held liable for any damage arising from such usage.
If necessary, provide adequate earthing for the workpiece.
Switch off unused devices.
Wear a safety harness if working at height.
Before working on the device, switch it off and pull out the mains plug.
Attach a clearly legible and easy-to-understand warning sign to the device to prevent anyone from plugging the mains plug back in and switching it on again.
After opening the device:If work on live parts is required, appoint a second person to switch off the main switch at the right moment.
Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
If power distribution boards, twin-head mounts, etc., are being used, note the following: The electrode of the welding torch / electrode holder that is not used is also live. Make sure that the welding torch / electrode holder that is not used is kept sufficiently insulated.
In the case of automated MIG/MAG applications, ensure that only an insulated wire electrode is routed from the welding wire drum, large wirefeeder spool or wirespool to the wirefeeder.
Do not reach into the rotating cogs of the wire drive or into rotating drive components.
Covers and side panels may only be opened/removed while maintenance or repair work is being carried out.
During operationThe welding wire emerging from the welding torch poses a high risk of injury (piercing of the hand, injuries to the face and eyes, etc.).
Therefore, always keep the welding torch away from the body (devices with wirefeeder) and wear suitable protective goggles.
Never touch the workpiece during or after welding - risk of burns.
Slag can jump off cooling workpieces. The specified protective equipment must therefore also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
Welding torches and other parts with a high operating temperature must be allowed to cool down before handling.
Special provisions apply in areas at risk of fire or explosion
- observe relevant national and international regulations.
Power sources for work in areas with increased electric risk (e.g. near boilers) must carry the "Safety" sign. However, the power source must not be located in such areas.
Risk of scalding from escaping coolant. Switch off cooling unit before disconnecting coolant flow or return lines.
Observe the information on the coolant safety data sheet when handling coolant. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Use only suitable load-carrying equipment supplied by the manufacturer when transporting devices by crane.
If the wirefeeder is attached to a crane holder during welding, always use a suitable, insulated wirefeeder hoisting attachment (MIG/MAG and TIG devices).
If the device has a carrying strap or handle, this is intended solely for carrying by hand. The carrying strap is not to be used if transporting with a crane, counterbalanced lift truck or other mechanical hoist.
All lifting tackle (straps, handles, chains, etc.) used in connection with the device or its components must be tested regularly (e.g. for mechanical damage, corrosion or changes caused by other environmental factors).
The testing interval and scope of testing must comply with applicable national standards and directives as a minimum.
Odourless and colourless shielding gas may escape unnoticed if an adapter is used for the shielding gas connection. Prior to assembly, seal the device-side thread of the adapter for the shielding gas connection using suitable Teflon tape.
Use filters if necessary.
Shielding gas cylinders contain gas under pressure and can explode if damaged. As the shielding gas cylinders are part of the welding equipment, they must be handled with the greatest of care.
Protect shielding gas cylinders containing compressed gas from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
Mount the shielding gas cylinders vertically and secure according to instructions to prevent them falling over.
Keep the shielding gas cylinders well away from any welding or other electrical circuits.
Risk of explosion - never attempt to weld a pressurised shielding gas cylinder.
Only use shielding gas cylinders suitable for the application in hand, along with the correct and appropriate accessories (regulator, hoses and fittings). Only use shielding gas cylinders and accessories that are in good condition.
Turn your face to one side when opening the valve of a shielding gas cylinder.
Close the shielding gas cylinder valve if no welding is taking place.
If the shielding gas cylinder is not connected, leave the valve cap in place on the cylinder.
The manufacturer's instructions must be observed as well as applicable national and international regulations for shielding gas cylinders and accessories.
Only set up and operate the device in accordance with the degree of protection shown on the rating plate.
When setting up the device, ensure there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to ensure that cooling air can flow in and out freely.
Do not lift or transport operational devices. Switch off devices before transport or lifting.
Before transporting the device, allow coolant to drain completely and detach the following components:After transporting the device, the device must be visually inspected for damage before commissioning. Any damage must be repaired by trained service technicians before commissioning the device.
Always fasten the shielding gas cylinder securely and remove it beforehand if the device is to be transported by crane.
Only the manufacturer's original coolant is suitable for use with our devices due to its properties (electrical conductibility, anti-freeze agent, material compatibility, flammability, etc.).
Only use suitable original coolant from the manufacturer.
Do not mix the manufacturer's original coolant with other coolants.
Only connect the manufacturer's system components to the cooling circuit.
The manufacturer accepts no liability for damage resulting from use of other system components or a different coolant. In addition, all warranty claims will be forfeited.
Cooling Liquid FCL 10/20 does not ignite. The ethanol-based coolant can ignite under certain conditions. Transport the coolant only in its original, sealed containers and keep well away from any sources of ignition.
Used coolant must be disposed of properly in accordance with the relevant national and international regulations. The coolant safety data sheet may be obtained from your service centre or downloaded from the manufacturer's website.
Check the coolant level before starting to weld, while the system is still cool.
The manufacturer recommends that a safety inspection of the device is performed at least once every 12 months.
The manufacturer recommends that the power source be calibrated during the same 12-month period.
A safety inspection should be carried out by a qualified electricianFor safety inspections, follow the appropriate national and international standards and directives.
Further details on safety inspection and calibration can be obtained from your service centre. They will provide you on request with any documents you may require.
Do not dispose of this device with normal domestic waste! To comply with the European Directive on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must either be returned to your dealer or given to one of the approved collection and recycling facilities in your area. Ignoring this European Directive may have potentially adverse affects on the environment and your health!
Devices with the CE mark satisfy the essential requirements of the low-voltage and electromagnetic compatibility directives (e.g. relevant product standards of the EN 60 974 series).
Fronius International GmbH hereby declares that the device is compliant with Directive 2014/53/EU. The full text on the EU Declaration of Conformity can be found at the following address: http://www.fronius.com
The user is responsible for the safekeeping of any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
The text and illustrations are all technically correct at the time of printing. We reserve the right to make changes. The contents of the operating instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the instructions, we will be most grateful for your comments.
In conjunction with the digital resonance inverter, an electronic regulator adapts the power source characteristic to suit the welding electrode during welding. The result is a lightweight and compact device with excellent ignition and weld properties.
The power source also features a Power Factor Correction, which adapts the current consumption of the power source to the sinusoidal mains voltage. This results in numerous advantages for the user, such as:When using cellulose electrodes (CEL), a dedicated operating mode can be chosen for perfect welding results.
TIG welding with touchdown ignition greatly extends the range of applications.
The warning notices and safety symbols on the power source must not be removed or painted over. They warn against incorrect operation which can lead to serious injury and damage.
Meaning of safety symbols on the device:
Welding is dangerous. The following basic requirements must be met to ensure the equipment is used properly:
Do not dispose of used devices with domestic waste. Dispose of them according to the safety rules. |
The power source is intended exclusively for MMA welding and TIG welding in conjunction with system components from Fronius.
Utilisation for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended purpose.
The manufacturer shall not be held liable for any damages arising from such usage.
Danger from machines toppling over or falling.
Set up the device securely on an even, solid surface.
Check all screw connections are tightly fastened after installation.
Cooling air
The device must be set up in such a way that cooling air can flow freely through the slots in the front and rear panels.
Dust
Ensure that metallic dust is not sucked into the system by the fan, when carrying out grinding for example.
Outdoor operation
The device can be set up and operated outdoors in accordance with IP23 degree of protection. Avoid direct wetting (e.g. from rain).
The power source is generator-compatible.
In order to dimension the required generator output, the maximum apparent power S1max of the power source is required.
The maximum apparent power S1max of the power source can be calculated as follows:
S1max = I1max x U1
See device rating plate or technical data for I1max and U1 values
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator may be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the power source.
When using single-phase devices with a 3-phase generator, note that the specified generator apparent power is often only available as a whole across all three phases of the generator. If necessary, obtain further information on the single-phase power of the generator from the generator manufacturer.
The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
Details of the mains voltage tolerance can be found in the "Technical data" section.
As a result of software updates, you may find that there are functions available on your device that are not described in these Operating Instructions, or vice versa.
Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
| (1) | Control panel |
| (2) | (-) current socket with bayonet latch |
| (3) | TMC connection (TIG Multi Connector) After connecting a remote control to the power source
| (4) | (+) current socket with bayonet latch |
| (5) | Carrying strap |
| (6) | Cable strap for holding the mains cable and the welding power-leads Do not use to move the device! |
| (7) | Mains switch |
| (8) | Air filter |
| (9) | Shielding gas connection |
| (8) | Air filter |
(1) | Setting value indicator | |
(2) | Unit indicator | |
(3) | Setting value button |
(4) | Display |
(5) | Welding process indicator | |
(6) | Welding process button |
(7) | Adjusting dial |
(8) | Status indicators |
Danger from electric shocks. As soon as the power source is switched on, the electrode in the electrode holder is live.
This can result in injury and damage to property.
Ensure the electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.).
1Use the welding process button to select one of the following processes: | ||
2Press the setting value button until | ||
3Adjust the welding current using the adjusting dial
This function is used to set the starting current.
Setting range: 1 - 200 %
Operating principle:
At the start of the welding process, the welding current is reduced (SoftStart) or increased (HotStart) for 0.5 seconds, depending on the setting.
The change is shown as a percentage from the set welding current.
The duration of the starting current can be changed in the Setup menu using the starting current duration (Hti) parameter.
Setting the starting current:
1Press the setting value button until | ||
2Turn the adjusting dial until the desired value is reached
Examples (set welding current = 100 A): | |
100 % | = 100 A starting current = function deactivated |
80 % | = 80 A starting current = SoftStart |
135 % | = 135 A starting current = HotStart |
200 % | = 160 A starting current on TransPocket 150 = HotStart, maximum current limit is reached! |
200 % | = 200 A starting current on TransPocket 180 = HotStart |
To obtain optimum welding results, it will sometimes be necessary to adjust the arc-force dynamic.
Setting range: 0 - 100 (corresponds to 0 - 200 A current increase)
At the moment of droplet transfer or in the event of a short circuit, the amperage is briefly increased in order to obtain a stable arc.
If the rod electrode threatens to sink into the weld pool, this measure prevents the weld pool solidifying, as well as preventing a prolonged short-circuit of the arc. This largely prevents the rod electrode from sticking.
Setting the arc-force dynamic:
2Turn the adjusting dial until the desired correction value is reached
Pulse welding is welding with a pulsing welding current. It is used for out-of-position welding of steel pipes or when welding thin sheets.
In these applications, the welding current set at the start of welding is not always ideal for the whole welding process:Setting range: 0.2 - 990 Hz
Operating principle:The power source controls the Duty cycle dcY parameter and base current I-G according to the set pulse current and pulse frequency.
Pull back and hold the torch trigger | |
Release the torch trigger forwards | |
Push forward and hold the torch trigger | |
Release the torch trigger backwards |
See the description Operating mode (trigger mode) on page (→) for details on how to activate 2-step mode.
See the description Operating mode (trigger mode) on page (→) for details on how to activate 4-step mode.
Intermediate lowering means that the welder uses the torch trigger during the main current phase to lower the welding current to the specified reduced current I-2 .
Do not use pure tungsten electrodes (colour-coded green) if the TIG welding process has been selected.
2-step and 4-step welding is only possible if a welding torch with a TIG Multi Connector plug is used.
Danger from falling gas cylinders.
Place gas cylinders on a solid, level surface so that they remain stable. Secure gas cylinders to prevent them from falling over.
Observe the safety rules of the gas cylinder manufacturer.
Danger from electric shocks. As soon as the power source is switched on, the electrode in the welding torch is live.
1Select TIG welding with the welding process button | ||
3Adjust the welding current using the adjusting dial | ||
When using a welding torch with a torch trigger and TIG Multi Connector plug (with 2-step mode factory setting): 4Place the gas nozzle down on the ignition location, ensuring there is a gap of approx. 2 to 3 mm (5/64 to 1/8 in.) between the tungsten electrode and the workpiece 5Gradually tilt the welding torch up until the tungsten electrode touches the workpiece 6Pull back and hold the torch trigger - shielding gas flows 7Raise the welding torch and rotate it into its normal position - the arc ignites 8Carry out welding | ||
To activate and set the TIG Comfort Stop function, see the description Comfort Stop Sensitivity starting on page (→).
Operating principle and use of the TIG Comfort Stop:
| (1) | Gas pre-flow |
| (2) | Gas post-flow |
DownSlope:
The DownSlope time tdown is 0.5 seconds and cannot be adjusted.
Gas post-flow:
The gas post-flow can be changed in the Setup menu via the "Gas post-flow time" parameter (Gas Post flow).
In these applications, the welding current set at the start of welding is not always ideal for the whole welding process:Setting range: 0.5 - 100 Hz
To use pulse welding:
2Turn the adjusting dial until the desired frequency value (Hz) is reached
To activate and set the tacking function, see the description Tacking function (tACking) starting on page (→).
The power source controls the pulse frequency F-P, pulse current I-P, duty cycle dcY and base current I-G parameters according to the set main current I-1.
The pulse current startsAfter the tAC time has elapsed, welding continues at a constant welding current, and any pulse parameters that may have been set are available.
1Use the Welding Process button to select the process whose Setup parameters are to be changed: | ||
2Press the Setting Value and Welding Process buttons at the same time
1Turn the adjusting dial to select the required parameter | |
2Press the adjusting dial to display the preset value of the parameter | |
3Turn the adjusting dial to change the value - the new value becomes effective immediately - exception: when restoring the factory settings, press the adjusting dial after changing the value to activate the new value. | |
4Press the adjusting dial to return to the list of parameters |
1Press the Setting Value or Welding Process button to exit the Setup menu |
Parameter | Description | Range | Unit | |
Starting current duration For the SoftStart / HotStart function Factory setting: 0.5 seconds | 0.1 - 2.0 | Seconds | ||
Anti-stick When the anti-stick function is active, the arc is extinguished after 1.5 seconds in the event of a short circuit (sticking of the electrode) Factory setting: ON (activated) | On |
Start ramp To activate/deactivate grinding mode Factory setting: ON (activated) | On |
Break voltage (Voltage cut off) Used to specify at which arc length the welding process is to be completed. Factory setting: 45 volts | 25 - 90 | Volts | ||
Factory setting (FACtory) This can be used to reset the device to its factory settings |
| no | ||
| YES | ||
| ALL | ||
Resetting of the selected value to its factory setting must be confirmed by pressing the adjusting dial. |
Level 2 Setup menu To set general welding parameters For details, see the "Level 2 Setup menu" section |
| Operating mode (trigger mode) |
| OFF |
| 2t |
Factory setting: 2t | 4t |
Starting current (I-Start) This parameter is only available in 4-step mode (tri = 4t) Factory setting: 35% | 1 - 200 | Percent | ||
Reduced current This parameter is only available in 4-step mode (tri = 4t) Factory setting: 50% | 1 - 200 | Percent | ||
Final current (I-End) This parameter is only available in 4-step mode (tri = 4t) Factory setting: 30% | 1 - 100 | Percent | ||
Gas pre-flow time (Gas Pre flow) Duration of gas pre-flow Factory setting: 0.0 seconds | 0.0 - 9.9 | Seconds | ||
Gas post-flow (Gas Post flow) Specified period during which gas flows at the end of welding Factory setting: AUt | AUt | Seconds | ||
Gas purging (gas purging) Purging of the protective gas shield begins as soon as GPU is allocated a value. For safety reasons, purging of the protective gas shield cannot be restarted until a new GPU value is entered. IMPORTANT! Purging the shielding gas is necessary if condensation forms when the device is left unused in a cold environment for a prolonged period. Long hosepacks are most affected. Factory setting: off | 0.1 - 9.9 | Minutes | ||
Comfort Stop Sensitivity This parameter is only available when the tri parameter is set to OFF For details, see TIG Comfort Stop starting at page (→) | 0.6 - 3.5 | Volts | ||
Break voltage (Voltage cut off) Used to specify at which arc length the welding process is to be completed. Factory setting: 35 volts (for 2-step mode, 4-step mode and pedal remote control) Factory setting: 25 V (for the trigger = oFF mode) | 10 - 45 | Volts | ||
Tacking function (tACking) Factory setting: OFF For details, see description of the "Tacking function" | OFF |
| no | ||
| YES | ||
| ALL | ||
Level 2 Setup menu To set general welding parameters For details, see the "Level 2 Setup menu" chapter |
Software version The full version number of the currently installed software is spread across a number of displays and can be retrieved by turning the adjusting dial |
Automatic switch-off (time Shut down) If the device is not used or operated for a specified period of time, it automatically switches itself into Standby mode Pressing any button on the control panel will cancel Standby mode and the device will be ready to resume welding Factory setting: OFF | 5 - 60 | Minutes | |
Fuse For displaying/setting the fuse used Factory setting:
If a fuse is set on the power source, the power source limits the power drawn from the mains. This prevents the circuit breaker from tripping immediately | At At | Ampere |
TransPocket 150 - Ratio between set fuse and welding current: | ||||
Mains voltage | Set | Welding current electrode | TIG | Duty cycle |
230 V | 10 A | 110 A | 150 A | 35 % |
| 13 A | 130 A | 150 A | 35 % |
16 A | 150 A | 150 A | 35 % | |
TransPocket 180 - Ratio between set fuse and welding current: | ||||
Mains voltage | Set fuse | Welding current electrode | TIG | Duty cycle |
230 V | 10 A | 125 A | 180 A | 40 % |
| 13 A | 150 A | 200 A | 40 % |
| 16 A | 180 A | 220 A | 40 % |
| OFF (TP 180 MV only) | 180 A | 220 A | 40 % |
120 V* | 15 A | 85 A | 130 A | 40 % |
| 16 A | 95 A | 140 A | 40 % |
| 20 A (TP 180 MV only) | 120 A | 170 A | 40 % |
| OFF (TP 180 MV only) | 120 A | 170 A | 40 % |
* Depending on the triggering characteristic of the circuit breaker, the full duty cycle of 40% cannot be achieved on 120 V grids (e.g. USA circuit breaker type CH ̴15% D.C.). | ||||
Operating time (System on time) For displaying the operating time (begins to count as soon as the device is switched on) The full operating time is spread across a number of displays and can be retrieved by turning the adjusting dial |
| Hours, minutes, seconds | |
Welding time (System Active time) For displaying how long the system has been active for (only shows the time during which welding was in progress) The full system active time is spread across a number of displays and can be retrieved by turning the adjusting dial |
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
Under normal operating conditions, the device requires only a minimum of care and maintenance. However, it is vital to observe some important points to ensure the device remains in a usable condition for many years.
| Cause: | Operating temperature too high |
| Remedy: | Allow device to cool (do not switch off the device - the fan will cool it down) |
When E and a 2 digit error number appear in the display (e.g. E02) and the "Error" indicator lights up, this is an internal power source service code.
Example:
It is also possible that several error numbers are present. These appear when turning the adjusting dial.
Make a note of the error numbers shown in the display, and of the serial number and configuration of the power source, and contact our after-sales service team with a detailed description of the error.
| Cause: | Fault in power module |
| Remedy: | Contact After-Sales Service |
| Cause: | Open circuit voltage is not being reached: electrode in contact with workpiece / hardware fault |
| Remedy: | Remove electrode holder from workpiece. If the service code continues to be displayed, contact after-sales service |
| Cause: | System start-up failed |
| Remedy: | Switch device off and on again. Contact after-sales service if a repeated occurrence |
| Cause: | Overvoltage at the current socket (> 113 VDC) |
| Remedy: | Contact after-sales service |
| Cause: | Memory fault |
| Remedy: | Contact After-Sales Service / Press adjusting dial to acknowledge the service message |
NOTE!On standard variants of the device, acknowledging the service message has no effect on the availability of power source functions. On all other variants (TIG, etc.), only a restricted range of functions is available after acknowledging the message. Contact After-Sales Service to have the full functionality restored. | |
| Cause: | Overtemperature or undertemperature |
| Remedy: | Operate the device in permitted ambient temperatures. For more details on environmental conditions, see "Environmental conditions" in the "Safety rules" section |
| Cause: | Improper use of the device |
| Remedy: | Only use the device for its intended purpose |
| Cause: | Welding current set too high |
| Remedy: | Ensure that the power source is being operated on the correct mains voltage; ensure that the correct fuse is set; set a lower welding current |
| Cause: | Mains voltage too high |
| Remedy: | Pull out the mains plug immediately; ensure that the power source is being operated on the correct mains voltage |
| Cause: | Mains voltage outside tolerance or maximum load of grid is too low |
| Remedy: | Ensure that the power source is being operated on the correct mains voltage; ensure that the correct fuse is set; |
| Cause: | Communication error with the display |
| Remedy: | Switch device off and on again / contact after-sales service if a repeated occurrence |
| Cause: | Mains switch is faulty |
| Cause: | Welding power-lead connections have been disconnected |
| Remedy: | Establish proper welding power-lead connections |
| Cause: | Poor or no earth |
| Remedy: | Establish a connection to the workpiece |
| Cause: | There is a break in the power cable in the welding torch or electrode holder |
| Remedy: | Replace welding torch or electrode holder |
| Cause: | Duty cycle exceeded - device overloaded - fan running |
| Remedy: | Keep within duty cycle |
| Cause: | Thermostatic automatic circuit breaker has switched off the device |
| Remedy: | Wait until the power source comes back on automatically at the end of the cooling phase (do not switch off the device - the fan will cool it down) |
| Cause: | The fan in the power source is faulty |
| Cause: | Insufficient cooling air intake |
| Remedy: | Ensure adequate air supply |
| Cause: | Air filter is dirty |
| Remedy: | Clean air filter |
| Cause: | Power module error |
| Remedy: | Turn off the device, then turn it on again If the error occurs frequently, contact After-Sales Service |
| Cause: | Incorrect welding process selected |
| Remedy: | Select "MMA welding" or "MMA welding with Cel electrode" process |
| Cause: | Starting current too low; electrode sticking during ignition |
| Remedy: | Increase starting current using HotStart function |
| Cause: | Starting current too high; electrode consumed too quickly during ignition or is generating a lot of spatter |
| Remedy: | Reduce starting current using SoftStart function |
| Cause: | Break voltage (Uco) set too low |
| Remedy: | Increase break voltage (Uco) in Setup menu |
| Cause: | Electrode (e.g. grooved electrode) voltage too high |
| Remedy: | If possible, use an alternative electrode or a power source with more welding power |
| Cause: | Value of arc-force dynamic parameter (MMA welding) set too low |
| Remedy: | Increase value of arc-force dynamic parameter |
| Cause: | Incorrect electrode polarity |
| Remedy: | Reverse electrode polarity (refer to manufacturer's instructions) |
| Cause: | Poor grounding (earthing) connection |
| Remedy: | Fasten earthing clamps directly to workpiece |
| Cause: | Setup parameters not ideal for selected welding process |
| Remedy: | Select the optimal settings in the Setup menu for the selected welding process |
| Cause: | Incorrect tungsten electrode polarity |
| Remedy: | Connect the TIG welding torch to the (-) current socket |
| Cause: | Incorrect (or no) shielding gas |
| Remedy: | Use inert shielding gas (argon) |
Average wire electrode consumption at a wire speed of 5 m/min | |||
| 1.0 mm wire electrode diameter | 1.2 mm wire electrode diameter | 1.6 mm wire electrode diameter |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminium wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminium wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
If the ambient temperature is higher, either the ED or output must be reduced accordingly.
Example: Welding at 150 A at 60% ED
If the device is to be continuously operated without stopping:
Mains voltage (U1) | 1 x 230 V | ||
Max. effective primary current (I1eff) | 15 A | ||
Max. primary current (I1max) | 24 A | ||
Max. apparent power (S1max) | 5.52 kVA | ||
Mains fuse protection | 16 A slow-blow | ||
Mains voltage tolerance | -20% / +15% | ||
Grid frequency | 50/60 Hz | ||
Cos phi | 0.99 | ||
Max. permitted mains impedance Zmax at PCC1) | 32 mOhm | ||
Recommended earth-leakage circuit breaker | Type B | ||
Welding current range (I2) rod electrode | 10 - 150 A | ||
Welding current range (I2) TIG | 10 - 150 A | ||
Welding current for MMA welding 10 min / 40 °C (104 °F) | 35 % | 60 % | 100 % |
Welding current for TIG welding 10 min / 40 °C (104 °F) | 35 % | 60 % | 100 % |
Output voltage range according to standard characteristic (U2) rod electrode | 20.4 - 26 V | ||
Output voltage range according to standard characteristic (U2) TIG | 10.4 - 16 V | ||
Open circuit voltage (U0 peak) | 96 V | ||
Degree of protection | IP 23 | ||
Type of cooling | AF | ||
Overvoltage category | III | ||
Pollution degree according to IEC60664 | 3 | ||
EMC device class | A | ||
Safety symbols | S, CE | ||
Max. shielding gas pressure | 5 bar | ||
Dimensions (length x width x height) | 365 x 130 x 285 mm | ||
Weight | 6.6 kg | ||
Idle state power consumption | 15 W | ||
Power source efficiency at | 87 % | ||
| 1) | Interface to a 230/400 V and 50 Hz public grid |
Max. effective primary current (I1eff) | 16 A | ||
Max. primary current (I1max) | 25 A | ||
Max. apparent power (S1max) | 5.75 kVA | ||
Cos phi | 0.99 | ||
Max. permitted mains impedance Zmax at PCC1) | 285 mOhm | ||
Welding current range (I2) rod electrode | 10 - 180 A | ||
Welding current range (I2) TIG | 10 - 220 A | ||
Welding current for MMA welding 10 min / 40 °C (104 °F) | 40 % | 60 % | 100 % |
Welding current for TIG welding 10 min / 40 °C (104 °F) | 40 % | 60 % | 100 % |
Output voltage range according to standard characteristic (U2) rod electrode | 20.4 - 27.2 V | ||
Output voltage range according to standard characteristic (U2) TIG | 10.4 - 18.8 V | ||
Open circuit voltage (U0 peak) | 101 V | ||
Dimensions (length x width x height) | 435 x 160 x 310 mm | ||
Weight | 9.0 kg | ||
Power source efficiency at | 88 % | ||
Mains voltage (U1) | 1 x 230 V | 1 x 120 V | 1 x 120 V |
Max. effective primary current (I1eff) | 16 A | 20 A | 15 A |
Max. primary current (I1max) | 25 A | 29 A | 19 A |
Max. apparent power (S1max) | 5.75 kVA | 3.48 kVA | 2.28 kVA |
Mains fuse protection | 16 A slow-blow | 20 A slow-blow | 15 A slow-blow |
Cos phi | 0.99 | ||
Welding current range (I2) |
Welding current for MMA welding, | 40%/180 A | 40%/120 A | 40%/85 A |
Welding current for TIG welding, | 40%/220 A | 40%/170 A | 40%/140 A |
Output voltage range according to standard characteristic (U2) |
Weight | 9.2 kg | ||
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
