en
      Operating InstructionsiWave 190i - 230i
    • General information
      • General
        • Explanation of safety instructions
        • Obligations of the operator
        • Obligations of personnel
        • Safety symbols
        • Data security
        • Copyright
      • Proper use
        • Intended use
        • Foreseeable misuse
      • Information about the device
        • Device concept
        • How it works
        • Application areas
        • Conformities
        • Bluetooth trademarks
        • Power source = welding machine
      • Notices on the device
      • System components
        • General
        • Overview
        • Options
    • Control elements and connections
      • Control panel
        • General
        • Danger from incorrect operation
        • Control panel
      • The favourites button
        • Assigning the Favourites button
        • Retrieving favourites
        • Deleting favourites
        • Assigning EasyJobs to the Favourites button
      • Connections, switches and mechanical components
    • Before installation and commissioning
      • Minimum equipment needed for welding task
        • General
        • TIG AC welding
        • Minimum equipment for TIG DC welding
        • Manual metal arc (MMA) welding
        • Generator-powered operation
        • Mains connection
      • Connecting the mains cable
        • General
        • Safety
      • Transport and setup regulations
        • Transporting individual devices
        • Checking lifting tackle
        • Setup regulations
    • Dangers during welding
      • Danger from incorrect operation or misuse
        • Danger from incorrect operation and misuse
      • Danger from mains current and welding current
        • Danger from electromagnetic emissions
      • Danger from flying sparks, arc radiation and noise
        • Danger from arc radiation
        • Danger due to noise
        • Noise emission values
        • Danger from welding operation
      • Danger from toxic gases and vapours
      • Danger due to missing safety devices and moving components
        • Danger due to missing covers
      • Danger from shielding gas cylinders and shielding gas supply
      • Danger from hot parts and slag
    • Start-up
      • Start-up
        • Safety
        • Remarks on the cooling unit
        • General
        • Fitting the system components
        • Connecting the gas cylinder
        • Connecting the welding torch to the welding machine and the cooling unit
        • Establishing a ground earth connection to the workpiece
      • Locking and unlocking the welding machine using the NFC key
        • General
        • Limitations
    • Welding
      • TIG modes
        • Safety
        • Symbols and their explanations
        • 2-step mode
        • 4-step mode
        • Special 4-step mode:
          Variant 1
          Variant 2
          Variant 3
          Variant 4
          Variant 5
          Variant 6
        • Spot welding
        • CycleTIG
      • TIG welding
        • Danger from incorrect operation and electric current
        • Preparation
        • TIG welding
        • Welding parameters for TIG DC welding
        • CycleTIG welding parameters
        • Welding parameters for TIG AC welding
      • Igniting the arc
        • General
        • Igniting the arc using high frequency
          (HF ignition)
        • Touchdown ignition
        • Electrode overload
        • End of welding
      • TIG special functions
        • Ignition timeout function
        • TIG pulsing
        • Tacking function
        • CycleTIG
      • Manual metal arc welding, CEL welding
        • Preparation
        • Welding parameters for manual metal arc welding
        • Welding parameters for MMA welding with cellulose electrodes
        • Starting current > 100 % (HotStart)
        • Starting current < 100 %
          (SoftStart)
        • Anti-stick function
      • EasyJob mode
        • Storing EasyJob operating points
        • Retrieving EasyJob operating points
        • Deleting EasyJob operating points
      • Welding job
        • Preparation
        • Welding a job
    • Setup settings
      • The Setup menu
        • General
        • Accessing the Setup menu
        • Overview
        • Changing menus and parameters
      • The TIG menu
        • Parameters in the TIG DC menu
        • Parameters in the TIG AC menu
      • The MMA menu
        • Parameters in the rod electrode menu
      • The CEL menu
        • Parameters in the CEL menu
      • Ignition and mode settings
        • Ignition parameters
        • Arc monitoring
        • Operating mode defaults
      • The gas menu
        • Parameters in the Gas menu
      • The components menu
        • Parameters in the Components menu
        • Emptying the torch hosepack
        • Filling the torch hosepack
      • The documentation menu
      • The Job menu
        • Saving a job
        • Saving a job via the Job menu
        • Saving a job using the adjusting dial
        • Loading a job
        • Deleting a job
        • Optimising job process parameters
        • Defaults for "Save job"
        • EasyJobs on Favourites button
      • Defaults
        • Overview
      • Display
        • Backlighting
        • Languages
        • Time & Date
        • Show system data
        • Display additional parameters
        • iJob parameter display
      • System
        • Welding machine configuration
        • Reset to factory settings
        • Reset website password
        • Torch trigger I2 - cap mode
        • Performing R/L alignment
      • Network settings
        • General
        • Bluetooth on
        • Configuring Bluetooth devices
        • Network setup
        • Activating WLAN
        • WLAN settings
      • User management
        • Overview
      • General
        • General
        • Explanation of terms used
        • Pre-defined roles and users
        • Recommendation for creating roles and users
      • Create users and roles
        • Creating a user
        • Creating roles
      • Edit user / roles, deactivate user administration
        • Editing users
        • Editing roles
        • Deactivating user management
      • CENTRUM - Central User Management
        • Activating the CENTRUM server
      • Management
        • Trial license
        • Activating the trial license
      • System informations
        • Device information
    • SmartManager - the welding machine website
        • General
        • Opening the welding machine SmartManager
        • Fronius
        • Changing password / logging off
        • Language
      • Current system data
      • Documentation logbook
        • Logbook
        • Basic settings
      • Job-Data
        • Job data
        • Job overview
        • Editing a job
        • Importing a job
        • Exporting a job
        • Export job(s) as…
      • Backup & Restore
        • General
        • Backup & restore
      • User management
        • General
        • Users
        • User roles
        • Export & import
        • CENTRUM server
      • Overview
        • Overview
        • Expanding / reducing all groups
        • Export component overview as ...
      • Update
        • Update
      • Function Packages
        • Function packages
        • Installing a function package
      • Screenshot
        • Screenshot
    • Troubleshooting and maintenance
      • Troubleshooting
        • General
        • Safety
        • Troubleshooting the welding machine
      • Care, maintenance and disposal
        • General
        • Safety
        • At every start-up
        • Every 2 months
        • Every 6 months
        • Disposal
    • Appendix
      • Technical data
        • Explanation of the term "duty cycle"
        • Overview with critical raw materials, year of production of the device
        • Special voltages
        • Average shielding gas consumption during TIG welding
        • Environmental conditions
        • Versions of the appliance
        • iWave 190i AC/DC
        • iWave 190i AC/DC /MV
        • iWave 230i AC/DC
        • iWave 230i AC/DC /MV
        • iWave 230i DC
        • iWave 230i DC /MV
        • Explanation of footnotes
        • Radio parameters
    • 015-22012026
    iWave 190i - 230i
    download
    Control panel
    Controls and connections
    Commissioning
    TIG welding
    Setup menu
    Technical data
    Spare parts
    ContactImprintTerms and ConditionsData privacy statementCookie Policy
    General information
    link_horizontalLink copied
    General
    DANGER!
    Indicates immediate danger.
    This can result in death or serious injuries.
    Avoid the described danger.
    WARNING!
    Indicates a dangerous situation.
    This can result in serious injuries and death.
    Avoid the dangerous situation.
    CAUTION!
    Indicates a damaging situation.
    This can result in injuries and damage to property.
    Avoid the damaging situation.
    NOTE!
    Indicates the possibility of damage to property and flawed results as well as necessary additional information, tips & tricks, recommendations, etc.
    1. General information
    General
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. General
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. General
    The operator must only allow persons to work with the device who:
    • are familiar with the fundamental instructions regarding safety at work and accident prevention and have been instructed in how to use the device
    • have read and understood these operating instructions, especially the section "safety rules", and have confirmed as much with their signatures
    • are trained to produce the required results.
    2. General
    Before using the device, all persons instructed to do so undertake:
    • to observe the basic instructions regarding safety at work and accident prevention,
    • to read these operating instructions, especially the "Safety rules" section and sign to confirm that they have understood them and will follow them.
    2. General
    Safety symbols
    Devices with the CE mark meet the requirements of all valid EU directives, such as:
    • Directive 2014/30/EU on Electromagnetic Compatibility
    • Directive 2014/35/EU Low Voltage Directive
    • Directive 2014/53/EU Radio Equipment Directive
    • EN IEC 60974 Arc welding equipment
    • And so on
    The full text of the EU Declaration of Conformity can be found at
    https://www.fronius.com .
    Devices with the CSA mark satisfy the requirements of the relevant standards in Canada and the USA.
    2. General
    Data security
    • saving and retaining personal settings
    2. General
    Copyright
    Proper use
    Intended use
    The device has been manufactured in line with the state of the art and according to recognised safety standards.
    The welding machine may only be used for TIG and manual metal arc welding in combination with Fronius components.
    Use for any other purpose, or in any other manner, is deemed not in accordance with the intended use.
    Intended use also includes:
    • Fully reading and understanding these operating instructions
    • Following all safety instructions
    • Performing all stipulated inspection and maintenance work
    2. Proper use
    Intended use
    2. Proper use
    Foreseeable misuse
    IMPORTANT! Utilisation for any other purpose, or in any other manner, shall be deemed to be improper use.
    Prohibited improper use includes:
    • Using the device to thaw pipes
    • Using the device to charge batteries/rechargeable batteries
    • Using the device to start engines
    • Operation or storage of the device outside the environmental conditions specified in the technical data
    • Operation or storage of the device outside the protection class specified in the technical data
    Device concept
    The iWave 230i DC, iWave 190i AC/DC and iWave 230i AC/DC TIG welding machines are fully digitised, microprocessor-controlled inverter welding machines.
    Their modular design and potential for system add-ons ensure a high degree of flexibility. The devices can be adapted to any situation.
    The welding machines are generator-compatible. They are exceptionally sturdy in day-to-day operation thanks to the protected control elements and their powder-coated housings.
    The iWave welding machines are equipped with a TIG pulsed arc function with a wide frequency range.
    To optimise the ignition sequence in TIG AC welding, the iWave AC/DC takes into account not only the diameter of the electrode, but also its current temperature, calculated with reference to the preceding welding time and welding off-time.
    2. Information about the device
    Device concept
    How it works
    The central control and regulation unit of the welding machines is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
    During the welding process, the actual data is measured continuously and the machine responds immediately to any changes. Rule algorithms ensure that the desired target state is maintained.
    This results in:
    • A precise welding process
    • Exact reproducibility of all results
    • Excellent weld properties
    Application areas
    The devices are used in workshops and industry for manual TIG applications with unalloyed and low-alloy steel and high-alloy chrome-nickel steels.
    The iWave AC/DC welding machines perform exceptionally well when it comes to welding aluminium, aluminium alloys and magnesium due to the variable AC frequency.
    Conformities
    FCC
    This equipment complies with the limit values for an EMC device class A digital device pursuant to Part 15 of the FCC Rules. These limit values are intended to provide an adequate level of protection against harmful emissions when the device is being used in an industrial environment. This device generates and uses high-frequency energy and can cause interference to radio communications if it is not installed and used according to the Operating Instructions.
    The use of this device in residential areas will probably cause harmful interference, in which case the user will be obliged to correct the interference at their own expense.
    FCC ID: QKWBCU2
    Industry Canada RSS
    This device complies with the Industry Canada licence-exempt RSS standards. Its use is subject to the following conditions:
    (1)
    The device must not cause any harmful interference.
    (2)
    The device must be able to cope with any interference, including that which could adversely affect its operation.
    IC: 12270A-BCU2
    EU
    Conformity with Directive 2014/53 / EU - Radio Equipment Directive (RED)
    When installing the antennae to be used for this transmitter, it is essential to maintain a minimum distance of 20 cm from all people. They must not be installed or operated with any other antenna or transmitter.
    OEM integrators and end users must be aware of the operating conditions of the transmitter in order to comply with the radio frequency exposure guidelines.
    NOM / Mexico
    Operation of this device is subject to the following two conditions:
    (1)
    This device must not cause any harmful interference,
    and
    (2)
    This device must accept any interference received, including interference that may cause undesired operation.
    The Bluetooth® word mark and logos are registered trademarks owned by Bluetooth SIG, Inc. and any use of such marks by Fronius International GmbH is under license. Other trademarks and trade names are those of their respective owners.
    Depending on the device firmware, in some cases "power source" may still be shown on the display.
    Warning notices and safety symbols are affixed to welding machines with the CSA test mark for use in North America (USA and Canada). These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and damage.
    * MV welding machines: 1 ~ 100 - 230 V
    Safety symbols on the rating plate:
    Welding is dangerous. The following basic requirements must be met:
    • Welders must be sufficiently qualified
    • Suitable protective equipment must be used
    • All persons not involved in the welding process must be kept at a safe distance
    • These operating instructions
    • All the operating instructions for the system components, especially the safety rules
    2. Notices on the device
    System components
    General
    The iWave DC and iWave AC/DC welding machines can be used with a wide variety of system extensions and options.
    2. System components
    General
    Overview
    (1)
    TIG welding torches
    (2)
    Welding machines
    (3)
    Cooling units (only for iWave 230i DC and iWave 230i AC/DC)
    (4)
    Trolley with gas cylinder holder
    Not shown:
    • Remote controls
    • Pedal remote controls
    • Electrode cable
    • Return lead cable
    Options
    OPT/i Ethernet iWave 190i/230i
    Option for a permanent network connection
    Carrying strap option
    OPT/i Pulse Pro
    Function package for the extended pulse function (the Base current and Duty cycle parameters can be set, extended pulse frequency range)
    OPT/i Jobs
    Function package for Job mode (EasyJobs, save and edit jobs)
    OPT/i Documentation
    Option for the documentation function
    OPT/i Limit Monitoring
    Option for specifying the limit values for the welding current, welding voltage and wire speed
    OPT/i CycleTIG
    Enhanced TIG stitch welding
    OPT/i Custom NFC - ISO 14443A
    Option to use a customer-specific frequency band for key cards
    OPT/i OPC-UA
    Standardised data interface protocol
    OPT/i MQTT
    Control panel
    General
    NOTE!
    Due to software updates, you may find that your device has certain functions that are not described in these Operating Instructions or vice versa.
    Certain illustrations may also differ slightly from the actual controls on your device, but these controls function in exactly the same way.
    1. Control elements and connections
    Control panel
    General
    NOTE!
    2. Control panel
    General
    NOTE!
    2. Control panel
    WARNING!
    Fully read and understand this document.
    2. Control panel
    Control panel
    No.Function
    (1)
    Mode/welding process button
    For selecting welding processes and mode
    (2)
    Gas-test button
    To set the required shielding gas flow rate on the gas pressure regulator
    After pressing the gas-test button, shielding gas flows for 30 seconds. Press the button again to stop the gas flow prematurely.
    (3)
    Key card reader for NFC keys
    Only in certified countries
    To lock/unlock the welding machines using NFC keys
    NFC key = NFC card or NFC key ring
    (4)
    Adjusting dial with turn/press function
    • To select elements, set values and scroll through lists
    • To save jobs when the FP Job function package is present:
      if the adjusting dial is pressed for more than 3 seconds, the selected welding parameters are saved as a job.
      An overview of the most important parameters is displayed.
      For more about how to save a job, see Setup settings / the Job menu / Save job starting on page (→)
    (5)
    Menu key
    To open the Setup menu
    (6)
    Favourites button
    To save/retrieve preferred settings
    (7)
    Display
    (8)
    Hold indicator - welding current
    At the end of each welding operation, the actual values for the welding current and welding voltage are stored - HOLD lights up.
    (9)
    Status bar
    The status bar displays the following information:
    • Current welding process
    • Current operating mode
    • Selected current type
    • Active functions (e.g. high frequency ignition, tacking, pulsing, etc.)
    • Indication of electrode overload
    • Lock status of the welding machine (locked / unlocked)
    • Active Bluetooth connection
    • Time
    • Date
    The information shown in the status bar varies according to which welding process has been selected.
    (10)
    Hold indicator - welding voltage
    The Favourites button can be assigned a parameter from the following Setup menus:
    This parameter can then be called up and changed directly on the control panel.
    1Select the desired parameter in the Setup menu
    More information about the Setup menu can be found from page (→) onwards
    2To assign the selected parameter to the Favourites button, press the Favourites button for approx. 5 seconds
    A confirmation message is displayed.
    3Press the adjusting dial to confirm
    The selected parameter is now assigned to the Favourites button.
    IMPORTANT! Saving a favourite overwrites the previously saved favourite without warning.
    2. The favourites button
    1Press the Favourites button briefly
    The assigned parameter is displayed:
    The retrieved parameter can be changed by turning the adjusting dial (blue background).
    The new value takes effect immediately.
    Press and turn the adjusting dial to choose from the available welding parameters.
    Deleting favourites
    1Press the Favourites button for longer than 5 seconds
    The assigned parameter is deleted and a message is displayed.
    2Press the adjusting dial to confirm
    If the FP Job function package is present on the welding machine, EasyJobs can be assigned to the Favourites button.
    IMPORTANT! If EasyJobs are assigned to the Favourites button, any previously saved favourite parameter will no longer be accessible using that button.
    1Select the Job menu from the Setup menu
    2In the Job menu, set the “EasyJobs on Favourites button” parameter to “on”
    3Press the Menu key
    Five EasyJob buttons for the welding parameters are displayed as icons.
    4Press the Favourites button
    The 5 EasyJob buttons are displayed and can be selected by turning and pressing the adjusting dial.
    More information about using EasyJobs can be found in the “EasyJob mode” section starting on page (→).
    Front
    Rear
    No.Function
    (1)
    (-) current socket with integrated gas connection
    To connect:
    • the TIG welding torch
    • the electrode cable for manual metal arc welding
    Symbols on iWave DC welding machines:
    Symbols on iWave AC/DC welding machines:
    (2)
    TMC connection (TIG Multi Connector)
    • to connect the TIG welding torch control plug
    • to connect pedal remote controls
    • to connect the remote control during MMA welding
    (3)
    USB port
    For connecting USB flash drives (such as service dongles and licence keys).
    IMPORTANT! The USB port is not electrically isolated from the welding circuit.
    This means that devices that establish an electrical connection with another device must not be connected to the USB port.
    (4)
    (+) current socket
    For connecting the grounding cable
    (5)
    Mains switch
    For switching the welding machine on and off
    Mains switch for MV devices:
    (6)
    Mains cable with strain relief
    On MV devices:
    Mains cable connection
    (7)
    Shielding gas connection
    (8)
    Blanking cover
    for Ethernet option
    2. Connections, switches and mechanical components
    Front
    Rear
    No.Function
    (1)
    To connect:
    (2)
    (3)
    USB port
    (4)
    (+) current socket
    (5)
    Mains switch
    (6)
    On MV devices:
    (7)
    (8)
    Blanking cover
    for Ethernet option
    General
    Depending on the welding process, a certain minimum equipment level is required in order to work with the welding machine.
    The welding processes and the corresponding minimum equipment for the welding operation are described in the following.
    1. Before installation and commissioning
    General
    2. Minimum equipment needed for welding task
    General
    TIG AC welding
    • iWave AC/DC welding machine
    • Return lead cable
    • TIG welding torch with rocker switch
    • Gas connection (shielding gas supply), with pressure regulator
    • Filler metals (as required by the application)
    • Welding machine
    • Return lead cable
    • TIG welding torches
    • Shielding gas supply with pressure regulator
    • Welding machine
    • Return lead cable
    • Electrode holder
    • Rod electrodes (as required by the application)
    WARNING!
    2. Before installation and commissioning
    WARNING!
    The welding system is generator-compatible.
    In order to dimension the required generator output, the maximum apparent power S1max of the welding system is required.
    The maximum apparent power S1max of the welding system can be calculated as follows:
    S1max = I1max x U1
    See device rating plate or technical data for I1max and U1 values
    The generator apparent power SGEN needed is calculated using the following rule of thumb:
    SGEN = S1max x 1.35
    A smaller generator may be used when not welding at full power.
    IMPORTANT! The generator apparent power SGEN must always be higher than the maximum apparent power S1max of the welding system.
    When using single-phase devices with a 3-phase generator, note that the specified generator apparent power is often only available as a whole across all three phases of the generator. If necessary, obtain further information on the single-phase power of the generator from the generator manufacturer.
    NOTE!
    The voltage delivered by the generator must never exceed the upper or lower limits of the mains voltage tolerance range.
    Details of the mains voltage tolerance can be found in the ‘Technical data’ section.
    Mains connection
    • The devices are designed for the mains voltage specified on the rating plate.
    • If your version of the appliance does not come with mains cables and mains plugs ready-fitted, these must be fitted by a qualified person in accordance with national standards.
    • The fuse protection for the mains lead is indicated in the technical data.
    WARNING!
    Risk of electric shock due to inadequate mains connection.
    This can result in serious injury and death.
    Only connect the device to a grid with a ground conductor.
    Only connect the device to the grid via a connector system with a ground conductor contact.
    If operating the device on a grid without ground conductor and on a socket without ground conductor contact, observe all national regulations for protective separation.
    CAUTION!
    Danger due to insufficiently dimensioned electrical installations.
    Dimension the mains lead and its fuse to suit the local power supply.
    The technical data shown on the rating plate applies.
    NOTE!
    Before connecting the device to the mains, check with the grid operator whether the device may be connected.
    The maximum permissible mains impedance that is decisive for a mains connection is stated in the technical data.
    IMPORTANT! Ensure that the mains connection is earthed properly!
    Due to local regulations and national guidelines, a residual current circuit breaker may be required when connecting a device to the public grid. The type of residual current circuit breaker recommended for the device is specified in the technical data.
    General
    If welding machines are delivered without a mains cable fitted, a mains cable that is suitable for the connection voltage must be connected to the welding machine before commissioning.
    The mains cable is included in the scope of supply of the welding machine.
    2. Connecting the mains cable
    General
    Safety
    WARNING!
    1Connect the mains cable:
    • Plug in the mains cable
    • Turn the mains cable 45° to the right until you hear it latch into place
    WARNING!
    Danger from electric current.
    This can result in serious personal injury.
    Do not lift or transport operational devices.
    Switch off devices before transport or lifting and disconnect from the mains.
    Disconnect ground earth connections before transport.
    WARNING!
    Danger due to device toppling over.
    Use only transport equipment supplied by the manufacturer when transporting devices by crane.
    Hook chains or ropes onto the suspension points provided on the transport equipment.
    Chains or ropes must be at the smallest angle possible to the vertical.
    Observe and comply with applicable national and regional guidelines for the prevention of accidents and risks during transport.
    CAUTION!
    Danger due to damaged devices.
    This can result in personal injury and damage to property.
    After transport and before commissioning, visually inspect the device for damage.
    Any damage must be repaired by trained service technicians before commissioning the device.
    NOTE!
    The carrying handle on the device is only to be used for transport by hand.
    The carrying handle is not suitable for transporting with a crane, counterbalanced lift truck or other mechanical hoist.
    2. Transport and setup regulations
    WARNING!
    WARNING!
    CAUTION!
    NOTE!
    WARNING!
    Danger from machines and components falling as a result of damaged lifting tackle.
    Regularly check all lifting tackle used for crane transport, such as straps, buckles, chains, etc., for mechanical damage, corrosion and changes caused by other environmental factors.
    The inspection interval and scope of the inspection must comply with the relevant valid national standards and guidelines.
    Setup regulations
    WARNING!
    Danger due to devices or welding systems toppling over.
    Set up the device securely on an even, solid surface.
    The maximum permissible tilt angle is 10°.
    Check all screw connections are tightly fastened after installation.
    WARNING!
    Danger from areas at risk of fire and explosion as well as from areas with increased electrical risk.
    Observe national and international regulations for areas at risk of fire and explosion.
    Observe national and international regulations for areas with increased electrical risk.
    CAUTION!
    Danger due to inappropriate selection of the installation location.
    Only set up and operate the device in accordance with the protection class shown on the rating plate.
    The ambient air must be free from dust, acids, corrosive gases or substances and similar.
    Do not install and operate the device over 2000 m (6561 ft.) 8.16 in.) above sea level.
    The device is tested to IP23 protection, meaning:
    • Protection against penetration by solid foreign bodies with diameters > 12.5 mm (0.49 in.)
    • Protection against spraywater at any angle up to 60° to the vertical
    The device can be set up and operated outdoors in accordance with protection class IP23.
    Avoid direct wetting (e.g. from rain).
    The venting duct is a very important safety device. When choosing the installation location, ensure that the cooling air can enter and exit unhindered through the air ducts on the front and back of the machine. Electroconductive metallic dust must not be allowed to get sucked directly into the device (e.g. from grinding work).
    WARNING!
    Danger from incorrect operation or misuse.
    This can result in serious personal injuries – including to third parties, damage to property and impaired welding results.
    All persons involved in commissioning, operating, maintaining and servicing the device must be appropriately qualified and have knowledge of welding.
    Read and follow these operating instructions carefully.
    The operating instructions must always be at hand wherever the device is being used.
    Observe generally applicable and regional rules on accident prevention and environmental protection.
    1. Dangers during welding
    WARNING!
    2. Danger from incorrect operation or misuse
    WARNING!
    WARNING!
    Danger from electric shocks.
    These can result in serious injury and death.
    Do not touch live parts either inside or outside the device.
    Use an adequately insulated, dry base or cover for the earth or ground potential.
    This base or cover must extend over the entire area between the body and the earth or ground potential.
    Only use undamaged, insulated and adequately dimensioned cables and leads.
    Do not wrap cables or leads around the body or parts of the body.
    Never touch the tungsten electrode or rod electrode when the welding machine is switched on.
    Earth the workpiece.
    Switch off unused devices.
    Before working on the device, switch off the device, pull out the mains plug and attach a clearly legible and easy-to-understand warning sign to prevent anyone from plugging the mains plug back in and switching it on again.
    After opening the device, ensure that all components in the device are de-energised – especially components that store electrical charges.
    WARNING!
    Danger from electromagnetic fields.
    Damage to health and effects on the health of persons in the vicinity, e.g. those with pacemakers and hearing aids, may result.
    Maintain as large a distance as possible between the welding power-leads and the head/torso of the welder.
    Do not carry welding power-leads and hosepacks over the shoulders or wind them around any part of the body.
    Individuals with pacemakers must seek advice from their doctor before approaching the device or any welding that is in progress.
    CAUTION!
    Danger from stray welding currents.
    This can result in overheating of components, fire, destruction of ground conductors and damage to the device and other electrical equipment.
    Position the device with sufficient insulation against electrically conductive environments, such as insulation against conductive floor or insulation to conductive racks.
    If power distribution boards, twin-head mounts, etc. are being used, ensure that the unused welding torch/electrode holder is adequately insulated.
    2. Danger from mains current and welding current
    WARNING!
    WARNING!
    CAUTION!
    Electromagnetic compatibility (EMC) describes the unwanted reciprocal influence of electrical/electronic devices.
    The EMC device classification is stated on the rating plate of the device or in the technical data.
    Despite compliance with the standardised emission limit values, electrical devices can influence each other in special cases in the intended area of application.
    Equipment that may be susceptible to interference from the device includes:
    • Safety devices
    • Mains leads, signal and data transfer lines
    • IT and telecommunications devices
    • Measuring and calibrating devices
    • Medical devices
    • etc.
    CAUTION!
    Danger from electromagnetic emissions.
    These can result in operating faults and malfunctions as well as resulting damage.
    Use suitable line filters.
    Keep welding power-leads as short as possible, allow the power-leads to run close together and lay the power-leads far away from other cables.
    Carry out equipotential bonding.
    Earth the workpiece, e.g. using suitable capacitors.
    Shield the entire welding system.
    Shield other devices nearby.
    WARNING!
    Danger from flying sparks.
    These can result in fires and explosions.
    Never weld close to flammable materials.
    Keep flammable materials at least 11 metres (36 ft. 1.07 in.) away from the arc, or cover with an approved cover.
    Take appropriate measures to ensure that sparks and hot metal parts do not pass through small cracks and openings into surrounding areas.
    Only weld in areas with a fire or explosion risk or on sealed tanks, vessels or pipes if these have been prepared in accordance with the relevant national and international standards.
    Do not weld on containers in which gases, fuels, mineral oils and the like are or were stored.
    Flammable vapours should be kept away from the arc's radiation area (e.g. solvent vapours).
    WARNING!
    Danger due to flying sparks and hot pieces of metal.
    This can result in injuries.
    Suitable protective clothing must be worn when working with the device.
    The protective clothing must be flame-retardant, insulating and dry, cover the whole body and be undamaged. Trousers must not have turn-ups.
    Wear stout footwear that provides insulation even in wet conditions.
    Wear suitable, electrically insulated and heat protective gloves.
    Wear a safety helmet.
    2. Danger from flying sparks, arc radiation and noise
    WARNING!
    WARNING!
    WARNING!
    Danger from arc radiation, UV rays, heat and flying sparks, which can damage the eyes and skin
    Use a protective visor with a regulation filter element.
    Wear regulation protective goggles with side protection behind the protective visor.
    Danger due to noise
    CAUTION!
    Danger due to increased noise exposure.
    This can result in hearing damage.
    Use ear protection during welding.
    The device generates a maximum sound power level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation at the maximum permissible operating point under maximum rated load conditions according to EN 60974-1.
    It is not possible to provide a workplace-related emission value during welding (or cutting) as this is influenced by both the process and the environment. All manner of different welding parameters come into play, including the welding process (MIG/MAG, TIG welding), the type of power selected (DC or AC), the power range, the type of weld metal, the resonance characteristics of the workpiece, the workplace environment, etc.
    WARNING!
    Danger from welding operation (dazzling, flying sparks, harmful welding fume, noise, etc.)
    This can result in personal injury.
    Keep all persons not involved out of the working area while any devices are in operation or welding is in progress.
    Inform people in the vicinity about all hazards of welding operation.
    Provide suitable protective equipment.
    Erect suitable safety screens/curtains.
    WARNING!
    Danger from gases and vapours that are harmful to health.
    Fume produced during welding contains substances that cause cancer, as stated in Monograph 118 of the International Agency for Research on Cancer.
    Keep your face away from welding fume and gases.
    Do not breathe in fume or harmful gases.
    Ensure an adequate supply of fresh air.
    Ensure that there is a ventilation rate of at least 20 m³/h (11.77 cfm) at all times.
    2. Danger from toxic gases and vapours
    WARNING!
    WARNING!
    Danger due to missing, defective or circumvented safety devices.
    Only operate the device when all safety devices are fully functional.
    Any safety devices that are not fully functional must be repaired by a qualified specialist before the device is switched on.
    2. Danger due to missing safety devices and moving components
    WARNING!
    CAUTION!
    Danger due to missing or opened covers.
    Ensure that all covers and side panels are in place and fitted properly before operation.
    During operation ensure all covers and side panels are closed.
    Open covers and side panels only while carrying out assembly and maintenance activities.
    WARNING!
    Danger due to pressurised shielding gas cylinders.
    This can result in serious personal injury and damage to property as a result of explosions.
    Protect pressurised shielding gas cylinders from excessive heat, mechanical impact, slag, naked flames, sparks and arcs.
    Do not weld on pressurised shielding gas cylinders.
    Keep the shielding gas cylinders well away from any welding or other circuits.
    Do not hang the welding torch on a shielding gas cylinder.
    If the shielding gas cylinder is not connected, leave the protective cap in place on the valve on the cylinder.
    Mount shielding gas cylinders vertically and secure them to prevent them from falling over according to the instructions.
    The manufacturer's instructions must be observed and followed as well as national and international regulations for shielding gas cylinders and accessories.
    Before transporting a welding system with a trolley by crane, remove the shielding gas cylinder.
    Observe safety and maintenance instructions on the shielding gas cylinder or a central gas supply.
    WARNING!
    Danger from shielding gas escaping unnoticed.
    Shielding gas is colourless and odourless and, in the event of a leak, can displace the oxygen in the ambient air.
    This can result in serious injury and death from suffocating.
    There must be a ventilation rate of at least 20 m³ / hour at all times.
    Close the valve of the shielding gas cylinder or a central gas supply if no welding is taking place.
    Turn your face away from the outlet when opening a valve of a shielding gas cylinder.
    Check the shielding gas cylinder or the central gas supply for uncontrolled gas leakage before every start-up.
    When using an adapter, prior to assembly seal the device-side thread of the shielding gas connection using suitable Teflon tape.
    CAUTION!
    Danger from contaminated shielding gas.
    This can result in damage to property and flawed welding results.
    The quality of the shielding gas must meet the following requirements:
    Solid particle size < 40 μm
    Pressure dew point < -20 °C
    Max. oil content < 25 mg/m³
    2. Danger from shielding gas cylinders and shielding gas supply
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    Danger from hot components, parts and liquids.
    These can result in burns and injuries.
    Never touch the workpiece during or after welding.
    Allow hot components, hot parts and hot liquids to cool before touching (e.g. welding torch).
    Switch off an existing cooling unit before disconnecting coolant hoses.
    CAUTION!
    Danger from slag jumping off cooling workpieces.
    This can result in burns and injuries.
    The protective equipment must also be worn when reworking workpieces, and steps must be taken to ensure that other people are also adequately protected.
    2. Danger from hot parts and slag
    CAUTION!
    CAUTION!
    Start-up
    Start-up
    Safety
    WARNING!
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    WARNING!
    Danger from electrical current due to electrically conductive dust in the device.
    Only operate the device with an air filter fitted. The air filter is a very important safety device for achieving IP23 protection.
    1. Start-up
    Start-up
    Safety
    WARNING!
    WARNING!
    1. Start-up
    2. Start-up
    Safety
    WARNING!
    WARNING!
    1. Start-up
    2. Start-up
    The iWave 230i DC and iWave 230i AC/DC welding machines can be operated with a cooling unit.
    A cooling unit is recommended for the following applications:
    • Hosepacks over 5 m long
    • TIG AC welding
    • In general, where welding is performed in higher power ranges
    The welding machine acts as the power supply for the cooling unit. The cooling unit is ready for operation when the mains switch of the welding machine is in the “I” position.
    More information on the cooling unit can be found in the Operating Instructions for the cooling unit.
    1. Start-up
    2. Start-up
    General
    This section describes how to commission the welding machine:
    • for the main TIG welding application
    • with reference to a standard configuration for a TIG welding system
    The standard configuration consists of the following system components:
    • Welding machine
    • TIG manual welding torch
    • Pressure regulator
    • Gas cylinder
    1. Start-up
    2. Start-up
    For more detailed information about installing and connecting the system components, please refer to the appropriate Operating Instructions.
    1. Start-up
    2. Start-up
    WARNING!
    There is a high risk of very serious injury and damage if a gas cylinder falls over.
    Place gas cylinders on a solid, level surface in such a way that they remain stable.
    Secure gas cylinders to prevent them from toppling over: Fix the safety strap at the same height as the top part of the cylinder.
    Never fix the safety strap around the neck of the cylinder.
    Observe the safety rules of the gas cylinder manufacturer.
    When using a TIG welding torch with an integral gas connection:
    3Use the gas hose to connect the pressure regulator to the shielding gas connection on the rear of the welding machine
    4Tighten the union nut on the gas hose
    When using a TIG welding torch with no integral gas connection:
    3Connect the TIG welding torch gas hose to the pressure regulator
    NOTE!
    When using a MultiControl (MC) cooling unit, please see the Operating Instructions of the cooling unit for a description of the gas connection.
    1. Start-up
    2. Start-up
    NOTE!
    Do not use pure tungsten electrodes (colour-coded green) on iWave DC welding machines.
    1Set up the welding torch in accordance with the welding torch Operating Instructions
    During welding, check the coolant flow at regular intervals.
    NOTE!
    Before each start-up:
    Check the sealing ring on the welding torch connection.
    Check coolant level.
    1. Start-up
    2. Start-up
    1Turn the mains switch to the "O" position
    1. Start-up
    General
    The welding machine can be locked using an NFC key, e.g. to prevent unauthorised access or welding parameters being changed without permission.
    A contactless system on the control panel allows the welding machine to be locked and unlocked.
    The welding machine must be switched on before it can be locked or unlocked.
    1. Start-up
    2. Locking and unlocking the welding machine using the NFC key
    General
    1. Start-up
    Limitations
    Locking and unlocking of the welding machine is only permitted in certified countries.
    1. Start-up
    Locking the welding machine
    1Hold the NFC key on the NFC key reader
    The key icon in the status bar lights up.
    The welding machine is now locked.
    Only the welding parameters can be viewed and adjusted using the adjusting dial.
    Any attempt to access a locked function will result in a notification being displayed.
    Unlocking the welding machine
    The key icon in the status bar is no longer lit.
    All functions of the welding machine are available again without restriction.
    NOTE!
    More information about locking and unlocking the welding machine can be found in the “Defaults - Management / Administration” chapter from page (→).
    Welding
    TIG modes
    Safety
    WARNING!
    Danger from incorrect operation.
    Possible serious injury and damage to property.
    Do not use the functions described here until you have read and completely understood these operating instructions.
    Do not use the functions described here until you have fully read and understood all of the operating instructions for the system components, in particular the safety rules!
    See the "The Setup menu" section for information on the settings, setting range and units of measurement of the available welding parameters.
    1. Welding
    TIG modes
    Safety
    WARNING!
    1. Welding
    2. TIG modes
    Safety
    WARNING!
    1. Welding
    2. TIG modes
    (1) Pull back and hold the torch trigger (2) Release the torch trigger (3) Pull back the torch trigger briefly (< 0.5 s)
    (4) Push forward and hold the torch trigger (5) Release the torch trigger
    GPr
    Gas pre-flow
    SPt
    Spot welding time
    IS
    Starting current:
    Carefully warm up with low welding current to position the filler metal correctly
    IE
    Final current:
    To avoid local overheating of the base material by heat accumulation at the end of the welding. This eliminates any risk of weld seam drop-through.
    tUP
    UpSlope:
    The starting current is steadily increased until it reaches the main current (welding current) I1
    tDOWN
    DownSlope:
    Continuous reduction of the welding current until it reaches the final current
    I1
    Main current (welding current):
    Uniform thermal input into the base material heated by advancing heat
    I2
    Reduced current:
    Intermediate lowering of the welding current in order to prevent any local overheating of the base material
    GPO
    Gas post-flow
    1. Welding
    2. TIG modes
    2-step mode
    • Welding: Pull back the torch trigger and hold it in this position
    • End of welding: Release the torch trigger
    2-step mode
    1. Welding
    2. TIG modes
    4-step mode
    • Start of welding with starting current IS: Pull back the torch trigger and hold it in this position
    • Welding with main current I1: Release the torch trigger
    • Lowering to final current IE: Pull back the torch trigger and hold it in this position
    4-step mode
    *) Intermediate lowering
    With intermediate lowering, the welding current is lowered to the set lowering current I2  during the main current phase.
    • To activate intermediate lowering, push the torch trigger forward and hold it in this position
    • Release the torch trigger to resume the main current
    1. Welding
    2. TIG modes
    Variant 1
    Briefly pull back the torch trigger to start intermediate lowering to the specified reduced current I2. Briefly pull back the torch trigger a second time, to restore the main current I1.
    Special 4-step mode: Variant 1
    Variant 1 of the special 4-step mode is activated with the following parameter setting:
    • Starting current time = off
    • Final current time = off
    • Reduced current slope 1 = off
    • Reduced current slope 2 = off
    • I2 via torch trigger = on
    • Reduced current button function = I2
    1. Welding
    2. TIG modes
    Variant 2
    Intermediate lowering takes place in variant 2 on the basis of the selected reduced current slope 1/2 values:
    • Push forward and hold the torch trigger: the welding current continuously drops at the set reduced current slope 1 value until it reaches the specified reduced current I2. It remains at the reduced current value I2 until the torch trigger is released.
    • When the torch trigger is released: the welding current rises at the specified reduced current slope 2 value until it reaches the main current value I1.
    Special 4-step mode: Variant 2
    Variant 2 of the special 4-step mode is activated with the following parameter setting:
    • Reduced current slope 1 = on
    • Reduced current slope 2 = on
    • I2 via torch trigger = off
    1. Welding
    2. TIG modes
    Variant 3
    In variant 3, push forward and hold the torch trigger to start intermediate lowering of the welding current. Release the torch trigger to resume the main current I1.
    When the torch trigger is pulled back, welding ends immediately without DownSlope and final current.
    Special 4-step mode: Variant 3
    Variant 3 of the special 4-step mode is activated with the following parameter setting:
    • Final current time = 0.01 s
    1. Welding
    2. TIG modes
    Variant 4
    • Welding start-up and welding: briefly pull back and release the torch trigger - the welding current will rise at the specified UpSlope value from the starting current IS until it reaches the main current value I1.
    • Push forward and hold the torch trigger for intermediate lowering
    • Release the torch trigger to resume the main current I1
    • End of welding: briefly pull back and release the torch trigger
    Special 4-step mode: Variant 4
    Variant 4 of the special 4-step mode is activated with the following parameter setting:
    • Starting current time = on
    • Final current time = on
    1. Welding
    2. TIG modes
    Variant 5
    Variant 5 allows the welding current to be increased and reduced without an Up/Down torch.
    • The longer the torch trigger is held in the forward position during welding, the more the welding current increases (up to the maximum).
    • The welding current remains constant when the torch trigger is released.
    • The longer the torch trigger is pushed forward again, the more the welding current decreases.
    Special 4-step mode: Variant 5
    Variant 5 of the special 4-step mode is activated with the following parameter setting:
    • I2 via torch trigger = off or on
    • Reduced current button function = I1
    1. Welding
    2. TIG modes
    Variant 6
    • Welding start-up with starting current IS and UpSlope: Pull back and hold the torch trigger
    • Intermediate lowering to I2 and changing from I2 back to the main current I1: briefly press (< 0.5 s) and release the torch trigger
    • End the welding process: press the torch trigger for longer (> 0.5 s) and release.
    The process is automatically ended after the DownSlope phase and the final current phase.
    If the torch trigger is pressed briefly (< 0.5 s) and released during either the DownSlope phase or the final current phase, then an UpSlope will take effect until it reaches the main current and the welding process will continue.
    Special 4-step mode: Variant 6
    Variant 6 of the special 4-step mode is activated with the following parameter setting:
    1. Welding
    2. TIG modes
    Spot welding
    When the spot welding operating mode is selected, the symbol for spot welding appears on the status indicator next to the welding process symbol:
    • Welding: briefly pull back the torch trigger
      The welding time corresponds to the value set for the spot welding time setup parameter.
    • To end the welding process prematurely: pull the torch trigger back again
    1. Welding
    2. TIG modes
    CycleTIG
    CycleTIG
    Enhanced stitch welding process for DC welding
    CycleTig activated
    When the CycleTIG function is activated, the following parameters are available:
    (1)
    Interval time
    (2)
    Interval break time
    (3)
    Interval cycles
    (4)
    Base current
    NOTE!
    For more details on CycleTIG, see from page (→).
    Description of the CycleTIG parameters from page (→).
    1. Welding
    TIG welding
    WARNING!
    WARNING!
    1. Welding
    2. TIG welding
    WARNING!
    WARNING!
    1. Welding
    2. TIG welding
    Preparation
    1Plug in the mains plug
    CAUTION!
    Risk of injury and damage to property from electric shock.
    As soon as the mains switch is in the "I" position, the tungsten electrode of the welding torch is live.
    Ensure that the tungsten electrode does not touch any persons or electrically conductive or earthed parts (e.g. housing, etc.).
    2Move the mains switch to the "I" position
    The Fronius logo appears on the display.
    1. Welding
    2. TIG welding
    TIG welding
    1Press the welding process / operating mode key
    The welding processes and operating modes are displayed.
    2Select the desired welding process by turning the adjusting dial
    3Confirm the selection by pressing the adjusting dial
    4Select the desired operating mode by turning the adjusting dial
    5Confirm the selection by pressing the adjusting dial
    After a short period of time or after pressing the welding process / operating mode key, the available TIG welding parameters are displayed.
    6Turn the adjusting dial to select the required parameter
    7Press the adjusting dial
    The value of the welding parameter is highlighted in blue and can now be changed.
    8Turn the adjusting dial: change the value of the parameter
    9Press the adjusting dial
    10If required, set further parameters in the Setup menu
    (For details, see the “Setup settings” chapter, starting on page (→))
    11Open the gas cylinder valve
    12Press the Gas-test button
    The test gas flow lasts for a maximum of 30 seconds. Press the button again to stop the gas flow prematurely.
    13Turn the adjusting screw on the underside of the pressure regulator until the manometer indicates the desired shielding gas flow rate
    NOTE!
    All welding parameter set values that have been set using the adjusting dial remain stored until the next time they are changed.
    This applies even if the welding machine was switched off and on again in the interim.
    14Start welding (ignite the arc)
    1. Welding
    2. TIG welding
    The polarity welding parameter is only available on iWave AC/DC welding machines.
    If the polarity welding parameter is set to DC-, the following welding parameters are available:
    xxA = actual current value depending on the specified main current
    Starting current
    Starting current, 2-step mode and spot welding
    Starting current, 4-step mode
    Setting range: 0 - 200% (of main current)
    Factory setting: 50%
    IMPORTANT! The starting current is saved separately for TIG AC welding and TIG DC- welding.
    UpSlope
    UpSlope, 2-step mode and spot welding
    UpSlope, 4-step mode
    Setting range: off; 0.1 - 30.0 s
    Factory setting: 0.5 s
    IMPORTANT! The saved UpSlope value applies to both the 2-step and 4-step modes.
    Main current (I1)
    Main current, 2-step mode and spot welding
    Main current, 4-step mode
    Setting range: 3 - 190 A ... iWave 190i, 3 - 230 A ... iWave 230i
    Factory setting: -
    IMPORTANT! On welding torches with the Up/Down Function, the entire setting range can be selected while the device is idling.
    Reduced current (I2)
    only in 4-step mode
    Reduced current I2 < Main current I1
    Reduced current I2 > Main current I1
    Setting range: 0 - 200% (of main current I1)
    I2 < 100%
    short-term, adapted reduction of the welding current
    (e.g. when changing the welding wire during the welding process)
    I2 > 100%
    short-term, adjusted increase in welding current
    (e.g. to weld over tacked spots at higher power)
    The values for Slope1 and Slope2 can be set using the TIG menu.
    DownSlope
    DownSlope, 2-step mode and spot welding
    DownSlope, 4-step mode
    Factory setting: 1.0 s
    IMPORTANT! The saved DownSlope value applies to both the 2-step and 4-step modes.
    Final current
    Final current, 2-step mode and spot welding
    Final current, 4-step mode
    Setting range: 0 - 100% (of main current)
    Factory setting: 30%
    Electrode diameter
    Setting range: off; 1.0 - 4.0 mm
    Factory setting: 2.4 mm
    Polarity
    Setting range: DC-/AC
    Factory setting: DC-
    1. Welding
    2. TIG welding
     If the CycleTIG function is activated, the CycleTIG welding parameters are displayed after the main current for the TIG DC welding parameters:
    Interval cycles
    for setting how many cycles are to be repeated
    Setting range: Permanent / 1 - 2000
    Factory setting: Permanent
    Interval time
    for setting the length of time the welding current I1 is active
    Setting range: 0.02 - 2.00 s
    Interval break time
    for setting the length of time the base current is active
    Base current
    for setting the interval base current to which the current is reduced during the interval break time
    Setting range: off / 3 - max. A
    Factory setting: off
    1. Welding
    2. TIG welding
    If the polarity welding parameter is set to AC-, the following welding parameters are available:
    Starting current
    UpSlope
    Main current (I1)
    Factory setting: -
    only in 4-step mode
    I2 < 100%
    I2 > 100%
    DownSlope
    Final current
    Balance
    only on iWave AC/DC
    Balance = 15%
    Balance = 35%
    Balance = 50%
    Setting range: 15 - 50%
    Factory setting: 35%
    15: highest fusing power, lowest cleaning action
    50: highest cleaning action, lowest fusing power
    Effect of the balance on the waveshape:
    Electrode diameter
    Cap mode
    only iWave AC/DC
    Setting range: off / on
    off
    Automatic cap-shaping function is deactivated
    on
    For the entered diameter of the tungsten electrode, the optimum cap is formed during the welding start.
    A separate cap-shaping action on a test workpiece is not required.
    After this, the automatic cap-shaping function is reset and deactivated again.
    (1) ... before ignition
    (2) ... after ignition
    Cap mode must be activated separately for each tungsten electrode.
    NOTE!
    The automatic cap-shaping function is not necessary if a sufficiently large cap has already formed at the tip of the tungsten electrode.
    Polarity
    1. Welding
    Igniting the arc
    General
    To ensure the best ignition sequence in the TIG AC welding process, the iWave AC/DC welding machines take account of:
    • the diameter of the tungsten electrode
    • the current temperature of the tungsten electrode with reference to the preceding welding and weld-off times
    1. Welding
    2. Igniting the arc
    General
    1. Welding
    2. Igniting the arc
    (HF ignition)
    CAUTION!
    Risk of injury due to shock caused by electric shock
    Although Fronius devices comply with all relevant standards, high-frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
    Use prescribed protective clothing, especially gloves!
    Only use suitable, completely intact and undamaged TIG hosepacks!
    Do not work in damp or wet environments!
    Take special care when working on scaffolding, work platforms, in forced positions (out-of-position welding), in tight, difficult to access or exposed areas!
    HF ignition is activated when a time value has been set for the ignition timeout setup parameter in the HF menu.
    The HF ignition indicator lights up in the status bar on the control panel.
    Unlike touchdown ignition, HF ignition eliminates the risk of contamination of the tungsten electrode and the workpiece.
    Procedure for HF ignition:
    1Place the gas nozzle down on the ignition location, ensuring there is a gap of approx. 2 to 3 mm (5/64 to 1/8 in.) between the tungsten electrode and the workpiece Gap exists.
    2Increase the slope of the welding torch and actuate the torch trigger according to the mode you have selected
    The arc ignites without the electrode touching down on the workpiece.
    3Tilt the torch back into the normal position
    4Carry out welding
    1. Welding
    2. Igniting the arc
    Touchdown ignition
    If the ignition timeout setup parameter is set to off, HF ignition is deactivated. The welding arc is ignited by touching the workpiece with the tungsten electrode.
    Procedure for igniting the arc using touchdown ignition:
    2Actuate the torch trigger
    shielding gas flows
    3Gradually tilt the welding torch up until the tungsten electrode touches the workpiece
    4Raise the welding torch and rotate it into its normal position
    The arc ignites.
    5Carry out welding
    1. Welding
    2. Igniting the arc
    Electrode overload
    If the tungsten electrode is overloaded, material can detach from the electrode that then contaminates the weld pool.
    If the tungsten electrode is overloaded, the "Electrode overload" indicator in the status bar of the control panel lights up.
    The "Electrode overload" indicator depends on the electrode diameter and welding current that have been set.
    1. Welding
    2. Igniting the arc
    End of welding
    1Depending on the set mode, finish welding by releasing the torch trigger
    2Wait for the set gas post-flow and hold welding torch in position over the end of the weld seam
    1. Welding
    The welding machine has an ignition timeout function.
    Once the torch trigger is pressed, gas pre-flow begins immediately. Ignition then begins. If an arc does not appear within the time specified in the Setup menu, the welding machine cuts out automatically.
    The settings for the parameter Ignition timeout are described in the “The HF menu” section from page (→) onwards.
    1. Welding
    2. TIG special functions
    1. Welding
    TIG pulsing
    The welding current set at the start of welding is not always ideal for the welding process as a whole:
    • if the amperage is too low, the base material will not melt sufficiently
    • if overheating occurs, the liquid weld pool may drip
    The TIG pulsing function (TIG welding with pulsing welding current) offers a remedy:
    a low base current (2) rises steeply to the significantly higher pulse current and, depending on the set duty cycle (5), drops back to the base current (2).
    In TIG pulsing, small sections of the welding location melt quickly and then solidify again quickly.
    In manual applications using TIG pulsing, the welding wire is applied in the maximum current phase (only possible in the low frequency range: 0.25 - 5 Hz). Higher pulse frequencies are mainly used in automatic mode to stabilise the arc.
    TIG pulsing is used for out-of-position welding of steel pipes or when welding thin sheets.
    Mode of operation of TIG pulsing when TIG DC welding is selected:
    TIG pulsing - welding current curve
    Legend:
    (1) Main current, (2) Base current, (3) Starting current, (4) UpSlope, (5) Pulse frequency *)
    (6) Duty cycle, (7) DownSlope, (8) Final current
    *) (1/F-P = time interval between two pulses)
    1. Welding
    Tacking function
    The tacking function is available for the TIG DC welding process.
    When a time period is specified for the tacking setup parameter (4), the tacking function is assigned to 2-step mode and 4-step mode. The operating sequence of the modes remains unchanged.
    The tacking (TAC) indicator lights up in the status bar on the display:
    During this period, there is a pulsed welding current that makes the weld pool run together better when two components are being tacked.
    Mode of operation of tacking function for TIG DC welding:
    Tacking function - welding current curve
    Legend:
    (1) Main current, (2) Starting current, (3) UpSlope, (4) Duration of pulsed welding current for tacking, (5) DownSlope, (6) Final current
    NOTE!
    The following points apply to the pulsed welding current:
    The welding machine automatically regulates the pulsing parameters depending on the set main current (1).
    There is no need to set any pulsing parameters.
    The pulsed welding current begins
    • after the end of the starting-current phase (2)
    • with the UpSlope phase (3)
    Depending on what tacking period has been set, the pulsed welding current may continue up to and including the final current phase (6) (tacking setup parameter (4) set to “on”).
    After the tacking time has elapsed, welding continues at a constant welding current, and any pulsing parameters that may have been set continue to be available.
    1. Welding
    CycleTIG
    The CycleTIG stitch welding process is available for the TIG DC welding process.
    The welding result is influenced and controlled by different parameter combinations.
    The main advantages of CycleTIG are easy control of the weld pool, targeted heat input and fewer temper colours.
    CycleTIG variations
    CycleTIG + low base current
    • For out-of-position welding, edge applications and orbital welding
    • Well suited to joins on heavy/light-gauge sheets
    • Excellent weld characteristics
    • HF ignition only at welding start
    • Long electrode service life
    • Good control of the weld pool
    • Targeted heat input
    CycleTIG + reversed polarity ignition = on + base current = off
    • For repair work (e.g. edge applications)
    • Biggest advantage in combination with the HF ignition ignition setting = Touch HF
    • HF ignition at every cycle (!)
    • Very short electrode service life (!)
    Recommendation: iWave AC/DC with the reversed polarity ignition ignition setting = auto
    CycleTIG + tacking
    • For tacking light-gauge sheets, orbital applications and for joins on heavy and light-gauge sheets
    • Excellent seam appearance
    • Tacking function generates automatic pulse setting
    CycleTIG + pulse
    CycleTIG can be used individually with all pulse settings. This allows pulsing in both the high power and low power phases.
    • For tacking light-gauge sheets and for cladding applications
    • For joins on heavy/light-gauge sheets
    • Individual pulse settings possible
    • More parameters to set
    1. Welding
    Manual metal arc welding, CEL welding
    Danger from incorrect operation and electric current
    WARNING!
    WARNING!
    1. Welding
    2. Manual metal arc welding, CEL welding
    WARNING!
    WARNING!
    1. Welding
    Preparation
    1Move the mains switch to the "O" position
    2Disconnect the mains plug
    3Remove the TIG welding torch
    IMPORTANT! Observe the instructions on the packaging of the rod electrode when selecting the appropriate type of current and for correctly connecting the electrode cable and grounding cable.
    4Plug in and latch the grounding cable:
    in the (+) current socket ... for DC- welding (=/-)
    in the (-) current socket ... for DC+ welding (=/+)
    5Use the other end of the grounding cable to establish a connection to the workpiece
    6Plug in the electrode cable and turn it clockwise to latch it in place:
    in the (-) current socket ... for DC- welding (=/-)
    in the (+) current socket ... for DC+ welding (=/+)
    7Plug in the mains plug
    CAUTION!
    As soon as the mains switch is in the "I" position, the rod electrode in the electrode holder is live.
    Make sure the rod electrode does not touch any persons or electrically conductive or earthed parts (e.g. the housing, etc.).
    8Move the mains switch to the "I" positionThe Fronius logo appears on the display.
    1. Welding
    1Press the Mode button
    2Select the electrode (Stick / MMA) or CEL welding process (turn and press the adjusting dial)
    If the MMA welding process is selected, any cooling unit present is automatically deactivated. It is not possible to switch it on.
    3Turn the adjusting dial to select the Polarity parameter:
    DC- / DC+ / AC ... during MMA welding
    DC- / DC+ ... during MMA welding with cellulose electrodes
    4Press the adjusting dial
    5Set the polarity for the rod electrodes to be used by turning the adjusting dial
    6Confirm the selection by pressing the adjusting dial
    7Turn the adjusting dial to select further welding parameters
    8Press the adjusting dial
    The value of the parameter is highlighted in blue and can now be changed.
    9Turn the adjusting dial: change the value of the parameter
    10Press the adjusting dial
    11If required, set further parameters in the Setup menu
    NOTE!
    12Start welding
    1. Welding
    Welding parameters for manual metal arc welding
    Depending on the selected current type, (+), (-) or the alternating current symbol is displayed here.
    Starting current
    Starting current: starting current < main current ("SoftStart")
    Starting current: starting current = main current
    Starting current: starting current > main current ("HotStart")
    Factory setting: 150%
    Main current
    Main current: starting current < main current ("SoftStart")
    Main current: starting current = main current
    Main current: starting current > main current ("HotStart")
    Setting range: 0 - 190 A ... iWave 190i, 0 - 230 A ... iWave 230i
    Factory setting:-
    Arc-force dynamic
    To obtain optimum welding results, it will sometimes be necessary to adjust the arc-force dynamic.
    Factory setting: 20
    0 ... soft and low-spatter arc
    100 ... harder and more stable arc
    Functional principle:
    At the instant of droplet transfer or in the event of a short circuit, there is a momentary rise in amperage. In order to obtain a stable arc, the welding current is temporarily increased. If the rod electrode threatens to sink into the weld pool, this measure prevents the weld pool solidifying, as well as preventing more prolonged short circuiting of the arc. This largely prevents the rod electrode from sticking.
    Polarity
    Polarity, set to DC-
    Polarity, set to DC+
    Polarity, set to AC
    Setting range: DC- / DC+ / AC
    1. Welding
    Welding parameters for MMA welding with cellulose electrodes
    link_horizontalLink copied
    Depending on the selected current type, (+) or (-) is displayed here.
    Starting current
    Main current
    Factory setting: -
    Arc-force dynamic
    Factory setting: 20
    Polarity
    1. Welding
    Starting current > 100 % (HotStart)
    Advantages
    • Improved ignition properties, even when using electrodes with poor ignition properties
    • Better fusion of the base material in the start-up phase, meaning fewer cold-shut defects
    • Largely prevents slag inclusions
    Example with a starting current > 100% (HotStart)
    (1)
    0-2 s, factory setting 0.5 s
    (2)
    Starting current
    0-200%, factory setting 150%
    (3)
    Main current = pre-set welding current I1
    Mode of operation
    during the specified starting current time (1), the welding current I1 (3) is increased to the starting current (2).
    The starting current time is set in the Setup menu.
    1. Welding
    Starting current < 100 %
    (SoftStart)
    A starting current < 100% (SoftStart) is intended for basic electrodes. Ignition takes place at a low welding current. Once the arc is stable, the welding current continues to rise until it reaches the welding current command value.
    Example with a starting current < 100% (SoftStart)
    Benefits:
    • Improved ignition properties for electrodes that ignite at low welding currents
    • Reduces welding spatter
    (1)
    Starting current
    (2)
    (3)
    Main current
    The starting current time is set in the rod electrodes menu.
    1. Welding
    Anti-stick function
    As the arc becomes shorter, the welding voltage may also fall so that the stick electrode is more likely to stick to the workpiece. This may also cause the stick electrode to burn out.
    Electrode burn-out is prevented by activating the anti-stick function. If the stick electrode begins to stick, the welding machine immediately switches the welding current off. The welding process can be resumed without problems once the stick electrode has been detached from the workpiece.
    The anti-stick function is activated and deactivated in the stick electrode menu.
    1. Welding
    EasyJob mode
    Storing EasyJob operating points
    NOTE!
    The EasyJobs are stored under job numbers 1 - 5 and can also be retrieved from the Job menu.
    Storing an EasyJob overwrites any other job saved under the same number!
    Prerequisite:
    EasyJobs must be assigned to the Favourites button (see "Assigning EasyJobs to the Favourites button", starting on page (→).
    1Set the welding process, mode and welding parameters
    2Press the Favourites buttonThe 5 EasyJob buttons are opened.
    3Turn the adjusting dial and select the desired storage location
    4To save the current welding settings, press and hold the adjusting dial for about 3 seconds
    The size and colour of the button changes.
    After about 3 seconds, the button is displayed in green.
    The settings have now been stored. The most recently stored settings will be active. An active EasyJob is indicated by a flag on the EasyJob button.
    An occupied storage location is displayed in black, e.g.:
    Storage location 1 ... occupied and active
    Storage location 2 ... selected
    Storage location 3 ... free
    Storage location 4 ... free
    Storage location 5 ... free
    1. Welding
    2. EasyJob mode
    NOTE!
    Prerequisite:
    1. Welding
    2. EasyJob mode
    Retrieving EasyJob operating points
    1Press the Favourites buttonThe 5 EasyJob buttons are opened.
    2Turn the adjusting dial and select the desired storage location
    3To retrieve a saved EasyJob operating point, press the adjusting dial briefly (< 3 seconds)The size and colour of the button changes.
    The EasyJob buttons are then minimised and the active EasyJob is indicated by a flag.
    1. Welding
    2. EasyJob mode
    Deleting EasyJob operating points
    2Turn the adjusting dial and select the storage location to be deleted
    3To delete an EasyJob operating point, press and hold the adjusting dial for about 5 secondsThe button
    • first changes its size and colour;
    • it changes to a green colour after about 3 seconds;
      The saved operating point is overwritten with the current settings.
    • is highlighted in red (= delete) after a total of 5 seconds.
    The EasyJob operating point has been deleted.
    1. Welding
    Welding job
    WARNING!
    WARNING!
    1. Welding
    2. Welding job
    WARNING!
    WARNING!
    1. Welding
    2. Welding job
    Preparation
    1Set up and install the welding machine in accordance with the welding job
    2Plug in the mains plug
    CAUTION!
    Risk of injury and damage from electric shock.
    As soon as the mains switch is in the “I” position, the tungsten electrode of the welding torch is live.
    3Move the mains switch to the “I” position
    1. Welding
    2. Welding job
    Welding a job
    2Select "JOB" (turn adjusting dial and press)
    The welding parameters of the previously opened job are displayed after a short time. The job number is selected.
    The job number can now be modified.
    4Select the job number of the welding job (turn adjusting dial and press)
    The welding parameters of the selected job are displayed and the job can now be welded.
    Setup settings
    The Setup menu
    General
    The Setup menu provides easy access to the knowledge base in the welding machine and to additional functions. The Setup menu can be used to make simple adjustments to the welding parameters to suit the various job settings.
    The following can be found in the Setup menu:
    • all setup parameters that have an immediate effect on the welding process,
    • all setup parameters needed for making the preliminary settings on the welding system.
    The display of the parameters and the ability to change them depends on the selected menu and the current settings for the welding process and operating mode.
    Parameters that are not relevant to the current settings are greyed out and cannot be selected.
    1. Setup settings
    The Setup menu
    General
    1. Setup settings
    2. The Setup menu
    General
    1. Setup settings
    2. The Setup menu
    Accessing the Setup menu
    1Press Menu key
    The Setup menu appears.
    2To leave the Setup menu, press the Menu key again
    The current welding parameters will be displayed.
    1. Setup settings
    2. The Setup menu
    Overview
    ItemDescription
    (1)
    TIG menu
    for setting the TIG parameters for TIG DC and TIG AC
    (2)
    Rod electrode menu
    for setting rod electrode parameters
    (3)
    CEL menu
    for setting the parameters for manual metal arc welding with cellulose electrodes
    (4)
    Ignition and mode settings
    for setting the
    • Ignition parameters
    • Arc monitoring
    • Operating mode defaults
    (5)
    Gas menu
    for setting the shielding gas parameters
    (6)
    Component settings
    for setting the cooling unit mode
    (7)
    Documentation menu
    (only with OPT/i documentation option present)
    • to display welds, events, logbook
    • for setting the sampling rate and limit value monitoring
    (8)
    Job menu
    (only if OPT/i Jobs function package is present)
    • to save, load and delete jobs
    • to assign EasyJobs to the Favourites button
    (9)
    Defaults
    for setting the
    • display (backlighting, languages, date & time, etc.)
    • system (welding machine configuration, factory setting, etc.)
    • network settings (Bluetooth, network setup, WiFi, etc.)
    • user management (create user, create role, etc.)
    • management (trial license)
    For a detailed overview of the defaults, see page (→).
    (10)
    System information
    to view device information such as software version or IP address (if the welding machine is integrated into a network)
    (11)
    Scroll bar
    (if there are several parameters)
    (12)
    Available menus
    The number of menus available may vary depending on the firmware version and available options.
    (13)
    Value, unit
    (14)
    Setup parameters
    Depending on the selected menu and the current settings for the welding process and operating mode, parameters that are not relevant are greyed out and cannot be selected.
    (15)
    Indication of the currently selected menu
    Taking into account the current settings for welding process and operating mode
    Menu currently being adjusted (blue background)
    Position of the currently selected menu
    1. Setup settings
    2. The Setup menu
    Changing menus and parameters
    Selected menu
    Selected parameter
    Change the menu
    Set the parameter
    Selecting a menu
    If a parameter is selected (blue frame, white background):
    1Turn the adjusting dial until the parameter’s higher-level menu is selected
    The background of the selected menu becomes blue.
    3Turn the adjusting dial and select the desired menu (blue background)
    Setting parameters
    4Press the adjusting dial in the selected menu
    The first parameter in the menu is selected.
    5Turn the adjusting dial and select the desired parameter
    6Press the adjusting dial to change the parameter
    The background of the parameter value becomes blue.
    7Turn the adjusting dial and set the value of the parameter
    The change in the parameter value takes effect immediately
    8Press the adjusting dial to select other parameters
    1. Setup settings
    The TIG menu
    Parameters in the TIG DC menu
    Tacking
    Tacking function – duration of the pulsed welding current at the start of tacking
    off / 0.1 - 9.9 s / on
    on
    The pulsed welding current remains until the end of the tacking process
    0.1 - 9.9 s
    The set time begins with the UpSlope phase. After the set time has elapsed, welding is continued with a constant welding current; the pulse parameters, if any, are available
    off
    Tacking function switched off
    The tacking indicator (TAC) in the status bar on the display lights up provided that a value has been set.
    Pulse frequency
    off / 0.20 - 2000 Hz (10,000 Hz with FP Pulse Pro option)
    IMPORTANT! If the pulse frequency is set to "off", the Base current and Duty cycle parameters cannot be selected.
    The set pulse frequency is also used for the reduced current.
    The pulse indicator in the status bar on the display lights up provided a value has been specified for the pulse frequency.
    OPT/i Pulse Pro
    For setting the base current, duty cycle, pulse waveform and base current waveform parameters
    Base current
    0 - 100% (of main current I1)
    Duty cycle
    Ratio of pulse duration to base current duration in cases where a pulse frequency has been set
    10 - 90%
    Pulse waveform
    To optimise the arc pressure
    Hard rectangle / Soft rectangle / Sine
    Factory setting: Hard rectangle
    Hard rectangle:
    Pure rectangular waveform;
    slightly louder arc noise. Rapid current changes
    Used for orbital welding, for example
    Soft rectangle:
    Rectangular waveform with decreased edge steepness, for noise reduction compared to the pure rectangular waveform;
    universal applications
    Sine:
    Sinusoidal waveform (default setting for low noise and stable arc);
    used for corner seams and cladding applications, for example
    Optimising the arc pressure has the following effects:
    • Better wetting of the weld pool (improved welding of butt welds or corner welds)
    • Slow current rise or current drop (especially with fillet welds, high-alloy steels or cladding applications, the filler material or the weld pool is not pushed away)
    • Quieter welding thanks to smoother waveforms
    Base current waveform
    Hard rectangle:
    Soft rectangle:
    Sine:
    The starting current time specifies the duration of the starting-current phase .
    off / 0.01 - 30.0 s
    IMPORTANT! The starting current time only applies to 2-step mode and spot welding. In 4-step mode, the duration of the starting-current phase  is controlled using the torch trigger.
    Final current time
    The final current time specifies the duration of the final current phase.
    off / 0.01 - 30 s
    IMPORTANT! The final current time only applies to 2-step mode and spot welding. In 4-step mode, the duration of the final current phase is controlled using the torch trigger (see "TIG operating modes").
    Slope reduced current
    To set the Slope1 reduced current and Slope2 reduced current parameters
    off / 0.01 - 30 s
    If a time value has been entered for the Slope1 reduced current parameter, the short-term current reduction or current increase is not abrupt, but rather slow and adapted to the desired current curve.
    This reduces negative effects on the weld seam and component, especially for aluminium applications.
    off / 0.01 - 30 s
    If a time value has been entered for the Slope2 reduced current parameter, the adaptation of the reduced current to the welding current is not abrupt, but rather slow and adapted to the desired current curve.
    For example, during a current increase, the weld pool is heated slowly, not abruptly. This allows the weld pool to outgas and reduces pores during aluminium welding.
    Spot welding time
    (spot welding mode only)
    0.02 - 120 s
    Factory setting: 5.0 s
    1. Setup settings
    2. The TIG menu
    Tacking
    on
    0.1 - 9.9 s
    off
    Pulse frequency
    OPT/i Pulse Pro
    Base current
    Duty cycle
    10 - 90%
    Pulse waveform
    Hard rectangle:
    Soft rectangle:
    Sine:
    Hard rectangle:
    Soft rectangle:
    Sine:
    off / 0.01 - 30.0 s
    Final current time
    off / 0.01 - 30 s
    off / 0.01 - 30 s
    off / 0.01 - 30 s
    Spot welding time
    0.02 - 120 s
    1. Setup settings
    2. The TIG menu
    Parameters in the TIG AC menu
    Pulse frequency
    IMPORTANT! If the pulse frequency is set to “off”, the Base current and Duty cycle parameters cannot be selected.
    OPT/i Pulse Pro
    Base current
    Duty cycle
    10-90%
    Pulse waveform
    Hard rectangle:
    Soft rectangle:
    Sine:
    used for corner seams and overlay welding applications, for example
    Hard rectangle:
    Soft rectangle:
    Sine:
    (only in 2-step mode and during spot welding)
    off / 0.01 - 30.0 s
    Final current time
    off / 0.01 - 30 s
    IMPORTANT! The final current time only applies to 2-step mode and spot welding. In 4-step mode, the duration of the final current phase is controlled using the torch trigger (see “TIG operating modes”).
    off / 0.01 - 30 s
    off / 0.01 - 30 s
    Spot welding time
    0.02 - 120 s
    AC frequency
    Syn / 40 - 250 Hz
    Factory setting: 60 Hz
    Syn
    Setting for synchronous welding (both-sided, simultaneous welding with 2 welding machines)
    For synchronous welding, the AC frequency must be set to “Syn” on both welding machines.
    Synchronous welding is used for thick material thicknesses to achieve a high deposition rate and to minimise inclusions during welding.
    IMPORTANT! Owing to the phasing of the input voltage, in some cases the synchronisation of the two welding machines cannot be carried out properly.
    In this case, pull out the mains plug of the welding machine, turn it through 180° and plug it back in again.
    Low frequency
    soft, wide arc with shallow heat input
    High frequency
    focused arc with deep heat input
    Effect of the AC frequency on the waveshape:
    AC current offset
    -70 to +70%
    Factory setting: 0%
    +70%
    Wide arc with low heat input
    High stress on the tungsten electrode
    Good surface cleaning
    -70%
    Narrow arc with high heat input
    Less stress on the tungsten electrode
    Very little surface cleaning.
    Effect of the AC current offset on the waveshape:
    * Factory setting: 0 (corresponds to a 10% shift to negative)
    Positive half-wave waveform
    Hard rectangle / Soft rectangle / Triangle / Sine
    Factory setting: Sine
    Hard rectangle
    pure rectangular waveform (stable but loud arc)
    Soft rectangle
    rectangular waveform with decreased edge steepness, for noise reduction compared to the pure rectangular waveform
    Triangle
    increased current peaks for more arc pressure
    Sine
    default setting for low noise arc
    Negative half-wave waveform
    Factory setting: Soft rectangle
    Hard rectangle
    Soft rectangle
    Triangle
    Sine
    1. Setup settings
    The MMA menu
    Parameters in the rod electrode menu
    HotStart
    0.0 - 2.0 s
    To obtain optimum welding results, it will sometimes be necessary to adjust the HotStart function.
    Benefits:
    Char
    To select welding characteristics
    I-constant / 0.1 - 20.0 A/V / P-constant
    Factory setting: I-constant
    Adjustable characteristics
    (1)
    Load line for rod electrode
    (2)
    Load line for rod electrode where arc length is increased
    (3)
    Load line for rod electrode where arc length is reduced
    (4)
    Characteristic for parameter setting I-constant (constant welding current)
    (5)
    Characteristic for parameter setting 0.1 - 20.0 (drooping characteristic with adjustable slope)
    (6)
    Characteristic for parameter setting P-constant (constant welding power)
    (7)
    Example of pre-set arc-force dynamic where characteristic (4) is selected
    (8)
    Example of pre-set arc-force dynamic where characteristic (5) or (6) is selected
    • If the I-constant characteristic is set, the welding current will be kept constant, irrespective of the welding voltage. This results in a vertical characteristic (4).
    • The setting is particularly suitable for
      rutile electrodes,
      basic electrodes,
      arc air gouging (set the dynamic to 100 for arc air gouging).
    0.1 - 20.0 A/V (drooping characteristic with adjustable slope)
    • Setting 0.1 - 20.0 is used to set a drooping characteristic (5). The setting range is from 0.1 A/V (very steep) to 20 A/V (very flat).
    • Setting a flat characteristic (5) is only advisable for cellulose electrodes.
    NOTE!
    When setting a flat characteristic (5), set the arc-force dynamic to a higher value.
    • If the P-constant characteristic is set, the welding power is kept constant, irrespective of the welding voltage and welding current. This results in a hyperbolic characteristic (6).
    • This setting is particularly suitable for cellulose electrodes.
    NOTE!
    If there are problems with a rod electrode tending to “stick”, set the arc-force dynamic to a higher value.
    Settings example: I1 = 250 A, arc-force dynamic = 50
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (7)
    (8)
    (a)
    Operating point where arc length is long
    (b)
    Operating point when welding current I1 is set
    (c)
    Operating point where arc length is short
    The characteristics (4), (5) and (6) shown here apply when using a rod electrode whose characteristic corresponds to the load line (1) at a given arc length.
    Depending on what welding current (I) has been set, the point of intersection (operating point) of characteristics (4), (5) and (6) will be displaced along the load line (1). The operating point provides information on the actual welding voltage and the actual welding current.
    Where the welding current (I1) is permanently set, the operating point may migrate along the characteristics (4), (5) and (6) depending on the welding voltage at that moment in time.
    The welding voltage U is dependent upon the arc length.
    If the arc length changes (e.g. in accordance with the load line (2)) the resulting operating point will be the point where the corresponding characteristic (4), (5) or (6) intersects with the load line (2).
    For characteristics (5) and (6), if a constant value is set for I1, the welding current (I) will also become smaller or larger depending on the welding voltage.
    Break-voltage
    Welding voltage limitation
    20 - 90 V
    Factory setting: 20 V
    The arc length depends on the welding voltage. To end the welding process, it is usually necessary to significantly lift the rod electrode away from the workpiece. With this parameter, the welding voltage can be limited to a value that makes it possible to end the welding operation simply by slightly lifting the rod electrode.
    NOTE!
    If, during welding, you often find that the welding operation is ended unintentionally, increase the value of the break-voltage parameter.
    Anti-stick
    on / off
    Factory setting: on
    As the arc becomes shorter, the welding voltage may drop so far that the rod electrode will tend to stick. This may also cause the rod electrode to burn out.
    Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the welding machine immediately switches the welding current off. After the rod electrode has been detached from the workpiece, the welding process can be continued without any problems.
    AC frequency
    only for MMA AC welding (welding parameter polarity = AC)
    40 - 250 Hz
    1. Setup settings
    2. The MMA menu
    HotStart
    0.0 - 2.0 s
    Benefits:
    Char
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (7)
    (8)
      rutile electrodes,
      basic electrodes,
    NOTE!
    NOTE!
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (7)
    (8)
    (a)
    (b)
    (c)
    Break-voltage
    20 - 90 V
    NOTE!
    Anti-stick
    on / off
    Factory setting: on
    AC frequency
    40 - 250 Hz
    1. Setup settings
    The CEL menu
    Parameters in the CEL menu
    HotStart
    0.0 - 2.0 s
    Benefits:
    Break-voltage
    20 - 90 V
    NOTE!
    Anti-stick
    on / off
    Factory setting: on
    1. Setup settings
    2. The CEL menu
    HotStart
    0.0 - 2.0 s
    Benefits:
    Break-voltage
    20 - 90 V
    NOTE!
    Anti-stick
    on / off
    Factory setting: on
    1. Setup settings
    Ignition parameters
    HF ignition
    on / off / Touch HF / External
    Factory setting: on
    on
    High frequency ignition is activated when welding is started
    off
    No high-frequency ignition when welding is started.
    In this case, welding starts with touchdown ignition.
    Touch HF
    The welding process is initiated by briefly touching the workpiece with the tungsten electrode. The high frequency ignition occurs after the set HF ignition delay time has elapsed.
    External
    Start with external ignition aid, e.g. plasma welding
    The HF ignition indicator in the status bar on the display lights up as long as HF ignition has been set to On.
    CAUTION!
    Duration until the high frequency ignition takes place after touching the workpiece with the tungsten electrode.
    0.1 - 5.0 s
    Reversed polarity ignition
    (iWave AC/DC welding machines only)
    To optimise the ignition sequence in TIG DC welding, the polarity is reversed briefly when welding starts. Electrons emerge from the workpiece and strike the tungsten electrode. This results in rapid heating-up of the tungsten electrode - which in itself is an essential precondition for optimum ignition performance.
    off / on
    IMPORTANT! Reversed polarity ignition is not recommended when welding light-gauge sheets.
    1. Setup settings
    2. Ignition and mode settings
    Ignition parameters
    HF ignition
    Factory setting: on
    on
    off
    Touch HF
    External
    CAUTION!
    0.1 - 5.0 s
    off / on
    1. Setup settings
    Arc monitoring
    Ignition timeout
    Ignition timeout until safety shutdown after abortive ignition attempt.
    0.1 - 9.9 s
    Factory setting: 5 s
    IMPORTANT! Ignition timeout is a safety function and cannot be deactivated.
    The description of the ignition timeout function can be found in the section “TIG welding”.
    Arc break time
    Duration until safety shutdown after arc break
    If, following an arc break, there is no current flow within the time specified here, the welding machine shuts down automatically.
    To start the welding process again, press any key on the control panel or the torch trigger.
    0.00 - 2.00 s
    Factory setting: 0.20 s
    Arc break monitoring
    Reaction if there is no current flow within the arc break time
    ignore / Error
    Factory setting: ignore
    ignore
    The interruption is ignored.
    Error
    An error message to be acknowledged is displayed on the welding machine.
    1. Setup settings
    Torch trigger
    Welding start using torch trigger
    on / off
    Factory setting: on
    on
    Welding is started via the torch trigger
    off
    Welding is started by touching the workpiece with the tungsten electrode;
    especially suitable for welding torches without a torch trigger, ignition sequence depending on ignition parameters
    The display shows the symbol for the deactivated torch trigger in the status bar, the selection of the operating mode is deactivated.
    to activate / deactivate whether it is possible to switch over to the reduced current I2 by means of the torch trigger
    The setting of the I2 via torch trigger parameter also influences variants 1 - 6 of the special 4-step mode (see from page (→)).
    on / off
    The setting of the Reduced current button function parameter also influences variants 1 - 6 of the special 4-step mode (see from page (→)).
    I1 / I2
    Factory setting: I2
    Arc break voltage
    for setting a voltage value at which the welding process can be terminated by slightly raising the TIG welding torch.
    The higher the break voltage, the higher the arc can be drawn.
    The arc break voltage value is stored together for 2-step mode, 4-step mode and operation with a pedal remote control.
    If the "Torch trigger" parameter is set to "off", the value is stored separately.
    off / 6.0 - 90.0 V
    Comfort Stop sensitivity
    The parameter is only available if the "Torch trigger" parameter is set to "off".
    off / 0.1 - 10.0 V
    At the end of the welding operation, the welding current is switched off automatically if the arc length increases by more than a defined amount. This prevents the arc from being unnecessarily lengthened when the TIG welding torch is lifted.
    Sequence:
    1Welding
    2At the end of the welding action, briefly raise the welding torch
    The arc length is increased significantly.
    3Lower the welding torch
    • The arc length is reduced significantly
    • The Comfort Stop function has been activated
    4Keep the welding torch at the same height
    • The welding current is continuously decreased (DownSlope).
    • The arc goes out.
    IMPORTANT! The DownSlope is pre-set and cannot be adjusted.
    5 Raise the welding torch from the workpiece
    1. Setup settings
    The gas menu
    Parameters in the Gas menu
    Gas pre-flow
    Duration of gas pre-flow
    0.0 - 9.9 s
    Factory setting: 0.4 s
    Gas post-flow
    Duration of gas post-flow
    auto / 0 - 60 s
    Factory setting: auto
    auto
    Depending on the electrode diameter and welding current, the welding machine calculates the optimum gas post-flow time and adjusts it automatically.
    1. Setup settings
    2. The gas menu
    Gas pre-flow
    0.0 - 9.9 s
    Gas post-flow
    auto / 0 - 60 s
    auto
    1. Setup settings
    The components menu
    Parameters in the Components menu
    Cooling circuit operating mode
    for controlling a cooling unit
    eco / auto / on / off
    auto
    When welding is started, the cooling unit starts to operate (fan and coolant pump are running).
    At the end of welding, the cooling unit continues to operate for 2 minutes. The cooling unit switches off after these 2 minutes.
    on
    Continuous operation
    As soon as the welding machine is switched on, the cooling unit starts to operate (fan and coolant pump are running permanently)
    off
    No operation, even when welding is started
    eco
    The coolant pump starts when welding starts.
    The fan starts working from a coolant return temperature of 40°C (104°F) (only in conjunction with the flow temperature sensor option).
    When filling the torch hosepack, the coolant pump continues to run for 10 seconds once the flow rate is > 0.7 l/m.
    At the end of welding, the cooling unit continues to run for at least another 15 seconds. As soon as the coolant return temperature is < 40 °C, the cooling unit cuts out.
    The maximum post-run time is 2 minutes.
    Flow sensor filter time
    (only if the flow temperature sensor option is present on the cooling unit)
    to set the time from when the flow sensor responds until a warning message is output
    5 - 25 s
    Factory setting: 10 s
    Coolant flow warning level
    If the parameter is activated, a warning is generated if the value entered is not reached.
    off / 0.75 / 0.8 / 0.85 / 0.9 / 0.95
    Empty/fill torch hosepack
    (only in conjunction with a MultiControl cooling unit CU 600t /MC or CU 600t MV/MC)
    Function to drain and fill the torch hosepack, for example when changing the torch body.
    A detailed description of the two functions follows.
    1. Setup settings
    2. The components menu
    auto
    on
    off
    eco
    5 - 25 s
    1. Setup settings
    Emptying the torch hosepack
    Prerequisites for emptying the torch hosepack:
    • MultiControl cooling unit present
    • Cooling unit operating mode = eco or auto
    • Welding machine must not be in welding operation
    • Torch hosepack must not be in the process of being filled via the “Fill torch hosepack” function
    • Torch body must be fitted
    • Torch hosepack must be connected up correctly
    The torch hosepack can be emptied via the welding machine Setup menu or by entering a key combination on the TIG welding torch.
    Start via Setup menu
    1Accessing the Setup menu
    2Select the component settings
    3Select “Empty/fill torch hosepack”:
    Turn and press adjusting dial
    4Ensure that the welding torch has been connected up correctly
    5Select “Start”
    Start via key combination on welding torch
    * Press intermediate lowering key to interrupt the process
    1Press and hold the LED key
    2Press and hold the Down (-) key for 2 seconds
    If the coolant temperature is too high, you will first need to wait for the coolant to cool down (cooling phase). During this cooling phase, the LED on the welding torch will flash roughly every 2 seconds.
    The emptying process will start as soon as the coolant temperature is low enough. It takes roughly 30 seconds to empty the torch hosepack. During this time the LED on the welding torch will flash roughly every second.
    When the emptying process has been completed successfully, a confirmation to this effect is displayed.
    The torch body can now be changed.
    Switch off the welding machine before changing the torch hosepack.
    IMPORTANT! It is not possible to perform any welding operations with an empty torch hosepack!
    1. Setup settings
    Filling the torch hosepack
    Prerequisites for filling the torch hosepack:
    • Torch hosepack must not be in the process of being emptied via the “Empty torch hosepack” function
    The torch hosepack can be filled via the welding machine Setup menu or by entering a key combination on the TIG welding torch.
    3Select “Empty/fill welding torch”:
    A note is displayed if the torch hosepack is empty.
    4Ensure that the welding torch is connected up correctly and the torch body is properly fitted
    5Press the Gas-test button
    2Press and hold the Up (+) key for 2 seconds
    The filling process is started. It takes roughly 30 seconds to fill the torch hosepack. During this time the LED on the welding torch will flash roughly every second.
    When the filling process has been completed successfully, a confirmation to this effect is displayed.
    IMPORTANT! Before starting to weld again, check the operating mode of the cooling unit and, if necessary, apply the correct value for the task at hand.
    1. Setup settings
    The documentation menu
    Displaying welds
    1Press the adjusting dial to display welds
    The following data is also logged:
    (1)
    Welding operation number
    (2)
    Date (ddmmyy)
    (3)
    Time (hhmmss)
    (4)
    Welding duration in s
    (5)
    Welding current in A (average value)
    (6)
    Welding voltage in V (average value)
    (7)
    Arc energy in kJ
    (8)
    Job no.
    Turn the adjusting dial to scroll through the list.
    2Select Close to exit the overview of the welds
    Displaying events
    1Press the adjusting dial to display the events
    The logged events are displayed with the date and time.
    2Select Close to exit the overview of the events
    Displaying the logbook
    1Press the adjusting dial to display the logbook (welds and events)
    The logged data is displayed in the same way as the welds.
    2Select Close to exit the logbook
    Basic settings / sampling rate
    2Turn the adjusting dial and change the sampling rate value:
    off
    Sampling rate is deactivated; only average values are stored.
    0.1–100.0 s
    Documentation is stored with the set sampling rate.
    3Press the adjusting dial to confirm the sampling rate
    Limit monitoring
    for activating/deactivating limit monitoring
    2Turn the adjusting dial and change the value for limit monitoring:
    off
    Limit monitoring is deactivated.
    on
    Limit monitoring is activated according to the specifications.
    3Press the adjusting dial to accept the setting
    1. Setup settings
    2. The documentation menu
    Displaying welds
    (1)
    (2)
    Date (ddmmyy)
    (3)
    Time (hhmmss)
    (4)
    (5)
    (6)
    (7)
    Arc energy in kJ
    (8)
    Job no.
    Displaying events
    off
    0.1–100.0 s
    Limit monitoring
    off
    on
    1. Setup settings
    The Job menu
    Saving a job
    When jobs are saved, the welding process and all the settings in the welding parameters and the respective Setup menus are saved.
    When creating jobs you MUST therefore also take into account the welding parameters in the Setup menus.
    Jobs can be saved in two ways:
    • Save job via the Job menu
    • Save job using the adjusting dial
    1. Setup settings
    2. The Job menu
    Saving a job
    1. Setup settings
    2. The Job menu
    Saving a job via the Job menu
    1Set welding process, mode, welding parameters and setup parameters
    2Press the Menu key
    3Turn the adjusting dial and select the Job menu
    5Turn the adjusting dial and select "Save Job as ..."
    An overview of the most important parameters is displayed.
    7Select "More" (turn adjusting dial and press)
    Overwrite existing job
    (after pressing the adjusting dial, a confirmation prompt asking whether you really want to overwrite the job is displayed)
    or
    Create new job
    Press the adjusting dial; the first available job number is displayed.
    9Select Job number (turn adjusting dial and press)
    10Select "More" (turn adjusting dial and press)
    The keyboard is displayed.
    11Turn and press the adjusting dial to enter a name for the job
    12Select "More" (turn adjusting dial and press)
    A message confirming that the job has been saved is displayed.
    13Select "Finish" (turn adjusting dial and press)
    1. Setup settings
    2. The Job menu
    Saving a job using the adjusting dial
    2Press the adjusting dial for more than 3 seconds
    3Select "More" (turn adjusting dial and press)
    4Turn the adjusting dial:
    or
    Create new job
    5Select Job number (turn adjusting dial and press)
    6Select "More" (turn adjusting dial and press)
    7Turn and press the adjusting dial to enter a name for the job
    8Select "More" (turn adjusting dial and press)
    9Select "Finish" (turn adjusting dial and press)
    1. Setup settings
    2. The Job menu
    Loading a job
    The Load job function can be used to load the data for a saved job or an EasyJob into the welding parameters.
    The relevant data from the job can be changed, saved as a new job or EasyJob, or used to start welding.
    1Press the Menu key
    2Turn the adjusting dial and select the Job menu
    4Turn the adjusting dial and select "Load Job ..."
    5Press the adjusting dial
    The job list is displayed.
    6Select the job that you want to load (turn adjusting dial and press)
    A message advising that the job is about to be loaded is displayed.
    7Select "Yes" (turn adjusting dial and press)
    The job is loaded into the welding parameters.
    1. Setup settings
    2. The Job menu
    Deleting a job
    1Press the Menu key
    4Turn the adjusting dial and select "Delete Job ..."
    6Select the job that you want to delete (turn adjusting dial and press)
    A warning that the job is about to be deleted is displayed.
    The job is deleted.
    1. Setup settings
    2. The Job menu
    Optimising job process parameters
    The following process parameters can be set for job optimisation:
    Job parameters
    Starting current
    [% of main current]
    DownSlope
    [s]
    UpSlope
    [s]
    Final current
    [% of main current]
    Main current
    [A]
    AC balance
    only on iWave AC/DC welding machines
    Reduced current
    for 4-step mode
    [% of main current]
    Electrode diameter
    [mm]
    Welding process settings
    Polarity
    [DC- / AC]
    TIG welding torch mode
    [2-step / 4-step / spot welding]
    TIG pulse settings
    Tacking
    [s]
    Duty cycle
    Pulse frequency
    [Hz]
    Pulse waveform
    [rectangle / triangle / sine]
    Base current
    [% of main current]
    TIG AC settings
    (only on iWave AC/DC welding machines)
    AC frequency
    [Hz]
    AC current offset
    Ignition parameters
    HF ignition
    [on / off / touch HF / external]
    [off / on]
    HF ignition delay
    [s]
    Arc monitoring
    Ignition timeout
    [s]
    [ignore / error]
    Arc break filter time
    [s]
    Mode settings
    Arc break voltage
    [V]
    Comfort stop sensitivity
    [V]
    General settings
    [s]
    [s]
    Final current time
    [s]
    Spot welding time
    [s]
    [s]
    TIG gas settings
    Gas pre-flow
    [s]
    Gas post-flow
    [s]
    Job correction limits
    Upper main current limit
    0 - 50%
    Factory setting: 0%
    Job slope
    defines the time between the job that is currently selected and the next job
    0.0 - 10.0 s
    Factory setting: 0 s
    Lower main current limit
    -50 - 0%
    Factory setting: 0%
    CycleTIG settings
    CycleTIG activated
    Interval cycles
    Interval time
    [s]
    Base current
    [A]
    Interval break time
    [s]
    Documentation
    Sampling rate
    Limit monitoring
    Voltage set value
    0.0 - 100.0 V
    Factory setting: 100.0 V
    Lower welding duration limit
    -50.0 - 0.0 s
    Factory setting: -1.0 s
    Lower voltage limit
    -10.0 - 0.0 V
    Factory setting: -1.0 V
    Upper welding duration limit
    0.0 - 50.0 s
    Upper voltage limit
    0.0 - 10.0 V
    Factory setting: 1.0 V
    Welding time monitoring
    off / on
    Max. time of voltage deviation
    off / 0.1 - 10.0 s
    Energy set value
    0.0 - max. kJ
    Factory setting: 1.0 kJ
    Current set value
    0.0 - 1000.0 A
    Factory setting: -
    Lower energy limit
    -100.0 - 0.0 kJ
    Factory setting: 0.0 kJ
    Lower current limit
    -100 - 0 A
    Factory setting: - 10 A
    Upper energy limit
    0.0 - 100.0 kJ
    Upper current limit
    0 - 100 A
    Factory setting: 10 A
    Energy monitoring
    off / on
    Max. time of current deviation
    off / 0.1 - 10.0 s
    Limit reaction
    ignore / warning / error
    Welding duration set value
    0.0 - 999.9 s
    Job number online
    to activate / deactivate whether the active job in Job Mode is changed over and processed at the same time
    1. Setup settings
    2. The Job menu
    Defaults for "Save job"
    After confirming the displayed information, the following process parameters can be set for the "Save as Job" pre-settings:
    Job slope
    Job slope
    0.0 - 10.0 s
    for setting the upper main current limit for a job
    0.0 - 20.0%
    Factory setting: 0
    for setting the lower main current limit for a job
    -20.0 - 0.0%
    Factory setting: 0
    Limit monitoring
    Voltage command value
    0.0 - 100.0 V
    Lower voltage limit
    -10.0 - 0.0 V
    Upper voltage limit
    0.0 - 10.0 V
    off / 0.1 - 10.0 s
    Current command value
    0.0 - 1000.0 A
    Factory setting: -
    Lower current limit
    -100 - 0 A
    Upper current limit
    0 - 100 A
    off / 0.1 - 10.0 s
    Welding duration command value
    0.0 - 999.9 s
    -50.0 - 0.0 s
    0.0 - 50.0 s
    off / on
    Energy command value
    0.0 - max. kJ
    Lower energy limit
    -100.0 - 0.0 kJ
    Upper energy limit
    0.0 - 100.0 kJ
    Energy monitoring
    off / on
    Limit reaction
    ignore / Warning / Error
    1. Setup settings
    2. The Job menu
    EasyJobs on Favourites button
    The procedure for saving EasyJobs on the Favourites button is described starting from page (→).
    1. Setup settings
    Defaults
    Overview
    Defaults contains the following sections:
    Display
    • Backlighting
    • Languages
    • Date & time
    • Show system data
    • Display additional parameters
    • iJob parameter display
    System
    • Power source configuration
    • Reset to factory settings
    • Reset website password
    • Torch trigger I2 - cap mode
    • Perform R/L alignment
    Network settings
    • Bluetooth on
    • Configure Bluetooth devices
    • Network settings
    • Activate WLAN
    • WLAN settings
    User management
    • Create user / overview
    • Create role / overview
    • CENTRUM server
    Management
    • Trial Lizenz
    1. Setup settings
    2. Defaults
    Overview
    Display
    • Backlighting
    • Languages
    • Date & time
    • Show system data
    System
    Network settings
    • Bluetooth on
    • Network settings
    • Activate WLAN
    • WLAN settings
    User management
    • CENTRUM server
    Management
    • Trial Lizenz
    1. Setup settings
    Display
    Backlighting
    Backlighting
    to set the brightness of the display
    Unit       -
    Setting range      0 - 10
    Factory setting      10
    Adjust backlighting:
    1Defaults / Display / Backlighting
    3Select backlighting brightness (turn adjusting dial and press)
    1. Setup settings
    2. Display
    Backlighting
    Backlighting
    Unit       -
    Factory setting      10
    1. Setup settings
    2. Display
    Languages
    Language
    Setting range: dependent on the software version
    Factory setting: English
    Setting the language:
    1Defaults / Display / Language
    2Select the desired language (turn adjusting dial and press)
    The Globe symbol appears briefly and the language changes.
    1. Setup settings
    2. Display
    Time & Date
    Time & Date
    to set the time and date
    Setting range: Year / Month / Day / Hour / Minute / Time zone
    Factory setting: -
    Setting the date & time:
    1Defaults / Display / Time & Date
    2Select the desired parameter (turn adjusting dial and press)
    3Modify parameter by turning the adjusting dial
    4Confirm the modified parameter by pressing the adjusting dial
    5Press the menu key to exit the date and time settings
    1. Setup settings
    2. Display
    Show system data
    After selecting "Show system data", the current system data of the welding system is displayed:
    (1)
    Welding current actual/hold value
    (2)
    Current arc power
    (3)
    Current arc energy
    (4)
    Coolant circulation
    (5)
    Coolant temperature
    (6)
    Total operating hours
    (7)
    Current flow time
    (8)
    Welding voltage
    (9)
    Welding current command value
    Press the adjusting dial to hide the system data and return to the welding parameters screen.
    1. Setup settings
    2. Display
    In the case of welding parameters 1 - 3, this function enables additional parameters or settings to be displayed.
    • Not assigned
    • Process
    • TIG welding torch mode
    • TIG settings:
      Tacking, pulse frequency, base current, duty cycle, pulse waveform, base current waveform, starting current time, final current time, spot welding time, reduced current slope 1, reduced current slope 2, AC frequency, AC current offset, positive half-wave waveform, negative half-wave waveform
    • Electrode settings:
      Starting current time, characteristic, break voltage, anti-stick, AC frequency
    • CEL settings:
      Starting current time, break voltage, anti-stick
    • Ignition settings:
      HF ignition, HF ignition delay time, ignition timeout, arc break filter time, arc break monitoring, torch trigger, arc break voltage, comfort stop sensitivity, reversed polarity ignition
    • Gas settings:
      Gas pre-flow, gas post-flow
    • Components settings:
      Cooling circuit operating mode, filter time flow sensor, cooler flow warning limit
    Display additional parameters:
    1Default / Display / Display additional parameters
    3Select parameter location P1 - P3 (turn and press adjusting dial)
    4Choose which parameter to display in the selected parameter location (turn adjusting dial and press)
    5Select Save (turn adjusting dial and press)
    The parameter is displayed in the selected parameter location, where it can now also be modified.
    1. Setup settings
    2. Display
    In the case of jobs, this function enables additional parameters or settings to be stored.
    • Job parameters:
      Starting current, UpSlope, reduced current, DownSlope, final current, AC balance, electrode diameter
    • Welding process settings:
      Cap mode, polarity
    • TIG pulse settings:
      Tacking, pulse frequency, base current, duty cycle, waveform pulse, waveform base current
    • AC settings:
      AC frequency, positive half-wave waveform, negative half-wave waveform
    • Ignition & mode settings:
    • General settings:
      2-step setup (starting current time, final current time)
      4-step settings (reduced current slope 1, reduced current slope 2)
      Spot welding settings (spot welding time)
    • CycleTIG:
      CycleTIG activated, interval time, interval break time, interval cycles, base current
    To display the iJob parameter display:
    1Defaults / Display / Select iJob parameter display
    2Turn the adjusting dial and select the desired group
    4Turn the adjusting dial and select the desired parameter
    6Select Save to exit the iJob parameter display
    The parameter is displayed in the jobs, where it can now also be modified.
    1. Setup settings
    System
    Welding machine configuration
    Power source = welding machine
    1Defaults / system / power source configuration
    3Select name, plant, hall, cell, additional info by turning the adjusting dial
    4Press the dial to edit the selection
    5Enter the configuration data by turning and pressing the adjusting dial
    6Select “OK” (turn adjusting dial and press)
    7After entering all configuration data, select “Save” (adjusting dial wheel and press)
    1. Setup settings
    2. System
    1. Setup settings
    2. System
    1Defaults / system / reset to factory settings.
    2Press the adjusting dial.
    A confirmation prompt asking whether you really want to restore the factory settings is displayed.
    3Select yes by turning the adjusting dial.
    4Press the adjusting dial to reset to factory settings.
    The welding machine is reset to the factory settings.
    1. Setup settings
    2. System
    1Defaults / System / Reset website password
    A confirmation prompt asking whether you really want to reset the website password is displayed.
    4Press the adjusting dial to reset the website password
    The website password is reset to the factory setting.
    Factory settings
    1. For devices supplied with firmware version ≥ 2.4.1:User name = admin
      Password = 20-digit number on the welding machine rating plate (unique password)
    2. For devices supplied with an earlier version:
      User name = admin
      Password = admin
      In the case of devices supplied with earlier versions, the factory setting is always admin / admin regardless of any firmware updates.
    1. Setup settings
    2. System
    1Defaults / System / Torch trigger I2 - cap mode
    3Select off or on by turning the adjusting dial
    off
    It is not possible to activate cap mode by actuating the torch trigger for a long time.
    on
    Cap mode is activated by actuating the torch trigger for a long time.
    1. Setup settings
    2. System
    Performing R/L alignment
    NOTE!
    R/L alignment must be carried out separately for each welding process.
    Welding circuit resistance R [mOhm]
    Measuring the welding circuit resistance "r" provides information on the overall resistance of the torch hosepack, welding torch, workpiece and grounding cable.
    If an increased welding circuit resistance is detected, e.g. after changing the welding torch, this may mean that the following components are faulty:
    • Torch hosepack
    • Welding torch
    • Grounding (earthing) connection to the workpiece
    • Grounding cable
    Welding circuit inductivity L [µH]
    The way that the hosepack is arranged has a very significant effect on the weld properties.
    Particularly with pulsed-arc welding and AC welding, a high welding circuit inductivity may occur, depending on the length of the hosepack and on the way that it is arranged. The result is that the current rise is restricted.
    The weld results can be optimised by changing the arrangement of the torch hosepack.
    The hosepack must be laid out as shown in the illustration.
    1Defaults / System / Perform R/L alignment
    The current values are displayed
    3Select More (turn adjusting dial and press)
    The second R/L alignment screen is displayed.
    4Follow the instructions displayed on the screen
    5Select More (turn adjusting dial and press)
    The third R/L alignment screen is displayed.
    6Follow the instructions displayed on the screen
    7Select More (turn and press adjusting dial)
    The current values are calculated.
    After R/L alignment has been completed, a confirmation and the current values are displayed.
    1. Setup settings
    Network settings
    General
    Each Bluetooth device has its own MAC address. This MAC address can be used to assign the devices to specific welding machines, preventing mix-ups.
    The welding machine is able to communicate with the following Bluetooth devices:
    • Remote control RC Panel Basic /BT
    • Pedal remote control RC Pedal TIG /BT
    • Welding helmet Vizor Connect /BT
    An active Bluetooth connection is indicated in the status bar on the display by an illuminated Bluetooth symbol.
    For safety reasons, when using Bluetooth devices of the same type, only one device can be actively connected to the welding machine.
    It is possible to establish multiple active Bluetooth connections when using Bluetooth devices of different types.
    New Bluetooth devices must always be configured in the Setup menu.
    An existing, active Bluetooth connection cannot be interrupted or influenced by another Bluetooth device.
    Bluetooth remote controls have priority over wired remote controls or welding torches with control functions.
    If the connection between a wired or Bluetooth remote control and the welding machine is interrupted during the welding process, the welding process is ended.
    1. Setup settings
    2. Network settings
    General
    1. Setup settings
    2. Network settings
    Bluetooth on
    Bluetooth on
    to activate/deactivate the Bluetooth function
    Setting range: on / off (check box)
    Activating/deactivating the Bluetooth function:
    1Defaults / Network settings / Bluetooth on
    2To activate/deactivate the Bluetooth function, press the adjusting dial
    Bluetooth function deactivated
    Bluetooth function activated
    Bluetooth devices can be configured when the Bluetooth function is active.
    1. Setup settings
    2. Network settings
    Configuring Bluetooth devices
    1Switch on the Bluetooth device
    2Defaults / Network settings / Configure Bluetooth devices
    All Bluetooth devices detected are displayed in a list along with their names, MAC addresses and additional information.
    4Turn the adjusting dial and select the desired Bluetooth device
    5Compare the MAC address displayed with the MAC address on the devicePress the adjusting dial to create an active connection with the selected device
    A prompt to connect to the Bluetooth device is displayed.
    6Select Yes
    An active connection to the selected Bluetooth device is established. The active connection is displayed under Info.
    Symbols displayed under Info:
    Active Bluetooth connection
    An active change can be made to the welding machine via the Bluetooth device.
    Depending on the availability of the data, additional information is also displayed, such as the battery status, signal strength, etc. of the Bluetooth device.
    Paired
    The Bluetooth device has already been actively connected to a welding machine at least once and appears in the list of the Bluetooth devices.
    Inactive
    A new Bluetooth device has been detected or the Bluetooth device was removed by the user.
    1. Setup settings
    2. Network settings
    Network setup
    1Defaults / Network settings / Select network settings
    The network setup overview is displayed.
    If DHCP is enabled, the IP address, Network mask, Standard gateway, DNS Server 1 and DNS Server 2 parameters are greyed out and cannot be adjusted.
    3Turn the adjusting dial and select "DHCP"
    DHCP is disabled, the network parameters can now be set.
    4Turn the adjusting dial and select the desired network parameter
    The numerical pad for the selected parameter is displayed.
    6Enter a value for the network parameter
    7Select "Save" and confirm the value for the network parameter / press the adjusting dial
    The value for the network parameter is applied, the network setup overview is displayed.
    8Select "Store" to apply changes to the network setup
    1. Setup settings
    2. Network settings
    Activating WLAN
    Activate WLAN
    to activate/deactivate the WLAN function
    Factory setting: off
    To activate/deactivate the WLAN function:
    1Defaults / Network settings / Enable WLAN
    2To activate/deactivate the WLAN function, press the adjusting dial
    WLAN function deactivated
    WLAN function activated
    When the WLAN function is activated, the WLAN settings can be executed.
    1. Setup settings
    2. Network settings
    WLAN settings
    1Preferences / Network settings / Select WLAN settings
    The available WLAN networks are displayed.
    1Select "Country" and press the adjusting dial
    2Select "Country" and press the adjusting dial
    3Turn the adjusting dial and select the corresponding country
    5Select "Save" and press the adjusting dial
    6Select "OK" and press the adjusting dial
    1. Setup settings
    User management
    Overview
    User management consists of the following sections:
    • General
    • Create users and roles
    • Edit user / roles, deactivate user administration
    • CENTRUM server
    1. Setup settings
    2. User management
    Overview
    • General
    • CENTRUM server
    1. Setup settings
    General
    General
    User management is advisable if several users work with the same welding machine.
    User management works with different roles and the help of NFC keys.
    Users are assigned different roles depending on their level of training or qualifications.
    1. Setup settings
    2. General
    General
    1. Setup settings
    2. General
    Explanation of terms used
    Administrator
    An administrator has unlimited access rights to all functions on the welding machine. The administrator's duties include:
    • Creating roles
    • Editing and managing user data
    • Assigning access rights
    • Updating the firmware
    • Backing up data, etc.
    User management
    User management encompasses all users registered on the welding machine. Users are assigned different roles depending on their level of training or qualifications.
    NFC card
    An NFC card or an NFC key ring is assigned to a certain user who is registered on the welding machine.
    NFC cards and NFC key rings will both be referred to under the general term NFC key for the purpose of these Operating Instructions.
    IMPORTANT! Each user should be assigned their own NFC key.
    Roles
    Roles are used for managing registered users (= user management). Users' access rights and permitted activities are defined by their roles.
    1. Setup settings
    2. General
    Pre-defined roles and users
    Two roles are predefined in the factory under Defaults / User management:
    administrator
    with full rights and options
    The “administrator” role cannot be deleted, renamed or edited.
    The “administrator” role is assigned the pre-defined “admin” user, which cannot be deleted. The “admin” user can assign names, languages, units, web passwords and NFC keys.
    As soon as “admin” assigns an NFC key, user management is activated.
    locked
    Factory-set with access to welding processes, but not to process parameters and defaults
    The “locked” role
    • cannot be deleted or renamed
    • can be edited to approve different functions according to demand
    The “locked” role cannot have any NFC keys assigned to it.
    If no NFC key is assigned to the pre-defined user “admin”, every NFC key will work to lock and unlock the welding machine (no user management, see “Locking and unlocking the welding machine using the NFC key”, page (→)).
    1. Setup settings
    2. General
    Recommendation for creating roles and users
    Please proceed systematically when creating roles and NFC keys.
    Fronius recommends creating one or two administrator keys. Without administrator rights, it may in the worst-case scenario no longer be possible to operate a welding machine.
    NOTE!
    Losing an NFC administrator key can lead to the welding machine becoming unusable, depending on the settings. Keep one of the two NFC administrator keys in a safe place.
    Procedure
    1Create two equivalent users with the “administrator” role
    This means that access to the administrator function is retained even if an administrator NFC key is lost.
    2Consider further roles:
    • How many roles are needed?
    • Which rights will be assigned to each role?
    • How many users are there?
    3Create roles
    4Assign users to roles
    5Check that the created users have access to their respective roles with their NFC keys.
    1. Setup settings
    Creating a user
    NOTE!
    If an NFC key is assigned to the predefined user "admin" under Defaults / User management / Create user - overview, the user administration is activated.
    1Defaults / User management / Create user - overview
    The list of existing users is displayed.
    3Turn the dial and select "Create new user"
    NOTE!
    For privacy reasons, only person identity numbers and not full names should be entered when creating users.
    5Enter the user name by turning and pressing the adjusting dial
    6Select "OK"
    "Edit user" is displayed.
    7By turning the dial, select the desired entry, press the dial to edit the entry:
    • Username *
    • Role **
    • First name *
    • Last name *
    • Language **
    • Unit **
    • Standard **
    • NFC card:
      Follow the instructions shown
      (hold the new NFC key on the NFC key read zone and wait for the recognition confirmation)
    • Web password *
    • Mobile device:
      Follow instructions on the WeldConnect app
    * Input via keyboard
    ** Select from list
    8Select "Save" and press the adjusting dial
    1. Setup settings
    2. Create users and roles
    Creating a user
    NOTE!
    NOTE!
    6Select "OK"
    • Username *
    • Role **
    • First name *
    • Last name *
    • Language **
    • Unit **
    • Standard **
    • NFC card:
    • Web password *
    • Mobile device:
    ** Select from list
    1. Setup settings
    Creating roles
    1Defaults / User management / Create role - overview
    The list of existing roles is displayed.
    3Turn the dial and select "Create new role"
    5Enter the role name by turning and pressing the adjusting dial
    6Select "OK"
    "Edit role" is displayed.
    7Select the functions that can be carried out by this role by turning the adjusting dial, press the adjusting dial to enable the function.
    Symbols:
    ... hidden
    ... read only
    ... read and write
    1. Setup settings
    Editing users
    3Turn the adjusting dial and select the user to be edited
    5By turning the dial, select the desired entry, press the dial to edit the entry:
    Input via keyboard or selection from list
    7Select "Save" and press the adjusting dial
    1. Setup settings
    2. Edit user / roles, deactivate user administration
    Editing users
    1. Setup settings
    Editing roles
    3Turn the adjusting dial and select the role to be changed
    5Select the desired function by turning the adjusting dial, press the adjusting dial to edit the function
    1. Setup settings
    Deactivating user management
    3Select the predefined user “admin”
    4Turn the adjusting dial and select “NFC card”
    The NFC card replacement or deletion prompt appears.
    NOTE!
    If the NFC card is deleted by the predefined “admin” user, user management is deactivated.
    6Select “delete”
    User management is deactivated, the welding machine is locked.
    The welding machine can be locked and unlocked again with any NFC key (see page (→)).
    1. Setup settings
    CENTRUM - Central User Management
    Activating the CENTRUM server
    CENTRUM is a piece of software for the central management of users. Detailed information is available in the CENTRUM Operating Instructions (42,0426,0338,xx).
    The CENTRUM server can also be activated directly on the welding machine, as follows:
    1Defaults / User management / CENTRUM server
    “CENTRUM server settings” is displayed.
    4Select “CENTRUM server activated” and press the adjusting dial
    5Select “CENTRUM server”, press the adjusting dial and enter the address of the CENTRUM server using the keyboard
    6Select OK
    7Select the “Verify” button
    8Save
    1. Setup settings
    2. CENTRUM - Central User Management
    6Select OK
    8Save
    1. Setup settings
    Management
    Trial license
    The trial license allows you to use and test all currently available functional packages free of charge on the welding machine.
    Once the trial license is activated, all functional packages and extensions are available for a period of 10 hours of arc time. A warning message appears 2 hours before the trial license expires.
    An activated trial license cannot be interrupted, an expired trial license cannot be reactivated.
    The trial license is supplied as standard with the welding machine.
    1. Setup settings
    2. Management
    Trial license
    1. Setup settings
    2. Management
    Activating the trial license
    1Defaults / Management / Trial License
    The information for activating the trial license is displayed.
    3Select "Next"
    4Register via WeldConnect
    5Select "Next"
    6Start trial license by selecting "Next"
    7Confirm prompt
    The confirmation that the trial license has been started is displayed.
    8Select "Exit"
    Under Management, the remaining time until the trial license expires is displayed.
    1. Setup settings
    System informations
    Device information
    The following data is displayed in device information:
    Serial number
    Image version
    Software ver.
    IP addr.(es)
    Show open source licences...
    • Turn the adjusting dial to select "Show open source licences..."
    • Press the adjusting dial
      The open source licences used are displayed.
    • Select close by turning the adjusting dial
    1. Setup settings
    2. System informations
    Device information
    Serial number
    Image version
    Software ver.
    IP addr.(es)
    SmartManager - the welding machine website
    General
    The welding machine has its own website: SmartManager.
    As soon as the welding machine is connected to a computer using a network cable, or is on a network, the welding machine's SmartManager can be retrieved using the welding machine's IP address.
    At least IE 10 or a similar modern browser is required to access SmartManager.
    The entries displayed on SmartManager may vary depending on system configuration, software upgrades and available options.
    Examples of entries displayed:
    • Current system data
    • Documentation, logbook
    • Job data (only if the OPT/i Jobs function package is present)
    • Welding machine settings
    • Backup & restore
    • User management
    • Overview
    • Update
    • Function packages
    • Screenshot
    1. SmartManager - the welding machine website
    General
    • Backup & restore
    • User management
    • Overview
    • Update
    • Function packages
    • Screenshot
    2. SmartManager - the welding machine website
    General
    • Backup & restore
    • User management
    • Overview
    • Update
    • Function packages
    • Screenshot
    Opening the welding machine SmartManager
    1Note down the IP address for the welding machine in system information
    2Enter the IP address in the browser search field
    3Enter the user name and password
    Factory settings for user name and password
      User name = admin
      Password = admin
    4Confirm the displayed notice.
    The unique password does not have to be changed when logging in to the SmartManager for the first time.
    The SmartManager of the welding machine is displayed.
    Fronius
    A click on the Fronius logo opens the homepage of Fronius: www.fronius.com.
    Changing password / logging off
    By clicking this symbol
    • the user password can be changed
    • you can log out of SmartManager
    Changing the password for the SmartManager:
    1Enter the old password
    2Enter the new password*
    3Repeat the new password
    4Click on "Save"
    A password must meet the following criteria:
    • The password must be at least 10 and at most 16 characters long.
    • Three of the following four criteria must be met:
      Uppercase letters A - Z
      Lowercase letters a - z
      Digits 0 - 9
      Special characters , . @ = + - * / ~ " ° _ # ( ) ! ? & % : ;
    Language
    link_horizontalLink copied
    The languages available for SmartManager can be displayed by clicking on this symbol.
    The current language selection is displayed next to the symbol.
    To change the language, click on the one you would like.
    Current system data
    Current system data
    Depending on the welding process, the current data on the welding system is displayed, e.g.:
    TIG
    • Process
    • ACTUAL or HOLD
    • Welding current
    • Welding voltage
    • Current arc power
    • Current arc energy
    • Coolant flow *
    • Coolant temperature *
    • Shielding gas flow rate
    • Arc time
    • Total operating hours
    • Operating mode
    Rod electrode / CEL
    • Process
    • ACTUAL or HOLD
    • Welding current
    • Welding voltage
    • Starting current
    • Arc-force dynamic
    • Current arc power
    • Arc time
    Job
    • Process / Job name / Job no.
    • Additional data as per the welding process saved under the job
    Only if cooling unit with OPT/i CU flow temperature sensor option fitted is being used
    2. Current system data
    Current system data
    TIG
    • Process
    • ACTUAL or HOLD
    • Welding current
    • Welding voltage
    • Current arc power
    • Coolant flow *
    • Arc time
    • Operating mode
    Rod electrode / CEL
    • Process
    • ACTUAL or HOLD
    • Welding current
    • Welding voltage
    • Starting current
    • Arc-force dynamic
    • Current arc power
    • Arc time
    Job
    Documentation logbook
    Logbook
    The last 100 logbook entries are shown in the Logbook entry. These logbook entries can be welding operations, errors, warnings, notifications and events.
    Press the “Time filter” button to restrict the data to a specific period of time. To do so, the date (yyyy MM dd) and time (hh mm) are entered in the from – to format in each case.
    A blank filter loads the latest welding operations again.
    The option to show welding operations and events can be disabled.
    The following data is displayed:
    (1)
    (2)
    Start time (date and time)
    (3)
    (4)
    (5)
    (6)
    IP - arc power in W (from real-time values in accordance with ISO/TR 18491)
    (7)
    IE - arc energy in kJ (in total across the entire weld in accordance with ISO/TR 18491)
    Jobs are also displayed if present in the system.
    Clicking on a logbook entry will display details.
    Details for welds:
    • Section no.
    • Duration of the welding section in s
    • Welding current in A (average value)
    • Welding voltage in V (average value)
    • Welding speed (cm/min)
    • Arc power from real-time values in W
    • Arc energy in kJ
    • Job no.
    • Process
    Further values can be displayed by clicking on the “Insert column” button, such as the start time (welding machine time).
    If the OPT/i documentation option is available on the welding machine, individual welding sections can also be displayed.
    This documentation can be exported in the desired format using the “PDF” and “CSV” buttons.
    In order to create CSV exports, the OPT/i documentation option must be available on the welding machine.
    2. Documentation logbook
    Logbook
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (7)
    Details for welds:
    • Section no.
    • Arc energy in kJ
    • Job no.
    • Process
    Basic settings
    The sampling rate for the documentation can be set in the basic settings entry.
    Job-Data
    Job data
    The Job data entry is only displayed if the FP Job function package is present in the welding machine.
    In the “Job data” entry,
    • existing welding system jobs can be viewed
    • Existing welding system jobs can be optimised
    • Jobs stored externally can be transferred to the welding system
    • Existing jobs in the welding system can be exported as a PDF * or CSV file
    2. Job-Data
    Job data
    2. Job-Data
    Job overview
    The job overview lists all jobs stored in the welding system.
    Clicking on a job displays the data and parameters stored for this job.
    Job data and parameters can only be viewed in the job overview. The column width for parameters and values can be easily dragged and adjusted with the mouse pointer.
    Other jobs can easily be added to the list with the data listed by clicking on the “Add column” button.
    This offers a simple way of comparing the values from various jobs.
    2. Job-Data
    Editing a job
    Existing welding system jobs can be edited.
    1Click on “Edit job”
    2Click on the job to be amended in the list of available jobs
    The selected job is opened and the following job data is shown:
    • Parameter
      The parameter currently stored in the job
    • Value
      The values of the parameter currently stored in the job
    • Change value to
      To enter the new parameter value
    • Setting range
      Possible setting range for the new parameter values
    3Amend the values accordingly
    4Save / Delete adjustments, Save as / Delete job
    As an aid when editing a job, other jobs can be easily added to the list with the data displayed by clicking on “Add column”.
    Creating a new job
    1Click on “Create new job”
    2Enter job data
    3Click on “OK” to apply the new job
    2. Job-Data
    Importing a job
    This function enables previously exported jobs to be transferred into the welding system.
    1Click on "Search Job-file"
    2Select desired job file
    Individual jobs can be selected and new job numbers assigned in the preview of the job import list.
    3Click on "Import Job"
    If the import is successful, a corresponding confirmation is displayed and the imported jobs appear in the list.
    2. Job-Data
    Exporting a job
    This function enables jobs to be exported from the welding machine and saved externally.
    1Select jobs to be exported:
    • Click on the job and the arrow
      or
    • Double-click on the job
      or
    • Drag & drop
    2Click on “Export Job”
    The jobs are exported as an XML file into the computer’s Download folder.
    2. Job-Data
    Export job(s) as…
    Existing jobs in the welding system can be exported as a PDF or CSV file under Job overview and Edit job.
    1Click on “Export job(s) as...”
    The PDF or CSV settings are displayed.
    2Select the job(s) to be exported:
    current job / all jobs / job numbers
    3Click on “Save PDF” or “Save CSV”
    A PDF or CSV file containing the selected jobs is created and saved according to the settings of the browser in question.
    Backup & Restore
    General
    In the backup & restore entry
    • all welding system data can be saved as a backup (e.g. current parameter settings, jobs, defaults, etc.),
    • any existing backups can be restored to the welding system
    2. Backup & Restore
    General
    2. Backup & Restore
    Backup & restore
    Starting backup
    1Click on “Start backup” to save a backup of the welding system data
    The data is saved in a selected location in the default format
    Backup_SNxxxxxxxx_YYYY_MM_DD_HHmmSS.fbc.
    SNxxxxxxxx = Serial number (8-digit)
    YYYY = Year
    MM = Month
    DD = Day
    HH = Hour
    mm = Minute
    SS = Second
    The date and time correspond to the welding machine settings.
    Searching for a restore file
    1Click on “Search restore file” to transfer an existing backup to the welding machine
    2Select the file and click on “Open"
    The selected backup file is displayed on the welding machine’s SmartManager under “Restore”.
    3Click on “Start recovery"
    Once the data has been successfully restored, a confirmation to this effect is displayed.
    User management
    General
    In the user management entry
    • users can be created, viewed and changed.
    • user roles can be created, viewed and changed.
    • users and user roles can be exported or imported on the welding machine.
      User management data present on the welding machine is overwritten by importing.
    • a CENTRUM server can be activated.
    User management is created on a welding machine and can then be saved with the export/import function and transferred to other welding machines.
    2. User management
    General
    2. User management
    Users
    Existing users can be viewed, changed and deleted; new users can be created.
    Viewing/changing a user:
    1Select user
    2Alter the user data directly in the display field
    3Save changes
    Deleting a user:
    1Select user
    2Click the "Delete user" button
    3When prompted, confirm with OK
    Creating a user:
    1Click the "Create new user" button
    2Enter user data
    3Confirm with OK
    2. User management
    User roles
    Existing user roles can be viewed, changed and deleted, new user roles can be created
    Viewing/changing a user role:
    1Select user role
    2Alter the user role directly in the display field
    3Save changes
    The "Administrator" role cannot be changed.
    Deleting a user role:
    1Select user role
    2Click the "Delete user role" button
    The "Administrator" and "Locked" roles cannot be deleted.
    Creating a user role:
    1Click the "Create new user role" button
    2Enter a role name, apply values
    3Confirm with OK
    2. User management
    Export & import
    Exporting users and user roles from a welding machine
    1Click on "Export"
    The user management data from the welding machine will be saved to the "Downloads" folder on the computer.
    File format: userbackup_SNxxxxxxxx_YYYY_MM_DD_hhmmss.user
    SN = Serial number, YYYY = Year, MM = Month, DD = Day
    hh = hour, mm = minute, ss = second
    Importing users and user roles to a welding machine
    1Click on "Search user data file"
    2Select the file and click "Open"
    3Click on "Import"
    The user management data will be saved to the welding machine.
    2. User management
    CENTRUM server
    For activating a CENTRUM server
    (CENTRUM = Central User Management)
    1Activate CENTRUM server
    2In the input field, enter the domain name or IP address of the server where Central User Management has been installed.
    A valid DNS server must be configured in the welding machine network settings if using a domain name.
    3Click the "Verify server" button
    This checks the availability of the specified server.
    4Save changes
    Overview
    Overview
    In the overview entry, welding system components and options are displayed with all available information, e.g. firmware version, item number, serial number, production date, etc.
    2. Overview
    Overview
    2. Overview
    Expanding / reducing all groups
    Clicking on the button “Expand all groups” displays further details for the individual system components.
    Welding machine example:
    • TT/MW Smart: Item number
      BCU1-COM: Item number, version, serial number, production date
      Bootloader: Version
      Image: Version
      Licences: ...
    • SC2: Item number
      Firmware: Version
    Clicking on the button “Reduce all groups” hides the details for the system components.
    2. Overview
    Export component overview as ...
    Click the "XML" button to create an XML file of the system component details. This XML file can either be opened or saved.
    Update
    Update
    The welding machine firmware can be updated in the "Update" entry.
    The current version of the firmware on your welding machine is displayed.
    The update file can be downloaded via the following link:
    https://www.fronius.com/iwave-downloads
    To update the welding machine firmware:
    1Organise and save the update file
    2Click on "Search update file"
    3Select and open the update file
    The selected update file is displayed on the welding machine SmartManager under "Update file".
    Click on "Update"
    A progress bar is displayed above the update process.
    When this reaches 100%, you will be prompted to restart the welding machine
    SmartManager is not available during the restart.
    After the restart, SmartManager may not be available any more.
    If you select "No", the new software functions are activated when you next switch the device on/off.
    4To restart the power source, click on "Yes"
    The welding machine restarts; the display goes black for a short time.
    The Fronius logo is shown on the welding machine display during the restart.
    Once the update has been completed successfully, a confirmation and the current firmware version are displayed.
    5You can now log on to SmartManager again
    2. Update
    Update
    Click on "Update"
    Function Packages
    Function packages
    In the Function Packages entry, the function packages present on the welding machine are displayed.
    New function packages can be uploaded.
    2. Function Packages
    Function packages
    Installing a function package
    1Organise and save a function package
    2Click on "Search function package file"
    3Select the desired function package file (*.xml)
    4Click on "Open"
    The selected function package file is displayed on the welding machine's SmartManager under "Install function package".
    5Click on "Install function package"
    Once the function package has been successfully installed, a confirmation to this effect is displayed.
    Screenshot
    Screenshot
    In the Screenshot entry, a digital image of the welding machine display can be created at any time, irrespective of the navigation or set values.
    1Click on "Create screenshot" to capture a screenshot of the display
    A screenshot of the currently displayed settings is created.
    Different functions are available for saving the screenshot depending on the browser used; the display may vary.
    2. Screenshot
    Screenshot
    Troubleshooting and maintenance
    Troubleshooting
    General
    The welding machines are equipped with an intelligent safety system. This means that apart from the fuse for the coolant pump, it has been possible to dispense with fuses entirely. After a possible malfunction or error has been remedied, the welding machine can be put back into normal operation again without any fuses having to be replaced.
    1. Troubleshooting and maintenance
    Troubleshooting
    General
    2. Troubleshooting
    General
    2. Troubleshooting
    Safety
    WARNING!
    Fully read and understand this document.
    WARNING!
    Danger from electric current.
    Before starting maintenance or servicing work, switch off all the devices and components involved and disconnect them from the mains.
    Secure all the devices and components involved to prevent unintentional restarting.
    CAUTION!
    Danger from inadequate ground conductor connections.
    This can result in injury and damage to property.
    The housing screws provide a suitable ground conductor connection for earthing the housing.
    The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
    2. Troubleshooting
    Troubleshooting the welding machine
    Welding machine does not function
    Mains switch is on, but indicators are not lit up
    Cause:There is a break in the mains lead; the mains plug is not plugged in
    Remedy:Check the mains lead, ensure that the mains plug is plugged in
    Cause:Mains socket or mains plug faulty
    Remedy:Replace faulty parts
    Cause:Mains fuse
    Remedy:Change the mains fuse protection
    No welding current
    Mains switch is ON, overtemperature indicator is lit up
    Cause:Overloading
    Remedy:Check duty cycle
    Cause:Thermostatic automatic circuit breaker has tripped
    Remedy:Wait until the welding machine automatically switches back on after the end of the cooling phase
    Cause:Faulty fan in welding system
    Remedy:Contact After-Sales Service
    No welding current
    Mains switch is on, indicators are lit up
    Cause:Grounding (earthing) connection is incorrect
    Remedy:Check the grounding (earthing) connection and terminal for correct polarity
    Cause:There is a break in the current cable in the welding torch
    Remedy:Replace welding torch
    Nothing happens when the torch trigger is pressed
    Cause:The control plug is not plugged in
    Remedy:Plug in the control plug
    Cause:Welding torch or welding torch control line is faulty
    No protective gas shield
    All other functions are OK
    Cause:Gas cylinder is empty
    Remedy:Change the gas cylinder
    Cause:Gas pressure regulator is faulty
    Remedy:Change the gas pressure regulator
    Cause:Gas hose is not fitted or is damaged
    Remedy:Fit or change the gas hose
    Cause:Welding torch is faulty
    Remedy:Change the welding torch
    Cause:Gas solenoid valve is faulty
    Poor weld properties
    Cause:Incorrect welding parameters
    Remedy:Check the settings
    Welding torch becomes very hot
    Cause:Welding torch is inadequately dimensioned
    Remedy:Observe the duty cycle and loading limits
    Cause:Only on water-cooled systems: inadequate coolant flow
    Remedy:Check coolant level, flow rate, contamination, etc.;
    coolant pump blocked: use a screwdriver - placed on the bushing - to turn the coolant pump shaft
    Cause:Only on water-cooled systems: The "Cooling unit operating mode" setup parameter is set to "Off".
    Remedy:In the Setup menu, change the parameter "Cooling unit operating mode" to "eco", "On" or "auto" under the component settings.
    Care, maintenance and disposal
    General
    Under normal operating conditions, the welding machine requires only a minimum of care and maintenance. However, certain points must be observed to ensure that the welding machine gives reliable service for many years.
    2. Care, maintenance and disposal
    General
    Safety
    WARNING!
    WARNING!
    CAUTION!
    At every start-up
    • Check mains plug, mains cable, welding torch, interconnecting hosepack and ground earth connection for damage
    • Check that the device has an all-round clearance of 0.5 m (1 ft. 8 in.) to ensure that cooling air can flow in and out freely
    NOTE!
    The air inlets and outlets must never be covered, not even partially.
    Every 2 months
    • If present: clean air filter
    Every 6 months
    CAUTION!
    Danger due to the effect of compressed air.
    Do not bring the air nozzle too close to electronic components.
    1Dismantle device side panels and clean inside of device with dry, reduced compressed air
    2If a lot of dust has accumulated, clean the cooling air ducts
    WARNING!
    Risk of electric shock from improperly connected ground cables and equipment grounds.
    An electric shock can be fatal!
    When reassembling the side panels, make sure that grounding cables and equipment grounds are properly connected.
    Disposal
    Packaging materials
    • Collect separately
    • Observe locally valid regulations
    • Compress the cardboard box to reduce volume
    Appendix
    Technical data
    Explanation of the term "duty cycle"
    Duty cycle (ED) is the proportion of time in a 10-minute cycle at which the device may be operated at its rated output without overheating.
    NOTE!
    The ED values specified on the rating plate are based on an ambient temperature of 40 °C.
    If the ambient temperature is higher, either the ED or output must be reduced accordingly.
    Example: Welding at 150 A at 60% ED
    • Welding phase = 60% of 10 minutes = 6 minutes
    • Cooling phase = remaining time = 4 minutes
    • After the cooling phase, the cycle begins again.
    If the device is to be continuously operated without stopping:
    1Look in the technical data for a ED value of 100% for the current ambient temperature.
    2Reduce the output or amperage in line with this value so that the device can remain in use without observing a cooling phase.
    1. Appendix
    Technical data
    NOTE!
    1. Appendix
    2. Technical data
    NOTE!
    1. Appendix
    2. Technical data
    Overview with critical raw materials, year of production of the device
    Overview with critical raw materials:
    An overview of which critical raw materials are contained in this device can be found at the following Internet address.
    <HyperContainer>https://www.fronius.com/welding-technology/downloads
    </HyperContainer>
    Find downloads: critical
    To calculate the year of production of the device:
    • Each device is provided with a serial number
    • The serial number consists of 8 digits - for example 28020099
    • The first two digits give the number from which the year of production of the device can be calculated
    • This figure minus 11 gives the year of production
      • For example: Serial number = 28020065, calculation of the year of production = 28 - 11 = 17, year of production = 2017
    1. Appendix
    2. Technical data
    Special voltages
    CAUTION!
    An inadequately dimensioned electrical installation can cause serious damage.
    The mains lead and its fuse must be dimensioned accordingly.
    The technical data shown on the rating plate applies.
    1. Appendix
    2. Technical data
    Average shielding gas consumption during TIG welding
    Gas nozzle size
    5
    6
    7
    8
    10
    Average consumption
    6 l/min
    8 l/min
    10 l/min
    12 l/min
    12 l/min
    15 l/min
    1. Appendix
    2. Technical data
    Environmental conditions
    Ambient air temperature range:
    during operation
    during transport and storage
    -10 °C to + 40 °C / 14 °F to 104 °F
    -20 °C to +55 °C / -4 °F to 131 °F
    Relative humidity of the ambient air:
    at 40 °C / 104 °F
    at 20 °C / 68 °F
    max. 50%
    max. 90%
    1. Appendix
    2. Technical data
    Versions of the appliance
    Depending on the ending of the device name, the devices are available in the following versions:
    /EF
    Device with fitted European mains cable
    /np
    Device with fitted mains cable without plug
    /MV/B
    Multi Voltage device with mounted US mains cable
    /MV/np
    Multi Voltage device with mounted US mains cable without plug
    1. Appendix
    2. Technical data
    iWave 190i AC/DC
    Mains voltage U1
    1 x 230 V
    Mains voltage tolerance
    ± 15%
    Grid frequency
    50/60 Hz
    Mains fuse protection (slow-blow)
    16 A
    Mains connection1)
    Zmax on PCC3) = 315 mOhm
    Cos phi
    0.99
    Primary power module S1max (at 100% ED2))
    TIG
    2.7 kVA
    Electrode
    3.55 kVA
    Welding current range
    TIG
    3-190 A
    Electrode
    10-170 A
    Welding current at
    10 min/40°C (104°F) 35% ED2)
    190 A 4)
    170 A 5)
    10 min/40°C (104°F) 60% ED2)
    160 A 4)
    140 A 5)
    10 min/40°C (104°F) 100% ED2)
    140 A 4)
    120 A 5)
    Open circuit voltage
    100 V
    Working voltage
    TIG
    10.1-17.6 V
    Electrode
    20.4-26.8 V
    Striking voltage (Up)
    9.6 kV
    The arc striking voltage is suitable for manual operation.
    Protection class
    IP 23
    Type of cooling
    AF
    Overvoltage category
    III
    Pollution degree according to IEC 60664
    EMC device class
    A 6)
    Insulation class
    B
    Dimensions L/W/H (with handle)
    558/210/369 mm / 22.0/8.3/14.5 in.
    Weight
    17.0 kg / 37.5 lb.
    Mark of conformity
    S, CE
    Max. shielding gas pressure
    6 bar / 87.02 psi
    Noise emission (LWA)
    68 dB(A)
    Idle state power consumption at 230 V
    23.8 W
    Welding machine efficiency at 170 A / 26.8 V
    84%
    1. Appendix
    2. Technical data
    iWave 190i AC/DC /MV
    Mains voltage U1
    1 x 120 / 230 V
    ± 15%
    Grid frequency
    50/60 Hz
    16 A (U1 = 230 V)
    20 A (U1 = 120 V)
    Mains connection1)
    Cos phi
    0.99
    TIG
    2.7 kVA (U1 = 230 V)
    1.84 kVA (U1 = 120 V)
    Electrode
    3.55 kVA (U1 = 230 V)
    1.94 kVA (U1 = 120 V)
    TIG
    3-190 A
    Electrode
    10-170 A
    Welding current at
    190 A 4) (U1 = 230 V)
    150 A 4) (U1 = 120 V)
    170 A 5) (U1 = 230 V)
    100 A 5) (U1 = 120 V)
    160 A 4) (U1 = 230 V)
    120 A 4) (U1 = 120 V)
    140 A 5) (U1 = 230 V)
    80 A 5) (U1 = 120 V)
    140 A 4) (U1 = 230 V)
    100 A 4) (U1 = 120 V)
    120 A 5) (U1 = 230 V)
    70 A 5) (U1 = 120 V)
    100 V
    Working voltage
    TIG
    10.1-17.6 V
    Electrode
    20.4-26.8 V
    9.6 kV
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC device class
    A 6)
    Insulation class
    B
    Weight
    16.5 kg / 36.4 lb.
    Mark of conformity
    S, CE, CSA 7)
    6 bar / 87.02 psi
    68 dB(A)
    23.8 W
    84%
    1. Appendix
    2. Technical data
    iWave 230i AC/DC
    Mains voltage U1
    1 x 230 V
    ± 15%
    Grid frequency
    50/60 Hz
    16 A
    Mains connection1)
    Zmax on PCC3) = 273 mOhm
    Cos phi
    0.99
    TIG
    3540 VA
    Electrode
    3540 VA
    TIG
    3-230 A
    Electrode
    10-190 A
    Welding current at
    230 A 4)
    190 A 5)
    195 A 4)
    150 A 5)
    165 A 4)
    120 A 5)
    100 V
    Working voltage
    TIG
    10.1-19.2 V
    Electrode
    20.4-27.6 V
    9.6 kV
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC device class
    A 6)
    Insulation class
    B
    Weight
    17.0 kg / 37.5 lb.
    Mark of conformity
    S, CE
    6 bar / 87.02 psi
    68 dB(A)
    23.7 W
    Welding machine efficiency at 190 A / 27.6 V
    84%
    1. Appendix
    2. Technical data
    iWave 230i AC/DC /MV
    Mains voltage U1
    1 x 120 / 230 V
    ± 15%
    Grid frequency
    50/60 Hz
    16 A (U1 = 230 V)
    20 A (U1 = 120 V)
    Mains connection1)
    Cos phi
    0.99
    TIG
    3540 VA (U1 = 230 V)
    2390 VA (U1 = 120 V)
    Electrode
    2410 VA (U1 = 120 V)
    TIG
    3-230 A
    Electrode
    10-190 A
    Welding current at
    230 A 4) (U1 = 230 V)
    170 A 4) (U1 = 120 V)
    190 A 5) (U1 = 230 V)
    120 A 5) (U1 = 120 V)
    195 A 4) (U1 = 230 V)
    140 A 4) (U1 = 120 V)
    150 A 5) (U1 = 230 V)
    105 A 5) (U1 = 120 V)
    165 A 4) (U1 = 230 V)
    85 A 5) (U1 = 120 V)
    100 V
    Working voltage
    TIG
    10.1-19.2 V
    Electrode
    20.4-27.6 V
    9.6 kV
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC device class
    A 6)
    Insulation class
    B
    Weight
    16.5 kg / 36.4 lb.
    Mark of conformity
    S, CE, CSA 7)
    6 bar / 87.02 psi
    68 dB(A)
    23.7 W
    84%
    1. Appendix
    2. Technical data
    iWave 230i DC
    Mains voltage U1
    1 x 230 V
    ± 15%
    Grid frequency
    50/60 Hz
    16 A
    Mains connection1)
    Cos phi
    0.99
    TIG
    3.36 kVA
    Electrode
    3.59 kVA
    TIG
    3-230 A
    Electrode
    10-190 A
    Welding current at
    190 A 5)
    10 min/40°C (104°F) 45% ED2)
    230 A 4)
    205 A 4)
    155 A 5)
    170 A 4)
    125 A 5)
    97 V
    Working voltage
    TIG
    10.1-19.2 V
    Electrode
    20.4-27.6 V
    9.6 kV
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC device class
    A 6)
    Insulation class
    B
    Weight
    16.4 kg / 36.2 lb.
    Mark of conformity
    S, CE
    6 bar / 87.02 psi
    68 dB(A)
    24.4 W
    87%
    1. Appendix
    2. Technical data
    iWave 230i DC /MV
    Mains voltage U1
    1 x 120 / 230 V
    ± 15%
    Grid frequency
    50/60 Hz
    16 A (U1 = 230 V)
    20 A (U1 = 123 V)
    Mains connection1)
    Cos phi
    0.99
    TIG
    3.36 kVA (U1 = 230 V)
    2.38 kVA (U1 = 120 V)
    Electrode
    3.59 kVA (U1 = 230 V)
    2.32 kVA (U1 = 120 V)
    TIG
    3-230 A
    Electrode
    10-190 A
    Welding current at
    205 A 4) (U1 = 230 V)
    155 A 4) (U1 = 120 V)
    155 A 5) (U1 = 230 V)
    170 A 4) (U1 = 230 V)
    130 A 4) (U1 = 120 V)
    125 A 5) (U1 = 230 V)
    97 V
    Working voltage
    TIG
    10.1-19.2 V
    Electrode
    20.4-27.6 V
    9.6 kV
    Protection class
    IP 23
    Type of cooling
    AF
    III
    EMC device class
    A 6)
    Insulation class
    B
    Weight
    15.9 kg / 35.1 lb.
    Mark of conformity
    S, CE, CSA 7)
    6 bar / 87.02 psi
    68 dB(A)
    24.4 W
    87%
    1. Appendix
    2. Technical data
    Explanation of footnotes
    1)
    Connected to public grids with 230 / 400 V and 50 Hz
    2)
    ED = Duty cycle
    3)
    PCC = interface to the public grid
    4)
    TIG welding
    5)
    Manual metal arc welding
    6)
    An emission class A device is not designed for use in residential areas supplied with power from a public low-voltage grid.
    The electromagnetic compatibility can be influenced by conducted or radiated radio frequencies.
    7)
    CSA certification only for /MV/B devices
    1. Appendix
    2. Technical data
    Radio parameters
    Conformity with Directive 2014/53 / EU - Radio Equipment Directive (RED)
    The following table contains the frequency ranges and maximum HF transmission power used by Fronius wireless products sold in the EU in accordance with Article 10.8 (a) and 10.8 (b) of the RED.
    Frequency range
    Channels used
    Power
    Modulation
    2412 - 2462 MHz
    Channel: 1 - 11 b ,g, n HT20
    Channel: 3 - 9 HT40
    < 16 dBm
    802.11b: DSSS
    (1Mbps DBPSK, 2Mbps DQPSK, 5.5/11Mbps CCK)
    802.11g: OFDM
    (6/9Mbps BPSK, 12/18Mbps QPSK, 24/36Mbps 16-QAM, 48/54Mbps 64-QAM)
    802.11n: OFDM
    (6.5Mbps BPSK, 13/19 Mbps QPSK, 26/39 Mbps16-QAM,52/58.5/65Mbps 64-QAM)
    13.56 MHz
    -14.6 dBµA/m at 10 m
    Functions:
    R/W, card emulation and P2P
    Protocol standards:
    ISO 14443A/B, ISO15693, ISO18092,
    NFCIP-2,
    Data rate:
    848 kbps
    Reader/Writer, Card Emulation, Peer to Peer Modes
    2402 - 2482 MHz
    0 - 39
    < 4 dBm
    GFSK
