Indicates an immediate danger.
Indicates a possibly dangerous situation.
Indicates the possibility of flawed results and damage to the equipment.
The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device mustFor the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
The device is intended exclusively for the welding process specified on the rating plate.
Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose." The manufacturer is not responsible for any damage resulting from improper use.
The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
The manufacture shall also not be liable for faulty or incorrect work results.
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
This may affect a number of device types in terms of:*) both at the interface with the public grid
See technical data
In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
IMPORTANT! Ensure secure grounding of the grid connection!
Local regulations and national guidelines may mean that a residual current circuit breaker is required when connecting a device to the public grid.
The residual current circuit breaker recommended for the device by the manufacturer can be found in the technical data.
The device produces a maximum noise level of <80 dB(A) (ref. 1pW) when idling and in the cooling phase following operation in relation to the maximum permitted operating point at standard loading in accordance with EN 60974-1.
A workplace-specific emission value for welding (and cutting) cannot be specified because this value depends on the welding process and the environmental conditions. It is influenced by a wide range of parameters, such as the welding process itself (MIG/MAG, TIG welding), the selected current type (direct current, alternating current), the power range, the type of weld metal, the resonance properties of the workpiece, the workplace environment, and many other factors.
The fumes produced during welding contain toxic gases and vapors.
Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
Use at-source extraction source and a room extraction system.
If possible, use a welding torch with an integrated extraction device.
Keep your head out of the welding fumes and gases.
Take the following precautionary measures for fumes and harmful gases:Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
Use a welding helmet with air supply if there is insufficient ventilation.
If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
The following components are factors that determine how toxic the welding fumes are:Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
Flying sparks can cause fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
Keep suitable, tested fire extinguishers on hand.
Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
Do not touch voltage-carrying parts inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wirespool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Before every use, check power connections for secure fit by hand.
In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
Do not wrap cables or leads around your body or parts of the body.
Concerning the electrode (rod electrode, tungsten electrode, welding wire, etc.)The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
Switch off unused devices.
When working at elevated heights, wear a safety harness to prevent falls.
Before working on the device, switch off the device and remove the grid plug.
Secure the device to prevent the grid plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
After opening the device:If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Covers and side parts must only be opened/removed during maintenance and repair work.
During operationThe protrusion of welding wire from the welding torch represents a high risk of injury (cuts to the hand, facial and eye injuries, etc.)
Therefore always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
Do not touch the workpiece during or after welding—burning hazard.
Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Leave the welding torch and other parts with a high operating temperature to cool before working on them.
Special regulations apply in areas at risk of fire or explosion
–follow the appropriate national and international regulations.
Power sources for work in areas with increased electrical hazard (e.g. boilers) must be labeled with the symbol (Safety). However, the power source may not be located in such areas.
Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
If the device is equipped with a carrier belt or handle, then this is used exclusively for transport by hand. The carrier belt is not suitable for transport by crane, counterbalanced lift truck or other mechanical lifting tools.
All lifting equipment (belts, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g. for mechanical damage, corrosion, or changes due to other environmental influences).
The test interval and scope must at least comply with the respective valid national standards and guidelines.
There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
Use filters if necessary.
Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
Keep shielding gas cylinders away from welding or other electrical circuits.
Risk of explosion: Never weld on a compressed shielding gas cylinder.
Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
When no welding is taking place, close the valve of the shielding gas cylinder.
Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
Risk of asphyxiation due to uncontrolled shielding gas leak
Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
Do not lift or transport any active devices. Switch off devices before transport or lifting.
Before transporting the device, completely drain the coolant and dismantle the following components:It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is switched on.
Before switching on the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
Always secure the shielding gas cylinder well and remove before transporting by crane.
Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
Only use appropriate original coolant from the manufacturer.
Do not mix original coolant from the manufacturer with other coolants.
Only connect system components from the manufacturer to the cooling unit circuit.
If there is damage due to use of other system components or other coolants, the manufacturer accepts no liability for this and all warranty claims are forfeited.
Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
When the system is cool, always check the coolant level before starting welding.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating power sources within the same 12-month interval.
A safety inspection by a certified electrician is recommended:For the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
Do not dispose of this device with normal domestic waste! To comply with the European Directive on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must be returned to your dealer, or you must locate the approved collection and recycling facilities in your area. Ignoring this European Directive may have potentially adverse affects on the environment and your health!
Devices with the CE label satisfy the essential requirements of the low-voltage and electromagnetic compatibility directive (e.g., relevant product standards of the EN 60974 series).
Fronius International GmbH declares that the device complies with Directive 2014/53/EU. The full text of the EU Declaration of Conformity is available on the following website: http://www.fronius.com
The user is responsible for backing up any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
Copyright of these Operating Instructions remains with the manufacturer.
Text and illustrations were accurate at the time of printing. Fronius reserves the right to make changes. The contents of the Operating Instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the Operating Instructions, we will be most grateful for your comments.
The TransTig 170 and TransTig 210 TIG power sources are microprocessor-controlled inverter power sources.
A modular design and easy ability to extend the system guarantee a high degree of flexibility.
The power sources are generator-compatible and are equipped with protected operating elements and a robust plastic housing.
As a result of the simple operating concept, key functions can be quickly viewed and adjusted.
The power source can also be operated via the standard TIG Multi Connector with various remote controls or an Up/Down torch.
The TIG pulsed arc function means that the power source offers a wide frequency range.
Additionally, the power source offers "Power Factor Correction", meaning the current consumption of the power source adapts to the sinusoidal grid voltage. This results in advantages such as:
The central control unit of the power source controls the entire welding process.
During the welding process, actual values are continually measured and any changes are immediately responded to. Control algorithms ensure that the desired status is maintained.
The power source can be used in repair and maintenance for production and manufacturing tasks.
Warning notices and safety symbols can be found on power sources with the CSA test mark for use in the North American region (USA and Canada). These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and property damage.
Safety symbols on the rating plate:
Because of software updates, certain functions may be available for your device but not described in these Operating Instructions or vice versa.
In addition, individual figures may also differ slightly from the operating elements of your device. However, the function of these operating elements is identical.
Read and understand all safety rules and user documentation for this equipment and all system components.
| Item | Name |
| (1) | Special indicators HF ignition indicator (high frequency ignition) Illuminates when the "IGn" setup parameter has been set to "on" Tacking indicator Illuminates when the "tAC" setup parameter has been set to a period of time Pulsing indicator Illuminates when the "F-P" setup parameter has been set to a pulse frequency Spot welding indicator Illuminates when the "SPt" setup parameter has been set to a spot welding time |
| (2) | Special indicators Remote control indicator Illuminates when a foot-operated remote control is connected Electrode overloaded indicator Illuminates when the tungsten electrode is overloaded Further information related to the "electrode overloaded" indicator can be found in the "TIG welding" section of the "Welding mode" chapter CEL indicator Illuminates when the "CEL" setup parameter has been set to "on" Trigger indicator Illuminates when the "tri" setup parameter has been set to "off" |
| (3) | Welding current display To display the welding current for the parameters:
Before the start of welding, the left digital display shows the set value. For IS, I2, and IE, the right digital display also indicates the % amount of the welding current I1. After the start of welding, the left digital display shows the current actual value of the welding current. The relevant parameters in the welding process are shown by the illuminated segment in the welding parameter overview (10) |
| (4) | Left digital display |
| (5) | HOLD indicator At the end of welding, the current actual values for the welding current and welding voltage are saved - the "hold" indicator illuminates. The "hold" indicator relates to the last main current I1 to be reached. Any further interaction with the power source will cause the "hold" indicator to go out. IMPORTANT! No hold values are output if the main current phase has never been reached. |
| (6) | Right digital display |
| (7) | Welding voltage indicator Illuminates when parameter "I1" is selected. During welding, the current actual value of the welding voltage is shown on the right digital display. Before welding, the right digital display shows:
| (8) | Unit indicators s indicator Illuminates if the parameters "tup" and "tdown" have been selected, as well as the following setup parameters: GPr | GPo | SPt | tAC | t-S | t-E | Hti | Ito | ArC | St1 | St2 | SPb Hz indicator Illuminates: When a value for the pulse frequency has been set for the "F-P" setup parameter If the "F-P" setup parameter is selected. % indicator Illuminates when parameters "IS", "I2" and "IE" have been selected, as well as the setup parameters "dcY", "I‑G", and "HCU" mm indicator Illuminates when the "ELd" setup parameter is set |
| (9) | "Mode" button For selecting the operating mode 2-step mode 4-step mode Manual metal arc welding When an operating mode is selected, the corresponding LED lights up. If the "Trigger" parameter is set to "oFF" in the Setup menu or a foot-operated remote control is connected, the 2T and 4T LEDs light up at the same time. |
| (10) | Welding parameter overview The welding parameter overview contains the most important welding parameters for the welding operation. The welding parameter sequence is depicted by a "washing line" structure. Navigation within the welding parameter overview is carried out by turning the selection dial. |
The welding parameter overview contains the following welding parameters: Starting current IS For TIG welding UpSlope tup Period of time it takes to rise from the starting current IS to the specified main current I1 during TIG welding t-u for the UpSlope is displayed on the left digital display. IMPORTANT! The UpSlope tup is saved separately for the following operating modes:
Main current (welding current) I1
Lowering current I2 For TIG 4-step mode DownSlope tdown Period of time it takes to fall from the specified main current I1 to the final current IE during TIG welding t-d for the DownSlope is displayed on the left digital display. IMPORTANT! The DownSlope tdown is saved separately for the following operating modes:
Final current IE For TIG welding Pulses *) Pulse frequency for TIG welding Tacking *) Duration of the pulsed welding current *) The pulsing and tacking parameters are only displayed if the setup parameter "Ptd - pulse TAC display" is set to "on". |
| (11) | Selection dial with rotary/push button function For selecting elements, setting values, and scrolling through lists |
| (12) | Gas-test button For setting the required shielding gas volume on the pressure regulator When the gas-test button is pressed, shielding gas will flow for 30 s. Press the button again or start welding to stop the gas flow prematurely. |
| (1) | Control panel |
| (2) | (-) Current socket with integrated gas connection For connecting: the TIG welding torch the electrode cable during manual metal arc welding |
| (3) | TMC connection (TIG Multi Connector) For connecting the control plug of the TIG welding torch For connecting foot remote controls For connecting remote controls for manual metal arc welding |
| (4) | (+) Current socket with bayonet latch Connect the grounding cable here |
| (5) | Carry strap |
| (6) | Cable strap To hold the mains cable and the welding power-leads IMPORTANT! Do not use the cable strap to transport the device! |
| (7) | Mains switch |
| (8) | Mains cable with strain relief For MV devices: mains cable to plug in (see "Connecting the Mains Cable" on page (→)) |
| (9) | Air filter |
| (10) | Shielding gas connection socket |
| (5) | Carry strap |
| (9) | Air filter |
Depending on the welding process, a minimum level of equipment is required to work with the power source.
The following describes the welding processes and the corresponding minimum equipment for welding operations.
The power source is intended exclusively for TIG welding and manual metal arc welding.
Any other use does not constitute proper use.
The manufacturer accepts no responsibility for any damage resulting from improper use.
The device can be set up and operated outdoors in accordance with degree of protection IP 23.
Direct moisture (e.g., from rain) must be avoided.
Toppling or falling devices can be deadly.
Place devices on a solid, level surface so that they remain stable.
The ventilation channel is a very important safety device. When selecting the setup location, ensure that the cooling air can enter or exit unhindered through the vents on the front and back. Any electrically conductive dust (e.g. from grinding work) must not be allowed to be sucked directly into the device.
The devices are designed for the grid voltage stated on the rating plate. If the mains cable or mains plug has not been attached to your version of the appliance, these must be installed according to national standards. Fuse protection for the grid lead can be found in the technical data.
Danger due inadequately dimensioned electrical installations.
This can lead to serious damage
The grid lead and its fuse protection should be designed to suit the existing power supply.
The technical data on the rating plate should be followed.
The power source is generator-compatible.
The maximum apparent power S1max of the power source is required for dimensioning the necessary generator output.
The maximum apparent power S1max of the power source is calculated as follows:
S1max = I1max x U1
I1max and U1 according to the device rating plate and technical data
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator can be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the power source!
When single phase devices are being operated with a 3-phase generator, note that the stated apparent power of the generator is often just the total that can be present across all three phases of the generator. If necessary, obtain further information about the single-phase power of the generator from the generator manufacturer.
The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
The mains voltage tolerance is specified in the "Technical Data" section.
If a power source is delivered without a mains cable installed, a mains cable corresponding to the power source's connection voltage must be connected before commissioning.
The mains cable is included in the scope of supply for the power source.
IMPORTANT! If the power source is equipped with a mains cable but no mains plug, connection to the public grid must only be carried out in accordance with national guidelines and only by trained and qualified personnel.
Before starting work, switch off all devices and components involved, and disconnect them from the grid.
Danger of electrical current due to electrically conductive dust in the device.
Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
Commissioning of the power source is described in relation to a standard configuration for the main usage scenario of TIG welding.
The standard configuration consists of the following system components:
Danger of falling gas cylinders.
Securely set up the gas cylinders on a level and stable surface. Secure gas cylinders to prevent them from falling over.
Please observe the gas cylinder manufacturer's safety rules.
Do not use pure tungsten electrodes for TransTig power sources (color code: green).
IMPORTANT! For optimum welding results, determine the welding circuit resistance " r " before starting welding.
The welding circuit resistance " r " must also be determined if one of the following components of the welding system is changed:
For more information on determining the welding circuit resistance, refer to the 2nd TIG menu (see page(→)).
Danger due to incorrect operation.
Do not use the functions described here until you have fully read and understood the Operating Instructions.
Do not use the functions described here until you have fully read and understood all of the Operating Instructions of the system components, especially the safety rules.
Follow the guidelines referring to setting, setting range, and units of measurement for the available parameters in the "Setup Menu" section.
| IS | Starting-current phase: the temperature is raised gently at low welding current, so that the filler metal can be positioned correctly |
| tS | Starting current duration |
| tup | UpSlope phase: steady rise of the starting current to the main current (welding current) I1 |
| I1 | Main current phase (welding current phase): uniform thermal input into the parent material, whose temperature is raised by the advancing heat |
| I2 | Lowering current phase: intermediate lowering of the welding current to avoid local overheating of the parent material |
| tdown | DownSlope phase: steady lowering of the welding current until it reaches the final current |
| IE | Final current phase: to avoid local overheating of the parent material caused by heat accumulation at the end of welding. This prevents possible sagging of the weld seam. |
| tE | Final current duration |
| SPt | Spot welding time |
| GPr | Gas pre-flow time |
| GPo | Gas post-flow time |
The Setup menu can be used to set a starting current time (t-S) and a final current time (t-E) for 2-step mode.
*) Intermediate lowering
With intermediate lowering, the welding current is lowered to the set lowering current I-2 during the main current phase.
If a value has been set for the setup parameter SPt, then 2-step mode operating mode is the same as spot welding operating mode. The spot welding special display illuminates on the control panel.
When using a foot remote control, the spot welding time begins when the foot remote control is pressed. Foot remote controls cannot be used to adjust the power.
When the power switch is switched to position - I -, the tungsten electrode of the welding torch is live.
Ensure that the tungsten electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
All parameter set values that are set using the selection dial are saved until their next alteration.
This applies even if the power source is switched off and on again.
| IS | Starting current 1 - 200% of the main current I1 Factory setting 35% |
| tup | UpSlope off / 0.01 - 9.9 s Factory setting: 0.5 s IMPORTANT! The UpSlope tup is saved separately for the following operating modes:
| I1 | Main current 10 – 170 A ... TT 170 10 – 210 A ... TT 210 Factory setting: 100 A |
| I2 | Lowering current (only in 4-step mode) 1 - 200% (of the main current I1) Factory setting: 50% |
| tdown | DownSlope off / 0.01 - 9.9 s Factory setting: 1.0 s IMPORTANT! The DownSlope tdown is saved separately for the following operating modes:
| IE | Final current 1 - 100% (of the main current I1) Factory setting: 30% |
F-P (pulse frequency) off / 0.2 - 990 Hz Factory setting: off | |
Duration of the pulsed welding current off / 0.1 - 9.9 s / on Factory setting: off |
| * | The pulsing and tacking parameters are only displayed if the setup parameter "Ptd - pulse TAC display" is set to "on". |
Risk of injury due to an electric shock
Although Fronius devices comply with all relevant standards, the high frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
Use prescribed protective clothing, especially gloves!
Only use suitable, completely intact and undamaged TIG hosepacks!
Do not work in damp or wet environments!
Take special care when working on scaffolds, work platforms, in forced positions, in tight, difficult to access or exposed places!
HF ignition is activated when the setup parameter "IGn" is set to "on".
The HF ignition special indicator illuminates on the control panel.
Unlike with contact ignition, there is no risk of contaminating the tungsten electrode and workpiece during HF ignition.
Procedure for HF ignition:
The arc ignites without coming into contact with the workpiece.
When the setup parameter IGn is set to OFF, the HF ignition is deactivated. The arc ignites when the workpiece makes contact with the tungsten electrode.
Procedure for igniting the arc using contact ignition for welding torches with torch trigger:
Shielding gas flows
The arc ignites.
When the setup parameter "IGn" is set to "oFF", the HF ignition is deactivated. The arc ignites when the workpiece makes contact with the tungsten electrode.
The setup parameter "Tri" must be set to "oFF".
Procedure for igniting the arc using contact ignition for welding torches without torch trigger:
Shielding gas flows
The arc ignites.
Although Fronius devices comply with all relevant standards, the high-frequency ignition can transmit a harmless but noticeable electric shock under certain circumstances.
The welding process is initiated by briefly touching the workpiece with the tungsten electrode. The high-frequency ignition is performed after the set HF ignition delay time has elapsed.
If the tungsten electrode is overloaded, the "electrode overloaded" display illuminates on the control panel.
Possible causes of an overloaded tungsten electrode:
Remedy:
IMPORTANT! The "electrode overloaded" display is tailored for use with ceriated tungsten electrodes. For all other electrodes, the "electrode overloaded" indicator can be used as a guide.
It is also possible to end welding with the TIG Comfort Stop (CSS) function on welding torches with or without a torch trigger.
This function can be adjusted in the TIG - 2nd level Setup menu (see page (→)).
If the arc breaks and no current flow takes place during the time set in the Setup menu, the power source automatically switches off. The control panel displays the service code "no | Arc".
Press any button on the control panel or the torch trigger to restart the welding process.
The "2nd Level Setup Menu" section describes how to set the arc break monitoring (Arc) setup parameters.
The power source has an ignition time-out function.
If the torch trigger is pressed, gas pre-flow begins immediately. Then the ignition procedure is initiated. If no arc emerges during the period of time set in the Setup menu, the power source automatically switches off. The control panel displays the service code "no | IGn".
Press any button on the control panel or the torch trigger to launch a further attempt.
The "2nd Level Setup Menu" section describes how to set the "ignition time-out function" (Ito) parameter.
The welding current set at the start of welding may not always be optimum for the entire welding process:
The TIG pulsing function is able to help with this (TIG welding with a pulsing welding current):
A low base current I-G rises steeply to a significantly higher pulse current I1 and falls again, after the set time dcY (duty cycle), to the base current I-G.
During TIG pulsing, small sections of the welding point are quickly melted and then allowed to quickly solidify again.
During manual applications, the welding wire is applied in the maximum current phase during TIG pulsing (only possible in the low frequency range from 0.25 - 5 Hz). Higher pulse frequencies are mostly used in automated applications and mainly serve to stabilize the arc.
TIG pulsing is used to weld steel pipes when welding out-of-position or to weld thin sheet metal.
TIG pulsing in operation:
Key:
*) (1/F-P = Time between two impulses)
There is a tacking function on the power source.
When a period of time is set for the setup parameter tAC (tacking), the tacking function is assigned to the 2-step and 4-step modes. The process of the operating modes remains unchanged.
During this time, a pulsed welding current is available, which optimizes the merging of the weld pool when tacking two components.
Tacking function in operation:
Key:
| tAC | Duration of pulsed welding current for tacking process |
| IS | Starting current |
| IE | Final current |
| tup | UpSlope |
| tDown | DownSlope |
| I1 | Main current |
IMPORTANT! When using a pulsed welding current:
The pulsed welding current starts
Depending on the set tAC time, the pulsed welding current can be stopped up to and including the final current phase IE (tAC setup parameter to "On").
After the tAC time has passed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
IMPORTANT! To set a defined tacking time, the setup parameter tAC can be combined with the setup parameter SPt (spot welding time).
When the power switch is switched to position - I -, the rod electrode in the electrode holder is live.
Ensure that the rod electrode is not touching any people or electrically conductive or grounded parts (housing, etc.).
All displays on the control panel briefly illuminate.
IMPORTANT! To weld with Cel electrodes, the setup parameter CEL must be set to "on" (also see page (→))!
Pulse welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:Adjustment range: off, 0.2 - 990 Hz
Operating principle:The power source regulates the duty cycle parameter "dcY" and the base current "I-G" according to the set pulse frequency.
Adjustable parameters:
| F-P | Pulse frequency (1/F-P = Time between two pulses) |
| - | SoftStart / HotStart |
Fixed parameters:
| I-G | Base current |
| dcY | Duty cycle |
Advantages
Key:
Hti
Hot current time,
0-2 s,
Factory setting 0.5 s
HCU
HotStart current,
0-200%,
Factory setting 150%
I1
Main current = set welding current
Operation
During the set hot current time (Hti) the welding current I1 rises to the HotStart current HCU.
The setting of the available parameters is described in the "Setup Menu" section on page (→).
A starting current of < 100% (SoftStart) is suitable for basic electrodes. Ignition is carried out with a low welding current. As soon as the arc is stable, the welding current continues to increase until it reaches the welding current command value that was set.
| (1) | HCU starting current |
| (2) | Hti starting current time |
| (3) | Main current I1 |
The starting current and starting current time are set in the Setup menu from page (→).
As the arc becomes shorter, the welding voltage may also fall so that the rod electrode is more likely to stick to the workpiece. This can also cause the rod electrode to anneal.
Activating the anti-stick function will prevent this annealing. If the rod electrode starts to stick to the workpiece, the power source switches off the welding current immediately. The welding process can be resumed without problems once the rod electrode has been detached from the workpiece.
The anti-stick function can be activated or deactivated in the Setup menu, see page (→).
The power source Setup menu provides easy access to expert knowledge and additional functions. The Setup menu makes it possible to easily adjust the parameters for various tasks.
Located in the Setup menu are:
The corresponding Setup menu will be displayed for the set operating mode.
The parameters in the Setup menu are adjusted as follows:
The following sections describe the Setup menu:
The following parameters are available through the TIG Setup menu:
Electrode diameter
0.0 - 3.2 mm
Factory setting: 2.4 mm
Spot welding time/interval welding time
off / 0.05 - 25 s
If a value has been set for the setup parameter SPt, this means that 2-step mode corresponds to the spot welding mode.
The spot welding special display illuminates on the control panel if a value for the spot welding time has been entered.
Interval pause time
This parameter is only available in 2-step mode and when the "SPt" parameter is activated.
off / 0.5 - 25 s
Tacking
Tacking function - duration of the pulsed welding current at the start of the tacking process
on
The pulsed welding current remains present until the end of the tacking process
0.1 - 9.9 s
The set time begins with the UpSlope phase. After the set time has passed, further welding is carried out at a constant welding current. Set pulse parameters are available if applicable.
off
Tacking function is switched off
The tacking special display illuminates on the control panel if a value has been set.
Pulse frequency
off / 0.2 - 990 Hz
The set pulse frequency is also applied for the lowering current.
The pulsing special display illuminates on the control panel if a value for the pulse frequency has been entered.
Duty cycle
Relationship between pulse duration and base current duration at the set pulse frequency
10 - 90%
Base current
0 - 100% (of the main current I1)
Factory setting:50%
Starting current time
The starting current time indicates the duration of the starting-current phase .
off / 0.01 - 9.9 s
IMPORTANT! The starting current time is only valid for 2-step mode, spot welding, and operation using a foot-operated remote control.
In 4-step mode, the duration of the starting-current phase is determined by the torch trigger.
Final current time
The final current time indicates the duration of the final current phase.
off / 0.01 - 9.9 s
IMPORTANT! The final current time is only valid for 2-step mode and spot welding. In 4-step mode, the duration of the final current phase is determined by the torch trigger (section "TIG Operating Modes").
Gas pre-flow time
Duration of the gas pre-flow
0 - 9.9 s
Factory setting: 0.4 s
Gas post-flow time
Duration of the gas post-flow
0.2 - 25 s / Aut
Factory setting: Aut
Gas purging
off / 0.1 - 9.9 minutes
Shielding gas pre-purging starts once a value has been set for GPU.
For safety reasons, it is necessary to re-enter a value for GPU in order to re-start shielding gas pre-purging.
IMPORTANT! Shielding gas pre-purging is mainly required if condensate has built up after longer periods of downtime in the cold. Long hosepacks in particular may be affected by this.
Reset welding system
No / YES / ALL
Factory setting: No
YES:
Only the currently active welding mode is reset (2T / 4T / trigger = oFF / STICK / STICK CEL / foot-operated remote control)
ALL:
All operating modes are reset.
For setting the following parameters:
For viewing "system active time", "system on time", "fuse", and "software version" parameters
For setting the "time shut down" parameter
Electrode diameter
0.0 - 3.2 mm
off / 0.05 - 25 s
Interval pause time
off / 0.5 - 25 s
Tacking
on
0.1 - 9.9 s
off
Pulse frequency
off / 0.2 - 990 Hz
Duty cycle
10 - 90%
Base current
Factory setting:50%
off / 0.01 - 9.9 s
Final current time
off / 0.01 - 9.9 s
Gas pre-flow time
0 - 9.9 s
Gas post-flow time
0.2 - 25 s / Aut
Gas purging
No / YES / ALL
Factory setting: No
YES:
ALL:
The following parameters are available through the second level of the TIG Setup menu:
Welding circuit resistance
For displaying the total resistance of the torch hosepack, welding torch, workpiece, and grounding cable
IMPORTANT! The ground earth connection and contact of the tungsten electrode must be made on a cleaned workpiece surface.
If an error occurs while determining the welding circuit resistance, "r" is displayed on the left display and "Err" is displayed on the right display.
Pressing the torch trigger or the gas-test button restarts the determination of the welding circuit resistance.
In the event of an error:
Slope Time 1 (only available in 4-step mode)
Ramping time from the main current I1 to the lowering current I2
off / 0.01 - 9.9 s
Slope Time 2 (only available in 4-step mode)
Ramping time from the lowering current I2 back up to the main current I1
off / 0.01 - 9.9 s
Trigger
Torch trigger operating mode
off / on
Factory setting: on
off
Operating welding torch without torch trigger
High frequency ignition is deactivated.
on
TIG 2-step or 4-step mode
HF ignition
off / tHF / EHF / on
Factory setting: on
off
No HF ignition at the start of welding - welding started by contact ignition
tHF
EHF
Start with external ignition aid, e.g. plasma welding
on
The HF ignition special indicator illuminates on the control panel when the "HF ignition" parameter is set to "on".
Time after touching the workpiece with the tungsten electrode after which the high-frequency ignition takes place.
0.1 - 5.0 s
Pulse TAC display
off / on
Factory setting: on
This menu item can be used to hide the pulsing and tacking parameters on the control panel in the welding parameter overview.
Ignition time out
Period of time until the safety cut-out following failed ignition
0.1 - 9.9 s
Factory setting: 5 s
Arc break monitoring
Period of time until the safety cut-out following an arc break
0.1 - 9.9 s
IMPORTANT! Arc break monitoring is a safety function and cannot be deactivated.
A description of the arc break monitoring function can be found in the "TIG welding" section on page (→).
TIG Comfort Stop Sensibility - comfort stop sensitivity
The parameter is only available if the "Trigger" parameter is set to "off".
oFF / 0.6 - 3.5 V
Factory setting: 1.5 V
At the end of the welding process, an automatic shutdown of the welding current follows a significant increase of the arc length. This prevents the arc from having to be unnecessarily lengthened when lifting the TIG welding torch.
Process:
Break voltage
For setting a voltage value at which the welding process may be ended by slightly raising the TIG welding torch.
The higher the break voltage value, the higher the arc can be raised.
The break voltage values for 2-step mode, 4-step mode, and operation with a foot-operated remote control are all stored together.
If the "tri" parameter (trigger - torch trigger operating mode) is set to "oFF", the values are stored separately.
10 - 45 V
Factory setting: 35 V (for 2-step and 4-step mode and operation with a foot-operated remote control)
Factory setting: 25 V (for trigger = oFF operation)
Main current changeover
on / off
Factory setting: on
on
After welding has started, an automatic selection of the main current I1 takes place.
The main current I1 can be adjusted immediately.
off
During welding, the last selected parameter remains selected.
The last selected parameter can be adjusted immediately.
No automatic selection of the main current I1 takes place.
The following parameters are available through the second level of the Setup menu:
System active time
To display the welding duration (the time during which welding has taken place)
The complete welding duration is divided across several displays and can be viewed by turning the selection dial.
Displayed in h / min. / sec.
System on time
For displaying the operating duration (count begins as soon as the device is switched on)
The complete operating duration is divided across several displays and can be accessed by turning the selection dial.
Fuse
To display/set the fuse being used
At 230 V: 10, 13, 16 A / off *
at 120 V: 15, 16, 20 A * / off *
* Only on the TT 170 MV / TT 210 MV
Factory setting:
16 A at a grid voltage of 230 V
16 A at a grid voltage of 120 V
If a fuse is set on the power source, the power source will limit the current drawn from the grid, which prevents an immediate tripping of the power circuit breaker.
| Max. welding current depending on the selected fuse | ||||
| Device | Mains voltage | Fuse | Max. TIG welding current | Max. electrode welding current |
TT 170 TT 170 MV | 230 V | 10 A | 170 A | 125 A | |
| 13 A | 170 A | 150 A | ||
| 16 A | 170 A | 150 A | ||
| oFF * | 170 A | 150 A | ||
| 120 V ** | 15 A | 130 A | 85 A | |
| 16 A | 140 A | 95 A | ||
| 20 A * | 140 A | 100 A | ||
| oFF * | 140 A | 100 A | ||
| TT 210 TT 210 MV | 230 V | 10 A | 180 A | 125 A |
| 13 A | 200 A | 150 A | ||
| 16 A | 210 A | 150 A | ||
| oFF * | 210 A | 150 A | ||
| 20 A * | 170 A | 120 A | ||
| oFF * | 170 A | 120 A | ||
| * | Only on the TT 170 MV / TT 210 MV |
| ** | Depending on the trigger characteristics of the power circuit breaker used, the full duty cycle of 40% may not be reached with a 120 V grid (for example, USA circuit breaker type CH 15% D.C.). |
Software version
The complete version number of the current software is divided across several displays and can be viewed by turning the selection dial.
Automatic shutdown
off / 5 - 60 minutes
If the device is not used or operated within a set period of time, it automatically switches into Standby mode.
Pressing a button on the control panel switches off Standby mode - the device is now ready for welding.
The following parameters are available through the rod electrode setup menu:
HotStart current
1 - 200%
Factory setting: 130%
0.1 - 2.0 s
Start ramp
To activate/deactivate the start ramp for the manual metal arc welding ignition process
on / off
Factory setting: on (activated)
Pulse frequency
for pulse welding with rod electrodes
off / 0.2 - 990 Hz
The pulsing special indicator illuminates on the control panel if a value for the pulse frequency has been entered.
Anti-stick
on / off
Factory setting: on
As the arc becomes shorter, the welding voltage may also fall so that the rod electrode is more likely to stick to the workpiece. This may also cause the rod electrode to burn out.
Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. The welding process can be resumed without problems once the rod electrode has been detached from the workpiece.
CEL mode
on / off
To weld with Cel electrodes, the parameter must be set to "on".
Dynamic correction
To optimize the welding result
0 - 100
Factory setting: 20
0
Softer and low-spatter arc
100
Harder and more stable arc
At the moment of droplet transfer or in event of a short circuit, a short-term increase in the amperage will occur. To maintain a stable arc, the welding current temporarily rises. If the rod electrode is at risk of sinking into the weld pool, this action prevents the weld pool from solidifying, as well as reducing the duration of the arc's short circuit. The risk of the rod electrode sticking is therefore largely ruled out.
Break voltage
Limitation of the welding voltage
25 - 90 V
Factory setting: 45 V
In principle, the arc length depends on the welding voltage. To end the welding process, a significant lifting of the rod electrode is usually required. The "Uco" parameter allows the welding voltage to be limited to a value, which permits the welding process to be ended by only slightly lifting the rod electrode.
IMPORTANT! If the welding process regularly comes to an unintentional end, set the break voltage parameter to a higher value.
No / YES / ALL
Factory setting: No
YES:
ALL:
For viewing "system active time", "system on time", "fuse" and "software version" parameters
For more details about the 2nd level Setup menu, see page (→).
HotStart current
1 - 200%
0.1 - 2.0 s
Start ramp
on / off
Pulse frequency
off / 0.2 - 990 Hz
Anti-stick
on / off
Factory setting: on
CEL mode
on / off
Dynamic correction
0 - 100
Factory setting: 20
0
100
Break voltage
25 - 90 V
No / YES / ALL
Factory setting: No
YES:
ALL:
The power source is equipped with an intelligent safety system, which completely negates the need for fuses. After correcting a possible error, the power source can be properly operated again without having to change any fuses.
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
| Cause: | Operating temperature is too high |
| Remedy: | Leave the device to cool (Do not switch off the device - the fan will cool the device) |
If "Err" is displayed on the left display and an error code is displayed on the right display, this is an internal service code for the power source.
Example:
There can be multiple error codes. These appear by turning the adjustment wheel.
Take note of all displayed error codes as well as the serial number and configuration of the power source, and then contact the service center with a detailed error description.
| Cause: | Power module error |
| Remedy: | Contact the service team |
| Cause: | Open circuit voltage has not been reached: Electrode is in contact with the component/hardware defect |
| Remedy: | Remove the electrode support from the component. If the service code continues to be displayed, contact service team |
| Cause: | System start failure |
| Remedy: | Turn device off and on again. If this happens multiple times, inform service team |
| Cause: | Overvoltage at the current socket (> 113 VDC) |
| Cause: | Memory error |
| Remedy: | Contact service team; Err 16: press selection dial to acknowledge service message |
NOTE!For standard device variants, acknowledging the service message does not have an effect on the power source's range of functions. For all other device variants (TIG, etc.), the power source only offers a restricted range of functions after acknowledgment. Inform the service team to re-establish the full range of functions. | |
| Cause: | Overtemperature or undertemperature |
| Remedy: | Operate device at permitted ambient temperature. For more information about environmental conditions see "Environmental Conditions" in the "Safety Rules" section |
| Cause: | Improper use of the device |
| Remedy: | Only use the device in accordance with the intended purpose |
| Cause: | Welding current set too high |
| Remedy: | Ensure that the power source is being operated at the correct grid voltage; ensure the correct fuse is set; set a lower welding current |
| Cause: | Grid voltage exceeds admissible limits |
| Remedy: | Immediately pull out the mains plug and ensure that the power source is being operated at the correct grid voltage |
| Cause: | Grid voltage is outside of the tolerance or grid output is insufficient for the connected device(s) |
| Remedy: | Ensure that the power source is being operated at the correct grid voltage; ensure the correct fuse is set; |
| Cause: | Error in communicating with the display |
| Remedy: | Turn device off and on again / inform service team if this happens multiple times |
| Cause: | Error while determining the welding circuit resistance |
| Remedy: | Inspect torch hosepack, welding torch, and grounding cable for damage; check connections and contacts; check the cleanliness of the workpiece surface. For more information on determining the welding circuit resistance, refer to the 2nd TIG menu (see page (→)). |
| Cause: | Defective power switch |
| Remedy: | Inform service team |
| Cause: | Welding power-lead connections interrupted |
| Remedy: | Correctly establish welding power-lead connections |
| Cause: | Poor grounding or no grounding at all |
| Remedy: | Establish a connection with the workpiece |
| Cause: | Power cable in the welding torch or electrode holder interrupted |
| Remedy: | Replace welding torch or electrode holder |
| Cause: | Duty cycle exceeded - device overloaded - fan running |
| Remedy: | Observe duty cycle |
| Cause: | Thermal automatic circuit breaker has shut down the device |
| Remedy: | Wait for device to cool down (do not switch off the device - the fan will cool the device); the power source will switch on again automatically after a short time |
| Cause: | Fan in the power source is faulty |
| Cause: | Cooling air supply is insufficient |
| Remedy: | Ensure there is a sufficient air supply |
| Cause: | Air filter is dirty |
| Remedy: | Clean air filter |
| Remedy: | Switch the device off and then on again If this error persists, inform service team |
| Cause: | The wrong process has been selected |
| Remedy: | Select "manual metal arc welding" or "manual metal arc welding with Cel electrodes" process |
| Cause: | Starting current too low; electrode remains stuck during ignition process |
| Remedy: | Raise starting current with HotStart function |
| Cause: | Starting current too high; electrode burns too quickly during ignition process or spatters strongly |
| Remedy: | Reduce starting current with SoftStart function |
| Cause: | Break voltage (Uco) is set too low |
| Remedy: | Raise the break voltage (Uco) in the Setup menu |
| Cause: | Voltage of the electrode too high (e.g. grooved electrode) |
| Remedy: | Use alternative electrode if possible or use power source with higher welding power |
| Cause: | Value for dynamic parameter (manual metal arc welding) set too low |
| Remedy: | Set a higher value for dynamic parameter |
| Cause: | Incorrect polarity of the electrode |
| Remedy: | Reverse the polarity of the electrode (observe manufacturer guidelines) |
| Cause: | Poor ground earth connection |
| Remedy: | Attach earthing clamps directly to the workpiece |
| Cause: | Non-viable setup setting for the selected process |
| Remedy: | Optimize the setting for the selected process in the Setup menu |
| Cause: | Incorrect polarity of the tungsten electrode |
| Remedy: | Connect TIG welding torch to the (-) current socket |
| Cause: | Incorrect shielding gas, no shielding gas |
| Remedy: | Use inert shielding gas (argon) |
The power source only requires minimal care and maintenance under normal operating conditions. However, several points must be observed in order for the power source to remain operational for years to come.
Air inlet and outlet openings must not be blocked or even partially covered.
Materials should be disposed of according to valid local and national regulations.
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
For devices designed for special voltages, the technical data on the rating plate applies.
Grid voltage U1 | 1 x 230 V |
Max. effective primary current (I1eff) | 11.3 A |
Max. primary current (I1max) | 15.0 A |
Mains voltage tolerance | - 30% / +15% |
Grid frequency | 50 / 60 Hz |
Mains fuse protection | 16 A slow-blow |
Grid connection 1) | Zmax at PCC3) = 356 MOhm |
Primary continuous power (100% D.C. 2) ) | 2.7 kVA |
Max. apparent power S1max | 3.5 kVA |
Cos phi | 0.99 |
Welding current range |
TIG | 3 - 170 A |
Rod electrode | 10 - 150 A |
Welding current at 10 min / 40 °C (104 °F), U1 = 230 V |
TIG | 40% D.C. 2) / 170 A |
| 60% D.C.2) / 155 A |
| 100% D.C.2) / 140 A |
Rod electrode | 40% D.C. 2) / 150 A |
| 60% D.C. 2) / 120 A |
| 100% D.C. 2) / 110 A |
Open circuit voltage (pulsed) |
TIG | 35 V |
Rod electrode | 101 V |
Working voltage |
TIG | 10.1 - 16.8 V |
Rod electrode | 20.4 - 26.0 V |
Striking voltage Up | 9.0 kV |
| The arc ignition device is suitable for manual operation |
Degree of protection | IP 23 |
Type of cooling | AF |
Insulation class | A |
EMC device class (according to EN/IEC 60974-10) | A |
Overvoltage category | III |
Pollution degree according to IEC60664 | 3 |
Ambient temperature | -10 °C - +40 °C / +14 °F - +104 °F |
Storage temperature | -25 °C - +55 °C / -13 °F - +131 °F |
Dimensions l x w x h | 435 x 160 x 310 mm / 17.1 x 6.3 x 12.2 in. |
Weight | 9.8 kg / 21.61 lb. |
Marks of conformity | CE |
Safety symbol | S |
Max. shielding gas pressure | 5 bar / 73 psi |
Noise emissions (LWA) | 68.0 dB (A) |
Idle state power consumption at 230 V | 15 W |
Power source efficiency at 150 A / 26 V | 88 % |
Grid voltage | 1 x 120 V / 1 x 230 V |
1 x 120 V | 14.5 A |
1 x 230 V | 11.3 A |
1 x 120 V | 22.7 A |
1 x 230 V | 15.0 A |
1 x 120 V | - 20% / +15% |
1 x 230 V | - 30% / +15% |
1 x 120 V | 20 A slow-blow |
1 x 230 V | 16 A slow-blow |
Grid connection 1) | Zmax at PCC 3) = 356 mOhm |
1 x 120 V | 1.8 kVA |
1 x 230 V | 2.7 kVA |
1 x 120 V | 2.8 kVA |
1 x 230 V | 3.5 kVA |
Cos phi | 0.99 |
TIG / 1 x 120 V | 3 - 140 A |
TIG / 1 x 230 V | 3 - 170 A |
Rod electrode / 1 x 120 V | 10 - 100 A |
Rod electrode / 1 x 230 V | 10 - 150 A |
Welding current at 10 min / 40 °C (104 °F) |
TIG / 1 x 120 V | 40% D.C. 2) / 140 A |
| 100% D.C 2) / 100 A |
TIG / 1 x 230 V | 40% D.C. 2) / 170 A |
Rod electrode / 1 x 120 V | 40% D.C. 2) / 100 A |
| 60% D.C. 2) / 90 A |
| 100% D.C. 2) / 80 A |
Rod electrode / 1 x 230 V | 40% D.C. 2) / 150 A |
TIG | 35 V |
Working voltage |
TIG / 1 x 120 V | 10.1 - 15.6 V |
TIG / 1 x 230 V | 10.5 - 16.8 V |
Rod electrode / 1 x 120 V | 20.4 - 24.0 V |
Rod electrode / 1 x 230 V | 20.4 - 26.0 V |
Striking voltage Up | 9 kV |
Marks of conformity | CE, CSA |
Safety symbol | S |
Max. effective primary current (I1eff) | 13.5 A |
Max. primary current (I1max) | 20.0 A |
Grid connection 1) | Zmax at PCC3)= 261 MOhm |
Primary continuous power (100% D.C. 2) ) | 3.2 kVA |
Max. apparent power S1max | 4.6 kVA |
Cos phi | 0.99 |
TIG | 3 - 210 A |
Rod electrode | 10 - 180 A |
Welding current at 10 min / 40 °C (104 °F), |
TIG | 40% D.C. 2) / 210 A |
| 60% D.C. 2) / 185 A |
| 100% D.C. 2) / 160 A |
Rod electrode | 40% D.C. 2) / 180 A |
| 60% D.C. 2) / 150 A |
| 100% D.C. 2) / 120 A |
TIG | 35 V |
Working voltage |
TIG | 10.1 - 18.4 V |
Rod electrode | 20.4 - 27.2 V |
Safety symbol | S |
1 x 120 V | 18.0 A |
1 x 230 V | 13.5 A |
1 x 120 V | 29.0 A |
1 x 230 V | 20.0 A |
1 x 120 V | 2.2 kVA |
1 x 230 V | 3.2 kVA |
1 x 120 V | 3.5 kVA |
1 x 230 V | 4.6 kVA |
Cos phi | 0.99 |
TIG / 1 x 120 V | 3 - 170 A |
TIG / 1 x 230 V | 3 - 210 A |
Rod electrode / 1 x 120 V | 10 - 120 A |
Rod electrode / 1 x 230 V | 10 - 180 A |
TIG / 1 x 120 V | 40% D.C. 2) / 170 A |
TIG / 1 x 230 V | 40% D.C. 2) / 210 A |
| 100% D.C.2) / 160 A |
Rod electrode / 1 x 120 V | 40% D.C. 2) / 120 A |
| 60% D.C. 2) / 100 A |
| 100% D.C. 2) / 90 A |
Rod electrode / 1 x 230 V | 40% D.C. 2) / 180 A |
| 100% D.C.2) / 120 A |
TIG | 35 V |
Working voltage |
TIG / 1 x 120 V | 10.1 - 16.8 V |
TIG / 1 x 230 V | 10.1 - 18.4 V |
Rod electrode / 1 x 120 V | 20.4 - 24.8 V |
Rod electrode / 1 x 230 V | 20.4 - 27.2 V |
Weight | 9.9 kg / 21.8 lb. |
Safety symbol | S |
| /EF | Power source with mains cable fitted |
| /np | Power source with mains cable fitted and without plug for the public grid |
| /B | Power source with mains cable to plug in |
| 1) | On a public grid with 230 V and 50 Hz |
| 2) | D.C. = duty cycle |
| 3) | PCC = interface to the public grid |
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
