en
      User informationTPS/i Interface Signal Descriptions
    • General
      • Data types used
      • Behavior of the welding machine when an interface is connected
      • Availability of Functions
      • Signal Transmission Time
      • Safety
    • Digital Inputs
      • Welding start (Welding on) - Single Bit
      • Robot ready (Robot ready) - Single Bit
      • Working mode (operating mode) - Group Bit
      • Gas on (Gas on) - Single Bit
      • Wire forward (Wire forwards) - Single Bit
      • Wire backward (Wire return) - Single Bit
      • Error reset (Reset error) ‑ Single Bit
      • TouchSensing (TouchSensing) ‑ Single Bit
      • Torch blow out (Blow out welding torch) - Single Bit
      • Processline select (Process line selection) - Group Input
      • Welding simulation (Welding simulation) - Single Bit
      • Synchropulse on (SynchroPulse on) - Single Bit
      • TAC on - Single Bit
      • Cap-shaping - Single Bit
      • Pilot arc on (Pilot arc on) - Single Bit
      • Booster manual - Single Bit
      • ColdWire disable - Single Bit
      • WireBrake on (Wire brake on) - Single Bit
      • Torchbody Xchange (Change torch body) - Single Bit
      • Teach mode - Single Bit
      • WireSense start - Single Bit
      • WireSense break - Single Bit
      • WireSense joint type (joint type) - Group Input
      • TWIN mode (TWIN operating mode) - Group Input
      • Documentation mode (Documentation mode) - Single Bit
      • Disable process controlled correction (Deactivate process-dependent correction) - Single Bit
      • ExtInput 1-8 (External input 1-8) - Single Bit
      • Job number (Job number) - Group Input
      • Welding characteristic (Characteristic number) - Group Input
      • Seam number (Seam number) - Group Input / Analog Input
      • Contact tip short circuit detection on (contact tip short circuit detection on) - Single Bit
    • Analog Inputs
      • Wire feed speed command value - Group Input / Analog Input
      • Main- / Hotwire current command value - Analog Input
      • Arclength correction (arc length correction) - Group Input / Analog Input
      • Hotwire current (Hot-wire amperage) - Group Input / Analog Input
      • Pulse-/ dynamic correction (Pulse/dynamic correction) - Group Input / Analog Input
      • Wire correction (DynamicWire)
      • Wire retract correction (Wire retraction correction) - Group Input / Analog Input
      • Wire retract end (Wire retract at end of welding) - Analog Input
      • Welding speed (Welding speed) - Group Input / Analog Input
      • Wire positioning start - Analog Input
      • Plasma gas command value - Analog Input
      • Wire forward / backward length (length specification wire threading / wire retraction) - Group Input / Analog Input
      • WireSense trigger level - Group Input / Analog Input
    • Digital Outputs
      • Definition
      • Heartbeat power source (Heartbeat power source) - Single Bit
      • Power source ready (Welding machine ready) - Single Bit
      • Warning (Warning) - Single Bit
      • Process active (Process active) - Single Bit
      • Current flow (current flow) - Single Bit
      • Arc stable / Touch signal (Arc stable/touch signal) - Single Bit
      • Main current signal (main current signal) - Single Bit
      • Touch signal (Touch signal) - Single Bit
      • Collisionbox active (CrashBox active) - Single Bit
      • Robot motion release (Robot motion release) - Single Bit
      • Wire stick workpiece (Wire stick workpiece) - Single Bit
      • Electrode overloaded
      • Short circuit contact tip (contact tip short circuit) - Single Bit
      • Parameter selection internally (Internal parameter selection) - Single Bit
      • Characteristic number valid (Characteristic number valid) - Single Bit
      • Torchbody gripped (Torch body gripped) - Single Bit
      • Command value out of range (set value out of range) - Single Bit
      • Correction out of range (Correction out of range) - Single Bit
      • Limitsignal
        (Limit signal) - Single Bit
      • Standby active - Single Bit
      • Main supply status (Mains voltage status) - Single Bit
      • Sensor Status 1 (sensor status 1) - Single Bit
      • Sensor Status 2 (sensor status 2) - Single Bit
      • Sensor Status 3 (sensor status 3) - Single Bit
      • Sensor Status 4 (sensor status 4) - Single Bit
      • Function status (Function status) - Single Bit
      • Safety status - Single Bit
      • Notification (Notification) - Single Bit
      • System not ready - Single Bit
      • Pulse current active (Pulse current active) - Single Bit
      • Pilot arc active (Pilot arc active) - Single Bit
      • Process run (Process run) - Single Bit
      • Process Bit (Process bit) - Group Output
      • Active process line - Single Bit
      • Touch signal gas nozzle - Single Bit
      • Twin synchronization active - Single Bit
      • ExtOutput 1-8 (External output 1-8) - Single Bit
    • Analog Outputs
      • Welding voltage (Welding voltage) - Group Output / Analog Output
      • Welding current (Welding current) - Group Output / Analog Output
      • Wire feed speed (Wire speed) - Group Output / Analog Output
      • Actual real value for seam tracking (Current actual value for seam tracking) - Group Output / Analog Output
      • Error number (Error number) - Group Output / Analog Output
      • Warning number (Warning number) - Group Output / Analog Output
      • Motor current M1 (Motor current M1) - Group Output / Analog Output
      • Motor current M2 (Motor current M2) - Group Output / Analog Output
      • Motor current M3 (Motor current M3) - Group Output / Analog Output
      • Actual real value AVC - Group Output / Analog Output
      • Resistance - Single Bit
      • Wire position (wire position) - Group Output / Analog Output
      • Wire buffer fill level - Group Output / Analog Output
    • Available Process Images
      • Process image types
      • Changing/assigning characteristic numbers/program numbers (Retro Fit mode)
    • Information on the use of the MIG/MAG standard manual, TIG, electrode, and ConstantWire welding processes
      • MIG/MAG standard manual
      • TIG
      • Electrode
      • ConstantWire
    • Arc Break Monitoring
      • Arc break monitoring
    • Fronius Data Channel
    • Signal sequence when selected using "Job Mode" operating mode
    • Signal sequence when selected using "Characteristics Mode" operating mode
    • WireSense - more information
      • WireSense joint type description
      • WireSense trigger level description
      • Process description WireSense contour sensing mode (contour detection)
      • Process description WireSense joint type detection (joint type detection)
      • Signal profile in joint type detection mode for lap joint
      • Signal profile in joint type detection mode for T-joint
      • Signal profile in joint type detection mode for YV butt joint
      • Signal profile in joint type detection mode for square butt joint
      • Signal profile in joint type detection mode for flange joint
      • Signal profile in joint type detection mode for corner joint
      • Signal profile WireSense break (only possible in contour sensing mode)
      • Signal profile in contour sensing mode for different surface geometries
      • Representation of the possible WireSense measurement range
      • Note on height measurement for lap joints with falling edges
      • Note on ignition timeout (Ignition Timeout)
      • WireSense Isolated mode
    • Available signals for component scanning
      • Signal list
    • Limit Monitoring - functions and activation
      • Functions of Limit Monitoring
      • Available function packages
      • Prerequisites for the successful use of Limit Monitoring
      • Switch Limit Monitoring on / off
      • Detailed description of Limit Monitoring
    • Limit Monitoring - details on the individual welding parameters
      • Voltage monitoring
      • Current monitoring
      • Wirefeeder monitoring
      • Welding time monitoring
      • Energy monitoring
      • Setting of the reaction when exceeding or falling below the limits:
      • Setting of the reaction when exceeding or falling below the limits for the motor force
      • Smart Manager + OPT/i Jobs (4,067,002)
    • 035-12062026
    download
    Digital inputs
    Analog inputs
    Digital outputs
    Analog outputs
    Available process images
    Spare parts
    ContactLegal NoticeTerms and conditions of useData Privacy StatementCookie Policy
    General
    link_horizontalLink copied
    Data types used
    UINT 16 (Unsigned Integer) = Whole number in the range from 0 to 65,535.
    SINT 16 (Signed Integer) = Whole number in the range from -32,768 to 32,767.
    Conversion examples:
    • For a positive value (SINT 16) = desired wirefeeder speed x factor = 12.3 m/min x 100 = 1230dec = 04CEhex.
    • For a positive value (SINT 16) = desired arc length correction x factor = -6.4 x 10 = -64dec = FFC0hex.
    Unsigned (UINT):
    Type:
    Unsigned 16 Bit integer = 16 bits
    Range:
    0 to 65535
    0000
    -10
    (0000000000000000)
    32767
    0
    (0111111111111111)
    65535
    +10
    (1111111111111111)
    Signed (SINT):
    Type:
    Signed 16 Bit integer (15 bits + 1 Sign-Bit*)
    Range:
    -32768 to 32767
    0000
    0000
    (0*000000000000000)
    56
    56
    (0*000000000111000)
    -64
    -64
    (1*111111111000000)
    * = if the value entered has a negative sign, the sign is Bit High – see markings.
    1. General
    Data types used
    Unsigned (UINT):
    Type:
    Range:
    0 to 65535
    0000
    -10
    (0000000000000000)
    32767
    0
    (0111111111111111)
    65535
    +10
    (1111111111111111)
    Signed (SINT):
    Type:
    Range:
    -32768 to 32767
    0000
    0000
    (0*000000000000000)
    56
    56
    (0*000000000111000)
    -64
    -64
    (1*111111111000000)
    1. General
    If a welding machine from the TPS/i series is connected to a robot interface, the settings on the welding machine remain unchanged (2-step mode, special 2-step mode, etc.).
    If a welding machine from the TPS series is connected to a robot interface, the welding machine automatically selects 2-step mode.
    1. General
    As a result of updates, certain functions may be available on your device that are not described in this document, or vice versa.
    1. General
    Representation of the signal transmission time; the signals shown are for illustrative purposes only
    1. General
    Safety
    WARNING!
    Danger due to incorrect operation and work not carried out correctly.
    This may result in serious personal injury and damage to property.
    All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
    Read and understand all safety rules and user documentation for this equipment and all system components.
    Digital Inputs
    The rising edge of the Welding start signal starts the welding process.
    • The welding process runs for as long as the Welding start signal is active.
      Exceptions: The Robot ready signal is deactivated or the welding machine is reporting an error (for example: overtemperature, too little coolant, etc.).
    • The Welding start signal can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    • Touch mode cannot be activated as long as the Welding start signal remains set.
    Additional information for TWIN systems:
    • In single wire mode, the welding process is started on the active welding machine.
    • In TWIN mode, the welding process is started on both welding machines.
    1. Digital Inputs
    1. Digital Inputs
    The robot sets this signal as soon as it is ready to weld.
    • If the signal is reset by the robot during welding, the welding process is ended in a controlled manner (without any crater filling routines).
    • In addition, the Robot not ready error is output. This error must either be reset on the welding machine control panel or using the robot interface.
    • It is still possible to specify the set values in the internal parameter selection operating mode, even if the Robot ready signal is not set.
    1. Digital Inputs
    This signal is used to select the operating mode of the welding machine.
    Value range for operating mode:
    Bit 4
    Bit 3
    Bit 2
    Bit 1
    Bit 0
    Description
    0
    0
    0
    0
    0
    0
    0
    0
    0
    Special 2-step mode characteristics
    0
    0
    0
    0
    Job Mode
    0
    0
    0
    0
    0
    0
    0
    MIG/MAG standard manual, 2-step
    0
    0
    0
    0
    Quiet mode
    0
    0
    0
    Stop coolant pump
    0
    0
    0
    R/L measurement
    Description of internal parameter selection:
    • The control panel or a remote control can be used to specify all the set values and material settings important for welding. This makes creating and saving jobs easy.
    • The robot outputs all other signals.
    • These values can also be specified during welding.
    Internal parameter selection can be used to select:
    • 4-step mode
    • Special 4-step mode
    • Electrode
    • TIG
    Description of special 2-step mode characteristics:
    • To select welding parameters using the analog set values and the characteristic number (characteristic ID), the correct characteristic number must be used. The characteristic numbers can be found on the website of the welding machine, in the characteristics overview.
    • The welding process is also defined using the characteristic number (MIG/MAG standard synergic, MIG/MAG pulse synergic, MIG/MAG LSC, MIG/MAG PMC, MIG/MAG CMT, TIG, TIG cold wire, TIG DynamicWire, HotWire).
    • Only characteristics that have previously been approved for the welding machine can be selected.
    • The parameters from the start of welding/end of welding are used in the special 2-step mode characteristics.
    Special 2-step mode signal sequence
    Description of Job Mode:
    • The welding parameters are selected using the data saved in the jobs.
    • The EasyJob function is deactivated as soon as a CC module (an RI IO/i or a RI IO PRO/i) is connected.
    • There is no job with the number 0. Job number 0 can be used to select the job on the control panel of the welding machine.
    Description of 2-step mode characteristics:
    • The welding process is also defined using the characteristic ID (MIG/MAG standard synergic, MIG/MAG pulse synergic, MIG/MAG LSC, MIG/MAG PMC, MIG/MAG CMT, etc.).
    For MIG/MAG standard manual characteristics, the 2-step mode characteristics must be used.
    Description of MIG/MAG standard manual, 2-step:
    • MIG/MAG standard manual welding is a MIG/MAG welding process with no synergic function. Changing one parameter does not result in any automatic adjustments to the other parameters. All of the variable parameters (wire speed, welding voltage, arc-force dynamic) must therefore be adjusted individually, as dictated by the welding process in question.
    Description of Quiet mode / Idle mode ("Working mode 16"):
    • This signal is used to put the welding machine in Idle mode. In Idle mode, the booster is reduced to a minimum of the supply voltage in order to reduce the power consumption.
    • In this working mode, it is not possible to start processes such as Welding start, Wire forward, Wire backward, TouchSensing, and Teach.
    Description of Stop coolant pump ("Working mode 17"):
    • In Working mode 17, the coolant pump is switched to "stop" (also possible from an external control). The cooling circuit is interrupted, all other functions of the welding machine remain active. The process parameter "Cooling unit operating mode" is not changed by Working mode 17.
    • Once Working mode 17 has finished, the desired operating mode must be selected again.
    • Welding is not possible in Working mode 17.
    Description of R/L-measurement (“Working mode 24"):
    • In Working mode 24, the welding circuit resistance (R) and the welding circuit inductance (L) of the welding system are measured.
      Requirements for R/L measurement:
      The welding system must be complete: closed welding circuit with welding torch and torch hosepack, wirefeeders, return lead cables, and interconnecting hosepacks.
      Performing an R/L measurement:
      • Use the robot or the controller to select Working mode 24. The current values for welding circuit inductance and welding circuit resistance are displayed.
      • IMPORTANT! Contact between the earthing clamp and the workpiece must be made on a cleaned workpiece surface.
      • The R/L measurement is started with the "Wire forward" input signal.
      • After the measurement has been carried out, the new measured values for the welding circuit resistance (R) and the welding circuit inductance (L) are displayed on the R/L alignment wizard.
        The "Function status" output signal transmits the status of the measurement (Inactive, Idle, Finished, Error).
        The "Resistance" output signal transmits the measured value.
      • Select a different Working mode to exit the R/L alignment wizard.
    1. Digital Inputs
    The Gas on signal opens the gas solenoid valve and thus activates the gas flow.
    • As long as the signal is High, the gas solenoid valve remains open.
    • The gas flow can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    • During welding, the gas pre-flow and the gas post-flow are controlled by the welding machine. It is therefore not necessary to activate the gas pre-flow and gas post-flow separately.
    • If the Gas on High signal is set before the Welding start signal, the gas pre-flow of the welding machine is not active.
    • The Gas on signal can only be set if the Robot ready signal is set at the same time. If this is not the case, the gas flow must be activated by pressing a button on one of the Fronius system components (welding machine, wirefeeder, torch hosepack, etc.).
    • In single wire mode with a Single-torch body, the gas solenoid valve of the active process line is opened.
    • In TWIN mode, both gas solenoid valves are opened.
    • When welding with a TWIN torch body, both gas solenoid valves are always opened.
    1. Digital Inputs
    The Wire forward signal activates the start of the wirefeeder.
    • The wire electrode is threaded into the hosepack without current or gas.
    • The wirefeeder can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    • The signal corresponds to the wire threading button on the control panel of the welding machine, on the wirefeeder, and on the torch hosepack. The precise function of the wire threading button is described in the operating instructions of the respective system components/the documentation of the whole welding system.
    • As long as the Wire forward signal is set, the Wire backward signal cannot be set.
    • The Wire forward signal can only be set if the Robot ready signal is set at the same time. If this is not the case, wire threading must be controlled using the wire threading button on one of the Fronius system components (wirefeeder, torch hosepack, etc.).
    • The wire electrode can be threaded a maximum of 50 m (164 feet 0.5 inches) (=safety stop).
    The signal can be set in two ways:
    • Pulse signal = wire electrode moves approx. 1 mm (0.039 inches) forwards.
    • Continuous signal = creep function—the wirefeeder is stopped as soon as the wire electrode touches the welding ground.
    • In single wire mode, the wire electrode of the active process line is fed.
    • In TWIN mode, both wire electrodes are fed.
    • If the TWIN operating mode changes during wirefeeding, the wirefeeding is adapted in line with the change.
    1. Digital Inputs
    The Wire backward signal activates the retraction of the wire electrode.
    • It can be used to retract the wire electrode out of the welding torch completely or only by a specific length.
    • The retraction can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    • The signal corresponds to the wire-return button on the control panel of the welding machine, on the wirefeeder, and on the torch hosepack. The precise function of the wire-return button is described in the operating instructions of the respective system components/the documentation of the whole welding system.
    • As long as the Wire backward signal is set, the Wire forward signal cannot be set.
    • The Wire backward signal can only be set if the Robot ready signal is set at the same time. If this is not the case, retraction of the wire electrode must be controlled using the wire-return button on one of the Fronius system components (wirefeeder, torch hosepack, etc.).
    • The wire electrode can be retracted a maximum of 50 m (164 feet 0.5 inches) (=safety stop).
    • Pulse signal = wire moves approx. 1 mm (0.039 inches) backwards.
    • Continuous signal = permanent wire retraction.
    1. Digital Inputs
    If an error message is output on the welding machine, the error is reset using the Error reset signal.
    In order to reset the signal successfully, the signal must remain set for at least 10 ms.
    WARNING!
    Danger due to welding processes starting unexpectedly.
    The cause of the error must always be resolved before the error message is reset using the Error reset signal.
    WARNING!
    Danger due to welding processes starting unexpectedly if the Error reset signal is always active and the Welding start signal is set at the same time.
    Ensure that the Welding start signal is not set during troubleshooting if the Error reset signal is active at the same time.
    The signal resets the error on both welding machines.
    1. Digital Inputs
    CAUTION!
    Danger from unexpected electric shock.
    When TouchSensing is activated, a voltage of approx. 70 V (up to 3 A) is applied to the wire electrode/gas nozzle.
    If touched, a harmless but perceptible electric shock can be transmitted. This can result in injuries.
    Do not touch the wire electrode and the torch body (gas nozzle, contact tip, etc.) when TouchSensing is active.
    When Teach mode is active, do not touch any electrically conductive parts that are touched by the wire electrode and the torch body (gas nozzle, contact tip, etc.).
    The TouchSensing signal can be used to detect contact between the wire electrode or the gas nozzle and the workpiece = short circuit between workpiece and wire electrode or gas nozzle.
    • If the TouchSensing signal is set, the control panel of the welding machine displays touch and a voltage of approx. 70 V (current limited to 3 A) is applied to the wire electrode/the gas nozzle.
    • If a short circuit occurs, this is reported to the robot controller by the Arc stable / Touch signal (see section Arc stable / Touch signal (Arc stable/touch signal) - Single Bit) and Touch signal (see section Touch signal (Touch signal) - Single Bit).
    • The output of the Arc stable / Touch signal (see section Arc stable / Touch signal (Arc stable/touch signal) - Single Bit) and Touch signal (see section Touch signal (Touch signal) - Single Bit) lasts 0.3 seconds longer than the duration of the short circuit current.
    • As long as the Welding start signal is set, the TouchSensing signal cannot be activated.
    • The welding process can also be started if the TouchSensing signal is active. This automatically deactivates the touch function.
    • TouchSensing can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    TouchSensing function/process:
    NOTE!
    Risk of signal overlap.
    This can lead to problems in connection with the WireBrake option.
    After deactivating the TouchSensing signal, wait 4 seconds before setting another signal.
    • TouchSensing is started on both welding machines, but is only ever carried out on one wire electrode.
    • In single wire mode, the wire electrode of the active process line is used.
    • In TWIN mode, the wire electrode of the leading process line (Lead) is used—only when the wire electrode of the Lead-welding machine is touched are the TouchSensing signals generated.
    Additional information for TouchSensing with the gas nozzle:
    If the position detection is carried out by touching the workpiece with the gas nozzle (instead of the wire electrode), the gas nozzle must be connected to the welding current lead using an RC element or the TouchSensing Adv. option.
    Gas nozzle + RC element:
    • The use of an RC element is required so that if the gas nozzle comes into contact with the workpiece during welding:
      • Unacceptable currents in the connection between the gas nozzle and the welding current lead are avoided.
      • The welding process is not influenced.
    • When the position is detected by contact with the gas nozzle, the short circuit current flows until the capacitors of the RC element are charged (a few milliseconds). To ensure safe position detection by the robot controller, the Arc stable and TouchSensing signals are on for 300 milliseconds longer than the short circuit current.
    Gas nozzle + OPT/i Touch Sense Adv.:
    • The OPT/i Touch Sense Adv. option can be used to detect whether the gas nozzle is touching the workpiece ("gas nozzle touching"). In addition, a distinction is made as to whether the gas nozzle or the wire electrode has touched the workpiece.
    • Furthermore, OPT/i Touch Sense Adv. checks whether there is a short circuit between the gas nozzle and the contact tip (see Short circuit contact tip signal in section Short circuit contact tip (contact tip short circuit) - Single Bit and Touch signal gas nozzle signal in section Touch signal gas nozzle - Single Bit).
    1. Digital Inputs
    If the robot wirefeeder is fitted with an additional solenoid valve for compressed air, this is controlled using the Torch blow out signal.
    The signal is used to remove contaminations from the gas nozzle during torch cleaning.
    1. Digital Inputs
    This signal is used to select the desired process line.
    The signal is only available if:
    • The OPT/i TPS Dual Head Robotics option is present in the welding machine.
    • Each process line has its own wirefeeder.
    Bit 1
    Bit 0
    Description
    0
    0
    Wirefeeder 1 (factory setting)
    0
    Wirefeeder 2
    0
    Wirefeeder 3
    Function information:
    • It is only possible to switch between the process lines using the robot.
    • The inactive wirefeeders are only supplied with voltage, the system bus is switched off. This has the following limitations:
      • Available software updates will only be applied to the wirefeeder if the wirefeeder is part of the process line selected.
      • The CAT signal of inactive wirefeeders is not evaluated.
      • It is not possible to carry out gas tests, wire threading, wire retraction, etc. on the hosepacks of the inactive process lines.
      • The welding torch identification of hosepacks of the inactive process lines is not read.
      • The remote controls of the inactive process lines are also inactive.
    1. Digital Inputs
    The welding machine uses the Welding simulation signal to simulate an actual welding process.
    • This allows the user to follow a welding path that has been programmed in the robot controller without any actual welding taking place.
    • All signals are set as if actual welding were taking place (no actual values)
      • Process active
      • Current flow
      • Arc stable
    • No arc is ignited (Welding start signal).
    • No wire electrode is moved (Wire forward and Wire backward signal).
    • The gas solenoid valve is not triggered ( Gas on signal).
    • The gas purging valve is not triggered ( Torch blow out signal).
    1. Digital Inputs
    The Synchropulse on signal activates/deactivates the SynchroPulse function set in the welding machine. The signal can be set before or during welding.
    1. Digital Inputs
    TAC on - Single Bit
    The tacking function is used for the TIG DC welding process.
    Whenever a period of time is set for the "Tacking" (4) parameter under process parameters/TIG DC settings, the tacking function is assigned to the 2-step and 4-step modes. The sequence of operating modes remains unchanged.
    The tacking (TAC) indicator lights up on the status bar:
    During this time, a pulsed welding current is available, which optimizes the merging of the weld pool when tacking two components.
    How the tacking function works during TIG DC welding:
    Key:
    I-P
    Pulse current
    I-S
    Starting current
    F-P
    Pulse frequency *)
    I-E
    Final current
    dcY
    Duty cycle
    tup
    UpSlope
    I-G
    Base current
    tDown
    DownSlope
    I-1
    Main current
    *) (1/F-P = Time between two pulses)
    NOTE!
    When using a pulsed welding current:
    The welding machine automatically controls the pulse parameters according to the set main current (I-P).
    No pulse parameters need to be set.
    The pulsed welding current starts
    • After the starting-current phase has elapsed (I-S)
    • With the UpSlope phase tup
    • After the DownSlope has elapsed (tDown)
    • Before the final current phase (I-E)
    The pulsed welding current lasts until the final current phase (I-E) (TIG DC tacking parameter "on").
    1. Digital Inputs
    Only for iWave AC/DC!
    The Cap-shaping signal enables automatic cap-shaping when the AC welding process is selected.
    This takes into account the set electrode diameter to deliver optimum results. Automatic cap-shaping ensures that the optimum cap is formed during the start of welding. After that, cap-shaping is automatically deactivated and welding must be restarted.
    Setting range: off / on
    Factory setting: off
    Off: Automatic cap-shaping function is deactivated.
    On: The optimum cap for the entered diameter of the tungsten electrode is shaped during the start of welding.
    The automatic cap-shaping function is then reset and deactivated.
    (1) ... before ignition
    (2) ... after ignition
    1. Digital Inputs
    The rising edge of the Pilot arc on signal starts the plasma pilot arc.
    • The plasma pilot arc burns as long as the Pilot arc on signal is active.
      Exceptions: The Robot ready signal is deactivated or the welding machine issues an error message (e.g., overtemperature, insufficient coolant, etc.).
    • The pilot arc remains active after the main arc has gone out as long as the Pilot arc on signal is set.
    • The Pilot arc on signal can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    • Touch mode and wire threading cannot be activated as long as the Pilot arc on signal is set.
    1. Digital Inputs
    This signal can be used to deactivate the automatic Idle mode.
    If there is no welding activity for a certain period of time, the welding machine switches to Idle mode. In Idle mode, the booster is reduced to a minimum of the supply voltage in order to reduce the power consumption.
    The booster will be re-initialized every time at the start of welding. This means there may be a short delay of a few milliseconds before the booster is active again.
    Note: If this signal is activated, the idle power consumption can rise above 50 watts.
    1. Digital Inputs
    This signal interrupts the wirefeeder of the cold wire during the welding process without ending the welding process itself. If the cold wire is interrupted, the value set for "Wire retract end" is ALWAYS used.
    1. Digital Inputs
    By activating the WireBrake on signal, the wire electrode is held by the OPT/i MHP WireBrake.
    OPT/i MHP WireBrake is a mechanical component that is installed between the torch hosepack and the torch body.
    WireBrake on can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    If OPT/i MHP WireBrake is detected in the system, the WireBrake on signal is automatically set in TouchSensing.
    NOTE!
    This may result in problems holding the wire electrode.
    It is not recommended to activate any other signals while the WireBrake on signal is active.
    After deactivating the WireBrake on signal, wait 4 seconds before activating another signal.
    A detailed description of the program sequence can be found in the Robacta TX 10i/G/W Operating Instructions.
    WireBrake is not available for TWIN hosepacks.
    1. Digital Inputs
    The Torchbody Xchange signal is only available in conjunction with a torch body change system.
    If the signal is High, the torch body coupling is opened.
    Torchbody Xchange can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode).
    NOTE!
    This may result in problems changing the torch body.
    It is not recommended to activate any other signals while the Torchbody Xchange signal is active.
    After deactivating the Torchbody Xchange signal, wait 3 seconds before activating another signal.
    Detailed description of the program sequence—see operating instructions for the torch body change system.
    1. Digital Inputs
    WARNING!
    Danger from electrical current due to Teach mode being active. When Teach mode is active, a voltage of approx. 70 V (up to 3 A) is applied to the wire electrode/contact tip.
    This may result in serious injuries or death.
    Do not touch the wire electrode and the contact tip when Teach mode is active.
    When Teach mode is active, do not touch any electrically conductive parts that are touched by the wire electrode or the contact tip.
    Teach mode can be used to create the robot program. Teach mode being activated (signal High) avoids the wire electrode becoming bent when setting up the robot.
    Teach mode can be activated independently of the operating mode (internal parameter selection, special 2-step mode characteristics, Job Mode, etc.).
    The wire electrode is cyclically moved back and forth when the component is touched. The current wire position is output on the Wire position signal.
    Teach mode function:
    • Ensure the desired distance (Stickout) to the workpiece.
    • Cut the wire electrode to the correct Stickout .
    • If the distance between the gas nozzle and the workpiece becomes smaller during robot movement, the wirefeeder retracts the wire electrode. This means that the wire electrode cannot be bent.
    • If the distance between the gas nozzle and the workpiece becomes bigger during robot movement, the wirefeeder unwinds the wire electrode up to the set Stickout .
    • The wire electrode will not be unwound any further once the set Stickout value has been reached, even if the wire electrode is no longer in contact with the workpiece.
    The Touch signal is set as follows when using Teach mode:
    • As soon as the wire electrode touches the workpiece, the Touch signal is set to High.
    • Only when the wire electrode is no longer in contact with the workpiece is the Touch signal set to Low.
    NOTE!
    Danger from using Teach mode in conjunction with very soft wire electrodes.
    This may result in unexpected welding results caused by bent wire electrodes.
    Using Teach mode with very soft wire electrodes may result in the wire electrodes becoming bent. To prevent wire burn-back caused by the bent wire electrode, unwind the wire electrode by approx. 50 mm (1.97 inches) before the start of welding and shorten it.
    • In single wire mode, Teach mode is activated for the active process line.
    • In TWIN mode, Teach mode is activated for both process lines.
      • The scanning frequency of the wire electrode during component contact with the Lead-welding machine is higher than the scanning frequency with the Trail-welding machine.
    1. Digital Inputs
    WARNING!
    Danger from electrical current. When the WireSense start signal is active, a voltage of approx. 50 V (up to 1 A) is applied to the wire electrode/contact tip.
    Do not touch the wire electrode and contact tip when the WireSense start signal is active.
    Do not touch any electrically conductive parts that are touched by the wire electrode or the contact tip when the WireSense start signal is active.
    This signal starts one of the following two functions:
    1. WireSense contour sensing mode function (= contour detection): Used for scanning the component surface/component geometry.
      • This function is active when the WireSense start signal is activated and a height value less than 0.5 mm (0.02 inches) is specified for the WireSense trigger level signal.
      • Detection of a special joint type (WireSense joint type detection mode) is not active with this function.
      • The Touch signal is not output for this function.
    2. WireSense joint type detection mode function (= joint type detection): Used to detect the set joint type.
      • This function is active when the WireSense start signal is activated and a height value greater than / equal to 0.5 mm (0.02 inches) is specified for the WireSense trigger level signal.
      • For more information on this, see WireSense trigger level - Group Input / Analog Input.
    Other effects of the WireSense start signal:
    • As soon as the signal is active, the forward and backward movement of the wire electrode begins.
    • After the wire electrode has touched the workpiece for the first time, the point of the first contact is used as a zero position (reference point) for the WireSense process.
    Safety functions with WireSense:
    • If WireSense is already active (WireSense process already running), the wire electrode can be conveyed a maximum of 24 mm (0.98 inches). If there is no workpiece contact within 24 mm (0.98 inches), wirefeeding is stopped.
    • If WireSense is started for the first time (without previous workpiece contact), the wire electrode can be conveyed a maximum of 450 mm (17.72 inches). If there is no workpiece contact within 450 mm (17.72 inches), wirefeeding is stopped.
    For more information on WireSense, see section WireSense - more information.
    • In single wire mode, WireSense is only activated and evaluated for the active process line.
    • In TWIN mode, WireSense is activated for both process lines. Please note the following:
      • The Touch signal, which can be output in WireSense joint type detection mode, is only triggered by the Lead-welding machine.
      • The position signals during contour detection  (WireSense contour sensing mode) are output at the interface with two individual output signals simultaneously—with the Wire position signal for
        welding machine 1 and welding machine 2.
    1. Digital Inputs
    • This signal only has an impact if the WireSense process is active in Contour sensing mode, the WireSense start signal is active, and the WireSense trigger level signal is less than 0.5 mm.
    • This signal is used to interrupt the WireSense process but at the same time to obtain the reference point that was determined when the WireSense process was first started.
      • The WireSense break signal stops the wire movement while the WireSense start signal is active—for example, to bridge larger distances between two workpieces (if the wire electrode is touching a workpiece while the WireSense break signal is active, the wire electrode is still retracted to prevent bending).
      • The reference point, which was determined when the WireSense process was first started, remains stored while the WireSense break signal is active.
      • After the WireSense break signal is deactivated, the wire movement starts again and the height measurement continues.
    • If the WireSense break signal is set, the Arc stable signal is disabled at the same time. As soon as the WireSense break signal is deactivated again, the Arc stable signal is reactivated.
    For more information on WireSense , see section WireSense - more information.
    • In single wire mode, WireSense break only stops the wire electrode of the active process line.
    • In TWIN mode, WireSense break stops both wire electrodes.
    1. Digital Inputs
    This signal selects which joint type is to be searched for by means of the WireSense process. The type of joint is selected before starting the WireSense process (see section WireSense start - Single Bit).
    WireSense joint type value range:
    Bit 3
    Bit 2
    Bit 1
    Bit 0
    Description
    0
    0
    0
    0
    Lap joint/trigger both edges
    0
    0
    0
    Lap joint/trigger rising edge
    0
    0
    0
    Lap joint/trigger falling edge
    0
    0
    Lap joint/trigger second rising edge
    0
    0
    0
    Lap joint/trigger second falling edge
    0
    0
    T-joint
    0
    0
    YV butt joint
    0
    Square butt joint
    0
    0
    0
    Flange joint
    0
    0
    Corner joint
    For more information onWireSense, see section WireSense - more information.
    1. Digital Inputs
    This signal defines which TWIN mode will be used to operate the respective welding machine.
    The following can be specified using the signal:
    • Single wire / or TWIN welding.
    • Which process line is leading during TWIN welding (Lead).
    • Which process line is active during single wire welding.
    The operating modes can be changed both before and during welding.
    Bit 32
    Bit 33
    Description
    0
    0
    Single wire mode, line 1
    0
    TWIN mode, line 2 leading (Lead)
    0
    TWIN mode, line 1 leading (Lead)
    Single wire mode, line 2
    Value range for TWIN mode
    1. Digital Inputs
    The signal is used to select whether the weld seams are counted by the welding machine or the robot.
    Signal level = Low:
    • The welds are counted by the welding machine.
    • Each time welding is completed, the weld seam count increases by 1. Switching the welding machine off and on again restarts the count at 0. In addition, it is also possible to specify an initial value (starting the count at 10 instead of 0, for example).
      • Exception: If the Fronius Data Channel is used, the number of weld seams is specified using the Fronius Data Channel and not the welding machine.
    Signal level = High:
    • The number of weld seams is specified using the robot.
    1. Digital Inputs
    If this signal is active, a process-dependent correction (Process controlled correction signal) can be manually selected on the welding machine.
    Process-dependent corrections must be activated separately for both welding machines.
    1. Digital Inputs
    Inputs used to control options, such as OPT/i RI FB REL.
    • Max. voltage = DC 113 V / AC 68 V
    • Max. current load 1 A
    Example outputs: ExtInput1 = OPT_Output 1.
    The inputs have no effect on other signals (for example Robot ready, etc.)
    (1)
    Robot output
    (2)
    Welding machine input
    (3)
    Options output
    • TWIN systems are only compatible with the OPT/i RI FB REL EXT 8I/8O option.
    • The signals are forwarded to both welding machines and are then available at the outputs of the relay station used.
    1. Digital Inputs
    This signal is used to carry out welding using the welding parameters that are saved under the selected job number (1-1000).
    The signal is represented as UINT16 and has a value range of 0-1000.
    Job numbers must be selected separately for both welding machines.
    1. Digital Inputs
    This signal is used to specify the welding process using the characteristic number.
    The signal is represented as UINT16 and has a value range of 0-65535.
    Characteristic number 0 can be used to select the material setting and the welding process on the control panel of the welding machine.
    Examples of characteristic numbers:
    • 2765 = G3Si1 / 1.2 mm / Ar 15-20%, CO2 / LSC
    • 3189 = G3Si1 / 1.2 mm / Ar 15-20%, CO2 / PMC
    Characteristic numbers must be selected separately for both welding machines.
    1. Digital Inputs
    The seam number of the respective welding process is specified with this signal, for example, for documentation purposes.
    For more detailed information regarding weld seam documentation, please refer to Documentation mode (Documentation mode) - Single Bit.
    The seam number for both welding machines is specified at the same time.
    1. Digital Inputs
    If this signal is set to High, a short circuit check between the two contact tips in the TWIN welding torch starts.
    • If a short circuit is detected, the signal Short circuit contact tip is set high.
    This signal is only available for TWIN systems operating in TWIN mode (not available for single wire operation).
    Analog Inputs
    The signal is used to control the wire speed when using a cold wirefeeder.
    As described below, the set value can be specified on a Digital Interface or an Analog Interface.
    The following set value specifications apply to the MIG/MAG standard synergic, MIG/MAG pulse synergic, MIG/MAG PMC, MIG/MAG LSC, CMT, ConstantWire, TIG ColdWire.
    Digital Interface:
    The wirefeeder set value is specified by entering a value between -32,768 and +32,767 (SINT 16).
    Value range
    Designation
    Min./max. possible value
    -32768
    Wire feed speed
    -327.68 m/min (depending on wirefeeder)
    +32767
    Wire feed speed
    +327.67 m/min (depending on wirefeeder)
    The digital set value must be entered separately for both welding machines.
    Analog Interface:
    The wirefeeder set value is specified through an analog method by entering a value between 0 and 10 V.
    Value range
    Designation
    0 V
    Wire feed speed
    0% (depending on wirefeeder)
    10 V
    Wire feed speed
    100% (depending on wirefeeder)
    It is not possible to enter an analog set value on TWIN systems.
    Job correction (specifications apply for Single and TWIN welding):
    • Factor = 100
    • Data type SINT
    • Specified as a percentage. Example: 15% = 1,500 step change.
    1. Analog Inputs
    Digital Interface:
    Value range
    Designation
    -32768
    Wire feed speed
    +32767
    Wire feed speed
    Analog Interface:
    Value range
    Designation
    0 V
    Wire feed speed
    10 V
    Wire feed speed
    • Factor = 100
    • Data type SINT
    1. Analog Inputs
    The main current/hot-wire amperage is set on the selected characteristic by entering a value between 0 and 6,553.5 (0-100%).
    Digital Interface:
    The main / hot-wire amperage set value is specified by entering a value between 0 and 6,553.5 (UINT 16).
    Value range
    Designation
    0
    0 A
    6,553.5
    6,553.5 A
    Analog Interface:
    The hot-wire amperage is specified by using an analog method to enter a value between 0 and 10 V.
    Value range
    Designation
    0 V
    Hotwire current
    0
    10 V
    Hotwire current
    100%
    (the effective current value depends on the output of the welding machine)
    1. Analog Inputs
    As described below, the value for the arc length correction can be specified on a Digital Interface or an Analog Interface.
    The following specifications apply to the MIG/MAG standard synergic, MIG/MAG pulse synergic, MIG/MAG PMC, and MIG/MAG LSC welding processes.
    Digital Interface:
    By entering a value between -32,768 and +32,767 (SINT 16) the arc length is corrected, but the wire speed is not changed.
    Value range
    Designation
    -32,768
    Arc length correction
    -10% = shorter arc
    0
    0% = saved value
    +32,767
    +10% = longer arc
    Analog Interface:
    By entering a value between 0 and 10 V using an analog method, the arc length is corrected, but the wire speed is not changed.
    Value range
    Designation
    0 V
    -10% = shorter arc
    5 V
    0% = saved value
    10 V
    +10% = longer arc
    Job correction (specifications apply for Single-and TWIN welding):
    • Factor = 10
    • Data type SINT
    • Specified as absolute value. Example: 1.5 = 150 step change.
    1. Analog Inputs
    As described below, the value for the hot-wire amperage can be specified on a Digital Interface or an Analog Interface.
    The following specifications apply to the ConstantWire welding process.
    Digital Interface:
    The hot-wire amperage is specified by entering a value between 0 and 65,535 (UINT 16).
    Value range
    Designation
    0
    Hot-wire amperage
    0
    65,535
    Hot-wire amperage
    6553.5 A
    The digital value must be entered separately for both welding machines.
    Analog Interface:
    Value range
    Designation
    0 V
    Hot-wire amperage
    0
    10 V
    Hot-wire amperage
    100%
    It is not possible to enter an analog value on TWIN systems.
    1. Analog Inputs
    As described below, the value for the pulse/dynamic correction can be specified on a Digital Interface or an Analog Interface.
    Digital Interface:
    Entering a value between -32,768 and +32,767 (SINT 16) specifies the pulse/dynamic correction, the wire speed is not changed.
    Value range
    Designation
    -32,768
    -10% = pulse/dynamic correction
    0
    0% = saved value
    +32,767
    +10% = pulse/dynamic correction
    Analog Interface:
    Entering a value between 0 and 10 V using an analog method specifies the pulse/dynamic correction, the wire speed is not changed.
    Value range
    Designation
    0 V
    5 V
    0% = saved value
    10 V
    1. Analog Inputs
    The signal is used to fine-tune the wire speed with TIG DynamicWire.
    Digital Interface:
    Entering a value between -32,768 and +32,767 (SINT 16) specifies how quickly the welding wire re-enters the melt pool after the short circuit is broken.
    Value range
    Designation
    -32768
    Wire correction
    -10
    0
    Wire correction
    0
    +32767
    Wire correction
    +10
    Setting range: -10 - // +10
    Factory setting: 0
    -10 = slow immersion
    +10 = fast immersion
    1. Analog Inputs
    As described below, the value for the wire retraction correction can be specified on a Digital Interface or an Analog Interface.
    The following specifications apply to the MIG/MAG standard synergic, MIG/MAG pulse synergic, MIG/MAG PMC, MIG/MAG LSC, CMT, and ConstantWire welding processes.
    Digital Interface:
    The wire retraction correction is specified by entering a value between 0 and 65,535 (UINT 16).
    Value range
    Designation
    0
    0
    65,535
    +10
    Analog Interface:
    The wire retraction correction is specified by using an analog method to enter a value between 0 and 10 V.
    Value range
    Designation
    0 V
    0
    10 V
    +10
    1. Analog Inputs
    The signal indicates how far the welding wire is retracted after the end of welding or when the wire stops.
    Digital Interface:
    Entering a value between 0 and 65535 (UINT 16) specifies how far the welding wire is retracted after the end of welding.
    Value range
    Designation
    0
    Wire retraction
    OFF
    65535
    Wire retraction
    50 mm
    Setting range: off / 1-50 mm
    1. Analog Inputs
    This value is used to transmit the robot's TCP speed.
    The TCP speed for both welding machines is transmitted at the same time.
    1. Analog Inputs
    The signal indicates the length of the welding wire and how far it is from the workpiece before welding starts.
    Digital Interface:
    Entering a value between 0 and 65,535 specifies how far the welding wire is from the workpiece before welding starts (UINT 16).
    Value range
    Designation
    0
    OFF
    65,535
    50 mm
    1. Analog Inputs
    Digital Interface:
    The plasma gas set value is specified by entering a value between 0 and 65,535 (UINT 16).
    Value range
    Designation
    0
    0.1 l/min
    65,535
    9.0 l/min
    Plasma gas flow set value:
    0.1-9.0 l/min
    1. Analog Inputs
    Signal behavior:
    • The signal is active as soon as a value greater than or equal to 1 mm (0.039 inches) is entered (0 = signal inactive).
    • If a value greater than or equal to 1 mm (0.039 inches) is specified, the wire electrode is only fed by the specified value when the signal Wire forward is set. After reaching the preset value, the end of wirefeeding takes place automatically.
    • As soon as the specified value is reached:
      • The Touch signal (WORD 0 / Byte 0 / Bit 7) is set
      • The signal Wire forward must be deactivated (otherwise the wire threading function remains active)
      • The signal Wire position is accompanied by an output defining how far the wire electrode has been moved [the value remains set for 1 second; +/- 1 mm (+/- 0.039 inches)]
    • If the wire electrode touches the workpiece before the preset value has been reached, the Touch signal (WORD 0 / Byte 0 / Bit 7) and additionally the Arc stable / Touch signal (WORD 0 / Byte 0 / Bit 5) are set. The end of wirefeeding takes place automatically.
    • The wire electrode can be conveyed a maximum of 50 m (164 feet 0.5 inches) (=safety stop).
    If not all wire feeds of the welding system are synchronized (e.g. due to the combination of a Robacta Drive drive unit and a Stand Alone unwind wirefeeder), inaccuracies of +/- 5 mm (+/- 0.196 inches) may occur in the specification of the wire electrode fed due to the system.
    The following set value specifications apply to the MIG/MAG standard synergic, MIG/MAG pulse synergic, MIG/MAG PMC, and MIG/MAG LSC welding processes.
    Digital Interface:
    The set value for the length of wire to be fed is specified by entering a value between -32,768 and +32,767 (UINT 16).
    Value range
    -32,768
    1 mm (0.039 inches)
    +32,767
    10,000 mm (393.7 inches)
    Analog Interface:
    The set value for the length of wire to be fed is specified by entering an analog value of 0 to 10 V.
    Value range
    0 V
    1 mm (0.039 inches)
    10 V
    Signal course - set Wire forward length (= 25 mm / 0.984 inches) could be reached according to plan:
    Signal course - workpiece contact occurs before the set Wire forward length (= 25 mm / 0.984 inches) could be reached:
    1. Analog Inputs
    Contour detection (= WireSense contour sensing mode):
    • If a value less than 0.5 mm (0.02 inches) is specified with the WireSense trigger level signal, the WireSense start signal is used for contour detection.
      • The surface of the component is scanned cyclically by the wire electrode and the measured height value is output continuously at the Wire position analog output signal (see Wire position (wire position) - Group Output / Analog Output).
      • The Touch signal is not active at the same time.
    Joint type detection (= WireSense joint type detection mode):
    • If a value of 0.5-20 mm (0.02-0.787 inches) is specified with the WireSense trigger level signal, the WireSense start signal is used to detect different joint types (depending on the current setting of the WireSense joint type signal).
    • The specified value defines the threshold value from which the currently set joint type is detected.
      • Example: If a 2 mm (0.079 inches) thick sheet is welded with a lap joint, it is recommended to set 1.5 mm (0.059 inches) for this signal. It is not recommended to always use the minimum value of 0.5 mm
        (0.02 inches), as this may cause false detection, for example, due to welding spatter or inaccurate robot movements.
    • The Touch signal is output when the threshold is exceeded and the set joint type is detected.
    Digital Interface:
    The threshold value for edge detection is specified by entering a value between 0 and 200 (UINT 16).
    Value range
    Designation
    0
    Threshold value
    0 mm (0 inches)
    200
    Threshold value
    20 mm (0.787 inches)
    For more information on WireSense , see section Wire position (wire position) - Group Output / Analog Output.
    Additional information for joint type detection:
    For the detection of lap joints, a further 0.15 mm is subtracted from the specified threshold value for the internal welding machine calculation.
    • In single wire mode, only the wire electrode of the active process line is used for WireSense joint type detection  .
    • In TWIN mode, both wire electrodes are used for WireSense joint type detection . The Touch signal is only ever generated and output by the Lead-welding machine.
    • The two wire electrodes from the TWIN system can only be used for the same WireSense function:
      • Both wire electrodes for either contour detection or edge detection.
    Digital Outputs
    Definition
    Digital outputs are signals from the welding machine to the robot.
    (1)
    Robot input
    (2)
    Welding machine output
    1. Digital Outputs
    Definition
    (1)
    Robot input
    (2)
    1. Digital Outputs
    As soon as the interface creates an authenticated connection to the welding machine, this signal changes its activity with a frequency of 1 Hz (1 second High, 1 second Low, 1 second High, etc.).
    As soon as the RI FB/i TWIN Controller establishes an authenticated connection to both welding machines, this signal changes its activity with a frequency of 1 Hz (1 second High, 1 second Low, 1 second High, etc.).
    1. Digital Outputs
    • The signal is High when the welding machine is ready to weld.
    • The signal is Low, if a fault occurs on the welding machine (Error) or a notification (Notification) is issued.
    • The signal can also be called a "common error", as it is set to Low for all types of internal and external error.
    The signal is only set to High when both welding machines are ready to weld.
    1. Digital Outputs
    • The signal is High when the welding machine issues a warning.
    • The signal remains High until the reason for the warning has been rectified.
    • The signal automatically changes to Low, as soon as the reason for the warning has been eliminated.
    • The signal has no effect on the welding process or the operability of the welding machine (welding can be started; running process is not interrupted, etc.).
    The signal is set to High as soon as one of the two welding machines issues a warning.
    1. Digital Outputs
    The Process active signal is set from the beginning of gas pre-flow to the end of gas post-flow in order to inform the robot that welding is still taking place. This means that, for example, the dwell time of the robot can be synchronized at the end of the weld seam to ensure that there is an ideal gas shield.
    If the Welding start signal is set, the gas pre-flow time begins to count down, even before the arc is ignited.
    After extinguishing the arc, the gas post-flow time begins to count down.
    (1)
    Process active (process active)
    The signal is set as soon as one of the two welding machines becomes active.
    1. Digital Outputs
    This signal is set as soon as the wire electrode touches the workpiece and current begins to flow – the signal is High as soon as the workpiece is touched.
    During welding the signal can fall to Low during all welding processes – the signal functions in the same way for all welding processes.
    (1)
    The signal is set to High as soon as one of the two wire electrodes becomes live.
    1. Digital Outputs
    • This signal is set as soon as the wire electrode touches the workpiece and current flows, thus reporting to the robot controller that the arc is burning.
    • If the Arc stable / Touch signal is active, the arc monitoring is also active. This is not the case for the Current flow signal.
    • If an arc monitoring time has been set, the Arc stable / Touch signal is only reset if the Current flow signal is inactive for longer than the set arc monitoring time.
    • The Arc stable / Touch signal is active as long as the arc is burning.
    • The Arc stable / Touch signal is set in Teach mode for 50 ms each time the wire electrode touches the component.
    • The Arc stable / Touch signal is also set as soon as the wire electrode or the gas nozzle comes into contact with the workpiece in Touch mode (Touch sensing signal is active).
    • For more information about the Touch sensing signal, see TouchSensing (TouchSensing) ‑ Single Bit.
    • When using WireSense, the Arc stable / Touch signal is set as soon as the wire electrode comes into contact with the workpiece for the first time and the WireSense process is running stably (for example, when the WireSense - Slaghammer function is automatically triggered, the Arc stable / Touch signal is only set after the WireSense - Slaghammer function has been successfully executed)
      • For more information on WireSense, see section WireSense start - Single Bit.
    • When unwinding the wire electrode (Wire forward signal), the Arc stable / Touch signal is set as soon as the wire electrode touches the workpiece.
    (1)
    Arc stable / Touch signal (arc stable/touch signal)
    The signal functions differently depending on the welding process. See below for an overview of the function of the signal in conjunction with the different welding processes.
    MIG/MAG pulse synergic, MIG/MAG PMC, mixed processes:
    Example of correct ignition at the start of welding.
    Example of incorrect ignition at the start of welding.
    MIG/MAG standard synergic, MIG/MAG standard manual, MIG/MAG LSC, MIG/MAG CMT, MIG/MAG CMT mixed processes:
    • In single-wire operation, the following applies:
      • Once welding is started, the Arc stable / Touch signal is set as soon as the wire electrode comes into contact with the workpiece and current begins to flow.
      • In Touch mode, the Arc stable / Touch signal is set as soon as the wire electrode touches the workpiece.
      • When using WireSense, the Arc stable / Touch signal is set as soon as the WireSense-process is running stably (as soon as the Slaghammer is ended).
    • In TWIN operation, the following applies:
      • Once welding is started, the Arc stable / Touch signal is set as soon as both wire electrodes come into contact with the workpiece and current begins to flow.
      • In Touch mode the Arc stable / Touch signal is set as soon as one of the two wire electrodes or the gas nozzle touches the workpiece.
      • When unwinding the wire electrode (Wire forward signal), the Arc stable / Touch signal is set as soon as one of the two wire electrodes touches the workpiece.
      • When using WireSense, the Arc stable / Touch signal is set as soon as the WireSense-process is running stably with both wire electrodes (as soon as the Slaghammer is ended).
    Additional information for ConstantWire:
    • In the case of operation with no ground connection, contact of the welding wire with the workpiece is not detected.
    • The Arc stable / Touch signal is set automatically as soon as the gas pre-flow is finished.
    • The Arc stable / Touch signal is automatically deactivated as soon as the Welding start signal is deactivated.
    1. Digital Outputs
    If welding is carried out with a defined starting current and a defined final current, the Main current signal is set between the end of the starting current and the start of the final current phases.
    (1)
    • In single wire mode, the signal is set as soon as the active process line starts welding using the main current.
    • In TWIN mode, the signal is set as soon as both process lines start welding using the main current.
    1. Digital Outputs
    The signal is used for various functions and indicates that:
    • In Touch mode the gas nozzle or the wire electrode touches the workpiece (depending on the system configuration).
    • In Teach mode the wire electrode touches the workpiece cyclically and thus the set stickout has been undershot.
    • During unwinding (Wire forward signal) the wire electrode touches the workpiece.
    • When using the WireSense joint type detection function, the set threshold value has been reached and thus the required joint type has been successfully detected.
      • For more information on WireSense, see section WireSense - more information.
      • In Touch mode the Touch signal is set as soon as the wire electrode or the gas nozzle of the active welding machine touches the workpiece.
      • When unwinding the wire electrode (Wire forward signal), the Touch signal is set as soon as the wire electrode of the active welding machine touches the workpiece.
      • When using Teach mode, the Touch signal is set as soon as the wire electrode of the active welding machine touches the workpiece.
      • When using WireSense joint type detection, the Touch signal is set as soon as a joint type has been detected by the active welding machine.
      • In Touch mode the Touch signal is set as soon as one of the two wire electrodes or the gas nozzle touches the workpiece.
      • When unwinding the wire electrode (Wire forward signal), the Touch signal is set as soon as the wire electrode of the Lead-welding machine touches the workpiece (the Trail-welding machine is ignored).
      • When using Teach mode, the Touch signal is set as soon as the wire electrode of the Lead-welding machine touches the workpiece (the Trail-welding machine is ignored).
      • When using WireSense joint type detection, the Touch signal is set as soon as a joint type is detected by the Lead-welding machine (the Trail-welding machine is ignored).
    1. Digital Outputs
    If a collision occurs (with the workpiece, clamping device, etc.) while using the CrashBox, the contact of the CrashBox is opened and the Collisionbox active signal is set to Low.
    In this case, it is recommended that:
    • Immediate shutdown of the robot is initiated.
    • The welding process is ended.
    The signal has no effect on the welding machine.
    1. Digital Outputs
    The signal is active from the end of the starting current to the end of the gas post-flow.
    The starting current time begins as soon as Current flow is High. Even if Current flow is interrupted, the starting current time continues to run until the set end (the starting current time does not reset).
    If an arc monitoring time has been set, the Robot motion release signal is only reset if the Current flow signal is inactive for longer than the set arc monitoring time.
    (1)
    At the start of welding the signal is set to High in the following instance:
    • Arc stable High.
    • Current flow High.
    • The starting current time has elapsed (not the slope time).
    During welding the signal is set to Low in the following instance:
    • Arc stable Low.
    At the end of welding the signal is set to Low in the following instance:
    • Welding start Low.
    • The gas post-flow has ended.
    The signal is output separately for both process lines.
    1. Digital Outputs
    The signal is High if a wire stick is detected on the workpiece. This signal is always output regardless of other settings.
    The signal is set to High as soon as one of the two wire electrodes sticks.
    1. Digital Outputs
    If the tungsten electrode is overloaded, this can result in material detachment on the electrode, which can cause contamination to enter the weld pool.
    If the tungsten electrode is overloaded, the "Electrode overloaded" indicator lights up on the status bar of the control panel and this signal is output.
    The "Electrode overloaded" indicator depends on the set electrode diameter and the set welding current.
    1. Digital Outputs
    This signal is set to High if a short circuit between the contact tip and the gas nozzle has been detected in the following operating states:
    • In Touch mode
    • In welding operation
    • During wire threading
    • In Teach mode
    • In WireSense mode
    In addition, a separate warning message is output.
    The cause of a short circuit between the contact tip and the gas nozzle can be soiling, for example due to welding spatter.
    In order for this signal to be available, the TouchSense Adv. option must be installed in the welding system.
    This signal is set to High in Touch mode if a short circuit has been detected between one of the two contact tips and the gas nozzle.
    The signal is only set to High if there is a short circuit between the contact tip of the lead welding machine and the gas nozzle in the following operating states:
    • Wire threading (Inching)
    • Teach mode
    • WireSense
    In TWIN welding mode, the signal is not available and remains permanently in the Low level.
    In addition, this signal is set to High when the input signal Contact tip short circuit detection on is set to High and a short circuit between the two contact tips is detected.
    Once again here, the cause of a short circuit between the contact tips may be soiling, for example due to welding spatter.
    The OPT/i TouchSense Adv. option does not have to be present in the welding system to perform the short-circuit check between the two contact tips.
    1. Digital Outputs
    Parameter selection internally (Internal parameter selection) - Single Bit
    This signal indicates whether the parameter selection has been set to "internal".
    This setting can be applied:
    • Using the Working mode signal/internal parameter selection, or
    • directly on the welding machine itself under: Defaults / Interface setup / Welding parameters.
    The following signals can be set on the welding machine itself if the Parameter selection internally High signal is active:
    • Welding process (MIG/MAG pulse synergic, MIG/MAG standard synergic, etc.)
    • Operating mode (2-step mode, etc.)
    • Characteristic/job number (depending on the welding process)
    • Wirefeeder
    • Arc length correction
    • Pulse/dynamic correction
    • Wire retraction
    • Process-dependent correction
    • SynchroPulse on/off
    The signal is set to High as soon as parameter selection is set to "internal" on one of the two process lines.
    1. Digital Outputs
    Characteristic number valid (Characteristic number valid) - Single Bit
    If the signal is High, the selected characteristic and the selected process are approved and can be used.
    1. Digital Outputs
    Torchbody gripped (Torch body gripped) - Single Bit
    This signal indicates that a Fronius torch body has been registered in the system.
    1. Digital Outputs
    Command value out of range (set value out of range) - Single Bit
    This signal indicates that the „Wire feed speed command value“ input is outside of the possible range.
    The signal is High if, for example:
    • The possible range is limited by the wirefeeder:
      • Selected wirefeeder set value = 25 m/min (984.25 inches/min)
      • Maximum wirefeeder set value based on characteristic = 25 m/min (984.25 inches/min)
      • Maximum possible speed of the wirefeeder = 15 m/min (590.55 inches/min).
    • The possible range is limited by the characteristic:
      • Maximum wirefeeder set value based on characteristic = 15 m/min
      • Maximum possible speed of the wirefeeder = 30 m/min (1181.1 inches/min).
    The signal is set as soon as one of the two process lines exceeds a defined range.
    1. Digital Outputs
    Correction out of range (Correction out of range) - Single Bit
    This signal indicates that at least one of the selected corrections (for example, Arc length correction) is outside of the specified range.
    The signal is set as soon as one of the selected corrections exceeds the defined range.
    1. Digital Outputs
    Limitsignal
    (Limit signal) - Single Bit
    This signal indicates that the set limits for voltage, current, wirefeeder, welding time, and energy input have been exceeded or not reached.
    This signal is only available in Job Mode.
    Requirements
    • In the menu on the welding machine "Process parameters/Job/Optimize Job/Limit monitoring/Limit reaction", the reaction is set to "Warning" or "Error".
    • OPT/i Limit Monitoring enabled for the welding machine.
    For more information on Limit Monitoring see section:
    • Limit Monitoring - functions and activation and
    • Limit Monitoring - details on the individual welding parameters
    1. Digital Outputs
    Standby active - Single Bit
    link_horizontalLink copied
    This signal indicates that the welding machine is in Working mode 16 or has automatically switched to Idle mode.
    1. Digital Outputs
    Main supply status (Mains voltage status) - Single Bit
    This signal indicates whether a phase error has occurred on the welding machine (incorrect power supply to the welding machine).
    If this error has occurred, the error numbers 6451 or 6515 will be shown on the display of the welding machine or transmitted to the robot via the interface as an Error number signal.
    The signal is set to High as soon as a phase error occurs on one of the two welding machines.
    1. Digital Outputs
    Sensor Status 1 (sensor status 1) - Single Bit
    This signal indicates the status of the wire end option 4,100,869.
    Signal level
    Description
    High
    Wire electrode present
    Low
    No wire electrode present
    The signal is output as soon as the sensor of the option is detected in the system.
    If there is no sensor in the system, the signal is set to High.
    1. Digital Outputs
    Sensor Status 2 (sensor status 2) - Single Bit
    This signal indicates the status of the wire end option 4,100,879.
    Signal level
    Description
    High
    Low
    1. Digital Outputs
    Sensor Status 3 (sensor status 3) - Single Bit
    This signal indicates the status of the wire end option 4,100,878.
    Signal level
    Description
    High
    Low
    1. Digital Outputs
    Sensor Status 4 (sensor status 4) - Single Bit
    The signal indicates the status of the wire buffer set CMT TPS/i 4,001,763 option.
    Signal level
    Description
    High
    Wire buffer is not empty
    Low
    Wire buffer is empty
    1. Digital Outputs
    Function status (Function status) - Single Bit
    This signal indicates the status of the R/L-measurement, which is transmitted during the measurement in Working mode 24 (R/L-measurement).
    Bit 1
    Bit 0
    Description
    0
    0
    Inactive
    0
    Idle
    0
    Finished
    Error
    1. Digital Outputs
    Safety status - Single Bit
    This signal indicates the status of the OPT/i Safety Stop PL d and OPT/i TPS External Stop options.
    Bit 1
    Bit 0
    Description
    0
    0
    Reserve
    0
    Hold
    0
    Stop
    Not installed/active
    1. Digital Outputs
    Notification (Notification) - Single Bit
    • The signal is High when the welding machine issues a notification.
    • Notifications can arise, for example, due to set process limits, external sensors, etc.
    • The signal automatically interrupts the welding process.
    • Operation of the welding machine is possible while the signal is High.
    • The signal remains High until the reason for the notification has been resolved.
    • The signal automatically changes to Low, as soon as the reason for the notification has been eliminated.
    Additional information for TWIN systems:
    The signal is set to High as soon as one of the two welding machines issues a notification.
    1. Digital Outputs
    System not ready - Single Bit
    This signal indicates whether the welding system is ready for use:
    • This signal is Low if there are no error messages in the welding system (all error sources must be eliminated for the signal to change to Low.
    • This signal is High as soon as a component of the welding system outputs an error message.
    Examples of when this signal changes to High:
    • A component of the welding system performs an update.
    • Occurrence of an emergency stop.
    • In conjunction with wire sensors (ring sensor, sensor on wire drum, etc.), for example, errors 16828, 16837, 16838.
    If the following exceptions occur, the signal remains Low despite the error messages:
    • The Robot ready signal is Low.
    • During the welding process, a welding torch detection problem occurs (BID error).
    1. Digital Outputs
    Pulse current active (Pulse current active) - Single Bit
    This output signal on the interface indicates the "Pulse high phase" and works up to a maximum pulse frequency of 10 Hz.
    This ensures that the robot reliably receives all signals up to a frequency of 10 Hz. At frequencies above 10 Hz, correct transmission of the "Pulse high" signal can no longer be guaranteed.
    A permanent high signal is output at a pulse frequency above 10 Hz. For example, the pulse duration at a frequency of 1 kHz is only 1 ms.
    1. Digital Outputs
    Pilot arc active (Pilot arc active) - Single Bit
    This signal indicates when the plasma pilot arc is active.
    If the Welding start signal is set by the robot, the gas pre-flow time begins to count down, even before the arc is ignited.
    1. Digital Outputs
    Process run (Process run) - Single Bit
    This signal indicates that any welding process (MIG/MAG, TIG, CMT, etc.) or a special process (TeachMode, WireSense, threading, touching) is currently active on the welding machine.
    The signal can be used to monitor whether time-controlled or one-time-triggered processes (e.g., CMT Cycle Step or the spot function) have ended unexpectedly (e.g., by arc break). The higher-level PLC or the robot controller recognizes that the process should still be active and can respond accordingly.
    1. Digital Outputs
    Process Bit (Process bit) - Group Output
    These signals indicate which welding process has been selected.
    Value range for welding process:
    Bit 4
    Bit 3
    Bit 2
    Bit 1
    Bit 0
    Description
    0
    0
    0
    0
    0
    No internal mode selection or process
    0
    0
    0
    0
    MIG/MAG pulsed synergic
    0
    0
    0
    0
    0
    0
    0
    MIG/MAG PMC
    0
    0
    0
    0
    MIG/MAG LSC
    0
    0
    0
    0
    0
    0
    Electrode
    0
    0
    TIG
    0
    0
    0
    0
    CMT
    0
    0
    0
    ConstantWire
    1. Digital Outputs
    Active process line - Single Bit
    This signal indicates the currently selected process line.
    Bit 1
    Bit 0
    Description
    0
    0
    0
    Wirefeeder 2
    0
    Wirefeeder 3
    1. Digital Outputs
    The Touch signal gas nozzle is set to High as soon as a short circuit between the gas nozzle and the workpiece (welding ground) is detected in the following operating states:
    • In Touch mode
    • In Teach mode
    • In WireSense mode
    In the operating states welding mode, wire threading, Teach mode, and
    WireSense, a warning message is additionally output when the gas nozzle touches the workpiece. During these states, contact between the gas nozzle and the workpiece should be avoided.
    The Touch signal gas nozzle signal is set in Touch mode in addition to the following signals:
    • Arc stable / Touch signal
    • Touch signal
    In order for the Touch signal gas nozzle signal to be available, the TouchSense Adv. option must be installed in the welding system.
    The Touch signal gas nozzle signal in Touch Mode allows the user to determine whether there has been workpiece contact by the wire electrode or gas nozzle.
    Note on the use of this function in Touch mode:
    The function is only available in Touch mode if the gas nozzle first touches the workpiece while the wire electrode or the contact tip has no contact with the component.
    If the welding wire touches the workpiece before the gas nozzle makes contact due to too long a stickout or incorrect torch alignment, the signal is not set to High.
    If this signal is used in Touch mode for collision detection of the welding torch with the workpiece, the Touch signal must also be monitored (see section Touch signal (Touch signal) - Single Bit). In welding mode, during wire threading, in Teach mode, and in WireSense mode, additional monitoring of the Touch signal is not necessary.
    This signal is set to High in the operating states:
    • Touch mode
    • Teach mode
    • WireSense if a short circuit between the gas nozzle and the workpiece is detected.
    In the wire threading operating state (Inching), this signal is only set to High if a short circuit between the gas nozzle and the workpiece is detected and the wire threading process is carried out on the lead welding machine.
    1. Digital Outputs
    Twin synchronization active - Single Bit
    The signal indicates that the synchronization between the two welding machines is active.
    1. Digital Outputs
    ExtOutput 1-8 (External output 1-8) - Single Bit
    Outputs used to control options, such as OPT/i RI FB REL.
    • Max. current load 2 A
    Example outputs: ExtOutput1 = OPT_Input 1.
    (1)
    Robot input
    (2)
    (3)
    Options input
    • If an input signal is set on one of the two welding machines, the signal is also set on the fieldbus output
    Analog Outputs
    Welding voltage (Welding voltage) - Group Output / Analog Output
    As described below, the current welding voltage actual value can be output on a Digital Interface or an Analog Interface.
    Digital Interface:
    • During the welding process, the current welding voltage actual value will be output as a value between 0 - 65,535 (UINT 16).
    • The welding voltage set value is output when idling.
    • The Hold value is output immediately after welding.
    Value range
    Designation
    0
    Welding voltage
    0 V (set value/actual value/Hold value)
    32,767
    Welding voltage
    327.67 V (set value/actual value/Hold value)
    The digital actual value is output separately for both welding machines.
    Analog Interface:
    • During the welding process, the current welding voltage actual value will be output as a value between 0 - 10 V.
    Value range
    Designation
    0 V
    Welding voltage
    10 V
    Welding voltage
    100 V (set value/actual value/Hold value)
    The analog actual value is not output on TWIN systems.
    1. Analog Outputs
    Digital Interface:
    Value range
    Designation
    0
    Welding voltage
    32,767
    Welding voltage
    Analog Interface:
    Value range
    Designation
    0 V
    Welding voltage
    10 V
    Welding voltage
    1. Analog Outputs
    Welding current (Welding current) - Group Output / Analog Output
    As described below, the present welding current actual value can be output on a Digital Interface or an Analog Interface.
    Digital Interface:
    • During the welding process, the present welding current actual value will be output as a value between 0 and 65,535 (UINT 16).
    • The welding current command value is output when idling.
    Value range
    Designation
    0
    Welding current
    0 A (set value/actual value/Hold value)
    32,767
    Welding current
    3276.7 A (set value/actual value/Hold value)
    Analog Interface:
    • During the welding process, the present welding current actual value will be output as a value between 0 - 10 V.
    • The Hold- value is output immediately after welding.
    Value range
    Designation
    0 V
    Welding current
    10 V
    Welding current
    1000 A (set value/actual value/Hold value)
    1. Analog Outputs
    Wire feed speed (Wire speed) - Group Output / Analog Output
    As described below, the current wire speed actual value can be output on a Digital Interface or an Analog Interface.
    Digital Interface:
    • During the welding process, the current wire speed actual value will be output as a value between -32,768 and +32,767 (SINT 16) .
    • The wire speed set value is output when idling.
    Value range
    Designation
    -32,768
    Wirefeeder
    -327.68 m/min (set value/actual value/Hold value)
    +32,767
    Wirefeeder
    +327.67 m/min (set value/actual value/Hold value)
    Analog Interface:
    • During the welding process, the current wire speed actual value will be output using an analog method as a value between 0 - 10 V.
    Value range
    Designation
    0 V
    Wirefeeder
    0 m/min (set value/actual value/Hold value)
    10 V
    Wirefeeder
    depending on the wirefeeder used
    1. Analog Outputs
    Actual real value for seam tracking (Current actual value for seam tracking) - Group Output / Analog Output
    As described below, the current actual value for seam tracking can be output on a Digital Interface or an Analog Interface.
    The signal is calculated for all MIG/MAG characteristics.
    Whether and how the signal is output for a characteristic can be seen in the "Synergic_lines_TPSi_x.x.x" file in the "Seamtrack 50%" column.
    The file "Synergic_lines_TPSi_x.x.x" is sent with each firmware release bundle "PW_FW_ReleaseBundle_Official_TPSi_iWave_vx.x.x".
    Signal output options available:
    Characteristics with Seamtrack 50% = function available
    With the stickout with which the characteristic was created and with neutral correction values, a signal value of approx. 5000 (50% of 10,000) results for these characteristics
    Example:
    Synergic Line 2566 (Steel / 1.2 mm / Stickout = 13 mm)
    A signal value of approx. 5000 results for this characteristic.
    Characteristics with Seamtrack 50% = no function
    With these characteristics, a Seamtrack signal can be output, but the signal is not scaled with 50%.
    The output signal varies, e.g., when weaving in a fillet weld.
    Example:
    Synergic Line 3931 (Steel / 1.2 mm / Stickout = 13 mm)
    A signal value of approx. 8000 results for this characteristic.
    Characteristics with Seamtrack 50% = signal available*
    With the stickout with which the characteristic was created and with neutral correction values, a signal value of approx. 5000 (50% of 10,000) results for these characteristics, although with restrictions (e.g., with aluminum characteristics).
    Characteristics with Seamtrack 50% = no function*
    The output signal varies, e.g., when weaving in a fillet weld, although with restrictions (e.g., with aluminum characteristics).
    NOTE!
    signal available* - no function*
    The SeamTracking signal does not provide consistent results for vertical seam tracking in aluminum welding.
    The signal is ineffective for tracking horizontal seams in aluminum welding.
    Digital Interface:
    • During the welding process, the current actual value for seam tracking will be output as a value between 0 and 65,535 (UINT 16).
    • The Hold-value is output at the end of welding.
    Value range
    Designation
    0
    0
    (depending on the position of the welding torch)
    65535
    65,535
    (actual value / Hold-value)
    Analog Interface:
    • During the welding process, the current actual value for seam tracking will be output using an analog method as a value between 0 - 10 V.
    Value range
    Designation
    0 V
    0
    10 V
    • The digital actual value is output separately for both welding machines.
    • The analog actual value is not output with TWIN systems.
    Weaving overview (current actual value for seam tracking, the values given are for illustrative purposes only):
    (1)
    Stickout: 10 mm (0.394 inches)
    Wire speed: 7 m/min
    (275.59 inches/min)
    Arc length correction: 0
    Current actual value for seam tracking: approx. 7650
    (2)
    Stickout: 25 mm (0.984 inches)
    Wire speed: 7 m/min
    (275.59 inches/min)
    Current actual value for seam tracking: approx. 5853
    (3)
    Wire speed: 7 m/min
    (275.59 inches/min)
    Weaving function overview:
    • The current actual value for seam tracking is calculated using the welding current and the welding voltage.
    • The current actual value for seam tracking changes with the Stickout.
    • The current actual value for seam tracking is between 0 and 10,000:
      • Stickout becomes shorter—signal increases.
      • Stickout becomes longer—signal reduces.
    1. Analog Outputs
    Error number (Error number) - Group Output / Analog Output
    This signal indicates the current error number on the welding machine and the robot controller.
    1. Analog Outputs
    Warning number (Warning number) - Group Output / Analog Output
    This signal indicates the current warning number on the welding machine and the robot controller.
    1. Analog Outputs
    Motor current M1 (Motor current M1) - Group Output / Analog Output
    Motor current M1 is the motor current of the central motor in the welding system (drive unit of the welding torch, etc.). As described below, the present motor current actual value M1 can be output on a Digital Interface or an Analog Interface.
    Digital Interface:
    During the welding process, the present motor current actual value will be output as a value between 0 and 65,535 (UINT 16).
    Value range
    Designation
    0
    Motor current
    0 A (actual value)
    +327.67
    Motor current
    327.67 A (actual value)
    Analog Interface:
    During the welding process, the present motor current actual value will be output as a value between 0 - 10 V.
    Value range
    Designation
    0 V
    Motor current
    0 A (actual value)
    10 V
    Motor current
    10 A (actual value)
    1. Analog Outputs
    Motor current M2 (Motor current M2) - Group Output / Analog Output
    Motor current M2 is the motor current of the front motor in the welding system (wirefeeder, etc.). As described below, the present motor current actual value M2 can be output on a Digital Interface or an Analog Interface.
    Digital Interface:
    Value range
    Designation
    0
    Motor current
    0 A (actual value)
    +327.67
    Motor current
    Analog Interface:
    During the welding process, the present motor current actual value will be issued as a value between 0 and 10 V.
    Value range
    Designation
    0 V
    Motor current
    0 A (actual value)
    10 V
    Motor current
    10 A (actual value)
    1. Analog Outputs
    Motor current M3 (Motor current M3) - Group Output / Analog Output
    Motor current M3 is the motor current of the rear motor in the welding system (unwinding wirefeeder, etc.). As described below, the present motor current actual value M3 can be output on a Digital Interface or an Analog Interface.
    Digital Interface:
    Value range
    Designation
    0
    Motor current
    0 A (actual value)
    +327.67
    Motor current
    Analog Interface:
    Value range
    Designation
    0 V
    Motor current
    0 A (actual value)
    10 V
    Motor current
    10 A (actual value)
    1. Analog Outputs
    Actual real value AVC - Group Output / Analog Output
    AVC = automatic voltage control (Arc Voltage Control)
    In a TIG/plasma process, the "AVC signal" output signal is the voltage that is proportional to the arc length. The advantage of this signal is that signal processing takes place in the welding machine for DC pulse and AC processes.
    The external control of the arc height regulation controls the arc voltage by evaluating the AVC signal and regulating the distance between the tungsten electrode and the workpiece.
    This results in a constant arc length with unchanged welding parameters.
    If the welding current changes, the arc voltage must also be adjusted to maintain a constant arc length. Wear on the tungsten electrode also has a similar effect.
    Digital Interface:
    During the welding process, the actual real value AVC will be output as a value between 0 and 65,535 (UINT 16).
    Value range
    Designation
    0
    0 V
    65,535
    655.35 V
    Output to the controller:
    Signal: actual real value AVC
    An output at the interface that indicates the AVC value
    Update rate of the interface (frequency): 10 ms
    Value: 0-655.35 [V]
    DC pulse welding:
    Pulse-synchronized averaging of the values Ū1/Ū2/Ūn (1 Hz up to the maximum pulse frequency).
    At low frequencies (below 1 Hz), the AVC value is transmitted directly and pulse-synchronized averaging does not occur.
    Reason for limitation: e.g.: 0.5 Hz = the controller receives a new value every 2 seconds.
    AC welding:
    Welding voltage is measured in the negative half wave, as only this voltage is relevant for AVC control. We recommend that the user calculate their own average value for AC welding with pulse function.
    1. Analog Outputs
    Resistance - Single Bit
    This signal indicates the measured welding circuit resistance (R), which is transmitted during the measurement in Working mode 24 (R/L-measurement).
    The saved welding circuit resistance (R) of the welding system is transmitted before and after the measurement.
    1. Analog Outputs
    This signal indicates:
    1. How high the edge found in the WireSense joint type detection mode for lap joints was (no value is output here for all other joint types).
      • See also description WireSense trigger level - Group Input / Analog Input.
    2. The current value of the height measurement in WireSense contour sensing mode. The value is output cyclically.
      • See also description WireSense - more information.
    3. The length to which the wire electrode has currently been retracted in Teach mode.
    4. The length to which the wire electrode has been conveyed during threading or retraction with the length specification function.
      • See also description Wire forward / backward length (length specification wire threading / wire retraction) - Group Input / Analog Input.
    Additional information for WireSense:
    The wire electrode can move forward to the first detected zero position (reference point) by a maximum of 24 mm (0.945 inches).
    Digital Interface:
    During the processes described above, the wire position is output in the range of ‑32768 to +32767 (SINT 16).
    Value range
    Designation
    ‑32768
    Wire position
    -327.68 mm
    +32767
    Wire position
    +327.67 mm
    1. Analog Outputs
    Wire buffer fill level - Group Output / Analog Output
    This signal indicates the current fill level of the CMT wire buffer. In regular operation, the value is in the range of +/- 10%. For processes with strongly fluctuating wire speeds (e.g., SynchroPuls), the value can be up to +/- 50%.
    A value of -100% means that the wire buffer is empty.
    A value of +100% means that the wire buffer is full.
    These values are an indication of a fault in the wirefeed system.
    Digital Interface:
    If there is a wire buffer in the system, the fill level is output in the range of ‑32768 to +32767 (SINT 16).
    Value range
    Designation
    ‑100
    Fill level
    -100%
    +100
    Fill level
    +100%
    Available Process Images
    Process image types
    Dip switch
    8
    7
    6
    5
    Process image and configuration
    OFF
    OFF
    Standard Image 320 Bit
    OFF
    ON
    Economy Image 128 Bit
    ON
    OFF
    Retrofit Image (scope dependent on bus module)
    ON
    ON
    Not used
    1. Available Process Images
    Process image types
    Dip switch
    8
    7
    6
    5
    OFF
    OFF
    OFF
    ON
    ON
    OFF
    ON
    ON
    Not used
    Changing/assigning characteristic numbers/program numbers (Retro Fit mode)
    For welding machines in the TPS series, the material, the wire diameter, and the protective gas shield can be selected using the program number. A bit width of 8 bits was defined for this.
    It is possible to assign a program number to a characteristic number (1-255) so that the 8-bit signal can be used in retrofit mode.
    Note down the IP address of the welding machine being used:
    1Connect the welding machine to the computer (for example using a LAN cable)
    2Select "Defaults" in the left sidebar of the welding machine control panel
    3Select "System" in the right sidebar of the welding machine control panel
    4Press the "Information" button on the welding machine control panel
    5Note down the displayed IP address (example: 10.5.72.13)
    Access website of the welding machine in the internet browser:
    6Enter the IP address of the welding machine in the search bar of the internet browser and confirm
    • The website of the welding machine is displayed
    7Enter user name and password
    Factory setting:
    User name = admin
    Password = admin
    Note down the IDs of the desired characteristics:
    8On the welding machine website, select the "Synergic lines overview" tab
    9Note down the IDs of the characteristics that it should be possible to select using the interface
    10On the welding machine website, select the tab for the interface used
    For example: RI IO PRO/i
    11Under "Synergic line assignment", assign the desired characteristic IDs to the program numbers (= bit numbers).
    For example: Program number 1 = Synergic line ID 2501, Program number 2 = Synergic line ID 3246, etc.
    • The assigned characteristics can then be retrieved using the interface and the selected program numbers (=bit numbers)
    12Once all of the desired characteristic IDs have been assigned, press "Save assignment"
    • All of the program numbers with their assigned characteristic IDs are displayed under "Actual assigned program numbers to synergic lines"
    Website of the welding machine
    Information on the use of the MIG/MAG standard manual, TIG, electrode, and ConstantWire welding processes
    Use the MIG/MAG standard manual welding process:
    1Select 2-step mode characteristics
    2Select the MIG/MAG standard manual welding process using the appropriate characteristic number
    During the standard manual welding process, the wire speed and welding voltage parameters are set as follows:
    • In order to set the Wire feed speed command value manual parameter, the Wire feed speed command value analog input signal must be used.
    • In order to set the Welding voltage command value manual parameter, the Arc length correction analog input signal must be used.
    • In order to set the Dynamic correction manual parameter, the Pulse-/dynamic correction analog input signal must be used.
    • In order to set the Wire retract correction manual parameter, the Wire retract correction analog input signal must be used.
    1. Information on the use of the MIG/MAG standard manual, TIG, electrode, and ConstantWire welding processes
    TIG
    Use the TIG welding process:
    1Select the TIG welding process using the appropriate characteristic number
    Electrode
    Use the electrode welding process:
    1Select the electrode welding process using the appropriate characteristic number
    ConstantWire
    • ConstantWire can be used in conjunction with 2-step mode characteristics and Job Mode.
      • With 2-step mode characteristics, the welding process is automatically defined via the selected characteristic.
      • In Job Mode, the welding process is automatically defined via the selected job.
    • The ConstantWire process starts as soon as the Welding start signal is set to High. Separately starting the wire movement and current flow is not required.
    • The wire speed is specified with the Wire feed speed command value signal.
    • The voltage limitation does not need to be set, because the automatic setting of the voltage limitation always ensures the current flow.
      • If required, the voltage limitation can also be set manually (refer in this regard to the operating instructions for the respective welding machine).
    Arc Break Monitoring
    Arc break monitoring
    The arc break monitoring is a function that can be activated on the welding machine. The function becomes active when arc breaks occur.
    If the arc break monitoring becomes active due to an arc break, the Robot motion release signal is set to Low.
    The following can be set in order to use the arc break monitoring:
    • The break length after which the arc break monitoring becomes active.
    • In which way the arc break monitoring is activated
      • With "Ignore"
      • With "Error"
    Process if the arc break monitoring reacts to an arc break with "Error"; arc break monitoring set to 200 ms:
    • If the arc breaks for 190 ms, the arc break monitoring is not activated.
    • If the arc breaks for 210 ms, the welding machine reports an error message and stops the welding process.
    Process if the arc break monitoring reacts to an arc break with "Ignore"; arc break monitoring set to 200 ms:
    • If an arc breaks for 210 ms, the Arc stable signal is set to Low by the arc break monitoring. Whether the Welding start signal remains High or is set to Low by the robot depends on the setting selected on the robot.
    Example of arc break monitoring behavior
    (1) The status of the Welding start signal is dependent on:
    • The arc break monitoring setting.
    • The robot setting (how the robot should react to the "Ignore" setting on the arc break monitoring).
    For the "Ignore" setting:
    • The robot sets the Welding start signal to Low (= no reignition of the arc), or
    • Leaves the Welding start signal on High (= reignition of the arc)—depending on the robot setting.
    For the "Error" setting:
    • An error message is output and the welding process is stopped.
    1. Arc Break Monitoring
      • With "Ignore"
      • With "Error"
    A variety of signals and data can be written and exchanged between the welding machine and a control unit (robot controller, etc.) via the Ethernet connection on the rear of the welding machine (service port).
    In order to be able to use the Fronius Data Channel, OPT/i Documentation must be enabled for the welding machine.
    On TWIN systems, the Ethernet connection socket on the welding machine of process line 1 must be used.
    Available signals and data:
    Number
    Designation
    Description
    Type of signal
    Process active
    1/0
    Output
    Current flow
    1/0
    Output
    Article number
    String
    Input
    Serial number
    String
    Input
    5
    Seam number
    Integer
    Input
    Windows example (PuTTY)
    A TCP socket connection must be established for data transfer.
    1For this purpose, enter the IP address of the welding machine service port and the port number 4714.
    1. Fronius Data Channel
    Number
    Designation
    Description
    Type of signal
    Process active
    1/0
    Output
    Current flow
    1/0
    Output
    Article number
    String
    Input
    Serial number
    String
    Input
    5
    Seam number
    Integer
    Input
    Signal sequence when selected using "Job Mode" operating mode
    (1)
    Wait time of at least 0.1 seconds
    (2)
    (3)
    Gas pre-flow time
    (4)
    Starting current time
    (5)
    Slope 1
    (6)
    Gas post-flow time
    (7)
    Slope 2 + final current time
    (1)
    (2)
    (3)
    Gas pre-flow time
    (4)
    (5)
    Slope 1
    (6)
    Gas post-flow time
    (7)
    Signal sequence when selected using "Characteristics Mode" operating mode
    (1)
    (2)
    (3)
    (4)
    Gas pre-flow time
    (5)
    (6)
    Slope 1
    (7)
    Gas post-flow time
    (8)
    (1)
    (2)
    (3)
    (4)
    Gas pre-flow time
    (5)
    (6)
    Slope 1
    (7)
    Gas post-flow time
    (8)
    WireSense joint type description
    Joint type: Lap joint/trigger both edges
    For position detection of lap joints with two sheets. The edge detection and the subsequent output of the touch signal takes place at the first rising edge or first falling edge. The sheet thickness must be at least as high as the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Lap joint/trigger rising edge
    For position detection of lap joints with two sheets. The edge detection and the subsequent output of the touch signal takes place at the first rising edge only. The sheet thickness must be at least as high as the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Lap joint/trigger falling edge
    For position detection of lap joints with two sheets. The edge detection and the subsequent output of the touch signal takes place at the first falling edge only. The sheet thickness must be at least as high as the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Lap joint/trigger second rising edge
    For position detection of lap joints with three sheets. The edge detection and the subsequent output of the touch signal takes place at the second rising edge only. The sheet thickness of the two top sheets must be at least as high as the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Lap joint/trigger second falling edge
    For position detection of lap joints with three sheets. The edge detection and the subsequent output of the touch signal takes place at the second falling edge only. The sheet thickness of the two top sheets must be at least as high as the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: T-joint
    For position detection of T-joints. The location of the position found and the subsequent output of the touch signal depends on the set trigger level. The torch position should be equal to the bisector of the angle during the entire torch movement.
    Joint type: YV butt joint
    For position detection of Y or V butt joints. The location of the position found and the subsequent output of the touch signal depends on the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Square butt joint
    For position detection of square butt joints with an air gap. The air gap must be at least as wide as the wire diameter used. The location of the position found and the subsequent output of the touch signal depends on the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Flange joint
    For position detection of flange joints. The location of the position found and the subsequent output of the touch signal depends on the set trigger level. The welding torch should be moved parallel to the sheet metal surfaces.
    Joint type: Corner joint
    For position detection of corner joints. The location of the position found and the subsequent output of the touch signal depends on the set trigger level. The torch position should be equal to the bisector of the angle during the entire torch movement.
    1. WireSense - more information
    This signal selects which joint type is to be searched for by means of the WireSense process. The type of joint is selected before starting the WireSense process (see section WireSense start - Single Bit).
    Joint type: T-joint
    WireSense trigger level description
    Trigger level: Lap joints with rising edges
    With this type of joint, the height at which the edge/sheet is to be detected is set. If the currently measured wire position exceeds the set trigger level, the touch signal will be output. Since the current wire position always starts at 0 mm at the start of the process, the trigger level refers to the lower or the upper sheet depending on the direction of movement. In the example given, the trigger level only applies to movements from right to left.
    Trigger level: T-joints
    With this type of joint, the height at which the second sheet is to be detected in relation to the reversal point is set. If the currently measured wire position exceeds the set trigger level, the touch signal will be output. The trigger level refers to the vertical or horizontal sheet, depending on the direction of movement from the reversal point. In the example given, the trigger level applies to movements at an angle equal to the bisector of the angle from bottom to top.
    Trigger level: YV butt joints
    With this type of joint, the height at which the second sheet is to be detected in relation to the reversal point is set. If the currently measured wire position exceeds the set trigger level, the touch signal will be output. The trigger level refers to the right or left sheet, depending on the direction of movement from the reversal point. In the example given, the trigger level applies to movements from right to left.
    Trigger level: Square butt joints with air gap
    With this type of joint, the extent to which the wire has to sink into the air gap and rise again is set. If the currently measured wire position exceeds the set trigger level, the touch signal will be output. With this type of joint, the trigger level applies to both sheets and (as shown in the example given) to both directions of movement.
    Trigger level: Flange joints
    Trigger level: Corner joints
    Process description WireSense contour sensing mode (contour detection)
    For more information on contour detection, see:
    • Section WireSense start - Single Bit
    • Section WireSense trigger level - Group Input / Analog Input
    • Section WireSense break - Single Bit
    Process description WireSense joint type detection (joint type detection)
    For more information on edge detection, see:
    • Section Touch signal (Touch signal) - Single Bit
    Signal profile in joint type detection mode for lap joint
    * The start time of the Arc stable / Touch signal signal may vary depending on the condition and electrical conductivity of the wire electrode tip. Below are two examples.
    1. No slag on the tip of the wire electrode:
      The WireSense process starts without the WireSense -Slaghammer function and the Arc stable / Touch signal signal is output around 20 ms after the wire electrode touches the workpiece.
    2. Slag present on the tip of the wire electrode:
      Before the WireSensefunction starts, the WireSense -Slaghammer function is automatically activated to remove the slag residues from the tip of the wire electrode. The Arc stable / Touch signal signal is activated only after successful removal of the slag and sufficient electrical contact between the wire electrode and the workpiece. The delay time for the Arc stable / Touch signal signal can thus be many times greater than 20 ms.
    Signal profile in joint type detection mode for T-joint
    Signal profile in joint type detection mode for YV butt joint
    Signal profile in joint type detection mode for square butt joint
    Signal profile in joint type detection mode for flange joint
    Signal profile in joint type detection mode for corner joint
    Signal profile WireSense break (only possible in contour sensing mode)
      The WireSense process starts without the WireSense -Slaghammer function and the Arc stable / Touch signal is output around 20 ms after the wire electrode touches the workpiece.
      Before the WireSense function starts, the WireSense -Slaghammer function is automatically activated to remove the slag residues from the tip of the wire electrode. The Arc stable / Touch signal is activated only after successful removal of the slag and sufficient electrical contact between the wire electrode and the workpiece. The delay time for the Arc stable / Touch signal can thus be many times greater than 20 ms.
    Signal profile in contour sensing mode for different surface geometries
    Representation of the possible WireSense measurement range
    Length limit for wire movement in WireSense contour sensing mode (contour detection):
    Length limit for wire movements in WireSense joint type detection mode (joint type detection) for lap joints with falling edges:
    Length limit for wire movements in WireSense joint type detection mode (joint type detection) for all other joint types:
    Additional information for length limits:
    If the welding torch is moved so far in the direction of the workpiece that an electrical connection to the contact tip is established, the wire is retracted 40 mm and the error message is set. (Error number 1334: "Short circuit between contact tip and welding ground during active WireSense/teach process")
    Note on height measurement for lap joints with falling edges
    WireSense joint type detection mode (joint type detection) for lap joints with falling edge without height measurement:
    Analog input: WireSense trigger level = 1 mm
    Max. wire forward movement = WireSense trigger level + 3 mm
    = 1 mm + 3 mm
    = 4 mm
    The wirefeeder stops after 4 mm. The wire electrode does not move any further forward and does not reach the lower sheet. This means that it is not possible to measure the height at the edge of the sheet.
    However, the Touch signal is output as usual as soon as the set Trigger level value has been exceeded.
    This behavior can be undesirable, e.g., when measuring sheet edges.
    Remedy:
    Set a WireSense trigger level value that is max. 2 mm less than the expected edge height to be measured.
    For example: a 5 mm edge results in an optimal Trigger level value of 3 mm.
    In other applications, this behavior may be desired, e.g., in applications with an insulating weld pool support.
    The component position is determined by the Touch signal, but the height is not measured.
    It is important that the wire electrode stops before the insulating weld pool support and does not touch the weld pool support.
    If the wire electrode touches the support, this will cause a malfunction in the WireSense process.
    Application with insulating weld pool support (CERAMIC)
    Note on ignition timeout (Ignition Timeout)
    If the ignition timeout is set to 30 mm (1.18 inches) and the wire electrode is located at a greater distance from the workpiece, for example, the WireSense function will not start, as wirefeeding stops after 30 mm (1.18 inches) even before the electrode can reach the workpiece.
    (1)
    For example, distance = 40 mm (1.57 inches)
    (2)
    Ignition timeout setting = after 30 mm (1.18 inches), for example
    WireSense Isolated mode
    If WireSense is operated in Contour sensing mode, then Isolated mode is automatically also active. This means that a WireSense search operation can also be carried out on surfaces with non-conductive sections. Such surfaces may include weld seams on which slag, silicates, or oxides have been deposited.
    Notes on the use of WireSense in Isolated mode:
    1. Isolated mode is only possible in Contour sensing mode. The WireSense trigger level must be set to a value of less than 0.5 mm.
    2. The welding wire material set via the welding characteristic must have a yield point above 230 N. These are, for example, materials based on steel or stainless steel. The function is not active for aluminum-based, magnesium-based, or copper-based materials, for example.
    3. The WireSense process must start on a conductive section. Only then will the Slaghammer function not be triggered. However, this only allows the removal of silicates deposited on the wire tip. The Slaghammer is usually not capable of sufficiently removing slag on the component or the weld seam.
    WireSense Isolated mode Monitoring functions:
    Permanent operation on insulating materials is not intended. After more than 30 continuous WireSense movement cycles on a non-conductive material, an error message appears (error number 1340: "Maximum number of movement cycles on isolating materials achieved") and the process stops automatically. At a slow search speed of 30 cm/min, this corresponds to a silicate width of approx. 5 mm.
    The internal evaluation algorithm works differently in isolated mode than with conductive materials, therefore the following are also monitored:
    • Current motor forces
    • Wire speed profile
    In the event of noticeable deviations or imperfections, a warning message (warning number 16680: "Increased motor force / unstable wirefeed process detected during isolated mode") is triggered. This does not abort the running process, but indicates that the WireSense process is no longer being executed properly in isolated mode and error message 1340 may be triggered incorrectly if operation continues.
    Such problems are especially more likely to occur with:
    • Special torch types (e.g., very long torch geometries or special torch geometries)
    • Special filler metals (e.g., CuMn13Al8)
    • Use of unsuitable inner liners or inner liners not adapted to the wire diameter
    • Uncommon wire diameters (e.g., 0.8 mm, 1.6 mm)
      In such cases, it must be clarified with Technical Support whether alternative system configurations are possible and whether WireSense can be used in Isolated mode.
    Isolated Teach mode:
    The Isolated mode described above is also available in Teach mode. This means that Teach mode can be used for final runs on multirun welds with possible silicate deposits, for example. Teach mode can also be used with heavily soiled workpiece surfaces or component sections with a poor ground connection.
    The Isolated mode for Teach mode is not active by default and must be activated in the component menu under the robot settings.
    Available signals for component scanning
    Signal list
    Signal designation
    Type of signal
    Data type
    Factor
    Value range
    WireSense start
    (BIT 29)
    Input
    BIT
    WireSense break
    (BIT 30)
    Input
    BIT
    Wire position
    (BIT 256-271)
    Output
    WORD (SINT) in mm
    100
    -327.68 to +327.67
    WireSense joint type detection (joint type detection):
    Signal designation
    Type of signal
    Data type
    Factor
    Value range
    WireSense start
    (BIT 29)
    Input
    BIT
    (BIT 52-55)
    Input
    BIT
    GROUP
    WireSense trigger
    level
    (BIT 256-271)
    Input
    WORD (UINT) in mm
    10
    0 to 20 mm
    Touch signal
    (BIT 7)
    Output
    BIT
    Wire position
    (BIT 256-271)
    Output
    WORD (SINT) in mm
    100
    -327.68 to +327.67
    Teach Mode:
    Signal designation
    Type of signal
    Data type
    Factor
    Value range
    Teach mode
    (BIT 25)
    Input
    BIT
    Wire position
    (BIT 256-271)
    Output
    WORD (SINT) in mm
    100
    -327.68 to +327.67
    Touch signal
    (BIT 7)
    Output
    BIT
    1. Available signals for component scanning
    Signal list
    Signal designation
    Type of signal
    Data type
    Factor
    Value range
    WireSense start
    (BIT 29)
    Input
    BIT
    WireSense break
    (BIT 30)
    Input
    BIT
    Wire position
    (BIT 256-271)
    Output
    WORD (SINT) in mm
    100
    -327.68 to +327.67
    Signal designation
    Type of signal
    Data type
    Factor
    Value range
    WireSense start
    (BIT 29)
    Input
    BIT
    (BIT 52-55)
    Input
    BIT
    GROUP
    WireSense trigger
    level
    (BIT 256-271)
    Input
    WORD (UINT) in mm
    10
    0 to 20 mm
    Touch signal
    (BIT 7)
    Output
    BIT
    Wire position
    (BIT 256-271)
    Output
    WORD (SINT) in mm
    100
    -327.68 to +327.67
    Teach Mode:
    Signal designation
    Type of signal
    Data type
    Factor
    Value range
    Teach mode
    (BIT 25)
    Input
    BIT
    Wire position
    (BIT 256-271)
    Output
    WORD (SINT) in mm
    100
    -327.68 to +327.67
    Touch signal
    (BIT 7)
    Output
    BIT
    Functions of Limit Monitoring
    • Limit Monitoring monitors the welding parameters of the welding process.
    • Limit Monitoring indicates whether the weld is performed within the predefined limit values of the weld specification (= job set values).
    • If Limit Monitoring determines that the actual values are outside the defined limits, the weld seam should be checked.
      • If the weld seam is OK in such a case, it is recommended to check the defined limits and adjust them if necessary.
      • If the weld seam is not OK in such a case, it is recommended to check the welding parameters and adjust them if necessary.
    • Limit Monitoring is only active in the main current phase.
    • Limit Monitoring is not active during the Slope-phases.
    • Limit Monitoring can only be used in conjunction with Job Mode.
    Limit Monitoring does not monitor the quality of the weld seam. As a result, Limit Monitoring does not provide any information on whether the weld seam is OK or not.
    Limit Monitoring is available for the following processes:
    • MIG/MAG standard synergic
    • MIG/MAG pulse synergic
    • MIG/MAG PMC
    • MIG/MAG LSC
    • CMT
    It is not recommended to use Limit Monitoring for the following processes:
    • MIG/MAG PMC Mix
    • CMT Mix
    • CMT Cycle Step
    • SynchroPulse welding with
      • MIG/MAG PMC
      • MIG/MAG LSC
    1. Limit Monitoring - functions and activation
    • MIG/MAG PMC
    • MIG/MAG LSC
    • CMT
    • MIG/MAG PMC Mix
    • CMT Mix
    • CMT Cycle Step
      • MIG/MAG PMC
      • MIG/MAG LSC
    Available function packages
    OPT/i Limit Monitoring (= required), 4,067,004
    Among other things, to monitor:
    • Voltage
    • Current
    • Wirefeeder
    • Welding time
    • Energy
    OPT/i Jobs (= optional), 4,067,002
    • Enables remote access (for example from a PC) to the welding machine (Smart Manager). For example, the limit values of job parameters can be changed via the Smart Manager; directly from the PC, without having to implement the setting at the welding machine itself.
    OPT/i Documentation (= optional), 4,067,003
    • Is used to export the welding data stored in the welding machine as a CSV file, in addition to the export as a PDF file available by default.
    • Enables the use of FroniusDataChannel, which is used for the exchange of Traceability data.
    Prerequisites for the successful use of Limit Monitoring
    1. Job mode must be enabled for each welding machine.
    2. At least 1 job must be assigned to each weld seam
      • It is recommended to use several jobs per weld seam if significant influencing factors change during welding, such as robot speed, angle of attack of the welding torch, stickout, etc.
    3. Only create jobs when the correct welding parameters have already been determined
      • If the welding parameters in the job are changed, the limits must also be adjusted accordingly.
    4. Always set limits based on measured actual values (not based on set values). The following options are available
      • Read actual values on the display of the welding machine during welding.
      • Read actual values via the Smart Manger during welding.
      • Evaluation of the welding parameters by means of WeldCube Premium.
    Switch Limit Monitoring on / off
    Limit Monitoring on
    Limit Monitoring off
    Detailed description of Limit Monitoring
    • The data is recorded / checked every 50 ms during Limit Monitoring.
    • At point A, the upper voltage limit is exceeded; the time until the reaction of Limit Monitoring begins to count constantly upwards.
    • At point B, the voltage falls below the upper limit again; the time until the reaction of Limit Monitoring counts down to 0.
    • At point C, the upper voltage limit is exceeded again; the time until the reaction of Limit Monitoring starts to count upwards constantly again.
    • At point D, the set time limit for the reaction of limit monitoring is reached:
      • The hysteresis time starts to run.
      • Point E shows the hysteresis of +20% to the set time value (time until reaction from Limit Monitoring).
      • A warning or an error is issued depending on the setting.
      • The Limitsignal (Word 1 / Byte 2 / Bit 19) changes to High.
    • At point F, the Limitsignal (Word 1 / Byte 2 / Bit 19) changes to Low.
    Functionality of Limit Monitoring for energy and welding duration:
    • With energy monitoring, Limit Monitoring does not monitor each job individually, but the entire weld seam - for more information see Energy monitoring from page (→).
    • With welding time monitoring, Limit Monitoring does not monitor each job individually, but the entire weld seam - for more information see Welding time monitoring from page (→).
    Voltage monitoring
    Serves to:
    • Set the voltage set value and the desired limits.
    • Monitor the voltage actual value per weld seam / job.
    Voltage monitoring
    Adjustable parameters:
    (1)
    Voltage set value:
    0 to 100 V
    (2)
    Lower voltage limit:
    -10 to 0 V
    (3)
    Upper voltage limit:
    0 to 10 V
    (4)
    Time limit for the reaction of Limit Monitoring:
    Off / 0 to 10 seconds
    Explanation for setting from 0 to 10 seconds:
    • If, for example, 5 seconds are set, Limit Monitoring will only react after a limit has been exceeded or undershot continuously for 5 seconds.
    Explanation for "Off" setting:
    • Limit Monitoring is disabled for this welding parameter.
    • There is no display of limit overruns
    Possible error messages during voltage monitoring:
    19 |
    Lower voltage limit undershot
    20 |
    Upper voltage limit exceeded
    1. Limit Monitoring - details on the individual welding parameters
    Voltage monitoring
    Serves to:
    Voltage monitoring
    (1)
    Voltage set value:
    0 to 100 V
    (2)
    -10 to 0 V
    (3)
    0 to 10 V
    (4)
    19 |
    20 |
    Current monitoring
    Serves to:
    • Set the current set value and the desired limits.
    • Monitor the current actual value per weld seam / job.
    Current monitoring
    (1)
    Current set value:
    0 to 100 A
    (2)
    Lower current limit:
    -10 to 0 A
    (3)
    Upper current limit:
    0 to 10 A
    (4)
    • There is no display of limit overruns.
    Possible error messages during current monitoring:
    21 |
    Lower current limit undershot
    22 |
    Upper current limit exceeded
    Wirefeeder monitoring
    Serves to:
    • Set the wirefeeder set value and the desired limits.
    • Monitor the wirefeeder actual value per weld seam / job.
    (1)
    Wirefeeder set value:
    0 to 100 m/min
    (2)
    Lower wirefeeder limit:
    -10 to 0 m/min
    (3)
    Upper wirefeeder limit:
    0 to 10 m/min
    (4)
    Possible error messages during wirefeeder monitoring:
    23 |
    Lower wirefeeder limit undershot
    24 |
    Upper wirefeeder limit exceeded
    Serves to:
    • Set the welding time set value and the desired limits.
    • Monitor the welding time per weld seam / job.
    If a weld seam consists of 2 or more jobs, the welding time of the previously welded job must be added for the jobs following in the welding sequence.
    Example:
    • A weld seam consists of 4 jobs, each with a duration of 4 seconds.
    • Limit Monitoring ignores the first 3 jobs and only records the last job.
    • For this reason, a welding time set value of at least 16 seconds must be set for the last job (4 x 4 seconds) in order to prevent Limit Monitoring from unintentionally issuing a notification.
    (1)
    Welding time set value:
    0 to 999.9 seconds
    (2)
    Lower welding time limit:
    -50 to 0 seconds
    (3)
    Upper welding time limit:
    0 to 50 seconds
    (4)
    Possible error messages during welding time monitoring:
    50 |
    Lower welding time limit not reached
    51 |
    Upper welding time limit exceeded
    Energy monitoring
    Serves to:
    • Set the energy set value and the desired limits.
    • Monitor the energy input per weld seam / job.
    If a weld seam consists of 2 or more jobs, the energy input of the previously welded job must be added for the subsequent jobs in the weld sequence.
    Example:
    • A weld seam consists of 4 jobs, with an energy input of 40 kJ each.
    • For this reason, an energy set value of at least 160 kJ must be set for the last job (4 x 40 kJ) in order to prevent Limit Monitoring from unintentionally issuing a notification.
    Energy monitoring
    (1)
    Energy set value:
    0 to 9999.9 kJ
    (2)
    Lower energy limit:
    -10 to 0 kJ
    (3)
    Upper energy limit:
    0 to 10 kJ
    (4)
    Energy monitoring:
    On/Off
    Possible error messages:
    47 |
    Lower energy limit not reached
    48 |
    Upper energy limit exceeded
    Setting of the reaction when exceeding or falling below the limits:
    The setting is used for:
    • Determination of how the welding machine reacts when the set limits are exceeded or not reached.
    The following reactions are possible:
    • Ignore
    • Warning
    • Error
    The following is a description of each reaction.
    Reaction when limits are exceeded or undershot = ignore:
    • No reaction
    • No entry in the logbook
    Reaction when limits are exceeded or undershot = Ignore
    Reaction when limits are exceeded or undershot = warning:
    • Entry is made in the logbook.
    • The welding parameters affected by exceeding or falling below the limits are marked in red.
    Reaction when limits are exceeded or undershot = Warning
    Overview of the entries in the logbook
    Display of the individual sections in the logbook
    Additional information on reactions of the welding machine to a warning:
    • The welding machine indicates whether the limits have been overrun or undershot.
    • The overrun or undershoot is displayed until the end of welding.
    Display of the warning with the welding parameters
    Display of the warning with the system data
    Display of the warning with Job optimization
    Additional information on reactions at the interface to a warning:
    • During welding, the limit signal (WORD 1 / Byte 2 / Bit 19) reacts directly to exceeding or falling below the limits
      • If no overshoot or undershoot of the limits is detected, the Limitsignal Low remains.
      • If an overshoot or undershoot of the limits is detected, the Limitsignal changes to High.
      • As soon as the welding parameters are within the defined limits again, the Limitsignal changes back to Low after 1 second.
    • No warning number is output at the interface (WORD 9 / Byte 18 - 19 / Bit 144 - 159).
    Indicator on the interface; Limitsignal = Low
    Indicator on the interface; Limitsignal = High
    Reaction when limits are exceeded or undershot = error:
    • Welding machine stops the welding process.
    Reaction when limit exceeded / limit undershot = error
    Error message
    Logbook details
    Additional information on reactions at the interface to an error:
    • During welding, the limit signal (WORD 1 / Byte 2 / Bit 19) reacts directly to exceeding or falling below the limits.
      • Welding is stopped immediately.
      • The error number (= reason for the welding stop) can be read out at the interface (WORD 8 / Byte 16 - 17 / Bit 128 - 134).
    Overview of the interface functionalities in case of exceeding or falling below the limits:
    Set reaction
    Limit signal
    Error number (WORD 8 / Byte 16 - 17 / Bit 128 - 134)
    Warning number (WORD 9 / Byte 18 - 19 / Bit 144 - 159)
    Stop welding: yes / no
    Ignore
    Warning
    x
    Error
    x
    x
    Yes
    Setting of the reaction when exceeding or falling below the limits for the motor force
    General information:
    • Motor force monitoring is not linked to a job and is therefore always available.
    • In order to draw conclusions about the condition of the wire feed section (wear of the inner liner, condition of the motor, etc.), the motor force can be monitored and a corresponding reaction can be set if the defined limits are exceeded or undershot.
    • Motor force monitoring is available from version 2.3.1 of the welding machine onwards.
    • The motor force of the main motor M1 is monitored.
    • Motor force monitoring is also active during the threading process.
    • Determination of how the welding machine reacts when the set limit for the motor force is exceeded or undershot.
    • Ignore
    • Warning
    • Error
    • No reaction at the welding machine.
    • No entry is made in the logbook.
    Reaction when limits are exceeded or undershot = Error
    Error message
    Logbook details
    Smart Manager + OPT/i Jobs (4,067,002)
    If the function package OPT/i Jobs has been activated, the desired limits can also be defined via the Smart Manager:
    Define limit in Smart Manager
    Information on exceeding or falling below limits is also displayed in the Smart Manager :
    Smart Manager
    Smart Manager
    Display of overshooting or undershooting limits in the system data display of the Smart Manager:
    System data display in the Smart Manager
