The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device mustFor the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
The device is intended exclusively for the welding process specified on the rating plate.
Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose."
The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
The manufacture shall also not be liable for faulty or incorrect work results.
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
This may affect a number of device types in terms of:*) both at the interface with the public grid
See technical data
In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
IMPORTANT! Ensure secure grounding of the grid connection!
The fumes produced during welding contain toxic gases and vapors.
Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
Use at-source extraction source and a room extraction system.
If possible, use a welding torch with an integrated extraction device.
Keep your head out of the welding fumes and gases.
Take the following precautionary measures for fumes and harmful gases:Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
Use a welding helmet with air supply if there is insufficient ventilation.
If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
The following components are factors that determine how toxic the welding fumes are:Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
Flying sparks can cause fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
Keep suitable, tested fire extinguishers on hand.
Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
Do not touch voltage-carrying parts inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wire spool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Before every use, check power connections for secure fit by hand.
In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
Do not wrap cables or leads around your body or parts of the body.
Concerning the electrode (stick electrode, tungsten electrode, welding wire, etc.)The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence.
Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
Switch off unused devices.
When working at elevated heights, wear a safety harness to prevent falls.
Before working on the device, switch off the device and remove the mains plug.
Secure the device to prevent the mains plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
After opening the device:If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Covers and side panels must only be opened/removed during maintenance and repair work.
During operationThe welding wire protruding from the welding torch poses a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
Do not touch the workpiece during or after welding—risk of burns.
Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Leave the welding torch and other parts with a high operating temperature to cool before working on them.
Special regulations apply in areas at risk of fire or explosion
– follow the appropriate national and international regulations.
Welding machines for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the welding machine may not be located in such areas.
Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
Welding with the device during crane transport is only permitted if this is clearly stated in the intended use of the device.
If the device is equipped with a carrier strap or handle, then this is used exclusively for transport by hand. The carrier strap is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
All lifting equipment (straps, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
The test interval and scope must at least comply with the respective valid national standards and guidelines.
There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
Use filters if necessary.
Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
Keep shielding gas cylinders away from welding or other electrical circuits.
Risk of explosion: Never weld on a compressed shielding gas cylinder.
Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
When no welding is taking place, close the valve of the shielding gas cylinder.
Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
Risk of asphyxiation due to uncontrolled shielding gas leak
Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
Do not lift or transport any active devices. Switch off and disconnect devices from the grid before transport or lifting.
Before transporting a welding system (e.g., with a trolley, cooling unit, welding machine, and wirefeeder), completely drain the coolant and dismantle the following components:It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is switched on.
Before switching on the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
Always secure the shielding gas cylinder well and remove before transporting by crane.
Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
Only use appropriate original coolant from the manufacturer.
Do not mix original coolant from the manufacturer with other coolants.
Only connect system components from the manufacturer to the cooling unit circuit.
Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
When the system is cool, always check the coolant level before starting welding.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating welding machines within the same 12-month interval.
A safety inspection by a qualified electrician is recommendedWhen performing the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your Fronius branch or your Fronius partner, who will provide the necessary documents upon request.
The full text of the EU Declaration of Conformity is available at
https://www.fronius.com .
Devices bearing the CSA label satisfy the requirements of the relevant standards for Canada and the USA.
TWIN welding systems are used exclusively with automated MIG/MAG applications, e.g.:
TWIN welding torch
+ Fixing bracket
+ Index disk
MTB 2x500i PA or PB
+ OPT/i MTB xx° sym.
or
MTB 900i PA or PB
CrashBox
TWIN hosepack
MHP 2x500 A W/FSC
+ TWIN Basic Kit (depending on material and wire diameter)
TWIN wirefeeder
WF 30i R /TWIN
Wirefeeder holder
WF MOUNTING TWIN
Interconnecting hosepacks
1 x HP 95i CON /W /xx m
1 x HP 95i CON /G /xx m
2 x wirefeeding hose (max. 3 m)
or
2 x Fronius PowerLiner (max. 10 m)
2 x welding machine
TPS 500i / 600i
+ Welding Package Pulse
+ Firmware official_TPSi_2.2.3-20789.15069.ffw and higher
Cooling unit
CU 2000i Pro /MC (2-part)
TWIN Controller
RI FB Pro/i TWIN Controller
+ Firmware official_robpro-1.8.xx-svn6108_official
2 x return lead cable
TWIN welding torch
+ Fixing bracket
+ Index disk
MTB 2x500i PA or PB
or
MTB 900i PA or PB
CrashBox
TWIN hosepack
MHP 2x500 A W/FSC
TWIN wirefeeder
WF 30i R /TWIN
Wirefeeder holder
WF MOUNTING TWIN
or
2 x welding machine
TPS 500i / 600i
Cooling unit
TWIN Controller
TWIN welding torch
+ Fixing bracket
+ Index disk
MTB 2x500i PA or PB
or
MTB 900i PA or PB
CrashBox
TWIN hosepack (with TWIN drive unit WF 60i TWIN Drive)
MHP 2x450i RD/W/FSC
+ Toothed drive roller CMT
+ Toothed pressure roller CMT
TWIN wirefeeder
WF 30i R /TWIN
+ OPT/i WF TWIN R Push Pull
Wirefeeder holder
or
2 x welding machine
TPS 500i / 600i
+ Firmware official_TPSi_3.2.0-xxxxx.xxxxx.ffw and higher
Cooling unit
TWIN Controller
+ Firmware official_robpro-1.8.0
TWIN welding torch
+ Fixing bracket
+ Index disk
MTB 2x500i PA or PB
or
MTB 900i PA or PB
CrashBox
MHP 2x450i RD/W/FSC
TWIN wirefeeder
WF 30i R /TWIN
Wirefeeder holder
TWIN wire buffer set
or
2 x welding machine
TPS 500i / 600i
+ Welding Package Standard
+ Welding Package CMT
Cooling unit
TWIN Controller
The following mechanical requirements must be met in order to achieve a stable and reproducible TWIN welding process:
The use of the following devices is recommended in order to increase the system availability:
Robacta TSS /i
welding torch service station
Robacta Reamer TWIN/Single
mechanical torch cleaning device, can be used for all base materials such as steel, aluminum, CrNi steels, copper, etc.
Robacta TC 2000 TWIN
electromagnetic torch cleaning device for ferromagnetic base materials
TXi TWIN
torch body change system
(only for TWIN Push welding systems)
Use a separate return lead cable for each welding machine:
When establishing a ground earth connection, observe the following points:
Use a separate return lead cable for each welding machine—see Figure A
Keep positive cables and return lead cables together as long and as close as possible
Physically separate the welding circuits of individual welding machines
Do not route several return lead cables in parallel
If parallel routing cannot be avoided, keep a minimum distance of 30 cm between the welding circuits
Keep the return lead cables as short as possible and use cables with a large cross-section
Do not cross over return lead cables
Avoid ferromagnetic materials between the return lead cables and the interconnecting hosepack
Do not wind up long return lead cables—coil effect!
Route long return lead cables in loops—see Figure C
Do not route return lead cables in iron pipes, metal cable trays, or along steel beams, avoid cable ducts
Routing positive cables and return lead cables together in an iron pipe does not cause any problems
If several return lead cables are being used, separate the grounding points on the component as far as possible and do not allow crossed current paths between the individual arcs
Use compensated interconnecting hosepacks (interconnecting hosepacks with integrated return lead cable)
Further information on connecting the return lead cable can be found from page (→).
The use of wire drums is required for a faultless working process.
In the TWIN welding process, the two welding machines are referred to as the lead welding machine and trail welding machine.
| (1) | Welding wire drum Depending on the application, two WFi R REEL unwinding wirefeeders can be used additionally for optimal wirefeeding |
| (2) | Wirefeeding hoses |
| (3) | Robot control |
| (4) | Connection cable from robot controls to RI FB Pro/i TWIN Controller |
| (5) | Connection cable from robot controls to TWIN welding torch change station |
| (6) | Welding machine 1: TPS 500i / 600i + WP Pulse + RI FB Pro/i TWIN Controller + Cooling unit CU 2000i / part 1 + Remote control RC Panel Pro + TU podium (screwed in place) |
| (7) | Welding machine 2: TPS 500i / 600i + WP Pulse + Cooling unit CU 2000i / part 2 + Remote control RC Panel Pro + TU podium (screwed in place) |
| (8) | SpeedNet cable from RI FB Pro/i TWIN Controller to welding machine 1 |
| (9) | SpeedNet cable from RI FB Pro/i TWIN Controller to welding machine 2 |
| (10) | HP 95i CON /G /10 m interconnecting hosepack |
| (11) | HP 95i CON /W /10 m interconnecting hosepack |
| (12) | Robot |
| (13) | Wirefeeder WF 30i R /TWIN + WF Mounting wirefeeder holder + TWIN Basic Kit |
| (14) | MHP 2x500 A W/FSC TWIN hosepack |
| (15) | CrashBox /i XXL + Fixing bracket + Index disk |
| (16) | MTB 2x500i PA welding torch + OPT/i MTB 11.5° sym. |
| (17) | TWIN welding torch change station TXi TWIN |
| (18) | Connection cable from robot controls to welding torch service station |
| (19) | Robacta TSS /i welding torch service station |
| (12) | Robot |
| (1) | Robot control |
| (2) | Connection cable from robot controls to RI FB Pro/i TWIN Controller |
| (3) | Connection cable from robot controls to welding torch service station |
| (4) | SpeedNet cable from RI FB Pro/i TWIN Controller to welding machine 1 |
| (5) | Welding machine 1 + Welding Package Pulse + Welding Package CMT + RI FB Pro/i TWIN Controller + Cooling unit CU 2000i / part 1 + Remote control RC Panel Pro + TU podium (screwed in place) |
| (6) | SpeedNet cable from RI FB Pro/i TWIN Controller to welding machine 2 |
| (7) | HP 95i CON /W /10 m interconnecting hosepack |
| (8) | Welding machine 2 + Welding Package Pulse + Welding Package CMT + Cooling unit CU 2000i / part 2 + Remote control RC Panel Pro + TU podium (screwed in place) |
| (9) | HP 95i CON /G /10 m interconnecting hosepack |
| (10) | Welding wire drum 2 |
| (11) | Welding wire drum 1 Depending on the application, two WFi R REEL unwinding wirefeeders can be used additionally for optimal wirefeeding. |
| (12) | OPT/i WF Tower + Mounting WF Twin Tower (12a) |
| (13) | TWIN wirefeeder WF 30i R /TWIN + OPT/i WF TWIN PushPull |
| (14) | MHP 2x450i RD/W/FSC (with TWIN drive unit WF 60i TWIN Drive) + Toothed pressure roller CMT + Fixing bracket |
| (15) | Wirefeeding hose 1 WF 30i R /TWIN - Wire buffer 1 |
| (16) | Control cable wire buffer 1 |
| (17) | Wirefeeding hose 2 WF 30i R /TWIN - Wire buffer 2 |
| (18) | Control cable wire buffer 2 |
| (19) | Robot |
| (20) | Robot support Y-piece ** |
| (21) | TWIN wire buffer set * (required for TWIN CMT applications) |
| (22) | CrashBox /d TWIN |
| (23) | MTB 2x500i PA welding torch + OPT/i MTB 11.5° sym. |
| (24) | Robacta TSS /i welding torch service station |
| * | Instead of mounting the wire buffers on the side of the robot, they can also be suspended from a balancer. |
| ** | The balancer mounting Y-piece can also be used instead of the robot support Y-piece. |
Single wire application
WF 30i TWIN
+ MHP TWIN torch hosepack
+ TXi torch body coupling
+ Adapter TWIN-MTB Single
+ MTB Single welding torch
= single wire application
With a TXi TWIN welding torch change station and the corresponding torch body couplings, an automated changeover from a TWIN welding torch to a single welding torch and vice versa can be performed.
Single wire application for different additive materials or different wire diameters
WF 30i TWIN
+ 2x adapter TWIN-MTB Single
+ 2x MTB Single welding torch
(e.g., for different additional materials or different wire diameters)
The single welding torches must be equipped according to the wire electrode to be conveyed.
Before changing the welding line, the current wire electrode must be withdrawn and the single welding torches must be replaced.
The wirefeeder WF 30i R /TWIN has been specially designed for automated applications in connection with a MIG/MAG TWIN welding process.
The standard 4-roller drive offers excellent wire feeding properties.
The device is intended exclusively for wirefeeding in automated MIG/MAG welding in combination with Fronius system components. Any other use does not constitute proper use. The manufacturer accepts no liability for any damage resulting from improper use.
Proper use also means:
The wirefeeder has safety symbols and a rating plate fitted. These safety symbols and the rating plate must not be removed or painted over. The safety symbols warn against operating the equipment incorrectly, as this may result in serious injury and damage to property.
Welding is dangerous. To ensure that this device can be used correctly and safely, the following basic requirements must be met:
Dispose of old devices in accordance with safety rules and not in normal domestic waste.
Keep hands, hair, loose clothing, and tools away from moving parts, such as:
Warning notices are attached to the device for certain device versions.
The arrangement of the symbols may vary.
| ! | Warning! Caution! The symbols represent possible dangers. |
| A | Drive rollers can injure fingers. |
| B | The welding wire and drive parts are under welding voltage during operation. Keep hands and metal objects away! |
| 1. | An electric shock can be fatal. |
| 1.1 | Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves. |
| 1.2 | Use a base that is insulated from the floor and work area to protect against electric shock. |
| 1.3 | Before working on the device, switch off the device and remove the mains plug or disconnect the power supply. |
| 2. | Inhalation of welding fumes can be harmful to health. |
| 2.1 | Keep your face away from any welding fumes. |
| 2.2 | Use forced-air ventilation or local extraction to remove welding fumes. |
| 2.3 | Remove welding fumes with a fan. |
| 3. | Welding sparks can cause an explosion or fire. |
| 3.1 | Keep flammable materials away from the welding process. Do not perform welding near flammable materials. |
| 3.2 | Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher. |
| 3.3 | Do not weld on drums or closed containers. |
| 4. | Arc rays can burn the eyes and injure the skin. |
| 4.1 | Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body. |
| 5. | Before working on the machine or welding: undertake training on the device and read the instructions! |
| 6. | Do not remove or paint over the sticker with the warnings. |
| * | Manufacturer order number of the sticker |
The interconnecting hosepacks connect the welding machines to the TWIN wirefeeder or the two robot wirefeeders.
In TWIN welding systems, one water-cooled and one gas-cooled interconnecting hosepack are used.
The water-cooled TWIN torch hosepack connects
For TWIN Push/Pull and TWIN CMT applications, the TWIN drive unit is integrated into the torch hosepack.
The CrashBox is a protection device for the torch body and the torch body coupling.
In the event of a collision, the CrashBox emits a signal to the robot controls, which causes the robot controls to stop the robot immediately. Due to the welding torch holder of the CrashBox, the welding torch and the installed system components are protected from damage in the event of a collision.
The magnetic coupling of the CrashBox allows for a low-force deflection with large deflection path in the event of a crash.
The clamp system is used to hold the TWIN welding torch for TWIN Push systems.
With the index disk corresponding to the torch body curvature, the clamp system positions the welding torch so that the TCP is in the 6th axis.
A robot-specific, insulating robot flange is required for the installation of the CrashBox.
To avoid damage to the welding torch or the torch hosepack, or to prevent false triggering of the CrashBox, consider the following points:
Avoid strong accelerations and maximum speeds during robot movements.
Ensure the free movement of the torch hosepack during all robot movements;
The torch hosepack must not tighten in any position and thus exert a strain on the CrashBox.
The torch hosepack must not whip around or get stuck when moving.
If possible, check all movement situations with Fronius system components in a simulation as early as the concept phase.
Only complete CrashBoxes should be sent for repair!
Incomplete CrashBoxes (e.g. without magnetic ring) cannot be checked in the course of a repair.
Robot flange as per price list
| NOTE!Do not assemble the CrashBox /i holder (1) and magnetic ring (6) before installing on the robot. It is difficult to separate the components afterwards due to the strong magnetism. |
The drive unit support is available with 30° and with 45°.
The water-cooled MTB 2x500i R and MTB 900i R robot welding torches transfer the arc power to the workpiece. The TWIN welding torches are designed for use with the CrashBox /i XXL and are available in two versions:
| PA | with contact tips arranged one over the other, welding torch angle 30° or 45° |
| PB | with contact tips arranged next to each other, welding torch angle 30° or 45° |
MTB 900i R
The robust MTB 900i R is suitable for TWIN applications in harsh environments with a non-changing contact tip tilt angle.
MTB 2x500i R
The MTB 2x500i R is designed for the application of different contact tip tilt angles; for details see from page (→).
Two wear part systems are available for the MTB 2x500i R:
The welding torches are delivered fully assembled with all wear parts.
The following components are required in order to fit the robot welding torch to the hosepack without an automatic TXi TWIN torch body change system:
MTB 900i R
MTB 2x500i R
Depending on the application, different tilt angles of the contact tips toward each other of 0°, 4°, 8°, and 11.5° are available for the MTB 2x500i R welding torches.
Corresponding assembly components are required for each angle:
| 0° | OPT/i MTB TWIN 0.0° sym. |
| 4° | OPT/i MTB TWIN 4.0° sym. |
| 8° | OPT/i MTB TWIN 8.0° sym |
| 11.5° | OPT/i MTB TWIN 11.5° sym. |
Details of the assembly components can be found under the adjacent link in the Fronius online spare parts catalog. https://spareparts.fronius.com |
The tilt angle-dependent dimensions of the welding torch can be found in the technical data from page (→).
The following assembly components are included in the OPT/i MTB TWIN xx°:
| (1) | 1 x gas nozzle |
| (2) | 2 x insulating sleeve* |
| (3) | 2 x nozzle fitting |
| (4) | 1 x gas distributor |
| (5) | 4 x cylinder head screws M2.5 x 16 mm |
| (6) | 2 x nozzle fitting holder |
| * | The insulating sleeves are not included in the OPT/i MTB TWIN xx° Sleeve option. |
Application recommendations for the tilt angles of the contact tips can be found from page (→) onwards.
With the aid of the TWIN-MTB Single adapter, the TWIN welding system can be operated with a single torch body.
The adapter combines gas and compressed air lines as well as the wirefeeding lines of both welding lines. The coolant lines are run and the current paths of both welding lines are merged into one.
The weld line is defined by inserting the inner liner into the respective wire inlet on the TWIN-MTB Single adapter.
If there is a torch body change system in the welding system, the changeover from the TWIN welding torch to the single welding torch and vice versa can also be automated.
When operating a single welding torch on a TWIN welding system, observe the maximum welding current and the duty cycle (D.C.) of the single welding torch.
Material | Shielding gas |
Non-alloyed and low-alloy steels | ArCO2, ArO2 and ArCO2O2 mixtures |
CrNi steels, high-alloy steels | ArCO2 mixtures, proportion of active gas max. 2.5% |
Aluminum | Ar (99.9%), ArHe mixtures |
Nickel-based alloys | Ar (100%), Ar+0.5-3% CO2 or ArHeCO2H2 mixtures |
Gas control
Set the same gas flow volume on both welding machines.
The entire gas flow volume must be a total of approx. 25–30 l/min.
Example:
gas flow volume = 30 l/min
==> set welding machine 1 to 15 l/min and welding machine 2 to 15 l/min
TWIN welding torch/TWIN mode:
both solenoid valves are switched
TWIN welding torch/single wire mode:
Single welding torch with adapter (TXi interchangeable coupling optional):
one solenoid valve is switched
(solenoid valve for the welding machine selected by the robot controls)
Gas pre-flow/gas post-flow with TWIN welding torch:
the same value should generally be set on both welding machines.
If the values are different, the larger value is automatically applied to both welding machines.
Gas control
Example:
Gas control
Example:
IMPORTANT! The R/L comparison must be carried out separately for each welding machine.
R = welding circuit resistance [mOhm]
L = welding circuit inductivity [µH]
Select the work angle of the welding torch so that the lead wire electrode (= wire electrode of the lead welding machine) is in a neutral to slightly leading position.
Approx. 90–100° for steel applications
Approx. 100–115° for aluminum applications
Stick out (SO ) and distance of the wire electrodes depending on the diameter (D) of the wire electrode:
D [mm / inch] | SO [mm / inch] |
1.0/0.039 | 15/0.591 |
1.2/0.047 | 17/0.669 |
1.4/0.055 | 18/0.709 |
1.6/0.063 | 21/0.827 |
| (1) | Wire electrode 1 |
| (2) | Contact tip 1 |
| (3) | Gas nozzle |
| (4) | Contact tip 2 |
| (5) | Wire electrode 2 |
| * | The distance of the wire electrodes depending on the tilt angle of the contact tips and the stick out can be found in the technical data from page (→). |
By material:
Application | Tilt angle | |||
0° | 4° | 8° | 11.5° | |
Aluminum |
| x1) |
Steel ferritic | x1) | x1) | x1) | x1) |
Austenitic steel, CrNi |
| x2) | x1) |
| 1) | Lead/trail = PMC TWIN/PMC TWIN or PCS TWIN/PMC TWIN |
| 2) | Lead/trail = PMC TWIN/CMT TWIN or CMT TWIN/CMT TWIN |
According to seam geometry (for steel):
Fillet weld - thin sheet (< 3 mm/0.12 inch) |
| x | x |
Fillet weld - thick sheet (> 3 mm/0.12 inch) | x | x |
BUTT WELD | x | x |
| x |
Lap joint |
| x |
According to general criteria:
high welding speed for thin sheet applications |
| x | x |
high welding speed for thick sheet applications | x | x | x | |
Penetration - thin sheet | x | x | ||
Penetration - thick sheet | x | x | x | |
A CMT TWIN welding process requires a WF 60i TWIN Drive unit and a wire buffer.
In conjunction with a WF 60i TWIN Drive unit, all TWIN characteristics ignite according to the above sequence.
The robot controls use the signals "Operating mode TWIN System Bit 0" and "Operating mode TWIN System Bit 1" to define
Only PMC TWIN characteristics with the following properties are available for the TWIN welding process:
Universal
Characteristic packages for conventional welding tasks
The characteristics are optimized for a wide range of applications in synchronized TWIN welding.
The pulse synchronization ratio and the lead/trail phase shift are supported, provided that a TWIN universal characteristic is in use at both welding machines.
Multi arc
The characteristics are optimized for synchronized TWIN welding with multiple welding systems and reduce the mutual influence of multiple welding machines.
The pulse synchronization ratio and the lead/trail phase shift are supported, provided that a TWIN multi arc characteristic is in use at both welding machines.
PCS (Pulse Controlled Sprayarc)
These characteristics combine the advantages of pulse and standard arcs in one characteristic: a concentrated pulse arc passes directly into a short spray arc; the intermediate arc is blanked out.
The characteristic curve does not support synchronization.
Overlay welding
The characteristics are optimized for synchronized TWIN overlay welding.
A special current profile ensures a wide arc with optimized weld flow and low dilution.
The pulse synchronization ratio and the lead/trail phase shift are supported, provided that a TWIN Universal or a TWIN multi arc characteristic is in use at both welding machines.
Root
Characteristics for root passes
The characteristics are optimized for CMT welding at the lead and trail electrode.
IMPORTANT! The same TWIN characteristic must be selected on both process lines.
Prerequisites for using a PMC TWIN characteristic:
Universal
Multi arc
Overlay welding
Root
PR = Process
Stahl:
No. | Wire diameter | Shielding gas | Property |
4256 | 0.9 mm | C1 CO2 100% | TWIN universal |
4257 | 0.9 mm | M21 Ar + 15–20% CO2 | TWIN universal |
4258 | 0.9 mm | M20 Ar + 5–10% CO2 | TWIN universal |
3940 | 1.0 mm | M21 Ar + 15–20% CO2 | TWIN universal |
4019 | 1.0 mm | M20 Ar + 5–10% CO2 | TWIN universal |
4251 | 1.0 mm | M21 Ar + 15–20% CO2 | TWIN universal |
4254 | 1.0 mm | M20 Ar + 8–10% CO2 | TWIN universal |
4255 | 1.0 mm | C1 CO2 100% | TWIN universal |
3564 | 1.2 mm | M21 Ar + 15–20% CO2 | TWIN universal |
3565 | 1.2 mm | M20 Ar + 5–10% CO2 | TWIN universal |
4200 | 1.2 mm | M21 Ar + 15–20% CO2 | TWIN universal |
4221 | 1.2 mm | C1 CO2 100% | TWIN universal |
4250 | 1.2 mm | M20 Ar + 5–10% CO2 | TWIN universal |
3892 | 1.3 mm | M20 Ar + 5–10% CO2 | TWIN universal |
3845 | 1.4 mm | M21 Ar + 15–20% CO2 | TWIN universal |
3734 | 1.6 mm | M21 Ar + 15–20% CO2 | TWIN universal |
3735 | 1.6 mm | M20 Ar + 5–10% CO2 | TWIN universal |
4018 | 1.0 mm | M21 Ar + 15–20% CO2 | TWIN PCS |
4020 | 1.0 mm | M20 Ar + 5–10% CO2 | TWIN PCS |
3833 | 1.2 mm | M21 Ar + 15–20% CO2 | TWIN PCS |
3834 | 1.2 mm | M20 Ar + 5–10% CO2 | TWIN PCS |
3893 | 1.3 mm | M20 Ar + 5–10% CO2 | TWIN PCS |
3846 | 1.4 mm | M21 Ar + 15–20% CO2 | TWIN PCS |
3840 | 1.6 mm | M21 Ar + 15–20% CO2 | TWIN PCS |
3841 | 1.6 mm | M20 Ar + 5–10% CO2 | TWIN PCS |
4021 | 1.0 mm | M21 Ar + 15–20% CO2 | TWIN multi arc |
4023 | 1.0 mm | M20 Ar + 5–10% CO2 | TWIN multi arc |
3837 | 1.2 mm | M21 Ar + 15–20% CO2 | TWIN multi arc |
3838 | 1.2 mm | M20 Ar + 5–10% CO2 | TWIN multi arc |
Metal Cored (flux core wire):
3894 | 1.2 mm | M20 Ar + 5–10% CO2 | TWIN universal |
3903 | 1.2 mm | M21 Ar + 15–20% CO2 | TWIN universal |
3897 | 1.6 mm | M20 Ar + 5–10% CO2 | TWIN universal |
3905 | 1.6 mm | M21 Ar + 15–20% CO2 | TWIN universal |
3896 | 1.2 mm | M20 Ar + 5–10% CO2 | TWIN PCS |
3901 | 1.6 mm | M20 Ar + 5–10% CO2 | TWIN PCS |
3904 | 1.2 mm | M21 Ar + 15–20% CO2 | TWIN PCS |
3906 | 1.6 mm | M21 Ar + 15–20% CO2 | TWIN PCS |
CrNi 19 9/19 12 3:
4024 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN universal |
4261 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN universal |
4026 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN PCS |
CrNi 18 8/18 8 6:
4027 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN universal |
4262 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN universal |
4028 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN PCS |
NiCrMo-3:
4030 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN universal |
4032 | 1.2 mm | M12 Ar + 2–5% CO2 | TWIN PCS |
4034 | 1.2 mm | Z Ar + 30% He + 2% H2 + 0.05% CO2 | TWIN overlay welding |
4035 | 1.2 mm | I1 Ar 100% | TWIN overlay welding |
AlMg4.5 Mn (Zr):
4147 | 1.2 mm | I1 Ar 100% | TWIN universal |
4287 | 1.2 mm | I3 Ar + 30% He | TWIN universal |
4041 | 1.6 mm | I1 Ar 100% | TWIN universal |
4053 | 1.6 mm | I3 Ar + 30% He | TWIN universal |
4289 | 1.2 mm | I3 Ar + 30% He | TWIN PCS |
4298 | 1.2 mm | I1 Ar 100% | TWIN PCS |
4044 | 1.6 mm | I1 Ar 100% | TWIN PCS |
4054 | 1.6 mm | I3 Ar + 30% He | TWIN PCS |
4284 | 1.2 mm | I1 100% Ar | TWIN multi arc |
4288 | 1.2 mm | I3 Ar+30% He | TWIN multi arc |
4290 | 1.6 mm | I1 100% Ar | TWIN multi arc |
AlMg 5:
4259 | 1.2 mm | I1 Ar 100% | TWIN universal |
4279 | 1.2 mm | I1 100% Ar | TWIN universal |
4280 | 1.2 mm | I3 Ar+30% He | TWIN universal |
4264 | 1.6 mm | I1 100% Ar | TWIN universal |
4293 | 1.6 mm | I1 100% Ar | TWIN universal |
4245 | 1.2 mm | I1 100% Ar | TWIN multi arc |
4283 | 1.2 mm | I3 Ar+30% He | TWIN multi arc |
4292 | 1.6 mm | I1 100% Ar | TWIN multi arc |
4246 | 1.2 mm | I1 100% Ar | TWIN PCS |
4286 | 1.2 mm | I3 Ar + 30% He | TWIN PCS |
4294 | 1.6 mm | I1 Ar 100% | TWIN PCS |
AlSi 5:
4260 | 1.2 mm | I1 Ar 100% | TWIN universal |
4265 | 1.6 mm | I1 Ar 100% | TWIN universal |
The SlagHammerfunction is implemented in all PMC Twin and CMT Twin characteristics.
In conjunction with a TWIN drive unit WF 60i TWIN Drive, slag is knocked off the weld seam and wire electrode end by a reversing wire movement without arc before welding.
Knocking off the slag ensures reliable and precise ignition of the arc.
A wire buffer is not required for the SlagHammerfunction.
The SlagHammerfunction is automatically executed for PMC Twin and CMT Twin characteristics.
Lead wire electrode | Trail wire electrode |
PMC TWIN | PMC TWIN |
PCS TWIN | PCS TWIN |
PMC TWIN | CMT TWIN |
PCS TWIN | CMT TWIN |
CMT TWIN | CMT TWIN |
Single wire | - |
- | Single wire |
* activation required
IMPORTANT! There are no TWIN characteristics available for Pulse or Standard welding processes.
Welding process combinations using Pulse or Standard are not recommended!
Single wire | - |
- | Single wire |
The following symbols are used in the descriptions of the TWIN welding processes below:
Trail wire electrode | |
Lead wire electrode | |
Active PMC arc with droplet transfer | |
Inactive PMC arc (no droplet transfer) | |
Active PCS arc | |
CMT weld pool | |
CMT droplet melting phase | |
CMT start of arcing phase | |
CMT droplet detachment | |
IL | Welding current of the lead welding machine |
IT | Welding current of the trail welding machine |
Welding direction |
Time coordination of the welding machines
The PMC processes of the two process lines are synchronized with each other. This ensures a stable, consistent tandem welding process.
The relative position of the pulses/droplet detachment is stored in the characteristic but can also be freely selected.
Significantly different outputs at lead and trail wire electrode
The TPS/i TWIN welding system enables significantly different outputs or wire speeds to be used, even during synchronized PMC tandem processes.
A significantly higher output is usually selected at the lead wire electrode than at the trail wire electrode.
This results in:
IMPORTANT! Only PMC TWIN characteristics synchronize.
For synchronization, a TWIN universal, a TWIN multi arc, or a TWIN cladding characteristic must be used on the lead and trail wire electrode respectively.
A combination of PMC Single characteristics and PMC TWIN characteristics (lead/trail or trail/lead) does not lead to synchronization.
The TWIN process PMC TWIN/PMC TWIN should generally be used for all welding applications.
PCS TWIN characteristics are predominantly used in order to weld with a modified spray arc at the lead wire electrode and a pulsed arc at the trail wire electrode.
Pulse synchronization is not activated when a PCS TWIN characteristic is used.
Advantages:
In the TWIN process PCS TWIN / PCS TWIN, only weld the lead wire electrode in the spray arc.
Advantages:
The TWIN welding process PMC TWIN / CMT TWIN can be used for both welding directions.
In the TWIN welding process PMC TWIN / CMT TWIN, optimum welding results are achieved with a contact tip tilt angle of 8°.
In this process variant, the same characteristics are used for both wire electrodes.
The arc of the lead wire electrode is shorter than that of the trail wire electrode. This results in a higher output on the lead wire electrode.
The arc of the trail wire electrode is specifically matched to the weld pool.
The TWIN welding process CMT TWIN / CMT TWIN can be used for both welding directions.
Welding current time curves and schematic representation of the material transition for the lead welding machine
Welding current time curves and schematic representation of the material transition for the trail welding machine
Single wire welding
In single wire welding, a signal is emitted by the robot controls, meaning that only one welding machine welds.
Depending on the torch position or restricted position of the weld, single wire welding can be carried out by the lead or trail welding machine. The second welding machine pauses.
In order to ensure a full gas shield during single wire welding with TWIN welding torches, the solenoid valve for the pausing welding machine is open.
The solenoid valve is controlled via the welding machine.
PMC, Pulse, LSC, Standard, and CMT arcs are possible during single wire welding as long as the appropriate welding package is available on the welding machine. It is not necessary to change the welding torch.
Single wire welding is used in a TWIN welding system:The following TWIN process parameters are available at the welding machines in TWIN mode under Process parameters / TWIN process control:
For PMC TWIN / PMC TWIN
PMC lead electrode
| PMC trail electrode
For PMC TWIN / CMT TWIN
PMC lead electrode
| CMT trail electrode
For CMT TWIN / CMT TWIN
CMT lead electrode
| CMT trail electrode
Further TWIN process parameters
| * | The following sections contain a detailed description of special process parameters for TWIN mode. |
PMC lead electrode
| PMC trail electrode
PMC lead electrode
| CMT trail electrode
CMT lead electrode
| CMT trail electrode
When this function is activated, the ignition point of the trail arc always depends on the present phase of the lead arc. The start parameters of the trail arc are automatically adapted to the prevailing conditions of the lead arc.
The trail arc starts without contact in TWIN Push systems and with a synchronized SFI (spatter-free ignition) in TWIN Push/Pull systems.
As a result, the start of the trail arc is significantly smoother and failed ignitions are avoided or their number reduced.
Automatic (auto) mode implements an optimum ignition delay.
When set manually, an ignition delay of 0–2 seconds can be set. The start of the trail arc is synchronized.
The function can be deactivated. In this case, the trail arc is ignited immediately and is not synchronized.
Adjustment range: auto, 1/1, 1/2, 1/3
Factory setting: auto
Only active if the same PMC TWIN characteristic is set for both wire electrodes.
The pulse synchronization ratio enables both process lines to be operated with significantly different wire speeds.
In the case of greater differences in output, the pulse frequency is adjusted in such a way that it differs between lead and trail by an integral multiple. Only every second or every third pulse is then executed for the trail arc, for example.
The characteristic for automatic ("auto") mode contains an optimum frequency ratio based on the wire speed values for both process lines. The wire speed can be set separately for each process line.
When setting the frequency ratio manually, the value can be set on both welding machines independently. The value set on the trail welding machine is applied to the process.
| 1/1 | Both arcs work with the same pulse frequency. The number of droplets per time unit is identical in both process lines. |
| 1/2 | The trail arc works with half the pulse frequency of the lead arc. Droplet detachment only takes place at the trail arc with every other pulse. |
| 1/3 | The trail arc works with a third of the pulse frequency of the lead arc. Droplet detachment only takes place at the trail arc every third pulse. |
Adjustment range: auto, 0–95%
Lead/trail phase shift enables the time of droplet detachment to be freely selected for the trail arc. As the trail droplet detachment does not have to take place in the quiescent current phase of the lead arc, an arc blow between the two arcs can be counteracted.
In automatic ("auto") mode, the characteristics contain the optimum location of the two main current phases in relation to one another and this can change along the characteristic.
When set manually, the phase shift can be set between the two pulses as a percentage of the period duration. The adjustment range of 0–95% corresponds to a phase shift of 0–342°.
| 0% | Synchronous mode—no phase shift between the two process lines, lead and trail droplet detachments take place at the same time. |
| 50% | Asynchronous mode—180° phase shift, each droplet detachment takes place in the quiescent current phase of the other arc. |
SynchroPulse is available for all process (Standard / Pulse / LSC / PMC).
The cyclic change of the welding power between two operating points with SynchroPulse achieves a finely rippled weld appearance and a non-continuous heat input.
From the firmware version "official_TPSi_4.0.0-xxxxx.xxxxx.ffw", SynchroPulse can also be used in a TWIN welding process.
For TWIN SynchroPulse, the SynchroPulse parameters Frequency and DutyCycle (high) are set and specified at the lead welding machine.
The settings for Frequency and DutyCycle (high) at the trail welding machine have no effect.
The remaining welding parameters can be selected differently on both process lines.
The following data are standard values determined under laboratory conditions.
Shielding gas and filler metal used:
Shielding gas | M20 Ar + 5-15% CO2 |
Filler metal | ER70S-6 |
Wire diameter | 1.2 mm |
Characteristic (lead + trail) | PMC TWIN Universal 3565 |
a-dimension | Lead (L) | Wire speed | Welding current | Welding voltage | Welding speed | Energy per unit length | Deposition rate | Sheet thickness | Micrograph/macro |
3.5 | L | 21.0 | 378 | 24.1 | 250 | 3.7 | 16.5 | 3 | |
4.0 | L | 22.5 | 394 | 27.3 | 200 | 6.1 | 19.2 | 6 | |
4.5 | L | 22.0 | 414 | 28.6 | 160 | 7.5 | 17.9 | 6 | |
5.0 | L | 24.0 | 430 | 27.8 | 125 | 10.0 | 19.9 | 8 | |
6.0 | L | 23.0 | 430 | 26.8 | 90 | 13.2 | 18.2 | 10 | |
7.0 | L | 26.2 | 409 | 27.6 | 78 | 15.0 | 19.5 | 10 | |
8.0 | L | 24.6 | 451 | 27.6 | 60 | 19.6 | 17.7 | 15 | |
8.5 | L | 20.0 | 369 | 24.9 | 45 | 20.9 | 15.3 | 15 | |
9.0 | L | 22.5 | 429 | 27.0 | 40 | 26.5 | 16.4 | 15 |
3.5 | L | 18.0 | 397 | 23.2 | 210 | 4.4 | 14.3 | 3 | |
4.0 | L | 20.0 | 396 | 27.8 | 150 | 6.8 | 15.9 | 6 | |
4.5 | L | 23.5 | 362 | 24.8 | 130 | 6.8 | 17.7 | 6 | |
5.0 | L | 20.5 | 392 | 25.7 | 120 | 8.4 | 16.1 | 8 | |
5.5 | L | 21.5 | 389 | 26.5 | 100 | 10.4 | 17.1 | 10 | |
6.0 | L | 22.0 | 392 | 27.0 | 90 | 12.1 | 17.4 | 10 |
Shielding gas | M21 Ar + 15-20% CO2 |
Contact tip tilt angle | 11.5° |
Characteristic (lead + trail) | PMC TWIN Universal 3564 |
2.3 | L | 7.5 | 215 | 23.4 | 200 | 2.4 | 5.8 | 1.5 | |
3.0 | L | 11.6 | 285 | 25.0 | 180 | 3.7 | 8.2 | 2.0 | |
3.7 | L | 12.5 | 304 | 26.1 | 150 | 5.5 | 10.2 | 3.0 |
- | L | 7.0 | 210 | 23.2 | 245 | 2.7 | 7.0 | 1.5 | |
- | L | 8.5 | 225 | 23.8 | 220 | 3.5 | 7.7 | 2.0 | |
- | L | 12.0 | 298 | 25.8 | 230 | 4.1 | 9.7 | 3.0 |
Contact tip tilt angle | 8° |
Characteristic |
1.8 | L | 10.5 | 295 | 18.5 | 330 | 1.68 | 8.78 | 1.5 | |
2.5 | L | 10.0 | 258 | 24.5 | 300 | 2.34 | 9.16 | 2.0 | |
2.5 | L | 11.5 | 291 | 25.4 | 260 | 3.03 | 10.2 | 3.0 |
Characteristic |
Characteristic |
- | L | 11.5 | 291 | 25.4 | 515 | 1.54 | 9.68 | 1.5 | |
- | L | 12.0 | 298 | 25.8 | 480 | 1.77 | 10.7 | 2.0 | |
- | L | 11.5 | 291 | 25.4 | 300 | 2.7 | 10.1 | 3.0 | |
- | L | 18.0 | 370 | 31.0 | 290 | 4.15 | 14.9 | 4.0 |
Danger due to incorrect operation and work not carried out correctly.
This may result in serious personal injury and damage to property.
All the work and functions described in this document must be carried out by technically trained and qualified personnel only.
Read and understand all safety rules and user documentation for this equipment and all system components.
| No. | Function |
| (1) | Welding torch connection 1 For connecting the welding torch |
| (2) | (+) Current socket with fine thread 1 For connecting the power cable from the interconnecting hosepack |
| (3) | SpeedNet connection 1 For connecting the SpeedNet cable from the interconnecting hosepack |
| (4) | Shielding gas connection 1 |
| (5) | Welding torch connection 2 For connecting the welding torch |
| (6) | (+) Current socket with fine thread 2 For connecting the power cable from the interconnecting hosepack |
| (7) | Shielding gas connection 2 |
| (8) | SpeedNet connection 2 For connecting the SpeedNet cable from the interconnecting hosepack |
| (9) | Coolant connection For connecting the coolant connection from the interconnecting hosepack |
| (10) | Coolant supply connection (blue) For connecting the coolant hose from the torch hosepack |
| (11) | Coolant return connection (red) For connecting the coolant hose from the torch hosepack |
| (12) | Compressed air connection IN OPT/i WF gas purging option 16 bar |
| No. | Function |
| (1) | Operating status LED 1 illuminates green if wirefeeder unit 1 is ready for operation |
| (2) | Gas-test button 1 for setting the required gas volume on the pressure regulator |
| (3) | Wire-return button 1 retract the wire electrode without gas or current |
| (4) | Wire-threading button 1 for threading the wire electrode into the torch hosepack without gas or current |
| (5) | 4-roller drive 1 |
| (6) | Clamping lever 1 for adjusting the contact pressure of the feed rollers |
| (7) | Protective cover of the 4-roller drive 1 |
| (8) | Welding torch clamping lever 1 |
| (9) | Operating status LED 2 illuminates green if wirefeeder unit 2 is ready for operation |
| (10) | Wire-return button 2 retract the wire electrode without gas or current |
| (11) | Gas-test button 2 for setting the required gas volume on the pressure regulator |
| (12) | Wire-threading button 2 for threading the wire electrode into the torch hosepack without gas or current |
| (13) | 4-roller drive 2 |
| (14) | Clamping lever 2 for adjusting the contact pressure of the feed rollers |
| (15) | Protective cover of the 4-roller drive 2 |
| (16) | Welding torch clamping lever 2 |
| (17) | Cover |
Lights up green when the device is ready for operation
Gas-test button
After pressing the gas-test button, gas is released for 30 s. Pressing the button again will end the process prematurely.
Wire-return button
There are two options available for retracting the wire electrode:
Option 1
Withdraw wire electrode at the preset wire return speed:
Option 2
Withdraw wire electrode in 1 mm steps (0.039 in. steps)
Only retract the wire electrode a small amount at a time, to avoid the wire electrode becoming entangled on the wirespool during retraction.
If there is a ground earth connection with the contact tip, before the wire-return button is pressed, the wire electrode is retracted by pressing the wire-return button until the wire electrode is short-circuit-free—however, this must not exceed 10 mm (0.39 in.) each time the button is pressed.
If the wire electrode needs to be retracted further, press the wire-return button again.
There are two options available for the wire threading:
Option 1
Thread the wire electrode at the preset feeder inching speed:
Option 2
Thread the wire electrode in 1 mm steps (0.039 in. steps)
If there is a ground earth connection with the contact tip, before the wire-threading button is pressed, the wire electrode is retracted by pressing the wire-threading button until the wire electrode is short-circuit-free—however, this must not exceed 10 mm (0.39 in.) each time the button is pressed.
If after the 10 mm (0.39 in.) wire retraction there is still a ground earth connection with the contact tip, then when the wire-threading button is pressed again, the wire electrode is retracted again by a maximum of 10 mm (0.39 in.). The process is repeated until there is no longer any ground earth connection with the contact tip.
| No. | Function |
| (1) | Wire infeed tube 1 |
| (2) | Wire infeed tube 2 |
| (3) | Dummy cover |
| (4) | Dummy cover |
| (5) | Dummy cover |
| (6) | Dummy cover |
| (1) | Drive roller and clamping lever – welding line 1 |
| (2) | Contact pressure adjustment unit For adjusting the contact pressure for both lines |
| (3) | Wirefeeding hose 1 lock |
| (4) | External wirefeeding hose 1 connection |
| (5) | External wirefeeding hose 2 connection |
| (6) | Wirefeeding hose 2 lock |
| (7) | Control panel |
| (8) | Drive roller and clamping lever – welding line 2 |
| (9) | Heat shield |
| (1) | Wire-return button* Retracts the wire electrode without gas or current |
| (2) | Gas-test button* For setting the required gas volume on the gas pressure regulator |
| (3) | Wire-threading button* For threading the wire electrode into the torch hosepack without gas or current |
| (4) | LEDs 1/2/TWIN/External Light up when the respective mode is selected |
| (5) | Mode button For selecting the modes 1/2/TWIN/External Mode 1 When the wire-return, gas-test, and wire-threading buttons are pressed, the respective functions are only carried out on welding line 1 Mode 2 When the wire-return, gas-test, and wire-threading buttons are pressed, the respective functions are only carried out on welding line 2 TWIN mode When the wire-return, gas-test, and wire-threading buttons are pressed, the respective functions are carried out on both welding lines External mode Mode 1, 2 or TWIN is specified by the robot interface |
| (6) | Teach on LED Lights up when teach mode is activated |
| (7) | Status LED lights up green: Data connection to welding machine intact, no error lights up orange: No data connection to the welding machine, or the connection is in the process of being established lights up red: There is an error on one of the two TWIN lines |
| (8) | Teach on/off button For activating/deactivating teach mode Teach mode is used for creating the robot program. When the teach mode is active, bending of the wire electrode is avoided when setting up the robot. In TWIN teach mode (with both wire electrodes), the lead wire electrode has a higher scanning frequency than the trail wire electrode. Details on the teach mode can be found in the operating instructions "Signal descriptions interface TPS /i", 42,0426,0227,xx. |
| * | For a functional description of the wire-return, gas-test, and wire-threading buttons, see page (→). |
| (1) | SpeedNet cable |
| (2) | Coolant hoses |
| (3) | Protective gas shield hose |
| (4) | Power cable |
| (4) | Power cable |
| (1) | Current/coolant Welding line 1 |
| (2) | Shielding gas |
| (3) | Wire electrode welding line 2 |
| (4) | Current/coolant Welding line 2 |
| (5) | Wire electrode Welding line 1 |
| (6) | Compressed air |
| (7) | Common wire outlet |
| (8) | Common compressed air and inert gas output |
| (9) | Common power contacts/coolant flow |
| (10) | Common power contacts/coolant return |
Incorrect operation and incorrectly performed work can cause serious injury and property damage.
All work listed in this document may only be performed by trained specialist personnel.
All functions described in this document may only be used by trained specialist personnel.
Do not perform the work or use the functions described below until you have thoroughly read and understood the following documents:
This document
All operating instructions for system components, especially the safety rules.
Before starting the described work:
Switch the power switch on the welding machine to - O -
Disconnect the welding machine from the grid
Ensure that the welding machine remains disconnected from the grid until all work is complete
Danger of severe injury and damage to property due to falling objects.
Check all screw connections listed below:
For secure fastening after installation
For secure fastening following unusual operating situations (for example, crash)
For secure fastening at regular intervals
Improper connections can cause personal injury and/or damage to equipment.
All cables, leads, and hosepacks must be securely connected, undamaged, correctly insulated, and adequately sized.
This document
This document
Danger due to uninsulated wire electrode.
Personal injury, damage to property, and impaired welding results may result.
In automated applications, only guide the wire electrode from the welding wire drum, large spool or wirespool to the wirefeeder with insulation (for example using a wirefeeding hose).
A ground fault or earth leakage can be caused by:
In order to avoid ground faults or earth leakage:
Toppling or falling devices can be deadly.
Set up all system components, upright brackets and trolleys so that they are stable on a flat and solid surface.
The WF 30i TWIN wirefeeder can be set up and operated outdoors in accordance with degree of protection IP 23. Direct moisture (e.g. from rain) must be avoided.
The following overview covers the installation work required for a TWIN welding system in accordance with the system overview on page (→).
The installation of similar TWIN systems is carried out analogously to this.
Initial situation:
Installing the TWIN wirefeeder and accessories on the robot
Laying, installing, and connecting interconnecting hosepacks
Connecting the TWIN Controller
Installing the CrashBox, torch hosepack, and TWIN welding torch
Connecting the shielding gas and return lead cable
Preparing the TWIN wirefeeder for operation
Defining welding lines 1 and 2 on the welding machines
Final tasks
Installation of the hose clamps depends on the robot:
The hose clamps can
be mounted on the hosepack holder in advance,
be screwed to the hosepack holder,
be inserted into the hosepack holder until they engage.
The hose clamps can
Installation of the side holder depends on the robot.
Follow the Installation Instructions!
If the interconnecting hosepack is laid incorrectly it can have a significant influence on the welding results, a stable welding process is not guaranteed!
As far as possible, maintain a distance of 30 - 50 cm between the two interconnecting hosepacks.
IMPORTANT! When connecting the interconnecting hosepacks, observe marks 1 and 2 on the interconnecting hosepacks and on the wirefeeder:
1 = water-cooled interconnecting hosepack
2 = gas-cooled interconnecting hosepack
If interconnecting hosepacks are installed on the robot, make sure that there is no tension or strain in the hosepacks during any movement in a robot axis.
Route hosepacks in a loop.
IMPORTANT! When connecting the interconnecting hosepacks, observe marks 1 and 2 on the interconnecting hosepacks and on the welding machines:
As far as possible, maintain a distance of 30 to 50 cm between the two interconnecting hosepacks.
Observe the torques when fitting the robot flange:
Tightening torque for screws with strength class 8.8
| M4 | 2,3 - 3,3 Nm 1,70 - 2,43 lb·ft |
| M5 | 4,4 - 6,5 Nm 3,25 - 4,79 lb·ft |
| M6 | 7,70 - 11,3 Nm 5,68 - 8,33 lb·ft |
| M8 | 18,5 - 27,3 Nm 13,65 - 20,14 lb·ft |
| M10 | 36,0 - 54,0 Nm 26,55 - 39,83 lb·ft |
| M12 | 63,0 - 93,0 Nm 46,47 - 68,60 lb·ft |
So that the inner liner can be correctly installed, lay the hosepack out straight when installing the inner liner.
| * | After insertion, ensure that the inner liner is right at the front in the hosepack. IMPORTANT! The screws for securing the inner liners must not be loosened! |
| *** | Screw the clamping nipple onto the inner liner up to the stop. The inner liner needs to be visible through the hole in the cap. |
To avoid jamming the welding torch hosepack:
Tighten the screws crosswise
Observe the specified sequence when tightening
Pre-tighten screws with 1 Nm, then tighten with 4 Nm
IMPORTANT! When connecting the torch hosepack, pay attention to marks 1 and 2 on the torch hosepack and on the wirefeeder.
Connect coolant hoses from the welding torch according to the color markings on the coolant supply and coolant return connections
The coupling areas between the torch body and TWIN torch hosepack must always be free of oil, grease, and dust, and be dry.
Visually check that the springs are present, not deformed or otherwise damaged.
To prevent small parts from falling out or being lost, do not clean the area around the springs with compressed air.
| * | Special key BY2,0201,4863 |
| ** | The thread adapter is included as standard in the TWIN hose package. |
Switch off the cooling unit before dismantling the torch body!
The coupling areas between the torch body coupling and torch body must always be free of oil, grease, and dust, and be dry.
To prevent small parts from falling out or being lost, do not clean the area marked [ * ] on the torch hosepack with compressed air!
Flawless operation of the interchangeable coupling can only be guaranteed with a vertical alignment facing down.
If the torch body coupling opens and closes correctly, check the manual locking of a torch body in the torch body coupling.
Checking manual locking
The locking balls of the torch body coupling are intended for dry operation.
Do not lubricate the locking balls.
Always insert the torch body into the torch body coupling so that it is straight and until it reaches the stop.
If the torch body can be correctly locked in the torch body coupling by hand, then the torch body coupling is ready for use.
This document
This document
This document
Set up all system components, upright brackets, and trolleys so that they are stable on a flat and solid surface.
The system components can be set up and operated in dry rooms in accordance with protection class IP 20.
The following overview covers the installation work required for a Push/Pull TWIN welding system in accordance with the system overview on page (→).
Initial situation:
Mounting the TWIN wirefeeder on the OPT/i WF Tower
Installing the balancer mounting/wire buffers
Final tasks
The balancer mounting Y-piece is used when the Y-piece is not mounted on the robot.
Installation of the support Y-piece depends on the robot.
The recess marked with * must be present on the robot holder for the TWIN wire buffer set!
If this recess is missing, the TWIN wire buffer set must NOT be mounted!
For detailed information on the wire buffer, refer to the Operating Instructions for the wire buffer (42,0410,1254).
Max. tightening torque for screws with strength class 8.8
| M4 | 3.3 Nm / 2.43 lb-ft |
| M5 | 5.0 Nm / 3.69 lb-ft |
| M6 | 6.0 Nm / 4.43 lb-ft |
| M8 | 27.3 Nm / 20.14 lb-ft |
| M10 | 54 Nm / 39.83 lb-ft |
| M12 | 93 Nm / 68.60 lb-ft |
The TWIN drive unit is already mounted on the torch hosepack on delivery.
To make things simpler, the TWIN drive unit is shown without the torch hosepack in the following illustrations.
Mounting the Y-piece from the torch hosepack on the robot support Y-piece
The mounting position A, B, or C depends on the torch hosepack length and the robot.
Observe the following table!
Robot type | Twin PP hosepack | Mounting position |
ABB IRB2600 12 / 1.85 | 4,051,611 - 613 | B |
ABB IRB260012 / 1.65 | 4,051,611 - 613 | B |
ABB IRB2600 20 / 1.65 | 4,051,611 - 613 | B |
ABB IRB 4600-20 / 2.50 | 4,051,614 - 615 | B |
ABB IRB 2600iD 15 / 185 | 4,051,611 - 613 | B |
ABB IRB 2600iD 8 / 200 | 4,051,430 / 460 / 550 / 551 | A |
FANUC AM120iD | 4,051,611 - 613 | A |
YASKAWA HP20 | 4,051,430 / 460 / 550 / 551 | A |
YASKAWA AR1730 | 4,051,611 - 613 | B |
YASKAWA AR2010 | 4,051,430 / 460 / 550 / 551 | A |
KUKA KR16 R2010 | 4,051,430 / 460 / 550 / 551 | A |
KUKA KR16 R1610 | 4,051,611 - 613 | B |
KUKA KR20 R3100 | 4,051,618 | B |
KUKA KR30 R2100 | 4,051,614 - 615 | C |
KUKA KR50 R2100 | 4,051,614 - 615 | C |
KUKA KR50 R2500 | 4,051,614 - 615 | C |
KUKA KR70 R2100 | 4,051,614 - 615 | C |
If torch hosepacks are installed on the robot, make sure that there is no tension or strain in the hosepacks during any movement in a robot axis.
The torch hosepack is equipped with anti-kink protection rings on delivery.
These anti-kink protection rings fulfill several tasks:
The anti-kink protection rings may only be mounted according to the following illustration:
| (1) | The first anti-kink protection ring connects the corrugated protective hose to the plastic cover of the TWIN drive unit |
| (2) | 2 groove gap Fit the rings either |
| (3) | front face to front face or |
| (4) | groove to groove on the corrugated protective hose Groove to groove always follows front face to front face and vice versa! Do not combine groove and front face! At least 6 rings! |
IMPORTANT! Any deviating installation of the anti-kink protection rings will result in the loss of warranty claims.
An anti-kink protection ring consists of two half shells, which are screwed together on the corrugated protective hose with two M4 x 10 mm Allen screws.
Tightening torque = 1 Nm / 0.74 lb·ft
The anti-kink protection rings are available individually as an option from Fronius.
The coupling areas between the torch body and TWIN drive unit must always be free of oil, grease, and dust, and be dry.
Do not clean the area around the springs with compressed air.
For TWIN Push/Pull systems without wire buffers
The feed rollers are not inserted in the system when first delivered.
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
Danger due to deficient feed rollers.
This can result in poor-quality weld properties.
Only use feed rollers which match the wire electrode.
Only use toothed feed rollers for TWIN applications.
An overview of the available feed rollers and their possible uses can be found in the Spare Parts Lists.
The feed rollers are included in the TWIN Basic Kits.
The following Basic Kits are available:
BK = Basic Kit
Install by performing the steps in the reverse order
IMPORTANT! Check the contact pressure before recommissioning!
Connect the wirefeeding hoses in the same way as on the TWIN Push system (see page (→)).
The following wirefeeding hoses are required:
The coupling area of the torch body must always be free of oil, grease, and dust, and be dry.
When mounting a plastic inner liner, the contact tips must be mounted on the torch body.
All other available inner liners can be mounted like a plastic inner liner from the coupling side.
Spatter Guard wear parts
For detailed information, refer to the Installation Instructions 42,0410,2487 ... OPT/i TWIN 0/4/8/11.5°
Sleeve wear parts
For detailed information, refer to the Installation Instructions 42,0410,2932 ... OPT/i TWIN 0/4/8/11.5° Sleeve
Fronius recommends running single applications on welding line 1.
Danger due to feed roller holders shooting upwards.
This could result in injury.
When unlocking the clamping lever, keep fingers away from the area to the left and right of the clamping lever.
Danger due to open feed rollers.
After inserting/changing the feed rollers, always install the protective cover of the 4-roller drive.
When using the OPT/i WF wire straightener option, observe the information in the Operating Instructions 42,0410,1944!
Connect the interconnecting hosepacks to the robot wirefeeders in the same way as you connect them to the TWIN wirefeeder (see page (→)).
Connect the welding machine to the TWIN Controller via the SpeedNet cable
TPSi 1 = welding machine 1
TPSi 2 = welding machine 2
HP CON 1 = interconnecting hosepack 1
HP CON 2 = interconnecting hosepack 2
R-C = robot controls
For detailed information, refer to the following Operating Instructions:
For connection and installation:
42,0426,0299,xx ... RI FB PRO/i TWIN Controller
For signal descriptions:
42,0410,2449 ... ProfiNet
42,0410,2450 ... DeviceNet
42,0410,2451 ... Ethernet IP-2P
42,0410,2452 ... EtherCAT
Danger due to incorrect routing of the return lead cables!
This can result in severely impaired welding results!
Disconnect welding circuits!
Provide a separate ground earth connection for each welding circuit!
Do not use a common grounding cable!
Route the return lead cable as close as possible to the interconnecting hosepack.
Further information on routing the return lead cables can be found from page (→).
Danger of injury and property damage due to welding current and unintentional ignition of an arc.
Before starting work, disconnect the ground earth connection between the welding system and workpiece.
Danger of damage to the welding torch due to sharp-edged end of the wire electrodes.
Thoroughly deburr the end of the wire electrodes before inserting.
Danger of injury due to spring effect of the coiled wire electrodes.
When inserting the wire electrodes into the 4 roller drive, keep a secure hold of the end of the wire electrodes in order to prevent injuries due to wire electrodes springing back.
Danger of injury and property damage due to protruding wire electrodes.
During work
Position the welding torch so that the tip of the welding torch points away from the face and body
Wear suitable protective goggles
Do not point the welding torch at people
Ensure that the wire electrodes do not touch any electrically conductive or grounded parts (housing, etc.)
During work
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
Use the specified standard values on the sticker on the protective cover to adjust the contact pressure.
Contact pressure standard values
steel rollers
Steel: 4 - 5
CrNi: 4 - 5
Al: 0.5 - 1.5
Tubular covered electrodes: 2 - 3
plastic rollers
Al: 3 - 4
The wire electrode can be threaded on the TWIN robot wirefeeder or on the TWIN drive unit.
Thread the wire electrode in the same way as on the TWIN Push system (see page (→)).
Set the contact pressure for both wire electrodes.
The following requirements must be fulfilled for commissioning a TWIN welding system:
All components must be installed and connected in accordance with the "Installation" chapter.
The TWIN welding system may only be fitted and operated with original Fronius components.
Do not fit or install any third-party components!
All necessary welding media must be connected to the wirefeeder or to the TWIN drive unit.
Feed rollers corresponding to the wire electrodes to be welded must be inserted in the wirefeeder or the TWIN drive unit.
Wire electrodes must be threaded in.
Contact pressure of the feed rollers must be set.
Motor calibration must be carried out.
All covers must be present and closed
All side parts must be installed
All safety devices must be intact and installed in the location intended (for example, protective covers)
IMPORTANT! Before starting for the first time, spray the welding torch wearing parts from the front so that they are wetted with parting agent.
Spraying can be performed manually or automatically.
When using a TWIN welding process, welding is started by an active welding start signal from the robot controls.
Before starting any maintenance or servicing work, switch off all the devices and components involved and disconnect them from the grid.
Secure all these devices and components so they cannot be switched back on.
Danger due to hot system components and/or equipment.
This can result in burns or scalding.
Before starting work, allow all hot system components and/or equipment to cool to +25°C/+77°F (e.g., coolant, water-cooled system components, wirefeeder drive motor, etc.).
Wear suitable protective equipment if cooling down is not possible (e.g., heat-resistant gloves, safety goggles, etc.).
Make a note of the serial number and configuration of the device, and provide the service team with a detailed error description if:
| Cause: | Mains lead damaged or broken, mains plug not inserted |
| Remedy: | Check mains lead, if necessary insert mains plug |
| Cause: | Mains socket or mains plug faulty |
| Remedy: | Replace faulty parts |
| Cause: | Mains fuse |
| Remedy: | Replace mains fuse |
| Cause: | Short circuit on the 24 V power supply of the SpeedNet connection or external sensor |
| Remedy: | Disconnect connected components |
| Cause: | Interconnecting hosepack faulty or not connected correctly |
| Remedy: | Check interconnecting hosepack |
| Cause: | No communication with the robot controls |
| Remedy: | Check the communication with the robot controls |
| Cause: | Incorrect ground connection |
| Remedy: | Check ground connection for polarity |
| Cause: | Power cable in welding torch damaged or broken |
| Remedy: | Replace the welding torch |
| Cause: | Gas cylinder empty |
| Remedy: | Change gas cylinder |
| Cause: | Gas pressure regulator faulty |
| Remedy: | Replace gas pressure reducer |
| Cause: | Gas hose not attached, or damaged |
| Remedy: | Attach or replace gas hose |
| Cause: | Welding torch faulty |
| Remedy: | Change welding torch |
| Cause: | Gas solenoid valve faulty |
| Remedy: | Inform the service team |
| Cause: | Contact tip hole too narrow |
| Remedy: | Use suitable contact tip |
| Cause: | Inner liner in the welding torch faulty |
| Remedy: | Check inner liner for kinks, soiling, etc. |
| Cause: | Feed rollers not suitable for wire electrode used |
| Remedy: | Use suitable feed rollers |
| Cause: | Incorrect contact pressure of the feed rollers |
| Remedy: | Optimize contact pressure |
| Cause: | Improper laying of the hosepack |
| Remedy: | Lay hosepack as straight as possible while avoiding tight bending radii |
| Cause: | Welding torch is inadequately sized |
| Remedy: | Observe duty cycle and load limits |
| Cause: | For water-cooled systems only: Coolant flow too low |
| Remedy: | Check coolant level, coolant flow rate, coolant contamination, etc. For more detailed information, refer to the operating instructions for the cooling unit |
| Cause: | Distance from workpiece is too small |
| Remedy: | Increase the distance (stick out) |
| Cause: | Incorrect welding parameters |
| Remedy: | Check settings |
| Cause: | Poor ground earth connection |
| Remedy: | Establish good contact with workpiece |
| Cause: | Too little or no shielding gas |
| Remedy: | Check pressure regulator, gas hose, gas solenoid valve, welding torch gas connection, etc. |
| Cause: | Welding torch leaks |
| Cause: | Incorrect or heavily worn contact tip |
| Remedy: | Change contact tip |
| Cause: | Incorrect wire alloy or incorrect wire diameter |
| Remedy: | Check wire electrode in use |
| Remedy: | Check the weldability of the base material |
| Cause: | Shielding gas not suitable for wire alloy |
| Remedy: | Use correct shielding gas |
| Cause: | Dirty gas nozzle |
| Remedy: | Clean the gas nozzle, remove welding spatter |
The following error codes may be output on the welding machine in relation to a TWIN welding process:
| Cause: | No welding torch connected, welding torch has not been detected |
| Remedy: | Check the connection between the welding torch and the torch hosepack; if the welding torch is connected correctly, inform the service team |
| Cause: | Torch hosepack not present or not connected correctly |
| Remedy: | Check the connection between the torch hosepack and the TWIN wirefeeder; if the torch hosepack is connected correctly, inform the service team |
| Cause: | The interconnecting hosepack connections have been mixed up |
| Remedy: | Connect the interconnecting hosepacks to the TWIN wirefeeder correctly (observe markings 1 and 2) |
| Cause: | The torch hosepacks have been mixed up |
| Remedy: | Connect the torch hosepacks to the TWIN wirefeeder correctly (observe markings 1 and 2) |
| Cause: | The second welding machine is not ready |
| Remedy: | Check whether the second welding machine is switched on; check whether the second welding machine is connected to the TWIN Controller. |
| Cause: | Welding machines are not synchronized |
| Remedy: | Check whether the SpeedNet cable is connected to both welding machines and the TWIN Controller correctly |
| Cause: | The welding machine is connected to the wrong port on the TWIN Controller |
| Remedy: | Check that welding machine 1 is connected to port 1 and welding machine 2 is connected to port 2 on the TWIN Controller |
| Cause: | Single welding torch on a TWIN hosepack |
| Remedy: | Select single mode or switch to a TWIN welding torch |
The device only requires minimal of service and maintenance under normal operating conditions. However, several points must be observed for the welding system to remain operational for years to come.
In case of more visible damage to the contact spring:
Replace the contact spring
Clean the welding torch interface, and especially the contacts of the torch identification, with a soft cloth
In case of more visible contamination or coolant at the welding torch interface:
Clean the interface earlier!
Do not use pointed or sharp objects such as a screwdriver, wire electrode or the like to clean the interface!
Check 74 mm inner liner piece in the TWIN drive unit, replace if necessary.
Replace 74 mm inner liner piece:
Install by performing the steps in the reverse order.
Danger from compressed air at close range.
Electronic parts may be damaged.
Do not bring the air nozzle too close to electronic parts.
Packaging materialsSupply voltage | 24 V DC / 60 V DC | ||
Nominal current | 0.5 A / 1.4 A | ||
Welding current | 40% ED1) 650 A | ||
Maximum pressure of shielding gas | 7 bar/101.53 psi | ||
Coolant | Original Fronius | ||
Maximum pressure of coolant | 5 bar/72.53 psi | ||
Wire speed | 1 - 30 m/min / 39.37 - 1181.10 ipm | ||
Wire drive | 4-roller drive | ||
Recommended wire diameter | 1.2 - 1.6 mm/0.05 - 0.06 in. | ||
Protection class | IP 23 | ||
Mark of conformity | S, CE, CSA | ||
Dimensions l × w × h | 410 x 300 x 280 mm | ||
Weight | 12.75 kg/28.11 Ib. | ||
EMC emission class | A | ||
Welding current at 10 min/40°C |
Wire diameter | 1.2 - 1.6 mm/0.05 - 0.06 inch |
* ED = Duty cycle |
* ED = Duty cycle |
Welding current at 10 min / 40°C |
Wire diameter | 1.2 - 1.6 mm / 0.05 - 0.06 inch |
* ED = Duty cycle |
The dimensions of the MTB 2x500i R, which depend on the contact tip tilt angle, can be found in the following section.
α = 11,5° |
| β = 0° / PB | β = 30° / PB & PA | β = 45° / PB & PA | ||||||
SO [mm] | L1 [mm] | s [mm] | x [mm] | L [mm] | H [mm] | L [mm] | H [mm] | L [mm] | H [mm] | |
15 | 60.56 | 10.44 | 7.43 | 327.01 | 0.00 | 327.14 | 82.00 | 327.30 | 149.30 | |
16 | 61.55 | 10.44 | 7.23 | 328.00 | 0.00 | 328.00 | 82.50 | 328.00 | 150.00 | |
17 | 62.55 | 10.44 | 7.03 | 329.00 | 0.00 | 328.86 | 83.00 | 328.70 | 150.70 | |
18 | 63.54 | 10.44 | 6.83 | 329.99 | 0.00 | 329.72 | 83.50 | 329.41 | 151.41 | |
19 | 64.54 | 10.44 | 6.63 | 330.99 | 0.00 | 330.58 | 83.99 | 330.11 | 152.11 | |
20 | 65.53 | 10.44 | 6.43 | 331.98 | 0.00 | 331.45 | 84.49 | 330.81 | 152.81 | |
21 | 66.53 | 10.44 | 6.23 | 332.98 | 0.00 | 332.31 | 84.99 | 331.52 | 153.52 | |
22 | 67.52 | 10.44 | 6.03 | 333.97 | 0.00 | 333.17 | 85.49 | 332.22 | 154.22 | |
23 | 68.52 | 10.44 | 5.83 | 334.97 | 0.00 | 334.03 | 85.98 | 332.92 | 154.92 | |
24 | 69.51 | 10.44 | 5.63 | 335.96 | 0.00 | 334.89 | 86.46 | 333.63 | 155.63 | |
25 | 70.51 | 10.44 | 5.43 | 336.96 | 0.00 | 335.75 | 86.98 | 334.33 | 156.33 | |
26 | 71.50 | 10.44 | 5.23 | 337.95 | 0.00 | 336.62 | 87.48 | 335.03 | 157.03 | |
27 | 72.50 | 10.44 | 5.03 | 338.94 | 0.00 | 337.48 | 87.97 | 335.74 | 157.74 | |
28 | 73.49 | 10.44 | 4.83 | 339.93 | 0.00 | 338.34 | 88.47 | 336.44 | 158.44 | |
29 | 74.49 | 10.44 | 4.63 | 340.93 | 0.00 | 339.20 | 88.97 | 337.15 | 159.15 | |
30 | 75.48 | 10.44 | 4.43 | 341.93 | 0.00 | 340.06 | 89.46 | 337.85 | 159.85 | |
α = 8,0° |
15 | 60.91 | 13.65 | 11.55 | 327.25 | 0.00 | 327.44 | 82.18 | 327.54 | 149.54 | |
16 | 61.90 | 13.65 | 11.42 | 328.35 | 0.00 | 328.30 | 82.67 | 328.25 | 150.25 | |
17 | 62.90 | 13.65 | 11.28 | 329.35 | 0.00 | 329.17 | 83.17 | 328.95 | 150.95 | |
18 | 63.90 | 13.65 | 11.14 | 330.34 | 0.00 | 330.03 | 83.67 | 329.66 | 151.66 | |
19 | 64.90 | 13.65 | 11.00 | 331.34 | 0.00 | 330.89 | 84.17 | 330.36 | 152.36 | |
20 | 65.89 | 13.65 | 10.86 | 332.34 | 0.00 | 331.76 | 84.67 | 331.07 | 153.07 | |
21 | 66.89 | 13.65 | 10.72 | 333.34 | 0.00 | 332.62 | 85.17 | 331.77 | 153.77 | |
22 | 67.89 | 13.65 | 10.58 | 334.34 | 0.00 | 333.49 | 85.67 | 332.48 | 154.48 | |
23 | 68.89 | 13.65 | 10.44 | 335.33 | 0.00 | 334.35 | 86.17 | 333.18 | 155.18 | |
24 | 69.88 | 13.65 | 10.30 | 336.33 | 0.00 | 335.21 | 86.67 | 333.89 | 155.89 | |
25 | 70.88 | 13.65 | 10.16 | 337.33 | 0.00 | 336.08 | 87.16 | 334.59 | 156.59 | |
26 | 71.88 | 13.65 | 10.02 | 338.33 | 0.00 | 336.94 | 87.67 | 335.30 | 157.30 | |
27 | 72.88 | 13.65 | 9.88 | 339.32 | 0.00 | 337.81 | 88.16 | 336.01 | 158.01 | |
28 | 73.87 | 13.65 | 9.74 | 340.32 | 0.00 | 338.67 | 88.66 | 336.71 | 158.71 | |
29 | 74.87 | 13.65 | 9.60 | 341.32 | 0.00 | 339.53 | 89.16 | 337.42 | 159.42 | |
33 | 75.87 | 13.65 | 9.46 | 332.32 | 0.00 | 340.40 | 89.66 | 338.12 | 160.12 | |
α = 4,0° |
15 | 61.24 | 17.32 | 16.27 | 327.68 | 0.00 | 327.73 | 82.34 | 327.78 | 149.78 | |
16 | 62.24 | 17.32 | 16.20 | 328.68 | 0.00 | 328.59 | 82.84 | 328.48 | 150.48 | |
17 | 63.24 | 17.32 | 16.14 | 329.68 | 0.00 | 329.46 | 83.34 | 329.19 | 151.19 | |
18 | 64.24 | 17.32 | 16.07 | 330.68 | 0.00 | 330.32 | 83.84 | 329.90 | 151.90 | |
19 | 65.24 | 17.32 | 16.00 | 331.68 | 0.00 | 331.19 | 84.34 | 330.60 | 152.60 | |
20 | 66.23 | 17.32 | 15.93 | 332.68 | 0.00 | 332.05 | 84.84 | 331.31 | 153.31 | |
21 | 67.23 | 17.32 | 15.86 | 333.68 | 0.00 | 332.92 | 85.34 | 332.02 | 154.02 | |
22 | 68.23 | 17.32 | 15.79 | 334.68 | 0.00 | 333.78 | 85.84 | 332.72 | 154.72 | |
23 | 69.23 | 17.32 | 15.72 | 335.68 | 0.00 | 334.65 | 86.34 | 333.43 | 155.43 | |
24 | 70.23 | 17.32 | 15.65 | 336.68 | 0.00 | 335.51 | 86.84 | 334.14 | 156.14 | |
25 | 71.23 | 17.32 | 15.58 | 337.68 | 0.00 | 336.38 | 87.34 | 334.84 | 156.84 | |
26 | 72.23 | 17.32 | 15.51 | 338.68 | 0.00 | 337.25 | 87.84 | 335.55 | 157.55 | |
27 | 73.23 | 17.32 | 15.44 | 339.68 | 0.00 | 338.11 | 88.34 | 336.26 | 158.26 | |
28 | 74.23 | 17.32 | 15.37 | 340.69 | 0.00 | 338.98 | 88.84 | 336.96 | 158.96 | |
29 | 75.23 | 17.32 | 15.30 | 341.68 | 0.00 | 339.84 | 89.34 | 337.67 | 159.67 | |
30 | 76.23 | 17.32 | 15.23 | 342.67 | 0.00 | 340.71 | 89.84 | 338.38 | 160.38 | |
α = 0° |
15 | 61.50 | 21.00 | 21.00 | 327.95 | 0.00 | 327.95 | 82.47 | 327.96 | 149.96 | |
16 | 62.50 | 21.00 | 21.00 | 328.95 | 0.00 | 328.82 | 82.97 | 328.82 | 150.67 | |
17 | 63.50 | 21.00 | 21.00 | 329.95 | 0.00 | 329.68 | 83.47 | 329.38 | 151.38 | |
18 | 64.50 | 21.00 | 21.00 | 330.95 | 0.00 | 330.55 | 83.97 | 330.08 | 152.08 | |
19 | 65.50 | 21.00 | 21.00 | 331.95 | 0.00 | 331.42 | 84.47 | 330.79 | 152.79 | |
20 | 66.50 | 21.00 | 21.00 | 332.95 | 0.00 | 332.28 | 84.97 | 331.50 | 153.50 | |
21 | 67.50 | 21.00 | 21.00 | 333.95 | 0.00 | 333.15 | 85.47 | 332.20 | 154.20 | |
22 | 68.50 | 21.00 | 21.00 | 334.95 | 0.00 | 334.01 | 85.97 | 332.91 | 154.91 | |
23 | 69.50 | 21.00 | 21.00 | 335.95 | 0.00 | 334.88 | 86.47 | 333.62 | 155.62 | |
24 | 70.50 | 21.00 | 21.00 | 336.95 | 0.00 | 335.75 | 86.97 | 334.33 | 156.33 | |
25 | 71.50 | 21.00 | 21.00 | 337.95 | 0.00 | 336.61 | 87.47 | 335.03 | 157.03 | |
26 | 72.50 | 21.00 | 21.00 | 338.95 | 0.00 | 337.48 | 87.97 | 335.74 | 157.74 | |
27 | 73.50 | 21.00 | 21.00 | 339.95 | 0.00 | 338.34 | 88.47 | 336.45 | 158.45 | |
28 | 74.50 | 21.00 | 21.00 | 340.95 | 0.00 | 339.21 | 88.97 | 337.15 | 159.15 | |
29 | 75.50 | 21.00 | 21.00 | 341.95 | 0.00 | 340.08 | 89.47 | 337.86 | 159.86 | |
30 | 76.50 | 21.00 | 21.00 | 342.95 | 0.00 | 338.57 | 89.97 | 340.94 | 160.57 | |
MTB 250i W/R
Wire diameter | 0.8 - 1.2 mm/0.032 - 0.047 inch |
MTB 330i W/R (TX, TXM)
Wire diameter | 0.8 - 1.6 mm/0.032 - 0.063 inch |
MTB 400i W/R (TX, TXM)
MTB 500i W/R (TX, TXM)
Wire diameter | 1.0 - 1.6 mm/0.039 - 0.063 inch |
MTB 700i W/R (TX, TXM)
| * | ED = Duty cycle |
Wire diameter | 1.2-1.6 mm |
Hosepack length | 1.3 m / 1.55 m / 1.75 m / 2.3 m / 3.3 m |
Lowest cooling capacity as per IEC standard 60974-2, depending on the hosepack length |
Minimum coolant flow rate | 1 l/min |
Min. coolant pressure | 3 bar |
Max. coolant pressure | 5 bar |
TWIN Push/Pull hosepack
Wire diameter | 0.8 - 1.6 mm / 0.03 - 0.06 inches |
Hosepack length | 4 m / 6 m / 8 m / 10 m |
Lowest cooling capacity as per IEC standard 60974-2, depending on the hosepack length | 1100 W / 1300 W / 1500 W / 1700 W |
Minimum coolant flow Qmin | 1 l/min |
Minimum coolant pressure pmin | 3 bar |
Maximum coolant pressure pmax | 5 bar |
WF 60i TWIN Drive W
Wire diameter | 0.8 - 1.6 mm |
Supply voltage | 2 x 60 V DC |
Nominal current | 2 x 1.5 A RMS |
Wire speed | 2 x 1 - 60 m/min |
Welding current at 10 min/40°C (104°F) | 40% ED* / 400 A |
Welding current at 10 min/40°C (104°F) | 60% ED* / 600 A |
Welding current at 10 min/40°C (104°F) | 40% ED* / 500 A |
Welding current at 10 min/40°C (104°F) | 40% ED* / 600 A |
Item number | 44,0350,3380 |
Degree of repeatability (1) | ± 0.05 mm a) |
Triggering torques in x/y direction | See table on the next page |
Maximum displacement in x/y direction | ~ 45° |
Weight | 1250 g |
Dimensions | Ø90 mm x 60 mm |
a) A distance of 300 mm away from the robot flange
Triggering torques and weight-distance diagram
Max. possible displacement | z direction [mm] | ~ 30 |
| The values listed only apply when in a static state! |
x/y direction [°] | ~ 45 |
Activated within 300 mm distance | max [°] | 1.5275 |
max [mm] | 8 |
min [°] | 0.664 |
min [mm] | 3.5 |
Weight (distance [mm]) [kg] | 400 | 15.78 |
300 | 21.03 |
200 | 31.55 |
100 | 63.1 |
50 | 126.2 |
Triggering | 63.1 Nm |
CrashBox /i XXL |
Weight | 1250 g |
max [mm] | 8 |
min [°] | 0.664 |
min [mm] | 3.5 |
300 | 21.03 |
200 | 31.55 |
100 | 63.1 |
50 | 126.2 |
CrashBox /i XXL |
Item number | 44,0350,270 |
Maximum displacement in x/y direction | min. 20° |
Weight | 2160 g |
Dimensions | Ø90 mm x 83.3 mm |
Max. possible displacement | z direction [mm] | ~ 30 | The values listed only apply when in a static state! | |
x/y direction [°] | ~ 45 | |||
Activated within 30 mm distance | max [°] | 1.5275 | ||
max [mm] | 8 | |||
min [°] | 0.4775 | |||
min [mm] | 2.5 | |||
Weight (distance [mm]) [kg] | 400 | 15.78 | ||
300 | 21.03 | |||
200 | 31.55 | |||
100 | 63.1 | |||
50 | 126.2 | |||
Triggering | 63.1 Nm | |||
CrashBox /d | ||||
Weight | 2160 g |
max [mm] | 8 | |||
300 | 21.03 | |||
200 | 31.55 | |||
100 | 63.1 | |||
50 | 126.2 | |||
CrashBox /d | ||||
