Indicates an immediate danger.
Indicates a possibly dangerous situation.
Indicates the possibility of flawed results and damage to the equipment.
The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, all applicable local rules and regulations regarding accident prevention and environmental protection must also be followed.
All safety and danger notices on the device mustFor the location of the safety and danger notices on the device, refer to the section headed "General" in the Operating Instructions for the device.
Before switching on the device, remove any faults that could compromise safety.
The device is intended exclusively for the welding process specified on the rating plate.
Utilization for any other purpose, or in any other manner, shall be deemed to be "not in accordance with the intended purpose." The manufacturer is not responsible for any damage resulting from improper use.
The device is designed for operation in industry and business. The manufacture shall not be liable for any damage resulting from use in a living area.
The manufacture shall also not be liable for faulty or incorrect work results.
Temperature range of the ambient air:Ambient air: free of dust, acids, corrosive gases or substances, etc.
Altitude above sea level: up to 2000 m (6561 ft. 8.16 in.)
The safety-conscious work of the personnel must be checked regularly.
Before leaving the workplace, ensure that no personal injury or property damage can occur in one's absence.
Devices with a high output can influence the energy quality of the grid due to their current consumption.
This may affect a number of device types in terms of:*) both at the interface with the public grid
See technical data
In this case, the operator or the person using the device should check whether or not the device is allowed to be connected, where appropriate through discussion with the power supply company.
IMPORTANT! Ensure secure grounding of the grid connection!
The fumes produced during welding contain toxic gases and vapors.
Welding fumes contain substances that cause cancer, as stated in monograph 118 from the International Agency for Research on Cancer.
Use at-source extraction source and a room extraction system.
If possible, use a welding torch with an integrated extraction device.
Keep your head out of the welding fumes and gases.
Take the following precautionary measures for fumes and harmful gases:Ensure that there is a sufficient supply of fresh air. Ensure that there is a ventilation flow rate of at least 20 m³ per hour.
Use a welding helmet with air supply if there is insufficient ventilation.
If there is uncertainty as to whether the extraction capacity is sufficient, compare the measured toxic emission values against the permissible limit values.
The following components are factors that determine how toxic the welding fumes are:Consult the corresponding material safety data sheets and manufacturer's instructions for the components listed above.
Recommendations for exposure scenarios, risk management measures and identifying working conditions can be found on the European Welding Association website under Health & Safety (https://european-welding.org).
Keep flammable vapors (such as solvent vapors) out of the arc radiation range.
When no welding is taking place, close the valve of the shielding gas cylinder or the main gas supply.
Flying sparks can cause fires and explosions.
Never undertake welding near flammable materials.
Flammable materials must be kept at least 11 meters (36 ft. 1.07 in.) from the arc or protected with a certified cover.
Keep suitable, tested fire extinguishers on hand.
Sparks and pieces of hot metal may also get into surrounding areas through small cracks and openings. Take appropriate measures to ensure that there is no risk of injury or fire.
Do not undertake welding in areas at risk of fire and explosion, or on sealed tanks, drums, or pipes if these have not been prepared in accordance with corresponding national and international standards.
Do not undertake welding on containers in which gases, fuels, mineral oils, and the like are/were stored. Residues pose a risk of explosion.
Do not touch voltage-carrying parts inside or outside the device.
During MIG/MAG welding and TIG welding, the welding wire, the wirespool, the feed rollers, as well as all pieces of metal that are in contact with the welding wire, are live.
Always place the wirefeeder on a sufficiently insulated base or use a suitable insulating wirefeeder holder.
Ensure suitable personal protection with dry temporary backing or cover with sufficient insulation against the ground potential. The temporary backing or cover must completely cover the entire area between the body and the ground potential.
All cables and leads must be secured, undamaged, insulated, and adequately dimensioned. Replace loose connections and scorched, damaged, or inadequately dimensioned cables and leads immediately.
Before every use, check power connections for secure fit by hand.
In the case of power cables with bayonet connectors, turn the power cable by at least 180° around the longitudinal axis and pretension.
Do not wrap cables or leads around your body or parts of the body.
Concerning the electrode (rod electrode, tungsten electrode, welding wire, etc.)The open circuit voltage of a welding system may double, for example, between the electrodes of two welding systems. Touching the potentials of both electrodes at the same time may be life-threatening in some cases.
Have the grid and device supply lead regularly inspected by an electrician to ensure that the ground conductor is functioning properly.
Protection class I devices require a grid with a ground conductor and a connector system with ground conductor contact for proper operation.
Operation of the device on a grid without a ground conductor and on a socket without a ground conductor contact is only permitted if all national regulations for protective separation are observed.
Otherwise, this is considered gross negligence. The manufacturer accepts no liability for any damage resulting from improper use.
Use suitable equipment to ensure that the workpiece is sufficiently grounded if necessary.
Switch off unused devices.
When working at elevated heights, wear a safety harness to prevent falls.
Before working on the device, switch off the device and remove the grid plug.
Secure the device to prevent the grid plug from being connected and switched on again by applying a clearly legible and understandable warning sign.
After opening the device:If work is needed on voltage-carrying parts, bring in a second person who will switch off the main switch at the correct time.
Ensure that the workpiece clamp is securely connected to the workpiece.
Secure the workpiece clamp as close to the spot to be welded as possible.
Position the device with sufficient insulation against electrically conductive environments, e.g., insulation against electrically conductive floors or electrically conductive mounts.
Observe the following when using power distribution boards, twin-head mounts, etc.: Even the electrode of the welding torch/electrode holder not in use carries electric potential. Ensure that there is sufficient insulation when the unused welding torch/electrode holder is stored.
In automated MIG/MAG applications, only guide the wire electrode from the welding wire drum, large spool, or wirespool to the wirefeeder with insulation.
In certain cases, even though a device complies with the standard limit values for emissions, it may affect the application area for which it was designed (e.g., when there is sensitive equipment at the same location, or if the site where the device is installed is close to either radio or television receivers).
Do not reach into rotating gears of the wire drive or into rotating drive parts.
Covers and side panels must only be opened/removed during maintenance and repair work.
During operationThe protrusion of welding wire from the welding torch represents a high risk of injury (cuts to the hand, facial and eye injuries, etc.).
Therefore, always hold the welding torch away from the body (devices with wirefeeder) and use suitable protective goggles.
Do not touch the workpiece during or after welding – risk of burns.
Slag may fly off cooling workpieces. Therefore, also wear regulation-compliant protective equipment when reworking workpieces and ensure that other persons are sufficiently protected.
Leave the welding torch and other parts with a high operating temperature to cool before working on them.
Special regulations apply in areas at risk of fire or explosion
– follow the appropriate national and international regulations.
Power sources for work in areas with increased electrical hazard (e.g., boilers) must be labeled with the symbol (Safety). However, the power source may not be located in such areas.
Risk of scalding due to leaking coolant. Switch off the cooling unit before disconnecting connections for the coolant supply or return.
When handling coolant, observe the information on the coolant safety data sheet. The coolant safety data sheet can be obtained from your service center or via the manufacturer's website.
Only use suitable load-carrying equipment from the manufacturer to transport devices by crane.
In the event of crane attachment of the wirefeeder during welding, always use a suitable, insulating wirefeeder hoisting attachment (MIG/MAG and TIG devices).
If the device is equipped with a carrier belt or handle, then this is used exclusively for transport by hand. The carrier belt is not suitable for transport by crane, counterbalanced lift truck, or other mechanical lifting tools.
All lifting equipment (belts, buckles, chains, etc.), which is used in association with the device or its components, must be checked regularly (e.g., for mechanical damage, corrosion, or changes due to other environmental influences).
The test interval and scope must at least comply with the respective valid national standards and guidelines.
There is a risk of colorless, odorless shielding gas escaping without notice if an adapter is used for the shielding gas connection. Use suitable Teflon tape to seal the thread of the shielding gas connection adapter on the device side before installation.
Use filters if necessary.
Shielding gas cylinders contain compressed gas and may explode if damaged. Shielding gas cylinders are an integral part of the welding equipment, so they must be handled very carefully.
Protect shielding gas cylinders with compressed gas from excessive heat, mechanical impact, slag, open flames, sparks, and arcs.
Mount the shielding gas cylinders vertically and secure them in accordance with instructions so they cannot fall over.
Keep shielding gas cylinders away from welding or other electrical circuits.
Risk of explosion: Never weld on a compressed shielding gas cylinder.
Always use suitable shielding gas cylinders for the application in question and the correct matching accessories (controller, hoses, and fittings, etc.) Only use shielding gas cylinders and accessories that are in good condition.
If a valve on a shielding gas cylinder is open, turn your face away from the outlet.
When no welding is taking place, close the valve of the shielding gas cylinder.
Leave the cap on the valve of the shielding gas cylinder when the cylinder is not connected.
Follow the manufacturer's instructions and applicable national and international provisions for shielding gas cylinders and accessories.
Risk of asphyxiation due to uncontrolled shielding gas leak
Shielding gas is colorless and odorless and may suppress the oxygen in the ambient air in the event of leakage.
Use instructions and checks within the company to ensure that the vicinity of the workplace is always clean and organized.
Only set up and operate the device in accordance with the protection class shown on the rating plate.
When setting up the device, ensure that there is an all-round clearance of 0.5 m (1 ft. 7.69 in.) to allow cooling air to circulate unhindered.
Take care to ensure that the applicable national and regional guidelines and accident prevention regulations are observed when transporting the device, especially guidelines concerning hazards during transport and shipment.
Do not lift or transport any active devices. Switch off devices before transport or lifting.
Before transporting the device, completely drain the coolant and dismantle the following components:It is essential to conduct a visual inspection of the device to check for damage after it has been transported but before commissioning. Have any damage repaired by trained service technicians before commissioning the device.
Safety devices that are not fully functional must be repaired before the device is switched on.
Before switching on the device, ensure that no one can be put in danger.
The device must be examined at least once a week for externally detectable damage and functionality of the safety devices.
Always secure the shielding gas cylinder well and remove before transporting by crane.
Only the original coolant from the manufacturer is suitable for use in our devices due to its properties (electrical conductivity, anti-freeze, material compatibility, flammability, etc.)
Only use appropriate original coolant from the manufacturer.
Do not mix original coolant from the manufacturer with other coolants.
Only connect system components from the manufacturer to the cooling unit circuit.
If there is damage due to use of other system components or other coolants, the manufacturer accepts no liability for this and all warranty claims are forfeited.
Cooling Liquid FCL 10/20 is not flammable. The ethanol-based coolant is flammable in certain conditions. Only transport the coolant in closed original containers and keep away from sources of ignition.
Properly dispose of used coolant according to national and international regulations. The coolant safety data sheet can be obtained from your service center or via the manufacturer’s website.
When the system is cool, always check the coolant level before starting welding.
The manufacturer recommends that a safety inspection of the device be performed at least every 12 months.
The manufacturer recommends calibrating power sources within the same 12-month interval.
A safety inspection by a certified electrician is recommended:For the safety inspection, follow the appropriate national and international standards and guidelines.
You can obtain more information about the safety inspection and calibration from your service center. The service center will provide the necessary documents upon request.
To comply with European directives and national law, waste electrical and electronic equipment must be collected separately and sent for environmentally-friendly recycling. Used devices must be returned to a distributor or an approved collection and recycling facility in your area. Proper disposal of used devices promotes the sustainable recycling of material resources. Ignoring this may have potentially adverse effects on the environment and your health.
Packaging materials
Materials collected separately. Check the regulations in your area. Reduce the volume of cardboard.
Devices with the CE label satisfy the essential requirements of the low-voltage and electromagnetic compatibility directive (e.g., relevant product standards of the EN 60974 series).
Fronius International GmbH declares that the device complies with Directive 2014/53/EU. The full text of the EU Declaration of Conformity is available on the following website: http://www.fronius.com
The user is responsible for backing up any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
Copyright of these Operating Instructions remains with the manufacturer.
Text and illustrations were accurate at the time of printing. Fronius reserves the right to make changes. The contents of the Operating Instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the Operating Instructions, we will be most grateful for your comments.
The TransSteel (TSt) 2700c MP and TSt 3500c MP power sources are fully digitized, microprocessor-controlled inverter power sources.
A modular design and easy ability to extend the system guarantee a high degree of flexibility. The devices are designed for the welding of steel.
The following welding processes are available on the power sources:
MIG/MAG welding
Manual metal arc welding
TIG welding with touchdown ignition
The central control and regulation unit of the power sources is coupled with a digital signal processor. The central control and regulation unit and signal processor control the entire welding process.
During the welding process, the actual data is measured continuously and the device responds immediately to any changes. Control algorithms ensure that the desired status is maintained.
The device has a "Power limitation" safety feature. This means that the power source can be operated at the power limit without compromising process safety.
This results in:The devices are used in trade and industry for manual applications with classical steel and galvanized sheets.
The TSt 2700c MP is primarily used in light-gage steel sheet (light steelwork) applications.
Repair, maintenance, and assembly work in shipyards, automotive suppliers, workshops or the furniture construction industry are among the typical application areas. The TSt 2700c MP power source thus positions itself in its power category between the trade/workshop and the industry sector.
There are warning notices and safety symbols on the power sources. These warning notices and safety symbols must not be removed or painted over. They warn against incorrect operation, as this may result in serious injury and property damage.
Safety symbols on the rating plate:
Welding is dangerous. The following basic requirements must be met:
Warning notices are attached to the device for certain device versions.
The arrangement of the symbols may vary.
| ! | Warning! Caution! The symbols represent possible dangers. |
| A | Drive rollers can injure fingers. |
| B | The welding wire and drive parts are under welding voltage during operation. Keep hands and metal objects away! |
| 1. | An electric shock can be fatal. |
| 1.1 | Wear dry, insulating gloves. Do not touch the wire electrode with bare hands. Do not wear wet or damaged gloves. |
| 1.2 | Use a base that is insulated from the floor and work area to protect against electric shock. |
| 1.3 | Before working on the device, switch off the device and remove the mains plug or disconnect the power supply. |
| 2. | Inhalation of welding fumes can be harmful to health. |
| 2.1 | Keep your face away from any welding fumes. |
| 2.2 | Use forced-air ventilation or local extraction to remove welding fumes. |
| 2.3 | Remove welding fumes with a fan. |
| 3. | Welding sparks can cause an explosion or fire. |
| 3.1 | Keep flammable materials away from the welding process. Do not perform welding near flammable materials. |
| 3.2 | Welding sparks can cause a fire. Have fire extinguishers ready. If necessary, have a supervisor ready who can operate the fire extinguisher. |
| 3.3 | Do not weld on drums or closed containers. |
| 4. | Arc rays can burn the eyes and injure the skin. |
| 4.1 | Wear headgear and protective goggles. Use ear protection and wear a shirt collar with button. Use a welding helmet with the correct tinting. Wear suitable protective clothing over the entire body. |
| 5. | Before working on the machine or welding: undertake training on the device and read the instructions! |
| 6. | Do not remove or paint over the sticker with the warnings. |
| * | Manufacturer order number of the sticker |
The power sources can be operated with various system components and options. This makes it possible to optimize procedures and to simplify machine handling and operation, depending on the field of application for the power source.
Read and understand all safety rules and user documentation for this equipment and all system components.
| No. | Function |
| (1) | MIG/MAG welding torch |
| (2) | Stabilization of the gas cylinder holder |
| (3) | Power source |
| (4) | Trolley and gas cylinder holder |
| (5) | Grounding and electrode cable |
| (6) | TIG welding torch |
| No. | Function |
| (4) | Cooling unit only TSt 3500c |
| (5) | Trolley and gas cylinder holder |
| (6) | Grounding and electrode cable |
| (7) | TIG welding torch |
The functions are all arranged in a logical way on the control panel. The individual parameters required for welding can be
The power source uses the Synergic control panel and certain general items of data such as sheet thickness, filler metal, wire diameter and shielding gas to calculate the best welding parameters. As a result, stored expert knowledge is available at all times. All the parameters can be corrected manually. The Synergic control panel also allows entirely manual configuration of parameters.
Because of software updates, certain functions may be available for your device but not described in these Operating Instructions or vice versa.
In addition, individual figures may also differ slightly from the operating elements of your device. These operating elements function in exactly the same way, however.
Sheet thickness in mm or in. | |||||
Welding current in A *) | |||||
Wire speed in m/min or ipm *) | |||||
Arc length correction | |||||
Welding voltage in V *) | |||||
Arc-force dynamic | |||||
Real Energy Input | |||||
| MANUAL - MIG/MAG standard manual welding | ||||
| SYNERGIC - MIG/MAG standard synergic welding | ||||
| Manual metal arc welding | ||||
| TIG welding | ||||
| 2 T - 2-step mode | ||||
| 4 T - 4-step mode | ||||
| Special 4-step mode | ||||
| Spot welding/stitch welding | ||||
| *) | In the MIG/MAG standard synergic welding process, if one of these parameters is selected, then the synergic function ensures that all other parameters, including the welding voltage parameter, are adjusted automatically. |
| **) | The Real Energy Input indicator must be activated in level 2 of the Setup menu – EnE parameter. The value continuously rises during welding in line with the permanently increasing energy input. The final value is stored after welding ends until welding starts again or the power source is switched back on - the HOLD indicator lights up. |
Various service parameters can be retrieved by pressing the "Parameter selection" buttons at the same time.
Opening the display
The first parameter "Firmware version" will be displayed, e.g., "1.00 | 4.21"
Selecting parameters
Use the "Mode" and "Process" buttons or the left-hand selection dial to select the required setup parameter
Available parameters
Explanation | |
Example: | Firmware version |
Example: | Welding program configuration |
Example: | Number of the currently selected welding program |
Example: | Indicates the actual arc time since first use |
Example: | Motor current for wire drive in A |
2nd | Second menu level for service technicians |
A keylock can be selected to prevent the settings from being inadvertently changed on the control panel. As long as the keylock is active:
Activating/deactivating the keylock:
Keylock activated:
The message "CLO | SEd" appears on the displays.
Keylock deactivated:
The message "OP | En" appears on the displays.
The keylock can also be activated and deactivated using the keylock switch option.
| (1) | LocalNet connection Standardized connection for remote control |
| (2) | Welding torch connection For connecting the welding torch |
| (3) | TIG Multi Connector For connecting the TIG welding torch |
| (4) | (+) Current socket with bayonet latch Used for
| (5) | (-) Current socket with bayonet latch Used for
| (6) | Polarity reverser For selecting the welding potential on the MIG/MAG welding torch |
| (7) | MIG/MAG shielding gas connection socket For the shielding gas supply to the welding torch connection (2) |
| (8) | TIG shielding gas connection socket For the shielding gas supply for the (-) current socket (5) |
| (9) | Grid cable with strain relief device Not prefitted on all models |
| (10) | Power switch For switching the power source on and off |
| (11) | LED wirespool interior lighting with the setup parameter LED the turn-off time is adjustable |
| (12) | Wirespool holder with brake For holding standard wirespools with a max. diameter of 300 mm (11.81 in.) and a max. weight of 19 kg (41.89 lbs.) |
| (13) | 4-roller drive |
| (1) | (-) Current socket with bayonet latch Used for
| (4) | Power switch For switching the power source on and off |
| (5) | LocalNet connection Standardized connection for remote control |
| (6) | (+) Current socket with bayonet latch Used for
| (7) | Polarity reverser For selecting the welding potential on the MIG/MAG welding torch |
| (8) | MIG/MAG shielding gas connection socket For the shielding gas supply to the welding torch connection (2) |
| (9) | TIG shielding gas connection socket For the shielding gas supply for the (-) current socket (1) |
| (10) | EASY DOCUMENTATION label |
| (11) | Grid cable with strain relief device Not prefitted on all models |
Depending on the welding process, a minimum level of equipment is required to work with the power source.
The following describes the welding processes and the corresponding minimum equipment for welding operations.
Before starting work, switch off all devices and components involved, and disconnect them from the grid.
The power source is only intended for MIG/MAG, MMA and TIG welding. Any other use is deemed to be "not in accordance with the intended purpose." The manufacturer shall not be liable for any damage resulting from such improper use.
Intended use also means:The device can be set up and operated outdoors in accordance with degree of protection IP 23.
Direct moisture (e.g., from rain) must be avoided.
Danger from machines toppling over or falling.
Set up the device securely on an even, solid surface.
Check all screw connections are tightly fastened after installation.
Danger of electrical current due to electrically conductive dust in the device.
Only operate the device if an air filter is fitted. The air filter is a very important safety device for achieving IP 23 protection.
The ventilation channel is a very important safety device. When selecting the setup location, ensure that the cooling air can enter or exit unhindered through the vents on the front and back. Any electrically conductive dust (e.g., from grinding work) must not be allowed to be sucked into the device.
The devices are designed for the grid voltage stated on the rating plate. If the mains cable or mains plug has not been attached to your version of the appliance, these must be installed according to national standards. Fuse protection for the grid lead can be found in the technical data.
Danger due inadequately dimensioned electrical installations.
This can lead to serious damage
The grid lead and its fuse protection should be designed to suit the existing power supply.
The technical data on the rating plate should be followed.
The power source is generator-compatible.
The maximum apparent power S1max of the power source must be known in order to select the correct generator output.
The maximum apparent power S1max of the power source is calculated as follows:
Three-phase devices: S1max = I1max x U1 x √3
Single-phase devices: S1max = I1max x U1
I1max and U1 according to the device rating plate and technical data
The generator apparent power SGEN needed is calculated using the following rule of thumb:
SGEN = S1max x 1.35
A smaller generator can be used when not welding at full power.
IMPORTANT! The generator apparent power SGEN must not be less than the maximum apparent power S1max of the power source!
When single phase devices are being operated with a 3-phase generator, note that the stated apparent power of the generator is often just the total that can be present across all three phases of the generator. If necessary, obtain further information about the single-phase power of the generator from the generator manufacturer.
The voltage delivered by the generator must never fall outside of the mains voltage tolerance range.
The mains voltage tolerance is specified in the "Technical Data" section.
SGEN = S1max x 1.35
As an alternative to three-phase operation, the multivoltage variant (MV) of the power source enables a welding operation with limited power or duration from just a single-phase supply. The maximum possible welding power is limited by the dimensioning of the mains fuse protection, which determines the safety cut-out of the power source.
If the grid lead has a 20 A or 30 A fuse, the FUS parameter may be changed to 20 A or 30 A. Welding with a higher maximum power or for longer periods is therefore possible. The FUS welding parameter can be found in the Setup menu 2nd level and can be set when the US setting is enabled or a single-phase supply is being used (SEt welding parameter set to US).
In order to use the power source in single-phase operation, the following prerequisite must be fulfilled:
The following table shows which grid voltages and fuse ratings limit the welding current in single-phase operation:
Grid voltage | Welding process | D.C. [%] | Welding current limitation [A] |
230 V | MIG/MAG | 40 | 160 |
Rod electrode | 40 | 140 | |
TIG | 35 | 180 | |
230 V | MIG/MAG | 40 | 170 |
TIG | 35 | 210 | |
230 V | MIG/MAG | 40 | 180 |
Rod electrode | 40 | 150 | |
TIG | 35 | 220 | |
240 V | MIG/MAG | 40 | 180 |
Rod electrode | 40 | 40 | |
TIG | 35 | 220 | |
240 V | MIG/MAG | 40 | 200 |
Rod electrode | 40 | 180 | |
TIG | 35 | 260 | |
240 V | MIG/MAG | 40 | 220 |
TIG | 35 | 260 |
| D.C. | = Duty cycle |
| * | The 100% values relate to welding with no time limits and without cooling breaks. |
The welding current data applies at an ambient temperature of 40 °C (104 °F).
At a grid voltage of 240 V and a fuse rating of 30 A, the maximum value of 220 A is possible for MIG/MAG welding with a duty cycle of 40% for example.
In single-phase operation, a safety cut-out prevents the fuse from tripping at higher welding powers. The safety cut-out is active at fuse ratings of 15 A, 16 A and 20 A and determines the possible welding duration, without the fuse being tripped. If the precalculated weld time is exceeded, thus causing the welding current to switch off, the service code "toF" is displayed. A countdown immediately appears next to the "toF" indicator, which shows the remaining time until the power source is ready for welding again. After this time, the message disappears, and the power source is ready for operation again.
At a fuse rating of 30 A, the temperature monitoring for the power source ensures the welding current is promptly switched off. A service code from "to1" to "to7" is displayed. Detailed information on the service codes "to1" to "to7" can be found in the "Troubleshooting" chapter under "Displayed service codes". If there is no fault or the cooling components are not dirty, then the device will be ready for welding again after an appropriate welding pause.
TIG | 35 | 180 | |
TIG | 35 | 210 | |
TIG | 35 | 220 | |
TIG | 35 | 220 | |
TIG | 35 | 260 | |
TIG | 35 | 260 |
For single-phase operation, the "Technical Data" chapter specifies duty cycle values as a function of the fuse rating and the welding current. Although the percentages of these duty cycle values are also based on the ten-minute cycle explained in the "Technical Data" chapter for general duty cycles, the cooling phase of the fuse, however, is calculated at approx. 60 s only. Afterwards, the power source is once again ready for use.
Due to technical standards, in single-phase operation, the duty cycle is only specified up to the end (switch off) of the first welding cycle. If the relationship to the ten-minute cycle normally used when specifying the duty cycle was also established with respect to the cooling phases, in practice there would be longer welding phases than those stated. The values are actually based on cooling phases of approx. 60 s only, after which the power source is ready for further use.
The following example shows the welding and pause cycles as defined in the relevant standards, with a welding current of 180 A and a duty cycle of 15%.
The following diagram shows the possible welding time in accordance with standards, depending on the fuse rating and welding current.
(1) 10 A mains fuse protection (2) 13 A mains fuse protection (3) 15 A mains fuse protection
(4) 16 A mains fuse protection (5) 20 A mains fuse protection
Danger from work that is not carried out properly.
The work described below may only be performed by trained specialist personnel.
Follow national standards and guidelines.
Danger from improperly prepared mains cable.
Short circuits and damage to property may result.
Fit ferrules to all phase conductors and the ground conductor of the stripped mains cable.
A strain-relief device for the following cable cross-sections is fitted to the power source:
Power source | Cable cross-section |
TSt 2700c MP | AWG 14 to AWG 6 *) | 4G2.5 |
TSt 3500c MP | AWG 12 *) | 4G2.5 |
| *) | Canada / US cable type: Extra-hard usage |
Strain-relief devices for other cable cross-sections must be designed accordingly.
Power source | Grid voltage | Cable cross-section |
TSt 2700c MP | 1 x 230 / 240 V | AWG 14 (15 A) *) | 3G2.5 (16 A) |
TSt 2700c MP | 1 x 240 V | AWG 12 (20 A) *) | - |
TSt 2700c MP | 1 x 240 V | AWG 12 (30 A) *) | - |
TSt 2700c MP | 3 x 200 V | AWG 12 | 4G2.5 |
TSt 2700c MP | 3 x 230 / 240 V | AWG 14 | 4G2.5 |
TSt 2700c MP | 3 x 380 / 400 V | AWG 14 *) | 4G2.5 |
| 3 x 460 V | AWG 14 *) | 4G2.5 |
TSt 3500c MP | 3 x 380 / 400 V | AWG 12 *) | 4G2.5 |
| 3 x 460 V | AWG 12 *) | 4G2.5 |
The item numbers of the different cables can be found in the Spare Parts List.
American Wire Gauge
If no mains cable is connected, a mains cable that is suitable for the connection voltage must be fitted before start-up.
The ground conductor (PE) should be approx. 10 - 15 mm (0.4 - 0.6 in.) longer than the phase conductor (L1) and neutral conductor (N).
The geometry of the existing power switch may differ from the illustration.
The mains cable is connected in the same way.
To connect the mains cable:
IMPORTANT! Tie the phase conductor, neutral conductor, and ground conductor together near the strain-relief device using a cable tie.
The ground conductor should be approx. 10 - 15 mm (0.4 - 0.6 in.) longer than the phase conductors.
IMPORTANT! Tie the phase conductors near the strain-relief device using cable ties.
IMPORTANT! Tie the phase conductors near the block terminal using a cable tie.
The steps and activities described below include references to various system components, such as
For more detailed information about installing and connecting the system components, please refer to the appropriate Operating Instructions for the system components.
Work performed incorrectly can cause serious injury and damage.
The following activities must only be carried out by trained and qualified personnel.
Please note the information in the "Safety instructions" chapter!
The following diagram shows an overview of how the individual system components are put together.
For detailed information about the individual steps, please refer to the corresponding Operating Instructions for the system components.
Danger of severe injury and damage to property if gas cylinders fall over.
When using gas cylinders:
Place them on a solid, level surface in such a way that they remain stable
Secure the gas cylinders to prevent them from falling over
Fit the optional wirefeeder holder
Follow the gas cylinder manufacturer's safety rules.
US devices (TSt 3500c only) are supplied with an adapter for the gas hose:
Seal the outside thread on the gas solenoid valve using suitable means before screwing on the adapter.
Test the adapter to ensure that it is gas-tight.
Operating the device incorrectly can cause serious injury and damage to property.
Do not use the functions described here until you have fully read and understood the Operating Instructions.
Do not use the functions described here until you have fully read and understood all of the Operating Instructions of the system components, especially the safety rules.
The device is started up by pressing the torch trigger (for manual applications).
When connecting the welding torch, check that
all connections are connected properly
all cables, leads and hosepacks are undamaged and correctly insulated.
| * | The TSt 3500c MP can be optionally equipped with a cooling unit. Coolant hoses are only available on water-cooled welding torches. |
Risk of injury due to feed roller holders shooting upwards.
When unlocking the lever, keep fingers away from the area to the left and right of the lever.
In order to achieve optimum wire electrode feed, the feed rollers must be suitable for the diameter and alloy of the wire being welded.
An overview of the available feed rollers can be found in the Spare Parts Lists.
Risk of injury due to springiness of spooled wire electrode.
When inserting the wirespool/basket-type spool, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Risk of injury from falling wirespool/basket-type spool.
Make sure that the wirespool or basket-type spool with basket-type spool adapter is fitted securely to the wirespool holder.
Danger of injury and material damage if the wirespool/basket-type spool topples over because the locking ring has been placed the wrong way round.
Always position the locking ring as shown in the diagram on the left.
When working with basket-type spools, only use the basket-type spool adapter supplied with the device.
Danger from falling gas cylinders.
Serious personal injury and damage to property may result.
Place gas cylinders on a solid, level surface so that they remain stable.
Please observe the gas cylinder manufacturer's safety rules.
Connecting the Polarity Reverser
If the polarity reverser is incorrectly connected, it can result in poor-quality weld properties.
Connect the polarity reverser according to the wire electrode used.
Check the wire electrode packaging to determine whether the wire electrode is for (+) or (-) welding.
Establishing a Ground Earth Connection
Connect grounding cable to the free current socket
When inserting the wire electrode into the 4-roller drive, hold the end of the wire electrode firmly to avoid injuries caused by the wire electrode springing back.
Risk of damage to the welding torch from sharp end of wire electrode.
Deburr the end of the wire electrode well before threading in.
Risk of injury from emerging wire electrode.
When pressing the "Wire threading" button or the torch trigger, keep the welding torch away from your face and body, and wear suitable protective goggles.
IMPORTANT! To facilitate wire threading, the following procedure is possible when the "Wire threading" button is pressed and held down.
If you release the "Wire threading" button and press it again before one second has elapsed, the sequence starts again from the beginning. This makes it possible to continuously position the wire at a low wire speed of 1 m/min or 39.37 ipm where necessary.
If there is no "Wire threading" / "Gas-test" button, the torch trigger can be used in a similar way. Before using the torch trigger for wire threading, proceed as follows:
Danger of injury and damage from electric shock and from the wire electrode emerging from the torch.
When you press the torch trigger:
Keep the welding torch away from your face and body
Wear suitable protective goggles
Do not point the welding torch at people
Make sure that the wire electrode does not touch any conductive or grounded parts (e.g., housing, etc.)
IMPORTANT! If the torch trigger is pressed instead of the "Wire threading"/"Gas-test" button, the welding wire runs at the feeder creep speed (depending on the welding program) for the first 3 seconds. After these 3 seconds, wirefeeding is briefly interrupted.
The welding system detects that the welding process should not start, but that the wire is to be threaded in. At the same time, the gas solenoid valve closes, and the welding voltage on the wire electrode is switched off.
If the torch trigger is kept pressed, wirefeeding restarts immediately without shielding gas and welding voltage, and the process continues as described above.
Set the contact pressure in such a way that the wire electrode is not deformed but nevertheless ensures proper wirefeeding.
Standard values for the U-groove rollers:
Steel: 4 - 5
CrNi: 4 - 5
Tubular covered electrodes: 2 - 3
After releasing the torch trigger the wirespool must stop unreeling.
If it continues unreeling, readjust the brake.
Danger from incorrect installation.
Do not dismantle the brake.
Maintenance and servicing of brakes is to be carried out by trained, qualified personnel only.
The brake is only available as a complete unit.
The illustration of the brake is for information purposes only.
"Power limitation" is a safety function for MIG/MAG welding. This means that the power source can be operated at the power limit whilst maintaining process safety.
Wire speed is a determining parameter for welding power. If it is too high, the arc gets smaller and smaller and may be extinguished. In order to prevent this, the welding power is lowered.
If the "MIG/MAG standard synergic welding" process is selected, the symbol for the "Wire speed" parameter flashes as soon as the safety function trips. The flashing continues until the next welding start-up, or until the next parameter change.
If the "Wire speed" parameter is selected, for example, the reduced value for wire speed is displayed.
For details of the meaning, settings, setting range and units of the available welding parameters (e.g., gas pre-flow time), please refer to the "Setup parameters" chapter.
| GPr | Gas pre-flow time |
| I-S | Starting current Can be increased or decreased depending on the application |
| SL | Slope Starting current is continuously lowered as far as the welding current and the welding current as far as the final current |
| I | Welding current phase Even heat input into the parent material whose temperature is raised by the advancing heat |
| I-E | Final current To fill up end-craters |
| GPo | Gas post-flow time |
| SPt | Spot welding time / interval welding time |
| SPb | Interval pause time |
"4-step mode" is suitable for longer weld seams.
Special 4-step mode allows the starting and final current to be configured in addition to the advantages of 4-step mode.
The "Spot welding" mode is suitable for welded joints on overlapped sheets.
Start by pressing and releasing the torch trigger - GPr gas pre-flow time - welding current phase over the SPt spot welding time duration - GPo gas post-flow time.
If the torch trigger is pressed again before the end of the spot welding time (< SPt), the process is canceled immediately.
The "2-step stitch welding" mode is suitable for welding short weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
The "4-step stitch welding" mode is suitable for welding longer weld seams on thin sheets, to prevent the weld seams from dropping through the parent material.
Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component (TR 2000 or TR 3000 remote control) on the control panel of the power source.
All welding parameter set values remain stored until the next time they are changed. This is still true if the power source has been turned off and on again in the meantime. To display the actual welding current during welding, select the welding current parameter.
Make sure that the wire electrode does not touch any conductive or grounded parts (e.g., housing)
To obtain the best possible welding results, the arc length correction and arc-force dynamic welding parameters will sometimes need to be corrected.
The MIG/MAG standard manual welding process is a MIG/MAG welding process with no synergic function.
Changing one parameter does not result in any automatic adjustments to the other parameters. All of the variable parameters must therefore be adjusted individually, as dictated by the welding process in question.
The following parameters are available for MIG/MAG manual welding:
Wire speed | |
Welding voltage | |
Welding current |
The welding parameter values are shown in the digital display located above
To display the actual welding current during welding:
To obtain the best possible welding results, the arc-force dynamic parameter will sometimes need to be adjusted.
The spot and stitch welding modes are MIG/MAG welding processes.
Spot welding is used on welded joints on overlapping sheets that are only accessible on one side.
Stitch welding is used for light-gage sheets.
As the wire electrode is not fed continuously, the weld pool can cool down during the intervals. Local overheating leading to the parent material being melted through is largely avoided.
Check the rod electrode packaging to determine whether the rod electrode is for (+) or (-) welding.
Danger due to welding processes starting unintentionally.
Personal injury and damage to property may result.
As soon as the power source is switched on, ensure that the rod electrode does not unintentionally/accidentally touch electrically conductive or grounded parts (such as housing).
1Press the "Process" button to select the MMA welding process: | ||
| The welding voltage is applied to the welding socket with a three second time lag. | |
| NOTE! Under certain circumstances, it may not be possible to change welding parameters that have been set on the control panel of a system component (TR 2000 or TR 3000) on the control panel of the power source. | |
2Press the "Parameter selection" button to select the amperage parameter. | ||
3Use the selection dial to set the desired amperage. | ||
| The amperage value is displayed on the left-hand digital display. | |
| All welding parameter set values remain stored until the next time they are changed. This is still true if the power source has been turned off and on again in the meantime. | |
4Initiate welding process | ||
| To display the actual welding current during welding: | |
Arc-force dynamic:
For influencing the short-circuiting dynamic at the instant of droplet transfer
| - | = hard, stable arc |
| 0 | = neutral arc |
| + | = soft, low-spatter arc |
Arc-force dynamic:
| 0 | = neutral arc |
This function is activated at the factory.
AdvantagesKey
| Hti | Hot-current time, 0 - 2 s, factory setting 0.5 s |
| HCU | HotStart current, 100 - 200%, factory setting 150% |
| IH | Main current = set welding current |
The Hti and HCU parameters can be set in the Setup menu. For a parameter description see section Parameters for MMA Welding from page (→).
Function
During the specified hot-current time (Hti), the welding current is increased to a certain value. This value (HCU) is higher than the selected welding current (IH).
As the arc becomes shorter, the welding voltage may also fall so that the rod electrode is more likely to stick to the workpiece. This may also cause the rod electrode to burn out.
Electrode burn-out is prevented by activating the anti-stick function. If the rod electrode begins to stick, the power source immediately switches the welding current off. The welding process can be resumed without problems once the rod electrode has been detached from the workpiece.
For a parameter description see section Anti-stick function from page (→).
As soon as the power source is switched on, ensure that the tungsten electrode does not unintentionally/accidentally touch electrically conductive or grounded parts (such as housing).
When using a welding torch with a torch trigger and TIG Multi Connector plug (with 2-step mode factory setting):
Pulsed welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:Pulsed welding is welding with a pulsing welding current. It is used to weld steel pipes out-of-position or to weld thin sheet metal.
In these applications, the welding current set at the start of welding is not always optimum for the entire welding process:The power source controls the "Duty cycle dcY" and "Base current I-G" parameters according to the set pulse current (welding current) and pulse frequency.
Adjustable parameters:
| I-S | Starting current |
| I-E | Final current |
| F-P | Pulse frequency (1/F-P = Time between two pulses) |
| I-P | Pulse current (set welding current) |
Fixed parameters:
| tup | UpSlope |
| tdown | DownSlope |
| dcY | Duty cycle |
| I-G | Base current |
For a parameter description see section Parameters for TIG welding from page (→).
The "Save" buttons allow five EasyJobs to be saved. The adjustable parameters on the control panel are saved as EasyJobs.
Setup parameters are not saved as EasyJobs.
Press one of the "Save" buttons on the control panel to retrieve the saved settings using the Up/Down welding torch.
1Press one of the "Save" buttons on the control panel, e.g.:
The "Save" buttons can now be selected using the buttons on the Up/Down welding torch. Vacant "Save" buttons are skipped.
In addition to the "Save" button number lighting up, a number is displayed directly on the Up/Down welding torch:
Number 1 |
Number 2 |
Number 3 |
Number 4 |
Number 5 |
If the Easy Documentation option is available on the power source, the most important welding data for each welding operation can be documented and saved as a CSV file on a USB thumb drive.
A Fronius signature is stored with the welding data, which can be used to check and guarantee the authenticity of the data.
Easy Documentation is activated / deactivated by plugging / unplugging the supplied Fronius USB thumb drive with FAT32 formatting into the back of the power source.
IMPORTANT! To document the welding data, the date and time must be set correctly.
The following data are documented:
Device type
File name
Part number
Serial number
Firmware version of power source
Firmware of PC board DOCMAG (Easy Documentation)
Document version
https://www.easydocu.weldcube.com (A PFDF report of selected welding data can be created under this link)
Nr. | Meter |
Date | Date yyyy-mm-dd |
Time | Time hh:mm:ss |
Duration | Duration in [s] |
I | Welding current * in [A] |
U | Welding voltage * in [V] |
vd | Wire speed * in [m/min] |
wfs | Wire speed * in [ipm] |
IP | Power * from current values in [W] |
IE | Energy from instantaneous values in [kJ] |
I-Mot | Motor current * in [A] |
Synid | Characteristic number |
Job | EasyJob number |
Process | Welding process |
Mode | Operating mode |
Status | PASS: regular welding |
Interval | Weld seam number for "Interval" operating mode |
Signature | Signature for each weld seam number |
* | in each case from the main process phase; |
The welding data are documented as average values in the main process phase and for each welding operation.
By scanning this link...
https://easydocu.weldcube.com |
Setting the date and time is carried out in the 2nd level of the service menu.
The first parameter in the service menu is displayed.
Select the "2nd" setup parameter using the left-hand selection dial
The first parameter in the 2nd level of the service menu is displayed.
Select the "yEA" (= year) setup parameter using the left-hand selection dial
To set the date and time:
Setting ranges:
| yEA | Year (20yy; 0 - 99) |
| Mon | Month (mm; 1 -1 12) |
| dAY | Day (dd; 1 - 31) |
| Hou | Hour (hh; 0 - 24) |
| Min | Minute (mm; 0 - 59) |
If the power source is reset to factory settings via setup parameter FAC, the date and time remain stored.
Setting ranges:
Risk of data loss or data damage due to premature disconnection of the USB thumb drive
Do not disconnect the USB thumb drive until approx. 10 seconds after the end of the last welding operation to ensure correct data transfer.
The power source display shows:
Easy Documentation is deactivated.
The Setup menu offers easy access to expert knowledge related to the power source, as well as additional functions. The Setup menu makes it possible to easily adjust the parameters for various tasks.
Accessing the Setup menu is described with reference to the MIG/MAG standard synergic welding process.
Access is the same for the other welding processes.
Press the "Process" button to select the "MIG/MAG standard synergic welding" process
The control panel is now located in the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
Adjusting parameters
Select the desired setup parameter using the left-hand selection dial
Change the setup parameter value using the right-hand selection dial
Exiting the Setup menu
| GPr | Gas pre-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 0.1 |
| GPo | Gas post-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 0.5 |
| SL | Slope Unit: seconds Setting range: 0 - 9.9 Factory setting: 1 |
| I-S | Starting current Unit: % of welding current Setting range: 0 - 200 Factory setting: 100 |
| I-E | Final current Unit: % of welding current Setting range: 0 - 200 Factory setting: 50 |
| t-S | Start current duration Unit: seconds Setting range: 0 - 9.9 Factory setting: 0 |
| t-E | Final current duration Unit: seconds Setting range: 0 - 9.9 Factory setting: 0 |
| Fdi | Feeder inching speed Unit: m/min (ipm) Setting range: 1 - 18.5 (39.37 - 728.35) Factory setting: 10 (393.7) |
| Ito | Length of wire that is fed before the safety cut-out trips Unit: mm (in.) Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94) Factory setting: OFF The "Ignition time-out" function (Ito) is a safety function. If the power source determines that no ignition has occurred after the preset wire length has been fed, wirefeeding is stopped. |
| SPt | Spot welding time Unit: seconds Setting range: 0.3 - 5 Factory setting: 1 |
| SPb | Spot pause time Unit: seconds Setting range: OFF, 0.3 - 10 (in 0.1 s increments) Factory setting: OFF |
| Int | Interval Unit: - Setting range: 2T (2-step), 4T (4-step) Factory setting: 2T (2-step) |
| FAC | Reset power source to factory settings Press and hold one of the "Parameter selection" buttons for two seconds to restore the factory settings When the power source is reset, the majority of the applied settings are deleted. The following values remain:- when "PrG" appears on the digital display, the power source has been reset.
| 2nd | Second level of the Setup menu (see "Setup Menu 2nd Level") |
| IGc | Ignition current Unit: Ampere Setting range: 100 - 390 Factory setting: 300 |
| Ito | Length of wire that is fed before the safety cut-out trips Unit: mm (in.) Setting range: OFF, 5 - 100 (OFF, 0.2 - 3.94) Factory setting: OFF The ignition time-out function (Ito) is a safety feature. If the power source determines that no ignition has occurred after the preset wire length has been fed, wirefeeding is stopped. |
| SPt | Spot welding time Unit: seconds Setting range: OFF, 0.3 - 5 Factory setting: 1 |
| HCU | HotStart current Unit: % Setting range: 100 - 200 Factory setting: 150 |
| Hti | Hot current time Unit: seconds Setting range: 0 - 2.0 Factory setting: 0.5 |
| Ast | Anti-stick function Unit: - Setting range: On, OFF Factory setting: On |
| F-P | Pulse frequency Unit: Hertz Setting range: OFF; 1 - 990 (up to 10 Hz: in 0.1 Hz increments) (up to 100 Hz: in 1 Hz increments) (over 100 Hz: in 10 Hz increments) Factory setting: OFF |
| tUP | UpSlope Unit: seconds Setting range: 0.01 - 9.9 Factory setting: 0.5 |
| tdo | DownSlope Unit: seconds Setting range: 0.01 - 9.9 Factory setting: 1 |
| I-S | Starting current Unit: % of main current Setting range: 1 - 200 Factory setting: 35 |
| I-2 | Lowering current Unit: % of main current Setting range: 1 - 100 Factory setting: 50 |
| I-E | Final current Unit: % of main current Setting range: 1 - 100 Factory setting: 30 |
| GPo | Gas post-flow time Unit: seconds Setting range: 0 - 9.9 Factory setting: 9.9 |
| tAC | Tacking Unit: seconds Setting range: OFF, 0.1 - 9.9 Factory setting: OFF |
The following restrictions occur in relation to the Setup menu 2nd level:
Setup menu 2nd level cannot be selected:
If level 2 of the Setup menu is selected, the following functions are not available, even in robot mode:
To access the 2nd level of the Setup menu:
The control panel is now located in the 2nd level of the Setup menu of the "MIG/MAG standard synergic welding" process - the last selected setup parameter is displayed.
A parameter is displayed in the first level of the Setup menu.
| C-C | Cooling unit control (only with TST 3500c MP and if cooling unit is connected) Unit: - Setting range: Aut, On, OFF Factory setting: Aut Aut: The cooling unit cuts out after a 2-minute welding off-time. IMPORTANT! If the coolant temperature and flow monitoring options have been installed in the cooling unit, the cooling unit cuts out as soon as the return-flow temperature drops below 50 °C, but at the earliest after a 2-minute welding off-time. On: The cooling unit is permanently ON OFF: The cooling unit is always OFF IMPORTANT! If the FAC welding parameter is used, the C-C parameter is not reset to the factory setting. If the MMA welding process is selected, the cooling unit is always switched off, even if the switch is in the "On" position. |
| C-t | Cooling time (only with TST 3500c MP and if cooling unit is connected) Time from when flow monitoring is triggered until the "no | H2O" service code is output. For example, if there are air bubbles in the cooling system, the cooling unit will not cut out until the end of this preset time. Unit: s Setting range: 5 - 25 Factory setting: 10 IMPORTANT! Every time the power source is switched on, the cooling unit carries out a test run for 180 seconds. |
| SEt | Country-specific setting (Standard/USA) ... Std/US Unit: - Setting range: Std, US (Standard/USA) If Std is selected, the Euro welding programs are used as stated in the welding program table. If US is selected, the US welding programs are used as stated in the welding program table. Factory setting: Standard version: Std (measurements in cm/mm) USA version: US (measurements: inches) |
| FUS | Mains fuse The maximum possible welding power is limited by the rating of the mains fuse protection used. Unit: A The available mains fuse ratings are determined by the SEt parameter setting: SEt parameter set as Std: OFF / 10 / 13 / 16 SEt parameter set as US: OFF / 15 / 20 (only for 120 V grid voltage) Factory setting: OFF |
| LED | Time delay for the cut-off of the wirespool interior lighting The time delay starts with the last key operation. Unit: Minutes Setting range: ON / OFF / 0-100 Factory setting: 10 only at TSt 2700c MP |
| r | Welding circuit resistance (in mOhm) See "Measuring the Welding Circuit Resistance r" |
| L | Welding circuit inductivity (in microhenrys) See "Displaying the Welding Circuit Inductivity L" |
| EnE | Real Energy Input Unit: kJ Setting range: ON / OFF Factory setting: OFF Since the full range of values (1 kJ - 99,999 kJ) cannot be displayed on the three-digit display, the following display format has been selected: Value in kJ: 1 to 999 / indicator on display: 1 to 999 Value in kJ: 1000 to 9999 / indicator on display: 1.00 to 9.99 (without unit digit, e.g., 5270 kJ -> 5.27) Value in kJ: 10,000 to 99,999 / indicator on display: 10.0 to 99.9 (without unit digit or tens digit, e.g., 23,580 kJ -> 23.6) |
| ALC | Arc length correction display (For setting how the arc length correction parameter is displayed) Setting range: ON / OFF Factory setting: OFF If set to ON, if the welding voltage parameter is selected and set on the control panel, the left-hand display shows the arc correction value for three seconds, the right-hand display shows the value for the welding voltage at the same time. |
| Ejt | EasyJob Trigger To activate/deactivate switching between EasyJobs using the torch trigger Unit: - Setting range: On/OFF Factory setting: OFF Function with MIG/MAG torch trigger Press torch trigger briefly (< 0.5 s) No welding taking place:
Welding taking place:
Function with MIG/MAG Up/Down key If an EasyJob is selected, the EasyJob is changed, otherwise the welding current is changed. No welding taking place:
| SEt | Country-specific setting (Standard/USA) ... Std/US Unit: - Setting range: Std, US (Standard/USA) Factory setting: Standard device: Std (measurements in cm/mm) USA device: US (measurements: inches) |
| r | Welding circuit resistance (in mOhm) See section Measuring the welding circuit resistance (MIG/MAG welding) from page (→) |
| L | Welding circuit inductivity (in microhenrys) See section Displaying the welding circuit inductivity from page (→) |
| FUS | Mains fuse protection The maximum possible welding power is limited by the rating of the mains fuse protection used. Unit: A The available mains fuse ratings are determined by the SEt parameter setting: SEt parameter set as Std: OFF / 10 / 13 / 16 SEt parameter set as US: OFF / 15 / 20 (only for 120 V grid voltage) Factory setting: OFF |
Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The calculated welding circuit resistance is shown on the display.
r = welding circuit resistance in milliohm (mOhm)
If the welding circuit resistance has been measured correctly, the set welding voltage will correspond exactly to the welding voltage at the arc. If you manually measure the voltage on the output jacks of the power source, this voltage will be higher than the welding voltage at the arc - that is, higher by the same amount as the voltage drop of the hosepack.
The welding circuit resistance depends on the hosepack used:Measuring the welding circuit resistance makes it possible to have a constant welding result at all times, even with hosepacks of different lengths. The welding voltage at the arc is then always precisely regulated, regardless of the length and cross-sectional area of the hosepack. The use of arc length correction is no longer required.
The welding circuit resistance depends on the hosepack used:Risk of incorrect measurement of the welding circuit resistance.
This can have a negative effect on the welding results.
Ensure that the workpiece has an optimum contact surface in the area of the earthing clamp (clean surface, no rust, etc.).
Ensure that the workpiece has an optimum contact surface for the contact tip (clean surface, no rust, etc.).
The measurement is finished when the welding circuit resistance is shown on the display in mOhm (for example 11.4).
The way that the hosepack is arranged has a very significant effect on the welding circuit inductivity and therefore affects the welding process. It is important to lay the hosepacks correctly in order to obtain the best possible welding result.
The setup parameter "L" is used to display the most recently calculated welding circuit inductivity. The welding circuit inductivity is adjusted when the welding circuit resistance is measured. Detailed information in this regard can be found under the "Welding circuit resistance" chapter.
The most recently calculated welding circuit inductivity L is shown on the right-hand digital display.
L ... Welding circuit inductivity (in microhenrys)
The devices are equipped with an intelligent safety system, which largely negates the need for melting-type fuses. Melting-type fuses therefore no longer need to be replaced. After a possible malfunction has been remedied, the device is ready for use again.
Danger due to insufficient ground conductor connection.
The housing screws provide a suitable ground conductor connection for grounding the housing.
The housing screws must not under any circumstances be replaced by other screws without a reliable ground conductor connection.
Make a note of the serial number and configuration of the device, and provide the service team with a detailed error description if:
| Cause: | There is a break in the mains lead; the mains plug is not plugged in |
| Remedy: | Check the mains lead, ensure that the mains plug is plugged in |
| Cause: | Mains socket or mains plug faulty |
| Remedy: | Replace faulty parts |
| Cause: | Mains fuse protection |
| Remedy: | Change the mains fuse protection |
| Cause: | Only for welding torches with an external control plug: Control plug not plugged in |
| Remedy: | Plug in control plug |
| Cause: | Welding torch or welding torch control line faulty |
| Remedy: | Replace welding torch |
| Cause: | Interconnecting hosepack faulty or not connected correctly |
| Remedy: | Check interconnecting hosepack |
| Cause: | Overloading |
| Remedy: | Observe the duty cycle |
| Cause: | Thermal automatic circuit breaker has tripped |
| Remedy: | Wait until the power source automatically comes back on after the end of the cooling phase |
| Cause: | Limited supply of cooling air |
| Remedy: | Remove air filter on the rear of the housing from the side and clean. Ensure that the cooling air ducts are accessible |
| Cause: | Fan in the power source is faulty |
| Remedy: | Inform After-Sales Service |
| Cause: | Incorrect ground connection |
| Remedy: | Check ground connection for polarity |
| Cause: | Power cable in welding torch damaged or broken. |
| Cause: | Gas cylinder empty |
| Remedy: | Change gas cylinder |
| Cause: | Gas pressure regulator faulty |
| Remedy: | Replace gas pressure reducer |
| Cause: | Gas hose not attached, or damaged |
| Remedy: | Attach or replace gas hose |
| Cause: | Welding torch faulty |
| Remedy: | Change welding torch |
| Cause: | Gas solenoid valve faulty |
| Remedy: | Inform the service team |
| Cause: | Braking force has been set too high |
| Remedy: | Loosen the brake |
| Cause: | Contact tip hole too narrow |
| Remedy: | Use suitable contact tip |
| Cause: | Inner liner in the welding torch faulty |
| Remedy: | Check the inner liner for kinks, dirt, etc. and replace if necessary |
| Cause: | Feed rollers not suitable for wire electrode used |
| Remedy: | Use suitable feed rollers |
| Cause: | Feed rollers have the wrong contact pressure |
| Remedy: | Optimize contact pressure |
| Cause: | Incorrect arrangement of welding torch hosepack |
| Remedy: | Arrange the welding torch hosepack in as straight a line as possible, avoiding tight bends |
| Cause: | Welding torch is inadequately sized |
| Remedy: | Observe duty cycle and load limits |
| Cause: | For water-cooled systems only: Coolant flow too low |
| Remedy: | Check coolant level, coolant flow rate, coolant contamination, etc. For more detailed information, refer to the Operating Instructions for the cooling unit |
| Cause: | Incorrect welding parameters |
| Remedy: | Check settings |
| Cause: | Poor ground earth connection |
| Remedy: | Establish good contact with workpiece |
| Cause: | Too little or no shielding gas |
| Remedy: | Check gas pressure regulator, gas hose, gas solenoid valve, welding torch gas connection, etc. |
| Cause: | Welding torch leaks |
| Cause: | Incorrect or heavily worn contact tip |
| Remedy: | Change contact tip |
| Cause: | Incorrect wire alloy or incorrect wire diameter |
| Remedy: | Check wire electrode in use |
| Remedy: | Check weldability of the base material |
| Cause: | Shielding gas not suitable for wire alloy |
| Remedy: | Use correct shielding gas |
If an error message that is not described here appears on the displays, first try to resolve the problem as follows:
If the error occurs again despite several attempts to eliminate it, or if the troubleshooting measures listed here are unsuccessful.
| Cause: | The cooling unit used is not compatible with the power source |
| Remedy: | Connect compatible cooling unit |
| Cause: | An invalid welding process was called up on the robot interface (no. 37) or an empty flag was selected (no. 32) |
| Remedy: | Call up a valid welding process or select assigned "Save" button |
| Cause: | The connected wirefeeder is not supported |
| Remedy: | Connect supported wirefeeder |
| Cause: | Different control panels for selecting materials are in the system |
| Remedy: | Connect similar control panels to select materials |
| Cause: | Impermissible change of welding process during welding |
| Remedy: | During welding do not make any impermissible change to the welding process, reset error message by pressing any button |
| Cause: | More than one robot interface is connected |
| Remedy: | Only one robot interface may be connected, check the system configuration |
| Cause: | More than one remote control is connected |
| Remedy: | Only one remote control may be connected, check the system configuration |
| Cause: | The power source control has detected a primary overvoltage |
| Remedy: | Check the grid voltage. If the service code persists, switch off the power source, wait for 10 seconds and then switch the power source on again. If the error still persists, contact the After-Sales Service team |
| Cause: | The earth current watchdog has triggered the safety cut-out of the power source. |
| Remedy: | Switch off the power source Place the power source on an insulating surface Connect the grounding cable to a section of the workpiece that is closer to the arc Wait for 10 seconds and then switch the power source on again If you have tried this several times and the error keeps recurring, contact the After-Sales Service team |
| Cause: | If the VRD option is available, the open circuit voltage limit of 35 V has been exceeded. |
| Remedy: | Switch off the power source Wait for 10 seconds and then switch the power source on again |
| Cause: | The VRD option has tripped too early. |
| Remedy: | Check whether all welding power-leads and control lines are connected. Switch off the power source Wait 10 seconds and switch the power source back on again If the error occurs again - contact the After-Sales Service team. |
| Cause: | "External stop" option has tripped |
| Remedy: | Remedy the event that triggered the external stop |
| Cause: | Flag on the robot interface was not deleted from the robot |
| Remedy: | Delete the "Robot ready" signal on the robot interface |
| Cause: | Phase failure with TSt 2700c in particular: If the failure occurs during welding, the welding operation stops. with TSt 2700 MV in particular: A single-phase operation with limited power is possible: When switching on the power source, "PHA | SE1" is displayed in order to show that a power reduction will be in effect. If a change in supply from three-phase to single-phase occurs during welding (display: "PHA | SE1") or from single-phase to three-phase (display: "PH | ASE 3"), the welding operation stops. |
| Remedy: | Check the mains fuse, grid lead and mains plug. Switch off the power source, wait 10 seconds and switch the power source back on again. |
| Cause: | The power source is being used in single-phase mode |
| Remedy: | - |
| Cause: | The power source is being used in three-phase mode |
| Remedy: | - |
| Cause: | Mains undervoltage: the grid voltage has fallen below the tolerance range |
| Remedy: | Check the grid voltage. If the service code persists, contact the After-Sales Service team |
| Cause: | Mains overvoltage: the grid voltage has risen above the tolerance range |
| Cause: | Incorrect wirefeeder connected |
| Remedy: | Connect correct wirefeeder |
| Cause: | Wirefeeder overtemperature |
| Remedy: | Allow wirefeeder to cool down |
| Cause: | Fault in the wirefeed system (overcurrent in wirefeeder drive) |
| Remedy: | Arrange the hosepack in as straight a line as possible; check that there are no kinks or dirt in the inner liner; check the contact pressure on the 4 roller drive |
| Cause: | Wirefeeder motor is sticking or faulty |
| Remedy: | Check the wirefeeder motor or contact the After-Sales Service team |
| Cause: | Overtemperature in the primary circuit of the power source |
| Remedy: | Allow power source to cool down, check air filter and clean if necessary, check that fan is on |
| Cause: | Overtemperature on the booster located in the power source |
| Cause: | Overtemperature in the secondary circuit of the power source |
| Remedy: | Allow power source to cool down, check that fan is on |
| Cause: | Overtemperature in wirefeeder motor |
| Cause: | Overtemperature in welding torch |
| Remedy: | Allow welding torch to cool down |
| Cause: | Overtemperature in cooling unit |
| Remedy: | Allow cooling unit to cool down, check that fan is on |
| Cause: | Overtemperature on the power source transformer |
| Cause: | Overtemperature in the power source |
| Cause: | With the TSt 2700c MV power source operating in single-phase mode, the power source safety cut-out has tripped in order to prevent the mains fuse from tripping. |
| Remedy: | After a pause in welding of around 60 s, the message disappears and the power source is operational again. |
| Cause: | Undertemperature in the power source primary circuit |
| Remedy: | Place power source in a heated room and allow it to warm up |
| Cause: | Undertemperature on the booster located in the power source |
| Cause: | Undertemperature in the power source secondary circuit |
| Cause: | Undertemperature in the wirefeeder motor |
| Remedy: | Place wirefeeder in a heated room and allow to warm up |
| Cause: | Undertemperature in the welding torch |
| Remedy: | Place welding torch in a heated room and allow to warm up |
| Cause: | Undertemperature in the cooling unit |
| Remedy: | Place cooling unit in a heated room and allow to warm up |
| Cause: | Undertemperature on the power source transformer |
| Cause: | Undertemperature in power source |
| Cause: | Coolant flow rate too low |
| Remedy: | Check coolant flow rate and cooling unit, including cooling circuit (for minimum coolant flow, see "Technical Data" chapter in the Operating Instructions for the device) |
| Cause: | The coolant temperature is too high |
| Remedy: | Allow cooling unit and cooling circuit to cool down, until "hot | H2O" is no longer displayed. Open the cooling unit and clean the cooler, check fan is working properly. Robot interface or fieldbus coupler: Before resuming welding, set the "Source error reset" signal. |
| Cause: | No preconfigured program has been selected |
| Remedy: | Select a configured program |
| Cause: | "Ignition time-out" function is active; current did not start flowing before the length of wire specified in the Setup menu had been fed. The power source safety cut-out has tripped |
| Remedy: | Shorten the wire stick-out; press the torch trigger again; clean the surface of the workpiece; if necessary, set the "Ito" parameter in the Setup menu |
| Cause: | The selected welding program is invalid |
| Remedy: | Select a valid welding program |
| Cause: | The required wirefeeder is not available for the selected characteristic |
| Remedy: | Connect the correct wirefeeder, check the plug connections for the hosepack |
| Cause: | Measurement of the welding circuit resistance failed |
| Remedy: | Check grounding cable, current cable, or hosepack and replace if necessary, re-measure the welding circuit resistance |
| Cause: | The gas watchdog option has detected that there is no gas pressure |
| Remedy: | Connect a new gas cylinder or open the gas cylinder valve/pressure regulator, replace "Gas watchdog" option, reset "no | GAS" error message by pressing any button. |
| Cause: | Date and time are not set on the power source |
| Remedy: | To reset the service code, press the arrow key; Set date and time in the 2nd level of the service menu: see page (→) |
| Cause: | The battery of OPT Easy Documentation is low |
| Remedy: | To reset the service code, press the arrow key; Contact service (to change the battery) |
| Cause: | The battery of the OPT Easy Documentation is empty |
| Remedy: | To reset the service code, press the arrow key - the display shows no | dAt; Contact service (to change the battery); After changing the battery, the date and time in the are displayed in the 2nd level of the service menu: see page (→) |
| Cause: | Error writing data; Internal documentation error; Communication error; |
| Remedy: | Turn power source off and on again |
| Cause: | Invalid file system on USB thumb drive; General USB error |
| Remedy: | Unplug the USB thumb drive |
| Cause: | The plugged in USB thumb drive is full |
| Remedy: | Unplug USB thumb drive, plug in new USB thumb drive |
Under normal operating conditions, the welding system requires only a minimum of care and maintenance. However, several points must be observed in order for the welding system to remain operational for years to come.
Air inlet and outlet openings must not be blocked or even partially covered.
Depending on the dust accumulation:
TSt 2700cDanger of damage to property.
The air filter must only be fitted when dry.
If required, clean air filter using dry compressed air or by washing it.
Danger due to the effect of compressed air.
Do not bring the air nozzle too close to electronic parts.
Danger of electric shock due to grounding cable and device grounding points not being connected properly.
When refitting the side panels, ensure that the grounding cable and device grounding points are properly connected.
Materials should be disposed of according to valid local and national regulations.
Average wire electrode consumption at a wire speed of 5 m/min | |||
| 1.0 mm wire electrode diameter | 1.2 mm wire electrode diameter | 1.6 mm wire electrode diameter |
Steel wire electrode | 1.8 kg/h | 2.7 kg/h | 4.7 kg/h |
Aluminum wire electrode | 0.6 kg/h | 0.9 kg/h | 1.6 kg/h |
CrNi wire electrode | 1.9 kg/h | 2.8 kg/h | 4.8 kg/h |
Average wire electrode consumption at a wire speed of 10 m/min | |||
Steel wire electrode | 3.7 kg/h | 5.3 kg/h | 9.5 kg/h |
Aluminum wire electrode | 1.3 kg/h | 1.8 kg/h | 3.2 kg/h |
CrNi wire electrode | 3.8 kg/h | 5.4 kg/h | 9.6 kg/h |
Wire electrode diameter | 1.0 mm | 1.2 mm | 1.6 mm | 2.0 mm | 2 x 1.2 mm (TWIN) |
Average consumption | 10 l/min | 12 l/min | 16 l/min | 20 l/min | 24 l/min |
Gas nozzle size | 4 | 5 | 6 | 7 | 8 | 10 |
Average consumption | 6 l/min | 8 l/min | 10 l/min | 12 l/min | 12 l/min | 15 l/min |
For devices designed for special voltages, the technical data on the rating plate applies.
The following applies for all devices with a permitted grid voltage of up to 460 V: The standard mains plug allows the user to operate with a grid voltage of up to 400 V. For grid voltages up to 460 V fit a mains plug permitted for such use or install the mains supply directly.
The duty cycle (ED) is the period of a ten minute cycle in which the device may be operated at the stated power without overheating.
The ED values cited on the rating plate relate to an ambient temperature of 40 °C.
If the ambient temperature is higher, the ED or power must be lowered accordingly.
Example: Welding with 150 A at 60% ED
To use the device without interruptions:
Grid voltage (U1) |
| 3 x | 380 V | 400 V | 460 V | |
Max. effective primary current (I1eff) |
| 7 A | 6.7 A | 5.8 A | |
Max. primary current (I1max) |
| 13.7 A | 13.0 A | 11.2 A | |
Mains fuse | 16 A slow-blow | |||||
Apparent power | At 400 V AC |
| 9.0 kVA | |||
Mains voltage tolerance | -10 / +15% | |||||
Grid frequency | 50 / 60 Hz | |||||
cos phi (1) | 0.99 | |||||
Max. permitted grid impedance Zmax on PCC1) |
| 220 mOhm | ||||
Welding current range (I2) |
MIG/MAG |
| 10 - 270 A | |||
MMA |
| 10 - 270 A | |||
TIG |
| 10 - 270 A | |||
Welding current at | 10 min / 40 °C (104 °F) |
| 30% | 60% | 100% | |
U1 = 3 x 380 - 400 V | MIG/MAG |
| 270 A | 210 A | 170 A | |
U1 = 3 x 460 V | MIG/MAG |
U1 = 3 x 380 - 400 V | MMA |
U1 = 3 x 460 V | MMA |
U1 = 3 x 380 - 400 V | TIG |
U1 = 3 x 460 V | TIG |
Output voltage range according to standard characteristic (U2) |
MIG/MAG |
| 14.3 - 27.5 V | |||
MMA |
| 10.4 - 20.8 V | |||
TIG |
| 20.4 - 30.8 V | |||
Open circuit voltage (U0 peak) |
| 85 V | ||||
Degree of protection |
| IP 23 | |||
Insulation class |
| B | |||
Overvoltage category |
| III | |||
Pollution degree according to IEC60664 |
| 3 | ||||
EMC device class |
| A 2) | ||||
Safety markings |
| S, CE | ||||
Dimensions l x w x h |
| 687 x 276 x 445 mm | ||||
Weight |
| 30 kg | |||
Max. shielding gas pressure |
| 7 bar | |||
Wire speed |
| 1 - 25 m/min | ||||
Wirefeeder |
| 4-roller drive | ||||
Wire diameter | 0.8 - 1.6 mm | |||||
Wirespool diameter |
| max. 300 mm | ||||
Wirespool weight |
| max. 20.0 kg | ||||
Idle state power consumption at 400 V | 38,3 W | |||||
Power source efficiency at 270 A / 30,8 V | 89 % | |||||
| 1) | Interface to a 230/400 V, 50 Hz public grid |
| 2) | A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Mains voltage (U1) |
| 3 x | 230 V | 380 V | 460 V | |
| 12.6 A | 7.5 A | 6.2 A | |
| 23.0 A | 13.7 A | 11.1 A | |
Mains fuse protection (slow-blow) | 32.0 A | 16.0 A | 16.0 A | |||
Apparent power at 380 V AC | 9.02 kVA | |||||
Mains voltage (U1) | 1 x | 230 V | 240 V | |||
| 18.1 A | 18.1 A | |||
| 24.9 A | 28.1 A | |||
| 16 A | 30 A | |||
Apparent power |
| 5.98 kVA | 6.74 kVA | |||
Max. permitted grid impedance Zmax on PCC1) | 228 mOhm | |||||
Welding current range (I2) | ||||||
MIG/MAG |
| 10 - 270 A | |||
MMA |
| 10 - 270 A | |||
TIG |
| 10 - 270 A | |||
Welding current range (I2) in single-phase operation 2) | ||||||
MIG/MAG |
| 10 - 220 A | |||
MMA |
| 10 - 180 A | |||
TIG |
| 10 - 260 A | |||
Welding current at | 10 min / 40 °C (104 °F) | 30% | 60% | 100% | ||
U1 = 3 x 200 - 230 V: | MIG/MAG |
| 270 A | 200 A | 170 A | |
U1 = 3 x 380 - 460 V: | MIG/MAG |
| 270 A | 215 A | 185 A | |
U1 = 3 x 200 - 230 V: | MMA |
U1 = 3 x 380 - 460 V: | MMA |
U1 = 3 x 200 - 230 V: | TIG (35%) |
| 270 A | 220 A | 185 A | |
U1 = 3 x 380 - 460 V: | TIG (35%) |
| 270 A | 230 A | 195 A | |
Welding current in single-phase operation 2) at | 10 min / 40 °C (104 °F) | 40% | 100% | |||
U1 = 1 x 230 V: | MIG / MAG, fuse 16 A | 180 A |
| 145 A | ||
U1 = 1 x 240 V: | MIG / MAG, fuse 30 A | 220 A |
| 170 A | ||
U1 = 1 x 230 V: | MMA, fuse 16 A | 150 A |
| 130 A | ||
U1 = 1 x 240 V: | MMA, fuse 30 A | 180 A |
| 140 A | ||
Welding current in single-phase operation 2) at | 10 min / 40 °C (104 °F) | 35% | 100% | |||
U1 = 230 V: | TIG, fuse 16 A | 220 A |
| 170 A | ||
U1 = 240 V: | TIG, fuse 30 A | 260 A |
| 180 A | ||
Output voltage range according to standard characteristic (U2) | ||||||
MIG/MAG |
| 14.5 - 27.5 V | |||
MMA |
| 20.4 - 30.8 V | |||
TIG |
| 10.4 - 20.8 V | |||
Output voltage range according to standard characteristic (U2) in single-phase operation 2) | ||||||
MIG/MAG |
| 14.5 - 25.0 V | |||
MMA |
| 20.4 - 27.2 V | |||
TIG |
| 10.4 - 20.4 V | |||
| 85 V | ||||
Protection class |
| IP 23 | |||
Insulation class |
| B | |||
| III | |||
| 3 | ||||
EMC device class |
| A 3) | ||||
Safety symbols |
| S, CE, CSA | ||||
Weight |
| 31.8 kg | |||
| 7 bar | |||
Wire speed |
| 1 - 25 m/min | ||||
Wire drive |
| max. 300 mm | ||||
Wirespool weight |
| max. 20.0 kg | ||||
Idle state power consumption at 400 V | 38.5 W | |||||
Power source efficiency at 270 A / 30.8 V | 89% | |||||
| 1) | Interface to a 230/400-V and 50-Hz public grid |
| 2) | Detailed information on the duty cycle in single-phase operation can be found in the "Installation" chapter under "TransSteel 2700c MV MP - Single-Phase Operation" from page (→). |
| 3) | A device in emissions class A is not intended for use in residential areas in which the power is supplied via a public low-voltage grid. The electromagnetic compatibility may be influenced by conducted or radiated radio frequencies. |
Grid voltage (U1) |
| 14.8 A | 14.1 A | 12.7 A | ||
| 23.8 A | 23.1 A | 21.1 A | ||
Mains fuse | 35 A slow-blow | |||||
cos phi (1) |
| 0.99 | ||||
Max. permitted grid impedance Zmax on PCC1) | 77 mOhm | |||||
Recommended residual-current circuit breaker |
| Type B | ||||
MIG/MAG |
| 10 - 350 A | |||
MMA |
| 10 - 350 A | |||
TIG |
| 10 - 350 A | |||
| 40% | 60% | 100% | |
MIG/MAG |
| 350 A | 300 A | 250 A | |
MMA |
TIG |
MIG/MAG |
| 14.5 - 31.5 V | |||
MMA |
| 20.4 - 34.0 V | |||
TIG |
| 10.4 - 24.0 V | |||
Open circuit voltage (U0 peak) | 59 V | |||||
Apparent power at 400 V AC |
| 15.87 kVA | |||
| IP 23 | |||
Type of cooling |
| AF | |||
Insulation class |
| B | |||
| III | |||
Pollution degree according to IEC60664 | 3 | |||||
EMC device class |
| A 2) | ||||
Safety markings |
| S, CE, CSA | ||||
| 747 x 300 x 497 mm | ||||
Weight |
| 36 kg | |||
| 5 bar | |||
Coolant |
| Original Fronius | ||||
Wire speed |
| 1 - 25 m/min | ||||
Wirefeeder |
| max. 300 mm | ||||
Wirespool weight |
| max. 19.0 kg | ||||
Max. noise emission (LWA) |
| 72 dB (A) | ||||
Idle state power consumption at 400 V | 36,5 W | |||||
Power source efficiency at 350 A / 34 V | 90 % | |||||
Overview with critical raw materials:
An overview of which critical raw materials are contained in this device can be found at the following Internet address.
UID 3788 welding program database
| * | Diameter = 0.6 mm (0.024 inch) |
UID 3826 welding program database
UID 3787 welding program database
| * | Diameter = 1.2 mm (0.45 inch) |
