Indicates an immediate danger.
Indicates a possibly dangerous situation.
Indicates the possibility of flawed results and damage to the equipment.
The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device mustFor the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
The device is intended exclusively for the welding process specified on the rating plate.
Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose." The manufacturer is not responsible for any damage resulting from improper use.
The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
The manufacture shall also not be liable for faulty or incorrect work results.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
This may affect a number of device types in terms of:*) both at the interface with the public grid
See technical data
In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
IMPORTANT! Ensure secure grounding of the grid connection!
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Local regulations and national guidelines may mean that a residual current circuit breaker is required when connecting a device to the public grid.
The residual current circuit breaker recommended for the device by the manufacturer can be found in the technical data.
The device produces a maximum noise level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation in relation to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
A workplace-specific emission value for welding (and cutting) cannot be specified because this value depends on the welding process and the environmental conditions. It is influenced by a wide range of parameters, such as the welding process itself (MIG/MAG, TIG welding), the selected current type (direct current, alternating current), the power range, the type of weld metal, the resonance properties of the workpiece, the workplace environment, and many other factors.
The fumes produced during welding contain toxic gases and vapors.
Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
Use at-source extraction source and a room extraction system.
If possible, use a welding torch with an integrated extraction device.
Keep your head out of the welding fumes and gases.
Take the following precautionary measures for fumes and harmful gases:Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
Use a welding helmet with air supply if there is insufficient ventilation.
If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
The following components are factors that determine how toxic the welding fumes are:Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
Flying sparks can cause fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
Keep suitable, tested fire extinguishers on hand.
Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
Do not touch voltage-carrying parts inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wirespool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Before every use, check power connections for secure fit by hand.
In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
Do not wrap cables or leads around your body or parts of the body.
Concerning the electrode (rod electrode, tungsten electrode, welding wire, etc.)The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
Switch off unused devices.
When working at elevated heights, wear a safety harness to prevent falls.
Before working on the device, switch off the device and remove the grid plug.
Secure the device to prevent the grid plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
After opening the device:If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Covers and side panels must only be opened/removed during maintenance and repair work.
During operationThe protrusion of welding wire from the welding torch represents a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
Do not touch the workpiece during or after welding – risk of burns.
Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Leave the welding torch and other parts with a high operating temperature to cool before working on them.
Special regulations apply in areas at risk of fire or explosion
– follow the appropriate national and international regulations.
Power sources for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the power source may not be located in such areas.
Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
If the device is equipped with a carrier belt or handle, then this is used exclusively for transport by hand. The carrier belt is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
All lifting equipment (belts, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
The test interval and scope must at least comply with the respective valid national standards and guidelines.
There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
Use filters if necessary.
Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
Keep shielding gas cylinders away from welding or other electrical circuits.
Risk of explosion: Never weld on a compressed shielding gas cylinder.
Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
When no welding is taking place, close the valve of the shielding gas cylinder.
Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
Risk of asphyxiation due to uncontrolled shielding gas leak
Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
Do not lift or transport any active devices. Switch off devices before transport or lifting.
Before transporting the device, completely drain the coolant and dismantle the following components:It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is switched on.
Before switching on the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
Always secure the shielding gas cylinder well and remove before transporting by crane.
Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
Only use appropriate original coolant from the manufacturer.
Do not mix original coolant from the manufacturer with other coolants.
Only connect system components from the manufacturer to the cooling unit circuit.
If there is damage due to use of other system components or other coolants, the manufacturer accepts no liability for this and all warranty claims are forfeited.
Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
When the system is cool, always check the coolant level before starting welding.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating welding systems within the same 12-month interval.
A safety inspection by a certified electrician is recommended:For the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
Packaging materialsDevices with the CE label satisfy the essential requirements of the low-voltage and electromagnetic compatibility directive (e.g., relevant product standards of the EN 60974 series).
Fronius International GmbH declares that the device complies with Directive 2014/53/EU. The full text of the EU Declaration of Conformity is available on the following website: http://www.fronius.com
The user is responsible for backing up any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
The TransSteel (TSt) 2200 power source is a completely digitized, microprocessor-controlled power source.
This power source is designed for the welding of steel and can be used for the following welding processes:The central control and regulation unit of the power source is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Control algorithms ensure that the desired target state is maintained.
The power source has a "Power limitation" safety feature.
This function is only available for the MIG/MAG standard synergic welding process.
Mode of operation:
If necessary, the power source reduces the welding power to prevent the arc from being extinguished during welding at the power limit of the power source. The reduced parameters are displayed on the control panel until welding starts again or until the next parameter change.
As soon as the function is active, the indicator for the wire speed parameter on the control panel flashes.
The flashing continues until the next welding start-up, or until the next parameter change.
Warning notices and safety symbols are affixed to the power source. These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and property damage.
Dispose of old devices in accordance with safety rules and not in normal domestic waste.
Warning notices are attached to the device for certain device versions.
The arrangement of the symbols may vary.
| ! | Warning! Caution! The symbols represent possible dangers. |
| A | Drive rollers can injure fingers. |
| B | The welding wire and drive parts are under welding voltage during operation. Keep hands and metal objects away! |
| 1. | An electric shock can be fatal. |
| 1.1 | Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves. |
| 1.2 | Use a base that is insulated from the floor and work area to protect against electric shock. |
| 1.3 | Before working on the device, switch off the device and remove the mains plug or disconnect the power supply. |
| 2. | Inhalation of welding fumes can be harmful to health. |
| 2.1 | Keep your face away from any welding fumes. |
| 2.2 | Use forced-air ventilation or local extraction to remove welding fumes. |
| 2.3 | Remove welding fumes with a fan. |
| 3. | Welding sparks can cause an explosion or fire. |
| 3.1 | Keep flammable materials away from the welding process. Do not perform welding near flammable materials. |
| 3.2 | Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher. |
| 3.3 | Do not weld on drums or closed containers. |
| 4. | Arc rays can burn the eyes and injure the skin. |
| 4.1 | Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body. |
| 5. | Before working on the machine or welding: undertake training on the device and read the instructions! |
| 6. | Do not remove or paint over the sticker with the warnings. |
| * | Manufacturer order number of the sticker |
As a result of software updates, you may find that there are functions available on your device that are not described in these Operating Instructions, or vice versa.
Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
Serious personal injury and damage to property may result.
Read and understand this document.
Read and understand all the Operating Instructions for the system components, especially the safety rules.
| (1) | Spot welding indicator The spot welding indicator lights up if:
| (2) | 2-step stitch welding indicator The 2-step stitch welding indicator lights up if:
| (3) | 4-step stitch welding indicator The 4-step stitch welding indicator lights up if:
| (4) | Hold indicator At the end of each welding operation, the actual values for welding current and welding voltage are stored - the "HOLD" indicator lights up |
| (5) | Intermediate arc indicator A spatter-prone intermediate arc occurs between the dip transfer arc and the spray arc. The intermediate arc indicator lights up to alert you to this critical range |
| (6) | "Parameter selection" button (left) For selecting the parameters listed below The relevant symbol lights up when a welding parameter is selected. Sheet thickness in mm or inch (synergic parameter)1 If, for example, the welding current to be selected is not known, entering the sheet thickness alone is sufficient. Entering one synergic parameter means that all other synergic parameters are set automatically. Welding current in amperes (synergic parameter)1 Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding. Wire speed in m/min or ipm (synergic parameter)1 |
1 If one of these parameters is selected in the MIG/MAG standard synergic welding process, then the synergic function ensures that all other synergic parameters are adjusted automatically.
| (7) | "Parameter selection" button (right) For selecting the parameters listed below The relevant symbol lights up when a welding parameter is selected. Arc length correction For correcting the arc length Welding voltage in V (synergic parameter)1 Before welding begins, the device automatically displays a standard value based on the programmed parameters. The actual value is displayed during welding. Arc-force dynamic For influencing the short-circuiting dynamic at the moment of droplet transfer - ... Harder and more stable arc 0 ... Neutral arc + ... Soft and low-spatter arc Real Energy Input2 For displaying the energy applied during the welding operation |
2 This parameter can only be selected if the EnE parameter is set to ON in the Setup menu 2nd level.
The value continuously rises during welding in line with the permanently increasing energy input.
The final value is stored after the end of welding until welding starts again or the power source is switched back on - the HOLD indicator lights up.
| (8) | "Gas-test" button For setting the required gas flow rate on the gas pressure regulator/for filling the torch hosepack with shielding gas. When the "Gas-test" button is pressed, shielding gas will flow for 30 seconds. Press the button again to stop the gas flow prematurely. |
| (9) | Selection dial (left) For changing the sheet thickness, welding current, and wire speed parameters, and for changing parameters in the Setup menu |
| (10) | "Wire threading" button For threading the wire into the torch hosepack with no accompanying flow of gas. While the button is being held down, the wire drive runs at feeder inching speed |
| (11) | Selection dial (right) For changing the arc length correction, welding voltage, and arc-force dynamic parameters, and for changing parameters in the Setup menu |
| (12) | "Material" button For selecting the filler metal to be used |
| (13) | "Save" button 1 For saving an EasyJob |
| (14) | "Mode" button For selecting the operating mode |
| (15) | "Wire diameter" button For selecting the wire diameter to be used |
| (16) | "Save" button 2 For saving an EasyJob |
| (17) | "Process" button For selecting the welding process MANUAL = MIG/MAG standard manual welding SYNERGIC = MIG/MAG standard synergic welding STICK = Stick welding (SMAW) TIG = TIG welding |
| (18) | "Shielding gas" button For selecting the shielding gas to be used |
A keylock can be activated to prevent the settings from being inadvertently changed on the control panel. As long as the keylock is active:
Keylock activated:
The message "CLO | SEd" appears on the displays.
Keylock deactivated:
The message "OP | En" appears on the displays.
| (1) | Welding torch connection For connecting the welding torch |
| (2) | (-) Current socket with bayonet latch Used for
| (3) | TMC connection (TIG Multi Connector) For connecting the TIG welding torch |
| (4) | (+) Current socket with bayonet latch Used for
| (5) | Ventilation openings (air outlet vents) For device cooling |
| (6) | Polarity reverser For selecting the welding potential on the MIG/MAG welding torch |
| (7) | MIG/MAG shielding gas connection socket For the shielding gas supply to the welding torch connection (1) |
| (8) | Power switch For switching the power source on and off |
| (9) | Ventilation openings (air inlet vents) For device cooling, the air filter is located behind these vents |
| (10) | Mains cable with strain relief Not prefitted on all models |
| (11) | TIG shielding gas connection socket For the shielding gas supply for the (-) current socket (2) |
| (1) | D100 wirespool holder with brake For holding standard wirespools with a max. diameter of 100 mm (3.94 in) |
| (2) | D200 wirespool holder with brake For holding standard wirespools with a max. diameter of 200 mm (7.87 in.) and a max. weight of 6.8 kg (14.99 lbs.) |
| (3) | 2-roller drive |
Read and understand all safety rules and user documentation for this equipment and all system components.
The power source is intended exclusively for MIG/MAG, rod electrode, and TIG welding.
Utilization for any other purpose, or in any other manner, shall be deemed to be not in accordance with the intended purpose.
The manufacturer shall not be held liable for any damages arising from such use.
The device can be set up and operated outdoors in accordance with protection class IP 23.
Direct moisture (e.g., from rain) must be avoided.
Danger from machines falling or toppling over.
Always place the device on a solid, level surface.
Danger of electrical current due to electrically conductive dust in the device.
Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
The ventilation channel is a very important safety device. When choosing the device location, ensure that the cooling air can enter and exit unhindered through the ventilation openings on the front and back of the device. Electroconductive metallic dust (e.g., from grinding work) must not be allowed to get sucked into the device.
The devices are designed for the grid voltage stated on the rating plate. If the mains cable or mains plug has not been attached to your version of the appliance, these must be installed according to national standards. Fuse protection for the grid lead can be found in the technical data.
Danger due inadequately dimensioned electrical installations.
This can lead to serious damage
The grid lead and its fuse protection should be designed to suit the existing power supply.
The technical data on the rating plate should be followed.
The power source is generator-compatible.
The maximum apparent power S1max of the power source must be known in order to select the correct generator output.
The maximum apparent power S1max of the power source is calculated as follows:
S1max = I1max x U1
I1max and U1 according to the device rating plate or technical data.
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator may be used when not welding at full power.
The generator apparent power SGEN must not be less than the maximum apparent power S1max of the power source!
When single phase devices are being operated with a three-phase generator, note that the stated apparent power of the generator is often just the total that can be present across all three phases of the generator. If necessary, obtain further information about the single-phase power of the generator from the generator manufacturer.
The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
The mains voltage tolerance is specified in the "Technical data" section.
S1max = I1max x U1
SGEN = S1max x 1.35
The mains fuse protection selected on the power source limits the power drawn in from the grid and in turn the possible welding current. This prevents the automatic circuit breaker (e.g., in the fuse box) from tripping straight away.
The desired mains fuse protection can be selected on the power source depending on the grid voltage and automatic circuit breaker used.
The following table shows which grid voltages and fuse ratings limit the welding current.
TSt 2200:
Grid voltage | Welding current limitation |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
TSt 2200 MV:
120 V
| MIG/MAG welding: |
120 V
| MIG/MAG welding: |
120 V | MIG/MAG welding: |
120 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
240 V | MIG/MAG welding: |
* | 100% values = welding with no time limits and without cooling breaks. |
The welding current data applies at an ambient temperature of 40 °C (104 °F).
A safety cut-out prevents the automatic circuit breaker from tripping at higher welding powers. The safety cut-out defines the possible welding duration without the automatic circuit breaker tripping. If the precalculated weld time is exceeded, thus causing the welding current to switch off, the service code "toF" is displayed. A countdown immediately appears next to the "toF" indicator, which shows the remaining time until the power source is ready for welding again. After this time, the message disappears, and the power source is ready for operation again.
Depending on the selected fuse, the safety cut-out limits the maximum currents of the selected process. As a result, it is possible that welding can no longer occur at the saved operating points if these were saved before selecting the fuse.
If welding is nevertheless carried out at one of these operating points, the power source operates at the limit value of the selected fuse – the power limitation is active. The operating point should be re-saved in accordance with the power limitation.
TSt 2200:
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
TSt 2200 MV:
120 V
| MIG/MAG welding: |
120 V
| MIG/MAG welding: |
120 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
230 V
| MIG/MAG welding: |
Danger if the welding torch is not fully inserted.
The device may be damaged.
After inserting the welding torch, ensure it is in the correct end position.
Danger if welding torch is not screwed tight.
Always tighten the welding torch to the specified tightening torque.
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
Danger from springiness of spooled wire electrode.
It can cause injuries.
When inserting the wire electrode into the wire drive, hold the end of the wire electrode firmly.
It is only necessary to connect the mains cable to the power source for multivoltage power sources.
Danger from wire electrode emerging unexpectedly as it is being threaded.
Wear suitable protective goggles
Keep the tip of the welding torch away from your face and body
Do not point the tip of the welding torch at people
Make sure that the wire electrode does not touch any conductive or grounded parts (e.g., housing)
Danger from gas cylinders falling over.
Place the gas cylinders on a level and stable surface.
Secure the gas cylinders to prevent them from falling over
Observe the safety rules of the gas cylinder manufacturer.
Risk from incorrectly connected polarity reverser.
This can result in poor-quality weld properties.
Connect the polarity reverser according to the wire electrode being used. Check the wire electrode packaging to determine whether the wire electrode is for (+) or (-) welding
D200 wirespool holder:
Adjust the brake when using the wirespool holder for the first time and after changing the wirespool. To do so, proceed as described in the following section Adjusting the brake of the D200 wirespool holder.
D100 wirespool holder:
Adjust the brake when using the wirespool holder for the first time and after changing the wirespool. To do so, proceed as described in the following section Adjusting the brake of the D100 wirespool holder
After releasing the torch trigger (end of welding, end of wirefeeding), the wirespool must stop unreeling.
If it fails to do so, adjust the brake.
Danger from emerging wire electrode and moving parts.
Personal injury and damage to property may result.
Before starting work, turn the mains switch of the power source to - O - and disconnect the power source from the mains
Secure all devices and components involved so that they cannot be switched back on.
Explanation of symbols:
Abbreviations used:
| GPr | Gas pre-flow time |
| I | Welding current |
| GPo | Gas post-flow time |
Abbreviations used:
"4-step mode" is suitable for longer weld seams.
Abbreviations used:
"Special 4-step mode" is ideal for welding in higher power ranges. In special 4-step mode, the arc starts at a lower power, which makes it easier to stabilize.
Abbreviations used:
| I-S | Starting current |
| SL | Slope: continuous increasing / lowering of welding current |
| I | Main current |
| I-E | Final current |
The "Spot welding" mode is suitable for welded joints on overlapped sheets.
Abbreviations used:
| SPt | Spot welding time / stitch welding time |
The "2-step stitch welding" mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
Abbreviations used:
| SPb | Stitch pause time |
The "4-step stitch welding" mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
Abbreviations used:
The MIG/MAG standard manual welding process is a MIG/MAG welding process with no synergic function.
Changing one parameter does not result in any automatic adjustments to the other parameters – all variable parameters must be adjusted individually.
The following parameters are available for MIG/MAG manual welding:
All parameter set values remain stored until the next time they are changed. This applies even if the power source is switched off and on again.
The arc-force dynamic parameter can be used to optimize the welding result.
The arc-force dynamic parameter is used to influence the short-circuiting dynamic at the moment of droplet transfer:
| - | = hard, stable arc |
| 0 | = neutral arc |
| + | = soft, low-spatter arc |
The arc length correction and arc-force dynamic parameters can be used to optimize the welding result.
Arc length correction:
| - | = shorter arc, reduced welding voltage |
| 0 | = neutral arc |
| + | = longer arc, increased welding voltage |
Arc-force dynamic:
For influencing the short-circuiting dynamic at the instant of droplet transfer
| 0 | = neutral arc |
The spot and stitch welding modes are MIG/MAG welding processes.
Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
Stitch welding is used for light-gage sheets.
As the wire electrode is not fed continuously, the weld pool can cool down during the intervals. Local overheating leading to the parent material being melted through is largely avoided.
Danger due to welding processes starting unintentionally.
As soon as the power source is switched on, ensure that the tungsten electrode does not accidentally, or in an uncontrolled manner, touch any electrically conductive or grounded parts (e.g., the housing, etc.).
Abbreviations used:
| tup | UpSlope phase: the welding current is continually increased Duration: 0.5 seconds |
| tdown | DownSlope phase: the welding current is continuously reduced Duration: 0.5 seconds |
Abbreviations used:
Intermediate lowering means that the welder uses the torch trigger during the main current phase to lower the welding current to the specified reduced current I-2 .
Abbreviations used:
| I-S | Starting-current phase: the temperature is raised gently at low welding current, so that the filler metal can be positioned correctly |
| I-1 | Main current phase (welding current phase): uniform thermal input into the parent material, whose temperature is raised by the advancing heat |
| I-E | Final current phase: to prevent crater cracks or shrink holes |
| I-2 | Reduced current phase: intermediate lowering of the welding current in order to prevent any local overheating of the parent material |
| tS | Starting current duration |
| tE | Final current duration |
Pulsed welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:Pulsed welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:The power source controls the "Duty cycle dcY" and "Base current I-G" parameters according to the set pulse current (welding current) and pulse frequency.
Adjustable parameters:
| F-P | Pulse frequency (1/F-P = Time between two pulses) |
| I-P | Pulse current (set welding current) |
Fixed parameters:
| tup | UpSlope |
| tdown | DownSlope |
| dcY | Duty cycle |
| I-G | Base current |
For a parameter description see section Parameters for TIG welding from page (→).
Check the rod electrode packaging to determine whether the rod electrode is for (+) or (-) welding.
As soon as the power source is switched on, ensure that the rod electrode does not unintentionally touch electrically conductive or grounded parts (such as housing).
Arc-force dynamic:
| 0 | = neutral arc |
Arc-force dynamic:
| 0 | = neutral arc |
This function is activated at the factory.
AdvantagesKey
| Hti | Hot-current time, 0 - 2 s, factory setting 0.5 s |
| HCU | HotStart current, 100 - 200%, factory setting 150% |
| IH | Main current = set welding current |
The Hti and HCU parameters can be set in the Setup menu. For a parameter description see section Parameters for MMA Welding from page (→).
Function
During the specified hot-current time (Hti), the welding current is increased to a certain value. This value (HCU) is higher than the selected welding current (IH).
As the arc becomes shorter, the welding voltage may also fall so that the rod electrode is more likely to stick to the workpiece. This may also cause the rod electrode to burn out.
Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. The welding process can be resumed without problems once the rod electrode has been detached from the workpiece.
Accessing the Setup menu is described with reference to the MIG/MAG standard synergic (SYNERGIC) welding process.
Access is the same for the other welding processes.
Accessing the Setup menu:
Press the "Process" button to select the SYNERGIC welding process
The control panel is now located in the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
To change a parameter:
Select the desired setup parameter using the left-hand selection dial
Change the setup parameter value using the right-hand selection dial
To exit the Setup menu:
| GPr | Gas pre-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 0.1 |
| GPo | Gas post-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 0.5 |
| Fdi | Feeder inching speed Unit: m/min (ipm) Setting range: 1 - 18.5 (39.37 - 728.35) Factory setting: 10 (393.7) |
| IGc | Ignition current Unit: Ampere Setting range: 100 - 390 Factory setting: 300 |
| Ito | Length of wire that is fed before the safety cut-out trips Unit: mm (in.) Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94) Factory setting: OFF The ignition time-out function (Ito) is a safety feature. If the power source determines that no ignition has occurred after the preset wire length has been fed, wirefeeding is stopped. |
| SPt | Spot welding time Unit: seconds Setting range: OFF, 0.3 - 5 Factory setting: 1 |
| SPb | Spot pause time Unit: seconds Setting range: OFF, 0.3 - 10 (in 0.1 s increments) Factory setting: OFF |
| Int | Interval Unit: - Setting range: 2T (2-step), 4T (4-step) Factory setting: 2T (2-step) |
| FAC | Reset power source to factory settings Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings When the power source is reset, the majority of the applied settings are deleted. The following values remain:- when "PrG" appears on the digital display, the power source has been reset
| 2nd | Second level of the Setup menu (see "Setup Menu 2nd Level") |
| SL | Slope Unit: seconds Setting range: 0 - 9.9 Factory setting: 1 |
| I-S | Starting current Unit: % of welding current Setting range: 0 - 200 Factory setting: 100 |
| I-E | Final current Unit: % of welding current Setting range: 0 - 200 Factory setting: 50 |
| t-S | Start current duration Unit: seconds Setting range: 0 - 9.9 Factory setting: 0 |
| t-E | Final current duration Unit: seconds Setting range: 0 - 9.9 Factory setting: 0 |
| Ito | Length of wire that is fed before the safety cut-out trips Unit: mm (in.) Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94) Factory setting: OFF The "Ignition time-out" function (Ito) is a safety function. If the power source determines that no ignition has occurred after the preset wire length has been fed, wirefeeding is stopped. |
| SPt | Spot welding time Unit: seconds Setting range: 0.3 - 5 Factory setting: 1 |
| FAC | Reset power source to factory settings Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings When the power source is reset, the majority of the applied settings are deleted. The following values remain:- when "PrG" appears on the digital display, the power source has been reset.
| F-P | Pulse frequency Unit: Hertz Setting range: OFF; 1 - 990 (up to 10 Hz: in 0.1 Hz increments) (up to 100 Hz: in 1 Hz increments) (over 100 Hz: in 10 Hz increments) Factory setting: OFF |
| tUP | UpSlope Unit: seconds Setting range: 0.01 - 9.9 Factory setting: 0.5 |
| tdo | DownSlope Unit: seconds Setting range: 0.01 - 9.9 Factory setting: 1 |
| I-S | Starting current Unit: % of main current Setting range: 1 - 200 Factory setting: 35 |
| I-2 | Lowering current Unit: % of main current Setting range: 1 - 100 Factory setting: 50 |
| I-E | Final current Unit: % of main current Setting range: 1 - 100 Factory setting: 30 |
| GPo | Gas post-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 9.9 |
| tAC | Tacking Unit: seconds Setting range: OFF, 0.1 - 9.9 Factory setting: OFF |
| HCU | HotStart current Unit: % Setting range: 100 - 200 Factory setting: 150 |
| Hti | Hot current time Unit: seconds Setting range: 0 - 2.0 Factory setting: 0.5 |
| Ast | Anti-stick function Unit: - Setting range: On, OFF Factory setting: On |
Accessing the 2nd level of the Setup menu:
Press the "Process" button to select the "MIG/MAG standard synergic welding" process
Select the "2nd" setup parameter using the left-hand selection dial
The control panel is now located in the 2nd level of the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
A parameter is displayed in the first level of the Setup menu.
| SEt | Country-specific setting (Standard/USA) ... Std/US Unit: - Setting range: Std, US (Standard/USA) Factory setting: Standard device: Std (measurements in cm/mm) USA device: US (measurements: inches) |
| FUS | Mains fuse protection The maximum possible welding power is limited by the rating of the mains fuse protection used. Unit: A The available mains fuse ratings are determined by the SEt parameter setting: SEt parameter set as Std: OFF / 10 / 13 / 16 SEt parameter set as US: OFF / 15 / 20 (only for 120 V grid voltage) Factory setting: OFF |
| r | Welding circuit resistance (in mOhm) See section Measuring the welding circuit resistance (MIG/MAG welding) from page (→) |
| L | Welding circuit inductivity (in microhenrys) See section Displaying the welding circuit inductivity from page (→) |
| EnE | Real Energy Input Unit: kJ Setting range: ON / OFF Factory setting: OFF Since the full range of values (1 kJ - 99999 kJ) cannot be displayed on the three-digit display, the following display format has been selected: Value in kJ: 1 to 999 / indicator on display: 1 to 999 Value in kJ: 1000 to 9999 / indicator on display: 1.00 to 9.99 (without unit digit, e.g., 5270 kJ -> 5.27) Value in kJ: 10,000 to 99,999 / indicator on display: 10.0 to 99.9 (without unit digit or tens digit, e.g., 23580 kJ -> 23.6) |
| ALC | Arc length correction display (For setting how the arc length correction parameter is displayed) Setting range: ON / OFF Factory setting: OFF Set to ON if the welding voltage parameter is selected and set on the control panel
| r | Welding circuit resistance (in mOhm) See section Measuring the welding circuit resistance (stick welding) from page (→) |
Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The calculated welding circuit resistance is shown on the display.
r = welding circuit resistance in milliohm (mOhm)
If the welding circuit resistance has been measured correctly, the set welding voltage will correspond exactly to the welding voltage at the arc. If you manually measure the voltage on the output jacks of the power source, this voltage will be higher than the welding voltage at the arc - that is, higher by the same amount as the voltage drop of the hosepack.
The welding circuit resistance depends on the hosepack used:Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The welding circuit resistance depends on the hosepack used:Risk of incorrect measurement of the welding circuit resistance.
This can have a negative effect on the welding results.
Ensure that the workpiece has an optimum contact surface in the area of the earthing clamp (clean surface, no rust, etc.).
Ensure that the workpiece has an optimum contact surface for the contact tip (clean surface, no rust, etc.).
The measurement is finished when the welding circuit resistance is shown on the display in mOhm (for example 11.4).
Ensure that the workpiece has an optimum contact surface for the electrode flush (clean surface, no rust, etc.).
The way that the hosepack is arranged has a very significant effect on the welding circuit inductivity and therefore affects the welding process. It is important to lay the hosepacks correctly in order to obtain the best possible welding result.
The setup parameter "L" is used to display the most recently calculated welding circuit inductivity. The welding circuit inductivity is adjusted when the welding circuit resistance is measured. Detailed information in this regard can be found under the "Welding circuit resistance" chapter.
The most recently calculated welding circuit inductivity L is shown on the right-hand digital display.
L ... Welding circuit inductivity (in microhenrys)
Various service parameters can be retrieved by pressing the left and right-hand "Parameter selection" buttons at the same time.
Opening the display:
The first parameter "Firmware version" will be displayed, e.g., "1.00 | 4.21"
Selecting parameters:
Use the "Mode" and "Process" buttons or the left-hand selection dial to select the required setup parameter
Available parameters
Example: | Firmware version |
Example: | Welding program configuration |
Example: | Number of the currently selected welding program |
Example: | Indicates the actual arc time since first use. |
Example: | Motor current for wire drive in A |
2nd | Second menu level for service technicians |
Before starting work, switch off all devices and components involved, and disconnect them from the grid.
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
Make a note of the serial number and configuration of the device, and provide the service team with a detailed error description if:
| Cause: | Grid lead damaged or broken, grid plug not inserted |
| Remedy: | Check grid lead, if necessary insert grid plug |
| Cause: | Grid socket or grid plug faulty |
| Remedy: | Replace faulty parts |
| Cause: | Grid fuse |
| Remedy: | Replace grid fuse |
| Cause: | Welding torch or welding torch control line faulty |
| Remedy: | Replace welding torch |
| Cause: | Overloading |
| Remedy: | Observe the duty cycle |
| Cause: | Thermal automatic circuit breaker has tripped |
| Remedy: | Wait until the power source automatically comes back on after the end of the cooling phase |
| Cause: | Limited supply of cooling air |
| Remedy: | Clean the air filter, ensure accessibility to the ventilation openings - see section Maintenance as required, at least every two months from page (→) |
| Cause: | Fan in the power source is faulty |
| Remedy: | Contact After-Sales Service |
| Cause: | Incorrect ground connection |
| Remedy: | Check ground connection for polarity |
| Cause: | Power cable in welding torch damaged or broken. |
| Cause: | Gas hose is not connected to the correct connection socket for the current welding process |
| Remedy: | Connect the gas hose to the correct connection socket for the current welding process |
| Cause: | Gas cylinder empty |
| Remedy: | Change gas cylinder |
| Cause: | Gas pressure regulator faulty |
| Remedy: | Replace gas pressure regulator |
| Cause: | Gas hose is not fitted or is damaged |
| Remedy: | Fit or change gas hose |
| Cause: | Welding torch faulty |
| Remedy: | Change welding torch |
| Cause: | Gas solenoid valve faulty |
| Remedy: | Inform service team |
| Cause: | Braking force has been set too high |
| Remedy: | Loosen the brake |
| Cause: | Contact tip hole too narrow |
| Remedy: | Use suitable contact tip |
| Cause: | Faulty inner liner in welding torch |
| Remedy: | Check the inner liner for kinks, dirt, etc. and replace if necessary |
| Cause: | Feed rollers not suitable for wire electrode used |
| Remedy: | Use suitable feed rollers |
| Cause: | Incorrect contact pressure of feed rollers |
| Remedy: | Optimize contact pressure |
| Cause: | Incorrect arrangement of welding torch hosepack |
| Remedy: | Arrange the welding torch hosepack in as straight a line as possible, avoiding bends |
| Cause: | Welding torch is inadequately sized |
| Remedy: | Observe duty cycle and load limits |
| Cause: | Incorrect welding parameters |
| Remedy: | Check settings |
| Cause: | Poor ground earth connection |
| Remedy: | Establish good contact with workpiece |
| Cause: | Too little or no shielding gas |
| Remedy: | Check gas pressure regulator, gas hose, gas solenoid valve, welding torch gas connection, etc. |
| Cause: | Welding torch leaks |
| Cause: | Incorrect or heavily worn contact tip |
| Remedy: | Change contact tip |
| Cause: | Incorrect wire alloy or incorrect wire diameter |
| Remedy: | Check wire electrode in use |
| Remedy: | Check weldability of the base material |
| Cause: | Shielding gas not suitable for wire alloy |
| Remedy: | Use correct shielding gas |
If an error message that is not described here appears on the displays, first try to resolve the problem as follows:
If the error occurs again despite several attempts to eliminate it, or if the troubleshooting measures listed here are unsuccessful:
| Cause: | Impermissible change of welding process during welding |
| Remedy: | During welding do not make any impermissible change to the welding process, reset error message by pressing any button |
| Cause: | The power source control has detected a primary overvoltage |
| Remedy: | Check the grid voltage. If the service code persists, switch off the power source, wait for 10 seconds and then switch the power source on again. If the error still persists, contact the After-Sales Service team |
| Cause: | Mains undervoltage: Mains voltage has fallen below the tolerance range |
| Remedy: | Check the mains voltage. If the service code remains, contact After-Sales Service |
| Cause: | Mains overvoltage: the grid voltage has risen above the tolerance range |
| Remedy: | Check the grid voltage. If the service code persists, contact After-Sales Service |
| Cause: | Fault in the wirefeed system - overcurrent in the wirefeeder motor (2-roller drive) |
| Remedy: | Arrange the hosepack in as straight a line as possible; check that there are no kinks or dirt in the inner liner; check the contact pressure on the 2-roller drive; check that there is no entangled wire in the 2-roller drive |
| Cause: | Wirefeeder motor is sticking or defective |
| Remedy: | Check the wirefeeder motor or contact After-Sales Service |
| Cause: | Overtemperature on the PC board LSTMAG20 (secondary circuit) |
| Remedy: | Allow power source to cool down, check air filter and clean if necessary, check that fan is on |
| Cause: | Overtemperature in the secondary circuit of the power source |
| Remedy: | Allow power source to cool down, check air filter and clean if necessary (see section Maintenance as required, at least every two months on page (→)), check whether the fan is running |
| Cause: | Overtemperature on the PC board LSTMAG20 (wirefeeder) |
| Cause: | Overtemperature on the PC board LSTMAG20 (voltage doubler) |
| Cause: | Overtemperature in the power source |
| Cause: | Overtemperature on the power module |
| Remedy: | Allow power source to cool down, check that fan is on |
| Cause: | Overtemperature on the PFC module |
| Cause: | Overtemperature on the PC board LSTMAG20 (PFC) |
| Cause: | The power source's safety cut-out reacted in order to prevent tripping of the mains fuse. |
| Remedy: | After a pause in welding of around 90 s, the message disappears and the power source is operational again. |
| Cause: | Undertemperature on the PC board (secondary circuit) |
| Remedy: | Place power source in a heated room and allow it to warm up |
| Cause: | Undertemperature in the power source secondary circuit |
| Cause: | Undertemperature on the PC board LSTMAG20 (wirefeeder) |
| Cause: | Undertemperature on the PC board LSTMAG20 (voltage doubler) |
| Cause: | Undertemperature in power source |
| Cause: | Undertemperature on the power module |
| Cause: | Undertemperature on the PFC module |
| Cause: | Undertemperature on the PC board LSTMAG20 (PFC) |
| Cause: | No saved program selected |
| Remedy: | Select saved program |
| Cause: | "Ignition time-out" function is active; current did not start flowing before the length of wire specified in the Setup menu had been fed. The power source safety cut-out has tripped |
| Remedy: | Shorten the wire stick-out; press the torch trigger again; clean the surface of the workpiece; if necessary, set the "Ito" parameter in the Setup menu |
| Cause: | Arc break during TIG welding |
| Remedy: | Press the torch trigger repeatedly, clean the surface of the workpiece |
| Cause: | The selected welding program is invalid |
| Remedy: | Select a valid welding program |
| Cause: | Measurement of the welding circuit resistance failed |
| Remedy: | Check grounding cable, current cable, or hosepack and replace if necessary, re-measure the welding circuit resistance |
Under normal operating conditions, the welding system requires only a minimum of care and maintenance. However, several points must be observed in order for the welding system to remain operational for years to come.
Danger from wet air filter.
Ensure that the air filter is dry when it is fitted.
Danger due to the effect of compressed air.
Do not bring the air nozzle too close to electronic parts.
Materials should be disposed of according to valid local and national regulations.
Average wire electrode consumption at a wire speed of 5 m/min | |||
| 1.0 mm wire electrode diameter | 1.2 mm wire electrode diameter | 1.6 mm wire electrode diameter |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminum wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminum wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
For devices designed for special voltages, the technical data on the rating plate applies.
The duty cycle (D.C.) is the period of a ten minute cycle in which the device may be operated at the stated power without overheating.
The D.C. values cited on the rating plate relate to an ambient temperature of 40 °C.
If the ambient temperature is higher, the D.C. or power must be lowered accordingly.
Example: Welding with 150 A at 60% D.C.
To use the device without interruptions:
Grid voltage (U1) |
| 1 x | 230 V | |
Max. effective primary current (I1eff) |
| 16 A | |
Max. primary current (I1max) |
| 26 A | ||
Mains fuse protection | 16 A slow-blow | |||||
Max. apparent power (S1max) | 5.98 kVA | |||||
Mains voltage tolerance | -20 / +15% | |||||
Grid frequency | 50 / 60 Hz | |||||
Cos phi (1) | 0.99 | |||||
Max. permitted grid impedance Zmax on PCC1) |
| 250.02 mOhm | ||||
Recommended residual-current circuit breaker |
| Type B | ||||
Welding current range (I2) |
MIG/MAG |
| 10 - 210 A | |||
MMA |
| 10 - 180 A | |||
TIG |
| 10 - 230 A | |||
Welding current at | 10 min / 40 °C (104 °F) |
| 30% | 60% | 100% | |
MIG/MAG | U1 230 V |
| 210 A | 170 A | 150 A |
| 35% | 60% | 100% | |
MMA | U1 230 V |
| 180 A | 150 A | 130 A |
TIG | U1 230 V |
| 230 A | 200 A | 170 A |
Output voltage range according to standard characteristic (U2) |
MIG/MAG |
| 14.5 - 24.5 V | |||
MMA |
| 20.4 - 27.2 V | |||
TIG |
| 10.4 - 19.2 V | |||
Open circuit voltage (U0 peak / U0 r.m.s) |
| 90 V | ||||
Protection class |
| IP 23 | |||
Type of cooling |
| AF | |||
Overvoltage category |
| III | |||
Pollution degree according to IEC60664 |
| 3 | ||||
EMC device class |
| A 2) | ||||
Safety markings |
| S, CE | ||||
Dimensions l x w x h |
| 560 x 215 x 370 mm | ||||
Weight |
| 15 kg | |||
Max. shielding gas pressure |
| 5 bar | |||
Wire speed |
| 1.5 - 18 m/min | ||||
Wire drive |
| 2-roller drive | ||||
Wire diameter | 0.6 - 1.2 mm | |||||
Wirespool diameter |
| max. 200 mm | ||||
Wirespool weight |
| max. 6.8 kg | ||||
Max. noise emission (LWA) |
| 65.5 dB | ||||
Idle state power consumption at |
| 17.4 W | ||||
Power source efficiency at |
| 89 % | ||||
| 1) | Interface to a 230 V, 50 Hz public grid |
| 2) | A device in emissions class A is not intended for use in residential areas in which the electrical power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Grid voltage (U1) |
| 1 x | 120 V | |
| 15 A | |
| 20 A | ||
Mains fuse protection | 15 A slow-blow | |||||
Max. apparent power (S1max) | 2.40 kVA | |||||
Grid voltage (U1) |
| 1 x | 120 V | |
| 20 A | |
| 29 A | ||
Mains fuse protection | 20 A slow-blow | |||||
Max. apparent power (S1max) | 3.48 kVA | |||||
Grid voltage (U1) |
| 1 x | 230 V | |
| 16 A | |
| 26 A | ||
Grid voltage (U1) |
| 1 x | 240 V | |
| 15 A | |
| 26 A | ||
Mains fuse2) | 20 A time-delay fuse3) | |||||
Max. apparent power (S1max) | 6.24 kVA | |||||
Cos phi | 0.99 | |||||
| 250.02 mOhm | ||||
| Type B | ||||
MIG/MAG |
| 10 - 210 A | |||
MMA |
| 10 - 180 A | |||
TIG |
| 10 - 230 A | |||
MIG/MAG | U1 120 V | (15 A) |
| 105 A | 95 A | 80 A |
| U1 120 V | (20 A) |
| 135 A | 120 A | 105 A |
| U1 230 V |
MMA | U1 120 V | (15 A) |
| 90 A | 80 A | 70 A |
| U1 120 V | (20 A) |
| 110 A | 100 A | 90 A |
| U1 230 V |
TIG | U1 120 V | (15 A) |
| U1 120 V | (20 A) |
| 160 A | 150 A | 130 A |
| U1 230 V |
MIG/MAG |
| 14.5 - 24.5 V | |||
MMA |
| 20.4 - 27.2 V | |||
TIG |
| 10.4 - 19.2 V | |||
| 90 V | ||||
Protection class |
| IP 23 | |||
Type of cooling |
| AF | |||
| III | |||
| 3 | ||||
EMC device class |
| A 4) | ||||
Safety markings |
| S, CE, CSA | ||||
Weight |
| 15.2 kg | |||
| 5 bar | |||
Wire speed |
Wire drive |
| max. 200 mm | ||||
Wirespool weight |
| max. 6.8 kg | ||||
| 65.5 dB | ||||
| 17.4 W | ||||
| 89 % | ||||
| 1) | Interface to a 230 V, 50 Hz public grid. |
| 2) | Only applies to USA: If an automatic circuit breaker is used instead of a fuse, the current/time characteristic of the automatic circuit breaker must match that of the mains fuse specified above. It is permitted for the tripping current of the automatic circuit breaker to be higher than the tripping current of the mains fuse specified above. |
| 3) | Only applies to USA: Time-delay fuse conforming to UL Class RK5 (see UL 248). |
| 4) | A device in emissions class A is not intended for use in residential areas in which the electrical power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
TransSteel 2200c EF | TransSteel 2200 Set EF |
Welding program database: DB 3815
