en
      Operating instructionsFronius Symo GEN24 6 - 10 kW Plus/Symo GEN24 6-12 kW Plus SC
    • General information
      • Safety information
        • Safety
        • Safety instructions and important information
        • Environmental conditions
        • Electromagnetic fields
        • EMC measures
        • Backup power
        • Ground conductor
      • Protection of people and equipment
        • Central grid and system protection
        • WSD (wired shutdown)
        • RCMU
        • Insulation monitoring
        • AFCI - Arc Fault Circuit Interrupter (Arc Guard)
        • Safe state
      • General
        • Information on the device
        • How information is presented in the document
        • Target group
        • Data security
        • Privacy policy
        • Copyright
      • Fronius Symo GEN24/Symo GEN24 SC
        • Device concept
        • Function overview
        • Fronius UP
        • Scope of supply
        • Intended use
        • Thermal concept
        • Fronius Solar.web
        • Local communication
      • Different operating modes
        • Operating modes – Explanation of symbols
        • Operating mode – Inverter with battery
        • Operating mode – Inverter with battery and several Smart Meters
        • Operating mode – Inverter with battery, AC-coupled to another inverter
        • Operating mode – Inverter with battery and backup power function
        • Operating mode – Inverter with battery and Ohmpilot
        • Operating mode – Inverter with battery, Ohmpilot, and backup power function
        • Operating mode – Inverter with battery and another inverter
        • Operating mode – Inverter with battery, another inverter, and backup power function
        • Energy flow direction of the inverter
        • Operating states (only for battery systems)
      • Energy-saving mode
        • General
        • Switch-off conditions
        • Switch-on conditions
        • Special case
        • Indication of energy saving mode
      • Suitable batteries
        • General
        • Fronius batteries
        • BYD batteries
        • LG FLEX
      • Manual system start
        • Requirements
        • Notification of system shutdown
        • Manual battery start after system shutdown
        • Starting backup power operation after a system shutdown
      • Operating controls and connections
        • Connection area
        • Connection area divider
        • Ground electrode terminal
        • DC disconnector
        • Data communication area
        • Button functions and LED status indicator
        • Schematic internal wiring of IOs
    • Backup power variant - PV Point (OP)
      • General
        • Explanatory note - PV Point/PV Point Comfort
        • PV Point (OP)
        • PV Point Comfort
    • Backup power variant - Full Backup
      • General
        • Prerequisites for backup power mode
        • Transitioning from grid power feed operation to backup power mode
        • Transitioning from backup power mode to grid power feed operation
        • Backup power and energy saving mode
      • Automatic switch to backup power with Fronius Backup Controller 3P-35A incl. backup power circuits and 3-pin separation, e.g., Austria or Australia
        • Functions
        • Transition from grid power feed operation to backup power mode
        • Transition from backup power mode to grid power feed operation
        • Parallel Backup
      • Automatic switch to backup power including backup power circuits and 3-pin separation, e.g., Austria or Australia
        • Functions
      • Automatic switch to backup power mode, all-pin disconnection, e.g., in Germany with Fronius Backup Controller 3PN-35A
        • Functions
      • Automatic switch to backup power all-pin separation, e.g., Germany, France, Spain
        • Functions
      • Automatic switch to backup power all-pin separation, Italy
        • Functions
      • Manual switch to backup power 3-pin separation, e.g., Austria / all-pin separation, e.g., Germany
        • Functions
    • Installation
      • General
        • Quick-fastener system
        • System component compatibility
      • Installation location and position
        • Choosing the location of the inverter
        • Choosing the location of third-party batteries
        • Installation position of the inverter
      • Installing the mounting bracket and attaching the inverter
        • Selecting the mounting material
        • Properties of the mounting bracket
        • Do not deform the mounting bracket
        • Fitting the mounting bracket to a wall
        • Installing the mounting bracket on a mast or beam
        • Attaching the mounting bracket to mounting rails
        • Attaching the inverter to the mounting bracket
      • Requirements for connecting the inverter
        • Different cable types
        • Permitted cables for the electrical connection
        • Permitted cables for the data communication connection
        • Cable diameter of the AC cable
        • Cable diameter of the DC cable
        • Maximum alternating current fuse protection
      • Connecting the inverter to the public grid (AC side)
        • Safety
      • Connecting solar module strings to the inverter
        • General information about PV modules
        • Safety
        • PV Generator, general
        • Module array configuration
        • Module array configuration Symo GEN24 6-12 kW SC
      • Connecting the battery to the inverter
        • Safety
        • Connecting the battery on the DC side
        • Connecting the LG FLEX ground conductor
      • Connecting backup power - PV Point (OP)
        • Safety
        • Installation
        • Testing backup power mode
      • Connecting backup power - Full Backup
        • Safety
        • Automatic switch to backup power 3-pole disconnection e.g., Austria or Australia
        • Automatic switch to backup power 4-pole disconnection e.g., Germany, France, Spain
        • Automatic switch to backup power 4-pole disconnection e.g., Italy
        • Manual switch to backup power 3-pole disconnection e.g., Austria / 4-pole disconnection e.g., Germany
      • Connecting the data communication cables
        • Modbus participants
        • Routing data communication cables
        • Connecting the battery communication cable
        • Terminating resistors
        • Installing the WSD (wired shutdown)
      • Closing and commissioning the inverter
        • Closing the inverter's connection area/housing cover, and commissioning
        • Starting the inverter for the first time
        • Installation with the app
        • Installation with the browser
      • De-energizing the inverter and switching it back on
    • Settings – User interface of the inverter
      • User settings
        • User login
        • Selecting languages
      • Device configuration
        • Components
        • Functions and I/Os
        • Inverter
      • Energy management
        • Permitted maximum battery charge from the public grid
        • Battery management
        • Examples - Time-dependent battery control
        • Permitted battery control regulations
        • PV power reduction
        • Load management
        • Self-consumption optimization
      • System
        • General
        • Update
        • Setup wizard
        • Restoring factory settings
        • Event log
        • Information
        • License Manager
        • Licensing
        • Support
      • Communication
        • Network
        • Modbus
        • Cloud control
        • Solar API
        • Fronius Solar.web
      • Safety and grid requirements
        • Country setup
        • Requesting inverter codes in Solar.SOS
        • Absolute Generation Limit
        • Feed-in limit
        • Import limitation
        • Feed-in limit – examples
        • Multiple Inverter Control
        • I/O Power Management
        • 4-relay connection example
        • I/O power management settings – 4 relay example
        • 3-relay connection example
        • I/O power management settings – 3 relay example
        • 2-relay connection example
        • I/O power management settings – 2 relay example
        • 1-relay connection example
        • I/O power management settings – 1 relay example
        • Connecting the ripple control receiver with several inverters
        • Autotest
          (CEI 0-21)
    • Options
      • Surge protection device (SPD)
        • General
        • Safety
        • Scope of supply
        • Starting up the inverter
      • DC Connector Kit GEN24
        • General
        • Safety
        • Scope of supply
        • Installation
      • PV Point Comfort
        • Safety
        • Scope of supply
        • Installation
        • Configuring the PV Point Comfort
    • Appendix
      • Service, maintenance and disposal
        • General
        • Maintenance
        • Cleaning
        • Safety
        • Operation in dusty environments
        • Disposal
      • Warranty provisions
        • Warranty
      • Components for switching to backup power
        • Components for automatic backup power changeover to Full Backup
        • Components for manual backup power changeover to Full Backup
      • Status codes and remedy
        • Display
        • Status codes
      • Technical data
        • Fronius Symo GEN24 6.0/6.0 Plus
        • Fronius Symo GEN24 6.0 SC / 6.0 Plus SC
        • Fronius Symo GEN24 8.0/8.0 Plus
        • Fronius Symo GEN24 8.0 SC / 8.0 Plus SC
        • Fronius Symo GEN24 10.0/10.0 Plus
        • Fronius Symo GEN24 10.0 SC / 10.0 Plus SC
        • Fronius Symo GEN24 10.0 SC/10.0 Plus SC
          (Australia only)
        • Fronius Symo GEN24 12.0 SC / 12.0 Plus SC
        • WLAN
        • Technical data of surge protection device DC SPD type 1+2 GEN24
        • Explanation of footnotes
        • Integrated DC disconnector
    • System circuit diagrams
      • Fronius Symo GEN24 and Fronius Reserva
      • Fronius Symo GEN24 with Fronius Reserva connected in parallel
      • Fronius Symo GEN24 and Fronius Reserva Pro
      • Fronius Symo GEN24 with Fronius Reserva Pro connected in parallel
      • Fronius Symo GEN24 and BYD Battery-Box Premium HV
      • Fronius Symo GEN24 with two BYD Battery-Box Premium HV connected in parallel
      • Fronius Symo GEN24 with three BYD Battery-Box Premium HV connected in parallel
      • Fronius Symo GEN24 and BYD Battery-Box HVS+/HVM+
      • Fronius Symo GEN24 with BYD Battery-Box HVS+/HVM+ connected in parallel
      • Fronius Symo GEN24 and LG FLEX
    • Circuit diagrams—PV Point
      • Emergency power terminal—PV Point (OP)
      • Circuit diagram - PV Point (OP) Australia
      • Backup power terminal - PV Point (OP) with battery only for France
      • Backup power terminal - PV Point (OP) manual changeover
      • PV Point Comfort
    • Circuit diagrams—automatic switch to backup power with Fronius Backup Controller
      • Fronius Backup Controller 3-pin separation, e.g., Austria
      • Fronius Backup Controller 3-pin separation, parallel backup
      • Fronius Backup Controller 4-pin separation, e.g., Germany
    • Circuit diagrams—automatic switch to backup power with third-party components
      • Automatic switch to backup power 3-pin single FRT-capable separation - e.g., Austria
      • Automatic switch to backup power 3-pin single separation - e.g., Australia
      • Automatic switch to backup power 3-pin double separation with ext. grid and system protection
      • Automatic switch to backup power 4-pin single separation - e.g., Germany
      • Automatic switch to backup power 4-pin single FRT-capable separation
      • Automatic switch to backup power 4-pin single separation - e.g., France
      • Automatic switch to backup power 4-pin single separation - e.g., Spain
      • Automatic switch to backup power 4-pin double separation with ext. grid and system protection - e.g., Italy
    • Circuit diagrams—manual switch to backup power with Fronius Backup Switch
      • Manual switch to backup power 3-pin separation with grid and system protection
      • Manual switch to backup power 4-pin separation, e.g., Germany
    • Dimensions of the inverter
      • Fronius Symo GEN24 6 - 10 kW/Symo GEN24 6 - 12 kW SC
    • 039-19062026
    download
    General information
    link_horizontalLink copied
    Safety information
    Safety
    CAUTION
    Danger from crushing due to the incorrect handling of attachments and connection parts.
    Injuries to limbs may result.
    Use the integrated grips when lifting up, putting down, and attaching the inverter.
    When fitting attachments, ensure that no limbs are located between the attachment and the inverter.
    Do not hold on to the individual poles on the terminals when locking and unlocking.
    1. General information
    Safety information
    Safety
    CAUTION
    2. Safety information
    Safety
    CAUTION
    Warnings are intended to warn people of possible injuries and to avoid personal injury and damage to the product. They relate to individual actions with and on the product.
    DANGER
    Indicates an immediately dangerous situation.
    Serious injury or death will result if the danger is not avoided.
    Action step to escape the situation.
    WARNING
    Serious injury or death may result if the danger is not avoided.
    CAUTION
    Minor or moderate injury may result if the danger is not avoided.
    NOTE
    Indicates a situation that may result in property damage.
    If the situation is not avoided, impaired work results, material damage to the product or other property are the possible consequences.
    Action step to avoid the situation.
    Safety instructions are designed to ensure safe product use. They are preventive and help to inform users about the fundamental risks involved when dealing with the product. They do not refer specifically to individual actions with and on the product.
    WARNING
    Incorrect operation or misuse
    IMPORTANT!
    In addition to the operating instructions, observe the following general and local rules:
    • Accident prevention
    • Fire protection
    • Environmental protection
    IMPORTANT!
    IMPORTANT!
    All safety and danger notices on the device:
    • Must be kept in a legible state
    • Must not be damaged/marked
    • Must not be removed
    • Must not be covered, have anything stuck on them, or painted over
    WARNING
    Tampered-with and non-functioning protection devices
    WARNING
    NOTE
    The device may be damaged
    Operation or storage of the machine outside the stipulated area will be deemed as not in accordance with the intended purpose.
    For exact information on permitted environmental conditions, please refer to the technical data.
    During operation, due to the high electrical voltages and currents, local electromagnetic fields (EMF) are generated. These occur in the immediate vicinity of the inverter and the Fronius system components. Electromagnetic fields are also present in the area of the PV modules and their supply lines.
    As long as the intended use and a minimum distance of 20 cm are observed, all limit values for human exposure are observed.
    If the limit values are complied with, according to current scientific knowledge, no negative health effects from EMF exposure are to be expected. For persons with prostheses1) or active physical aids2), there is a possible health risk in the vicinity of photovoltaic system components. To avoid possible health risks, consult with the responsible doctor.
    1) e.g., implants or metal parts
    2) e.g., pacemaker, insulin pump, hearing aid, etc.
    EMC measures
    Backup power
    This system has backup power functions. A backup power supply can be established in the event of a failure in the public grid.
    If an automatic backup power supply is installed, attach the backup power supply warning notice (https://www.fronius.com/en/solar-energy/installers-partners/downloads?searchword=42,0409,0275) to the electrical distributor.
    WARNING
    Danger due to electrical voltage on live parts of the PV system
    Depending on the irradiance conditions and the battery state of charge, the backup power supply is automatically deactivated and activated. This can cause the backup power supply to unexpectedly return from standby mode. This can result in serious personal injury and damage to property.
    Disconnect the inverter on the network side before performing maintenance and installation work in the home network.
    Set the integrated DC disconnector on the inverter to the "Off" switch position to end the backup power supply.
    Test the function of the residual current devices for the backup power supply at least every 6 months.
    A description of how to run the test mode can be found in the backup power checklist (https://www.fronius.com/en/solar-energy/installers-partners/downloads?searchword=42,0426,0365).
    Influencing factors on the total output in backup power mode:
    Reactive power
    Electrical loads with a power factor not equal to 1 require active power as well as reactive power. The reactive power places a further load on the inverter. Use the current resulting from the active and reactive power for the correct calculation of the total power. The rated power of the loads is not relevant.
    Devices with a high reactive power are mainly electric motors, such as:
    • Water pumps
    • Circular saws
    • Fans
    High starting/start-up current
    Electrical loads that need to accelerate a large mass generally require a high starting/start-up current. This can be up to ten times the nominal current. The maximum current of the inverter is available for the starting/start-up current. Loads with too high a starting/start-up current cannot, therefore, be started/operated, even though the nominal power of the inverter suggests otherwise. Therefore, consider the connected load power and the starting/start-up current when sizing the backup power circuit.
    Devices with a high starting/start-up current include:
    • Devices with electric motors (e.g., lift platforms, circular saws, workbenches)
    • Devices with a high transmission ratio and flywheel mass
    • Devices with compressors (e.g., compressed air compressors, air-conditioning systems)
    IMPORTANT!
    Very high start-up currents can temporarily distort or interrupt the output voltage. Avoid simultaneous operation of electronic devices in the same backup power circuit.
    Unbalanced load
    When dimensioning three-phase backup power circuits, consider the total output power and the powers per phase of the inverter.
    IMPORTANT!
    Only operate the inverter within the limits of its technical capabilities. Operation outside of its technical capabilities can cause the inverter to shut down.
    Ground conductor
    Connection of a point in the device, system, or installation to ground to protect against electric shock in the event of a fault. When installing an inverter from safety class 1 (see Technical data), a ground conductor connection is required.
    When connecting the ground conductor, ensure that it is secured to prevent unintentional disconnection. All of the points listed in the chapter headed Connecting the inverter to the public grid (AC side) on page (→) must be observed. When using cable glands, ensure that the ground conductor is last to be subjected to a load in the event of a failure of the cable gland. The respective national standards and regulations and requirements for minimum cross-section must be observed when connecting the ground conductor.
    The inverter offers the option to use the integrated AC relays as section switches in conjunction with a central grid and system protection unit (in accordance with VDE-AR-N 4105:2018:11 §6.4.1). For this purpose, the central trigger device (switch) must be integrated into the WSD chain as described in chapter WSD (wired shutdown) on page (→).
    2. Protection of people and equipment
    The wired shutdown (WSD) interrupts the inverter's grid power feed if the trigger device (switch, e.g., Emergency Stop or fire alarm contact) has been activated.
    If an inverter (slave) fails, it is bypassed and the other inverters continue operating. If a second inverter (slave) or the inverter (master) fails, the operation of the entire WSD chain is interrupted.
    For installation, see Installing the WSD (wired shutdown) on page (→).
    RCMU
    The inverter is equipped with an RCMU (RCMU = residual current monitoring unit) according to IEC 62109-2 and IEC63112.
    It monitors residual currents from the PV module up to the AC output and disconnects the inverter from the grid when an improper residual current is detected.
    In the case of photovoltaic systems with ungrounded PV modules, the inverter checks the resistance between the positive or negative pole of the photovoltaic system and the ground potential before starting grid power feed operation. In the event of a short circuit between the DC+ or DC- cable and ground (e.g., due to inadequately insulated DC cables or defective PV modules), feeding into the public grid is prevented.
    An AFCI (Arc Fault Circuit Interrupter) protects against arc faults and is a protective device in the event of contact errors. The Arc Fault Circuit Interrupter monitors faults that occur in the current and voltage flow on the DC side and shuts down the circuit with an electronic circuit if a contact error is detected. The function prevents overheating at poor contact points and, ideally, possible fires. In the Technical data chapter, check whether the Arc Fault Circuit Interrupter is available for the device in question.
    CAUTION
    Faulty or incorrect DC installation
    Arcs lead to prohibited thermal loads on the DC installation. There is a risk of fire. This may result in injury and damage to the inverter and the components of the photovoltaic system.
    Check the plug connections to ensure that they are correct.
    Repair faulty insulation correctly.
    Perform connection work in line with the instructions.
    IMPORTANT!
    Fronius will not bear any costs that may arise due to a detected electric arc and its consequences. Fronius accepts no liability for damage which may occur despite the integrated Arc Fault Circuit Interrupter/interruption (e.g., due to a parallel arc).
    IMPORTANT!
    Active PV module electronics (e.g., power optimizers) can impair the function of the Arc Fault Circuit Interrupter. Fronius cannot guarantee the correct function of the Arc Fault Circuit Interrupter in combination with active PV module electronics.
    Reconnection behavior
    Grid power feed operation is interrupted for at least 5 minutes after an arc has been detected. Depending on the configuration, grid power feed operation is then automatically resumed. If several arcs occur within a period of 24 hours, grid power feed operation will remain interrupted until a manual reconnection is performed.
    Safe state
    In the safe state, the inverter infeed is deactivated and is disconnected from the grid by the AC relay opening. The inverter switches to the safe state when the following events occur:
    1. One of the following safety devices triggers:
      • WSD
      • RCMU
      • AFCI
    2. The diagnostic function of the inverter detects a malfunction of these safety devices.
    General
    Technical data, warning notices, labels, and safety symbols are located on the inverter. This information must be kept in a legible condition and must not be removed, covered, pasted over, or painted over. The notices and safety symbols warn against incorrect operation, which may result in serious injury and property damage.
    Symbols on the rating plate:
    CE label – confirms compliance with applicable EU directives and regulations.
    UKCA marking – confirms compliance with applicable UK directives and regulations.
    WEEE marking – waste electrical and electronic equipment must be collected separately and recycled in an environmentally sound manner in accordance with the European Directive and national law.
    RCM marking – tested according to the requirements of Australia and New Zealand.
    ICASA marking – tested according to the requirements of the Independent Communications Authority of South Africa.
    CMIM marking – tested according to IMANOR requirements for import regulations and compliance with Moroccan standards.
    Safety symbols:
    Integrated switch disconnector on the input side of the inverter with switch-on, switch-off, and isolating function according to IEC 60947-3 and AS 60947.3. The values required by the applicable standard for Ithe solar +60°C are given.
    Risk of serious injury and property damage due to incorrect operation.
    • These operating instructions.
    • All operating instructions for the system components of the photovoltaic system, especially the safety rules.
    Dangerous electrical voltage.
    Allow the capacitors of the inverter to discharge (2 minutes).
    Warning notice text:
    WARNING!
    An electric shock can be fatal. Before opening the device, ensure that the input and output sides are de-energized and disconnected.
    2. General
    Safety symbols:
    WARNING!
    2. General
    Application notes
    Software
    Example: Click Save.
    Instructions for action
    1Action steps are displayed with consecutive numbering.
    ✓This symbol indicates the result of the action step or the entire instruction.
    2. General
    Target group
    This document provides detailed information and instructions to ensure that people can use the machine safely and efficiently.
    The information is intended for the following groups of people:
    • Technical specialists: People with appropriate qualifications and fundamental knowledge of electronics and mechanics. The activities of a technical specialist include installation, operation, maintenance, and service work.
    • User: People that use the machine in daily operation and want to understand its basic functions.
    Regardless of any qualifications, only perform the activities listed in this document.
    The definition of professional qualifications and their applicability are subject to national law.
    2. General
    Data security
    • Backing up any changes made to the factory settings
    • Saving and storing personal settings
    NOTE
    2. General
    Privacy policy
    When you connect your device (and any associated devices) to the internet, the following device and operating data (device ID/identifier, device IP address, device time, configuration settings, hardware and software information, device status log files, serial number) is sent automatically to
    Fronius International GmbH, Froniusstraße 1, 4643 Pettenbach, Austria, telephone +43(0) 7242241-0, email: contact@fronius.com (controller)
    and stored.
    The processing of this device and operating data is carried out for the purpose of ensuring the operational safety of the device (time synchronization, provision of updates). This processing is therefore necessary for the functionality of the device and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
    If you do not wish to have such data processed, you must manually disable the device's internet connection.
    In addition, the device and operating data is also processed for the purpose of providing services as part of a supplementary digital service for your device (such as solar.web or similar) as soon as you have registered your device with such a digital service (identification). This data is processed to provide the requested digital services and is therefore necessary for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
    Furthermore, this data processing is also carried out for maintenance and support purposes and for handling customer concerns as well as in warranty and guarantee cases (only in individual cases and given connection between device and internet). In this context, the device and operating data may also be passed on to our cooperation partners (third-party providers and suppliers). The processing of this data is necessary for maintenance and support purposes or for processing warranty and guarantee cases and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
    Device and operating data are also processed for analysis and diagnostic purposes in order to gain insights into the functionality of the devices and improve them accordingly. This data processing is based on our legitimate interest (Art. 6 (1) (f) GDPR).
    We store this data for as long as it is necessary to fulfill the existing contract with you. Any storage beyond this is carried out for legal reasons or if we have a legitimate interest in doing so. For more information on data processing for the solar.web-digital service, as well as our general privacy policy and your rights as a data subject, please visit https://www.fronius.com.
    2. General
    Copyright
    Device concept
    The inverter transforms the direct current generated by the PV modules into alternating current. This alternating current is fed into the public grid and synchronized with the mains voltage in use. Moreover, the solar energy can also be stored in a connected battery for later use.
    The inverter is intended for use in grid-connected photovoltaic systems. The inverter has backup power functions and switches to backup power mode if it has been wired accordingly*.
    The inverter automatically monitors the public grid. Whenever conditions in the electric grid are inconsistent with standard conditions (e.g., grid switch-off, interruption), the inverter will immediately stop producing power and interrupt the supply of power into the grid.
    The grid is monitored by monitoring the voltage, frequency, and islanding conditions.
    After installation and commissioning, the inverter's operation is fully automatic; the inverter draws the maximum possible power from the solar modules.
    Depending on the operating point, this power is used in the home, stored in a battery*, or fed into the grid.
    As soon as the energy provided by the solar modules is no longer sufficient, the power from the battery is fed into the home network. Depending on the setting, power may also be obtained from the public grid in order to charge the battery*.
    When its temperature gets too high, the inverter automatically reduces the output or charging power, or switches off completely, in order to protect itself.
    Reasons for the temperature being too high include a high ambient temperature or insufficient heat dissipation (for example, inadequate heat dissipation when installed in switch cabinets).
    Depending on the device variant, suitable battery, corresponding cabling, settings, and local standards and regulations.
    2. Fronius Symo GEN24/Symo GEN24 SC
    Device concept
    Function overview
    Function
    Symo GEN24 Plus/Symo GEN24 Plus SC
    Battery connection*
    optionally available**
    For suitable batteries, see chapter Suitable batteries.
    The functions are optionally available via Fronius UP (see chapter Fronius UP).
    Fronius UP
    With Fronius UP*, optionally available functions can be added to the inverter by the authorized specialist company (see chapter Function overview).
    The availability of Fronius UP is country-specific. Click here for further information on availability.
    Scope of supply
    (1)
    Housing cover
    (2)
    Inverter
    (3)
    Mounting bracket (illustration)
    (4)
    Quick Start Guide
    (5)
    2 ferrite rings with holder
    Intended use
    The inverter is designed to convert direct current from PV modules into alternating current and feed this power into the public grid. A backup power mode* is possible if the wiring is set up accordingly.
    Intended use also means:
    • Carefully reading and following all the instructions as well as complying with the safety and danger notices in the operating instructions
    • Installation in accordance with the chapter headed Installation, from page (→)
    Follow all grid operator regulations regarding energy fed into the grid and connection methods.
    The inverter is a grid-connected inverter with backup power function and is not a stand-alone inverter. The following restrictions in backup power mode must therefore be observed:
    • The inverter may be operated for max. 2000 operating hours in backup power mode
    • The inverter may be operated for more than 2000 operating hours in backup power mode provided 20% of the grid power feed operating time of the inverter is not exceeded at the time in question
    Thermal concept
    Ambient air is drawn in at the front of the device by the fan and blown out at the sides. The even heat dissipation allows several inverters to be installed next to each another.
    NOTE
    Risk due to insufficient cooling of the inverter.
    This may result in a loss of power in the inverter.
    Do not block the fan (e.g., with objects that protrude through the touch guard).
    Do not cover the ventilation slots, even partially.
    Make sure that the ambient air can always flow through the inverter's ventilation slots unimpeded.
    Fronius Solar.web
    System owners and installers can easily monitor and analyze the PV system using Fronius Solar.web or Fronius Solar.web Premium. With the appropriate configuration, the inverter transmits data such as power, yield, load, and energy balance to Fronius Solar.web. More detailed information can be found at Solar.web - Monitoring & analysis.
    Configuration is carried out via the Setup wizard, see chapter Installation with the app or Installation with the browser.
    Requirements for configuration:
    • Internet connection (download: min. 512 kbit/s, upload: min. 256 kbit/s)*.
    • User account at solarweb.com.
    • Completed configuration using the Setup wizard.
    These specifications do not provide an absolute guarantee of flawless operation. High error rates in the transmission, fluctuating receptions or misfires can have an adverse effect on data transfer. Fronius recommends on-site testing to ensure that the connections meet the minimum requirements.
    Local communication
    The inverter can be found via the Multicast DNS (mDNS) protocol. We recommend searching for the inverter using the assigned host name.
    The following data can be called up via mDNS:
    • NominalPower
    • Systemname
    • DeviceSerialNumber
    • SoftwareBundleVersion
    PV module
    generates direct current
    Fronius GEN24 inverter
    converts direct current into alternating current and charges the battery (battery charging requires battery support, see chapter Function overview). The integrated system monitoring enables the inverter to be integrated into a network by means of WiFi.
    Additional inverter in the system
    converts the direct current into alternating current. However, it cannot charge a battery and is not available in backup power mode.
    Battery
    is coupled to the inverter on the direct current side, and stores electrical energy.
    Fronius Ohmpilot
    for using excess energy to heat water.
    Primary meter
    records the load curve of the system and makes the measured data available for energy profiling in Fronius Solar.web. The primary meter also controls the dynamic power of feeding in.
    Secondary meter
    records the load curve of individual loads (e.g., washing machine, lights, television, heat pump, etc.) in the load branch and makes the measured data available for energy profiling in Fronius Solar.web.
    Loads in the system
    are the loads connected in the system.
    Additional loads and producers in the system
    which are connected to the system by means of a Smart Meter.
    PV Point
    is a non-interruption-free 1‑phase backup power circuit, which supplies electrical devices up to a maximum output of 3 kW, provided sufficient power is available from the PV modules or the battery.
    Full Backup
    the inverter is prepared for backup power mode. The backup power function must be implemented in the switch cabinet by the electrician performing the installation. The PV system operates in a stand-alone manner in backup power mode.
    Grid
    supplies the loads in the system if insufficient power is being generated by the PV modules or supplied by the battery.
    2. Different operating modes
    PV module
    Battery
    Fronius Ohmpilot
    Primary meter
    Secondary meter
    Loads in the system
    PV Point
    Full Backup
    Grid
    In order to be able to obtain the highest rate of self-consumption with your photovoltaic system, a battery can be used to store excess energy. The battery is coupled to the inverter on the direct current side. Multiple current conversion is therefore not required, and the efficiency is increased.
    IMPORTANT!
    In backup power mode, an increased nominal frequency is used in order to prevent undesired parallel operation with other power generators.
    When the hybrid PV system is equipped with all the available features, the inverter can:
    • Supply loads in the house
    • Store excess energy in the battery and/or feed it into the grid
    • Supply connected loads in the event of a power failure
    IMPORTANT!
    In the fully equipped hybrid PV system with a Fronius Ohmpilot, the Ohmpilot cannot be operated in the event of a power failure for regulatory reasons. It is therefore sensible to install the Ohmpilot outside of the backup power branch.
    In the hybrid PV system, batteries may only be connected to an inverter with battery support. Batteries cannot be split between multiple inverters with battery support. Depending on the battery manufacturer, however, several batteries can be combined on one inverter.
    (1)
    PV module – inverter – load/grid/battery
    (2)
    Battery – inverter – load/grid*
    (3)
    Grid – inverter – load/battery*
    * Charging the battery from the public grid depends on the settings and local standards and regulations.
    Battery systems distinguish between different operating states. In each case, the relevant current operating state is displayed on the user interface of the inverter or in Fronius Solar.web.
    Operating state
    Description
    Normal operation
    The energy is stored or drawn, as required.
    Min. state of charge (SoC) reached
    The battery has reached the minimum SoC specified by the manufacturer or the set minimum SoC. The battery cannot be discharged further.
    Energy saving mode (standby)
    The system has been put into energy-saving mode. Energy saving mode is automatically ended as soon as sufficient surplus power is available again.
    Start
    The battery system starts from energy-saving mode (standby).
    Forced re-charging
    The inverter recharges the battery, in order to maintain the SoC specified by the manufacturer or the set minimum SoC (protection against deep discharge).
    Calibration charging
    The battery system is charged to the SoC of 100% and then discharged to the SoC of 0%. After 1 hour of waiting time at SoC 0%, the calibration charge is stopped and the battery switches to normal operation.
    Service mode
    The battery system is charged or discharged to the SoC of 30% and the SoC of 30% is maintained until the end of the service mode.
    Deactivated
    The battery is not active. It has either been deactivated, switched off, or the communication between the battery and the inverter has been interrupted.
    Energy-saving mode
    General
    Energy saving mode (standby mode) is used to reduce the self-consumption of the system. Both the inverter and the battery automatically switch to energy saving mode under certain conditions.
    The inverter switches to energy saving mode if the battery is flat and no PV power is available. Only the inverter's communication with the Fronius Smart Meter and Fronius Solar.web is maintained.
    2. Energy-saving mode
    General
    If all the switch-off conditions are met, the battery switches into energy saving mode within ten minutes. This time delay ensures that the inverter can at least be restarted.
    The battery state of charge is less than or equal to the input minimum state of charge.
    The current charging or discharging power of the battery is less than 100 W.
    Less than 50 W is available for charging the battery. The power of feeding into the public grid is at least 50 W less than the power currently required in the home network.
    The inverter automatically switches into energy saving mode, following the battery.
    If one of the following conditions is met for at least 30 seconds, energy saving mode is ended:
    • Energy saving mode is no longer permissible owing to a changed setting on the user interface of the inverter.
    • If dynamic power reduction of 0 is set, or if the system is operating in backup power mode, the power of feeding into the public grid is always less than the required power in the home network.
      There is a separate condition for this case (dynamic power reduction < 300 W or active backup power mode):
      • If the PV power is above a specified threshold, energy saving mode is ended.
    • Battery charging from the public grid is requested via the user interface of the inverter.
    • The battery is being recharged in order to restore the minimum state of charge or perform calibration.
    Special case
    If the inverter does not operate for 12 minutes (e.g., fault), or there is an interruption in the electrical connection between the inverter and the battery and there is no backup power mode, the battery switches to energy-saving mode in any case. This reduces self discharge of the battery.
    During energy saving mode:
    • Operating LED of the inverter lights up orange (see Button functions and LED status indicator on page (→)).
    • The user interface of the inverter can be reached.
    • All the available data are saved and transmitted to Solar.web.
    • The real-time data can be seen on Solar.web.
    Energy saving mode is shown on the user interface of the inverter and in Solar.web by an "i" beside the battery symbol in the system overview.
    Suitable batteries
    General
    Fronius explicitly points out that the third-party batteries are not Fronius products. Fronius is not the manufacturer, distributor, or retailer of these batteries. Fronius accepts no liability and offers no service or guarantees for these batteries.
    Obsolete firmware/software states may lead to incompatibilities between the inverter and the battery. In this case, the following steps are to be performed:
    1Update battery software—see the battery documentation.
    2Update inverter firmware—see Update on page (→).
    Read this document and the Installation Instructions before installing and commissioning the external battery. The documentation is either enclosed with the external battery or can be obtained from the battery manufacturer or their service partners
    All documents associated with the inverter can be found at the following address:
    2. Suitable batteries
    General
    Fronius batteries
    Fronius Reserva
    Capacity [kWh]
    6.3 - 15.8
    Number of modules
    2 - 5
    Fronius Symo GEN24/Symo GEN24 SC1)
    Fronius Symo GEN24 Plus/Symo GEN24 Plus SC
    Battery parallel operation2)
    Fronius Reserva Pro
    Capacity [kWh]
    12.0 - 32.0
    Number of modules
    3 - 8
    1)
    Battery support optionally available.
    2)
    Max. 4 batteries with the same capacity can be combined.
    BYD batteries
    BYD Battery-Box Premium HVS
    Capacity [kWh]1)
    5.1 - 12.8
    Number of modules
    2 - 5
    Fronius Symo GEN24/Symo GEN24 SC2)
    Battery parallel operation3)
    BYD Battery-Box Premium HVM
    BYD Battery-Box HVM+
    Capacity [kWh]
    8.3
    11.0 - 22.1
    Number of modules
    4 - 8
    1)
    The capacity of 12.8 kWh is not approved and certified for Italy.
    2)
    3)
    Max. 3 batteries with the same capacity can be combined. With BYD Battery-Box Premium HVM 22.1 max. 2 batteries can be combined.
    IMPORTANT!
    See the battery manufacturer's documentation for the maximum DC cable length.
    IMPORTANT! The following switch-on sequence for the system must always be followed to ensure reliable operation with a BYD Battery-Box Premium.
    Switch on the battery.
    Turn on the automatic circuit breaker. Set the DC disconnector to the "on" switch position.
    LG FLEX
    LG FLEX
    8.6
    12.9
    17.2
    Number of battery modules
    Fronius Symo GEN24/Symo GEN24 SC*
    Battery support is optionally available.
    Switching on the battery
    1Pull off the housing cover to the right.
    2Pull off the cover of the DC disconnector to the front.
    To assemble the battery, perform the steps listed above in reverse order.
    Manual system start
    Requirements
    There is no energy available from the PV modules or from the public grid. If backup power operation or battery operation are not possible (e.g., deep discharge protection of the battery), the inverter and battery switch off.
    2. Manual system start
    Requirements
    Status codes about the inactive state of the battery are displayed on the user interface of the inverter. A notification via e-mail can be activated in Fronius Solar.web.
    As soon as energy is available again, the inverter starts operation automatically; however, the battery must be started manually. The switch-on sequence must be observed for this, see chapter Suitable batteries on page (→).
    The inverter requires energy from the battery to start backup power operation. This is done manually on the battery; further information on the power supply for restarting the inverter via the battery can be found in the battery manufacturer's Operating Instructions.
    Connection area
    (1)
    2 x 4-pin DC push-in terminal
    (2)
    Push-in WSD (wired shutdown) terminal
    (3)
    Push-in terminals in the data communication area (Modbus, digital inputs and outputs)
    (4)
    3-pin push-in terminal for PV Point (OP)
    (5)
    5-pin AC push-in terminal
    (6)
    Cable gland/cable connection AC
    (7)
    6-pin ground electrode terminal
    (8)
    Data communication area cable gland/cable connection
    (9)
    (10)
    10 x DC glands
    (11)
    Optional cable gland (M16)
    (12)
    Optional cable gland (M16 - M20)
    (13)
    Optional cable gland (M16 - M32)
    (14)
    Optional cable gland (M16 - M25)
    2. Operating controls and connections
    Connection area
    (1)
    (2)
    (3)
    (4)
    (5)
    (6)
    (7)
    (8)
    (9)
    (10)
    10 x DC glands
    (11)
    (12)
    (13)
    (14)
    The connection area divider separates the high-voltage conductors (DC and AC) from the signal lines. To make it easier to reach the connection area, the divider can be removed for the connection work, and must be re-inserted.
    (1)
    Integrated cable duct
    (2)
    Recesses for removing the connection area divider
    (3)
    Snap tabs for locking/unlocking
    (4)
    Defined breaking point for the DatCom connection
    The integrated cable duct (1) allows for the lines to be laid from one area of the inverter to the other. As a result, multiple inverters can be easily installed next to each other.
    The ground electrode terminal    provides the option of grounding additional components, such as:
    • AC cable
    • Module mounting system
    • Ground spike
    DC disconnector
    The DC disconnector has 3 switch settings:
    (1)
    Locked/off (turned to the left)
    (2)
    Off
    (3)
    On
    IMPORTANT!
    In switch settings (1) and (3), the inverter can be secured to prevent it from being switched on/off using a standard padlock. The national guidelines must be complied with in this respect.
       Operating LED
    Indicates the inverter operating status.
    BAT switch
    Position 1: Setting for connecting compatible batteries (factory setting)
    Position 0:
    not in use
    WSD (wired shutdown) switch
    Defines the inverter as the WSD master or WSD secondary device.
    Position 1: WSD master
    Position 0:
    Modbus 0 (MB0) switch
    Switches the terminating resistor for Modbus 0 (MB0) on/off.
    Position 1: Terminating resistor on (factory setting)
    Position 0: Terminating resistor off
    Modbus 1 (MB1) switch
    Switches the terminating resistor for Modbus 1 (MB1) on/off.
       Optical sensor
    For operating the inverter. See Button functions and LED status indicator.
       Communications LED
    Indicates the inverter connection status.
     Battery Connection (Modbus RJ45)
    Modbus connection for connecting a compatible battery.
    IMPORTANT!
    • This connection only works with hybrid inverters.
    • The connection is connected to Modbus 0.
    • Do not connect any network components (e.g., WiFi router) to this connection.
    LAN 1
    Ethernet connection for data communication (e.g., WiFi router, home network) or, for commissioning with a laptop, see Installation with the browser.
    LAN 2
    Reserved for future functions.
    I/O terminal
    Push-in terminal for digital inputs/outputs. See Permitted cables for the data communication connection.
    The designations (RG0, CL0, 1/5, 2/6, 3/7, 4/8) relate to the Function Demand Response Mode, see Functions and I/Os.
    WSD terminal
    Push-in terminal for the WSD installation. See WSD (wired shutdown).
    Modbus terminal
    Push-in terminal for the installation of Modbus 0, Modbus 1, 12 V, and GND (ground).
    The inverter establishes the data connection to the connected components via the Modbus terminal. The inputs M0 and M1 can be freely selected. Max. four Modbus participants per input, see Modbus participants.
    The operating LED indicates the inverter status. In case of faults, follow the individual steps in the Fronius Solar.start app.
    Actuate the optical sensor by touching it with a finger.
    The communication LED indicates the status of the connection. To establish a connection, follow the individual steps in the Fronius Solar.start app.
    Sensor functions
    1x    = WiFi access point (AP) is opened.
       Flashes blue
    2x    = WiFi protected setup (WPS) is activated.
       Flashes green
    3 seconds    (max. 6 seconds) = the service message disappears.
       Flashes white (quickly)
    The inverter is operating correctly.
       Lights up green
    The inverter is performing the grid checks required by the applicable standards for grid power feed operation.
       Flashes green
    The inverter is on standby, is not operating (e.g., no energy fed into the grid at night), or is not configured.
       Lights up yellow
    The inverter displays an error. The inverter is operating correctly.
       Flashes yellow
    The inverter displays a critical status and no energy is fed into the grid.
       Lights up red
    The inverter displays a backup power overload.
       Flashes red
    The network connection is being established via WPS.
    2x    = WPS search mode.
       Flashes green
    The network connection is being established via WiFi AP.
    1x    = WiFi AP search mode (active for 30 minutes).
       Flashes blue
    The network connection is not configured.
       Lights up yellow
    There is a network error, the inverter is operating correctly.
       Lights up red
    The network connection is active.
       Lights up blue
    The inverter is performing an update.
       /    Flash blue
    There is a service message.
       Lights up white
    The V+/ GND pin provides the possibility of feeding in a voltage in the range of 12.5 to 24 V (+ max. 20%) using an external power supply unit. Outputs IO 0 - 5 can then be operated using the external voltage that has been fed in. A maximum of 1 A may be drawn per output, whereby a total of max. 3 A is permitted. The fuse protection must take place externally.
    CAUTION
    Danger from polarity reversal at the terminals due to improper connection of external power supply units.
    This may result in severe damage to the inverter.
    Check the polarity of the external power supply unit with a suitable measuring device before connecting it.
    Connect the cables to the V+/GND outputs while ensuring the correct polarity.
    IMPORTANT!
    If the total output (6 W) is exceeded, the inverter switches off the entire external power supply.
    (1)
    Current limitation
    General
    IMPORTANT!
    If several backup power variants are available, please note that only one backup power variant may be installed and configured.
    The inverter can provide 220‑240 V at the PV Point/PV Point Comfort. A corresponding configuration must be set up during commissioning.
    At 220‑240 V output voltage, max. 13 A AC continuous current is available.
    Example:
    220 V *13 A = 2,860 W
    230 V *13 A = max. 3 kW
    In backup power mode, some electrical appliances cannot function properly as starting currents are too high (for example, fridges and freezers). It is recommended to switch off non-essential loads during backup power mode. Overload capacity of 35% is possible for a duration of 5 seconds, depending on the capacity of the PV modules and/or the battery at that moment in time.
    There is a brief interruption when switching from grid-connected mode to backup power mode. For this reason, the backup power function cannot be used as an uninterruptible power supply, for example for computers.
    If no energy from the battery or the PV modules is available in backup power mode, backup power mode ends automatically. If sufficient energy becomes available from the PV modules once again, backup power mode starts again automatically.
    In the event of excessive consumption, backup power mode is stopped and the "backup power overload" status code is displayed on the inverter's LED status indicator (see Button functions and LED status indicator on page (→)). The maximum power in backup power mode according to the technical data must be observed.
    1. Backup power variant - PV Point (OP)
    General
    IMPORTANT!
    Example:
    2. General
    IMPORTANT!
    Example:
    2. General
    PV Point (OP)
    With the PV Point, in the event of a failure of the public grid, 1‑phase electrical devices can be connected to the Opportunity Power (OP) terminal and supplied with a maximum power of 3 kW, if enough power is available in the solar modules or an optional battery. In grid connected operation, the OP terminal is not supplied with voltage, therefore the connected loads will not be permanently supplied with power.
    IMPORTANT!
    A grid switchover with relay is not possible.
    For the installation instructions, see chapter Connecting backup power - PV Point (OP) on page (→).
    2. General
    PV Point Comfort
    With the PV Point Comfort, 1-phase electrical devices are permanently supplied with a maximum power of 3 kW.
    Switching between grid connected and backup power mode takes place automatically. In the event of a failure of the public grid or the inverter, the PV Point Comfort permanently supplies connected loads. When the grid becomes available again and stability is ensured, the PV Point Comfort automatically switches to grid connected mode and backup power mode is terminated.
    IMPORTANT!
    Backup power mode requires sufficient power from the PV modules or a battery. The PV Point Comfort is not available in Australia and New Zealand.
    For further information and the installation instructions, see chapter PV Point Comfort on page (→).
    General
    IMPORTANT!
    If several backup power variants are available, it is important to note that only one backup power variant may be installed and configured.
    The following prerequisites must be met in order to use the inverter's backup power function:
    • The inverter must support the backup power variant 'Full Backup' (see chapter Function overview on page (→)).
    • A battery suitable for backup power use must be installed and configured.
    • Correct cabling of the backup power system in the electrical installation (see chapter Components for switching to backup power on page (→) or Circuit diagrams—automatic switch to backup power with Fronius Backup Controller on page (→)).
    • Install and configure the Fronius Smart Meter at the feed-in point.
    • Attach a backup power supply warning (https://www.fronius.com/en/search-page, item number: 42,0409,0275) to the electrical distributor.
    • Apply the necessary settings in the Devices and system components > Functions and pins > Backup Power menu item and activate backup power.
    • Go through the checklist - Backup power (https://www.fronius.com/en/search-page, item number: 42,0426,0365) step by step and confirm.
    1. Backup power variant - Full Backup
    General
    IMPORTANT!
    2. General
    IMPORTANT!
    2. General
    1. The public grid is monitored by the inverter's internal grid and system protection unit and by the Fronius Smart Meter connected to it.
    2. The public grid fails or specific grid parameters are undershot or exceeded.
    3. The inverter carries out the measures necessary according to the country standard and then switches off.
    4. The inverter starts backup power mode after a checking period.
    5. All loads in the household that are in the backup power circuit are supplied by the battery and the PV modules. The remaining loads are not supplied with power and are safely isolated.
    2. General
    1. The inverter is operating in backup power mode.
    2. The public grid is functioning correctly again.
    3. The Fronius Smart Meter monitors the grid parameters on the public grid and passes this information to the inverter.
    4. The stability of the restored public grid is determined by checking the measured values of the Fronius Smart Meter.
    5. Backup power mode is terminated automatically or manually depending on the design of the backup power switchover facility.
    6. All circuits are reconnected to the public grid and are supplied by the grid.
    7. The inverter can start grid power feed operation again after performing the grid checks required by the relevant standard.
    2. General
    Under the following conditions, the battery and the inverter are switched to energy saving mode after a waiting time of 8-12 minutes and backup power mode is ended:
    • The battery is discharged to the minimum state of charge and no energy is coming from the PV modules.
    • The inverter is set to energy saving mode (standby mode).
    If the battery and inverter are in energy saving mode, the system is reactivated by the following:
    • Enough energy is available from the PV modules.
    • The public grid is functioning again.
    • The battery is switched off and on.
    Functions
    IMPORTANT!
    Depending on the installation, the entire house or only selected circuits are supplied with backup power if the public grid fails. The total load of the backup power circuits must not exceed the rated power of the inverter. Note the capacity of the connected battery.
    • Disconnects from the public grid after the required FRT time if the grid parameters are outside the country-specific standards in order to enable backup power mode.
    • Reconnects to the public grid if the grid parameters are within the limits of the country-specific standards.
    • Possibility of a separate backup power circuit or several backup power circuits, which are also supplied during a failure of the public grid. The total load of the backup power circuits must not exceed the rated power of the inverter. The capacity of the connected battery must also be taken into account.
    2. Automatic switch to backup power with Fronius Backup Controller 3P-35A incl. backup power circuits and 3-pin separation, e.g., Austria or Australia
    Functions
    IMPORTANT!
    1. The public grid is monitored by the inverter's internal grid and system protection and by the connected Fronius Smart Meter.
    2. Failure of the public grid.
    3. The inverter takes the necessary measures according to the country standard and then switches off.
      The Fronius Backup Controller disconnects the backup power circuits and the inverter from the rest of the home network and from the public grid.
    4. Based on the feedback from the Fronius Backup Controller and the measurements at the inverter terminals, the inverter decides that backup power mode can be started.
    5. After all required connection tests have been carried out, the inverter starts in backup power mode.
    6. All loads that are in the backup power circuits are supplied. The remaining loads are not supplied and are safely disconnected.
    1. The inverter is operating in backup power mode. The backup power circuits are disconnected from the public grid.
    2. Public grid is available again.
    3. The Fronius Smart Meter measures the grid parameters on the public grid and passes this information on to the inverter.
    5. The inverter ends backup power mode and de-energizes the outputs.
    6. The inverter gives the Fronius Backup Controller approval to reconnect to the public grid.
    7. All backup power circuits are reconnected to the public grid by the Fronius Backup Controller.
    8. Once the grid checks required by the applicable standards have been performed, the inverter can start feeding power into the grid again.
    Parallel Backup
    Parallel Backup enables synchronized backup power mode for several inverters. An inverter with connected battery operates as a primary inverter (parallel backup coordinator). The primary inverter controls a maximum of four secondary inverters in the system (parallel backup supporters). After release by the parallel backup coordinator, the parallel backup supporters feed additional available PV power into the backup power circuit. In the event of backup power, this helps to cover the power demand and charge the battery on the primary inverter.
    For the configuration of Parallel Backup on the primary inverter or on the secondary inverters and for the I/O cable extension when using Parallel Backup, see Functions and I/Os.
    The primary inverter:
    • Controls the secondary inverters
    • Controls the backup controller
    • Supplies the mains voltage
    • Regulates the frequency routing in the backup power circuit
    Requirements for Parallel Backup:
    • The current software version is installed on the primary and secondary inverters. See Update.
    • The primary and secondary inverters share the same phase assignment.
    Parallel backup coordinators can be:
    • Fronius Symo GEN24 6-10 kW Plus
    • Fronius Symo GEN24 6-12 kW Plus SC
    • Fronius Verto Plus 15-20 kW Plus
    • Fronius Verto Plus 25-33.3 kW Plus
    Parallel backup supporters can be:
    • All Fronius Symo GEN24
    • All Fronius Verto
    Functions
    • Measuring and transferring the required parameters for energy management and Solar.web by the Fronius Smart Meter.
    • Disconnecting from the public grid to enable operation in backup power mode if the grid parameters are outside the country-specific standards.
    • Reconnecting to the public grid when the grid parameters are within the limits specified by the country-specific standards.
    • Option of having a separate backup power circuit or several backup power circuits that are supplied even during failure of the public grid. The total load of the backup power circuits must not exceed the nominal output of the inverter. Furthermore, the performance of the connected battery must also be considered.
    2. Automatic switch to backup power including backup power circuits and 3-pin separation, e.g., Austria or Australia
    Functions
    Transitioning from grid power feed operation to backup power mode
      Contactor K1 drops out. This disconnects the backup power circuits and the inverter from the rest of the home network and from the public grid, as the main contacts of contactor K1 open. The inverter activates relay K3, which interrupts the supply to contactor K1. This prevents unintentional activation of contactor K1 and thus a grid connection when voltage is restored in the grid. The NC auxiliary contacts of contactor K1 send feedback to the inverter that the contactor is open (a condition for starting backup power mode).
    4. The NO contact of relay K3 gives additional feedback to the inverter on whether the locking was successfully performed by relay K3.
    5. The inverter decides based on the contactor's feedback as well as the measurements on the inverter terminals that the backup power mode can be activated.
    6. After all the required activation tests have been carried out, the inverter starts backup power mode.
    7. All loads in the backup power circuits are supplied with power. The remaining loads are not supplied with power and are safely isolated.
    Transitioning from backup power mode to grid power feed operation
    1. The inverter is operating in backup power mode. Contactor K1 to the public grid is open.
    2. Public grid available again.
    5. The inverter ends backup power mode and disconnects the outputs.
    6. The inverter deactivates K3. Contactor K1 is reactivated.
    7. All circuits are reconnected to the public grid and are supplied by the grid. The inverter does not feed anything into the grid at this time.
    8. The inverter can start grid power feed operation again after performing the grid checks required by the relevant standard.
    Automatic switch to backup power mode, all-pin disconnection, e.g., in Germany with Fronius Backup Controller 3PN-35A
    Functions
    IMPORTANT!
    Depending on the installation, the entire house or only selected circuits are supplied with backup power if the public grid fails. The total load of the backup power circuits must not exceed the rated power of the inverter. Note the capacity of the connected battery. When using the Fronius Backup Controller 3PN-35A, the data communication area may be loaded with additional loads up to max. 3 W.
    • Establish a correct ground connection for backup power mode to ensure the functions of the protective devices.
    2. Automatic switch to backup power mode, all-pin disconnection, e.g., in Germany with Fronius Backup Controller 3PN-35A
    Functions
    IMPORTANT!
    Transition from grid power feed operation to backup power mode
      The Fronius Backup Controller disconnects the backup power circuits and the inverter from the rest of the home network and from the public grid at all pins. A multiple connection is also established between the neutral conductor and the ground conductor.
    Transition from backup power mode to grid power feed operation
    Automatic switch to backup power all-pin separation, e.g., Germany, France, Spain
    Functions
    • Establishing a proper ground connection for backup power mode to ensure the protection devices function correctly.
    • Option of having a separate backup power circuit or several backup power circuits that are supplied even during failure of the public grid. The total load of the backup power circuits must not exceed the rated power of the inverter. Furthermore, the performance of the connected battery must also be considered.
    2. Automatic switch to backup power all-pin separation, e.g., Germany, France, Spain
    Functions
    3. The inverter carries out the necessary measures according to the country standard and then switches off.
      Contactors K1, K4, and K5 drop out. This disconnects the backup power circuits and the inverter from the rest of the home network and from the public grid, as the main contacts of contactor K1 open (all-pin). The NC auxiliary contacts of contactor K1 send feedback to the inverter that the contactor is open (a condition for starting backup power mode).
    4. The NC main contacts of contactors K4 and K5 are closed, establishing a connection between the neutral conductor and the ground conductor. The two other NC main contacts of contactors K4 and K5 give feedback to the inverter that the ground connection has been established correctly (a condition for starting backup power mode).
    5. The inverter activates relay K3, which interrupts the supply to contactors K1, K4, and K5. This prevents unintentional activation of contactors K1, K4, and K5 and thus a grid connection when voltage is restored in the grid.
    6. The NO contact of relay K3 gives additional feedback to the inverter on whether the locking was successfully performed by relay K3.
    7. The inverter decides based on the contactors' feedback as well as the measurements on the inverter terminals that the backup power mode can be started.
    8. After all the required activation tests have been carried out, the inverter starts backup power mode.
    9. All loads in the backup power circuits are supplied with power. The remaining loads are not supplied with power and are safely isolated.
    6. The inverter deactivates K3. Power is restored to contactors K1, K4, and K5.
    Automatic switch to backup power all-pin separation, Italy
    Functions
    • Monitoring of the voltage and frequency grid parameters by the inverter.
    • Establishing a correct ground connection for backup power mode.
    2. Automatic switch to backup power all-pin separation, Italy
    Functions
    1. The public grid is monitored by the inverter's internal grid and system protection unit and by an external grid and system protection unit.
    4. The external grid and system protection unit opens contactors K1 and K2 for grid monitoring. This disconnects the backup power circuits and the inverter from the rest of the home network and from the public grid, as the main contacts of contactors K1 and K2 open (all-pin). To ensure that the public grid has definitely been disconnected, the NC auxiliary contacts of contactor K1 give feedback to the external grid and system protection unit.
    5. The NC main contacts of contactors K4 and K5 are closed, establishing a connection between the neutral conductor and the ground conductor. The two other NC main contacts of contactors K4 and K5 give feedback to the inverter that the ground connection has been established correctly.
    6. The inverter activates relay K3, which activates the remote input of the external grid and system protection unit via an NC contact. This prevents a connection to the public grid when voltage is restored in the grid.
    7. The NO contact of relay K3 gives additional feedback to the inverter on whether the locking was successfully performed by relay K3.
    8. The inverter decides based on the contactor's feedback as well as the measurement on the inverter terminals that the backup power mode can be activated.
    9. The inverter starts backup power mode after a defined checking period.
    10. All loads in the backup power circuits are supplied with power. The remaining loads are not supplied with power and are safely isolated.
    link_horizontalLink copied
    1. The inverter is operating in backup power mode. The contactors K1 and K2 to the public grid are open.
    5. On the basis of adjustments that have been carried out, the inverter ends backup power mode and disconnects the outputs.
    6. The inverter deactivates K3. Power is restored to contactors K1, K2, K4, and K5.
    Manual switch to backup power 3-pin separation, e.g., Austria / all-pin separation, e.g., Germany
    Functions
    • Monitoring of the grid parameters by the inverter.
    • Possibility of manual separation from the public grid if it fails or is deemed unstable.
    • If, in the event of a public grid failure, there is no manual switch to backup power mode within the first 10 minutes, this may cause the inverter and the battery to shut down. In order to then start backup power mode, manual switching must take place and a manual system start must be performed, if necessary (see chapter Manual system start on page (→)).
    • It is possible to manually reconnect the inverter and loads in the backup power circuit to the public grid once it is deemed to be stable again. The inverter only starts feed-in mode once the required grid monitoring time has passed.
    2. Manual switch to backup power 3-pin separation, e.g., Austria / all-pin separation, e.g., Germany
    Functions
    4. The user switches the Fronius Backup Switch from switch position 1 (grid operation) via switch position 0 to switch position 2 (backup power mode). This disconnects the backup power circuits and the inverter from the rest of the home network and from the public grid. In the case of all-pole disconnection, the connection of ground conductor and neutral conductor is also made via the main contacts of the switch. Switch position 2 (backup power mode) is fed back to the inverter via a main contact of the Fronius Backup Switch. In addition, when the Fronius Backup Switch switches via switch position 0, the WSD line is interrupted. This causes the inverter to switch off immediately. This behavior is ensured via 2 contacts. The communication between the inverter and the Fronius Smart Meter is optionally prevented via a contact. The suspended communication prevents automatic termination of backup power mode when power returns to the public grid. The inverter then remains in backup power mode until it is manually switched back again.
    5. Based on the feedback for switch position 2 and the measurements at the inverter terminals, the inverter decides that backup power mode can be started.
    6. After all required connection tests have been carried out, the inverter starts in backup power mode.
    7. All loads that are in the backup power circuits are supplied. The remaining loads are not supplied and are safely disconnected.
    1. The inverter is operating in backup power mode. The Fronius Backup Switch is in switch position 2 (backup power mode).
    3. The user switches the Fronius Backup Switch from switch position 2 (backup power mode) via switch position 0 to switch position 1 (grid operation). When switching via switch position 0, the inverter switches off immediately. This is ensured by the Fronius Backup Switch. In order to protect sensitive loads, it is recommended to remain in the zero position for at least 1 second during the switchover process from backup power mode to the public grid.
    4. The inverter is connected to the entire home network and to the public grid again.
    5. Communication between the inverter and the Fronius Smart Meter is restored.
    6. Once the grid checks required by the applicable standards have been performed, the inverter can start feeding power into the grid again.
    Installation
    General
    Quick-fastener system
    NOTE
    Danger when using a drill driver.
    This may result in the destruction of the quick-fastener system due to overtorque.
    Use a screwdriver (TX20).
    Do not turn the screws more than 180°.
    A quick-fastener system (3) is used to mount the connection area cover and front cover. The system is opened and closed with a half-rotation (180°) of the captive screw (1) into the quick-fastener spring (2).
    The system is independent of torque.
    1. Installation
    General
    NOTE
    1. Installation
    2. General
    NOTE
    1. Installation
    2. General
    System component compatibility
    All installed components in the PV system must be compatible with each other and have the necessary configuration options. The installed components must not restrict or negatively affect the functioning of the PV system.
    NOTE
    Risk due to components in the PV system that are not and/or only partially compatible.
    Incompatible components can restrict and/or negatively affect the operation and/or functioning of the PV system.
    Only install components recommended by the manufacturer in the PV system.
    Before installation, check the compatibility of components that have not been expressly recommended with the manufacturer.
    1. Installation
    Installation location and position
    Choosing the location of the inverter
    Please observe the following criteria when choosing a location for the inverter:
    Only install on a solid, non-flammable surface.
    Max. ambient temperatures:
    -25 °C - +60 °C
    Relative humidity:
    0-100%
    When installing the inverter in a switch cabinet or similar closed environment, it is necessary to make sure that the hot air that develops will be dissipated by forced-air ventilation.
    For more detailed information on inverter dimensions, see chapter Dimensions of the inverter on page (→).
    When installing the inverter on the outer walls of cattle sheds, it is important to maintain a minimum clearance of 2 m between all sides of the inverter and the ventilation and building openings.
    The following substrates are permissible for installation:
    • Walls (corrugated metal walls [mounting rails], brick walls, concrete walls, or other non-flammable surfaces sufficiently capable of bearing loads)
    • Mast or beam (installed using mounting rails, behind the PV modules directly on the PV mounting system)
    • Flat roofs (if this is for a film roof, make sure that the films comply with the fire protection requirements and are not highly flammable. Ensure compliance with the national provisions.)
    • Covered parking lot roofs (no overhead installation)
    The inverter is suitable for indoor installation.
    The inverter is suitable for outdoor installation.
    Because of its IP 66 protection class, the inverter is not susceptible to water spray from any direction and can also be operated in moist environments.
    In order to keep inverter heating as low as possible, do not expose the inverter to direct sunlight.
    The inverter should be installed in a protected location, e.g., near the PV modules or under an overhanging roof.
    The inverter must not be installed or operated at more than 4,000 m above sea level.
    Do not install the inverter:
    • Where it may be exposed to ammonia, corrosive gases, acids, or salts (e.g., fertilizer storage areas, vent openings for livestock stables, chemical plants, tanneries)
    During certain operating phases the inverter may produce a slight noise. For this reason it should not be installed in an occupied living area.
    Do not install the inverter in:
    • Areas where there is an increased risk of accidents from farm animals (e.g., horses, cattle, sheep, pigs)
    • Stables or adjoining areas
    • Storage areas for hay, straw, chaff, animal feed, and fertilizers
    The inverter is designed to be dust-proof (IP 66). In areas of high dust accumulation, dust deposits may collect on the cooling surfaces, and thus impair the thermal performance. Regular cleaning is required in this case, see chapter Operation in dusty environments on page (→). We therefore recommend not installing the inverter in areas and environments with high dust accumulation.
    • Greenhouses
    • Storage or processing areas for fruit, vegetables, or viticulture products
    • Areas used in the preparation of grain, green fodder, or animal feeds
    1. Installation
    2. Installation location and position
    -25 °C - +60 °C
    Relative humidity:
    0-100%
    • Greenhouses
    1. Installation
    Choosing the location of third-party batteries
    IMPORTANT!
    Refer to the manufacturer's documents for specifications regarding the suitable location of third-party batteries.
    1. Installation
    Installation position of the inverter
    The inverter is suitable for vertical installation on a vertical wall or column.
    The inverter is suitable for a horizontal installation position.
    The inverter is suitable for installation on a sloping surface.
    Do not install the inverter on a sloping surface with the connections upwards.
    Do not install the inverter in a sloping position on a vertical wall or column.
    Do not install the inverter in a horizontal position on a vertical wall or column.
    Do not install the inverter with the connections upwards on a vertical wall or column.
    Do not install the inverter overhanging with the connections upwards.
    Do not install the inverter overhanging with the connections downwards.
    Do not install the inverter on the ceiling.
    1. Installation
    Installing the mounting bracket and attaching the inverter
    Selecting the mounting material
    Use the corresponding fixing materials depending on the subsurface and observe the screw dimension recommendations for the mounting bracket.
    The installer is responsible for selecting the right type of fixing.
    1. Installation
    2. Installing the mounting bracket and attaching the inverter
    1. Installation
    Properties of the mounting bracket
    The mounting bracket (illustration) can also be used as a gauge.
    The pre-drilled holes on the mounting bracket are intended for screws with a thread diameter of 6 - 8 mm (0.24 - 0.32 inches).
    Unevenness on the mounting surface (such as coarse-textured plaster) is largely compensated by the mounting bracket.
    1. Installation
    Do not deform the mounting bracket
    NOTE
    When attaching the mounting bracket to the wall or to a column, make sure that the mounting bracket is not deformed.
    A deformed mounting bracket may make it difficult to clip/swivel the inverter into position.
    1. Installation
    Fitting the mounting bracket to a wall
    IMPORTANT!
    Fit the mounting bracket with the arrow pointing upwards.
    Align the mounting bracket and mark the drill holes.
    Drill the drill holes.
    Insert dowels and fasten the mounting bracket to the wall with 4 screws.
    1. Installation
    Installing the mounting bracket on a mast or beam
    When installing the inverter on a mast or beam, Fronius recommends using the "Pole clamp" (order no. SZ 2584.000) mounting kit from Rittal GmbH.
    The "Pole clamp" kit covers the following dimensions:
    • Rectangular mast or beam with a side length of 50–150 mm (1.97–5.91 inches)
    • Round mast or beam with a diameter of 40–190 mm (1.57–7.48 inches)
    1. Installation
    Attaching the mounting bracket to mounting rails
    IMPORTANT!
    The mounting bracket must be affixed at a minimum of four points.
    1. Installation
    Attaching the inverter to the mounting bracket
    Lift the inverter by the integrated side handles.
    Clip the inverter into the mounting bracket from above. The connections must point downwards.
    Press the lower area of the inverter into the snap-in tabs on the mounting bracket until the inverter engages on both sides with an audible click.
    3Check that the inverter is correctly in position on both sides.
    1. Installation
    Requirements for connecting the inverter
    Different cable types
    Single-core
    Multi-stranded
    Fine-stranded
    Fine-stranded with ferrule and collar
    Fine-stranded with ferrule without collar
    Single-core cable type
    Multi-stranded cable type
    Fine-stranded cable type
    Fine-stranded with ferrule and collar cable type
    Fine-stranded with ferrule without collar cable type
    1. Installation
    2. Requirements for connecting the inverter
    Single-core
    Multi-stranded
    Fine-stranded
    1. Installation
    Permitted cables for the electrical connection
    Connect round copper conductors to the terminals of the inverter as described below. Select a sufficiently large cable cross-section based on the actual device output.
    Grid connections
    Number of pins
    5
    2.5 - 10 mm2
    2.5 - 10 mm2
    2.5 - 10 mm2
    2.5 - 6 mm2
    2.5 - 6 mm2
    Backup power grid connections
    Number of pins
    1.5 - 10 mm2
    1.5 - 10 mm2
    1.5 - 10 mm2
    1.5 - 6 mm2
    1.5 - 6 mm2
    PV/BAT connections*
    Number of pins
    2 x 4
    4 - 10 mm2
    4 - 10 mm2
    4 - 10 mm2
    4 - 6 mm2
    4 - 6 mm2
    Ground electrode terminal**
    Number of pins
    2.5 - 16 mm2
    2.5 - 16 mm2
    2.5 - 16 mm2
    2.5 - 16 mm2
    2.5 - 16 mm2
    2.5 - 10 mm2
    2.5 - 10 mm2
    2.5 - 10 mm2
    2.5 - 10 mm2
    2.5 - 10 mm2
    Dimension the cable cross-section according to the specifications of the battery manufacturer and depending on the installation situation.
    According to product standard IEC 62109, the ground conductor must correspond to the phase cross-section with phase cross-sections of ≤16 mm² and at least 16 mm² with phase cross-sections of >16 mm². With a conductor cross-section of 1.5 mm2, the maximum permitted line length is 100 m.
    1. Installation
    IMPORTANT!
    If several single conductors are connected to an input of the terminal, connect the single conductors with a corresponding ferrule.
    WSD connections
    Distance
    Stripping length
    Cable recommendation
    100 m 109 yd
    10 mm
    0.39 inches
    0.14 - 1.5 mm2
    AWG 26 - 16
    0.14 - 1.5 mm2
    AWG 26 - 16
    0.14 - 1 mm2
    AWG 26 - 18
    0.14 - 1.5 mm2
    AWG 26 - 16
    Min. CAT 5 UTP (unshielded twisted pair)
    Modbus connections
    Distance
    Stripping length
    300 m 328 yd
    10 mm
    0.39 inches
    0.14 - 1.5 mm2
    AWG 26 - 16
    0.14 - 1.5 mm2
    AWG 26 - 16
    0.14 - 1 mm2
    AWG 26 - 18
    0.14 - 1.5 mm2
    AWG 26 - 16
    Min. CAT 5 STP (shielded twisted pair)
    IO connections
    Distance
    Stripping length
    30 m
    32 yd
    10 mm
    0.39 inches
    0.14 - 1.5 mm2
    AWG 26 - 16
    0.14 - 1.5 mm2
    AWG 26 - 16
    0.14 - 1 mm2
    AWG 26 - 18
    0.14 - 1.5 mm2
    AWG 26 - 16
    Single conductors possible
    LAN connections
    Fronius recommends using at least CAT 5 STP (shielded twisted pair) cables and a maximum distance of 100 m (109 yd).
    1. Installation
    Cable diameter of the AC cable
    For a standard M32 cable gland with a reducer:
    7-15 mm
    For a standard M32 cable gland without a reducer:
    11-21 mm
    (with a cable diameter of less than 11 mm, the strain-relief force is reduced from 100 N to a maximum of 80 N)
    With cable diameters greater than 21 mm, the M32 cable gland must be replaced by an M32 cable gland with a larger clamping area—item number: 42,0407,0780—strain-relief device M32 x 1.5 KB 18-25.
    1. Installation
    Cable diameter of the DC cable
    Cable diameter for the strain-relief device: max. 9 mm.
    .Cable diameter for the connection to the push-in terminal: max. 6 mm
    IMPORTANT!
    For double-insulated cables with a cable diameter over 6 mm, the external insulation layer must be removed to connect to the push-in terminal.
    1. Installation
    Maximum alternating current fuse protection
    NOTE
    A residual current circuit breaker for the AC connecting cable may be required depending on national regulations, the grid operator, and other conditions.
    A type A residual current circuit breaker is generally sufficient in this case. Nevertheless, false alarms can be triggered for the type A residual current circuit breaker in individual cases and depending on local conditions. For this reason, Fronius recommends using a residual current circuit breaker suitable for frequency inverters with a tripping current of at least 100 mA (national provisions must be taken into account).
    IMPORTANT!
    Use the inverter with a 32 A automatic circuit breaker as a maximum.
    Inverter
    Phases
    AC power
    Maximum fuse protection
    Recommended fuse protection
    Fronius Symo GEN24 6.0/Symo GEN24 6.0 SC
    6000 W
    32 A
    16 A
    Fronius Symo GEN24 8.0/Symo GEN24 8.0 SC
    8000 W
    32 A
    25 A
    Fronius Symo GEN24 10.0/Symo GEN24 10.0 SC
    10,000 W
    32 A
    32 A
    Fronius Symo GEN24 12.0 SC
    12,000 W
    32 A
    32 A
    1. Installation
    Connecting the inverter to the public grid (AC side)
    Safety
    WARNING
    Read the Installation Instructions and Operating Instructions before installing and commissioning the equipment.
    Only qualified personnel are authorized to commission the inverter and only within the scope of the respective technical regulations.
    WARNING
    Danger from grid voltage and DC voltage from PV modules that are exposed to light.
    Prior to any connection work, ensure that the inverter is de-energized on the AC side and the DC side.
    Only an authorized electrical engineer is permitted to connect this equipment to the public grid.
    WARNING
    Danger from damaged and/or contaminated terminals.
    Prior to connection work, check the terminals for damage and contamination.
    Remove any contamination while the equipment is de-energized.
    Have defective terminals replaced by an authorized specialist.
    1. Installation
    2. Connecting the inverter to the public grid (AC side)
    Safety
    WARNING
    WARNING
    WARNING
    1. Installation
    CAUTION
    Danger due to incorrect connection of the inverter.
    It is not possible to operate the inverter in ungrounded networks, e.g., IT networks (isolated networks without ground conductor).
    The neutral conductor must be connected in order to operate the inverter.
    Make sure that the grid's neutral conductor is grounded.
    1.
    Tools required: Screwdriver TX20
    2.
    Ground conductor PE dimensioned longer and laid with a movement loop.
    3.
    Tools required: Crimping tool
    4.
    Only one conductor may be connected to each pin.
    Turn off the automatic circuit breaker. Set the DC disconnector to the "off" switch position.
    Loosen the 5 screws on the connection area cover by rotating them 180° to the left using a screwdriver (TX20).
    Remove the connection area cover from the device.
    Press the latch on the back of the terminal and remove the AC terminal.
    Insert the ferrite rings supplied into the holder.
    5
    Guide the mains cable from below through the cable gland on the right side and the ferrite core.
    IMPORTANT!
    The ground conductor must not be fed through the ferrite core. Dimension the ground conductor longer and lay it with a movement loop so that it will be the last conductor subjected to mechanical stress in the event of a cable gland failure.
    For more information about the cable gland, see chapter Cable diameter of the AC cable on page (→).
    6
    Select the cable cross-section in accordance with chapter Permitted cables for the electrical connection on page (→).
    Strip 12 mm of insulation from the single conductors.
    7
    Lift the operating lever of the terminal to open. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then close the operating lever until it engages.
    IMPORTANT!
    Only one conductor may be connected to each pin. The AC cables can be connected to the AC terminal without ferrules.
    L1
    Phase conductor
    L2
    Phase conductor
    L3
    Phase conductor
    N
    Neutral conductor
    PE
    Ground conductor
    8
    Insert the AC terminal into the AC slot until it engages. Fasten the union nut of the cable gland with a torque of 6 ‑ 7 Nm.
    1. Installation
    Connecting solar module strings to the inverter
    General information about PV modules
    To enable suitable PV modules to be chosen and to use the inverter as efficiently as possible, it is important to bear the following points in mind:
    • If insolation is constant and the temperature is falling, the open circuit voltage of the PV modules will increase. The open circuit voltage must not exceed the max. permissible system voltage. An open circuit voltage above the indicated values will damage the inverter, and all warranty rights will become null and void.
    • The temperature coefficients on the data sheet of the PV modules must be observed.
    • Exact values for sizing the PV modules can be obtained using suitable calculation tools, such as the Fronius Solar.creator.
    IMPORTANT!
    Before connecting up the PV modules, check that the voltage for the PV modules specified by the manufacturer corresponds to the actual measured voltage.
    IMPORTANT!
    The PV modules connected to the inverter must comply with the IEC 61730 Class A standard.
    IMPORTANT!
    Solar module strings must not be grounded.
    1. Installation
    2. Connecting solar module strings to the inverter
    IMPORTANT!
    IMPORTANT!
    IMPORTANT!
    1. Installation
    Safety
    WARNING
    The commissioning, maintenance, and service work in the inverter's power stage set may only be carried out by Fronius-trained service personnel in accordance with the technical specifications.
    Read the installation instructions and operating instructions before installing and commissioning the equipment.
    WARNING
    Danger from mains voltage and DC voltage from PV modules that are exposed to light.
    All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and are de-energized.
    WARNING
    Danger of an electric shock due to improperly connected terminals/PV plug connectors.
    When connecting, ensure that each pole of a string is routed via the same PV input, e.g.:
    + pole string 1 to the input PV 1.1+ and - pole string 1 to the input PV 1.1-
    WARNING
    Have defective terminals replaced by an authorized specialist company.
    1. Installation
    PV Generator, general
    Two independent PV inputs (PV 1 and PV 2) are available. These inputs can be connected to a different number of modules.
    When starting for the first time, set up the PV Generator in accordance with the respective configuration (can also be carried out at a later date in the Device Configuration > Components menu area).
    1. Installation
    Module array configuration
    Symo GEN24 6 - 10 kW
    IMPORTANT!
    Carry out the installation in accordance with the nationally applicable standards and guidelines.
    Current less than or equal to 25 A (Idcmax).
    Module array settings:
    PV 1: ON
    PV 2: OFF
    Combined solar module strings with total current less than or equal to 25 A (dcmax).
    PV 1: ON
    PV 2: OFF
    Combined solar module strings with total current greater than 25 A (Idcmax).
    PV 1: ON
    PV 2: OFF
    PV 1 + PV 2 (connected in parallel): ON
    IMPORTANT!
    The maximum current load of a single terminal is 25 A. PV‑connection strings with a total current of more than 25 A must be split between both PV inputs upstream of the terminals (ISC max ≤ 60 A). The plug connection for splitting the total current must be sufficiently dimensioned, suitable, and installed by a professional. It is not permitted to split the current by bridging from PV 1 to PV 2 at the terminal.
    PV 1 less than or equal to 40 A (ISC PV1)
    PV 2 less than or equal to 20 A (ISC PV2)
    PV 1: ON
    PV 2: ON
    1. Installation
    Module array configuration Symo GEN24 6-12 kW SC
    IMPORTANT!
    Carry out the installation in accordance with the nationally applicable standards and guidelines. If the Arc Fault Circuit Interrupter integrated in the inverter is being used for arc detection according to IEC 63027, the solar module strings must not be combined upstream of the inverter.
    Current less than or equal to 28 A (Idcmax).
    PV 1: ON
    PV 2: OFF
    Combined solar module strings with total current less than or equal to 28 A (dcmax).
    PV 1: ON
    PV 2: OFF
    Combined solar module strings with total current greater than 28 A (Idcmax).
    PV 1: ON
    PV 2: OFF
    IMPORTANT!
    The maximum current load of a single terminal is 28 A. PV‑connection strings with a total current of more than 28 A must be split between both PV inputs upstream of the terminals (ISC max ≤ 60 A). The plug connection for splitting the total current must be sufficiently dimensioned, suitable, and installed by a professional. It is not permitted to split the current by bridging from PV 1 to PV 2 at the terminal.
    PV 1: ON
    PV 2: ON
    1. Installation
    1.
    WARNING! An electric shock can be fatal.
    2.
    Push the cables through the DC bushing before stripping the insulation.
    3.
    4.
    Disconnect connections from the solar module strings (+/-).
    Push the DC cables through the DC bushings by hand.
    IMPORTANT!
    Push the cables through the DC bushings before stripping them. This avoids twisting/bending single wires.
    Remove the DC push-in terminals from the slots.
    For measurements on the DC cables, use the Fronius Inspection Kit (44,0240,0004) or an adapter cable with a suitable DC plug (e.g., MC4). Connect the adapter cable to the DC push-in terminals and place the DC plug outside the inverter.
    WARNING
    Danger from loose and/or incorrectly clamped single conductors in the terminal.
    Only connect one single conductor in the slot provided for each terminal.
    Check that the single conductors are secure in the terminal.
    Make sure that the single conductor has been fully inserted into the terminal and that no single wires are protruding out of the terminal.
    Select the cable cross-section in accordance with the instructions in Permitted cables for the electrical connection from page (→).
    Strip the insulation of the single conductors by 12 mm.
    5
    6
    Connect the solar module strings (+/-).
    NOTE
    Danger due to polarity reversal at the terminals.
    Use a suitable measuring instrument to check the polarity of the DC cabling.
    Use a suitable measuring instrument to check the voltage (max. 1000 VDC)
    7
    Use a suitable measuring instrument to check the voltage and polarity of the DC cabling. Remove both DC terminals from the slots.
    NOTE
    Risk due to overtorque at the strain-relief device.
    Damage to the strain-relief device may result.
    Do not use a drill driver.
    8
    Insert the DC terminals into the respective slot until they engage. Fasten the screws of the strain-relief device to the housing using a screwdriver (TX20) and a torque of 1.3 - 1.5 Nm.
    1. Installation
    Connecting the battery to the inverter
    Safety
    WARNING
    Only a technical specialist is permitted to perform commissioning, maintenance, and service activities for inverters and batteries, and only within the scope of the technical regulations.
    Read the installation instructions and operating instructions from the respective manufacturer before installing and commissioning the equipment.
    WARNING
    Danger from mains voltage and DC voltage from the PV module that are exposed to light, as well as batteries.
    All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and battery, and are de-energized.
    Only a technical specialist is permitted to connect this equipment to the public grid.
    WARNING
    Have defective terminals repaired by a technical specialist.
    1. Installation
    2. Connecting the battery to the inverter
    Safety
    WARNING
    WARNING
    WARNING
    1. Installation
    Connecting the battery on the DC side
    NOTE
    Danger due to operation of the battery above the permissible altitude specified by the manufacturer.
    Operating the battery above the permissible altitude can result in restricted operation, loss of operation, and unsafe states of the battery.
    Adhere to the manufacturer's instructions regarding the permissible altitude.
    Operate the battery only at the altitude specified by the manufacturer.
    IMPORTANT!
    Prior to installing a battery, ensure that the battery is switched off. Observe the max. DC cable length for the installation of third-party batteries according to the specifications of the manufacturer, see chapter Suitable batteries on page (→).
    1.
    2.
    Connect the ground conductor of the battery at an external point.
    3.
    4.
    Use a suitable measuring instrument to check the polarity of the DC cabling when the battery is switched on.
    5.
    IMPORTANT!
    Push the cables through the DC bushings by hand before stripping the insulation. This avoids twisting/bending single wires.
    * The battery ground conductor must be connected externally (e.g., switch cabinet). When connecting an LG FLEX battery, the battery ground conductor can be connected in the inverter see chapter Connecting the LG FLEX ground conductor on page (→). Observe the minimum cross-section of the battery ground conductor.
    WARNING
    Make sure that the single conductor has been fully inserted into the terminal and that no single strands are protruding out of the terminal.
    NOTE
    Danger due to overvoltage when using other slots on the terminal.
    This may result in damage to the battery and/or the PV modules due to discharge.
    Only use the slots labeled "BAT" for connecting the battery.
    Strip the insulation of the single conductors by 12 mm. Lift the operating lever of the terminal to open. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then close the operating lever until it engages.
    NOTE
    Serious damage to the PV system may result.
    The maximum voltage for the battery input must not be exceeded (see Technical data on page (→)).
    5
    Insert the DC terminals into the respective slot until they engage. Fasten the screws of the cable guide to the housing using a screwdriver (TX20) and a torque of 1.3-1.5 Nm.
    NOTE
    IMPORTANT!
    Information for connection to the battery's DC connections can be found in the installation instructions from the relevant manufacturer.
    1. Installation
    Push the ground conductor through the DC bushing by hand before stripping the insulation.
    Place the battery ground conductor in the integrated cable duct of the connection area divider in the AC connection area. Fasten the battery ground conductor to the ground electrode terminal at the second input from above using a screwdriver (TX20) and a torque of 1.8-2 Nm.
    IMPORTANT!
    1. Installation
    Safety
    WARNING
    Installing and connecting an option must only be carried out by service personnel trained by Fronius and only within the scope of the respective technical regulations.
    Follow the safety rules.
    WARNING
    Danger due to damaged and/or contaminated terminals.
    Before making any connections, check the terminals for damage and contamination.
    Remove contamination in the de-energized state.
    Have defective terminals repaired by an authorized specialist.
    NOTE
    During the switch from grid-connected operation to backup power mode, momentary interruptions will occur. The PV Point output requires PV power from the solar modules or a battery to power the connected loads.
    Connected loads will not be supplied with power during the switchover.
    Do not connect any loads that require an uninterruptible supply ( e.g., IT networks, life-sustaining medical devices).
    IMPORTANT!
    The valid national laws, standards, and provisions, as well as the specifications of the relevant grid operator are to be taken into account and applied.
    It is highly recommended that the specific installation be agreed with the grid operator and explicitly approved by this operator. This obligation applies to system constructors in particular (e.g., installers).
    1. Installation
    2. Connecting backup power - PV Point (OP)
    Safety
    WARNING
    WARNING
    NOTE
    IMPORTANT!
    1. Installation
    Installation
    NOTE
    All loads that have to be supplied via the OP terminal must be protected by means of a residual current circuit breaker.
    In order to ensure the residual current circuit breaker operates properly, a connection must be established between the neutral conductor N´ (OP) and ground.
    For the circuit diagram recommended by Fronius, see Circuit diagrams—PV Point on page (→).
    Switch off the automatic circuit breaker and DC disconnector. Turn the DC disconnector to the "off" switch setting.
    CAUTION
    Danger from faulty or incorrect bores.
    This may lead to injuries to the eyes and hands as a result of flying debris and sharp edges, as well as damage to the inverter.
    When drilling, wear suitable protective goggles.
    Only use a step drill when drilling.
    Ensure that nothing on the inside of the device is damaged (e.g., the connection block).
    Adapt the diameter of the bore to match the corresponding connection.
    Deburr the bores using a suitable tool.
    Remove the drilling residues from the inverter.
    Drill out the optional cable guide with a step drill.
    Insert the cable gland into the bore and fasten it using the torque specified by the manufacturer.
    5
    Guide the mains cable through the cable gland from below.
    Remove the OP terminal.
    6
    Strip 12 mm of insulation from the single conductors. The cable cross-section must be between 1.5  mm2 and 10 mm 2.
    WARNING
    7
    Lift to open the terminal's operating lever and insert the stripped single conductor into the slot provided, all the way up to the stop. Then close the operating lever until it engages.
    L1´
    Phase conductor
    N´
    Neutral conductor
    N´
    PEN conductor
    8
    IMPORTANT!
    The PEN conductor must be produced with ends that are permanently marked blue, according to the national provisions, and have a cross-section of 10 mm².
    9
    Fasten the ground conductor and PEN conductor to the ground electrode terminal using a screwdriver (TX20) and a torque of 2 Nm.
    10
    Insert the OP terminal into the OP slot until it engages. Tighten the union nut of the cable gland.
    1. Installation
    Testing backup power mode
    Testing backup power mode:
    • during first-time installation and configuration
    • after working on the switch cabinet
    • during ongoing operation (recommendation: at least every 6 months)
    A battery charge of min. 30% is recommended for test mode.
    A description of how to run the test mode can be found in the checklist – Backup power (https://www.fronius.com/de/download-center?searchword=42,0426,0365).
    1. Installation
    Connecting backup power - Full Backup
    Safety
    WARNING
    Danger from incorrect installation, commissioning, operation, or incorrect use.
    This can result in severe personal injury/damage to property.
    Only trained and qualified personnel are authorized to install and commission the system, and only within the scope of the technical regulations.
    The Installation and Operating Instructions must be read carefully prior to use.
    If anything is unclear, contact your vendor immediately.
    IMPORTANT!
    It is highly recommended to coordinate the concrete examples implemented and in particular the specific installation with the grid operator to obtain their explicit approval. This obligation applies to system constructors in particular (e.g., installers).
    The examples suggested here show a backup power supply with or without an external protection relay (external grid and system protection unit). The respective grid operator decides whether an external protection relay must be used or not.
    IMPORTANT!
    An uninterruptible power supply (UPS) may only be used to supply individual loads (e.g., computers). Feeding into the power supply of the house network is not permitted. The Installation and Operating Instructions must be read carefully prior to use. If anything is unclear, contact your vendor immediately.
    The examples given in this document (in particular cabling variants and circuit diagrams) are suggestions only. These examples have been carefully developed and tested. They can therefore be used as a basis for real-life installation. Anyone following or using these examples does so at their own risk.
    1. Installation
    2. Connecting backup power - Full Backup
    Safety
    WARNING
    IMPORTANT!
    IMPORTANT!
    1. Installation
    Automatic switch to backup power 3-pole disconnection e.g., Austria or Australia
    IMPORTANT!
    The cabling variant required by the utility must be clarified with the utility.
    Circuit diagrams
    • Fronius Backup Controller 3-pin separation, e.g., Austria on page (→).
    • Automatic switch to backup power 3-pin single FRT-capable separation - e.g., Austria on page (→).
    • Automatic switch to backup power 3-pin single separation - e.g., Australia on page (→).
    Cabling of the backup power circuits and non-backup power circuits:
    If not all the loads in the home need to be supplied in a backup power situation, the circuits need to be divided into backup power circuits and non-backup power circuits. The total load of the backup power circuits must not exceed the rated power of the inverter.
    Cabling with third-party components
    The backup power circuits and non-backup power circuits must be fused separately according to the required safety measures (e.g., residual current circuit breaker, automatic circuit breaker).
    In backup power mode, only the backup power circuits are disconnected from the grid at 3 pins by contactor K1. In this case the rest of the home network is not supplied.
    Observe the following points
    • The main contacts of contactor K1 must be installed between the Fronius Smart Meter and the inverter or the residual current circuit breakers of the backup power circuits.
    • The supply voltage for contactor K1 is provided by the public grid and must be connected to phase 1 (L1) downstream of the Fronius Smart Meter and fused accordingly.
    • An NC contact for relay K3 interrupts the supply voltage to contactor K1. This prevents the backup power network of the inverter from being switched to the public grid.
    • The NO contact of relay K3 gives feedback to the inverter that relay K3 has blocked the power.
    • Additional inverters or other AC sources can be installed in the backup power circuit downstream of the main contacts of K1. The sources will not synchronize with the network of the inverter because this backup power network has a frequency of 53 Hz.
    1. Installation
    Automatic switch to backup power 4-pole disconnection e.g., Germany, France, Spain
    Circuit diagrams
    • Fronius Backup Controller 4-pin separation, e.g., Germany on page (→).
    • Automatic switch to backup power 4-pin single separation - e.g., Germany on page (→).
    • Automatic switch to backup power 4-pin single FRT-capable separation on page (→).
    • Automatic switch to backup power 4-pin single separation - e.g., France on page (→).
    • Automatic switch to backup power 4-pin single separation - e.g., Spain on page (→).
    In backup power mode, only the backup power circuits are disconnected from the grid at all pins by contactor K1, and a ground connection is established for them. In this case the rest of the home network is not supplied.
    • To ensure residual current circuit breakers function in backup power mode, the connection between the neutral conductor and the ground conductor must be implemented in accordance with the respective circuit diagram. An NC contact is used for this purpose for each of the main contacts of contactors K4 and K5. This ensures that the ground connection is established as soon as the public grid connection is no longer available.
    • As with contactor K1, the supply voltage for contactors K4 and K5 is supplied via phase 1 (L1) of the public grid.
    • An NC contact for relay K3 interrupts the supply voltage to contactors K1, K4, and K5. This prevents the ground connection from being immediately disconnected again when power returns to the public grid and the backup power network of the inverter from being switched to the public grid.
    • The NO contact of relay K3 gives feedback to the inverter on whether relay K3 has blocked the power.
    1. Installation
    Automatic switch to backup power 4-pole disconnection e.g., Italy
    Circuit diagram
    • Automatic switch to backup power 4-pin double separation with ext. grid and system protection - e.g., Italy on page (→).
    IMPORTANT!
    For this circuit variant, the Fronius Smart Meter WR must be used.
    In backup power mode, only the backup power circuits are disconnected from the grid by contactors K1 and K2, and a ground connection is established for them. In this case the rest of the home network is not supplied.
    The following points regarding cabling must be considered:
    • The main contacts of contactors K1 and K2 must be installed between the Fronius Smart Meter and the residual current circuit breaker of the inverter or the residual current circuit breakers of the backup power circuits.
    • The supply voltage for contactors K1 and K2 is provided by the public grid and must be connected to phase 1 (L1) downstream of the Fronius Smart Meter and fused accordingly.
    • Actuation of contactors K1 and K2 is carried out by the external grid and system protection.
    • The external grid and system protection unit must be installed downstream of the Fronius Smart Meter. Detailed installation and wiring instructions for external grid and system protection units can be found in the unit's operating instructions.
    • The remote trip input of the external grid and system protection unit must be set to NC according to the manufacturer's operating instructions.
    • To ensure residual current circuit breakers function in backup power mode, the connection between the neutral conductor and the ground conductor must be established as close as possible to the inverter, but in any case upstream of the first residual current circuit breaker. An NC contact is used for this purpose for the main contacts of contactors K4 and K5. This ensures that the ground connection is established as soon as the public grid connection is no longer available.
    • The supply voltage for the contactors K1, K2, K4, and K5 is supplied via phase 1 (L1) of the public grid and is switched via the external grid and system protection unit.
    • An NC contact for relay K3, which activates the remote input of the external grid and system protection unit, interrupts the supply voltage to contactors K1, K2, K4, and K5. This prevents the ground connection from being immediately disconnected again when power returns to the public grid and the backup power network of the inverter from being switched to the public grid.
    • The NO contact of relay K3 gives additional feedback to the inverter on whether relay K3 has blocked the power.
    • Additional inverters or other AC sources can be installed in the backup power circuit downstream of the main contacts of K1 and K2. The sources will not synchronize with the network of the inverter because this backup power network has a frequency of 53 Hz.
    1. Installation
    Manual switch to backup power 3-pole disconnection e.g., Austria / 4-pole disconnection e.g., Germany
    Circuit diagrams
    • Manual switch to backup power 3-pin separation, e.g., Austria on page (→).
    • Manual switch to backup power 4-pin separation, e.g., Germany on page (→).
    IMPORTANT!
    The circuit diagrams to be used must be applied in line with the country standard and the implementing regulations of the utility.
    In backup power mode, only the backup power circuits and the inverter are disconnected from the grid by changeover switch Q1. In the case of all-pole disconnection, a ground connection is also established. In this case, the loads in the non-backup power circuits are not supplied by the inverter.
    The following points regarding installation must be considered:
    • The changeover switch Q1 must be dimensioned for the fuses installed upstream, the max. occurring amperage, and the max. occurring short circuit current. An auxiliary switching element with 2 NO contacts is required for switch position 1 (grid operation) to match the installed changeover switch Q1.
      The changeover switch Q1 used must fulfil a short-circuit breaking capacity of at least 10 kA according to standard IEC 60947-1. If the short circuit current at the installation point reaches a value above 10 kA, a switch with a corresponding short-circuit breaking capacity must be used.
    • The circuitry is only to be used in household-like applications and systems (small businesses and agriculture) or up to upstream fuses with a nominal current of 63 A.
    • Min. impulse withstand voltage of the changeover switch of 4 kV according to IEC 60947-1.
    • It must be clarified with the utility whether the 3-pole or all-pole disconnection must be used.
    • The protective measure must be tested regularly; if this is not regulated by law, it must be performed annually.
    • Data transfer between the Fronius Smart Meter and the inverter may be interrupted in backup power mode (switch position 2). This is optionally ensured via a NO contact of the auxiliary contact. Interrupting the Smart Meter connection via auxiliary contact Q1.1 is optional and prevents the backup power function from ending when power returns to the public grid. If this does not take place, the inverter interrupts the backup power supply when power returns to the public grid. Failure to manually switch to parallel grid mode within the first 10 minutes of the power returning to the public grid may cause the inverter and battery to shut down. In this case, a manual system start must be carried out (see chapter Manual system start on page (→)). This behavior must be taken into account especially during a test of manual switching, because the inverter does not start backup power mode when there is a grid connection due to Smart Meter data being available.
    • The data communication connection with the Fronius Smart Meter must be established separately from the battery to its dedicated Modbus input so that battery data communication is maintained (see chapter Modbus participants on page (→)).
    • Feedback to the digital inputs (IOs) of the inverter via the changeover switch Q1 (switch position 2) is a starting condition for the inverter's backup power mode.
    • The AC output of the inverter is de-energized when switching via switch position 0. This is ensured by interrupting the WSD line with the 2nd NO contact of the auxiliary contact and the changeover switch Q1 in position 0.
    • The continuous connection between the equipotential bonding rail and the neutral conductor from the inverter must not be interrupted in the case of 3-pole disconnection.
    • In the case of all-pole disconnection, the PE-N conductor connection is made via the main contacts of changeover switch Q1 in duplicate.
    • Additional inverters or other AC sources can be installed in the backup power circuit downstream of the changeover switch Q1. The sources will not synchronize with the backup power network of the inverter in a backup power situation because this is operated at 53 Hz.
    1. Installation
    1. Installation
    Connecting the data communication cables
    Modbus participants
    The inputs M0 and M1 can be freely selected. A maximum of four Modbus participants can be connected to the Modbus terminal at inputs M0 and M1.
    IMPORTANT!
    Only one primary meter, one battery, and one Ohmpilot can be connected per inverter. Due to the high data transfer of the battery, the battery occupies two subscribers. If the Inverter Control via Modbus function is activated in the Communication > Modbus menu area, no Modbus participants are possible. It is not possible to send and receive data at the same time.
    Example 1:
    Input
    Battery
    Fronius
    Ohmpilot
    Number of primary meters
    Number of secondary meters
    Modbus 0
    (M0)
    0
    0
    0
    Modbus 1
    (M1)
    Example 2:
    Input
    Battery
    Fronius
    Ohmpilot
    Modbus 0
    (M0)
    Modbus 1
    (M1)
    0
    0
    0
    1. Installation
    2. Connecting the data communication cables
    Modbus participants
    IMPORTANT!
    Example 1:
    Input
    Battery
    Fronius
    Ohmpilot
    Modbus 0
    (M0)
    0
    0
    0
    Modbus 1
    (M1)
    Example 2:
    Input
    Battery
    Fronius
    Ohmpilot
    Modbus 0
    (M0)
    Modbus 1
    (M1)
    0
    0
    0
    1. Installation
    Routing data communication cables
    IMPORTANT!
    If data communication cables are wired into the inverter, observe the following points:
    • Depending on the number and cross-section of the wired data communication cables, remove the corresponding blanking plugs from the sealing insert and insert the data communication cables.
    • Make sure that you insert the corresponding blanking plugs into any free openings on the sealing insert.
    IMPORTANT!
    Ingress protection rating IP 66 cannot be ensured if blanking plugs are missing or incorrectly inserted.
    1.
    Loosen the union nut, push out the sealing ring, and remove the corresponding blanking plug.
    Remove the union nut on the cable gland and press the sealing ring with the blanking plugs out from the inside of the device.
    Open up the sealing ring at the location where the blanking plugs are to be removed.
    * Remove the blanking plugs with a sideways motion.
    First, guide the data cables through the union nut of the cable gland and then through the housing opening.
    Insert the sealing ring between the union nut and the housing opening. Press the data cables into the seal's cable guide. Then press in the seal until it reaches the underside of the cable gland.
    1. Installation
    Connecting the battery communication cable
    Modbus RJ45
    IMPORTANT!
    For this connection version, the BAT switch on the data communication area must be in position 1.
    NOTE
    Power supply
    Voltage is present at the connection. If network devices (e.g., WiFi routers) are connected, the device may be damaged.
    Only connect batteries to the battery connection
    1Knock out the protective cover
    2Connect the cable to the RJ45 socket
    ✓The LEDs on the RJ45 socket light up red when the battery connection is active.
    Modbus terminal
    Strip 10 mm of insulation from the single conductors and fit the ferrules if necessary.
    IMPORTANT!
    If several single conductors are connected to an input of the push-in terminals, connect the single conductors with a corresponding ferrule.
    Insert the cables into the respective slot and check the cables are securely retained.
    IMPORTANT!
    Use a twisted cable pair for data cables that belong together.
    Twist the cable shield and insert into the "SHIELD" slot.
    IMPORTANT!
    Improperly fitted shielding can cause data communication problems.
    Fasten the union nut of the cable gland with a torque of min. 2.5 - max. 4 Nm.
    1.
    Disconnect the terminal.
    2.
    Route the data communication cable. Press in the seal until it reaches the bottom edge of the strain-relief device.
    For the circuit diagram recommended by Fronius, see System circuit diagrams on page (→).
    1. Installation
    Terminating resistors
    It may be possible for the system to function without terminating resistors. However, owing to interference, the use of terminating resistors according to the following overview is recommended for trouble-free operation.
    For permissible cables and max. distances for the data communication area, refer to the chapter headed Permitted cables for the data communication connection on page (→).
    IMPORTANT!
    Terminating resistors that are not positioned as illustrated can result in interference in the data communication.
    1. Installation
    Installing the WSD (wired shutdown)
    IMPORTANT!
    The push-in WSD terminal in the inverter's connection area is delivered with a bypass ex works as standard. The bypass must be removed when installing a trigger device or a WSD chain.
    The WSD switch of the first inverter with connected trigger device in the WSD chain must be in position 1 (master). The WSD switch of all other inverters should be in position 0 (secondary device).
    Max. distance between 2 devices: 100 m
    Max. Number of devices: 28
    * Floating contact of the trigger device (e.g., central grid and system protection). If several floating contacts are used in a WSD chain, these must be connected in series.
    1. Installation
    Closing and commissioning the inverter
    Closing the inverter's connection area/housing cover, and commissioning
    NOTE
    The housing cover is fitted with a lock for safety reasons, which allows the housing cover on the inverter to be pivoted only when the DC disconnector is off.
    Only clip and pivot the housing cover into the inverter when the DC disconnector is switched off.
    Do not use excessive force to clip in and pivot the housing cover.
    Place the cover on the connection area. Tighten the 5 screws by rotating them 180° to the right in the indicated order using a screwdriver (TX20).
    Clip the housing cover into the inverter from above.
    Press on the lower part of the housing cover and tighten the 2 screws by rotating them 180° to the right using a screwdriver (TX20).
    Turn the DC disconnector to the "on" switch setting. Turn on the automatic circuit breaker. For systems with a battery, observe the switch-on sequence according to the chapter Button functions and LED status indicator on page (→).
    IMPORTANT! Open the WiFi access point with the optical sensor, see chapter Suitable batteries on page (→)
    1. Installation
    2. Closing and commissioning the inverter
    NOTE
    1. Installation
    Starting the inverter for the first time
    When starting the inverter for the first time, various setup settings must be configured.
    If the setup is canceled before completion, the input data is not saved and the start screen with the installation wizard is shown once again. The data is saved in the event of an interruption, e.g., a power failure. Commissioning is continued at the point at which the interruption occurred after the power supply is restored. If the setup was interrupted, the inverter feeds energy into the grid at maximum 500 W and the operating status LED flashes yellow.
    The country setup can only be set when starting the inverter for the first time. If the country setup needs to be changed at a later date, contact your installer/technical support.
    1. Installation
    Installation with the app
    The Fronius Solar.start app is required for installation. Depending on the mobile device used to perform the installation, the app is available on the relevant platform.
    1Download and install the Fronius Solar.start app.
    2Open the access point by touching the sensor    .
    ✓Communication LED flashes blue.
    3Open the Fronius Solar.start app and follow the installation wizard. Scan the QR code on the rating plate with a smartphone or tablet to connect to the inverter.
    4Add system components in Fronius Solar.web and commission the PV system.
    1. Installation
    Installation with the browser
    WiFi:
    1Open the access point by touching the sensor    .
    2Establish the connection to the inverter in the network settings (the inverter is displayed with the name "FRONIUS_" and the serial number of the device).
    3Enter the password from the rating plate and confirm.
    IMPORTANT!
    To enter the password, first select the Connect using a security key instead link in order to establish the connection with the password.
    4Enter the IP address 192.168.250.181 in the address bar of the browser and confirm. The installation wizard opens.
    5Follow the installation wizard and complete the installation in the individual areas.
    6Add the system components in Fronius Solar.web and commission the PV system.
    Ethernet:
    1Establish a connection to the inverter (LAN1) using a network cable (min. CAT5 STP).
    2Open the access point by touching the sensor once    .
    3Enter the IP address 169.254.0.180 in the address bar of the browser and confirm. The installation wizard opens.
    4Follow the installation wizard and complete the installation in the individual areas.
    5Add the system components in Fronius Solar.web and commission the PV system.
    1. Installation
    De-energizing the inverter and switching it back on
    Disconnecting the inverter from the power supply:
    1Turn off the automatic circuit breaker.
    2Turn the DC disconnector to the "off" switch setting.
    IMPORTANT!
    Wait for the capacitors of the inverter to discharge!
    Switching on the inverter:
    If the inverter has not been in operation for six months or more after installation, it must be tested before commissioning.
    1Turn the DC disconnector to the "on" switch setting.
    2Turn on the automatic circuit breaker.
    1. Installation
    2. De-energizing the inverter and switching it back on
    IMPORTANT!
    Settings – User interface of the inverter
    User settings
    User login
    1Open the user interface of the inverter in the browser.
    2In the Login menu area, log in with username and password, or, in the User > User Login menu area, log in with username and password.
    IMPORTANT!
    Depending on the authorization of the user, settings can be made in the individual menu areas.
    1. Settings – User interface of the inverter
    User settings
    User login
    IMPORTANT!
    2. User settings
    User login
    IMPORTANT!
    2. User settings
    Selecting languages
    1In the User > Language menu area, select the desired language.
    Device configuration
    Components
    All available components of the system can be added via Add component+.
    PV Generator
    Activate the MPP tracker and enter the connected PV output in the relevant field. In the case of combined solar module strings, PV 1 + PV 2 connected in parallel must be activated.
    Meter
    Primary meter
    IMPORTANT!
    For problem-free operation with further energy generators and in Full Backup power mode, it is important to install and configure a Fronius Smart Meter as the primary meter at the feed-in point. The inverter and further generators must be connected to the public grid via the Fronius Smart Meter. Only one primary meter can be configured in the system.
    This setting has an effect on the behavior of the inverter during the night. If the primary meter has been configured, the inverter remains permanently connected to the grid in order to enable it to draw energy from other generators at any time.
    If the primary meter has not been configured, the inverter switches to standby mode as soon as there is no more PV power available. No energy management specification is sent to the battery (e.g., minimum state of charge reached). The message "Power low" is displayed. The inverter starts again as soon as an energy management specification is sent or sufficient PV power is available.
    Secondary meter
    In addition to the primary meter, further secondary meters can be added to the system to record the load curves of individual loads and generators (e.g., heat pump, wind power plant, etc.) and provide the measured data for energy profiling in Fronius Solar.web.
    1. After connecting the meter, select a category:
      • Primary meter
      • Secondary meter
    2. Select one of the following device types:
      • Modbus RTU
      • Modbus TCP
      • MQTT (available MQTT device is displayed automatically)
    NOTE
    For communication via MQTT and Modbus TCP, install the inverter and Smart Meter in the same sub-network.
    1. Additionally define the following parameters for the Smart Meter:
      • Application of primary meter (Feed-in point or Load branch)
      • Application of secondary meter (Production meter or Secondary meter)
      • Name
      • Category (e.g., inverter, heat pump)
      • IP Address (for Modbus TCP)
      • Port (for Modbus TCP)
      • Modbus Address (for Modbus RTU and TCP)
    The Watt value for the production meter is the sum of all production meters. The Watt value for the secondary meter is the sum of all secondary meters.
    Battery
    If the SoC Limit Mode is set to Auto, the values SoC Minimum and SoC Maximum are preset according to the technical specifications of the battery manufacturer.
    If the SoC Limit Mode is set to Manual, the values SoC Minimum and SoC Maximum can be changed after consultation with the battery manufacturer within the framework of their technical specifications. In a backup power situation, the set values are not taken into account.
    The setting Allow battery charging from other generators in the home network activates/deactivates charging of the battery from other generators.
    The power consumption of the Fronius inverter can be restricted by specifying a value in the Max. Charging Power from AC field. As a maximum, a power consumption equal to the AC rated power of the Fronius inverter is possible.
    The setting Allow battery charging from public grid + Allow battery charging from other generators in the home network activates/deactivates the charging of the battery from the public grid and, if present, from other generators in the home network.
    The normative or compensatory specifications must be taken into account for this setting. Irrespective of this setting, necessary service-related charging from the public grid is performed (e.g., forced re-charging to protect against deep discharge).
    IMPORTANT!
    Fronius accepts no liability for damage to third-party batteries.
    Ohmpilot
    All the Ohmpilots available in the system are displayed. Select the desired Ohmpilot and add to the system via Add.
    2. Device configuration
    Components
    PV Generator
    Meter
    Primary meter
    IMPORTANT!
    Secondary meter
      • Primary meter
      • Secondary meter
      • Modbus RTU
      • Modbus TCP
    NOTE
      • Name
    Battery
    IMPORTANT!
    Ohmpilot
    Functions and I/Os
    Backup power
    In backup power mode, select one of the following settings:
    • Parallel backup supporters
    • Full Backup
    • Off
    • PV Point
    The Full Backup power mode is available under the following conditions:
    • The required I/O assignments for backup power are configured.
    • A Fronius Smart Meter is installed and configured at the feed-in point.
    • A suitable battery is connected to the inverter.
    IMPORTANT! For configuration of the PV Point backup power mode, observe the instructions in chapter Safety.
    For configuration of the Full Backup backup power mode, observe the instructions in chapter Safety.
    Parallel Backup
    Parallel Backup enables the additional use of PV power in backup power mode, which secondary inverters make available in the system.
    Configuration for all inverters in Parallel Backup operation:
    1Under Device Configuration > Inverter in the Backup power menu, set the same Backup power frequency offset.
    Configuration on the primary inverter:
    1In the Backup power mode drop-down menu, select the Full Backup option.
    2Select the parallel backup coordinator slider.
    Configuration on the secondary inverter:
    1In the Backup power mode drop-down menu, select the Parallel backup supporter option.
    ✓Parallel Backup has been configured.
    Backup Nominal Voltage
    Select the voltage for backup power mode.
    SoC warning level
    In backup power mode, a warning is emitted when this residual battery capacity is reached.
    Reserve Capacity
    The set value results in a residual capacity (depending on the battery capacity) that is reserved for backup power situations. The battery does not discharge below the reserve capacity in grid connected mode. In backup power mode, the manually set value of SoC Minimum is not taken into account. The battery discharges up to the automatically preset, minimum state of charge. This value is specified by the battery manufacturer.
    System preservation during night
    To ensure continuous backup power operation even during the night, the inverter calculates a residual capacity for system preservation depending on the battery capacity. When the calculated limit value is reached, the inverter and the battery switch to standby mode. This is maintained for a period of 16 hours. Connected loads are no longer supplied. The battery discharges up to the preset minimum state of charge.
    Rapid switch mode
    Disconnection from the grid and synchronized reconnection each take place within 20 ms.
    NOTE
    Material damage due to misconfiguration
    This can result in damage to system components.
    Only activate the Rapid switch mode function on the primary inverter in conjunction with a Fronius Backup Controller 63A.
    Only activate the Rapid switch mode function for secondary inverters if the function is also activated for the primary inverter.
    Configuration on the inverter:
    1Enable the Rapid switch mode slider.
    Load Management
    Select up to four pins for the load management. Further settings for the load management are available in the Load Management menu item.
    Default: Pin 1
    Australia - Demand Response Modes (DRM)
    Activate the slider if DRM is required. Configure the pins for control via DRM as follows:
    Mode
    Description
    Information
    DRM Pin
    I/O pin
    DRM0
    Inverter disconnects from the grid
    DRM0 occurs in the event of an interruption or short circuit on the REF GEN or COM LOAD lines, or in the event of invalid combinations of DRM1 - DRM8.
    The grid relays open.
    REF GEN
    COM LOAD
    IO4
    IO5
    DRM1
    Import Pnom ≤ 0% without disconnection from grid
    currently not supported
    DRM 1/5
    IN6
    DRM2
    Import Pnom ≤ 50%
    DRM 2/6
    IN7
    DRM3
    Import Pnom ≤ 75% &
    +Qrel* ≥ 0%
    DRM 3/7
    IN8
    DRM4
    Import Pnom ≤ 100%
    DRM 4/8
    IN9
    DRM5
    Export Pnom ≤ 0% without disconnection from grid
    DRM 1/5
    IN6
    DRM6
    Export Pnom ≤ 50%
    DRM 2/6
    IN7
    DRM7
    Export Pnom ≤ 75% & -Qrel* ≥ 0%
    DRM 3/7
    IN8
    DRM8
    Export Pnom ≤ 100%
    DRM 4/8
    IN9
    The percentage specifications always relate to the rated device power.
    IMPORTANT! If the Australia - Demand Response Modes (DRM) function is activated and no DRM control is connected, the inverter switches to standby mode.
    Battery Grid Import Limit (§ 14a EnWG)
    Define a pin for the implementation of the regulatory requirement per § 14a EnWG.
    Inverter
    link_horizontalLink copied
    Enforce Standby
    When this function is activated, grid power feed operation of the inverter is interrupted. This makes it possible to shut down the inverter without power and protect its components. The standby function is automatically deactivated when the inverter is restarted.
    Fan test
    IMPORTANT!
    For settings in this menu item, select the Technician user, enter the password for the Technician user, and confirm. Settings may only be made by trained and qualified personnel.
    Use this function to check whether the fans of the inverter are working correctly based on acoustics, for example after replacing a fan.
    1Click Start fan test
    ✓The inverter successively activates all fans that are running at partial load during the test phase to avoid unnecessary noise. The inverter is in standby during this time.
    The test takes around 30 seconds per fan. The inverter then switches back to normal operation. Use the Stop fan test function to stop the test manually.
    PV 1 and PV 2
    Parameter
    Value range
    Description
    Mode
    Off
    The MPP tracker is deactivated.
    Auto
    The inverter uses the voltage at which the maximum possible output of the MPP tracker is possible.
    Fixed
    The MPP tracker uses the voltage defined in UDC fixed.
    UDC fixed
    80 ‑ 530 V
    The inverter uses the fixed voltage that is used on the MPP tracker.
    Dynamic Peak Manager
    Off
    Function is deactivated.
    On
    The entire solar module string is checked for optimization potential and the best possible voltage for grid power feed operation is determined.
    On (MLSD)
    The function is optimized for systems with Module Level Shutdown devices (MLSD) and is not suitable for PV optimizers.
    Rated power
    0-2,000,000
    Rated output of PV input
    Ripple Control
    Ripple control signals are signals that are sent by an energy company in order to switch controllable loads on and off. The inverter damps or amplifies the ripple control signals, depending on the installation situation. This can be counteracted if necessary by applying the following settings.
    Parameter
    Value range
    Description
    Reduction of influence
    Off
    On
    Function is activated.
    Frequency of the ripple control signal
    100 ‑ 3000 Hz
    The frequency specified by the energy company must be entered here.
    Grid inductance
    0.00001 ‑ 0.005 H
    The value measured at the feed-in point must be entered here.
    Measures to prevent FI/RCMU false alarms
    (when using a 30 mA residual current circuit breaker)
    NOTE
    A type A residual current circuit breaker is generally sufficient in this case. Nevertheless, false alarms can be triggered for the type A residual current circuit breaker in individual cases and depending on local conditions. For this reason, Fronius recommends using a residual current circuit breaker suitable for frequency inverters with a release current of least 100 mA, taking into account national provisions.
    Parameter
    Value range
    Description
    Leakage current factor to reduce RCMU/FI false tripping
    0 ‑ 0.25
    (default: 0.16)
    By reducing the setting value, the leakage current is reduced and the intermediate circuit voltage is increased, which slightly lowers the efficiency.
    • A set value of 0.16 ensures optimum efficiency.
    • A setting value of 0 enables minimum leakage currents.
    Shutdown before 30 mA RCD triggers
    Off
    The function for reducing false tripping of the residual current circuit breaker is deactivated.
    On
    The function for reducing false tripping of the residual current circuit breaker is activated.
    Rated non-tripping fault current limit value
    0.015 ‑ 0.3
    Value of the non-tripping residual current specified by the manufacturer for the residual current circuit breaker at which the residual current circuit breaker does not switch off under specified conditions.
    Insulation warning
    Parameter
    Value range
    Description
    Insulation warning
    Off
    The insulation warning is deactivated.
    On
    The insulation warning is activated.
    A warning is output in the event of an insulation fault.
    Insulation measurement mode
    Exact
    Insulation monitoring takes place with the highest degree of accuracy. The measured insulation resistance is displayed on the user interface of the inverter.
    Fast
    Insulation monitoring takes place with a lesser degree of accuracy. The duration of the insulation measurement is shortened. The insulation resistance value is not displayed on the user interface of the inverter.
    Threshold for the insulation warning
    100,000 ‑
    10,000,000
    If the value drops below the threshold, status code 1083 is displayed on the user interface of the inverter.
    Continuous residual current monitoring
    Parameter
    Value range
    Description
    Limit value
    0.03-0.3A
    Defines the limit value for shutdown in the event of residual current.
    Backup power
    Parameter
    Value range
    Description
    Backup power nominal voltage
    220 ‑ 240 V
    The nominal phase voltage that the inverter outputs in backup power mode.
    -5 to +5 Hz
    The setting value can be used to reduce or increase the backup power frequency (see Technical data) by the offset value. The default value is +3 Hz. Connected loads (e.g., Fronius Ohmpilot) detect active backup power mode based on the change in frequency and react accordingly (e.g., activation of energy-saving mode).
    IMPORTANT!
    If another AC source is available in the system, the backup power frequency must not be changed. The default value (+3 Hz) prevents the following events:
    • Feeding in further AC sources in backup power mode in parallel to the inverter.
    • Overvoltages
    • Shutting down the respective backup power circuit
    Backup power undervoltage protection limit value U< [pu]
    0 ‑ 2 %V
    This setting value represents the limit value for shutting down backup power mode
    e.g., setting value 0.9 = 90% of the nominal voltage.
    Backup power undervoltage protection time U<
    0.04 ‑ 20 s
    Trip time for falling below the backup power undervoltage protection limit value.
    Backup power surge protection limit value U> [pu]
    0 ‑ 2 %V
    e.g., setting value 1.1 = 110% of the nominal voltage.
    Backup power surge protection time U>
    0.04 ‑ 20 s
    Trip time for exceeding the backup power surge protection limit value.
    Fast undervoltage protection / ground fault protection limit value U<< [pu]
    0-100%V
    Defines the voltage limit value below which rapid undervoltage protection or protection against ground faults is triggered. Typically, a value such as 0.3 pu (30% of the nominal voltage) is set here.
    Fast undervoltage protection / ground fault protection time U<<
    0 ‑ 10 s
    Defines the maximum time (in seconds) for which the voltage may be below the set limit value, after which the inverter switches off. This value must be ≤ 0.4 s in accordance with ÖVE E 8101.
    Backup power restart delay
    0 ‑ 600 s
    Waiting time for restarting backup power mode following a shutdown.
    Backup power restart attempts
    1 ‑ 10
    The maximum number of automated restart attempts. Once the maximum number of automated restart attempts has been reached, service message 1177 must be manually acknowledged.
    External frequency monitoring in backup power mode
    (only for Italy)
    Off
    On
    For Full Backup power mode in Italy, activate external frequency monitoring. The inverter checks the mains frequency before ending backup power mode. If the mains frequency is within the permitted limits, the loads are connected to the public grid.
    Backup power short circuit switch-off time
    0.001 ‑ 60 s
    If a short circuit occurs during backup power mode, backup power mode is interrupted within the set time.
    Energy management
    Permitted maximum battery charge from the public grid
    In Germany, new rules for charging batteries came into force on January 1, 2024. When applying §14a EnWG, the charging current must be reduced to a maximum of 4.2 kW by the grid operator for dimming controllable load equipment in accordance with §14a EnWG.
    In order to document implementation of the control command, the inverter can be connected to Fronius Solar.web and ensure a permanent Internet connection. In addition, in the menu item Device configuration > Functions & I/Os, activate the Battery Grid Import Limit (§ 14a EnWG).
    2. Energy management
    Battery management
    State of charge settings
    If the SoC Limit Mode is set to Manual, the values SoC Minimum and SoC Maximum can be changed. Change the values SoC Minimum and SoC Maximum only after consultation with the battery manufacturer within the framework of their technical specifications. In a backup power situation, the set values are not taken into account.
    If Battery charging from other sources is activated, the following options are available:
    • The setting From other generators in the home network and from public grid activates/deactivates the charging of the battery from the public grid and, if present, from other generators in the home network.
      Take into account the normative or compensatory specifications for this setting. Irrespective of this setting, necessary service-related charging from the public grid is performed (e.g., forced re-charging to protect against deep discharge).
    • The setting From other generators in the home network activates/deactivates charging of the battery from other generators.
    SoC warning level
    Reserve Capacity
    IMPORTANT! Fronius accepts no liability for damage to third-party batteries.
    Time-dependent battery control
    Using the Time-dependent battery control, it is possible to specify, restrict, or prevent the charging or discharging of the battery at/to a defined power.
    Battery Management is influenced, for example, by the following settings:
    • Permitted battery charging from the public grid
    • Power limit of the inverter, battery storage, or overall system
    • Control specifications via Modbus
    • Self-consumption optimization
    IMPORTANT! The defined rules for battery control have the second lowest priority after Self-Consumption Optimization. Depending on the configuration, the rules may not be fulfilled due to other settings.
    The following values can be selected for the Time-dependent battery control rules:
    • Max. charging power
      The maximum charging power of the battery is the value set in the Power input field.
    • Min. charging power
      The minimum charging power of the battery is the value set in the Power input field.
    • Max. discharge power
      The maximum discharge power of the battery is the value set in the Power input field.
    • Min. discharge power
      The minimum discharge power of the battery is the value set in the Power input field.
    The timing of when the rule applies is set in the Time input fields and by selecting the days of the week.
    It is not possible to define a time window beyond midnight (00:00).
    Example: Two entries are needed to set a rule of 22:00 to 06:00: "22:00 - 23:59" and "00:00 - 06:00"
    Service Mode
    If Service Mode is activated, the battery system is charged or discharged to the state of charge of 30%. The state of charge of 30% is maintained until the end of service mode.
    IMPORTANT! Service Mode is only available for Fronius battery systems.
    Examples - Time-dependent battery control
    The following examples serve to explain the energy flows. Efficiency levels are not taken into account.
    Battery system
    PV system to inverter
    1000 W
    Power into the battery
    500 W
    Power output (AC) of the inverter
    500 W
    Set target value at feed-in point
    0 W
    Infeed into the public grid
    0 W
    Consumption in home
    500 W
    Battery system without photovoltaics, including second generator in the house
    1500 W
    Power consumption (AC) of the inverter
    1500 W
    Second generator in home network
    2000 W
    0 W
    0 W
    Consumption in home
    500 W
    Battery system including second generator in the house
    1000 W
    2500 W
    1500 W
    2000 W
    0 W
    0 W
    Consumption in home
    500 W
    Permitted battery control regulations
    A regulation always consists of a restriction or specification, and the time and days of the week when the regulation is active. The time of regulations with the same restriction (e.g., max. charging power) must not overlap.
    Max. charging and discharging limits
    One max. charging and one max. discharging power can be configured at the same time.
    Specify charging range
    It is possible to define a charging range using a min. and max. charging limit. In this case, it is not possible to discharge the battery.
    Specify discharging range
    It is possible to define a discharging range using a min. and max. discharging limit. In this case, it is not possible to charge the battery.
    Specify a defined charge
    It is possible to specify a defined charging power by setting the min. and max. charging power to the same value.
    Specify a defined discharge
    It is possible to specify a defined discharging power by setting the min. and max. discharging power to the same value.
    Possible applications
    • Time-dependent energy tariffs
    • Battery reservation in the event of market-specific power limitation
    • Time-dependent storage reservation for a backup power situation
    PV power reduction
    The regulations in the Battery Management menu area enable optimal use of the energy generated. In some situations, the PV power cannot be used in full due to the time-dependent battery control.
    Example
    Fronius inverter (max. output power)
    6000 W
    Defined discharge of the battery
    6000 W
    PV power
    1000 W
    In this case, the inverter reduces the PV power to 0 W, since the output power of the inverter is max. 6000 W. The inverter is already being fully utilized through discharging the battery.
    Load management
    Priorities
    If additional components (e.g., battery, Fronius Ohmpilot) are present in the system, the priorities can be set here. Devices having higher priority are actuated first, and subsequently, if there is still excess energy available, the other devices.
    IMPORTANT!
    If there is a Fronius Wattpilot in the photovoltaic system, it is considered to be a load. The priority for the load management of the Fronius Wattpilot must be configured in the Fronius Solar.wattpilot app.
    Rules
    It is possible for up to four different load management rules to be defined. At the same threshold values, the rules are activated in succession. For deactivation, this is done in reverse; the I/O last switched on is the first to be switched off. In the case of different thresholds, the I/O with the lowest threshold is switched on first, followed by the second lowest, and so on.
    I/Os controlled by the produced power are always prioritized over a battery and Fronius Ohmpilot. That is to say that an I/O can switch on and result in the battery no longer being charged or the Fronius Ohmpilot no longer being activated.
    IMPORTANT!
    An I/O is activated/deactivated after 60 seconds.
    Load
    • Control is Off (deactivated).
    • Control is effected by the Power Production.
    • Control is effected by Power Surplus (with feed-in limits). This option can only be selected if a meter has been connected. Control is effected using the actual power of feeding in with respect to the grid.
    Thresholds
    • On: For entering an effective power limit, at which the output is activated.
    • Off: For entering an effective power limit, at which the output is deactivated.
    Duration
    • Field for activating the Minimum duration per on-signal for which the output is to be activated for each switch-on process.
    • Field for activating the Maximum duration per day.
    • Field for activating the Desired duration for which the output is to be activated in total per day (several switch-on processes are allowed for).
    Set the operating mode to Manual or Automatic. The inverter always adjusts to the set Target value at feed-in point. In Automatic operating mode (factory setting), an adjustment is made to 0 W at the feed-in point (max. self-consumption).
    The Target value at feed-in point also applies if a further source feeds into this Smart Meter. In this case, however:
    • The Fronius Smart Meter must be installed and configured at the feed-in point.
    • The Allow battery charging from other generators in the home network function must be activated in the Components > Battery menu area.
    If Manual has been selected under Self-Consumption Optimization, the Operation Mode (Consumption/Feed-in) and the Target value at feed-in point can be set.
    IMPORTANT!
    Self-Consumption Optimization has lower priority than Battery Management.
    System
    General
    1Enter the name of the system in the input field PV System Name (max. 30 characters).
    2Select the Timezone Region and Timezone Location in the drop-down lists.
    3Click Save.
    ✓System name, time zone, and time zone location are saved.
    2. System
    General
    3Click Save.
    2. System
    Update
    All available updates for inverters and other Fronius devices are provided on the product pages and in the "Fronius Download Search" area at www.fronius.com .
    Update
    1Drag the firmware file into the Drag & drop file here field, or select via Browse file.
    ✓Update is started.
    2. System
    Setup wizard
    The guided setup wizard can be accessed here.
    2. System
    Restoring factory settings
    All settings
    Resets all configuration data, apart from the country setup. Changes to the country setup may only be made by authorized personnel.
    All settings without network
    Resets all configuration data, apart from the country setup and the network settings. Changes to the country setup may only be made by authorized personnel.
    2. System
    Event log
    Current messagesAll current events of the linked system components are displayed here.
    IMPORTANT!
    Depending on the type of event, this must be confirmed via the "tick" button so that it can be further processed.
    History
    All events of the linked system components that are no longer present are displayed here.
    2. System
    Information
    All the information regarding the system and the current settings is displayed and provided for download in this menu area.
    2. System
    License Manager
    The power data and functional scope of the inverter are stored in the license file.
    If the inverter, power stage set PC board, or data communication area is replaced, the license file must also be replaced.
    2. System
    Licensing
    Licensing - online (recommended)
    This requires an Internet connection and a completed Fronius Solar.web configuration.
    1Finish all installation work (refer to the chapter headed Closing the inverter's connection area/housing cover, and commissioning on page (→)).
    2Establish a connection to the user interface of the inverter.
    3Enter the serial number and verification code (VCode) of the defective and replacement device. The serial number and VCode can be found on the rating plate of the inverter (refer to the chapter headed Information on the device on page (→)).
    4Click the Start online licensing button.
    5Skip past the Terms and conditions of use and Network settings menu items by clicking Next.
    ✓License activation is started.
    Licensing - offline
    There must be no Internet connection in this case. If offline licensing is carried out while there is an active Internet connection, the license file is automatically loaded onto the inverter, resulting in the following error when the license file is uploaded: "The license has already been installed and the wizard can be closed".
    4Click the Start offline licensing button.
    5Download the service file onto the mobile device by clicking the Download service file button.
    6Open licensemanager.solarweb.com and log in with username and password.
    7Drag the service file into the Drag service file here or click to upload field or click to upload it.
    8Download the newly generated license file onto the mobile device by clicking the Download license file button.
    9Switch to the user interface of the inverter and drag the license file into the Drag & drop license file here field or select via Choose license file.
    2. System
    Support
    Activating the support user
    1Click the Enable Support User Account button.
    ✓The support user is activated.
    IMPORTANT!
    The support user exclusively enables Fronius Technical Support to configure settings on the inverter via a secure connection. Access is deactivated by clicking the Terminate Support User Session button.
    Generating support info (for Fronius Support)
    1Click the Generate support info button.
    2The sdp.cry file is downloaded automatically. For manual download, click the Download support info button.
    ✓The sdp.cry file is saved in the downloads.
    Activating remote access
    1Click the Activate Remote Access button.
    ✓Remote access is activated for Fronius Support.
    IMPORTANT!
    The remote access exclusively enables Fronius Technical Support to access the inverter via a secure connection. In this case, diagnostics data are transmitted, which are used for troubleshooting. The remote access can be activated only upon request by Fronius Support.
    Communication
    Network
    Server addresses for data transfer
    If a firewall is used for outgoing connections, allow the below protocols, server addresses, and ports for successful data transfer, see:
    When using FRITZ!Box products, configure Internet access without any restrictions or limitations. Do not set the DHCP Lease Time (validity) to 0 (=infinite).
    LAN:
    Establishing a connection:
    1Enter the host name.
    2Select the connection type: Automatic or Static.
    3For the Static connection type, enter the IP address, subnet mask, DNS, and gateway.
    4Click the Connect button.
    ✓The connection is established.
    After establishing the connection, check the connection status.
    WiFi:
    Establishing a connection via WPS:
      Activate the access point of the inverter. This is opened by touching the sensor    > Communications LED flashes blue
    1.
    2.
    IMPORTANT!
    3.
    4.
    In the Communication > Network > WLAN > WPS menu area, click the Activate button.
    5.
    Activate WPS on the WiFi router (see WiFi router documentation).
    6.
    Click on the Start button. The connection is established automatically.
    7.
    Log in to the user interface of the inverter.
    8.
    Check the network details and connection to Fronius Solar.web.
    1Establish the connection to the inverter in the network settings (the inverter is displayed with the name "FRONIUS_" and the serial number of the device).
    2Enter the password from the rating plate and confirm.
    IMPORTANT!
    3Enter the IP address 192.168.250.181 in the address bar of the browser and confirm.
    4In the Communication > Network > WLAN > WPS menu area, click the Activate button.
    5Activate WPS on the WiFi router (see WiFi router documentation).
    6Click on the Start button. The connection is established automatically.
    7Log in to the user interface of the inverter.
    8Check the network details and connection to Fronius Solar.web.
    After connecting, the status of the connection should be checked.
    Selecting and connecting to a WiFi network:
    The networks found are displayed in the list. Click the refresh button    to perform a new search for available WiFi networks. If necessary, restrict the selection list further via the Search network input field.
    1Select network from the list.
    3For the Automatic connection type, enter the WiFi password and host name.
    4For the Static connection type, enter the IP address, subnet mask, DNS, and gateway.
    5Click the Connect button.
    Access point:
    The inverter serves as the access point. A PC or mobile device connects directly to the inverter. Connecting to the Internet is not possible. Assign a Network Name (SSID) and Network Key (PSK) to establish a connection. Assign a Network Key (PSK) with at least 20 characters, consisting of upper and lower case letters, special characters, and numbers, to protect the device from unauthorized access.
    It is possible to operate a connection via WiFi and via the access point at the same time.
    2. Communication
    Network
    LAN:
    WiFi:
    1.
    2.
    IMPORTANT!
    3.
    4.
    5.
    6.
    7.
    8.
    IMPORTANT!
    Access point:
    2. Communication
    Modbus
    The inverter communicates with system components (e.g., Fronius Smart Meter) and other inverters via Modbus. The primary device (Modbus Client) sends control commands to the secondary device (Modbus Server). The control commands are executed by the secondary device.
    RTU Server
    The following input fields and functions are available for communication via Modbus RTU:
    Meter address offset
    The value entered (1-247) is the identification number (unit ID) assigned to the meter.
    Factory setting: 200
    Inverter address
    The value entered (1-247) is the identification number (unit ID) assigned to the inverter.
    Factory setting: 1
    SunSpec Model Type
    There are two different settings, depending on the SunSpec model.
    float: SunSpec Inverter Model 111, 112, 113 or 211, 212, 213.
    int + SF: SunSpec Inverter Model 101, 102, 103 or 201, 202, 203.
    Interface
    Select one of the two interfaces Modbus 0 (M0) RTU or Modbus 1 (M1) RTU.
    Baud Rate
    The baud rate influences the speed of the transmission between the individual components connected in the system. When selecting the baud rate, it should be ensured that this is the same on the transmit and receive side.
    Parity
    The parity bit can be used for parity checks. This is used to identify transmission errors. In this case, a parity bit can ensure a specified number of bits. The value (0 or 1) of the parity bit must be calculated at the transmitter, and is checked at the receiver using the same calculation. The calculation of the parity bit can be carried out for even or odd parity.
    Allow Control
    If this option is activated, the inverter is controlled via Modbus.
    Inverter control includes the following functions:
    • On/off
    • Power reduction
    • Setting a constant power factor (cos phi)
    • Setting a constant reactive power
    • Battery control settings with battery
    TCP Server
    The following input fields and functions are available for communication via Modbus TCP:
    SunSpec Model Type
    Modbus port
    Number of the TCP port (502 or 1502) to be used for Modbus communication.
    Meter Address
    The value entered is the identification number (unit ID) assigned to the meter, which can be found on the user interface of the inverter in the Communication > Modbus menu area.
    Allow Control
    • On/off
    • Power reduction
    Restrict Control
    Restrict the control of the inverter to a device with a fixed IP address.
    2. Communication
    Cloud control
    The utility/energy supplier can influence the output power of the inverter with Cloud control. This requires the inverter to have an active Internet connection.
    Parameter
    Display
    Description
    Cloud control
    Off
    Cloud control of the inverter is deactivated.
    On
    Cloud control of the inverter is activated.
    Profile
    Value range
    Description
    Allow cloud control for regulatory purposes (Technician)
    Deactivated/Activated
    The function may be mandatory for proper operation of the system.*
    Allow cloud control for Virtual Power Plants (Customer)
    If the Allow remote control for regulatory purposes (technician) function is activated (technician access required), the Allow remote control for virtual power plants function is automatically activated and cannot be deactivated.*
    * Cloud control
    A virtual power plant is an interconnection of multiple generators. This virtual power plant can be controlled by means of the cloud control via the Internet. An active inverter Internet connection is a prerequisite for this. System data are transferred.
    2. Communication
    Solar API
    The Solar API is an IP-based, open JSON interface. If enabled, IOT devices in the local network may access inverter information without authentication. For security reasons, the interface is disabled in the factory. Activate the interface manually if it is required for a third-party application (e.g., EV charger, smart home solutions, etc.). If there is a Fronius Wattpilot in the network, the inverter automatically activates the Solar API.
    Fronius recommends using Fronius Solar.web for monitoring and analyzing the inverter and connected system components.
    In the event of a firmware update to version 1.14.x, the Solar API setting is applied. In systems with a version below 1.14.x, the Solar API is activated; with higher versions, it is deactivated but can be switched on and off via the menu.
    Manually activating the Fronius Solar API
    On the user interface of the inverter in the Communication > Solar API menu area, activate the function Activate communication via Solar API.
    2. Communication
    Fronius Solar.web
    In this menu, you can agree to the technically necessary data processing or reject it.
    In addition, the transfer of analysis data and remote configuration via Fronius Solar.web can be enabled or disabled.
    Safety and grid requirements
    Country setup
    WARNING
    Danger from unauthorized fault analyses and repair work.
    Fault analyses and repair work on the PV system may only be carried out by installers/service technicians from authorized specialist companies in accordance with national standards and regulations.
    NOTE
    Risk due to unauthorized access.
    Incorrectly set parameters can have a negative effect on the public grid and/or the grid power feed operation of the inverter and result in the loss of standard conformity.
    Parameters may only be adjusted by installers/service technicians from authorized specialist companies.
    Do not give the access code to third parties and/or unauthorized persons.
    NOTE
    Risk due to incorrectly set parameters.
    Incorrectly set parameters can have a negative effect on the public grid and/or cause inverter malfunctions and failures and result in the loss of standard conformity.
    Parameters may only be adjusted if this has been approved or requested by the utility.
    Any parameter adjustments must be made in compliance with nationally applicable standards and/or directives as well as the specifications of the utility.
    The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. To apply for the access code required for this menu area, see chapter Requesting inverter codes in Solar.SOS.
    The selected country setup for the country in question contains preset parameters in accordance with nationally applicable standards and requirements. Changes may need to be made to the selected country setup depending on local grid conditions and the specifications of the utility.
    2. Safety and grid requirements
    Country setup
    WARNING
    NOTE
    NOTE
    The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. The inverter access code required for this menu area can be requested in the Fronius Solar.SOS portal.
    Requesting inverter codes in Fronius Solar.SOS:
    1.
    Open solar-sos.fronius.com in the browser
    2.
    Log in with your Fronius account
    3.
    At the top right, click on the drop-down menu
    4.
    Select the Show inverter codes menu item
    5.
    A contract page appears on which the request for the access code to change the grid parameters for Fronius inverters is located
    6.
    Accept the terms and conditions of use by checking Yes, I have read and agree to the terms of use and click Confirm & Save
    7.
    After that, the codes can be retrieved in the drop-down menu at the top right under Show inverter codes
    1Open solar-sos.fronius.com in the browser
    2Log in with your Fronius account
    3At the top right, click on the drop-down menu
    4Select the Show inverter codes menu item
    ✓A contract page appears on which the request for the access code to change the grid parameters for Fronius inverters is located
    5Accept the terms and conditions of use by checking Yes, I have read and agree to the terms of use and click Confirm & Save
    6After that, the codes can be retrieved in the drop-down menu at the top right under Show inverter codes
    CAUTION
    Absolute Generation Limit
    Activating this function limits the output power of the inverter to the specified value in watts.
    Feed-in limit
    Energy companies or grid operators can prescribe feed-in limits for inverters (e.g., max. 70% of the kWp or max. 5 kW). The inverter limits the effective power at the grid connection point (installation location of the Fronius Smart Meter or primary meter) to the set value.
    The inverter takes account of self-consumption in the household before the power is reduced. An individual limit can be set.
    In order to minimize the yield losses due to the power of feeding in limitation, the power available from the module array can be:
    • Used for controllable system components, such as Fronius Ohmpilot or Fronius Wattpilot
    • Used by loads controlled via I/Os
    • Stored in a battery
    If these possibilities have been exhausted, the power drawn from the module array is reduced to such an extent that the feed-in limit is not exceeded.
    Installation variants with an inverter, Fronius Smart Meter, and system components are listed under Different operating modes.
    Total DC power of the system
    The input field for the total DC power of the entire system in Wp. Always enter this value if the Maximum grid feed-in power is specified in %.
    Power Control deactivated
    The inverter converts all available PV energy.
    Power Control activated
    Feeding in limited with the following selection options:
    • Total Power Limit
      Set the value of the permissible total power of feeding in for the photovoltaic system.
    • Limit per phase – asymmetric generation
      The inverter determines the optimum per phase. The inverter regulates the individual phases in such a way that none of the phases exceeds the set value.
    • Limit per phase – weakest phase
      The inverter measures each individual phase. If the permissible feed-in limit is exceeded on one phase, the inverter symmetrically reduces the total power for all phases until the limit is reached.
    IMPORTANT! Implement the settings for Limit per phase if national standards and regulations require a limitation of the single-phase power. Set the value for the permissible power of feeding in for each phase.
    IMPORTANT! Power Control settings are automatically applied for the dynamic feed-in limit of I/O power management. Total Power Limit is the default configuration.
    Dynamic feed-in limit (Soft Limit)
    If this value is exceeded, the inverter readjusts down to the set value.
    Export Limit Protection (PAV,E protection)
    This function monitors compliance with the feed-in limit. If Dynamic feed-in limit (Soft Limit) is activated, the inverter controls the power of feeding in in such a way that this function is usually not activated. If the specified limit values and the switch-off times are exceeded, this protection function disconnects the inverter from the grid.
    The Maximum grid feed-in power (PAV,E) in the case of an asymmetric feed-in (Limit per phase – asymmetric generation or Limit per phase – weakest phase) can be combined with the export limit protection (PAV,E protection) function. The Maximum grid feed-in power is calculated as follows: Maximum grid feed-in power per phase (PAV,E) x 3.
    The export limit protection (PAV,E protection) function is only possible if a Smart Meter IP configured with MQTT is installed at the feed-in point.
    Export Limit Protection (Hard Limit Trip)
    IMPORTANT!
    This function is only available if Dynamic feed-in limit (Soft Limit) is activated.
    Input field for the Maximum grid feed-in power in W or % (setting range: ‑10 % to 100 %).
    If there is no meter in the system or if the primary meter has failed, the inverter limits its output power to the set value.
    If this value is exceeded, the inverter switches off within max. 5 s. This value must be higher than the value set for Export Limit Control (Soft Limit).
    If required, enable the fail-safe function Reduce inverter power to 0% if meter connection has been lost. When this function is enabled, the inverter activates standby mode. No feed-in takes place.
    The use of WiFi for communication between the Fronius Smart Meter and the inverter is not recommended with the fail-safe function activated at the same time. Even short-term disconnections can cause the inverter to shut down. This problem arises with weak WiFi signal strengths, a slow or overloaded WiFi connection, and automatic channel selection of the router.
    Import limitation
    Energy companies or grid operators can prescribe import limitations for inverters. The amperage is limited to the set value.
    1Under Limit select Current Limitation.
    2Enter the limit value in amperes.
    3Click on Save.
    Feed-in limit – examples
    Total Power Limit
    (feed-in limit 0 kW with battery)
    Explanation
    No power (0 kW) may be fed into the public grid at the grid feed-in point. The load requirement in the home network (6 kW) is supplied by the power generated by the inverter. Surplus production (4 kW) is stored in the battery.
    (feed-in limit 0 kW per phase) – asymmetric
    Explanation
    The load requirement in the home network per phase is determined and supplied.
    (feed-in limit 0 kW per phase with battery) – asymmetric
    Explanation
    The load requirement in the home network per phase is determined and supplied. Additional power required (2 kW) is provided by the battery.
    (feed-in limit 0 kW per phase with battery) – symmetrical
    Explanation
    The weakest phase in the load requirement in the home network is determined (phase 1 = 1 kW). The result of the weakest phase (1 kW) is applied to all phases. Phase 1 (1 kW) can be supplied. Phase 2 (2 kW) and phase 3 (3 kW) cannot be supplied, power from the public grid is required (phase 2 = 1 kW, phase 3 = 2 kW). Surplus production (7 kW) is stored in the battery.
    Multiple Inverter Control
    IMPORTANT! To view and change settings in this menu item, select the Technician user. Enter and confirm the password for the Technician user. Settings in this menu area may only be made by trained and qualified personnel.
    The inverter can be used as a primary device to control dynamic feed-in limits for additional Fronius inverters (secondary devices) so that feed-in limits prescribed by energy companies or utilities can be centrally managed. This control refers to the Soft Limit feed-in limit see Feed-in limit. To do so, the following requirements must be met:
    • A Fronius Smart Meter is configured as a primary meter and connected to the master.
    • Power Control is activated and configured in the Feed-in limit menu on the user interface of the primary device. The power control limit is set to Total Power Limit.
    • Master and secondary device(s) are physically connected to the same network router via LAN.
    • If Use Modbus TCP is enabled, the inverter control via Modbus TCP must be activated and configured for all secondary devices.
    IMPORTANT! Only one primary meter is required for the primary device.
    IMPORTANT! If an inverter with a battery is connected, use this inverter as the primary device for Multiple Inverter Control.
    Example connection diagram for Multiple Inverter Control
    System limits
    • Systems with a maximum of 20 inverters (1 primary device + 19 secondary devices) are supported if the Use Modbus TCP function is activated. Otherwise, a maximum of one primary device and two secondary devices are supported.
    • The control system is designed for photovoltaic systems with a total output of up to 300 kW.
    • In the case of larger system capacities, the control times in the system are extended.
    • The use of a plant controller is recommended for systems >300 kW.
    External grid and system protection
    • Regional standards and guidelines may require the installation of external grid and system protection for systems >30 kVA.
    • External grid and system protection can be omitted under the following conditions:
      • A Fronius Smart Meter IP performs the external voltage measurement.
      • The Fronius Smart Meter IP communicates with the primary device via the MQTT protocol.
      • In the country setup, select On at Smart Meter from the Long Time Average Limit menu.
      • On the user interface of the secondary device, the Use Modbus TCP function is disabled.
    Multiple Inverter Control is available for the following device combinations:
    Primary devices
    Secondary devices
    GEN24, Verto, Tauro
    • GEN24
    • Verto
    • Tauro
    • Argeno
    • SnapINverter with Fronius Datamanager 2.0*
    * Up to four additional SnapINverters can be connected to each SnapINverter with Fronius Datamanager 2.0.
    Primary meter
    One Fronius Smart Meter acts as the only primary meter and is connected directly to the primary device. This Smart Meter measures the total output power of all inverters into the grid and passes this information to the primary device.
    Primary device
    Configure the feed-in limit on the user interface of the inverter:
    1In the Safety and Grid Regulations > Feed-in limit menu area, activate the Power Control function and Select Total Power Limit.
    2Configure the country-specific settings.
    3In the Safety and Grid Regulations > Multiple Inverter Control menu area, activate the Multiple Inverter Control function.
    The primary device automatically scans the network for available secondary devices.
    ✓A list shows the inverters found.
    To perform the search again, press the Refresh button    .
    If Use Modbus TCP is activated, it is also possible to select Fronius SnapINverters with Datamanager 2.0 and Fronius Argeno with Use Inverter.
    4Activate Use Inverter against all secondary devices to which a common feed-in limit applies. Click Use all Inverters to enable the function for the primary device and all secondary devices.
    The status of the inverters listed is displayed as follows:
    • Inactive: Secondary device is not configured for the power control or a firmware update is required.
    • Disconnected: Secondary device is configured, network connection not possible.
    • Connected: Secondary device is configured and accessible via the network of the primary device.
    5In the Safety and Grid Regulations > I/O Power Management menu area, set the controlling priorities as follows:
    1. I/O Power Limit
    2. Feed-in limit
    3. Modbus Control
    Adding Fronius Argeno and other inverters manually
    1In the Multiple Inverter Control menu, select the Multiple Inverter Control function.
    2Select additional inverters and click + Add.
    3Enter the name, hostname or IP address, and the Modbus address of the secondary device.
    4Click Add.
    For more information on configuring the Fronius Argeno or Fronius Datamanager 2.0 as a secondary device, refer to the respective operating instructions.
    Secondary device
    Each secondary device takes over the settings for the feed-in limit from the primary device. A secondary device does not transmit any data for the feed-in limit to the primary device. To do so, the following requirements must be met:
    • Multiple Inverter Control is activated and configured in the Multiple Inverter Control menu on the user interface of the primary device.
    Set the following configurations for the feed-in limit on the secondary device:
    User interface secondary device GEN24 / Verto / Tauro
    1Select the user Technician and enter the password for the user Technician.
    Only carry out work steps 2 and 3 if Use Modbus TCP is activated on the primary device.
    2In the Communication > Modbus menu area, activate the TCP Server mode and the Allow Control function.
    3For a fail-safe scenario, in the Safety and Grid Regulations > I/O Power Management menu area, set the controlling priorities as follows:
    1. Modbus Control
    2. Feed-in limit
    3. I/O Power Limit
    4In the Safety and Grid Regulations > Feed-in limit menu area, select and edit the following settings:
    • Enable the Power Control function.
    • Select Total Power Limit and specify the Total DC power of the system in watts.
    • Activate the Dynamic feed-in limit (Soft Limit) and enter a value of 0 W for the Maximum grid feed-in power.
    • Enable the Reduce inverter power to 0% if meter connection has been lost function.
    General
    Settings relevant to the grid operator are defined as rules under this menu item. This relates to an effective power limit in % or watts and/or a power factor specification. To view and change settings, select the Technician user, and enter and confirm the password. Only technical specialists may make settings in this menu area.
    Under Rules, expand a menu area (e.g., Rule 1). Configure the following settings:
    Limitation
    IMPORTANT!
    A dynamic feed-in limit for several inverters can be configured under Feed-in limit. I/O power management rules are transferred from the inverter (primary device) to connected inverters in the system (secondary devices).
    Select the following rules for power management:
    • I/O Generation Limit (%): The total output power of the connected inverter is statically limited to the defined value of the absolute rated power.
    • Export Limit Control (W): The active power fed in at the grid connection point is limited to the set value (e.g., 5000 watts). The output powers of the inverters (primary and secondary devices) are dynamically adjusted depending on their self-consumption.
    • Shutdown single device: The inverter stops grid power feed operation and switches to standby mode.
    IMPORTANT!
    The rules for shutdown apply to this device and cannot be applied to other inverters in the system.
    Input pattern (assignment of individual I/Os)
    1 click = white, contact open
    2 clicks = blue, contact closed
    3 clicks = gray, not used
    Power Factor (cos φ) (define value)
    Impedance response
    • Capacitive
    • Inductive
    DNO Feedback
    If the rule is activated, always configure the DNO Feedback output, e.g., for operating a signal device.
    The Import and Export of defined rules can be carried out in the data format *.fpc. The rules and pin assignments in the following connection examples are not the only possible configurations. For pin assignment, take into account the available connections at the Data communication area and settings of the device configuration.
    If there is an active rule for the control of the inverter, the device indicates this in the overview of the user interface under Device State.
    Controlling Priorities
    Used to set controlling priorities for I/O Power Management (DRM or ripple control receiver), the feed-in limit, and control via Modbus.
    1 = highest priority, 3 = lowest priority
    Local priorities of the I/O power management, the feed-in limit, and the Modbus interface are deactivated by cloud control commands (regulatory purposes and virtual power plants) – see Cloud control – and by backup power.
    In terms of controlling priorities, the device differentiates between power control and inverter shutdown. Inverter shutdown always takes precedence over power control. An inverter shutdown command is always executed and does not need to be prioritized.
    Power control
    • I/O Power Management (DRM/ripple control receiver signal) – according to command
    • Export Limitation (Soft Limit) – always active
    • Modbus (generation limit) – according to command
    Inverter shutdown
    • Export Limitation (Hard Limit)
    • Modbus (shutdown command) – according to command
    4-relay connection example
    Connect the ripple control signal receiver and the I/O terminals of the inverter to one another as shown in the connection diagram.
    For distances greater than 10 m between the inverter and the ripple control signal receiver, use a shielded data communication cable (CAT 5 or higher) with twisted cable pairs. Connect the shielding on one side to the terminal of the data communication area (SHIELD).
    (1)
    Ripple control signal receiver with 4 relays for effective power limitation.
    (2)
    I/O connection terminals of the data communication area.
    Use pre-configured file for 4-relay operation:
    1Download the file (.fpc) under 4-relay operation to the mobile device.
    2Upload the file (.fpc) in the I/O Power Management menu area by clicking the Import button.
    3Click Save.
    ✓The settings for 4-relay operation are saved.
    I/O power management settings – 4 relay example
    3-relay connection example
    (1)
    Ripple control signal receiver with 3 relays for effective power limitation.
    (2)
    Use pre-configured file for 3-relay operation:
    1Download the file (.fpc) under 3-relay operation to the mobile device.
    3Click Save.
    ✓The settings for 3-relay operation are saved.
    I/O power management settings – 3 relay example
    2-relay connection example
    (1)
    Ripple control signal receiver with 2 relays for effective power limitation.
    (2)
    Use pre-configured file for 2-relay operation:
    1Download the file (.fpc) under 2-relay operation to the mobile device.
    3Click Save.
    ✓The settings for 2-relay operation are saved.
    I/O power management settings – 2 relay example
    1-relay connection example
    (1)
    Ripple control signal receiver with 1 relay for effective power limitation.
    (2)
    Use pre-configured file for 1-relay operation:
    1Download the file (.fpc) under 1-relay operation to the mobile device.
    3Click Save.
    ✓The settings for 1-relay operation are saved.
    I/O power management settings – 1 relay example
    Connecting the ripple control receiver with several inverters
    The grid operator may request the connection of one or more inverters to a ripple control receiver in order to limit the active power and/or the power factor of the photovoltaic system.
    Connection diagram for ripple control receiver with several inverters
    Connect the following Fronius inverters to a ripple control receiver via a distributor (coupling relay):
    • Symo GEN24
    • Primo GEN24
    • Tauro
    • Verto
    • SnapINverter (only devices with Fronius Datamanager 2.0)
    On the user interface of each inverter connected to the ripple control receiver, set the same parameters for I/O power management.
    Autotest
    (CEI 0-21)
    Description
    The Autotest makes it possible to check the Italian protection function, required by the applicable standard for monitoring the voltage and frequency limit values of the inverter during commissioning. In normal operation, the inverter constantly checks the real-time actual value of the voltage and frequency of the grid.
    Once the Autotest has started, different individual tests are carried out automatically, in succession. Depending on the grid conditions, the duration of the test is approximately 15 minutes.
    IMPORTANT!
    In Italy, the inverter may only be commissioned following a successfully completed Autotest (CEI 0-21). If an Autotest is not passed, grid power feed operation may not take place. Once the Autotest is started, it must be completed successfully. The Autotest cannot be started during backup power mode.
    Umax
    Test for checking the maximum voltage in the phase conductors
    Umin
    Test for checking the minimum voltage in the phase conductors
    fmax
    Test for checking the maximum mains frequency
    fmin
    Test for checking the minimum mains frequency
    fmax alt
    Test for checking an alternative maximum mains frequency
    fmin alt
    Test for checking an alternative minimum mains frequency
    U outer min
    Test for checking the minimum outer voltages
    U longT.
    Test for checking the 10 min. voltage average
    Print to PDF
    1Click the Print to PDF button.
    2Enter the file name into the input field and click on the Print button.
    ✓The PDF is created and shown.
    Note on the Autotest
    The limit values are set in the Safety and Grid Regulations > Country Setup> Grid Support Functions menu area.
    The Country Setup menu area is intended exclusively for installers/service technicians from authorized specialist companies. The inverter access code required for this menu area can be requested in the Fronius Solar.SOS portal (see chapter Requesting inverter codes in Solar.SOS on page (→)).
    Options
    Surge protection device (SPD)
    General
    A surge protection device (SPD) protects against temporary overvoltages and diverts surge currents (e.g., lightning strike). Based on an overall lightning protection concept, the SPD contributes to the protection of the photovoltaic system components.
    For detailed information on the wiring diagram of the surge protection device, see chapter Surge protection device (SPD) on page (→).
    If the surge protection device is triggered, the color of the indicator changes from green to red (mechanical display) and the operating status LED of the inverter lights up red (see chapter Button functions and LED status indicator on page (→)). The error code 1030 WSD Open is displayed on the user interface of the inverter in the System > Event Log menu area or in the user menu under Notifications and in Fronius Solar.web. In this case, the inverter must be repaired by an authorized specialist company.
    IMPORTANT!
    The inverter also switches off if the 2-pin signal cable of the surge protection device is interrupted or damaged.
    External surge protection device
    To receive a notification when external surge protection devices are triggered, it is recommended to connect the feedback contacts connected in series to the WSD input.
    1. Options
    General
    IMPORTANT!
    1. Options
    2. Surge protection device (SPD)
    General
    IMPORTANT!
    1. Options
    Safety
    WARNING
    Danger due to electrical voltage on live parts of the photovoltaic system.
    Disconnect live parts of the photovoltaic system on all pins and on all sides.
    Secure against re-activation in accordance with national regulations.
    Allow the capacitors of the inverter to discharge (2 minutes).
    Check that the inverter is de-energized with a suitable measuring device.
    WARNING
    Installing and connecting an option must only be carried out by service personnel trained by Fronius and only within the scope of the respective technical regulations.
    Follow the safety rules.
    1. Options
    Scope of supply
    The surge protection device (SPD) is available as an option and can be retrofitted to the inverter.
    For technical data, see chapter Technical data on page (→).
    1. PC board
    2. 4 TX20 screws
    3. Ground conductor
    4. 2-pin signal cable
    5. PV- cable
    6. PV+ cable
    7. User information
    IMPORTANT!
    A larger ground conductor cross-section may be required depending on national standards and regulations.
    Fit a ring cable lug (internal diameter: 4 mm, outer diameter: max. 10 mm) as well as a corresponding ferrule. Fasten the ground conductor to the PC board with a torque of 1.5 Nm.
    1. Options
    De-energizing the inverter
    Turn off the automatic circuit breaker. Set the DC disconnector to the "off" switch position.
    2Disconnect connections from the solar module strings (+/-).
    Switch off the battery connected to the inverter.
    Wait for the capacitors of the inverter to discharge (2 minutes).
    1. Options
    Starting up the inverter
    1Connect the solar module strings (+/-).
    Switch on the battery connected to the inverter.
    Set the DC disconnector to the "on" switch position. Turn on the automatic circuit breaker.
    1. Options
    DC Connector Kit GEN24
    General
    The DC Connector Kit GEN24 (item number: 4,240,046) enables PV-connection strings with the following total currents to be connected:
    • Symo GEN24: > 25 A
    • Symo GEN24 SC: > 28 A
    • Primo GEN24: > 25 A
    • Primo GEN24 SC: > 22 A
    IMPORTANT!
    Do not use the DC Connector Kit GEN24 if the device has an integrated Arc Fault Circuit Interrupter (AFCI), which is used for the arc detection requirement according to IEC 63027. Carry out installation in accordance with the nationally applicable standards and guidelines.
    1. Options
    2. DC Connector Kit GEN24
    General
    IMPORTANT!
    1. Options
    General information about PV modules
    To enable suitable PV modules to be chosen and to use the inverter as efficiently as possible, it is important to bear the following points in mind:
    • If insolation is constant and the temperature is falling, the open circuit voltage of the PV modules will increase. The open circuit voltage must not exceed the max. permissible system voltage. An open circuit voltage above the indicated values will damage the inverter, and all warranty rights will become null and void.
    • The temperature coefficients on the data sheet of the PV modules must be observed.
    • Exact values for sizing the PV modules can be obtained using suitable calculation tools, such as the Fronius Solar.creator.
    IMPORTANT!
    Before connecting up the PV modules, check that the voltage for the PV modules specified by the manufacturer corresponds to the actual measured voltage.
    IMPORTANT!
    The PV modules connected to the inverter must comply with the IEC 61730 Class A standard.
    IMPORTANT!
    Solar module strings must not be grounded.
    1. Options
    Safety
    WARNING
    The commissioning, maintenance, and service work in the inverter's power stage set may only be carried out by Fronius-trained service personnel in accordance with the technical specifications.
    Read the installation instructions and operating instructions before installing and commissioning the equipment.
    WARNING
    Danger from mains voltage and DC voltage from PV modules that are exposed to light.
    All connection, maintenance, and service work should only be carried out when the AC and DC sides have been disconnected from the inverter and are de-energized.
    Only an authorized electrical engineer is permitted to connect this equipment to the public grid.
    WARNING
    Danger of an electric shock due to improperly connected terminals/PV plug connectors.
    When connecting, ensure that each pole of a string is routed via the same PV input, e.g.:
    + pole string 1 to the input PV 1.1+ and - pole string 1 to the input PV 1.1-
    WARNING
    Danger from damaged and/or contaminated terminals.
    Prior to connection work, check the terminals for damage and contamination.
    Remove any contamination while the equipment is de-energized.
    Have defective terminals replaced by an authorized specialist company.
    1. Options
    Scope of supply
    The DC Connector Kit GEN24 is available as an option and can be retrofitted to the inverter.
    1. User information
    2. 2 TX20 screws
    3. DC Connector Kit GEN24
    1. Options
    1. Options
    Installation
    CAUTION
    Risk due to insufficiently dimensioned DC cables.
    This may result in damage to the inverter due to thermal overload.
    For dimensioning the DC cables, observe the information according to chapter Permitted cables for the electrical connection on page (→).
    Loosen the 2 screws on the underside of the housing cover by rotating them 180° to the left using a screwdriver (TX20). Then lift the housing cover away from the inverter at the bottom and detach from above.
    Loosen the 5 screws on the connection area cover by rotating them 180° to the left using a screwdriver (TX20).
    Remove the connection area cover from the device.
    Insert the DC Connector GEN24 into the inverter and fasten it using the 2 screws supplied (TX20) and a torque of 1.2 Nm.
    Push the DC cables through the DC bushings by hand.
    5
    Press the latch on the back of the terminal and remove the DC terminals.
    6
    Strip the insulation of the single conductors by 18 - 20 mm.
    Select the cable cross-section in accordance with the instructions in Permitted cables for the electrical connection from page (→).
    7
    Press the latch on the terminal with a slotted screwdriver. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then remove the slotted screwdriver from the latch.
    8
    Lift the operating lever of the terminal to open. Insert the stripped single conductor into the slot provided in the terminal as far as it will go. Then close the operating lever until it engages.
    9
    NOTE
    Danger due to polarity reversal at the terminals.
    This may result in severe damage to the inverter.
    Use a suitable measuring instrument to check the voltage (max. 1000 VDC) and the polarity of the DC cabling.
    10
    Use a suitable measuring instrument to check the voltage and polarity of the DC cabling.
    NOTE
    Risk due to overtorque at the strain-relief device.
    Damage to the strain-relief device may result.
    Do not use a drill driver.
    11
    Insert the DC terminals into the respective slot until they engage. Fasten the screws of the strain-relief device to the housing using a screwdriver (TX20) and a torque of 1.4 Nm.
    12
    Place the cover on the connection area. Tighten the 5 screws by rotating them 180° to the right in the indicated order using a screwdriver (TX20).
    13
    Clip the housing cover into the inverter from above.
    Press on the lower part of the housing cover and tighten the 2 screws by rotating them 180° to the right using a screwdriver (TX20).
    1. Options
    1. Options
    PV Point Comfort
    Safety
    WARNING
    WARNING
    WARNING
    Danger due to damaged and/or contaminated terminals.
    Before making any connections, check the terminals for damage and contamination.
    Remove contamination in the de-energized state.
    Have defective terminals repaired by an authorized specialist.
    CAUTION
    Danger due to electrostatic discharge (ESD).
    This may result in damage to electronic components.
    Pay attention to the ESD marking on the product and/or on the packaging.
    Take ESD protection measures (grounding, neutralizing, and shielding).
    NOTE
    The continuous supply via the PV Point depends on the available PV power.
    If the solar modules are not supplying enough power, interruptions may occur.
    Do not connect any loads that require an uninterruptible supply.
    IMPORTANT!
    The valid national laws, standards, and provisions, as well as the specifications of the relevant grid operator are to be taken into account and applied.
    It is highly recommended that the specific installation be agreed with the grid operator and explicitly approved by this operator. This obligation applies to system constructors in particular (e.g., installers).
    1. Options
    2. PV Point Comfort
    Safety
    link_horizontalLink copied
    WARNING
    WARNING
    WARNING
    CAUTION
    NOTE
    IMPORTANT!
    1. Options
    2. PV Point Comfort
    Scope of supply
    The PV Point Comfort is available as an option and can be retrofitted to the inverter.
    1. Insulation film
    2. PV Point Comfort
    3. PEN connection
    4. Phase/neutral conductors
    5. 4 TX20 screws
    6. Cable gland
    7. Quick Start Guide
    1. Options
    2. PV Point Comfort
    1. Options
    2. PV Point Comfort
    Installation
    NOTE
    Danger due to insufficiently dimensioned ground conductors.
    Observe the national standards and regulations for dimensioning of the ground conductor.
    Press the latch on the back of the terminal and remove the AC terminals. Loosen the cable gland.
    Disconnect the single conductors from the AC terminal (only necessary for an existing installation).
    5
    Remove the ferrite core and the mains cable from the inverter.
    6
    Drill out the optional cable gland with a step drill.
    7
    Insert the cable gland into the hole and fasten with a torque of 6 Nm.
    8
    Insert the insulating film on the right side of the ground electrode terminal.
    9
    Insert the PC board into the inverter.
    10
    Fasten the PC board using the 4 screws supplied (TX20) and a torque of 1.2 Nm.
    11
    Fasten the supplied phase and neutral conductors to the terminal using a slotted screwdriver.
    12
    Strip 12 mm of insulation from the single conductors. Lift the operating lever of the AC terminal to open. Insert the stripped single conductor into the slot provided in the AC terminal as far as it will go. Then close the operating lever until it engages.
    IMPORTANT!
    Establish the PEN connection in accordance with national regulations. If necessary, replace the supplied PEN connection.
    13
    Fasten the PEN connection to the ground electrode terminal at the second input from above using a screwdriver (TX20) and a torque of 1.8 - 2 Nm.
    14
    Strip 12 mm of the insulation from the single conductors.
    Select the cable cross-section according to the specifications for the respective power category of the inverter (see chapter Permitted cables for the electrical connection on page (→)).
    Execute the residual current circuit breaker and automatic circuit breaker in accordance with national regulations.
    IMPORTANT!
    If necessary, use an automatic circuit breaker with a maximum 16 A for fuse protection. A max of 13 A can be supplied in backup power mode. If the inverter is protected with an automatic circuit breaker with a maximum 16 A, it is possible to dispense with an additional automatic circuit breaker.
    15
    Pass the phase/neutral conductors through the ferrite core. Fasten the ground conductor to the ground electrode terminal at the third input from above using a screwdriver (TX20) and a torque of 1.8 - 2 Nm.
    IMPORTANT!
    The ground conductors must not be passed through the ferrite core and must be connected using a movement loop so that the ground conductors are disconnected last if the cable glands fail.
    16
    Connect the stripped phase/neutral conductors to the terminals provided.
    17
    Insert the terminals into the respective slot until they engage. Fasten the union nuts of the cable glands with a torque of 4 Nm.
    18
    19
    1. Options
    2. PV Point Comfort
    1. Options
    2. PV Point Comfort
    Configuring the PV Point Comfort
    Firmware version 1.25.2 or higher is required to commission the PV Point Comfort. Outdated firmware versions could lead to incompatibilities between the inverter and PV Point Comfort. In this case, the inverter firmware should be updated in accordance with the chapter headed Update on page (→).
    1Call up the user interface of the inverter.
    - Open web browser.
    - In the browser's address bar, enter the IP address (IP address for WLAN: 192.168.250.181, IP address for LAN: 169.254.0.180) or enter and confirm the host and domain name of the inverter.
    ✓The user interface of the inverter is displayed.
    2Click on the Device Configuration button.
    3Log in to the login area with user Technician and the technician password.
    4Go to the Device Configuration > Functions and I/Os menu area.
    5Enable the Backup Power function.
    6Select PV Point mode in the Backup Power Mode drop-down list.
    7Click the Save button to save the settings.
    ✓The PV Point backup power mode has been configured.
    1. Options
    2. PV Point Comfort
    Testing backup power mode
    Testing backup power mode:
    • during first-time installation and configuration
    • after working on the switch cabinet
    • during ongoing operation (recommendation: at least every 6 months)
    A battery charge of min. 30% is recommended for test mode.
    A description of how to run the test mode can be found in the checklist – Backup power (https://www.fronius.com/de/download-center?searchword=42,0426,0365).
    Appendix
    Service, maintenance and disposal
    General
    The inverter is designed so that it does not require additional maintenance work. Nevertheless, a few points must be considered during operation to ensure that the inverter works perfectly.
    1. Appendix
    General
    1. Appendix
    2. Service, maintenance and disposal
    General
    1. Appendix
    Maintenance
    Maintenance and service work may only be carried out by a technical specialist.
    1. Appendix
    Cleaning
    Wipe the inverter, if necessary, with a damp cloth.
    Do not use cleaning agents, scouring agents, solvents, or similar products to clean the inverter.
    1. Appendix
    Safety
    The DC disconnector is used only to switch off power to the power stage set. When the DC disconnector is turned off, the connection area is still energized.
    WARNING
    Danger from mains voltage and DC voltage from PV modules.
    The connection area must only be opened by an authorized electrician.
    The separate power stage set area must only be opened by Fronius-trained service technicians.
    Prior to any connection work, ensure that the inverter is de-energized on the AC side and the DC side.
    WARNING
    Danger of residual voltage from capacitors.
    1. Appendix
    Operation in dusty environments
    NOTE
    If the inverter is operated in dusty environments, dirt may build up on the heat sink and fan.
    This may result in a loss of power due to insufficient cooling of the inverter.
    Make sure that the ambient air can always flow through the inverter's ventilation slots unimpeded.
    Remove any build-ups of dirt from the heat sink and the fan.
    Switch off power to the inverter and wait for the capacitors to discharge (2 minutes) and the fan to shut down.
    Turn the DC disconnector to the "off" switch setting.
    Loosen the screws on the underside of the housing cover by rotating them 180° to the left using a screwdriver (TX20). Then lift the housing cover away from the inverter at the bottom and detach from above.
    NOTE
    Risk due to damage to the fan bearing in the event of incorrect cleaning.
    Excessive speeds and the application of pressure to the fan bearing can cause damage.
    Block the fan and clean with compressed air.
    When using a cloth or brush, clean the fan without applying any pressure.
    Remove any build-up of dirt on the heat sink and fan using compressed air, a cloth, or a brush.
    To start up the inverter again, follow the steps listed above in reverse order.
    1. Appendix
    Disposal
    In accordance with the EU Directive and national law, the following products must be disposed of separately and recycled:
    • Waste electrical and electronic equipment
    • Used batteries (portable batteries, industrial batteries)
    Used equipment and batteries must be returned to the distributor or an authorized local collection system. Do not dispose of batteries with domestic waste. Protect batteries from high temperatures, direct sunlight, moisture and corrosive environments.
    Arrange for the safe collection and proper disposal of damaged, leaking or used batteries by a battery recycling company or the Fronius Service Partner.
    In addition, it should be noted that batteries contain substances that, if disposed of improperly, can have a significant negative impact on the environment as well as on human health and the safety of persons, in particular due to the leakage of hazardous substances such as heavy metals or electrolytes, which can contaminate soil, water and air.
    This ensures environmental protection and the sustainable use of natural resources.
    Packaging materials
    • Collect separately
    • Observe local regulations
    • Compress the cardboard box to reduce volume
    1. Appendix
    Warranty provisions
    Warranty
    Detailed warranty conditions specific to your country can be found at https://www.fronius.com/en/download-center?searchword=Warranty+conditions .
    If there is a warranty for the relevant product, register the product at https://warranty.fronius.com/ and activate or extend the warranty.
    1. Appendix
    2. Warranty provisions
    Warranty
    1. Appendix
    Components for switching to backup power
    Components for automatic backup power changeover to Full Backup
    Fronius components
    With the Fronius components, no additional components are required for the automatic changeover to backup power. If components are not available depending on national availability, automatic changeover to backup power can be implemented with the following third-party components.
    Item number
    Fronius Backup Controller 3P-35A
    4,240,047,CK
    Fronius Backup Controller 3PN-35A
    4,240,048,CK
    Fronius Smart Meter IP 5kA-3
    42,0411,0347
    Fronius Smart Meter 63A-3
    43,0001,1473
    Fronius Smart Meter 50kA-3
    43,0001,1478
    Fronius Smart Meter TS 65A-3
    43,0001,0044
    Fronius Smart Meter TS 5kA-3
    43,0001,0046
    Fronius Smart Meter WR
    43,0001,3591
    Third-party components
    Manufacturers/types other than the product examples listed are permissible, provided that they meet the same technical and functional requirements.
    Grid and system protection
    Manufacturer/type
    Bender GmbH & Co. KG VMD460-NA-D-2
    Tele Haase Steuergeräte Ges.m.b.H. RE-NA003-M64
    K1 and K2 - AC installation contactor with auxiliary contact
    Number of pins
    3-pin or 4-pin
    (depending on the cabling variant)
    Rated current
    depending on the house connection
    Coil voltage
    230 VAC
    Rated frequency
    50/60 Hz
    Coil fuse
    6 A
    Minimum short circuit current
    3 kA (contacts)
    Test standard
    IEC 60947-4-1
    Auxiliary contact
    Number of NC contacts
    Switching voltage
    12 - 230 V @ 50 / 60 Hz
    Minimum nominal current
    1 A
    1 kA
    Manufacturer/type
    ISKRA IK63-40 / Schrack BZ326461
    Buffer power supply - Fault Ride Through cabling variant
    Manufacturer/type
    BKE JS-20-240/DIN_BUF
    K1 and K2 - DC installation contactor with auxiliary contact (Fault Ride Through)
    Number of pins
    3-pin or 4-pin
    Rated current
    Coil voltage
    24 VDC
    3 kA (contacts)
    Test standard
    IEC 60947-4-1
    Auxiliary contact
    Switching voltage
    24 VDC
    1 A
    1 kA
    Manufacturer/type
    Finder 22.64.0.024.4710
    K3 - Modular relay
    Number of changeover contacts
    Coil voltage
    12 VDC
    Test standard
    IEC 60947-4-1
    Manufacturer/type
    Finder 22.23.9.012.4000 / Schrack relay RT424012 (bracket RT17017, relay base RT78725)
    K4 and K5 - Installation contactor
    2 (25 A)
    Coil voltage
    230 V AC (2P)
    Rated frequency
    50/60 Hz
    Coil fuse
    6 A
    3 kA (contacts)
    Test standard
    IEC 60947-4-1
    Manufacturer/type
    ISKRA IKA225-02
    1. Appendix
    2. Components for switching to backup power
    Fronius components
    Item number
    4,240,047,CK
    4,240,048,CK
    42,0411,0347
    43,0001,1473
    43,0001,1478
    43,0001,0044
    43,0001,0046
    43,0001,3591
    Manufacturer/type
    Number of pins
    3-pin or 4-pin
    Rated current
    Coil voltage
    230 VAC
    Rated frequency
    50/60 Hz
    Coil fuse
    6 A
    3 kA (contacts)
    Test standard
    IEC 60947-4-1
    Auxiliary contact
    Switching voltage
    1 A
    1 kA
    Manufacturer/type
    Manufacturer/type
    Number of pins
    3-pin or 4-pin
    Rated current
    Coil voltage
    24 VDC
    3 kA (contacts)
    Test standard
    IEC 60947-4-1
    Auxiliary contact
    Switching voltage
    24 VDC
    1 A
    1 kA
    Manufacturer/type
    K3 - Modular relay
    Coil voltage
    12 VDC
    Test standard
    IEC 60947-4-1
    Manufacturer/type
    2 (25 A)
    Coil voltage
    230 V AC (2P)
    Rated frequency
    50/60 Hz
    Coil fuse
    6 A
    3 kA (contacts)
    Test standard
    IEC 60947-4-1
    Manufacturer/type
    ISKRA IKA225-02
    1. Appendix
    Components for manual backup power changeover to Full Backup
    Item number
    43,0001,1473
    43,0001,0044
    Fronius Backup Switch 1P/3P-63A
    4,050,221
    Fronius Backup Switch 1PN/3PN-63A
    4,050,220
    1. Appendix
    Status codes and remedy
    Display
    Status codes are displayed on the user interface of the inverter in the System > Event Log menu area or in the user menu under Notifications and in Fronius Solar.web*.
    If configured accordingly, see chapter Fronius Solar.web on page (→).
    1. Appendix
    2. Status codes and remedy
    Display
    1. Appendix
    Status codes
    1030 – WSD Open (operating LED: flashes red)
    Cause:A device that is connected in the WSD chain has interrupted the signal line (e.g., surge protection device) or the bypass installed ex works as standard has been removed and no trigger device has been installed.
    Remedy:If the SPD surge protection device has tripped, the inverter must be repaired by an authorized specialist.
    OR:Install the bypass installed ex works as standard or a trigger device.
    OR:Turn the WSD (wired shutdown) switch to position 1 (WSD primary device).
    WARNING
    Danger from work that is not carried out properly.
    The installation and connection of an SPD surge protection device may only be carried out by Fronius-trained service personnel in accordance with the technical specifications.
    Observe safety rules.
    1. Appendix
    Technical data
    Fronius Symo GEN24 6.0/6.0 Plus
    DC input data
    MPP voltage range
    (at rated power)
    174 - 800 V
    Maximum connected load (PPV max)
    Total
    PV 1
    PV 2
    9000 Wp
    7500 Wp
    6500 Wp
    Maximum processable PV power
    Total
    PV 1
    PV 2
    6220 Wp
    6220 Wp
    6000 Wp
    Maximum input voltage
    at 1000 W/m²/-10 °C in an open circuit
    1000 V
    Feed-in start voltage in grid operation 5)
    80 V
    Maximum input current
    PV 1
    PV 2
    25.0 A
    12.5 A
    Maximum short circuit current for module array (ISC PV)
    PV 1
    PV 2
    40 A
    20 A
    Maximum total short circuit current for module array
    (ISC PV1 + ISC PV2 = ISC max)
    60 A
    Max. inverter backfeed current to the array 3)
    PV 1
    PV 2
    40 A
    20 A
    Number of inputs—PV 1
    Number of inputs—PV 2
    Maximum capacity of the PV generator against ground
    1200 nF
    Limit value of the insulation resistance test between module array and ground (on delivery) 10)
    100 kΩ
    Adjustable range of insulation resistance test between module array and ground 9)
    10-10,000 kΩ
    Limit value and trip time of sudden residual fault current monitoring (on delivery)
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    Limit value and trip time of continuous residual fault current monitoring (on delivery)
    300/300 mA/ms
    Adjustable range of continuous residual current monitoring 9)
    30-300 mA
    Cyclic repetition of the insulation resistance test (on delivery)
    24 h
    Adjustable range for cyclic repetition of the insulation resistance test
    DC input data battery 8)
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    6000 W
    DC inputs
    AC input/output data
    Rated power (Pnom)
    6000 W
    Maximum output power
    6000 W
    Rated apparent power
    6000 VA
    Nominal mains voltage
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    Minimum mains voltage
    154 V 1)
    Maximum mains voltage
    280 V 1)
    Maximum output current
    16.4 A
    Rated output current
    (at 230 V)
    8.7 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    Initial symmetrical short-circuit current/phase IK"
    16.4 A
    Nominal frequency for Full Backup
    53/63 Hz 1)
    Total harmonic distortion
    < 3.5%
    Power factor cos phi 2)
    0-1 (adjustable)
    0.7-1 (recommended)
    Maximum permitted grid impedance Zmax on PCC 4)
    None
    Maximum output fault current / duration
    80.7 A/10 ms
    AC output data PV Point/PV Point Comfort
    4133 W (for 5 s)
    Nominal output power
    3000 W
    13 A
    1 ~ NPE 220 V/230 V/240 V
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    AC output data Full Backup 8)
    12,400 W (for 5 s)
    Maximum output power (per phase)
    4133 W (for 5 s)
    6000 W
    Nominal output power (per phase) 7)
    3680 W
    (per phase)
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.2%
    Europ. efficiency (Umpp nom)
    97.7%
    Europ. efficiency (Umpp max)
    97.3%
    Europ. efficiency (Umpp min)
    96.5%
    Self-consumption at night
    ≤ 10 W
    Cooling
    Controlled forced-air ventilation
    Ingress protection rating
    IP 66
    Dimensions H × W × D
    595 × 529 × 180 mm
    Weight
    23.4 kg
    Inverter topology
    Non-insulated, no transformer
    Permitted ambient temperature
    -25 °C - +60 °C
    Permissible humidity
    0-100% (incl. condensation)
    EMC emission class
    (in accordance with IEC 61000‑6‑2, IEC 61000‑6‑3)
    B
    DC/AC overvoltage category
    (in accordance with IEC 62109-1)
    2/3
    Pollution degree
    Sound pressure level
    47 dB(A) (ref. 20µPA)
    Protective class
    Protective devices
    DC isolation measurement
    Warning/shutdown at RISO < 100 kOhm
    Overload performance
    Operating point shift, power limit
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    The software class of the safety platform(s) is defined as a class B control function (single-channel with periodic self-test) in accordance with IEC 60730 Annex H.
    Active anti-islanding method
    Frequency point shift method
    Data communication
    WiFi SMA-RP connection
    (FCC ID: QKWPILOT1/IC 12270A-PILOT1)
    802.11b/g/n (WPA, WPA2)
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    Wired shutdown (WSD)
    Max. 28 devices/WSD chain
    Max. distance between two devices = 100 m
    Modbus RTU SunSpec (2x)
    RS485 2-wire
    Battery connection
    Modbus O/RJ 45/12 V power supply
    Voltage level of digital inputs
    Low: min. 0 V-max. 1.8 V
    High: min. 4.5 V-max. 28.8 V
    Input currents of digital inputs
    depending on the input voltage;
    input resistance = 70 kOhm
    Total power for digital output (with internal supply)
    6 W at 12 V
    Power per digital output
    (with external supply)
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Datalogger/web server
    Integrated
    1. Appendix
    2. Technical data
    DC input data
    MPP voltage range
    (at rated power)
    174 - 800 V
    Total
    PV 1
    PV 2
    9000 Wp
    7500 Wp
    6500 Wp
    Total
    PV 1
    PV 2
    6220 Wp
    6220 Wp
    6000 Wp
    1000 V
    80 V
    PV 1
    PV 2
    25.0 A
    12.5 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    1200 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    6000 W
    DC inputs
    Rated power (Pnom)
    6000 W
    6000 W
    6000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    16.4 A
    (at 230 V)
    8.7 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    16.4 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4133 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,400 W (for 5 s)
    4133 W (for 5 s)
    6000 W
    3680 W
    (per phase)
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.2%
    97.7%
    97.3%
    96.5%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    23.4 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 6.0 SC / 6.0 Plus SC
    DC input data
    MPP voltage range
    (at rated power)
    148 - 800 V
    Total
    PV 1
    PV 2
    9000 Wp
    7500 Wp
    7500 Wp
    Total
    PV 1
    PV 2
    6180 Wp
    6180 Wp
    6180 Wp
    (at 1000 W/m²/-10 °C in an open circuit)
    1000 V
    Minimum input voltage
    80 V
    80 V
    PV 1
    PV 2
    28.0 A
    14.0 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    Total
    PV 1
    PV 2
    1200 nF
    1000 nF
    1000 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    6000 W
    DC inputs
    Rated power (Pnom)
    6000 W
    6000 W
    6000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    18.5 A
    Rated output current (at 230 V)
    8.7 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    18.5 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4255 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,765 W (for 5 s)
    4255 W (for 5 s)
    6000 W
    4133 W
    Rated output current (per phase)
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.3%
    97.9%
    97.6%
    96.3%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    22.8 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    47 dB(A) (ref. 20 µPA)
    Protective class
    Protective devices
    DC isolation measurement 11)
    DC disconnector
    Integrated
    RCMU 11)
    Integrated
    RCMU classification
    AFCI
    Integrated
    AFPE (AFCI) classification (according to IEC 63027) 11)
    = F-I-AFPE-1-3-1
    Full coverage
    Integrated
    AFPE
    1 monitored string per input port
    3 input ports per channel (MPP1: 2, MPP2: 1)
    1 monitored channel
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 8.0/8.0 Plus
    DC input data
    MPP voltage range
    (at rated power)
    224 - 800 V
    Total
    PV 1
    PV 2
    12,000 Wp
    10,000 Wp
    7000 Wp
    Total
    PV 1
    PV 2
    8260 Wp
    8260 Wp
    6000 Wp
    1000 V
    80 V
    PV 1
    PV 2
    25.0 A
    12.5 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    1600 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    8000 W
    DC inputs
    Rated power (Pnom)
    8000 W
    8000 W
    8000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    16.4 A
    (at 230 V)
    11.6 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    16.4 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4133 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,400 W (for 5 s)
    4133 W (for 5 s)
    8000 W
    3680 W
    (per phase)
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.2%
    97.8%
    97.5%
    96.9%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    23.4 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 8.0 SC / 8.0 Plus SC
    DC input data
    MPP voltage range
    (at rated power)
    197 - 800 V
    Total
    PV 1
    PV 2
    12,000 Wp
    10,000 Wp
    8500 Wp
    Total
    PV 1
    PV 2
    8240 Wp
    8240 Wp
    8240 Wp
    1000 V
    80 V
    80 V
    PV 1
    PV 2
    28.0 A
    14.0 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    Total
    PV 1
    PV 2
    1600 nF
    1330 nF
    1130 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    8000 W
    DC inputs
    Rated power (Pnom)
    8000 W
    8000 W
    8000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    18.5 A
    11.6 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    18.5 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4255 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,765 W (for 5 s)
    4255 W (for 5 s)
    8000 W
    4133 W
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.3%
    98.0%
    97.8%
    96.7%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    22.8 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    AFCI
    Integrated
    = F-I-AFPE-1-3-1
    Full coverage
    Integrated
    AFPE
    1 monitored channel
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 10.0/10.0 Plus
    DC input data
    MPP voltage range
    (at rated power)
    278 - 800 V
    Total
    PV 1
    PV 2
    15,000 Wp
    12,500 Wp
    7500 Wp
    Total
    PV 1
    PV 2
    10,300 Wp
    10,300 Wp
    6000 Wp
    1000 V
    80 V
    PV 1
    PV 2
    25.0 A
    12.5 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    2000 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    10,000 W
    DC inputs
    Rated power (Pnom)
    10,000 W
    10,000 W
    10,000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    154 V 1)
    280 V 1)
    16.4 A
    (at 230 V)
    14.5 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    16.4 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4133 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,400 W (for 5 s)
    4133 W (for 5 s)
    10,000 W
    (per phase) 7)
    3680 W
    (per phase)
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.2%
    97.9%
    97.7%
    97.1%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    23.4 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 10.0 SC / 10.0 Plus SC
    DC input data
    MPP voltage range
    (at rated power)
    246 - 800 V
    Total
    PV 1
    PV 2
    15,000 Wp
    12,500 Wp
    9000 Wp
    Total
    PV 1
    PV 2
    10,300 Wp
    10,300 Wp
    8600 Wp
    1000 V
    80 V
    80 V
    PV 1
    PV 2
    28.0 A
    14.0 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    Total
    PV 1
    PV 2
    2000 nF
    1660 nF
    1200 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    10,000 W
    DC inputs
    Rated power (Pnom)
    10,000 W
    10,000 W
    10,000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    18.5 A
    14.5 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    18.5 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4255 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,765 W (for 5 s)
    4255 W (for 5 s)
    10,000 W
    4133 W
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.3%
    98.1%
    97.9%
    97.0%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    22.8 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    AFCI
    Integrated
    = F-I-AFPE-1-3-1
    Full coverage
    Integrated
    AFPE
    1 monitored channel
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 10.0 SC/10.0 Plus SC
    (Australia only)
    DC input data
    MPP voltage range
    (at rated power)
    246 - 800 V
    Total
    PV 1
    PV 2
    15,000 Wp
    12,500 Wp
    9000 Wp
    Total
    PV 1
    PV 2
    10,300 Wp
    10,300 Wp
    8600 Wp
    1000 V
    80 V
    80 V
    PV 1
    PV 2
    28.0 A
    14.0 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    Total
    PV 1
    PV 2
    2000 nF
    1660 nF
    1200 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    10,000 W
    DC inputs
    Rated power (Pnom)
    9999 W
    9999 W
    9999 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    18.5 A
    14.5 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    18.5 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4255 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,765 W (for 5 s)
    4255 W (for 5 s)
    9999 W
    4133 W
    16 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.3%
    98.1%
    97.9%
    97.0%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    22.8 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    AFCI
    Integrated
    = F-I-AFPE-1-3-1
    Full coverage
    Integrated
    AFPE
    1 monitored channel
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    Fronius Symo GEN24 12.0 SC / 12.0 Plus SC
    DC input data
    MPP voltage range
    (at rated power)
    295 - 800 V
    Total
    PV 1
    PV 2
    18,000 Wp
    14,000 Wp
    9000 Wp
    Total
    PV 1
    PV 2
    12,360 Wp
    12,360 Wp
    8600 Wp
    1000 V
    80 V
    80 V
    PV 1
    PV 2
    28.0 A
    14.0 A
    PV 1
    PV 2
    40 A
    20 A
    60 A
    PV 1
    PV 2
    40 A
    20 A
    Total
    PV 1
    PV 2
    2400 nF
    1860 nF
    1200 nF
    100 kΩ
    10-10,000 kΩ
    30/300 mA/ms
    60/150 mA/ms
    90/40 mA/ms
    300/300 mA/ms
    30-300 mA
    24 h
    Maximum voltage
    700 V
    Minimum voltage
    160 V
    Maximum current
    22 A
    Maximum output
    12,000 W
    DC inputs
    Rated power (Pnom)
    12,000 W
    12,000 W
    12,000 VA
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    Grounding systems
    TN-S (allowed)
    TN-C-S (allowed)
    IT (not allowed)
    154 V 1)
    280 V 1)
    18.5 A
    17.4 A
    Current (inrush) 6)
    9.9 A/4 ms
    Nominal frequency
    50/60 Hz 1)
    18.5 A
    53/63 Hz 1)
    < 3.5%
    0-1 (adjustable)
    0.7-1 (recommended)
    None
    80.7 A/10 ms
    4255 W (for 5 s)
    3000 W
    13 A
    Nominal frequency
    53/63 Hz 1)
    Switching time
    ~ 15 s
    0 - 1
    12,765 W (for 5 s)
    4255 W (for 5 s)
    12,000 W
    4133 W
    17.4 A
    3 ~ NPE 220 V/380 V
    3 ~ NPE 230 V/400 V
    53/63 Hz 1)
    Switching time
    ~ 10 s
    Switching time with
    Rapid switch mode
    < 20 ms
    0 - 1
    General data
    Maximum efficiency
    98.2%
    97.9%
    97.5%
    97.0%
    ≤ 10 W
    Cooling
    IP 66
    595 × 529 × 180 mm
    Weight
    22.8 kg
    Inverter topology
    -25 °C - +60 °C
    EMC emission class
    B
    2/3
    Pollution degree
    Protective class
    Protective devices
    DC disconnector
    Integrated
    RCMU
    Integrated
    RCMU classification
    AFCI
    Integrated
    = F-I-AFPE-1-3-1
    Full coverage
    Integrated
    AFPE
    1 monitored channel
    Data communication
    Frequency: 2.4 GHz
    Ethernet (LAN)
    RJ 45, 10/100 Mbit
    RS485 2-wire
    Battery connection
    6 W at 12 V
    1 A at >12.5 V-24 V
    (max. 3 A in total)
    Integrated
    1. Appendix
    2. Technical data
    WLAN
    Frequency range
    2412 - 2462 MHz
    Channels / power used
    Channel: 1-11 b,g,n HT20
    Channel: 3-9 HT40
    <18 dBm
    Modulation
    802.11b: DSSS (1Mbps DBPSK, 2Mbps DQPSK, 5.5/11Mbps CCK)
    802.11g: OFDM (6/9Mbps BPSK, 12/18Mbps QPSK, 24/36Mbps 16-QAM, 48/54Mbps 64-QAM)
    802.11n: OFDM (6.5 BPSK, QPSK, 16-QAM, 64-QAM)
    1. Appendix
    2. Technical data
    Technical data of surge protection device DC SPD type 1+2 GEN24
    General data
    Continuous operating current (Icpv)
    < 0.1 mA
    Rated discharge current (In)
    - 15 x 8/20 µs pulses
    20 kA
    Lightning surge current (limp)
    Max. discharge capacity @ 10/350 µs
    6.25 kA
    Protection level (Up)
    (star-shaped mounting)
    4 kV
    Short circuit strength PV (Iscpv)
    15 kA
    Disconnector
    Thermal disconnector
    Integrated
    External fuse
    None
    Mechanical properties
    Disconnection indicator
    Mechanical indicator (red)
    Remote communication of the connection interruption
    Output on the changeover contact
    Housing material
    Thermoplastic UL-94-V0
    Test standards
    IEC 61643-31 / DIN EN 50539-11
    UL1449 ed.4 / VDE 0185-305-3 Bbl. 5
    1. Appendix
    2. Technical data
    Explanation of footnotes
    1)
    The values provided are standard values. If required, the inverter is customized for a specific country.
    2)
    Depending on the country setup or device-specific settings
    (ind. = inductive; cap. = capacitive).
    3)
    Maximum current from a defective PV module to all other PV modules. From the inverter itself to the PV side of the inverter, this is 0 A.
    4)
    Assured by the electrical design of the inverter.
    5)
    For backup power mode (PV Point) without a battery, a min. voltage of 150 V is required.
    6)
    Peak current when turning on the inverter.
    7)
    The total nominal output power per phase must not exceed the nominal output power of the inverter.
    8)
    Valid for Fronius inverter with battery support.
    9)
    The values provided are standard values. These values must be adjusted according to requirements and PV output.
    10)
    The value provided is a max. value. If this value is exceeded, this may impair the function.
    1. Appendix
    2. Technical data
    Integrated DC disconnector
    Symo GEN24 3-10 kW Plus
    General data
    Product name
    Benedict LS32 E 7905
    Rated insulation voltage
    1000 VDC
    Rated impulse withstand voltage
    8 kV
    Suitability for insulation
    Yes, DC only
    Utilization category and/or PV utilization category
    according to IEC/EN 60947-3 utilization category DC-PV2
    Rated short-time withstand current (Icw)
    Rated short-time withstand current (Icw): 1000 A
    Rated short-circuit capacity (Icm)
    Rated short-circuit capacity (Icm): 1000 A
    Rated operating current and rated breaking capacity
    Rated operating voltage (Ue)
    Rated operating current (Ie)
    I(make) / I(break)
    I(make) / I(break)
    ≤ 500 VDC
    14 A
    56 A
    36 A
    144 A
    600 VDC
    8 A
    32 A
    30 A
    120 A
    700 VDC
    3 A
    12 A
    26 A
    88 A
    800 VDC
    3 A
    12 A
    17 A
    68 A
    900 VDC
    2 A
    8 A
    12 A
    48 A
    1000 VDC
    2 A
    8 A
    6 A
    24 A
    Number of pins
    Symo GEN24 3-12 kW Plus SC
    General data
    Product name
    Benedict LSA32 E 8229
    1000 VDC
    6 kV
    Yes, DC only
    I(make) / I(break)
    I(make) / I(break)
    300 VDC
    27 A
    108 A
    47 A
    188 A
    400 VDC
    20 A
    80 A
    45 A
    180 A
    500 VDC
    14 A
    56 A
    38 A
    152 A
    600 VDC
    11.5 A
    46 A
    33 A
    132 A
    700 VDC
    7.5 A
    30 A
    28 A
    112 A
    800 VDC
    5.75 A
    23 A
    23 A
    92 A
    900 VDC
    4.75 A
    19 A
    20 A
    80 A
    1000 VDC
    4 A
    16 A
    13 A
    52 A
    Number of pins
    System circuit diagrams
    Fronius Symo GEN24 and Fronius Reserva
    1. System circuit diagrams
    Fronius Symo GEN24 with Fronius Reserva connected in parallel
    Fronius Symo GEN24 and Fronius Reserva Pro
    Fronius Symo GEN24 with Fronius Reserva Pro connected in parallel
    Fronius Symo GEN24 and BYD Battery-Box Premium HV
    Fronius Symo GEN24 with two BYD Battery-Box Premium HV connected in parallel
    Fronius Symo GEN24 with three BYD Battery-Box Premium HV connected in parallel
    Fronius Symo GEN24 and BYD Battery-Box HVS+/HVM+
    Fronius Symo GEN24 with BYD Battery-Box HVS+/HVM+ connected in parallel
    Fronius Symo GEN24 and LG FLEX
    Circuit diagrams—PV Point
    Emergency power terminal—PV Point (OP)
    1. Circuit diagrams—PV Point
    Circuit diagram - PV Point (OP) Australia
    Backup power terminal - PV Point (OP) with battery only for France
    Backup power terminal - PV Point (OP) manual changeover
    PV Point Comfort
    Circuit diagrams—automatic switch to backup power with Fronius Backup Controller
    Fronius Backup Controller 3-pin separation, e.g., Austria
    1. Circuit diagrams—automatic switch to backup power with Fronius Backup Controller
    Fronius Backup Controller 3-pin separation, parallel backup
    Fronius Backup Controller 4-pin separation, e.g., Germany
    Circuit diagrams—automatic switch to backup power with third-party components
    Automatic switch to backup power 3-pin single FRT-capable separation - e.g., Austria
    1. Circuit diagrams—automatic switch to backup power with third-party components
    Automatic switch to backup power 3-pin single separation - e.g., Australia
    Automatic switch to backup power 3-pin double separation with ext. grid and system protection
    Automatic switch to backup power 4-pin single separation - e.g., Germany
    Automatic switch to backup power 4-pin single FRT-capable separation
    Automatic switch to backup power 4-pin single separation - e.g., France
    Automatic switch to backup power 4-pin single separation - e.g., Spain
    Automatic switch to backup power 4-pin double separation with ext. grid and system protection - e.g., Italy
    Circuit diagrams—manual switch to backup power with Fronius Backup Switch
    Manual switch to backup power 3-pin separation, e.g., Austria
    1. Circuit diagrams—manual switch to backup power with Fronius Backup Switch
    Manual switch to backup power 3-pin separation with grid and system protection
    Manual switch to backup power 4-pin separation, e.g., Germany
    Dimensions of the inverter
    Fronius Symo GEN24 6 - 10 kW/Symo GEN24 6 - 12 kW SC
    1. Dimensions of the inverter
