Warnings are intended to warn people of possible injuries and to avoid personal injury and damage to the product. They relate to individual actions with and on the product.
Indicates an immediately dangerous situation.
Serious injury or death will result if the danger is not avoided.
Action step to escape the situation.
Serious injury or death may result if the danger is not avoided.
Minor or moderate injury may result if the danger is not avoided.
Indicates a situation that may result in property damage.
If the situation is not avoided, impaired work results, material damage to the product or other property are the possible consequences.
Action step to avoid the situation.
Safety instructions are designed to ensure safe product use. They are preventive and help to inform users about the fundamental risks involved when dealing with the product. They do not refer specifically to individual actions with and on the product.
Incorrect operation or misuse
IMPORTANT!
Tampered-with and non-functioning protection devices
The device may be damaged
Operation or storage of the machine outside the stipulated area will be deemed as not in accordance with the intended purpose.
For exact information on permitted environmental conditions, please refer to the technical data.
Application notes
Software
Example: Click Save.
Instructions for action
Application notes
Software
This document provides detailed information and instructions to ensure that people can use the machine safely and efficiently.
The information is intended for the following groups of people:Regardless of any qualifications, only perform the activities listed in this document.
The definition of professional qualifications and their applicability are subject to national law.
When you connect your device (and any associated devices) to the internet, the following device and operating data (device ID/identifier, device IP address, device time, configuration settings, hardware and software information, device status log files, serial number) is sent automatically to
Fronius International GmbH, Froniusstraße 1, 4643 Pettenbach, Austria, telephone +43(0) 7242241-0, email: contact@fronius.com (controller)
and stored.
The processing of this device and operating data is carried out for the purpose of ensuring the operational safety of the device (time synchronization, provision of updates). This processing is therefore necessary for the functionality of the device and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
If you do not wish to have such data processed, you must manually disable the device's internet connection.
In addition, the device and operating data is also processed for the purpose of providing services as part of a supplementary digital service for your device (such as solar.web or similar) as soon as you have registered your device with such a digital service (identification). This data is processed to provide the requested digital services and is therefore necessary for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
Furthermore, this data processing is also carried out for maintenance and support purposes and for handling customer concerns as well as in warranty and guarantee cases (only in individual cases and given connection between device and internet). In this context, the device and operating data may also be passed on to our cooperation partners (third-party providers and suppliers). The processing of this data is necessary for maintenance and support purposes or for processing warranty and guarantee cases and thus for the fulfillment of the contract (Art. 6 (1) (b) GDPR).
Device and operating data are also processed for analysis and diagnostic purposes in order to gain insights into the functionality of the devices and improve them accordingly. This data processing is based on our legitimate interest (Art. 6 (1) (f) GDPR).
We store this data for as long as it is necessary to fulfill the existing contract with you. Any storage beyond this is carried out for legal reasons or if we have a legitimate interest in doing so. For more information on data processing for the solar.web-digital service, as well as our general privacy policy and your rights as a data subject, please visit https://www.fronius.com.
The Fronius Smart Meter is a bidirectional electricity meter for optimizing self-consumption and recording a household's load characteristic curve. Together with a Fronius inverter or Fronius Datamanager 2.0 and a Fronius data interface, the Fronius Smart Meter allows you to view your own power consumption. The meter measures the energy flow to the loads or to the public grid and forwards the information to the Fronius inverter or Fronius Datamanager 2.0 via the Modbus RTU/RS485 interface.
Danger due to non-compliance with the safety instructions
Risk of injury and damage to the device as a result.
Follow all safety instructions.
Switch off the power supply before establishing the mains connection.
Technical data, labels, and safety symbols are located on the Fronius Smart Meter TS. This information must be kept in a legible condition and must not be removed, covered, painted over, or concealed by stickers or labels. It warns against incorrect operation, which may result in serious injury and property damage.
Markings: | |
The equipment complies with all the requisite and relevant standards and directives that form part of the relevant EU directive, and therefore is permitted to display the CE mark. | |
Insulated (protective class II) | |
RCM (Regulatory Compliance Mark) | |
To comply with European Directive 2012/19/EU on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must be returned to your distributor, or you must locate the approved collection and recycling facilities in your area. Ignoring this European Directive may have potentially adverse effects on the environment and your health. | |
RoHS (Restriction of Hazardous Substances) | |
Safety symbols: | |
Risk of serious injury and property damage due to incorrect operation. | |
Dangerous electrical voltage. | |
The Fronius Smart Meter TS is a fixed piece of equipment for public grids of TN/TT systems and records the self-consumption or individual loads in the system. The Fronius Smart Meter TS is required for systems with an installed battery storage system and/or a Fronius Ohmpilot for communication between the individual components. The Smart Meter must be installed indoors on a DIN rail with corresponding back-up fuses, which are selected to suit the cable cross-sections of the copper conductors and the maximum current of the meter. The Fronius Smart Meter TS must only be operated in accordance with the specifications in the enclosed documentation and in accordance with local laws, regulations, provisions, standards, and within the limits of technical possibilities. Any use of the product other than as described under intended use shall be deemed to be not in accordance with intended use. The available documentation forms part of the product and must be read, observed, and kept in good condition. It must also be accessible at all times at the place of installation. The available documents do not replace regional, state, provincial, federal, or national laws, or regulations or standards that apply to the installation, electrical safety, and use of the product. Fronius International GmbH assumes no responsibility for compliance with or non-compliance with these laws or regulations in connection with the installation of the product.
Interventions in the Fronius Smart Meter TS, e.g., modifications and alterations, are not permitted. Unauthorized interventions will void the warranty and warranty claims and, as a rule, void the user's authority to operate the equipment.
Reasonably foreseeable misuse:
The Fronius Smart Meter TS is not suitable for the power supply of life-sustaining medical devices or for billing costs to subtenants.
| (1) | 2x protective cover |
| (2) | Fronius Smart Meter TS 65A-3 |
| (3) | 2x seal wire |
| (4) | 2x connection cover |
| (5) | Quick Start Guide |
The Smart Meter can be installed in the following positions in the system:
Positioning at the feed-in point
Positioning at the consumption point
The Fronius Smart Meter TS can be mounted on a 35 mm DIN rail. The housing comprises 3 modules according to DIN 43880.
The Fronius Smart Meter TS is a hard-wired device and requires a disconnecting device (circuit breaker, switch or disconnector) and overcurrent protection (automatic circuit breaker).
The Fronius Smart Meter TS consumes 10 - 30 mA, the nominal capacity of the disconnecting devices and the overcurrent protection is determined by the wire thickness, the mains voltage, and the required breaking capacity.
IMPORTANT!
Always switch off the power supply before connecting the mains voltage inputs to the Fronius Smart Meter TS.
Connect each power cable to the terminal board as shown in the diagrams below.
IMPORTANT!
For this connection variant, select the value 3Pn in the configuration menu under System > P3. This prevents incorrect measurements.
Danger from mains voltage.
Switch off the power supply before connecting the mains voltage inputs to the Fronius Smart Meter TS.
Insert the protective covers into the guides and press firmly.
Danger due to electrical voltage from missing or improperly fitted protective covers.
An electric shock can be fatal and/or cause serious damage to property.
Fit the protective covers immediately after installing the live cables.
Fit the protective covers properly and check that they are secure.
Connect the data communication connections of the Fronius Smart Meter TS to the Modbus interface of the Fronius inverter using a network cable (type CAT5 or higher).
Several Smart Meters can be installed in the system, see chapter Multi-meter system - Fronius SnapINverter on page (→).
To avoid interference, the terminating resistor must be used (see chapter Connecting the terminating resistor on page (→)).
Inverter in the system | |
Meter - Fronius Smart Meter TS | |
Modbus RTU, third-party device | |
Terminating resistor |
The terminating resistor is integrated in the Fronius Smart Meter TS and is manufactured with a bridge between the M and T connections (T = termination).
Due to interference, it is recommended that terminating resistors are used as illustrated below to ensure proper functioning.
* The terminating resistor is integrated in the Fronius Smart Meter TS and is manufactured with a bridge between the M and T connections (T = termination).
Insert the connection covers into the guides and press firmly.
IMPORTANT!
When fitting the connection covers, ensure that the cables are not kinked, pinched, crushed, or otherwise damaged.
Grid | |
Fronius Smart Meter | |
Primary meter | |
Secondary meter | |
Loads in the system | |
Additional loads in the system | |
Additional producers in the system | |
A maximum of 4 Modbus stations can be connected to the Modbus connection terminal.
IMPORTANT!
Only one primary meter, one battery and one Ohmpilot can be connected per inverter. Due to the high data transfer of the battery, the battery occupies 2 subscribers.
Example:
Input | Battery | Fronius | Number | Number |
Modbus | 1 | 0 | ||
1 | 1 | |||
1 | 2 | |||
1 | 3 |
If several Fronius Smart Meter TS are installed, a separate address must be set for each (see Setting the address on the Fronius Smart Meter TS on page (→)). The primary meter is always assigned address 1. All the other meters are numbered consecutively with the address range from 2 to 14. Different Fronius Smart Meter power categories can be used in combination.
IMPORTANT!
Max. Use 3 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to chapter Connecting the terminating resistor on page (→).
The inputs M0 and M1 can be freely selected. A maximum of 4 Modbus participants can be connected to the Modbus terminal on the inputs M0 and M1.
IMPORTANT!
Example 1:
Modbus 0 | 0 | 4 | ||
0 | 2 | |||
0 | 1 | |||
Modbus 1 | 1 | 3 |
Example 2:
Modbus 0 | 1 | 3 | ||
Modbus 1 | 0 | 4 | ||
0 | 2 | |||
0 | 1 |
If several Fronius Smart Meter TS are installed, a separate address must be set for each one (see Setting the address on the Fronius Smart Meter TS on page (→)). The primary meter always receives the address 1. All other meters are numbered consecutively in the address range from 2 to 14. Different Fronius Smart Meter power categories can be used together.
IMPORTANT!
Use no more than 7 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to the chapter Connecting the terminating resistor on page (→).
Image | Screen | Description |
00 |
01 |
02 |
03 |
04 |
05 |
06 |
07 |
08 |
09 |
10 |
11 |
12 |
13 |
14 |
15 |
16 |
17 |
18 |
19 |
| * | Displayed when easy connection mode is activated (measurement = A). This value indicates the total energy without considering the direction. |
| ** | Factory setting - displayed when drawn and delivered energy are measured separately (measurement = b). |
Screen | Code | Description | Values |
PASS*** | P1 | Enter the current password | 2633* |
nPASS | P2 | Password change ** | Four digits (0000-9999) |
SYStEM | P3 | Type of system | 3Pn*: three-phase system, 4-core |
MEASurE | P6 | Measurement mode ** | A: easy connection, measures all energy without taking the direction into account. |
InStALL | P7 | Connection check | On: activated |
P int | P8 | Average power calculation interval (minutes) | 1* - 30 |
MOdE | P9 | Display mode ** | Full*: full display |
tArIFF | P10 | Tariff management ** | On: activated |
HoME | P11 | Screen showing measured variables displayed at startup and after 120 seconds of inactivity ** | For full display (Mode = Full): 0 - 20* |
AddrESS*** | P14 | Modbus address | 1* - 247 |
bAUd | P15 | Baud rate (kBit/s) ** | 9.6* / 19.2 / 38.4 / 57.6 / 115.2 |
PArITY | P16 | Parity ** | Even/No* |
STOP bit | P16-2 | Only if parity = No. Stop bit. ** | 1* / 2 |
rESET | P17 | Activation of the reset function for energy tariffs, maximum requested power, and part values of active and reactive energy (the latter are only transmitted via the serial interface) ** | No*: reset function deactivated. |
End | P18 | Returns to the measured variables start screen | None |
| * | Factory settings |
| ** | The settings can be protected by changing the default password (password cannot be reset). |
| *** | Settings that need to be configured. |
Symbol | Name | Event | Function |
Up | 1 x | Scroll one screen forward, increase the value by 1 | |
Down | 1 x | Scroll one screen back, decrease the value by 1 | |
Enter | 2 seconds | Call up settings, confirm value |
IMPORTANT!
The password cannot be reset.
If the measured signal exceeds the permissible limit values of the meter, a corresponding message or symbol appears on the display:
Note: Active and reactive energy measurements are displayed but do not change.
IMPORTANT! Settings under the "Meter" menu item are only to be made by trained and qualified personnel!
The service password must be entered in order to access the "Meter" menu item.
Three-phase or single-phase Fronius Smart Meter TS can be used. In both cases, the selection is made under the "Fronius Smart Meter" item. The Fronius Datamanager automatically identifies the meter type.
A primary meter and several secondary meters can be selected. The primary meter needs to be configured first before a secondary meter can be selected.
Access Point:
LAN:
The Fronius Smart Meter TS is configured as a primary meter.
The "Current general view" menu area displays the power of the PV modules, self-consumption, the energy fed into the grid, and the battery charge (if available).
The Fronius Smart Meter TS is configured as a secondary meter.
IMPORTANT! Settings under the "Device configuration" menu item are only to be made by trained and qualified personnel!
The service password must be entered in order to access the "Device configuration" menu item.
Three-phase or single-phase Fronius Smart Meter TS can be used. In both cases, the selection is made under the "Components" menu area. The meter type is determined automatically.
WiFi:
Ethernet:
Modbus transmission speed: 9600 baud
Parity bit:none
Measuring input | |
Nominal voltage | 208 - 400 V |
Power consumption in the voltage path (max. voltage) | ≤ 10 VA |
Nominal frequency | 50 - 60 Hz |
Nominal current, lb | 5 A |
Maximum current, Imax | 65 A |
Starting current | 20 mA |
Short-time overload | 30 lmax / 0.001 s |
Self-consumption - current path (max. current) | ≤ 1 W |
Power factor | active cosφ 0.5 ind - 0.8 cap, |
Current total harmonic distortion | In acc. with EN 50470 |
Data output | |
RS485 communication | |
Standard | RS485 - 3 conductors |
Transmission | Serial, asynchronous |
Protocol | Compatible with Modbus RTU |
Addresses | 1 - 255 |
Number of bits | 8 |
Stop bit | 1 |
Parity bit | None - odd - even |
Baud rate | 300, 2400, 9600 bit/s |
Response time | ≤ 200 ms |
Insulation (EN IEC 62052-11, EN IEC 62053-21) | |
Installation category | III |
Pollution degree | 2 |
Insulation voltage | 4 kVAC RMS (1min) |
Electromagnetic compatibility | |
Emission test | In acc. with EN IEC 62052-11, EN 50470-3 |
Immunity test | In acc. with EN IEC 62052-11, EN 50470-3 |
Operating conditions | |
Reference temperature | 25 °C (±5 °C) |
Operating range | -25 bis +55 °C |
Temperature limit for storage and transport | -30 to +80 °C |
Mechanical environment | M2 |
Housing | |
Housing | 3 modules according to DIN 43880 |
Sealable housing/terminal cover |
Connection | Screw connection |
Mounting | Can be snapped onto 35 mm DIN rail |
Housing material | Noryl, self-extinguishing |
Degree of protection (EN 60529) | IP51 housing, IP20 connections |
Weight | 240 grams |
Communication LED signals | |
red, flashing | Pulse light according to EN50470-3, EN62052-11, 1000 pulse/kWh (min. frequency 90 ms) |
orange, lights up permanently | Negative total efficiency This check is only carried out if Configuration menu - structure and parameters measurement mode "B" is active. In this case, the device measures drawn and delivered energy. |
Terminals | |
Measuring input | |
Wire | min. 1 mm² / max. 16 mm² |
Recommended torque | max. 2.8 Nm |
Data output | |
Wire | min 0.05 mm² |
Recommended torque | max. 0.4 Nm |
Parity bit:none
Measuring input | |
Data output | |
Stop bit | 1 |
Housing | |
Terminals | |
Measuring input | |
Data output | |
Detailed warranty conditions specific to your country can be found at https://www.fronius.com/en/download-center?searchword=Warranty+conditions .
If there is a warranty for the relevant product, register the product at https://warranty.fronius.com/ and activate or extend the warranty.
