en
      Operating instructionsFronius Tauro, Fronius Tauro Eco
    • General information
      • Safety information
        • Safety instructions and important information
        • Safety measures at the installation site
        • Environmental conditions
        • Electromagnetic fields
        • EMC measures
        • Protective earthing (PE)
        • Maintenance
      • Protection of people and equipment
        • Safety
        • Central grid and system protection
        • WSD (wired shutdown)
        • RCMU
        • Surge protection device SPD
        • AFCI – arc fault circuit interrupter (ArcGuard)
        • Safe state
      • General
        • Information on the device
        • How information is presented in the document
        • Target group
        • Data security
        • Privacy policy
        • Copyright
      • Product description
        • Description of the device
        • AC Daisy Chain
        • String fuses
        • Fronius Solar.web
        • Local communication
      • Utilization in accordance with "intended purpose"
        • Intended use
        • Foreseeable misuse
        • Provisions for the photovoltaic system
      • Functional principle
        • Operating principle
        • Cooling of the inverter through forced-air ventilation
        • Overload performance
      • Operating controls and connections
        • Controls and displays
        • PV connections - Tauro 50-3-D (direct)
        • PV connections - Tauro Eco 50-3-D (direct)
        • PV connections - Tauro 50-3-D (30 A fuses)
        • PV connections - Tauro Eco 50-3-D (30 A fuses)
        • PV connections - Tauro Eco 99-3-D / 100-3-D (direct, 20 A option)
        • PV connections - Tauro Eco 99-3-D / 100-3-D (direct, 30 A option)
        • String arrangement in Solar.web
        • PV connections - pre-combined
        • Mounting option for third-party components
        • Data communication area in the inverter
        • Schematic internal wiring of IOs
        • Button functions and LED status indicator
    • Installation and Startup
      • General
        • System component compatibility
      • Installation location and position
        • Choosing the location of the inverter
        • Installation position
      • Transport
        • Crane transport
        • Transport using a forklift or lift truck
      • Installing the inverter
        • Selecting the mounting material
        • Mounting bracket dimensions
        • Mounting the inverter on the wall
        • Mounting the inverter on floor racks
      • Connecting the inverter to the public grid (AC side)
        • Monitoring the grid
        • AC connection area
        • Connecting aluminum cables
        • Permitted cables
        • Maximum alternating current fuse protection
        • Changing the clamping area for V-type terminal
        • Sector conductors at the V-type terminal
        • Additional PE introduction for earthing
        • Safety
        • Opening the inverter
        • Switching off the AC disconnector option
        • Connecting the inverter to the public grid - Singlecore
        • Connecting the inverter to the public grid - Singlecore with PEN conductor
        • Connecting the inverter to the public grid - Multicore
        • Connecting the inverter to the public grid - Daisy Chain
        • Connecting cables with a cable lug
      • Connecting the PV cable to the inverter
        • Safety
        • General information about PV modules
        • Permitted cables
        • DC fuse protection - pre-combined
        • Example of Fronius Tauro Eco 50-3-P / 99-3-P / 100-3-P combiner box
        • Example Fronius Tauro 50-3-P combiner box
        • Distribution of solar module strings in the direct variant
        • Connecting PV cables - MC4 connector
        • MC4 connector cover
        • Connecting PV cables - pre-combined
        • Replacing the string fuses
        • Closing and switching on the inverter
      • Connecting the data communication cables
        • Modbus participants
        • Permitted cables for the data communication area
        • Multiple inverters in one network
        • Routing data communication cables
        • Installing the WSD (wired shutdown)
      • First startup
        • Starting the inverter for the first time
        • Fronius system monitoring (Pilot) display
        • Installation with the app
        • Installation with the browser
      • De-energizing the inverter and switching it back on
    • Settings – User interface of the inverter
      • User settings
        • User login
        • Selecting languages
      • Device configuration
        • Components
        • Functions and IOs
        • UC Editor—AUS—Demand Response Modes (DRM)
        • Inverter
      • System
        • General
        • Update
        • Setup wizard
        • Restoring factory settings
        • Event log
        • Information
        • License Manager
        • Licensing
        • Support
      • Communication
        • Network
        • Modbus
        • Cloud control
        • Solar API
        • Fronius Solar.web
      • Safety and grid requirements
        • Country setup
        • Requesting inverter codes in Solar.SOS
        • Absolute Generation Limit
        • Import limitation
        • Feed-in limit
        • Multiple Inverter Control
        • I/O Power Management
        • 4-relay connection example
        • I/O power management settings – 4 relay example
        • 3-relay connection example
        • I/O power management settings – 3 relay example
        • 2-relay connection example
        • I/O power management settings – 2 relay example
        • 1-relay connection example
        • I/O power management settings – 1 relay example
        • Connecting the ripple control receiver with several inverters
    • Appendix
      • Status codes and remedy
        • Status codes
      • Technical data
        • Tauro 50-3-D / 50-3-P
        • Tauro Eco 50-3-D / 50-3-P
        • Tauro Eco 99-3-D / 99-3-P
        • Tauro Eco 100-3-D / 100-3-P
        • WLAN
        • Explanation of footnotes
        • Integrated DC disconnector
      • Relevant Standards and Directives
        • CE Conformity Marking
        • WLAN
        • Mains failure
      • Service, warranty terms and conditions, and disposal
        • Fronius SOS
        • Warranty
        • Disposal
    • 040-28082026
    download
    Connecting the AC
    Connecting the DC
    Starting for the first time
    ContactImprintTerms of usePrivacy statementCookie policy
    General information
    link_horizontalLink copied
    Safety information
    Warnings are intended to warn people of possible injuries and to avoid personal injury and damage to the product. They relate to individual actions with and on the product.
    DANGER!
    Indicates an immediately dangerous situation.
    Serious injury or death will result if the danger is not avoided.
    Action step to escape the situation.
    WARNING!
    Serious injury or death may result if the danger is not avoided.
    CAUTION!
    Minor or moderate injury may result if the danger is not avoided.
    NOTE!
    Indicates a situation that may result in property damage.
    If the situation is not avoided, impaired work results, material damage to the product or other property are the possible consequences.
    Action step to avoid the situation.
    Safety instructions are designed to ensure safe product use. They are preventive and help to inform users about the fundamental risks involved when dealing with the product. They do not refer specifically to individual actions with and on the product.
    1. General information
    Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    2. Safety information
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    WARNING!
    Incorrect operation or misuse
    IMPORTANT!
    In addition to the operating instructions, observe the following general and local rules:
    • Accident prevention
    • Fire protection
    • Environmental protection
    IMPORTANT!
    IMPORTANT!
    All safety and danger notices on the device:
    • Must be kept in a legible state
    • Must not be damaged/marked
    • Must not be removed
    • Must not be covered, have anything stuck on them, or painted over
    WARNING!
    Tampered-with and non-functioning protection devices
    WARNING!
    NOTE!
    The device may be damaged
    When installing devices with ventilation slots, ensure that the ambient air can enter and exit unhindered through the vents. When selecting the installation site, observe the protection class (IP).
    Operation or storage of the machine outside the stipulated area will be deemed as not in accordance with the intended purpose.
    For exact information on permitted environmental conditions, please refer to the technical data.
    During operation, due to the high electrical voltages and currents, local electromagnetic fields (EMF) are generated. These occur in the immediate vicinity of the inverter and the Fronius system components. Electromagnetic fields are also present in the area of the PV modules and their supply lines.
    As long as the intended use and a minimum distance of 20 cm are observed, all limit values for human exposure are observed.
    If the limit values are complied with, according to current scientific knowledge, no negative health effects from EMF exposure are to be expected. For persons with prostheses1) or active physical aids2), there is a possible health risk in the vicinity of photovoltaic system components. To avoid possible health risks, consult with the responsible doctor.
    1) e.g., implants or metal parts
    2) e.g., pacemaker, insulin pump, hearing aid, etc.
    EMC measures
    Connection of a point in the device, system or installation to earth to protect against electric shock in the event of a fault. When installing the Tauro inverter, the PE connection is mandatory as it is a protection class 1 device. When connecting the PE conductor, ensure that it is secured against accidental disconnection. All points listed under "Connecting the inverter to the public grid (AC side)" must be observed, including the use of washers, screw locks, and nuts with the defined torque.
    It must be ensured that when using the strain-relief devices, the ground conductor is the last to be disconnected in the event of a possible failure. When connecting the ground conductor, the minimum cross-section requirements specified by the respective national regulations must be observed. In addition, the minimum cross-section of the PE conductor must be at least half of the phase cross-sections according to the product standard IEC 62109-1, as a cross-section of at least 35 mm² (50 kW) or 70 mm² (99.99 / 100 kW) must be used for the phases (L1 / L2 / L3).
    Maintenance
    In principle, Tauro inverters are maintenance-free. If maintenance work is nevertheless carried out on the inverter, such as cleaning or replacing components, this must be done in consultation with a Fronius-trained service technician. The manufacturer accepts no liability for damage caused by improper use.
    Safety
    WARNING!
    All the work and functions described in this document must only be carried out by trained and qualified personnel.
    Read and understand this document.
    Read and understand all the Operating Instructions for the system components, especially the safety rules.
    WARNING!
    Danger from electromagnetic fields. Electromagnetic fields are generated during operation.
    Effects on the health of persons (e.g., those wearing a pacemaker) can result.
    Do not remain closer than 20 cm from the inverter for a prolonged period of time.
    2. Protection of people and equipment
    Safety
    WARNING!
    WARNING!
    The inverter offers the option to use the integrated AC relays as section switches in conjunction with a central grid and system protection unit (in accordance with VDE-AR-N 4105:2018:11 § 6.4.1). For this purpose, integrate the central trigger device (switch) into the WSD chain as described in chapter (→) on page WSD (wired shutdown).
    Grid and system protection for systems with multiple inverters
    • Regional standards and guidelines may require the installation of external grid and system protection for systems >30 kVA.
    • External grid and system protection can be omitted if the following conditions are met:
      • A Fronius Smart Meter IP performs the external voltage measurement.
      • The Fronius Smart Meter IP communicates with the primary device via the MQTT protocol.
      • The On at Smart Meter option is selected in the country setup in the Long Time Average Limit menu for each device. This equates to grid and system protection with remote voltage measurement.
      • On the user interface of the secondary device, the Multiple Inverter Control function is disabled.
    The wired shutdown (WSD) interrupts the inverter's grid power feed if the trigger device (switch, e.g., Emergency Stop or fire alarm contact) has been activated.
    If an inverter (slave) fails, it is bypassed and the other inverters continue operating. If a second inverter (slave) or the inverter (master) fails, the operation of the entire WSD chain is interrupted.
    For installation, see Installing the WSD (wired shutdown) on page (→).
    RCMU
    The inverter is equipped with an RCMU (RCMU = residual current monitoring unit) according to IEC 62109-2 and IEC63112.
    It monitors residual currents from the PV module up to the AC output and disconnects the inverter from the grid when an improper residual current is detected.
    The surge protection device (SPD) protects against temporary overvoltages and diverts surge currents (e.g., lightning strike). Based on an overall lightning protection concept, the SPD contributes to the protection of the photovoltaic system components.
    If the surge protection device is triggered, the color of the indicator changes from green to red (mechanical display).
    A triggered SPD must be replaced with a fully functional SPD immediately by an authorized specialist company in order to maintain the full protective function of the device.
    It is possible to enable the option of digitally displaying the triggering of an SPD. If you wish to set this function, refer to the PDF "SPD Triggering / Temporary SPD Triggering" in the Service & Support area at www.fronius.com
    IMPORTANT!
    After setting the function described above, the inverter also responds if the 2-pole signal cable of the surge protection device is damaged or is subject to an interruption.
    The following components can be used to replace existing AC SPDs with type 1+2 products:
    • CITEL - DAC1-13S-31-275 (for mains voltages of 380–400 V)
    • CITEL - DAC1-13S-31-320 (for mains voltages of 440–480 V)
    Note: Replacing a device does not automatically result in replacement of the existing SPDs.
    There is a device variant with arc detection AFCI (ArcFault Circuit Interrupter).
    An AFCI protects against arc faults and is a protection device in the event of contact faults. The AFCI evaluates faults that occur in the current and voltage flow using an electronic circuit and shuts down the circuit if a contact fault is detected. This prevents overheating and possible fires at poor contact points.
    IMPORTANT! Active PV module electronics (e.g., power optimizers) can impair the function of the Arc Fault Circuit Interrupter. We cannot guarantee that the Arc Fault Circuit Interrupter will work correctly in combination with active PV module electronics.
    WARNING!
    Arc faults due to faulty or incorrect DC installation
    Risk of fire as well as serious injuries and damage to the inverter and PV system.
    Connection work must be carried out in accordance with the technical specifications.
    Check the plug connections to ensure that they are in proper condition.
    Professionally repair faulty insulation.
    IMPORTANT! Despite the integrated Arc Fault Circuit Interrupter and arc interruption, damage to the device as well as to other system components may occur (e.g., due to a parallel arc).
    Reconnection behavior
    The inverter interrupts grid power feed operation and stops PV power generation after an arc has been detected. The configuration in the Country Setup > Safety > DC Arc Fault Protection menu item determines whether or not the inverter automatically resumes PV power generation and grid power feed operation. If more arcs have been detected within 24 hours than are set in Automatic Reconnects, a manual reconnection needs to be performed.
    Safe state
    If one of the following safety devices trips, the inverter will change to a safe state:
    • WSD
    • isolation measurement
    • RCMU and
    • AFCI
    In the safe state, the inverter no longer feeds into the grid and is disconnected from the grid by opening the AC relays.
    General
    Technical data, warning notices, labels, and safety symbols are located on and in the inverter. This information must be kept in a legible condition and must not be removed, covered, pasted over, or painted over. The notices and symbols warn against incorrect operation that may result in serious injury and damage.
    Symbols on the rating plate:
    CE label – confirms compliance with applicable EU directives and regulations.
    UKCA marking – confirms compliance with applicable UK directives and regulations.
    WEEE marking – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law.
    RCM marking – tested according to the requirements of Australia and New Zealand.
    ICASA marking – tested according to the requirements of the Independent Communications Authority of South Africa.
    CMIM marking – tested according to IMANOR requirements for import regulations and compliance with Moroccan standards.
    Safety symbols:
    Risk of serious injury and property damage due to incorrect operation.
    • These operating instructions.
    • All operating instructions for the system components of the photovoltaic system, especially the safety rules.
    Dangerous electrical voltage.
    Wait until the capacitors have discharged before opening the device.
    Warning notice text:
    WARNING!
    An electric shock can be fatal. Before opening the device, ensure that the input and output sides are de-energized and isolated.
    2. General
    Safety symbols:
    WARNING!
    2. General
    Application notes
    Software
    Example: Click Save.
    Instructions for action
    1Action steps are displayed with consecutive numbering.
    ✓This symbol indicates the result of the action step or the entire instruction.
    2. General
    Target group
    This document provides detailed information and instructions to ensure that people can use the machine safely and efficiently.
    The information is intended for the following groups of people:
    • Technical specialists: People with appropriate qualifications and fundamental knowledge of electronics and mechanics. The activities of a technical specialist include installation, operation, maintenance, and service work.
    • User: People that use the machine in daily operation and want to understand its basic functions.
    Regardless of any qualifications, only perform the activities listed in this document.
    The definition of professional qualifications and their applicability are subject to national law.
    2. General
    Data security
    • Backing up any changes made to the factory settings
    • Saving and storing personal settings
    NOTE!
    2. General
    Privacy policy
    When you connect your device (and any associated devices) to the internet, the following device and operating data (device ID/identifier, device IP address, device time, configuration settings, hardware and software information, device status log files, serial number) is sent automatically to
    Fronius International GmbH, Froniusstraße 1, 4643 Pettenbach, Austria, telephone +43(0) 7242241-0, email: contact@fronius.com (controller)
    and stored.
    The processing of this device and operating data is carried out for the purpose of ensuring the operational safety of the device (time synchronization, provision of updates). This processing is therefore necessary for the functionality of the device and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
    If you do not wish to have such data processed, you must manually disable the device's internet connection.
    In addition, the device and operating data is also processed for the purpose of providing services as part of a supplementary digital service for your device (such as solar.web or similar) as soon as you have registered your device with such a digital service (identification). This data is processed to provide the requested digital services and is therefore necessary for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
    Furthermore, this data processing is also carried out for maintenance and support purposes and for handling customer concerns as well as in warranty and guarantee cases (only in individual cases and given connection between device and internet). In this context, the device and operating data may also be passed on to our cooperation partners (third-party providers and suppliers). The processing of this data is necessary for maintenance and support purposes or for processing warranty and guarantee cases and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
    Device and operating data are also processed for analysis and diagnostic purposes in order to gain insights into the functionality of the devices and improve them accordingly. This data processing is based on our legitimate interest (Art. 6 (1) (f) GDPR).
    We store this data for as long as it is necessary to fulfill the existing contract with you. Any storage beyond this is carried out for legal reasons or if we have a legitimate interest in doing so. For more information on data processing for the solar.web-digital service, as well as our general privacy policy and your rights as a data subject, please visit https://www.fronius.com.
    2. General
    Copyright
    Product description
    The inverter transforms the direct current generated by the PV modules into alternating current. This alternating current is fed into the public grid and synchronized with the mains voltage in use.
    The inverter has been designed exclusively for use in grid-connected photovoltaic systems. It cannot generate electric power independently of the grid.
    The inverter also has a design and functions that ensure it can offer maximum safety during installation and during operation.
    2. Product description
    AC Daisy Chain
    With the "AC Daisy Chain" inverter version, the AC lead can be fed directly from the inverter to another inverter. Several Tauro inverters, up to an output power of max. 200 kW, can be thereby be quickly connected to one another.
    The minimum cable cross-section is defined by the fuse at the mains connection point. A larger cable cross-section can be selected at any time. The applicable national standards must be taken into account and applied.
    String fuses
    Only applies to device types Fronius Tauro 50-3-D / Eco 50-3-D / Eco 99-3-D / Eco 100-3-D (direct):
    String fuses are used in the Fronius Tauro to provide additional protection for the solar modules.
    The maximum short circuit current Isc, the maximum module return current IR or the maximum string fuse rating specified in the module data sheet of the respective solar module is crucial in affording the solar modules the correct fuse protection.
    The national regulations regarding fuse protection must be observed. The electrical engineer carrying out the installation is responsible for the correct choice of string fuses.
    To replace the string fuses, see chapter Replacing the string fuses on page (→).
    Fronius Solar.web
    System owners and installers can easily monitor and analyze the PV system using Fronius Solar.web or Fronius Solar.web Premium. With the appropriate configuration, the inverter transmits data such as power, yield, load, and energy balance to Fronius Solar.web. More detailed information can be found at Solar.web - Monitoring & analysis.
    Configuration is carried out via the Setup wizard, see chapter Installation with the app or Installation with the browser.
    Requirements for configuration:
    • Internet connection (download: min. 512 kbit/s, upload: min. 256 kbit/s)*.
    • User account at solarweb.com.
    • Completed configuration using the Setup wizard.
    These specifications do not provide an absolute guarantee of flawless operation. High error rates in the transmission, fluctuating receptions or misfires can have an adverse effect on data transfer. Fronius recommends on-site testing to ensure that the connections meet the minimum requirements.
    Local communication
    The inverter can be found via the Multicast DNS (mDNS) protocol. We recommend searching for the inverter using the assigned host name.
    The following data can be called up via mDNS:
    • NominalPower
    • Systemname
    • DeviceSerialNumber
    • SoftwareBundleVersion
    Intended use
    The inverter is designed exclusively to convert direct current from PV modules into alternating current and feed this power into the public grid.
    Intended use also includes following all information from the operating instructions.
    2. Utilization in accordance with "intended purpose"
    Intended use
    Foreseeable misuse
    The following circumstances are considered to be reasonably foreseeable misuse:
    • Any use that is not the intended use or goes beyond the intended use.
    • Alterations to the inverter that are not expressly recommended by Fronius.
    • Installation of components that are not expressly recommended or sold by Fronius.
    The inverter is designed exclusively to be connected and used with PV modules.
    Use with other DC generators (e.g., wind generators) is not permitted.
    When configuring the photovoltaic system, make sure that all photovoltaic system components are operating exclusively within their permitted operating range.
    All measures recommended by the PV module manufacturer for maintaining the PV module properties must be followed.
    Operating principle
    The inverter is fully automatic. Starting at sunrise, as soon as the PV modules are generating enough energy, the inverter starts checking the PV system (insulation measurement) and the grid (mains voltage and mains frequency). If all values are within the normative framework, the system is automatically connected to the grid and grid power feed operation begins.
    The control system of the inverter ensures that the maximum possible power output is drawn from the PV modules at all times. This function is called MPPT (Maximum Power Point Tracking). In the event of shady conditions affecting the PV modules, a large part of the local maximum power point (LMPP) of the PV system can still be obtained via the "Dynamic Peak Manager" function.
    As dusk starts and there is no longer sufficient energy available to feed energy into the grid, the inverter shuts down the connection of the power electronics to the grid completely and stops operating. All settings and recorded data are saved.
    2. Functional principle
    Operating principle
    Cooling of the inverter is performed by a forced-air ventilation system via temperature-controlled fans. Air is sucked in from the front and fed, via a sealed duct, through the AC and DC heat sink, before passing directly over the inductors and dissipating.
    The sealed air duct prevents the electronics compartment from coming into contact with the ambient air. This approach largely prevents any contamination of the electronics compartment.
    The fan speed and temperature of the inverter are monitored.
    The variable-speed, ball-bearing mounted fans in the inverter permit the following:
    • Optimum cooling of the inverter
    • Cooler components, therefore a longer service life
    • Lowest-possible energy consumption
    • High output power including in top temperature range of the inverter
    When the device temperature gets too high, the inverter automatically reduces the current output power in order to protect itself. Reasons for an excessively high device temperature can be a high ambient temperature or insufficient heat dissipation (for example, when installed in containers without sufficient heat dissipation).
    The output of the inverter is reduced such that the temperature will not exceed the permissible limit.
    If a maximum temperature is exceeded, the inverter switches off in a safe state and resumes grid power feed operation only after the device has cooled down.
    (1)
    DC disconnector
    Disconnects the electrical connection from the solar modules to the inverter. Depending on the device type, 2 or 3 DC disconnectors are installed.
    The DC disconnectors can be secured against switching on with a padlock.
    (2)
    The optional AC disconnector breaks the connection from the inverter to the grid
    (3)
    Button function
    For further information about the button function, see Button functions and LED status indicator
    (4)
    For further information about the LED status indicator, see Button functions and LED status indicator
    2. Operating controls and connections
    (1)
    DC disconnector
    (2)
    (3)
    Button function
    (4)
    The currents of the individual strings are visible in Solar.web under History - Devices - Channels.
    Solar.web
    Current DC string #
    20 A option
    30 A option
    50-3-D
    ECO 50-3-D
    ECO 99-3-D /
    100-3-D
    50-3-D
    ECO 50-3-D
    ECO 99-3-D /
    100-3-D
    PV1.1
    PV1.1
    PV1.1
    PV1.1
    PV1.1
    PV1.1
    PV1.2
    PV1.2
    PV1.2
    PV1.2
    PV1.2
    PV1.2
    PV1.3
    PV1.3
    PV1.3
    PV1.3
    PV1.3
    PV1.3
    PV1.4
    PV1.4
    PV1.4
    PV1.4
    PV1.4
    PV1.4
    5
    PV2.1
    PV1.5
    PV1.5
    PV2.1
    PV2.1
    PV2.1
    6
    PV2.2
    PV1.6
    PV1.6
    PV2.2
    PV2.2
    PV2.2
    7
    PV2.3
    PV1.7
    PV1.7
    PV2.3
    PV2.3
    PV2.3
    8
    PV3.1
    PV2.1
    PV2.1
    PV2.4
    PV2.4
    PV2.4
    9
    PV3.2
    PV2.2
    PV2.2
    PV2.5
    PV2.5
    PV2.5
    10
    PV3.3
    PV2.3
    PV2.3
    PV3.1
    PV3.1
    11
    PV3.4
    PV2.4
    PV2.4
    PV3.2
    PV3.2
    12
    PV3.5
    PV2.5
    PV2.5
    PV3.3
    PV3.3
    13
    PV3.6
    PV2.6
    PV2.6
    PV3.4
    PV3.4
    14
    PV3.7
    PV2.7
    PV2.7
    PV3.5
    PV3.5
    15
    PV3.1
    16
    PV3.2
    17
    PV3.3
    18
    PV3.4
    19
    PV3.5
    20
    PV3.6
    21
    PV3.7
    22
    PV3.8
    Tauro 50-3-P
    Above the DC connection area there is space for mounting third-party components. Components up to a maximum width of 14.5 cm (8 DU) can be mounted on the DIN rail. The components must have a temperature resistance of ‑40 °C to +85 °C.
    The data communication area (Pilot PC board) is located above the DC connections in the inverter.
       Operating LED
    Indicates the inverter operating status.
    WSD (wired shutdown) switch
    Defines the inverter as the WSD master or WSD slave.
    Position 1: WSD master
    Position 0:
    WSD slave
    Modbus 0 (MB0) switch
    Switches the terminating resistor for Modbus 0 (MB0) on/off.
    Position 1: Terminating resistor on (factory setting)
    Position 0: Terminating resistor off
    Modbus 1 (MB1) switch
    Switches the terminating resistor for Modbus 1 (MB1) on/off.
       Optical sensor
    For operating the inverter. See chapter Button functions and LED status indicator on page (→).
       Communications LED
    Indicates the inverter connection status.
    LAN 1
    Ethernet connection for data communication (e.g., WiFi router, home network or, for commissioning with a laptop, see chapter Installation with the browser on page (→)).
    LAN 2
    Reserved for future functions. To avoid malfunctions, only use LAN 1.
    I/O terminal
    Push-in terminal for digital inputs/outputs. See chapter Permitted cables for the data communication area on page (→).
    The designations (RG0, CL0, 1/5, 2/6, 3/7, 4/8) relate to the Demand Response Mode function, see chapter UC Editor—AUS—Demand Response Modes (DRM) on page (→).
    WSD terminal
    Push-in terminal for the WSD installation. See chapter WSD (wired shutdown) on page (→).
    Modbus terminal
    Push-in terminal for the installation of Modbus 0, Modbus 1, 12 V, and GND (ground).
    The data connection to the connected components is established via the Modbus terminal. The inputs M0 and M1 can be freely selected. Max. 4 Modbus participants per input; see chapter Modbus participants on page (→).
    The V+/ GND pin provides the possibility of feeding in a voltage in the range of 12.5 to 24 V (+ max. 20%) using an external power supply unit. Outputs IO 0 - 5 can then be operated using the external voltage that has been fed in. A maximum of 1 A may be drawn per output, whereby a total of max. 3 A is permitted. The fuse protection must take place externally.
    CAUTION!
    Danger from polarity reversal at the terminals due to improper connection of external power supply units.
    This may result in severe damage to the inverter.
    Check the polarity of the external power supply unit with a suitable measuring device before connecting it.
    Connect the cables to the V+/GND outputs while ensuring the correct polarity.
    IMPORTANT!
    If the total output (6 W) is exceeded, the inverter switches off the entire external power supply.
    (1)
    Current limitation
    The operating status LED displays the status of the inverter. In case of faults, follow the individual steps in the Fronius Solar.web live app.
    The optical sensor is actuated by touching it with a finger.
    The communications LED displays the connection status. To establish a connection, follow the individual steps in the Fronius Solar.web live app.
    Sensor functions
    1x    = WLAN access point (AP) is opened.
       Flashes blue
    2x    = WLAN protected setup (WPS) is activated.
       Flashes green
    3 seconds    (max. 6 seconds) = The service message disappears.
       Flashes white (quickly)
    The inverter is operating correctly.
       Lights up green
    The inverter is starting.
       Flashes green
    The inverter is on standby, is not operating (e.g., no energy fed into the grid at night), or is not configured.
       Lights up yellow
    The inverter displays a non-critical status.
       Flashes yellow
    The inverter displays a critical status and no energy is fed into the grid.
       Lights up red
    The network connection is being established via WPS.
    2x  = WPS search mode.
       Flashes green
    The network connection is being established via WLAN AP.
    1x  = WLAN AP search mode (active for 30 minutes).
       Flashes blue
    The network connection is not configured.
       Lights up yellow
    A network error is displayed, the inverter is operating correctly.
       Lights up red
    The inverter is performing an update.
       /    Flash blue
    There is a service message.
       Lights up white
    General
    All installed components in the PV system must be compatible with each other and have the necessary configuration options. The installed components must not restrict or negatively affect the functioning of the PV system.
    NOTE!
    Risk due to components in the PV system that are not and/or only partially compatible.
    Incompatible components can restrict and/or negatively affect the operation and/or functioning of the PV system.
    Only install components recommended by the manufacturer in the PV system.
    Before installation, check the compatibility of components that have not been expressly recommended with the manufacturer.
    1. Installation and Startup
    General
    NOTE!
    2. General
    NOTE!
    Please observe the following criteria when choosing a location for the inverter:
    Only install on a solid, non-flammable surface
    Criteria (distance, temperature, humidity) for choosing the location of the inverter
    Max. ambient temperatures: -40 °C / +65 °C
    * with built-in optional AC disconnector: -30 °C / +65 °C
    Relative humidity: 0 - 100%
    When installing the inverter in a switch cabinet or similar closed environment, ensure adequate heat dissipation by forced-air ventilation.
    When installing the inverter on the outer walls of cattle sheds, it is important to maintain a minimum clearance of 2 m between all sides of the inverter and the ventilation and building openings.
    The following surfaces are permitted for installation:
    • Walls (corrugated metal walls [mounting rails], brick walls, concrete walls or other non-flammable surfaces sufficiently capable of bearing loads)
    • Poles (installed using mounting rails, behind the PV modules directly on the PV mounting system)
    • Flat roofs (if this is for a foil roof, make sure that the foils comply with the fire protection requirements and are not highly flammable. Ensure compliance with the national provisions.)
    • Covered parking lot roofs (no overhead installation)
    The DC disconnectors must always be freely accessible after installation of the inverter.
    The inverter is suitable for indoor installation.
    The inverter is suitable for outdoor installation. IP65
    Because of its IP 65 protection class, the inverter is not susceptible to hose water on any side and can also be operated in moist environments.
    The inverter is suitable for outdoor installation. Do not expose the display to direct sunlight.
    In order to keep inverter heating as low as possible, it is recommended that the inverter is not exposed to direct sunlight. The inverter should be installed in a protected location, for example, near the solar modules or under an overhanging roof.
    The inverter must not be installed or operated at more than 4000 m above sea level.
    IMPORTANT! The inverter must not be installed or operated at more than 4000 m above sea level.
    Do not install the inverter: Where it may be exposed to ammonia, corrosive gases, acids, or salts (for example, fertilizer storage areas, vent openings for livestock stables, chemical plants, tanneries, etc.)
    • Where it may be exposed to ammonia, corrosive gases, acids, or salts (for example, fertilizer storage areas, vent openings for livestock stables, chemical plants, tanneries, etc.)
    During certain operating phases the inverter may produce a noise. For this reason it should not be installed in an occupied living area.
    Do not install the inverter in: Stables or similar buildings.
    • Areas where there is an increased risk of accidents from farm animals (horses, cattle, sheep, pigs, etc.)
    • Stables or adjoining areas
    • Storage areas for hay, straw, chaff, animal feed, fertilizers, etc.
    • Storage or processing areas for fruit, vegetables, or viticulture products
    • Areas used in the preparation of grain, green fodder, or animal feeds
    We therefore recommend not installing the inverter in areas and environments with high dust accumulation.
    The inverter is designed to be dust-proof (IP 65). However, in areas of high dust accumulation, the cooling surfaces can become dusty, which can impair the thermal performance. In this case, the dust must be removed regularly. We therefore recommend not installing the inverter in areas and environments with high dust accumulation.
    2. Installation location and position
    The inverter is designed to be installed vertically on a vertical wall. The optional floor racks must not be used for vertical mounting.
    The inverter should have a minimum inclination of 3° in a horizontal installation position so that water can run off. Mounting of the optional floor racks is recommended. The floor racks may only be used on an installation position of 0 - 45°.
    The inverter is suitable for installation on a sloping surface.
    Do not install the inverter on a sloping surface with its connection sockets at the top.
    Do not install the inverter at an angle on a vertical wall or column.
    Do not install the inverter horizontally on a vertical wall or pillar.
    Do not install the inverter on a vertical wall or pillar with its connection sockets facing upwards.
    Do not install the inverter overhanging with the connection sockets at the top.
    Do not install the inverter overhanging with the connection sockets at the bottom.
    Do not install the inverter on the ceiling.
    Transport
    Crane transport
    WARNING!
    Danger of serious injury and damage from articles being dropped or falling over.
    When transporting by crane:
    Hook chains and ropes onto the suspension points only
    Always hook chains and ropes onto both suspension points
    2. Transport
    Crane transport
    WARNING!
    2. Transport
    WARNING!
    Falling or toppling devices can be deadly.
    When transporting the inverter by forklift or lift truck secure the inverter from falling.
    Do not turn, brake, or accelerate in a sudden, jerking manner
    Use the corresponding fixing materials depending on the subsurface and observe the screw dimension recommendations for the mounting bracket.
    The installer is responsible for selecting the right type of fixing.
    2. Installing the inverter
    Dimensions of the mounting bracket—all dimensions in mm.
    1.
    Observe the local regulations for lifting heavy loads or use a crane to lift the device (attach to crane-hoisting lugs)
    2.
    To attach the inverter to the mounting bracket, use only the screws included in the scope of delivery.
    5
    The floor racks can be ordered as an optional accessory.
    Mounting the inverter on a horizontal mounting surface is not mandatory, but recommended.
    Depending on the surface, different wall plugs and screws are required for floor mounting the floor racks. Wall plugs and screws are therefore not included in the scope of supply of the inverter. The installer is responsible for selecting the correct wall plugs and screws.
    2Mount the inverter and floor racks securely to a suitable surface using the appropriate installation materials
    Do not climb onto the device!
    Monitoring the grid
    IMPORTANT! To provide the best possible grid monitoring, the resistance in the leads to the mains connections should be as low as possible.
    2. Connecting the inverter to the public grid (AC side)
    Monitoring the grid
    AC connection area
    IMPORTANT! Only the following cables may be connected to V-type terminals:
    • RE (solid round conductor)
    • RM (stranded round conductor)
    • SE (solid sector conductor)
    • SM (stranded sector conductor)
    • Fine-core cables only in conjunction with ferrules
    Fine-core cables without ferrules may only be connected to the M12 threaded bolts of the grid connections using a suitable M12 cable lug;
    torque = 32 Nm
    Cable gland "Multicore" version
    The following cable outer diameters are compatible with the larger bushing:
    16 - 27.8 - 36.2 - 44.6 - 53 - 61.4 mm
    For the small bushing (M32 PG gland), earth cables of 10 - 25 mm can be fed through.
    Cable gland "Singlecore" version
    5 M40 bushings
    Cable gland "AC Daisy Chain" version
    10 M32 bushings
    Aluminum cables can also be connected to the AC connections.
    NOTE!
    When using aluminum cables:
    Follow all national and international guidelines regarding the connection of aluminum cables.
    Grease aluminum wires with appropriate grease to protect them from oxidation.
    Follow the instructions of the cable manufacturer.
    Permitted cables
    The temperature resistance of the AC cables must be at least 90 °C.
    If cables are used that do not withstand this temperature requirement, fit the protective hose (item number: 4.251.050) over the phases (L1 / L2 / L3) and neutral conductor (N)! The grounding PE does not need to be protected with a protective hose.
    With the AC daisy chain option, all phases and neutral conductors must be protected with the protective hose. This means that the AC daisy chain option requires two protective hose sets.
    AC connections
    Select a sufficiently large cable cross-section based on the power category and connection variant!
    Power category
    Connection variant
    Cable cross-section
    Tauro 50-3
    Tauro Eco 50-3
    Single core / multi-core
    35 - 240 mm2 *
    Optional AC disconnector
    35 - 240 mm2 *
    Daisy chain (without AC disconnector)
    35 - 240 mm2 *
    Tauro ECO 99-3
    Tauro ECO 100-3
    70 - 240 mm2 *
    70 - 240 mm2 *
    70 - 240 mm2 *
    * The cable cross-section of the neutral conductor can be reduced to 25 mm² if no local guidelines or standards require otherwise.
    NOTE!
    There is no general requirement to use a residual current circuit breaker.
    Nonetheless, if a residual current circuit breaker (RCD) is used then it must be a type B with a release current of at least 1000 mA.
    NOTE!
    The inverter may be used with a maximum C355 A automatic circuit breaker.
    50-3-D / 50-3-P
    Eco 50-3-D / 50-3-P
    Eco 99-3-P
    Eco 99-3-D
    Eco 100-3-P
    Eco 100-3-D
    Recommended output overcurrent protection [A]
    for 50 kW output power
    80
    80
    for 100 kW output power
    (Example: daisy chaining)
    160
    160
    160
    160
    160
    160
    for 150 kW output power
    250
    250
    250
    250
    250
    250
    for 200 kW output power
    355
    355
    355
    355
    355
    355
    The clamping range of the V-type terminal is 35 - 150 mm² when delivered. The clamping range can be changed to 185 - 240 mm² by a simple modification of the V-type terminal.
    An optional hole can be made on the right side of the housing at the bottom for an additional PE introduction.
    CAUTION!
    Danger from faulty or incorrect holes.
    This may lead to injuries to the eyes and hands as a result of flying debris and sharp edges, as well as damage to the inverter.
    When drilling, wear suitable protective goggles.
    Only use a step drill when drilling.
    Ensure that nothing is damaged inside the device (for example connection block).
    Adapt the diameter of the hole to match the corresponding connection.
    Deburr the holes using a suitable tool.
    Remove the drilling residues from the inverter.
    Insert the screw connection in the hole and secure to the torque specified by the manufacturer.
    The opening must be sealed in accordance with the protection class of the inverter!
    Safety
    WARNING!
    Danger from mains voltage and DC voltage from PV modules.
    Prior to any connection work, ensure that the inverter is de-energized on the AC side and the DC side.
    Only an authorized electrical engineer is permitted to connect this equipment to the public grid.
    CAUTION!
    Danger of damaging the inverter due to improperly connected wires.
    Improperly connected wires can cause thermal damage to the inverter and may cause a fire.
    When connecting AC and DC wires, make sure that all cables are secured to the inverter connections using the correct torque.
    IMPORTANT! For the PE connection, the requirements defined under "Safety rules" for safe connection of the PE conductor must also be observed.
    Ensure that the phases are connected in the right order: PE, N, L1, L2 and L3.
    5
    6
    7
    Ensure that the phases are connected in the right order: PE, PEN, L1, L2 and L3.
    NOTE!
    The PEN conductor must be produced with ends that are permanently marked blue, according to the national provisions.
    5
    6
    7
    8
    When connecting, ensure that the phases are in the correct order: PE, N, L1, L2 and L3.
    5
    6
    Secure to the torque specified by the manufacturer of the strain-relief device. The strain-relief device is not part of the scope of supply.
    7
    8
    9
    5
    6
    7
    8
    9
    10
    Alternatively, a cable with a cable lug can be connected to the M12 threaded bolts on the grid connections in order to connect the cables to the V-type terminals.
    Safety
    WARNING!
    Danger due to grid voltage and DC voltage from solar modules that are exposed to light.
    Prior to any connection work, disconnect the inverter on the AC side and the DC side.
    Only an authorized electrical technician is permitted to connect this equipment to the public grid.
    WARNING!
    Danger of electric shock due to incorrectly connected terminals / PV plug connectors.
    When connecting version D ("direct string"), ensure that every pole of a string is fed across the same PV input, e.g.:
    "+ pole string 1" at input PV 1.1+ and "- pole string 1" at input PV 1.1-
    WARNING!
    Danger from DC voltage. Even when the DC disconnectors are switched off, the fuse boards (100-3-D / 99-3-D) / fuse board (50-3-D) and everything before the DC disconnectors are live.
    CAUTION!
    Risk of damage to the inverter as the result of incorrectly tightened terminals.
    Incorrectly tightened terminals can cause heat damage to the inverter that may result in a fire.
    When connecting AC and DC cables, ensure that all the terminals are tightened to the specified torque.
    CAUTION!
    Risk of damage to the inverter due to PV modules that are not connected with the correct polarity.
    PV modules that are not connected with the correct polarity can cause thermal damage to the inverter.
    Measure the DC cables from the PV modules and connect them to the inverter with the correct polarity.
    CAUTION!
    Risk of damage to the inverter by exceeding the maximum input current per string.
    Exceeding the maximum input current per string can cause damage to the inverter.
    Observe the maximum input current per string for the inverter according to the technical data.
    The maximum input current must not be exceeded even when using Y or T connectors.
    2. Connecting the PV cable to the inverter
    Safety
    WARNING!
    WARNING!
    WARNING!
    CAUTION!
    CAUTION!
    CAUTION!
    To enable suitable PV modules to be chosen and to use the inverter as efficiently as possible, it is important to bear the following points in mind:
    • If insolation is constant and the temperature is falling, the open circuit voltage of the PV modules will increase. The open circuit voltage must not exceed the max. permissible system voltage. An open circuit voltage above the indicated values will damage the inverter, and all warranty rights will become null and void.
    • The temperature coefficients on the data sheet of the PV modules must be observed.
    • Exact values for sizing the PV modules can be obtained using suitable calculation tools, such as the Fronius Solar.creator.
    IMPORTANT!
    Before connecting up the PV modules, check that the voltage for the PV modules specified by the manufacturer corresponds to the actual measured voltage.
    IMPORTANT!
    The PV modules connected to the inverter must comply with the IEC 61730 Class A standard.
    IMPORTANT!
    Solar module strings must not be grounded.
    Permitted cables
    DC connections
    Select a sufficiently large cable cross-section based on the device type! The temperature resistance of the DC cables must be at least 90 °C.
    Power category
    Device type
    Cable cross-section
    Tauro 50-3 / Eco 50-3 /
    Eco 99-3 / Eco 100-3
    pre-combined
    25 - 95 mm2
    direct
    2.5 - 10 mm² (see data sheet of the plug)
    CAUTION!
    Risk of damage to the inverter as the result of incorrectly fused PV lines.
    PV lines for the "pre-combined" model that are not fused can cause damage to the inverter.
    PV lines must be fused in a combiner box before the inverter ("pre-combined" version).
    * DC fuse optional depending on national standard / DC breaker optional / DC SPD optional
    Distribute the existing solar module strings evenly between the PV inputs (PV1 / PV2 / PV3) of the inverter.
    Start with the odd inputs first and then fill the even inputs to distribute the power as evenly as possible and increase the service life of the fuses, for example: (1.1, 2.1, 3.1, 1.3, 2.3etc.).
    Connect the PV cables from the solar modules to the MC4 connectors as labeled
    Unused MC4 connectors on the inverter must be covered with the cover plates supplied with the inverter.
    MC4 connector cover
    To protect the MC4 connectors, a cover plate can be mounted on the inverter. The cover plate can be ordered as an optional accessory together with the floor racks.
    Solar module strings that are combined in a DC combiner box, must, according to the applicable national regulations, be fused per string in the DC combiner box!
    Before working in the connection area of the inverter, the DC voltage must be switched off. This can also be done in the DC combiner box.
    5
    6
    7
    8
    CAUTION!
    Danger due to faulty fuses.
    This can lead to fires.
    Only replace faulty fuses with new ones of the same rating.
    Do not replace faulty fuses with bolts.
    CAUTION!
    Danger due to incorrectly dimensioned string fuses
    Incorrectly dimensioned string fuses can cause damage to the inverter for these connected components.
    The following string fuses should be used for the -D (direct) version of the Fronius Tauro:
    Max. 10 A per string → use of 15 A gPV fuse 1000 V possible (Fronius item number: 41,0007,0230 - fuse 15 1000 F PV 15A)
    Max. 14.5 A per string → use of 20 A gPV fuse 1000V required (Fronius item number: 41,0007,0233 - fuse-HL 20 A 1KV fast)
    Max. 22 A per string → use of 30 A gPV fuse 1000V required (Fronius item number: 41,0007,0241 - fuse-HL 30 A 1KV fast)
    Replacing fuses:
    Fronius Tauro 50-3-D string 1.1 - 3.7 /
    Fronius Tauro 50-3-D (30 A fuses) string 1.1 - 3.5 /
    Fronius Tauro Eco 50-3-D string 1.1 - 2.7 /
    Tauro Eco 50-3-D (30 A fuses) string 1.1 - 2.5 /
    Fronius Tauro Eco 99 / 100-3-D string 1.1 - 2.7 /
    Fronius Tauro Eco 99 / 100-3-D (30 A fuses) string 1.1 - 3.5
    Check values! Only replace faulty fuses with new ones of the same rating.
    Replacing fuses:
    Fronius Tauro Eco 99 / 100-3-D string 3.1 - 3.8
    5
    WARNING!
    Danger due to DC disconnectors that are not switched on properly
    Turn all existing DC disconnectors to the ON position before turning on the AC connection.
    The DC disconnectors may only ever be actuated simultaneously (one immediately after the other).
    5
    The WLAN access point can be opened with the optical sensor, see chapter Button functions and LED status indicator on page (→)
    6
    Modbus participants
    The inputs M0 and M1 can be freely selected. A maximum of 4 Modbus participants can be connected to the Modbus terminal on inputs M0 and M1.
    IMPORTANT!
    If the function “Inverter control via Modbus” is activated in the menu area “Communication” → “Modbus”, no Modbus participants are possible. It is not possible to send and receive data at the same time.
    2. Connecting the data communication cables
    Modbus participants
    IMPORTANT!
    Cables with the following design can be connected to the terminals of the inverter:
    • Copper: round, solid
    • Copper: round, fine-stranded
    WSD connections with push-in terminal
    Distance
    max.
    Stripping length
    Solid
    Fine-stranded
    Fine-stranded with ferrules with collar
    Fine-stranded with ferrules without collar
    Cable recommendation
    100 m
    10 mm
    0.14 - 1.5 mm2
    0.14 - 1.5 mm2
    0.14 - 1 mm2
    0.14 - 1.5 mm2
    min. CAT 5 UTP
    Modbus connections with push-in terminal
    Distance
    max.
    Stripping length
    Solid
    Fine-stranded
    300 m
    10 mm
    0.14 - 1.5 mm2
    0.14 - 1.5 mm2
    0.14 - 1 mm2
    0.14 - 1.5 mm2
    min. CAT 5 STP
    IO connections with push-in terminal
    Distance
    max.
    Stripping length
    Solid
    Fine-stranded
    30 m
    10 mm
    0.14 - 1.5 mm2
    0.14 - 1.5 mm2
    0.14 - 1 mm2
    0.14 - 1.5 mm2
    Single conductors possible
    LAN connections
    Fronius recommends using at least CAT 5 STP (shielded twisted pair) cables and a maximum distance of 100 m.
    The network cabling of the inverters must be in a star arrangement. Observe the maximum lengths and requirements for the cable!
    In order to be able to use the connection to Fronius Solar.web or Modbus TCP, each Tauro must be connected directly to the network via LAN.
    IMPORTANT! If data communication cables are wired into the inverter, observe the following points:
    • Depending on the number and cross-section of the wired data communication cables, remove the corresponding blanking plugs from the sealing insert and insert the data communication cables.
    • Make sure that you insert the corresponding blanking plugs into any free openings on the sealing insert.
    Note! Ingress protection rating IP65 cannot be ensured if blanking plugs are missing or incorrectly inserted.
    Remove the cap nut on the strain-relief device and press the sealing ring out from the inside of the device using the blanking plugs.
    Open up the sealing ring at the location where the blanking plugs are to be removed.
    * Remove the blanking plugs with a sideways motion.
    First, guide the data cables through the cap nut of the strain-relief device and then through the housing opening.
    Insert the sealing ring between the cap nut and the housing opening. Press the data cables into the seal's cable guide. Then press in the seal until it reaches the underside of the strain-relief device.
    5
    Connect the data cables to the data communication area using a movement loop, and fasten the cap nut with min. 2.5–max. 4 Nm.
    IMPORTANT!
    The push-in WSD terminal in the inverter's connection area is delivered with a bypass ex works as standard. The bypass must be removed when installing a trigger device or a WSD chain.
    The WSD switch of the first inverter with connected trigger device in the WSD chain must be in position 1 (master). The WSD switch of all other inverters should be in position 0 (secondary device).
    Max. distance between 2 devices: 100 m
    Max. Number of devices: 28
    * Floating contact of the trigger device (e.g., central grid and system protection). If several floating contacts are used in a WSD chain, these must be connected in series.
    First startup
    When starting the inverter for the first time, various setup settings must be configured.
    If the setup is canceled before completion, the input data is not saved and the start screen with the installation wizard is shown once again. The data is saved in the event of an interruption, e.g., a power failure. Commissioning is continued at the point at which the interruption occurred after the power supply is restored. If the setup was interrupted, the inverter feeds energy into the grid at maximum 500 W and the operating status LED flashes yellow.
    The country setup can only be set when starting the inverter for the first time. If the country setup needs to be changed at a later date, contact your installer/technical support.
    2. First startup
    2. First startup
    To simplify the display, the vertical installation position of the Pilot PC board (LED display) is shown horizontally below.
    2. First startup
    The Fronius Solar.start app is required for installation. Depending on the mobile device used to perform the installation, the app is available on the relevant platform.
    1Download and install the Fronius Solar.start app.
    2Open the access point by touching the sensor    .
    ✓Communication LED flashes blue.
    3Open the Fronius Solar.start app and follow the installation wizard. Scan the QR code on the rating plate with a smartphone or tablet to connect to the inverter.
    4Add system components in Fronius Solar.web and commission the PV system.
    2. First startup
    WiFi:
    1Open the access point by touching the sensor    .
    2Establish the connection to the inverter in the network settings (the inverter is displayed with the name "FRONIUS_" and the serial number of the device).
    3Enter the password from the rating plate and confirm.
    IMPORTANT!
    To enter the password, first select the Connect using a security key instead link in order to establish the connection with the password.
    4Enter the IP address 192.168.250.181 in the address bar of the browser and confirm. The installation wizard opens.
    5Follow the installation wizard and complete the installation in the individual areas.
    6Add the system components in Fronius Solar.web and commission the PV system.
    Ethernet:
    1Establish a connection to the inverter (LAN1) using a network cable (min. CAT5 STP).
    2Open the access point by touching the sensor once    .
    3Enter the IP address 169.254.0.180 in the address bar of the browser and confirm. The installation wizard opens.
    4Follow the installation wizard and complete the installation in the individual areas.
    5Add the system components in Fronius Solar.web and commission the PV system.
    Disconnecting the inverter from the power supply:
    1Switch off the automatic circuit breaker (AC and, if present, battery).
    2Turn the DC disconnector to the "Off" switch setting.
    IMPORTANT!
    Wait for the capacitors of the inverter to discharge!
    Switching on the inverter:
    If the inverter has not been in operation for six months or more after installation, it must be tested before commissioning.
    1Turn the DC disconnector to the "On" switch setting.
    2Switch on the automatic circuit breaker (AC and, if present, battery).
    2. De-energizing the inverter and switching it back on
    IMPORTANT!
    User settings
    User login
    1Open the user interface of the inverter in the browser.
    2In the Login menu area, log in with username and password, or, in the User > User Login menu area, log in with username and password.
    IMPORTANT!
    Depending on the authorization of the user, settings can be made in the individual menu areas.
    1. Settings – User interface of the inverter
    User settings
    User login
    IMPORTANT!
    2. User settings
    User login
    IMPORTANT!
    2. User settings
    Selecting languages
    1In the User > Language menu area, select the desired language.
    Components
    All available components of the system can be added via "Add component+".
    PV Generator
    Activate the respective PV generator and enter the connected PV output in the relevant field.
    Primary meter
    For problem-free operation with further energy generators, it is important to install the Fronius Smart Meter at the feed-in point. The inverter and further generators must be connected to the public grid via the Fronius Smart Meter. This setting also has an effect on the behavior of the inverter during the night. If the function is deactivated, the inverter switches to standby mode as soon as there is no more PV power available. The message "Power low" appears. The inverter starts up again as soon as sufficient PV power is available.
    After connecting the meter, select one of the following device types:
    • Modbus RTU
    • Modbus TCP
    • MQTT (available MQTT device is displayed automatically)
    NOTE!
    For communication via MQTT, the inverter and Smart Meter must be in the same sub-network.
    The following parameters must also be defined for the Smart Meter:
    • Application (Production meter or Secondary meter)
    • Name
    • Category (e.g., Inverter)
    • IP Address (for Modbus TCP)
    • Port (for Modbus TCP)
    • Modbus Address (for Modbus RTU and TCP)
    Several Fronius Smart Meters can be installed in the system. The Watt value in the "Production meter" field is the sum of all the production meters. The Watt value in the "Consumption meter" field is the sum of all the secondary meters.
    Ohmpilot
    All the Ohmpilots available in the system are displayed. Select the desired Ohmpilot and add to the system via "Add".
    2. Device configuration
    Components
    PV Generator
    Primary meter
    • Modbus RTU
    • Modbus TCP
    NOTE!
    • Name
    Ohmpilot
    Functions and IOs
    Load Management
    Select up to four pins for the load management. Further settings for the load management are available in the Load Management menu item.
    Default: Pin 1
    Australia - Demand Response Modes (DRM)
    Activate the slider if DRM is required. Configure the pins for control via DRM as follows:
    Mode
    Description
    Information
    Default pin
    DRM0
    Inverter disconnects from the grid
    Grid relays open
    REF GEN
    RG0
    COM LOAD
    CL0
    DRM0 occurs in the event of an interruption or short circuit on the REF GEN or COM LOAD lines. Or in the event of an invalid combination of DRM1—DRM8.
    IMPORTANT! If the Australia - Demand Response Modes (DRM) function is activated and no DRM control is connected, the inverter switches to standby mode.
    Here, for the Australian country setup, a value for the apparent power consumption and the apparent power output can be entered.
    Inverter
    "Force standby"
    When this function is activated, the power feed from the inverter into the grid is interrupted. This makes it possible to shut down the inverter without power and protect its components. The standby function is automatically deactivated when the inverter is restarted.
    "PV 1" and "PV 2"
    Parameter
    Value range
    Description
    "Mode"
    Off
    The MPP tracker is deactivated.
    Auto
    The inverter uses the voltage at which the maximum possible output of the MPP tracker is possible.
    Fixed
    The MPP tracker uses the voltage defined in "UDC fixed".
    "UDC fixed"
    80 ‑ 530 V
    The inverter uses the fixed voltage that is used on the MPP tracker.
    Off
    Function is deactivated.
    On
    The entire solar module string is checked for optimization potential and the best possible voltage for the supply of energy from the inverter into the grid is determined.
    "Ripple control signal"
    Ripple control signals are signals that are sent by the energy company in order to switch controllable loads on and off. Depending on the installation situation, ripple control signals can be dampened or amplified by the inverter. This can be counteracted if necessary by applying the following settings.
    Parameter
    Value range
    Description
    "Reduction of influence"
    Off
    On
    Function is activated.
    "Frequency of the ripple control signal"
    100 ‑ 3000 Hz
    The frequency specified by the energy company must be entered here.
    "Grid inductance"
    0.00001 ‑ 0.005 H
    The value measured at the feed-in point must be entered here.
    "Measure against RCD false triggers"
    (when using a 30 mA residual current circuit breaker)
    NOTE!
    A residual current circuit breaker for the AC connecting cable may be required depending on national regulations, the grid operator, and other conditions.
    A type A residual current circuit breaker is generally sufficient in this case. Nevertheless, false alarms can be triggered for the type A residual current circuit breaker in individual cases and depending on local conditions. For this reason, Fronius recommends using a residual current circuit breaker suitable for frequency inverters with a release current of least 100 mA, taking into account national provisions.
    Parameter
    Value range
    Description
    Leakage current factor to reduce RCMU/FI false tripping
    0 ‑ 0.25
    (default: 0.16)
    By reducing the setting value, the leakage current is reduced and the intermediate circuit voltage is increased, which slightly lowers the efficiency.
    • A setting value of 0.16 ensures optimum efficiency.
    • A setting value of 0 enables minimum leakage currents.
    Shutdown before 30 mA RCD triggers
    Off
    The function for reducing false tripping of the residual current circuit breaker is deactivated.
    On
    The function for reducing false tripping of the residual current circuit breaker is activated.
    Rated non-tripping fault current limit value
    0.015 ‑ 0.3
    Value of the non-tripping residual current specified by the manufacturer for the residual current circuit breaker at which the residual current circuit breaker does not switch off under specified conditions.
    "Insulation warning"
    Parameter
    Value range
    Description
    Off
    The insulation warning is deactivated.
    On
    The insulation warning is activated.
    A warning is output in the event of an insulation fault.
    "Insulation measurement mode"
    Exact
    Insulation monitoring takes place with the highest degree of accuracy and the measured insulation resistance is displayed on the user interface of the inverter.
    Fast
    Insulation monitoring takes place with a lesser degree of accuracy, whereby the time to take the insulation measurement is shortened and the insulation value is not displayed on the user interface of the inverter.
    "Threshold for the insulation warning"
    10 ‑
    10,000 kΩ
    If the value drops below the threshold, status code 1083 is displayed on the user interface of the inverter.
    System
    link_horizontalLink copied
    General
    1Enter the name of the system in the input field PV System Name (max. 30 characters).
    2Select the Timezone Region and Timezone Location in the drop-down lists.
    3Click Save.
    ✓System name, time zone, and time zone location are saved.
    2. System
    General
    3Click Save.
    2. System
    Update
    All available updates for inverters and other Fronius devices are provided on the product pages and in the "Fronius Download Search" area at www.fronius.com .
    Update
    1Drag the firmware file into the Drag & drop file here field, or select via Browse file.
    ✓Update is started.
    2. System
    Setup wizard
    The guided setup wizard can be accessed here.
    2. System
    Restoring factory settings
    All settings
    Resets all configuration data, apart from the country setup. Changes to the country setup may only be made by authorized personnel.
    All settings without network
    Resets all configuration data, apart from the country setup and the network settings. Changes to the country setup may only be made by authorized personnel.
    2. System
    Event log
    Current messagesAll current events of the linked system components are displayed here.
    IMPORTANT!
    Depending on the type of event, this must be confirmed via the "tick" button so that it can be further processed.
    History
    All events of the linked system components that are no longer present are displayed here.
    2. System
    Information
    All the information regarding the system and the current settings is displayed and provided for download in this menu area.
    2. System
    License Manager
    The power data and functional scope of the inverter are stored in the license file.
    If the inverter, power stage set control PCB, or the data communication area is replaced, the license file must also be replaced.
    2. System
    Licensing
    Licensing - online (recommended)
    This requires an Internet connection and a completed Fronius Solar.web configuration.
    1Finish all installation work (refer to the chapter headed Starting the inverter for the first time on page (→)).
    2Establish a connection to the user interface of the inverter.
    3Enter the serial number and verification code (VCode) of the defective and replacement device. The serial number and VCode can be found on the rating plate of the inverter (refer to the chapter headed Information on the device on page (→)).
    4Click the Start online licensing button.
    5Skip past the Terms and conditions of use and Network settings menu items by clicking Next.
    ✓License activation is started.
    Licensing - offline
    There must be no Internet connection in this case. If offline licensing is carried out while there is an active Internet connection, the license file is automatically loaded onto the inverter, resulting in the following error when the license file is uploaded: "The license has already been installed and the wizard can be closed".
    1Finish all installation work (refer to the chapter headed First startup on page (→)).
    4Click the Start offline licensing button.
    5Download the service file onto the mobile device by clicking the Download service file button.
    6Open licensemanager.solarweb.com and log in with username and password.
    7Drag the service file into the Drag service file here or click to upload field or click to upload it.
    8Download the newly generated license file onto the mobile device by clicking the Download license file button.
    9Switch to the user interface of the inverter and drag the license file into the Drag & drop license file here field or select via Choose license file.
    2. System
    Support
    Activating the support user
    1Click the Enable Support User Account button.
    ✓The support user is activated.
    IMPORTANT!
    The support user exclusively enables Fronius Technical Support to configure settings on the inverter via a secure connection. Access is deactivated by clicking the Terminate Support User Session button.
    Generating support info (for Fronius Support)
    1Click the Generate support info button.
    2The sdp.cry file is downloaded automatically. For manual download, click the Download support info button.
    ✓The sdp.cry file is saved in the downloads.
    Activating remote access
    1Click the Activate Remote Access button.
    ✓Remote access is activated for Fronius Support.
    IMPORTANT!
    The remote access exclusively enables Fronius Technical Support to access the inverter via a secure connection. In this case, diagnostics data are transmitted, which are used for troubleshooting. The remote access can be activated only upon request by Fronius Support.
    Communication
    Network
    Server addresses for data transfer
    If a firewall is used for outgoing connections, allow the below protocols, server addresses, and ports for successful data transfer, see:
    When using FRITZ!Box products, configure Internet access without any restrictions or limitations. Do not set the DHCP Lease Time (validity) to 0 (=infinite).
    LAN:
    Establishing a connection:
    1Enter the host name.
    2Select the connection type: Automatic or Static.
    3For the Static connection type, enter the IP address, subnet mask, DNS, and gateway.
    4Click the Connect button.
    ✓The connection is established.
    After establishing the connection, check the connection status.
    WiFi:
    Establishing a connection via WPS:
      Activate the access point of the inverter. This is opened by touching the sensor    > Communications LED flashes blue
    1.
    2.
    IMPORTANT!
    3.
    4.
    In the Communication > Network > WLAN > WPS menu area, click the Activate button.
    5.
    Activate WPS on the WiFi router (see WiFi router documentation).
    6.
    Click on the Start button. The connection is established automatically.
    7.
    Log in to the user interface of the inverter.
    8.
    Check the network details and connection to Fronius Solar.web.
    1Establish the connection to the inverter in the network settings (the inverter is displayed with the name "FRONIUS_" and the serial number of the device).
    2Enter the password from the rating plate and confirm.
    IMPORTANT!
    3Enter the IP address 192.168.250.181 in the address bar of the browser and confirm.
    4In the Communication > Network > WLAN > WPS menu area, click the Activate button.
    5Activate WPS on the WiFi router (see WiFi router documentation).
    6Click on the Start button. The connection is established automatically.
    7Log in to the user interface of the inverter.
    8Check the network details and connection to Fronius Solar.web.
    After connecting, the status of the connection should be checked.
    Selecting and connecting to a WiFi network:
    The networks found are displayed in the list. Click the refresh button    to perform a new search for available WiFi networks. If necessary, restrict the selection list further via the Search network input field.
    1Select network from the list.
    3For the Automatic connection type, enter the WiFi password and host name.
    4For the Static connection type, enter the IP address, subnet mask, DNS, and gateway.
    5Click the Connect button.
    Access point:
    The inverter serves as the access point. A PC or mobile device connects directly to the inverter. Connecting to the Internet is not possible. Assign a Network Name (SSID) and Network Key (PSK) to establish a connection. Assign a Network Key (PSK) with at least 20 characters, consisting of upper and lower case letters, special characters, and numbers, to protect the device from unauthorized access.
    It is possible to operate a connection via WiFi and via the access point at the same time.
    2. Communication
    Network
    LAN:
    WiFi:
    1.
    2.
    IMPORTANT!
    3.
    4.
    5.
    6.
    7.
    8.
    IMPORTANT!
    Access point:
    2. Communication
    Modbus
    To use the Modbus TCP or the connection to Fronius Solar.web, each Tauro must be connected directly to the network via LAN.
    Modbus RTU interface 0 / 1
    If one of the two Modbus RTU interfaces is set to Slave, the following input fields are available:
    Baud rate
    The baud rate influences the transmission speed between the individual components connected in the system. When selecting the baud rate, ensure that it is the same at both the sending and receiving end.
    Parity
    The parity bit can be used to check the parity. It detects transmission errors. A parity bit can safeguard a specific number of bits. The value (0 or 1) of the parity bit must be calculated by the sender and is checked by the recipient using the same calculation. The parity bit can be calculated for even and odd parity.
    SunSpec Model Type
    Depending on the SunSpec model, there are two different settings.
    float: SunSpec Inverter Model 111, 112, 113 or 211, 212, 213.
    int + SF: SunSpec Inverter Model 101, 102, 103 or 201, 202, 203.
    Meter address
    The value entered is the identification number (Unit ID) assigned to the meter. Can be found on the user interface of the inverter in the Communication → Modbus menu.
    Factory setting: 200
    Meter address
    Factory setting: 1
    Slave as Modbus TCP
    This setting is necessary to enable inverter control via Modbus. If the function Slave as Modbus TCP is activated, the following input fields are available:
    Modbus port
    Number of the TCP port that is to be used for Modbus communication.
    SunSpec Model Type
    Meter address
    Inverter address
    The value entered is the identification number (Unit ID) assigned to the inverter. Can be found on the user interface of the inverter in the Communication → Modbus menu.
    Factory setting: This value is invariably defined as 1.
    If this option is activated, the inverter is controlled via Modbus.
    Inverter control includes the following functions:
    • on/off
    • Power reduction
    • Specification of a constant power factor (cos phi)
    • Specification of a constant reactive power value
    Restrict Control
    An IP address can be entered here, which is the only one authorized to control the inverter.
    2. Communication
    Cloud control
    The utility/energy supplier can influence the output power of the inverter with Cloud control. This requires the inverter to have an active Internet connection.
    Parameter
    Display
    Description
    Cloud control
    Off
    Cloud control of the inverter is deactivated.
    On
    Cloud control of the inverter is activated.
    Profile
    Value range
    Description
    Allow cloud control for regulatory purposes (Technician)
    Deactivated/Activated
    The function may be mandatory for proper operation of the system.*
    Allow cloud control for Virtual Power Plants (Customer)
    If the Allow remote control for regulatory purposes (technician) function is activated (technician access required), the Allow remote control for virtual power plants function is automatically activated and cannot be deactivated.*
    * Cloud control
    A virtual power plant is an interconnection of multiple generators. This virtual power plant can be controlled by means of the cloud control via the Internet. An active inverter Internet connection is a prerequisite for this. System data are transferred.
    2. Communication
    Solar API
    The Solar API is an IP-based, open JSON interface. If enabled, IOT devices in the local network may access inverter information without authentication. For security reasons, the interface is disabled in the factory. Activate the interface manually if it is required for a third-party application (e.g., EV charger, smart home solutions, etc.). If there is a Fronius Wattpilot in the network, the inverter automatically activates the Solar API.
    Fronius recommends using Fronius Solar.web for monitoring and analyzing the inverter and connected system components.
    In the event of a firmware update to version 1.14.x, the Solar API setting is applied. In systems with a version below 1.14.x, the Solar API is activated; with higher versions, it is deactivated but can be switched on and off via the menu.
    Manually activating the Fronius Solar API
    On the user interface of the inverter in the Communication > Solar API menu area, activate the function Activate communication via Solar API.
    2. Communication
    Fronius Solar.web
    In this menu, you can agree to the technically necessary data processing or reject it.
    In addition, the transfer of analysis data and remote configuration via Fronius Solar.web can be enabled or disabled.
    Safety and grid requirements
    Country setup
    WARNING!
    Danger from unauthorized fault analyses and repair work.
    Fault analyses and repair work on the PV system may only be carried out by installers/service technicians from authorized specialist companies in accordance with national standards and regulations.
    NOTE!
    Risk due to unauthorized access.
    Incorrectly set parameters can have a negative effect on the public grid and/or the grid power feed operation of the inverter and result in the loss of standard conformity.
    Parameters may only be adjusted by installers/service technicians from authorized specialist companies.
    Do not give the access code to third parties and/or unauthorized persons.
    NOTE!
    Risk due to incorrectly set parameters.
    Incorrectly set parameters can have a negative effect on the public grid and/or cause inverter malfunctions and failures and result in the loss of standard conformity.
    Parameters may only be adjusted if this has been approved or requested by the utility.
    Any parameter adjustments must be made in compliance with nationally applicable standards and/or directives as well as the specifications of the utility.
    The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. To apply for the access code required for this menu area, see chapter Requesting inverter codes in Solar.SOS.
    The selected country setup for the country in question contains preset parameters in accordance with nationally applicable standards and requirements. Changes may need to be made to the selected country setup depending on local grid conditions and the specifications of the utility.
    2. Safety and grid requirements
    Country setup
    WARNING!
    NOTE!
    NOTE!
    The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. The inverter access code required for this menu area can be requested in the Fronius Solar.SOS portal.
    Requesting inverter codes in Fronius Solar.SOS:
    1.
    Open solar-sos.fronius.com in the browser
    2.
    Log in with your Fronius account
    3.
    At the top right, click on the drop-down menu
    4.
    Select the Show inverter codes menu item
    5.
    A contract page appears on which the request for the access code to change the grid parameters for Fronius inverters is located
    6.
    Accept the terms and conditions of use by checking Yes, I have read and agree to the terms of use and click Confirm & Save
    7.
    After that, the codes can be retrieved in the drop-down menu at the top right under Show inverter codes
    1Open solar-sos.fronius.com in the browser
    2Log in with your Fronius account
    3At the top right, click on the drop-down menu
    4Select the Show inverter codes menu item
    ✓A contract page appears on which the request for the access code to change the grid parameters for Fronius inverters is located
    5Accept the terms and conditions of use by checking Yes, I have read and agree to the terms of use and click Confirm & Save
    6After that, the codes can be retrieved in the drop-down menu at the top right under Show inverter codes
    CAUTION!
    Absolute Generation Limit
    Activating this function limits the output power of the inverter to the specified value in watts.
    Import limitation
    Energy companies or grid operators can prescribe import limitations for inverters. The amperage is limited to the set value.
    1Under Limit select Current Limitation.
    2Enter the limit value in amperes.
    3Click on Save.
    Feed-in limit
    Due to hardware limitations, the Fronius Tauro cannot reduce the power to 0%, but only to 0.5 to 1%.
    Grid operators or utilities can prescribe feed-in limits for an inverter (e.g., max. 70% of the kWp or max. 5 kW).
    The feed-in limit takes account of self-consumption before the power of an inverter is reduced:
    There are two options for the feed-in limit:
    1. Easily reduce the power of an inverter with a Fronius Smart Meter
    2. Reduce the power with an external plant controller
    The following formulas provide guidance on which solution can be used:
    PWRn ... Power of inverter n
    0% PWR1 + 100% PWR2 + 100% PWR3... ≤ feed-in limit → solution a)
    0% PWR1 + 100% PWR2 + 100% PWR3... > feed-in limit → solution b)
    Solution a) – Power reduction of a single inverter
    The specifications can be met if the prescribed feed-in limit is reached by reducing the power of a single inverter to ≥ 0%.
    Example:
    There are 3 inverters in a system: 1x Fronius Tauro 100 kW, 2x Fronius Tauro 50 kW. The specified feed-in limit at the transfer point must not exceed 100 kW.
    Solution:
    The Fronius Tauro can be regulated to 0% output power to meet the feed-in limit. The power of the other two inverters is not reduced and can be fed in at any time without restriction.
    If the power reduction of an inverter to 0% is not sufficient, solution b) must be used.
    Solution b) – Integration of a plant controller
    This solution is used if the requirements of the utility cannot be met by limiting a single inverter or if permanent access (e.g., remote shutdown) is required. In this case, the integration of a PLANT CONTROLLER is recommended.
    A detailed technical overview of this solution can be found at www.fronius.com using the keyword "feed-in management".
    In order to benefit from the advantages of Fronius Solar.web in addition to the monitoring function of the PLANT CONTROLLER system, a Fronius Smart Meter can also be installed. The integration of a Fronius Smart Meter ensures that the consumption and feed-in data of the PV system are visualized in Fronius Solar.web and are available for analysis.
    Total DC power of the system
    Input field for the total DC power of the entire system in Wp. Always enter this value if the Maximum grid feed-in power is specified in %.
    Power Control deactivated
    The inverter converts all available PV energy.
    Power Control activated
    Feeding in limited with the following selection options:
    • Total Power Limit
      The entire photovoltaic system is limited to a fixed feed-in limit. Set a value for the permissible total power of feeding in.
    • Limit per phase – weakest phase
      The inverter measures each individual phase. If the permissible feed-in limit is exceeded on one phase, the inverter symmetrically reduces the total power for all phases until the limit is reached.
    Export Limit Control (Soft Limit)
    If this value is exceeded, the inverter readjusts down to the set value. The adjustment of the value takes place within the time required by the national standards and regulations.
    Input field for the Maximum grid feed-in power in W or % (setting range: -10 to 100%).
    If there is no meter in the system or if the primary meter has failed, the inverter limits its output power to the set value.
    Export Limit Protection (PAV,E protection)
    This function monitors compliance with the feed-in limit. If Dynamic feed-in limit (Soft Limit) is activated, the inverter controls the power of feeding in in such a way that this function is usually not activated. If the specified limit values and the switch-off times are exceeded, this protection function disconnects the inverter from the grid.
    The Maximum grid feed-in power (PAV,E) in the case of an asymmetric feed-in (Limit per phase – weakest phase) can be combined with the export limit protection (PAV,E protection) function. The Maximum grid feed-in power is calculated as follows: Maximum grid feed-in power per phase (PAV,E) x 3.
    The export limit protection (PAV,E protection) function is only possible if a Smart Meter IP configured with MQTT is installed at the feed-in point.
    Multiple Inverter Control
    IMPORTANT! To view and change settings in this menu item, select the Technician user. Enter and confirm the password for the Technician user. Settings in this menu area may only be made by technical specialists.
    The inverter can be used as a primary device to control dynamic feed-in limits for additional Fronius inverters (secondary devices) so that feed-in limits prescribed by energy companies or utilities can be centrally managed. This control refers to the Soft Limit feed-in limit, see Feed-in limit. To do so, the following requirements must be met:
    • A Fronius Smart Meter is configured as a primary meter and connected to the master.
    • Power Control is enabled and configured in the Feed-in limit menu on the user interface of the primary device. The power control limit is set to Total Power Limit.
    • Master and secondary device(s) are physically connected to the same network router via LAN.
    • If Use Modbus TCP is enabled, the inverter control via Modbus TCP must be activated and configured for all secondary devices.
    IMPORTANT! Only one primary meter is required for the primary device.
    IMPORTANT! If an inverter with a battery is connected, use this inverter as the primary device for Multiple Inverter Control.
    Example connection diagram for Multiple Inverter Control
    System limits
    • Systems with a maximum of 20 inverters (1 primary device + 19 secondary devices) are supported if the Use Modbus TCP function is enabled. Otherwise, a maximum of one primary device and two secondary devices are supported.
    • The control system is designed for photovoltaic systems with a total output of up to 300 kW.
    • In the case of larger system capacities, the control times in the system are extended.
    • The use of a plant controller is recommended for systems >300 kW.
    External grid and system protection
    Regional standards and guidelines may require the installation of external grid and system protection for systems >30 kVA (see Central grid and system protection).
    Multiple Inverter Control is available for the following device combinations:
    Primary devices
    Secondary devices
    GEN24, Verto, Tauro
    • GEN24
    • Verto
    • Tauro
    • Argeno
    • SnapINverter with Fronius Datamanager 2.0*
    * Up to four additional SnapINverters can be connected to each SnapINverter with Fronius Datamanager 2.0.
    Primary meter
    One Fronius Smart Meter acts as the only primary meter and is connected directly to the primary device. This Smart Meter measures the total output power of all inverters into the grid and passes this information to the primary device.
    Primary device
    Configure the feed-in limit on the user interface of the inverter:
    1In the Safety and Grid Regulations > Feed-in limit menu area, enable the Power Control function and select Total Power Limit.
    2Configure the country-specific settings.
    3In the Safety and Grid Regulations > Multiple Inverter Control menu area, enable the Multiple Inverter Control function.
    The primary device automatically scans the network for available secondary devices.
    ✓A list shows the inverters found.
    To perform the search again, press the Refresh button.
    If Use Modbus TCP is enabled, it is also possible to select Fronius SnapINverters with Datamanager 2.0 and Fronius Argeno with Use Inverter.
    4Enable Use Inverter against all secondary devices to which a common feed-in limit applies. Click Use all Inverters to enable the function for the primary device and all secondary devices.
    The status of the inverters listed is displayed as follows:
    • Inactive: Secondary device is not configured for the power control or a firmware update is required.
    • Disconnected: Secondary device is configured, network connection not possible.
    • Connected: Secondary device is configured and accessible via the network of the primary device.
    5In the Safety and Grid Regulations > I/O Power Management menu area, set the controlling priorities as follows:
    1. I/O Power Management
    2. Feed-in limit
    3. Modbus Control
    Adding Fronius Argeno and other inverters manually
    1In the Multiple Inverter Control menu, select the Multiple Inverter Control function.
    2Select additional inverters and click + Add.
    3Enter the name, hostname or IP address, and the Modbus address of the secondary device.
    4Click Add.
    For more information on configuring the Fronius Argeno or Fronius Datamanager 2.0 as a secondary device, refer to the respective operating instructions.
    Secondary device
    Each secondary device takes over the settings for the feed-in limit from the primary device. A secondary device does not transmit any data for the feed-in limit to the primary device. To do so, the following requirements must be met:
    • Multiple Inverter Control is enabled and configured in the Multiple Inverter Control menu on the user interface of the primary device.
    Set the following configurations for the feed-in limit on the secondary device:
    User interface secondary device GEN24 / Verto / Tauro
    1Select the user Technician and enter the password for the user Technician.
    Only carry out work steps 2 and 3 if Use Modbus TCP is enabled on the primary device.
    2In the Communication > Modbus menu area, enable TCP Server mode and the Allow Control function.
    3For a fail-safe scenario, in the Safety and Grid Regulations > I/O Power Management menu area, set the controlling priorities as follows:
    1. Modbus Control
    2. Feed-in limit
    3. I/O Power Management
    4In the Safety and Grid Regulations > Feed-in limit menu area, select and edit the following settings:
    • Enable the Power Control function.
    • Select Total Power Limit and specify the Total DC power of the system in watts.
    • Enable the Dynamic feed-in limit (Soft Limit) and enter a value of 0 W for the Maximum grid feed-in power.
    • Enable the Reduce inverter power to 0% if meter connection has been lost function.
    General
    Settings relevant to the grid operator are defined as rules under this menu item. This relates to an effective power limit in % or watts and/or a power factor specification. To view and change settings, select the Technician user, and enter and confirm the password. Only technical specialists may make settings in this menu area.
    Under Rules, expand a menu area (e.g., Rule 1). Configure the following settings:
    Limitation
    IMPORTANT!
    A dynamic feed-in limit for several inverters can be configured under Feed-in limit. I/O power management rules are transferred from the inverter (primary device) to connected inverters in the system (secondary devices).
    Select the following rules for power management:
    • I/O Generation Limit (%): The total output power of the connected inverter is statically limited to the defined value of the absolute rated power.
    • Export Limit Control (W): The active power fed in at the grid connection point is limited to the set value (e.g., 5000 watts). The output powers of the inverters (primary and secondary devices) are dynamically adjusted depending on their self-consumption.
    • Shutdown single device: The inverter stops grid power feed operation and switches to standby mode.
    IMPORTANT!
    The rules for shutdown apply to this device and cannot be applied to other inverters in the system.
    Input pattern (assignment of individual I/Os)
    1 click = white, contact open
    2 clicks = blue, contact closed
    3 clicks = gray, not used
    Power Factor (cos φ) (define value)
    Impedance response
    • Capacitive
    • Inductive
    DNO Feedback
    If the rule is activated, always configure the DNO Feedback output, e.g., for operating a signal device.
    The Import and Export of defined rules can be carried out in the data format *.fpc. The rules and pin assignments in the following connection examples are not the only possible configurations. For pin assignment, take into account the available connections at the Data communication area and settings of the device configuration.
    If there is an active rule for the control of the inverter, the device indicates this in the overview of the user interface under Device State.
    Controlling Priorities
    Used to set controlling priorities for I/O Power Management (DRM or ripple control receiver), the feed-in limit, and control via Modbus.
    1 = highest priority, 3 = lowest priority
    Local priorities of the I/O power management, the feed-in limit, and the Modbus interface are deactivated by cloud control commands (regulatory purposes and virtual power plants) – see Cloud control – and by backup power.
    In terms of controlling priorities, the device differentiates between power control and inverter shutdown. Inverter shutdown always takes precedence over power control. An inverter shutdown command is always executed and does not need to be prioritized.
    Power control
    • I/O Power Management (DRM/ripple control receiver signal) – according to command
    • Export Limitation (Soft Limit) – always active
    • Modbus (generation limit) – according to command
    Inverter shutdown
    • Export Limitation (Hard Limit)
    • Modbus (shutdown command) – according to command
    4-relay connection example
    Connect the ripple control signal receiver and the I/O terminals of the inverter to one another as shown in the connection diagram.
    For distances greater than 10 m between the inverter and the ripple control signal receiver, use a shielded data communication cable (CAT 5 or higher) with twisted cable pairs. Connect the shielding on one side to the terminal of the data communication area (SHIELD).
    (1)
    Ripple control signal receiver with 4 relays for effective power limitation.
    (2)
    I/O connection terminals of the data communication area.
    Use pre-configured file for 4-relay operation:
    1Download the file (.fpc) under 4-relay operation to the mobile device.
    2Upload the file (.fpc) in the I/O Power Management menu area by clicking the Import button.
    3Click Save.
    ✓The settings for 4-relay operation are saved.
    I/O power management settings – 4 relay example
    3-relay connection example
    (1)
    Ripple control signal receiver with 3 relays for effective power limitation.
    (2)
    Use pre-configured file for 3-relay operation:
    1Download the file (.fpc) under 3-relay operation to the mobile device.
    3Click Save.
    ✓The settings for 3-relay operation are saved.
    I/O power management settings – 3 relay example
    2-relay connection example
    (1)
    Ripple control signal receiver with 2 relays for effective power limitation.
    (2)
    Use pre-configured file for 2-relay operation:
    1Download the file (.fpc) under 2-relay operation to the mobile device.
    3Click Save.
    ✓The settings for 2-relay operation are saved.
    I/O power management settings – 2 relay example
    1-relay connection example
    (1)
    Ripple control signal receiver with 1 relay for effective power limitation.
    (2)
    Use pre-configured file for 1-relay operation:
    1Download the file (.fpc) under 1-relay operation to the mobile device.
    3Click Save.
    ✓The settings for 1-relay operation are saved.
    I/O power management settings – 1 relay example
    Connecting the ripple control receiver with several inverters
    The grid operator may request the connection of one or more inverters to a ripple control receiver in order to limit the active power and/or the power factor of the photovoltaic system.
    Connection diagram for ripple control receiver with several inverters
    Connect the following Fronius inverters to a ripple control receiver via a distributor (coupling relay):
    • Symo GEN24
    • Primo GEN24
    • Tauro
    • Verto
    • SnapINverter (only devices with Fronius Datamanager 2.0)
    On the user interface of each inverter connected to the ripple control receiver, set the same parameters for I/O power management.
    Appendix
    Status codes and remedy
    Status codes
    1. Appendix
    Status codes
    1. Appendix
    2. Status codes and remedy
    Status codes
    1006 – ArcDetected (operation LED: flashes yellow)
    Cause:An arc was detected at a specific point on the PV system.
    Remedy:No action required. Feed-in mode is restarted again automatically after 5 minutes.
    1030 – WSD Open (operating LED: flashes red)
    Cause:A device that is connected in the WSD chain has interrupted the signal line (e.g., surge protection device) or the bypass installed ex works as standard has been removed and no trigger device has been installed.
    Remedy:If the SPD surge protection device has tripped, the inverter must be repaired by an authorized specialist.
    OR:Install the bypass installed ex works as standard or a trigger device.
    OR:Turn the WSD (wired shutdown) switch to position 1 (WSD primary device).
    WARNING!
    Danger from work that is not carried out properly.
    The installation and connection of an SPD surge protection device may only be carried out by Fronius-trained service personnel in accordance with the technical specifications.
    Observe safety rules.
    1173 – ArcContinuousFault (operating LED: flashes red)
    Cause:An electric arc has been identified on the PV system, and the maximum number of automatic connections within 24 hours has been reached.
    Remedy:Keep the sensor pressed on the inverter for 3 seconds  (max. 6 seconds).
    OR:On the user interface of the inverter, in the System > Event Log menu area, confirm the status 1173 - ArcContinuousFault.
    OR:On the user interface of the inverter, in the Notifications user menu, confirm the status 1173 - ArcContinuousFault.
    CAUTION!
    Danger from damaged components of the PV system
    Serious personal injury/damage to property may result.
    Before the status 1173 - ArcContinuousFault is confirmed, the entire photovoltaic system affected must be checked for any possible damage.
    Damaged components must be repaired by qualified specialists.
    1. Appendix
    Technical data
    Tauro 50-3-D / 50-3-P
    Input data
    Maximum input voltage
    (at 1000 W/m² / -10 °C in an open circuit)
    1000 VDC
    Start-up input voltage
    200 VDC
    MPP voltage range
    400 - 870 VDC
    Number MPP-controller
    Maximum input current (IDC max) Total
    PV1 / PV2 / PV3
    per string (only for D variant)
    134 A
    36 A / 36 A / 72 A
    14.5 A (20 A fuses) / 22 A (30A fuses)
    Max. short circuit current 8) Total
    PV1 / PV2 / PV3
    240 A
    72 A / 72 A / 125 A
    20 A (20 A fuses) / 30 A (30A fuses)
    Maximum PV field power (PPV max) Total
    PV1 / PV2 / PV3
    75 kWp
    25 kWp / 25 kWp / 50 kWp
    DC overvoltage category
    Max. inverter backfeed current to the array 3)
    D variant PV1 / PV2 / PV3
    P variant PV1 / PV2 / PV3
    72 / 72 / 125 A4)
    0 / 0 / 0 A4)
    Max. capacity of the PV generator against earth
    inverter
    10,000 nF
    per input PV1 / PV2 / PV3
    3325 / 3325 / 6650 nF
    Limit value of the insulation resistance test between PV generator and ground (on delivery) 7)
    34 kΩ
    Adjustable range of insulation resistance test between PV generator and ground 6)
    10 - 10,000 kΩ
    Limit value and trip time of sudden residual fault current monitoring (on delivery)
    30 / 300 mA / ms
    60 / 150 mA / ms
    90 / 40 mA / ms
    Limit value and trip time of continuous residual fault current monitoring (on delivery)
    450 / 300 mA / ms
    Adjustable range of continuous residual current monitoring 6)
    30 - 1000 mA
    Cyclic repetition of the insulation resistance test (on delivery)
    24 h
    Adjustable range for cyclic repetition of the insulation resistance test
    Output data
    Grid voltage range
    180 - 270 VAC
    Rated grid voltage
    220 VAC | 230 VAC 1)
    Rated power
    50 kW
    Rated apparent power
    50 kVA
    Rated frequency
    50/60 Hz 1)
    Maximum output current / phase
    76 A
    Initial symmetrical short-circuit current / phase IK"
    76 A
    Power factor (cos phi)
    0 - 1 ind./cap.2)
    Grid connection
    3~ (N)PE 380 / 220 VAC
    3~ (N)PE 400 / 230 VAC
    Earthing systems
    TT (allowed if UN_PE < 30V)
    TN-S (allowed)
    TN-C (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    Maximum output power
    50 kW
    Nominal output power
    50 kW
    Rated output current / phase
    75.8 A / 72.5 A
    Total harmonic distortion
    < 3%
    AC overvoltage category
    Current (inrush) 5)
    228 A peak /
    26.6 A rms over 3.2 ms 4)
    Max. output fault current / duration
    44.7 A / 16.24 ms
    General data
    Night-time power loss = standby consumption
    15 W
    European Efficiency (400 / 600 / 800 / 870 VDC)
    97.8 / 98.3 / 97.9 / 97.7%
    Maximum efficiency
    98.5%
    Safety class
    EMC emission class
    B
    Pollution degree
    Permitted ambient temperature
    with built-in "AC disconnector" option
    - 40 °C - +65 °C
    -30 °C - +65 °C
    Permitted storage temperature
    - 40 °C - +70 °C
    Relative humidity
    0 - 100%
    Sound pressure level (600 VDC)
    68.4 dB(A) (ref. 20 µPA)
    Protection class
    IP65
    Dimensions (height x width x depth)
    755 x 1109 x 346 mm
    Weight
    98 kg
    Inverter topology
    Non-insulated, no transformer
    Protection devices
    DC disconnector
    Integrated
    Cooling principle
    Controlled forced-air ventilation
    RCMU 9)
    Integrated
    DC isolation measurement 9)
    integrated 2)
    Overload performance
    Operating point shift,
    power limitation
    Active anti-islanding method
    Frequency shift method
    AFCI (only for D variant with 15/20 A fuse)
    Optional
    AFPE (AFCI) classification (according to IEC 63027) 9)
    = F-I-AFPE-1-4/3/7-3
    Full coverage
    Integrated
    AFPE
    1 monitored string per input port
    4/3/7 input ports per channel (AFD1: 4, AFD2: 3, AFD3: 7)
    3 monitored channels
    1. Appendix
    2. Technical data
    Input data
    1000 VDC
    200 VDC
    MPP voltage range
    400 - 870 VDC
    PV1 / PV2 / PV3
    134 A
    36 A / 36 A / 72 A
    PV1 / PV2 / PV3
    240 A
    72 A / 72 A / 125 A
    PV1 / PV2 / PV3
    75 kWp
    72 / 72 / 125 A4)
    0 / 0 / 0 A4)
    inverter
    10,000 nF
    34 kΩ
    10 - 10,000 kΩ
    30 / 300 mA / ms
    60 / 150 mA / ms
    90 / 40 mA / ms
    450 / 300 mA / ms
    30 - 1000 mA
    24 h
    Output data
    Grid voltage range
    180 - 270 VAC
    Rated grid voltage
    Rated power
    50 kW
    50 kVA
    Rated frequency
    50/60 Hz 1)
    76 A
    76 A
    0 - 1 ind./cap.2)
    Grid connection
    Earthing systems
    TN-S (allowed)
    TN-C (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    50 kW
    50 kW
    75.8 A / 72.5 A
    < 3%
    Current (inrush) 5)
    228 A peak /
    44.7 A / 16.24 ms
    General data
    15 W
    Maximum efficiency
    98.5%
    Safety class
    EMC emission class
    B
    Pollution degree
    - 40 °C - +65 °C
    -30 °C - +65 °C
    - 40 °C - +70 °C
    Relative humidity
    0 - 100%
    Protection class
    IP65
    755 x 1109 x 346 mm
    Weight
    98 kg
    Inverter topology
    Protection devices
    DC disconnector
    Integrated
    Cooling principle
    RCMU 9)
    Integrated
    integrated 2)
    power limitation
    Optional
    Full coverage
    Integrated
    AFPE
    1. Appendix
    2. Technical data
    Tauro Eco 50-3-D / 50-3-P
    Input data
    1000 VDC
    650 VDC
    MPP voltage range
    580 - 930 VDC
    PV1 / PV2
    87.5 A
    75 A / 75 A
    PV1 / PV2
    178 A
    125 A / 125 A
    PV1 / PV2
    75 kWp
    60 kWp / 60 kWp
    125 A4)
    inverter
    10,000 nF
    per input PV1 / PV2
    7980 / 7980 nF
    Limit value of the insulation resistance test between PV Generator and ground (on delivery) 7)
    34 kΩ
    10 - 10,000 kΩ
    30 / 300 mA / ms
    60 / 150 mA / ms
    90 / 40 mA / ms
    450 / 300 mA / ms
    30 - 1000 mA
    24 h
    Output data
    Grid voltage range
    180 - 270 VAC
    Rated grid voltage
    Rated power
    50 kW
    50 kVA
    Rated frequency
    50/60 Hz 1)
    76 A
    76 A
    0 - 1 ind./cap.2)
    Grid connection
    Earthing systems
    TN-S (allowed)
    TN-C (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    50 kW
    50 kW
    75.8 A / 72.5 A
    < 3%
    Current (inrush) 5)
    209 A peak /
    30.5 A rms over 2.1 ms 4)
    37.2 A / 19.4 ms
    General data
    15 W
    European Efficiency (580 / 800 / 930 VDC)
    98.2 / 97.7 / 97.3%
    Maximum efficiency
    98.5%
    Safety class
    EMC emission class
    B
    Pollution degree
    - 40 °C - +65 °C
    -30 °C - +65 °C
    - 40 °C - +70 °C
    Relative humidity
    0 - 100%
    Sound pressure level (580 VDC)
    68.5 dB(A) (ref. 20 µPA)
    Protection class
    IP65
    755 x 1109 x 346 mm
    Weight
    74 kg
    Inverter topology
    Protection devices
    DC disconnector
    Integrated
    Cooling principle
    RCMU 9)
    Integrated
    integrated 2)
    power limitation
    Optional
    = F-I-AFPE-1-7/7-2
    Full coverage
    Integrated
    AFPE
    7/7 input ports per channel (AFD1: 7, AFD2: 7)
    2 monitored channels
    1. Appendix
    2. Technical data
    Tauro Eco 99-3-D / 99-3-P
    Input data
    1000 VDC
    650 VDC
    MPP voltage range
    580 - 930 VDC
    P variant PV1 / PV2
    175 A
    100 A / 100 A
    75 A / 75 A / 75 A
    P variant Total
    D variant Total
    PV1 / PV2 / (PV3 only for D variant)
    250 A
    355 A
    125 A / 125 A / 125 A
    P variant PV1 / PV2
    150 kWp
    79 kWp / 79 kWp
    57 kWp / 57 kWp / 57 kWp
    P variant Total
    D variant Total
    125 A4)
    250 A4)
    inverter
    19,998 nF
    per input P variant PV1 / PV2
    per input D variant PV1 / PV2 / PV3
    10,507 / 10,507 nF
    7581 / 7581 / 7581 nF
    34 kΩ
    10 - 10,000 kΩ
    30 / 300 mA / ms
    60 / 150 mA / ms
    90 / 40 mA / ms
    900 / 300 mA / ms
    30 - 1000 mA
    24 h
    Output data
    Grid voltage range
    180 - 270 VAC
    Rated grid voltage
    Rated power
    99.99 kW
    99.99 kVA
    Rated frequency
    50/60 Hz 1)
    152 A
    152 A
    0 - 1 ind./cap.2)
    Grid connection
    Earthing systems
    TN-S (allowed)
    TN-C (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    99.99 kW
    99.99 kW
    151.5 A / 144.9 A
    < 3%
    Current (inrush) 5)
    244 A peak /
    27.2 A rms over 3.2 ms 4)
    93.9 A / 22 ms
    General data
    15 W
    98.2 / 97.7 / 97.3%
    Maximum efficiency
    98.5%
    Safety class
    EMC emission class
    B
    Pollution degree
    - 40 °C - +65 °C
    -30 °C - +65 °C
    - 40 °C - +70 °C
    Relative humidity
    0 - 100%
    Sound pressure level (580 VDC / 930 VDC)
    74.4 / 79.3 dB(A) (ref. 20 µPA)
    Protection class
    IP65
    755 x 1109 x 346 mm
    Weight
    103 kg
    Inverter topology
    Protection devices
    DC disconnector
    Integrated
    Cooling principle
    RCMU 9)
    Integrated
    integrated 2)
    power limitation
    Optional
    = F-I-AFPE-1-7/7/8-3
    Full coverage
    Integrated
    AFPE
    7/7/8 input ports per channel (AFD1: 7, AFD2: 7, AFD3: 8)
    1. Appendix
    2. Technical data
    Tauro Eco 100-3-D / 100-3-P
    Input data
    1000 VDC
    650 VDC
    MPP voltage range
    580 - 930 VDC
    P variant PV1 / PV2
    175 A
    100 A / 100 A
    75 A / 75 A / 75 A
    P variant Total
    D variant Total
    250 A
    355 A
    P variant PV1 / PV2
    150 kWp
    79 kWp / 79 kWp
    P variant Total
    D variant Total
    125 A4)
    250 A4)
    inverter
    20,000 nF
    10,507 / 10,507 nF
    34 kΩ
    10 - 10,000 kΩ
    30 / 300 mA / ms
    60 / 150 mA / ms
    90 / 40 mA / ms
    900 / 300 mA / ms
    30 - 1000 mA
    24 h
    Output data
    Grid voltage range
    180 - 270 VAC
    Rated grid voltage
    Rated power
    100 kW
    100 kVA
    Rated frequency
    50/60 Hz 1)
    152 A
    152 A
    0 - 1 ind./cap.2)
    Grid connection
    Earthing systems
    TN-S (allowed)
    TN-C (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    100 kW
    100 kW
    151.5 A / 144.9 A
    < 3%
    Current (inrush) 5)
    244 A peak /
    93.9 A / 22 ms
    General data
    15 W
    98.2 / 97.7 / 97.3%
    Maximum efficiency
    98.5%
    Safety class
    EMC emission class
    B
    Pollution degree
    - 40 °C - +65 °C
    -30 °C - +65 °C
    - 40 °C - +70 °C
    Relative humidity
    0 - 100%
    Protection class
    IP65
    755 x 1109 x 346 mm
    Weight
    103 kg
    Inverter topology
    Protection devices
    DC disconnector
    Integrated
    Cooling principle
    RCMU 9)
    Integrated
    integrated 2)
    power limitation
    Optional
    Full coverage
    Integrated
    AFPE
    1. Appendix
    2. Technical data
    WLAN
    Frequency range
    2412 - 2462 MHz
    Channels / power used
    Channel: 1-11 b,g,n HT20
    Channel: 3-9 HT40
    <18 dBm
    Modulation
    802.11b: DSSS (1Mbps DBPSK, 2Mbps DQPSK, 5.5/11Mbps CCK)
    802.11g: OFDM (6/9Mbps BPSK, 12/18Mbps QPSK, 24/36Mbps 16-QAM, 48/54Mbps 64-QAM)
    802.11n: OFDM (6.5 BPSK, QPSK, 16-QAM, 64-QAM)
    1. Appendix
    2. Technical data
    Explanation of footnotes
    1)
    The values stated are defaults; the inverter is configured specifically to suit the requirements of the relevant country.
    2)
    Depending on the country setup or device-specific settings
    (ind. = inductive; cap. = capacitive).
    3)
    Maximum current from a defective PV module to all other PV modules. From the inverter itself to the PV side of the inverter, it is 0 A.
    4)
    Guaranteed by the electrical configuration of the inverter.
    5)
    Current peak when switching on the inverter.
    6)
    Specified values are standard values; depending on the requirement and PV power, these values must be adjusted accordingly.
    7)
    Specified value is a max. value; exceeding the max. value may negatively affect the function.
    8)
    ISC PV = ICP PV ≥ ISC max = I SC (STC) x 1.25 according to e.g., IEC 60364-7-712, NEC 2020, AS/NZS 5033:2021
    9)
    Software class B (single channel with periodic self-test) control function according to IEC60730-1 Annex H.
    1. Appendix
    2. Technical data
    Integrated DC disconnector
    General data
    Product name
    EATON PV-DIS-10-125/2-REFOHA
    Rated insulation voltage
    1000 VDC
    Rated impulse withstand voltage
    6 kV
    Suitability for insulation
    Yes, DC only
    Rated operating current
    Rated operating current Ie ≤ 100 A: DC-PV2 utilization category (according to IEC/EN 60947-3)
    Rated operating current Ie ≤ 125 A: DC-PV1 utilization category (according to IEC/EN 60947-3)
    Utilization category and/or PV utilization category
    according to IEC/EN 60947-3 utilization category DC-PV2
    Rated short-time withstand current (Icw)
    12 x le
    Rated short-circuit capacity (Icm)
    1 000 A
    Rated operating current and rated breaking capacity
    Rated operating voltage (Ue)
    Rated operating current (Ie) DC-PV1
    I(make) / I(break) DC-PV1
    Rated operating current (Ie) DC-PV2
    I(make) / I(break) DC-PV2
    ≤ 500 VDC
    125 A
    187.5 A
    125 A
    500 A
    600 VDC
    125 A
    187.5 A
    125 A
    500 A
    800 VDC
    125 A
    187.5 A
    125 A
    500 A
    900 VDC
    125 A
    187.5 A
    110 A
    440 A
    1 000 VDC
    125 A
    187.5 A
    100 A
    400 A
    1. Appendix
    Relevant Standards and Directives
    CE Conformity Marking
    The equipment complies with all the requisite and relevant standards and directives that form part of the relevant EU directive, and therefore is permitted to display the CE mark.
    1. Appendix
    2. Relevant Standards and Directives
    1. Appendix
    WLAN
    Compliance with 2014/53/EU Radio Equipment Directive (RED)
    The above table of technical data lists the frequency ranges and maximum HF transmission power used by Fronius wireless products available for sale in the EU in accordance with Article 10.8 (a) and 10.8 (b) of the RED.
    Fronius products must be installed and operated such that the product is always 20 cm or more away from the body.
    1. Appendix
    Mains failure
    The standard measurement and safety procedures integrated into the inverter ensure that the power feed is immediately interrupted in the event of a grid failure (for example shut-off by the grid operator or damage to lines).
    1. Appendix
    Service, warranty terms and conditions, and disposal
    Fronius SOS
    Under sos.fronius.com you can retrieve warranty and device information at any time, start troubleshooting independently, and request replacement components.
    For more information on spare parts, contact your installer or point of contact for the PV system.
    1. Appendix
    2. Service, warranty terms and conditions, and disposal
    Fronius SOS
    1. Appendix
    Warranty
    Detailed warranty conditions specific to your country can be found at https://www.fronius.com/en/download-center?searchword=Warranty+conditions .
    If there is a warranty for the relevant product, register the product at https://warranty.fronius.com/ and activate or extend the warranty.
    1. Appendix
    Disposal
    In accordance with the EU Directive and national law, the following products must be disposed of separately and recycled:
    • Waste electrical and electronic equipment
    • Used batteries (portable batteries, industrial batteries)
    Used equipment and batteries must be returned to the distributor or an authorized local collection system. Do not dispose of batteries with domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
    Arrange for the safe collection and proper disposal of damaged, leaking or used batteries by a battery recycling company or the Fronius Service Partner.
    In addition, it should be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances such as heavy metals or electrolytes, which can contaminate soil, water and air.
    This ensures environmental protection and the sustainable use of natural resources.
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Compress the cardboard box to reduce volume
