LogoFronius Smart Meter TS 65A-3
  • en
    • Contact
    • Imprint
    • Terms and Conditions
    • Data Privacy Statement
    • Cookie Policy
    • Cookie Policy
    • 013-25052022
    • Safety rules
      • Safety rules
        • Explanation of safety notices
        • General
        • Environmental conditions
        • Qualified personnel
        • Copyright
        • Data protection
    • General information
      • Fronius Smart Meter TS 65A-3
        • Device description
        • Information on the device
        • Intended use
        • Scope of supply
        • Positioning
    • Installation
      • Installation
        • Checklist for installation
        • Installation
        • Protective circuit
        • Cabling
        • Fitting the protective cover for the terminals
        • Connecting the data communication cable to the inverter
        • Terminating resistors - Explanation of symbols
        • Connecting the terminating resistor
        • Mounting the connection cover
        • Multi-meter system - Explanation of symbols
        • Modbus participants - Fronius SnapInverter
        • Multi-meter system - Fronius SnapINverter
        • Modbus participants - Fronius GEN24
        • Multi-meter system - Fronius GEN24 inverter
        • Menu - Measured variables
        • Configuration menu - structure and parameters
        • Setting the address on the Fronius Smart Meter TS
    • Start-up
      • Fronius SnapINverter
        • General
        • Connecting to the Fronius Datamanager
        • Configuring the Fronius Smart Meter TS as the primary meter
        • Configuring the Fronius Smart Meter TS as a secondary meter
      • Fronius GEN24 inverter
        • General
        • Installation using the web browser
    • Technical data
      • Technical data
      • Fronius manufacturer's warranty
    Cabling
    Start-up
    Technical data
    Safety rules
    Safety rules
    DANGER!
    Indicates immediate danger.
    WARNING!
    CAUTION!
    NOTE!
    Safety rules
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    DANGER!
    WARNING!
    CAUTION!
    NOTE!
    General
    The device has been manufactured in line with the state of the art and according to recognized safety standards. If used incorrectly or misused, however, it can cause:
    • Injury or death to the operator or a third party
    • Damage to the device and other material assets belonging to the operating company.
    All personnel involved in commissioning, maintenance, and servicing of the device must:
    • Be suitably qualified
    • Have knowledge of and experience in dealing with electrical installations and
    • Have fully read and precisely followed these Operating Instructions
    The Operating Instructions must always be at hand wherever the device is being used. In addition to the Operating Instructions, attention must also be paid to any generally applicable and local regulations regarding accident prevention and environmental protection.
    All safety and danger notices on the device:
    • Must be kept in a legible state
    • Must not be damaged
    • Must not be removed
    • Must not be covered, pasted or painted over
    The terminals can reach high temperatures.
    Only operate the device when all protection devices are fully functional. If the protection devices are not fully functional, there is a danger of:
    Any safety devices that are not fully functional must be repaired by an authorised specialist before the device is switched on.
    For the location of the safety and danger notices on the device, refer to the section headed "General remarks" in the Operating Instructions for the device.
    Any equipment malfunctions which might impair safety must be remedied before the device is turned on.
    Qualified personnel
    The servicing information contained in these operating instructions is intended only for the use of qualified service engineers. An electric shock can be fatal. Do not carry out any actions other than those described in the documentation. This also applies to qualified personnel.
    All cables and leads must be secured, undamaged, insulated and adequately dimensioned. Loose connections, scorched, damaged or inadequately dimensioned cables and leads must be immediately repaired by authorised personnel.
    Maintenance and repair work must only be carried out by an authorised specialist.
    It is impossible to guarantee that bought-in parts are designed and manufactured to meet the demands made on them, or that they satisfy safety requirements. Use only original spare parts (also applies to standard parts).
    Components that are not in perfect condition must be changed immediately.
    Copyright
    The text and illustrations are all technically correct at the time of printing. We reserve the right to make changes. The contents of the operating instructions shall not provide the basis for any claims whatsoever on the part of the purchaser. If you have any suggestions for improvement, or can point out any mistakes that you have found in the instructions, we will be most grateful for your comments.
    Data protection
    The user is responsible for the safekeeping of any changes made to the factory settings. The manufacturer accepts no liability for any deleted personal settings.
    General information
    Device description
    The Fronius Smart Meter TS is a bidirectional electricity meter which optimises self-consumption and records the household's load curve. In conjunction with the Fronius inverter, Fronius Datamanager and Fronius data interface, the Fronius Smart Meter TS provides a clear overview of a user's own power consumption.
    The meter measures the power flow to the loads or to the grid and forwards the information via the Modbus RTU/RS485 communication to the Fronius inverter and the Fronius Datamanager.
    CAUTION!
    Observe and follow safety instructions!
    Failure to observe the safety instructions will result in damage to personnel and equipment.
    Switch off the power supply before establishing a mains connection.
    Observe the safety instructions.
    Device description
    CAUTION!
    Device description
    CAUTION!
    Technical data, markings and safety symbols are located on the Fronius Smart Meter TS. These must NOT be removed or painted over. They warn against incorrect operation which can lead to serious injury and damage.
    Markings:
    The devices comply with all the requisite and relevant standards and guidelines that form part of the relevant EU Directive, and are therefore permitted to display the CE mark.
    Insulated (protection class II)
    Regulatory Compliance Mark (RCM)
    Complies with all applicable regulatory requirements in Australia and New Zealand regarding safety and electromagnetic compatibility, as well as specific requirements for radio equipment.
    To comply with European Directive 2012/19/EU on Waste Electrical and Electronic Equipment and its implementation as national law, electrical equipment that has reached the end of its life must be collected separately and returned to an approved recycling facility. Any device that you no longer require must be returned to your distributor or disposed of at an approved collection and recycling facility in your area. Ignoring this European Directive may have potentially adverse effects on the environment and your health!
    RoHS (Restriction of Hazardous Substances)
    The limited use of certain hazardous substances in electrical and electronic equipment has been complied with in accordance with EU Directive 2011/65/EU.
    Safety symbols:
    Danger of serious injury and property damage due to incorrect operation.
    Dangerous electrical voltage.
    Intended use
    The Fronius Smart Meter TS is a fixed piece of equipment for public grids of TN/TT systems and records self-consumption and/or individual loads in the system. The Fronius Smart Meter TS is required for systems with a battery storage system and/or a Fronius Ohmpilot installed for communication between the individual components. The installation is carried out on an indoor DIN rail with corresponding back-up fuses, which are adapted to the cable cross-sections of the copper conductors and to the maximum current of the meter. The Fronius Smart Meter TS must only be operated in accordance with the specifications in the enclosed documentation and in accordance with local laws, regulations, provisions, standards and within the limits of technical possibilities. Any use of the product other than as described in the intended use shall be deemed to be not in accordance with the intended purpose. The available documentation forms part of the product and must be read, observed and kept in good condition. It must also be accessible at all times at the place of installation. The available documents do not replace regional, state, provincial or national laws, or regulations or standards that apply to the installation, electrical safety and use of the product. Fronius International GmbH assumes no responsibility for compliance with or non-compliance with these laws or regulations in connection with the installation of the product.
    Interventions on the Fronius Smart Meter TS, e.g. modifications and alterations, are not permitted. Unauthorised interventions will void the warranty and warranty claims and, as a rule, void the user's authority to operate the equipment. The manufacturer shall not be liable for any damage resulting from such use.
    Reasonably foreseeable misuse:
    The Fronius Smart Meter TS is not suitable for the supply of life-sustaining medical devices or for the billing of subtenants.
    Scope of supply
    (1)
    2x protective cover
    (2)
    (3)
    2x seal wire
    (4)
    2x connection cover
    (5)
    Quick Start guide
    Positioning
    The Fronius Smart Meter TS can be installed in the following positions in the system:
    Positioning at the feed-in point:
    Positioning at consumption point:
    For use as a secondary meter to measure individual loads and producers, see chapter Multi-meter system - Fronius SnapINverter on page (→).
    Installation
    Installation
    For installation information, see the following chapters:
    1Switch off the power supply before establishing a mains connection.
    2Mount the Fronius Smart Meter TS (see "Installation" on page (→)).
    3Connect automatic circuit breakers or automatic circuit breakers and disconnectors (see"Protective circuit" on page (→)).
    4Connect the mains cable to the Fronius Smart Meter TS (see "Cabling" on page (→)).
    5Fit the protective cover for the terminals (see "Fitting the protective cover for the terminals" on page (→)).
    6Connect the data communication connections of the Fronius Smart Meter TS to the Fronius system monitoring using a suitable cable (see "Connecting the data communication cable to the inverter" on page (→)).
    7If necessary, set terminating resistors (see "Connecting the terminating resistor" on page (→)).
    8Tug on each wire and plug to make sure that they are securely connected to the terminal blocks.
    9Switch on the power supply to the Fronius Smart Meter TS.
    10Check the firmware version of the Fronius system monitoring. To ensure compatibility between the inverter and the Fronius Smart Meter TS, the software must always be kept up to date. The update can be started via the inverter web page or using Solar.web.
    11If several Fronius Smart Meter TS are installed in the system, set the address (see "Setting the address" under "Setting the address on the Fronius Smart Meter TS" on page (→)).
    12Configure and commission the meter (see Start-up on page (→)).
    Installation
    Installation
    The Fronius Smart Meter TS can be mounted on a 35 mm DIN rail. The housing comprises 3 modules according to DIN 43880.
    Protective circuit
    The Fronius Smart Meter TS is a hard-wired device and requires a disconnecting device (circuit breaker, switch or disconnector) and overcurrent‑protection (automatic‑circuit breaker).
    The Fronius Smart Meter TS consumes 10 - 30 mA, the nominal capacity of the disconnecting devices and the overcurrent‑protection is determined by the wire thickness, the mains voltage and the required breaking capacity.
    • Disconnecting devices must be mounted within sight and as close as possible to the Fronius Smart Meter TS; they must also be easy to use.
    • The disconnecting devices must satisfy the requirements of IEC 60947-1 and IEC 60947-3, as well as all national and local regulations for electrical systems.
    • Use overcurrent‑protection rated for max. 65 A.
    • To monitor more than one mains voltage, use connected‑automatic circuit breakers.
    • The overcurrent‑protection must protect the mains terminals with the designations L1, L2 and L3. In rare cases, the neutral conductor has an overcurrent‑protection, which must interrupt both neutral and non-earthed cables concurrently.
    Cabling
    IMPORTANT!
    Always switch off the power supply before connecting the mains voltage inputs to the Fronius Smart Meter TS.
    Recommended thickness of stranded mains voltage cables for the terminals of the measuring input and measuring output:
    • Wire: 1 - 16 mm²
    • Recommended torque: max. 2.8 Nm
    Recommended thickness of stranded wires for data communication terminals:
    • Wire: min. 0.05 mm²
    • Recommended torque: max. 0.4 Nm
    Connect each voltage cable to the terminal strip as shown in the graphics below.
    3 phases, 4 conductors
    3 phases, 3 conductors
    2 phases, 3 conductors
    WARNING!
    Danger from mains voltage.
    Insert the protective covers into the guides and press firmly.
    WARNING!
    Danger due to electrical voltage from missing or improperly fitted protective covers.
    An electric shock can be fatal and/or cause serious damage to property.
    Fit the protective covers immediately after installing the live cables.
    Fit the protective covers properly and check that they are secure.
    Connect the data communication connections of the Fronius Smart Meter TS to the Modbus interface of the Fronius inverter using a network cable (type CAT5 or higher).
    Several Smart Meters can be installed in the system, see chapter Multi-meter system - Fronius SnapINverter on page (→).
     To avoid interference, the terminating resistor must be used (see chapter Connecting the terminating resistor on page (→)).
    IMPORTANT!
    More information on successful commissioning.
    Note the following information about connecting the data communication cable to the inverter.
    • Use network cables of type CAT5 or higher.
    • Use a mutual twisted cable pair for corresponding data lines (D+/D-, M1+/M1-).
    • If the data lines are close to the mains cabling, use wires or cables that are designed for 300 to 600 V (never less than the operating voltage).
    • Use double-insulated or sheathed data lines when they are close to bare conductors.
    • Use shielded twisted pair cables to avoid faults.
    • Two wires can be installed in each terminal; the wires are twisted first, inserted into the terminal and tightened.
      Note: A loose wire can disable an entire area of the network.
    • The data communication connections of the Fronius Smart Meter TS are electrically isolated from hazardous voltages.
    Inverter in the system
    e. g. Fronius Symo
    Meter - Fronius Smart Meter TS
    Terminating resistor R 120 Ohm is set with a wire jumper between M- and T.
    Modbus RTU slave
    e. g. Fronius Ohmpilot, Fronius Solar Battery, etc.
    R 120 Ohm
    The terminating resistor is integrated in the Fronius Smart Meter TS and is manufactured with a bridge between the M and T connections (T = termination).
    Due to interference, it is recommended that terminating resistors are used as illustrated below to ensure proper functioning.
    * The terminating resistor is integrated in the Fronius Smart Meter TS and is manufactured with a bridge between the M and T connections (T = termination).
    Insert the connection covers into the guides and press firmly.
    IMPORTANT!
    When fitting the connection covers, ensure that the cables are not kinked, pinched, crushed or otherwise damaged.
    Grid
    supplies the loads in the system if insufficient power is being generated by the PV modules or supplied by the battery.
    e. g. Fronius Primo, Fronius Symo, etc.
    Utility meter
    Measures the measurement data relevant for billing amounts of energy (in particular kilowatt hours of energy sourced from the grid and energy fed into the grid). Based on the relevant billing data, the electricity retailer will invoice the energy sourced from the grid and the purchaser of the surplus energy will reimburse the energy fed into the grid.
    Primary meter
    Records the system's load curve and provides measurement data for energy profiling in Fronius Solar.web. The primary meter also controls the dynamic feed-in control.
    Secondary meter
    Records the load curve of individual loads (e.g. washing machine, lamps, TV, heat pump, etc.) in the consumption branch and provides measurement data for energy profiling in Fronius Solar.web.
    Producer meter
    Records the load curve of individual producers (e.g. wind power plant) in the consumption branch and provides measurement data for energy profiling in Fronius Solar.web.
    Modbus RTU slave
    Loads in the system
    e. g. washing machine, lamps, TV, etc.
    Additional loads in the system
    e. g. heat pump
    Additional producers in the system
    e. g. wind power plant
    R 120 Ohm
    A maximum of 4 Modbus participants can be connected to the Modbus terminal.
    IMPORTANT!
    Only one primary meter, one battery and one Ohmpilot can be connected per inverter. Due to the high data transfer of the battery, the battery occupies 2 participants.
    Example:
    Input
    Battery
    Fronius
    Ohmpilot
    Quantity
    Primary meter
    Quantity
    Secondary meter
    Modbus
    0
    If several Fronius Smart Meter TS are installed, a separate address must be set for each (see Setting the address on the Fronius Smart Meter TS on page (→)). The primary meter is always assigned address 1. All the other meters are numbered consecutively with the address range from 2 to 14. Different Fronius Smart Meter power categories can be used in combination.
    IMPORTANT!
    Max. Use 3 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to chapter Connecting the terminating resistor on page (→).
    Location of the primary meter in the consumption branch. *Terminating resistor R 120 Ohm
    Location of the primary meter at the feed-in point. *Terminating resistor R 120 Ohm
    The following must be observed in a multi-meter system:
    • Only assign each Modbus address once.
    • Terminating resistors must be positioned individually for each channel.
    The inputs M0 and M1 can be selected for this purpose. A maximum of 4 Modbus participants can be connected to the Modbus terminal on inputs M0 and M1.
    IMPORTANT!
    Example 1:
    Input
    Battery
    Fronius
    Ohmpilot
    Quantity
    Primary meter
    Quantity
    Secondary meter
    Modbus 0 (M0)
    0
    0
    0
    Modbus 1 (M1)
    Example 2:
    Input
    Battery
    Fronius
    Ohmpilot
    Quantity
    Primary meter
    Quantity
    Secondary meter
    Modbus 0 (M0)
    Modbus 1 (M1)
    0
    0
    0
    IMPORTANT!
    Max. Use 7 secondary meters in the system. To avoid interference, it is recommended to install the terminating resistors according to chapter Connecting the terminating resistor on page (→).
    • Connect the primary meter and the battery to different channels (recommended).
    • The remaining Modbus participants must be distributed equally.
    Screen
    Description
    00
    1. Total active energy drawn*
    2. Total efficiency
    01
    1. Total active energy supplied**
    2. Total efficiency
    02
    2. Average conductor voltage in the system
    03
    2. Average phase voltage in the system
    04
    2. Power factor (L = inductive, C = capacitive)
    05
    2. Frequency
    06
    2. Total reactive power
    07
    1. Total reactive energy supplied**
    08
    1. Total active energy drawn**
    2. Total apparent power
    09
    2. Maximum demanded power (P = Peak demand) that has been reached since the last reset.
    3. Average demanded power (dMd = demand), calculated for the set interval. The value remains unchanged for the entire interval. It is "0" in the first interval after the start.
    10
    • Not used
    11
    • Not used
    12
    1. Active energy drawn*
    13
    1. Apparent power
    14
    1. Reactive energy drawn
    15
    1. Power factor (L = inductive, C = capacitive)
    16
    1. Phase voltage
    17
    1. Conductor voltage
    18
    1. Current
    19
    1. Effective power
    Displayed when easy connection mode is activated (measurement = A). This value indicates the total energy without considering the direction.
    Factory setting - displayed when drawn and delivered energy are measured separately (measurement = b).
    Screen
    Code
    Description
    Values
    PASS***
    P1
    Enter the current password
    2633*
    nPASS
    P2
    Password change **
    Four digits (0000-9999)
    SYStEM
    P3
    Type of system
    3Pn*: three-phase system, 4-core
    3P: three-phase system, 3-core
    2P: two-phase system, 3-core
    MEASurE
    P6
    Measurement mode **
    A: easy connection, measures all energy without taking the direction into account.
    B*: measures imported and exported energy separately.
    InStALL
    P7
    Connection check
    On: activated
    Off*: deactivated
    P int
    P8
    Average power calculation interval (minutes)
    1* - 30
    MOdE
    P9
    Display mode **
    Full*: full display
    Easy: reduced display. The values that are not displayed are still transmitted via the serial interface.
    tArIFF
    P10
    Tariff management **
    On: activated
    Off*: deactivated
    HoME
    P11
    Screen showing measured variables displayed at startup and after 120 seconds of inactivity **
    For full display (Mode = Full): 0 - 20*
    AddrESS***
    P14
    Modbus address
    1* - 247
    bAUd
    P15
    Baud rate (kBit/s) **
    9.6* / 19.2 / 38.4 / 57.6 / 115.2
    PArITY
    P16
    Parity **
    Even/No*
    STOP bit
    P16-2
    Only if parity = No. Stop bit. **
    1* / 2
    rESET
    P17
    Activation of the reset function for energy tariffs, maximum requested power and part values of active and reactive energy (the latter are only transmitted via the serial interface) **
    No*: reset function deactivated.
    Yes: reset function activated.
    End
    P18
    Returns to the measured variables start screen
    None
    Factory settings
    The settings can be protected by changing the default password (password cannot be reset).
    Settings that need to be configured.
    Symbol
    Name
    Event
    Function
    Up
    1 x
    Scroll one screen forward, increase the value by 1
    Down
    1 x
    Scroll one screen back, decrease the value by 1
    Enter
    2 seconds
    Call up settings, confirm value
    1Press and hold "Enter" for 2 seconds.
    2Use "Up" or "Down" to access the P1 screen.
    3Set password "2633" with "Up" and "Down" and confirm each individual value with "Enter".
    4Note down the password.
    IMPORTANT!
    The password cannot be reset.
    1Use "Up" or "Down" to access the P14 screen.
    2Press and hold "Enter" for 2 seconds.
    3Set the address with "Up" and "Down" and confirm each individual value with "Enter".
    4Press "Up" to access screen P18 and press and hold "Enter" for 2 seconds to exit the settings.
    Start-up
    General
    IMPORTANT! Settings under the "Meter" menu item are only to be made by trained and qualified personnel!
    The service password must be entered in order to access the "Meter" menu item.
    Three-phase or single-phase Fronius Smart Meter TS can be used. In both cases, the selection is made under the "Fronius Smart Meter" item. The Fronius Datamanager automatically identifies the meter type.
    A primary meter and several secondary meters can be selected. The primary meter needs to be configured first before a secondary meter can be selected.
    General
    General
    Access point:
    1.
    Navigate to settings (Setup).
    2.
    Navigate to WiFi Access Point.
    3.
    Network and password are displayed.
    4.
    Activate WiFi Access Point.
    1Select the "Setup" menu on the inverter display and enable the "Wi-Fi Access Point".
    2Establish the connection to the inverter in the network settings (the inverter is displayed with the name "Fronius_240.XXXXXX").
    3Password: Enter 12345678 and confirm.
    4In the browser address bar, enter and confirm the IP address http://192.168.250.181 and confirm.
    The Fronius Datamanager start page is displayed.
    LAN:
    1Connect the Fronius Datamanager and computer to a LAN cable.
    2Place the Fronius Datamanager IP switch in the 'A' position.
    3In the browser address bar, enter and confirm the IP address http://169.254.0.180 and confirm.
    1Go to the Fronius Datamanager website.
    -Open the web browser.
    -In the address bar of the browser, enter the IP address (IP address for WLAN: 192.168.250.181, IP address for LAN: 169.254.0.180) or the host and domain name of the Fronius Datamanager and confirm.
    -The Fronius Datamanager website will be displayed.
    2Click the "Settings" button.
    3Log in to the login area with the "service" user and the service password.
    4Call up the "Meter" menu area.
    5Select the primary meter from the drop-down list.
    6Click the "Settings" button.
    7In the pop-up window, set the position of the meter (feed-in point or consumption point). For more information on the position of the Fronius Smart Meter TS, see Positioning on page (→).
    8Click the "Ok" button when the OK status is displayed. If the Timeout status is displayed, try again.
    9Click the    button to save the settings.
    The Fronius Smart Meter TS is configured as a primary meter.
    The "Current general view" menu area displays the power of the PV modules, self-consumption, the energy fed into the grid and the battery charge (if available).
    5Select the secondary meter from the drop-down list.
    6Click the "Add" button.
    7Enter the name of the secondary meter in the "Name" input field.
    8Enter the previously assigned address in the “Modbus address” input field.
    9Add meter description.
    10Click the    button to save the settings.
    The Fronius Smart Meter TS is configured as a secondary meter.
    General
    IMPORTANT! Settings under the "Device configuration" menu item are only to be made by trained and qualified personnel!
    The service password must be entered in order to access the "Device configuration" menu item.
    Three-phase or single-phase Fronius Smart Meter TS can be used. In both cases, the selection is made under the "Components" menu area. The meter type is determined automatically.
    General
    WLAN:
    1Open the access point by touching the sensor once    → Communication LED: flashes blue.
    2Establish the connection to the inverter in the network settings (the inverter is displayed with the name "FRONIUS_PILOT" and the serial number of the device).
    3Password: enter 12345678 and confirm.
    IMPORTANT!
    To enter the password on a Windows 10 operating system, the link "Connect using a security key instead" must first be activated to establish a connection with the password: 12345678.
    4In the browser address bar, enter and confirm the IP address 192.168.250.181. The installation wizard is opened.
    5Follow the installation wizard in the individual sections and complete the installation.
    6Add system components in Solar.web and start up the PV system.
    The network wizard and the product setup can be carried out independently of each other. A network connection is required for the Solar.web installation wizard.
    Ethernet:
    1Establish a connection to the inverter (LAN1) with a network cable (CAT5 STP or higher).
    2Open the access point by touching the sensor once    → Communication LED: flashes blue.
    3In the browser address bar, enter and confirm IP address 169.254.0.180. The installation wizard is opened.
    4Follow the installation wizard in the individual sections and complete the installation.
    5Add system components in Solar.web and start up the PV system.
    1Access the inverter website.
    -In the address bar of the browser, enter the IP address (IP address for WLAN: 192.168.250.181, IP address for LAN: 169.254.0.180) or the host and domain name of the inverter and confirm.
    -The inverter website is displayed.
    2Click the "Device configuration" button.
    3Log in to the login area with the "Technician" user and the technician password.
    4Access the "Components“ menu area.
    5Click the "Add component" button.
    6In the "Position" drop-down list, set the position of the meter (feed-in point or consumption point). For more information on the position of the Fronius Smart Meter TS, see Positioning on page (→).
    7Click the "Add" button.
    8Click the "Save" button to save the settings.
    6In the "Position" drop-down list, select the meter type (producer/load meter).
    7Enter the previously assigned address in the “Modbus address” input field.
    8Enter the name of the meter in the "Name" input field.
    9In the "Category" drop-down list, select the category (producer or load).
    10Click the "Add" button.
    11Click the "Save" button to save the settings.
    Technical data
    Technical data
    Modbus transmission speed: 9600 baud
    Parity bit:none
    Software version:
    • Fronius Datamanager 2.0 (from version 3.16.1 onwards)
    • Fronius Symo Hybrid (from version 1.16.1 onwards)
    Measuring input
    Nominal voltage
    Operating range
    208 - 400 V
    166.4 - 480 V
    Power consumption in the voltage path (max. voltage)
    ≤ 10 VA
    Nominal frequency
    Tolerance
    50 - 60 Hz
    45 - 65 Hz
    Nominal current, lb
    5 A
    Maximum current, Imax
    65 A
    Starting current
    20 mA
    Short-time overload
    (EN IEC 62053-21, EN IEC 62053-23)
    30 lmax / 0.001 s
    Self-consumption - current path (max. current)
    ≤ 1 W
    Power factor
    Operating range
    active cosφ 0.5 ind - 0.8 cap,
    reactive sinφ 0.5 ind - 0.5 cap
    Current distortion factor
    in acc. with EN 50470
    Data output
    RS485 communication
    Electrically isolated from measuring input
    Standard
    RS485 - 3 conductors
    Transmission
    Serial, asynchronous
    Protocol
    Compatible with Modbus RTU
    Addresses
    1 - 255
    Number of bits
    8
    Stop bit
    Parity bit
    None - odd - even
    Baud rate
    300, 2400, 9600 bit/s
    Response time
    ≤ 200 ms
    Insulation (EN IEC 62052-11, EN IEC 62053-21)
    Installation category
    III
    Pollution degree
    Insulation voltage
    4 kVAC RMS (1min)
    Electromagnetic compatibility
    Emission test
    In acc. with EN IEC 62052-11, EN 50470-3
    Immunity test
    Operating conditions
    Reference temperature
    25 °C (±5 °C)
    Operating range
    -25 bis +55 °C
    Temperature limit for storage and transport
    -30 to +80 °C
    Mechanical environment
    Electromechanical environment
    M2
    E2
    Housing
    Housing
    Sealable housing/terminal cover
    Connection
    Screw connection
    Mounting
    Can be snapped onto 35 mm DIN rail
    Housing material
    Noryl, self-extinguishing
    Degree of protection (EN 60529)
    IP51 housing, IP20 connections
    Weight
    240 grams
    Terminals
    Measuring input
    Wire
    min. 1 mm² / max. 16 mm²
    Recommended torque
    max. 2.8 Nm
    Data output
    Wire
    min 0.05 mm²
    Recommended torque
    max. 0.4 Nm
    Technical data
    Parity bit:none
    Software version:
    Measuring input
    Nominal voltage
    Operating range
    208 - 400 V
    166.4 - 480 V
    ≤ 10 VA
    Nominal frequency
    Tolerance
    50 - 60 Hz
    45 - 65 Hz
    Nominal current, lb
    5 A
    65 A
    Starting current
    20 mA
    Short-time overload
    30 lmax / 0.001 s
    ≤ 1 W
    Power factor
    Operating range
    Data output
    RS485 communication
    Standard
    Transmission
    Protocol
    Addresses
    1 - 255
    Number of bits
    8
    Stop bit
    Parity bit
    None - odd - even
    Baud rate
    Response time
    ≤ 200 ms
    III
    Pollution degree
    Insulation voltage
    4 kVAC RMS (1min)
    Emission test
    Immunity test
    25 °C (±5 °C)
    Operating range
    -25 bis +55 °C
    -30 to +80 °C
    M2
    E2
    Housing
    Housing
    Connection
    Screw connection
    Mounting
    Housing material
    Weight
    240 grams
    Terminals
    Measuring input
    Wire
    Recommended torque
    max. 2.8 Nm
    Data output
    Wire
    min 0.05 mm²
    Recommended torque
    max. 0.4 Nm
    Detailed, country-specific warranty terms are available on the internet:
    www.fronius.com/solar/warranty
    To obtain the full warranty period for your newly installed Fronius inverter or storage system, please register at: www.solarweb.com.
